[GRASS-SVN] r68902 - grass-addons/grass7/raster/r.exdet
svn_grass at osgeo.org
Sat Jul 9 05:01:14 PDT 2016
Author: pvanbosgeo
Date: 2016-07-09 05:01:14 -0700 (Sat, 09 Jul 2016)
New Revision: 68902
grass-addons/grass7/raster/r.exdet/r.exdet.py
r.exdet: added, write metadata to layers created, furher cleanup code, added labels to parameters
Modified: grass-addons/grass7/raster/r.exdet/r.exdet.py
--- grass-addons/grass7/raster/r.exdet/r.exdet.py 2016-07-09 12:01:06 UTC (rev 68901)
+++ grass-addons/grass7/raster/r.exdet/r.exdet.py 2016-07-09 12:01:14 UTC (rev 68902)
@@ -12,7 +12,7 @@
# combinations between covariates (NT2).
# Based on Mesgaran et al.2014 [1]
-# COPYRIGHT: (C) 1997-2016 by the GRASS Development Team
+# COPYRIGHT: (C) 2014-2016 by Paulo van Breugel and the GRASS Development Team
# This program is free software under the GNU General Public
# License (>=v2). Read the file COPYING that comes with GRASS
@@ -29,7 +29,8 @@
#%option G_OPT_R_INPUTS
#% key: reference
-#% description: Reference environmental raster layers
+#% label: Reference conditions
+#% description: Reference environmental conditions
#% key_desc: raster
#% required: yes
#% multiple: yes
@@ -38,9 +39,10 @@
#% key: projection
-#% description: Projected environmental raster layers
+#% label: Projected conditions
+#% description: Projected conditions to be compared to reference conditions
#% key_desc: raster
-#% required: yes
+#% required: no
#% multiple: yes
#% guisection: Input
#%end
@@ -49,7 +51,8 @@
#% key: region
#% type: string
#% gisprompt: new,region
-#% description: Region defining the projected area
+#% label: Projection region
+#% description: Region defining the area to be compared to the reference area
#% key_desc: region
#% required: no
#% multiple: no
@@ -62,6 +65,7 @@
#%option G_OPT_R_BASENAME_OUTPUT
#% key: output
+#% label: Suffix name output layers
#% description: Root name of the output layers
#% key_desc: raster
#% required: yes
@@ -87,9 +91,6 @@
#% description: Keep layer mahalanobis distance?
#%end
-# Dependencies
-# Numpy >= 1.8, Scipy, grass >= 7.0
# import libraries
import os
import sys
@@ -123,7 +124,7 @@
def checkmask():
"""Check if there is a MASK set"""
- ffile = gs.find_file("MASK", element="CELL",
+ ffile = gs.find_file(name="MASK", element="cell",
mapset=gs.gisenv()['MAPSET'])
mask_presence = ffile['fullname'] != ''
return mask_presence
@@ -159,10 +160,13 @@
# Variables
ref = options['reference']
- ref = ref.split(',')
+ REF = ref.split(',')
pro = options['projection']
- pro = pro.split(',')
- opn = [z.split('@')[0] for z in pro]
+ if pro:
+ PRO = pro.split(',')
+ else:
+ PRO = REF
+ opn = [z.split('@')[0] for z in PRO]
opn = [x.lower() for x in opn]
out = options['output']
region = options['region']
@@ -174,30 +178,38 @@
ffile = gs.find_file(region, element="region")
if not ffile:
gs.fatal(_("the region {} does not exist").format(region))
- if ref == pro and checkmask() is False and not region:
- gs.fatal(_("Reference and projected layers are the same, and "
- "there are no mask or region defined. This means"
- "that there is difference between the reference and "
- "projection areas"))
- if len(ref) != len(pro):
- gs.fatal(_("be the same. Your provided %d reference and %d"
- "projection variables") % (len(ref), len(pro)))
+ if not pro and not checkmask() and not region:
+ gs.fatal(_("You need to provide projected layers, a region, or "
+ "a mask has to be set"))
+ if pro and len(REF) != len(PRO):
+ gs.fatal(_("The number of reference and projection layers need to "
+ "be the same. Your provided %d reference and %d"
+ "projection variables") % (len(REF), len(PRO)))
+ # Text for history in metadata
+ opt2 = dict((k, v) for k, v in options.iteritems() if v)
+ hist = ' '.join("{!s}={!r}".format(k, v) for (k, v) in opt2.iteritems())
+ hist = "r.exdet {}".format(hist)
+ unused, tmphist = tempfile.mkstemp()
+ text_file = open(tmphist, "w")
+ text_file.write(hist)
+ text_file.close()
# Create covariance table
tmpcov = tempfile.mkstemp()[1]
text_file = open(tmpcov, "w")
- text_file.write(gs.read_command("r.covar", quiet=True, map=ref))
+ text_file.write(gs.read_command("r.covar", quiet=True, map=REF))
text_file.close()
covar = np.loadtxt(tmpcov, skiprows=1)
VI = np.linalg.inv(covar)
os.remove(tmpcov)
# Import reference data & compute univar stats per reference layer
- s = len(ref)
+ s = len(REF)
dat_ref = stat_mean = stat_min = stat_max = None
layer = garray.array()
- for i, map in enumerate(ref):
+ for i, map in enumerate(REF):
layer.read(map, null=np.nan)
r, c = layer.shape
if dat_ref is None:
@@ -226,18 +238,17 @@
if region:
gs.run_command("g.region", region=region)
gs.info(_("The region has set to the region {}").format(region))
- if options['projection']:
- gs.run_command("g.region", raster=pro[0])
- # TODO: only set region to pro[0] when different from current region
+ if pro:
+ gs.run_command("g.region", raster=PRO[0])
+ # TODO: only set region to PRO[0] when different from current region
gs.info(_("The region has set to match the proj raster layers"))
# Import projected layers in numpy array
- s = len(pro)
+ s = len(PRO)
dat_pro = None
- for i, map in enumerate(pro):
+ for i, map in enumerate(PRO):
- s = len(pro)
r, c = layer.shape
if dat_pro is None:
dat_pro = np.empty((s, r, c), dtype=np.double)
@@ -250,39 +261,56 @@
mapname = "{}_mahalanobis".format(out)
mahal_pro.write(mapname=mapname)
gs.info(_("Mahalanobis distance map saved: {}").format(mapname))
+ gs.run_command("r.support", map=mapname,
+ title="Mahalanobis distance map", units="unitless",
+ description="Mahalanobis distance map",
+ loadhistory=tmphist)
# Compute NT2
nt2map = garray.array()
nt2map[...] = mahal_pro / mahal_ref_max
- nt2 = "{}__NT2".format(out)
- CLEAN_LAY.append(nt2)
+ nt2 = "{}_NT2".format(out)
nt2map.write(mapname=nt2)
+ gs.run_command("r.support", map=nt2, units="unitless",
+ title="Type 2 similarity",
+ description="Type 2 similarity (NT2)",
# Compute NT1
tmplay = tmpname(out)
- mnames = [None] * len(ref)
- for i in xrange(len(ref)):
- tmpout = "{}_{}".format(out, opn[i])
- CLEAN_LAY.append(tmpout)
+ mnames = [None] * len(REF)
+ for i in xrange(len(REF)):
+ tmpout = tmpname("exdet")
gs.mapcalc("$Dij = min(($prolay - $refmin), ($refmax - $prolay),"
- "0) / ($refmax - $refmin)", Dij=tmpout, prolay=pro[i],
+ "0) / ($refmax - $refmin)", Dij=tmpout, prolay=PRO[i],
refmin=stat_min[i], refmax=stat_max[i], quiet=True)
mnames[i] = tmpout
nt1 = "{}_NT1".format(out)
gs.run_command("r.series", quiet=True, input=mnames, output=nt1,
method="sum")
+ gs.run_command("r.support", map=nt1, units="unitless",
+ title="Type 1 similarity",
+ description="Type 1 similarity (NT1)",
# Compute exdet novelty map
- gs.mapcalc("$final = if($nt1<0,$nt1,$nt2)", final=out, nt1=nt1,
- nt2=nt2, quiet=True, overwrite=True)
+ novelty = "{}_NT1NT2".format(out)
+ gs.mapcalc("$final = if($nt1<0,$nt1,$nt2)", final=novelty,
+ nt1=nt1, nt2=nt2, quiet=True, overwrite=True)
+ gs.run_command("r.support", map=novelty, units="unitless",
+ title="Type 1 + 2 novelty / similarity",
+ description="Type 1 + 2 similarity (NT1)",
# Color table
- gs.write_command("r.colors", map=out, rules='-', stdin=COLORS_MES,
+ gs.write_command("r.colors", map=novelty, rules='-', stdin=COLORS_EXDET,
quiet=True)
- # Compute most influential covariate (MIC) metric for NT1
+ # Compute most influential covariate (MIC) metric for NT1
+ # TODO: compute MIC for NT2 as well (see email exchange with authors
+ # exdet program about deviating results)
if flag_o:
- mod = "{}_MIC1".format(out)
+ mod = "{}_MICNT1".format(out)
gs.run_command("r.series", quiet=True, output=mod, input=mnames,
method="min_raster")
tmpcat = tempfile.mkstemp()
@@ -293,84 +321,14 @@
gs.run_command("r.category", quiet=True, map=mod, rules=tmpcat[1],
separator=":")
os.remove(tmpcat[1])
+ gs.run_command("r.support", map=mod, units="unitless",
+ title="MIC for NT1",
+ description="Most influential covariate for NT1",
- # Compute most influential covariate (MIC) metric for NT2
- # TODO: Not implemented yet
+ # Finalize
+ gs.info(_("Done...."))
-# if flag_p:
-# laylist = []
-# layer = garray.array()
-# # compute ICp values
-# for i, map in enumerate(pro):
-# VItmp = array(VI)
-# VItmp[:,i] = 0
-# VItmp[i,:] = 0
-# ymap = mahal(v=dat_pro, m=stat_mean, VI=VItmp)
-# icp = (mahal_pro - ymap) / mahal_pro * 100
-# layer[:,:] = icp
-# layer.write(mapname=out + "_icp_" + opn[i])
-# laylist.append(out + "_icp_" + opn[i])
-# # Combine ICp layers
-# icpname = out + "_MIC2"
-# icptemp = tmpname(name="icp")
-# gs.run_command("r.series", quiet=True, output=icptemp,
-# input=laylist, method="max_raster")
-# # ICp values apply only to parts where NT2 > 1 and NT1 = 0
-# gs.mapcalc("$icpname = if($nt1<0,-888,if($nt2>1,$icptemp,-999))",
-# nt1=nt1, nt2=nt2, icpname=icpname, icptemp=icptemp,
-# quiet=True)
-# # Write categories
-# tmpcat = tempfile.mkstemp()
-# text_file = open(tmpcat[1], "w")
-# text_file.write(str(-999) + ":None\n")
-# text_file.write(str(-888) + ":NT1 range\n")
-# for cats in xrange(len(opn)):
-# text_file.write(str(cats) + ":" + opn[cats] + "\n")
-# text_file.close()
-# gs.run_command("r.category", quiet=True, map=icpname,
-# rules=tmpcat[1], separator=":")
-# os.remove(tmpcat[1])
-# gs.run_command("g.remove", quiet=True, type="raster", name=icptemp, flags="f")
- ## Clean up
- gs.run_command("g.remove", type="raster", flags="f",
- quiet=True, pattern=tmplay + "*")
- gs.run_command("g.remove", quiet=True, type="raster",
- name=mnames, flags="f")
- if flag_m:
- gs.run_command("g.rename", raster=[mask_backup,"MASK"])
- gs.info("Note, the original mask was restored")
- gs.info("Done....")
- if flag_r:
- gs.info("Original region is restored")
- else:
- gs.info("Region is set to match the projected/test layers")
if __name__ == "__main__":
atexit.register(cleanup)
sys.exit(main(*gs.parser()))
