[GRASS-SVN] r68900 - grass-addons/grass7/raster/r.exdet
Sat Jul 9 05:00:58 PDT 2016
Author: pvanbosgeo
Date: 2016-07-09 05:00:58 -0700 (Sat, 09 Jul 2016)
New Revision: 68900
   grass-addons/grass7/raster/r.exdet/r.exdet.html
   grass-addons/grass7/raster/r.exdet/r.exdet.py
r.exdet changes to make code more compliant with pep8 guidelines, write metadata to layers
Modified: grass-addons/grass7/raster/r.exdet/r.exdet.html
--- grass-addons/grass7/raster/r.exdet/r.exdet.html	2016-07-09 12:00:49 UTC (rev 68899)
+++ grass-addons/grass7/raster/r.exdet/r.exdet.html	2016-07-09 12:00:58 UTC (rev 68900)
@@ -80,15 +80,10 @@
 <h2>CITATION</h2>
-When using this tool, please use the citation to the original paper describing the method in your publications or other derived products:
+When using this tool, please use the citation to the original paper describing the method in your publications or other derived products.
 <ul><li>Mesgaran, M.B., Cousens, R.D. and Webber, B.L. (2014) Here be dragons: a tool for quantifying novelty due to covariate range and correlation change when projecting species distribution models. Diversity & Distributions, 20: 1147-1159, DOI: 10.1111/ddi.12209.</li></ul>
-<p>If, in addition, you want to cite this addon, you can use:
-<ul><li>van Breugel, P. (2015) r.exdet. http://grasswiki.osgeo.org/wiki/AddOns/GRASS_7</li></ul>
 <h2>REFERENCES</h2>
 [1] Mesgaran, M.B., Cousens, R.D. and Webber, B.L. (2014) Here be dragons: a tool for quantifying novelty due to covariate range and correlation change when projecting species distribution models. Diversity &  Distributions, 20: 1147-1159, DOI: 10.1111/ddi.12209.
Modified: grass-addons/grass7/raster/r.exdet/r.exdet.py
--- grass-addons/grass7/raster/r.exdet/r.exdet.py	2016-07-09 12:00:49 UTC (rev 68899)
+++ grass-addons/grass7/raster/r.exdet/r.exdet.py	2016-07-09 12:00:58 UTC (rev 68900)
@@ -12,31 +12,23 @@
 #               combinations between covariates (NT2).
 #               Based on Mesgaran et al.2014 [1]
-# COPYRIGHT:    (C) 2015 Paulo van Breugel
-#               http://ecodiv.org
-#               http://pvanb.wordpress.com/
-# NOTE:         Requires Numpy >= 1.8, GRASS >=7.0
+# COPYRIGHT: (C) 1997-2016 by the GRASS Development Team
 #        This program is free software under the GNU General Public
 #        License (>=v2). Read the file COPYING that comes with GRASS
 #        for details.
-# [1] Mesgaran, M.B., Cousens, R.D. & Webber, B.L. (2014) Here be dragons: a
-# tool for quantifying novelty due to covariate range and correlation change
-# when projecting species distribution models. Diversity & Distributions,
-# 20: 1147–1159, DOI: 10.1111/ddi.12209.
 #%module
-#% description: Detection and quantification of novel uni- and multi-variate environments
+#% description: Quantification of novel uni- and multi-variate environments
+#% keyword: similarity
+#% keyword: multivariate
 #% keyword: raster
 #% keyword: modelling
 #%end
-#%option
+#%option G_OPT_R_INPUTS
 #% key: reference
-#% type: string
-#% gisprompt: old,cell,raster
 #% description: Reference environmental raster layers
 #% key_desc: raster
 #% required: yes
@@ -44,10 +36,8 @@
 #% guisection: Input
 #%end
-#%option
 #% key: projection
-#% type: string
 #% description: Projected environmental raster layers
 #% key_desc: raster
 #% required: yes
@@ -56,17 +46,6 @@
 #%end
 #%option
-#% key: output
-#% type: string
-#% gisprompt: new,cell,raster
-#% description: Output layer
-#% key_desc: raster
-#% required: yes
-#% multiple: no
-#% guisection: Output
-#%end
-#%option
 #% key: region
 #% type: string
 #% gisprompt: new,region
@@ -77,6 +56,19 @@
 #%end
+#%rules
+#%exclusive: projection,region
+#%end
+#%option G_OPT_R_BASENAME_OUTPUT
+#% key: output
+#% description: Root name of the output layers
+#% key_desc: raster
+#% required: yes
+#% multiple: no
+#% guisection: Output
+#%end
 #%flag
 #% key: o
 #% description: Most influential covariate (MIC) for NT1
@@ -95,110 +87,77 @@
 #% description: Keep layer mahalanobis distance?
 #%end
-#%flag
-#% key: m
-#% description: Restore mask?
-#%end
-#%flag
-#% key: r
-#% description: Restore region?
-#%end
 # Dependencies
 # Numpy >= 1.8, Scipy, grass >= 7.0
-# Standard
 # import libraries
 import os
 import sys
 import atexit
 import numpy as np
-import grass.script as grass
+import grass.script as gs
 import grass.script.array as garray
 import tempfile
 import uuid
 import string
-if not os.environ.has_key("GISBASE"):
-    grass.message("You must be in GRASS GIS to run this program.")
-    sys.exit(1)
+COLORS_EXDET = """\
+0% 255:0:0
+0 255:200:200
+0.000001 200:255:200
+1.000001 200:200:255
+100% 0:0:255
-# create set to store names of temporary maps to be deleted upon exit
-clean_rast = set()
-def cleanup():
-    for rast in clean_rast:
-        grass.run_command("g.remove", type="rast", name=rast, quiet=True)
 # Functions
+CLEAN_LAY = []
-def tmpname(name):
-    tmpf = name + "_" + str(uuid.uuid4())
-    tmpf = string.replace(tmpf, '-', '_')
-    clean_rast.add(tmpf)
-    return tmpf
-def tmpregion():
-    regionname = tmpname("mahal")
-    k = 0
-    ffile = grass.find_file(regionname, element = 'region',
-                            mapset=grass.gisenv()['MAPSET'])
-    while ffile['fullname'] != '':
-        regionname = regionname + k
-        k = k + 1
-    grass.region(save=regionname)
-    grass.run_command("g.region", save=regionname)
-    return regionname
+def cleanup():
+    """Remove temporary maps specified in the global list"""
+    cleanrast = list(reversed(CLEAN_LAY))
+    for rast in cleanrast:
+        gs.run_command("g.remove", flags="f", type="all",
+                       name=rast, quiet=True)
-def tmpmask():
-    maskname = tmpname("mask")
-    k = 0
-    ffile = grass.find_file(maskname, element = 'cell',
-        maskname = maskname + k
-        k = k + 1
-    return maskname
 def checkmask():
-    ffile = grass.find_file("MASK", element = 'cell',
+    """Check if there is a MASK set"""
+    ffile = gs.find_file("MASK", element="CELL",
+                         mapset=gs.gisenv()['MAPSET'])
     mask_presence = ffile['fullname'] != ''
     return mask_presence
-def icovar(input):
-    tmpcov = tempfile.mkstemp()[1]
-    text_file = open(tmpcov, "w")
-    text_file.write(grass.read_command("r.covar", quiet=True, map=input))
-    text_file.close()
-    covar = np.loadtxt(tmpcov, skiprows=1)
-    VI = np.linalg.inv(covar)
-    os.remove(tmpcov)
-    return VI
+def tmpname(prefix):
+    """Generate a tmp name which contains prefix
+    Store the name in the global list.
+    Use only for raster maps.
+    tmpf = prefix + str(uuid.uuid4())
+    tmpf = string.replace(tmpf, '-', '_')
+    CLEAN_LAY.append(tmpf)
+    return tmpf
 def mahal(v, m, VI):
-    delta = v - m[:,None,None]
-    mahdist = np.sum(np.sum(delta[None,:,:,:] * VI[:,:,None,None],axis=1) * delta, axis=0)
+    """Compute the mahalanobis distance over reference layers"""
+    delta = v - m[:, None, None]
+    mahdist = np.sum(np.sum(delta[None, :, :, :] *
+                     VI[:, :, None, None], axis=1) * delta, axis=0)
     stat_mahal = garray.array()
     stat_mahal[...] = mahdist
     return stat_mahal
-def main():
-    # Variables
+def main(options, flags):
+    gisbase = os.getenv('GISBASE')
+    if not gisbase:
+        gs.fatal(_('$GISBASE not defined'))
+        return 0
+    # Variables
     ref = options['reference']
     ref = ref.split(',')
     pro = options['projection']
@@ -207,26 +166,33 @@
     opn = [x.lower() for x in opn]
     out = options['output']
     region = options['region']
-    flag_r = flags['r']
-    flag_m = flags['m']
     flag_d = flags['d']
     flag_o = flags['o']
-    # flag_p = flags['p'] # not implemented yet
+    #TODO: flag_p = flags['p']
-    if ref == pro and checkmask() == False and region == '':
-        grass.warning("1) reference and projected layers are the same, 2) you \
-        did not define a mask, 3) and you did not define a region to delimit \
-        the region for projection. Was that intentional?")
+    if region:
+        ffile = gs.find_file(region, element="region")
+        if not ffile:
+            gs.fatal(_("the region {} does not exist").format(region))
+    if ref == pro and checkmask() is False and not region:
+        gs.fatal(_("Reference and projected layers are the same, and "
+                   "there are no mask or region defined. This means"
+                   "that there is difference between the  reference and "
+                   "projection areas"))
     if len(ref) != len(pro):
-        grass.fatal("the number of reference and test layers should be the same")
+        gs.fatal(_("be the same. Your provided %d reference and %d"
+                   "projection variables") % (len(ref), len(pro)))
     # Create covariance table
-    VI = icovar(input=ref)
+    tmpcov = tempfile.mkstemp()[1]
+    text_file = open(tmpcov, "w")
+    text_file.write(gs.read_command("r.covar", quiet=True, map=ref))
+    text_file.close()
+    covar = np.loadtxt(tmpcov, skiprows=1)
+    VI = np.linalg.inv(covar)
+    os.remove(tmpcov)
     # Import reference data & compute univar stats per reference layer
     s = len(ref)
     dat_ref = stat_mean = stat_min = stat_max = None
     layer = garray.array()
@@ -245,50 +211,27 @@
         stat_min[i] = np.nanmin(layer)
         stat_mean[i] = np.nanmean(layer)
         stat_max[i] = np.nanmax(layer)
-        dat_ref[i,:,:] = layer
+        dat_ref[i, :, :] = layer
     del layer
-    # Compute mahalanobis over reference layers
-    # Compute mahalanobis over full set of layers
+    # Compute mahalanobis over full set of reference layers
     mahal_ref = mahal(v=dat_ref, m=stat_mean, VI=VI)
     mahal_ref_max = max(mahal_ref[np.isfinite(mahal_ref)])
     del mahal_ref
-    # Compute mahalanobis over projected layers
-    # Remove mask (and optionally backup the MASK)
+    # Remove mask and set new region based on user-defined region or
+    # otherwise based on projection layers
     if checkmask():
-        if flag_m:
-            mask_backup = tmpmask()
-            grass.mapcalc("$mask = MASK", mask=mask_backup, quiet=True)
-        grass.run_command("r.mask", flags="r")
+        gs.run_command("r.mask", flags="r")
+    if region:
+        gs.run_command("g.region", region=region)
+        gs.info(_("The region has set to the region {}").format(region))
+    if options['projection']:
+        gs.run_command("g.region", raster=pro[0])
+        # TODO: only set region to pro[0] when different from current region
+        gs.info(_("The region has set to match the proj raster layers"))
-    # Make backup of region if required
-    if flag_r:
-        region_backup = tmpregion()
-    # Set new region based on user-defined region or otherwise based on
-    # projected layers
-    if region != '':
-        ffile = grass.find_file(region, element = 'region',
-        if ffile != '':
-            grass.run_command("g.region", region=region)
-            grass.info("Region is set to the region. Please note that the function" + region)
-            grass.info("does not check if projected layers fall within this region")
-        else:
-            grass.fatal("the region you selected does not exist")
-    else:
-        grass.run_command("g.region", raster=pro[0])
-    if flag_r:
-        grass.info("The original region was saved as " + region_backup)
-    # Import projected layers
+    # Import projected layers in numpy array
     s = len(pro)
     dat_pro = None
@@ -298,86 +241,61 @@
         r, c = layer.shape
         if dat_pro is None:
             dat_pro = np.empty((s, r, c), dtype=np.double)
-        dat_pro[i,:,:] = layer
+        dat_pro[i, :, :] = layer
     del layer
     # Compute mahalanobis distance
     mahal_pro = mahal(v=dat_pro, m=stat_mean, VI=VI)
     if flag_d:
-        mapname = out + "_mahalanobis"
+        mapname = "{}_mahalanobis".format(out)
         mahal_pro.write(mapname=mapname)
-        grass.info("Mahalanobis distance map saved: " + mapname)
+        gs.info(_("Mahalanobis distance map saved: {}").format(mapname))
     # Compute NT2
     nt2map = garray.array()
     nt2map[...] = mahal_pro / mahal_ref_max
-    nt2 = out + "_NT2"
-    clean_rast.add(nt2)
+    nt2 = "{}__NT2".format(out)
+    CLEAN_LAY.append(nt2)
     nt2map.write(mapname=nt2)
     # Compute NT1
     tmplay = tmpname(out)
     mnames = [None] * len(ref)
     for i in xrange(len(ref)):
-        tmpout = out + "_" + opn[i]
-        clean_rast.add(tmpout)
-        grass.mapcalc("$Dij = min(($prolay - $refmin), ($refmax - $prolay), 0) / ($refmax - $refmin)",
-                      Dij=tmpout,
-                      prolay=pro[i],
-                      refmin=stat_min[i],
-                      refmax=stat_max[i],
-                      quiet=True)
+        tmpout = "{}_{}".format(out, opn[i])
+        CLEAN_LAY.append(tmpout)
+        gs.mapcalc("$Dij = min(($prolay - $refmin), ($refmax - $prolay),"
+                   "0) / ($refmax - $refmin)", Dij=tmpout, prolay=pro[i],
+                   refmin=stat_min[i], refmax=stat_max[i], quiet=True)
         mnames[i] = tmpout
-    nt1 = out + "_NT1"
-    grass.run_command("r.series", quiet=True, input=mnames, output=nt1, method="sum")
+    nt1 = "{}_NT1".format(out)
+    gs.run_command("r.series", quiet=True, input=mnames, output=nt1,
+                   method="sum")
     # Compute exdet novelty map
+    gs.mapcalc("$final = if($nt1<0,$nt1,$nt2)", final=out, nt1=nt1,
+               nt2=nt2, quiet=True, overwrite=True)
-    grass.mapcalc("$final = if($nt1<0,$nt1,$nt2)",
-                      final=out,
-                      nt1=nt1,
-                      nt2=nt2,
-                      quiet=True, overwrite=True)
     # Color table
-    tmpcol = tempfile.mkstemp()
-    text_file = open(tmpcol[1], "w")
-    text_file.write("0% 255:0:0\n")
-    text_file.write("0 255:200:200\n")
-    text_file.write("0.000001 200:255:200\n")
-    text_file.write("1 50:210:150\n")
-    text_file.write("1.000001 200:200:255\n")
-    text_file.write("100% 0:0:255\n")
-    text_file.close()
-    grass.run_command("r.colors", quiet=True, map=out, rules=tmpcol[1])
-    os.remove(tmpcol[1])
+    gs.write_command("r.colors", map=out, rules='-', stdin=COLORS_MES,
+                     quiet=True)
     # Compute  most influential covariate (MIC) metric for NT1
     if flag_o:
-        mod = out + "_MIC1"
-        grass.run_command("r.series", quiet=True, output=mod, input=mnames, method="min_raster")
+        mod = "{}_MIC1".format(out)
+        gs.run_command("r.series", quiet=True, output=mod, input=mnames,
+                       method="min_raster")
         tmpcat = tempfile.mkstemp()
         text_file = open(tmpcat[1], "w")
         for cats in xrange(len(opn)):
-            text_file.write(str(cats) + ":" + opn[cats] + "\n")
+            text_file.write("{}:{}\n".format(cats, opn[cats]))
         text_file.close()
-        grass.run_command("r.category", quiet=True, map=mod, rules=tmpcat[1], separator=":")
+        gs.run_command("r.category", quiet=True, map=mod, rules=tmpcat[1],
+                       separator=":")
         os.remove(tmpcat[1])
     # Compute  most influential covariate (MIC) metric for NT2
-    # Not implemented yet
+    # TODO: Not implemented yet
 #    if flag_p:
 #        laylist = []
@@ -395,10 +313,10 @@
 #        # Combine ICp layers
 #        icpname = out + "_MIC2"
 #        icptemp = tmpname(name="icp")
-#        grass.run_command("r.series", quiet=True, output=icptemp,
+#        gs.run_command("r.series", quiet=True, output=icptemp,
 #                          input=laylist, method="max_raster")
 #        # ICp values apply only to parts where NT2 > 1 and NT1 = 0
-#        grass.mapcalc("$icpname = if($nt1<0,-888,if($nt2>1,$icptemp,-999))",
+#        gs.mapcalc("$icpname = if($nt1<0,-888,if($nt2>1,$icptemp,-999))",
 #                      nt1=nt1, nt2=nt2, icpname=icpname, icptemp=icptemp,
 #                      quiet=True)
 #        # Write categories
@@ -409,34 +327,33 @@
 #        for cats in xrange(len(opn)):
 #           text_file.write(str(cats) + ":" + opn[cats] + "\n")
 #        text_file.close()
-#        grass.run_command("r.category", quiet=True, map=icpname,
+#        gs.run_command("r.category", quiet=True, map=icpname,
 #                          rules=tmpcat[1], separator=":")
 #        os.remove(tmpcat[1])
-#        grass.run_command("g.remove", quiet=True, type="raster", name=icptemp, flags="f")
+#        gs.run_command("g.remove", quiet=True, type="raster", name=icptemp, flags="f")
     ## Clean up
-    grass.run_command("g.remove", type="raster", flags="f",
+    gs.run_command("g.remove", type="raster", flags="f",
                       quiet=True, pattern=tmplay + "*")
-    grass.run_command("g.remove", quiet=True, type="raster",
+    gs.run_command("g.remove", quiet=True, type="raster",
                       name=mnames, flags="f")
     if flag_m:
-        grass.run_command("g.rename", raster=[mask_backup,"MASK"])
-        grass.info("Note, the original mask was restored")
+        gs.run_command("g.rename", raster=[mask_backup,"MASK"])
+        gs.info("Note, the original mask was restored")
-    grass.info("Done....")
+    gs.info("Done....")
     if flag_r:
-        grass.info("Original region is restored")
+        gs.info("Original region is restored")
     else:
-        grass.info("Region is set to match the projected/test layers")
+        gs.info("Region is set to match the projected/test layers")
 if __name__ == "__main__":
-    options, flags = grass.parser()
     atexit.register(cleanup)
-    sys.exit(main())
+    sys.exit(main(*gs.parser()))
