[GRASS-SVN] r67707 - grass/branches/releasebranch_7_0/lib/init
svn_grass at osgeo.org
Sat Jan 30 06:16:54 PST 2016
Author: marisn
Date: 2016-01-30 06:16:54 -0800 (Sat, 30 Jan 2016)
New Revision: 67707
grass/branches/releasebranch_7_0/lib/init/grass.py
Correct use of _() (backport of r67648)
Modified: grass/branches/releasebranch_7_0/lib/init/grass.py
--- grass/branches/releasebranch_7_0/lib/init/grass.py 2016-01-29 21:52:06 UTC (rev 67706)
+++ grass/branches/releasebranch_7_0/lib/init/grass.py 2016-01-30 14:16:54 UTC (rev 67707)
@@ -873,12 +873,13 @@
if not os.path.exists(location):
fatal(_("Path '%s' doesn't exist") % location)
if not os.access(location, os.W_OK):
- error = "Path '%s' not accessible." % location
+ error = _("Path '%s' not accessible.") % location
stat_info = os.stat(location)
mapset_uid = stat_info.st_uid
if mapset_uid != os.getuid():
- error += "You are not the owner of '%s'" % location
- fatal(_(error))
+ # GTC %s is mapset's folder path
+ error = "%s\n%s" % (error, _("You are not the owner of '%s'.") % location)
+ fatal(error)
# Check for concurrent use
lockfile = os.path.join(location, ".gislock")
