[GRASS-SVN] r68883 - grass/trunk/lib/init
svn_grass at osgeo.org
Thu Jul 7 08:21:01 PDT 2016
Author: neteler
Date: 2016-07-07 08:21:01 -0700 (Thu, 07 Jul 2016)
New Revision: 68883
grass/trunk/lib/init/grass.py
grass.py: fall back to C locale rather than refusing to start at all (see: https://lists.osgeo.org/pipermail/grass-user/2015-April/072331.html)
Modified: grass/trunk/lib/init/grass.py
--- grass/trunk/lib/init/grass.py 2016-07-07 12:10:48 UTC (rev 68882)
+++ grass/trunk/lib/init/grass.py 2016-07-07 15:21:01 UTC (rev 68883)
@@ -1108,10 +1108,12 @@
# If we get here, system locale settings are terribly wrong
# There is no point to continue as GRASS/Python will fail
# in some other unpredictable way.
- print("System locale is not usable. "
+ print("System locale is not usable (LC_ALL variable not defined). "
"It indicates misconfigured environment.")
print("Reported error message: %s" % e)
- sys.exit("Fix system locale settings and then try again.")
+ ## TOO DRASTIC: sys.exit("Fix system locale settings and then try again.")
+ locale.setlocale(locale.LC_ALL, 'C')
+ warning(_("Default locale settings are missing. GRASS running with C locale."))
language, encoding = locale.getdefaultlocale()
if not language:
