[GRASS-SVN] r68901 - grass-addons/grass7/raster/r.exdet
svn_grass at osgeo.org
Sat Jul 9 05:01:06 PDT 2016
Author: pvanbosgeo
Date: 2016-07-09 05:01:06 -0700 (Sat, 09 Jul 2016)
New Revision: 68901
grass-addons/grass7/raster/r.exdet/r.exdet.html
r.exdet: minor edits
Modified: grass-addons/grass7/raster/r.exdet/r.exdet.html
--- grass-addons/grass7/raster/r.exdet/r.exdet.html 2016-07-09 12:00:58 UTC (rev 68900)
+++ grass-addons/grass7/raster/r.exdet/r.exdet.html 2016-07-09 12:01:06 UTC (rev 68901)
@@ -11,15 +11,15 @@
hitherto not encountered in the area of interest. It is important to
identify such areas and to interpret model results with care.
-<p>The <em>r.exdet</em> function allows you to identify areas with
-novel conditions, following methods developed by Mesgaran et al.
-(2014) [1][2]. This includes areas where conditions fall outside the
-range of values observed in the reference / callibration data set
-(Type 1 novelty) or areas with novel combinations between the
-envirionmental variables (Type 2 novelty). It furthermore compute
-the most dissimilar variable for areas where conditions of at least
-one of the variables fall outside the range of values observed in
-the reference data set.
+<p>The <em>r.exdet</em> function allows you to identify areas with
+novel conditions, following methods developed by Mesgaran et al.
+(2014) [1][2]. This includes areas where conditions fall outside the
+range of values observed in the reference / callibration data set
+(Type 1 novelty) or areas with novel combinations between the
+envirionmental variables (Type 2 novelty). It furthermore compute
+the most influential covariate (MIC; i.e., the most dissimilar
+variable) for areas where conditions of at least one of the variables
+fall outside the range of values observed in the reference data set.
<p>The type 1 (<em>NT1</em>) similarity is similar to how the
multi-environmental similarity messure (MESS) computes novel
