[GRASS-SVN] r68957 - grass/trunk/gui/wxpython/datacatalog
svn_grass at osgeo.org
Thu Jul 14 05:39:24 PDT 2016
Author: annakrat
Date: 2016-07-14 05:39:24 -0700 (Thu, 14 Jul 2016)
New Revision: 68957
Added:
grass/trunk/gui/wxpython/datacatalog/dialogs.py
forgot to add new file to svn in r68949
Added: grass/trunk/gui/wxpython/datacatalog/dialogs.py
--- grass/trunk/gui/wxpython/datacatalog/dialogs.py (rev 0)
+++ grass/trunk/gui/wxpython/datacatalog/dialogs.py 2016-07-14 12:39:24 UTC (rev 68957)
@@ -0,0 +1,142 @@
+# -*- coding: utf-8 -*-
+ at package datacatalog.dialogs
+ at brief Dialogs used in data catalog
+Classes:
+ - dialogs::CatalogReprojectionDialog
+(C) 2016 by the GRASS Development Team
+This program is free software under the GNU General Public License
+(>=v2). Read the file COPYING that comes with GRASS for details.
+ at author Anna Petrasova <kratochanna gmail.com>
+import wx
+import grass.script as gscript
+from grass.script import task as gtask
+from gui_core.forms import CmdPanel
+from core.giface import Notification
+class CatalogReprojectionDialog(wx.Dialog):
+ def __init__(self, parent, giface, inputGisdbase, inputLocation, inputMapset, inputLayer,
+ outputGisdbase, outputLocation, outputMapset, etype,
+ id=wx.ID_ANY, title=_("Reprojection"),
+ style=wx.DEFAULT_DIALOG_STYLE | wx.RESIZE_BORDER):
+ self.parent = parent # GMFrame
+ self._giface = giface # used to add layers
+ wx.Dialog.__init__(self, parent, id, title, style=style,
+ name="ReprojectionDialog")
+ self.panel = wx.Panel(parent=self, id=wx.ID_ANY)
+ self.iGisdbase = inputGisdbase
+ self.iLocation = inputLocation
+ self.iMapset = inputMapset
+ self.iLayer = inputLayer
+ self.oGisdbase = outputGisdbase
+ self.oLocation = outputLocation
+ self.oMapset = outputMapset
+ self.etype = etype
+ self._blackList = {
+ 'enabled': True,
+ 'items': {
+ 'r.proj': {
+ 'params': ['location', 'mapset', 'input', 'dbase'],
+ 'flags': ['l']},
+ 'v.proj': {
+ 'flags': ['l']}}}
+ if self.etype == 'raster':
+ grass_task = gtask.parse_interface('r.proj', blackList=self._blackList)
+ elif self.etype == 'vector':
+ grass_task = gtask.parse_interface('v.proj', blackList=self._blackList)
+ self.settingsPanel = CmdPanel(parent=self, giface=self._giface, task=grass_task, frame=None)
+ self.closeOnFinished = wx.CheckBox(self.panel, label=_("Close dialog on finish"))
+ # buttons
+ # cancel
+ self.btn_close = wx.Button(parent=self.panel, id=wx.ID_CLOSE)
+ self.btn_close.Bind(wx.EVT_BUTTON, lambda evt: self.Close())
+ # run
+ self.btn_run = wx.Button(
+ parent=self.panel,
+ id=wx.ID_OK,
+ label=_("Reproject"))
+ self.btn_run.SetToolTipString(_("Reproject raster"))
+ self.btn_run.SetToolTipString(_("Reproject vector"))
+ self.btn_run.SetDefault()
+ self.btn_run.Bind(wx.EVT_BUTTON, self.OnReproject)
+ self.doLayout()
+ def doLayout(self):
+ """Do layout"""
+ dialogSizer = wx.BoxSizer(wx.VERTICAL)
+ dialogSizer.Add(wx.StaticText(self.panel, label=_("The copied layer needs to be reprojected:")),
+ flag=wx.ALL | wx.ALIGN_CENTER_VERTICAL | wx.EXPAND, border=5)
+ dialogSizer.Add(item=self.settingsPanel, proportion=1,
+ flag=wx.ALL | wx.EXPAND, border=5)
+ dialogSizer.Add(item=self.closeOnFinished, flag=wx.ALL | wx.EXPAND, border=5)
+ # buttons
+ btnsizer = wx.BoxSizer(orient=wx.HORIZONTAL)
+ btnsizer.Add(item=self.btn_close, proportion=0,
+ flag=wx.LEFT | wx.RIGHT | wx.ALIGN_CENTER,
+ border=10)
+ btnsizer.Add(item=self.btn_run, proportion=0,
+ flag=wx.RIGHT | wx.ALIGN_CENTER,
+ border=10)
+ dialogSizer.Add(
+ item=btnsizer,
+ proportion=0,
+ flag=wx.ALIGN_CENTER_VERTICAL | wx.ALIGN_RIGHT,
+ border=5)
+ self.panel.SetSizer(dialogSizer)
+ dialogSizer.Fit(self.panel)
+ self.Layout()
+ # sizing not working properly
+ self.SetMinSize(self.GetBestSize())
+ def getSettingsPageCmd(self):
+ return self.settingsPanel.createCmd(
+ ignoreErrors=True, ignoreRequired=True)
+ def OnReproject(self, event):
+ cmd = self.getSettingsPageCmd()
+ cmd.append('dbase=' + self.iGisdbase)
+ cmd.append('location=' + self.iLocation)
+ cmd.append('mapset=' + self.iMapset)
+ cmd.append('input=' + self.iLayer)
+ self.tmpfile, env = gscript.create_environment(self.oGisdbase, self.oLocation, self.oMapset)
+ self._giface.RunCmd(cmd, env=env,
+ onDone=self.OnDone, userData=None,
+ notification=Notification.MAKE_VISIBLE)
+ def OnDone(self, event):
+ gscript.try_remove(self.tmpfile)
+ if self.closeOnFinished.IsChecked() and event.returncode == 0:
+ self.Close()
