[GRASS-SVN] r67708 - in grass-addons/grass7/raster: . r.jpdf
Sat Jan 30 06:55:17 PST 2016
Author: tomhuld
Date: 2016-01-30 06:55:17 -0800 (Sat, 30 Jan 2016)
New Revision: 67708
Added:
   grass-addons/grass7/raster/r.jpdf/
   grass-addons/grass7/raster/r.jpdf/Makefile
   grass-addons/grass7/raster/r.jpdf/main.c
   grass-addons/grass7/raster/r.jpdf/r.jpdf.html
First commit of r.jpdf: a raster module to calculate the joint probability density function of two series of raster maps.
Added: grass-addons/grass7/raster/r.jpdf/Makefile
--- grass-addons/grass7/raster/r.jpdf/Makefile	                        (rev 0)
+++ grass-addons/grass7/raster/r.jpdf/Makefile	2016-01-30 14:55:17 UTC (rev 67708)
@@ -0,0 +1,13 @@
+MODULE_TOPDIR = ../..
+PGM = r.jpdf
+LIBES = $(GPROJLIB) $(RASTERLIB) $(GISLIB) $(MATHLIB) $(PROJLIB)
+DEPENDENCIES = $(GPROJDEP) $(RASTERDEP) $(GISDEP)
+EXTRA_INC = $(PROJINC) $(OCLINCPATH)
+EXTRA_LIBS = $(OCLLIB)
+#needed?  LIBES += $(OCLLIBPATH)  or  EXTRA_LDFLAGS = $(OCLLIBPATH)
+include $(MODULE_TOPDIR)/include/Make/Module.make
+default: cmd
Added: grass-addons/grass7/raster/r.jpdf/main.c
--- grass-addons/grass7/raster/r.jpdf/main.c	                        (rev 0)
+++ grass-addons/grass7/raster/r.jpdf/main.c	2016-01-30 14:55:17 UTC (rev 67708)
@@ -0,0 +1,349 @@
+ * MODULE:	   r.jpdf
+ * AUTHOR(S):	Thomas Huld <thomas.huld at jrc.ec.europa.eu> (original contributor)
+ * PURPOSE:
+ * COPYRIGHT:	(C) 2015 by the GRASS Development Team
+ *			   This program is free software under the GNU General Public
+ *			   License (>=v2). Read the file COPYING that comes with GRASS
+ *			   for details.
+#include <string.h>
+#include <stdlib.h>
+#include <unistd.h>
+#include <math.h>
+#include <grass/gis.h>
+#include <grass/glocale.h>
+#include <grass/stats.h>
+void findBins(double start, double end, int numBins, double val, int *pos)
+    int i;
+    double step;
+    if(val<start)
+            *pos=0;
+    else if(val>end)
+            *pos=numBins+1;
+    else
+            step=(end-start)/numBins;
+            i=1;
+            while(val>start+i*step)
+                    i++;
+            *pos=i;
+int main(int argc, char *argv[])
+	struct GModule *module;
+	struct
+	struct Option *input1, *input2, *output, *bins1, *bins2;
+	} parm;
+	struct
+	/* please, remove before GRASS 7 released */
+	struct Flag *quiet;
+	} flag;
+	char *mapset1, *mapset2;
+	int i,j, l;
+	int numdigits1, numdigits2;
+	int fd1,fd2;
+	int *output_fd;
+	int num_inputs;
+        int offset;
+	int num_outputs;
+	struct History history;
+	double *jpdf;
+	int nrows, ncols,ncells;
+        int *counts;
+	int row, col;
+        int pos1, pos2;
+	int nbins1,nbins2;
+	double startVal1,endVal1,startVal2,endVal2;
+	char output_format[16];
+	char outputName[1024];
+	double **raster1=NULL, **raster2=NULL;
+	DCELL *data1cell, *data2cell;
+        DCELL *cell1 = NULL;
+	G_gisinit(argv[0]);
+	module = G_define_module();
+	module->keywords = _("raster, series");
+	module->description =
+	_("From two series of input raster maps, calculates the joint probability function and outputs the probabilities of occurrence in the specified bins.");
+	parm.output = G_define_standard_option(G_OPT_R_OUTPUT);
+	parm.output->required = YES;
+	parm.output->description = _("Prefix of output raster name, will be followed by bin numbers");
+	parm.output->multiple = NO;
+	parm.output->guisection = _("Output_options");
+	parm.input1 = G_define_option();
+	parm.input1->key = "input1";
+	parm.input1->type = TYPE_STRING;
+	parm.input1->required = YES;
+	parm.input1->description = _("First set of input rasters");
+	parm.input1->multiple = YES;
+	parm.input1->guisection = _("Input_options");
+	parm.input2 = G_define_option();
+	parm.input2->key = "input2";
+	parm.input2->type = TYPE_STRING;
+	parm.input2->required = YES;
+	parm.input2->description = _("Second set of input rasters");
+	parm.input2->multiple = YES;
+	parm.input2->guisection = _("Input_options");
+	parm.bins1 = G_define_option();
+	parm.bins1->key = "bins1";
+	parm.bins1->type = TYPE_STRING;
+	parm.bins1->required = YES;
+	parm.bins1->description = _("Start value, end value, and number of bins for first independent variable (from first set of inputs)");
+	parm.bins1->multiple = YES;
+	parm.bins2 = G_define_option();
+	parm.bins2->key = "bins2";
+	parm.bins2->type = TYPE_STRING;
+	parm.bins2->required = YES;
+	parm.bins2->description = _("Start value, end value, and number of bins for second independent variable (from second set of inputs)");
+	parm.bins2->multiple = YES;
+	flag.quiet = G_define_flag();
+	flag.quiet->key = 'q';
+	flag.quiet->description = _("Run quietly");
+	if (G_parser(argc, argv))
+	exit(EXIT_FAILURE);
+	if (flag.quiet->answer) {
+		putenv("GRASS_VERBOSE=0");
+		G_warning(_("The '-q' flag is superseded and will be removed "
+			"in future. Please use '--quiet' instead."));
+	/* process the input maps */
+	for (i = 0; parm.input1->answers[i]; i++) ;
+	num_inputs = i;
+	/* The number of maps processed is the number in the shortest list */
+	for (i = 0; parm.input2->answers[i]; i++) ;
+	num_inputs = (i<num_inputs)?i:num_inputs;
+	if (num_inputs < 1)
+	G_fatal_error(_("No input raster map(s) specified"));
+        for (i = 0; i < num_inputs; i++) {
+	struct input *p = &inputs[i];
+	p->name = parm.input->answers[i];
+	p->mapset = G_find_cell2(p->name, "");
+	if (!p->mapset)
+		G_fatal_error(_("Raster map <%s> not found"), p->name);
+	else
+		G_message(_("Reading raster map <%s>..."), p->name);
+	p->fd = Rast_open_old(p->name, p->mapset);
+	if (p->fd < 0)
+		G_fatal_error(_("Unable to open raster map <%s> in mapset <%s>"),
+			  p->name, p->mapset);
+	p->buf = Rast_allocate_d_buf();
+	/* process the output maps */
+	if(sscanf(parm.bins1->answers[0],"%lf",&startVal1)!=1)
+		G_fatal_error(_("Could not read starting value of first independent value."));
+	if(sscanf(parm.bins1->answers[1],"%lf",&endVal1)!=1)
+		G_fatal_error(_("Could not read end value of first independent value."));
+	if(sscanf(parm.bins1->answers[2],"%d",&nbins1)!=1)
+		G_fatal_error(_("Could not read number of bins for first independent value."));
+	if(sscanf(parm.bins2->answers[0],"%lf",&startVal2)!=1)
+		G_fatal_error(_("Could not read starting value of second independent value."));
+	if(sscanf(parm.bins2->answers[1],"%lf",&endVal2)!=1)
+		G_fatal_error(_("Could not read end value of second independent value."));
+	if(sscanf(parm.bins2->answers[2],"%d",&nbins2)!=1)
+		G_fatal_error(_("Could not read number of bins for second independent value."));
+	if(nbins1<=0)
+		G_fatal_error(_("Number of bins for first independent must be >0."));
+	if(nbins2<=0)
+		G_fatal_error(_("Number of bins for second independent value must be >0."));
+	numdigits1=(int)(log10(1.0*nbins1))+1;
+	numdigits2=(int)(log10(1.0*nbins2))+1;
+	sprintf(output_format,"%%s_%%0%dd_%%0%dd",numdigits1,numdigits2);
+	num_outputs = (nbins1+2)*(nbins2+2); /* Extra rasters for bins containing values outside the range given by the user */
+	output_fd = G_malloc(num_outputs*sizeof(int));
+	for (i = 0; i < nbins1+2; i++)
+		for (j = 0; j < nbins2+2; j++)
+			sprintf(outputName,output_format,parm.output->answer,i,j);
+			output_fd[i*(nbins2+2)+j]=Rast_open_new(outputName, DCELL_TYPE);
+	nrows = Rast_window_rows();
+	ncols = Rast_window_cols();
+	ncells=nrows*ncols;
+        counts=(int *)G_malloc(nrows*ncols*sizeof(int));
+	memset(counts,0,nrows*ncols*sizeof(int));
+	jpdf = G_malloc((nbins1+2)*(nbins2+2)*nrows*ncols*sizeof(DCELL));
+	memset(jpdf,0,(nbins1+2)*(nbins2+2)*nrows*ncols*sizeof(DCELL));
+	/* process the data */
+	G_verbose_message(_("Percent complete..."));
+        if(raster1==NULL)
+                data1cell = Rast_allocate_d_buf();
+                data2cell = Rast_allocate_d_buf();
+                raster1 = (double **)G_malloc(sizeof(double *) * (nrows));
+                raster2 = (double **)G_malloc(sizeof(double *) * (nrows));
+                for (l = 0; l < nrows; l++) {
+                        raster1[l] = (double *)G_malloc(sizeof(double) * (ncols));
+                        raster2[l] = (double *)G_malloc(sizeof(double) * (ncols));
+                mapset1 = G_find_cell2(parm.input1->answers[i], "");
+                mapset2 = G_find_cell2(parm.input2->answers[i], "");
+                if (!mapset1)
+                                G_fatal_error(_("Raster map <%s> not found"), parm.input1->answers[i]);
+                else if (!mapset2)
+                                G_fatal_error(_("Raster map <%s> not found"), parm.input2->answers[i]);
+                G_message(_("Processing raster map <%s> and <%s>..."), parm.input1->answers[i],parm.input2->answers[i]);
+                fd1 = Rast_open_old(parm.input1->answers[i],"");
+                if (fd1 < 0)
+                                G_fatal_error(_("Unable to open raster map <%s> "),
+                                                parm.input1->answers[i] );
+                fd2 = Rast_open_old(parm.input2->answers[i],"");
+                if (fd2 < 0)
+                                                parm.input2->answers[i]);
+                for (row = 0; row < nrows; row++)
+                                Rast_get_d_row(fd1, data1cell, row);
+                                Rast_get_d_row(fd2, data2cell, row);
+                                for (col = 0; col < ncols; col++)
+                                        raster1[row][col] = (double)data1cell[col];
+                                        raster2[row][col] = (double)data2cell[col];
+                Rast_close(fd1);
+                Rast_close(fd2);
+                    for(col=0;col<ncols;col++)
+                        if(!Rast_is_d_null_value(&(raster1[row][col]))&&!Rast_is_d_null_value(&(raster2[row][col])))
+                            findBins(startVal1, endVal1, nbins1, raster1[row][col], &pos1);
+                        findBins(startVal2, endVal2, nbins2, raster2[row][col], &pos2);
+                        offset=ncells*((nbins2+2)*pos1+pos2);
+                        jpdf[offset+row*ncols+col]++;
+                        counts[row*ncols+col]++;
+	offset=0;
+        for (i = 0; i<(nbins1+2)*(nbins2+2);i++)
+            offset=i*nrows*ncols;
+            for(j=0;j<nrows*ncols;j++)
+                jpdf[offset+j]/=counts[j];
+    cell1 = Rast_allocate_d_buf();
+        offset=0;
+		for (row = 0; row < nrows; row++) {
+			for (col = 0; col < ncols; col++) {
+				cell1[col] = (DCELL) jpdf[offset+row*ncols+col];
+			Rast_put_d_row(output_fd[i*(nbins2+2)+j], cell1);
+			}				/* End loop over rows. */
+                Rast_close(output_fd[i*(nbins2+2)+j]);
+                offset+=ncells;
+	G_short_history(out->name, "raster", &history);
+	G_write_history(out->name, &history);
+	Rast_command_history(&history);
+	exit(EXIT_SUCCESS);
Added: grass-addons/grass7/raster/r.jpdf/r.jpdf.html
--- grass-addons/grass7/raster/r.jpdf/r.jpdf.html	                        (rev 0)
+++ grass-addons/grass7/raster/r.jpdf/r.jpdf.html	2016-01-30 14:55:17 UTC (rev 67708)
@@ -0,0 +1,51 @@
+<h2>DESCRIPTION</h2>
+<em>r.jpdf</em> reads two series of raster maps and calculates for each raster cell the joint probability density function of the two input series. The output is set of raster maps, each containing the probability within a range of values from the first set and a range from the second set. NULL values are ignored when calculating the JPDF.
+<p>
+The number of output raster maps is determined by the number of "bins" specified by the user using the parameters <em>input1</em> and <em>input2</em>. The users gives the range and density of bins with <em> input1=Start1,End1,Nbins1 input2=Start2,End2,Nbins2</em>. In this case the data from the first data set will be assigned to <em>Nbins1</em> intervals between <em>Start1</em> and <em>End1</em> and <em>Nbins2</em> intervals between <em>Start2</em> and <em>End2</em> for the second data set. In addition, <em>r.jpdf</em> will calculate extra bins for values below or above the start and end values given by the user. In total, the output will consist of (<em>Nbins1</em>+2)×(<em>Nbins2</em>+2) raster maps. The naming of the output rasters is <em>Prefix_N1_N2</em> where <em>Prefix</em> is given by the parameter <em>output</em>. <em>N1</em> and <em>N2</em> may contain leading zeros.
+</p>
+<h2>NOTES</h2>
+<h3>Input series of different lengths</h3>
+Rasters from the two series of input data will be compared in the order in which they appear in the two lists. If one list is longer than the other, the trailing raster maps will be ignored.
+<h3>Memory consumption</h3>
+The (<em>Nbins1</em>+2)×(<em>Nbins2</em>+2) raster maps are held in memory until the end of the processing. On the other hand, only one raster from each of the two series of input rasters will be held in memory.
+<h2>EXAMPLES</h2>
+Using <em>r.jpdf</em> with wildcards:
+<br>
+<div class="code"><pre>
+r.series input1="`g.list pattern='temperature*' sep=,`" input2="`g.list pattern='pressure*' sep=,`"\
+         output=jpdf_temp_pres bins1=-20,40,10 bins2=950,1030,10
+</pre></div>
+<p>
+Note the <em>g.list</em> script also supports regular expressions for
+selecting map names.
+<h2>SEE ALSO</h2>
+<em>
+<a href="g.list.html">g.list</a>,
+<a href="g.region.html">g.region</a>,
+<a href="r.quantile.html">r.quantile</a>,
+<a href="r.series.accumulate.html">r.series.accumulate</a>,
+<a href="r.series.interp.html">r.series.interp</a>,
+<a href="r.univar.html">r.univar</a>
+</em>
+<p>
+<a href="http://grasswiki.osgeo.org/wiki/Large_raster_data_processing">Hints for large raster data processing</a>
+<h2>AUTHOR</h2>
+Thomas Huld
+<p><i>Last changed: $Date: 2016-01-07 16:31:30 +0100 (Thu, 7 January 2016) $</i>
