[GRASS-SVN] r68950 - grass/trunk/display/d.northarrow
svn_grass at osgeo.org
Tue Jul 12 12:28:12 PDT 2016
Author: annakrat
Date: 2016-07-12 12:28:12 -0700 (Tue, 12 Jul 2016)
New Revision: 68950
grass/trunk/display/d.northarrow/draw_n_arrow.c
grass/trunk/display/d.northarrow/main.c
grass/trunk/display/d.northarrow/options.h
d.northarrow: enable transparent fill color, see #3044
Modified: grass/trunk/display/d.northarrow/draw_n_arrow.c
--- grass/trunk/display/d.northarrow/draw_n_arrow.c 2016-07-12 19:06:28 UTC (rev 68949)
+++ grass/trunk/display/d.northarrow/draw_n_arrow.c 2016-07-12 19:28:12 UTC (rev 68950)
@@ -46,7 +46,7 @@
if (rot_with_text)
D_text_rotation(rotation * 180.0 / M_PI);
D_get_text_box(lbl, &tt, &tb, &tl, &tr);
- D_use_color(fg_color);
+ D_use_color(text_color);
/* positions manually tuned */
switch (n_arrow_num[0]) {
@@ -114,24 +114,22 @@
fill_color = G_malloc(sizeof(RGBA_Color));
if (D_color_number_to_RGB(fg_color, &R, &G, &B) == 0)
- /* fall back to black on failure */
- G_str_to_color(DEFAULT_FG_COLOR, &R, &G, &B);
+ line_color->a = RGBA_COLOR_TRANSPARENT;
+ else
+ line_color->a = RGBA_COLOR_OPAQUE;
line_color->r = (unsigned char)R;
line_color->g = (unsigned char)G;
line_color->b = (unsigned char)B;
- line_color->a = RGBA_COLOR_OPAQUE;
if (D_color_number_to_RGB(bg_color, &R, &G, &B) == 0)
+ fill_color->a = RGBA_COLOR_TRANSPARENT;
+ else
+ fill_color->a = RGBA_COLOR_OPAQUE;
fill_color->r = (unsigned char)R;
fill_color->g = (unsigned char)G;
fill_color->b = (unsigned char)B;
- fill_color->a = RGBA_COLOR_OPAQUE;
- if (n_arrow_num[0] == '2' || n_arrow_num[0] == '9')
- fill_color->a = RGBA_COLOR_TRANSPARENT;
/* sizes manually tuned */
case '1':
Modified: grass/trunk/display/d.northarrow/main.c
--- grass/trunk/display/d.northarrow/main.c 2016-07-12 19:06:28 UTC (rev 68949)
+++ grass/trunk/display/d.northarrow/main.c 2016-07-12 19:28:12 UTC (rev 68950)
@@ -25,14 +25,14 @@
#include <grass/glocale.h>
#include "options.h"
-int fg_color, bg_color;
-int do_background = TRUE;
+int fg_color, bg_color, text_color;
+//int do_background = TRUE;
int main(int argc, char **argv)
struct GModule *module;
struct Option *bg_color_opt, *fg_color_opt, *coords, *n_arrow, *fsize,
- *width_opt, *rotation_opt, *lbl_opt;
+ *width_opt, *rotation_opt, *lbl_opt, *text_color_opt;
struct Flag *no_text, *rotate_text, *rads;
double east, north;
double rotation;
@@ -99,16 +99,21 @@
_("Displayed letter on the top of arrow");
lbl_opt->guisection = _("Text");
- fg_color_opt = G_define_standard_option(G_OPT_C);
+ fg_color_opt = G_define_standard_option(G_OPT_CN);
fg_color_opt->label = _("Line color");
fg_color_opt->guisection = _("Colors");
bg_color_opt = G_define_standard_option(G_OPT_CN);
bg_color_opt->key = "fill_color";
bg_color_opt->label = _("Fill color");
- bg_color_opt->answer = _("black");
bg_color_opt->guisection = _("Colors");
+ text_color_opt = G_define_standard_option(G_OPT_C);
+ text_color_opt->key = "text_color";
+ text_color_opt->label = _("Text color");
+ text_color_opt->answer = NULL;
+ text_color_opt->guisection = _("Colors");
width_opt = G_define_option();
width_opt->key = "width";
width_opt->type = TYPE_DOUBLE;
@@ -168,13 +173,22 @@
rotation += 2.0 * M_PI;
/* Parse and select foreground color */
- fg_color = D_parse_color(fg_color_opt->answer, 0);
+ fg_color = D_parse_color(fg_color_opt->answer, 1);
/* Parse and select background color */
bg_color = D_parse_color(bg_color_opt->answer, 1);
- if (bg_color == 0)
- do_background = FALSE;
+ /* Parse and select text color */
+ if (text_color_opt->answer)
+ text_color = D_parse_color(text_color_opt->answer, 0);
+ else if (strcmp(fg_color_opt->answer, "none") != 0)
+ text_color = D_parse_color(fg_color_opt->answer, 1);
+ else if (strcmp(bg_color_opt->answer, "none") != 0)
+ text_color = D_parse_color(bg_color_opt->answer, 1);
+ else
+ text_color = 0;
line_width = atof(width_opt->answer);
if (line_width < 0)
line_width = 0;
Modified: grass/trunk/display/d.northarrow/options.h
--- grass/trunk/display/d.northarrow/options.h 2016-07-12 19:06:28 UTC (rev 68949)
+++ grass/trunk/display/d.northarrow/options.h 2016-07-12 19:28:12 UTC (rev 68950)
@@ -2,7 +2,7 @@
/* globals */
extern int fg_color;
extern int bg_color;
-extern int do_background;
+extern int text_color;
/* draw_n_arrow.c */
int draw_n_arrow(double, double, double, char *, int, double, char *, double);
