[GRASS-SVN] r68958 - grass/trunk/gui/wxpython/mapwin
svn_grass at osgeo.org
Thu Jul 14 06:00:36 PDT 2016
Author: annakrat
Date: 2016-07-14 06:00:36 -0700 (Thu, 14 Jul 2016)
New Revision: 68958
grass/trunk/gui/wxpython/mapwin/decorations.py
wxGUI: fix trimming legend when it's too close to the edge and -d flagis active
Modified: grass/trunk/gui/wxpython/mapwin/decorations.py
--- grass/trunk/gui/wxpython/mapwin/decorations.py 2016-07-14 12:39:24 UTC (rev 68957)
+++ grass/trunk/gui/wxpython/mapwin/decorations.py 2016-07-14 13:00:36 UTC (rev 68958)
@@ -242,8 +242,8 @@
OverlayController.__init__(self, renderer, giface)
self._name = 'legend'
self._removeLabel = _("Remove legend")
- # TODO: synchronize with d.legend?
- self._defaultAt = 'at=5,50,7,10'
+ # default is in the center to avoid trimmed legend on the edge
+ self._defaultAt = 'at=5,50,47,50'
self._cmd = ['d.legend', self._defaultAt]
def GetPlacement(self, screensize):
@@ -256,8 +256,12 @@
for param in self._cmd:
if not param.startswith('at'):
continue
- b, t, l, r = [float(number) for number in param.split(
- '=')[1].split(',')] # pylint: disable-msg=W0612
+ # if the at= is the default, we will move the legend from the center to bottom left
+ if param == self._defaultAt:
+ b, t, l, r = 5, 50, 7, 10
+ else:
+ b, t, l, r = [float(number) for number in param.split(
+ '=')[1].split(',')] # pylint: disable-msg=W0612
x = int((l / 100.) * screensize[0])
y = int((1 - t / 100.) * screensize[1])
