[GRASS-SVN] r68960 - grass/trunk/display/d.legend
    svn_grass at osgeo.org
    Thu Jul 14 11:39:21 PDT 2016
Author: annakrat
Date: 2016-07-14 11:39:21 -0700 (Thu, 14 Jul 2016)
New Revision: 68960
   grass/trunk/display/d.legend/draw.c
   grass/trunk/display/d.legend/histogram.c
   grass/trunk/display/d.legend/local_proto.h
   grass/trunk/display/d.legend/main.c
fix problems from #3098 (by Adam Laza)
Modified: grass/trunk/display/d.legend/draw.c
--- grass/trunk/display/d.legend/draw.c	2016-07-14 18:18:24 UTC (rev 68959)
+++ grass/trunk/display/d.legend/draw.c	2016-07-14 18:39:21 UTC (rev 68960)
@@ -28,9 +28,8 @@
           double tit_fontsize, const char *title, double *tick_values,
           double t_step, int colorb, int colorbg, struct Option *opt_use,
           struct Option *opt_at, struct Option *opt_fontsize,
-          struct Option *opt_ticks, struct Option *opt_tstep,
-          struct Option *opt_range, struct Flag *histo, struct Flag *hidestr,
-          int log_sc, int draw, int digits)
+          struct Option *opt_tstep, struct Option *opt_range, struct Flag *histo,
+          struct Flag *hidestr, int log_sc, int draw, int digits)
     char buff[512];
     int black, white;
@@ -395,12 +394,10 @@
                 else{
                 if (!fp) {
                     if (!flip)
-                        tcell =
-                            min_ind + k * (double)(1 + max_ind -
-                                                   min_ind) / lleg;
+                        tcell = min_ind + k * (double)(1 + max_ind - min_ind) / lleg;
                     else
-                        D_box_abs(x0, y0 + k, x0 - (dx ? -dx : 1),
-                                  y0 + k + (dy ? -dy : 1));
+                        tcell = (max_ind + 1) - k * (double)(1 + max_ind - min_ind) / lleg;
+                    D_color((CELL) tcell, &colors);
                 else {
                     if (!flip)
@@ -424,8 +421,6 @@
         if (!fp) {              /* cut down labelnum so they don't repeat */
             if (do_cats < steps)
                 steps = do_cats;
-            if ((steps < 2))
-                steps = 2;      /* ward off the ppl floating point exception */
         /* Draw text and ticks */
@@ -586,12 +581,18 @@
             }                   /* for */
+        if (!fp) {
+            dmin = min_ind;
+            dmax = max_ind;
+            sprintf(DispFormat, "%s", "%.0f");
         /* LABEL_VALUE OPTION */
         if (ticksCount > 0) {
             for (i = 0; i < ticksCount; i++) {
                 if ((tick_values[i] < dmin) || (tick_values[i] > dmax)) {
-                    G_fatal_error(_("tick_value=%s out of range [%.3f, %.3f]"),
-                                  opt_ticks->answers[i], dmin, dmax);
+                    G_fatal_error(_("tick_value=%.3f out of range [%.3f, %.3f]"),
+                                  tick_values[i], dmin, dmax);
                 sprintf(buff, DispFormat, tick_values[i]);
@@ -722,7 +723,7 @@
             if (!flip) {
                 if (!horiz)
-                    while (t_start < dmax) {
+                    while (t_start <= dmax) {
                         sprintf(buff, DispFormat, t_start);
                         D_text_size(txsiz, txsiz);
                         D_get_text_box(buff,&bb,&bt, &bl, &br);
@@ -746,7 +747,7 @@
                         t_start += t_step;
                 else
@@ -774,7 +775,7 @@
             else {
                 if (!horiz)
@@ -799,7 +800,7 @@
                         t_start += t_step;
                 else
@@ -964,8 +965,10 @@
                     y0bg = y0 - titsiz - max_hist;
-            D_use_color(colorbg);
-            D_box_abs(x0bg, y0bg, x1bg, y1bg);
+            if (colorbg != 0) {
+                D_use_color(colorbg);
+                D_box_abs(x0bg, y0bg, x1bg, y1bg);
             D_use_color(colorb);
             D_begin();
Modified: grass/trunk/display/d.legend/histogram.c
--- grass/trunk/display/d.legend/histogram.c	2016-07-14 18:18:24 UTC (rev 68959)
+++ grass/trunk/display/d.legend/histogram.c	2016-07-14 18:39:21 UTC (rev 68960)
@@ -232,27 +232,27 @@
                 if (horiz) {
                     if (flip)
-                        D_box_abs(x0 + width + y0_adjust + ((i - 1) * dy),
+                        D_box_abs(x0 + width + y0_adjust + ((i - 2) * dy),
                                   y0 - 1,
-                                  x0 + width + y0_adjust + 1 + (i * dy),
+                                  x0 + width + y0_adjust + 1 + ((i - 1) * dy),
                                   y0 - 1 - dx);
                     else
-                        D_box_abs(x0 + y0_adjust + ((i - 1) * dy),
+                        D_box_abs(x0 + y0_adjust + ((i - 2) * dy),
                                   y0 - 1,
-                                  x0 - 1 + y0_adjust + (i * dy), y0 - 1 - dx);
+                                  x0 - 1 + y0_adjust + ((i - 1) * dy), y0 - 1 - dx);
                 else {          /* vertical */
                     if (flip)
                         /* GRASS_EPSILON fudge around D_box_abs() weirdness + PNG driver */
                         D_box_abs(x0 - 1 - GRASS_EPSILON * 10,
-                                  y0 + height + y0_adjust + ((i - 1) * dy),
+                                  y0 + height + y0_adjust + ((i - 2) * dy),
                                   x0 - 1 - dx,
-                                  y0 + height + y0_adjust + 1 + (i * dy));
+                                  y0 + height + y0_adjust + 1 + ((i - 1) * dy));
                     else
-                                  y0 + y0_adjust + ((i - 1) * dy),
-                                  x0 - 1 - dx, y0 + y0_adjust - 1 + (i * dy));
+                                  y0 + y0_adjust + ((i - 2) * dy),
+                                  x0 - 1 - dx, y0 + y0_adjust - 1 + ((i - 1) * dy));
Modified: grass/trunk/display/d.legend/local_proto.h
--- grass/trunk/display/d.legend/local_proto.h	2016-07-14 18:18:24 UTC (rev 68959)
+++ grass/trunk/display/d.legend/local_proto.h	2016-07-14 18:39:21 UTC (rev 68960)
@@ -42,4 +42,4 @@
           double, int, int, double, double, double *, int, int, int, double,
           double, const char *, double *, double, int, int, struct Option *,
           struct Option *, struct Option *, struct Option *, struct Option *,
-          struct Option *, struct Flag *, struct Flag *, int, int, int);
+          struct Flag *, struct Flag *, int, int, int);
Modified: grass/trunk/display/d.legend/main.c
--- grass/trunk/display/d.legend/main.c	2016-07-14 18:18:24 UTC (rev 68959)
+++ grass/trunk/display/d.legend/main.c	2016-07-14 18:39:21 UTC (rev 68960)
@@ -460,7 +460,7 @@
              cats, colors, X0, X1, Y0, Y1, flip, UserRange, UserRangeMin,
              UserRangeMax, catlist, catlistCount, use_catlist, ticksCount,
              fontsize, tit_fontsize, title, tick_values, t_step, colorb,
-             colorbg, opt_use, opt_at, opt_fontsize, opt_ticks, opt_tstep,
+             colorbg, opt_use, opt_at, opt_fontsize, opt_tstep,
              opt_range, histo, hidestr, log_scale, 0, digits);
     draw(map_name, maptype, color, thin, lines, steps, fp, label_indent,
@@ -468,7 +468,7 @@
          colors, X0, X1, Y0, Y1, flip, UserRange, UserRangeMin, UserRangeMax,
          catlist, catlistCount, use_catlist, ticksCount, fontsize,
          tit_fontsize, title, tick_values, t_step, colorb, colorbg, opt_use,
-         opt_at, opt_fontsize, opt_ticks, opt_tstep, opt_range, histo,
+         opt_at, opt_fontsize, opt_tstep, opt_range, histo,
          hidestr, log_scale, 1, digits);
     D_close_driver();
