[GRASS-SVN] r68959 - in grass/branches/releasebranch_7_2: raster/r.in.lidar raster3d/r3.in.lidar vector/v.in.lidar
svn_grass at osgeo.org
Thu Jul 14 11:18:24 PDT 2016
Author: wenzeslaus
Date: 2016-07-14 11:18:24 -0700 (Thu, 14 Jul 2016)
New Revision: 68959
grass/branches/releasebranch_7_2/raster/r.in.lidar/info.c
grass/branches/releasebranch_7_2/raster/r.in.lidar/main.c
grass/branches/releasebranch_7_2/raster3d/r3.in.lidar/main.c
grass/branches/releasebranch_7_2/vector/v.in.lidar/main.c
v.in.lidar, r.in.lidar and r3.in.lidar: make validity check an additional filter (backport r68951, see #3038)
Modified: grass/branches/releasebranch_7_2/raster/r.in.lidar/info.c
--- grass/branches/releasebranch_7_2/raster/r.in.lidar/info.c 2016-07-14 13:00:36 UTC (rev 68958)
+++ grass/branches/releasebranch_7_2/raster/r.in.lidar/info.c 2016-07-14 18:18:24 UTC (rev 68959)
@@ -112,9 +112,7 @@
while ((LAS_point = LASReader_GetNextPoint(LAS_reader)) != NULL) {
line++;
- if (!LASPoint_IsValid(LAS_point)) {
- continue;
+ /* we don't do any filtering here */
x = LASPoint_GetX(LAS_point);
y = LASPoint_GetY(LAS_point);
Modified: grass/branches/releasebranch_7_2/raster/r.in.lidar/main.c
--- grass/branches/releasebranch_7_2/raster/r.in.lidar/main.c 2016-07-14 13:00:36 UTC (rev 68958)
+++ grass/branches/releasebranch_7_2/raster/r.in.lidar/main.c 2016-07-14 18:18:24 UTC (rev 68959)
@@ -60,6 +60,7 @@
int pass, npasses;
unsigned long line, line_total;
unsigned int counter;
+ unsigned long n_invalid;
char buff[BUFFSIZE];
double x, y, z;
double intensity;
@@ -87,6 +88,7 @@
struct Flag *intens_flag, *intens_import_flag;
struct Flag *set_region_flag;
struct Flag *base_rast_res_flag;
+ struct Flag *only_valid_flag;
/* LAS */
LASReaderH LAS_reader;
@@ -334,11 +336,24 @@
_("For getting values from base raster, use its actual"
" resolution instead of computational region resolution");
+ only_valid_flag = G_define_flag();
+ only_valid_flag->key = 'v';
+ only_valid_flag->label = _("Use only valid points");
+ only_valid_flag->description =
+ _("Points invalid according to APSRS LAS specification will be"
+ " filtered out");
+ only_valid_flag->guisection = _("Selection");
G_option_exclusive(intens_flag, intens_import_flag, NULL);
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
+ int only_valid = FALSE;
+ n_invalid = 0;
+ if (only_valid_flag->answer)
+ only_valid = TRUE;
/* we could use rules but this gives more info and allows continuing */
if (set_region_flag->answer && !(extents_flag->answer || res_opt->answer)) {
G_warning(_("Flag %c makes sense only with %s option or -%c flag"),
@@ -638,8 +653,13 @@
counter = 0;
+ /* We always count them and report because behavior
+ * changed in between 7.0 and 7.2 from undefined (but skipping
+ * invalid points) to filtering them out only when requested. */
- continue;
+ n_invalid++;
+ if (only_valid)
+ continue;
@@ -767,6 +787,12 @@
if (set_region_flag->answer)
G_put_window(®ion);
+ if (n_invalid && only_valid)
+ G_message(_("%lu input points were invalid and filtered out"),
+ n_invalid);
+ if (n_invalid && !only_valid)
+ G_message(_("%lu input points were invalid, use -%c flag to filter"
+ " them out"), n_invalid, only_valid_flag->key);
if (infiles.num_items > 1) {
sprintf(buff, _("Raster map <%s> created."
" %lu points from %d files found in region."),
Modified: grass/branches/releasebranch_7_2/raster3d/r3.in.lidar/main.c
--- grass/branches/releasebranch_7_2/raster3d/r3.in.lidar/main.c 2016-07-14 13:00:36 UTC (rev 68958)
+++ grass/branches/releasebranch_7_2/raster3d/r3.in.lidar/main.c 2016-07-14 18:18:24 UTC (rev 68959)
@@ -118,6 +118,7 @@
struct Option *filter_opt, *class_opt;
struct Option *base_raster_opt;
G_gisinit(argv[0]);
module = G_define_module();
@@ -205,11 +206,23 @@
base_rast_res_flag->description =
_("Use base raster actual resolution instead of computational region");
+ " filtered out");
G_option_requires(base_rast_res_flag, base_raster_opt, NULL);
exit(EXIT_FAILURE);
LAS_reader = LASReader_Create(input_opt->answer);
@@ -326,11 +339,17 @@
long unsigned in_nulls = 0; /* or outside */
long unsigned n_return_filtered = 0;
long unsigned n_class_filtered = 0;
+ long unsigned n_invalid = 0;
- continue;
+ /* We always count them and report because r.in.lidar behavior
+ if (!LASPoint_IsValid(LAS_point)) {
+ n_invalid++;
+ if (only_valid)
+ continue;
if (use_return_filter) {
int return_n = LASPoint_GetReturnNumber(LAS_point);
int n_returns = LASPoint_GetNumberOfReturns(LAS_point);
@@ -391,10 +410,16 @@
outside + in_nulls);
else
G_message("Number of points outside: %lu", outside);
+ G_message(_("%lu input points were not valid and filtered out"),
+ n_invalid);
if (n_return_filtered)
G_message(_("%lu input points were filtered out by return number"), n_return_filtered);
if (n_class_filtered)
G_message(_("%lu input points were filtered out by class number"), n_class_filtered);
+ G_message(_("%lu input points were not valid, use -%c flag to filter"
Rast3d_close(binning.prop_sum_raster);
Rast3d_close(binning.prop_count_raster);
Modified: grass/branches/releasebranch_7_2/vector/v.in.lidar/main.c
--- grass/branches/releasebranch_7_2/vector/v.in.lidar/main.c 2016-07-14 13:00:36 UTC (rev 68958)
+++ grass/branches/releasebranch_7_2/vector/v.in.lidar/main.c 2016-07-14 18:18:24 UTC (rev 68959)
@@ -85,6 +85,7 @@
struct Flag *nocats_flag;
struct Flag *over_flag, *extend_flag, *no_import_flag;
struct Flag *invert_mask_flag;
char buf[2000];
struct Key_Value *loc_proj_info = NULL, *loc_proj_units = NULL;
struct Key_Value *proj_info, *proj_units;
@@ -285,6 +286,14 @@
invert_mask_flag->description = _("Invert mask when selecting points");
invert_mask_flag->guisection = _("Selection");
+ " filtered out");
extend_flag = G_define_flag();
extend_flag->key = 'e';
extend_flag->description =
@@ -373,6 +382,10 @@
exit(EXIT_SUCCESS);
struct ReturnFilter return_filter_struct;
return_filter_create_from_string(&return_filter_struct, filter_opt->answer);
struct ClassFilter class_filter;
@@ -598,12 +611,16 @@
double x, y, z;
G_percent(feature_count++, n_features, 1); /* show something happens */
- not_valid++;
- continue;
+ not_valid++;
+ if (only_valid)
+ continue;
Vect_reset_line(Points);
Vect_reset_cats(Cats);
@@ -709,10 +726,18 @@
Vect_build(&Map);
Vect_close(&Map);
+#ifdef HAVE_LONG_LONG_INT
+ unsigned long long not_valid_filtered = 0;
+#else
+ unsigned long not_valid_filtered = 0;
+#endif
+ if (only_valid)
+ not_valid_filtered = not_valid;
/* can be easily determined only when iterated over all points */
if (!count_decimation_control.limit_n && !cat_max_reached
&& points_imported != n_features
- - not_valid - n_outside - n_filtered - n_class_filtered
+ - not_valid_filtered - n_outside - n_filtered - n_class_filtered
- n_outside_mask - count_decimation_control.offset_n_counter
- count_decimation_control.n_count_filtered - zrange_filtered)
G_warning(_("The underlying libLAS library is at its limits."
@@ -728,8 +753,8 @@
else {
G_message(_("%llu points imported"), points_imported);
- if (not_valid)
- G_message(_("%llu input points were not valid"), not_valid);
+ if (not_valid && only_valid)
+ G_message(_("%llu input points were not valid and filtered out"), not_valid);
if (n_outside)
G_message(_("%llu input points were outside of the selected area"), n_outside);
if (n_outside_mask)
@@ -753,8 +778,8 @@
count_decimation_control.limit_n);
else
G_message(_("%lu points imported"), points_imported);
- if (not_valid)
- G_message(_("%lu input points were not valid"), not_valid);
+ G_message(_("%lu input points were not valid and filtered out"), not_valid);
if (n_outside)
G_message(_("%lu input points were outside of the selected area"), n_outside);
if (n_outside_mask)
@@ -776,6 +801,16 @@
if (count_decimation_control.limit_n)
G_message(_("The rest of points was ignored"));
+ if (not_valid && !only_valid)
+ G_message(_("%llu input points were not valid, use -%c flag to filter"
+ " them out"), not_valid, only_valid_flag->key);
+#else
+#endif
if (cat_max_reached)
G_warning(_("Maximum number of categories reached (%d). Import ended prematurely."
" Try to import without using category as an ID."), GV_CAT_MAX);
