[GRASS-SVN] r69019 - grass-addons/grass7/raster/r.quantile.ref
svn_grass at osgeo.org
Thu Jul 21 12:20:29 PDT 2016
Author: mmetz
Date: 2016-07-21 12:20:29 -0700 (Thu, 21 Jul 2016)
New Revision: 69019
Added:
grass-addons/grass7/raster/r.quantile.ref/r.quantile.ref.html
Removed:
grass-addons/grass7/raster/r.quantile.ref/r.series.html
grass-addons/grass7/raster/r.quantile.ref/test_suite/
grass-addons/grass7/raster/r.quantile.ref/Makefile
grass-addons/grass7/raster/r.quantile.ref/main.c
grass7 addons: +r.quantile.ref
Modified: grass-addons/grass7/raster/r.quantile.ref/Makefile
--- grass-addons/grass7/raster/r.quantile.ref/Makefile 2016-07-21 19:17:52 UTC (rev 69018)
+++ grass-addons/grass7/raster/r.quantile.ref/Makefile 2016-07-21 19:20:29 UTC (rev 69019)
@@ -1,9 +1,9 @@
MODULE_TOPDIR = ../..
-PGM = r.series
+PGM = r.quantile.ref
-LIBES = $(STATSLIB) $(RASTERLIB) $(GISLIB)
-DEPENDENCIES = $(STATSDEP) $(RASTERDEP) $(GISDEP)
+LIBES = $(RASTERLIB) $(GISLIB)
+DEPENDENCIES = $(RASTERDEP) $(GISDEP)
include $(MODULE_TOPDIR)/include/Make/Module.make
Modified: grass-addons/grass7/raster/r.quantile.ref/main.c
--- grass-addons/grass7/raster/r.quantile.ref/main.c 2016-07-21 19:17:52 UTC (rev 69018)
+++ grass-addons/grass7/raster/r.quantile.ref/main.c 2016-07-21 19:20:29 UTC (rev 69019)
@@ -1,12 +1,10 @@
- * MODULE: r.series
- * AUTHOR(S): Glynn Clements <glynn gclements.plus.com> (original contributor)
- * Hamish Bowman <hamish_b yahoo.com>, Jachym Cepicky <jachym les-ejk.cz>,
- * Martin Wegmann <wegmann biozentrum.uni-wuerzburg.de>
- * PURPOSE:
- * COPYRIGHT: (C) 2002-2008 by the GRASS Development Team
+ * MODULE: r.quantile.ref
+ * AUTHOR(S): Markus Metz
+ * PURPOSE: Get quantile of the input value from reference maps
+ * COPYRIGHT: (C) 2015 by the GRASS Development Team
* This program is free software under the GNU General Public
* License (>=v2). Read the file COPYING that comes with GRASS
@@ -20,116 +18,103 @@
#include <grass/gis.h>
#include <grass/raster.h>
#include <grass/glocale.h>
-#include <grass/stats.h>
-struct menu
- stat_func *method; /* routine to compute new value */
- stat_func_w *method_w; /* routine to compute new value (weighted) */
- int is_int; /* result is an integer */
- char *name; /* method name */
- char *text; /* menu display - full description */
-} menu[] = {
- {c_ave, w_ave, 0, "average", "average value"},
- {c_count, w_count, 1, "count", "count of non-NULL cells"},
- {c_median, w_median, 0, "median", "median value"},
- {c_mode, w_mode, 0, "mode", "most frequently occurring value"},
- {c_min, NULL, 0, "minimum", "lowest value"},
- {c_minx, NULL, 1, "min_raster", "raster with lowest value"},
- {c_max, NULL, 0, "maximum", "highest value"},
- {c_maxx, NULL, 1, "max_raster", "raster with highest value"},
- {c_stddev, w_stddev, 0, "stddev", "standard deviation"},
- {c_range, NULL, 0, "range", "range of values"},
- {c_sum, w_sum, 0, "sum", "sum of values"},
- {c_var, w_var, 0, "variance", "statistical variance"},
- {c_divr, NULL, 1, "diversity", "number of different values"},
- {c_reg_m, w_reg_m, 0, "slope", "linear regression slope"},
- {c_reg_c, w_reg_c, 0, "offset", "linear regression offset"},
- {c_reg_r2, w_reg_r2, 0, "detcoeff", "linear regression coefficient of determination"},
- {c_reg_t, w_reg_t, 0, "tvalue", "linear regression t-value"},
- {c_quart1, w_quart1, 0, "quart1", "first quartile"},
- {c_quart3, w_quart3, 0, "quart3", "third quartile"},
- {c_perc90, w_perc90, 0, "perc90", "ninetieth percentile"},
- {c_quant, w_quant, 0, "quantile", "arbitrary quantile"},
- {c_skew, w_skew, 0, "skewness", "skewness"},
- {c_kurt, w_kurt, 0, "kurtosis", "kurtosis"},
- {NULL, NULL, 0, NULL, NULL}
struct input
- const char *name;
+ const char *name, *mapset;
int fd;
DCELL *buf;
- DCELL weight;
struct output
const char *name;
int fd;
- DCELL *buf;
- stat_func *method_fn;
- stat_func_w *method_fn_w;
- double quantile;
+ FCELL *buf;
-static char *build_method_list(void)
+static int cmp_dcell(const void *a, const void *b)
- char *buf = G_malloc(1024);
- char *p = buf;
- int i;
+ DCELL da = *(DCELL *) a;
+ DCELL db = *(DCELL *) b;
+ return (da < db ? -1 : (da > db));
- for (i = 0; menu[i].name; i++) {
- char *q;
+/* return the smallest array index where values[idx] <= v
+ * return -1 if v < values[0]
+ * return n if v > values[n - 1] */
+static int bsearch_refidx(DCELL v, DCELL *values, int n)
+ int mid, lo, hi;
- if (i)
- *p++ = ',';
- for (q = menu[i].name; *q; p++, q++)
- *p = *q;
+ /* tests */
+ if (n < 1)
+ return -1;
+ lo = 0;
+ hi = n - 1;
+ if (values[lo] < v && v < values[hi]) {
+ /* bsearch */
+ mid = lo;
+ while (lo < hi) {
+ mid = (lo + hi) / 2;
+ if (values[mid] < v) {
+ lo = mid + 1;
+ else {
+ hi = mid;
+ if (values[mid] > v) {
+ mid--;
+ return mid;
- *p = '\0';
- return buf;
+ if (values[0] > v)
+ return -1;
-static int find_method(const char *method_name)
- int i;
+ if (values[0] == v)
+ return 0;
- if (strcmp(menu[i].name, method_name) == 0)
- return i;
+ if (values[n - 1] == v)
+ return n - 1;
- G_fatal_error(_("Unknown method <%s>"), method_name);
+ if (values[n - 1] < v)
+ return n;
- return -1;
+ return 0;
int main(int argc, char *argv[])
struct GModule *module;
struct
- struct Option *input, *file, *output, *method, *weights, *quantile, *range;
+ struct Option *input, *ref, *file, *output, *range;
} parm;
struct
- struct Flag *nulls, *lazy;
+ struct Flag *lazy;
} flag;
- int i;
+ int i, n, idx;
int num_inputs;
- struct input *inputs = NULL;
- int num_outputs;
- struct output *outputs = NULL;
+ struct input vinput, *refs;
+ struct output out;
struct History history;
- DCELL *values = NULL, *values_tmp = NULL;
- DCELL(*values_w)[2]; /* list of values and weights */
- DCELL(*values_w_tmp)[2]; /* list of values and weights */
- int have_weights;
+ struct Colors colors;
+ DCELL *values;
+ int dcellsize;
int nrows, ncols;
int row, col;
- double lo, hi;
+ DCELL lo, hi;
G_gisinit(argv[0]);
@@ -138,54 +123,29 @@
G_add_keyword(_("aggregation"));
G_add_keyword(_("series"));
module->description =
- _("Makes each output cell value a "
- "function of the values assigned to the corresponding cells "
- "in the input raster map layers.");
+ _("Determines quantile for input value from reference "
+ "raster map layers.");
- parm.input = G_define_standard_option(G_OPT_R_INPUTS);
- parm.input->required = NO;
+ parm.input = G_define_standard_option(G_OPT_R_INPUT);
+ parm.ref = G_define_standard_option(G_OPT_R_INPUTS);
+ parm.ref->key = "reference";
+ parm.ref->description =_("List ofreference raster maps");
+ parm.ref->required = NO;
parm.file = G_define_standard_option(G_OPT_F_INPUT);
parm.file->key = "file";
- parm.file->description = _("Input file with one raster map name and optional one weight per line, field separator between name and weight is |");
+ parm.file->description = _("Input file with one reference raster map name per line");
parm.file->required = NO;
parm.output = G_define_standard_option(G_OPT_R_OUTPUT);
- parm.output->multiple = YES;
- parm.method = G_define_option();
- parm.method->key = "method";
- parm.method->type = TYPE_STRING;
- parm.method->required = YES;
- parm.method->options = build_method_list();
- parm.method->description = _("Aggregate operation");
- parm.method->multiple = YES;
- parm.quantile = G_define_option();
- parm.quantile->key = "quantile";
- parm.quantile->type = TYPE_DOUBLE;
- parm.quantile->required = NO;
- parm.quantile->description = _("Quantile to calculate for method=quantile");
- parm.quantile->options = "0.0-1.0";
- parm.quantile->multiple = YES;
- parm.weights = G_define_option();
- parm.weights->key = "weights";
- parm.weights->type = TYPE_DOUBLE;
- parm.weights->required = NO;
- parm.weights->description = _("Weighting factor for each input map, default value is 1.0 for each input map");
- parm.weights->multiple = YES;
parm.range = G_define_option();
parm.range->key = "range";
parm.range->type = TYPE_DOUBLE;
parm.range->key_desc = "lo,hi";
parm.range->description = _("Ignore values outside this range");
- flag.nulls = G_define_flag();
- flag.nulls->key = 'n';
- flag.nulls->description = _("Propagate NULLs");
flag.lazy = G_define_flag();
flag.lazy->key = 'z';
flag.lazy->description = _("Do not keep files open");
@@ -193,24 +153,22 @@
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
- lo = -1.0 / 0.0; /* -inf */
- hi = 1.0 / 0.0; /* inf */
+ lo = -1.0 / 0.0;
+ hi = 1.0 / 0.0;
if (parm.range->answer) {
lo = atof(parm.range->answers[0]);
hi = atof(parm.range->answers[1]);
- if (parm.input->answer && parm.file->answer)
- G_fatal_error(_("%s= and %s= are mutually exclusive"),
- parm.input->key, parm.file->key);
- if (!parm.input->answer && !parm.file->answer)
- G_fatal_error(_("Please specify %s= or %s="),
- have_weights = 0;
+ /* open input map */
+ vinput.name = parm.input->answer;
+ vinput.mapset = G_find_raster2(vinput.name, "");
+ if (!vinput.mapset)
+ G_fatal_error(_("Raster map <%s> not found"), vinput.name);
+ vinput.fd = Rast_open_old(vinput.name, vinput.mapset);
+ vinput.buf = Rast_allocate_d_buf();
- /* process the input maps from the file */
+ /* process the reference maps */
if (parm.file->answer) {
FILE *in;
int max_inputs;
@@ -225,159 +183,74 @@
num_inputs = 0;
max_inputs = 0;
+ refs = NULL;
for (;;) {
- char buf[GNAME_MAX + 50]; /* Name and weight*/
- char tok_buf[GNAME_MAX + 50];
+ char buf[GNAME_MAX];
char *name;
- int ntokens;
- char **tokens;
struct input *p;
- double weight = 1.0;
if (!G_getl2(buf, sizeof(buf), in))
break;
- strcpy(tok_buf, buf);
- tokens = G_tokenize(tok_buf, "|");
- ntokens = G_number_of_tokens(tokens);
+ name = G_chop(buf);
- name = G_chop(tokens[0]);
- if (ntokens > 1) {
- weight = atof(G_chop(tokens[1]));
- if (weight <= 0)
- G_fatal_error(_("Weights must be positive"));
- if (weight != 1)
- have_weights = 1;
/* Ignore empty lines */
if (!*name)
continue;
if (num_inputs >= max_inputs) {
max_inputs += 100;
- inputs = G_realloc(inputs, max_inputs * sizeof(struct input));
+ refs = G_realloc(refs, max_inputs * sizeof(struct input));
- p = &inputs[num_inputs++];
+ p = &refs[num_inputs++];
p->name = G_store(name);
- p->weight = weight;
- G_verbose_message(_("Reading raster map <%s> using weight %f..."), p->name, p->weight);
+ p->mapset = G_find_raster2(p->name, "");
p->buf = Rast_allocate_d_buf();
if (!flag.lazy->answer)
- p->fd = Rast_open_old(p->name, "");
+ p->fd = Rast_open_old(p->name, p->mapset);
- if (num_inputs < 1)
- G_fatal_error(_("No raster map name found in input file"));
fclose(in);
+ if (num_inputs < 2)
+ G_fatal_error(_("At least two reference raster maps are required"));
else {
- int num_weights;
+ for (i = 0; parm.ref->answers[i]; i++) ;
+ num_inputs = i;
- for (i = 0; parm.input->answers[i]; i++)
- num_inputs = i;
- G_fatal_error(_("Raster map not found"));
+ refs = G_malloc(num_inputs * sizeof(struct input));
- /* count weights */
- num_weights = 0;
- if (parm.weights->answers) {
- for (i = 0; parm.weights->answers[i]; i++)
- num_weights = i;
- if (num_weights && num_weights != num_inputs)
- G_fatal_error(_("input= and weights= must have the same number of values"));
+ /* open reference maps */
+ for (i = 0; i < num_inputs; i++) {
+ struct input *p = &refs[i];
- inputs = G_malloc(num_inputs * sizeof(struct input));
- for (i = 0; i < num_inputs; i++) {
- struct input *p = &inputs[i];
- p->name = parm.input->answers[i];
- p->weight = 1.0;
- if (num_weights) {
- p->weight = (DCELL)atof(parm.weights->answers[i]);
- if (p->weight <= 0)
- if (p->weight != 1)
- have_weights = 1;
- p->buf = Rast_allocate_d_buf();
+ p->name = parm.ref->answers[i];
+ if (!p->mapset)
+ G_fatal_error(_("Raster map <%s> not found"), p->name);
+ p->buf = Rast_allocate_d_buf();
- /* process the output maps */
- for (i = 0; parm.output->answers[i]; i++)
- num_outputs = i;
+ dcellsize = sizeof(DCELL);
- for (i = 0; parm.method->answers[i]; i++)
- if (num_outputs != i)
- G_fatal_error(_("output= and method= must have the same number of values"));
+ /* open output */
+ out.name = parm.output->answer;
+ out.buf = Rast_allocate_f_buf();
+ out.fd = Rast_open_new(out.name, FCELL_TYPE);
+ if (out.fd < 0)
+ G_fatal_error(_("Unable to create raster map <%s>"), out.name);
- outputs = G_calloc(num_outputs, sizeof(struct output));
- for (i = 0; i < num_outputs; i++) {
- struct output *out = &outputs[i];
- const char *output_name = parm.output->answers[i];
- const char *method_name = parm.method->answers[i];
- int method = find_method(method_name);
- out->name = output_name;
- if (have_weights) {
- if (menu[method].method_w) {
- out->method_fn = NULL;
- out->method_fn_w = menu[method].method_w;
- else {
- G_warning(_("Method %s not compatible with weights, using unweighed version instead"),
- method_name);
- out->method_fn = menu[method].method;
- out->method_fn_w = NULL;
- menu[method].is_int = 0;
- else {
- out->quantile = (parm.quantile->answer && parm.quantile->answers[i])
- ? atof(parm.quantile->answers[i])
- : 0;
- out->buf = Rast_allocate_d_buf();
- out->fd = Rast_open_new(output_name,
- menu[method].is_int ? CELL_TYPE : DCELL_TYPE);
/* initialise variables */
values = G_malloc(num_inputs * sizeof(DCELL));
- values_tmp = G_malloc(num_inputs * sizeof(DCELL));
- values_w = NULL;
- values_w_tmp = NULL;
- values_w = (DCELL(*)[2]) G_malloc(num_inputs * 2 * sizeof(DCELL));
- values_w_tmp = (DCELL(*)[2]) G_malloc(num_inputs * 2 * sizeof(DCELL));
nrows = Rast_window_rows();
ncols = Rast_window_cols();
@@ -389,77 +262,114 @@
G_percent(row, nrows, 2);
if (flag.lazy->answer) {
- /* Open the files only on run time */
+ /* Open the raster maps only one at a time */
- inputs[i].fd = Rast_open_old(inputs[i].name, "");
- Rast_get_d_row(inputs[i].fd, inputs[i].buf, row);
- Rast_close(inputs[i].fd);
+ refs[i].fd = Rast_open_old(refs[i].name, refs[i].mapset);
+ Rast_get_d_row(refs[i].fd, refs[i].buf, row);
else {
+ Rast_get_d_row(vinput.fd, vinput.buf, row);
for (col = 0; col < ncols; col++) {
+ DCELL v;
int null = 0;
+ n = 0;
- DCELL v = inputs[i].buf[col];
+ v = refs[i].buf[col];
if (Rast_is_d_null_value(&v))
null = 1;
else if (parm.range->answer && (v < lo || v > hi)) {
- Rast_set_d_null_value(&v, 1);
null = 1;
- values[i] = v;
- values_w[i][0] = v;
- values_w[i][1] = inputs[i].weight;
+ else
+ values[n++] = v;
+ v = vinput.buf[col];
- if (null && flag.nulls->answer)
- Rast_set_d_null_value(&out->buf[col], 1);
+ if (Rast_is_d_null_value(&v) || null)
+ Rast_set_f_null_value(&out.buf[col], 1);
+ else if (n == 0)
+ else if (n == 1) {
+ out.buf[col] = 0.5;
+ if (v < values[0])
+ out.buf[col] = -1;
+ else if (v > values[n - 1])
+ out.buf[col] = 2;
+ else { /* n > 1 */
+ qsort(values, n, dcellsize, cmp_dcell);
+ out.buf[col] = 2;
else {
- if (out->method_fn_w) {
- memcpy(values_w_tmp, values_w, num_inputs * 2 * sizeof(DCELL));
- (*out->method_fn_w)(&out->buf[col], values_w_tmp, num_inputs, &out->quantile);
+ idx = bsearch_refidx(v, values, n);
+ if (v == values[idx]) {
+ int idx1 = idx;
+ while (idx1 < n - 1 && values[idx1 + 1] == v) {
+ idx1++;
+ out.buf[col] = ((FCELL) (idx + idx1)) / (2 * (n - 1));
- else {
- memcpy(values_tmp, values, num_inputs * sizeof(DCELL));
- (*out->method_fn)(&out->buf[col], values_tmp, num_inputs, &out->quantile);
+ else { /* values[idx] < v < values[idx + 1] */
+ double w = v - values[idx];
+ double wtot = values[idx + 1] - values[idx];
+ out.buf[col] = (idx + w / wtot) / (n - 1);
- Rast_put_d_row(outputs[i].fd, outputs[i].buf);
+ Rast_put_f_row(out.fd, out.buf);
- /* close output maps */
+ /* close maps */
+ Rast_close(vinput.fd);
+ Rast_close(refs[i].fd);
- Rast_close(out->fd);
+ Rast_close(out.fd);
- Rast_short_history(out->name, "raster", &history);
- Rast_command_history(&history);
- Rast_write_history(out->name, &history);
+ Rast_short_history(out.name, "raster", &history);
+ Rast_command_history(&history);
+ Rast_write_history(out.name, &history);
- /* Close input maps */
- if (!flag.lazy->answer) {
+ Rast_init_colors(&colors);
+ lo = -1;
+ hi = 0;
+ Rast_add_d_color_rule(&lo, 255, 0, 0, &hi, 255, 0, 0, &colors);
+ lo = 0;
+ hi = 0.3;
+ Rast_add_d_color_rule(&lo, 255, 0, 0, &hi, 220, 220, 0, &colors);
+ lo = 0.3;
+ hi = 0.5;
+ Rast_add_d_color_rule(&lo, 220, 220, 0, &hi, 180, 180, 180, &colors);
+ lo = 0.5;
+ hi = 0.7;
+ Rast_add_d_color_rule(&lo, 180, 180, 180, &hi, 0, 220, 220, &colors);
+ lo = 0.7;
+ hi = 1;
+ Rast_add_d_color_rule(&lo, 0, 220, 220, &hi, 0, 0, 255, &colors);
+ lo = 1;
+ hi = 2;
+ Rast_add_d_color_rule(&lo, 0, 0, 255, &hi, 0, 0, 255, &colors);
+ Rast_write_colors(out.name, G_mapset(), &colors);
exit(EXIT_SUCCESS);
Copied: grass-addons/grass7/raster/r.quantile.ref/r.quantile.ref.html (from rev 69018, grass-addons/grass7/raster/r.quantile.ref/r.series.html)
--- grass-addons/grass7/raster/r.quantile.ref/r.quantile.ref.html (rev 0)
+++ grass-addons/grass7/raster/r.quantile.ref/r.quantile.ref.html 2016-07-21 19:20:29 UTC (rev 69019)
@@ -0,0 +1,67 @@
+<h2>DESCRIPTION</h2>
+<em>r.quantile.ref</em> computes for each pixel the quantile ranking of
+the input value against the reference maps: values of 0, 0.5 and 1.0
+respectively indicate that the input value corresponds with the
+minimum, median or maximum of the reference values. A value of -1 is
+assigned if the input value is smaller than the minimum and a value of 2
+is assigned if the input value is larger than the maximum.
+<p>
+<em>r.quantile.ref</em> can be regarded as the inverse of
+<em>r.series method=quantile</em>: while <em>r.series</em> calculates
+the value for a given quantile, <em>r.quantile.ref</em> calculates the
+quantile for a given value. This is useful to compare e.g. current
+environmental conditions to a time series of historical environmental
+conditions.
+<h2>EXAMPLE</h2>
+Create some reference rasters:
+<div class="code"><pre>
+r.mapcalc "ref1 = 1"
+r.mapcalc "ref2 = 2"
+r.mapcalc "ref3 = 3"
+r.mapcalc "ref4 = 5"
+r.mapcalc "ref5 = 5"
+r.mapcalc "ref6 = 5"
+</pre></div>
+Create a test raster with cell value 4.5:
+r.mapcalc "test = 4.5"
+</pre></div>
+Get the quantile of the test raster for the reference maps:
+r.quantile.ref input=test reference=ref1,ref2,ref3,ref4,ref5,ref6 output=test_quant
+</pre></div>
+The quantile corresponding to the value 4.5 is 0.55.
+Create a test raster with cell value 5:
+r.mapcalc "test = 5"
+</pre></div>
+</pre></div>
+The quantile corresponding to the value 5 is 0.8.
+<h2>SEE ALSO</h2>
+<em>
+<a href="r.quantile.html">r.quantile</a>,
+<a href="r.series.html">r.series</a>
+</em>
+<h2>AUTHOR</h2>
+Markus Metz
+<p>
+<i>Last changed: $Date$</i>
Deleted: grass-addons/grass7/raster/r.quantile.ref/r.series.html
--- grass-addons/grass7/raster/r.quantile.ref/r.series.html 2016-07-21 19:17:52 UTC (rev 69018)
+++ grass-addons/grass7/raster/r.quantile.ref/r.series.html 2016-07-21 19:20:29 UTC (rev 69019)
@@ -1,216 +0,0 @@
-<h2>DESCRIPTION</h2>
-<em>r.series</em> makes each output cell value a function of the values
-assigned to the corresponding cells in the input raster map layers.
-<p>
-Following methods are available:
-<ul>
- <li>average: average value
- <li>count: count of non-NULL cells
- <li>median: median value
- <li>mode: most frequently occurring value
- <li>minimum: lowest value
- <li>maximum: highest value
- <li>range: range of values (max - min)
- <li>stddev: standard deviation
- <li>sum: sum of values
- <li>variance: statistical variance
- <li>diversity: number of different values
- <li>slope: linear regression slope
- <li>offset: linear regression offset
- <li>detcoeff: linear regression coefficient of determination
- <li>tvalue: linear regression t-value
- <li>min_raster: raster map number with the minimum time-series value
- <li>max_raster: raster map number with the maximum time-series value
-</ul>
-Note that most parameters accept multiple answers, allowing multiple
-aggregates to be computed in a single run, e.g.:
-<p>
-<div class="code"><pre>
-r.series input=map1,...,mapN \
- output=map.mean,map.stddev \
- method=average,stddev
-</pre></div>
-or:
-<p>
- output=map.p10,map.p50,map.p90 \
- method=quantile,quantile,quantile \
- quantile=0.1,0.5,0.9
-</pre></div>
-The same number of values must be provided for all options.
-<h2>NOTES</h2>
-<h3>No-data (NULL) handling</h3>
-With <em>-n</em> flag, any cell for which any of the corresponding
-input cells are NULL is automatically set to NULL (NULL propagation).
-The aggregate function is not called, so all methods behave this way
-with respect to the <em>-n</em> flag.
-<p>
-Without <em>-n</em> flag, the complete list of inputs for each cell
-(including NULLs) is passed to the aggregate function. Individual
-aggregates can handle data as they choose. Mostly, they just compute
-the aggregate over the non-NULL values, producing a NULL result only if
-all inputs are NULL.
-<h3>Minimum and maximum analysis</h3>
-The <em>min_raster</em> and <em>max_raster</em> methods generate a map
-with the number of the raster map that holds the minimum/maximum value
-of the time-series. The numbering starts at <em>0</em> up to <em>n</em>
-for the first and the last raster listed in <em>input=</em>,
-respectively.
-<h3>Range analysis</h3>
-If the <em>range=</em> option is given, any values which fall outside
-that range will be treated as if they were NULL. The <em>range</em>
-parameter can be set to <em>low,high</em> thresholds: values outside of
-this range are treated as NULL (i.e., they will be ignored by most
-aggregates, or will cause the result to be NULL if -n is given). The
-<em>low,high</em> thresholds are floating point, so use <em>-inf</em>
-or <em>inf</em> for a single threshold (e.g., <em>range=0,inf</em> to
-ignore negative values, or <em>range=-inf,-200.4</em> to ignore values
-above -200.4).
-<h3>Linear regression</h3>
-Linear regression (slope, offset, coefficient of determination,
-t-value) assumes equal time intervals. If the data have irregular time
-intervals, NULL raster maps can be inserted into time series to make
-time intervals equal (see example).
-<h3>Quantiles</h3>
-<em>r.series</em> can calculate arbitrary quantiles.
-<h3>Memory consumption</h3>
-Memory usage is not an issue, as <em>r.series</em> only needs to hold
-one row from each map at a time.
-<h3>Management of open file limits</h3>
-Number of raster maps to be processed is given by the limit of the
-operating system. For example, both the hard and soft limits are
-typically 1024. The soft limit can be changed with e.g. <tt>ulimit -n 1500</tt>
-(UNIX-based operating systems) but not higher than the hard
-limit. If it is too low, you can as superuser add an entry in
-/etc/security/limits.conf
-# <domain> <type> <item> <value>
-your_username hard nofile 1500
-</pre></div>
-This would raise the hard limit to 1500 file. Be warned that more
-files open need more RAM. See also the Wiki page
-<a href="http://grasswiki.osgeo.org/wiki/Large_raster_data_processing">Hints for large raster data processing</a>.
-<p>
-For each map a weighting factor can be specified using the
-<em>weights</em> option. Using weights can be meaningful when computing
-sum or average of maps with different temporal extent. The default
-weight is 1.0. The number of weights must be identical with the number
-of input maps and must have the same order. Weights can also be
-specified in the input file.
-<p>
-Use the <em>file</em> option to analyze large amount of raster maps
-without hitting open files limit and the size limit of command line
-arguments. The computation is slower than the <em>input</em> option
-method. For every sinlge row in the output map(s) all input maps are
-opened and closed. The amount of RAM will rise linear with the number
-of specified input maps. The input and file options are mutually
-exclusive. Input is a text file with a new line separated list of
-raster map names and optional weights. As separator between the map
-name and the weight the character "|" must be used.
-<h2>EXAMPLES</h2>
-Using <em>r.series</em> with wildcards:
-<br>
-r.series input="`g.list pattern='insitu_data.*' sep=,`" \
- output=insitu_data.stddev method=stddev
-</pre></div>
-<p>
-Note the <em>g.list</em> script also supports regular expressions for
-selecting map names.
-<p>
-Using <em>r.series</em> with NULL raster maps (in order to consider a
-"complete" time series):
-<br>
-r.mapcalc "dummy = null()"
-r.series in=map2001,map2002,dummy,dummy,map2005,map2006,dummy,map2008 \
- out=res_slope,res_offset,res_coeff meth=slope,offset,detcoeff
-</pre></div>
-<p>Example for multiple aggregates to be computed in one run (3 resulting aggregates
-from two input maps):
-r.series in=one,two out=result_avg,res_slope,result_count meth=sum,slope,count
-</pre></div>
-<p>Example to use the file option of r.series:
-cat > input.txt << EOF
-map1
-map2
-map3
-EOF
-r.series file=input.txt out=result_sum meth=sum
-</pre></div>
-<p>
-Example to use the file option of r.series including weights. The
-weight 0.75 should be assigned to map2. As the other maps do not have
-weights we can leave it out:
-map1
-map2|0.75
-map3
-EOF
-</pre></div>
-<p>
-Example for counting the number of days above a certain temperature using
-daily average maps ('???' as DOY wildcard):
-# Approach for shell based systems
-r.series input=`g.list rast pattern="temp_2003_???_avg" sep=,` \
- output=temp_2003_days_over_25deg range=25.0,100.0 method=count
-# Approach in two steps (e.g., for Windows systems)
-g.list rast pattern="temp_2003_???_avg" output=mapnames.txt
-r.series file=mapnames.txt \
-</pre></div>
-<h2>SEE ALSO</h2>
-<em>
-<a href="g.list.html">g.list</a>,
-<a href="g.region.html">g.region</a>,
-<a href="r.quantile.html">r.quantile</a>,
-<a href="r.series.accumulate.html">r.series.accumulate</a>,
-<a href="r.series.interp.html">r.series.interp</a>,
-<a href="r.univar.html">r.univar</a>
-</em>
-<p>
-<h2>AUTHOR</h2>
-Glynn Clements
-<p><i>Last changed: $Date$</i>
