[GRASS-SVN] r68949 - in grass/trunk: gui/wxpython/core gui/wxpython/datacatalog gui/wxpython/gui_core lib/python/script
svn_grass at osgeo.org
Tue Jul 12 12:06:29 PDT 2016
Author: annakrat
Date: 2016-07-12 12:06:28 -0700 (Tue, 12 Jul 2016)
New Revision: 68949
grass/trunk/gui/wxpython/core/giface.py
grass/trunk/gui/wxpython/datacatalog/__init__.py
grass/trunk/gui/wxpython/datacatalog/tree.py
grass/trunk/gui/wxpython/gui_core/forms.py
grass/trunk/lib/python/script/core.py
wxGUI/datacatalog: add reprojection when copying
Modified: grass/trunk/gui/wxpython/core/giface.py
--- grass/trunk/gui/wxpython/core/giface.py 2016-07-12 18:53:16 UTC (rev 68948)
+++ grass/trunk/gui/wxpython/core/giface.py 2016-07-12 19:06:28 UTC (rev 68949)
@@ -285,7 +285,7 @@
os.environ["GRASS_MESSAGE_FORMAT"] = orig
def GetLayerList(self):
- raise NotImplementedError()
+ return []
def GetLayerTree(self):
return None
Modified: grass/trunk/gui/wxpython/datacatalog/__init__.py
--- grass/trunk/gui/wxpython/datacatalog/__init__.py 2016-07-12 18:53:16 UTC (rev 68948)
+++ grass/trunk/gui/wxpython/datacatalog/__init__.py 2016-07-12 19:06:28 UTC (rev 68949)
@@ -2,4 +2,5 @@
'catalog',
'frame',
'tree',
+ 'dialogs'
Modified: grass/trunk/gui/wxpython/datacatalog/tree.py
--- grass/trunk/gui/wxpython/datacatalog/tree.py 2016-07-12 18:53:16 UTC (rev 68948)
+++ grass/trunk/gui/wxpython/datacatalog/tree.py 2016-07-12 19:06:28 UTC (rev 68949)
@@ -30,6 +30,7 @@
from core.giface import StandaloneGrassInterface
from core.treemodel import TreeModel, DictNode
from gui_core.treeview import TreeView
+from datacatalog.dialogs import CatalogReprojectionDialog
from grass.pydispatch.signal import Signal
@@ -97,25 +98,11 @@
for node in reversed(nodesToRemove):
model.RemoveNode(node)
-def getEnvironment(gisdbase, location, mapset):
- """Creates environment to be passed in run_command for example.
- Returns tuple with temporary file path and the environment. The user
- of this function is responsile for deleting the file."""
- tmp_gisrc_file = gscript.tempfile()
- with open(tmp_gisrc_file, 'w') as f:
- f.write('MAPSET: {mapset}\n'.format(mapset=mapset))
- f.write('GISDBASE: {g}\n'.format(g=gisdbase))
- f.write('LOCATION_NAME: {l}\n'.format(l=location))
- f.write('GUI: text\n')
- env = os.environ.copy()
- env['GISRC'] = tmp_gisrc_file
- return tmp_gisrc_file, env
def getLocationTree(gisdbase, location, queue, mapsets=None):
"""Creates dictionary with mapsets, elements, layers for given location.
Returns tuple with the dictionary and error (or None)"""
- tmp_gisrc_file, env = getEnvironment(gisdbase, location, 'PERMANENT')
+ tmp_gisrc_file, env = gscript.create_environment(gisdbase, location, 'PERMANENT')
env['GRASS_SKIP_MAPSET_OWNER_CHECK'] = '1'
maps_dict = {}
@@ -176,7 +163,7 @@
:param name: name of the map
:param element: data type ('raster', 'raster_3d', and 'vector')
- :param env environment created by function getEnvironment
+ :param env environment created by function gscript.create_environment
if not mapset:
mapset = gscript.run_command('g.mapset', flags='p', env=env).strip()
@@ -591,7 +578,7 @@
def OnRenameMap(self, event):
"""Rename layer with dialog"""
old_name = self.selected_layer.label
- gisrc, env = getEnvironment(
+ gisrc, env = gscript.create_environment(
gisenv()['GISDBASE'],
self.selected_location.label, mapset=self.selected_mapset.label)
new_name = self._getNewMapName(
@@ -624,7 +611,7 @@
def Rename(self, old, new):
"""Rename layer"""
string = old + ',' + new
self.selected_location.label, self.selected_mapset.label)
label = _("Renaming map <{name}>...").format(name=string)
@@ -652,7 +639,7 @@
GMessage(_("No map selected for copying."), parent=self)
return
if self.selected_location == self.copy_location:
gisenv()['GISDBASE'], self.selected_location.label, mapset=self.selected_mapset.label)
_('New name'),
@@ -725,9 +712,15 @@
message=_("g.copy completed").format(cmd=cmd))
gscript.try_remove(gisrc)
else:
- GError(
- _("Failed to copy map: action is allowed only within the same location."),
- parent=self)
+ if self.copy_type.label == 'raster_3d':
+ GError(_("Reprojection is not implemented for 3D rasters"), parent=self)
+ return
+ gisdbase = gisenv()['GISDBASE']
+ dlg = CatalogReprojectionDialog(self, self._giface, gisdbase, self.copy_location.label,
+ self.copy_mapset.label, self.copy_layer.label,
+ gisdbase, self.selected_location.label, self.selected_mapset.label,
+ etype=self.copy_type.label)
+ dlg.Show()
# expand selected mapset
self.ExpandNode(self.selected_mapset, recursive=True)
@@ -752,7 +745,7 @@
def OnDeleteMap(self, event):
"""Delete layer or mapset"""
if self._confirmDialog(
@@ -894,30 +887,31 @@
dlg.Destroy()
return res
- def _popupMenuLayer(self):
- """Create popup menu for layers"""
- menu = wx.Menu()
- genv = gisenv()
+ def _isCurrent(self, genv):
if self._restricted:
currentMapset = currentLocation = False
if self.selected_location.label == genv['LOCATION_NAME']:
currentLocation = True
if self.selected_mapset.label == genv['MAPSET']:
currentMapset = True
+ return currentLocation, currentMapset
else:
- currentMapset = currentLocation = True
+ return True, True
+ def _popupMenuLayer(self):
+ """Create popup menu for layers"""
+ menu = wx.Menu()
+ genv = gisenv()
+ currentLocation, currentMapset = self._isCurrent(genv)
item = wx.MenuItem(menu, wx.NewId(), _("&Copy"))
menu.AppendItem(item)
self.Bind(wx.EVT_MENU, self.OnCopyMap, item)
- item.Enable(currentLocation)
item = wx.MenuItem(menu, wx.NewId(), _("&Paste"))
self.Bind(wx.EVT_MENU, self.OnPasteMap, item)
- if not(
- currentLocation and self.copy_layer and self.selected_location ==
- self.copy_location):
+ if not(currentLocation and self.copy_layer):
item.Enable(False)
item = wx.MenuItem(menu, wx.NewId(), _("&Delete"))
@@ -944,11 +938,12 @@
"""Create popup menu for mapsets"""
menu = wx.Menu()
genv = gisenv()
- if not (self.copy_layer and self.selected_location == self.copy_location):
item.Enable(False)
item = wx.MenuItem(menu, wx.NewId(), _("&Switch mapset"))
@@ -966,7 +961,9 @@
+ genv = gisenv()
item.Enable(False)
self.PopupMenu(menu)
Modified: grass/trunk/gui/wxpython/gui_core/forms.py
--- grass/trunk/gui/wxpython/gui_core/forms.py 2016-07-12 18:53:16 UTC (rev 68948)
+++ grass/trunk/gui/wxpython/gui_core/forms.py 2016-07-12 19:06:28 UTC (rev 68949)
@@ -2076,6 +2076,9 @@
pLocation = None
pMapset = None
for p in self.task.params:
+ if self.task.blackList['enabled'] and self.task.get_name() in self.task.blackList['items'] and \
+ p.get('name', '') in self.task.blackList['items'][self.task.get_name()]['params']:
+ continue
guidep = p.get('guidependency', '')
if guidep:
Modified: grass/trunk/lib/python/script/core.py
--- grass/trunk/lib/python/script/core.py 2016-07-12 18:53:16 UTC (rev 68948)
+++ grass/trunk/lib/python/script/core.py 2016-07-12 19:06:28 UTC (rev 68949)
@@ -1570,6 +1570,21 @@
return True
+def create_environment(gisdbase, location, mapset):
+ """Creates environment to be passed in run_command for example.
+ Returns tuple with temporary file path and the environment. The user
+ of this function is responsile for deleting the file."""
+ tmp_gisrc_file = tempfile()
+ with open(tmp_gisrc_file, 'w') as f:
+ f.write('MAPSET: {mapset}\n'.format(mapset=mapset))
+ f.write('GISDBASE: {g}\n'.format(g=gisdbase))
+ f.write('LOCATION_NAME: {l}\n'.format(l=location))
+ f.write('GUI: text\n')
+ env = os.environ.copy()
+ env['GISRC'] = tmp_gisrc_file
+ return tmp_gisrc_file, env
if __name__ == '__main__':
import doctest
doctest.testmod()
