[GRASS-SVN] r69020 - grass/trunk/locale/po
svn_grass at osgeo.org
Thu Jul 21 14:30:45 PDT 2016
Author: neteler
Date: 2016-07-21 14:30:45 -0700 (Thu, 21 Jul 2016)
New Revision: 69020
grass/trunk/locale/po/grassmods_es.po
Daniel Torres: ES translation cont'ed
Modified: grass/trunk/locale/po/grassmods_es.po
--- grass/trunk/locale/po/grassmods_es.po 2016-07-21 19:20:29 UTC (rev 69019)
+++ grass/trunk/locale/po/grassmods_es.po 2016-07-21 21:30:45 UTC (rev 69020)
@@ -8,13 +8,13 @@
# Enrique Cerrillo Cuenca <ecerrillo at unex.es>, 2007.
# Carlos Dávila <carluti at users.sourceforge.net>, 2007, 2008.
# Joana Palahí/SIGTE-UdG <joana sigte.udg.edu>, 2011, 2014.
-# Daniel Torres <nobeeakon at gmail.com>, 2014, 2015.
+# Daniel Torres <nobeeakon at gmail.com>, 2014, 2015, 2016.
msgid ""
msgstr ""
"Project-Id-Version: grassmods_es\n"
"Report-Msgid-Bugs-To: \n"
"POT-Creation-Date: 2016-06-26 16:27+0200\n"
-"PO-Revision-Date: 2015-01-23 20:45-0600\n"
+"PO-Revision-Date: 2016-07-18 12:34-0500\n"
"Last-Translator: \n"
"Language-Team: Español <grass-translations at lists.osgeo.org>\n"
"Language: es_ES\n"
@@ -27,9 +27,8 @@
"Plural-Forms: nplurals=2; plural=(n != 1);\n"
#: ../db/drivers/mysql/index.c:55 ../db/drivers/sqlite/index.c:77
-#, fuzzy
msgid "Unable to create index:"
-msgstr "No se puede crear el índice"
+msgstr "No ha sido posible crear el índice:"
#: ../db/drivers/mysql/dbe.c:45
#, fuzzy
@@ -56,40 +55,35 @@
#: ../db/drivers/mysql/fetch.c:191
msgid "Unable to scan timestamp: "
-msgstr "No se puede explorar el indicador de tiempo: "
+msgstr "No se puede explorar la marca de tiempo:"
#: ../db/drivers/mysql/fetch.c:200
msgid "Unknown timestamp format: "
-msgstr "Formato de indicador de tiempo desconocido: "
+msgstr "Formato de marca de tiempo desconocido: "
#: ../db/drivers/mysql/fetch.c:215
msgid "Unable to scan date: "
-msgstr "No se explorar la fecha: "
+msgstr "No ha sido posible explorar fecha: "
#: ../db/drivers/mysql/fetch.c:229
msgid "Unable to scan time: "
-msgstr "No se puede explorar el tiempo: "
+msgstr "No ha sido posible explorar tiempo: "
#: ../db/drivers/mysql/fetch.c:245
msgid "Unable to scan datetime:"
-msgstr "No se puede explorar fecha y hora: "
+msgstr "No ha sido posible explorar fecha y hora: "
#: ../db/drivers/mysql/parse.c:62
msgid "Wrong port number in MySQL database definition: "
-msgstr ""
-"Número de puerto incorrecto en la definición de la base de datos MySQL: "
+msgstr "Número de puerto incorrecto en la definición de la base de datos MySQL: "
#: ../db/drivers/mysql/parse.c:73 ../db/drivers/postgres/parse.c:60
msgid "'user' in database definition is not supported, use db.login"
-msgstr ""
-"'usuario' no está soportado en las definiciones de la base de datos. Use db."
-"login"
+msgstr "'usuario' no está soportado en las definiciones de la base de datos. Use db.login"
#: ../db/drivers/mysql/parse.c:77 ../db/drivers/postgres/parse.c:64
msgid "'password' in database definition is not supported, use db.login"
-msgstr ""
-"'contraseña' no está soportado en las definiciones de la base de datos. Use "
-"db.login"
+msgstr "'contraseña' no está soportado en las definiciones de la base de datos. Use db.login"
#: ../db/drivers/mysql/parse.c:82
#, fuzzy
@@ -102,14 +96,12 @@
#: ../db/drivers/mysql/describe.c:32 ../db/drivers/sqlite/describe.c:92
#: ../db/drivers/sqlite/select.c:95
-#, fuzzy
msgid "Unable to describe table:"
-msgstr "No se puede describir la tabla<%s>"
+msgstr "No ha sido posible describir tabla:"
#: ../db/drivers/mysql/describe.c:50 ../db/drivers/postgres/select.c:69
-#, fuzzy
msgid "Unable to describe table"
+msgstr "No ha sido posible describir tabla"
#: ../db/drivers/mysql/describe.c:121
#, c-format
@@ -118,27 +110,20 @@
#: ../db/drivers/mysql/describe.c:127
#, c-format
-msgid ""
-"column '%s' : type BIGINT is stored as integer (4 bytes) some data may be "
-"damaged"
-msgstr ""
-"columna '%s' : el tipo BIGINT se guarda como entero (4 bytes) algunos datos "
-"pueden deteriorarse"
+msgid "column '%s' : type BIGINT is stored as integer (4 bytes) some data may be damaged"
+msgstr "columna '%s' : el tipo BIGINT se guarda como entero (4 bytes) algunos datos pueden deteriorarse"
#: ../db/drivers/mysql/execute.c:41 ../db/drivers/postgres/execute.c:42
-#, fuzzy
msgid "Unable to execute:"
-msgstr "No se puede establecer el tamaño"
+msgstr "No se ha podido ejecutar: "
#: ../db/drivers/mysql/execute.c:62
-#, fuzzy
msgid "Unable to start transaction:"
-msgstr "No se puede establecer la proyección"
+msgstr "No se ha podido iniciar transacción:"
#: ../db/drivers/mysql/execute.c:77
-#, fuzzy
msgid "Unable to commit transaction:"
+msgstr "No ha sido posible realizar transacción:"
#: ../db/drivers/mysql/select.c:42
msgid "Unable to select data:"
@@ -149,9 +134,8 @@
msgstr "No se puede describir la tabla."
#: ../db/drivers/mysql/cursor.c:44 ../db/drivers/postgres/cursor.c:41
-#, fuzzy
msgid "Unable allocate cursor."
-msgstr "No se puede asignar memoria"
+msgstr "No se ha podido asignar cursor."
#: ../db/drivers/mysql/cursor.c:53
#, fuzzy
@@ -161,20 +145,18 @@
#: ../db/drivers/mysql/create_table.c:108
#: ../db/drivers/sqlite/create_table.c:122
#: ../db/drivers/postgres/create_table.c:103
-#, fuzzy
msgid "Unable to create table:"
-msgstr "No se puede crear la tabla: %s"
+msgstr "No se ha podido crear tabla: "
#: ../db/drivers/mysql/db.c:61 ../db/drivers/postgres/db.c:72
#: ../db/drivers/postgres/db.c:251
-#, fuzzy
msgid "Connection failed."
-msgstr "Conexión"
+msgstr "Falló la conexión."
#: ../db/drivers/odbc/table.c:159
-#, fuzzy, c-format
+#, c-format
msgid "Table %s doesn't exist"
-msgstr "La herramienta no existe"
+msgstr "La tabla %s no existe"
#: ../db/drivers/odbc/table.c:176
#, c-format
@@ -193,9 +175,8 @@
msgstr "No se puede establecer ventana"
#: ../db/drivers/odbc/cursor.c:36 ../db/drivers/ogr/cursor.c:65
-#, fuzzy
msgid "Unable to allocate cursor"
+msgstr "No se ha podido asignar cursor"
#: ../db/drivers/odbc/cursor.c:55 ../db/drivers/sqlite/cursor.c:56
#: ../db/drivers/postgres/cursor.c:50
@@ -204,52 +185,44 @@
msgstr "No se puede leer el archivo de intervalo"
#: ../db/drivers/ogr/fetch.c:71
-#, fuzzy
msgid "DB_PREVIOUS not supported"
-msgstr "Capa 0 no soportada"
+msgstr "DB_PREVIOUS no soportado"
#: ../db/drivers/ogr/fetch.c:82
-#, fuzzy
msgid "DB_LAST not supported"
+msgstr "DB_LAST no soportado"
#: ../db/drivers/ogr/fetch.c:160 ../db/drivers/ogr/describe.c:200
msgid "Unknown type"
msgstr "Tipo desconocido"
#: ../db/drivers/ogr/listtab.c:49 ../db/drivers/sqlite/listtab.c:78
-#, fuzzy
msgid "Unable to db_alloc_string_array()"
+msgstr "No se ha podido db_alloc_string_array()"
#: ../db/drivers/ogr/describe.c:55
-#, fuzzy, c-format
+#, c-format
msgid "OGR layer <%s> does not exist\n"
-msgstr "El grupo <%s> no existe"
+msgstr "Capa OGR <%s> no existe\n"
#: ../db/drivers/ogr/describe.c:63 ../db/drivers/ogr/select.c:58
-#, fuzzy
msgid "Unable to describe table\n"
+msgstr "No se puede describir la tabla\n"
#: ../db/drivers/ogr/describe.c:112
-#, fuzzy, c-format
+#, c-format
msgid "OGR driver: column '%s', OGR type %d is not supported"
msgstr "Controlador OGR: columna '%s', tipo OGR %d no soportado"
#: ../db/drivers/ogr/describe.c:192
#, c-format
-msgid ""
-"column '%s', type 'string': unknown width -> stored as varchar(250) some "
-"data may be lost"
-msgstr ""
-"columna '%s', tipo 'cadena': anchura desconocida ->guardada como "
-"varchar(250). Algunos datos pueden perderse"
+msgid "column '%s', type 'string': unknown width -> stored as varchar(250) some data may be lost"
+msgstr "columna '%s', tipo 'cadena': anchura desconocida ->guardada como varchar(250). Algunos datos pueden perderse"
#: ../db/drivers/ogr/execute.c:56 ../vector/v.out.ogr/main.c:593
-#, fuzzy, c-format
+#, c-format
msgid "OGR layer <%s> not found"
-msgstr "%s: no se encontró <%s>"
+msgstr "Capa OGR <%s> no encontrada"
#: ../db/drivers/ogr/execute.c:69 ../vector/v.colors/scan_attr.c:35
#: ../vector/v.in.db/main.c:187 ../vector/v.to.3d/trans3.c:65
@@ -264,9 +237,8 @@
msgstr "Columna <%s> no encontrada en la tabla <%s>"
#: ../db/drivers/ogr/select.c:50
-#, fuzzy
msgid "Unable to select: \n"
+msgstr "No se ha podido seleccionar: \n"
#: ../db/drivers/ogr/cursor.c:74
#, fuzzy
@@ -279,19 +251,17 @@
msgstr "No se puede abrir el origen de datos <%s>"
#: ../db/drivers/ogr/db.c:60
-#, fuzzy
msgid "Unable to open OGR data source"
-msgstr "No se puede abrir el origen de datos <%s>"
+msgstr "No se ha podido abrir origen de datos OGR"
#: ../db/drivers/dbf/table.c:117 ../db/drivers/dbf/table.c:170
-#, fuzzy
msgid "Unable to open DBF file."
+msgstr "No se ha podido abrir archivo DBF."
#: ../db/drivers/dbf/table.c:312
-#, fuzzy, c-format
+#, c-format
msgid "Unable to move '%s' to '%s'."
-msgstr "No se puede abrir el archivo <%s>"
+msgstr "No se ha podido mover '%s' a '%s'."
#: ../db/drivers/dbf/column.c:49
#, c-format
@@ -299,24 +269,22 @@
msgstr "La columna '%s' ya existe (nombre duplicado)"
#: ../db/drivers/dbf/column.c:99
-#, fuzzy, c-format
+#, c-format
msgid "Column '%s' does not exist"
+msgstr "Columna <'%s> no existe"
#: ../db/drivers/dbf/describe.c:34
-#, fuzzy, c-format
+#, c-format
msgid "Table '%s' doesn't exist"
+msgstr "Tabla '%s' no existe"
#: ../db/drivers/dbf/execute.c:32
-#, fuzzy
msgid "Unable to execute statement."
+msgstr "No se ha podido ejecutar sentencia."
#: ../db/drivers/dbf/select.c:44
-#, fuzzy
msgid "Unable to open cursor."
-msgstr "No se puede abrir el cursor de selección"
+msgstr "No se ha podido abrir cursor."
#: ../db/drivers/dbf/dbfexe.c:72
#, fuzzy
@@ -324,80 +292,68 @@
msgstr "Parámetros"
#: ../db/drivers/dbf/dbfexe.c:74
-#, fuzzy
msgid "in statement:"
-msgstr "Situación"
+msgstr "en sentencia:"
#: ../db/drivers/dbf/dbfexe.c:88
-#, fuzzy, c-format
+#, c-format
msgid "Table '%s' doesn't exist."
+msgstr "La tabla '%s' no existe."
#: ../db/drivers/dbf/dbfexe.c:96
-#, fuzzy
msgid "Unable to load table head."
-msgstr "No se puede copiar la tabla"
+msgstr "No se ha podido cargar encabezado de la tabla."
#: ../db/drivers/dbf/dbfexe.c:106
msgid "Unable to modify table, don't have write permission for DBF file."
-msgstr ""
-"No es posible modificar la tabla, no tiene permiso de escribir para archivo "
-"DBF."
+msgstr "No es posible modificar la tabla, no tiene permiso de escribir para archivo DBF."
#: ../db/drivers/dbf/dbfexe.c:121 ../db/drivers/dbf/dbfexe.c:1023
-#, fuzzy, c-format
+#, c-format
msgid "Column '%s' not found"
-msgstr "Columna <%s> no encontrada"
+msgstr "Columna '%s' no encontrada"
#: ../db/drivers/dbf/dbfexe.c:145
-#, fuzzy
msgid "Incompatible value type."
-msgstr "Tipos de columnas incompatibles"
+msgstr "Tipos de valor incompatible."
#: ../db/drivers/dbf/dbfexe.c:161
-#, fuzzy
msgid "Unable to add column."
-msgstr "No se puede usar columna <%s>"
+msgstr "No se ha podido añadir columna."
#: ../db/drivers/dbf/dbfexe.c:183
-#, fuzzy
msgid "Unable to delete column."
-msgstr "No se puede borrar la línea %d"
+msgstr "No se ha podido borrar columna."
#: ../db/drivers/dbf/dbfexe.c:191
-#, fuzzy, c-format
+#, c-format
msgid "Table %s already exists"
-msgstr "<%s> ya existe"
+msgstr "La tabla '%s' ya existe"
#: ../db/drivers/dbf/dbfexe.c:206
-#, fuzzy
msgid "Unable to create table."
+msgstr "No se puede crear tabla."
#: ../db/drivers/dbf/dbfexe.c:263 ../db/drivers/dbf/dbfexe.c:273
#: ../db/drivers/dbf/dbfexe.c:303
-#, fuzzy
msgid "Error in selecting rows"
-msgstr "Error escribiendo fila %d"
+msgstr "Error al seleccionar filas"
#: ../db/drivers/dbf/dbfexe.c:552
-#, fuzzy
msgid "Cannot load table."
-msgstr "Imposible copiar la tabla"
+msgstr "No se puede cargar tabla."
#: ../db/drivers/dbf/dbfexe.c:567
-#, fuzzy
msgid "Incompatible types in WHERE condition."
-msgstr "Tipos incompatibles"
+msgstr "Tipos incompatibles en la condición WHERE."
#: ../db/drivers/dbf/dbfexe.c:572
msgid "Result of WHERE condition is not of type BOOL."
msgstr "Resultado de la condición WHERE no es de tipo BOOL."
#: ../db/drivers/dbf/dbfexe.c:588
-#, fuzzy
msgid "Error in evaluation of WHERE condition."
-msgstr "Error calculando conversiones"
+msgstr "Error al evaluar la condición WHERE."
#: ../db/drivers/dbf/dbfexe.c:600
#, c-format
@@ -409,9 +365,9 @@
msgstr ""
#: ../db/drivers/dbf/dbfexe.c:633
-#, fuzzy, c-format
+#, c-format
msgid "Unable to find order column '%s'"
-msgstr "No se puede encontrar la fuente '%s'\n"
+msgstr "No se ha podido encontrar columna '%s' de orden."
#: ../db/drivers/dbf/dbfexe.c:778
msgid "Division by zero"
@@ -430,33 +386,30 @@
msgstr "Valor del operando para NOT"
#: ../db/drivers/dbf/dbfexe.c:954 ../db/drivers/dbf/dbfexe.c:1151
-#, fuzzy, c-format
+#, c-format
msgid "Unknown operator %d"
-msgstr "Operador desconocido"
+msgstr "Operador desconocido %d"
#: ../db/drivers/dbf/dbfexe.c:1061
-#, fuzzy
msgid "Arithmetical operation with strings is not allowed"
-msgstr ""
-"No están permitidas las operaciones aritméticas con secuencias (strings)"
+msgstr "No están permitidas las operaciones aritméticas con cadenas (strings)"
#: ../db/drivers/dbf/dbfexe.c:1083
msgid "Comparison between string and number is not allowed"
msgstr "No está permitida la comparación entre número y secuencia (string)"
#: ../db/drivers/dbf/dbfexe.c:1098
-#, fuzzy, c-format
+#, c-format
msgid "Comparison '%s' between strings not allowed"
-msgstr "Este valor de paso no está permitido"
+msgstr "No está permitida la comparación '%s' entre cadenas (strings)"
#: ../db/drivers/dbf/dbfexe.c:1112
msgid "Match (~) between numbers not allowed"
msgstr "No está permitida la correspondencia (~) entre números"
#: ../db/drivers/dbf/cursor.c:47
-#, fuzzy
msgid "Unable to allocate new cursor"
+msgstr "No se ha podido asignar nuevo cursor"
#: ../db/drivers/dbf/cursor.c:59
#, fuzzy
@@ -464,24 +417,23 @@
#: ../db/drivers/dbf/create_table.c:22
-#, fuzzy
msgid "Unable to create table"
+msgstr "No se ha podido crear tabla"
#: ../db/drivers/dbf/db.c:94
-#, fuzzy, c-format
+#, c-format
msgid "Unable create DBF database: %s"
+msgstr "No se ha podido crear base de datos DBF: %s"
#: ../db/drivers/dbf/db.c:102
-#, fuzzy, c-format
+#, c-format
msgid "Cannot open DBF database directory: %s"
-msgstr "No se puede abrir la base de datos:"
+msgstr "No se ha podido abrir directorio de base de datos DBF: %s"
#: ../db/drivers/dbf/db.c:110
-#, fuzzy, c-format
+#, c-format
msgid "Unable to open DBF database: %s"
+msgstr "No se ha podido abrir base de datos DBF: %s"
#: ../db/drivers/sqlite/index.c:96 ../db/drivers/sqlite/describe.c:78
#: ../db/drivers/sqlite/describe.c:132 ../db/drivers/sqlite/execute.c:69
@@ -505,14 +457,12 @@
msgstr "No se puede recuperar el registro"
#: ../db/drivers/sqlite/fetch.c:87
-#, fuzzy
msgid "DB_PREVIOUS is not supported"
+msgstr "DB_PREVIOUS no está soportado"
#: ../db/drivers/sqlite/fetch.c:93
-#, fuzzy
msgid "DB_LAST is not supported"
+msgstr "DB_LAST no está soportado"
#: ../db/drivers/sqlite/fetch.c:171 ../db/drivers/postgres/fetch.c:129
msgid "Unable to scan date:"
@@ -527,25 +477,20 @@
msgstr "No se puede explorar marca temporal: "
#: ../db/drivers/sqlite/fetch.c:218
-msgid ""
-"SQLite driver: parsing of interval values not implemented; assuming seconds"
-msgstr ""
-"Controlador SQLite: análisis de valores de intervalo no está implementado; "
-"asumiendo segundos"
+msgid "SQLite driver: parsing of interval values not implemented; assuming seconds"
+msgstr "Controlador SQLite: análisis de valores de intervalo no está implementado; asumiendo segundos"
#: ../db/drivers/sqlite/fetch.c:223
msgid "Unable to scan interval:"
msgstr "No se puede explorar el intervalo:"
#: ../db/drivers/sqlite/fetch.c:286
-#, fuzzy
msgid "Unable to get number of rows:"
-msgstr "No se puede obtener la cabecera de %s"
+msgstr "No se ha podido obtener número de filas:"
#: ../db/drivers/sqlite/listtab.c:50 ../db/drivers/sqlite/listtab.c:66
-#, fuzzy
msgid "Unable to list tables:"
-msgstr "No se pueden listar las base de datos"
+msgstr "No se ha podido enlistar tablas:"
#: ../db/drivers/sqlite/describe.c:60 ../db/drivers/sqlite/execute.c:53
#: ../db/drivers/sqlite/select.c:63
@@ -558,34 +503,30 @@
msgstr "Controlador SQLite: columna '%s', el tipo SQLite %d no está soportado"
#: ../db/drivers/sqlite/execute.c:83
-#, fuzzy
msgid "Error in sqlite3_finalize():"
-msgstr "Error al cerrar archivo ASCII"
+msgstr "Error en sqlite3_finalize():"
#: ../db/drivers/sqlite/execute.c:111
-#, fuzzy
msgid "'BEGIN' transaction failed:"
+msgstr "Falló la transacción 'BEGIN':"
#: ../db/drivers/sqlite/execute.c:139
-#, fuzzy
msgid "'COMMIT' transaction failed:"
+msgstr "Falló la transacción 'COMMIT':"
#: ../db/drivers/sqlite/listdb.c:45 ../db/drivers/postgres/listdb.c:35
-#, fuzzy
msgid "No path given"
-msgstr "Ningún nombre de mapa especificado"
+msgstr "No se dio ninguna ruta"
#: ../db/drivers/sqlite/listdb.c:99
-#, fuzzy, c-format
+#, c-format
msgid "Unable to open directory '%s'"
+msgstr "No se ha podido abrir directorio '%s'"
#: ../db/drivers/sqlite/listdb.c:117
-#, fuzzy, c-format
+#, c-format
msgid "SQLite database connection '%s' is still busy"
-msgstr "Conexión a la base de datos no definida"
+msgstr "Conexión a la base de datos SQLite '%s' aún está ocupada"
#: ../db/drivers/sqlite/listdb.c:134 ../db/drivers/postgres/listtab.c:92
#: ../db/drivers/postgres/listdb.c:88 ../vector/v.vol.rst/user1.c:423
@@ -622,39 +563,35 @@
msgstr "Sin memoria"
#: ../db/drivers/sqlite/cursor.c:47
-#, fuzzy
msgid "Unable to allocate cursor."
#: ../db/drivers/sqlite/db.c:99
-#, fuzzy, c-format
+#, c-format
msgid "Unable to create directory '%s' for sqlite database"
+msgstr "No se ha podido crear directorio '%s' para base de datos sqlite"
#: ../db/drivers/sqlite/db.c:107
-#, fuzzy
msgid "Unable to open database:"
+msgstr "No se ha podido abrir bsae de datos:"
#: ../db/drivers/sqlite/db.c:134
-#, fuzzy
msgid "SQLite database connection is still busy"
+msgstr "Conexión a la base de datos SQLite aún está ocupada"
#: ../db/drivers/sqlite/db.c:155
-#, fuzzy, c-format
+#, c-format
msgid "Database <%s> already exists"
+msgstr "La base de datos <'%s'> ya existe"
#: ../db/drivers/sqlite/db.c:162
-#, fuzzy
msgid "Unable to create database:"
+msgstr "No se ha podido crear la base de datos:"
#: ../db/drivers/sqlite/db.c:186
-#, fuzzy, c-format
+#, c-format
msgid "Database <%s> not found"
-msgstr "Directorio de mapas <%s> no encontrado"
+msgstr "Base de datos <%s> no encontrada"
#: ../db/drivers/postgres/index.c:59 ../vector/v.extract/copy_tab.c:124
#: ../vector/v.overlay/main.c:585 ../vector/v.random/main.c:257
@@ -676,20 +613,15 @@
#: ../db/drivers/postgres/fetch.c:166
msgid "Unable to scan timestamp (no idea how to process time zone):"
-msgstr ""
-"No es posible explorar la marca de tiempo (timestamp)(ni idea de cómo "
-"procesar el huso horario):"
+msgstr "No es posible explorar la marca de tiempo (timestamp)(ni idea de cómo procesar el huso horario):"
#: ../db/drivers/postgres/fetch.c:174
msgid "Unable to scan timestamp (not enough arguments):"
-msgstr ""
-"No es posible explorar la marca de tiempo (timestamp)(no hay suficientes "
-"argumentos):"
+msgstr "No es posible explorar la marca de tiempo (timestamp)(no hay suficientes argumentos):"
#: ../db/drivers/postgres/fetch.c:188
-#, fuzzy
msgid "Unable to recognize boolean value"
-msgstr "No se puede reconocer el valor booleano"
+msgstr "No se ha podido reconocer el valor booleano"
#: ../db/drivers/postgres/fetch.c:206
#, fuzzy
@@ -698,84 +630,64 @@
#: ../db/drivers/postgres/parse.c:69
msgid "Unknown option in database definition for PostgreSQL: "
-msgstr ""
-"Opción desconocida en la definición de la base de datos para PostgreSQL: "
+msgstr "Opción desconocida en la definición de la base de datos para PostgreSQL: "
#: ../db/drivers/postgres/listtab.c:38
-#, fuzzy
msgid "Unable to select table names."
-msgstr "No se pueden seleccionar los atributos"
+msgstr "No se ha podido seleccionar nombres de tablas."
#: ../db/drivers/postgres/listtab.c:65
-#, fuzzy
msgid "Unable to select view names."
+msgstr "No se ha podido seleccionar nombres de vistas."
#: ../db/drivers/postgres/describe.c:123
-#, fuzzy, c-format
+#, c-format
msgid "PostgreSQL driver: column '%s', type %d is not supported"
-msgstr "Controlador MySQL: columna '%s', tipo %d no soportado"
+msgstr "Controlador PostgreSQL: columna '%s', tipo %d no soportado"
#: ../db/drivers/postgres/describe.c:130
#, c-format
-msgid ""
-"column '%s' : type int8 (bigint) is stored as integer (4 bytes) some data "
-"may be damaged"
-msgstr ""
-"columna '%s' : tipo int8 (bigint) se guarda como entero (4 bytes). Algunos "
-"datos pueden deteriorarse"
+msgid "column '%s' : type int8 (bigint) is stored as integer (4 bytes) some data may be damaged"
+msgstr "columna '%s' : tipo int8 (bigint) se guarda como entero (4 bytes). Algunos datos pueden deteriorarse"
#: ../db/drivers/postgres/describe.c:134
#, c-format
-msgid ""
-"column '%s' : type character varying is stored as varchar(250) some data may "
-"be lost"
-msgstr ""
-"columna '%s' : el tipo carácter variante se guarda como varchar(250). "
-"Algunos datos pueden perderse"
+msgid "column '%s' : type character varying is stored as varchar(250) some data may be lost"
+msgstr "columna '%s' : el tipo carácter variante se guarda como varchar(250). Algunos datos pueden perderse"
#: ../db/drivers/postgres/describe.c:140
#, c-format
-msgid ""
-"column '%s' : type bool (boolean) is stored as char(1), values: 0 (false), 1 "
-"(true)"
-msgstr ""
-"columna '%s' : el tipo bool (booleano) se guarda como char(1), valores: 0 "
-"(falso), 1 (verdadero)"
+msgid "column '%s' : type bool (boolean) is stored as char(1), values: 0 (false), 1 (true)"
+msgstr "columna '%s' : el tipo bool (booleano) se guarda como char(1), valores: 0 (falso), 1 (verdadero)"
#: ../db/drivers/postgres/execute.c:68
-#, fuzzy
msgid "Unable to 'BEGIN' transaction"
+msgstr "No se ha podido 'BEGIN' transacción"
#: ../db/drivers/postgres/execute.c:88
-#, fuzzy
msgid "Unable to 'COMMIT' transaction"
+msgstr "No se ha podido 'COMMIT' transacción"
#: ../db/drivers/postgres/select.c:31
msgid "Unable set DATESTYLE"
msgstr "No es posible definir DATESTYLE"
#: ../db/drivers/postgres/select.c:55
-#, fuzzy
msgid "Unable to select:"
+msgstr "No se ha podido seleccionar:"
#: ../db/drivers/postgres/listdb.c:65
-#, fuzzy
msgid "Unable to connect to Postgres:"
+msgstr "No se ha podido conectar a Postres:"
#: ../db/drivers/postgres/listdb.c:76
-#, fuzzy
msgid "Unable to select from Postgres:"
-msgstr "No se pueden seleccionar datos de la tabla"
+msgstr "No se ha podido seleccionar a partir de Postgres:"
#: ../db/drivers/postgres/create_table.c:90
-#, fuzzy, c-format
+#, c-format
msgid "Unknown column type (%s)"
-msgstr "Tipo de columna '%s' desconocido"
+msgstr "Tipo de columna desconocido (%s)"
#: ../db/drivers/postgres/create_table.c:132
#, fuzzy
@@ -783,24 +695,22 @@
msgstr "No se pueden otorgar privilegios sobre la tabla <%s>"
#: ../db/drivers/postgres/db.c:100
-#, fuzzy
msgid "Unable to set schema:"
+msgstr "No se puede definir el esquema:"
#: ../db/drivers/postgres/db.c:118
-#, fuzzy
msgid "Unable to select data types"
+msgstr "No se ha podido seleccionar tipo de datos"
#: ../db/drivers/postgres/db.c:270
-#, fuzzy, c-format
+#, c-format
msgid "Unable to create database <%s>"
-msgstr "No se puede crear la tabla <%s>"
+msgstr "No se puede crear base de datos <%s>"
#: ../db/drivers/postgres/db.c:272
-#, fuzzy, c-format
+#, c-format
msgid "Unable to drop database <%s>"
-msgstr "No se puede abrir la base de datos <%s>"
+msgstr "No se puede eliminar base de datos <%s>"
#: ../db/db.login/main.c:40 ../db/db.drivers/main.c:71 ../db/db.copy/main.c:35
#: ../db/db.describe/main.c:129 ../db/db.createdb/main.c:71
@@ -833,19 +743,16 @@
#: ../db/db.login/main.c:41 ../db/db.drivers/main.c:72
#: ../db/db.connect/main.c:45 ../temporal/t.connect/main.c:36
-#, fuzzy
msgid "connection settings"
-msgstr "Por favor, corrija la configuración"
+msgstr "configuraciones de conexión"
#: ../db/db.login/main.c:42
-#, fuzzy
msgid "Sets user/password for DB driver/database."
-msgstr "Establece usuario/contraseña para controlador/base de datos."
+msgstr "Establece el usuario/contraseña para controlador DB/base de datos."
#: ../db/db.login/main.c:59
-#, fuzzy
msgid "Username"
-msgstr "nombre"
+msgstr "Nombre de usuario"
#: ../db/db.login/main.c:60 ../db/db.login/main.c:68 ../db/db.login/main.c:77
#: ../db/db.login/main.c:86 ../vector/v.external.out/args.c:20
@@ -902,27 +809,24 @@
msgstr "Configuraciones"
#: ../db/db.login/main.c:67
-#, fuzzy
msgid "Password"
-msgstr "Pase: %d..."
+msgstr "Contraseña"
#: ../db/db.login/main.c:75
-#, fuzzy
msgid "Hostname"
-msgstr "Nombre de prueba"
+msgstr "Nombre de "
#: ../db/db.login/main.c:76 ../db/db.login/main.c:85
msgid "Relevant only for pg and mysql driver"
-msgstr ""
+msgstr "Importante solamente para controladores pg y mysql"
#: ../db/db.login/main.c:84
msgid "Port"
msgstr ""
#: ../db/db.login/main.c:90
-#, fuzzy
msgid "Print connection settings and exit"
-msgstr "Imprimir los parámetros de la conexión actual y salir"
+msgstr "Mostrar la configuración de la conexión y salir"
#: ../db/db.login/main.c:91 ../db/db.connect/main.c:53
#: ../db/db.connect/main.c:58 ../vector/v.external.out/args.c:63
@@ -979,28 +883,25 @@
msgstr "Imposible establecer usuario/contraseña"
#: ../db/db.login/main.c:109
-#, fuzzy, c-format
+#, c-format
msgid "The password was stored in file (%s%cdblogin)"
-msgstr "La contraseña se guardó en archivo"
+msgstr "La contraseña se guardó en archivo (%s%cdblogin)"
#: ../db/db.drivers/main.c:39
-#, fuzzy
msgid "Unable to read dbmscap file"
-msgstr "No se puede leer el archivo de color"
+msgstr "No se ha podido leer archivo dbmscap"
#: ../db/db.drivers/main.c:63
msgid "Full output"
msgstr "Salida completa"
#: ../db/db.drivers/main.c:67
-#, fuzzy
msgid "Print drivers and exit"
-msgstr "imprimir controladores y salir"
+msgstr "Mostrar controladores y salir"
#: ../db/db.drivers/main.c:73
-#, fuzzy
msgid "Lists all database drivers."
-msgstr "Listar todos los controladores de bases de datos."
+msgstr "Enlista todos los controladores de bases de datos."
#: ../db/db.copy/main.c:36 ../db/db.describe/main.c:130
#: ../db/db.createdb/main.c:72 ../db/db.databases/main.c:96
@@ -1047,13 +948,8 @@
msgstr "Copiar una tabla."
#: ../db/db.copy/main.c:40
-#, fuzzy
-msgid ""
-"Either 'from_table' (optionally with 'where') can be used or 'select' "
-"option, but not 'from_table' and 'select' at the same time."
-msgstr ""
-"Copiar una tabla. Se puede usar tanto la opción 'from_table' (opcionalmente "
-"con 'where') como 'select', pero no ambas al mismo tiempo."
+msgid "Either 'from_table' (optionally with 'where') can be used or 'select' option, but not 'from_table' and 'select' at the same time."
+msgstr "Se puede usar tanto la opción 'from_table' (opcionalmente con 'where') como 'select', pero no ambas al mismo tiempo."
#: ../db/db.copy/main.c:46
msgid "Input driver name"
@@ -1081,8 +977,7 @@
#: ../db/db.copy/main.c:87
msgid "Full select statement (only, if 'from_table' and 'where' is not used)"
-msgstr ""
-"Sentencia selección completa (sólo, si no se usan 'from_table' y 'where')"
+msgstr "Sentencia selección completa (sólo, si no se usan 'from_table' y 'where')"
#: ../db/db.copy/main.c:88
msgid "E.g.: SELECT dedek FROM starobince WHERE obec = 'Frimburg'"
@@ -1096,8 +991,7 @@
#: ../db/db.columns/main.c:44 ../db/db.select/main.c:53
#, c-format
msgid "Table <%s> not found in database <%s> using driver <%s>"
-msgstr ""
-"Tabla <%s> no encontrada en la base de datos <%s> usando el controlador <%s>"
+msgstr "Tabla <%s> no encontrada en la base de datos <%s> usando el controlador <%s>"
#: ../db/db.copy/main.c:122
msgid "Either 'from_table' or 'select' option must be given."
@@ -1145,8 +1039,7 @@
#: ../db/db.describe/main.c:108
msgid "Print column names only instead of full column descriptions"
-msgstr ""
-"Imprimir sólo nombres de columna en vez de descripciones completas de columna"
+msgstr "Imprimir sólo nombres de columna en vez de descripciones completas de columna"
#: ../db/db.describe/main.c:113
msgid "Print table structure"
@@ -1161,17 +1054,12 @@
msgstr "Crea una base de datos vacía."
#: ../db/db.databases/main.c:53
-msgid ""
-"Unable to list databases. Try to define correct connection settings by db."
-"login."
-msgstr ""
-"No es posible enlistar bases de datos. Trate de definir correctamente la "
-"configuración de la conexión usando bd.login."
+msgid "Unable to list databases. Try to define correct connection settings by db.login."
+msgstr "No es posible enlistar bases de datos. Trate de definir correctamente la configuración de la conexión usando bd.login."
#: ../db/db.databases/main.c:63
-#, fuzzy
msgid "No databases found"
-msgstr "No se encontraron mapas raster"
+msgstr "No se encontraron bases de datos"
#: ../db/db.databases/main.c:80 ../db/db.databases/main.c:91
#: ../db/db.select/main.c:219 ../db/db.select/main.c:224
@@ -1186,40 +1074,33 @@
msgstr "Conexión"
#: ../db/db.databases/main.c:87
-#, fuzzy
msgid "Location"
-msgstr "Localización: %s\n"
+msgstr "Localización"
#: ../db/db.databases/main.c:88
msgid "Path for SQLite driver, or connection string for PostgreSQL driver"
-msgstr ""
-"Ruta para controlador SQLite, o string de conexión para controlador "
-"PostgreSQL"
+msgstr "Ruta para controlador SQLite, o string de conexión para controlador PostgreSQL"
#: ../db/db.databases/main.c:99
-#, fuzzy
msgid "Lists all databases for a given driver and location."
-msgstr ""
-"Listar todas las bases de datos para un controlador y localización dados."
+msgstr "Lista todas las bases de datos para un controlador y Localización dados."
#: ../db/db.dropdb/main.c:74
-#, fuzzy
msgid "Removes an existing database."
-msgstr "Elimina una base de datos."
+msgstr "Elimina una base de datos existente."
#: ../db/db.tables/main.c:41 ../db/db.connect/main.c:141
msgid "Database connection not defined. Run db.connect."
msgstr "Conexión a base de datos no definida. Ejecute db.connect."
#: ../db/db.tables/main.c:54
-#, fuzzy, c-format
+#, c-format
msgid "Unable to list tables from database <%s>"
-msgstr "No se pueden seleccionar datos de la tabla <%s>"
+msgstr "No ha sido posible enlistar tablas de la base de datos <%s>"
#: ../db/db.tables/main.c:60
-#, fuzzy
msgid "No tables found"
-msgstr "¡No se encontró ninguna capa DXF!"
+msgstr "No se encontraron tablas"
#: ../db/db.tables/main.c:89
msgid "Print tables and exit"
@@ -1234,11 +1115,8 @@
msgstr "Lista todas las tablas para una base de datos dada."
#: ../db/db.connect/main.c:47
-#, fuzzy
msgid "Prints/sets general DB connection for current mapset."
-msgstr ""
-"Imprime/establece la conexión general a la base de datos para el directorio "
-"de mapas actual y sale."
+msgstr "Muestra/establece la conexión general a la base de datos para el Directorio de mapas actual."
#: ../db/db.connect/main.c:51 ../temporal/t.connect/main.c:42
msgid "Print current connection parameters and exit"
@@ -1249,15 +1127,12 @@
msgstr "Sustituir variables en la configuración de la base de datos"
#: ../db/db.connect/main.c:57
-#, fuzzy
msgid "Print current connection parameters using shell style and exit"
+msgstr "Mostrar los parámetros de la conexión actual estilo consola de comandos y salir"
#: ../db/db.connect/main.c:63 ../temporal/t.connect/main.c:48
msgid "Check connection parameters, set if uninitialized, and exit"
-msgstr ""
-"Comprobar parámetros de conexión, establecer si no estan inicializados, y "
-"salir"
+msgstr "Comprobar parámetros de conexión, establecer si no estan inicializados, y salir"
#: ../db/db.connect/main.c:64 ../db/db.connect/main.c:70
#: ../db/db.connect/main.c:75 ../db/db.connect/main.c:79
@@ -1267,17 +1142,15 @@
#: ../temporal/t.connect/main.c:69 ../general/g.gisenv/main.c:66
#: ../general/g.gisenv/main.c:74 ../general/g.gisenv/main.c:84
msgid "Set"
-msgstr ""
+msgstr "Establecer"
#: ../db/db.connect/main.c:68 ../temporal/t.connect/main.c:53
-#, fuzzy
msgid "Set from default settings and exit"
-msgstr "Establecido de la región predeterminada"
+msgstr "Definir a partir de la configuración predeterminada y salir"
#: ../db/db.connect/main.c:69
-#, fuzzy
msgid "Overwrite current settings if already initialized"
-msgstr "Sobrescribir MÁSCARA existente"
+msgstr "Sobreescribir configuración actual si ya se ha inicializado"
#: ../db/db.connect/main.c:91
msgid "Default group of database users to which select privilege is granted"
@@ -1297,7 +1170,7 @@
#: ../db/db.connect/main.c:166
msgid "DB settings already defined, nothing to do"
-msgstr ""
+msgstr "Configuraciones DB ya están definidas, nada qué hacer"
#: ../db/db.connect/main.c:172
msgid "Default driver is not set"
@@ -1456,162 +1329,131 @@
#: ../ps/ps.map/r_info.c:48 ../ps/ps.map/r_vlegend.c:49
#: ../ps/ps.map/r_colortable.c:65
-#, fuzzy
msgid "illegal where request"
-msgstr "Solicitud de borrado no permitida"
+msgstr ""
#: ../ps/ps.map/r_info.c:67 ../ps/ps.map/r_header.c:65
#: ../ps/ps.map/ps_outline.c:87 ../ps/ps.map/getgrid.c:61
#: ../ps/ps.map/getgrid.c:85 ../ps/ps.map/getgrid.c:171
#: ../ps/ps.map/getgrid.c:195
-#, fuzzy
msgid "Unsupported color request"
-msgstr "Petición de color '%s' desconocida"
+msgstr "Solicitud de color no soportada"
#: ../ps/ps.map/r_info.c:69 ../ps/ps.map/r_instructions.c:149
#: ../ps/ps.map/r_instructions.c:464 ../ps/ps.map/r_header.c:67
#: ../ps/ps.map/ps_outline.c:89 ../ps/ps.map/getgrid.c:63
#: ../ps/ps.map/getgrid.c:87 ../ps/ps.map/getgrid.c:173
#: ../ps/ps.map/getgrid.c:197
-#, fuzzy
msgid "illegal color request"
+msgstr "solicitud de color incorrecta"
#: ../ps/ps.map/r_info.c:81
-#, fuzzy
msgid "illegal bgcolor request"
+msgstr "color de fondo (bgcolor) solicitado no admitido"
#: ../ps/ps.map/r_info.c:93 ../ps/ps.map/r_vlegend.c:86
-#, fuzzy
msgid "illegal border color request"
+msgstr "color de borde solicitado no admitido"
#: ../ps/ps.map/r_info.c:103
-#, fuzzy
msgid "illegal mapinfo sub-request"
+msgstr "Sub solicitud de información de mapa no admitida"
#: ../ps/ps.map/r_instructions.c:62
-#, fuzzy
msgid "Data exist after final 'end' instruction!"
-msgstr "¡Existen datos después de la instrucción 'end' final!"
+msgstr "¡Existen datos después de la última instrucción 'end' !"
#: ../ps/ps.map/r_instructions.c:80
-#, fuzzy
msgid "no file specified"
-msgstr "Ninguna regla especificada"
+msgstr "no se especificó ningún archivo"
#: ../ps/ps.map/r_instructions.c:84
-#, fuzzy
msgid "unable to open"
-msgstr "no se puede abrir MÁSCARA"
+msgstr "no ha sido posible abrir"
#: ../ps/ps.map/r_instructions.c:115
-#, fuzzy
msgid "illegal maploc request"
+msgstr "solicitud de maploc no admitida"
#: ../ps/ps.map/r_instructions.c:129 ../ps/ps.map/main.c:220
-#, fuzzy
msgid "illegal copies request"
+msgstr "solicitud de copias no admitida"
#: ../ps/ps.map/r_instructions.c:144 ../ps/ps.map/r_instructions.c:340
-#, fuzzy
msgid "no raster map selected yet"
-msgstr "No se ha especificado ningún mapa raster"
+msgstr "todavía no se ha especificado ningún mapa ráster"
#: ../ps/ps.map/r_instructions.c:160
-#, fuzzy
msgid "illegal value list"
-msgstr "%s: especificación de valor no admitida"
+msgstr "valor de lista no admitido"
#: ../ps/ps.map/r_instructions.c:196
-#, fuzzy
msgid "scalebar is not appropriate for this projection"
-msgstr "Opción Rejilla Geográfica no disponible para la proyección LL"
+msgstr "barra de escala no es apropiada para esta proyección"
#: ../ps/ps.map/r_instructions.c:204
-#, fuzzy
msgid "Bad scalebar length"
-msgstr "Dibujar sólo una barra de escala"
+msgstr "Longitud de la barra de escala inadecuada"
#: ../ps/ps.map/r_instructions.c:220
-#, fuzzy
msgid "illegal text request"
+msgstr "solicitud de texto no admitida"
#: ../ps/ps.map/r_instructions.c:234
-#, fuzzy
msgid "illegal point request"
+msgstr "solicitud de punto no admitida"
#: ../ps/ps.map/r_instructions.c:248
-#, fuzzy
msgid "illegal eps request"
+msgstr "solicitud de eps no admitida"
#: ../ps/ps.map/r_instructions.c:265
-#, fuzzy
msgid "illegal line request"
+msgstr "solicitud de línea no admitida"
#: ../ps/ps.map/r_instructions.c:282
-#, fuzzy
msgid "illegal rectangle request"
+msgstr "solicitud de rectángulo no admitida"
#: ../ps/ps.map/r_instructions.c:293
-#, fuzzy
msgid "illegal comments request"
+msgstr "solicitud de comentarios no admitida"
#: ../ps/ps.map/r_instructions.c:309
-#, fuzzy
msgid "illegal scale request"
+msgstr "solicitud de escala no admitida"
#: ../ps/ps.map/r_instructions.c:369
-#, fuzzy
msgid "group not found"
-msgstr ""
-"\n"
-" grupo <%s> no encontrado"
+msgstr "grupo no encontrado"
#: ../ps/ps.map/r_instructions.c:411
-#, fuzzy
msgid "illegal grid spacing"
-msgstr "Deshabilitar el dibujo de la cuadrícula"
+msgstr "solicitud de espaciado de malla no admitida"
#: ../ps/ps.map/r_instructions.c:422
-#, fuzzy
msgid "geogrid is not available for this projection"
+msgstr "geogrid no está disponible para esta proyección"
#: ../ps/ps.map/r_instructions.c:432
msgid "illegal geo-grid spacing"
msgstr "inválido espaciado de la geo-malla"
#: ../ps/ps.map/r_instructions.c:469
-#, fuzzy
msgid "illegal request"
+msgstr "solicitud no admitida"
#: ../ps/ps.map/main.c:93
-#, fuzzy
msgid "postscript"
-msgstr "PostScript"
+msgstr "postscript"
#: ../ps/ps.map/main.c:94
-#, fuzzy
msgid "printing"
-msgstr "Escribiendo %s"
+msgstr "mostrando"
#: ../ps/ps.map/main.c:95
-#, fuzzy
msgid "Produces hardcopy PostScript map output."
-msgstr "Utilidad de salida de mapas PostScript Hardcopy."
+msgstr "Genera salida PostScript de mapas en papel."
#: ../ps/ps.map/main.c:99
msgid "Rotate plot 90 degrees"
@@ -1624,16 +1466,12 @@
#: ../locale/scriptstrings/v.unpack_to_translate.c:11
#: ../raster/r.univar/r.univar_main.c:42 ../raster/r.kappa/main.c:90
#: ../raster/r.kappa/main.c:98
-#, fuzzy
msgid "Output settings"
-msgstr "general, configuraciones"
+msgstr "Configuraciones de salida"
#: ../ps/ps.map/main.c:105
-#, fuzzy
msgid "List paper formats (name width height left right top bottom(margin))"
-msgstr ""
-"Listar formatos de papel ( nombre anchura altura izquierda derecha arriba "
-"abajo (margen) )"
+msgstr "Enlistar formatos de papel (nombre anchura altura izquierda derecha arriba abajo (margen))"
#: ../ps/ps.map/main.c:107 ../ps/ps.map/main.c:120
msgid "Utility"
@@ -1644,33 +1482,29 @@
msgstr "Crear archivo EPS (PostScript encapsulado) en vez de PostScript"
#: ../ps/ps.map/main.c:118
-msgid ""
-"Describe map-box's position on the page and exit (inches from top-left of "
-"paper)"
-msgstr ""
+msgid "Describe map-box's position on the page and exit (inches from top-left of paper)"
+msgstr "Describir posición de cajas de mapa en la página y salir (pulgadas desde borde superior izquierdo del papel)"
#: ../ps/ps.map/main.c:123
-#, fuzzy
msgid "File containing mapping instructions"
-msgstr "Archivo que contiene las firmas iniciales"
+msgstr "Archivo que contiene las instrucciones para el mapa"
#: ../ps/ps.map/main.c:124
msgid "Use '-' to enter instructions from keyboard)"
msgstr "Use '-' para ingresar instrucciones desde el teclado)"
#: ../ps/ps.map/main.c:127
-#, fuzzy
msgid "Name for PostScript output file"
-msgstr "Archivo PostScript de salida"
+msgstr "Nombre de archivo PostScript de salida"
#: ../ps/ps.map/main.c:133
msgid "Number of copies to print"
msgstr "Número de copias a imprimir"
#: ../ps/ps.map/main.c:205
-#, fuzzy, c-format
+#, c-format
msgid "Unable to open file '%s': %s"
+msgstr "No ha sido posible abrir archivo '%s': %s"
#: ../ps/ps.map/main.c:213 ../ps/ps.map/main.c:232
#: ../vector/v.univar/main.c:147 ../vector/v.to.db/parse.c:141
@@ -1684,19 +1518,17 @@
"\t(%s)"
#: ../ps/ps.map/main.c:273
-#, fuzzy, c-format
+#, c-format
msgid "PostScript file '%s' successfully written."
-msgstr "Archivo PostScript [%s] escrito con éxito."
+msgstr "Archivo PostScript '%s' escrito exitosamente."
#: ../ps/ps.map/r_vlegend.c:97
-#, fuzzy
msgid "illegal vlegend sub-request"
+msgstr "Sub solicitud de vlegend no admitida"
#: ../ps/ps.map/r_header.c:77
-#, fuzzy
msgid "illegal header sub-request"
+msgstr "Sub solicitud de encabezado no admitida"
#: ../ps/ps.map/ps_outline.c:43
#, c-format
@@ -1705,14 +1537,13 @@
#: ../ps/ps.map/ps_outline.c:100 ../ps/ps.map/r_colortable.c:73
#: ../ps/ps.map/r_colortable.c:89
-#, fuzzy
msgid "illegal width request"
+msgstr "solicitud de anchura no admitida"
#: ../ps/ps.map/ps_outline.c:107
#, fuzzy
msgid "illegal outline sub-request"
+msgstr "Sub solicitud de no admitida"
#: ../ps/ps.map/ps_vareas.c:67 ../ps/ps.map/ps_vareas.c:78
#: ../ps/ps.map/ps_vlines.c:84
@@ -1731,8 +1562,7 @@
#: ../ps/ps.map/ps_vpoints.c:201
#, c-format
msgid "Invalid RGB color definition in column <%s> for category [%d]"
-msgstr ""
-"Definición de color RGB no válida en la columna <%s> para la categoría [%d]"
+msgstr "Definición de color RGB no válida en la columna <%s> para la categoría [%d]"
#: ../ps/ps.map/ps_vareas.c:161 ../ps/ps.map/ps_vlines.c:56
#: ../ps/ps.map/ps_vpoints.c:71
@@ -1762,17 +1592,14 @@
#: ../raster/r.horizon/main.c:538 ../raster/r.sun/main.c:753
#: ../display/d.grid/plot.c:554 ../display/d.where/main.c:113
msgid "Can't get projection key values of current location"
-msgstr ""
-"No se pueden obtener los valores clave de la proyección de la localización "
-"actual"
+msgstr "No se pueden obtener los valores clave de la proyección de la localización actual"
#: ../ps/ps.map/do_geogrid.c:278 ../raster/r.latlong/main.c:114
#: ../raster/r.horizon/main.c:548 ../raster/r.sun/main.c:763
#: ../display/d.grid/plot.c:561 ../display/d.grid/plot.c:588
#: ../display/d.where/main.c:120 ../display/d.where/main.c:146
msgid "Unable to set up lat/long projection parameters"
-msgstr ""
-"No se pueden establecer los parámetros de la proyección latitud/longitud"
+msgstr "No se pueden establecer los parámetros de la proyección latitud/longitud"
#: ../ps/ps.map/do_psfiles.c:20
#, c-format
@@ -1790,23 +1617,20 @@
msgstr "Leyendo archivo de puntos vectoriales <%s en %s> ..."
#: ../ps/ps.map/do_scalebar.c:192
-#, fuzzy
msgid "meters"
-msgstr "Parámetros"
+msgstr "metros"
#: ../ps/ps.map/do_scalebar.c:194
-#, fuzzy
msgid "kilometers"
-msgstr "Filtro"
+msgstr "kilómetros"
#: ../ps/ps.map/do_scalebar.c:196
msgid "feet"
msgstr "pie"
#: ../ps/ps.map/do_scalebar.c:198
-#, fuzzy
msgid "miles"
-msgstr "Archivos"
+msgstr "millas"
#: ../ps/ps.map/do_scalebar.c:200
msgid "nautical miles"
@@ -1821,38 +1645,32 @@
msgstr "No se puede leer el símbolo. Se usa el icono predeterminado."
#: ../ps/ps.map/r_colortable.c:81
-#, fuzzy
msgid "illegal height request"
+msgstr "solicitud de altura no admitida"
#: ../ps/ps.map/r_colortable.c:106
-#, fuzzy
msgid "illegal range request"
+msgstr "solicitud de rango no admitida"
#: ../ps/ps.map/r_colortable.c:122
-#, fuzzy
msgid "illegal columns request"
+msgstr "solicitud de columnas no admitida"
#: ../ps/ps.map/r_colortable.c:141
-#, fuzzy
msgid "Unsupported color request (colortable)"
-msgstr "Formado de salida no soportado"
+msgstr "Solicitud de color no soportada (tabla de colores)"
#: ../ps/ps.map/r_colortable.c:143
msgid "illegal color request (colortable)"
msgstr "Solicitud de color inválida (tabla de colores, colortable)"
#: ../ps/ps.map/r_colortable.c:170
-#, fuzzy
msgid "illegal colortable sub-request"
+msgstr "Sub solicitud de colortable no admitida"
#: ../ps/ps.map/r_colortable.c:181
-#, fuzzy
msgid "No raster selected for colortable!"
-msgstr "No hay registros seleccionados de la tabla <%s>"
+msgstr "¡No se ha seleccionado ningún ráster para tabla de colores!"
#: ../ps/ps.map/ps_raster.c:42
msgid "Can't create temporary PostScript mask file."
@@ -1870,29 +1688,25 @@
msgstr "Leyendo el mapa ráster <%s>..."
#: ../ps/ps.map/ps_raster.c:105
-#, fuzzy, c-format
+#, c-format
msgid "Reading raster maps in group <%s>..."
-msgstr "Leyendo mapas ráster en el grupo <%s> ..."
+msgstr "Leyendo mapas ráster en grupo <%s> ..."
#: ../ps/ps.map/getgrid.c:95 ../ps/ps.map/getgrid.c:206
-#, fuzzy
msgid "illegal numbers request"
+msgstr "solicitud de números no admitida"
#: ../ps/ps.map/getgrid.c:126 ../ps/ps.map/getgrid.c:234
-#, fuzzy
msgid "illegal grid width request"
+msgstr "solicitud de tamaño de malla no admitida"
#: ../ps/ps.map/getgrid.c:132
-#, fuzzy
msgid "illegal request (grid)"
+msgstr "solicitud incorrecta (malla)"
#: ../ps/ps.map/getgrid.c:240
-#, fuzzy
msgid "illegal request (geogrid)"
+msgstr "solicitud no admitida (geomalla)"
#: ../ps/ps.map/catval.c:48 ../ps/ps.map/catval.c:110 ../ps/ps.map/catval.c:176
#: ../vector/v.vol.rst/user1.c:95 ../vector/v.class/main.c:111
@@ -1985,8 +1799,7 @@
#: ../ps/ps.map/do_labels.c:44
#, c-format
msgid "Can't open label file <%s> in mapset <%s>"
-msgstr ""
-"No se puede abrir el archivo de etiquetas <%s> en el directorio de mapas <%s>"
+msgstr "No se puede abrir el archivo de etiquetas <%s> en el directorio de mapas <%s>"
#: ../ps/ps.map/do_labels.c:48
#, c-format
@@ -2004,9 +1817,7 @@
#: ../ps/ps.map/do_labels.c:162
msgid "Text labels: 'fontsize' given so ignoring 'size'"
-msgstr ""
-"Etiquetas de texto: 'tamaño de fuente' proporcionado, por lo que se ignora "
-"'tamaño'"
+msgstr "Etiquetas de texto: 'tamaño de fuente' proporcionado, por lo que se ignora 'tamaño'"
#: ../ps/ps.map/ps_fclrtbl.c:46 ../ps/ps.map/ps_clrtbl.c:35
#, c-format
@@ -2019,8 +1830,7 @@
#: ../ps/ps.map/ps_fclrtbl.c:64
msgid "A floating point colortable must contain a range of values"
-msgstr ""
-"Una tabla de color de coma flotante debe contener un intervalo de valores"
+msgstr "Una tabla de color de coma flotante debe contener un intervalo de valores"
#: ../ps/ps.map/ps_fclrtbl.c:69 ../ps/ps.map/ps_clrtbl.c:44
msgid "Unable to read colors for colorbar"
@@ -2029,14 +1839,12 @@
#: ../ps/ps.map/ps_fclrtbl.c:97 ../ps/ps.map/ps_fclrtbl.c:102
#: ../ps/ps.map/ps_clrtbl.c:69
msgid "Colorbar y location beyond page margins. Adjusting."
-msgstr ""
-"Posición Y de la barra de colores fuera de los márgenes de página. Ajustando."
+msgstr "Posición Y de la barra de colores fuera de los márgenes de página. Ajustando."
#: ../ps/ps.map/ps_fclrtbl.c:108 ../ps/ps.map/ps_fclrtbl.c:113
#: ../ps/ps.map/ps_clrtbl.c:75
msgid "Colorbar x location beyond page margins. Adjusting."
-msgstr ""
-"Posición X de la barra de colores fuera de los márgenes de página. Ajustando."
+msgstr "Posición X de la barra de colores fuera de los márgenes de página. Ajustando."
#: ../ps/ps.map/ps_vpoints.c:177
#, c-format
@@ -2044,9 +1852,8 @@
msgstr "Atributo de tamaño no válido [%.3f] para la categoría [%d]"
#: ../ps/ps.map/r_plt.c:173
-#, fuzzy
msgid "Can't open eps file"
-msgstr "No se puede abrir el archivo de reglas <%s>"
+msgstr "No se puede abrir archivo eps"
#: ../ps/ps.map/ps_clrtbl.c:39 ../display/d.histogram/main.c:174
#, c-format
@@ -2054,34 +1861,27 @@
msgstr "Archivo de categoría para <%s> no disponible"
#: ../ps/ps.map/ps_clrtbl.c:54
-#, fuzzy
-msgid ""
-"Your cats/ file is invalid. A cats/ file with categories and labels is "
-"required for 'colortable' when using categorical legends; see the r.category "
-"help page. Colortable creation has been skipped."
+msgid "Your cats/ file is invalid. A cats/ file with categories and labels is required for 'colortable' when using categorical legends; see the r.category help page. Colortable creation has been skipped."
msgstr ""
-"Su archivo de categorías no es válido. Se requiere un archivo de categorías "
-"y etiquetas para la 'tabla de color' cuando se usan rásters CELL. No se "
-"asignará ninguna tabla de colores a este archivo PostScript de salida."
#: ../ps/ps.map/r_group.c:29
msgid "Can't get group information"
msgstr "No se puede obtener información del grupo"
#: ../ps/ps.map/eps.c:18
-#, fuzzy, c-format
+#, c-format
msgid "Can't open eps file <%s>"
+msgstr "No se puede abrir archivo eps <%s>"
#: ../ps/ps.map/eps.c:37
-#, fuzzy, c-format
+#, c-format
msgid "Bounding box in eps file <%s> was not found"
-msgstr "Archivo 3Dview <%s> no encontrado"
+msgstr "Bounding box en archivo eps <%s> no encontrado"
#: ../ps/ps.map/map_setup.c:82
-#, fuzzy, c-format
+#, c-format
msgid "Scale set to %s"
-msgstr "Escala fijada a %s."
+msgstr "Escala definida como %s"
#: ../ps/ps.map/do_masking.c:23
msgid "Can't open temporary PostScript mask file."
@@ -2138,9 +1938,9 @@
msgstr "Color del atributo no definido, utilizando por defecto <%s>"
#: ../misc/m.nviz.image/surface.c:137
-#, fuzzy, c-format
+#, c-format
msgid "Missing color attribute for surface %d"
-msgstr "Falta atributode topografía para superficie %d"
+msgstr "Falta atributo de color para superficie %d"
#: ../misc/m.nviz.image/surface.c:217
#, c-format
@@ -2156,9 +1956,8 @@
#: ../visualization/ximgview/main.c:294
#: ../locale/scriptstrings/r.shade_to_translate.c:6
#: ../locale/scriptstrings/d.shade_to_translate.c:6
-#, fuzzy
msgid "visualization"
-msgstr "Ecualización de histograma"
+msgstr "visualización"
#: ../misc/m.nviz.image/main.c:51 ../misc/m.nviz.script/main.c:70
#: ../visualization/ximgview/main.c:291
@@ -2425,28 +2224,20 @@
#: ../raster/r.colors.out/raster3d_main.c:46
#: ../raster/r.to.rast3elev/main.c:363 ../raster/r.colors/edit_colors.c:59
#: ../raster/r.univar/r3.univar_main.c:98
-#, fuzzy
msgid "raster3d"
-msgstr "ráster"
+msgstr "ráster3d"
#: ../misc/m.nviz.image/main.c:55
-#, fuzzy
msgid "Creates a 3D rendering of GIS data."
-msgstr "Crear una línea 3D a partir de 3 columnas de datos"
+msgstr "Crea una renderización 3D de datos SIG."
#: ../misc/m.nviz.image/main.c:56
-#, fuzzy
-msgid ""
-"Renders surfaces (raster data), 2D/3D vector data, and volumes (3D raster "
-"data) in 3D."
-msgstr ""
-"Renderiza superficies (datos raster), datos vectoriales 2D/3D, y volúmenes "
-"(datos raster 3D) en un espacio 3D."
+msgid "Renders surfaces (raster data), 2D/3D vector data, and volumes (3D raster data) in 3D."
+msgstr "Renderiza superficies (datos ráster), datos vectoriales 2D/3D, y volúmenes (datos ráster 3D) en 3D."
#: ../misc/m.nviz.image/main.c:82
-#, fuzzy
msgid "Unable to render data"
+msgstr "No ha sido posible renderizar datos"
#: ../misc/m.nviz.image/main.c:141
#, c-format
@@ -2456,9 +2247,7 @@
#: ../misc/m.nviz.image/main.c:153
#, c-format
msgid "Viewpoint height not given, using calculated value %.0f"
-msgstr ""
-"Altura del punto de observación no facilitada, utilizando valor calculado "
-"%.0f"
+msgstr "Altura del punto de observación no facilitada, utilizando valor calculado %.0f"
#: ../misc/m.nviz.image/main.c:239
msgid "Unsupported output format"
@@ -2470,9 +2259,9 @@
msgstr "Archivo <%s> creado"
#: ../misc/m.nviz.image/cplane.c:40
-#, fuzzy, c-format
+#, c-format
msgid "Cutting plane number <%d> not found"
-msgstr "No se encuentra el mapa ráster de latitudes de entada <%s>"
+msgstr "Plano de corte número <%d> no encontrado"
#: ../misc/m.nviz.image/args.c:51
msgid "Use draw mode for all loaded surfaces"
@@ -2521,9 +2310,7 @@
#: ../misc/m.nviz.image/args.c:142
msgid "Constant elevation value(s) to use instead of a raster DEM"
-msgstr ""
-"Valor(es) de elevación constante(s) a usarse en vez de un modelo digital de "
-"elevación ráster"
+msgstr "Valor(es) de elevación constante(s) a usarse en vez de un modelo digital de elevación ráster"
#: ../misc/m.nviz.image/args.c:149
msgid "Name of raster map(s) for color"
@@ -2554,9 +2341,8 @@
msgstr "Valor(es) de brillo"
#: ../misc/m.nviz.image/args.c:208
-#, fuzzy
msgid "Name of raster map(s) for emission"
-msgstr "Nombre del primer mapa ráster a mezclar"
+msgstr "Nombre del primer mapa(s) ráster para emisión"
#: ../misc/m.nviz.image/args.c:218
msgid "Emission value(s)"
@@ -2581,9 +2367,8 @@
msgstr "Resolución correcta"
#: ../misc/m.nviz.image/args.c:253
-#, fuzzy
msgid "Coarse resolution"
-msgstr "Correlación"
+msgstr "Resolución gruesa"
#: ../misc/m.nviz.image/args.c:264
msgid "Draw style"
@@ -2599,9 +2384,8 @@
msgstr "Color de línea"
#: ../misc/m.nviz.image/args.c:297
-#, fuzzy
msgid "Surface position"
-msgstr "Proyeccion del origen"
+msgstr "Posición de superficie"
#: ../misc/m.nviz.image/args.c:309
#, fuzzy
@@ -2617,28 +2401,24 @@
msgstr "Líneas vectoriales"
#: ../misc/m.nviz.image/args.c:317 ../misc/m.nviz.image/args.c:410
-#, fuzzy
msgid "Layer number or name for thematic mapping"
-msgstr "Nombre del mapa vectorial de entrada"
+msgstr "Número de capa o nombre para mapeo temático"
#: ../misc/m.nviz.image/args.c:329
msgid "Vector line width"
msgstr "Ancho de línea vectorial"
#: ../misc/m.nviz.image/args.c:337 ../misc/m.nviz.image/args.c:449
-#, fuzzy
msgid "Name of width definition column"
-msgstr "Nombre de la columna"
+msgstr "Nombre de la columna de definición de anchura"
#: ../misc/m.nviz.image/args.c:345
msgid "Vector line color"
msgstr "Color de línea vectorial"
#: ../misc/m.nviz.image/args.c:353 ../misc/m.nviz.image/args.c:465
-#, fuzzy
msgid "Name of color definition column"
-msgstr ""
-"Nombre de la columna de definición de color (para usar con la opción -a)"
+msgstr "Nombre de la columna de definición de color"
#: ../misc/m.nviz.image/args.c:364
msgid "Vector line display mode"
@@ -2653,14 +2433,12 @@
msgstr "Altura de la línea vectorial"
#: ../misc/m.nviz.image/args.c:390
-#, fuzzy
msgid "Vector lines position"
-msgstr "Ancho de línea vectorial"
+msgstr "Posición de lineas vectoriales"
#: ../misc/m.nviz.image/args.c:402
-#, fuzzy
msgid "Name of point vector overlay map(s)"
-msgstr "Las líneas/áreas vectoriales solapan el archivo(s)"
+msgstr "Nombre de mapa(s) puntos vectoriales a superponer"
#: ../misc/m.nviz.image/args.c:403 ../misc/m.nviz.image/args.c:411
#: ../misc/m.nviz.image/args.c:423 ../misc/m.nviz.image/args.c:432
@@ -2672,14 +2450,12 @@
msgstr "Puntos vectoriales"
#: ../misc/m.nviz.image/args.c:422
-#, fuzzy
msgid "Icon size (map units)"
-msgstr "Tamaño de etiqueta (en unidades de mapa)"
+msgstr "Tamaño de ícono (en unidades de mapa)"
#: ../misc/m.nviz.image/args.c:430
-#, fuzzy
msgid "Name of size definition column"
+msgstr "Nombre de la columna de definición de tamaño"
#: ../misc/m.nviz.image/args.c:441
msgid "Icon width"
@@ -2694,23 +2470,20 @@
msgstr "Marcador de iconos"
#: ../misc/m.nviz.image/args.c:486
-#, fuzzy
msgid "Name of marker definition column"
-msgstr "Nombre de la columna Arc cost"
+msgstr "Nombre de la columna de definición de marcador"
#: ../misc/m.nviz.image/args.c:497
-#, fuzzy
msgid "3D vector point display mode"
-msgstr "Modo de visualización de la línea vectorial"
+msgstr "Modo de visualización de puntos vectoriales 3D"
#: ../misc/m.nviz.image/args.c:499
msgid "surface;drape on raster surface;3D;place at 3D point's z-elevation"
msgstr ""
#: ../misc/m.nviz.image/args.c:512
-#, fuzzy
msgid "Vector points position"
-msgstr "Puntos vectoriales"
+msgstr "Posición de puntos vectoriales"
#: ../misc/m.nviz.image/args.c:529
msgid "Viewpoint position (x,y model coordinates)"
@@ -2762,57 +2535,48 @@
msgstr "Volume shading"
#: ../misc/m.nviz.image/args.c:629
-#, fuzzy
msgid "Volume position"
+msgstr "Posición de volumen"
#: ../misc/m.nviz.image/args.c:640
-#, fuzzy
msgid "Volume resolution"
+msgstr "Resolución de volumen"
#: ../misc/m.nviz.image/args.c:651
msgid "Isosurface level"
msgstr "Nivel de isosuperficies"
#: ../misc/m.nviz.image/args.c:660
-#, fuzzy
msgid "Name of volume for isosurface color"
-msgstr "Archivo ráster para superficie"
+msgstr "Nombre del volumen para color de isosuperficies"
#: ../misc/m.nviz.image/args.c:668
-#, fuzzy
msgid "Isosurface color"
-msgstr "Nivel de isosuperficies"
+msgstr "Color de isosuperficies"
#: ../misc/m.nviz.image/args.c:677
-#, fuzzy
msgid "Name of 3D raster map(s) for isosurface transparency"
-msgstr "Nombre del mapa raster(s) para transparencia"
+msgstr "Nombre de mapa(s) raster 3D para transparecia de isosuperficies"
#: ../misc/m.nviz.image/args.c:688
-#, fuzzy
msgid "Transparency value(s)for isosurfaces"
-msgstr "Valor(es) de transparencia"
+msgstr "Valor(es) de transparencia para isosuperficies"
#: ../misc/m.nviz.image/args.c:697
-#, fuzzy
msgid "Name of 3D raster map(s) for shininess"
-msgstr "Nombre del mapa(s) raster para el brillo"
+msgstr "Nombre de mapa(s) ráster 3D para el brillo"
#: ../misc/m.nviz.image/args.c:708
-#, fuzzy
msgid "Shininess value(s) for isosurfaces"
-msgstr "Valor(es) de brillo"
+msgstr "Valor(es) de brillo para isosuperficies"
#: ../misc/m.nviz.image/args.c:715
msgid "Toggles normal direction of all isosurfaces (changes light effect)"
msgstr ""
#: ../misc/m.nviz.image/args.c:721
-#, fuzzy
msgid "Draw volume box"
-msgstr "Valor ráster"
+msgstr "Dibujar caja de volumen"
#: ../misc/m.nviz.image/args.c:733
msgid "Volume slice parallel to given axis (x, y, z)"
@@ -2850,23 +2614,21 @@
#: ../misc/m.nviz.image/args.c:810
msgid "Cutting plane index (0-5)"
-msgstr ""
+msgstr "Índice de plano de corte (0-5)"
#: ../misc/m.nviz.image/args.c:811 ../misc/m.nviz.image/args.c:820
#: ../misc/m.nviz.image/args.c:829 ../misc/m.nviz.image/args.c:841
#: ../misc/m.nviz.image/args.c:852
-#, fuzzy
msgid "Cutting planes"
-msgstr "Calculando quantiles"
+msgstr "Planos de corte"
#: ../misc/m.nviz.image/args.c:819
-#, fuzzy
msgid "Cutting plane x,y,z coordinates"
-msgstr "Coordenadas inicial y final"
+msgstr "Coordenadas x,y,z de plano de corte"
#: ../misc/m.nviz.image/args.c:831
msgid "Cutting plane rotation along the vertical axis"
-msgstr ""
+msgstr "Rotación de plano de corte a lo largo del eje vertical"
#: ../misc/m.nviz.image/args.c:842
#, fuzzy
@@ -2875,21 +2637,19 @@
#: ../misc/m.nviz.image/args.c:854
msgid "Cutting plane color (between two surfaces)"
-msgstr ""
+msgstr "Color de plano de corte (entre dos superficies)"
#: ../misc/m.nviz.image/args.c:870
-#, fuzzy
msgid "North-West edge"
-msgstr "borde Norte=%f"
+msgstr "Borde Norte-Este"
#: ../misc/m.nviz.image/args.c:871
msgid "North-East edge"
msgstr "Norde Norte-Este"
#: ../misc/m.nviz.image/args.c:872
-#, fuzzy
msgid "South-West edge"
-msgstr "borde Sur=%f"
+msgstr "Borde Sur-Oeste"
msgid "South-East edge"
@@ -2914,28 +2674,21 @@
msgstr "Altura de la franja"
#: ../misc/m.nviz.image/args.c:903
-msgid ""
-"Place north arrow at given position \t(in screen coordinates from bottom "
-"left corner)"
-msgstr ""
-"Poner la flecha al norte en una posición dada \t(en coordenadas de la "
-"pantalla desde la esquina inferior izquierda)"
+msgid "Place north arrow at given position \t(in screen coordinates from bottom left corner)"
+msgstr "Poner la flecha al norte en una posición dada \t(en coordenadas de la pantalla desde la esquina inferior izquierda)"
#: ../misc/m.nviz.image/args.c:905 ../misc/m.nviz.image/args.c:915
#: ../misc/m.nviz.image/args.c:922
-#, fuzzy
msgid "Decoration"
+msgstr "Decoración"
#: ../misc/m.nviz.image/args.c:914
-#, fuzzy
msgid "North arrow size (in map units)"
+msgstr "Tamaño de flecha de Norte (en unidades de mapa)"
#: ../misc/m.nviz.image/args.c:921
-#, fuzzy
msgid "North arrow color"
-msgstr "Dibujar sólo una flecha de Norte"
+msgstr "Color de flecha de Norte"
#: ../misc/m.nviz.image/args.c:973
#, c-format
@@ -2946,38 +2699,38 @@
#: ../misc/m.nviz.image/args.c:1023 ../misc/m.nviz.image/args.c:1029
#: ../misc/m.nviz.image/args.c:1035 ../misc/m.nviz.image/args.c:1041
#: ../misc/m.nviz.image/args.c:1047
-#, fuzzy, c-format
+#, c-format
msgid "Inconsistent number of attributes (<%s/%s>: %d vs. <%s>: %d)"
-msgstr "Número de atributos incoherente(<%s/%s> %d: <%s> %d)"
+msgstr "Número inconsistente de atributos (<%s/%s>: %d vs. <%s>: %d)"
#: ../misc/m.nviz.image/args.c:1058
-#, fuzzy, c-format
+#, c-format
msgid "Inconsistent number of attributes (<%s>: %d vs. <%s>: %d x 3)"
-msgstr "Número de atributos incoherente (<%s> %d: <%s> %d)"
+msgstr "Número inconsistente de atributos (<%s>: %d vs. <%s>: %d x 3)"
#: ../misc/m.nviz.image/args.c:1064 ../misc/m.nviz.image/args.c:1070
#: ../misc/m.nviz.image/args.c:1082 ../misc/m.nviz.image/args.c:1089
#: ../misc/m.nviz.image/args.c:1096 ../misc/m.nviz.image/args.c:1103
#: ../misc/m.nviz.image/args.c:1110 ../misc/m.nviz.image/args.c:1122
#: ../misc/m.nviz.image/args.c:1127 ../misc/m.nviz.image/args.c:1164
-#, fuzzy, c-format
+#, c-format
msgid "Inconsistent number of attributes (<%s>: %d vs. <%s>: %d)"
+msgstr "Número inconsistente de atributos (<s/%s>: %d vs. <%s>: %d)"
#: ../misc/m.nviz.image/args.c:1146 ../misc/m.nviz.image/args.c:1156
-#, fuzzy, c-format
+#, c-format
msgid "Inconsistent number of attributes (<%s>: %d vs. <%s>: %d, <%s>: %d)"
-msgstr "Número de atributos incoherente (<%s/%s> %d: <%s> %d, <%s> %d"
+msgstr "Número inconsistente de atributos (<%s>: %d vs. <%s>: %d, <%s>: %d)"
#: ../misc/m.nviz.image/args.c:1171
-#, fuzzy, c-format
+#, c-format
msgid "Inconsistent number of attributes (<%s>: %d vs. <%s>: %d x 6)"
+msgstr "Número inconsistente de atributos (<%s>: %d vs. <%s>: %d x 6)"
#: ../misc/m.nviz.image/args.c:1183
-#, fuzzy, c-format
+#, c-format
msgid "Inconsistent number of attributes (<%s/%s>: %d vs. <%s>: %d, <%s>: %d)"
+msgstr "Número inconsistente de atributos (<%s/%s>: %d vs. <%s>: %d, <%s>: %d)"
#: ../misc/m.nviz.image/volume.c:42 ../misc/m.nviz.image/volume.c:133
#, c-format
@@ -2990,9 +2743,9 @@
msgstr "Error tokenize '%s'"
#: ../misc/m.nviz.image/volume.c:103 ../misc/m.nviz.image/volume.c:271
-#, fuzzy, c-format
+#, c-format
msgid "Volume set number %d is not available"
-msgstr "Archivo de color para <%s> no disponible"
+msgstr "Número %d de conjunto de volumen no está disponible"
#: ../misc/m.nviz.image/volume.c:108
#, c-format
@@ -3003,14 +2756,14 @@
#: ../misc/m.nviz.image/volume.c:153 ../misc/m.nviz.image/volume.c:172
#: ../misc/m.nviz.image/volume.c:182 ../misc/m.nviz.image/volume.c:195
#: ../misc/m.nviz.image/volume.c:205
-#, fuzzy, c-format
+#, c-format
msgid "Unable to set isosurface (%d) attribute (%d) of volume %d"
-msgstr "No se pueden seleccionar los atributos de los puntos de <%s>"
+msgstr "No ha sido posible definir isosuperficies (%d) atributo (%d) de volumen %d"
#: ../misc/m.nviz.image/volume.c:267
-#, fuzzy, c-format
+#, c-format
msgid "Wrong name for axis: %s"
-msgstr "Formato de entrada incorrecto: %s"
+msgstr "Nombre incorrecto para eje: %s"
#: ../misc/m.nviz.image/volume.c:276
#, fuzzy, c-format
@@ -3117,29 +2870,25 @@
#: ../misc/m.nviz.image/vector.c:300 ../misc/m.nviz.image/vector.c:309
#: ../misc/m.nviz.image/vector.c:319 ../misc/m.nviz.image/vector.c:329
-#, fuzzy, c-format
+#, c-format
msgid "Column <%s> in table <%s> not found"
+msgstr "No se encontró columna <%s> en tabla <%s>"
#: ../misc/m.nviz.image/vector.c:304
-#, fuzzy
msgid "Data type of color column must be character"
-msgstr "El tipo de datos de la columna clave debe ser entero"
+msgstr "Tipo de datos de la columna color debe ser character"
#: ../misc/m.nviz.image/vector.c:314
-#, fuzzy
msgid "Data type of size column must be numeric"
+msgstr "Tipo de datos de la columna tamaño debe ser numeric"
#: ../misc/m.nviz.image/vector.c:324
-#, fuzzy
msgid "Data type of width column must be numeric"
+msgstr "Tipo de datos de la columna anchura debe ser numeric"
#: ../misc/m.nviz.image/vector.c:335
-#, fuzzy
msgid "Data type of marker column must be character"
+msgstr "Tipo de datos de la columna marcador debe ser character"
#: ../misc/m.transform/main.c:92
#, c-format
@@ -3204,15 +2953,13 @@
#: ../raster/r.proj/main.c:146 ../imagery/i.pca/main.c:73
#: ../imagery/i.fft/main.c:79 ../imagery/i.ifft/main.c:78
#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:390
-#, fuzzy
msgid "transformation"
-msgstr "vectorial, transformación"
+msgstr "transformación"
#: ../misc/m.transform/main.c:320
#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:393
msgid "Computes a coordinate transformation based on the control points."
-msgstr ""
-"Procesa una transformación de coordenadas basada en los puntos de control."
+msgstr "Procesa una transformación de coordenadas basada en los puntos de control."
#: ../misc/m.transform/main.c:329
msgid "Rectification polynomial order"
@@ -3220,21 +2967,18 @@
#: ../misc/m.transform/main.c:340
#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:406
-#, fuzzy
msgid "point index"
-msgstr "Mostrar índice"
+msgstr "índice puntual"
#: ../misc/m.transform/main.c:341
#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:407
-#, fuzzy
msgid "source coordinates"
-msgstr "Una o más coordenadas"
+msgstr "coordenadas de fuente"
#: ../misc/m.transform/main.c:342
#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:408
-#, fuzzy
msgid "destination coordinates"
-msgstr "Coordenadas de cuadrícula E del mapa"
+msgstr "coordenadas de destino"
#: ../misc/m.transform/main.c:343
#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:409
@@ -3297,15 +3041,13 @@
#: ../misc/m.transform/main.c:366
#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:433
-#, fuzzy
msgid "Target east,north coordinates to local x,y"
-msgstr "Coordenadas inferior izquierda Este y Norte del mapa"
+msgstr "Coordenadas de destino este,norte para locales x,y"
#: ../misc/m.transform/main.c:370
#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:437
-#, fuzzy
msgid "Display transform matrix coefficients"
-msgstr "Mapa para el coeficiente X"
+msgstr "Mostrar coeficientes de matriz de transformación"
#: ../misc/m.cogo/main.c:226 ../vector/v.distance/main.c:91
#: ../locale/scriptstrings/r.grow_to_translate.c:3
@@ -3315,12 +3057,8 @@
msgstr "distancia"
#: ../misc/m.cogo/main.c:227
-msgid ""
-"A simple utility for converting bearing and distance measurements to "
-"coordinates and vice versa."
-msgstr ""
-"Una utility sencilla para convertir medidas de distancia y de marcación -"
-"bearing- en coordenades y viceversa."
+msgid "A simple utility for converting bearing and distance measurements to coordinates and vice versa."
+msgstr "Una utility sencilla para convertir medidas de distancia y de marcación -bearing- en coordenades y viceversa."
#: ../misc/m.cogo/main.c:229
msgid "It assumes a cartesian coordinate system"
@@ -3371,7 +3109,7 @@
#: ../misc/m.nviz.script/main.c:86
msgid "Prefix of output images (default = NVIZ)"
-msgstr "Prefijo de las imágenes de salida (predeterminado = NVIZ)"
+msgstr "Prefijo de imágenes de salida (predeterminado = NVIZ)"
#: ../misc/m.nviz.script/main.c:94
msgid "Route coordinates (east,north)"
@@ -3434,45 +3172,36 @@
#: ../misc/m.nviz.script/main.c:439
#, fuzzy
-msgid ""
-"Skipping this point, selected point is outside region. Perhaps the camera "
-"setback distance puts it beyond the edge?"
-msgstr ""
-"Saltando este punto, el punto seleccionado está fuera de la región. ¿Quizás "
-"la distancia setback lo sitúa más allá del borde?"
+msgid "Skipping this point, selected point is outside region. Perhaps the camera setback distance puts it beyond the edge?"
+msgstr "Omitiendo este punto, el punto seleccionado está fuera de la región. ¿Quizás la distancia setback lo sitúa más allá del borde?"
#: ../misc/m.measure/main.c:45
msgid "Measures the lengths and areas of features."
msgstr "Mide las distancias y áreas de los elementos."
#: ../misc/m.measure/main.c:47
-#, fuzzy
msgid "measurement"
-msgstr "Situación"
+msgstr "medición"
#: ../misc/m.measure/main.c:54
msgid "Units"
msgstr "Unidades"
#: ../misc/m.measure/main.c:55
-#, fuzzy
msgid "Default: location map units"
-msgstr "Error de discretización en unidades de mapa"
+msgstr "Predeterminado: unidades de mapa Localización"
#: ../misc/m.measure/main.c:59
-#, fuzzy
msgid "Shell script style"
-msgstr "Imprimir en estilo de script de consola"
+msgstr "Script estilo consola de comandos"
#: ../misc/m.measure/main.c:102
-#, fuzzy
msgid "Length:"
-msgstr "Longitud: %f\n"
+msgstr "Longitud:"
#: ../misc/m.measure/main.c:113
-#, fuzzy
msgid "Area:"
-msgstr "Área\n"
+msgstr "Área:"
#: ../vector/v.extract/copy_tab.c:57 ../vector/v.select/copy_tabs.c:17
#: ../vector/v.generalize/misc.c:134 ../vector/v.voronoi/main.c:384
@@ -3498,9 +3227,9 @@
#: ../vector/v.extract/copy_tab.c:117 ../vector/v.vect.stats/main.c:300
#: ../vector/v.vect.stats/main.c:384
-#, fuzzy, c-format
+#, c-format
msgid "Unable to open database <%s> with driver <%s>"
-msgstr "No se puede abrir la base de datos <%s> por el controlador <%s>"
+msgstr "No se puede abrir la base de datos <%s> con el controlador <%s>"
#: ../vector/v.extract/copy_tab.c:129 ../vector/v.overlay/main.c:590
#: ../vector/v.random/main.c:263 ../vector/v.in.dwg/main.c:249
@@ -3525,33 +3254,25 @@
#: ../vector/v.extract/extract.c:175
#, c-format
msgid "More categories (%d) found for area %d. Using first found category %d"
-msgstr ""
-"Más categorías (%d) encontradas para área %d. Usando la primer categoría "
-"encontrada %d"
+msgstr "Más categorías (%d) encontradas para área %d. Usando la primer categoría encontrada %d"
#: ../vector/v.extract/extract.c:228
-msgid ""
-"Topology level required for extracting areas for OGR layers. Areas will be "
-"not processed."
-msgstr ""
-"Nivel de topología es requerido para extraer áreas para capas OGR. Las áreas "
-"no serán procesadas."
+msgid "Topology level required for extracting areas for OGR layers. Areas will be not processed."
+msgstr "Nivel de topología es requerido para extraer áreas para capas OGR. Las áreas no serán procesadas."
#: ../vector/v.extract/main.c:78 ../vector/v.outlier/main.c:71
#: ../vector/v.decimate/main.c:127
#: ../locale/scriptstrings/t.vect.extract_to_translate.c:3
#: ../locale/scriptstrings/t.rast.extract_to_translate.c:3
#: ../locale/scriptstrings/t.rast3d.extract_to_translate.c:3
-#, fuzzy
msgid "extract"
-msgstr "vectorial, exportar"
+msgstr "extraer"
#: ../vector/v.extract/main.c:79 ../vector/v.outlier/main.c:72
#: ../vector/v.decimate/main.c:128
#: ../locale/scriptstrings/t.vect.db.select_to_translate.c:6
-#, fuzzy
msgid "select"
-msgstr "Selección"
+msgstr "seleccionar"
#: ../vector/v.extract/main.c:80
#: ../locale/scriptstrings/v.dissolve_to_translate.c:3
@@ -3562,18 +3283,12 @@
#: ../vector/v.perturb/main.c:65 ../raster/r.surf.random/main.c:38
#: ../raster/r.random/main.c:54 ../raster/r.surf.gauss/main.c:40
#: ../raster/r.random.surface/main.c:59 ../raster/r.random.cells/main.c:49
-#, fuzzy
msgid "random"
-msgstr "Desde_mapa"
+msgstr "aleatorio"
#: ../vector/v.extract/main.c:83
-#, fuzzy
-msgid ""
-"Selects vector features from an existing vector map and creates a new vector "
-"map containing only the selected features."
-msgstr ""
-"Selecciona objetos vectoriales de un vectorial existente y crea un nuevo "
-"mapa que contiene sólo los objetos seleccionados."
+msgid "Selects vector features from an existing vector map and creates a new vector map containing only the selected features."
+msgstr "Selecciona elementos vectoriales de un mapa vectorial existente y crea un nuevo mapa que contiene solamente los elementos seleccionados."
#: ../vector/v.extract/main.c:88
msgid "Dissolve common boundaries (default is no)"
@@ -3682,9 +3397,7 @@
#: ../vector/v.extract/main.c:123
msgid "Input text file with category numbers/number ranges to be extracted"
-msgstr ""
-"Archivo de texto de entrada con números de categoría/intervalo de números a "
-"extraer"
+msgstr "Archivo de texto de entrada con números de categoría/intervalo de números a extraer"
#: ../vector/v.extract/main.c:124
msgid "If '-' given reads from standard input"
@@ -3692,9 +3405,7 @@
#: ../vector/v.extract/main.c:132
msgid "Number of random categories matching vector objects to extract"
-msgstr ""
-"Número de categorías aleatorias que coinciden con los objetos vector a "
-"extraer"
+msgstr "Número de categorías aleatorias que coinciden con los objetos vector a extraer"
#: ../vector/v.extract/main.c:134
msgid "Number must be smaller than unique cat count in layer"
@@ -3702,22 +3413,16 @@
#: ../vector/v.extract/main.c:142
msgid "Desired new category value (enter -1 to keep original categories)"
-msgstr ""
-"Valor de la nueva categoría deseada (introducir -1 para mantener las "
-"categorías originales)"
+msgstr "Valor de la nueva categoría deseada (introducir -1 para mantener las categorías originales)"
#: ../vector/v.extract/main.c:144
msgid "If new >= 0, attributes is not copied"
msgstr "Si es nuevo >=0, los atributos no son copiados"
#: ../vector/v.extract/main.c:161
-#, fuzzy, c-format
-msgid ""
-"Options <%s>, <%s>, <%s> and <%s> options are exclusive. Please specify only "
-"one of them."
-msgstr ""
-"Las opciones lista, archivo, dónde y azar son exclusivas. Por favor "
-"especifica solo una de ellas"
+#, c-format
+msgid "Options <%s>, <%s>, <%s> and <%s> options are exclusive. Please specify only one of them."
+msgstr "Opciones <%s>, <%s>, <%s> y <%s> son excluyenetes. Por favor especifique solamente una de ellas."
#: ../vector/v.extract/main.c:208
#, c-format
@@ -3745,9 +3450,9 @@
#: ../vector/v.distance/main.c:459 ../vector/v.distance/main.c:540
#: ../vector/v.db.connect/main.c:213 ../vector/v.db.select/main.c:171
#: ../vector/v.to.rast3/main.c:80
-#, fuzzy, c-format
+#, c-format
msgid "Database connection not defined for layer <%s>"
-msgstr "La conexión a la base de datos no ha sido definida para la capa %d"
+msgstr "La conexión a la base de datos no ha sido definida para la capa <%s>"
#: ../vector/v.extract/main.c:259
#, c-format
@@ -3767,12 +3472,8 @@
msgstr[1] "%d categorías cargadas"
#: ../vector/v.extract/main.c:286
-msgid ""
-"This map has no categories attached. Use v.category to attach categories to "
-"this vector map."
-msgstr ""
-"Este mapa no tiene categorías adjuntat. Utilizar v.category para adjuntar "
-"categorías a este mapa vectorial."
+msgid "This map has no categories attached. Use v.category to attach categories to this vector map."
+msgstr "Este mapa no tiene categorías adjuntat. Utilizar v.category para adjuntar categorías a este mapa vectorial."
#: ../vector/v.extract/main.c:293
msgid "Please specify random number larger than 0"
@@ -3780,21 +3481,13 @@
#: ../vector/v.extract/main.c:297
#, c-format
-msgid ""
-"Random category count must be smaller than feature count. There are only %d "
-"features of type(s): %s"
-msgstr ""
-"La categoría aleatoria count debe ser más pequeña que el elemento count. Hay "
-"solo %d elementos del tipo(s): %s"
+msgid "Random category count must be smaller than feature count. There are only %d features of type(s): %s"
+msgstr "La categoría aleatoria count debe ser más pequeña que el elemento count. Hay solo %d elementos del tipo(s): %s"
#: ../vector/v.extract/main.c:320
#, fuzzy, c-format
-msgid ""
-"Random category count is larger or equal to uniq <%s> feature category count "
-"%d"
-msgstr ""
-"La categoría aleatoria count es mayor o igual que uniq <%s> elemento "
-"categoría count %d"
+msgid "Random category count is larger or equal to uniq <%s> feature category count %d"
+msgstr "La categoría aleatoria count es mayor o igual que uniq <%s> elemento categoría count %d"
#: ../vector/v.extract/main.c:346 ../vector/v.net.path/main.c:167
#: ../vector/v.edit/main.c:105 ../vector/v.edit/main.c:120
@@ -3856,26 +3549,22 @@
msgstr "Eliminando centroides duplicados..."
#: ../vector/v.external.out/format.c:22 ../vector/v.external/main.c:74
-msgid ""
-"Environment variable GRASS_VECTOR_OGR defined, but GRASS is compiled with "
-"OGR support. Using GRASS-PostGIS data driver instead."
-msgstr ""
+msgid "Environment variable GRASS_VECTOR_OGR defined, but GRASS is compiled with OGR support. Using GRASS-PostGIS data driver instead."
+msgstr "Variable ambiental GRASS_VECTOR_OGR definida, pero GRASS está compilado con soporte OGR. Usando controlador de datos GRASS-PostGIS en su lugar."
#: ../vector/v.external.out/format.c:27 ../vector/v.external/main.c:79
-msgid ""
-"GRASS is not compiled with PostgreSQL support. Using OGR-PostgreSQL driver "
-"instead of native GRASS-PostGIS data driver."
-msgstr ""
+msgid "GRASS is not compiled with PostgreSQL support. Using OGR-PostgreSQL driver instead of native GRASS-PostGIS data driver."
+msgstr "GRASS no está compilado con soporte PostgreSQL. Usando controlador OGR-PostgreSQL en vez del controlador de datos nativo GRASS-PostGIS."
#: ../vector/v.external.out/format.c:49 ../raster/r.external.out/main.c:156
-#, fuzzy, c-format
+#, c-format
msgid "Format <%s> not supported"
-msgstr "Tipo de columna no soportado"
+msgstr "Formato <%s> no soportado"
#: ../vector/v.external.out/format.c:52 ../raster/r.external.out/main.c:166
-#, fuzzy, c-format
+#, c-format
msgid "Format <%s> does not support writing"
-msgstr "El controlador <%s> no soporta la creación de rásters"
+msgstr "Formato <%s> no soporta escritura"
#: ../vector/v.external.out/main.c:44 ../vector/v.out.lidar/main.c:472
#: ../vector/v.out.svg/main.c:78 ../vector/v.out.ascii/main.c:48
@@ -3905,97 +3594,84 @@
msgstr "exportar"
#: ../vector/v.external.out/main.c:45 ../raster/r.external.out/main.c:237
-#, fuzzy
msgid "output"
-msgstr "Salida"
+msgstr "salida"
#: ../vector/v.external.out/main.c:46 ../vector/v.external/main.c:52
#: ../raster/r.external.out/main.c:238 ../raster/r.external/main.c:59
-#, fuzzy
msgid "external"
-msgstr "general"
+msgstr "externo"
#: ../vector/v.external.out/main.c:49
-#, fuzzy
msgid "Defines vector output format."
+msgstr "Define formato vectorial de salida."
#: ../vector/v.external.out/main.c:63
msgid "Switched from OGR to native format"
-msgstr ""
+msgstr "Cambiado de OGR a formato nativo"
#: ../vector/v.external.out/main.c:67
msgid "Switched from PostGIS to native format"
-msgstr ""
+msgstr "Cambiado de PostGIS a formato nativo"
#: ../vector/v.external.out/main.c:69 ../vector/v.external.out/main.c:96
-#, fuzzy, c-format
+#, c-format
msgid "Current output format for vectors: %s"
-msgstr "No se está produciendo mapas raster ni vectoriales"
+msgstr "Formato actual para vectoriales de salida: %s"
#: ../vector/v.external.out/status.c:25
-#, fuzzy, c-format
+#, c-format
msgid "format: native\n"
-msgstr "formato"
+msgstr "formato: nativo\n"
#: ../vector/v.external.out/status.c:80
-#, fuzzy
msgid "No settings defined"
-msgstr "Ningún mapa de datos especificado"
+msgstr "No se definió configuración"
#: ../vector/v.external.out/status.c:109 ../vector/v.external.out/status.c:149
-#, fuzzy
msgid "Format not defined"
-msgstr "Nombre del archivo de salida"
+msgstr "No se definió formato"
#: ../vector/v.external.out/status.c:116
-#, fuzzy
msgid "OGR datasource (dsn) not defined"
-msgstr "Nombre del origen de datos OGR"
+msgstr "Fuente de datos OGR (dsn) no definida"
#: ../vector/v.external.out/status.c:124
-#, fuzzy
msgid "PG connection info (conninfo) not defined"
-msgstr "Conexión a la base de datos no definida"
+msgstr "Información de conexión PG (conninfo) no definida"
#: ../vector/v.external.out/status.c:158 ../vector/v.external.out/link.c:88
-#, fuzzy
msgid "Unable to create settings file"
-msgstr "No se puede crear cell/%s file"
+msgstr "No es posible archivo de configuración"
#: ../vector/v.external.out/status.c:160 ../vector/v.external.out/link.c:91
-#, fuzzy
msgid "Error writing settings file"
-msgstr "Error al escribir el archivo de segmentos"
+msgstr "Error al escribir archivo de configuración"
#: ../vector/v.external.out/link.c:26 ../vector/v.out.ogr/main.c:96
#, c-format
-msgid ""
-"Data source starts with \"PG:\" prefix, expecting \"PostgreSQL\" format (\"%s"
-"\" given)"
-msgstr ""
+msgid "Data source starts with \"PG:\" prefix, expecting \"PostgreSQL\" format (\"%s\" given)"
+msgstr "Fuente de datos inicia con prefijo \"PG:\", se esperaba formato \"PostgreSQL\" (\"%s\" dado)"
#: ../vector/v.external.out/link.c:96
#, c-format
msgid "Switched to OGR format (%s)"
-msgstr ""
+msgstr "Cambiado a formato OGR (%s)"
#: ../vector/v.external.out/link.c:99
msgid "Switched to PostGIS format"
-msgstr ""
+msgstr "Cambiado a formato PostGIS"
#: ../vector/v.external.out/link.c:110
-#, fuzzy, c-format
+#, c-format
msgid "Unable to parse option '%s'"
-msgstr "No se puede abrir el archivo de entrada <%s>"
+msgstr "No ha sido posible parsear opción '%s'"
#: ../vector/v.external.out/args.c:14
-#, fuzzy
msgid "Name of output directory or OGR or PostGIS data source"
-msgstr "Nombre para la tabla de salida"
+msgstr "Nombre de directorio de salida o fuente de datos OGR o PostGIS"
#: ../vector/v.external.out/args.c:15 ../vector/v.external/args.c:15
-#, fuzzy
msgid ""
"Examples:\n"
"\t\tESRI Shapefile: directory containing a shapefile\n"
@@ -4003,19 +3679,18 @@
"\t\tPostGIS database: connection string, eg. 'PG:dbname=db user=grass'"
msgstr ""
"Ejemplos:\n"
-"\tShapefile de ESRI: directorio que contiene shapefiles\n"
-"\tArchivo MapInfo: directorio que contiene archivos MapInfo"
+"\t\tShapefile de ESRI: directorio que contiene shapefiles\n"
+"\t\tArchivo MapInfo: directorio que contiene archivo mapInfo\n"
+"\t\tBase de datos PostGIS: cadena de conexión, ej. 'PG:dbname=db user=grass'"
#: ../vector/v.external.out/args.c:24
-#, fuzzy
msgid "Format for output vector data"
-msgstr "Nombre para el mapa vectorial de salida"
+msgstr "Formato de salida para datos vectoriales"
#: ../vector/v.external.out/args.c:39 ../vector/v.out.postgis/args.c:52
#: ../raster/r.external.out/main.c:264
-#, fuzzy
msgid "Creation options"
+msgstr "Opciones de creación"
#: ../vector/v.external.out/args.c:40
msgid ""
@@ -4024,16 +3699,18 @@
"\t\t'GEOM_TYPE=geography': use geography PostGIS data\n"
"\t\t'SCHEMA=grass': create new PostGIS tables in 'grass' schema"
msgstr ""
+"Ejemplos:\n"
+"\t\t'SHPT=POINTZ': crea un archivo de datos Shape de puntos 3D\n"
+"\t\t'GEOM_TYPE=geography': usa datos geográficos de PostGIS\n"
+"\t\t'SCHEMA=grass': crea una nueva tabla PostGIS en el esquema 'grass'"
#: ../vector/v.external.out/args.c:52
-#, fuzzy
msgid "Name of input file to read settings from"
-msgstr "Nombre del archivo de entrada; o \"-\" a leer de stdin"
+msgstr "Nombre de directorio de entrada del cual leer configuraciones"
#: ../vector/v.external.out/args.c:58
-#, fuzzy
msgid "Name for output file where to save current settings"
-msgstr "Nombre del archivo de salida que contiene el informe final"
+msgstr "Nombre de archivo de salida donde guardar configuraciones actuales"
#: ../vector/v.external.out/args.c:62 ../vector/v.external/args.c:42
#: ../raster/r.external.out/main.c:271 ../raster/r.external/main.c:95
@@ -4043,46 +3720,40 @@
#: ../vector/v.external.out/args.c:68
msgid "Cease using OGR/PostGIS, revert to native output and exit"
-msgstr ""
+msgstr "Dejar de usar OGR/PostGIS, revertir a la salida nativa y salir"
#: ../vector/v.external.out/args.c:70
-#, fuzzy
msgid "Native"
-msgstr "Por tiempo"
+msgstr "Nativo"
#: ../vector/v.external.out/args.c:74 ../raster/r.external.out/main.c:282
-#, fuzzy
msgid "Print current status"
-msgstr "Imprimir la ruta de búsqueda del directorio de mapas actual"
+msgstr "Mostrar estatus actual"
#: ../vector/v.external.out/args.c:80
-#, fuzzy
msgid "Print current status in shell script style"
-msgstr "Imprimir las estadísticas en estilo de script de consola"
+msgstr "Mostrar estatus actual en estilo de script de consola de comandos"
#: ../vector/v.external.out/args.c:90 ../raster/r.resamp.filter/main.c:437
-#, fuzzy, c-format
+#, c-format
msgid "%s= and %s=/%s= are mutually exclusive"
-msgstr "weight= y -c son excluyentes mutuamente"
+msgstr "%s= y %s=/%s= son mutuamente excluyentes"
#: ../vector/v.external.out/args.c:98
-#, fuzzy, c-format
+#, c-format
msgid "%s= or %s= must be specified"
-msgstr ""
-"¡Se debe especificar \"-i\" o \"-r\" o una de las opciones \"color\", "
-"\"ráster\" o \"reglas\"!"
+msgstr "Se debe especificar %s o %s"
#: ../vector/v.external.out/args.c:101
-#, fuzzy, c-format
+#, c-format
msgid "%s= must be specified"
-msgstr "2 capas deben ser especificadas"
+msgstr "%s= debe ser especificado"
#: ../vector/v.external.out/list.c:102 ../vector/v.external/list.c:94
#: ../vector/v.in.ogr/main.c:334 ../raster/r.external/list.c:23
#: ../raster/r.in.gdal/main.c:288
-#, fuzzy
msgid "Supported formats:"
-msgstr "Formatos soportados:\n"
+msgstr "Formatos soportados:"
#: ../vector/v.net.path/main.c:43 ../vector/v.net.steiner/main.c:347
#: ../vector/v.net.visibility/main.c:46 ../vector/v.net.centrality/main.c:97
@@ -4139,11 +3810,8 @@
msgstr "Capa de nodo"
#: ../vector/v.net.path/main.c:72
-msgid ""
-"Name of file containing start and end points. If not given, read from stdin"
-msgstr ""
-"Nombre del archivo que contiene los puntos inicial y final. Si no se indica, "
-"se leerá de stdin."
+msgid "Name of file containing start and end points. If not given, read from stdin"
+msgstr "Nombre del archivo que contiene los puntos inicial y final. Si no se indica, se leerá de stdin."
#: ../vector/v.net.path/main.c:79 ../vector/v.net.centrality/main.c:129
#: ../vector/v.net.salesman/main.c:168 ../vector/v.net.iso/main.c:122
@@ -4212,14 +3880,8 @@
msgstr "Distancia máxima a la red"
#: ../vector/v.net.path/main.c:102
-msgid ""
-"If start/end are given as coordinates. If start/end point is outside this "
-"threshold, the path is not found and error message is printed. To speed up "
-"the process, keep this value as low as possible."
-msgstr ""
-"Si inicio/final se dan como coordenadas. Si el punto inicio/final está fuera "
-"de este umbral, la ruta no se encuentra y se imprime un mensaje de error. "
-"Para acelerar el proceso, mantenga este valor lo más bajo posible."
+msgid "If start/end are given as coordinates. If start/end point is outside this threshold, the path is not found and error message is printed. To speed up the process, keep this value as low as possible."
+msgstr "Si inicio/final se dan como coordenadas. Si el punto inicio/final está fuera de este umbral, la ruta no se encuentra y se imprime un mensaje de error. Para acelerar el proceso, mantenga este valor lo más bajo posible."
#: ../vector/v.net.path/main.c:110 ../vector/v.net.salesman/main.c:181
#: ../vector/v.net.iso/main.c:137 ../vector/v.net.alloc/main.c:129
@@ -4267,9 +3929,7 @@
#: ../vector/v.net.path/main.c:136 ../vector/v.net.distance/main.c:165
msgid "Write output as original input segments, not each path as one line."
-msgstr ""
-"Escribir la salida como los segmentos de entrada originales, no cada ruta "
-"como una línea."
+msgstr "Escribir la salida como los segmentos de entrada originales, no cada ruta como una línea."
#: ../vector/v.net.path/main.c:148 ../vector/v.net.centrality/main.c:222
#: ../vector/v.net.distance/main.c:205 ../vector/v.net.allpairs/main.c:142
@@ -4337,9 +3997,7 @@
#: ../vector/v.net.path/path.c:220
#, c-format
msgid "Point with category [%d] is not reachable from point with category [%d]"
-msgstr ""
-"El punto con categoría [%d] no es alcanzable desde el punto con categoría "
-"[%d]"
+msgstr "El punto con categoría [%d] no es alcanzable desde el punto con categoría [%d]"
#: ../vector/v.net.path/path.c:288
#, c-format
@@ -4387,15 +4045,13 @@
#: ../locale/scriptstrings/v.to.lines_to_translate.c:3
#: ../raster/r.circle/main.c:53 ../raster/r.thin/main.c:58
#: ../raster/r.patch/main.c:59 ../raster/r.to.vect/main.c:78
-#, fuzzy
msgid "geometry"
-msgstr "vectorial, geometría"
+msgstr "geometría"
#: ../vector/v.edit/main.c:56 ../vector/v.type/main.c:40
#: ../locale/scriptstrings/d.rast.edit_to_translate.c:3
-#, fuzzy
msgid "editing"
-msgstr "Configuraciones"
+msgstr "editando"
#: ../vector/v.edit/main.c:57 ../vector/v.type/main.c:42
#: ../vector/v.parallel/main.c:52 ../vector/v.category/main.c:681
@@ -4424,17 +4080,12 @@
#: ../vector/v.edit/main.c:60 ../vector/v.segment/main.c:65
#: ../vector/v.split/main.c:59 ../vector/v.build.polylines/main.c:116
#: ../vector/v.to.points/main.c:58
-#, fuzzy
msgid "vertex"
-msgstr "Vértices eliminados %5d"
+msgstr "vértice"
#: ../vector/v.edit/main.c:61
-msgid ""
-"Edits a vector map, allows adding, deleting and modifying selected vector "
-"features."
-msgstr ""
-"Edita un mapa vectorial, permite añadir, borrar y modificar los elementos "
-"del vectorial seleccionado."
+msgid "Edits a vector map, allows adding, deleting and modifying selected vector features."
+msgstr "Edita un mapa vectorial, permite añadir, borrar y modificar los elementos del vectorial seleccionado."
#: ../vector/v.edit/main.c:70
#, c-format
@@ -4462,20 +4113,14 @@
msgstr "Tipos de elementos soportados para formatos no nativos:"
#: ../vector/v.edit/main.c:138
-#, fuzzy, c-format
-msgid ""
-"Unable to open vector map <%s> on topological level. Try to rebuild vector "
-"topology by v.build."
-msgstr "No se puede abrir el mapa vectorial <%s> en el nivel topológico %d"
+#, c-format
+msgid "Unable to open vector map <%s> on topological level. Try to rebuild vector topology by v.build."
+msgstr "No ha sido posible abrir mapa vectorial <%s> en nivel topológico. Trate de reconstruir topología vectorial con v.build."
#: ../vector/v.edit/main.c:158
-#, fuzzy, c-format
-msgid ""
-"Unable to open vector map <%s> as the background map. It is given as vector "
-"map to be edited."
-msgstr ""
-"No se puede abrir el mapa vectorial <%s> como mapa de fondo. Se ha dado como "
-"mapa vectorial a editar."
+#, c-format
+msgid "Unable to open vector map <%s> as the background map. It is given as vector map to be edited."
+msgstr "No ha sido posible abrir mapa vectorial <%s> como mapa de fondo. Se ha dado como mapa vectorial a como editar."
#: ../vector/v.edit/main.c:169
#, c-format
@@ -4484,7 +4129,7 @@
#: ../vector/v.edit/main.c:205
msgid "Threshold for snapping must be > 0. No snapping applied."
-msgstr ""
+msgstr "Umbral para ensamblado debe ser > 0. No se aplicará autoensamblado."
#: ../vector/v.edit/main.c:212
msgid "Selecting features..."
@@ -4496,13 +4141,8 @@
#: ../vector/v.edit/main.c:232
#, c-format
-msgid ""
-"Vector map <%s> is not 3D. Tool '%s' requires 3D vector map. Please convert "
-"the vector map to 3D using e.g. %s."
-msgstr ""
-"El mapa vectorial <%s> no es 3D. La herramienta '%s' requiere mapas "
-"vectoriales 3D. Por favor, convierta el mapa vectorial a 3D usando por "
-"ejemplo %s."
+msgid "Vector map <%s> is not 3D. Tool '%s' requires 3D vector map. Please convert the vector map to 3D using e.g. %s."
+msgstr "El mapa vectorial <%s> no es 3D. La herramienta '%s' requiere mapas vectoriales 3D. Por favor, convierta el mapa vectorial a 3D usando por ejemplo %s."
#: ../vector/v.edit/main.c:274
#, c-format
@@ -4516,7 +4156,7 @@
#: ../vector/v.edit/main.c:400
#, c-format
msgid "Threshold value for snapping is %.2f"
-msgstr "El valor umbral para el snapping es %.2f "
+msgstr "El valor umbral para el ensamblado es %.2f "
#: ../vector/v.edit/main.c:294
#, c-format
@@ -4590,12 +4230,8 @@
#: ../vector/v.edit/main.c:385
#, c-format
-msgid ""
-"Multiple background maps were given. Selected features will be copied only "
-"from vector map <%s>."
-msgstr ""
-"Se han dado múltiples mapas de fondo. Los elementos seleccionados se "
-"copiarán sólo del mapa vectorial <%s>."
+msgid "Multiple background maps were given. Selected features will be copied only from vector map <%s>."
+msgstr "Se han dado múltiples mapas de fondo. Los elementos seleccionados se copiarán sólo del mapa vectorial <%s>."
#: ../vector/v.edit/main.c:395
#, c-format
@@ -4699,28 +4335,24 @@
msgstr "Seleccionar líneas y mostrar sus ID's"
#: ../vector/v.edit/args.c:68
-#, fuzzy
msgid "Set new categories to selected vector features for defined layer"
-msgstr ""
-"Imprimir la extensión mínima de la región de los elementos vectoriales "
-"seleccionados en lugar de los atributos"
+msgstr "Definir categorías nuevas para seleccionar elementos vectoriales de capa definida"
#: ../vector/v.edit/args.c:70
msgid "Delete categories from selected vector features for defined layer"
-msgstr ""
+msgstr "Eliminar categorías para elemetos vectoriales seleccionados para capa definida"
#: ../vector/v.edit/args.c:72
msgid "Copy selected features"
msgstr "Copia elementos seleccionados"
#: ../vector/v.edit/args.c:73
-#, fuzzy
msgid "Snap vector features in given threshold"
-msgstr "Herramienta: ajustar línea a vértice en umbral"
+msgstr "Ensamblar elementos vectoriales en umbral dado"
#: ../vector/v.edit/args.c:74
msgid "Flip direction of selected vector lines"
-msgstr ""
+msgstr "Rotar dirección de líneas vectoriales seleccionadas"
#: ../vector/v.edit/args.c:75
msgid "Connect two lines"
@@ -4736,14 +4368,11 @@
#: ../vector/v.edit/args.c:79
msgid "Delete selected areas from vector map (based on selected centroids)"
-msgstr ""
-"Eliminar áreas seleccioadas del mapa vectorial (basado en los centroides "
-"seleccionados)"
+msgstr "Eliminar áreas seleccioadas del mapa vectorial (basado en los centroides seleccionados)"
#: ../vector/v.edit/args.c:87
-#, fuzzy
msgid "Name of file containing data in GRASS ASCII vector format"
-msgstr "Nombre de archivo que contiene las signaturas iniciales"
+msgstr "Nombre de archivo que contiene datos en formato vectorial GRASS ASCII"
#: ../vector/v.edit/args.c:90 ../vector/v.edit/args.c:209
#: ../vector/v.in.ogr/main.c:160
@@ -4803,13 +4432,12 @@
msgstr "Entrada"
#: ../vector/v.edit/args.c:99
-#, fuzzy
msgid "Difference in x,y,z direction for moving feature or vertex"
-msgstr "Diferencia en dirección X, Y para mover elemento o vértice"
+msgstr "Diferencia en dirección x,y,z para elemento móvil o vértice"
#: ../vector/v.edit/args.c:106
msgid "Threshold distance (coords,snap,query)"
-msgstr "Distancia umbral (coords, snap, consulta)"
+msgstr "Distancia umbral (coordenadas,ensamblado,consulta)"
#: ../vector/v.edit/args.c:108
msgid "'-1' for threshold based on the current resolution settings"
@@ -4833,13 +4461,11 @@
#: ../vector/v.edit/args.c:154
msgid "For 'shorter' use negative threshold value, positive value for 'longer'"
-msgstr ""
-"Para 'más corto' usar valor de umbral negativo, para 'más largo' positivo"
+msgstr "Para 'más corto' usar valor de umbral negativo, para 'más largo' positivo"
#: ../vector/v.edit/args.c:160
-#, fuzzy
msgid "Select only lines or boundaries shorter/longer than threshold distance"
-msgstr "Eliminar todas las líneas o contornos de longitud cero"
+msgstr "Seleccionar solamente líneas o contornos más cortos/largos que distancia umbral"
#: ../vector/v.edit/args.c:162
msgid "Select dangles shorter/longer than threshold distance"
@@ -4850,24 +4476,20 @@
msgstr "Nombre del mapa(s) vectorial de fondo "
#: ../vector/v.edit/args.c:176
-msgid ""
-"Snap added or modified features in the given threshold to the nearest "
-"existing feature"
-msgstr ""
-"Autoensamblar objetos espaciales añadidos o modificados en el umbral dado al "
-"objeto espacial existente más próximo"
+msgid "Snap added or modified features in the given threshold to the nearest existing feature"
+msgstr "Ensamblar elementos añadidos o modificados en el umbral dado al elemento más próximo"
#: ../vector/v.edit/args.c:182
msgid "Not apply snapping"
-msgstr ""
+msgstr "No aplicar ensamblado"
#: ../vector/v.edit/args.c:183
msgid "Snap only to node"
-msgstr ""
+msgstr "Solamente ensamblar a nodo"
#: ../vector/v.edit/args.c:184
msgid "Allow snapping also to vertex"
-msgstr ""
+msgstr "Permitir ensamblado también a vértice"
#: ../vector/v.edit/args.c:192
msgid "Starting value and step for z bulk-labeling"
@@ -4947,19 +4569,18 @@
#: ../vector/v.colors/read_rgb.c:32
-#, fuzzy, c-format
+#, c-format
msgid "Data type of RGB column <%s> must be char"
+msgstr "El tipo de datos de la columna RGB <%s> debe ser caracter (char)"
#: ../vector/v.colors/read_rgb.c:37
-#, fuzzy
msgid "No RGB values found"
-msgstr "¡No se encontró ninguna capa DXF!"
+msgstr "No se encontraron valores RGB"
#: ../vector/v.colors/read_rgb.c:65
-#, fuzzy, c-format
+#, c-format
msgid "%d invalid RGB color values skipped"
-msgstr "Valor no válido para scalex"
+msgstr "%d valores de color RGB no válidos"
#: ../vector/v.colors/main.c:56 ../vector/v.colors.out/main.c:50
#: ../locale/scriptstrings/t.rast.colors_to_translate.c:3
@@ -4971,38 +4592,32 @@
msgstr "tabla de colores"
#: ../vector/v.colors/main.c:58
-#, fuzzy
msgid "Creates/modifies the color table associated with a vector map."
-msgstr "Crea/modifica la tabla de colores asociada a una capa de mapa ráster."
+msgstr "Crea/modifica la tabla de colores asociada a un mapa vectorial."
#: ../vector/v.colors/main.c:70
-#, fuzzy
msgid "Source values"
-msgstr "Valores de categoría de entrada"
+msgstr "Valores de fuente"
#: ../vector/v.colors/main.c:73
-#, fuzzy
msgid "read values from attribute table (requires <column> option)"
-msgstr "Tomar colores de columna de la tabla del mapa (en forma RRR:GGG:BBB)"
+msgstr "leer valores de la tabla de atributos (necesita opción <column>)"
#: ../vector/v.colors/main.c:74 ../vector/v.to.rast/main.c:78
-#, fuzzy
msgid "use category values"
+msgstr "usar valores de categoría"
#: ../vector/v.colors/main.c:75
-#, fuzzy
msgid "use z coordinate (3D points or centroids only)"
-msgstr "Coordenada Este (punto de interés)"
+msgstr "usa coordenada z (solamente puntos 3D o centroides)"
#: ../vector/v.colors/main.c:79
msgid "Name of column containing numeric data"
msgstr "Nombre de la columna que contiene los datos numéricos"
#: ../vector/v.colors/main.c:80
-#, fuzzy
msgid "Required for use=attr"
-msgstr "Requerido para la operación 'conectar'"
+msgstr "Necesario para use=attr"
#: ../vector/v.colors/main.c:81 ../vector/v.colors/main.c:92
#: ../vector/v.colors/main.c:99 ../vector/v.colors/main.c:106
@@ -5022,14 +4637,12 @@
#: ../raster/r.colors/edit_colors.c:122 ../raster/r.colors/edit_colors.c:133
#: ../raster/r.colors/edit_colors.c:138 ../raster/r.colors/edit_colors.c:143
#: ../raster/r.colors/edit_colors.c:148
-#, fuzzy
msgid "Define"
-msgstr "Líneas"
+msgstr "Definir"
#: ../vector/v.colors/main.c:87
-#, fuzzy
msgid "Manually set range (refers to 'column' option)"
-msgstr "Asignar rango manualmente (min,max)"
+msgstr "Definir rango de manera maual (se refiere a la opción 'column')"
#: ../vector/v.colors/main.c:88
msgid "Ignored when 'rules' given"
@@ -5038,16 +4651,14 @@
#: ../vector/v.colors/main.c:98
#: ../locale/scriptstrings/t.rast.colors_to_translate.c:8
#: ../raster/r.colors/edit_colors.c:96
-#, fuzzy
msgid "Raster map from which to copy color table"
-msgstr "Nombre del mapa ráster del que copiar la tabla de colores"
+msgstr "Mapa ráster del cual se copiará la tabla de color"
#: ../vector/v.colors/main.c:105
#: ../locale/scriptstrings/t.rast.colors_to_translate.c:10
#: ../raster/r.colors/edit_colors.c:103
-#, fuzzy
msgid "3D raster map from which to copy color table"
+msgstr "Mapa ráster 3D del cual se copiará la tabla de color"
#: ../vector/v.colors/main.c:111
#: ../locale/scriptstrings/t.rast.colors_to_translate.c:12
@@ -5056,19 +4667,17 @@
msgstr "Ruta al archivo de reglas"
#: ../vector/v.colors/main.c:112 ../raster/r.colors/edit_colors.c:110
-#, fuzzy
msgid "\"-\" to read rules from stdin"
-msgstr "Archivo de coordenadas de entrada (omitir para leer de stdin)"
+msgstr "\"-\" para leer reglas desde entrada estándar (stdin)"
#: ../vector/v.colors/main.c:117
#, fuzzy
msgid "Name of color column to populate RGB values"
-msgstr "Nombre de la columna a mostrar"
+msgstr "Nombre de la columna de color en la cual "
#: ../vector/v.colors/main.c:118
-#, fuzzy
msgid "If not given writes color table"
-msgstr "No escribir tabla de colores estándard GDAL"
+msgstr "Si no se da escribe tabla de colores"
#: ../vector/v.colors/main.c:122
#: ../locale/scriptstrings/t.rast.colors_to_translate.c:14
@@ -5087,9 +4696,8 @@
#: ../vector/v.colors/main.c:128
#: ../locale/scriptstrings/t.rast.colors_to_translate.c:16
#: ../raster/r.colors/edit_colors.c:121
-#, fuzzy
msgid "Only write new color table if it does not already exist"
-msgstr "Sólo escribir nueva tabla de colores si no existe ya una"
+msgstr "Solamente escribir tabla de colores nueva si no existe previamente"
#: ../vector/v.colors/main.c:132
#: ../locale/scriptstrings/t.rast.colors_to_translate.c:17
@@ -5116,18 +4724,16 @@
msgstr "Escalado logarítmico-absoluto"
#: ../vector/v.colors/main.c:153
-#, fuzzy
msgid "Convert color rules from RGB values to color table"
-msgstr "Listar formatos de salida soportados"
+msgstr "Convertir reglas de color desde valores RGB a tabla de colores"
#: ../vector/v.colors/main.c:154
msgid "Option 'rgb_column' with valid RGB values required"
-msgstr ""
+msgstr "Opción 'rgb_column' con valores válidos es requerida"
#: ../vector/v.colors/main.c:197
-#, fuzzy
msgid "No vector map specified"
-msgstr "No se ha especificado ningún mapa raster"
+msgstr "No hay mapa vectorial especificado"
#: ../vector/v.colors/main.c:200 ../raster/r.sunmask/main.c:444
#, c-format
@@ -5137,49 +4743,47 @@
#: ../vector/v.colors/main.c:202
#, c-format
msgid "Option <%s> given, assuming <use=attr>..."
-msgstr ""
+msgstr "Opción dada <%s>, asumiento <use=attr>..."
#: ../vector/v.colors/main.c:207 ../raster/r.series.accumulate/main.c:206
#: ../raster/r.series.interp/main.c:118 ../raster/r.series.interp/main.c:122
#: ../raster/r.series.interp/main.c:134 ../raster/r.series.interp/main.c:138
#: ../raster/r.series/main.c:204 ../raster/r.mapcalc/main.c:117
#: ../raster/r.external/main.c:159 ../raster/r.neighbors/main.c:266
-#, fuzzy, c-format
+#, c-format
msgid "%s= and %s= are mutually exclusive"
+msgstr "%s= y %s son mutuamente excluyentes"
#: ../vector/v.colors/main.c:217
-#, fuzzy, c-format
+#, c-format
msgid "One of -%c, -%c or %s=, %s= or %s= must be specified"
-msgstr ""
+msgstr "Uno de los -%c, -%c o %s=, %s= o %s= debe ser especificado"
#: ../vector/v.colors/main.c:222
-#, fuzzy, c-format
+#, c-format
msgid "%s=, %s= and %s= are mutually exclusive"
+msgstr "%s=, %s= y %s= son mutuamente excluyentes"
#: ../vector/v.colors/main.c:226 ../raster/r.out.bin/main.c:379
#: ../raster/r.in.bin/main.c:462
-#, fuzzy, c-format
+#, c-format
msgid "-%c and -%c are mutually exclusive"
+msgstr "-%c y -%c son mutuamente excluyentes"
#: ../vector/v.colors/main.c:230
-#, fuzzy, c-format
+#, c-format
msgid "%s= required for -%c"
-msgstr "Se requiere la opción <%s>"
+msgstr "%s= requerido para -%c"
#: ../vector/v.colors/main.c:245
-#, fuzzy, c-format
+#, c-format
msgid "Unable to remove color table of vector map <%s>"
-msgstr "No se puede eliminar tabla de color del mapa raster <%s>"
+msgstr "No ha sido posible eliminar tabla de color del mapa vectorial <%s>"
#: ../vector/v.colors/main.c:247
-#, fuzzy, c-format
+#, c-format
msgid "Color table of vector map <%s> not found"
-msgstr "No se encuentra la tabla de color del mapa raster <%s>"
+msgstr "No se encuentra la tabla de color del mapa vectorial <%s>"
#: ../vector/v.colors/main.c:255
msgid "Color table exists. Exiting."
@@ -5194,23 +4798,23 @@
#: ../vector/v.colors/main.c:271 ../vector/v.out.ascii/main.c:104
#: ../vector/v.colors.out/scan_cats.c:24
#: ../vector/v.colors.out/make_colors.c:27 ../vector/v.surf.rst/main.c:537
-#, fuzzy, c-format
+#, c-format
msgid "Layer <%s> not found"
-msgstr "%s: no se encontró <%s>"
+msgstr "Capa <%s> no encontrada"
#: ../vector/v.colors/main.c:277
#, c-format
msgid "Option <%s>: min must be greater or equal to max"
-msgstr ""
+msgstr "Opción <%s>: mínimo debe ser mayor o igual a máximo"
#: ../vector/v.colors/main.c:283
msgid "Reading color rules from standard input is currently not supported"
-msgstr ""
+msgstr "Lectura de regla de coloresdesde entrada estándar no soportada actualmente"
#: ../vector/v.colors/main.c:290
-#, fuzzy, c-format
+#, c-format
msgid "Color table <%s> not found"
+msgstr "Tabla de colores <%s> no encontrada"
#: ../vector/v.colors/main.c:316 ../raster/r.grow.distance/main.c:384
#: ../raster/r.colors.out/raster_main.c:69 ../raster/r.fill.dir/main.c:150
@@ -5235,19 +4839,18 @@
msgstr "Mapa ráster 3D <%s> no encontrado"
#: ../vector/v.colors/main.c:323 ../raster/r.colors/edit_colors.c:403
-#, fuzzy, c-format
+#, c-format
msgid "Unable to read color table for 3D raster map <%s>"
-msgstr "No se puede leer la tabla de color para el mapa raster <%s>"
+msgstr "No ha sido posible leer tabla de colores para mapa ráster 3D <%s>"
#: ../vector/v.colors/main.c:348
-#, fuzzy
msgid "Writing color rules..."
-msgstr "Escribiendo archivo de color..."
+msgstr "Escribiendo reglas de colores..."
#: ../vector/v.colors/main.c:364
-#, fuzzy, c-format
+#, c-format
msgid "Color table for vector map <%s> set to '%s'"
-msgstr "Tabla de colores para mapa raster <%s> establecida a '%s'"
+msgstr "Tabla de colores para mapa vectorial <%s> establecida a '%s'"
#: ../vector/v.colors/scan_z.c:31 ../vector/v.colors/scan_cats.c:19
#: ../vector/v.to.rast/do_lines.c:36 ../vector/v.colors.out/scan_cats.c:28
@@ -5282,14 +4885,13 @@
msgstr "Valor máximo (%f) está fuera del rango %f,%f"
#: ../vector/v.colors/scan_attr.c:38 ../vector/v.colors.out/make_colors.c:45
-#, fuzzy, c-format
+#, c-format
msgid "Column <%s> is not numeric"
-msgstr "Columna <%s> no encontrada"
+msgstr "La columna <%s> no es numérica"
#: ../vector/v.colors/scan_attr.c:45 ../vector/v.colors.out/make_colors.c:52
-#, fuzzy
msgid "No data selected"
-msgstr "Ninguna fuente seleccionada"
+msgstr "No hay datos seleccionados"
#: ../vector/v.colors/scan_attr.c:77 ../vector/v.colors/scan_cats.c:43
#, c-format
@@ -5302,52 +4904,46 @@
msgstr "Valor máximo (%d) está fuera del rango %d,%d"
#: ../vector/v.colors/scan_attr.c:108
-#, fuzzy
msgid "Converting color rules into categories..."
-msgstr ""
-"Se alcanzó el final del archivo ASCII antes que el final de las categorías"
+msgstr "Conviritiendo reglas de color en categorías..."
#: ../vector/v.colors/write_rgb.c:37 ../vector/v.what.rast/main.c:177
-#, fuzzy, c-format
+#, c-format
msgid "Unable to add column <%s> to table <%s>"
-msgstr "No se puede usar columna <%s>"
+msgstr "No se puede añadir la columna <%s> a la tabla <%s>"
#: ../vector/v.colors/write_rgb.c:60
-#, fuzzy, c-format
+#, c-format
msgid "Column <%s> added to table <%s>"
-msgstr "Columna <%s> no encontrada en la tabla <%s>"
+msgstr "Columna <%s> añadida a la tabla <%s>"
#: ../vector/v.colors/write_rgb.c:64
-#, fuzzy, c-format
+#, c-format
msgid "Data type of column <%s> must be char"
+msgstr "El tipo de datos de la columna <%s> debe ser caracter (char)"
#: ../vector/v.colors/write_rgb.c:68
-#, fuzzy
msgid "No categories found"
-msgstr "No se encontraron mapas raster"
+msgstr "No se encontraron categorías"
#: ../vector/v.colors/write_rgb.c:78
-#, fuzzy, c-format
+#, c-format
msgid "No color value defined for category %d"
-msgstr "No hay registro para la categoría [%d]"
+msgstr "No hay valores de color definidos para la categoría %d"
#: ../vector/v.colors/write_rgb.c:86
-#, fuzzy
msgid "Unable to update RGB values"
-msgstr "No se pueden actualizar los contornos"
+msgstr "No se pueden actualizar los valores RGB"
#: ../vector/v.colors/make_colors.c:14
-#, fuzzy, c-format
+#, c-format
msgid "Color table '%s' is not supported for floating point attributes"
-msgstr ""
-"La tabla de color 'aleatoria' no está soportada por una mapa raster de "
-"unidad de coma flotante"
+msgstr "Tabla de colores '%s' no está soportada pra atributos de punto flotante"
#: ../vector/v.colors/make_colors.c:18 ../vector/v.colors/make_colors.c:25
-#, fuzzy, c-format
+#, c-format
msgid "Color table <%s> not supported"
+msgstr "Tabla de color <%s> no soportada"
#: ../vector/v.colors/make_colors.c:51 ../raster/r.colors/edit_colors.c:386
#, c-format
@@ -5356,12 +4952,11 @@
#: ../vector/v.vol.rst/dataoct.c:196
msgid "Points are too concentrated -- please increase DMIN"
-msgstr ""
+msgstr "Puntos demasiado concentrados -- por favor aumente DMIN"
#: ../vector/v.vol.rst/dataoct.c:245
-#, fuzzy
msgid "Point out of range"
-msgstr "Número de borde fuera de rango"
+msgstr "Punto fuera de rango"
#: ../vector/v.vol.rst/main.c:236 ../vector/v.to.rast3/main.c:50
#: ../locale/scriptstrings/t.rast3d.algebra_to_translate.c:5
@@ -5394,9 +4989,8 @@
#: ../raster/r.contour/main.c:88 ../raster/r.surf.idw/main.c:105
#: ../raster/r.surf.fractal/main.c:39 ../raster/r.random.surface/main.c:58
#: ../raster/r.resamp.bspline/main.c:81
-#, fuzzy
msgid "surface"
-msgstr "Varianza de la suma"
+msgstr "superficie"
#: ../vector/v.vol.rst/main.c:238 ../vector/v.surf.bspline/main.c:93
#: ../vector/v.surf.rst/main.c:143 ../vector/v.surf.idw/main.c:89
@@ -5406,21 +5000,16 @@
#: ../raster/r.series.interp/main.c:66 ../raster/r.surf.contour/main.c:62
#: ../raster/r.resamp.interp/main.c:78 ../raster/r.surf.idw/main.c:106
#: ../raster/r.resamp.bspline/main.c:83
-#, fuzzy
msgid "interpolation"
-msgstr "vectorial, interpolación"
+msgstr "interpolación"
#: ../vector/v.vol.rst/main.c:239
msgid "RST"
msgstr "RST"
#: ../vector/v.vol.rst/main.c:241
-msgid ""
-"Interpolates point data to a 3D raster map using regularized spline with "
-"tension (RST) algorithm."
-msgstr ""
-"Interpola datos de puntos a volumen de cuadrícula G3D usando spline "
-"regularizado con algoritmo de tensión (RST)."
+msgid "Interpolates point data to a 3D raster map using regularized spline with tension (RST) algorithm."
+msgstr "Interpola datos de puntos a volumen de cuadrícula G3D usando spline regularizado con algoritmo de tensión (RST)."
#: ../vector/v.vol.rst/main.c:246
msgid "Name of input 3D vector points map"
@@ -5434,15 +5023,12 @@
#: ../imagery/i.vi/main.c:142 ../imagery/i.vi/main.c:150
#: ../imagery/i.vi/main.c:158 ../imagery/i.vi/main.c:166
#: ../imagery/i.vi/main.c:174
-#, fuzzy
msgid "Optional inputs"
-msgstr "Nombre de archivo de salida <%s> no válido"
+msgstr "Entradas opcionales"
#: ../vector/v.vol.rst/main.c:260
-#, fuzzy
msgid "Name of column containing w-values attribute to interpolate"
-msgstr ""
-"Nombre de la columna que contiene los w-values de atributo a interpolar"
+msgstr "Nombre de la columna que contiene los w-values de atributo a interpolar"
#: ../vector/v.vol.rst/main.c:267 ../vector/v.surf.rst/main.c:260
msgid "Tension parameter"
@@ -5490,9 +5076,7 @@
#: ../vector/v.vol.rst/main.c:296 ../vector/v.surf.rst/main.c:232
msgid "Name for output cross-validation errors vector point map"
-msgstr ""
-"Nombre de mapa vectorial de puntos de errores de la validación cruzada "
-"generado"
+msgstr "Nombre de mapa vectorial de puntos de errores de la validación cruzada generado"
#: ../vector/v.vol.rst/main.c:302
msgid "Name of input raster map used as mask"
@@ -5538,13 +5122,11 @@
#: ../vector/v.vol.rst/main.c:378
msgid "Name for output gradient horizontal angle 3D raster map"
-msgstr ""
-"Nombre para el mapa ráster 3D del gradiente horizontal de ángulo generado"
+msgstr "Nombre para el mapa ráster 3D del gradiente horizontal de ángulo generado"
#: ../vector/v.vol.rst/main.c:384
msgid "Name for output gradient vertical angle 3D raster map"
-msgstr ""
-"Nombre para el mapa ráster 3D del gradiente vertical de ángulo generado"
+msgstr "Nombre para el mapa ráster 3D del gradiente vertical de ángulo generado"
#: ../vector/v.vol.rst/main.c:390
msgid "Name for output change of gradient 3D raster map"
@@ -5560,8 +5142,7 @@
#: ../vector/v.vol.rst/main.c:408
msgid "Perform a cross-validation procedure without volume interpolation"
-msgstr ""
-"Realizar un procedimiento de validación cruzada sin interpolación de volumen"
+msgstr "Realizar un procedimiento de validación cruzada sin interpolación de volumen"
#: ../vector/v.vol.rst/main.c:471
msgid "Smoothing must be a positive value"
@@ -5570,21 +5151,15 @@
#: ../vector/v.vol.rst/main.c:477
#, c-format
msgid "Both crossvalidation options (-%c, %s) must be specified"
-msgstr ""
-"Se deben especificar las dos opciones (-%c, %s) de la validación cruzada"
+msgstr "Se deben especificar las dos opciones (-%c, %s) de la validación cruzada"
#: ../vector/v.vol.rst/main.c:480
msgid "Both crossvalidation and deviations must be specified"
msgstr "Se deben especificar tanto validación cruzada como desviaciones"
#: ../vector/v.vol.rst/main.c:491
-#, fuzzy
-msgid ""
-"Crossvalidation cannot be computed simultanuously with output grids or devi "
-"file"
-msgstr ""
-"La validación cruzada no se puede procesar de forma simultánea a la salida "
-"ráster o archivo devi"
+msgid "Crossvalidation cannot be computed simultanuously with output grids or devi file"
+msgstr "La validación cruzada puede ser calculada simultaneamente sin mallas de salida o archivos devi"
#: ../vector/v.vol.rst/main.c:507 ../vector/v.vol.rst/main.c:510
#: ../vector/v.vol.rst/main.c:513 ../vector/v.vol.rst/main.c:516
@@ -5601,31 +5176,31 @@
#: ../vector/v.surf.rst/main.c:487 ../vector/v.surf.rst/main.c:491
#: ../vector/v.surf.rst/main.c:496 ../vector/v.surf.rst/main.c:500
#: ../vector/v.surf.rst/main.c:504
-#, fuzzy, c-format
+#, c-format
msgid "Not enough memory for %s"
-msgstr "Memoria insuficiente para az"
+msgstr "Memoria insuficiente para %s"
#: ../vector/v.vol.rst/main.c:539 ../vector/v.vol.rst/main.c:544
#: ../vector/v.vol.rst/main.c:546 ../vector/v.surf.rst/main.c:511
#: ../vector/v.surf.rst/main.c:517 ../vector/v.surf.rst/main.c:520
#: ../vector/v.surf.rst/main.c:524
-#, fuzzy, c-format
+#, c-format
msgid "Unable to create %s"
-msgstr "No se puede crear la tabla: %s"
+msgstr "No ha sido posible crear %s"
#: ../vector/v.vol.rst/main.c:555
-#, fuzzy, c-format
+#, c-format
msgid "Unable to open %s"
-msgstr "No se puede abrir <%s>"
+msgstr "No ha sido posible abrir %s"
#: ../vector/v.vol.rst/main.c:563
msgid "Vector is not 3D"
msgstr "El vectorial no es 3D"
#: ../vector/v.vol.rst/main.c:605 ../vector/v.surf.rst/main.c:592
-#, fuzzy, c-format
+#, c-format
msgid "Unable to create table '%s'"
-msgstr "No se puede crear la tabla: '%s'"
+msgstr "No ha sido posible crear tabla '%s'"
#: ../vector/v.vol.rst/main.c:628 ../vector/v.vol.rst/main.c:659
#: ../vector/v.vol.rst/main.c:681 ../vector/v.vol.rst/main.c:703
@@ -5640,19 +5215,15 @@
#: ../vector/v.vol.rst/main.c:731 ../vector/v.vol.rst/main.c:753
#: ../vector/v.vol.rst/main.c:775 ../vector/v.vol.rst/main.c:797
msgid "Not enough disk space - cannot write temp files"
-msgstr ""
-"No hay suficiente espacio en disco -no es posible escribir archivos "
-"temporales"
+msgstr "No hay suficiente espacio en disco -no es posible escribir archivos temporales"
#: ../vector/v.vol.rst/main.c:640
-#, fuzzy
msgid "Unable to create cellout raster map without cellinp"
-msgstr "No se puede crear el mapa ráster <%s>"
+msgstr "o ha sido posible crear mapa ráster cellout sin cellinp"
#: ../vector/v.vol.rst/main.c:818
-#, fuzzy
msgid "Finished interpolating"
-msgstr "Interpolación bilineal."
+msgstr "Interpolación finalizada"
#: ../vector/v.vol.rst/main.c:853
#, c-format
@@ -5675,58 +5246,47 @@
msgstr "Falló la entrada"
#: ../vector/v.vol.rst/user3.c:548
-#, fuzzy
msgid "Secpar_loop failed"
-msgstr "Falló %s"
+msgstr "Ha fallado Secpar_loop"
#: ../vector/v.vol.rst/user3.c:588 ../vector/v.vol.rst/user3.c:599
#: ../vector/v.vol.rst/user3.c:610 ../vector/v.vol.rst/user3.c:621
#: ../vector/v.vol.rst/user3.c:632 ../vector/v.vol.rst/user3.c:643
#: ../vector/v.vol.rst/user3.c:654 ../vector/v.vol.rst/user3.c:665
-#, fuzzy
msgid "Not enough disk space--cannot write files"
-msgstr "%d bytes de espacio en disco para archivos temporales."
+msgstr "No hay suficiente espacio en el disco --no se pueden escribir archivos"
#: ../vector/v.vol.rst/user2.c:213
-#, fuzzy
msgid "Cannot allocate A"
-msgstr "No se puede asignar más memoria"
+msgstr "No se puede asignar A"
#: ../vector/v.vol.rst/user2.c:217
-#, fuzzy
msgid "Cannot allocate b"
+msgstr "No se puede asignar b"
#: ../vector/v.vol.rst/user2.c:221
-#, fuzzy
msgid "Cannot allocate w"
+msgstr "No se puede asignar w"
#: ../vector/v.vol.rst/user1.c:109
msgid "Column type of wcolumn is not supported (must be integer or double)"
msgstr "El tipo de la columna W no está soportado (debe ser entero o doble)"
#: ../vector/v.vol.rst/user1.c:123
-#, fuzzy
msgid "Cannot read column type of smooth column"
-msgstr "Valores del tipo de columna '%s' desconocido perdidos"
+msgstr "No se puede leer tipo de columna de columna smooth"
#: ../vector/v.vol.rst/user1.c:126
-#, fuzzy
msgid "Column type of smooth column (datetime) is not supported"
-msgstr ""
-"El tipo de columna suavizado no está soportado (debe ser entero o doble)"
+msgstr "Tipo de columna de columna smooth (datetime) no soportado"
#: ../vector/v.vol.rst/user1.c:128
-msgid ""
-"Column type of smooth column is not supported (must be integer or double)"
-msgstr ""
+msgid "Column type of smooth column is not supported (must be integer or double)"
+msgstr "El tipo de columna suavizado no está soportado (debe ser entero o doble)"
#: ../vector/v.vol.rst/user1.c:150
-#, fuzzy
msgid "Point without category"
-msgstr "Ningún punto con categoría [%d]"
+msgstr "Punto sin categoría"
#: ../vector/v.vol.rst/user1.c:172 ../vector/v.what.rast/main.c:609
#: ../vector/v.label.sa/labels.c:166 ../vector/v.buffer/main.c:526
@@ -5738,60 +5298,50 @@
msgstr "No hay registro para la categoría %d en la tabla <%s>"
#: ../vector/v.vol.rst/user1.c:208
-#, fuzzy
msgid "Some points outside of region -- will ignore..."
-msgstr "%d puntos fuera de la región actual fueron omitidos"
+msgstr "Algunos puntos está fuera de la región -- se ignorarán..."
#: ../vector/v.vol.rst/user1.c:215
-#, fuzzy
msgid "Cannot allocate memory for point"
-msgstr "No se puede asignar memoria para la cadena"
+msgstr "No se puede asignar memoria para punto"
#: ../vector/v.vol.rst/user1.c:223
#, c-format
msgid "Can't insert %lf,%lf,%lf,%lf,%lf a=%d"
-msgstr ""
+msgstr "No se puede insertar %lf,%lf,%lf,%lf,%lf a=%d"
#: ../vector/v.vol.rst/user1.c:270
msgid "Strip exists with insufficient data"
msgstr ""
#: ../vector/v.vol.rst/user1.c:280
-#, fuzzy
msgid "Zero segments!"
-msgstr "Procesando áreas de la entrada A..."
+msgstr "¡Cero segmetos!"
#: ../vector/v.vol.rst/user1.c:311
#, c-format
-msgid ""
-"There are points outside specified 2D/3D region--ignored %d points (total "
-"points: %d)"
-msgstr ""
+msgid "There are points outside specified 2D/3D region--ignored %d points (total points: %d)"
+msgstr "Hay puntos fuera de la región 2D/3D especificada--%d puntos ignorados (total de puntos: %d)"
#: ../vector/v.vol.rst/user1.c:315
#, c-format
-msgid ""
-"Points are more dense than specified 'DMIN'--ignored %d points (remain %d)"
-msgstr ""
+msgid "Points are more dense than specified 'DMIN'--ignored %d points (remain %d)"
+msgstr "Mayor densidad de puntos que 'DMIN' especificada--%d puntos ignorados (%d restantes)"
#: ../vector/v.vol.rst/user1.c:321
#, c-format
-msgid ""
-"%d points given for interpolation (after thinning) is less than given NPMIN="
-"%d"
-msgstr ""
+msgid "%d points given for interpolation (after thinning) is less than given NPMIN=%d"
+msgstr "%d puntos dados para interpolación (luego de adelgazamiento (thinning)) es menor que NPMIN=%d que se dio"
#: ../vector/v.vol.rst/user1.c:341
#, c-format
-msgid ""
-"There is less than %d points for interpolation, no segmentation is "
-"necessary, to run the program faster, set segmax=%d (see manual)"
-msgstr ""
+msgid "There is less than %d points for interpolation, no segmentation is necessary, to run the program faster, set segmax=%d (see manual)"
+msgstr "Hay menos de %d puntos para interpolación, no es necesaria la segmentación, para correr más rápido el programa definir segmax=%d (ver el manual)"
#: ../vector/v.vol.rst/user1.c:368
-#, fuzzy, c-format
+#, c-format
msgid "Mask raster map [%s] not found"
-msgstr "Mapa ráster 3D <%s> no encontrado"
+msgstr "Mapa ráster máscara [%s] no encontrado"
#: ../vector/v.vol.rst/user1.c:383
#, fuzzy
@@ -5802,33 +5352,32 @@
#: ../vector/v.vol.rst/user1.c:538 ../vector/v.vol.rst/user1.c:591
#: ../vector/v.vol.rst/user1.c:644 ../vector/v.vol.rst/user1.c:697
#: ../vector/v.vol.rst/user1.c:750
-#, fuzzy, c-format
+#, c-format
msgid "Unable to open %s for writing"
-msgstr "No se puede abrir el archivo <%s> para escribir"
+msgstr "No ha sido posible abrir %s para escritura"
#: ../vector/v.vol.rst/user1.c:443 ../vector/v.vol.rst/user1.c:496
#: ../vector/v.vol.rst/user1.c:549 ../vector/v.vol.rst/user1.c:602
#: ../vector/v.vol.rst/user1.c:655 ../vector/v.vol.rst/user1.c:708
#: ../vector/v.vol.rst/user1.c:761
-#, fuzzy
msgid "Unable to read data from temp file"
-msgstr "No se puede leer el archivo de color"
+msgstr "No ha sido posible leer datos desde archivo temporal"
#: ../vector/v.vol.rst/user1.c:461 ../vector/v.vol.rst/user1.c:514
#: ../vector/v.vol.rst/user1.c:567 ../vector/v.vol.rst/user1.c:620
#: ../vector/v.vol.rst/user1.c:673 ../vector/v.vol.rst/user1.c:726
#: ../vector/v.vol.rst/user1.c:779
-#, fuzzy, c-format
+#, c-format
msgid "Error writing cell (%d,%d,%d) with value %f"
-msgstr "Error escribiendo cell_misc/%s/gdal file"
+msgstr "Error al escribir celdas (%d,%d,%d) con valor %f"
#: ../vector/v.vol.rst/user1.c:474 ../vector/v.vol.rst/user1.c:527
#: ../vector/v.vol.rst/user1.c:580 ../vector/v.vol.rst/user1.c:633
#: ../vector/v.vol.rst/user1.c:686 ../vector/v.vol.rst/user1.c:739
#: ../vector/v.vol.rst/user1.c:792
-#, fuzzy, c-format
+#, c-format
msgid "Error closing output file %s"
-msgstr "Error al cerrar archivo ASCII"
+msgstr "Error al cerrar archivo de salida %s"
#: ../vector/v.vol.rst/user1.c:476 ../vector/v.vol.rst/user1.c:529
#: ../vector/v.vol.rst/user1.c:582 ../vector/v.vol.rst/user1.c:635
@@ -5852,21 +5401,16 @@
msgstr "Coste inicial desde el nodo %d"
#: ../vector/v.net.steiner/main.c:348
-#, fuzzy
msgid "steiner tree"
-msgstr "Ráster a eliminar"
+msgstr "árbol de Steiner"
#: ../vector/v.net.steiner/main.c:350
-#, fuzzy
msgid "Creates Steiner tree for the network and given terminals."
-msgstr "Crear árbol de Steiner para la red y terminales dados"
+msgstr "Crear árbol de Steiner para red y terminales dadas."
#: ../vector/v.net.steiner/main.c:352
-#, fuzzy
-msgid ""
-"Note that 'Minimum Steiner Tree' problem is NP-hard and heuristic algorithm "
-"is used in this module so the result may be sub optimal."
-msgstr "Tenga en cuenta que el PVV es"
+msgid "Note that 'Minimum Steiner Tree' problem is NP-hard and heuristic algorithm is used in this module so the result may be sub optimal."
+msgstr "Note que el problema del 'Árbol mínimo de Steiner' es NP-hard y se usa un algoritmo heurístico en este módulo por lo que el resultado puede ser subóptimo."
#: ../vector/v.net.steiner/main.c:373
msgid "Node layer (used for terminals)"
@@ -5881,9 +5425,8 @@
msgstr "Categorías de puntos en terminales (la capa se especifica por nlayer)"
#: ../vector/v.net.steiner/main.c:393
-#, fuzzy
msgid "Number of Steiner points (-1 for all possible)"
-msgstr "Número de puntos steiner (-1 para todos los posibles)"
+msgstr "Número de puntos Steiner (-1 para todos los posibles)"
#: ../vector/v.net.steiner/main.c:448
#, fuzzy, c-format
@@ -5914,17 +5457,12 @@
#: ../vector/v.net.steiner/main.c:522
#, c-format
msgid "Terminal at node [%d] cannot be connected to terminal at node [%d]"
-msgstr ""
-"La terminal en el nodo [%d] no se puede conectar a la terminal en el nodo "
-"[%d]"
+msgstr "La terminal en el nodo [%d] no se puede conectar a la terminal en el nodo [%d]"
#: ../vector/v.net.steiner/main.c:538
#, c-format
-msgid ""
-"[%d] (not reachable) nodes removed from list of Steiner point candidates"
-msgstr ""
-"[%d] nodos (no alcanzables) eliminados de la lista de puntos de Steiner "
-"candidatos"
+msgid "[%d] (not reachable) nodes removed from list of Steiner point candidates"
+msgstr "[%d] nodos (no alcanzables) eliminados de la lista de puntos de Steiner candidatos"
#: ../vector/v.net.steiner/main.c:543
#, c-format
@@ -5939,9 +5477,7 @@
#: ../vector/v.net.steiner/main.c:570
#, c-format
msgid "Steiner point at node [%d] was added to terminals (MST costs = %f)"
-msgstr ""
-"El punto de Steiner en el nodo [%d] se añadió a las terminales (coste MST = "
-"%f)"
+msgstr "El punto de Steiner en el nodo [%d] se añadió a las terminales (coste MST = %f)"
#: ../vector/v.net.steiner/main.c:582
msgid "No Steiner point found -> leaving cycle"
@@ -6006,25 +5542,20 @@
#: ../vector/v.in.db/main.c:55 ../vector/v.kcv/main.c:57
#: ../vector/v.out.lidar/main.c:474 ../vector/v.normal/main.c:74
#: ../vector/v.decimate/main.c:129
-#, fuzzy
msgid "points"
-msgstr "Puntos"
+msgstr "puntos"
#: ../vector/v.in.db/main.c:57
-msgid ""
-"Creates new vector (points) map from database table containing coordinates."
-msgstr ""
-"Crea un nuevo mapa vectorial (de puntos) a partir de una tabla de base de "
-"datos que contiene coordenadas."
+msgid "Creates new vector (points) map from database table containing coordinates."
+msgstr "Crea un nuevo mapa vectorial (de puntos) a partir de una tabla de base de datos que contiene coordenadas."
#: ../vector/v.in.db/main.c:61
msgid "Input table name"
msgstr "Nombre de tabla de entrada"
#: ../vector/v.in.db/main.c:66 ../vector/v.in.db/main.c:70
-#, fuzzy
msgid "Input DB"
-msgstr "Entrada"
+msgstr "DB de entrada"
#: ../vector/v.in.db/main.c:75
msgid "Name of column containing x coordinate"
@@ -6053,42 +5584,32 @@
msgstr "Se debe referir a una columna de enteros"
#: ../vector/v.in.db/main.c:101
-#, fuzzy
msgid "Use imported table as attribute table for new map"
-msgstr "Elimina la tabla de atributos existente de un mapa vectorial."
+msgstr "Usar tabla importada como tabla de atributos para mapa nuevo"
#: ../vector/v.in.db/main.c:141
#, c-format
-msgid ""
-"Vector map <%s> cannot be overwritten because input table <%s> is linked to "
-"this map."
-msgstr ""
+msgid "Vector map <%s> cannot be overwritten because input table <%s> is linked to this map."
+msgstr "Mapa vectorial <%s> no puede ser sobreescrito debido a que tabla de entrada <%s> está enlazada a este mapa."
#: ../vector/v.in.db/main.c:177
#, c-format
-msgid ""
-"Output vector map, table <%s> (driver: <%s>, database: <%s>) already exists"
-msgstr ""
-"La tabla del mapa vectorial de salida <%s> (controlador: <%s>, base de "
-"datos: <%s>) ya existe"
+msgid "Output vector map, table <%s> (driver: <%s>, database: <%s>) already exists"
+msgstr "La tabla del mapa vectorial de salida <%s> (controlador: <%s>, base de datos: <%s>) ya existe"
#: ../vector/v.in.db/main.c:190 ../vector/v.db.connect/main.c:295
msgid "Data type of key column must be integer"
msgstr "El tipo de datos de la columna clave debe ser entero"
#: ../vector/v.in.db/main.c:194
-#, fuzzy, c-format
+#, c-format
msgid "Option <%s> must be specified when -%c flag is given"
-msgstr ""
+msgstr "La opción <%s> debe ser especificada cuando se da la opción -%c"
#: ../vector/v.in.db/main.c:199
#, c-format
-msgid ""
-"Unable to define key column. This operation is not supported by <%s> driver. "
-"You need to define <%s> option."
-msgstr ""
+msgid "Unable to define key column. This operation is not supported by <%s> driver. You need to define <%s> option."
+msgstr "No ha sido posible definir columna clave. Esta operación no está soportada por controlador <%s>. Debe definir la opción <%s>."
#: ../vector/v.in.db/main.c:225 ../display/d.vect/attr.c:110
#: ../display/d.vect.chart/plot.c:86
@@ -6119,20 +5640,20 @@
msgstr "No se puede copiar la tabla"
#: ../vector/v.in.db/main.c:313
-#, fuzzy, c-format
+#, c-format
msgid "Unable to add key column <%s>: SERIAL type is not supported by <%s>"
+msgstr "No ha sido posible añadir columna clave <%s>: tipo SERIAL no está soportado por <%s>"
#: ../vector/v.in.db/main.c:324
-#, fuzzy, c-format
+#, c-format
msgid "Failed to update key column <%s>"
+msgstr "Hubo un fallo al actualizar columna clave <%s>"
#: ../vector/v.in.db/main.c:340
-#, fuzzy, c-format
+#, c-format
msgid "%d point written to vector map."
msgid_plural "%d points written to vector map."
-msgstr[0] "%d puntos escritos en mapa vectorial."
+msgstr[0] "%d punto escrito en mapa vectorial."
msgstr[1] "%d puntos escritos en mapa vectorial."
#: ../vector/v.in.pdal/projection.c:31 ../vector/v.in.lidar/projection.c:32
@@ -6142,8 +5663,7 @@
"Projection of dataset does not appear to match current location.\n"
"\n"
msgstr ""
-"La proyección del conjunto de datos parece no corresponder con la "
-"localización actual.\n"
+"La proyección del conjunto de datos parece no corresponder con la localización actual.\n"
"\n"
#: ../vector/v.in.pdal/projection.c:37 ../vector/v.in.lidar/projection.c:38
@@ -6157,9 +5677,7 @@
#: ../raster/r.in.lidar/projection.c:49 ../raster/r.in.lidar/projection.c:55
#: ../raster/r.external/proj.c:85 ../raster/r.in.gdal/main.c:531
msgid "Import dataset PROJ_INFO is:\n"
-msgstr ""
-"La información de proyección (PROJ_INFO) del conjunto de datos a importar "
-"es:\n"
+msgstr "La información de proyección (PROJ_INFO) del conjunto de datos a importar es:\n"
#: ../vector/v.in.pdal/projection.c:88 ../vector/v.in.lidar/projection.c:89
#: ../vector/v.in.ogr/main.c:689 ../raster/r.in.lidar/projection.c:91
@@ -6167,29 +5685,21 @@
#, c-format
msgid ""
"\n"
-"In case of no significant differences in the projection definitions, use the "
-"-o flag to ignore them and use current location definition.\n"
+"In case of no significant differences in the projection definitions, use the -o flag to ignore them and use current location definition.\n"
msgstr ""
+"\n"
+"En caso de que no haya diferencias significativas en las definiciones de proyección, use la bandera -o para ignorarlas y use la definición de la Localización actual.\n"
#: ../vector/v.in.pdal/projection.c:92 ../vector/v.in.lidar/projection.c:93
#: ../vector/v.in.ogr/main.c:693 ../raster/r.in.lidar/projection.c:95
-#, fuzzy
-msgid ""
-"Consider generating a new location with 'location' parameter from input data "
-"set.\n"
-msgstr ""
-"Considere generar una nueva localización con el parámetro 'localización' del "
-"conjunto de datos de entrada.\n"
+msgid "Consider generating a new location with 'location' parameter from input data set.\n"
+msgstr "Considere generar una nueva Localización con el parámetro 'location' del conjunto de datos de entrada.\n"
#: ../vector/v.in.pdal/projection.c:110 ../vector/v.in.pdal/projection.c:156
#: ../vector/v.in.pdal/projection.c:189 ../vector/v.in.lidar/projection.c:111
#: ../vector/v.in.ogr/main.c:603 ../raster/r.in.lidar/projection.c:113
-msgid ""
-"Unable to convert input map projection information to GRASS format for "
-"checking"
-msgstr ""
-"No se puede convertir información de la proyección del mapa de entrada a "
-"formato GRASS para comprobar"
+msgid "Unable to convert input map projection information to GRASS format for checking"
+msgstr "No se puede convertir información de la proyección del mapa de entrada a formato GRASS para comprobar"
#: ../vector/v.in.pdal/projection.c:125
#, fuzzy
@@ -6200,9 +5710,7 @@
#: ../vector/v.in.ogr/main.c:708 ../raster/r.in.lidar/projection.c:139
#: ../raster/r.external/proj.c:116 ../raster/r.in.gdal/main.c:569
msgid "Projection of input dataset and current location appear to match"
-msgstr ""
-"Las proyecciones del conjunto de datos de entrada y de la localización "
-"actual parecen coincidir"
+msgstr "Las proyecciones del conjunto de datos de entrada y de la localización actual parecen coincidir"
#: ../vector/v.in.pdal/filters.c:46
#, fuzzy, c-format
@@ -6262,28 +5770,25 @@
msgstr "patrón puntual"
#: ../vector/v.kcv/main.c:60
-#, fuzzy
msgid "Randomly partition points into test/train sets."
-msgstr "puntos."
+msgstr "Divide al azar los puntos en conjuntos de prueba/entrenamiento."
#: ../vector/v.kcv/main.c:70
msgid "Number of partitions"
msgstr "Número de particiones"
#: ../vector/v.kcv/main.c:71
-#, fuzzy
msgid "Must be > 1"
-msgstr "'layer' tiene que ser > 0"
+msgstr "Debe ser > 1"
#: ../vector/v.kcv/main.c:76
msgid "Name for new column to which partition number is written"
-msgstr ""
-"Nombre para la nueva columna en la que se escribe el número de partición"
+msgstr "Nombre para la nueva columna en la que se escribe el número de partición"
#: ../vector/v.kcv/main.c:85
-#, fuzzy, c-format
+#, c-format
msgid "'%s' must be > 1"
+msgstr "'%s' debe ser > 1"
#: ../vector/v.kcv/main.c:96 ../vector/v.kcv/main.c:186
#: ../vector/v.category/main.c:186 ../vector/v.category/main.c:250
@@ -6293,9 +5798,8 @@
msgstr "No se puede abrir el mapa vectorial <%s> al nivel topológico %d"
#: ../vector/v.kcv/main.c:102
-#, fuzzy
msgid "Layer number must be positive"
-msgstr "El tamaño del vecindario debe ser positivo"
+msgstr "El número de capa debe ser positivo"
#: ../vector/v.kcv/main.c:107
#, c-format
@@ -6308,19 +5812,18 @@
msgstr "No se puede obtener información de la capa para el mapa vectorial <%s>"
#: ../vector/v.kcv/main.c:145
-#, fuzzy, c-format
+#, c-format
msgid "Column <%s> already exists but is not numeric"
+msgstr "Columna <%s> ya existe pero no es numérica"
#: ../vector/v.kcv/main.c:160
-#, fuzzy, c-format
+#, c-format
msgid "Unable to alter table: %s"
+msgstr "No ha sido posible modificar tabla: %s"
#: ../vector/v.kcv/main.c:168 ../vector/v.db.connect/main.c:158
msgid "Unable to modify vector map stored in other mapset"
-msgstr ""
-"No se pueden editar mapas vectoriales guardados en otro directorio de mapas"
+msgstr "No se pueden editar mapas vectoriales guardados en otro directorio de mapas"
#: ../vector/v.kcv/main.c:179 ../vector/v.db.connect/main.c:341
#, c-format
@@ -6332,9 +5835,9 @@
msgstr "Los privilegios seleccionados fueron asignados sobre la tabla"
#: ../vector/v.kcv/main.c:267
-#, fuzzy, c-format
+#, c-format
msgid "No category for line %d in layer %d"
-msgstr "Ningún registro para el punto (cat = %d)"
+msgstr "No hay categoría para línea %d en capa %d"
#: ../vector/v.kcv/main.c:284 ../vector/v.sample/main.c:263
#, c-format
@@ -6342,28 +5845,24 @@
msgstr "No se puede insertar la fila: %s"
#: ../vector/v.kcv/main.c:300
-#, fuzzy
msgid "internal error"
-msgstr "%d errores al insertar"
+msgstr "error interno"
#: ../vector/v.net.visibility/main.c:48
msgid "visibility"
msgstr "visibilidad"
#: ../vector/v.net.visibility/main.c:49
-#, fuzzy
msgid "Performs visibility graph construction."
-msgstr "Construcción de gráfico de visibilidad."
+msgstr "Realiza construcción de gráfica de visibilidad."
#: ../vector/v.net.visibility/main.c:60
-#, fuzzy
msgid "Name of input vector map containing visable points"
-msgstr "Nombre del mapa vectorial de entrada que contiene líneas"
+msgstr "Nombre de mapa vectorial de entrada que contiene puntos visibles"
#: ../vector/v.net.visibility/main.c:61
-#, fuzzy
msgid "Add points after computing the visibility graph"
-msgstr "Añadir puntos después de computar el gráfico vis"
+msgstr "Añadir puntos después de calcular gráfica de visibilidad"
#: ../vector/v.net.visibility/main.c:85
#, c-format
@@ -6383,54 +5882,43 @@
#: ../raster/r.support/main.c:55 ../raster/r.timestamp/main.c:36
#: ../raster/r.describe/main.c:55 ../raster/r.region/main.c:52
#: ../raster/r.info/main.c:71
-#, fuzzy
msgid "metadata"
-msgstr "Metadatos"
+msgstr "metadatos"
#: ../vector/v.info/main.c:39 ../vector/v.build/main.c:37
#: ../vector/v.clean/main.c:52 ../vector/v.build.polylines/main.c:112
#: ../vector/v.out.postgis/main.c:48
#: ../locale/scriptstrings/v.build.all_to_translate.c:3
#: ../locale/scriptstrings/t.topology_to_translate.c:3
-#, fuzzy
msgid "topology"
-msgstr "vectorial, topología"
+msgstr "topología"
#: ../vector/v.info/main.c:40 ../locale/scriptstrings/t.info_to_translate.c:4
#: ../raster3d/r3.info/main.c:78 ../raster/r.info/main.c:72
-#, fuzzy
msgid "extent"
-msgstr "general"
+msgstr "extensión"
#: ../vector/v.info/main.c:41 ../raster/r.info/main.c:73
msgid "history"
msgstr "historia"
#: ../vector/v.info/main.c:42
-#, fuzzy
msgid "attribute columns"
-msgstr "Copiar atributos"
+msgstr "columna de atributos"
#: ../vector/v.info/main.c:45
-#, fuzzy
msgid "Outputs basic information about a vector map."
-msgstr ""
-"Muestra información básica sobre una capa de mapa vectorial especificada por "
-"el usuario."
+msgstr "Muestra información básica sobre un mapa vectorial."
#: ../vector/v.info/print.c:130
#, c-format
msgid "Database connection for map <%s> is not defined in DB file"
-msgstr ""
-"La conexión a la base de datos para el mapa <%s> no está definida en el "
-"archivo DB"
+msgstr "La conexión a la base de datos para el mapa <%s> no está definida en el archivo DB"
#: ../vector/v.info/print.c:134
-#, fuzzy, c-format
+#, c-format
msgid "Displaying column types/names for database connection of layer <%s>:"
-msgstr ""
-"Mostrando tipos/nombres de columna para la conexión a base de datos de la "
-"capa %d:"
+msgstr "Mostrando tipos/nombres de columna para la conexión a base de datos de la capa <%s>:"
#: ../vector/v.info/print.c:142
#, c-format
@@ -6438,166 +5926,137 @@
msgstr "No se puede abrir el driver <%s>"
#: ../vector/v.info/print.c:305
-#, fuzzy
msgid "Name:"
-msgstr "nombre"
+msgstr "Nombre:"
#: ../vector/v.info/print.c:308
msgid "Mapset:"
msgstr "Directorio de mapas:"
#: ../vector/v.info/print.c:312
-#, fuzzy
msgid "Location:"
-msgstr "Localización: %s\n"
+msgstr "Localización:"
#: ../vector/v.info/print.c:315
-#, fuzzy
msgid "Database:"
-msgstr "Controlador de base de datos"
+msgstr "Base de datos:"
#: ../vector/v.info/print.c:319
-#, fuzzy
msgid "Title:"
-msgstr "Archivos"
+msgstr "Título:"
#: ../vector/v.info/print.c:322
-#, fuzzy
msgid "Map scale:"
-msgstr "Escala del mapa: 1:%d"
+msgstr "Escala de mapa:"
#: ../vector/v.info/print.c:326
-#, fuzzy
msgid "Name of creator:"
-msgstr "Nombre del creador: %s"
+msgstr "Nombre del creador:"
#: ../vector/v.info/print.c:329
-#, fuzzy
msgid "Organization:"
-msgstr "Organización: %s"
+msgstr "Organización:"
#: ../vector/v.info/print.c:332
-#, fuzzy
msgid "Source date:"
-msgstr "Fecha del origen: %s"
+msgstr "Fecha del origen:"
#: ../vector/v.info/print.c:339
msgid "Timestamp (first layer): "
-msgstr ""
+msgstr "Marca de tiempo (primer capa):"
#: ../vector/v.info/print.c:343
msgid "Timestamp (first layer): none"
-msgstr ""
+msgstr "Marca de tiempo (primer capa): nada"
#: ../vector/v.info/print.c:351 ../vector/v.info/print.c:375
#: ../vector/v.info/print.c:415
-#, fuzzy
msgid "Map format:"
-msgstr "Formato del mapa: %s"
+msgstr "Formato del mapa:"
#: ../vector/v.info/print.c:356
-#, fuzzy
msgid "OGR layer:"
-msgstr "A la capa"
+msgstr "Capa OGR:"
#: ../vector/v.info/print.c:359
-#, fuzzy
msgid "OGR datasource:"
+msgstr "Fuente de datos OGR:"
#: ../vector/v.info/print.c:362 ../vector/v.info/print.c:391
-#, fuzzy
msgid "Feature type:"
-msgstr "Tipo de elemento"
+msgstr "Tipo de elemento:"
#: ../vector/v.info/print.c:380
-#, fuzzy
msgid "DB table:"
-msgstr "Ninguna tabla"
+msgstr "Tabla DB:"
#: ../vector/v.info/print.c:383
-#, fuzzy
msgid "DB name:"
-msgstr "nombre"
+msgstr "Nombre DB"
#: ../vector/v.info/print.c:387
-#, fuzzy
msgid "Geometry column:"
-msgstr "Columna de coste de nodo"
+msgstr "Columna de geometría:"
#: ../vector/v.info/print.c:401 ../vector/v.info/print.c:410
-#, fuzzy
msgid "Topology:"
+msgstr "Topología:"
#: ../vector/v.info/print.c:402
msgid "schema:"
msgstr "esquema:"
#: ../vector/v.info/print.c:406
-#, fuzzy
msgid "Topology column:"
-msgstr "Columnas"
+msgstr "Columna de topología"
#: ../vector/v.info/print.c:424
-#, fuzzy
msgid "Type of map"
-msgstr "Nombre de un elemento"
+msgstr "Tipo de mapa"
-#, fuzzy
msgid "level"
-msgstr "Etiquetas"
+msgstr "nivel"
#: ../vector/v.info/print.c:431
-#, fuzzy
msgid "Number of points:"
-msgstr "Número de líneas"
+msgstr "Cantidad de puntos:"
#: ../vector/v.info/print.c:433
-#, fuzzy
msgid "Number of centroids:"
+msgstr "Cantidad de centroides:"
#: ../vector/v.info/print.c:438
-#, fuzzy
msgid "Number of lines:"
-msgstr "Número de walkers"
+msgstr "Cantidad de líneas:"
#: ../vector/v.info/print.c:440
-#, fuzzy
msgid "Number of boundaries:"
-msgstr "Número de marcos"
+msgstr "Cantidad de contornos:"
#: ../vector/v.info/print.c:445
-#, fuzzy
msgid "Number of areas:"
+msgstr "Cantidad de áreas:"
#: ../vector/v.info/print.c:447
-#, fuzzy
msgid "Number of islands:"
-msgstr "Número de columnas"
#: ../vector/v.info/print.c:453
-#, fuzzy
msgid "Number of faces:"
-msgstr "Número de fotogramas"
+msgstr "Cantidad de faces:"
#: ../vector/v.info/print.c:455
-#, fuzzy
msgid "Number of kernels:"
+msgstr "Cantidad de kernels:"
#: ../vector/v.info/print.c:460
-#, fuzzy
msgid "Number of volumes:"
+msgstr "Cantidad de volúmenes:"
#: ../vector/v.info/print.c:462
-#, fuzzy
msgid "Number of holes:"
+msgstr "Cantidad de agujeros:"
#: ../vector/v.info/print.c:469
msgid "Map is 3D:"
@@ -6612,77 +6071,58 @@
msgstr "No"
#: ../vector/v.info/print.c:473
-#, fuzzy
msgid "Number of dblinks:"
+msgstr "Cantidad de dblinks:"
#: ../vector/v.info/print.c:486
-#, fuzzy
msgid "invalid"
-msgstr "Orden no válida"
+msgstr "no válida"
#: ../vector/v.info/print.c:488
-#, fuzzy
msgid "unspecified"
-msgstr "Ninguna regla especificada"
+msgstr "no especificado"
#: ../vector/v.info/print.c:493 ../vector/v.info/print.c:498
-#, fuzzy
msgid "Projection"
-msgstr "Proyecciones"
+msgstr "Proyección"
#: ../vector/v.info/print.c:494
-#, fuzzy
msgid "zone"
-msgstr "Zona horaria"
+msgstr "zona"
#: ../vector/v.info/print.c:527
-#, fuzzy
msgid "Digitization threshold"
-msgstr " Umbral de digitalización: %s"
+msgstr "Umbral de digitalización"
#: ../vector/v.info/print.c:529
-#, fuzzy
msgid "Comment"
-msgstr " Comentarios:"
+msgstr "Comentario"
#: ../vector/v.info/parse.c:24
-#, fuzzy
msgid "Print history instead of info and exit"
-msgstr "Imprimir histórico del ráster en vez de información"
+msgstr "Mostrar historia en vez de información y salir"
#: ../vector/v.info/parse.c:30
-#, fuzzy
-msgid ""
-"Print types/names of table columns for specified layer instead of info and "
-"exit"
-msgstr ""
-"Imprimir tipos/nombre de columnas de tabla para la capa especificada, en vez "
-"de información"
+msgid "Print types/names of table columns for specified layer instead of info and exit"
+msgstr "Mostrar tipos/nombres de columnas de tabla para la capa especificada, en vez de información y salir"
#: ../vector/v.info/parse.c:35
-#, fuzzy
msgid "Print region info in shell script style"
-msgstr ""
-"Imprimir información en el estilo de script de la consola de comandos de UNIX"
+msgstr "Mostrar información en estilo de script de la consola de comandos de UNIX"
#: ../vector/v.info/parse.c:40
-#, fuzzy
msgid "Print extended metadata info in shell script style"
+msgstr "Mostrar información de metadatos extendidos en estilo de consola de comandos UNIX"
#: ../vector/v.info/parse.c:45
-#, fuzzy
msgid "Print topology info in shell script style"
-msgstr ""
+msgstr "Mostrar información de topología estilo consola de comandos"
#: ../vector/v.to.3d/main.c:38 ../vector/v.hull/main.c:54
#: ../vector/v.drape/main.c:59 ../vector/v.surf.rst/main.c:144
#: ../vector/v.extrude/main.c:70 ../vector/v.out.postgis/main.c:49
-#, fuzzy
msgid "3D"
-msgstr "D"
+msgstr "3D"
#: ../vector/v.to.3d/main.c:40
msgid "Performs transformation of 2D vector features to 3D."
@@ -6722,18 +6162,17 @@
msgstr "Extensión vertical del mapa vectorial <%s>: B: %f T: %f"
#: ../vector/v.to.3d/trans3.c:45 ../vector/v.to.3d/trans2.c:43
-#, fuzzy, c-format
+#, c-format
msgid "Invalid layer number %d, assuming 1"
-msgstr "Número de tramos inválido: %s"
+msgstr "Número de capa %d no válido, asumiendo 1"
#: ../vector/v.to.3d/trans3.c:69 ../vector/v.to.3d/trans2.c:67
msgid "Column must be numeric"
msgstr "La columna tiene que ser numérica"
#: ../vector/v.to.3d/trans3.c:75
-#, fuzzy
msgid "Reading categories..."
-msgstr "Adjuntando categorías..."
+msgstr "Leyendo categorías..."
#: ../vector/v.to.3d/trans3.c:80 ../vector/v.to.3d/trans2.c:79
#: ../vector/v.transform/main.c:277
@@ -6751,18 +6190,17 @@
msgstr "El elemento id %d tiene más categorías. Utilizando categoría %d."
#: ../vector/v.to.3d/trans3.c:130 ../vector/v.to.db/update.c:222
-#, fuzzy, c-format
+#, c-format
msgid "Record (cat %d) does not exist (not updated)"
-msgstr "Categoría [%d]: la fila no existe (no se actualiza)"
+msgstr "Registro (cat %d) no existe (no actualizado)"
#: ../vector/v.to.3d/args.c:11
msgid "Reverse transformation; 3D vector features to 2D"
msgstr "Transformación inversa; elementos vectoriales 3D a 2D"
#: ../vector/v.to.3d/args.c:14
-#, fuzzy
msgid "Do not copy attribute table"
-msgstr "No copiar tabla"
+msgstr "No copiar tabla de atributos"
#: ../vector/v.to.3d/args.c:30
msgid "Name of attribute column used for height"
@@ -6770,9 +6208,7 @@
#: ../vector/v.to.3d/args.c:32
msgid "Can be used for reverse transformation, to store height of points"
-msgstr ""
-"Se puede utilizar para transformación inversa, para almacena la altura de "
-"los puntos"
+msgstr "Se puede utilizar para transformación inversa, para almacena la altura de los puntos"
#: ../vector/v.to.3d/args.c:33 ../vector/v.to.3d/args.c:41
#: ../vector/v.extrude/main.c:105 ../vector/v.extrude/main.c:113
@@ -6799,22 +6235,20 @@
msgstr "No es posible obtener la altura para la categoría del elemento %d"
#: ../vector/v.overlay/main.c:64 ../vector/v.select/main.c:50
-#, fuzzy
msgid "spatial query"
-msgstr "vectorial, consultar"
+msgstr "consulta espacial"
#: ../vector/v.overlay/main.c:65
-#, fuzzy
msgid "intersection"
+msgstr "intersección"
#: ../vector/v.overlay/main.c:66
msgid "union"
-msgstr ""
+msgstr "unión"
#: ../vector/v.overlay/main.c:67
msgid "clip"
-msgstr ""
+msgstr "corte"
#: ../vector/v.overlay/main.c:68
msgid "Overlays two vector maps."
@@ -6825,9 +6259,8 @@
msgstr "Nombre del mapa vectorial de entrada (A)"
#: ../vector/v.overlay/main.c:75
-#, fuzzy
msgid "Layer number or name (vector map A)"
-msgstr "Nombre del mapa vectorial de entrada"
+msgstr "Número de capa o nombre (mapa vectorial A)"
#: ../vector/v.overlay/main.c:79 ../vector/v.select/args.c:21
msgid "Feature type (vector map A)"
@@ -6838,9 +6271,8 @@
msgstr "Nombre del mapa vectorial de entrada (B)"
#: ../vector/v.overlay/main.c:89
-#, fuzzy
msgid "Layer number or name (vector map B)"
+msgstr "Número de capa o nombre (mapa vectorial B)"
#: ../vector/v.overlay/main.c:93 ../vector/v.select/args.c:36
msgid "Feature type (vector map B)"
@@ -6848,36 +6280,27 @@
#: ../vector/v.overlay/main.c:104
msgid "Operator defines features written to output vector map"
-msgstr ""
-"El operador define los elementos escritos en el mapa vectorial de salida"
+msgstr "El operador define los elementos escritos en el mapa vectorial de salida"
#: ../vector/v.overlay/main.c:107
-msgid ""
-"Feature is written to output if the result of operation 'ainput operator "
-"binput' is true. Input feature is considered to be true, if category of "
-"given layer is defined."
-msgstr ""
-"El elemento se escribe en la salida si el resultado de la operación 'entrada "
-"A operador entrada B' es verdadero. Un elemento de entrada se considera "
-"verdadero si se define la categoría de la capa dada."
+msgid "Feature is written to output if the result of operation 'ainput operator binput' is true. Input feature is considered to be true, if category of given layer is defined."
+msgstr "El elemento se escribe en la salida si el resultado de la operación 'entrada A operador entrada B' es verdadero. Un elemento de entrada se considera verdadero si se define la categoría de la capa dada."
#: ../vector/v.overlay/main.c:114
msgid "also known as 'intersection' in GIS"
-msgstr ""
+msgstr "también conocido en SIG como 'intersección'"
#: ../vector/v.overlay/main.c:115
msgid "also known as 'union' in GIS (only for atype=area)"
-msgstr ""
+msgstr "también conocido en SIG como 'unión' (solamente para atype=area)"
#: ../vector/v.overlay/main.c:116
msgid "features from ainput not overlayed by features from binput"
-msgstr ""
+msgstr "elementos de ainput no están sobrepuestos por elementos de binput"
#: ../vector/v.overlay/main.c:117
-msgid ""
-"features from either ainput or binput but not those from ainput overlayed by "
-"binput (only for atype=area)"
-msgstr ""
+msgid "features from either ainput or binput but not those from ainput overlayed by binput (only for atype=area)"
+msgstr "elementos ya sea de ainput o binput pero no aquellos de ainput sobrepuestos por binput (solamente para atype=area)"
#: ../vector/v.overlay/main.c:128
msgid "Output layer for new category, ainput and binput"
@@ -6889,26 +6312,26 @@
#: ../vector/v.overlay/main.c:136
msgid "Snapping threshold for boundaries"
-msgstr "Umbral de salto para contornos"
+msgstr "Umbral de ensamblado para contornos"
#: ../vector/v.overlay/main.c:137
msgid "Disable snapping with snap <= 0"
-msgstr ""
+msgstr "Deshabilitar ensamblado con snap <= 0"
#: ../vector/v.overlay/main.c:171 ../vector/v.select/main.c:85
-#, fuzzy, c-format
+#, c-format
msgid "Unknown operator '%s'"
-msgstr "Operador desconocido"
+msgstr "Operador desconocido '%s'"
#: ../vector/v.overlay/main.c:188
-#, fuzzy, c-format
+#, c-format
msgid "Unable to determine feature type for <%s>"
-msgstr "No se puede determinar el tipo de celda ráster"
+msgstr "No ha sido posible determinar tipo de elemento para <%s>"
#: ../vector/v.overlay/main.c:194
-#, fuzzy, c-format
+#, c-format
msgid "Invalid feature type (%d) for <%s>. Only '%s' or '%s' supported."
-msgstr "Tipo de columna (%s) no soportado"
+msgstr "Tipo de elemento (%d) no válido para <%s>. Solamente están soportados '%s' o '%s'"
#: ../vector/v.overlay/main.c:202
#, c-format
@@ -6917,21 +6340,18 @@
#: ../vector/v.overlay/main.c:220 ../vector/v.buffer/main.c:400
#: ../vector/v.in.ogr/main.c:931
-#, fuzzy
msgid "Unable to create temporary vector map"
-msgstr "No se puede leer el mapa vectorial"
+msgstr "No ha sido posible crear mapa vectorial temporal"
#: ../vector/v.overlay/main.c:257
-#, fuzzy, c-format
+#, c-format
msgid "Copying vector features from <%s>..."
-msgstr "Copiando objetos vectoriales del mapa vectorial <%s>..."
+msgstr "Copiando elementos vectoriales desde <%s>"
#: ../vector/v.overlay/main.c:338
#, c-format
msgid "No %s features found in vector map <%s>. Verify '%s' parameter."
-msgstr ""
-"No se han encontrado elementos %s en el mapa vectorial <%s>. Verificar "
-"parámetro '%s'."
+msgstr "No se han encontrado elementos %s en el mapa vectorial <%s>. Verificar parámetro '%s'."
#: ../vector/v.overlay/main.c:387
msgid "Collecting input attributes..."
@@ -6943,9 +6363,9 @@
msgstr "No se pueden seleccionar los atributos"
#: ../vector/v.overlay/main.c:467
-#, fuzzy, c-format
+#, c-format
msgid "Unknown column type '%s' of column '%s'"
+msgstr "Tipo de columna '%s' desconocido en la columna '%s'"
#: ../vector/v.overlay/main.c:480 ../vector/v.out.svg/main.c:400
#: ../vector/v.out.vtk/writeVTK.c:589 ../vector/v.out.ogr/attrb.c:53
@@ -6954,21 +6374,21 @@
msgstr "No se pueden recopilar datos de la tabla"
#: ../vector/v.overlay/main.c:532
-#, fuzzy, c-format
+#, c-format
msgid "Unknown column type '%s' of column '%s', values lost"
+msgstr "Tipo de columna '%s' desconocido en la columna '%s', valores perdidos"
#: ../vector/v.overlay/area_area.c:51
-#, fuzzy, c-format
+#, c-format
msgid "Snapping boundaries with %g ..."
-msgstr "Autoensamblando contornos..."
+msgstr "Ensamblando contornos con %g..."
#: ../vector/v.overlay/area_area.c:99
-#, fuzzy, c-format
+#, c-format
msgid "%d boundary snapped"
msgid_plural "%d boundaries snapped"
-msgstr[0] "%d contornos cerrados"
-msgstr[1] "%d contornos cerrados"
+msgstr[0] "%d contorno ensamblado"
+msgstr[1] "%d contornos ensamblados"
#: ../vector/v.overlay/area_area.c:109 ../vector/v.overlay/line_area.c:255
msgid "Breaking lines..."
@@ -7019,9 +6439,8 @@
msgstr "No se pueden insertar nuevos registros: '%s'"
#: ../vector/v.overlay/line_area.c:272
-#, fuzzy
msgid "Selecting lines..."
-msgstr "Seleccionando elementos..."
+msgstr "Seleccionando líneas..."
#: ../vector/v.build/main.c:39
msgid "Creates topology for vector map."
@@ -7036,11 +6455,8 @@
msgstr "Nombre de mapa vectorial"
#: ../vector/v.build/main.c:49
-#, fuzzy
-msgid ""
-"Name for output vector map where erroneous vector features are written to"
-msgstr ""
-"Nombre del mapa vectorial donde se escriben elementos vectoriales erróneos"
+msgid "Name for output vector map where erroneous vector features are written to"
+msgstr "Nombre de mapa vectorial de salida en donde se escribirán los elementos vectoriales erroneos"
#: ../vector/v.build/main.c:61
msgid "Build topology or dump topology or indices to standard output"
@@ -7051,42 +6467,33 @@
msgstr "construir topología"
#: ../vector/v.build/main.c:66
-#, fuzzy
msgid "write topology to stdout"
-msgstr "\"-\" para escribir a stdout"
+msgstr "escribir topología a salida estándar (stdout)"
#: ../vector/v.build/main.c:67
msgid "write spatial index to stdout"
msgstr "escribir índice espacial en la stdout"
#: ../vector/v.build/main.c:68
-#, fuzzy
msgid "write category index to stdout"
+msgstr "escribir índice de categoría en salida estándar (stdout)"
#: ../vector/v.build/main.c:69
msgid "write feature index to stdout (OGR simple-feature-based formats only)"
-msgstr ""
-"escribir un índice del elemento para stdout (solo para formatos OGR basados "
-"en elementos simples)"
+msgstr "escribir un índice del elemento para stdout (solo para formatos OGR basados en elementos simples)"
#: ../vector/v.build/main.c:75
msgid "Extensive checks for topological errors"
-msgstr ""
+msgstr "Revisiones extensivas de errores topológicos"
#: ../vector/v.build/main.c:76
msgid "Perform in-depth checks for topological errors when building topology"
-msgstr ""
+msgstr "Realiza revisión a profundidad de errores topológicos cuando se está construyendo la topología"
#: ../vector/v.build/main.c:106
#, c-format
-msgid ""
-"Direct read access to OGR layers is not supported by this module. Run %s to "
-"create a link as GRASS vector map in the current mapset."
-msgstr ""
-"La lectura directa del acceso a capas OGR no está soportada para este "
-"módulo. Ejecutar %s para crear un enlace como un mapa vectorial de GRASS en "
-"el directorio de mapas actual."
+msgid "Direct read access to OGR layers is not supported by this module. Run %s to create a link as GRASS vector map in the current mapset."
+msgstr "La lectura directa del acceso a capas OGR no está soportada para este módulo. Ejecutar %s para crear un enlace como un mapa vectorial de GRASS en el directorio de mapas actual."
#: ../vector/v.build/main.c:111
#, c-format
@@ -7128,10 +6535,8 @@
msgstr "Altura z máxima (necesita -z flag o column name)"
#: ../vector/v.random/main.c:150
-msgid ""
-"The seed to initialize the random generator. If not set the process ID is "
-"used"
-msgstr ""
+msgid "The seed to initialize the random generator. If not set the process ID is used"
+msgstr "La semilla para inicializar el generador aleatorio, Si no se define se usan las ID de lo procesos"
#: ../vector/v.random/main.c:153
msgid "Name of column for z values"
@@ -7161,10 +6566,8 @@
#: ../vector/v.random/main.c:205 ../vector/v.drape/main.c:150
#: ../vector/v.buffer/main.c:348
#, c-format
-msgid ""
-"Invalid layer number (%d). Parameter '%s' or '%s' specified, assuming layer "
-"'1'."
-msgstr ""
+msgid "Invalid layer number (%d). Parameter '%s' or '%s' specified, assuming layer '1'."
+msgstr "Número de capa (%d) no válido. Parámetro '%s' o '%s' especificados, asumiendo capa '1'."
#: ../vector/v.random/main.c:215
#, c-format
@@ -7190,20 +6593,13 @@
msgstr "La tabla tendría que contener sólo dos columnas"
#: ../vector/v.random/main.c:283
-msgid ""
-"You have created unsupported column type. This module supports only INTEGER "
-"and DOUBLE PRECISION column types."
-msgstr ""
-"Has creado un tipo de columna que no puede soportarse. Este módulo soporta "
-"sólo tipos de columna INTEGER i DOUBLE PRECISION."
+msgid "You have created unsupported column type. This module supports only INTEGER and DOUBLE PRECISION column types."
+msgstr "Has creado un tipo de columna que no puede soportarse. Este módulo soporta sólo tipos de columna INTEGER i DOUBLE PRECISION."
#: ../vector/v.random/main.c:346
#, c-format
-msgid ""
-"Selected areas in input vector <%s> do not overlap with the current region"
-msgstr ""
-"Áreas seleccionadas del vectorial de entrada <%s> no se sobrelapan con la "
-"región actual"
+msgid "Selected areas in input vector <%s> do not overlap with the current region"
+msgstr "Áreas seleccionadas del vectorial de entrada <%s> no se sobrelapan con la región actual"
#: ../vector/v.random/main.c:358
#, c-format
@@ -7234,21 +6630,17 @@
#: ../vector/v.what.rast/main.c:77 ../vector/v.drape/main.c:60
#: ../vector/v.what.rast3/main.c:70
-#, fuzzy
msgid "surface information"
-msgstr "vectorial, transformación"
+msgstr "información de superficie"
#: ../vector/v.what.rast/main.c:79
msgid "Uploads raster values at positions of vector points to the table."
-msgstr ""
-"Carga valores ráster en las posiciones de puntos vectoriales a la tabla."
+msgstr "Carga valores ráster en las posiciones de puntos vectoriales a la tabla."
#: ../vector/v.what.rast/main.c:83 ../vector/v.what.rast3/main.c:76
#: ../locale/scriptstrings/v.what.vect_to_translate.c:8
-#, fuzzy
msgid "Name of vector points map for which to edit attributes"
-msgstr ""
-"Nombre del mapa vectorial de puntos para el que editar la tabla de atributos"
+msgstr "Nombre de mapa vectorial de puntos del cual se editarán atributos"
#: ../vector/v.what.rast/main.c:93
msgid "Name of existing raster map to be queried"
@@ -7256,18 +6648,16 @@
#: ../vector/v.what.rast/main.c:98 ../vector/v.what.rast3/main.c:87
#: ../locale/scriptstrings/v.what.vect_to_translate.c:11
-#, fuzzy
msgid "Name of attribute column to be updated with the query result"
-msgstr "Columna a actualizar con el resultado de la consulta"
+msgstr "Nombre de la columna de atributos en la que se subirán los resultados de la búsqueda"
#: ../vector/v.what.rast/main.c:105
msgid "Interpolate values from the nearest four cells"
-msgstr ""
+msgstr "Interpola valores desde las cuatro celdas vecinas"
#: ../vector/v.what.rast/main.c:110
-#, fuzzy
msgid "Print categories and values instead of updating the database"
-msgstr "Imprimir valores medios en vez de intervalos"
+msgstr "Mostrar categorías y valores en vez de actualizar la base de datos"
#: ../vector/v.what.rast/main.c:170
#, fuzzy, c-format
@@ -7287,19 +6677,16 @@
#: ../vector/v.what.rast/main.c:189
msgid "Raster type is float and column type is integer, some data lost!!"
-msgstr ""
-"El tipo ráster es coma flotante y el tipo de columna es entero, ¡¡algunos "
-"datos perdidos!!"
+msgstr "El tipo ráster es coma flotante y el tipo de columna es entero, ¡¡algunos datos perdidos!!"
#: ../vector/v.what.rast/main.c:206 ../vector/v.what.rast3/main.c:158
-#, fuzzy
msgid "Reading features from vector map..."
-msgstr "Leyendo datos del mapa..."
+msgstr "Leyendo elementos desde mapa vectorial..."
#: ../vector/v.what.rast/main.c:257
-#, fuzzy, c-format
+#, c-format
msgid "No features of type (%s) found in vector map <%s>"
-msgstr "Encontradas %d líneas o contornos en el mapa vectorial <%s@%s>"
+msgstr "No hay elementos de tipo (%s) encontrados en mapa vectorial <%s>"
#: ../vector/v.what.rast/main.c:281
#, c-format
@@ -7312,9 +6699,9 @@
msgstr "%d puntos sin categoría fueron omitidos"
#: ../vector/v.what.rast/main.c:556 ../vector/v.what.rast/main.c:596
-#, fuzzy, c-format
+#, c-format
msgid "Multiple points (%d) of category %d, value set to 'NULL'"
-msgstr "Más puntos (%d) de categoría %d, el valor se establece a 'NULO'"
+msgstr "Varios puntos (%d) de categoría %d, valor que se definira como 'NULL'"
#: ../vector/v.what.rast/main.c:664
#, c-format
@@ -7322,9 +6709,9 @@
msgstr "%d categorías cargadas del vectorial"
#: ../vector/v.what.rast/main.c:666
-#, fuzzy, c-format
+#, c-format
msgid "%d duplicate categories in vector map <%s>"
-msgstr "%d categorías duplicadas en el vectorial"
+msgstr "%d categorías duplicadas en el mapa vectorial <%s>"
#: ../vector/v.what.rast/main.c:670
#, c-format
@@ -7343,40 +6730,35 @@
msgstr "%d errores al actualizar"
#: ../vector/v.what.rast/main.c:676 ../vector/v.distance/main.c:1672
-#, fuzzy, c-format
+#, c-format
msgid "%d records updated."
-msgstr "%d registros actualizados"
+msgstr "%d registros actualizados."
#: ../vector/v.vect.stats/main.c:131 ../vector/v.univar/main.c:94
#: ../locale/scriptstrings/v.rast.stats_to_translate.c:5
#: ../raster/r.univar/r3.univar_main.c:100
#: ../raster/r.univar/r.univar_main.c:106
-#, fuzzy
msgid "univariate statistics"
-msgstr "Actualizar estadísticas del mapa ráster"
+msgstr "estadísticas univariadas"
#: ../vector/v.vect.stats/main.c:132
#: ../locale/scriptstrings/v.rast.stats_to_translate.c:6
#: ../raster/r.univar/r.univar_main.c:107 ../raster/r.stats.zonal/main.c:103
#: ../raster/r.statistics/main.c:57
-#, fuzzy
msgid "zonal statistics"
-msgstr "ráster, estadísticas"
+msgstr "estadísticas de zona"
#: ../vector/v.vect.stats/main.c:133
-#, fuzzy
msgid "Count points in areas, calculate statistics from point attributes."
-msgstr "Calcula estadísticas univariantes a partir de un mapa ráster de GRASS."
+msgstr "Cuenta puntos en áreas, calcula estadísticas a partir de atributos de puntos."
#: ../vector/v.vect.stats/main.c:137
-#, fuzzy
msgid "Name of existing vector map with points"
-msgstr "Nombre del mapa vectorial existente (hasta)"
+msgstr "Nombre de mapa vectorial con puntos existente"
#: ../vector/v.vect.stats/main.c:142
-#, fuzzy
msgid "Name of existing vector map with areas"
-msgstr "Nombre del mapa vectorial existente"
+msgstr "Nombre de mapa vectorial con áreas existente"
#: ../vector/v.vect.stats/main.c:149 ../vector/v.net.bridge/main.c:101
#: ../vector/v.to.db/parse.c:41
@@ -7384,70 +6766,53 @@
#: ../vector/v.vect.stats/main.c:154
-#, fuzzy
msgid "Layer number for points map"
-msgstr "Número de capa (desde)"
+msgstr "Número de capa para mapa de puntos"
#: ../vector/v.vect.stats/main.c:158
-#, fuzzy
msgid "Layer number for area map"
-msgstr "Número de capa (mapa vectorial A)"
+msgstr "Número de capa para mapa de área"
#: ../vector/v.vect.stats/main.c:174
-#, fuzzy
msgid "Method for aggregate statistics"
-msgstr "vectorial, ráster, estadísticas"
+msgstr "Método para agregar estadísticas"
#: ../vector/v.vect.stats/main.c:181
-#, fuzzy
msgid "Column name of points map to use for statistics"
-msgstr "Nombre del mapa ráster del que calcular estadísticas"
+msgstr "Nombre de la columna del mapa de puntos a usar para estadísticas"
#: ../vector/v.vect.stats/main.c:182
-#, fuzzy
msgid "Column of points map must be numeric"
-msgstr "La columna tiene que ser numérica"
+msgstr "La columna del mapa de puntos tiene que ser numérica"
#: ../vector/v.vect.stats/main.c:189
-#, fuzzy
msgid "Column name to upload points count"
-msgstr "Column name o expresión"
+msgstr "Nombre de la columna "
#: ../vector/v.vect.stats/main.c:191
-msgid ""
-"Column to hold points count, must be of type integer, will be created if not "
-"existing"
-msgstr ""
+msgid "Column to hold points count, must be of type integer, will be created if not existing"
+msgstr "Columa para guardar conteo de puntos, debe ser de tipo entero, será creada si es que no existe"
#: ../vector/v.vect.stats/main.c:198
-#, fuzzy
msgid "Column name to upload statistics"
+msgstr "Nombre de la columna a la cual subir estadísticas"
#: ../vector/v.vect.stats/main.c:200
-msgid ""
-"Column to hold statistics, must be of type double, will be created if not "
-"existing"
-msgstr ""
+msgid "Column to hold statistics, must be of type double, will be created if not existing"
+msgstr "Columa para guardar estadísticas, debe ser de tipo doble, será creada si es que no existe"
#: ../vector/v.vect.stats/main.c:207
-#, fuzzy
msgid "Print output to stdout, do not update attribute table"
-msgstr "Imprimir la salida a stdout, no actualizar tabla de atributos"
+msgstr "Mostrar en la salida estándar (stdout), no subir a la tabla de atributos"
#: ../vector/v.vect.stats/main.c:208
-#, fuzzy
msgid "First column is always area category"
-msgstr ""
-"La primera columna es siempre la categoría del elemento 'desde' llamada "
-"from_cat"
+msgstr "La primera columna es siempre la categoría del área"
#: ../vector/v.vect.stats/main.c:252
#, c-format
msgid "Vector map <%s> is not in user mapset and cannot be updated"
-msgstr ""
-"El mapa vectorial <%s> no esta en el directorio de mapas del usuario y no se "
-"puede actualizar"
+msgstr "El mapa vectorial <%s> no esta en el directorio de mapas del usuario y no se puede actualizar"
#: ../vector/v.vect.stats/main.c:268 ../raster/r.proj/main.c:237
#: ../raster/r.stats.zonal/main.c:165 ../raster/r.statistics/main.c:118
@@ -7458,49 +6823,42 @@
msgstr "<%s=%s> desconocido %s"
#: ../vector/v.vect.stats/main.c:304
-#, fuzzy
msgid "count_column is required to upload point counts"
-msgstr "¡Se requiere el argumento valores para mapas de coma flotante!"
+msgstr "count_column es necesario para subir conteo de puntos"
#: ../vector/v.vect.stats/main.c:313
-#, fuzzy
msgid "count_column must be of type integer"
-msgstr "La columna clave debe ser entero"
+msgstr "count_column debe ser de tipo integer"
#: ../vector/v.vect.stats/main.c:326 ../vector/v.vect.stats/main.c:356
-#, fuzzy, c-format
+#, c-format
msgid "Unable to add column <%s>"
+msgstr "No se ha podido añadir columna <%s>"
#: ../vector/v.vect.stats/main.c:332
-#, fuzzy
msgid "stats_column is required to upload point stats"
+msgstr "stats_column es necesario para subir estadísticas de puntos"
#: ../vector/v.vect.stats/main.c:343
-#, fuzzy
msgid "stats_column must be of type double precision"
-msgstr "La columna X/Y/Z debe ser entero o doble"
+msgstr "stats_column debe ser de tipo double precision"
#: ../vector/v.vect.stats/main.c:367
-#, fuzzy
msgid "collecting attributes from points vector..."
-msgstr "Recogiendo atributos de entrada..."
+msgstr "colectando atributos desde puntos vectoriales..."
#: ../vector/v.vect.stats/main.c:408
-#, fuzzy
msgid "column for points vector must be numeric"
-msgstr "El tipo de columna de tamaño debe ser numérico"
+msgstr "columna para puntos vectoriales debe ser numérica"
#: ../vector/v.vect.stats/main.c:483
-#, fuzzy
msgid "Selecting points for each area..."
+msgstr "Seleccionando puntos para cada área..."
#: ../vector/v.vect.stats/main.c:580
-#, fuzzy, c-format
+#, c-format
msgid "could not find area category %d"
+msgstr "no se encontró área con categoría %d"
#: ../vector/v.vect.stats/main.c:708
#, c-format
@@ -7514,9 +6872,8 @@
#: ../vector/v.out.lidar/main.c:121 ../vector/v.out.lidar/main.c:158
#: ../vector/v.univar/main.c:358
-#, fuzzy
msgid "Only numeric column type is supported"
-msgstr "Tipo de columna no soportado"
+msgstr "Solamente está soportada columna de tipo numérico"
#: ../vector/v.out.lidar/main.c:123
msgid "Double values will be converted to integers"
@@ -7603,8 +6960,7 @@
#: ../vector/v.out.lidar/main.c:543
#, fuzzy
msgid "RGB color definition column"
-msgstr ""
-"Nombre de la columna de definición de color (para usar con la opción -a)"
+msgstr "Nombre de la columna de definición de color (para usar con la opción -a)"
#: ../vector/v.out.lidar/main.c:544 ../display/d.vect/main.c:129
msgid "Color definition in R:G:B form"
@@ -7629,9 +6985,7 @@
msgstr "Escala a aplicar a los datos Z"
#: ../vector/v.out.lidar/main.c:572 ../vector/v.out.lidar/main.c:582
-msgid ""
-"This scale does not change the values itself but only how precisely they are "
-"stored, for example 0.01 will preserve two decimal places"
+msgid "This scale does not change the values itself but only how precisely they are stored, for example 0.01 will preserve two decimal places"
msgstr ""
#: ../vector/v.out.lidar/main.c:581
@@ -7673,9 +7027,7 @@
#: ../vector/v.to.rast/support.c:176
#, c-format
msgid "Error in color definition column (%s) with cat %d: colorstring [%s]"
-msgstr ""
-"Error en la columna (%s) de definición de color con categoría %d: "
-"colorstring [%s]"
+msgstr "Error en la columna (%s) de definición de color con categoría %d: colorstring [%s]"
#: ../vector/v.to.rast/support.c:179
msgid "Color set to [200:200:200]"
@@ -7718,23 +7070,21 @@
#: ../vector/v.to.rast/vect2rast.c:104
#, c-format
msgid "Unable to use column <%s>"
-msgstr "No se puede usar columna <%s>"
+msgstr "No ha sido posible usar columna <%s>"
#: ../vector/v.to.rast/vect2rast.c:131
-#, fuzzy, c-format
+#, c-format
msgid "No areas selected from vector map <%s>"
-msgstr "%d de %d elementos seleccionados del mapa vectorial <%s>"
+msgstr "No hay áreas seleccionadas del mapa vectorial <%s>"
#: ../vector/v.to.rast/vect2rast.c:137
-msgid ""
-"Area conversion and line densification are mutually exclusive, disabling "
-"line densification."
+msgid "Area conversion and line densification are mutually exclusive, disabling line densification."
msgstr ""
#: ../vector/v.to.rast/vect2rast.c:152
#, c-format
msgid "Pass %d of %d:"
-msgstr "Pase %d de %d:"
+msgstr "Paso %d de %d:"
#: ../vector/v.to.rast/vect2rast.c:160
#, c-format
@@ -7757,8 +7107,7 @@
#: ../vector/v.to.rast/vect2rast.c:204
msgid "Color can be updated from database only if use=attr"
-msgstr ""
-"El color se puede actualizar desde la base de datos sólo si uso=atributo"
+msgstr "El color se puede actualizar desde la base de datos sólo si uso=atributo"
#: ../vector/v.to.rast/vect2rast.c:229
#, c-format
@@ -7780,14 +7129,12 @@
#: ../raster/r.in.ascii/main.c:71 ../raster/r.in.xyz/main.c:161
#: ../raster/r.in.lidar/main.c:110 ../raster/r.to.rast3elev/main.c:362
#: ../raster/r.to.rast3/main.c:198 ../raster/r.to.vect/main.c:77
-#, fuzzy
msgid "conversion"
-msgstr "Error en la conversión de texto"
+msgstr "conversión"
#: ../vector/v.to.rast/main.c:47
-#, fuzzy
msgid "rasterization"
-msgstr "ráster, elevación"
+msgstr "rasterización"
#: ../vector/v.to.rast/main.c:48
msgid "Converts (rasterize) a vector map into a raster map."
@@ -7798,31 +7145,24 @@
msgstr "Entrada de valores raster"
#: ../vector/v.to.rast/main.c:77
-#, fuzzy
msgid "read values from attribute table"
-msgstr "Copiar también la tabla de atributos"
+msgstr "leer valores desde tabla de atributos"
#: ../vector/v.to.rast/main.c:79
-#, fuzzy
msgid "use value specified by value option"
-msgstr ""
-"Asignar un valor especificado a las celdas sin datos para las bandas de "
-"salida"
+msgstr "usar valor especificado por la opción valor"
#: ../vector/v.to.rast/main.c:80
-#, fuzzy
msgid "use z coordinate (points or contours only)"
-msgstr "Coordenada Este (punto de interés)"
+msgstr "usar coordenada (solamente puntos o contornos)"
#: ../vector/v.to.rast/main.c:81
msgid "output as flow direction (lines only)"
-msgstr ""
+msgstr "salida como dirección de flujo (solamente líneas)"
#: ../vector/v.to.rast/main.c:87
msgid "Name of column for 'attr' parameter (data type must be numeric)"
-msgstr ""
-"Nombre de columna para el parámetro 'attr' (el tipo de datos debe ser "
-"numérico)"
+msgstr "Nombre de columna para el parámetro 'attr' (el tipo de datos debe ser numérico)"
#: ../vector/v.to.rast/main.c:93
msgid "Name of color definition column (with RRR:GGG:BBB entries)"
@@ -7841,28 +7181,24 @@
#: ../locale/scriptstrings/t.rast.import_to_translate.c:13
#: ../raster/r.proj/main.c:191 ../raster/r.stream.extract/main.c:141
#: ../raster/r.in.gdal/main.c:116 ../raster/r.resamp.bspline/main.c:151
-#, fuzzy
msgid "Maximum memory to be used (in MB)"
-msgstr "Memoria máxima a utilizar con -m flag (en MB)"
+msgstr "Memoria máxima a utilizar (en MB)"
#: ../vector/v.to.rast/main.c:117 ../vector/v.surf.bspline/main.c:195
#: ../locale/scriptstrings/r.import_to_translate.c:10
#: ../locale/scriptstrings/t.rast.import_to_translate.c:12
#: ../raster/r.proj/main.c:192 ../raster/r.stream.extract/main.c:142
#: ../raster/r.in.gdal/main.c:117 ../raster/r.resamp.bspline/main.c:152
-#, fuzzy
msgid "Cache size for raster rows"
-msgstr "Estadística a utilizar para los valores ráster"
+msgstr "Tamaño de caché para filas ráster"
#: ../vector/v.to.rast/main.c:121
-#, fuzzy
msgid "Create densified lines (default: thin lines)"
-msgstr "Longitud de página (por omisión: %d líneas)"
+msgstr "Crear líneas densificadas (predeterminado: thin lines)"
#: ../vector/v.to.rast/main.c:122
-msgid ""
-"All cells touched by the line will be set, not only those on the render path"
-msgstr ""
+msgid "All cells touched by the line will be set, not only those on the render path"
+msgstr "Todas las celdas tocadas por la línea searán definidas, no solamente aquellas visualizadas en la ruta "
#: ../vector/v.to.rast/main.c:132
#, c-format
@@ -7875,19 +7211,15 @@
#: ../vector/v.to.rast/main.c:146
msgid "Column parameter cannot be combined with use of category values option"
-msgstr ""
-"El parámetro columna no se puede combinar con el uso de la opción valores de "
-"categoría"
+msgstr "El parámetro columna no se puede combinar con el uso de la opción valores de categoría"
#: ../vector/v.to.rast/main.c:151
msgid "Column parameter cannot be combined with use of value option"
-msgstr ""
-"El parámetro columna no se puede combinar con el uso de la opción valor"
+msgstr "El parámetro columna no se puede combinar con el uso de la opción valor"
#: ../vector/v.to.rast/main.c:156
msgid "Column parameter cannot be combined with use of z coordinate"
-msgstr ""
-"El parámetro columna no se puede combinar con el uso de la coordenada Z"
+msgstr "El parámetro columna no se puede combinar con el uso de la coordenada Z"
#: ../vector/v.to.rast/main.c:162
#, c-format
@@ -7918,7 +7250,6 @@
msgstr "¡No se pudo importar el archivo DXF!"
#: ../vector/v.to.rast/do_areas.c:118
-#, fuzzy
msgid "Area without centroid (OK for island)"
msgstr "Área sin centroide (puede ser correcto para islas)"
@@ -7938,26 +7269,20 @@
msgstr "No se escribieron %d líneas con altura variable en el ráster"
#: ../vector/v.net.centrality/main.c:98
-#, fuzzy
msgid "centrality measures"
-msgstr "Calculando medias de clase ..."
+msgstr "medidas de centralidad"
#: ../vector/v.net.centrality/main.c:100
-msgid ""
-"Computes degree, centrality, betweeness, closeness and eigenvector "
-"centrality measures in the network."
-msgstr ""
-"Calcula grados, centralidad, intermediación -betweeness-, proximidad y las "
-"medidas de la centralidad del eigenvector en la red."
+msgid "Computes degree, centrality, betweeness, closeness and eigenvector centrality measures in the network."
+msgstr "Calcula grados, centralidad, intermediación -betweeness-, proximidad y las medidas de la centralidad del eigenvector en la red."
#: ../vector/v.net.centrality/main.c:148
msgid "Name of degree centrality column"
-msgstr ""
+msgstr "Nombre de columna de grado de centralidad"
#: ../vector/v.net.centrality/main.c:154
-#, fuzzy
msgid "Name of closeness centrality column"
-msgstr "Nombre de la columna"
+msgstr "Nombre de columna de proximidad central"
#: ../vector/v.net.centrality/main.c:160
#, fuzzy
@@ -7970,8 +7295,7 @@
#: ../vector/v.net.centrality/main.c:175
msgid "Maximum number of iterations to compute eigenvector centrality"
-msgstr ""
-"Número máximo de iteraciones para calcular centralidad del eigen vector"
+msgstr "Número máximo de iteraciones para calcular centralidad del eigen vector"
#: ../vector/v.net.centrality/main.c:183
msgid "Cumulative error tolerance for eigenvector centrality"
@@ -7997,9 +7321,7 @@
#: ../vector/v.net.centrality/main.c:325
msgid "Computing betweenness and/or closeness centrality measure"
-msgstr ""
-"Calculando la intermediación -betweeness- y/o la medida de la proximidad a "
-"la centralidad"
+msgstr "Calculando la intermediación -betweeness- y/o la medida de la proximidad a la centralidad"
#: ../vector/v.net.centrality/main.c:332
msgid "Computing eigenvector centrality measure"
@@ -8010,23 +7332,20 @@
msgstr "Escribiendo los datos en la tabla..."
#: ../vector/v.segment/main.c:64 ../vector/v.split/main.c:58
-#, fuzzy
msgid "segment"
-msgstr "Resolución"
+msgstr "segmento"
#: ../vector/v.segment/main.c:67
msgid "Creates points/segments from input vector lines and positions."
msgstr "Crea puntos/segmentos a partir de líneas y posiciones de entrada."
#: ../vector/v.segment/main.c:70
-#, fuzzy
msgid "Name of input vector lines map"
-msgstr "Nombre del mapa vectorial de puntos de entrada"
+msgstr "Nombre del mapa vectorial de líneas de entrada"
#: ../vector/v.segment/main.c:79
-#, fuzzy
msgid "Name of file containing segment rules"
-msgstr "Nombre del archivo que contiene sentencias SQL"
+msgstr "Nombre de archivo que contiene reglas de segmentos"
#: ../vector/v.segment/main.c:146 ../vector/v.segment/main.c:190
#, c-format
@@ -8044,8 +7363,7 @@
"Unable to get point on line: cat = %d offset = %f (line length = %.15g)\n"
"%s"
msgstr ""
-"No se puede obtener el punto en la línea: categoría = %d desplazamiento = %f "
-"(longitud de línea = %f)\n"
+"No se puede obtener el punto en la línea: categoría = %d desplazamiento = %f (longitud de línea = %f)\n"
"%s"
#: ../vector/v.segment/main.c:226
@@ -8058,8 +7376,7 @@
"Unable to make line segment: cat = %d : %f - %f (line length = %.15g)\n"
"%s"
msgstr ""
-"No se puede hacer el segmento de línea: categoría = %d : %f - %f (longitud "
-"de línea = %.15g)\n"
+"No se puede hacer el segmento de línea: categoría = %d : %f - %f (longitud de línea = %.15g)\n"
"%s"
#: ../vector/v.segment/main.c:254 ../vector/v.lrs/v.lrs.segment/main.c:336
@@ -8068,10 +7385,10 @@
msgstr "Tipo de segmento incorrecto: %s"
#: ../vector/v.segment/main.c:261
-#, fuzzy, c-format
+#, c-format
msgid "%d point read from input"
msgid_plural "%d points read from input"
-msgstr[0] "%d puntos leídos de la entrada"
+msgstr[0] "%d punto leído de la entrada"
msgstr[1] "%d puntos leídos de la entrada"
#. GTC Number of lost points
@@ -8082,31 +7399,31 @@
#, c-format
msgid "%d lost"
msgid_plural "%d lost"
-msgstr[0] ""
-msgstr[1] ""
+msgstr[0] "%d perdido"
+msgstr[1] "%d perdidos"
#. GTC %s is replaced with message indicating number of lost points.
#: ../vector/v.segment/main.c:267
-#, fuzzy, c-format
+#, c-format
msgid "%d point written to output map (%s)"
msgid_plural "%d points written to output map (%s)"
-msgstr[0] "%d puntos escritos en el mapa de salida (%d perdidos)"
-msgstr[1] "%d puntos escritos en el mapa de salida (%d perdidos)"
+msgstr[0] "%d punto escrito en el mapa de salida (%s)"
+msgstr[1] "%d puntos escritos en el mapa de salida (%s)"
#: ../vector/v.segment/main.c:272
-#, fuzzy, c-format
+#, c-format
msgid "%d line read from input"
msgid_plural "%d lines read from input"
-msgstr[0] "%d líneas leídas de la entrada"
+msgstr[0] "%d línea leídas de la entrada"
msgstr[1] "%d líneas leídas de la entrada"
#. GTC %s is replaced with message indicating number of lost lines.
#: ../vector/v.segment/main.c:278
-#, fuzzy, c-format
+#, c-format
msgid "%d line written to output map (%s)"
msgid_plural "%d lines written to output map (%s)"
-msgstr[0] "%d líneas escritas en el mapa de salida (%d perdidas)"
-msgstr[1] "%d líneas escritas en el mapa de salida (%d perdidas)"
+msgstr[0] "%d líneas escritas en el mapa de salida (%s)"
+msgstr[1] "%d líneas escritas en el mapa de salida (%s)"
#: ../vector/v.type/main.c:41 ../vector/v.category/main.c:693
#: ../vector/v.buffer/main.c:223
@@ -8117,9 +7434,8 @@
msgstr "área"
#: ../vector/v.type/main.c:44
-#, fuzzy
msgid "Changes type of vector features."
-msgstr "Cambiar tipo de boundary dangles"
+msgstr "Cambia tipo de elementos vectoriales."
#: ../vector/v.type/main.c:57
msgid "Feature type to convert from"
@@ -8146,36 +7462,27 @@
#: ../vector/v.net.salesman/main.c:131
msgid "Creates a cycle connecting given nodes (Traveling salesman problem)."
-msgstr ""
-"Crea una ruta circular que conecta los nodos indicados (Problema del "
-"vendedor viajero)"
+msgstr "Crea una ruta circular que conecta los nodos indicados (Problema del vendedor viajero)"
#: ../vector/v.net.salesman/main.c:133
-#, fuzzy
-msgid ""
-"Note that TSP is NP-hard, heuristic algorithm is used by this module and "
-"created cycle may be sub optimal"
+msgid "Note that TSP is NP-hard, heuristic algorithm is used by this module and created cycle may be sub optimal"
+msgstr "Note que TSP es NP-hard, algoritmo heurístico que es usado por este módulo y el círculo creado puede ser subóptimo"
#: ../vector/v.net.salesman/main.c:142
msgid "Categories of points ('cities') on nodes (layer is specified by nlayer)"
-msgstr ""
-"Categorías de puntos ('ciudades') en los nodos (la capa es especificada por "
-"nlayer)"
+msgstr "Categorías de puntos ('ciudades') en los nodos (la capa es especificada por nlayer)"
#: ../vector/v.net.salesman/main.c:162
msgid "Node layer (used for cities)"
msgstr "Capa de nodos (usada para ciudades)"
#: ../vector/v.net.salesman/main.c:176
-#, fuzzy
msgid "EXPERIMENTAL: Arc backward direction cost column (number)"
-msgstr "Delante del arco/ ambas direcciones de la columna de coste (número)"
+msgstr "EXPERIMENTAL: columna de costo de dirección de arco trasero (número)"
#: ../vector/v.net.salesman/main.c:203
-#, fuzzy
msgid "Name for output file holding node sequence (\"-\" for stdout)"
-msgstr "Nombre para el archivo de salida (si se omite o \"-\" salida a stdout)"
+msgstr "Nombre para archivo de salida que contendrá secuencia de nodos (\"-\" para salida a estándar)"
#: ../vector/v.net.salesman/main.c:277 ../vector/v.net.iso/main.c:241
#: ../vector/v.net.alloc/main.c:212
@@ -8183,33 +7490,32 @@
msgstr "El punto no está conectado a la red"
#: ../vector/v.net.salesman/main.c:286
-#, fuzzy, c-format
+#, c-format
msgid "Number of cities: %d"
-msgstr "Número de ciudades: [%d]"
+msgstr "Cantidad de ciudades: %d"
#: ../vector/v.net.salesman/main.c:288
msgid "Not enough cities (< 2)"
msgstr "Ciudades insuficientes (<2)"
#: ../vector/v.net.salesman/main.c:328
-#, fuzzy
msgid "Creating cost cache..."
-msgstr "Creando centroides..."
+msgstr "Creando caché de costo..."
#: ../vector/v.net.salesman/main.c:357 ../vector/v.net.salesman/main.c:371
-#, fuzzy, c-format
+#, c-format
msgid "No point at node %d"
-msgstr "Ningún punto con categoría [%d]"
+msgstr "Ningún punto en nodo %d"
#: ../vector/v.net.salesman/main.c:361 ../vector/v.net.salesman/main.c:375
-#, fuzzy, c-format
+#, c-format
msgid "No category for point at node %d"
+msgstr "No hay categoría para punto en nodo %d"
#: ../vector/v.net.salesman/main.c:378
-#, fuzzy, c-format
+#, c-format
msgid "Destination node [cat %d] is unreachable from node [cat %d]"
-msgstr "El nodo de destino [%d] no se puede alcanzar desde el nodo [%d]"
+msgstr "Nodo de destino [cat %d] no se puede alcanzar desde el nodo [cat %d]"
#: ../vector/v.net.salesman/main.c:421
msgid "Searching for the shortest cycle..."
@@ -8218,41 +7524,28 @@
#: ../vector/v.net.salesman/main.c:555
#, c-format
msgid "Cycle with total cost %.3f"
-msgstr ""
+msgstr "Ciclo con costo total %.3f"
#: ../vector/v.net.salesman/main.c:580 ../vector/v.rectify/main.c:170
-#, fuzzy, c-format
+#, c-format
msgid "Unable to open file '%s' for writing"
-msgstr "No se puede abrir el archivo <%s> para escribir"
+msgstr "No ha sido posible abrir archivo '%s' para escritura"
#: ../vector/v.net.iso/main.c:74
-#, fuzzy
msgid "isolines"
-msgstr "Líneas"
+msgstr "isolíneas"
#: ../vector/v.net.iso/main.c:75
msgid "Splits net by cost isolines."
msgstr "Divide la red por isolíneas de costes."
#: ../vector/v.net.iso/main.c:78
-#, fuzzy
-msgid ""
-"Splits net to bands between cost isolines (direction from center). Center "
-"node must be opened (costs >= 0). Costs of center node are used in "
-"calculation."
-msgstr ""
-"Divide la red en bandas entre isolíneas de coste (dirección desde el "
-"centro). El nodo central debe estar abierto (coste >= 0). Los costes de nodo "
-"central se usan en el cálculo."
+msgid "Splits net to bands between cost isolines (direction from center). Center node must be opened (costs >= 0). Costs of center node are used in calculation."
+msgstr "Divide la red en bandas entre isolíneas de coste (dirección desde el centro). El nodo central debe estar abierto (coste >= 0). Los costes de nodo central se usan en el cálculo."
#: ../vector/v.net.iso/main.c:89 ../vector/v.net.alloc/main.c:83
-#, fuzzy
-msgid ""
-"Categories of centers (points on nodes) to which net will be allocated, "
-"layer for this categories is given by nlayer option"
-msgstr ""
-"Categorías de los centros (puntos en nodos) a los que se asignará la red. La "
-"capa para estas categorías es dada por la opción nlayer"
+msgid "Categories of centers (points on nodes) to which net will be allocated, layer for this categories is given by nlayer option"
+msgstr "Categorías de los centros (puntos en nodos) a los que se asignará la red, la capa para estas categorías es dada por la opción nlayer"
#: ../vector/v.net.iso/main.c:98
msgid "Costs for isolines"
@@ -8298,8 +7591,7 @@
#: ../vector/v.net.iso/main.c:618 ../vector/v.net.alloc/main.c:394
#: ../vector/v.net.alloc/main.c:406
msgid "Cannot get line segment, segment out of line"
-msgstr ""
-"No se puede obtener el segmento de línea, el segmento está fuera de la línea"
+msgstr "No se puede obtener el segmento de línea, el segmento está fuera de la línea"
#: ../vector/v.out.svg/main.c:76
msgid "Exports a vector map to SVG file."
@@ -8334,9 +7626,9 @@
msgstr "La precisión no debe ser superior a 15"
#: ../vector/v.out.svg/main.c:201
-#, fuzzy, c-format
+#, c-format
msgid "Unable to create SVG file <%s>"
-msgstr "No se puede crear el archivo <%s>"
+msgstr "No ha sido posible crear archivo SVG <%s>"
#: ../vector/v.out.svg/main.c:218
#, c-format
@@ -8379,15 +7671,12 @@
msgstr "No se pueden seleccionar los atributos para la categoría %d"
#: ../vector/v.net.connectivity/main.c:54
-#, fuzzy
msgid "connectivity"
-msgstr "Correlación"
+msgstr "conectividad"
#: ../vector/v.net.connectivity/main.c:56
msgid "Computes vertex connectivity between two sets of nodes in the network."
-msgstr ""
-"Calcula la connectividad de los vértices entre dos conjuntos de nodos de la "
-"red."
+msgstr "Calcula la connectividad de los vértices entre dos conjuntos de nodos de la red."
#: ../vector/v.net.connectivity/main.c:96
msgid "Set1 category values"
@@ -8421,7 +7710,7 @@
#: ../vector/v.net.connectivity/main.c:153
#, c-format
msgid "No features for %s selected. Please check options '%s', '%s'."
-msgstr ""
+msgstr "No hay elementos para %s seleccionado. Por favor revise opciones '%s','%s'."
#: ../vector/v.net.connectivity/main.c:167
#: ../vector/v.net.connectivity/main.c:170
@@ -8430,17 +7719,12 @@
msgstr "%s está vacío"
#: ../vector/v.out.ascii/main.c:51
-#, fuzzy
msgid "Exports a vector map to a GRASS ASCII vector representation."
-msgstr ""
-"Convierte un mapa vectorial binario de GRASS a un mapa vectorial ASCII de "
-"GRASS"
+msgstr "Exporta un mapa vectorial a la representación vectorial GRASS ASCII."
#: ../vector/v.out.ascii/main.c:52
-msgid ""
-"By default only features with category are exported. To export all features "
-"use 'layer=-1'."
-msgstr ""
+msgid "By default only features with category are exported. To export all features use 'layer=-1'."
+msgstr "De maera predeterminada solamente se exportan elementos con categoría. Para exportar todos los elementos use 'layer=-1'."
#: ../vector/v.out.ascii/main.c:60
#, c-format
@@ -8448,28 +7732,26 @@
msgstr "Parámetro '%s' ignorado en el modo estándar"
#: ../vector/v.out.ascii/main.c:69
-#, fuzzy, c-format
+#, c-format
msgid "Format '%s' is not supported for old version"
-msgstr "El formato 'punto' no está soportado por la versión antigua"
+msgstr "Formato '%s' no es soportado por versión anterior"
#: ../vector/v.out.ascii/main.c:73
-#, fuzzy, c-format
+#, c-format
msgid "Parameter '%s' must be given for old version"
-msgstr "se debe proporcionar 'salida' para la versión antigua"
+msgstr "Parámetro '%s' debe ser dado para versión anterior"
#: ../vector/v.out.ascii/main.c:80
-#, fuzzy, c-format
-msgid ""
-"Unable to open vector map <%s> at topology level. Areas will not be "
-"processed."
-msgstr "No se puede abrir el mapa vectorial <%s> en el nivel topológico %d"
+#, c-format
+msgid "Unable to open vector map <%s> at topology level. Areas will not be processed."
+msgstr "No se puede abrir el mapa vectorial <%s> en el nivel topológico. Las áreas no serán procesadas."
#: ../vector/v.out.ascii/main.c:107
-#, fuzzy, c-format
+#, c-format
msgid "%d error in <%s> option"
msgid_plural "%d errors in <%s> option"
-msgstr[0] "%d errores en la opción id"
-msgstr[1] "%d errores en la opción id"
+msgstr[0] "%d error en opción <%s>"
+msgstr[1] "%d errores en opción <%s>"
#: ../vector/v.out.ascii/main.c:141
msgid "dig_att file already exist"
@@ -8490,26 +7772,20 @@
msgstr "No se encontraron puntos, no hay nada a exportar"
#: ../vector/v.out.ascii/main.c:159
-#, fuzzy
msgid "No features found, nothing to be exported"
-msgstr "Ningún elemento seleccionado, nada que editar"
+msgstr "No se encontró ningún elemento, nada que exportar"
#: ../vector/v.out.ascii/main.c:163
-#, fuzzy
msgid "An error occurred, nothing to be exported"
+msgstr "Ocurrió un error, nada que exportar"
#: ../vector/v.out.ascii/args.c:31
-#, fuzzy
msgid "Name for output ASCII file or ASCII vector name if '-o' is defined"
-msgstr ""
-"Ruta al archivo ASCII resultante o nombre del vectorial ASCII si se define '-"
-"o'"
+msgstr "Nombre de archivo ASCII de salida o nombre de vectorial ASCII si '-o' es definida"
#: ../vector/v.out.ascii/args.c:33 ../general/g.list/main.c:114
-#, fuzzy
msgid "If not given or '-' then standard output"
-msgstr "Si no se da lee de la entrada estándar"
+msgstr "Si no se da o '-' entonces salida estándar"
#: ../vector/v.out.ascii/args.c:35 ../vector/v.out.ascii/args.c:81
#: ../vector/v.in.ogr/main.c:165 ../vector/v.in.ogr/main.c:220
@@ -8573,7 +7849,7 @@
#: ../vector/v.out.ascii/args.c:39
msgid "\"*\" for all columns"
-msgstr ""
+msgstr "\"*\" para todas las columnas"
#: ../vector/v.out.ascii/args.c:40 ../vector/v.out.ascii/args.c:66
#: ../vector/v.out.ascii/args.c:76 ../vector/v.out.ascii/args.c:86
@@ -8588,16 +7864,15 @@
#: ../vector/v.out.ascii/args.c:59
msgid "Simple point format (point per row)"
-msgstr ""
+msgstr "Formato simple de punto (punto por fila)"
#: ../vector/v.out.ascii/args.c:60
-#, fuzzy
msgid "GRASS ASCII vector format"
-msgstr "Nombre de archivo que contiene las signaturas iniciales"
+msgstr "Formato vectorial GRASS ASCII"
#: ../vector/v.out.ascii/args.c:61
msgid "OGC well-known text"
-msgstr ""
+msgstr "texto bien conocido OGC"
#: ../vector/v.out.ascii/args.c:65
msgid "Field separator (points mode)"
@@ -8614,24 +7889,20 @@
msgstr "Crear archivo ASCII antiguo (versión 4)"
#: ../vector/v.out.ascii/args.c:85
-#, fuzzy
msgid "Include column names in output (points mode)"
-msgstr "No incluir nombres de columna en la salida"
+msgstr "Incluiye nombres de columnas en salida (modo de puntos)"
#: ../vector/v.out.ascii/args.c:91
msgid "Only export points falling within current 3D region (points mode)"
-msgstr ""
-"Sólo exportar los puntos que caen dentro de la región 3D actual (modo de "
-"puntos)"
+msgstr "Sólo exportar los puntos que caen dentro de la región 3D actual (modo de puntos)"
#: ../vector/v.out.ascii/args.c:109 ../vector/v.out.vtk/main.c:153
msgid "Failed to interpret 'dp' parameter as an integer"
msgstr "No se pudo interpretar el parámetro 'dp' como integer"
#: ../vector/v.colors.out/main.c:53
-#, fuzzy
msgid "Exports the color table associated with a vector map."
-msgstr "Exporta la tabla de color asociada con la capa de un mapa raster."
+msgstr "Exporta la tabla de colores asociada con la capa de un mapa vectorial."
#: ../vector/v.colors.out/main.c:61 ../raster/r.colors.out/raster_main.c:55
#: ../raster/r.colors.out/raster3d_main.c:56
@@ -8640,20 +7911,16 @@
#: ../vector/v.colors.out/main.c:62 ../raster/r.colors.out/raster_main.c:56
#: ../raster/r.colors.out/raster3d_main.c:57 ../raster/r.kappa/main.c:89
-#, fuzzy
msgid "If not given write to standard output"
+msgstr "Si no se da escribir en la salida estándar"
#: ../vector/v.colors.out/main.c:66
-#, fuzzy
msgid "Name of attribute (numeric) column to which refer color rules"
-msgstr "Nombre de columna de atributos a usar para etiquetas"
+msgstr "Nombre columna de atributo (numérico) a la cual referir reglas de colores"
#: ../vector/v.colors.out/main.c:67
-#, fuzzy
msgid "If not given, color rules refer to categories"
-msgstr ""
-"Se alcanzó el final del archivo ASCII antes que el final de las categorías"
+msgstr "Si no se da, reglas de colores se refieren a las categorías"
#: ../vector/v.colors.out/main.c:72 ../raster/r.colors.out/raster_main.c:61
#: ../raster/r.colors.out/raster3d_main.c:62
@@ -8661,14 +7928,14 @@
msgstr "Valores de salida como porcentajes"
#: ../vector/v.colors.out/main.c:85
-#, fuzzy, c-format
+#, c-format
msgid "Unable to read color table for vector map <%s>"
-msgstr "No se puede leer la tabla de color para el mapa raster <%s>"
+msgstr "No ha sido posible leer tabla de colores para mapa vectorial <%s>"
#: ../vector/v.colors.out/main.c:88
-#, fuzzy, c-format
+#, c-format
msgid "No color table defined for vector map <%s>"
-msgstr "No se puede obtener información de la capa para el mapa vectorial <%s>"
+msgstr "No hay tabla de colores definida para mapa vectorial <%s>"
#: ../vector/v.colors.out/main.c:103 ../raster3d/r3.support/main.c:153
#: ../general/g.cairocomp/main.c:66 ../raster/r.support/main.c:162
@@ -8680,19 +7947,16 @@
msgstr "No se puede abrir el archivo de salida <%s>"
#: ../vector/v.net.components/main.c:74
-#, fuzzy
msgid "components"
-msgstr "Porcentaje completado: "
+msgstr "componentes"
#: ../vector/v.net.components/main.c:76
msgid "Computes strongly and weakly connected components in the network."
-msgstr ""
-"Calcula componentes que están fuertemente y débilmente conectados en la red."
+msgstr "Calcula componentes que están fuertemente y débilmente conectados en la red."
#: ../vector/v.net.components/main.c:124
-#, fuzzy
msgid "Weakly connected components"
-msgstr "Tipo de componentes"
+msgstr "Componentes debilmente conectados"
#: ../vector/v.net.components/main.c:125
msgid "Strongly connected components"
@@ -8703,14 +7967,12 @@
#: ../vector/v.net.components/main.c:203
-#, fuzzy
msgid "Computing weakly connected components..."
+msgstr "Calculando componentes debilmente conectados..."
#: ../vector/v.net.components/main.c:207
-#, fuzzy
msgid "Computing strongly connected components..."
-msgstr "Componentes fuertemente conectados"
+msgstr "Calculando componentes fuertemente conectados..."
#: ../vector/v.net.components/main.c:213 ../vector/v.surf.bspline/main.c:895
#: ../raster/r.resamp.bspline/main.c:736
@@ -8718,9 +7980,9 @@
msgstr "Escribiendo salida..."
#: ../vector/v.net.components/main.c:279
-#, fuzzy, c-format
+#, c-format
msgid "Found %d components."
+msgstr "Se encontraron %d componentes."
#: ../vector/v.in.dwg/main.c:84
msgid "Converts DWG/DXF to GRASS vector map"
@@ -8789,11 +8051,8 @@
msgstr "%d elementos procesados"
#: ../vector/v.select/main.c:52
-msgid ""
-"Selects features from vector map (A) by features from other vector map (B)."
-msgstr ""
-"Selecciona elementos de un mapa vectorial (A) por elementos de otro mapa "
-"vectorial (B). "
+msgid "Selects features from vector map (A) by features from other vector map (B)."
+msgstr "Selecciona elementos de un mapa vectorial (A) por elementos de otro mapa vectorial (B). "
#: ../vector/v.select/main.c:94
msgid "Operator can only be 'overlap'"
@@ -8844,14 +8103,8 @@
msgstr "El operador define la relación exigida entre elementos"
#: ../vector/v.select/args.c:51
-msgid ""
-"A feature is written to output if the result of operation 'ainput operator "
-"binput' is true. An input feature is considered to be true, if category of "
-msgstr ""
-"El elemento se escribe en la salida si el resultado de la operación 'ainput "
-"operator binput' es verdadero. Un elemento de entrada se considera "
-"verdadero, si la categoría de la capa dada está definida."
+msgid "A feature is written to output if the result of operation 'ainput operator binput' is true. An input feature is considered to be true, if category of given layer is defined."
+msgstr "El elemento se escribe en la salida si el resultado de la operación 'ainput operator binput' es verdadero. Un elemento de entrada se considera verdadero, si la categoría de la capa dada está definida."
#: ../vector/v.select/args.c:59 ../vector/v.select/args.c:75
msgid "features partially or completely overlap"
@@ -8890,12 +8143,8 @@
msgstr "los elementos se traslapan espacialmente (usando GEOS)"
#: ../vector/v.select/args.c:84
-msgid ""
-"feature A is spatially related to feature B (using GEOS, requires 'relate' "
-"option)"
-msgstr ""
-"el elemento A está espacialmente relacionado con el elemento B (usando GEOS, "
-"requiere la opción 'relate')"
+msgid "feature A is spatially related to feature B (using GEOS, requires 'relate' option)"
+msgstr "el elemento A está espacialmente relacionado con el elemento B (usando GEOS, requiere la opción 'relate')"
#: ../vector/v.select/args.c:94
msgid "Intersection Matrix Pattern used for 'relate' operator"
@@ -8929,12 +8178,8 @@
msgstr "No se puede leer la id área %d del mapa vectorial<%s>"
#: ../vector/v.distance/main.c:95
-msgid ""
-"Finds the nearest element in vector map 'to' for elements in vector map "
-"'from'."
-msgstr ""
-"Encuentra el elemento 'a' más próximo del mapa vectorial para elementos del "
-"mapa vectorial 'desde'"
+msgid "Finds the nearest element in vector map 'to' for elements in vector map 'from'."
+msgstr "Encuentra el elemento 'a' más próximo del mapa vectorial para elementos del mapa vectorial 'desde'"
#: ../vector/v.distance/main.c:99
msgid "Name of existing vector map (from)"
@@ -8948,9 +8193,8 @@
msgstr "Desde"
#: ../vector/v.distance/main.c:104
-#, fuzzy
msgid "Layer number or name (from)"
-msgstr "Número de capa"
+msgstr "Número o nombre de capa (from)"
#: ../vector/v.distance/main.c:111
msgid "Feature type (from)"
@@ -8968,9 +8212,8 @@
msgstr "Hasta"
#: ../vector/v.distance/main.c:121
-#, fuzzy
msgid "Layer number or name (to)"
+msgstr "Número o nombre de capa (to)"
#: ../vector/v.distance/main.c:128
msgid "Feature type (to)"
@@ -8978,9 +8221,7 @@
#: ../vector/v.distance/main.c:134
msgid "Name for output vector map containing lines connecting nearest elements"
-msgstr ""
-"Nombre para el mapa vectorial de salida que contiene líneas que conectan los "
-"elementos más cercanos"
+msgstr "Nombre para el mapa vectorial de salida que contiene líneas que conectan los elementos más cercanos"
#: ../vector/v.distance/main.c:142
msgid "Maximum distance or -1 for no limit"
@@ -8995,67 +8236,48 @@
msgstr "Valores que describen la relación entre los dos elementos más próximos"
#: ../vector/v.distance/main.c:169
-#, fuzzy
msgid "category of the nearest feature"
-msgstr "%d categorías - ningún elemento más cercano encontrado"
+msgstr "categoría del elemento más cercano"
#: ../vector/v.distance/main.c:170
-#, fuzzy
msgid "minimum distance to nearest feature"
-msgstr "Distancia máxima a la línea más próxima"
+msgstr "distancia máxima al punto más cercano"
#: ../vector/v.distance/main.c:171
-#, fuzzy
msgid "x coordinate of the nearest point on the 'to' feature"
-msgstr "Coordenada Este de un punto en el plano"
+msgstr "coordenada x del punto más cercano en el elemanto 'to'"
#: ../vector/v.distance/main.c:172
-#, fuzzy
msgid "y coordinate of the nearest point on the 'to' feature"
+msgstr "coordenada y del punto más cercano en el elemanto 'to'"
#: ../vector/v.distance/main.c:173
-msgid ""
-"distance to the nearest point on the 'to' feature along that linear feature"
-msgstr ""
-"distancia al punto más cercano en el elemento 'to' a lo largo del elemento "
-"lineal"
+msgid "distance to the nearest point on the 'to' feature along that linear feature"
+msgstr "distancia al punto más cercano en el elemento 'to' a lo largo del elemento lineal"
#: ../vector/v.distance/main.c:175
-msgid ""
-"angle along the nearest linear feature in the 'to' map, measured CCW from "
-"the +x axis, in radians, between -Pi and Pi inclusive"
-msgstr ""
-"ángulos a lo largo del elemento lineal más cercano en el mapa 'to', CCW "
-"medida desde el eje +x, en radianes, entre -Pi y Pi incluyendolos"
+msgid "angle along the nearest linear feature in the 'to' map, measured CCW from the +x axis, in radians, between -Pi and Pi inclusive"
+msgstr "ángulos a lo largo del elemento lineal más cercano en el mapa 'to', CCW medida desde el eje +x, en radianes, entre -Pi y Pi incluyendolos"
#: ../vector/v.distance/main.c:178
msgid "attribute of nearest feature given by to_column option"
msgstr "atributo del elemento más cercano dado por la opción to_column "
#: ../vector/v.distance/main.c:191
-msgid ""
-"Column name(s) where values specified by 'upload' option will be uploaded"
-msgstr ""
-"Nombre(s) de columna donde se cargarán los valores especificados por la "
-"opción 'upload'"
+msgid "Column name(s) where values specified by 'upload' option will be uploaded"
+msgstr "Nombre(s) de columna donde se cargarán los valores especificados por la opción 'upload'"
#: ../vector/v.distance/main.c:197
msgid "Column name of nearest feature (used with upload=to_attr)"
-msgstr ""
-"Nombre de la columna del elemento más cercano (usada con upload=to_attr)"
+msgstr "Nombre de la columna del elemento más cercano (usada con upload=to_attr)"
#: ../vector/v.distance/main.c:203
-#, fuzzy
msgid "Name of table created when the 'distance to all' flag is used"
-msgstr ""
-"Nombre de la tabla creada para la salida cuando se usa la opción distancia a "
-"todos"
+msgstr "Nombre de tabla creada cuando es usada la bandera 'distance to all'"
#: ../vector/v.distance/main.c:206
-#, fuzzy
msgid "Field separator for printing output to stdout"
-msgstr "Separador de campos (modo de puntos)"
+msgstr "Separador de campos para mostrar en salida estándar (stdout)"
#: ../vector/v.distance/main.c:211
msgid "Print output to stdout, don't update attribute table"
@@ -9063,22 +8285,15 @@
#: ../vector/v.distance/main.c:213
msgid "First column is always category of 'from' feature called from_cat"
-msgstr ""
-"from_cat"
+msgstr "La primera columna es siempre la categoría del elemento 'desde' llamada from_cat"
#: ../vector/v.distance/main.c:218
msgid "Calculate distances to all features within the threshold"
msgstr "Calcular distancias a todos los elementos dentro del umbral"
#: ../vector/v.distance/main.c:220
-#, fuzzy
-msgid ""
-"Output is written to stdout but may be uploaded to a new table created by "
-"this module; multiple 'upload' options may be used."
-msgstr ""
-"La salida se escribe a stdout pero puede se puede cargar a una nueva tabla "
-"creada por este módulo. Las categorías 'desde' pueden ser múltiples."
+msgid "Output is written to stdout but may be uploaded to a new table created by this module; multiple 'upload' options may be used."
+msgstr "La salida se escribe en la salida estándar (stdout) pero puede se puede cargar a una nueva tabla creada por este módulo; es posible usar varias opciones 'upload'."
#: ../vector/v.distance/main.c:284
msgid "to_column option missing"
@@ -9093,44 +8308,41 @@
msgstr "Nombres de columnas insuficientes"
#: ../vector/v.distance/main.c:315 ../vector/v.distance/main.c:335
-#, fuzzy, c-format
+#, c-format
msgid "Input vector map <%s> is 3D"
-msgstr "El mapa vectorial de entrada <%s> no és 3D!"
+msgstr "El mapa vectorial de entrada <%s> es 3D"
#: ../vector/v.distance/main.c:326 ../vector/v.distance/main.c:347
-#, fuzzy, c-format
+#, c-format
msgid "No features of selected type found in <%s>"
+msgstr "No se encontraron elementos del tipo seleccionado en <%s>"
#: ../vector/v.distance/main.c:419
msgid "dmin can not be larger than dmax"
-msgstr ""
+msgstr "dmin no puede ser mayor que dmax"
#: ../vector/v.distance/main.c:561
msgid "Incompatible column types"
msgstr "Tipos de columnas incompatibles"
#: ../vector/v.distance/main.c:609
-#, fuzzy
msgid "No categories for 'from' for slected type and layer"
-msgstr "%d categorías leídas del mapa vectorial (capa %d)"
+msgstr "No hay categorías para 'from' para tipo y capa seleccionados"
#: ../vector/v.distance/main.c:633
-#, fuzzy
msgid "Finding nearest features..."
-msgstr "Imprimiendo ... "
+msgstr "Encontrando elementos más cercanos..."
#: ../vector/v.distance/main.c:734 ../vector/v.distance/main.c:1019
-#, fuzzy, c-format
+#, c-format
msgid "More cats found in to_layer (line=%d)"
-msgstr "Más categorías encontradas en capa_a (area=%d)"
+msgstr "Más categorías encontradas en to_layer (línea=%d)"
#: ../vector/v.distance/main.c:748 ../vector/v.distance/main.c:825
#: ../vector/v.distance/main.c:1033 ../imagery/i.segment/flag.c:21
#: ../imagery/i.segment/flag.c:28
-#, fuzzy
msgid "Out of memory!"
-msgstr "Sin memoria"
+msgstr "¡Sin memoria!"
#: ../vector/v.distance/main.c:811 ../vector/v.distance/main.c:1166
#, c-format
@@ -9138,9 +8350,8 @@
#: ../vector/v.distance/main.c:919
-#, fuzzy
msgid "Finding nearest features for areas..."
+msgstr "Encontrando elementos más cercanos para áreas..."
#: ../vector/v.distance/main.c:1283
msgid "DATETIME type not yet supported, no attributes will be uploaded"
@@ -9196,21 +8407,19 @@
msgstr "%d categorías leídas del mapa no existen en la tabla"
#: ../vector/v.distance/distance.c:49
-#, fuzzy, c-format
+#, c-format
msgid "Invalid segment number %d for %d points"
-msgstr "<%s=%s> número de puntos no válido"
+msgstr "Cantidad de segmentes %d no válida para %d puntos"
#: ../vector/v.distance/distance.c:426
-#, fuzzy
msgid "At least one point is really inside the area!"
-msgstr "Se debe especificar al menos una opción de %s"
+msgstr "¡Al menos un punto está realmente dentro del área!"
#: ../vector/v.parallel/main.c:51 ../vector/v.buffer/main.c:222
#: ../locale/scriptstrings/r.buffer.lowmem_to_translate.c:4
#: ../raster/r.buffer/main.c:67 ../raster/r.circle/main.c:52
-#, fuzzy
msgid "buffer"
-msgstr "ráster, buffer"
+msgstr "buffer"
#: ../vector/v.parallel/main.c:53
msgid "Creates parallel line to input vector lines."
@@ -9233,33 +8442,28 @@
msgstr "Lado"
#: ../vector/v.parallel/main.c:97
-#, fuzzy
msgid "Parallel line is on the left"
-msgstr "Linea no admitida en cabecera"
+msgstr "La línea paralela está a la izquierda"
#: ../vector/v.parallel/main.c:98
-#, fuzzy
msgid "Parallel line is on the right"
+msgstr "La línea paralela está a la derecha"
#: ../vector/v.parallel/main.c:99
-#, fuzzy
msgid "Parallel lines on both sides"
+msgstr "Líneas paralelas a ambos lados"
#: ../vector/v.parallel/main.c:108
-#, fuzzy
msgid "Tolerance of arc polylines in map units"
-msgstr "La tolerancia en unidades de mapa: %g"
+msgstr "Tolerancia de arco de polilíneas en unidades de mapa"
#: ../vector/v.parallel/main.c:112
msgid "Make outside corners round"
msgstr "Redondear las esquinas externas"
#: ../vector/v.parallel/main.c:116
-#, fuzzy
msgid "Create buffer-like parallel lines"
-msgstr "Crear línea paralela a las líneas de entrada"
+msgstr "Crear líneas paralelas tipo buffer"
#: ../vector/v.class/main.c:46 ../raster/r.kappa/main.c:70
#: ../imagery/i.cluster/main.c:76 ../imagery/i.gensigset/main.c:41
@@ -9305,19 +8509,12 @@
msgstr "Imprimir sólo clases de quiebra (sin mín y máx)"
#: ../vector/v.class/main.c:138
-#, fuzzy
msgid "Unable to sort array of values"
-msgstr "No se pueden seleccionar datos de la tabla"
+msgstr "No ha sido posible ordenar matriz de valores"
#: ../vector/v.class/main.c:173
-msgid ""
-"The discontinuities algorithm indicates that some class breaks are not "
-"statistically significant at alpha=0.05. You are advised to reduce the "
-"number of classes."
-msgstr ""
-"El algoritmo de discontinuidades indica que algunas clases de quiebra no son "
-"estadísticamente significantes en alfa=0.05- Se aconseja reducir el nombre "
-"de clases."
+msgid "The discontinuities algorithm indicates that some class breaks are not statistically significant at alpha=0.05. You are advised to reduce the number of classes."
+msgstr "El algoritmo de discontinuidades indica que algunas clases de quiebra no son estadísticamente significantes en alfa=0.05- Se aconseja reducir el nombre de clases."
#: ../vector/v.class/main.c:201
#, c-format
@@ -9419,8 +8616,7 @@
msgstr "Realiza generalización basada en vectoriales."
#: ../vector/v.generalize/main.c:102
-msgid ""
-"Lines and boundaries causing errors (collapsed to a point or topology errors)"
+msgid "Lines and boundaries causing errors (collapsed to a point or topology errors)"
msgstr ""
#: ../vector/v.generalize/main.c:126
@@ -9445,15 +8641,15 @@
#: ../vector/v.generalize/main.c:131
msgid "Boyle's Forward-Looking Algorithm"
-msgstr ""
+msgstr "Algoritmo Forward-Looking de Boyle"
#: ../vector/v.generalize/main.c:132
msgid "McMaster's Sliding Averaging Algorithm"
-msgstr ""
+msgstr "Algoritmo de media móvil de McMaster's"
#: ../vector/v.generalize/main.c:133
msgid "McMaster's Distance-Weighting Algorithm"
-msgstr ""
+msgstr "Algoritmo de ponderación de distancia de McMaster"
#: ../vector/v.generalize/main.c:134
msgid "Chaiken's Algorithm"
@@ -9484,14 +8680,12 @@
msgstr "Valor de toleracia máximo"
#: ../vector/v.generalize/main.c:155
-#, fuzzy
msgid "Look-ahead parameter"
-msgstr "Parámetro suavizado"
+msgstr "Parámetro de vista al frente (look-ahead)"
#: ../vector/v.generalize/main.c:164
msgid "Percentage of the points in the output of 'douglas_reduction' algorithm"
-msgstr ""
-"Porcentaje de los puntos en la salida del algoritmo 'douglas_reduction'"
+msgstr "Porcentaje de los puntos en la salida del algoritmo 'douglas_reduction'"
#: ../vector/v.generalize/main.c:173
msgid "Slide of computed point toward the original point"
@@ -9533,8 +8727,7 @@
#: ../vector/v.generalize/main.c:239
msgid "Do not modify end points of lines forming a closed loop"
-msgstr ""
-"No modificar los puntos terminales de las líneas que forman un ciclo cerrado"
+msgstr "No modificar los puntos terminales de las líneas que forman un ciclo cerrado"
#: ../vector/v.generalize/main.c:242
msgid "Do not copy attributes"
@@ -9564,7 +8757,7 @@
#: ../vector/v.generalize/main.c:386
msgid "Attributes are needed for 'where' option, copying table"
-msgstr ""
+msgstr "Se necesitan atributos para opción 'where', copiando tabla"
#: ../vector/v.generalize/main.c:402
#, c-format
@@ -9572,9 +8765,9 @@
msgstr "Generalización (%s)..."
#: ../vector/v.generalize/main.c:403
-#, fuzzy, c-format
+#, c-format
msgid "Using threshold: %g %s"
-msgstr "Usando resolución [%g]"
+msgstr "Usando umbral: %g %s"
#: ../vector/v.generalize/main.c:523
#, c-format
@@ -9584,32 +8777,27 @@
#: ../vector/v.generalize/main.c:528
#, c-format
msgid "Method '%s' did not preserve last point"
-msgstr ""
+msgstr "Método '%s' no preservó último punto"
#: ../vector/v.generalize/main.c:535
#, c-format
msgid "Method '%s' did not preserve loop"
-msgstr ""
+msgstr "Método '%s' no preservó bucle"
#: ../vector/v.generalize/main.c:567
#, c-format
-msgid ""
-"%d boundaries were not modified because modification would damage topology"
-msgstr ""
-"%d contornos no fueron modificados porque la modificación recorte dañaría la "
-"topología"
+msgid "%d boundaries were not modified because modification would damage topology"
+msgstr "%d contornos no fueron modificados porque la modificación recorte dañaría la topología"
#: ../vector/v.generalize/main.c:570
#, c-format
msgid "%d lines/boundaries were not modified due to over-simplification"
-msgstr ""
+msgstr "%d líneas/contornos no fueron modificados debido a sobre simplificación"
#: ../vector/v.generalize/main.c:591
-#, fuzzy, c-format
-msgid ""
-"Number of vertices for selected features %s from %d to %d (%d%% remaining)"
-msgstr ""
-"Número de vértices de los elementos seleccionados %s de %d a %d (%d%%). "
+#, c-format
+msgid "Number of vertices for selected features %s from %d to %d (%d%% remaining)"
+msgstr "Cantidad de vértices para elementos %s seleccionados desde %d hasta %d (%d%% faltantes)"
#: ../vector/v.generalize/main.c:592
msgid "reduced"
@@ -9637,9 +8825,8 @@
msgstr "Calculando medidas de centralidad..."
#: ../vector/v.in.region/main.c:43
-#, fuzzy
msgid "Creates a vector polygon from the current region extent."
-msgstr "Crear un nuevo vectorial a partir de la región actual."
+msgstr "Crear un polígono vectorial a partir de la extensión de la región actual."
#: ../vector/v.in.region/main.c:51
msgid "Select type: line or area"
@@ -9724,8 +8911,7 @@
#: ../vector/v.label.sa/main.c:135 ../vector/v.label/main.c:200
msgid "Opaque to vector (only relevant if background color is selected)"
-msgstr ""
-"Opaco a vectorial (sólo relevante si está seleccionado el color de fondo)"
+msgstr "Opaco a vectorial (sólo relevante si está seleccionado el color de fondo)"
#: ../vector/v.label.sa/main.c:144 ../vector/v.lrs/v.lrs.label/main.c:223
#: ../vector/v.label/main.c:193 ../display/d.grid/main.c:100
@@ -9738,9 +8924,9 @@
msgstr "Anchura de límites (sólo para salida de mapa PS)"
#: ../vector/v.label.sa/labels.c:68
-#, fuzzy, c-format
+#, c-format
msgid "Cannot allocate %lu bytes of memory"
-msgstr "No se pueden asignar %d de memoria"
+msgstr "No se pueden asignar %lu bytes de memoria"
#: ../vector/v.label.sa/labels.c:87
msgid "Unable to initialise FreeType"
@@ -9781,59 +8967,48 @@
#, c-format
msgid "Found %d point/centroid in <%s>, but at least 2 are needed"
msgid_plural "Found %d points/centroids in <%s>, but at least 2 are needed"
-msgstr[0] ""
-msgstr[1] ""
+msgstr[0] "Se encontró punto/centroide %d en <%s>, pero se necesitan al menos 2"
+msgstr[1] "Se encontraron %d puntos/centroides en <%s>, pero se necesitan al menos 2"
#: ../vector/v.voronoi/sw_main.c:410 ../vector/v.voronoi/sw_main.c:436
msgid "All boundaries in the list should be valid"
msgstr "Todos los límites en la lista deben ser válidos"
#: ../vector/v.voronoi/sw_main.c:416 ../vector/v.voronoi/sw_main.c:442
-#, fuzzy
msgid "Boundary is degenerate"
-msgstr "Anchura de contorno"
+msgstr "Contorno degenerado"
#: ../vector/v.voronoi/sw_main.c:468
#, c-format
msgid "Found %d vertex in <%s>, but at least 2 are needed"
msgid_plural "Found %d vertices in <%s>, but at least 2 are needed"
-msgstr[0] ""
-msgstr[1] ""
+msgstr[0] "Se encontró vértice %d en <%s>, pero se necesitan al menos 2"
+msgstr[1] "Se encontraron %d vértices en <%s>, pero se necesitan al menos 2"
#: ../vector/v.voronoi/main.c:125 ../vector/v.delaunay/main.c:87
-#, fuzzy
msgid "triangulation"
+msgstr "triangulación"
#: ../vector/v.voronoi/main.c:126
msgid "skeleton"
-msgstr ""
+msgstr "esqueleto"
#: ../vector/v.voronoi/main.c:127
-#, fuzzy
-msgid ""
-"Creates a Voronoi diagram in current region from an input vector map "
-"containing points or centroids."
-msgstr ""
-"Crea un diagrama de Voronoi a partir de un mapa vectorial de entrada que "
-"contiene puntos o centroides."
+msgid "Creates a Voronoi diagram in current region from an input vector map containing points or centroids."
+msgstr "Crea un diagrama de Voronoi en la región actual a partir de un mapa vectorial de entrada que contenga puntos o centroides."
#: ../vector/v.voronoi/main.c:131 ../vector/v.surf.bspline/main.c:110
#: ../vector/v.sample/main.c:82
-#, fuzzy
msgid "Name of input vector point map"
+msgstr "Nombre de mapa vectorial de puntos de entrada"
#: ../vector/v.voronoi/main.c:141
-#, fuzzy
msgid "Factor for output smoothness"
-msgstr "Nombre para el archivo de salida"
+msgstr "Factor para suavización de salida"
#: ../vector/v.voronoi/main.c:142
-msgid ""
-"Applies to input areas only. Smaller values produce smoother output but can "
-"cause numerical instability."
-msgstr ""
+msgid "Applies to input areas only. Smaller values produce smoother output but can cause numerical instability."
+msgstr "Aplica solamente para áreas de entrada. Valores más chicos producen salida más suave pero pueden causar inestabilidad numérica."
#: ../vector/v.voronoi/main.c:149
#, fuzzy
@@ -9841,10 +9016,8 @@
msgstr "Longitud máxima de segmento en la red"
#: ../vector/v.voronoi/main.c:150
-msgid ""
-"Applies only to skeleton extraction. Default = -1 will extract the center "
-"line."
-msgstr ""
+msgid "Applies only to skeleton extraction. Default = -1 will extract the center line."
+msgstr "Aplica solamente para de esqueleto. Predeterminado = -1 extraerá la línea central."
#: ../vector/v.voronoi/main.c:156
msgid "Create Voronoi diagram for input areas"
@@ -9852,23 +9025,23 @@
#: ../vector/v.voronoi/main.c:161
msgid "Extract skeletons for input areas"
-msgstr ""
+msgstr "Extraer esqueletos para áreas de entrada"
#: ../vector/v.voronoi/main.c:166
msgid "Output tessellation as a graph (lines), not areas"
msgstr "Producir telesación como grafo (líneas), no áreas"
#: ../vector/v.voronoi/main.c:182
-#, fuzzy, c-format
+#, c-format
msgid "Option '%s' is too small, set to %g"
-msgstr "Se requiere la opción <%s>"
+msgstr "Opción '%s' es demasiado pequeña, definir en %g"
#: ../vector/v.voronoi/main.c:226
-#, fuzzy, c-format
+#, c-format
msgid "Voronoi triangulation for %d point..."
msgid_plural "Voronoi triangulation for %d points..."
-msgstr[0] "Triangulación Voronoi..."
-msgstr[1] "Triangulación Voronoi..."
+msgstr[0] "Triangulación Voronoi para punto %d..."
+msgstr[1] "Triangulación Voronoi para %d puntos..."
#: ../vector/v.voronoi/main.c:230 ../vector/v.delaunay/in_out.c:93
msgid "Writing edges..."
@@ -9876,7 +9049,7 @@
#: ../vector/v.voronoi/main.c:239
msgid "Thin skeletons ..."
-msgstr ""
+msgstr "Adelgazar esqueletos..."
#: ../vector/v.voronoi/main.c:396
msgid "No table"
@@ -9887,23 +9060,21 @@
msgstr "Imposible copiar la tabla"
#: ../vector/v.voronoi/skeleton.c:293 ../vector/v.voronoi/skeleton.c:400
-#, fuzzy, c-format
+#, c-format
msgid "Pass %d"
-msgstr "Pase: %d..."
+msgstr "Paso: %d"
#: ../vector/v.voronoi/skeleton.c:509
-#, fuzzy
msgid "Node is outside any input area"
-msgstr "Nombre de una capa de entrada"
+msgstr "Nodo está fuera de todas las áreas de entrada"
#: ../vector/v.voronoi/clean_topo.c:20
msgid "Searching for topology errors..."
msgstr "Buscando errores en la topología..."
#: ../vector/v.voronoi/clean_topo.c:78
-#, fuzzy
msgid "Cleaning output topology"
-msgstr "Herramienta de limpieza"
+msgstr "Limiando topología"
#: ../vector/v.voronoi/clean_topo.c:87 ../vector/v.buffer/main.c:759
#: ../vector/v.in.ogr/main.c:1391
@@ -9917,25 +9088,20 @@
msgstr "Eliminando puentes..."
#: ../vector/v.voronoi/clean_topo.c:115
-#, fuzzy
msgid "Removing incorrect boundaries from output"
-msgstr "Eliminar todas las líneas o contornos de longitud cero"
+msgstr "Eliminando contornos incorrectos para salida"
#: ../vector/v.hull/main.c:56
-#, fuzzy
msgid "Produces a 2D/3D convex hull for a given vector map."
-msgstr "Realiza un polígono convexo para un mapa vectorial dado."
+msgstr "Produce un envolvente convexo 2D/3D para un mapa vectorial dado."
#: ../vector/v.hull/main.c:70
-#, fuzzy
msgid "Limit to current region"
-msgstr "Imprimir la región actual"
+msgstr "Limitar a región actual"
#: ../vector/v.hull/main.c:75
msgid "Create a 'flat' 2D hull even if the input is 3D points"
-msgstr ""
-"Crear un polígono envolvente 'plano' 2D incluso si la entrada es con puntos "
-"3D"
+msgstr "Crear un polígono envolvente 'plano' 2D incluso si la entrada es con puntos 3D"
#: ../vector/v.hull/main.c:100
#, c-format
@@ -9943,9 +9109,9 @@
msgstr "Error al cargarvectorial de puntos de <%s>"
#: ../vector/v.hull/main.c:103
-#, fuzzy, c-format
+#, c-format
msgid "Convex hull calculation requires at least three points (%d found)"
-msgstr "puntos"
+msgstr "Cálculo de envolvente convexa mínima necesita al menos tres puntos (%d encontrados)"
#: ../vector/v.hull/main.c:105
#, c-format
@@ -9957,29 +9123,20 @@
msgstr "Polígonos envolventes simples plaos todavía no implementados"
#: ../vector/v.hull/chull.c:212
-#, fuzzy
msgid "Reading 3D vertices..."
-msgstr "Leyendo areas..."
+msgstr "Leyendo vértices 3D..."
#: ../vector/v.hull/chull.c:396
-#, fuzzy
msgid "Constructing 3D hull..."
-msgstr "Convirtiendo ... "
+msgstr "Construyendo convexo 3D..."
#: ../vector/v.surf.bspline/main.c:96
-#, fuzzy
-msgid ""
-"Performs bicubic or bilinear spline interpolation with Tykhonov "
-"regularization."
-msgstr "Interpolación spline bicúbica o bilineal con regularización Tykhonov."
+msgid "Performs bicubic or bilinear spline interpolation with Tykhonov regularization."
+msgstr "Realiza interpolación spline bicúbica o bilineal con regularización Tykhonov."
#: ../vector/v.surf.bspline/main.c:101 ../raster/r.resamp.bspline/main.c:144
-msgid ""
-"Find the best Tykhonov regularizing parameter using a \"leave-one-out\" "
-"cross validation method"
-msgstr ""
-"Encontrar el mejor parámetro de regularización Tykhonov utilizando un "
-"\"leave-one-out\" método de validación cruzada"
+msgid "Find the best Tykhonov regularizing parameter using a \"leave-one-out\" cross validation method"
+msgstr "Encontrar el mejor parámetro de regularización Tykhonov utilizando un \"leave-one-out\" método de validación cruzada"
#: ../vector/v.surf.bspline/main.c:105
#: ../vector/v.lidar.edgedetection/main.c:80 ../vector/v.outlier/main.c:78
@@ -9990,38 +9147,28 @@
#: ../vector/v.surf.bspline/main.c:107
#: ../vector/v.lidar.edgedetection/main.c:82 ../vector/v.outlier/main.c:80
#: ../vector/v.lidar.correction/main.c:77
-msgid ""
-"Estimate point density and distance for the input vector points within the "
-"current region extends and quit"
-msgstr ""
-"Estimar la densidad de puntos y la distancia para los puntos vectoriales de "
-"entrada dentro de la extensión de la región actual y salir"
+msgid "Estimate point density and distance for the input vector points within the current region extends and quit"
+msgstr "Estimar la densidad de puntos y la distancia para los puntos vectoriales de entrada dentro de la extensión de la región actual y salir"
#: ../vector/v.surf.bspline/main.c:118 ../vector/v.surf.rst/main.c:178
-#, fuzzy
msgid "Name of the attribute column with values to be used for approximation"
-msgstr ""
-"Nombre de la columna de atributos con valores a usar para la aproximación "
-"(si capa>0)"
+msgstr "Nombre de la columna con valores a ser usados para aproximación"
#: ../vector/v.surf.bspline/main.c:119
-#, fuzzy
msgid "If not given and input is 3D vector map then z-coordinates are used."
-msgstr "[%d] categorías de puntos leídas"
+msgstr "Si no se da y la entrada es un mapa vectorial 3D entonces se usará la coordenada z."
#: ../vector/v.surf.bspline/main.c:126
-#, fuzzy
msgid "Name of input vector map with sparse points"
-msgstr "Nombre del mapa vectorial de entrada de puntos esparcidos"
+msgstr "Nombre del mapa vectorial de entrada con puntos esparcidos"
#: ../vector/v.surf.bspline/main.c:139
-#, fuzzy
msgid "Raster map to use for masking (applies to raster output only)"
-msgstr "Usar formato tipo ESRI (sólo aplicable a salida WKT)"
+msgstr "Mapa ráster para máscara (aplica solamente en salida ráster)"
#: ../vector/v.surf.bspline/main.c:140 ../raster/r.resamp.bspline/main.c:99
msgid "Only cells that are not NULL and not zero are interpolated"
-msgstr ""
+msgstr "Solamente celdas que no sean NULL o que no sean ceros serán interpoladas"
#: ../vector/v.surf.bspline/main.c:149
#: ../vector/v.lidar.edgedetection/main.c:94 ../vector/v.outlier/main.c:108
@@ -10067,9 +9214,8 @@
msgstr "Ninguna validación cruzada de salida ráster o vectorial"
#: ../vector/v.surf.bspline/main.c:226
-#, fuzzy
msgid "Unable to set default DB connection"
-msgstr "No se puede establecer la proyección"
+msgstr "No ha sido posible definir conexión DB predeterminada"
#: ../vector/v.surf.bspline/main.c:231
msgid "No default DB defined"
@@ -10084,14 +9230,11 @@
#: ../vector/v.lidar.correction/main.c:229
#, c-format
msgid "No database connection for driver <%s> is defined. Run db.connect."
-msgstr ""
-"No hay definida ninguna conexión a base de datos para el controlador <%s>. "
-"Ejecute db.connect."
+msgstr "No hay definida ninguna conexión a base de datos para el controlador <%s>. Ejecute db.connect."
#: ../vector/v.surf.bspline/main.c:252
-#, fuzzy
msgid "Old auxiliary table could not be dropped"
-msgstr "La tabla auxiliar antigua no se pudo eliminar"
+msgstr "No fue posible eliminar tabla auxiliar antigua"
#: ../vector/v.surf.bspline/main.c:262 ../vector/v.surf.bspline/main.c:330
#: ../vector/v.outlier/main.c:200
@@ -10100,21 +9243,17 @@
msgstr "No se puede abrir el mapa vectorial <%s> al nivel topológico"
#: ../vector/v.surf.bspline/main.c:272 ../vector/v.surf.rst/main.c:541
-msgid ""
-"Input is 3D: using attribute values instead of z-coordinates for "
-"approximation"
-msgstr ""
-"Entrada es 3D: usando valores del atributo en vez de la coordenada z paradas "
-"aproximación"
+msgid "Input is 3D: using attribute values instead of z-coordinates for approximation"
+msgstr "Entrada es 3D: usando valores del atributo en vez de la coordenada z paradas aproximación"
#: ../vector/v.surf.bspline/main.c:274 ../vector/v.surf.rst/main.c:543
msgid "Input is 3D: using z-coordinates for approximation"
msgstr "Entrada es 3D: usando coordenadas z para aproximación"
#: ../vector/v.surf.bspline/main.c:278
-#, fuzzy, c-format
+#, c-format
msgid "Input vector map is 2D. Parameter <%s> required."
+msgstr "Mapa vectorial de entrada es 2D. Se necesita parámetro <%s>."
#: ../vector/v.surf.bspline/main.c:289
#, c-format
@@ -10136,9 +9275,9 @@
msgstr "La validación cruzada no terminó correctamente"
#: ../vector/v.surf.bspline/main.c:313 ../raster/r.resamp.bspline/main.c:367
-#, fuzzy, c-format
+#, c-format
msgid "Cross validation finished for ew_step = %f and ns_step = %f"
-msgstr "La validación cruzada no terminó correctamente"
+msgstr "La validación cruzada para ew_step = %f y ns_step = %f"
#: ../vector/v.surf.bspline/main.c:322
#, c-format
@@ -10146,13 +9285,9 @@
msgstr "El mapa vectorial <%s> de puntos esparsos se innterpolará"
#: ../vector/v.surf.bspline/main.c:338
-#, fuzzy, c-format
-msgid ""
-"Sorry, the <%s> driver is not compatible with the vector output of this "
-"module. Try with raster output or another driver."
-msgstr ""
-"Lo siento, el controlador <%s> no está permitido para salida vectorial en "
-"este módulo. Pruebe con una salida ráster u otro controlador."
+#, c-format
+msgid "Sorry, the <%s> driver is not compatible with the vector output of this module. Try with raster output or another driver."
+msgstr "Lo siento, el controlador <%s> no es compatible con la salida vectorial de este módulo. Pruebe con una salida ráster u otro controlador."
#: ../vector/v.surf.bspline/main.c:361
#, c-format
@@ -10191,16 +9326,14 @@
#: ../raster/r.resamp.bspline/main.c:308 ../raster/r.resamp.bspline/main.c:394
#: ../raster/r.resamp.bspline/main.c:465 ../raster/r.cost/main.c:435
#: ../raster/r.cost/main.c:440
-#, fuzzy
msgid "Can not create temporary file"
-msgstr "No se pueden crear archivos temporales"
+msgstr "No se puede crear archivo temporal"
#: ../vector/v.surf.bspline/main.c:475 ../vector/v.surf.bspline/main.c:503
#: ../raster/r.resamp.bspline/main.c:313 ../raster/r.resamp.bspline/main.c:399
#: ../raster/r.resamp.bspline/main.c:470
-#, fuzzy
msgid "Can not initialize temporary file"
-msgstr "No pudimos iniciar nuetsras agendas"
+msgstr "No se puede inicializar archivo temporal"
#: ../vector/v.surf.bspline/main.c:478 ../raster/r.resamp.bspline/main.c:473
msgid "Initializing output..."
@@ -10211,19 +9344,19 @@
msgstr "Cargando mapa máscara "
#: ../vector/v.surf.bspline/main.c:550 ../vector/v.outlier/main.c:296
-#, fuzzy, c-format
+#, c-format
msgid "Adjusted EW splines %d"
-msgstr "splines EW %d ajustados"
+msgstr "Splines EO (EW) ajustadas %d"
#: ../vector/v.surf.bspline/main.c:551 ../vector/v.outlier/main.c:297
-#, fuzzy, c-format
+#, c-format
msgid "Adjusted NS splines %d"
-msgstr "splines NS %d ajustados"
+msgstr "Splines NS ajustadas %d"
#: ../vector/v.surf.bspline/main.c:622 ../vector/v.outlier/main.c:353
-#, fuzzy, c-format
+#, c-format
msgid "Processing subregion %d of %d..."
-msgstr "Procesando filas %d-%d (of %d)..."
+msgstr "Procesando subregión %d de %d..."
#: ../vector/v.surf.bspline/main.c:706
#, c-format
@@ -10236,20 +9369,17 @@
msgstr "Interpolación: (%d,%d): Ningún registro para el punto (cat = %d)"
#: ../vector/v.surf.bspline/main.c:889 ../vector/v.outlier/main.c:448
-#, fuzzy
msgid "No data within this subregion. Consider increasing spline step values."
-msgstr "No hay datos en esta subregión. Considerar cambiar el paso de spline."
+msgstr "No hay datos en esta subregión. Considere cambiar el valores de paso de spline."
#: ../vector/v.surf.bspline/main.c:942 ../vector/v.outlier/main.c:458
-#, fuzzy
msgid "Auxiliary table could not be dropped"
-msgstr "La tabla auxiliar no se pudo eliminar"
+msgstr "Tabla auxiliar no pudo ser eliminada"
#: ../vector/v.surf.bspline/crosscorr.c:75
#, c-format
msgid "%d are too many points. The cross validation would take too much time."
-msgstr ""
-"%d son demasiados puntos. La validación cruzada llevará demasiado tiempo."
+msgstr "%d son demasiados puntos. La validación cruzada llevará demasiado tiempo."
#: ../vector/v.surf.bspline/crosscorr.c:84
#, c-format
@@ -10257,13 +9387,8 @@
msgstr "%d puntos encontrados en la región"
#: ../vector/v.surf.bspline/crosscorr.c:88
-#, fuzzy
-msgid ""
-"Maybe it takes too long. It will depend on how many points you are "
-"considering."
-msgstr ""
-"Ppuede que lleve demasiado tiempo. Dependerá de cuántos puntos esté "
-"considerando."
+msgid "Maybe it takes too long. It will depend on how many points you are considering."
+msgstr "Es posible que lleve demasiado tiempo. Dependerá de cuántos puntos esté considerando."
#: ../vector/v.surf.bspline/crosscorr.c:119
#, c-format
@@ -10277,19 +9402,15 @@
#: ../vector/v.surf.bspline/crosscorr.c:151
#: ../raster/r.resamp.bspline/crosscorr.c:197
-#, fuzzy, c-format
-msgid ""
-"Too many splines (%d x %d). Consider changing spline steps \"ew_step=\" "
-"\"ns_step=\"."
-msgstr ""
-"Demasiadas splines (%d x %d). Considere cambiar los pasos de spline \"sie=\" "
-"\"sin=\"."
+#, c-format
+msgid "Too many splines (%d x %d). Consider changing spline steps \"ew_step=\" \"ns_step=\"."
+msgstr "Demasiadas splines (%d x %d). Considere cambiar los pasos de spline \"ew_step=\" \"ns_step=\"."
#: ../vector/v.surf.bspline/crosscorr.c:169
#: ../raster/r.resamp.bspline/crosscorr.c:215
-#, fuzzy, c-format
+#, c-format
msgid "Beginning cross validation with lambda_i=%.4f ... (%d of %d)"
-msgstr "Iniciando validación cruzada con lambda_i=%.4f..."
+msgstr "Iniciando validación cruzada con lambda_i=%.4f...(%d o %d)"
#: ../vector/v.surf.bspline/crosscorr.c:220
#: ../vector/v.surf.idw/read_sites.c:107
@@ -10305,38 +9426,31 @@
#: ../vector/v.surf.bspline/crosscorr.c:296
#: ../raster/r.resamp.bspline/crosscorr.c:307
-#, fuzzy, c-format
+#, c-format
msgid "Root Mean Square (RMS) = %.5lf"
msgstr "Raíz Media Cuadrada (RMS) = %.5lf"
#: ../vector/v.surf.bspline/crosscorr.c:313
#: ../raster/r.resamp.bspline/crosscorr.c:324
-msgid ""
-"Different number of splines and lambda_i values have been taken for the "
-"cross correlation"
-msgstr ""
-"Se ha tomado un número diferente de splines y valores lambda_i para la "
-"correlación cruzada"
+msgid "Different number of splines and lambda_i values have been taken for the cross correlation"
+msgstr "Se ha tomado un número diferente de splines y valores lambda_i para la correlación cruzada"
#: ../vector/v.surf.bspline/crosscorr.c:315
#: ../raster/r.resamp.bspline/crosscorr.c:326
#, c-format
-msgid ""
-"The minimum value for the test (rms=%lf) was obtained with: lambda_i = %.3f"
-msgstr ""
-"El valor mínimo para las pruebas (rms=%If) se obtuvo con: lambda_i = %.3f"
+msgid "The minimum value for the test (rms=%lf) was obtained with: lambda_i = %.3f"
+msgstr "El valor mínimo para las pruebas (rms=%If) se obtuvo con: lambda_i = %.3f"
#: ../vector/v.surf.bspline/crosscorr.c:323
#: ../raster/r.resamp.bspline/crosscorr.c:334
-#, fuzzy
msgid "Table of results:"
-msgstr "Formato de la tabla"
+msgstr "Tabla de resultados:"
#: ../vector/v.surf.bspline/crosscorr.c:324
#: ../raster/r.resamp.bspline/crosscorr.c:335
-#, fuzzy, c-format
+#, c-format
msgid " lambda | mean | rms |\n"
-msgstr " lambda | media | rms |"
+msgstr " lambda | media | rms |\n"
#: ../vector/v.surf.bspline/crosscorr.c:334
#: ../raster/r.resamp.bspline/crosscorr.c:345
@@ -10360,12 +9474,8 @@
msgstr "Encuentra puntos de articulación"
#: ../vector/v.drape/main.c:62
-#, fuzzy
msgid "Converts 2D vector features to 3D by sampling of elevation raster map."
-msgstr ""
-"Convierte mapa vectorial a 3D mostreaectorial 2D a vectorial 3D muestreando "
-"ráster de elevación. De forma predeterminada se muestrea por el vecino más "
-"próximo."
+msgstr "Convierte elementos vectoriales 2D a 3D muestreando mapa ráster de elevación."
#: ../vector/v.drape/main.c:83 ../vector/v.extrude/main.c:124
msgid "Elevation raster map for height extraction"
@@ -10379,39 +9489,34 @@
msgstr "Elevación"
#: ../vector/v.drape/main.c:92 ../vector/v.extrude/main.c:134
-#, fuzzy
msgid "Scale factor sampled raster values"
-msgstr "Estadística a utilizar para los valores ráster"
+msgstr "Factor de escalamiento para valores ráster muestreados"
#: ../vector/v.drape/main.c:100 ../vector/v.extrude/main.c:142
-#, fuzzy
msgid "Height for sampled raster NULL values"
+msgstr "Altura para valores NULL de mapa ráster muestreado"
#: ../vector/v.drape/main.c:199
-#, fuzzy, c-format
+#, c-format
msgid "Undefined height for feature %d. Skipping."
-msgstr "Ningún atributo encontrado para la categoría %d: %s"
+msgstr "Altura no definida para elemento %d. Omitiedo."
#: ../vector/v.drape/main.c:204
-#, fuzzy
msgid "Copying attribute tables..."
-msgstr "Copiando tabla(s) de atributos..."
+msgstr "Copiando tablas de atributos..."
#: ../vector/v.out.vtk/main.c:51
-#, fuzzy
msgid "Converts a vector map to VTK ASCII output."
-msgstr "Convierte un mapa vectorial binario de GRASS a salida ASCII VTK."
+msgstr "Convierte un mapa vectorial a salida ASCII VTK."
#: ../vector/v.out.vtk/main.c:59
-#, fuzzy
msgid "Name for output VTK file"
+msgstr "Nombre para archivo VTK de salida"
#: ../vector/v.out.vtk/main.c:76 ../raster3d/r3.out.vtk/parameters.c:94
#: ../raster/r.out.vtk/parameters.c:85
msgid "Scale factor for elevation"
-msgstr "Factor de escala para la elevación"
+msgstr "Factor de escalamiento para la elevación"
#: ../vector/v.out.vtk/main.c:84
#: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:10
@@ -10420,9 +9525,7 @@
#: ../vector/v.out.vtk/main.c:89
msgid "Export numeric attribute table fields as VTK scalar variables"
-msgstr ""
-"Exportar campos de la tabla de atributos numéricos como variables escalares "
-"VTK"
+msgstr "Exportar campos de la tabla de atributos numéricos como variables escalares VTK"
#: ../vector/v.out.vtk/main.c:155
msgid "dp has to be from 0 to 8"
@@ -10434,19 +9537,12 @@
#: ../vector/v.out.vtk/main.c:183
#, c-format
-msgid ""
-"Export of areas requires topology. Please adjust '%s' option or rebuild "
-"topology."
-msgstr ""
-"La exportación de áreas necesita de topología. Por favor ajuste la opción "
-"'%s' o reconstruya la topología."
+msgid "Export of areas requires topology. Please adjust '%s' option or rebuild topology."
+msgstr "La exportación de áreas necesita de topología. Por favor ajuste la opción '%s' o reconstruya la topología."
#: ../vector/v.out.vtk/writeVTK.c:196
-msgid ""
-"No coordinates to generate the output! Maybe an empty vector type chosen?"
-msgstr ""
-"No hay coordenadas para generar la salida! ¿Quizás se han encontrado un tipo "
-"de vector vacío?"
+msgid "No coordinates to generate the output! Maybe an empty vector type chosen?"
+msgstr "No hay coordenadas para generar la salida! ¿Quizás se han encontrado un tipo de vector vacío?"
#: ../vector/v.out.vtk/writeVTK.c:585 ../vector/v.out.ogr/attrb.c:48
#, c-format
@@ -10455,9 +9551,7 @@
#: ../vector/v.out.vtk/writeVTK.c:632
msgid "Cannot export attribute table fields for layer < 1. Skipping export"
-msgstr ""
-"No se puede exportar los campos de atributos de la capa <1. Saliendo de la "
-"exportación. "
+msgstr "No se puede exportar los campos de atributos de la capa <1. Saliendo de la exportación. "
#: ../vector/v.out.vtk/writeVTK.c:640
msgid "No attribute table found"
@@ -10522,9 +9616,8 @@
msgstr ""
#: ../vector/v.cluster/main.c:144 ../doc/vector/v.example/main.c:81
-#, fuzzy
msgid "Unable to set predetermined vector open level"
-msgstr "No se puede abrir el mapa de puntos vectorial de centroides"
+msgstr "No ha sido posible establecer nivel predeterminado de apertura de vectorial"
#: ../vector/v.cluster/main.c:165
#, fuzzy
@@ -10616,9 +9709,8 @@
#: ../vector/v.cluster/main.c:404 ../vector/v.cluster/main.c:613
#: ../vector/v.cluster/main.c:970 ../raster/r.clump/clump.c:224
#: ../raster/r.clump/clump.c:583
-#, fuzzy
msgid "Generating renumbering scheme..."
-msgstr "Generando puntos..."
+msgstr "Generando esquema de renumeración..."
#: ../vector/v.cluster/main.c:432 ../vector/v.cluster/main.c:647
#: ../vector/v.cluster/main.c:826 ../vector/v.cluster/main.c:998
@@ -10672,8 +9764,7 @@
#: ../vector/v.lidar.edgedetection/main.c:76
msgid "Detects the object's edges from a LIDAR data set."
-msgstr ""
-"Detecta los bordes de un objeto a partir de un conjunto de datos LIDAR."
+msgstr "Detecta los bordes de un objeto a partir de un conjunto de datos LIDAR."
#: ../vector/v.lidar.edgedetection/main.c:111
msgid "Regularization weight in gradient evaluation"
@@ -10681,7 +9772,7 @@
#: ../vector/v.lidar.edgedetection/main.c:120
msgid "High gradient threshold for edge classification"
-msgstr ""
+msgstr "Umbral de gradiente elevado (high gradient) para clasificación de borde"
#: ../vector/v.lidar.edgedetection/main.c:129
#, fuzzy
@@ -10731,8 +9822,7 @@
#: ../vector/v.lidar.edgedetection/main.c:260
#, c-format
msgid "It was impossible to create <%s> interpolation table in database."
-msgstr ""
-"Fue imposible crear la tabla de interpolación <%s> en la base de datos."
+msgstr "Fue imposible crear la tabla de interpolación <%s> en la base de datos."
#: ../vector/v.lidar.edgedetection/main.c:295
#: ../raster/r.resamp.bspline/main.c:224
@@ -10801,9 +9891,8 @@
msgstr "Imposible escribir en la tabla aux"
#: ../vector/v.net/main.c:49
-#, fuzzy
msgid "network maintenance"
-msgstr "Realiza el mantenimiento de redes."
+msgstr "mantenimiento de red"
#: ../vector/v.net/main.c:50
msgid "Performs network maintenance."
@@ -10815,64 +9904,58 @@
#: ../vector/v.net/main.c:139
-#, fuzzy, c-format
+#, c-format
msgid "%d new points (nodes) written to output."
-msgstr "%d puntos nuevos escritos en la salida"
+msgstr "%d nuevos puntos (nodos) escirtos en salida."
#: ../vector/v.net/main.c:151
-#, fuzzy, c-format
+#, c-format
msgid "%d lines (network arcs) written to output."
-msgstr "%ld bytes escritos a '%s'"
+msgstr "%d líneas (arcos de red) escritas en salida."
#: ../vector/v.net/connect.c:78
-#, fuzzy
msgid "Failed to find intersection segment"
-msgstr "No se pudo interpretar la anchura como entero"
+msgstr "Ha fallao la búsqueda de segmento de intersección"
#: ../vector/v.net/arcs.c:42
-#, fuzzy, c-format
+#, c-format
msgid "Error reading file: '%s'"
-msgstr "Error al leer el archivo ASCII: '%s'"
+msgstr "Error al leer archivo: '%s'"
#: ../vector/v.net/arcs.c:48
-#, fuzzy, c-format
+#, c-format
msgid "Skipping arc %d"
-msgstr "Intercambiando datos de cabecera"
+msgstr "Omitiendo arco %d"
#: ../vector/v.net/arcs.c:85
-#, fuzzy, c-format
+#, c-format
msgid "No point with category %d found"
+msgstr "No se encontró ningún punto con categoría %d"
#: ../vector/v.net/arcs.c:89
-#, fuzzy, c-format
+#, c-format
msgid "More points with category %d found"
+msgstr "Más puntos con categoría %d encontrados"
#: ../vector/v.net/args.c:14
-#, fuzzy
msgid "Name of input vector line map (arcs)"
-msgstr "Nombre del mapa vectorial de entrada"
+msgstr "Nombre de mapa vectorial de líneas (arcos) de entrada"
#: ../vector/v.net/args.c:15
-#, fuzzy
msgid "Required for operation 'nodes', 'connect', 'report' and 'nreport'"
-msgstr ""
-"Requerido para la operación 'conectar'. Conectar puntos en el umbral dado."
+msgstr "Requerido para operación 'nodes', 'connect', 'report' y 'nreport'"
#: ../vector/v.net/args.c:17 ../vector/v.net/args.c:57
msgid "Arcs"
-msgstr ""
+msgstr "Arcos"
#: ../vector/v.net/args.c:21
-#, fuzzy
msgid "Name of input vector point map (nodes)"
-msgstr "Nombre del mapa vectorial de puntos de entrada"
+msgstr "Nombre de mapa vectorial de puntos (nodos) de entrada"
#: ../vector/v.net/args.c:23
-#, fuzzy
msgid "Required for operation 'connect' and 'arcs'"
-msgstr "Requerido para la operación 'conectar'"
+msgstr "Requerido para operación 'connect' y 'arcs'"
#: ../vector/v.net/args.c:25 ../vector/v.net/args.c:71
#: ../vector/v.net/args.c:93 ../vector/v.net/args.c:100
@@ -10888,27 +9971,23 @@
#: ../vector/v.net/args.c:40
msgid "new point is placed on each node (line end) if doesn't exist"
-msgstr ""
+msgstr "se podrá un nuevo punto en cada nodo (final de línea) si no existe"
#: ../vector/v.net/args.c:42
-msgid ""
-"connect still unconnected points to vector network by inserting new line(s)"
-msgstr ""
+msgid "connect still unconnected points to vector network by inserting new line(s)"
+msgstr "conectar puntos aún no conectados a la red vectorial insertando nueva línea(s)"
#: ../vector/v.net/args.c:44
msgid "new line is created from start point to end point"
-msgstr ""
+msgstr "nueva línea es creada desde punto de inicio a punto de término"
#: ../vector/v.net/args.c:46
-msgid ""
-"print to standard output {line_category start_point_category "
-"end_point_category}"
-msgstr ""
+msgid "print to standard output {line_category start_point_category end_point_category}"
+msgstr "mostrar en la salida estándar {line_category start_point_category end_point_category}"
#: ../vector/v.net/args.c:48
-msgid ""
-"print to standard output {point_category line_category[,line_category...]}"
-msgstr ""
+msgid "print to standard output {point_category line_category[,line_category...]}"
+msgstr "mostrar en la salida estándar {point_category line_category[,line_category...]}"
#: ../vector/v.net/args.c:50
#, fuzzy
@@ -10917,18 +9996,15 @@
#: ../vector/v.net/args.c:80
msgid "Required for operation 'connect'. Connect points in given threshold."
-msgstr ""
+msgstr "Requerido para la operación 'conectar'. Conectar puntos en el umbral dado."
#: ../vector/v.net/args.c:84
-#, fuzzy
msgid "Name of input file"
-msgstr "Nombres de los archivos de entrada"
+msgstr "Nombre de archivo de entrada"
#: ../vector/v.net/args.c:86
-#, fuzzy
msgid "Required for operation 'arcs' ('-' for standard input)"
+msgstr "Requerido para operación 'arcs' ('-' para entrada estándar)"
#: ../vector/v.net/args.c:91
msgid "Assign unique categories to new points"
@@ -10939,15 +10015,12 @@
msgstr "Para la operación 'nodos'"
#: ../vector/v.net/args.c:97
-#, fuzzy
msgid "Snap points to network"
-msgstr "Mapa vectorial de puntos final"
+msgstr "Ensamblar puntos a red"
#: ../vector/v.net/args.c:99
-msgid ""
-"For operation 'connect'. By default, a new line from the point to the "
-"network is created."
-msgstr ""
+msgid "For operation 'connect'. By default, a new line from the point to the network is created."
+msgstr "Para operación 'connect'. De manera predeterminada, se crea una nueva línea del punto a la red."
#: ../vector/v.net/args.c:103
#, fuzzy
@@ -10955,16 +10028,11 @@
msgstr "Capa de líneas"
#: ../vector/v.net/args.c:106
-msgid ""
-"Layer where turntable will be attached. Format: layer number[/layer name]."
-"Required for operation 'turntable'."
+msgid "Layer where turntable will be attached. Format: layer number[/layer name].Required for operation 'turntable'."
msgstr ""
#: ../vector/v.net/args.c:117
-msgid ""
-"Layer with unique categories for every line in arc_layer and point on every "
-"node. The categories are used in turntable. Format: layer number[/layer "
-"name]. Required for operation 'turntable'."
+msgid "Layer with unique categories for every line in arc_layer and point on every node. The categories are used in turntable. Format: layer number[/layer name]. Required for operation 'turntable'."
msgstr ""
#: ../vector/v.net/args.c:146
@@ -11042,9 +10110,9 @@
msgstr "La línea %d no tiene categoría"
#: ../vector/v.net/report.c:67
-#, fuzzy, c-format
+#, c-format
msgid "%d points found: %g %g %g line category: %d"
-msgstr "%d puntos no encontrados: %.3lf %.3lf %.3lf categoría de línea: %d"
+msgstr "%d puntos encontrados: %g %g %g categoría de línea: %d"
#: ../vector/v.net/report.c:94
#, c-format
@@ -11052,20 +10120,16 @@
msgstr "Nodo duplicado en x=%g y=%g z=%g "
#: ../vector/v.category/main.c:76 ../raster/r.category/main.c:53
-#, fuzzy
msgid "category"
-msgstr "vectorial, geometría"
+msgstr "categoría"
#: ../vector/v.category/main.c:77 ../vector/v.db.connect/main.c:55
-#, fuzzy
msgid "layer"
-msgstr "Capa"
+msgstr "capa"
#: ../vector/v.category/main.c:79
-#, fuzzy
msgid "Attaches, deletes or reports vector categories to map geometry."
-msgstr ""
-"Acjuntar, borrar o informar categorías del vectorial a la geometría del mapa."
+msgstr "Adjunta, borra o reporta categorías del mapa vectorial a la geometría del mapa."
#: ../vector/v.category/main.c:92
msgid "Feature ids (by default all features are processed)"
@@ -11076,54 +10140,36 @@
msgstr "Acción a realizar"
#: ../vector/v.category/main.c:115
-#, fuzzy
msgid "add a category to features without category in the given layer"
-msgstr ""
-"Imprimir la extensión mínima de la región de los elementos vectoriales "
-"seleccionados en lugar de los atributos"
+msgstr "añadir una categoría a elementos sin categoría en la capa dada"
#: ../vector/v.category/main.c:116
-#, fuzzy
msgid "delete category (cat=-1 to delete all categories of given layer)"
-msgstr ""
+msgstr "eliminar categoría (cat=-1 para eliminar todas las categorías de la capa dada)"
#: ../vector/v.category/main.c:117
msgid "change layer number (e.g. layer=3,1 changes layer 3 to layer 1)"
-msgstr ""
-"cambiar el número de la capa (por ejemplo capa=3,1 cambia la capa 3 a la "
-"capa 1)"
+msgstr "cambiar el número de la capa (por ejemplo capa=3,1 cambia la capa 3 a la capa 1)"
#: ../vector/v.category/main.c:118
msgid "add the value specified by cat option to the current category value"
-msgstr ""
+msgstr "añadir valor especificado por opción cat al valor de categoría actual"
#: ../vector/v.category/main.c:119
-msgid ""
-"copy values from one layer to another (e.g. layer=1,2,3 copies values from "
-"layer 1 to layer 2 and 3)"
-msgstr ""
-"copia valores de una capa a otra (por ejemplo capa=1,2,3 copia los valores "
-"de la capa 1 a la capa 2 y 3)"
+msgid "copy values from one layer to another (e.g. layer=1,2,3 copies values from layer 1 to layer 2 and 3)"
+msgstr "copia valores de una capa a otra (por ejemplo capa=1,2,3 copia los valores de la capa 1 a la capa 2 y 3)"
#: ../vector/v.category/main.c:120
-#, fuzzy
msgid "print report (statistics), in shell style: layer type count min max"
-msgstr "Formato: capa tipo cuenta mínimo máximo"
+msgstr "muestrar reporte (estadísticas), estilo consola de comandos: tipo de capa cuenta mínimo máximo"
#: ../vector/v.category/main.c:121
-msgid ""
-"print category values, layers are separated by '|', more cats in the same "
-"layer are separated by '/'"
-msgstr ""
-"muestra los valores de la categoría, las capas son separadas por '|', más "
-"categorías en la misma capa son separadas por '/'"
+msgid "print category values, layers are separated by '|', more cats in the same layer are separated by '/'"
+msgstr "muestra los valores de la categoría, las capas son separadas por '|', más categorías en la misma capa son separadas por '/'"
#: ../vector/v.category/main.c:122
-#, fuzzy
msgid "print only layer numbers"
-msgstr "No mostrar números de categoría"
+msgstr "mostrar solo los números de capas"
#: ../vector/v.category/main.c:134
#: ../locale/scriptstrings/v.centroids_to_translate.c:7
@@ -11139,30 +10185,22 @@
#: ../vector/v.category/main.c:142
-#, fuzzy
msgid "Do not copy attribute table(s)"
-msgstr "No copiar tabla"
+msgstr "No copiar tabla(s) de atributos"
#: ../vector/v.category/main.c:160
-msgid ""
-"Database connection and attribute tables for concerned layers are not changed"
-msgstr ""
-"La conexión a base de datos y las tablas de atributos para las capas "
-"afectadas no se cambian"
+msgid "Database connection and attribute tables for concerned layers are not changed"
+msgstr "La conexión a base de datos y las tablas de atributos para las capas afectadas no se cambian"
#: ../vector/v.category/main.c:208
-msgid ""
-"Invalid category number (must be equal to or greater than 0). Normally "
-"category number starts at 1."
-msgstr ""
-"Número de categoría no válido (debe ser igual o mayor que 0). Normalmente el "
-"número de categoría empieza por el 1."
+msgid "Invalid category number (must be equal to or greater than 0). Normally category number starts at 1."
+msgstr "Número de categoría no válido (debe ser igual o mayor que 0). Normalmente el número de categoría empieza por el 1."
#: ../vector/v.category/main.c:217
-#, fuzzy, c-format
+#, c-format
msgid "%d error in id option"
msgid_plural "%d errors in id option"
-msgstr[0] "%d errores en la opción id"
+msgstr[0] "%d error en la opción id"
msgstr[1] "%d errores en la opción id"
#: ../vector/v.category/main.c:228
@@ -11178,9 +10216,9 @@
msgstr "2 capas deben ser especificadas"
#: ../vector/v.category/main.c:289
-#, fuzzy, c-format
+#, c-format
msgid "Categories already exist in layer %d"
+msgstr "Las categorías ya existen en capa %d"
#: ../vector/v.category/main.c:364 ../vector/v.delaunay/main.c:172
#: ../vector/v.in.ogr/main.c:1428
@@ -11188,10 +10226,10 @@
msgstr "No es posible calcular el centroide de área"
#: ../vector/v.category/main.c:378
-#, fuzzy, c-format
+#, c-format
msgid "%d new centroid placed in output map"
msgid_plural "%d new centroids placed in output map"
-msgstr[0] "%d centroides nuevos colocados en el mapa de salida"
+msgstr[0] "%d nuevo centroide colocado en mapa de salida"
msgstr[1] "%d centroides nuevos colocados en el mapa de salida"
#: ../vector/v.category/main.c:670
@@ -11222,9 +10260,8 @@
msgstr "Varianza de la suma"
#: ../vector/v.category/main.c:701
-#, fuzzy
msgid "kernel"
-msgstr "general"
+msgstr "kernel"
#: ../vector/v.category/main.c:705
msgid "all"
@@ -11235,61 +10272,52 @@
#: ../vector/v.category/main.c:769
-#, fuzzy, c-format
+#, c-format
msgid "Categories copied from layer %d to layer %d"
+msgstr "Categorías copiadas desde capa %d a capa %d"
#: ../vector/v.category/main.c:773
-#, fuzzy, c-format
+#, c-format
msgid "%d feature modified."
msgid_plural "%d features modified."
-msgstr[0] "%d elementos modificados."
+msgstr[0] "%d elemento modificado."
msgstr[1] "%d elementos modificados."
#: ../vector/v.reclass/main.c:68 ../raster/r.reclass/main.c:51
#: ../raster/r.recode/main.c:50
-#, fuzzy
msgid "reclassification"
-msgstr "Clasificación de puntos"
+msgstr "reclasificación"
#: ../vector/v.reclass/main.c:69
-#, fuzzy
msgid "attributes"
-msgstr "Copiar atributos"
+msgstr "atributos"
#: ../vector/v.reclass/main.c:71
-msgid ""
-"Changes vector category values for an existing vector map according to "
-"results of SQL queries or a value in attribute table column."
-msgstr ""
-"Cambia los valores vectoriales de categoría por un mapa vectorial existente "
-"de acuerdo con los resultados de consultas SQL o un valor en la columna de "
-"la tabla de atributos."
+msgid "Changes vector category values for an existing vector map according to results of SQL queries or a value in attribute table column."
+msgstr "Cambia los valores vectoriales de categoría por un mapa vectorial existente de acuerdo con los resultados de consultas SQL o un valor en la columna de la tabla de atributos."
#: ../vector/v.reclass/main.c:88
msgid "The name of the column whose values are to be used as new categories"
-msgstr ""
-"El nombre de la columna cuyos valores se utilizarán como nuevas categorías"
+msgstr "El nombre de la columna cuyos valores se utilizarán como nuevas categorías"
#: ../vector/v.reclass/main.c:89
-#, fuzzy
msgid "The source for the new key column must be type integer or string"
-msgstr "La columna clave debe ser entero"
+msgstr "La fuente para la columna clave debes ser de tipo entero o cadena"
#: ../vector/v.reclass/main.c:94
msgid "Full path to the reclass rule file"
msgstr "Ruta completa para reclasificar archivo rule"
#: ../vector/v.reclass/main.c:104
-#, fuzzy, c-format
+#, c-format
msgid "Either '%s' or '%s' must be specified"
-msgstr "Se debe especificar el valor umbral"
+msgstr "Se debe especificar ya sea '%s' o '%s'"
#: ../vector/v.reclass/main.c:128 ../vector/v.surf.idw/read_sites.c:50
#: ../vector/v.sample/main.c:133
-#, fuzzy, c-format
+#, c-format
msgid "Database connection not defined for layer %s"
-msgstr "La conexión a la base de datos no ha sido definida para la capa %d"
+msgstr "La conexión a la base de datos no definida para capa %s"
#: ../vector/v.reclass/main.c:254
msgid "Key column type is not integer"
@@ -11346,8 +10374,7 @@
#: ../vector/v.reclass/main.c:413
#, c-format
msgid "%d previously set categories overwritten by new category %d"
-msgstr ""
-"%d categorías previamente establecidas sobrescritas por la nueva categoría %d"
+msgstr "%d categorías previamente establecidas sobrescritas por la nueva categoría %d"
#: ../vector/v.reclass/main.c:439
msgid "Incomplete rule"
@@ -11359,22 +10386,12 @@
msgstr "%d elementos reclasificados."
#: ../vector/v.surf.rst/main.c:145
-#, fuzzy
msgid "Performs surface interpolation from vector points map by splines."
-msgstr ""
-"Interpolación de superficies a partir de datos de puntos vectoriales "
-"mediante Inverse Distance Squared Weighting."
+msgstr "Realiza interpolación de superficie a partir de mapa vectorial de puntos usando splines."
#: ../vector/v.surf.rst/main.c:147
-#, fuzzy
-msgid ""
-"Spatial approximation and topographic analysis from given point or isoline "
-"data in vector format to floating point raster format using regularized "
-"spline with tension."
-msgstr ""
-"Aproximación espacial y análisis topográfico a partir de los datos de puntos "
-"o isolíneas dados en formato vectorial a formato ráster de coma flotante "
-"usando spline regularizada con tensión."
+msgid "Spatial approximation and topographic analysis from given point or isoline data in vector format to floating point raster format using regularized spline with tension."
+msgstr "Aproximación espacial y análisis topográfico a partir de datos de puntos o isolíneas dados en formato vectorial a formato raster de punto flotante usando spline regularizada con tensión."
#: ../vector/v.surf.rst/main.c:154
msgid "Perform cross-validation procedure without raster approximation"
@@ -11413,15 +10430,12 @@
msgstr "Producir derivadas parciales en vez de parámetros topográficos"
#: ../vector/v.surf.rst/main.c:179 ../vector/v.surf.idw/main.c:102
-msgid ""
-"If not given and input is 2D vector map then category values are used. If "
-"input is 3D vector map then z-coordinates are used."
-msgstr ""
+msgid "If not given and input is 2D vector map then category values are used. If input is 3D vector map then z-coordinates are used."
+msgstr "Si no se da y salida es mapa vectorial 3D entonces se usan valores de categorías. Si entrada es mapa vectorial 3D entonces se usan coordenadas z."
#: ../vector/v.surf.rst/main.c:189
-#, fuzzy
msgid "Name for output surface elevation raster map"
-msgstr "Nombre para el mapa ráster de salida"
+msgstr "Nombre para mapa ráster de salida de elevación de superficie"
#: ../vector/v.surf.rst/main.c:195 ../raster/r.slope.aspect/main.c:165
msgid "Name for output slope raster map"
@@ -11440,34 +10454,28 @@
msgstr "Nombre del mapa raster de curvatura tangencial de salida"
#: ../vector/v.surf.rst/main.c:219
-#, fuzzy
msgid "Name for output mean curvature raster map"
-msgstr "Producir mapa ráster de curvatura de perfil"
+msgstr "Nombre de mapa ráster de salida de curvatura media"
#: ../vector/v.surf.rst/main.c:239
-#, fuzzy
msgid "Name for output vector map showing quadtree segmentation"
-msgstr "Producir mapa vectorial que muestre segmentación quadtree"
+msgstr "Nombre de mapa vectorial de salida que muestre segmentación quadtree"
#: ../vector/v.surf.rst/main.c:246
-#, fuzzy
msgid "Name for output vector map showing overlapping windows"
-msgstr "Producir mapa vectorial que muestre ventanas solapadas"
+msgstr "Nombre para mapa vectorial de salida que muestre ventanas que se sobrelapan"
#: ../vector/v.surf.rst/main.c:252
-#, fuzzy
msgid "Name of raster map used as mask"
-msgstr "Nombre del mapa ráster usado como máscara"
+msgstr "Nombre del mapa ráster que se usará como máscara"
#: ../vector/v.surf.rst/main.c:275
msgid "Name of the attribute column with smoothing parameters"
msgstr "Nombre de la columna de atributos con los parámetros de suavizado"
#: ../vector/v.surf.rst/main.c:308
-msgid ""
-"Maximum distance between points on isoline (to insert additional points)"
-msgstr ""
-"Distancia mínima entre puntos en isolíneas (para insertar puntos adicionales)"
+msgid "Maximum distance between points on isoline (to insert additional points)"
+msgstr "Distancia mínima entre puntos en isolíneas (para insertar puntos adicionales)"
#: ../vector/v.surf.rst/main.c:317
msgid "Conversion factor for values used for approximation"
@@ -11485,28 +10493,19 @@
#: ../vector/v.surf.rst/main.c:398 ../vector/v.surf.rst/main.c:403
#, c-format
msgid "Output vector map name <%s> is not valid map name"
-msgstr ""
-"El nombre del mapa vectorial de salida <%s> no es un nombre válido de mapa"
+msgstr "El nombre del mapa vectorial de salida <%s> no es un nombre válido de mapa"
#: ../vector/v.surf.rst/main.c:416
msgid "You are not outputting any raster or vector maps"
msgstr "No se está produciendo mapas raster ni vectoriales"
#: ../vector/v.surf.rst/main.c:425
-msgid ""
-"Both cross-validation options (-c flag and cvdev vector output) must be "
-"specified"
-msgstr ""
-"Se deben especificar las dos opciones de validación cruzada (opción -c y "
-"salida vectorial cvdev)"
+msgid "Both cross-validation options (-c flag and cvdev vector output) must be specified"
+msgstr "Se deben especificar las dos opciones de validación cruzada (opción -c y salida vectorial cvdev)"
#: ../vector/v.surf.rst/main.c:428
-msgid ""
-"The cross-validation cannot be computed simultaneously with output raster or "
-"devi file"
-msgstr ""
-"La validación cruzada no se puede procesar de forma simultánea a la salida "
-"ráster o archivo devi"
+msgid "The cross-validation cannot be computed simultaneously with output raster or devi file"
+msgstr "La validación cruzada no se puede procesar de forma simultánea a la salida ráster o archivo devi"
#: ../vector/v.surf.rst/main.c:446
msgid "Using anisotropy - both theta and scalex have to be specified"
@@ -11521,38 +10520,29 @@
msgstr "El procesado tardará demasiado - se sugiere un npmin más bajo"
#: ../vector/v.surf.rst/main.c:547
-#, fuzzy
msgid "Input is 2D: using attribute values for approximation"
-msgstr "Factor de conversión para valores usados para aproximación"
+msgstr "Entrada es 2D: usando valores de atributo para aproximación"
#: ../vector/v.surf.rst/main.c:549
-#, fuzzy
msgid "Input is 2D: using category values for approximation"
+msgstr "Entrada es 2D: usando valores de categoría para aproximación"
#: ../vector/v.surf.rst/main.c:662
-#, fuzzy, c-format
-msgid ""
-"Processing all selected output files will require %d bytes of disk space for "
-"temp files"
-msgstr ""
-"Procesar todos los archivos de salida seleccionados\n"
-"necesitará %d bytes en disco para archivos temporales"
+#, c-format
+msgid "Processing all selected output files will require %d bytes of disk space for temp files"
+msgstr "Procesado de todos los archivos de salida seleccionados necesita %d bytes de espacio en disco para archivos temporales"
#: ../vector/v.surf.rst/main.c:682
-#, fuzzy
msgid "Processing segments..."
-msgstr "Procesando áreas de la entrada A..."
+msgstr "Procesando segmentos..."
#: ../vector/v.surf.rst/main.c:688
msgid "Interp_segmets failed"
msgstr "falló Interp_segmets"
#: ../vector/v.surf.rst/main.c:706
-#, fuzzy
msgid "Unable to write raster maps - try to increase resolution"
-msgstr ""
-"No se pueden escribir los mapas ráster -- intente aumentar la resolución"
+msgstr "No ha sido posible escribir mapas ráster -- intente aumentar la resolución"
#: ../vector/v.surf.rst/main.c:821 ../vector/v.in.ascii/main.c:271
#: ../raster3d/r3.in.ascii/main.c:169 ../general/g.setproj/get_stp.c:162
@@ -11567,35 +10557,25 @@
#: ../vector/v.surf.rst/main.c:826 ../raster/r.thin/io.c:131
#: ../raster/r.thin/io.c:138 ../raster/r.thin/io.c:147
#: ../raster/r.resamp.rst/main.c:547
-#, fuzzy, c-format
+#, c-format
msgid "Error writing temporary file <%s>"
-msgstr "%s: error al escribir el archivo temporal"
+msgstr "Error al escribir archivo temporal <%s>"
#: ../vector/v.perturb/main.c:69
-#, fuzzy
msgid "Random location perturbations of vector points."
-msgstr ""
-"Perturbaciones de localizaciones aleatorias de puntos vectoriales de GRASS"
+msgstr "Perturbaciones aleatorias de ubicación de puntos vectoriales."
#: ../vector/v.perturb/main.c:83
msgid "Distribution of perturbation"
msgstr "Distribución de la perturbación"
#: ../vector/v.perturb/main.c:90
-#, fuzzy
msgid "Parameter(s) of distribution"
-msgstr "distribución de clases"
+msgstr "Parámetro(s) de distribución"
#: ../vector/v.perturb/main.c:91
-#, fuzzy
-msgid ""
-"If the distribution is uniform, only one parameter, the maximum, is needed. "
-"For a normal distribution, two parameters, the mean and standard deviation, "
-"are required."
-msgstr ""
-"Parámetro(s) de distribución. Se la distribución es uniforme, sólo se "
-"necesita un parámetro, el máximo. Para una distribución normal se requieren "
-"dos parámetros, la media y la desviación estándar."
+msgid "If the distribution is uniform, only one parameter, the maximum, is needed. For a normal distribution, two parameters, the mean and standard deviation, are required."
+msgstr "Si la distribución es uniforme, solamente se necesita un parámetro, el máximo. Para una distribución normal, se necesitan dos parámetros, la media y la desviación estándar."
#: ../vector/v.perturb/main.c:101
msgid "Minimum deviation in map units"
@@ -11631,37 +10611,33 @@
#: ../vector/v.out.ogr/main.c:86
msgid "Exports a vector map layer to any of the supported OGR vector formats."
-msgstr ""
-"Exporta un mapa vectorial a cualquiera de los formatos vectoriales OGR "
-"soportados."
+msgstr "Exporta un mapa vectorial a cualquiera de los formatos vectoriales OGR soportados."
#: ../vector/v.out.ogr/main.c:87
-#, fuzzy
msgid "By default a vector map layer is exported to Esri Shapefile format."
-msgstr "Exporta capas vectoriales de GRASS a formato de archivo DXF."
+msgstr "De manera predeterminada una capa de mapa vectorial es exportada a formato Shapefile de Esri."
#: ../vector/v.out.ogr/main.c:164
msgid "Volumes will be exported as sets of faces"
msgstr "Los volúmenes serán exportados como conjuntos de faces"
#: ../vector/v.out.ogr/main.c:182
-#, fuzzy
msgid "Unable to determine input map's vector feature type(s)."
-msgstr "No se puede determinar el tipo de celda ráster"
+msgstr "No ha sido posible determinar el tipo(s) de elemento vectorial del mapa(s) de entrada."
#: ../vector/v.out.ogr/main.c:197
-#, fuzzy, c-format
+#, c-format
msgid "Appending to OGR layer requires option '%s'"
-msgstr "La herramienta %s requiere la opción %s"
+msgstr "Para adjuntar a capa OGR se necesita opción '%s'"
#: ../vector/v.out.ogr/main.c:252
msgid "The combination of types is not supported by all formats."
msgstr "La combinación de tipos no está soportada por todos lo formatos."
#: ../vector/v.out.ogr/main.c:276
-#, fuzzy, c-format
+#, c-format
msgid "Unknown EPSG code %s"
-msgstr "Color desconocido: [%s]"
+msgstr "Código EPSG desconocido %s"
#: ../vector/v.out.ogr/main.c:294
#, c-format
@@ -11669,171 +10645,89 @@
msgstr "Capa OGR <%s> creada en fuente de datos <%s> (formato '%s)"
#: ../vector/v.out.ogr/main.c:306
-msgid ""
-"The map contains islands. With the -c flag, islands will appear as filled "
-"areas, not holes in the output map."
-msgstr ""
-"El mapa contiene islas. Con la opción -c, las islas aparecerán como áreas "
-"rellenas, no agujeros en el mapa de salida."
+msgid "The map contains islands. With the -c flag, islands will appear as filled areas, not holes in the output map."
+msgstr "El mapa contiene islas. Con la opción -c, las islas aparecerán como áreas rellenas, no agujeros en el mapa de salida."
#: ../vector/v.out.ogr/main.c:312
-#, fuzzy, c-format
-msgid ""
-"%d point found, but not requested to be exported. Verify 'type' parameter."
-msgid_plural ""
-"%d points found, but not requested to be exported. Verify 'type' parameter."
-msgstr[0] ""
-"%d punto(s) encontrado, pero no se ha solicitado exportarlos. Verificar el "
-"parámetro 'tipo'."
-msgstr[1] ""
+#, c-format
+msgid "%d point found, but not requested to be exported. Verify 'type' parameter."
+msgid_plural "%d points found, but not requested to be exported. Verify 'type' parameter."
+msgstr[0] "%d punto encontrado, pero no se ha solicitado exportarlo. Verifique el parámetro 'type'."
+msgstr[1] "%d puntos encontrados, pero no se ha solicitado exportarlos. Verifique el parámetro 'type'."
#: ../vector/v.out.ogr/main.c:320
-#, fuzzy, c-format
-msgid ""
-"%d line found, but not requested to be exported. Verify 'type' parameter."
-msgid_plural ""
-"%d line(s) found, but not requested to be exported. Verify 'type' parameter."
-msgstr[0] ""
-"%d línea(s) encontrada, pero no se ha solicitado exportarlas. Verificar el "
-msgstr[1] ""
+#, c-format
+msgid "%d line found, but not requested to be exported. Verify 'type' parameter."
+msgid_plural "%d line(s) found, but not requested to be exported. Verify 'type' parameter."
+msgstr[0] "%d línea encontrada, pero no se ha solicitado exportarla. Verifique el parámetro 'type'."
+msgstr[1] "%d líneas encontradas, pero no se ha solicitado exportarlas. Verifique el parámetro 'type'."
#: ../vector/v.out.ogr/main.c:329
-#, fuzzy, c-format
-msgid ""
-"%d boundary found, but not requested to be exported. Verify 'type' parameter."
-msgid_plural ""
-"%d boundaries found, but not requested to be exported. Verify 'type' "
-"parameter."
-msgstr[0] ""
-"%d contorno(s) encontrado, pero no se ha solicitado exportarlos. Verificar "
-"el parámetro 'tipo'."
-msgstr[1] ""
+#, c-format
+msgid "%d boundary found, but not requested to be exported. Verify 'type' parameter."
+msgid_plural "%d boundaries found, but not requested to be exported. Verify 'type' parameter."
+msgstr[0] "%d contorno encontrado, pero no se ha solicitado exportarlo. Verifique el parámetro 'type'."
+msgstr[1] "%d contornos encontrados, pero no se ha solicitado exportarlos. Verifique el parámetro 'type'."
#: ../vector/v.out.ogr/main.c:338
-#, fuzzy, c-format
-msgid ""
-"%d centroid found, but not requested to be exported. Verify 'type' parameter."
-msgid_plural ""
-"%d centroids found, but not requested to be exported. Verify 'type' "
-"parameter."
-msgstr[0] ""
-"%d centroide(s) encontrado, pero no se ha solicitado exportarlos. Verificar "
-msgstr[1] ""
+#, c-format
+msgid "%d centroid found, but not requested to be exported. Verify 'type' parameter."
+msgid_plural "%d centroids found, but not requested to be exported. Verify 'type' parameter."
+msgstr[0] "%d centroide encontrado, pero no se ha solicitado exportarlo. Verifique el parámetro 'type'."
+msgstr[1] "%d centroides encontrados, pero no se ha solicitado exportarlos. Verifique el parámetro 'type'."
#: ../vector/v.out.ogr/main.c:346
-#, fuzzy, c-format
-msgid ""
-"%d area found, but not requested to be exported. Verify 'type' parameter."
-msgid_plural ""
-"%d areas found, but not requested to be exported. Verify 'type' parameter."
-msgstr[0] ""
-"%d superficie(s) encontrada(s), pero no se ha solicitado exportarlas. "
-"Verificar el parámetro 'tipo'."
-msgstr[1] ""
+#, c-format
+msgid "%d area found, but not requested to be exported. Verify 'type' parameter."
+msgid_plural "%d areas found, but not requested to be exported. Verify 'type' parameter."
+msgstr[0] "%d área encontrada, pero no se ha solicitado exportarla. Verifique el parámetro 'type'."
+msgstr[1] "%d áreas encontradas, pero no se ha solicitado exportarlas. Verifique el parámetro 'type'."
#: ../vector/v.out.ogr/main.c:354
#, fuzzy, c-format
-msgid ""
-"%d face found, but not requested to be exported. Verify 'type' parameter."
-msgid_plural ""
-"%d faces found, but not requested to be exported. Verify 'type' parameter."
-msgstr[0] ""
-"%d cara(s) encontrada, pero no se ha solicitado exportarlas. Verificar el "
-msgstr[1] ""
+msgid "%d face found, but not requested to be exported. Verify 'type' parameter."
+msgid_plural "%d faces found, but not requested to be exported. Verify 'type' parameter."
+msgstr[0] "%d cara(s) encontrada, pero no se ha solicitado exportarlas. Verificar el parámetro 'tipo'."
+msgstr[1] "%d volumen encontrado, pero no se ha solicitado exportarlo. Verifique el parámetro 'type'."
#: ../vector/v.out.ogr/main.c:362
-#, fuzzy, c-format
-msgid ""
-"%d volume found, but not requested to be exported. Verify 'type' parameter."
-msgid_plural ""
-"%d volumes found, but not requested to be exported. Verify 'type' parameter."
-msgstr[0] ""
-"%d volumen(es) encontrado, pero no se ha solicitado exportarlos. Verificar "
-msgstr[1] ""
+#, c-format
+msgid "%d volume found, but not requested to be exported. Verify 'type' parameter."
+msgid_plural "%d volumes found, but not requested to be exported. Verify 'type' parameter."
+msgstr[0] "%d volumen encontrado, pero no se ha solicitado exportarlo. Verifique el parámetro 'type'."
+msgstr[1] "%d volúmenes encontrados, pero no se ha solicitado exportarlos. Verifique el parámetro 'type'."
#: ../vector/v.out.ogr/main.c:372
-#, fuzzy
-msgid ""
-"No points found, but requested to be exported. Will skip this feature type."
-msgstr ""
-"%d punto(s) encontrado(s), pero no se ha solicitado exportarlos. Verificar "
+msgid "No points found, but requested to be exported. Will skip this feature type."
+msgstr "No se encontraron puntos, pero se pidió que se exportaran. Se omitirá este tipo de elemento."
#: ../vector/v.out.ogr/main.c:381
-#, fuzzy
-msgid ""
-"No lines found, but requested to be exported. Will skip this feature type."
-msgstr ""
-"%d línea(s) encontrada(s), pero no se ha solicitado exportarlas. Verificar "
+msgid "No lines found, but requested to be exported. Will skip this feature type."
+msgstr "No se encontraron líneas, pero se pidió que se exportaran. Se omitirá este tipo de elemento."
#: ../vector/v.out.ogr/main.c:391
-#, fuzzy
-msgid ""
-"No boundaries found, but requested to be exported. Will skip this feature "
-"type."
-msgstr ""
-"%d límite(s) encontrado(s), pero no se ha solicitado exportarlos. Verificar "
+msgid "No boundaries found, but requested to be exported. Will skip this feature type."
+msgstr "No se encontraron contorno, pero se pidió que se exportaran. Se omitirá este tipo de elemento."
#: ../vector/v.out.ogr/main.c:400
-#, fuzzy
-msgid ""
-"No areas found, but requested to be exported. Will skip this feature type."
-msgstr ""
+msgid "No areas found, but requested to be exported. Will skip this feature type."
+msgstr "No se encontraron áreas, pero se pidió que se exportaran. Se omitirá este tipo de elemento."
#: ../vector/v.out.ogr/main.c:410
-#, fuzzy
-msgid ""
-"No centroids found, but requested to be exported. Will skip this feature "
-"type."
-msgstr ""
-"%d centroide(s) encontrado(s), pero no se ha solicitado exportarlos. "
+msgid "No centroids found, but requested to be exported. Will skip this feature type."
+msgstr "No se encontraron centroides, pero se pidió que se exportaran. Se omitirá este tipo de elemento."
#: ../vector/v.out.ogr/main.c:419
-#, fuzzy
-msgid ""
-"No faces found, but requested to be exported. Will skip this feature type."
-msgstr ""
-"%d cara(s) encontrada(s), pero no se ha solicitado exportarlas. Verificar el "
+msgid "No faces found, but requested to be exported. Will skip this feature type."
+msgstr "No se encontraron faces, pero se pidió que se exportaran. Se omitirá este tipo de elemento."
#: ../vector/v.out.ogr/main.c:428
-#, fuzzy
-msgid ""
-"No kernels found, but requested to be exported. Will skip this feature type."
-msgstr ""
+msgid "No kernels found, but requested to be exported. Will skip this feature type."
+msgstr "No se encontraron kernels, pero se pidió que se exportaran. Se omitirá este tipo de elemento."
#: ../vector/v.out.ogr/main.c:437
-#, fuzzy
-msgid ""
-"No volumes found, but requested to be exported. Will skip this feature type."
-msgstr ""
+msgid "No volumes found, but requested to be exported. Will skip this feature type."
+msgstr "No se encontraron volúmenes, pero se pidió que se exportaran. Se omitirá este tipo de elemento."
#: ../vector/v.out.ogr/main.c:462
#, c-format
@@ -11865,34 +10759,19 @@
msgstr "Anulando 'SHPT=' LCO existente definida por el usuario."
#: ../vector/v.out.ogr/main.c:557
-#, fuzzy, c-format
-msgid ""
-"Vector map <%s> is 3D. Use format specific layer creation options SHPT "
-"(parameter 'lco') or '-z' flag to export in 3D rather than 2D (default)"
-msgstr ""
-"El mapa vectorial <%s> es 3D. Use opciones de creación de capa específicas "
-"para el formato (parámetro 'Ico') para exportar en 3D en vez de 2D "
-"(predeterminado)."
+#, c-format
+msgid "Vector map <%s> is 3D. Use format specific layer creation options SHPT (parameter 'lco') or '-z' flag to export in 3D rather than 2D (default)"
+msgstr "El mapa vectorial <%s> es 3D. Use opciones de creación de capa específicas SHPT (parámetro 'Ico') o bandera '-z' para exportar en 3D en vez de 2D (predeterminado)."
#: ../vector/v.out.ogr/main.c:569
-#, fuzzy, c-format
-msgid ""
-"Vector map <%s> is 3D. Use format specific layer creation options DIM "
-"(parameter 'lco') to export in 3D rather than 2D (default)."
-msgstr ""
+#, c-format
+msgid "Vector map <%s> is 3D. Use format specific layer creation options DIM (parameter 'lco') to export in 3D rather than 2D (default)."
+msgstr "El mapa vectorial <%s> es 3D. Use opciones de creación de capa específicas DIM (parámetro 'Ico') para exportar en 3D en vez de 2D (predeterminado)."
#: ../vector/v.out.ogr/main.c:576
-#, fuzzy, c-format
-msgid ""
-"Vector map <%s> is 3D. Use format specific layer creation options (parameter "
-"'lco') to export <in 3D rather than 2D (default)."
-msgstr ""
+#, c-format
+msgid "Vector map <%s> is 3D. Use format specific layer creation options (parameter 'lco') to export <in 3D rather than 2D (default)."
+msgstr "El mapa vectorial <%s> es 3D. Use opciones de creación de capa específicas (parámetro 'Ico') para exportar en 3D en vez de 2D (predeterminado)."
#: ../vector/v.out.ogr/main.c:595
msgid "Unable to create OGR layer"
@@ -11900,15 +10779,11 @@
#: ../vector/v.out.ogr/main.c:607
msgid "No attribute table found -> using only category numbers as attributes"
-msgstr ""
-"No se encontró ninguna tabla de atributos -> sólo se usan los números de "
-"categoría como atributos"
+msgstr "No se encontró ninguna tabla de atributos -> sólo se usan los números de categoría como atributos"
#: ../vector/v.out.ogr/main.c:611
msgid "Exporting 'cat' anyway, as it is the only attribute table field"
-msgstr ""
-"Exportando 'cat' de todas formas, ya que es el único campo la tabla de "
-"atributos"
+msgstr "Exportando 'cat' de todas formas, ya que es el único campo la tabla de atributos"
#: ../vector/v.out.ogr/main.c:620 ../vector/v.out.ogr/main.c:692
#, c-format
@@ -11921,11 +10796,11 @@
msgstr "Columna clave <%s> no encontrada"
#: ../vector/v.out.ogr/main.c:717
-#, fuzzy, c-format
+#, c-format
msgid "Exporting %d feature..."
msgid_plural "Exporting %d features..."
-msgstr[0] "Extrayendo áreas..."
-msgstr[1] "Extrayendo áreas..."
+msgstr[0] "Exportando %d elemento..."
+msgstr[1] "Exportando %d elementos..."
#: ../vector/v.out.ogr/main.c:732
#, c-format
@@ -11961,31 +10836,27 @@
#: ../vector/v.out.ogr/main.c:782
#, c-format
-msgid ""
-"%d feature without category was skipped. Features without category are "
-"written only when -%c flag is given."
-msgid_plural ""
-"%d features without category were skipped. Features without category are "
-msgstr[0] ""
-msgstr[1] ""
+msgid "%d feature without category was skipped. Features without category are written only when -%c flag is given."
+msgid_plural "%d features without category were skipped. Features without category are written only when -%c flag is given."
+msgstr[0] "elemento %d sin categoría fue imitido. Solamente se escribirán elementos sin categoría cuando la bandera -%c sea dada."
+msgstr[1] "%d elementos sin categoría fue imitidos. Solamente se escribirán elementos sin categoría cuando la bandera -%c sea dada."
#: ../vector/v.out.ogr/main.c:798
msgid "Output layer is empty, no features written"
msgstr "La capa de salida está vacía, sin elementos escritos"
#: ../vector/v.out.ogr/main.c:799
-#, fuzzy, c-format
+#, c-format
msgid "%d feature (%s type) written to <%s> (%s format)."
msgid_plural "%d features (%s type) written to <%s> (%s format)."
-msgstr[0] "%d elementos escritos a <%s> (%s)."
-msgstr[1] "%d elementos escritos a <%s> (%s)."
+msgstr[0] "%d elemento (tipo %s) escritos a <%s> (formato %s)."
+msgstr[1] "%d elementos (tipo %s) escritos a <%s> (formato %s)."
#: ../vector/v.out.ogr/export_areas.c:150
#: ../vector/v.out.ogr/export_lines.c:178
-#, fuzzy, c-format
+#, c-format
msgid "Unable to export multi-features. No category index for layer %d."
-msgstr "No se pueden escribir categorías para el mapa raster <%s>"
+msgstr "No ha sido posible exportar multi-elementos. No hay índice de categoría para capa %d."
#: ../vector/v.out.ogr/export_areas.c:161
msgid "Exporting features with category..."
@@ -11993,35 +10864,29 @@
#: ../vector/v.out.ogr/export_areas.c:183
#: ../vector/v.out.ogr/export_lines.c:212
-#, fuzzy, c-format
-msgid ""
-"Unable to create multi-feature. Category %d not found in line %d, field %d"
-msgstr "No se puede borrar la capa/categoría [%d/%d] línea %d"
+#, c-format
+msgid "Unable to create multi-feature. Category %d not found in line %d, field %d"
+msgstr "No ha sido posible crear multi-elemento. Categoría %d no encontrada en línea %d, campo %d"
#: ../vector/v.out.ogr/export_areas.c:221
msgid "Exporting features without category..."
msgstr "Exportando elementos sin categoría..."
#: ../vector/v.out.ogr/args.c:9
-#, fuzzy
msgid "Name of input vector map to export"
-msgstr "Nombre del mapa ráster a reproyectar"
+msgstr "Nombre de mapa vectorial de entrada a exportar"
#: ../vector/v.out.ogr/args.c:18
msgid "Feature type(s)"
msgstr "Tipo(s) de elemento"
#: ../vector/v.out.ogr/args.c:20
-#, fuzzy
-msgid ""
-"Combination of types is not supported by all output formats. Default is to "
-"use first type found in input vector map."
-msgstr "La combinación de tipos no está soportada por todos lo formatos."
+msgid "Combination of types is not supported by all output formats. Default is to use first type found in input vector map."
+msgstr "Combinación de tipos no está soportada por todos los formatos de salida. De manera predeterminada se usa el primer tipo encontrado en mapa vectorial de entrada."
#: ../vector/v.out.ogr/args.c:28
-#, fuzzy
msgid "Name of output OGR datasource"
-msgstr "Nombre para la tabla de salida"
+msgstr "Nombre de fuente de datos OGR de salida"
#: ../vector/v.out.ogr/args.c:30
msgid ""
@@ -12037,9 +10902,7 @@
#: ../vector/v.out.ogr/args.c:47
msgid "Name for output OGR layer. If not specified, input name is used"
-msgstr ""
-"Nombre de capa OGR de salida. Si no se especifica, se usará en nombre de "
-"entrada"
+msgstr "Nombre de capa OGR de salida. Si no se especifica, se usará en nombre de entrada"
#: ../vector/v.out.ogr/args.c:49
msgid ""
@@ -12067,9 +10930,8 @@
msgstr "Cambiar opcionalmente el tipo de salida predeterminada"
#: ../vector/v.out.ogr/args.c:60
-#, fuzzy
msgid "export area boundaries as linestrings"
-msgstr "exporta bordes de áreas como linestrings"
+msgstr "exportar contornos de áreas como cadenas de líneas"
#: ../vector/v.out.ogr/args.c:61
msgid "export lines as polygons"
@@ -12077,85 +10939,67 @@
#: ../vector/v.out.ogr/args.c:71
msgid "OGR dataset creation option (format specific, NAME=VALUE)"
-msgstr ""
-"Opción de creación de conjunto de datos OGR (específica de formato, "
-"NOMBRE=VALOR)"
+msgstr "Opción de creación de conjunto de datos OGR (específica de formato, NOMBRE=VALOR)"
#: ../vector/v.out.ogr/args.c:81
msgid "OGR layer creation option (format specific, NAME=VALUE)"
msgstr "Opción de creación de capa OGR (específica de formato, NOMBRE=VALOR)"
#: ../vector/v.out.ogr/args.c:86
-#, fuzzy
msgid "Open an existing OGR datasource for update"
-msgstr "Abrir una fuente de datos existentes para actualizar"
+msgstr "Abrir una fuente de datos OGR existente para actualizar"
#: ../vector/v.out.ogr/args.c:90
msgid "Append to existing layer"
msgstr "Anexar a la capa existente"
#: ../vector/v.out.ogr/args.c:91
-#, fuzzy
msgid "A new OGR layer is created if it does not exist"
-msgstr "El grupo <%s> no existe"
+msgstr "Se creará una nueva capa OGR si es que no existe"
#: ../vector/v.out.ogr/args.c:96
msgid "Skip export of GRASS category ID ('cat') attribute"
msgstr "Saltar exportación del atributo de la categoría GRASS ID ('cat')"
#: ../vector/v.out.ogr/args.c:102
-#, fuzzy
-msgid ""
-"Also export features without category (not labeled). Otherwise only features "
-"with category are exported."
-msgstr ""
-"Exportar sólo elementos con categoría (etiquetados). En caso contrario se "
-"exportarán todos."
+msgid "Also export features without category (not labeled). Otherwise only features with category are exported."
+msgstr "Exportaar tambien elementos sin categoría (sin leyenda). De otro modo solamente se exportarán elementos con categoría."
#: ../vector/v.out.ogr/args.c:108
msgid "Use ESRI-style .prj file format (applies to Shapefile output only)"
-msgstr ""
-"Usar formato de archivo .prj tipo ESRI (sólo se aplica al Shapefile de "
-"salida)"
+msgstr "Usar formato de archivo .prj tipo ESRI (sólo se aplica al Shapefile de salida)"
#: ../vector/v.out.ogr/args.c:114
-#, fuzzy
msgid "Force 2D output even if input is 3D (applies to Shapefile output only)"
-msgstr ""
-"Crear salida 3D si la entrada es 3D (sólo se aplica a Shapefile de salida)"
+msgstr "Forsar salida 2D aun si la entrada es 3D (aplica solamente para Shapefile de salida)"
#: ../vector/v.out.ogr/args.c:116 ../vector/v.in.ogr/main.c:275
#: ../vector/v.out.postgis/args.c:78
msgid "Useful if input is 3D but all z coordinates are identical"
-msgstr ""
+msgstr "Es útil si la entrada es 3D pero todas las coordenadas son idénticas"
#: ../vector/v.out.ogr/args.c:122
msgid "Export vector data as multi-features"
msgstr "Exportar datos como multi-elementos"
#: ../vector/v.out.ogr/args.c:128
-#, fuzzy
-msgid ""
-"Create a new empty layer in defined OGR datasource and exit. Nothing is read "
-"from input."
-msgstr "Crear un mapa nuevo vacío y salir. No se lee nada de la entrada"
+msgid "Create a new empty layer in defined OGR datasource and exit. Nothing is read from input."
+msgstr "Crear una capa vacía nueva en fuente de datos OGR definida y salir. Nada qué leer desde entrada."
#: ../vector/v.out.ogr/attrb.c:65
#, c-format
msgid "No database record for cat = %d and export of 'cat' disabled"
-msgstr ""
-"No hay archivo de la base de datos para cat = %d y la exportación de 'cat' "
-"está inutilizada"
+msgstr "No hay archivo de la base de datos para cat = %d y la exportación de 'cat' está inutilizada"
#: ../vector/v.out.ogr/create.c:20
-#, fuzzy, c-format
+#, c-format
msgid "OGR driver <%s> not available"
-msgstr "Capa <%s> no disponible"
+msgstr "Controlador OGR <%s> no disponible"
#: ../vector/v.out.ogr/create.c:26
-#, fuzzy, c-format
+#, c-format
msgid "Creation of output OGR datasource <%s> failed"
-msgstr "No se puede abrir el origen de datos OGR '%s'"
+msgstr "Falló la creación de fuente de datos OGR de salida <%s>"
#: ../vector/v.out.ogr/create.c:36
#, c-format
@@ -12167,9 +11011,8 @@
msgstr "Convierte puntos GRASS x,y,z al formato POV-Ray x,z,y."
#: ../vector/v.out.pov/main.c:60
-#, fuzzy
msgid "Name for output POV file"
-msgstr "Nombre para el archivo de salida"
+msgstr "Nombre para archivo POV de salida"
#: ../vector/v.out.pov/main.c:67
msgid "Radius of sphere for points and tube for lines"
@@ -12180,19 +11023,16 @@
msgstr "Puede estar disponible también, por ejemplo grass_r."
#: ../vector/v.out.pov/main.c:74
-#, fuzzy
msgid "Modifier for z coordinates"
-msgstr "Cambiando valor para coordenadas Z"
+msgstr "Modificador para coordenadas <"
#: ../vector/v.out.pov/main.c:75
-msgid ""
-"This string is appended to each z coordinate. Examples: '*10', '+1000', "
-"'*10+100', '*exaggeration'"
-msgstr ""
+msgid "This string is appended to each z coordinate. Examples: '*10', '+1000', '*10+100', '*exaggeration'"
+msgstr "Esta cadena es adjuntada a cada coordenada z. Ejemplos: '*10', '+1000', '*10+100', '*exaggeration'"
#: ../vector/v.out.pov/main.c:82
msgid "Object modifier (OBJECT_MODIFIER in POV-Ray documentation)"
-msgstr ""
+msgstr "Modificador de objetos (OBJECT_MODIFIER en documentación POV-Ray)"
#: ../vector/v.out.pov/main.c:83
msgid "Example: \"pigment { color red 0 green 1 blue 0 }\""
@@ -12205,29 +11045,19 @@
msgstr "No se puede crear el archivo de salida <%s>"
#: ../vector/v.out.pov/main.c:218
-#, fuzzy, c-format
+#, c-format
msgid "%d feature written."
msgid_plural "%d features written."
-msgstr[0] "%d elementos escritos"
+msgstr[0] "%d elemento escrito"
msgstr[1] "%d elementos escritos"
#: ../vector/v.net.distance/main.c:69
-msgid ""
-"Computes shortest distance via the network between the given sets of "
-"features."
-msgstr ""
-"Calcula la distancia más corta a través de la red entre los conjuntos de "
-"elementos facilitados."
+msgid "Computes shortest distance via the network between the given sets of features."
+msgstr "Calcula la distancia más corta a través de la red entre los conjuntos de elementos facilitados."
#: ../vector/v.net.distance/main.c:72
-#, fuzzy
-msgid ""
-"Finds the shortest paths from each 'from' point to the nearest 'to' feature "
-"and various information about this relation are uploaded to the attribute "
-"table."
-msgstr ""
-"Encuentra las rutas más cortas entre un elemento 'a' a cada elemento 'desde' "
-"y se carga varia información sobre esta relación a la tabla de atributos."
+msgid "Finds the shortest paths from each 'from' point to the nearest 'to' feature and various information about this relation are uploaded to the attribute table."
+msgstr "Encuentra las rutas más cortas entre un elemento 'from' al elemento 'to' más cercano y se carga a la tabla de atributos información varia sobre esta relación."
#: ../vector/v.net.distance/main.c:100
msgid "From layer number or name"
@@ -12259,54 +11089,49 @@
#: ../vector/v.net.distance/main.c:169
msgid "Write each output path as one line, not as original input segments."
-msgstr ""
+msgstr "Escribir cada ruta de salida como una línea, no como en los segmentos de entrada originales."
#: ../vector/v.net.distance/main.c:244
#, c-format
msgid "No 'from' features selected. Please check options '%s', '%s', '%s'."
-msgstr ""
+msgstr "No hay elementos 'from' seleccionados. Por favor revise opciones '%s', '%s', '%s'."
#: ../vector/v.net.distance/main.c:251
#, c-format
msgid "No 'to' features selected. Please check options '%s', '%s', '%s'."
-msgstr ""
+msgstr "No hay elementos 'to' seleccionados. Por favor revise opciones '%s', '%s', '%s'."
#: ../vector/v.net.distance/main.c:260
-#, fuzzy
msgid "No 'to' features"
-msgstr "Escribiendo elementos seleccionados..."
+msgstr "No hay elementos 'to'"
#: ../vector/v.net.distance/main.c:268
-#, fuzzy
msgid "Distances to 'to' features ..."
+msgstr "Distancias a elementos 'to'..."
#: ../vector/v.net.distance/main.c:307
-#, fuzzy
msgid "Tracing paths from 'from' features ..."
-msgstr "Transformando elementos..."
+msgstr "Trazando rutas desde elementos 'from'..."
#: ../vector/v.net.distance/main.c:423
#, c-format
msgid "%d 'from' feature was not reachable"
msgid_plural "%d 'from' features were not reachable"
-msgstr[0] ""
-msgstr[1] ""
+msgstr[0] "%d elemento 'from' no fue alcanzable"
+msgstr[1] "%d elementos 'from' no fue alcanzable"
#: ../vector/v.outlier/main.c:73 ../raster3d/r3.neighbors/main.c:215
#: ../raster/r.mfilter/main.c:59 ../raster/r.neighbors/main.c:173
-#, fuzzy
msgid "filter"
-msgstr "Filtro"
+msgstr "filtro"
#: ../vector/v.outlier/main.c:74
-#, fuzzy
msgid "Removes outliers from vector point data."
-msgstr "Elimina outliers de vectorial datos"
+msgstr "Elimina discrepantes (outliers) desde datos vectoriales de puntos."
#: ../vector/v.outlier/main.c:92
msgid "Name of output outlier vector map"
-msgstr ""
+msgstr "Nombre de mapa vectorial de discrepantes (outliers) de salida"
#: ../vector/v.outlier/main.c:100
msgid "Name of vector map for visualization in QGIS"
@@ -12330,9 +11155,8 @@
msgstr "Fue imposible crear <%s> tabla."
#: ../vector/v.outlier/main.c:355
-msgid ""
-"No subregions found! Check values for 'ew_step' and 'ns_step' parameters"
-msgstr ""
+msgid "No subregions found! Check values for 'ew_step' and 'ns_step' parameters"
+msgstr "¡no se encontraron subregiones! Por favor revise valores para parámetros 'ew_step' y 'ns_step'"
#: ../vector/v.outlier/main.c:428
msgid "Outlier detection"
@@ -12368,14 +11192,12 @@
#: ../locale/scriptstrings/r.import_to_translate.c:4
#: ../general/g.proj/main.c:65 ../general/g.setproj/main.c:79
#: ../raster/r.proj/main.c:145 ../raster/r.latlong/main.c:59
-#, fuzzy
msgid "projection"
-msgstr "Proyeccion del origen"
+msgstr "proyección"
#: ../vector/v.proj/main.c:71
msgid "Re-projects a vector map from one location to the current location."
-msgstr ""
-"Reproyecta un mapa vectorial desde una localización a la localización actual."
+msgstr "Reproyecta un mapa vectorial desde una localización a la localización actual."
#: ../vector/v.proj/main.c:77
msgid "Location containing input vector map"
@@ -12397,22 +11219,20 @@
msgstr "Predeterminado: nombre del directorio de mapas actual"
#: ../vector/v.proj/main.c:87
-#, fuzzy
msgid "Name of input vector map to re-project"
+msgstr "Nombre de mapa vectorial de entrada a reproyectar"
#: ../vector/v.proj/main.c:92 ../raster/r.proj/main.c:167
msgid "Path to GRASS database of input location"
msgstr "Ruta a la base de datos de GRASS de la localización de entrada"
#: ../vector/v.proj/main.c:99
-#, fuzzy
msgid "Maximum segment length in meters in output vector map"
-msgstr "Conjunto de mapas que contiene el mapa vectorial de entrada"
+msgstr "Distancia en metros de máxima de segmentos en mapa vectorial de salida"
#: ../vector/v.proj/main.c:100
msgid "Increases accuracy of reprojected shapes, disable with smax=0"
-msgstr ""
+msgstr "Aumentar precisión de formas reproyectadas, desactivar con smax=0"
#: ../vector/v.proj/main.c:101 ../vector/v.proj/main.c:106
#: ../vector/v.proj/main.c:118 ../vector/v.proj/main.c:125
@@ -12435,14 +11255,12 @@
msgstr "Sólo mapas vectoriales 3D"
#: ../vector/v.proj/main.c:116
-#, fuzzy
msgid "Assume z coordinate is ellipsoidal height and transform if possible"
-msgstr ""
-"Asumir que la coordenada Z es altura elipsoidal y transformara si es posible"
+msgstr "Asumir coordenada z como altura elipsoidal y transformar si es posible"
#: ../vector/v.proj/main.c:122
msgid "Latlon output only, default is -180,180"
-msgstr ""
+msgstr "Solamente salida LatitudLongitud, predeterminada es -180,180"
#: ../vector/v.proj/main.c:124
msgid "Disable wrapping to -180,180 for latlon output"
@@ -12454,7 +11272,7 @@
#: ../imagery/i.gensig/parse.c:50
#, c-format
msgid "option <%s>: <%s> exists. To overwrite, use the --overwrite flag"
-msgstr ""
+msgstr "opción <%s>: <%s> existe. Para sobreescribir, use la bandera --overwrite"
#: ../vector/v.proj/main.c:159 ../raster/r.proj/main.c:252
msgid "Input and output locations can not be the same"
@@ -12466,29 +11284,23 @@
msgstr "Comprobando localización <%s> directorio de mapas <%s>"
#: ../vector/v.proj/main.c:194
-#, fuzzy
msgid "No vector maps found"
-msgstr "No se encontraron mapas raster"
+msgstr "No se encontraron mapas vectoriales"
#: ../vector/v.proj/main.c:207
#, c-format
msgid "Vector map <%s> in location <%s> mapset <%s> not found"
-msgstr ""
-"No se encuentra el mapa vectorial <%s> en la localización <%s> en el "
-"directorio de mapas <%s>"
+msgstr "No se encuentra el mapa vectorial <%s> en la localización <%s> en el directorio de mapas <%s>"
#: ../vector/v.proj/main.c:237
#, c-format
msgid "Mapset <%s> in input location <%s> - permission denied"
-msgstr ""
-"Directorio de mapas <%s> en la localización de entrada <%s> - permiso "
-"denegado"
+msgstr "Directorio de mapas <%s> en la localización de entrada <%s> - permiso denegado"
#: ../vector/v.proj/main.c:240
#, c-format
msgid "Mapset <%s> in input location <%s> not found"
-msgstr ""
-"Directorio de mapas <%s> en la localización de entrada <%s> no encontrado"
+msgstr "Directorio de mapas <%s> en la localización de entrada <%s> no encontrado"
#: ../vector/v.proj/main.c:285 ../vector/v.proj/main.c:411
#: ../vector/v.rectify/main.c:233
@@ -12496,9 +11308,9 @@
msgstr "Leyendo mapa vectorial de entrada"
#: ../vector/v.proj/main.c:308
-#, fuzzy, c-format
+#, c-format
msgid "Input vector map <%s> is empty"
-msgstr "El mapa vectorial de entrada <%s> no és 3D!"
+msgstr "Mapa vectorial de entrada <%s> está vacío"
#: ../vector/v.proj/main.c:316 ../vector/v.proj/main.c:327
#: ../vector/v.proj/main.c:342 ../vector/v.proj/main.c:357
@@ -12506,15 +11318,14 @@
msgstr "Error en pj_do_transform"
#: ../vector/v.proj/main.c:402
-#, fuzzy
msgid "Reprojecting primitives ..."
-msgstr "Reproyectado la tabla de los GCP:"
+msgstr "Reproyectado primitivas..."
#: ../vector/v.proj/main.c:439 ../vector/v.proj/main.c:446
#: ../vector/v.proj/main.c:472 ../vector/v.proj/main.c:486
-#, fuzzy, c-format
+#, c-format
msgid "Unable to re-project vector map <%s> from <%s>"
-msgstr "No se puede abrir el mapa vectorial <%s@%s>"
+msgstr "No ha sido posible reproyectar mapa vectorial <%s> desde <%s>"
#: ../vector/v.proj/main.c:505
msgid "Try to disable wrapping to -180,180 if topological errors occurred"
@@ -12558,15 +11369,11 @@
#: ../vector/v.support/main.c:110
msgid "Text to append to the comment line of the map's metadata file"
-msgstr ""
-"Texto a añadir a la línea de comentario del archivo de metadatos del mapa"
+msgstr "Texto a añadir a la línea de comentario del archivo de metadatos del mapa"
#: ../vector/v.support/main.c:118
-msgid ""
-"Command line to store into vector map history file (used for vector scripts)"
-msgstr ""
-"Línea de comandos a guardar en el archivo histórico de mapa vectorial (usado "
-"para scripts vectoriales)"
+msgid "Command line to store into vector map history file (used for vector scripts)"
+msgstr "Línea de comandos a guardar en el archivo histórico de mapa vectorial (usado para scripts vectoriales)"
#: ../vector/v.support/main.c:122
msgid "Replace comment instead of appending it"
@@ -12578,9 +11385,8 @@
msgstr "No se puede abrir el archivo histórico del vectorial <%s>"
#: ../vector/v.what/main.c:63
-#, fuzzy
msgid "Queries a vector map at given locations."
-msgstr "Consulta una capa de mapa vectorial en las localizaciones dadas."
+msgstr "Consulta un mapa vectorial en ubicaciones dadas."
#: ../vector/v.what/main.c:75 ../raster/r.what/main.c:109
msgid "Coordinates for query"
@@ -12591,9 +11397,8 @@
msgstr "Consultar distancia umbral"
#: ../vector/v.what/main.c:84
-#, fuzzy
msgid "Threshold"
-msgstr "Herramienta: umbral"
+msgstr "Umbral"
#: ../vector/v.what/main.c:88
msgid "Print topological information (debugging)"
@@ -12609,26 +11414,21 @@
msgstr "Imprimir las estadísticas en estilo de script de consola"
#: ../vector/v.what/main.c:103
-#, fuzzy
msgid "Print the stats in JSON"
-msgstr "Imprimir las estadísticas en estilo de script de consola"
+msgstr "Mostrar estadísticas en JSON"
#: ../vector/v.what/main.c:118
-#, fuzzy
msgid "No input vector maps!"
-msgstr "Nombre del mapa vectorial de entrada (A)"
+msgstr "¡No hay mapas vectoriales de entrada!"
#: ../vector/v.what/main.c:121
-#, fuzzy
msgid "Flags g and j are mutually exclusive"
-msgstr "weight= y -c son excluyentes mutuamente"
+msgstr "Banderas g y j son mutuamente excluyentes"
#: ../vector/v.what/main.c:166
-#, fuzzy, c-format
+#, c-format
msgid "Number of given vector maps (%d) differs from number of layers (%d)"
-msgstr ""
-"El número de columnas definidas (%d) no concuerda con el número de columnas "
-"(%d) en la entrada"
+msgstr "Número (%d) de mapas vectoriales dados difiere del número de capas (%d)"
#: ../vector/v.what/main.c:175
#, c-format
@@ -12641,19 +11441,16 @@
msgstr "Formato de entrada desconocido, se salta: '%s'"
#: ../vector/v.what/what.c:44
-#, fuzzy
msgid "Cannot open driver"
-msgstr "No se puede abrir el archivo <%s>"
+msgstr "No se puede abrir controlador"
#: ../vector/v.what/what.c:52
-#, fuzzy
msgid "Cannot open database"
-msgstr "Imposible copiar la tabla"
+msgstr "No se abrir base de datos"
#: ../vector/v.what/what.c:65
-#, fuzzy
msgid "Cannot open select cursor"
-msgstr "No se puede abrir el cursor de selección: '%s'"
+msgstr "No puede seleccionar cursor"
#: ../vector/v.what/what.c:72
#, fuzzy
@@ -12661,12 +11458,11 @@
msgstr "No se puede recuperar la fila"
#: ../vector/v.what/what.c:75
-#, fuzzy
msgid "No database record"
+msgstr "No hay registro en base de datos"
#: ../vector/v.what/what.c:227
-#, fuzzy, c-format
+#, c-format
msgid "Nothing found.\n"
msgstr "No se ha encontrado nada.\n"
@@ -12700,16 +11496,17 @@
"Coordenadas: %.6f, %.6f, %.6f\n"
#: ../vector/v.what/what.c:322
-#, fuzzy, c-format
+#, c-format
msgid ""
",\n"
"\"Node[%d]\": %d,\n"
"\"Number_lines\": %d,\n"
"\"Coordinates\": %.6f,%.6f,%.6f"
msgstr ""
-"Nodo[%d]: %d\n"
-"Número de líneas: %d\n"
-"Coordenadas: %.6f, %.6f, %.6f\n"
+",\n"
+"\"Nodo[%d]\": %d,\n"
+"\"Number_lines\": %d,\n"
+"\"Coordenadas\": %.6f,%.6f,%.6f"
#: ../vector/v.what/what.c:327
#, c-format
@@ -12732,9 +11529,9 @@
"Ángulo: %.8f\n"
#: ../vector/v.what/what.c:365
-#, fuzzy, c-format
+#, c-format
msgid "Type: %s\n"
-msgstr "Tipo: %s"
+msgstr "Tipo: %s\n"
#: ../vector/v.what/what.c:366
#, c-format
@@ -12752,7 +11549,7 @@
msgstr "Altura de la línea: %f\n"
#: ../vector/v.what/what.c:421
-#, fuzzy, c-format
+#, c-format
msgid ""
"Line height min: %f\n"
"Line height max: %f\n"
@@ -12794,7 +11591,7 @@
msgstr "Isla: %d en área: %d\n"
#: ../vector/v.what/what.c:524
-#, fuzzy, c-format
+#, c-format
msgid ""
"Sq Meters: %.3f\n"
"Hectares: %.3f\n"
@@ -12803,12 +11600,12 @@
"Hectáreas: %.3f\n"
#: ../vector/v.what/what.c:526
-#, fuzzy, c-format
+#, c-format
msgid ""
"Acres: %.3f\n"
"Sq Miles: %.4f\n"
msgstr ""
-"Acres: %.3f\n"
+"Acros: %.3f\n"
"Millas cuadradas: %.4f\n"
#: ../vector/v.what/what.c:556
@@ -12836,19 +11633,12 @@
"Columna de clave: %s\n"
#: ../vector/v.patch/main.c:71
-#, fuzzy
msgid "Creates a new vector map by combining other vector maps."
-msgstr ""
-"Crear una capa de mapa vectorial nueva combinando otras capas de mapas "
-"vectoriales."
+msgstr "Crear un nuevo mapa vectorial combinando otros mapas vectoriales."
#: ../vector/v.patch/main.c:82
-msgid ""
-"Name for output vector map where bounding boxes of input vector maps are "
-"written to"
-msgstr ""
-"Nombre para el mapa vectorial de salida en el que se escriben los recuadros "
-"de límites de los mapas vectoriales de entrada"
+msgid "Name for output vector map where bounding boxes of input vector maps are written to"
+msgstr "Nombre para el mapa vectorial de salida en el que se escriben los recuadros de límites de los mapas vectoriales de entrada"
#: ../vector/v.patch/main.c:86
#, fuzzy
@@ -12876,11 +11666,8 @@
msgstr "Actualmente sólo está soportada la tabla de la capa 1"
#: ../vector/v.patch/main.c:104
-msgid ""
-"Append files to existing file (overwriting existing files must be activated)"
-msgstr ""
-"Añadir archivos al existente (debe estar activada la sobrescritura de "
-"archivos existentes)"
+msgid "Append files to existing file (overwriting existing files must be activated)"
+msgstr "Añadir archivos al existente (debe estar activada la sobrescritura de archivos existentes)"
#: ../vector/v.patch/main.c:214
msgid "Missing table"
@@ -12920,15 +11707,14 @@
msgstr "No se puede crear la tabla <%s>"
#: ../vector/v.patch/main.c:347
-#, fuzzy, c-format
+#, c-format
msgid "Patching vector map <%s>..."
-msgstr "Parcheando el mapa vectorial <%s@%s>..."
+msgstr "Parchando mapa vectorial <%s>..."
#: ../vector/v.patch/main.c:371
#, c-format
msgid "Error reading vector map <%s> - some data may not be correct"
-msgstr ""
-"Error al leer el mapa vectorial <%s> - algunos datos pueden no ser correctos"
+msgstr "Error al leer el mapa vectorial <%s> - algunos datos pueden no ser correctos"
#: ../vector/v.patch/main.c:424
#, c-format
@@ -12937,7 +11723,7 @@
#: ../vector/v.patch/main.c:430
msgid "Intersections at borders will have to be snapped"
-msgstr "Las intersecciones en los bordes tendrán que autoensamblarse"
+msgstr "Las intersecciones en los bordes tendrán que ensamblarse"
#: ../vector/v.patch/main.c:431
msgid "Lines common between files will have to be edited"
@@ -12978,26 +11764,22 @@
#: ../vector/v.in.lidar/main.c:48
#, c-format
-msgid ""
-"Values of %s and %s are the same. All categories would be stored only in "
-"layer number <%d>"
+msgid "Values of %s and %s are the same. All categories would be stored only in layer number <%d>"
msgstr ""
#: ../vector/v.in.lidar/main.c:138
-#, fuzzy
msgid "Converts LAS LiDAR point clouds to a GRASS vector map with libLAS."
-msgstr "Convertir capas vectoriales OGR a mapas vectoriales de GRASS."
+msgstr "Convierte nubes de puntos LAS LiDAR a un mapa vectorial GRASS con libLAS."
#: ../vector/v.in.lidar/main.c:141 ../raster3d/r3.in.lidar/main.c:137
#: ../raster/r.in.lidar/main.c:118
-#, fuzzy
msgid "LAS input file"
-msgstr "Archivo DXF de entrada"
+msgstr "Archivo de entrada LAS"
#: ../vector/v.in.lidar/main.c:142 ../raster/r.in.lidar/main.c:119
#: ../raster/r.in.lidar/main.c:129
msgid "LiDAR input files in LAS format (*.las or *.laz)"
-msgstr ""
+msgstr "Archivos de entrada LiDAR en formato LAS (*.las o *.laz)"
#: ../vector/v.in.lidar/main.c:149
msgid "Set to 1 by default, use -c to not store it"
@@ -13034,25 +11816,22 @@
#: ../vector/v.in.lidar/main.c:200 ../raster3d/r3.in.lidar/main.c:185
#: ../raster/r.in.lidar/main.c:260
msgid "Only import points of selected return type"
-msgstr ""
+msgstr "Solamente importa puntos de tipo de retorno seleccionado"
#: ../vector/v.in.lidar/main.c:201 ../raster3d/r3.in.lidar/main.c:186
#: ../raster/r.in.lidar/main.c:261
-#, fuzzy
msgid "If not specified, all points are imported"
-msgstr "Se importan los valores enteros"
+msgstr "Si se especifica, se importan los valores enteros"
#: ../vector/v.in.lidar/main.c:210 ../raster3d/r3.in.lidar/main.c:195
#: ../raster/r.in.lidar/main.c:270
msgid "Only import points of selected class(es)"
-msgstr ""
+msgstr "Solamente importa puntos de clase(s) seleccionada(s)"
#: ../vector/v.in.lidar/main.c:211 ../raster3d/r3.in.lidar/main.c:196
#: ../raster/r.in.lidar/main.c:271
-#, fuzzy
-msgid ""
-"Input is comma separated integers. If not specified, all points are imported."
+msgid "Input is comma separated integers. If not specified, all points are imported."
+msgstr "En entrada los enteros están separados con comas. Si no se especifica, se importarán todos los puntos."
#: ../vector/v.in.lidar/main.c:218
msgid "Areas where to import points"
@@ -13074,9 +11853,7 @@
#: ../vector/v.in.lidar/main.c:233
#, fuzzy
-msgid ""
-"For example, 5 will import 80 percent of points. If not specified, all "
-"points are imported"
+msgid "For example, 5 will import 80 percent of points. If not specified, all points are imported"
#: ../vector/v.in.lidar/main.c:235 ../vector/v.in.lidar/main.c:245
@@ -13091,9 +11868,7 @@
#: ../vector/v.in.lidar/main.c:243
#, fuzzy
-msgid ""
-"For example, 4 will import 25 percent of points. If not specified, all "
+msgid "For example, 4 will import 25 percent of points. If not specified, all points are imported"
#: ../vector/v.in.lidar/main.c:252 ../vector/v.decimate/main.c:181
@@ -13120,9 +11895,8 @@
msgstr "Nombre de la nueva localización a crear"
#: ../vector/v.in.lidar/main.c:275 ../raster/r.in.lidar/main.c:278
-#, fuzzy
msgid "Print LAS file info and exit"
-msgstr "Imprimir histórico del ráster en vez de información"
+msgstr "Mostrar archivo de información LAS y salir"
#: ../vector/v.in.lidar/main.c:281 ../vector/v.in.ogr/main.c:298
msgid "Limit import to the current region"
@@ -13135,10 +11909,8 @@
#: ../vector/v.in.lidar/main.c:291 ../vector/v.in.ogr/main.c:303
#: ../raster/r.external/main.c:108 ../raster/r.in.gdal/main.c:191
-#, fuzzy
msgid "Extend region extents based on new dataset"
-msgstr ""
-"Ampliar la extensión de la localización en base a nuevo conjunto de datos"
+msgstr "Extender extensión de región basado en nuevo conjunto de datos"
#: ../vector/v.in.lidar/main.c:294 ../vector/v.in.lidar/main.c:302
#: ../vector/v.in.lidar/main.c:305 ../vector/v.decimate/main.c:241
@@ -13164,9 +11936,8 @@
#: ../locale/scriptstrings/t.rast.import_to_translate.c:17
#: ../raster/r.in.lidar/main.c:302 ../raster/r.external/main.c:102
#: ../raster/r.in.gdal/main.c:178
-#, fuzzy
msgid "Override projection check (use current location's projection)"
-msgstr "Ignorar proyección (usar proyección de la localización)"
+msgstr "Invalida verificación de la proyección (usar la proyección de la localización actual)"
#: ../vector/v.in.lidar/main.c:312
#: ../locale/scriptstrings/t.vect.import_to_translate.c:14
@@ -13175,26 +11946,22 @@
#: ../locale/scriptstrings/t.rast.import_to_translate.c:18
#: ../raster/r.in.lidar/main.c:304 ../raster/r.external/main.c:104
#: ../raster/r.in.gdal/main.c:180
-#, fuzzy
msgid "Assume that the dataset has same projection as the current location"
-msgstr ""
-"No se pueden obtener unidades de la proyección de la localización actual"
+msgstr "Asumir que el conjunto de datos tiene la misma proyección de la Localización actual"
#: ../vector/v.in.lidar/main.c:317 ../vector/v.in.ogr/main.c:316
-msgid ""
-"Create the location specified by the \"location\" parameter and exit. Do not "
-"import the vector data."
-msgstr ""
+msgid "Create the location specified by the \"location\" parameter and exit. Do not import the vector data."
+msgstr "Crear la Localización especificada por el parámetro \"location\" y salir. No importa datos vectoriales."
#: ../vector/v.in.lidar/main.c:338 ../raster/r.in.lidar/main.c:384
-#, fuzzy, c-format
+#, c-format
msgid "Input file <%s> does not exist"
+msgstr "Archivo de entrada <%s> no existe"
#: ../vector/v.in.lidar/main.c:345 ../raster/r.in.lidar/main.c:391
#, c-format
msgid "Input file <%s> is not a LAS LiDAR point cloud"
-msgstr ""
+msgstr "Archivo de entrada <%s> no es nube de puntos LAS LiDAR"
#: ../vector/v.in.lidar/main.c:399
#, c-format
@@ -13208,9 +11975,7 @@
#: ../vector/v.in.lidar/main.c:409
#, fuzzy, c-format
-msgid ""
-"Storing generated point IDs as categories in the layer <%d>, consequently no "
-"more than %d points can be imported"
+msgid "Storing generated point IDs as categories in the layer <%d>, consequently no more than %d points can be imported"
msgstr "Número de capa (desde)"
#: ../vector/v.in.lidar/main.c:434 ../vector/v.in.ogr/main.c:720
@@ -13223,18 +11988,14 @@
#: ../vector/v.in.lidar/main.c:491 ../vector/v.in.ogr/main.c:575
#: ../raster/r.in.gdal/main.c:430 ../raster/r.in.gdal/main.c:819
-msgid ""
-"Unable to convert input map projection to GRASS format; cannot create new "
-"location."
-msgstr ""
-"No se puede convertir la proyección del mapa de entrada a formato GRASS; no "
-"se puede crear la nueva localización."
+msgid "Unable to convert input map projection to GRASS format; cannot create new location."
+msgstr "No se puede convertir la proyección del mapa de entrada a formato GRASS; no se puede crear la nueva localización."
#: ../vector/v.in.lidar/main.c:497 ../vector/v.in.ogr/main.c:581
#: ../raster/r.in.gdal/main.c:436 ../raster/r.in.gdal/main.c:843
-#, fuzzy, c-format
+#, c-format
msgid "Unable to create new location <%s>"
-msgstr "No se puede crear la localización: %s"
+msgstr "No se puede crear nueva Localización <%s>"
#: ../vector/v.in.lidar/main.c:500 ../vector/v.in.ogr/main.c:584
#: ../general/g.proj/create.c:15 ../raster/r.in.gdal/main.c:439
@@ -13263,9 +12024,7 @@
msgstr "Explorando %d puntos..."
#: ../vector/v.in.lidar/main.c:718
-msgid ""
-"The underlying libLAS library is at its limits. Previously reported counts "
-"might have been distorted. However, the import itself should be unaffected."
+msgid "The underlying libLAS library is at its limits. Previously reported counts might have been distorted. However, the import itself should be unaffected."
msgstr ""
#: ../vector/v.in.lidar/main.c:724
@@ -13369,9 +12128,7 @@
msgstr "%d puntos fuera del umbral"
#: ../vector/v.in.lidar/main.c:774
-msgid ""
-"Accuracy of the printed point counts might be limited by your computer "
-"architecture."
+msgid "Accuracy of the printed point counts might be limited by your computer architecture."
msgstr ""
#: ../vector/v.in.lidar/main.c:777
@@ -13381,9 +12138,7 @@
#: ../vector/v.in.lidar/main.c:780
#, c-format
-msgid ""
-"Maximum number of categories reached (%d). Import ended prematurely. Try to "
-"import without using category as an ID."
+msgid "Maximum number of categories reached (%d). Import ended prematurely. Try to import without using category as an ID."
msgstr ""
#: ../vector/v.in.lidar/vector_mask.c:20
@@ -13397,11 +12152,8 @@
msgstr "No se puede abrir la base de datos <%s> por el controlador <%s>"
#: ../vector/v.external/main.c:55
-#, fuzzy
-msgid ""
-"Creates a new pseudo-vector map as a link to an OGR-supported layer or a "
-"PostGIS feature table."
-msgstr "Crea un nuevo vectorial como un enlace de sólo lectura a una capa OGR."
+msgid "Creates a new pseudo-vector map as a link to an OGR-supported layer or a PostGIS feature table."
+msgstr "Crea un nuevo mapa pseudo vectorial como un enlace a una capa soportada por OGR o una tabla de elementos PosGIS."
#: ../vector/v.external/main.c:122 ../vector/v.in.ogr/main.c:479
#, c-format
@@ -13409,9 +12161,9 @@
#: ../vector/v.external/main.c:147
-#, fuzzy, c-format
+#, c-format
msgid "Unable to delete '%s'"
-msgstr "No se puede borrar la línea %d"
+msgstr "No ha sido posible eliminar '%s'"
#: ../vector/v.external/main.c:154
#, c-format
@@ -13424,17 +12176,14 @@
msgstr "Liga al mapa vectorial <%s> creada."
#: ../vector/v.external/args.c:14
-#, fuzzy
msgid "Name of input OGR or PostGIS data source"
+msgstr "Nombre de fuente de datos OGR o PostGIS de entrada"
#: ../vector/v.external/args.c:27
-#, fuzzy
msgid "Name of OGR layer or PostGIS feature table to be linked"
-msgstr "Archivo raster a ser enlazado"
+msgstr "Nombre de capa OGR o tabla de elementos PostGIS que será enlazada"
#: ../vector/v.external/args.c:28
-#, fuzzy
msgid ""
"Examples:\n"
"\t\tESRI Shapefile: shapefile name\n"
@@ -13442,27 +12191,25 @@
"\t\tPostGIS database: table name"
msgstr ""
"Ejemplos:\n"
-"\t\tShapefile ESRI: nombre del shapefile\n"
-"\t\tArchivo MapInfo: nombre del archivo MapInfo"
+"\t\tShapefile de ESRI: nombre de archivo shape\n"
+"\t\tArchivo MapInfo: nombre de archivo mapinfo\n"
+"\t\tBase de datos PostGIS: nombre de tabla"
#: ../vector/v.external/args.c:38
-#, fuzzy
msgid "Name for output GRASS vector map (default: input layer)"
-msgstr "Nombre para el mapa vectorial de salida (por defecto: el de entrada)"
+msgstr "Nombre para el mapa vectorial GRASS de salida (predeterminado: el de entrada)"
#: ../vector/v.external/args.c:48
msgid "List available layers in data source and exit"
msgstr "Listar las capas disponibles en la fuente de datos y salir"
#: ../vector/v.external/args.c:54
-#, fuzzy
msgid "List available layers including feature type in data source and exit"
-msgstr "Listar las capas disponibles en la fuente de datos y salir"
+msgstr "Enlistar capas disponibles en la fuente de datos incluyendo tipo de elemento y salir"
#: ../vector/v.external/args.c:56
-#, fuzzy
msgid "Format: layer name,type,projection check,geometry"
-msgstr "Formato: capa tipo cuenta mínimo máximo"
+msgstr "Formato: nombre de capa,tipo,revisión de proyección,geometría"
#: ../vector/v.external/dsn.c:21 ../vector/v.in.ogr/dsn.c:21
msgid "Invalid connection string (dbname missing)"
@@ -13477,55 +12224,45 @@
msgstr "GRASS no está compilado con soporte OGR"
#: ../vector/v.external/list.c:158
-#, fuzzy
msgid "Connection to PostgreSQL database failed."
-msgstr "Conexión"
+msgstr "Falló la conexión a base de datos PostgreSQL."
#: ../vector/v.external/list.c:168
-#, fuzzy
msgid "No feature tables found in database."
-msgstr "Lista todas las tablas para una base de datos dada."
+msgstr "No se encontró ninguna tabla de elementos en la base de datos."
#: ../vector/v.external/list.c:179
#, c-format
msgid "PostGIS database <%s> contains %d feature table:"
msgid_plural "PostGIS database <%s> contains %d feature tables:"
-msgstr[0] ""
-msgstr[1] ""
+msgstr[0] "Base de datos PostGIS <%s> contiene tabla de elementos %d:"
+msgstr[1] "Base de datos PostGIS <%s> contiene %d tabla de elementos:"
#: ../vector/v.external/list.c:260
-#, fuzzy, c-format
+#, c-format
msgid "Unable to open data source '%s'"
-msgstr "No se puede abrir el origen de datos <%s>"
+msgstr "No ha sido posible abrir origen de datos '%s'"
#: ../vector/v.external/list.c:267
-#, fuzzy, c-format
+#, c-format
msgid "Data source <%s> (format '%s') contains %d layer:"
msgid_plural "Data source <%s> (format '%s') contains %d layers:"
-msgstr[0] "El origen de datos contiene %d capas:"
-msgstr[1] "El origen de datos contiene %d capas:"
+msgstr[0] "Origen de datos <%s> (formato '%s') contiene %d capa:"
+msgstr[1] "Origen de datos <%s> (formato '%s') contiene %d capas:"
#: ../vector/v.external/list.c:300
-#, fuzzy, c-format
-msgid ""
-"Unable to convert input map projection to GRASS format. Projection check "
-"cannot be provided for OGR layer <%s>"
-msgstr ""
+#, c-format
+msgid "Unable to convert input map projection to GRASS format. Projection check cannot be provided for OGR layer <%s>"
+msgstr "No ha sido posible convertir proyección de mapa de entrada a formato GRASS. Revisión de proyección no puede proveer capa OGR <%s>"
#: ../vector/v.external/list.c:316
-#, fuzzy, c-format
+#, c-format
msgid "Invalid geometry column %d"
-msgstr "Orden no válida"
+msgstr "Columna de geometría no válida %d"
#: ../vector/v.delaunay/main.c:88
-msgid ""
-"Creates a Delaunay triangulation from an input vector map containing points "
-"or centroids."
-msgstr ""
-"Crea una triangulación de Delaunay a partir de un mapa vectorial de entrada "
-"que contiene puntos o centroides."
+msgid "Creates a Delaunay triangulation from an input vector map containing points or centroids."
+msgstr "Crea una triangulación de Delaunay a partir de un mapa vectorial de entrada que contiene puntos o centroides."
#: ../vector/v.delaunay/main.c:98 ../vector/v.normal/main.c:96
msgid "Use only points in current region"
@@ -13544,9 +12281,8 @@
msgstr "Triangulación Delaunay..."
#: ../vector/v.delaunay/main.c:162
-#, fuzzy
msgid "Calculating area centroids..."
-msgstr "Creando centroides..."
+msgstr "Calculando centroides de área..."
#: ../vector/v.delaunay/main.c:178
msgid "Unable to calculate area centroid z coordinate"
@@ -13564,61 +12300,55 @@
msgstr "Se han utilizado todos los bordes asignados."
#: ../vector/v.delaunay/in_out.c:214
-#, fuzzy
msgid "Reading point features..."
-msgstr "Leyendo datos..."
+msgstr "Leyendo elementos puntuales..."
#: ../vector/v.buffer/geos.c:19
-#, fuzzy
msgid "Invalid GEOS geometry!"
+msgstr "¡Geometría GEOS no válida!"
#: ../vector/v.buffer/geos.c:25
msgid "No coordinates in GEOS geometry (can be ok for negative distance)!"
-msgstr ""
+msgstr "¡No hay coordenadas en geometría GEOS (puede ser correcto para distancia negativa)!"
#: ../vector/v.buffer/geos.c:33
-#, fuzzy, c-format
+#, c-format
msgid "Invalid x coordinate %f"
-msgstr "Coordenadas inválidas"
+msgstr "Coordenadas x no válida %f"
#: ../vector/v.buffer/geos.c:35
-#, fuzzy, c-format
+#, c-format
msgid "Invalid y coordinate %f"
+msgstr "Coordenadas y no válida %f"
#: ../vector/v.buffer/geos.c:107
msgid "Corrupt GEOS geometry"
-msgstr ""
+msgstr "Geometría GEOS corrupta"
#: ../vector/v.buffer/geos.c:135
-#, fuzzy
msgid "Unknown GEOS geometry type"
-msgstr "Tipo de geometría desconocido"
+msgstr "Tipo de geometría GEOS desconocido"
#: ../vector/v.buffer/geos.c:178
-#, fuzzy, c-format
+#, c-format
msgid "Buffering failed (feature %d)"
-msgstr "Archivo de lectura"
+msgstr "Ha fallado bufffer (elemento %d)"
#: ../vector/v.buffer/main.c:224 ../raster/r.circle/main.c:54
msgid "circle"
-msgstr ""
+msgstr "círculo"
#: ../vector/v.buffer/main.c:227
msgid "grow"
-msgstr ""
+msgstr "incremento"
#: ../vector/v.buffer/main.c:228
msgid "shrink"
-msgstr ""
+msgstr "encoger"
#: ../vector/v.buffer/main.c:230
-#, fuzzy
msgid "Creates a buffer around vector features of given type."
-msgstr ""
-"Crear un buffer alrededor de los elementos de tipo dado (las áreas deben "
-"contener centroide)."
+msgstr "Crear un buffer alrededor de los elementos vectoriales de un tipo dado."
#: ../vector/v.buffer/main.c:255
msgid "Buffer distance along major axis in map units"
@@ -13643,40 +12373,28 @@
msgstr "Factor de escala para valores de columna de atributos"
#: ../vector/v.buffer/main.c:293
-msgid ""
-"Maximum distance between theoretical arc and polygon segments as multiple of "
-"buffer"
-msgstr ""
-"Distancia máxima entre arcos teóricos y segmentos de polígonos como múltiplo "
-"de buffer"
+msgid "Maximum distance between theoretical arc and polygon segments as multiple of buffer"
+msgstr "Distancia máxima entre arcos teóricos y segmentos de polígonos como múltiplo de buffer"
#: ../vector/v.buffer/main.c:298
msgid "Make outside corners straight"
msgstr "Hacer las esquinas externas rectas"
#: ../vector/v.buffer/main.c:302
-#, fuzzy
msgid "Do not make caps at the ends of polylines"
-msgstr "No mostrar números de categoría"
+msgstr "No hacer remates al final de las polilíneas"
#: ../vector/v.buffer/main.c:306
-#, fuzzy
msgid "Transfer categories and attributes"
-msgstr "Imprime atributos de mapa vectorial."
+msgstr "Transferir categorías y atributos"
#: ../vector/v.buffer/main.c:326
-msgid ""
-"Note: In latitude-longitude coordinate system specify distances in degree "
-"unit"
-msgstr ""
-"Nota: en coordenadas latitud-longitud especifique distancias en unidades de "
-"grado"
+msgid "Note: In latitude-longitude coordinate system specify distances in degree unit"
+msgstr "Nota: en coordenadas latitud-longitud especifique distancias en unidades de grado"
#: ../vector/v.buffer/main.c:330
msgid "Select a buffer distance/minordistance/angle or column, but not both."
-msgstr ""
-"Selecciona una distancia al buffer/ menor distancia/ ángulo o columna pero "
-"no ambo."
+msgstr "Selecciona una distancia al buffer/ menor distancia/ ángulo o columna pero no ambo."
#: ../vector/v.buffer/main.c:359
msgid "The bufcol option requires a valid layer."
@@ -13706,21 +12424,17 @@
msgstr "No se pueden seleccionar datos de la tabla <%s>"
#: ../vector/v.buffer/main.c:464
-msgid ""
-"No features available for buffering. Check type option and features "
-"available in the input vector."
-msgstr ""
+msgid "No features available for buffering. Check type option and features available in the input vector."
+msgstr "No hay elementos disponible para hacer buffer. Revisar opción tipo y elementos disponibles en mapa vectorial de entrada."
#: ../vector/v.buffer/main.c:481
#, c-format
msgid "Flags -%c/%c ignored by this version, GEOS >= 3.3 is required"
-msgstr ""
+msgstr "Banderas -%c/%c ignoradas por esta versión, se requiere GEOS >= 3.3"
#: ../vector/v.buffer/main.c:486
-msgid ""
-"Negative distances for internal buffers are not supported and converted to "
-"positive values."
-msgstr ""
+msgid "Negative distances for internal buffers are not supported and converted to positive values."
+msgstr "Distancias negativas para buffers internos no están soportadas y se convertirán a valores positivos."
#: ../vector/v.buffer/main.c:496
msgid "Buffering areas..."
@@ -13754,7 +12468,7 @@
#: ../vector/v.buffer/main.c:735
msgid "Snapping boundaries..."
-msgstr "Autoensamblando contornos..."
+msgstr "Ensamblando contornos..."
#: ../vector/v.buffer/main.c:738 ../vector/v.in.ogr/main.c:1352
msgid "Breaking polygons..."
@@ -13790,9 +12504,8 @@
msgstr "No se puede calcular el centroide para el área %d"
#: ../vector/v.normal/main.c:76
-#, fuzzy
msgid "Tests for normality for vector points."
-msgstr "Test de normalidad para puntos."
+msgstr "Prueba de normalidad para puntos vectoriales."
#: ../vector/v.normal/main.c:88
msgid "Lists of tests (1-15)"
@@ -13807,34 +12520,31 @@
msgstr "Lognormalidad en vez de normalidad "
#: ../vector/v.normal/main.c:131
-#, fuzzy
msgid "Only numeric column type supported"
-msgstr "Tipo de columna no soportado"
+msgstr "Solamente está soportada columna de tipo numérico"
#: ../vector/v.normal/main.c:174 ../vector/v.normal/main.c:182
-#, fuzzy, c-format
+#, c-format
msgid "No record for cat %d"
-msgstr "No hay registro para la categoría [%d]"
+msgstr "No hay registro para categoría %d"
#: ../vector/v.normal/main.c:192
-#, fuzzy, c-format
+#, c-format
msgid "Number of points: %d"
-msgstr "Número de líneas"
+msgstr "Cantidad de puntos: %d"
#: ../vector/v.normal/main.c:195 ../vector/v.surf.idw/main.c:176
#: ../vector/v.neighbors/main.c:175
-#, fuzzy
msgid "No points found"
-msgstr "No se han encontrado puntos de datos"
+msgstr "No se encontraron puntos"
#: ../vector/v.normal/main.c:198
-#, fuzzy
msgid "Too small sample"
-msgstr "Herramienta: eliminar áreas pequeñas"
+msgstr "Muestra demasiado pequeña"
#: ../vector/v.normal/main.c:206
msgid "Negative or very small point values set to -10.0"
-msgstr ""
+msgstr "Negativo o muy pequeño valor puntual definido a -10.0"
#: ../vector/v.normal/main.c:223
#, c-format
@@ -13844,7 +12554,7 @@
#: ../vector/v.normal/main.c:228
#, c-format
msgid "Geary's a-statistic & an approx. normal: "
-msgstr ""
+msgstr "Estadístico-a de Geary & una aproximación normal: "
#: ../vector/v.normal/main.c:233
#, c-format
@@ -13854,7 +12564,7 @@
#: ../vector/v.normal/main.c:238
#, c-format
msgid "D'Agostino's D & an approx. normal: "
-msgstr ""
+msgstr "D de D'Agostino's & una aproximación normal: "
#: ../vector/v.normal/main.c:244
#, c-format
@@ -13889,8 +12599,7 @@
#: ../vector/v.normal/main.c:280
#, c-format
msgid "Chi-Square stat (equal probability classes) and d.f.: "
-msgstr ""
-"Estadísico Xi-cuadrada (para clases equiprobables) y grados de libertad: "
+msgstr "Estadísico Xi-cuadrada (para clases equiprobables) y grados de libertad: "
#: ../vector/v.normal/main.c:286
msgid "Shapiro-Wilk's W cannot be used for n > 50"
@@ -13916,7 +12625,7 @@
#: ../vector/v.normal/main.c:307
msgid "Royston only extended Shapiro-Wilk's W up to n = 2000"
-msgstr ""
+msgstr "Royston solamente extendió W de Shapiro-Wilk's W hasta n = 2000"
#: ../vector/v.normal/main.c:309
#, c-format
@@ -13926,34 +12635,27 @@
#: ../vector/v.normal/main.c:315
#, c-format
msgid "Kotz' T'_f (Lognormality vs. Normality): "
-msgstr ""
+msgstr "Kotz' T'_f (Lognormalidad vs. Normalidad): "
#: ../vector/v.db.connect/main.c:57
msgid "Prints/sets DB connection for a vector map to attribute table."
-msgstr ""
-"Imprime/establece la conexión a la base de datos para un mapa vectorial a la "
-"tabla de atributos."
+msgstr "Imprime/establece la conexión a la base de datos para un mapa vectorial a la tabla de atributos."
#: ../vector/v.db.connect/main.c:79
-#, fuzzy
msgid "Format: layer number[/layer name]"
-msgstr "Formato: capa[/nombre de capa] tabla clave base de datos controlador"
+msgstr "Formato: número de capa[/nombre de capa]"
#: ../vector/v.db.connect/main.c:83
-#, fuzzy
msgid "Field separator for shell script style output"
+msgstr "Separador de campos para salida estilo consola de comandos"
#: ../vector/v.db.connect/main.c:88
msgid "Print all map connection parameters and exit"
msgstr "Imprimir todos los parámetros de conexión del mapa y salir"
#: ../vector/v.db.connect/main.c:93
-#, fuzzy
msgid "Print all map connection parameters in shell script style and exit"
-msgstr ""
-"Imprimir todos los parámetros de conexión del mapa y salir en estilo de "
-"script de consola"
+msgstr "Mostrar todos los parámetros de conexión del mapa en estilo de script de consola y salir"
#: ../vector/v.db.connect/main.c:95
msgid "Format: layer[/layer name] table key database driver"
@@ -13961,9 +12663,7 @@
#: ../vector/v.db.connect/main.c:101
msgid "Print types/names of table columns for specified layer and exit"
-msgstr ""
-"Imprimir tipos/nombre de columnas de la tabla para capas especificadas y "
-"salir"
+msgstr "Imprimir tipos/nombre de columnas de la tabla para capas especificadas y salir"
#: ../vector/v.db.connect/main.c:108
msgid "Overwrite connection parameter for certain layer"
@@ -13978,14 +12678,14 @@
msgstr "Por favor, elija sólo un estilo de impresión"
#: ../vector/v.db.connect/main.c:166
-#, fuzzy, c-format
+#, c-format
msgid "Map <%s> is not connected to a database"
-msgstr "<%s> no ha sido creado en la base de datos."
+msgstr "Mapa <%s> no está conectado a base de datos"
#: ../vector/v.db.connect/main.c:175
-#, fuzzy, c-format
+#, c-format
msgid "Vector map <%s> is connected by:\n"
-msgstr "El mapa vectorial <%s> está conectado por:"
+msgstr "El mapa vectorial <%s> está conectado por:\n"
#: ../vector/v.db.connect/main.c:180 ../display/d.vect/opt.c:143
#: ../display/d.vect.thematic/main.c:205
@@ -13993,20 +12693,14 @@
msgstr "Conexión a la base de datos no definida"
#: ../vector/v.db.connect/main.c:197
-#, fuzzy, c-format
-msgid ""
-"layer <%d/%s> table <%s> in database <%s> through driver <%s> with key <%s>\n"
-msgstr ""
-"capa <%d> tabla <%s> en la base de datos <%s> a través del controlador <%s> "
-"con clave <%s>\n"
+#, c-format
+msgid "layer <%d/%s> table <%s> in database <%s> through driver <%s> with key <%s>\n"
+msgstr "capa <%d/%s> tabla <%s> en la base de datos <%s> a través del controlador <%s> con clave <%s>\n"
#: ../vector/v.db.connect/main.c:203
#, c-format
-msgid ""
-"layer <%d> table <%s> in database <%s> through driver <%s> with key <%s>\n"
-msgstr ""
-"con clave <%s>\n"
+msgid "layer <%d> table <%s> in database <%s> through driver <%s> with key <%s>\n"
+msgstr "capa <%d> tabla <%s> en la base de datos <%s> a través del controlador <%s> con clave <%s>\n"
#: ../vector/v.db.connect/main.c:266
#, c-format
@@ -14020,20 +12714,12 @@
#: ../vector/v.db.connect/main.c:302 ../vector/v.db.connect/main.c:320
#, c-format
-msgid ""
-"The table <%s> is now part of vector map <%s> and may be deleted or "
-"overwritten by GRASS modules"
-msgstr ""
-"La tabla <%s> ahora es parte del mapa vectorial <%s> y se puede borrar o "
-"sobrescribir por los módulos de GRASS"
+msgid "The table <%s> is now part of vector map <%s> and may be deleted or overwritten by GRASS modules"
+msgstr "La tabla <%s> ahora es parte del mapa vectorial <%s> y se puede borrar o sobrescribir por los módulos de GRASS"
#: ../vector/v.db.connect/main.c:351
-msgid ""
-"For defining a new connection you have to specify these parameters: driver, "
-"database, table [, key [, layer]]"
-msgstr ""
-"Para definir una nueva conexión tiene que especificar estos parámetros: "
-"controlador, base de datos, tabla [, clave [, capa]]"
+msgid "For defining a new connection you have to specify these parameters: driver, database, table [, key [, layer]]"
+msgstr "Para definir una nueva conexión tiene que especificar estos parámetros: controlador, base de datos, tabla [, clave [, capa]]"
#: ../vector/v.out.dxf/write_dxf.c:21
#, c-format
@@ -14055,14 +12741,12 @@
msgstr "DXF"
#: ../vector/v.out.dxf/main.c:60
-#, fuzzy
msgid "Exports vector map to DXF file format."
-msgstr "Exporta capas vectoriales de GRASS a formato de archivo DXF."
+msgstr "Exporta mapa vectorial a formato de archivo DXF."
#: ../vector/v.out.dxf/main.c:68
-#, fuzzy
msgid "Name for DXF output file"
+msgstr "Nombre para archivo DXF de salida"
#: ../vector/v.out.dxf/main.c:93
#, c-format
@@ -14071,23 +12755,16 @@
#: ../vector/v.net.alloc/main.c:59 ../raster/r.walk/main.c:181
#: ../raster/r.cost/main.c:143
-#, fuzzy
msgid "cost allocation"
-msgstr "Localización: %s\n"
+msgstr "asignación de costo"
#: ../vector/v.net.alloc/main.c:61
msgid "Allocates subnets for nearest centers (direction from center)."
-msgstr ""
-"Asigna subredes para los centros más próximos (dirección a partir del "
-"centro)."
+msgstr "Asigna subredes para los centros más próximos (dirección a partir del centro)."
#: ../vector/v.net.alloc/main.c:63
-msgid ""
-"center node must be opened (costs >= 0). Costs of center node are used in "
-"calculation"
-msgstr ""
-"nodo central debe estar abierto (costos >=0). Los costos del nodo central se "
-"usan en los cálculos."
+msgid "center node must be opened (costs >= 0). Costs of center node are used in calculation"
+msgstr "nodo central debe estar abierto (costos >=0). Los costos del nodo central se usan en los cálculos."
#: ../vector/v.net.alloc/main.c:76
msgid "Use costs from centers or costs to centers"
@@ -14113,21 +12790,15 @@
#: ../vector/v.surf.idw/main.c:90 ../raster/r.surf.idw/main.c:107
msgid "IDW"
-msgstr ""
+msgstr "IDW"
#: ../vector/v.surf.idw/main.c:92
-#, fuzzy
-msgid ""
-"Provides surface interpolation from vector point data by Inverse Distance "
-"Squared Weighting."
-msgstr ""
-"Interpolación de superficies a partir de datos de puntos vectoriales "
-"mediante Inverse Distance Squared Weighting."
+msgid "Provides surface interpolation from vector point data by Inverse Distance Squared Weighting."
+msgstr "Provee interpolación de superficie a partir de datos de puntos vectoriales mediante la Ponderación del cuadrado del inverso de la distancia."
#: ../vector/v.surf.idw/main.c:101
-#, fuzzy
msgid "Name of attribute column with values to interpolate"
-msgstr "Columna de la tabla de atributos con valores a interpolar"
+msgstr "Nombre de columna de atributo con valores a interpolar"
#: ../vector/v.surf.idw/main.c:104
msgid "Values"
@@ -14138,33 +12809,25 @@
msgstr "Número de puntos de interpolación"
#: ../vector/v.surf.idw/main.c:121
-#, fuzzy
msgid "Power parameter"
-msgstr "Parámetros"
+msgstr "Parámetros potencia"
#: ../vector/v.surf.idw/main.c:123
-#, fuzzy
msgid "Greater values assign greater influence to closer points"
-msgstr ""
-"Parámetro power; los valores más altos asignan una mayor influencia a los "
-"puntos más próximos"
+msgstr "Valores más altos asignan una mayor influencia a los puntos más próximos"
#: ../vector/v.surf.idw/main.c:128
msgid "Don't index points by raster cell"
msgstr "No indexar puntos por celda ráster"
#: ../vector/v.surf.idw/main.c:129
-msgid ""
-"Slower but uses less memory and includes points from outside region in the "
-"interpolation"
-msgstr ""
-"Más lento pero usa menos memoria e incluye puntos de la región exterior en "
-"la interpolación"
+msgid "Slower but uses less memory and includes points from outside region in the interpolation"
+msgstr "Más lento pero usa menos memoria e incluye puntos de la región exterior en la interpolación"
#: ../vector/v.surf.idw/main.c:139
-#, fuzzy, c-format
+#, c-format
msgid "Illegal number (%s) of interpolation points"
-msgstr "%s=%s - número de puntos de interpolación no admitido"
+msgstr "Número (%s) de puntos a interpolar no admitido"
#. GTC Count of window rows
#. GTC Count of raster rows
@@ -14184,49 +12847,45 @@
#: ../vector/v.surf.idw/main.c:261 ../vector/v.kernel/main.c:304
#: ../raster/r.thin/io.c:107 ../raster/r.thin/io.c:174
#: ../raster/r.thin/io.c:183
-#, fuzzy, c-format
+#, c-format
msgid "%d column"
msgid_plural "%d columns"
-msgstr[0] "Columnas"
-msgstr[1] "Columnas"
+msgstr[0] "%d columna"
+msgstr[1] "%d columnas"
#. GTC First argument is map name, second - message about number of rows, third - columns.
#: ../vector/v.surf.idw/main.c:263
-#, fuzzy, c-format
+#, c-format
msgid "Interpolating raster map <%s> (%s, %s)..."
-msgstr "Interpolando mapa ráster <%s>... %d filas... "
+msgstr "Interpolando mapa ráster <%s> (%s, %s)..."
#: ../vector/v.surf.idw/read_sites.c:37
-#, fuzzy, c-format
+#, c-format
msgid "Input vector map <%s> is 2D - using categories to interpolate"
-msgstr "No se creará ningún dato vectorial."
+msgstr "Mapa vectorial de entrada <%s> es 2D - usando categorías para interpolación"
#: ../vector/v.surf.idw/read_sites.c:40
-#, fuzzy, c-format
+#, c-format
msgid "Input vector map <%s> is 3D - using z-coordinates to interpolate"
+msgstr "Mapa vectorial de entrada <%s> es 3D - usando coordenada z para interpolación"
#: ../vector/v.surf.idw/read_sites.c:70
-#, fuzzy, c-format
+#, c-format
msgid "One record selected from table"
msgid_plural "%d records selected from table"
-msgstr[0] "%d registros seleccionados de la tabla"
+msgstr[0] "Un registro seleccionado de la tabla"
msgstr[1] "%d registros seleccionados de la tabla"
#: ../vector/v.surf.idw/read_sites.c:123
-#, fuzzy, c-format
+#, c-format
msgid "%ld point loaded"
msgid_plural "%ld points loaded"
-msgstr[0] "%d puntos cargados"
-msgstr[1] "%d puntos cargados"
+msgstr[0] "%ld punto cargado"
+msgstr[1] "%ld puntos cargados"
#: ../vector/v.transform/main.c:74
-#, fuzzy
-msgid ""
-"Performs an affine transformation (shift, scale and rotate) on vector map."
-msgstr ""
-"Realiza una transformación afín (shift, escalado o rotación o GPCs) sobre un "
-"mapa vectorial."
+msgid "Performs an affine transformation (shift, scale and rotate) on vector map."
+msgstr "Realiza una transformación afín (desplazamiento, escalado y rotación) sobre mapa vectorial."
#: ../vector/v.transform/main.c:79
msgid "Shift all z values to bottom=0"
@@ -14234,10 +12893,9 @@
#: ../vector/v.transform/main.c:84
msgid "Swap coordinates x, y and then apply other parameters"
-msgstr ""
+msgstr "Intercambiar coordenadas x,y y luego aplicar otros parámetros"
#: ../vector/v.transform/main.c:88
-#, fuzzy
msgid "Do not build topology"
msgstr "No construir topología"
@@ -14274,41 +12932,36 @@
msgstr "Factor de escala para coordenadas Z"
#: ../vector/v.transform/main.c:157
-#, fuzzy
msgid "Rotation around z axis in degrees (counter-clockwise)"
-msgstr "Rotación alrededor del eje Z en grados en sentido horario"
+msgstr "Rotación alrededor del eje Z en grados (en contra de las manecillas del reloj)"
#: ../vector/v.transform/main.c:163
msgid "Name of attribute column(s) used as transformation parameters"
-msgstr ""
-"Nombre de la columna(s) de atributos usada como parámetros de transformación"
+msgstr "Nombre de la columna(s) de atributos usada como parámetros de transformación"
#: ../vector/v.transform/main.c:165
msgid "Format: parameter:column, e.g. xshift:xs,yshift:ys,zrot:zr"
msgstr "Formato: parámetro:columna, ej. xshift:xs,yshift:ys,zrot:zr"
#: ../vector/v.transform/main.c:182
-#, fuzzy, c-format
+#, c-format
msgid "Columns require a valid layer. Please use '%s' parameter."
-msgstr ""
-"El nombre de la tabla no está definido. Por favor use el parámetro '%s'."
+msgstr "Columna require nombre de capa válido. Por favor use el parámetro '%s'"
#: ../vector/v.transform/main.c:212
-#, fuzzy, c-format
+#, c-format
msgid "Unknown column parameter '%s'"
-msgstr "Operador desconocido"
+msgstr "Parámetro de columna '%s' desconocido"
#: ../vector/v.transform/main.c:223
-#, fuzzy, c-format
+#, c-format
msgid "Unable to tokenize column string: [%s]"
-msgstr "a"
+msgstr ""
#: ../vector/v.transform/main.c:290
-#, fuzzy, c-format
+#, c-format
msgid "New vector map <%s> boundary coordinates:"
-msgstr ""
-"\n"
-"Coordenadas del contorno del nuevo mapa vectorial <%s>:"
+msgstr "Coordenadas de contorno de nuevo mapa vectorial <%s>::"
#: ../vector/v.transform/main.c:292
#, c-format
@@ -14332,54 +12985,39 @@
#: ../vector/v.transform/trans_digit.c:112
#, c-format
-msgid ""
-"Unable to select value for category %d from table <%s>, column <%s>. For "
-"category %d using default transformation parameter %.3f."
-msgstr ""
-"No se puede seleccionar el valor para la categoría %d de la tabla <%s>, "
-"columna <%s>. Para la categoría %d usando el parámetro de transformación "
-"predeterminado %.3f."
+msgid "Unable to select value for category %d from table <%s>, column <%s>. For category %d using default transformation parameter %.3f."
+msgstr "No se puede seleccionar el valor para la categoría %d de la tabla <%s>, columna <%s>. Para la categoría %d usando el parámetro de transformación predeterminado %.3f."
#: ../vector/v.transform/trans_digit.c:123
msgid "No category number defined. Using default transformation parameters."
-msgstr ""
-"Ningún número de categoría definido. Se usan los parámetros de "
-"transformación predeterminados."
+msgstr "Ningún número de categoría definido. Se usan los parámetros de transformación predeterminados."
#: ../vector/v.net.allpairs/main.c:65
msgid "Computes the shortest path between all pairs of nodes in the network."
msgstr "Calcula la ruta más corta entre todos los pares de nodos de la red"
#: ../vector/v.net.allpairs/main.c:208
-#, fuzzy
msgid "Writing node points..."
-msgstr "Importando puntos..."
+msgstr "Escribiendo puntos de nodos..."
#: ../vector/v.net.allpairs/main.c:242
-#, fuzzy
msgid "Collecting shortest paths..."
-msgstr "Recopilando estadísticas..."
+msgstr "Recopilando caminos más cortos..."
#: ../vector/v.net.allpairs/main.c:296
-#, fuzzy
msgid "Writing shortest paths..."
-msgstr "Escribiendo salida..."
+msgstr "Escribiendo caminos más cortos..."
#: ../vector/v.lrs/v.lrs.segment/main.c:72
#: ../vector/v.lrs/v.lrs.where/main.c:58
#: ../vector/v.lrs/v.lrs.create/main.c:122
#: ../vector/v.lrs/v.lrs.label/main.c:103
-#, fuzzy
msgid "linear reference system"
-msgstr "Crear Sistema de Referencia Lineal (LRS)"
+msgstr "sistema de referencia lineal"
#: ../vector/v.lrs/v.lrs.segment/main.c:75
-msgid ""
-"Creates points/segments from input lines, linear reference system and "
-"positions read from stdin or a file."
-msgstr ""
-"Crea puntos/segmentos a partir de las líneas de entrada, sistema de "
-"referencia lineal y posiciones leídas de stdin o un archivo."
+msgid "Creates points/segments from input lines, linear reference system and positions read from stdin or a file."
+msgstr "Crea puntos/segmentos a partir de las líneas de entrada, sistema de referencia lineal y posiciones leídas de stdin o un archivo."
#: ../vector/v.lrs/v.lrs.segment/main.c:79
#: ../vector/v.lrs/v.lrs.where/main.c:66
@@ -14421,9 +13059,7 @@
#: ../vector/v.lrs/v.lrs.segment/main.c:114
msgid "Name of file containing segment rules. If not given, read from stdin."
-msgstr ""
-"Nombre del archivo que contiene reglas de segmentos. Si no se indica, se lee "
-"de stdin."
+msgstr "Nombre del archivo que contiene reglas de segmentos. Si no se indica, se lee de stdin."
#: ../vector/v.lrs/v.lrs.segment/main.c:155
#: ../vector/v.lrs/v.lrs.where/main.c:147
@@ -14460,8 +13096,7 @@
"Cannot get point on line: cat = [%d] distance = [%f] (line length = %f)\n"
"%s"
msgstr ""
-"No se puede obtener punto en línea: categoría = [%d] distancia = [%f] "
-"(longitud de línea = %f)\n"
+"No se puede obtener punto en línea: categoría = [%d] distancia = [%f] (longitud de línea = %f)\n"
"%s"
#: ../vector/v.lrs/v.lrs.segment/main.c:253
@@ -14488,8 +13123,7 @@
"Requested offset for the 1. point not found, using nearest found:\n"
" %s"
msgstr ""
-"Offset solicitado para el punto 1. no encontrado, utilizando el más próximo "
-"encontrado:\n"
+"Offset solicitado para el punto 1. no encontrado, utilizando el más próximo encontrado:\n"
" %s"
#: ../vector/v.lrs/v.lrs.segment/main.c:273
@@ -14507,8 +13141,7 @@
"Requested offset for the 2. point not found, using nearest found:\n"
" %s"
msgstr ""
-"Offset utilizado para el punto 2. no encontrado, utilizando el más próximo "
-"encontrado:\n"
+"Offset utilizado para el punto 2. no encontrado, utilizando el más próximo encontrado:\n"
" %s"
#: ../vector/v.lrs/v.lrs.segment/main.c:282
@@ -14535,49 +13168,43 @@
"Cannot make line segment: cat = %d : %f - %f (line length = %f)\n"
"%s"
msgstr ""
-"No se puede hacer el segmento de línea: categoría = %d : %f - %f (longitud "
-"de línea = %f)\n"
+"No se puede hacer el segmento de línea: categoría = %d : %f - %f (longitud de línea = %f)\n"
"%s"
#: ../vector/v.lrs/v.lrs.segment/main.c:356
#: ../vector/v.lrs/v.lrs.where/main.c:222
-#, fuzzy, c-format
+#, c-format
msgid "[%d] point read from input"
msgid_plural "[%d] points read from input"
-msgstr[0] "[%d] puntos leídos de la entrada"
+msgstr[0] "[%d] punto leído de la entrada"
msgstr[1] "[%d] puntos leídos de la entrada"
#. GTC %s will be replaced with a message about lost points.
#: ../vector/v.lrs/v.lrs.segment/main.c:363
-#, fuzzy, c-format
+#, c-format
msgid "[%d] point written to output map (%s)"
msgid_plural "[%d] points written to output map (%s)"
-msgstr[0] "[%d] puntos escritos en el mapa de salida (%d perdidos)"
-msgstr[1] "[%d] puntos escritos en el mapa de salida (%d perdidos)"
+msgstr[0] "[%d] punto escrito en el mapa de salida (%s)"
+msgstr[1] "[%d] puntos escritos en el mapa de salida (%s)"
#: ../vector/v.lrs/v.lrs.segment/main.c:368
-#, fuzzy, c-format
+#, c-format
msgid "[%d] line read from input"
msgid_plural "[%d] lines read from input"
-msgstr[0] "[%d] líneas leídas de la entrada"
-msgstr[1] "[%d] líneas leídas de la entrada"
+msgstr[0] "[%d] línea leída desde entrada"
+msgstr[1] "[%d] líneas leídas desde entrada"
#. GTC %s will be replaced with a message about lost lines.
#: ../vector/v.lrs/v.lrs.segment/main.c:375
-#, fuzzy, c-format
+#, c-format
msgid "[%d] line written to output map (%s)"
msgid_plural "[%d] lines written to output map (%s)"
-msgstr[0] "[%d] líneas escritas en el mapa de salida (%d perdidas)"
-msgstr[1] "[%d] líneas escritas en el mapa de salida (%d perdidas)"
+msgstr[0] "[%d] línea escrita en el mapa de salida (%s)"
+msgstr[1] "[%d] líneas escritas en el mapa de salida (%s)"
#: ../vector/v.lrs/v.lrs.where/main.c:61
-#, fuzzy
-msgid ""
-"Finds line id and real km+offset for given points in vector map using linear "
-"reference system."
-msgstr ""
-"Hallar una id de línea y km reales + compensación para puntos especificados "
-"en un mapa vectorial empleando sistema de referencia lineal"
+msgid "Finds line id and real km+offset for given points in vector map using linear reference system."
+msgstr "Encontrar una id de línea y km reales + compensación para puntos especificados en un mapa vectorial empleando sistema de referencia lineal"
#: ../vector/v.lrs/v.lrs.where/main.c:70
msgid "Input vector map containing points"
@@ -14593,37 +13220,36 @@
msgstr "Distancia máxima a la línea más próxima"
#: ../vector/v.lrs/v.lrs.where/main.c:225
-#, fuzzy, c-format
+#, c-format
msgid "[%d] position found"
msgid_plural "[%d] positions found"
-msgstr[0] "[%d] posiciones encontradas"
+msgstr[0] "[%d] posición encontrada"
msgstr[1] "[%d] posiciones encontradas"
#: ../vector/v.lrs/v.lrs.where/main.c:229
-#, fuzzy, c-format
+#, c-format
msgid "[%d] point outside threshold"
msgid_plural "[%d] points outside threshold"
-msgstr[0] "[%d] puntos fuera del umbral"
+msgstr[0] "[%d] punto fuera del umbral"
msgstr[1] "[%d] puntos fuera del umbral"
#: ../vector/v.lrs/v.lrs.where/main.c:233
-#, fuzzy, c-format
+#, c-format
msgid "[%d] point - no record found"
msgid_plural "[%d] points - no record found"
-msgstr[0] "[%d] puntos - ningún registro encontrado"
+msgstr[0] "[%d] punto - ningún registro encontrado"
msgstr[1] "[%d] puntos - ningún registro encontrado"
#: ../vector/v.lrs/v.lrs.where/main.c:237
-#, fuzzy, c-format
+#, c-format
msgid "[%d] point - too many records found"
msgid_plural "[%d] points - too many records found"
-msgstr[0] "[%d] puntos - demasiados registros encontrados"
+msgstr[0] "[%d] punto - demasiados registros encontrados"
msgstr[1] "[%d] puntos - demasiados registros encontrados"
#: ../vector/v.lrs/v.lrs.create/main.c:124
-#, fuzzy
msgid "Creates a linear reference system."
+msgstr "Crea un Sistema de referencia lineal."
#: ../vector/v.lrs/v.lrs.create/main.c:133
msgid "Output vector map where oriented lines are written"
@@ -14647,21 +13273,16 @@
#: ../vector/v.lrs/v.lrs.create/main.c:173
msgid "Column containing milepost position for the beginning of next segment"
-msgstr ""
-"Columna que contiene la posición del punto kilométrico para el comienzo del "
-"siguiente segmento"
+msgstr "Columna que contiene la posición del punto kilométrico para el comienzo del siguiente segmento"
#: ../vector/v.lrs/v.lrs.create/main.c:182
#, fuzzy
-msgid ""
-"Column containing offset from milepost for the beginning of next segment"
+msgid "Column containing offset from milepost for the beginning of next segment"
msgstr "Columna que contiene "
#: ../vector/v.lrs/v.lrs.create/main.c:191
msgid "Column containing milepost position for the end of previous segment"
-msgstr ""
-"Columna que contiene la posición del punto kilométrico para el final del "
-"segmento anterior"
+msgstr "Columna que contiene la posición del punto kilométrico para el final del segmento anterior"
#: ../vector/v.lrs/v.lrs.create/main.c:200
msgid "Column containing offset from milepost for the end of previous segment"
@@ -14724,8 +13345,7 @@
#: ../vector/v.lrs/v.lrs.create/main.c:490
#, c-format
msgid "Milepost (start) %f+%f used as %f+%f (change MP to integer)"
-msgstr ""
-"Punto kilométrico (inicio) %f+%f usado como %f+%f (cambiar PK a entero)"
+msgstr "Punto kilométrico (inicio) %f+%f usado como %f+%f (cambiar PK a entero)"
#: ../vector/v.lrs/v.lrs.create/main.c:512
#, c-format
@@ -14740,8 +13360,7 @@
#: ../vector/v.lrs/v.lrs.create/main.c:585
#, c-format
msgid "Point [%d] cat [%d] is out of threshold (distance = %f)"
-msgstr ""
-"El punto [%d] con categoría [%d] está fuera del umbral (distancia = %f)"
+msgstr "El punto [%d] con categoría [%d] está fuera del umbral (distancia = %f)"
#: ../vector/v.lrs/v.lrs.create/main.c:717
#, c-format
@@ -14750,34 +13369,27 @@
#: ../vector/v.lrs/v.lrs.create/main.c:734
msgid "Start of 1. MP >= end of 2. MP for points' cats %[d], [%d]"
-msgstr ""
-"Comienzo del PK 1. >= final del PK 2. para categorías de punto %[d], [%d]"
+msgstr "Comienzo del PK 1. >= final del PK 2. para categorías de punto %[d], [%d]"
#: ../vector/v.lrs/v.lrs.create/main.c:751
#, c-format
msgid "Start of 1. MP >= start of 2. MP for points' cats [%d], [%d]"
-msgstr ""
-"Comienzo del PK 1. >= comienzo del PK 2. para categorías de punto [%d], [%d]"
+msgstr "Comienzo del PK 1. >= comienzo del PK 2. para categorías de punto [%d], [%d]"
#: ../vector/v.lrs/v.lrs.create/main.c:761
#, c-format
msgid "Distance along line identical for points' cats [%d], [%d]"
-msgstr ""
-"Distancia a lo largo de línea idéntica para categorías de punto [%d], [%d]"
+msgstr "Distancia a lo largo de línea idéntica para categorías de punto [%d], [%d]"
#: ../vector/v.lrs/v.lrs.create/main.c:775
#, c-format
msgid "Not enough points (%d) attached to the line (cat %d), line skip."
-msgstr ""
-"Puntos insuficientes (%d) asignados a la línea (categoría %d). Se salta la ?"
-"ínea."
+msgstr "Puntos insuficientes (%d) asignados a la línea (categoría %d). Se salta la ?ínea."
#: ../vector/v.lrs/v.lrs.create/main.c:780
#, c-format
msgid "Unable to guess direction for the line (cat %d), line skip."
-msgstr ""
-"No se puede averiguar la dirección para la línea (categoría %d), se salta la "
-"línea."
+msgstr "No se puede averiguar la dirección para la línea (categoría %d), se salta la línea."
#: ../vector/v.lrs/v.lrs.create/main.c:784
#, c-format
@@ -14800,12 +13412,12 @@
#: ../vector/v.lrs/v.lrs.label/main.c:105
#, fuzzy
msgid "Creates stationing from input lines, and linear reference system."
-msgstr "líneas"
+msgstr "Crea estaciones a partir de las líneas de entrada, y de un sistema de referencia lineal."
#: ../vector/v.lrs/v.lrs.label/main.c:113
#, fuzzy
msgid "Output vector map where stationing will be written"
-msgstr "Salida vectorial"
+msgstr "Mapa vectorial de salida en donde se escribirán las estaciones"
#: ../vector/v.lrs/v.lrs.label/main.c:147
msgid "Label file"
@@ -14868,7 +13480,7 @@
#: ../vector/v.clean/main.c:54 ../locale/scriptstrings/t.snap_to_translate.c:4
msgid "snapping"
-msgstr ""
+msgstr "ensamblando"
#: ../vector/v.clean/main.c:55
msgid "Toolset for cleaning topology of vector map."
@@ -14883,92 +13495,72 @@
msgstr "Herramienta de limpieza"
#: ../vector/v.clean/main.c:97
-#, fuzzy
msgid "break lines at each intersection"
-msgstr "Herramienta: romper líneas en las intersecciones"
+msgstr "rompe líneas en cada intersección"
#: ../vector/v.clean/main.c:98
msgid "remove duplicate geometry features (pay attention to categories!)"
-msgstr ""
-"eliminar elementos geométricos duplicados (¡ponga atención a las categorías!)"
+msgstr "eliminar elementos geométricos duplicados (¡ponga atención a las categorías!)"
#: ../vector/v.clean/main.c:99
msgid "remove dangles, threshold ignored if < 0"
msgstr ""
#: ../vector/v.clean/main.c:100
-msgid ""
-"change the type of boundary dangle to line, threshold ignored if < 0, input "
-"line type is ignored"
+msgid "change the type of boundary dangle to line, threshold ignored if < 0, input line type is ignored"
msgstr ""
#: ../vector/v.clean/main.c:102
msgid "remove bridges connecting area and island or 2 islands"
-msgstr ""
+msgstr "elimina puentes que conectan área e isla o 2 islas"
#: ../vector/v.clean/main.c:103
-msgid ""
-"change the type of bridges connecting area and island or 2 islands from "
-"boundary to line"
-msgstr ""
+msgid "change the type of bridges connecting area and island or 2 islands from boundary to line"
+msgstr "cambiar el tipo de puentes que conectan área e isla o 2 islas desde línea de contorno"
#: ../vector/v.clean/main.c:105
-#, fuzzy
msgid "snap lines to vertex in threshold"
-msgstr "Herramienta: ajustar línea a vértice en umbral"
+msgstr "ensamblar líneas a vértices en umbral"
#: ../vector/v.clean/main.c:106
-#, fuzzy
msgid "remove duplicate area centroids ('type' option ignored)"
-msgstr "Eliminar centroides de área duplicados"
+msgstr "eliminar centroides de área duplicados (se ignora la opción 'type')"
#: ../vector/v.clean/main.c:107
-msgid ""
-"break (topologically clean) polygons (imported from non topological format, "
-"like ShapeFile). Boundaries are broken on each point shared between 2 and "
-"more polygons where angles of segments are different"
-msgstr ""
+msgid "break (topologically clean) polygons (imported from non topological format, like ShapeFile). Boundaries are broken on each point shared between 2 and more polygons where angles of segments are different"
+msgstr "romper polígonos (topológicamente limpios) (importados desde formato no topológico como ShapeFile). Se romperán los contornos en cada punto compartido entre 2 o más polígonos en donde los ángulos de los segmentos sean distintos"
#: ../vector/v.clean/main.c:110
-msgid ""
-"remove vertices in threshold from lines and boundaries, boundary is pruned "
-"only if topology is not damaged (new intersection, changed attachment of "
-"centroid), first and last segment of the boundary is never changed"
-msgstr ""
+msgid "remove vertices in threshold from lines and boundaries, boundary is pruned only if topology is not damaged (new intersection, changed attachment of centroid), first and last segment of the boundary is never changed"
+msgstr "eliminar vértices en el límite de líneas y contornos, el contorno es cortado solo si la topología no está dañada (nueva intersección, fijación de centroide cambiada), los segmentos primero y último del contorno no son cambiados nunca"
#: ../vector/v.clean/main.c:114
msgid "remove small areas, the longest boundary with adjacent area is removed"
-msgstr ""
+msgstr "remover áreas pequeñas, es eliminado el contorno más largo con área adyacente"
#: ../vector/v.clean/main.c:115
-#, fuzzy
msgid "remove all lines or boundaries of zero length, threshold is ignored"
-msgstr "Eliminar todas las líneas o contornos de longitud cero"
+msgstr "eliminar todas las líneas o contornos de longitud cero, se ignora el umbral"
#: ../vector/v.clean/main.c:116
-#, fuzzy
msgid "remove small angles between lines at nodes"
-msgstr "Eliminar ángulos y nodos pequeños"
+msgstr "eliminar ángulos pequeños entre líneas en nodos"
#: ../vector/v.clean/main.c:124
-#, fuzzy
msgid "Threshold in map units, one value for each tool"
-msgstr ""
-"Umbral en unidades de mapa, un valor para cada herramienta (por omisión: "
-"0.0[,0.0,...])"
+msgstr "Umbral en unidades de mapa, un valor para cada herramienta"
#: ../vector/v.clean/main.c:125
msgid "Default: 0.0[,0.0,...])"
-msgstr ""
+msgstr "Predeterminado: 0.0[,0.0,...])"
#: ../vector/v.clean/main.c:130
-#, fuzzy
msgid "Do not build topology for the output vector"
-msgstr "No construir la topología para el vectorial de salida"
+msgstr "No construir topología para el vectorial de salida"
#: ../vector/v.clean/main.c:135
msgid "Combine tools with recommended follow-up tools"
-msgstr ""
+msgstr "Combinar herramientas con herramientas de seguimiento recomendadas"
#: ../vector/v.clean/main.c:156
msgid "You must select at least one tool"
@@ -14979,10 +13571,8 @@
msgstr "La herramienta no existe"
#: ../vector/v.clean/main.c:202
-msgid ""
-"Note: In latitude-longitude coordinate system specify threshold in degree "
-"unit"
-msgstr ""
+msgid "Note: In latitude-longitude coordinate system specify threshold in degree unit"
+msgstr "Nota: en sistema de coordenadas especificar umbral en unidad de grado"
#: ../vector/v.clean/main.c:215
#, c-format
@@ -15019,7 +13609,7 @@
#: ../vector/v.clean/main.c:249
msgid "Snap vertices"
-msgstr "Autoensamblar vértices"
+msgstr "Ensamblar vértices"
#: ../vector/v.clean/main.c:252
msgid "Remove duplicate area centroids"
@@ -15047,12 +13637,11 @@
#: ../vector/v.clean/main.c:314
msgid "Topological cleaning works best with native GRASS vector format"
-msgstr ""
+msgstr "Limpiado topología funciona mejor con formato vectorial GRASS nativo"
#: ../vector/v.clean/main.c:325
-#, fuzzy
msgid "Failed to copy attribute table to output vector map"
-msgstr "Error al copia tabla de atributos al mapa de salida"
+msgstr "Ha ocurrido un fallo al copia tabla de atributos al mapa vectorial de salida"
#: ../vector/v.clean/main.c:340 ../vector/v.clean/main.c:351
msgid "Rebuilding parts of topology..."
@@ -15060,9 +13649,8 @@
#: ../vector/v.clean/main.c:360 ../vector/v.clean/main.c:405
#: ../vector/v.clean/main.c:456
-#, fuzzy
msgid "Tool: Split lines"
-msgstr "Herramienta: recortar líneas/límites"
+msgstr "Herramienta: dividir líneas"
#: ../vector/v.clean/main.c:363 ../vector/v.clean/main.c:409
#: ../vector/v.clean/main.c:462
@@ -15077,9 +13665,8 @@
#: ../vector/v.clean/main.c:369 ../vector/v.clean/main.c:418
#: ../vector/v.clean/main.c:469
-#, fuzzy
msgid "Tool: Merge lines"
-msgstr "Unir contornos:"
+msgstr "Herramienta: unir líneas"
#: ../vector/v.clean/main.c:379
msgid "Tool: Remove dangles"
@@ -15103,7 +13690,7 @@
#: ../vector/v.clean/main.c:399
msgid "Tool: Snap line to vertex in threshold"
+msgstr "Herramienta: ensamblar línea a vértice en umbral"
#: ../vector/v.clean/main.c:413 ../vector/v.clean/main.c:447
#: ../vector/v.clean/main.c:466
@@ -15123,9 +13710,8 @@
#: ../vector/v.clean/main.c:442
-#, fuzzy
msgid "Tool: Merge boundaries"
+msgstr "Herramienta: unir contornos"
#: ../vector/v.clean/main.c:475
msgid "Tool: Remove all lines and boundaries of zero length"
@@ -15140,9 +13726,9 @@
msgstr "Construyendo topología para el mapa vectorial de errores..."
#: ../vector/v.clean/split.c:85
-#, fuzzy, c-format
+#, c-format
msgid "Line splits: %d"
-msgstr "Línea: %d\n"
+msgstr "Divisiones de línea: %d"
#: ../vector/v.clean/rmline.c:64
#, c-format
@@ -15155,13 +13741,9 @@
msgstr "Dublicar centroides de área: %d"
#: ../vector/v.clean/prune.c:216
-#, fuzzy, c-format
-msgid ""
-"%d vertices from input %d (vertices of given type) removed, i.e. %.2f %%"
-msgstr ""
-"\n"
-"%d vértices de la entrada %d (vértices del tipo dado) eliminados, esto es "
-"%.2f %%"
+#, c-format
+msgid "%d vertices from input %d (vertices of given type) removed, i.e. %.2f %%"
+msgstr "%d vértices de la entrada %d (vértices del tipo dado) eliminados, i.e. %.2f %%"
#: ../vector/v.clean/prune.c:220
#, c-format
@@ -15187,28 +13769,21 @@
msgstr "Separador de registros vertical de salida"
#: ../vector/v.db.select/main.c:100
-msgid ""
-"Print minimal region extent of selected vector features instead of attributes"
-msgstr ""
-"Imprimir la extensión mínima de la región de los elementos vectoriales "
-"seleccionados en lugar de los atributos"
+msgid "Print minimal region extent of selected vector features instead of attributes"
+msgstr "Imprimir la extensión mínima de la región de los elementos vectoriales seleccionados en lugar de los atributos"
#: ../vector/v.db.select/main.c:101
-#, fuzzy
msgid "Region"
-msgstr "Región\n"
+msgstr "Región"
#: ../vector/v.db.select/main.c:115
-#, fuzzy
msgid "Exclude attributes not linked to features"
-msgstr "Poblar valores de base de datos a partir de elementos vectoriales."
+msgstr "Excluye atributos no enlazados a elementos"
#: ../vector/v.db.select/main.c:157
-#, fuzzy, c-format
-msgid ""
-"Unable to open vector map <%s> at topology level. Flag '%c' requires "
-"topology level."
-msgstr "No se puede abrir el mapa vectorial <%s> en el nivel topológico %d"
+#, c-format
+msgid "Unable to open vector map <%s> at topology level. Flag '%c' requires topology level."
+msgstr "No ha sido posible abrir mapa vectorial <%s> en el nivel topológico. La bandera '%c' requiere del nivel topológico."
#: ../vector/v.db.select/main.c:208
msgid "Unable to open select cursor"
@@ -15226,39 +13801,35 @@
#: ../vector/v.net.spanningtree/main.c:48
msgid "spanning tree"
-msgstr ""
+msgstr "árbol de expansión"
#: ../vector/v.net.spanningtree/main.c:50
msgid "Computes minimum spanning tree for the network."
-msgstr "Calcula el minimum spanning tree para la red"
+msgstr "Calcula el árbol de expansión mínima para la red."
#: ../vector/v.split/main.c:56
-#, fuzzy
msgid "densification"
-msgstr "Selección"
+msgstr "densificación"
#: ../vector/v.split/main.c:60
msgid "Splits vector lines to shorter segments."
-msgstr ""
+msgstr "Dividir lineas vectoriales en segmentos menores."
#: ../vector/v.split/main.c:73
-#, fuzzy
msgid "Maximum segment length"
-msgstr "Longitud máxima de fila de entrada: %d"
+msgstr "Longitud máxima de segmento"
#: ../vector/v.split/main.c:82
-#, fuzzy
msgid "Length units"
-msgstr "Longitud: %f\n"
+msgstr "Unidades de longitud"
#: ../vector/v.split/main.c:89
-#, fuzzy
msgid "Maximum number of vertices in segment"
-msgstr "Número máximo de puntos en un segmento"
+msgstr "Número máximo de vértices en segmento"
#: ../vector/v.split/main.c:93
msgid "Add new vertices, but do not split"
-msgstr ""
+msgstr "Añadir nuevos vértices, pero no dividir"
#: ../vector/v.split/main.c:94 ../vector/v.split/main.c:99
msgid "Applies only to 'length' option"
@@ -15269,61 +13840,49 @@
msgstr ""
#: ../vector/v.split/main.c:108
-#, fuzzy
msgid "Use either length or vertices"
-msgstr "Escribir vértices de líneas"
+msgstr "Usar longitud o vértices"
#: ../vector/v.split/main.c:115
-#, fuzzy, c-format
+#, c-format
msgid "Length must be positive but is %g"
-msgstr "El suavizado debe ser un valor positivo"
+msgstr "La longitud debe ser positiva pero es %g"
#: ../vector/v.split/main.c:131
-#, fuzzy, c-format
+#, c-format
msgid "Unknown unit %s"
-msgstr "Tipo de columna '%s' desconocido"
+msgstr "Unidad %s desconocida"
#: ../vector/v.split/main.c:149
-#, fuzzy
msgid "Can not get projection units"
-msgstr "No se pueden obtener las unidades de la proyección del mapa de entrada"
+msgstr "No se pueden obtener unidades de proyección"
#: ../vector/v.split/main.c:156
-#, fuzzy, c-format
+#, c-format
msgid "Length in map units: %g"
-msgstr "longitud %f\n"
+msgstr "Longitud en unidades del mapa: %g"
#: ../vector/v.split/main.c:158
-#, fuzzy, c-format
+#, c-format
msgid "Length in meters: %g"
+msgstr "Longitud en metro: %g"
#: ../vector/v.split/main.c:164
-#, fuzzy
msgid "Number of vertices must be at least 2"
-msgstr "¡El número de clases deber ser < 256!"
+msgstr "El número de vertices debe ser al menos 2"
#: ../vector/v.split/main.c:250
-#, fuzzy, c-format
+#, c-format
msgid "Unable to make line segment: %f - %f (line length = %f)"
-msgstr ""
-"de línea = %.15g)\n"
-"%s"
+msgstr "No ha sido posible hacer segmento de línea: %f - %f (longitud de línea = %f)"
#: ../vector/v.lidar.growing/main.c:78
-msgid ""
-"Building contour determination and Region Growing algorithm for determining "
-"the building inside"
-msgstr ""
-"Construyendo algoritmo Contour determination y de Region Growing para "
-"determinar la construcción interior"
+msgid "Building contour determination and Region Growing algorithm for determining the building inside"
+msgstr "Construyendo algoritmo Contour determination y de Region Growing para determinar la construcción interior"
#: ../vector/v.lidar.growing/main.c:83
-#, fuzzy
msgid "Input vector (v.lidar.edgedetection output)"
-msgstr ""
-"Nombre del mapa vectorial de observación de entrada (salida v.lidar.growing)"
+msgstr "Vectorial de entrada (salida v.lidar.edgedetection)"
#: ../vector/v.lidar.growing/main.c:93
msgid "Name of the first pulse vector map"
@@ -15331,11 +13890,11 @@
#: ../vector/v.lidar.growing/main.c:100
msgid "Threshold for cell object frequency in region growing"
-msgstr ""
+msgstr "Umbral para celda de frecuencia de objeto en región incremental"
#: ../vector/v.lidar.growing/main.c:108
msgid "Threshold for double pulse in region growing"
-msgstr ""
+msgstr "Umbral para pulso doble en región incremental"
#: ../vector/v.lidar.growing/main.c:176
#, c-format
@@ -15369,24 +13928,20 @@
msgstr "...saliendo ahora al sistema..."
#: ../vector/v.mkgrid/hexgrid.c:86
-#, fuzzy
msgid "Writing out hexagon grid..."
-msgstr "Escribiendo mapa..."
+msgstr "Escribiendo malla hexagonal..."
#: ../vector/v.mkgrid/main.c:72
msgid "grid"
msgstr "cuadrícula"
#: ../vector/v.mkgrid/main.c:74
-#, fuzzy
msgid "Creates a vector map of a user-defined grid."
-msgstr ""
-"Crea un mapa vectorial de GRASS de una cuadrícula definida por el usuario."
+msgstr "Crea un mapa vectorial a partir de una malla definida por el usuario."
#: ../vector/v.mkgrid/main.c:81
-#, fuzzy
msgid "rows,columns"
-msgstr "Columnas"
+msgstr "filas,columnas"
#: ../vector/v.mkgrid/main.c:85
msgid "Number of rows and columns in grid"
@@ -15397,14 +13952,12 @@
msgstr "Dónde colocar la cuadrícula"
#: ../vector/v.mkgrid/main.c:98
-#, fuzzy
msgid "current region"
-msgstr "Usar la región actual"
+msgstr "región actual"
#: ../vector/v.mkgrid/main.c:99
-#, fuzzy
msgid "use 'coor' and 'box' options"
-msgstr "region;región actual;coor;usar las opciones 'coor' y 'box'"
+msgstr "usa las opciones 'coor' y 'box'"
#: ../vector/v.mkgrid/main.c:104
msgid "Lower left easting and northing coordinates of map"
@@ -15423,48 +13976,42 @@
msgstr "Ángulo de rotación (en grados en el sentido de las agujas del reloj)"
#: ../vector/v.mkgrid/main.c:127
-#, fuzzy
msgid "Number of vertex points per grid cell"
-msgstr "Número de puntos vértice horizontales porrr"
+msgstr "Número de puntos vértice por celda de malla"
#: ../vector/v.mkgrid/main.c:135
#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:7
#: ../raster/r.to.vect/main.c:87
-#, fuzzy
msgid "Output feature type"
-msgstr "Hata tipo de elemento"
+msgstr "Tipo de elemento de salida"
#: ../vector/v.mkgrid/main.c:140
-#, fuzzy
msgid "Create hexagons (default: rectangles)"
-msgstr "Longitud de página (por omisión: %d líneas)"
+msgstr "Genera hexágonos (predeterminado: rectángulos)"
#: ../vector/v.mkgrid/main.c:145
msgid "Allow asymmetric hexagons"
-msgstr ""
+msgstr "Permitir hexágonos asimétricos"
#: ../vector/v.mkgrid/main.c:185
msgid "'coor' and 'position=region' are exclusive options"
-msgstr ""
+msgstr "'coor' y 'position=region' son opciones excluyentes"
#: ../vector/v.mkgrid/main.c:188
msgid "'box' and 'grid' are exclusive options for 'position=region'"
-msgstr ""
+msgstr "'box' y 'grid' son opciones excluyentes para 'position=region'"
#: ../vector/v.mkgrid/main.c:211 ../vector/v.mkgrid/main.c:247
-#, fuzzy
msgid "Invalid width"
-msgstr "Ancho del icono"
+msgstr "Anchura no válida"
#: ../vector/v.mkgrid/main.c:214 ../vector/v.mkgrid/main.c:250
-#, fuzzy
msgid "Invalid height"
-msgstr "Este no válido"
+msgstr "Altura no válida"
#: ../vector/v.mkgrid/main.c:230
-#, fuzzy
msgid "'grid' option missing"
-msgstr "Falta la opción 'coor'"
+msgstr "Falta la opción 'grid'"
#: ../vector/v.mkgrid/main.c:233
msgid "'coor' option missing"
@@ -15484,27 +14031,26 @@
#: ../vector/v.mkgrid/main.c:308
msgid "The hexagons will be asymmetrical."
-msgstr ""
+msgstr "Los hexágonos serán asimétricos."
#: ../vector/v.mkgrid/main.c:321 ../vector/v.mkgrid/main.c:324
msgid "Please use a higher resolution or a larger region"
-msgstr ""
+msgstr "Por favor use una resolución mayor o una región mayor"
#: ../vector/v.mkgrid/main.c:328
-#, fuzzy, c-format
+#, c-format
msgid "The number of rows has been adjusted from %d to %d"
-msgstr "OOPS: cambiadas filas desde %d hasta %d"
+msgstr "El número de filas ha sido ajustado de %d a %d"
#: ../vector/v.mkgrid/main.c:331
-#, fuzzy, c-format
+#, c-format
msgid "The number of columns has been adjusted from %d to %d"
-msgstr "El número de subrangos tiene que ser igual o mayor que 1"
+msgstr "El número de columnas ha sido ajustado de %d a %d"
#: ../vector/v.mkgrid/main.c:360 ../vector/v.mkgrid/main.c:445
#: ../vector/v.mkgrid/main.c:457
-#, fuzzy
msgid "Unable to fill attribute table"
-msgstr "No se puede describir la tabla<%s>"
+msgstr "No ha sido posible rellenar tabla de atributos"
#: ../vector/v.mkgrid/main.c:364 ../vector/v.mkgrid/main.c:462
#: ../vector/v.in.dxf/write_vect.c:70 ../vector/v.in.ascii/points.c:452
@@ -15514,7 +14060,7 @@
#: ../vector/v.mkgrid/main.c:371
msgid "The rectangles will be asymmetrical."
-msgstr ""
+msgstr "Los rectángulos serán asimétricos."
#: ../vector/v.mkgrid/main.c:416
msgid "Creating centroids..."
@@ -15538,9 +14084,8 @@
#: ../raster/r.mfilter/main.c:57 ../raster/r.mapcalc/main.c:70
#: ../raster/r.quantile/main.c:256 ../raster/r.neighbors/main.c:168
#: ../raster/r.texture/main.c:102
-#, fuzzy
msgid "algebra"
-msgstr "ráster, álgebra de mapas"
+msgstr "álgebra"
#: ../vector/v.neighbors/main.c:54
#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:3
@@ -15552,25 +14097,16 @@
#: ../raster3d/r3.in.lidar/main.c:130 ../raster3d/r3.neighbors/main.c:212
#: ../raster/r.in.xyz/main.c:162 ../raster/r.in.lidar/main.c:111
#: ../raster/r.series/main.c:138 ../raster/r.neighbors/main.c:170
-#, fuzzy
msgid "aggregation"
-msgstr "Correlación"
+msgstr "agregación"
#: ../vector/v.neighbors/main.c:55
-#, fuzzy
msgid "Neighborhood analysis tool for vector point maps."
-msgstr "Nombre del mapa vectorial de puntos de entrada"
+msgstr "Herramienta de análisis de vecindario para mapas vectoriales de puntos."
#: ../vector/v.neighbors/main.c:56
-#, fuzzy
-msgid ""
-"Makes each cell value a function of the attribute values assigned to the "
-"vector points or centroids around it, and stores new cell values in an "
-"output raster map."
-msgstr ""
-"Hace cada valor de categoría de celda una función de los valores de "
-"categoría asignados a las celdas a su alrededor y guarda los nuevos valores "
-"de celda en una capa de mapa ráster de salida."
+msgid "Makes each cell value a function of the attribute values assigned to the vector points or centroids around it, and stores new cell values in an output raster map."
+msgstr "Hace que el valor de cada celda sea una función de los valores de los atributos asignados a los puntos vectoriales o centroides a su alrededor, y guarda los nuevos valores de celda en una capa de mapa ráster de salida."
#: ../vector/v.neighbors/main.c:72 ../raster/r.neighbors/main.c:204
msgid "Neighborhood operation"
@@ -15586,24 +14122,16 @@
#: ../vector/v.neighbors/main.c:103
#, c-format
-msgid ""
-"The search diameter %g is smaller than cell diagonal %g: some points could "
-"not be detected"
+msgid "The search diameter %g is smaller than cell diagonal %g: some points could not be detected"
msgstr ""
#: ../vector/v.lidar.correction/main.c:71
-#, fuzzy
-msgid ""
-"Corrects the v.lidar.growing output. It is the last of the three algorithms "
-"for LIDAR filtering."
-msgstr ""
-"Corrección de la salida de v.lidar.growing. Es el último de los tres "
-"algoritmos para el filtrado de LIDAR."
+msgid "Corrects the v.lidar.growing output. It is the last of the three algorithms for LIDAR filtering."
+msgstr "Corrije la salida de v.lidar.growing. Es el último de los tres algoritmos para el filtrado de LIDAR."
#: ../vector/v.lidar.correction/main.c:81
msgid "Input observation vector map name (v.lidar.growing output)"
-msgstr ""
+msgstr "Nombre del mapa vectorial de observación de entrada (salida v.lidar.growing)"
#: ../vector/v.lidar.correction/main.c:84
msgid "Output classified vector map name"
@@ -15615,7 +14143,7 @@
#: ../vector/v.lidar.correction/main.c:118
msgid "Regularization weight in reclassification evaluation"
-msgstr ""
+msgstr "Peso de regularización en evaluación de reclasificación"
#: ../vector/v.lidar.correction/main.c:126
msgid "High threshold for object to terrain reclassification"
@@ -15626,18 +14154,18 @@
msgstr "Bajo umbral para terreno objetar reclasificación"
#: ../vector/v.lidar.correction/main.c:273
-#, fuzzy, c-format
+#, c-format
msgid "adjusted EW spline %d"
msgid_plural "adjusted EW splines %d"
-msgstr[0] "splines EW %d ajustados"
-msgstr[1] "splines EW %d ajustados"
+msgstr[0] "spline %d ajustada EO (EW)"
+msgstr[1] "splines %d ajustadas EO (EW)"
#: ../vector/v.lidar.correction/main.c:276
-#, fuzzy, c-format
+#, c-format
msgid "adjusted NS spline %d"
msgid_plural "adjusted NS splines %d"
-msgstr[0] "splines NS %d ajustados"
-msgstr[1] "splines NS %d ajustados"
+msgstr[0] "spline %d ajustada NS"
+msgstr[1] "splines %d ajustadas NS"
#: ../vector/v.lidar.correction/main.c:324
#, c-format
@@ -15667,15 +14195,12 @@
msgstr "Sólo puntos del TERRENO"
#: ../vector/v.lidar.correction/main.c:415
-#, fuzzy
msgid "Correction and creation of terrain vector"
-msgstr "vectorial"
+msgstr "Correción y creación de vectorial de terreno"
#: ../vector/v.label/main.c:62
msgid "Creates paint labels for a vector map from attached attributes."
-msgstr ""
-"Crea etiquetas de pintura para un mapa vectorial a partir de atributos "
-"asociados."
+msgstr "Crea etiquetas de pintura para un mapa vectorial a partir de atributos asociados."
#: ../vector/v.label/main.c:69
msgid "If not given the name of the input map is used"
@@ -15736,11 +14261,8 @@
msgstr "Ningún dispositivo de gráficos seleccionado"
#: ../vector/v.label/main.c:251
-msgid ""
-"size and space options vary significantly which may lead to crummy output"
-msgstr ""
-"las opciones de tamaño y espacio varía de forma significativa, lo que puede "
-"dar una salida horrible"
+msgid "size and space options vary significantly which may lead to crummy output"
+msgstr "las opciones de tamaño y espacio varía de forma significativa, lo que puede dar una salida horrible"
#: ../vector/v.label/main.c:259
msgid "Too many parameters for <reference>"
@@ -15757,9 +14279,8 @@
#: ../vector/v.qcount/main.c:72
#, fuzzy
-msgid ""
-"Name for output quadrat centers map (number of points is written as category)"
-msgstr "Salida puntos"
+msgid "Name for output quadrat centers map (number of points is written as category)"
+msgstr "Nombre para mapa de salida de centro de "
#: ../vector/v.qcount/main.c:78
msgid "Number of quadrats"
@@ -15793,8 +14314,7 @@
#: ../vector/v.decimate/main.c:131
-msgid ""
-"Copies points from one vector to another while applying different decimations"
+msgid "Copies points from one vector to another while applying different decimations"
msgstr ""
#: ../vector/v.decimate/main.c:159
@@ -15803,9 +14323,7 @@
#: ../vector/v.decimate/main.c:161
#, fuzzy
-msgid ""
-"For example, 5 will import 80 percent of points. If not specified, all "
-"points are copied"
+msgid "For example, 5 will import 80 percent of points. If not specified, all points are copied"
msgstr "Se importan los valores enteros"
#: ../vector/v.decimate/main.c:163 ../vector/v.decimate/main.c:174
@@ -15819,9 +14337,7 @@
#: ../vector/v.decimate/main.c:172
#, fuzzy
-msgid ""
-"For example, 4 will import 25 percent of points. If not specified, all "
+msgid "For example, 4 will import 25 percent of points. If not specified, all points are copied"
#: ../vector/v.decimate/main.c:191
@@ -15854,9 +14370,7 @@
#: ../vector/v.decimate/main.c:211
-msgid ""
-"Preserves only the given number of points per grid cell in grid-based "
-"decimation"
+msgid "Preserves only the given number of points per grid cell in grid-based decimation"
msgstr ""
#: ../vector/v.decimate/main.c:216
@@ -15887,9 +14401,7 @@
#: ../vector/v.decimate/main.c:274
#, c-format
-msgid ""
-"Input layer must be set to a particular layer, not <%s>, when using <%s> "
-"option or <-%c> flag"
+msgid "Input layer must be set to a particular layer, not <%s>, when using <%s> option or <-%c> flag"
msgstr ""
#: ../vector/v.decimate/main.c:316
@@ -15901,9 +14413,7 @@
msgstr ""
#: ../vector/v.decimate/main.c:348
-msgid ""
-"Settings for count-based decimation would cause it to do nothing and no "
-"other options has been set."
+msgid "Settings for count-based decimation would cause it to do nothing and no other options has been set."
msgstr ""
#: ../vector/v.rectify/target.c:18
@@ -15946,17 +14456,12 @@
msgstr "Por favor, ejecutar i.targer para group."
#: ../vector/v.rectify/main.c:71 ../imagery/i.rectify/main.c:100
-#, fuzzy
msgid "rectify"
-msgstr "grupo de imaginería"
+msgstr "rectificar"
#: ../vector/v.rectify/main.c:73
-msgid ""
-"Rectifies a vector by computing a coordinate transformation for each object "
-"in the vector based on the control points."
-msgstr ""
-"Rectifica un vectorial calculando una transformación de coordenadas para "
-"cada objeto en el vectorial basándose en los puntos de control."
+msgid "Rectifies a vector by computing a coordinate transformation for each object in the vector based on the control points."
+msgstr "Rectifica un vectorial calculando una transformación de coordenadas para cada objeto en el vectorial basándose en los puntos de control."
#: ../vector/v.rectify/main.c:88
msgid "Name of input file with control points"
@@ -15964,14 +14469,11 @@
#: ../vector/v.rectify/main.c:93
msgid "Name of output file with RMS errors (if omitted or '-' output to stdout"
-msgstr ""
-"Nombre para el archivo de salida que contiene errores cuadráticos medios "
-"(RMS) (si se omite o \"-\" salida a salida estandar)"
+msgstr "Nombre para el archivo de salida que contiene errores cuadráticos medios (RMS) (si se omite o \"-\" salida a salida estandar)"
#: ../vector/v.rectify/main.c:102 ../imagery/i.rectify/main.c:124
-#, fuzzy
msgid "Rectification polynomial order (1-3)"
-msgstr "Rectificación de orden polinómico (1-3)"
+msgstr "Orden de polinomio de rectificación (1-3)"
#: ../vector/v.rectify/main.c:105
msgid "Field separator for RMS report"
@@ -15991,9 +14493,7 @@
#: ../vector/v.rectify/main.c:118
msgid "Print RMS errors and exit without rectifying the input map"
-msgstr ""
-"Mostrar errores cuadráticos medios (RMS) y salir sin rectificar el mapa de "
-"entrada"
+msgstr "Mostrar errores cuadráticos medios (RMS) y salir sin rectificar el mapa de entrada"
#: ../vector/v.rectify/main.c:136
msgid "Please select a group or give an input file."
@@ -16001,9 +14501,7 @@
#: ../vector/v.rectify/main.c:138
msgid "Points in group will be ignored, GCPs in input file are used."
-msgstr ""
-"Los puntos en el grupo serán ignorados, GCPs del archivo de entrada serán "
-"usados."
+msgstr "Los puntos en el grupo serán ignorados, GCPs del archivo de entrada serán usados."
#: ../vector/v.rectify/main.c:143 ../imagery/i.rectify/main.c:199
#, c-format
@@ -16053,9 +14551,7 @@
#: ../vector/v.rectify/cp.c:359 ../imagery/i.rectify/cp.c:47
#, c-format
msgid "Not enough active control points for current order, %d are required."
-msgstr ""
-"No hay suficientes puntos de control activos para el orden actual, se "
-"requieren %d."
+msgstr "No hay suficientes puntos de control activos para el orden actual, se requieren %d."
#: ../vector/v.rectify/cp.c:363 ../imagery/i.rectify/cp.c:24
#: ../imagery/i.rectify/cp.c:51
@@ -16070,8 +14566,7 @@
#: ../vector/v.rectify/cp.c:367 ../imagery/i.rectify/cp.c:28
#: ../imagery/i.rectify/cp.c:55
msgid "Not enough memory to solve for transformation equation"
-msgstr ""
-"No hay suficiente memoria para solucionar la equación de transformación"
+msgstr "No hay suficiente memoria para solucionar la equación de transformación"
#: ../vector/v.rectify/cp.c:370 ../imagery/i.rectify/cp.c:31
#: ../imagery/i.rectify/cp.c:58
@@ -16080,18 +14575,12 @@
#: ../vector/v.extrude/main.c:72
#, fuzzy
-msgid ""
-"Extrudes flat vector features to 3D vector features with defined height."
+msgid "Extrudes flat vector features to 3D vector features with defined height."
msgstr "Eleva objetos vectoriales planos a 3D con alturas definidas."
#: ../vector/v.extrude/main.c:74
-#, fuzzy
-msgid ""
-"Optionally the height can be derived from sampling of elevation raster map."
-msgstr ""
-"Convierte mapa vectorial a 3D mostreaectorial 2D a vectorial 3D muestreando "
-"ráster de elevación. De forma predeterminada se muestrea por el vecino más "
-"próximo."
+msgid "Optionally the height can be derived from sampling of elevation raster map."
+msgstr "Opcionalmente la altura puede ser derivada muestreando un mapa ráster de elevación."
#: ../vector/v.extrude/main.c:78
msgid "Trace elevation"
@@ -16108,15 +14597,13 @@
#: ../vector/v.extrude/main.c:202
#, c-format
-msgid ""
-"Invalid layer number (%d). Parameter '%s', '%s' or '%s' specified, assuming "
-"layer '1'."
-msgstr ""
+msgid "Invalid layer number (%d). Parameter '%s', '%s' or '%s' specified, assuming layer '1'."
+msgstr "Número de capa (%d) no válido. Parámetro '%s', '%s' o '%s' especificado, asumiendo capa '1'."
#: ../vector/v.extrude/main.c:234
-#, fuzzy, c-format
+#, c-format
msgid "Column <%s> does not exist"
-msgstr "El grupo <%s> no existe"
+msgstr "Columna <%s> no existe"
#: ../vector/v.extrude/main.c:243
#, c-format
@@ -16128,14 +14615,13 @@
msgstr "Elevando áreas..."
#: ../vector/v.extrude/main.c:287
-#, fuzzy, c-format
+#, c-format
msgid "No category defined for area %d. Using default fixed height %f."
-msgstr "Ningún atributo encontrado para la categoría %d: %s"
+msgstr "No hay categoría definida para área %d. Usando altura fija predetermianda %f."
#: ../vector/v.extrude/main.c:293
#, c-format
-msgid ""
-"Unable to fetch height from DB for area %d. Using default fixed height %f."
+msgid "Unable to fetch height from DB for area %d. Using default fixed height %f."
msgstr ""
#: ../vector/v.extrude/main.c:319
@@ -16144,89 +14630,71 @@
msgstr "Extrayendo áreas..."
#: ../vector/v.extrude/main.c:340
-#, fuzzy, c-format
+#, c-format
msgid "No category defined for feature %d. Using default fixed height %f."
-msgstr ""
+msgstr "No hay categoría definida para elemento %d. Usando altura %f predeterminada fijada."
#: ../vector/v.extrude/main.c:346
#, c-format
-msgid ""
-"Unable to fetch height from DB for line %d. Using default fixed height %f."
+msgid "Unable to fetch height from DB for line %d. Using default fixed height %f."
msgstr ""
#: ../vector/v.extrude/main.c:364
-#, fuzzy
msgid "Copying attribute table..."
-msgstr "Copiando tabla(s) de atributos..."
+msgstr "Copiando tabla de atributos..."
#: ../vector/v.extrude/db.c:27
-#, fuzzy, c-format
+#, c-format
msgid "Unable to select attributes category %d"
-msgstr "No se pueden seleccionar los atributos"
+msgstr "No ha sido posible seleccionar categoría de atributos %d"
#: ../vector/v.sample/main.c:79
msgid "Samples a raster map at vector point locations."
msgstr "Muestrear un mapa ráster en localizaciones de puntos vectoriales."
#: ../vector/v.sample/main.c:89
-#, fuzzy
msgid "Name of attribute column to use for comparison"
-msgstr "Columna de atributos del mapa vectorial a usar para comparación"
+msgstr "Nombre de columna de atributos para comparación"
#: ../vector/v.sample/main.c:92
-#, fuzzy
msgid "Name for output vector map to store differences"
-msgstr "Mapa vectorial para guardar las diferencias"
+msgstr "Nombre de mapa vectorial de salida para guardar diferencias"
#: ../vector/v.sample/main.c:96
-#, fuzzy
msgid "Name of raster map to be sampled"
-msgstr "Nombre del mapa ráster a visualizar"
+msgstr "Nombre de mapa ráster a muestrear"
#: ../vector/v.sample/main.c:107
-#, fuzzy
msgid "Scaling factor for values read from raster map"
-msgstr "Factor de escala para las flechas (mapa de magnitud)"
+msgstr "Factor de escalamiento para valores leidos de desde mapa ráster"
#: ../vector/v.sample/main.c:109
-#, fuzzy
msgid "Sampled values will be multiplied by this factor"
-msgstr ""
-"Opción factor de escala para valores leídos de un mapa ráster. Los valores "
-"muestrados se multiplicarán por este factor"
+msgstr "Valores muestreados serán multiplicados por este factor"
#: ../vector/v.sample/main.c:148
#, c-format
msgid "Column type <%s> not supported (must be integer or double precision)"
-msgstr ""
-"El tipo de columna <%s> no está soportado (debe ser entero o precisión doble)"
+msgstr "El tipo de columna <%s> no está soportado (debe ser entero o precisión doble)"
#: ../vector/v.sample/main.c:154
-#, fuzzy, c-format
+#, c-format
msgid "%d record selected from table"
+msgstr[0] "%d registro seleccionado de la tabla"
#: ../vector/v.sample/main.c:200
-#, fuzzy
msgid "Reading points..."
-msgstr "Leyendo entradas..."
+msgstr "Leyendo puntos..."
#: ../vector/v.univar/main.c:98
-#, fuzzy
msgid "Calculates univariate statistics of vector map features."
-msgstr "Calcula estadísticas univariantes a partir de un mapa ráster de GRASS."
+msgstr "Calcula estadísticas univariadas de elementos de mapa vectorial."
#: ../vector/v.univar/main.c:99
-#, fuzzy
-msgid ""
-"Variance and standard deviation is calculated only for points if specified."
-msgstr ""
-"Calcula estadísticas univariante para atributos. La varianza y la desviación "
-"estándar sólo se calculan para puntos si se especifica."
+msgid "Variance and standard deviation is calculated only for points if specified."
+msgstr "Varianza y desviación estándar son calculadas solamente para puntos especificados."
#: ../vector/v.univar/main.c:122
#: ../locale/scriptstrings/db.univar_to_translate.c:6
@@ -16248,30 +14716,21 @@
msgstr "Pesar por longitud de la línea o tamaño del área"
#: ../vector/v.univar/main.c:138
-#, fuzzy
msgid "Calculate geometric distances instead of attribute statistics"
-msgstr "Calculando distancias geométricas en lugar de los datos de la tabla."
+msgstr "Calculando distancias geométricas en lugar de estadísticas de atributos"
#: ../vector/v.univar/main.c:192
#, c-format
msgid "Geometry distances are not supported for areas. Use '%s' instead."
-msgstr ""
-"Las distancias entre geometrías no está soportada para áreas. Use su lugar "
-"use '%s'."
+msgstr "Las distancias entre geometrías no está soportada para áreas. Use su lugar use '%s'."
#: ../vector/v.univar/main.c:195
-msgid ""
-"Incompatible vector type(s) specified, only number of features, minimum, "
-"maximum and range can be calculated"
-msgstr ""
-"Especificados tipo(s) vectoriales incompatibles, sólo se pueden calcular "
-"número de elementos, mínimo, máximo e intervalo"
+msgid "Incompatible vector type(s) specified, only number of features, minimum, maximum and range can be calculated"
+msgstr "Especificados tipo(s) vectoriales incompatibles, sólo se pueden calcular número de elementos, mínimo, máximo e intervalo"
#: ../vector/v.univar/main.c:200
msgid "Extended statistics is currently supported only for points/centroids"
-msgstr ""
-"Las estadísticas ampliadas sólo están soportadas actualmente para puntos/"
-"centroides"
+msgstr "Las estadísticas ampliadas sólo están soportadas actualmente para puntos/centroides"
#: ../vector/v.univar/main.c:225
msgid "'layer' must be > 0 for 'where'."
@@ -16283,52 +14742,48 @@
msgstr "No se pueden seleccionar registros de la tabla <%s>"
#: ../vector/v.univar/main.c:253
-#, fuzzy, c-format
+#, c-format
msgid "Calculating geometric distances between %d primitives..."
+msgstr "Calculando distancias geométricas entre %d primitivas..."
#: ../vector/v.univar/main.c:343
-#, fuzzy, c-format
+#, c-format
msgid " Database connection not defined for layer <%s>"
-msgstr "La conexión a la base de datos no ha sido definida para la capa %d"
+msgstr " La conexión a la base de datos no ha sido definida para la capa <%s>"
#: ../vector/v.univar/main.c:652
msgid "Cannot sort the key/value array"
msgstr "No se pueden ordenar la matriz de claves/valores"
#: ../vector/v.what.rast3/main.c:72
-#, fuzzy
msgid "Uploads 3D raster values at positions of vector points to the table."
-msgstr ""
-"Carga valores ráster en las posiciones de puntos vectoriales a la tabla."
+msgstr "Carga a la tabla valores de ráster 3D en las posiciones de puntos vectoriales."
#: ../vector/v.what.rast3/main.c:82
-#, fuzzy
msgid "Name of existing 3D raster map to be queried"
-msgstr "Nombre del mapa ráster existente a consultar"
+msgstr "Nombre de mapa ráster 3D existente a consultar"
#: ../vector/v.what.rast3/main.c:135
-#, fuzzy, c-format
+#, c-format
msgid "Error opening 3D raster map <%s>"
-msgstr "Error al abrir el mapa ráster 3D <%s>"
+msgstr "Error al abrir mapa ráster 3D <%s>"
#: ../vector/v.what.rast3/main.c:144
-#, fuzzy
msgid "Column type not supported, please use a column with double type"
-msgstr "Tipo de columna no soportado (debe ser cadena)"
+msgstr "Tipo de columna no soportado, por favor use una columna de tipo double"
#: ../vector/v.what.rast3/main.c:215
-#, fuzzy, c-format
+#, c-format
msgid "%d point outside current region was skipped"
msgid_plural "%d points outside current region were skipped"
-msgstr[0] "%d puntos fuera de la región actual fueron omitidos"
+msgstr[0] "%d punto fuera de la región actual fue omitido"
msgstr[1] "%d puntos fuera de la región actual fueron omitidos"
#: ../vector/v.what.rast3/main.c:220
-#, fuzzy, c-format
+#, c-format
msgid "%d point without category was skipped"
msgid_plural "%d points without category were skipped"
-msgstr[0] "%d puntos sin categoría fueron omitidos"
+msgstr[0] "%d punto sin categoría fue omitido"
msgstr[1] "%d puntos sin categoría fueron omitidos"
#: ../vector/v.what.rast3/main.c:259
@@ -16337,58 +14792,55 @@
msgstr "Más puntos (%d) de categoría %d, el valor se establece a 'NULO'"
#: ../vector/v.what.rast3/main.c:329
-#, fuzzy, c-format
+#, c-format
msgid "%d category loaded from table"
msgid_plural "%d categories loaded from table"
-msgstr[0] "%d categorías cargadas de la tabla"
-msgstr[1] "%d categorías cargadas de la tabla"
+msgstr[0] "%d categoría cargadas desde tabla"
+msgstr[1] "%d categorías cargadas desde tabla"
#: ../vector/v.what.rast3/main.c:332
-#, fuzzy, c-format
+#, c-format
msgid "%d category loaded from vector"
msgid_plural "%d categories loaded from vector"
-msgstr[0] "%d categorías cargadas del vectorial"
-msgstr[1] "%d categorías cargadas del vectorial"
+msgstr[0] "%d categoría cargada desde vectorial"
+msgstr[1] "%d categorías cargadas desde vectorial"
#: ../vector/v.what.rast3/main.c:335
-#, fuzzy, c-format
+#, c-format
msgid "%d category from vector missing in table"
msgid_plural "%d categories from vector missing in table"
-msgstr[0] "%d categorías del vectorial faltan en la tabla"
+msgstr[0] "%d categoría del vectorial falta en la tabla"
msgstr[1] "%d categorías del vectorial faltan en la tabla"
#: ../vector/v.what.rast3/main.c:339
-#, fuzzy, c-format
+#, c-format
msgid "%d duplicate category in vector"
msgid_plural "%d duplicate categories in vector"
-msgstr[0] "%d categorías duplicadas en el vectorial"
+msgstr[0] "%d categoría duplicada en el vectorial"
msgstr[1] "%d categorías duplicadas en el vectorial"
#: ../vector/v.what.rast3/main.c:343
-#, fuzzy, c-format
+#, c-format
msgid "%d update error"
msgid_plural "%d update errors"
-msgstr[0] "%d errores al actualizar"
-msgstr[1] "%d errores al actualizar"
+msgstr[0] "%d error actualizado"
+msgstr[1] "%d errores actualizados"
#: ../vector/v.what.rast3/main.c:347
-#, fuzzy, c-format
+#, c-format
msgid "%d record updated."
msgid_plural "%d records updated."
-msgstr[0] "%d registros actualizados"
+msgstr[0] "%d registro actualizado"
msgstr[1] "%d registros actualizados"
#: ../vector/v.in.ogr/main.c:138
msgid "Imports vector data into a GRASS vector map using OGR library."
-msgstr ""
-"Importa datos vecotriales a mapas vectoriales de GRASS usando la librería "
-"OGR."
+msgstr "Importa datos vecotriales a mapas vectoriales de GRASS usando la librería OGR."
#: ../vector/v.in.ogr/main.c:144
#: ../locale/scriptstrings/v.import_to_translate.c:5
-#, fuzzy
msgid "Name of OGR datasource to be imported"
-msgstr "Mapa ráster a importar"
+msgstr "Nombre de fuente de datos OGR de salida a importar"
#: ../vector/v.in.ogr/main.c:145
msgid ""
@@ -16403,8 +14855,7 @@
#: ../vector/v.in.ogr/main.c:156
#: ../locale/scriptstrings/v.import_to_translate.c:7
msgid "OGR layer name. If not given, all available layers are imported"
-msgstr ""
-"Nombre de capa OGR. Si no se indica, se importan todas las capas disponibles."
+msgstr "Nombre de capa OGR. Si no se indica, se importan todas las capas disponibles."
#: ../vector/v.in.ogr/main.c:158
msgid ""
@@ -16417,14 +14868,12 @@
"\t\tArchivo MapInfo: nombre del archivo MapInfo"
#: ../vector/v.in.ogr/main.c:187
-#, fuzzy
msgid "Minimum size of area to be imported (square meters)"
-msgstr "Tamaño mínimo del área a importar (unidades cuadradas)"
+msgstr "Tamaño de área mínimo a importar (metros cuadrados)"
#: ../vector/v.in.ogr/main.c:189
msgid "Smaller areas and islands are ignored. Should be greater than snap^2"
-msgstr ""
-"Las áreas más pequeñas y las islas se ignorarán. Debería ser mayor que snap²"
+msgstr "Las áreas más pequeñas y las islas se ignorarán. Debería ser mayor que snap^2"
#: ../vector/v.in.ogr/main.c:195
msgid "Optionally change default input type"
@@ -16432,110 +14881,94 @@
#: ../vector/v.in.ogr/main.c:199
msgid "import area centroids as points"
-msgstr "importa centroides de áreas como puntos"
+msgstr "importar centroides de áreas como puntos"
#: ../vector/v.in.ogr/main.c:200
msgid "import area boundaries as lines"
-msgstr "importa bordes de área como líneas"
+msgstr "importar contorno de área como líneas"
#: ../vector/v.in.ogr/main.c:201
msgid "import lines as area boundaries"
-msgstr "importa líneas como bordes de áreas"
+msgstr "importar líneas como contornos de área"
#: ../vector/v.in.ogr/main.c:202
msgid "import points as centroids"
-msgstr "importa puntos como centroides"
+msgstr "importar puntos como centroides"
#: ../vector/v.in.ogr/main.c:211
#: ../locale/scriptstrings/v.import_to_translate.c:17
-#, fuzzy
msgid "Snapping threshold for boundaries (map units)"
-msgstr "Umbral de salto para contornos"
+msgstr "Umbral de autoensamblado para contornos (unidades de mapa)"
#: ../vector/v.in.ogr/main.c:212
#: ../locale/scriptstrings/v.import_to_translate.c:18
msgid "'-1' for no snap"
-msgstr "'-1' para sin autoensamblaje"
+msgstr "'-1' para no ensamblar"
#: ../vector/v.in.ogr/main.c:224
-msgid ""
-"List of column names to be used instead of original names, first is used for "
-"category column"
-msgstr ""
-"Lista de nombres de columna a usar en vez de los originales. El primero se "
-"usa para la columna de categoría"
+msgid "List of column names to be used instead of original names, first is used for category column"
+msgstr "Lista de nombres de columna a usar en vez de los originales. El primero se usa para la columna de categoría"
#: ../vector/v.in.ogr/main.c:233
#: ../locale/scriptstrings/v.import_to_translate.c:14
#: ../locale/scriptstrings/db.in.ogr_to_translate.c:11
-#, fuzzy
msgid "Encoding value for attribute data"
-msgstr "Error al leer el archivo ASCII: '%s'"
+msgstr "Valor de codificación para atributo de datos"
#: ../vector/v.in.ogr/main.c:235
#: ../locale/scriptstrings/v.import_to_translate.c:15
msgid "Overrides encoding interpretation, useful when importing ESRI Shapefile"
-msgstr ""
+msgstr "Anula interpretación de codificación, útil cuando se importa Shapefile de ESRI"
#: ../vector/v.in.ogr/main.c:243
msgid "Name of column used for categories"
msgstr "Nombre de la columna para categorías"
#: ../vector/v.in.ogr/main.c:245
-msgid ""
-"If not given, categories are generated as unique values and stored in 'cat' "
-"column"
-msgstr ""
+msgid "If not given, categories are generated as unique values and stored in 'cat' column"
+msgstr "Si no se da, las categorías son generadas como valores únicos y guardados en la columna 'cat'"
#: ../vector/v.in.ogr/main.c:250
msgid "Name of geometry column"
msgstr "Nombre de la columna de geometría"
#: ../vector/v.in.ogr/main.c:251
-#, fuzzy
msgid "If not given, all geometry columns from the input are used"
-msgstr "Si no se da se usa el nombre del mapa de entrada"
+msgstr "Si no se da, se usarán todas las columnas de geometría de la entrada"
#: ../vector/v.in.ogr/main.c:256
#: ../locale/scriptstrings/v.import_to_translate.c:25
-#, fuzzy
msgid "List supported OGR formats and exit"
-msgstr "Listar los formatos soportados y salir"
+msgstr "Enlistar formatos OGR soportados y salida"
#: ../vector/v.in.ogr/main.c:262
#: ../locale/scriptstrings/v.import_to_translate.c:26
-#, fuzzy
msgid "List available OGR layers in data source and exit"
-msgstr "Listar las capas disponibles en la fuente de datos y salir"
+msgstr "Enlistar las capas OGR disponibles en la fuente de datos y salir"
#: ../vector/v.in.ogr/main.c:269
msgid "Do not clean polygons (not recommended)"
msgstr "No limpiar polígonos (no recomendado)"
#: ../vector/v.in.ogr/main.c:274
-#, fuzzy
msgid "Force 2D output even if input is 3D"
-msgstr "Forzar salida de valores enteros"
+msgstr "Forzar salida 2D aunque la entrada sea 3D"
#: ../vector/v.in.ogr/main.c:286
#: ../locale/scriptstrings/v.import_to_translate.c:28
#: ../locale/scriptstrings/r.import_to_translate.c:32
#, fuzzy
msgid "Assume that the dataset has the same projection as the current location"
-msgstr ""
-"No se pueden obtener unidades de la proyección de la localización actual"
+msgstr "No se pueden obtener unidades de la proyección de la localización actual"
#: ../vector/v.in.ogr/main.c:291 ../raster/r.in.gdal/main.c:185
-#, fuzzy
msgid "Perform projection check only and exit"
-msgstr "Imprimir los parámetros de la conexión actual y salir"
+msgstr "Solamente realizar revisión de proyección y salir"
#: ../vector/v.in.ogr/main.c:305 ../raster/r.external/main.c:109
#: ../raster/r.in.gdal/main.c:193
msgid "Also updates the default region if in the PERMANENT mapset"
-msgstr ""
-"También actualiza la región predeterminada si está en el directorio de mapas "
-"PERMANENT"
+msgstr "También actualiza la región predeterminada si está en el directorio de mapas PERMANENT"
#: ../vector/v.in.ogr/main.c:310
msgid "Change column names to lowercase characters"
@@ -16548,67 +14981,62 @@
#: ../vector/v.in.ogr/main.c:413
#, c-format
-msgid ""
-"Option <%s> will be ignored. OGR doesn't support it for selected format (%s)."
-msgstr ""
+msgid "Option <%s> will be ignored. OGR doesn't support it for selected format (%s)."
+msgstr "Opción <%s> será ignorada. OGR no lo soporta para el formato seleccionado (%s)."
#: ../vector/v.in.ogr/main.c:418
#, c-format
-msgid ""
-"Option <%s> will be ignored. Multiple geometry fields are supported by GDAL "
-">= 1.11"
-msgstr ""
+msgid "Option <%s> will be ignored. Multiple geometry fields are supported by GDAL >= 1.11"
+msgstr "Opción <%s> será ignorada. Múltiples campos de geometría son soportados por GDAL >=1.11"
#: ../vector/v.in.ogr/main.c:431
-#, fuzzy, c-format
+#, c-format
msgid "Encoding value not supported by OGR driver <%s>"
-msgstr "La posición del cursor no está soportada por el controlador MySQL"
+msgstr "Valor codificado no soportado por el controlador OGR <%s>"
#: ../vector/v.in.ogr/main.c:440
-#, fuzzy, c-format
+#, c-format
msgid "Data source <%s> (format '%s') contains %d layers:"
-msgstr "El origen de datos contiene %d capas:"
+msgstr "Fuente de datos <%s> (formato '%s') contiene %d capas:"
#: ../vector/v.in.ogr/main.c:495
-#, fuzzy
msgid "No OGR layers available"
-msgstr "Capa <%s> no disponible"
+msgstr "No hay capas OGR disponibles"
#: ../vector/v.in.ogr/main.c:498
-#, fuzzy, c-format
+#, c-format
msgid "All available OGR layers will be imported into vector map <%s>"
-msgstr "No se puede obtener información de la capa para el mapa vectorial <%s>"
+msgstr "Todos las capas OGR disponibles serán importadas al mapa vectorial <%s>"
#: ../vector/v.in.ogr/main.c:521 ../vector/v.in.ogr/main.c:857
-#, fuzzy, c-format
+#, c-format
msgid "Geometry column <%s> not found in OGR layer <%s>"
-msgstr "Columna <%s> no encontrada en la tabla <%s>"
+msgstr "Columna geometría <%s> no encontrada en capa OGR <%s>"
#: ../vector/v.in.ogr/main.c:722
msgid "The region flag is applied only to the first OGR layer"
-msgstr ""
+msgstr "La bandera region solamente es aplicada a la primer capa OGR"
#: ../vector/v.in.ogr/main.c:732
msgid "The current region does not overlap with OGR input. Nothing to import."
-msgstr ""
+msgstr "La región actual no se sobrelapa con OGR de entrada. Nada qué importar."
#: ../vector/v.in.ogr/main.c:759
msgid "The 'spatial' option is applied only to the first OGR layer"
-msgstr ""
+msgstr "La opción 'spatial' es aplicada solamente con la primer capa OGR"
#: ../vector/v.in.ogr/main.c:790
-msgid ""
-"The 'spatial' parameters do not overlap with OGR input. Nothing to import."
-msgstr ""
+msgid "The 'spatial' parameters do not overlap with OGR input. Nothing to import."
+msgstr "Los parámetros 'spatial' no sobrelapan con entrada OGR. No qué importar."
#: ../vector/v.in.ogr/main.c:824
msgid "The 'where' option is applied only to the first OGR layer"
-msgstr ""
+msgstr "La opción 'where' es aplicada solamente a la primer capa OGR"
#: ../vector/v.in.ogr/main.c:867
#, c-format
msgid "Check if OGR layer <%s> contains polygons..."
-msgstr ""
+msgstr "Revise si capa OGR <%s> contiene polígonos..."
#: ../vector/v.in.ogr/main.c:903
#, c-format
@@ -16616,84 +15044,72 @@
msgstr "Distancia de división de límites en unidades de mapa: %G"
#: ../vector/v.in.ogr/main.c:933
-#, fuzzy, c-format
+#, c-format
msgid "Using temporary vector <%s>"
-msgstr "No se puede crear el mapa vectorial <%s>"
+msgstr "Usando vectorial temporal <%s>"
#: ../vector/v.in.ogr/main.c:969
-#, fuzzy, c-format
+#, c-format
msgid "Key column '%s' not found"
msgstr "Columna clave '%s' no encontrada"
#: ../vector/v.in.ogr/main.c:981
-#, fuzzy, c-format
+#, c-format
msgid "Key column '%s' is not integer"
-msgstr "La columna clave debe ser de tipo integer"
+msgstr "La columna '%s' no es de tipo entero"
#: ../vector/v.in.ogr/main.c:1046
-#, fuzzy, c-format
+#, c-format
msgid "Column name <%s> renamed to <%s>"
+msgstr "Nombre de columna <%s> renombrada como <%s>"
#: ../vector/v.in.ogr/main.c:1076
-#, fuzzy, c-format
+#, c-format
msgid "Writing column <%s> with integer 64 as integer 32"
-msgstr ""
-"Escribiendo columna <%s> con longitud fija de %d caracteres (puede quedar "
-"truncada)"
+msgstr "Escribiendo columna <%s> con entero 64 como entero 32"
#: ../vector/v.in.ogr/main.c:1089
#, c-format
msgid "Writing column <%s> with fixed length %d chars (may be truncated)"
-msgstr ""
-"truncada)"
+msgstr "Escribiendo columna <%s> con longitud fija de %d caracteres (puede quedar truncada)"
#: ../vector/v.in.ogr/main.c:1112
#, c-format
-msgid ""
-"Width for column %s set to 255 (was not specified by OGR), some strings may "
-"be truncated!"
-msgstr ""
-"Anchura para la columna %s establecida a 255 (no fue especificada por OGR). "
-"¡Algunas cadenas pueden quedar truncadas!"
+msgid "Width for column %s set to 255 (was not specified by OGR), some strings may be truncated!"
+msgstr "Anchura para la columna %s establecida a 255 (no fue especificada por OGR). ¡Algunas cadenas pueden quedar truncadas!"
#: ../vector/v.in.ogr/main.c:1124
#, c-format
msgid "Writing column %s with fixed length %d chars (may be truncated)"
-msgstr ""
-"Escribiendo la columna %s con longitud fija de %d caracteres (puede quedar "
-"truncada)"
+msgstr "Escribiendo la columna %s con longitud fija de %d caracteres (puede quedar truncada)"
#: ../vector/v.in.ogr/main.c:1128
-#, fuzzy, c-format
+#, c-format
msgid "Column type (Ogr_ftype: %d) not supported (Ogr_fieldname: %s)"
-msgstr "Tipo de columna no soportado (%s)"
+msgstr "Tipo de columna (Ogr_fyle: %d) no soportado (Ogr_fieldname: %s)"
#: ../vector/v.in.ogr/main.c:1169
-#, fuzzy, c-format
+#, c-format
msgid "Importing %d features (OGR layer <%s>)..."
-msgstr "Importando elementos %d del mapa..."
+msgstr "Importando elementos %d (capa OGR <%s>)..."
#: ../vector/v.in.ogr/main.c:1307
-#, fuzzy, c-format
+#, c-format
msgid "%d %s without geometry skipped"
-msgstr "%d %s sin geometría"
+msgstr "%d %s sin geometría omitidos"
#: ../vector/v.in.ogr/main.c:1334
-#, fuzzy
msgid "Cleaning polygons"
-msgstr "Rompiendo polígonos..."
+msgstr "Limpiando polígonos"
#: ../vector/v.in.ogr/main.c:1338
-#, fuzzy, c-format
+#, c-format
msgid "Snapping boundaries (threshold = %.3e)..."
-msgstr "Ajustar contornos (umbral = %.3e):"
+msgstr "Ensamblar contornos (umbral = %.3e):"
#: ../vector/v.in.ogr/main.c:1382
-#, fuzzy
msgid "Merging boundaries..."
-msgstr "Rompiendo los bordes..."
+msgstr "Uniendo contornos..."
#: ../vector/v.in.ogr/main.c:1387
#, fuzzy
@@ -16701,26 +15117,18 @@
msgstr "Cambiar nodos colgantes de los contornos a líneas:"
#: ../vector/v.in.ogr/main.c:1400
-#, fuzzy
msgid "Changing boundary bridges to lines..."
-msgstr "Cambiar puentes de contornos a líneas:"
+msgstr "Cambiando puentes de contornos a líneas..."
#: ../vector/v.in.ogr/main.c:1444
-#, fuzzy, c-format
+#, c-format
msgid "Finding centroids for OGR layer <%s>..."
-msgstr "Encontrar centroides para capa: %s"
+msgstr "Encontrando centroides para capa OGR <%s>..."
#: ../vector/v.in.ogr/main.c:1529
#, c-format
-msgid ""
-"%d areas represent more (overlapping) features, because polygons overlap in "
-"input layer(s). Such areas are linked to more than 1 row in attribute table. "
-"The number of features for those areas is stored as category in layer %d"
-msgstr ""
-"%d áreas representan más elementos (solapados), porque los polígonos solapan "
-"en la capa(s) de entrada. Estas áreas están enlazadas a más de una fila en "
-"la tabla de atributos. El número de elementos para estas áreas se guarda "
-"como categoría en la capa %d"
+msgid "%d areas represent more (overlapping) features, because polygons overlap in input layer(s). Such areas are linked to more than 1 row in attribute table. The number of features for those areas is stored as category in layer %d"
+msgstr "%d áreas representan más elementos (solapados), porque los polígonos solapan en la capa(s) de entrada. Estas áreas están enlazadas a más de una fila en la tabla de atributos. El número de elementos para estas áreas se guarda como categoría en la capa %d"
#: ../vector/v.in.ogr/main.c:1539
#, c-format
@@ -16764,50 +15172,50 @@
#: ../vector/v.in.ogr/main.c:1629
msgid "Some input polygons are overlapping each other."
-msgstr ""
+msgstr "Algunos de los polígonos de entrada se sobrelapan entre sí."
#: ../vector/v.in.ogr/main.c:1630
msgid "If overlapping is not desired, the data need to be cleaned."
-msgstr ""
+msgstr "Si no se quiere sobrelapamiento, los datos necesitan ser limpiados."
#: ../vector/v.in.ogr/main.c:1633 ../vector/v.in.ogr/main.c:1662
msgid "The input could be cleaned by snapping vertices to each other."
-msgstr ""
+msgstr "La entrada puede ser limpiada ensamblando vértices entre ellos."
#: ../vector/v.in.ogr/main.c:1634 ../vector/v.in.ogr/main.c:1657
#: ../vector/v.in.ogr/main.c:1663
#, c-format
msgid "Estimated range of snapping threshold: [%g, %g]"
-msgstr ""
+msgstr "Rango estimado para umbral de ensamblado: [%g, %g]"
#: ../vector/v.in.ogr/main.c:1638
#, c-format
msgid "Try to import again, snapping with at least %g: 'snap=%g'"
-msgstr ""
+msgstr "Trate de importar de nuevo, ensamblando con al menos %g: 'snap=%g'"
#: ../vector/v.in.ogr/main.c:1642
#, c-format
msgid "Try to import again, snapping with %g: 'snap=%g'"
-msgstr ""
+msgstr "Trate de importar de nuevo, ensamblando con %g: 'snap=%g'"
#: ../vector/v.in.ogr/main.c:1646 ../vector/v.in.ogr/main.c:1659
msgid "Manual cleaning may be needed."
-msgstr ""
+msgstr "Es posible que sea necesario limpiar manualmente."
#: ../vector/v.in.ogr/main.c:1650
#, c-format
msgid "%d input polygons got lost during import."
-msgstr ""
+msgstr "%d polígonos de entrada fueron perdidos durante la importación."
#: ../vector/v.in.ogr/main.c:1653
#, c-format
msgid "%d additional areas where created during import."
-msgstr ""
+msgstr "%d áreas adicionales fueron creadas durante la importación."
#: ../vector/v.in.ogr/main.c:1656
-#, fuzzy, c-format
+#, c-format
msgid "The snapping threshold %g might be too large."
+msgstr "El umbral %g para ensamblado puede ser demasiado grande."
#: ../vector/v.in.ogr/main.c:1672 ../vector/v.in.ascii/main.c:546
#: ../vector/v.in.ascii/main.c:549
@@ -16815,15 +15223,14 @@
msgstr "Falló importación."
#: ../vector/v.in.ogr/main.c:1685
-#, fuzzy, c-format
+#, c-format
msgid "Unable to drop table: '%s'"
-msgstr "No se puede eliminar la tabla: %s"
+msgstr "No ha sido posible eliminar tabla: '%s'"
#: ../vector/v.in.ogr/main.c:1719 ../raster/r.external/window.c:93
#: ../raster/r.in.gdal/main.c:892
-#, fuzzy
msgid "Default region for this location updated"
-msgstr "¡Información de la proyección actualizada!"
+msgstr "Se actualizó la región predeterminada para esta Localización"
#: ../vector/v.in.ogr/main.c:1722 ../raster/r.external/window.c:96
#: ../raster/r.in.gdal/main.c:895
@@ -16831,59 +15238,49 @@
msgstr "Actualizada la región para el directorio de mapas actual"
#: ../vector/v.in.ogr/main.c:1726
-#, fuzzy
-msgid ""
-"Input data contains 3D features. Created vector is 2D only, disable -2 flag "
-"to import 3D vector."
-msgstr ""
-"Los datos de entrada contienen elementos 3D. El vectorial creado es 2D. Use "
-"la opción -z para importar vectoriales 3D."
+msgid "Input data contains 3D features. Created vector is 2D only, disable -2 flag to import 3D vector."
+msgstr "Datos de entrada contienen elementos 3D. El vectorial creado es 2D. Use la bandera -2 para importar vectorial 3D."
#: ../vector/v.in.ogr/geom.c:76 ../vector/v.in.ogr/geom.c:261
#: ../vector/v.in.ogr/geom.c:275 ../vector/v.in.ogr/geom.c:304
#: ../vector/v.in.ogr/geom.c:352
-#, fuzzy, c-format
+#, c-format
msgid "Skipping empty geometry feature %d"
-msgstr "Esquivando elemento geométrico vacío"
+msgstr "Omitiendo elemento geométrico vacío %d"
#: ../vector/v.in.ogr/geom.c:199 ../vector/v.in.ogr/geom.c:220
-#, fuzzy
msgid "Unable to read part of geometry"
-msgstr "No se puede leer parte de la geometría"
+msgstr "No ha sido posible escribir parte de geometría"
#: ../vector/v.in.ogr/geom.c:320
-#, fuzzy, c-format
+#, c-format
msgid "Feature (cat %d): degenerated polygon (%d vertices)"
-msgstr "Degenerar polígono ([%d] vértices)"
+msgstr "Elemento (cat %d): polígono degenerado (%d vértices)"
#: ../vector/v.in.ogr/geom.c:366
-#, fuzzy, c-format
+#, c-format
msgid "Degenerate island (%d vertices)"
-msgstr "Degenerar isla ([%d] vértices)"
+msgstr "Degenerar isla (%d vértices)"
#: ../vector/v.in.ogr/geom.c:400
-#, fuzzy
msgid "Unable calculate centroid"
-msgstr "No es posible calcular el centroide de área"
+msgstr "No ha sido posible calcular centroide"
#: ../vector/v.in.ogr/geom.c:431
msgid "No centroid written for polygon with 0 vertices"
msgstr "Ningún centroide escrito para polígonos con 0 vértices"
#: ../vector/v.in.ogr/geom.c:452
-#, fuzzy
msgid "Unable to write part of geometry"
-msgstr "No se puede escribir parte de la geometría"
+msgstr "No ha sido posible escribir parte de la geometría"
#: ../vector/v.in.ogr/geom.c:458
msgid "Unknown geometry type"
msgstr "Tipo de geometría desconocido"
#: ../vector/v.in.dxf/main.c:68
-#, fuzzy
msgid "Converts file in DXF format to GRASS vector map."
-msgstr ""
-"Convierte archivos en formato DXF a formato de mapa vectorial de GRASS."
+msgstr "Convierte archivo en formato DXF a mapa vectorial de GRASS."
#: ../vector/v.in.dxf/main.c:72
msgid "Ignore the map extent of DXF file"
@@ -16895,9 +15292,8 @@
msgstr "Importar"
#: ../vector/v.in.dxf/main.c:84
-#, fuzzy
msgid "List available DXF layers and exit"
-msgstr "Listar las capas disponibles y salir"
+msgstr "Enlistar capas DXF disponibles y salir"
#: ../vector/v.in.dxf/main.c:85 ../vector/v.in.dxf/main.c:92
#: ../vector/v.in.dxf/main.c:97 ../vector/v.in.dxf/main.c:110
@@ -16905,9 +15301,8 @@
msgstr "Capas DXF"
#: ../vector/v.in.dxf/main.c:91
-#, fuzzy
msgid "Invert selection by DXF layers (don't import layers in list)"
-msgstr "Invertir la selección por capas (no importar las capas en la lista)"
+msgstr "Invertir la selección por capas DXF (no importar capas en lista)"
#: ../vector/v.in.dxf/main.c:96
msgid "Import all objects into one layer"
@@ -16918,14 +15313,12 @@
msgstr "Ruta al archivo DXF de entrada"
#: ../vector/v.in.dxf/main.c:109
-#, fuzzy
msgid "List of DXF layers to import (default: all)"
-msgstr "Lista de capas a importar"
+msgstr "Lista de capas DXF a importar (predeterminado: todas)"
#: ../vector/v.in.dxf/main.c:124
-#, fuzzy
msgid "Please specify list of DXF layers to exclude"
-msgstr "Por favor, especifique una columna Z razonable"
+msgstr "Por favor especifique lista de capas DXF a excluir"
#: ../vector/v.in.dxf/main.c:128
#, c-format
@@ -16933,9 +15326,8 @@
msgstr "No se puede abrir archivo DXF <%s>"
#: ../vector/v.in.dxf/main.c:131
-#, fuzzy
msgid "Layer number: layer name / GRASS compliant name"
-msgstr "Número de capa: nombre de la capa / "
+msgstr "Número de capa: nombre de la capa / nombre GRASS válido"
#: ../vector/v.in.dxf/main.c:165
msgid "Building topology failed"
@@ -16946,9 +15338,8 @@
msgstr "¡No se pudo importar el archivo DXF!"
#: ../vector/v.in.dxf/add_polyline.c:47
-#, fuzzy
msgid "vertices following flag missing"
-msgstr "Faltan los vértices que siguen a "
+msgstr "faltan los vértices que siguen a la bandera"
#: ../vector/v.in.dxf/write_vect.c:52
msgid "Entity handle truncated to 16 characters."
@@ -16995,19 +15386,16 @@
msgstr "Nombre o "
#: ../vector/v.net.timetable/main.c:315
-#, fuzzy
msgid "Name of column with route ids"
-msgstr "Nombre de la column name con los ids de la ruta"
+msgstr "Nombre de la columna con las ids de la ruta"
#: ../vector/v.net.timetable/main.c:322
-#, fuzzy
msgid "Name of column with stop timestamps"
-msgstr "Nombre de la columna con parámetros de suavizado"
+msgstr "Nombre de la columna que tiene marcas de tiempo de paradas"
#: ../vector/v.net.timetable/main.c:328
-#, fuzzy
msgid "Name of column with stop ids"
-msgstr "Nombre de la columna a mostrar"
+msgstr "Nombre de la columna que tiene ids de paradas"
#: ../vector/v.net.timetable/main.c:334
#, fuzzy
@@ -17039,18 +15427,14 @@
#: ../vector/v.to.db/main.c:48
#, c-format
-msgid ""
-"Vector map <%s> not found in the current mapset. Unable to modify vector "
-"maps from different mapsets."
-msgstr ""
+msgid "Vector map <%s> not found in the current mapset. Unable to modify vector maps from different mapsets."
+msgstr "Mapa vectorial <%s> no encontrado en el Directorio de mapas actual. No es posible modificar mapas vectoriales de Directorios de mapas distintos."
#: ../vector/v.to.db/main.c:65 ../vector/v.to.db/query.c:83
#: ../vector/v.to.db/update.c:28 ../vector/v.to.db/update.c:32
#, c-format
msgid "Database connection not defined for layer %d. Use v.db.connect first."
-msgstr ""
-"Conexión a base de datos no definida para la capa %d. Use v.db.connect "
-"primero."
+msgstr "Conexión a base de datos no definida para la capa %d. Use v.db.connect primero."
#: ../vector/v.to.db/main.c:105
#, fuzzy, c-format
@@ -17058,16 +15442,12 @@
msgstr "No se encuentra la tabla de color del mapa raster <%s>"
#: ../vector/v.to.db/parse.c:36
-#, fuzzy
msgid "Layer number or name (write to)"
-msgstr "Nombre del mapa vectorial de entrada"
+msgstr "Número o nombre de capa (write to)"
#: ../vector/v.to.db/parse.c:43
-#, fuzzy
msgid "For coor valid point/centroid, for length valid line/boundary"
-msgstr ""
-"Tipo de elementos (para coordenadas válido punto/centroide, para longitud "
-"válido línea/perímetro)"
+msgstr "Para coordenada punto/centroide válido, para longitud valida línea/contorno"
#: ../vector/v.to.db/parse.c:54
msgid "Value to upload"
@@ -17075,64 +15455,59 @@
#: ../vector/v.to.db/parse.c:72
msgid "insert new row for each category if doesn't exist yet"
-msgstr ""
+msgstr "insertar nueva fila para cada categoría si es que no existe todavía"
#: ../vector/v.to.db/parse.c:73
-#, fuzzy
msgid "area size"
-msgstr "área"
+msgstr "tamaño de área"
#: ../vector/v.to.db/parse.c:74
msgid ""
"compactness of an area, calculated as \n"
" compactness = perimeter / (2 * sqrt(PI * area))"
msgstr ""
+"Compactación de un área, calculada como \n"
+" compactación = perímetro / (2 * sqrt(PI * área))"
#: ../vector/v.to.db/parse.c:76
msgid ""
"fractal dimension of boundary defining a polygon, calculated as \n"
" fd = 2 * (log(perimeter) / log(area))"
msgstr ""
+"dimensión fractal de contorno que define un polígono ,calculada como \n"
+" fd = 2 * (log(perímetro) / log(área))"
#: ../vector/v.to.db/parse.c:78
-#, fuzzy
msgid "perimeter length of an area"
+msgstr "longitud de perímetro de un área"
#: ../vector/v.to.db/parse.c:79
-#, fuzzy
msgid "line length"
-msgstr "Longitud de página no admitida"
+msgstr "longitud de línea"
#: ../vector/v.to.db/parse.c:80
-#, fuzzy
msgid "number of features for each category"
-msgstr "No es posible obtener la altura para la categoría del elemento %d"
+msgstr "cantidad de elementos para cada categoría"
#: ../vector/v.to.db/parse.c:81
-#, fuzzy
msgid "point coordinates, X,Y or X,Y,Z"
-msgstr "Coordenadas de puntos seed"
+msgstr "coordenadas de puntos, X,Y o X,Y,Z"
#: ../vector/v.to.db/parse.c:82
msgid "line/boundary starting point coordinates, X,Y or X,Y,Z"
-msgstr ""
+msgstr "coordenadas X,Y o X,Y,Z de punto inicial de línea/contorno"
#: ../vector/v.to.db/parse.c:83
msgid "line/boundary end point coordinates, X,Y or X,Y,Z"
-msgstr ""
+msgstr "coordenadas X,Y o X,Y,Z de punto final de línea/contorno"
#: ../vector/v.to.db/parse.c:84
-msgid ""
-"categories of areas on the left and right side of the boundary, "
-"'query_layer' is used for area category"
-msgstr ""
+msgid "categories of areas on the left and right side of the boundary, 'query_layer' is used for area category"
+msgstr "categorías de áreas al lado derecho o izquierdo del contorno, 'query_layer' es usado para categoría del área"
#: ../vector/v.to.db/parse.c:86
-msgid ""
-"result of a database query for all records of the geometry(or geometries) "
-"from table specified by 'query_layer' option"
-msgstr ""
+msgid "result of a database query for all records of the geometry(or geometries) from table specified by 'query_layer' option"
+msgstr "resultado de una consulta de una base de datos para todos los registros de la geometría (o geometrías) desde tabla especificada por opción 'query_layer'"
#: ../vector/v.to.db/parse.c:88
#, fuzzy
@@ -17140,15 +15515,12 @@
msgstr "Mapa de salida: factor de inclinación de la pendiente (S) para USLE"
#: ../vector/v.to.db/parse.c:89
-msgid ""
-"line sinuousity, calculated as line length / distance between end points"
-msgstr ""
+msgid "line sinuousity, calculated as line length / distance between end points"
+msgstr "sinuosidad de línea, calculada como longitud de línea / distancia entre puntos"
#: ../vector/v.to.db/parse.c:90
-msgid ""
-"line azimuth, calculated as angle between North direction and endnode "
-"direction at startnode"
-msgstr ""
+msgid "line azimuth, calculated as angle between North direction and endnode direction at startnode"
+msgstr "azimut de línea, calculado como el ángulo entre la dirección norte y la dirección del nodo final desde el nodo inicial"
#: ../vector/v.to.db/parse.c:94
#, fuzzy
@@ -17156,9 +15528,8 @@
msgstr "Nombre de la columna"
#: ../vector/v.to.db/parse.c:103
-#, fuzzy
msgid "Query layer number or name (read from)"
-msgstr "Número de capa"
+msgstr "Consultar capa número o nombre (leidos desde)"
#: ../vector/v.to.db/parse.c:109
msgid "Name of attribute column used for 'query' option"
@@ -17169,24 +15540,20 @@
msgstr "Ej.: 'categoría', 'cuenta(*)', 'suma(valores)'"
#: ../vector/v.to.db/parse.c:115
-#, fuzzy
msgid "Field separator for print mode"
-msgstr "Separador de campos (modo de puntos)"
+msgstr "Separador de campos para modo de impresión"
#: ../vector/v.to.db/parse.c:120
msgid "Print only"
msgstr "Sólo imprimir"
#: ../vector/v.to.db/parse.c:126
-#, fuzzy
msgid "Only print SQL statements"
-msgstr "Sólo imprimir sentencias SQL"
+msgstr "Mostrar solamente sentencias SQL"
#: ../vector/v.to.db/parse.c:132
-#, fuzzy
msgid "Print also totals for option length, area, or count"
-msgstr ""
-"En modo impresión imprime totales para las opciones: longitud,área,cuenta"
+msgstr "Mostrar también totales para opción length, area o count"
#: ../vector/v.to.db/parse.c:178
msgid "This option requires one column"
@@ -17222,29 +15589,21 @@
#: ../vector/v.to.db/query.c:109
#, c-format
-msgid ""
-"Query for category '0' (no category) was not executed because of too many "
-"(%d) query categories. All later reported values for cat 0 are not valid."
-msgstr ""
-"La consulta de categorías '0' (sin categoría) no se ejecutó debido a "
-"demasiadas categorías de consulta (%d). Todos los valores anteriores "
-"informados para la categoría 0 no son válidos."
+msgid "Query for category '0' (no category) was not executed because of too many (%d) query categories. All later reported values for cat 0 are not valid."
+msgstr "La consulta de categorías '0' (sin categoría) no se ejecutó debido a demasiadas categorías de consulta (%d). Todos los valores anteriores informados para la categoría 0 no son válidos."
#: ../vector/v.to.db/query.c:146
#, c-format
msgid "Multiple query results, output value set to NULL (category [%d])"
-msgstr ""
-"Múltiples resultados de la consulta, valores de salida establecidos a NULO "
-"(categoría [%d])"
+msgstr "Múltiples resultados de la consulta, valores de salida establecidos a NULO (categoría [%d])"
#: ../vector/v.to.db/query.c:153
msgid "Unable to fetch record"
msgstr "No se puede recuperar el registro"
#: ../vector/v.to.db/report.c:13
-#, fuzzy
msgid "No totals for selected option"
-msgstr " Ningún monitor seleccionado"
+msgstr "No hay totales para la opción seleccionada"
#: ../vector/v.to.db/report.c:201
#, c-format
@@ -17259,15 +15618,12 @@
#: ../vector/v.to.db/report.c:208
#, c-format
msgid "%d categories read from vector map exist in selection from table"
-msgstr ""
-"%d categorías leídas del mapa vectorial existen en la selección de la tabla"
+msgstr "%d categorías leídas del mapa vectorial existen en la selección de la tabla"
#: ../vector/v.to.db/report.c:211
#, c-format
msgid "%d categories read from vector map don't exist in selection from table"
-msgstr ""
-"%d categorías leídas del mapa vectorial no existen en la selección de la "
-"tabla"
+msgstr "%d categorías leídas del mapa vectorial no existen en la selección de la tabla"
#: ../vector/v.to.db/report.c:213
#, c-format
@@ -17275,9 +15631,9 @@
msgstr "%d registros actualizados/insertados (capa %d)"
#: ../vector/v.to.db/report.c:216
-#, fuzzy, c-format
+#, c-format
msgid "%d update/insert errors (layer %d)"
-msgstr "%d errores de actualización/inserción"
+msgstr "%d actualizar/insertar errores (capa %d)"
#: ../vector/v.to.db/report.c:219
#, c-format
@@ -17294,9 +15650,9 @@
msgstr "Más elementos de la categoría %d, nada cargado a la base de datos"
#: ../vector/v.to.db/update.c:214
-#, fuzzy, c-format
+#, c-format
msgid "Record (cat %d) already exists (not inserted)"
-msgstr "Categoría [%d]: la fila ya existe (no se inserta)"
+msgstr "Registro (cat %d) ya existe (no insertado)"
#: ../vector/v.kernel/main.c:68
#, c-format
@@ -17308,65 +15664,50 @@
msgstr "densidad kernel"
#: ../vector/v.kernel/main.c:111
-#, fuzzy
msgid "point density"
-msgstr "densidad kernel"
+msgstr "densidad de puntos"
#: ../vector/v.kernel/main.c:112
msgid "heatmap"
-msgstr ""
+msgstr "mapa de calor"
#: ../vector/v.kernel/main.c:113
msgid "hotspot"
-msgstr ""
+msgstr "punto caliente"
#: ../vector/v.kernel/main.c:115
-#, fuzzy
msgid "Generates a raster density map from vector points map."
-msgstr "Genera un mapa de puntos vectorial 2D/3D de GRASS de forma aleatoria."
+msgstr "Genera un mapa ráster de densidad a partir de mapa vectorial de puntos."
#: ../vector/v.kernel/main.c:116
-#, fuzzy
-msgid ""
-"Density is computed using a moving kernel. Optionally generates a vector "
-"density map on a vector network."
-msgstr ""
-"Genera un mapa raster de densidad a partir de datos de puntos vectoriales "
-"usando un kernel de Gauss isotrópico 2D en movimiento u opcionalmente genera "
-"un mapa vectorial de densidad en una red vectorial con un kernel 1D."
+msgid "Density is computed using a moving kernel. Optionally generates a vector density map on a vector network."
+msgstr "La densidad se calcula usando un kernel móvil. Opcionalmente genera un mapa vectorial de densidad o una red vectorial."
#: ../vector/v.kernel/main.c:120
-#, fuzzy
msgid "Name of input vector map with training points"
-msgstr "Vectorial de entrada con puntos de entrenamiento"
+msgstr "Nombre de mapa vectorial de entrada que contiene puntos de entrenamiento"
#: ../vector/v.kernel/main.c:125
-#, fuzzy
msgid "Name of input network vector map"
-msgstr "Mapa vectorial de red de entrada"
+msgstr "Nombre de mapa vectorial de red de entrada"
#: ../vector/v.kernel/main.c:128 ../vector/v.kernel/main.c:157
#: ../vector/v.kernel/main.c:165 ../vector/v.kernel/main.c:187
#: ../vector/v.kernel/main.c:212 ../vector/v.kernel/main.c:218
-#, fuzzy
msgid "Network"
-msgstr "vectorial, trabajo en red"
+msgstr "Red"
#: ../vector/v.kernel/main.c:135
-#, fuzzy
msgid "Name for output raster/vector map"
-msgstr "Nombre para el mapa ráster de salida"
+msgstr "Nombre para mapa ráster/vectorial de salida"
#: ../vector/v.kernel/main.c:136
-#, fuzzy
msgid "Outputs vector map if network map is given, otherwise raster map"
-msgstr ""
-"El nombre del mapa vectorial de salida <%s> no es un nombre válido de mapa"
+msgstr "Mapa vectorial de salida si se da un mapa de red, de otro modo mapa ráster"
#: ../vector/v.kernel/main.c:142
-#, fuzzy
msgid "Kernel radius in map units"
-msgstr "Distancia de buffer a lo largo del eje mayor en unidades de mapa"
+msgstr "Radio de kernel en unidades mapa"
#: ../vector/v.kernel/main.c:148
msgid "Discretization error in map units"
@@ -17389,50 +15730,32 @@
msgstr "Métodode los nodos"
#: ../vector/v.kernel/main.c:184
-#, fuzzy
msgid "No method applied at nodes with more than 2 arcs"
-msgstr ""
-"ninguno; No se ha aplicado ningún método a los nodos com más de 2 arcos; "
-"split; Partición igual (Okabe 2009) aplicada a los nodos;"
+msgstr "No se aplicó ningún método a los nodos con más de 2 arcos"
#: ../vector/v.kernel/main.c:185
msgid "Equal split (Okabe 2009) applied at nodes"
-msgstr ""
+msgstr "Dividición equitativa (Okabe 2009) aplicada en nodos"
#: ../vector/v.kernel/main.c:193
msgid "Kernel function"
msgstr "Función kernel"
#: ../vector/v.kernel/main.c:201
-#, fuzzy
-msgid ""
-"Try to calculate an optimal radius with given 'radius' taken as maximum "
-"(experimental)"
-msgstr ""
-"Intentar calcular una desviación estándar óptima con 'stddeviation tomado "
-"como máximo (experimental)"
+msgid "Try to calculate an optimal radius with given 'radius' taken as maximum (experimental)"
+msgstr "Intentar calcular un radio ótimo con 'radius' dado tomado como máximo (experimental)"
#: ../vector/v.kernel/main.c:206
-#, fuzzy
msgid "Only calculate optimal radius and exit (no map is written)"
-msgstr ""
-"Sólo calcular desviación estándar óptima y salir (no se escribe ningún mapa)"
+msgstr "Solamente calcular radio óptimo y salir (no se escribe ningún mapa)"
#: ../vector/v.kernel/main.c:211
-msgid ""
-"In network mode, normalize values by sum of density multiplied by length of "
-"each segment. Integral over the output map then gives 1.0 * mult"
-msgstr ""
-"En el modo de red, normalizar valores por la suma de densidades multiplicada "
-"por la longitud de cada segmento. Entonces la integral sobre el mapa de "
-"salida da 1.0 * mult"
+msgid "In network mode, normalize values by sum of density multiplied by length of each segment. Integral over the output map then gives 1.0 * mult"
+msgstr "En el modo de red, normalizar valores por la suma de densidades multiplicada por la longitud de cada segmento. Entonces la integral sobre el mapa de salida da 1.0 * mult"
#: ../vector/v.kernel/main.c:217
-#, fuzzy
msgid "In network mode, multiply the result by number of input points"
-msgstr ""
-"En el modo de red, multiplicar el resultado por el número de puntos de "
-"entrada."
+msgstr "En el modo de red, multiplicar el resultado por el número de puntos de entrada"
#: ../vector/v.kernel/main.c:236 ../raster/r.relief/main.c:194
#: ../raster/r.in.gdal/main.c:346 ../raster/r.in.gdal/main.c:693
@@ -17456,51 +15779,39 @@
msgstr "Función kernel desconocida"
#: ../vector/v.kernel/main.c:281
-msgid ""
-"Optimal standard deviation calculation is supported only for node method "
-"'none' and kernel function 'gaussian'."
-msgstr ""
-"El cálculo de la desviación estándar óptima es soportado solo por el método "
-"de nodos 'ninguno' y por la función kernel 'gaussiana'."
+msgid "Optimal standard deviation calculation is supported only for node method 'none' and kernel function 'gaussian'."
+msgstr "El cálculo de la desviación estándar óptima es soportado solo por el método de nodos 'ninguno' y por la función kernel 'gaussiana'."
#: ../vector/v.kernel/main.c:285
-msgid ""
-"Optimal standard deviation calculation is supported only for kernel function "
-"'gaussian'."
-msgstr ""
-"El cálculo de la desviación estándar óptima solo es soportado por la función "
-"kernel 'gaussiana'."
+msgid "Optimal standard deviation calculation is supported only for kernel function 'gaussian'."
+msgstr "El cálculo de la desviación estándar óptima solo es soportado por la función kernel 'gaussiana'."
#: ../vector/v.kernel/main.c:302
-#, fuzzy, c-format
+#, c-format
msgid "Standard deviation: %f"
-msgstr "Desviación estándar"
+msgstr "Desviación estándar: %f"
#: ../vector/v.kernel/main.c:307
-#, fuzzy, c-format
+#, c-format
msgid "Output raster map: resolution: %f\t%s\t%s"
-msgstr "Se requiere mapa raster de salida"
+msgstr "Mapa ráster de salida: resolución: %f\t%s\t%s"
#: ../vector/v.kernel/main.c:310
-#, fuzzy, c-format
+#, c-format
msgid "Output raster map resolution: %f"
+msgstr "Resolución de mapa ráster de salida: %f"
#: ../vector/v.kernel/main.c:358
-#, fuzzy, c-format
+#, c-format
msgid "%d point outside threshold"
msgid_plural "%d points outside threshold"
-msgstr[0] "%d puntos fuera del umbral"
+msgstr[0] "%d punto fuera del umbral"
msgstr[1] "%d puntos fuera del umbral"
#: ../vector/v.kernel/main.c:381
-#, fuzzy, c-format
-msgid ""
-"Automatic choice of smoothing parameter (radius), maximum possible value of "
-"radius is set to %f"
-msgstr ""
-"Elección automática de parámetro de suavizado (desviación estándar), el "
-"máximo valor posible de desviación estándar se estableció en %f"
+#, c-format
+msgid "Automatic choice of smoothing parameter (radius), maximum possible value of radius is set to %f"
+msgstr "Elección automática de parámetro de suavizado (radio), el máximo valor posible de radio se estableció en %f"
#: ../vector/v.kernel/main.c:388
#, c-format
@@ -17513,20 +15824,16 @@
msgstr "Número de puntos de entrada: %d."
#: ../vector/v.kernel/main.c:403
-#, fuzzy, c-format
+#, c-format
msgid "%d distance read from the map."
msgid_plural "%d distances read from the map."
-msgstr[0] "%d distancias leídas del mapa."
-msgstr[1] "%d distancias leídas del mapa."
+msgstr[0] "%d distancia leída desde el mapa."
+msgstr[1] "%d distancias leídas desde el mapa."
#: ../vector/v.kernel/main.c:408
#, c-format
-msgid ""
-"Distances between all points are beyond %e (4 * standard deviation), unable "
-"to calculate optimal value."
-msgstr ""
-"Las distancias entre todos los puntos están más allá de %e (4 * desviación "
-"estándar). No se puede calcular el valor óptimo."
+msgid "Distances between all points are beyond %e (4 * standard deviation), unable to calculate optimal value."
+msgstr "Las distancias entre todos los puntos están más allá de %e (4 * desviación estándar). No se puede calcular el valor óptimo."
#: ../vector/v.kernel/main.c:419
#, c-format
@@ -17534,25 +15841,19 @@
msgstr "Parámetro de suavizado óptimo (desviación estándar): %f."
#: ../vector/v.kernel/main.c:450
-#, fuzzy, c-format
+#, c-format
msgid "Writing output vector map using smooth parameter %f"
-msgstr ""
-"\n"
-"Escribiendo mapa vectorial de salida usando parámetro de suavizado=%f."
+msgstr "Escribiendo mapa vectorial de salida usando parámetro de suavizado %f"
#: ../vector/v.kernel/main.c:452 ../vector/v.kernel/main.c:562
-#, fuzzy, c-format
+#, c-format
msgid "Normalising factor %f"
-msgstr ""
-"\n"
-"Factor de normalización=%f."
+msgstr "Factor de normalización %f"
#: ../vector/v.kernel/main.c:560
-#, fuzzy, c-format
+#, c-format
msgid "Writing output raster map using smooth parameter %f"
-msgstr ""
-"\n"
-"Escribiendo mapa ráster de salida usando parámetro de suavizado=%f."
+msgstr "Escribiendo mapa ráster de salida usando parámetro de suavizado %f"
#: ../vector/v.kernel/main.c:612
#, c-format
@@ -17568,18 +15869,16 @@
msgstr "Modo de números de categoría"
#: ../vector/v.build.polylines/main.c:132
-#, fuzzy
msgid "Do not assign any category number to polyline"
-msgstr "No mostrar números de categoría"
+msgstr "No asignar ningún número de categoría a polilínea"
#: ../vector/v.build.polylines/main.c:133
msgid "Assign category number of first line to polyline"
-msgstr ""
+msgstr "Asignar número de categoría de primer línea a polilínea"
#: ../vector/v.build.polylines/main.c:134
-#, fuzzy
msgid "Assign multiple category numbers to polyline"
-msgstr "Asignar categorías únicas a nuevos puntos"
+msgstr "Asignar múltiples números de categoría a polilínea"
#: ../vector/v.build.polylines/main.c:135
#, fuzzy
@@ -17587,65 +15886,52 @@
msgstr "Crea línea paralela a las líneas vectoriales de entrada"
#: ../vector/v.build.polylines/main.c:231
-#, fuzzy, c-format
+#, c-format
msgid "%d line or boundaries found in input vector map"
msgid_plural "%d lines or boundaries found in input vector map"
-msgstr[0] "Encontradas %d líneas o contornos en el mapa vectorial <%s@%s>"
-msgstr[1] "Encontradas %d líneas o contornos en el mapa vectorial <%s@%s>"
+msgstr[0] "%d línea o contorno encontrado en mapa vectorial de entrada"
+msgstr[1] "%d líneas o contornos encontrados en mapa vectorial de entrada"
#: ../vector/v.build.polylines/main.c:235
-#, fuzzy, c-format
+#, c-format
msgid "%d polyline stored in output vector map"
msgid_plural "%d polylines stored in output vector map"
-msgstr[0] "%d polilíneas guardadas en mapa vectorial <%s@%s>"
-msgstr[1] "%d polilíneas guardadas en mapa vectorial <%s@%s>"
+msgstr[0] "%d polilínea guardada en mapa vectorial de salida"
+msgstr[1] "%d polilíneas guardadas en mapa vectorial de salida"
#: ../vector/v.to.points/main.c:61
-#, fuzzy
msgid "Creates points along input lines in new vector map with 2 layers."
-msgstr ""
-"Creaa puntos a lo largo de líneas de entrada en un nuevo vectorial con 2 "
-"capas."
+msgstr "Crea puntos a lo largo de líneas de entrada en nuevo vectorial con 2 capas."
#: ../vector/v.to.points/main.c:79
-#, fuzzy
msgid "Use line nodes or vertices only"
-msgstr "Escribir vértices de líneas"
+msgstr "Usar nodos de línea o vértices solamente"
#: ../vector/v.to.points/main.c:87
msgid "Maximum distance between points in map units"
msgstr "Distancia máxima entre puntos en unidades de mapa"
#: ../vector/v.to.points/main.c:91
-#, fuzzy
msgid "Interpolate points between line vertices (only for use=vertex)"
-msgstr "Interpolar puntos entre vértices de líneas"
+msgstr "Interpolar puntos entre vértices de línea (solamente para use=vertex)"
#: ../vector/v.to.points/main.c:232
#, c-format
-msgid ""
-"%d features without category in layer <%d> skipped. Note that features "
-"without category (usually boundaries) are not skipped when '%s=-1' is given."
-msgstr ""
+msgid "%d features without category in layer <%d> skipped. Note that features without category (usually boundaries) are not skipped when '%s=-1' is given."
+msgstr "%d elementos sin categoría en capa <%d> omitidos. Note que elementos sin categoría (normalmente contornos) no son omitidos cuando '%s=-1' es dado."
#: ../vector/v.to.points/main.c:282
-#, fuzzy, c-format
+#, c-format
msgid "%d points written to output vector map."
-msgstr "Escritos [%d] puntos en el mapa vectorial de salida"
+msgstr "%d puntos escritos en el mapa vectorial de salida."
#: ../vector/v.to.rast3/main.c:51
-#, fuzzy
msgid "Converts a vector map (only points) into a 3D raster map."
-msgstr ""
-"Convierte un mapa vectorial binario de GRASS (sólo puntos) en una capa de "
-"mapa ráster 3D de GRASS."
+msgstr "Convierte un mapa vectorial (sólo puntos) en una capa de mapa ráster 3D."
#: ../vector/v.to.rast3/main.c:62
-#, fuzzy
msgid "Name of attribute column (data type must be numeric)"
-msgstr ""
-"Nombre de columna para el parámetro atributos (el tipo de datos debe ser "
-"numérico)"
+msgstr "Nombre de columna de atributo (tipo de datos debe ser numeric)"
#: ../vector/v.to.rast3/main.c:107
msgid "Unable to create output map"
@@ -17660,125 +15946,109 @@
msgstr "PostGIS"
#: ../vector/v.out.postgis/main.c:47
-#, fuzzy
msgid "simple features"
-msgstr "Escribiendo elementos seleccionados..."
+msgstr "elementos simples"
#: ../vector/v.out.postgis/main.c:52
-#, fuzzy
msgid "Exports a vector map layer to PostGIS feature table."
-msgstr "Convierte un mapa vectorial binario de GRASS a salida ASCII VTK."
+msgstr "Exporta una capa de mapa vectorial a tabla de elemetos PostGIS."
#: ../vector/v.out.postgis/main.c:103
-#, fuzzy, c-format
+#, c-format
msgid "Vector map <%s> is not in native format. Export cancelled."
-msgstr ""
-"No se encuentra el mapa vectorial <%s> en el directorio de mapas actual"
+msgstr "Mapa vectorial <%s> no está en formato nativo. Se canceló la exportación."
#: ../vector/v.out.postgis/main.c:110 ../general/g.region/main.c:473
-#, fuzzy, c-format
+#, c-format
msgid "Unable to open vector map <%s> on topological level"
-msgstr "No se puede abrir el mapa vectorial <%s> al nivel topológico %d"
+msgstr "No ha sido posible abrir el mapa vectorial <%s> al nivel topológico"
#: ../vector/v.out.postgis/main.c:134
-#, fuzzy, c-format
+#, c-format
msgid "Unable to create PostGIS layer <%s>"
-msgstr "No se puede crear la tabla <%s>"
+msgstr "No ha sido posible crear la capa PostGIS <%s>"
#: ../vector/v.out.postgis/main.c:141
-#, fuzzy, c-format
+#, c-format
msgid "Feature type %d is not supported"
-msgstr "Tipo de columna (%s) no soportado"
+msgstr "Tipo de elemento %d no soportado"
#: ../vector/v.out.postgis/main.c:151
-#, fuzzy
msgid "Copying features failed"
-msgstr "Fallo al copiar la tabla"
+msgstr "Ha fallado el copiado de elementos"
#: ../vector/v.out.postgis/main.c:159
-#, fuzzy, c-format
+#, c-format
msgid "Building %s topology failed"
-msgstr "Falló la construcción de la topología"
+msgstr "Ha fallado la construcción de la topología %s"
#: ../vector/v.out.postgis/main.c:163
-#, fuzzy, c-format
+#, c-format
msgid "No features exported. PostGIS layer <%s> not created."
-msgstr "No se han especificado reglas. El mapa ráster <%s> no se ha creado."
+msgstr "No se exportaron elementos. Capa PostGIS <%s> no creada."
#: ../vector/v.out.postgis/main.c:167
-#, fuzzy, c-format
+#, c-format
msgid "%d feature (%s type) written to <%s>."
msgid_plural "%d features (%s type) written to <%s>."
-msgstr[0] "%d elementos escritos a <%s> (%s)."
-msgstr[1] "%d elementos escritos a <%s> (%s)."
+msgstr[0] "%d elemento (tipo %s) escrito en <%s>."
+msgstr[1] "%d elementos (tipo %s) escrito en <%s>."
#: ../vector/v.out.postgis/main.c:173
-#, fuzzy, c-format
+#, c-format
msgid "%d primitive written to <%s>."
msgid_plural "%d primitives written to <%s>."
+msgstr[0] "%d primitiva escrita en <%s>."
+msgstr[1] "%d primitivas escritas en <%s>."
#: ../vector/v.out.postgis/main.c:212
-#, fuzzy, c-format
+#, c-format
msgid "Unable to drop table <%s.%s>"
+msgstr "No ha sido posible eliminar tabla <%s.%s>"
#: ../vector/v.out.postgis/main.c:220
-#, fuzzy, c-format
+#, c-format
msgid "Unable to drop topology schema <%s>"
-msgstr "No se puede encontrar el vector de fin <%s>"
+msgstr "No ha sido posible eliminar esquema de topología <%s>"
#: ../vector/v.out.postgis/table.c:27
-#, fuzzy, c-format
+#, c-format
msgid "No database connection for layer <%s>"
+msgstr "No hay conexión a base de datos para capa <%s>"
#: ../vector/v.out.postgis/table.c:50
#, c-format
-msgid ""
-"Invalid FID column (%s). FID column must be integer. Please specify "
-"different FID column by 'options=\"FID=<name>\"'."
-msgstr ""
+msgid "Invalid FID column (%s). FID column must be integer. Please specify different FID column by 'options=\"FID=<name>\"'."
+msgstr "FID de columna (%s) no válido. Columna FID debe ser integer. Por favor especifique una columna FID diferente con 'options=\"FID=<name>\"'."
#: ../vector/v.out.postgis/table.c:57
#, c-format
-msgid ""
-"Column (%s) already exists in the table. Please specify different geometry "
-"column by 'options=\"GEOMETRY_NAME=<name>\"'."
-msgstr ""
+msgid "Column (%s) already exists in the table. Please specify different geometry column by 'options=\"GEOMETRY_NAME=<name>\"'."
+msgstr "Columna (%s) ya existe en la tabla. Por favor especifique una columna de geometría distinta con 'options=\"GEOMETRY_NAME=<name>\"'."
#: ../vector/v.out.postgis/args.c:25
-#, fuzzy
msgid "Name for output PostGIS datasource"
-msgstr "Nombre para la tabla de salida"
+msgstr "Nombre para fuente de datos PostGIS de salida"
#: ../vector/v.out.postgis/args.c:27
msgid "Starts with 'PG' prefix, eg. 'PG:dbname=grass'"
-msgstr ""
+msgstr "Empiza con prefijo 'PG', ej. 'PG:dbname=grass'"
#: ../vector/v.out.postgis/args.c:35
-#, fuzzy
msgid "Name for output PostGIS layer"
-msgstr "Nombre para el archivo de salida"
+msgstr "Nombre para capa PostGIS de salida"
#: ../vector/v.out.postgis/args.c:37
-#, fuzzy
msgid "If not specified, input name is used"
-msgstr ""
-"Nombre de capa OGR. Si no se especifica, se usará en nombre de entrado."
+msgstr "Si no se especifica, se usará el nombre de entrada"
#: ../vector/v.out.postgis/args.c:44
-#, fuzzy
-msgid ""
-"Name for output vector map defined as a link to the PostGIS feature table"
-msgstr "Crea un nuevo vectorial como un enlace de sólo lectura a una capa OGR."
+msgid "Name for output vector map defined as a link to the PostGIS feature table"
+msgstr "Nombre para mapa vectorial de salida definido como un enlace a la tabla de elementos PostGIS"
#: ../vector/v.out.postgis/args.c:46
-msgid ""
-"If not specified, the vector link is not created. The link can be also "
-"manually created by 'v.external' module."
-msgstr ""
+msgid "If not specified, the vector link is not created. The link can be also manually created by 'v.external' module."
+msgstr "Si no se especifica, no se crea el enlace vectorial. El enlace puede ser creado manualmente con el módulo 'v.external'."
#: ../vector/v.out.postgis/args.c:53
msgid ""
@@ -17789,34 +16059,30 @@
msgstr ""
"Ejemplos:\n"
"\t\t'FID=cat': define la columna id de la característica 'cat'\n"
-"\t\t'GEOMETRY_NAME=wkb_geometry': define la columna geometría "
-"'wkb_geometry'\n"
+"\t\t'GEOMETRY_NAME=wkb_geometry': define la columna geometría 'wkb_geometry'\n"
"\t\t'SPATIAL_INDEX=NO': no crea índice espacial en la columna geometría"
#: ../vector/v.out.postgis/args.c:66
-#, fuzzy
msgid "Do not export attribute table"
-msgstr "No crear la tabla de atributos"
+msgstr "No exportar tabla de atributos"
#: ../vector/v.out.postgis/args.c:72
-#, fuzzy
msgid "Export PostGIS topology instead of simple features"
-msgstr "Tablas de sistema en vez de tablas de usuario"
+msgstr "Exportar topología PostGIS en lugar de elementos simples"
#: ../vector/v.out.postgis/args.c:77
-#, fuzzy
msgid "Force 2D output even if input is 3D "
#: ../vector/v.out.postgis/create.c:28
-#, fuzzy, c-format
+#, c-format
msgid "Unable to create <%s> file"
-msgstr "No se puede crear cell/%s file"
+msgstr "No se ha podido crear archivo <%s>"
#: ../vector/v.out.postgis/create.c:66
-#, fuzzy, c-format
+#, c-format
msgid "Invalid option skipped: %s"
-msgstr "Método no válido: %s"
+msgstr "Opción no válida omitida: %s"
#: ../vector/v.out.postgis/create.c:74
#, c-format
@@ -17824,14 +16090,13 @@
msgstr "Código EPSG (%s) definido para la localización actual será ignorado"
#: ../vector/v.out.postgis/create.c:102
-#, fuzzy, c-format
+#, c-format
msgid "Error writing <%s> file"
-msgstr "Error al escribir el archivo PPM"
+msgstr "Error al escribir archivo <%s>"
#: ../vector/v.in.ascii/main.c:72
msgid "Creates a vector map from an ASCII points file or ASCII vector file."
-msgstr ""
-"Crea un mapa vectorial a partir de archivo de puntos ASCII o ASCII vectorial."
+msgstr "Crea un mapa vectorial a partir de archivo de puntos ASCII o ASCII vectorial."
#: ../vector/v.in.ascii/main.c:76 ../raster3d/r3.in.ascii/main.c:86
#: ../raster/r.in.ascii/main.c:78
@@ -17845,7 +16110,7 @@
#: ../vector/v.in.ascii/main.c:91
msgid "GRASS vector ASCII format"
-msgstr ""
+msgstr "Formato vectorial ASCII GRASS "
#: ../vector/v.in.ascii/main.c:94
msgid "Input file format"
@@ -17858,25 +16123,19 @@
#: ../vector/v.in.ascii/main.c:104
msgid "Special characters: doublequote, singlequote"
-msgstr ""
+msgstr "Caracteres especiales: comillas dobles, comillas simples"
#: ../vector/v.in.ascii/main.c:114
msgid "Number of header lines to skip at top of input file (points mode)"
-msgstr ""
-"Número de líneas de la cabecera a saltar al comienzo del archivo de entrada "
-"(modo de puntos)"
+msgstr "Número de líneas de la cabecera a saltar al comienzo del archivo de entrada (modo de puntos)"
#: ../vector/v.in.ascii/main.c:123
msgid "Column definition in SQL style (points mode)"
msgstr "Definición de columna en estilo SQL (modo de puntos)"
#: ../vector/v.in.ascii/main.c:124
-msgid ""
-"For example: 'x double precision, y double precision, cat int, name "
-"varchar(10)'"
-msgstr ""
-"Por ejemplo: 'X doble precisión, Y doble precisión, cat int, nombre "
-"varchar(10)'"
+msgid "For example: 'x double precision, y double precision, cat int, name varchar(10)'"
+msgstr "Por ejemplo: 'X doble precisión, Y doble precisión, cat int, nombre varchar(10)'"
#: ../vector/v.in.ascii/main.c:136 ../vector/v.in.ascii/main.c:146
msgid "First column is 1"
@@ -17899,17 +16158,12 @@
msgstr "Número de columna usada como categoría (modo de puntos)"
#: ../vector/v.in.ascii/main.c:168
-msgid ""
-"First column is 1. If 0, unique category is assigned to each row and written "
-"to new column 'cat'"
-msgstr ""
-"La primera columna es 1. Si es 0, se asigna una única categoría a cada fila "
-"y se escribe una nueva columna 'cat'"
+msgid "First column is 1. If 0, unique category is assigned to each row and written to new column 'cat'"
+msgstr "La primera columna es 1. Si es 0, se asigna una única categoría a cada fila y se escribe una nueva columna 'cat'"
#: ../vector/v.in.ascii/main.c:177
msgid "Create a new empty vector map and exit. Nothing is read from input."
-msgstr ""
-"Crear un mapa vectorial nuevo vacío y salir. No se lee nada de la entrada."
+msgstr "Crear un mapa vectorial nuevo vacío y salir. No se lee nada de la entrada."
#: ../vector/v.in.ascii/main.c:182
msgid "Do not expect a header when reading in standard format"
@@ -17925,8 +16179,7 @@
#: ../vector/v.in.ascii/main.c:197
msgid "Only import points falling within current region (points mode)"
-msgstr ""
-"Sólo importar los puntos que caen dentro de la región actual (modo de puntos)"
+msgstr "Sólo importar los puntos que caen dentro de la región actual (modo de puntos)"
#: ../vector/v.in.ascii/main.c:202
#, fuzzy
@@ -17977,12 +16230,8 @@
#: ../vector/v.in.ascii/main.c:292 ../vector/v.in.ascii/main.c:296
#: ../vector/v.in.ascii/main.c:301 ../vector/v.in.ascii/main.c:306
#, c-format
-msgid ""
-"'%s' column number > minimum last column number (incorrect field separator "
-"or format?)"
-msgstr ""
-"número de la columna '%s' >mínimo número de la última columna (¿separador de "
-"campo incorrecto?)"
+msgid "'%s' column number > minimum last column number (incorrect field separator or format?)"
+msgstr "número de la columna '%s' >mínimo número de la última columna (¿separador de campo incorrecto?)"
#: ../vector/v.in.ascii/main.c:311 ../vector/v.in.ascii/main.c:314
#: ../vector/v.in.ascii/main.c:317 ../vector/v.in.ascii/main.c:320
@@ -17996,23 +16245,18 @@
#: ../vector/v.in.ascii/main.c:437
#, c-format
-msgid ""
-"Number of columns defined (%d) does not match number of columns (%d) in input"
-msgstr ""
-"El número de columnas definidas (%d) no concuerda con el número de columnas "
-"(%d) en la entrada"
+msgid "Number of columns defined (%d) does not match number of columns (%d) in input"
+msgstr "El número de columnas definidas (%d) no concuerda con el número de columnas (%d) en la entrada"
#: ../vector/v.in.ascii/main.c:465
#, c-format
msgid "Column number %d <%s> defined as double has only integer values"
-msgstr ""
-"La columna número %d <%s> definida como double sólo tiene valores integer"
+msgstr "La columna número %d <%s> definida como double sólo tiene valores integer"
#: ../vector/v.in.ascii/main.c:470
#, c-format
msgid "Column number %d <%s> defined as string has only integer values"
-msgstr ""
-"La columna número %d<%s> definida como string sólo tiene valores integer"
+msgstr "La columna número %d<%s> definida como string sólo tiene valores integer"
#: ../vector/v.in.ascii/main.c:477
#, c-format
@@ -18032,15 +16276,12 @@
#: ../vector/v.in.ascii/main.c:494
#, c-format
msgid "Column number %d <%s> defined as double has string values"
-msgstr ""
-"La columna número %d <%s> definida como double sólo tiene valores string"
+msgstr "La columna número %d <%s> definida como double sólo tiene valores string"
#: ../vector/v.in.ascii/main.c:499
#, c-format
msgid "Length of column %d <%s> (%d) is less than maximum value length (%d)"
-msgstr ""
-"La longitud de la columna %d <%s> (%d) es menor que la longitud del valor "
-"máximo (%d)"
+msgstr "La longitud de la columna %d <%s> (%d) es menor que la longitud del valor máximo (%d)"
#: ../vector/v.in.ascii/main.c:535
msgid "Populating table..."
@@ -18048,12 +16289,8 @@
#: ../vector/v.in.ascii/main.c:538
#, fuzzy
-msgid ""
-"Unable to close attribute table. The DBMI driver did not accept all "
-"attributes"
-msgstr ""
-"No se pudo cerrar la tabla de atributos. El driver DBMI no aceptó todos los "
-"atributos"
+msgid "Unable to close attribute table. The DBMI driver did not accept all attributes"
+msgstr "No se pudo cerrar la tabla de atributos. El driver DBMI no aceptó todos los atributos"
#: ../vector/v.in.ascii/points.c:82
msgid "Scanning input for column types..."
@@ -18101,9 +16338,8 @@
#: ../vector/v.timestamp/main.c:37 ../raster3d/r3.timestamp/main.c:44
#: ../raster/r.timestamp/main.c:37
-#, fuzzy
msgid "timestamp"
-msgstr "Marca de tiempo no válida"
+msgstr "marca de tiempo"
#: ../vector/v.timestamp/main.c:38
#: ../locale/scriptstrings/v.what.strds_to_translate.c:8
@@ -18156,9 +16392,8 @@
#: ../locale/scriptstrings/t.rast3d.extract_to_translate.c:6
#: ../locale/scriptstrings/t.rast.import_to_translate.c:5
#: ../raster3d/r3.timestamp/main.c:45 ../raster/r.timestamp/main.c:38
-#, fuzzy
msgid "time"
+msgstr "tiempo"
#: ../vector/v.timestamp/main.c:39
#, fuzzy
@@ -18166,9 +16401,8 @@
msgstr "Modifica un timestamp para una mapa raster."
#: ../vector/v.timestamp/main.c:40
-#, fuzzy
msgid "Print/add/remove a timestamp for a vector map."
-msgstr "Imprimir/añadir/eliminar marca de tiempo para un mapa ráster."
+msgstr "Mostrar/añadir/eliminar marca de tiempo para un mapa ráster."
#: ../vector/v.timestamp/main.c:50 ../raster/r.timestamp/main.c:49
msgid "Datetime, datetime1/datetime2, or 'none' to remove"
@@ -18179,9 +16413,9 @@
msgstr "Formato: '15 enero 1994' (absoluto) o 'dos años' (relativo)"
#: ../vector/v.timestamp/main.c:66
-#, fuzzy, c-format
+#, c-format
msgid "Vector map <%s> not found %s"
-msgstr "Mapa vectorial <%s> no encontrado"
+msgstr "Mapa vectorial <%s> no encontrado %s"
#: ../vector/v.net.flow/main.c:60 ../raster/r.sim/r.sim.water/main.c:116
msgid "flow"
@@ -18221,12 +16455,12 @@
#: ../vector/v.net.flow/main.c:199
#, c-format
msgid "No source features selected. Please check options '%s', '%s'."
-msgstr ""
+msgstr "No hay fuentes seleccionadas. Por favor revise opciones '%s', '%s'."
#: ../vector/v.net.flow/main.c:206
#, c-format
msgid "No sink features selected. Please check options '%s', '%s'."
-msgstr ""
+msgstr "No hay elementos sumidero (sink) seleccionados. Por favor revise opciones '%s', '%s'."
#: ../vector/v.net.flow/main.c:215
msgid "No sources"
@@ -18242,48 +16476,39 @@
msgstr "Escribiendo mapa..."
#: ../temporal/t.connect/main.c:38
-#, fuzzy
-msgid ""
-"Prints/sets general temporal GIS database connection for current mapset."
-msgstr ""
-"Imprime/establece la conexión general a la base de datos para el directorio "
-"de mapas actual y sale."
+msgid "Prints/sets general temporal GIS database connection for current mapset."
+msgstr "Muestra/establece la conexión general a la base de datos SIG temproal para el Directorio de mapas actual."
#: ../temporal/t.connect/main.c:54
-#, fuzzy
msgid "Overwrite current settings if initialized"
-msgstr "Sobrescribir MÁSCARA existente"
+msgstr "Sobrescribir configuraciones actuales si ya se ha inicializado"
#: ../temporal/t.connect/main.c:59
-#, fuzzy
msgid "Print current connection parameter in shell style and exit"
+msgstr "Mostrar los parámetros de la conexión actual estilo consola de comandos y salir"
#: ../temporal/t.connect/main.c:83 ../temporal/t.connect/main.c:95
-#, fuzzy
msgid "Temporal GIS database connection not defined. Run t.connect."
-msgstr "Conexión a base de datos no definida. Ejecute db.connect."
+msgstr "Conexión de base de datos SIG temporal no definida. Ejecute t.connect."
#: ../temporal/t.connect/main.c:111
-#, fuzzy, c-format
+#, c-format
msgid ""
"Default TGIS driver / database set to:\n"
"driver: %s\n"
"database: %s"
msgstr ""
-"Driver por defecto / Base de datos establecida a:\n"
-"driver: %s\n"
+"Controlador predeterminado TGIS / base de datos definida a:\n"
+"controlador: %s\n"
"base de datos: %s"
#: ../temporal/t.connect/main.c:118
-#, fuzzy
msgid "Default TGIS driver is not set"
-msgstr "No se ha establecido el driver por defecto"
+msgstr "Controlador TGIS predeterminado no está definido"
#: ../temporal/t.connect/main.c:121
-#, fuzzy
msgid "Default TGIS database is not set"
-msgstr "La base de datos por defecto no está asignada"
+msgstr "La base de datos predeterminada TGIS no está definida"
#: ../visualization/ximgview/main.c:64 ../general/g.cairocomp/main.c:89
#: ../general/g.cairocomp/main.c:256
@@ -18415,24 +16640,16 @@
#: ../locale/scriptstrings/d.frame_to_translate.c:11
#, fuzzy
-msgid ""
-"Screen coordinates in percent where to place the frame (0,0 is lower-left)"
-msgstr ""
-"Tamaño y posición como porcentaje de coordenadas de pantalla (0,0 es abajo a "
-"la izquierda)"
+msgid "Screen coordinates in percent where to place the frame (0,0 is lower-left)"
+msgstr "Tamaño y posición como porcentaje de coordenadas de pantalla (0,0 es abajo a la izquierda)"
#: ../locale/scriptstrings/d.frame_to_translate.c:12
msgid "Implies only when -c or --overwrite flag is given"
msgstr ""
#: ../locale/scriptstrings/i.pansharpen_to_translate.c:1
-#, fuzzy
-msgid ""
-"Image fusion algorithms to sharpen multispectral with high-res panchromatic "
-"channels"
-msgstr ""
-"Transformación de Brovey para fundir canales multiespectrales y "
-"pancromáticos de alta resolución"
+msgid "Image fusion algorithms to sharpen multispectral with high-res panchromatic channels"
+msgstr "Algoritmos de fusión de imágenes para mejorar multiespectral con canales pancromáticos de alta resolución"
#: ../locale/scriptstrings/i.pansharpen_to_translate.c:2
#: ../locale/scriptstrings/r.in.aster_to_translate.c:4
@@ -18473,7 +16690,7 @@
#: ../locale/scriptstrings/i.pansharpen_to_translate.c:4
msgid "sharpen"
-msgstr ""
+msgstr "afilado"
#: ../locale/scriptstrings/i.pansharpen_to_translate.c:5
msgid "Brovey"
@@ -18481,11 +16698,11 @@
#: ../locale/scriptstrings/i.pansharpen_to_translate.c:6
msgid "IHS"
-msgstr ""
+msgstr "IHS"
#: ../locale/scriptstrings/i.pansharpen_to_translate.c:7
msgid "HIS"
-msgstr ""
+msgstr "HIS"
#: ../locale/scriptstrings/i.pansharpen_to_translate.c:8
#: ../imagery/i.pca/main.c:74
@@ -18493,31 +16710,24 @@
msgstr "PCA (Análisis de Componentes Principales)"
#: ../locale/scriptstrings/i.pansharpen_to_translate.c:9
-#, fuzzy
msgid "Name of raster map to be used for <red>"
-msgstr "Nombre del mapa ráster a usar para <%s>"
+msgstr "Nombre del mapa ráster a usar para <red>"
#: ../locale/scriptstrings/i.pansharpen_to_translate.c:10
-#, fuzzy
msgid "Name of raster map to be used for <green>"
+msgstr "Nombre del mapa ráster a usar para <green>"
#: ../locale/scriptstrings/i.pansharpen_to_translate.c:11
-#, fuzzy
msgid "Name of raster map to be used for <blue>"
+msgstr "Nombre del mapa ráster a usar para <blue>"
#: ../locale/scriptstrings/i.pansharpen_to_translate.c:12
-#, fuzzy
msgid "Name of raster map to be used for high resolution panchromatic channel"
-msgstr ""
+msgstr "Nombre del mapa ráster que será usado para canal pancromático de alta resolución"
#: ../locale/scriptstrings/i.pansharpen_to_translate.c:13
-#, fuzzy
msgid "Method for pan sharpening"
-msgstr "Texto a usar para unidades de datos del mapa"
+msgstr "Método para pan sharpening"
#: ../locale/scriptstrings/i.pansharpen_to_translate.c:14
msgid "Serial processing rather than parallel processing"
@@ -18528,12 +16738,8 @@
msgstr "Rebalancear canal azul para LANDSAT"
#: ../locale/scriptstrings/v.what.strds_to_translate.c:1
-#, fuzzy
-msgid ""
-"Uploads space time raster dataset values at positions of vector points to "
-"the table."
-msgstr ""
-"Carga valores ráster en las posiciones de puntos vectoriales a la tabla."
+msgid "Uploads space time raster dataset values at positions of vector points to the table."
+msgstr "Carga valores de ráster en las posiciones de puntos vectoriales a la tabla."
#: ../locale/scriptstrings/v.what.strds_to_translate.c:3
#: ../locale/scriptstrings/t.rast3d.algebra_to_translate.c:2
@@ -18584,63 +16790,44 @@
#: ../locale/scriptstrings/t.rast.gapfill_to_translate.c:2
#: ../locale/scriptstrings/t.rast3d.extract_to_translate.c:2
#: ../locale/scriptstrings/t.rast.import_to_translate.c:2
-#, fuzzy
msgid "temporal"
-msgstr "Elementos"
+msgstr "temporal"
#: ../locale/scriptstrings/v.what.strds_to_translate.c:9
-#, fuzzy
msgid "Update attribute table of input vector map"
-msgstr "Error al copia tabla de atributos al mapa de salida"
+msgstr "Actualizar tabla de atributos para mapa vectorial de entrada"
#: ../locale/scriptstrings/v.what.strds_to_translate.c:10
-msgid ""
-"Instead of creating a new vector map update the attribute table with value(s)"
-msgstr ""
+msgid "Instead of creating a new vector map update the attribute table with value(s)"
+msgstr "En vez de crear un nuevo mapa vectorial actualiazr la tabla de atributos con valor(es)"
#: ../locale/scriptstrings/r.in.aster_to_translate.c:1
-#, fuzzy
-msgid ""
-"Georeference, rectify, and import Terra-ASTER imagery and relative DEMs "
-"using gdalwarp."
-msgstr ""
-"Georreferenciar, rectificar e importar imaginería Terra ASTER y MDT "
-"relativos usando gdalwarp."
+msgid "Georeference, rectify, and import Terra-ASTER imagery and relative DEMs using gdalwarp."
+msgstr "Georreferenciar, rectificar, e importar imaginería Terra-ASTER y MDT relativos usando gdalwarp."
#: ../locale/scriptstrings/r.in.aster_to_translate.c:5
msgid "Terra-ASTER"
-msgstr ""
+msgstr "ASTER-Terra"
#: ../locale/scriptstrings/r.in.aster_to_translate.c:6
-#, fuzzy
msgid "Name of input ASTER image"
-msgstr "Nombre de una capa de entrada"
+msgstr "Nombre de imagen ASTER de entrada"
#: ../locale/scriptstrings/r.in.aster_to_translate.c:7
msgid "ASTER imagery processing type (Level 1A, Level 1B, or relative DEM)"
-msgstr ""
-"Tipo de procesado de Imaginería ASTER (Nivel 1A, Nivel 1B o MDT relacionado)"
+msgstr "Tipo de procesado de Imaginería ASTER (Nivel 1A, Nivel 1B o MDT relacionado)"
#: ../locale/scriptstrings/r.in.aster_to_translate.c:8
-#, fuzzy
-msgid ""
-"List L1A or L1B band to translate (1,2,3n,...), or enter 'all' to translate "
-"all bands"
-msgstr ""
-"Banda L1A o L1B a traducir (1, 2, 3n, 3b, 4-14). Sólo se puede traducir una "
-"banda"
+msgid "List L1A or L1B band to translate (1,2,3n,...), or enter 'all' to translate all bands"
+msgstr "Enlista banda L1A o L1B a traducir (1,2,3n, 3b,...), o introduzca 'all' para traducir todas las bandas"
#: ../locale/scriptstrings/r.in.aster_to_translate.c:9
-#, fuzzy
-msgid ""
-"Base name for output raster map (band number will be appended to base name)"
-msgstr "Nombre para el mapa ráster de salida (por omisión: el de entrada)"
+msgid "Base name for output raster map (band number will be appended to base name)"
+msgstr "Nombre base para mapas ráster de salida (el número de banda será adjuntado al nombre base)"
#: ../locale/scriptstrings/r.blend_to_translate.c:1
msgid "Blends color components of two raster maps by a given ratio."
-msgstr ""
-"Mezcla los componentes de color de dos mapas raster en la proporción "
-"indicada."
+msgstr "Mezcla los componentes de color de dos mapas raster en la proporción indicada."
#: ../locale/scriptstrings/r.blend_to_translate.c:3
#: ../raster/r.composite/main.c:73
@@ -18656,11 +16843,8 @@
msgstr "Nombre del segundo mapa ráster a mezclar"
#: ../locale/scriptstrings/r.blend_to_translate.c:6
-#, fuzzy
msgid "Basename for red, green and blue output raster maps"
-msgstr ""
-"Nombre base para los mapas de salida rojo, verde y azul que contendrán la "
-"mezcla"
+msgstr "Nombre base para mapas ráster de salida rojo, verde y azul"
#: ../locale/scriptstrings/r.blend_to_translate.c:7
msgid "Percentage weight of first map for color blending"
@@ -18668,20 +16852,16 @@
#: ../locale/scriptstrings/r.blend_to_translate.c:8
msgid "Combine resulting R,G,B layers into single output map"
-msgstr ""
+msgstr "Combinar capas R,G,B resultantes en un solo mapa de salida"
#: ../locale/scriptstrings/t.rast3d.algebra_to_translate.c:1
#, fuzzy
-msgid ""
-"Apply temporal and spatial operations on space time 3D raster datasets using "
-"temporal 3D raster algebra."
+msgid "Apply temporal and spatial operations on space time 3D raster datasets using temporal 3D raster algebra."
msgstr "Convierte mapas ráster 3D en mapas ráster 2D"
#: ../locale/scriptstrings/t.rast3d.algebra_to_translate.c:7
#, fuzzy
-msgid ""
-"Algebraic expression for temporal and spatial analysis of space time 3D "
-"raster datasets"
+msgid "Algebraic expression for temporal and spatial analysis of space time 3D raster datasets"
msgstr "Listar mapas vectoriales en la localización de entrada y salir"
#: ../locale/scriptstrings/t.rast3d.algebra_to_translate.c:8
@@ -18700,9 +16880,8 @@
#: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:8
#: ../locale/scriptstrings/t.rast.gapfill_to_translate.c:6
#: ../locale/scriptstrings/t.rast.import_to_translate.c:6
-#, fuzzy
msgid "Basename of the new generated output maps"
-msgstr "Nombre del mapa ráster 3D de entrada"
+msgstr "Nombre base de los mapas nuevos generados de salida"
#: ../locale/scriptstrings/t.rast3d.algebra_to_translate.c:9
#: ../locale/scriptstrings/t.rast.contour_to_translate.c:8
@@ -18720,24 +16899,21 @@
#: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:9
#: ../locale/scriptstrings/t.rast.gapfill_to_translate.c:7
#: ../locale/scriptstrings/t.rast.import_to_translate.c:7
-msgid ""
-"A numerical suffix separated by an underscore will be attached to create a "
-"unique identifier"
-msgstr ""
+msgid "A numerical suffix separated by an underscore will be attached to create a unique identifier"
+msgstr "Un sufijo numérico separado por un guión bajo será añadido para crear un identificador único"
#: ../locale/scriptstrings/t.rast3d.algebra_to_translate.c:10
#: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:10
#: ../locale/scriptstrings/t.rast3d.extract_to_translate.c:10
-#, fuzzy
msgid "Number of r3.mapcalc processes to run in parallel"
-msgstr "Número de clases a definir"
+msgstr "Número de procesos r3.mapcalc que correrán en paralelo"
#: ../locale/scriptstrings/t.rast3d.algebra_to_translate.c:11
#: ../locale/scriptstrings/t.rast.algebra_to_translate.c:10
#: ../locale/scriptstrings/t.vect.algebra_to_translate.c:9
#: ../locale/scriptstrings/t.select_to_translate.c:8
msgid "Activate spatial topology"
-msgstr ""
+msgstr "Activar topología espacial"
#: ../locale/scriptstrings/t.rast3d.algebra_to_translate.c:12
#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:14
@@ -18748,9 +16924,8 @@
#: ../locale/scriptstrings/t.rast.extract_to_translate.c:11
#: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:12
#: ../locale/scriptstrings/t.rast3d.extract_to_translate.c:11
-#, fuzzy
msgid "Register Null maps"
-msgstr "Mapas raster de entrada"
+msgstr "Registrado mapas Nulos"
#: ../locale/scriptstrings/t.rast3d.algebra_to_translate.c:13
#: ../locale/scriptstrings/t.rast.algebra_to_translate.c:12
@@ -18758,12 +16933,8 @@
msgstr ""
#: ../locale/scriptstrings/r.plane_to_translate.c:1
-msgid ""
-"Creates raster plane map given dip (inclination), aspect (azimuth) and one "
-"point."
-msgstr ""
-"Crea un mapa ráster plano dando pendiente (inclinación), orientación "
-"(azimut) y un punto."
+msgid "Creates raster plane map given dip (inclination), aspect (azimuth) and one point."
+msgstr "Crea un mapa ráster plano dando pendiente (inclinación), orientación (azimut) y un punto."
#: ../locale/scriptstrings/r.plane_to_translate.c:3
#: ../locale/scriptstrings/r.shade_to_translate.c:3
@@ -18774,14 +16945,12 @@
msgstr "elevación"
#: ../locale/scriptstrings/r.plane_to_translate.c:4
-#, fuzzy
msgid "Dip of plane in degrees"
-msgstr "Ángulo de anisotropía (en grados)"
+msgstr ""
#: ../locale/scriptstrings/r.plane_to_translate.c:5
-#, fuzzy
msgid "Azimuth of the plane in degrees"
-msgstr "A: azimut del sol desde el Norte, grados"
+msgstr "Azimut de plano en grados"
#: ../locale/scriptstrings/r.plane_to_translate.c:6
msgid "Easting coordinate of a point on the plane"
@@ -18796,28 +16965,20 @@
msgstr "Coordenada de elevación de un punto en el plano"
#: ../locale/scriptstrings/r.plane_to_translate.c:9
-#, fuzzy
msgid "Type of raster map to be created"
-msgstr "Tipo de mapa ráster a crear"
+msgstr "Tipo de mapa ráster que será creado"
#: ../locale/scriptstrings/wxpyimgview_to_translate.c:1
-#, fuzzy
msgid "Views BMP images from the PNG driver."
msgstr "Ver imágenes BMP desde el controlador PNG."
#: ../locale/scriptstrings/wxpyimgview_to_translate.c:5
-#, fuzzy
msgid "Name of input image file"
-msgstr "Nombres de los archivos de entrada"
+msgstr "Nombre de archivo de imagen de entrada"
#: ../locale/scriptstrings/t.rast.univar_to_translate.c:1
-#, fuzzy
-msgid ""
-"Calculates univariate statistics from the non-null cells for each registered "
-"raster map of a space time raster dataset."
-msgstr ""
-"Calcula estadísticas univariantes a partir de celdas no nulas de un mapa "
-"ráster."
+msgid "Calculates univariate statistics from the non-null cells for each registered raster map of a space time raster dataset."
+msgstr "Calcula estadísticas univariadas a partir de celdas no nulas para cada mapa ráster registrado en un conjunto de datos espacio temporales."
#: ../locale/scriptstrings/t.rast.univar_to_translate.c:7
#: ../locale/scriptstrings/t.rast.list_to_translate.c:14
@@ -18827,9 +16988,8 @@
#: ../locale/scriptstrings/t.vect.list_to_translate.c:13
#: ../locale/scriptstrings/t.vect.univar_to_translate.c:8
#: ../locale/scriptstrings/t.list_to_translate.c:16
-#, fuzzy
msgid "Field separator character between the output columns"
-msgstr "Separador de campos (modo conciso solamente)"
+msgstr "Caracter que separa campos entre las columnas de salida"
#: ../locale/scriptstrings/t.rast.univar_to_translate.c:8
#: ../locale/scriptstrings/t.rast.univar_to_translate.c:12
@@ -18860,10 +17020,8 @@
msgstr "Formateando"
#: ../locale/scriptstrings/t.rast.univar_to_translate.c:10
-msgid ""
-"Ignore the current region settings and use the raster map regions for univar "
-"statistical calculation"
-msgstr ""
+msgid "Ignore the current region settings and use the raster map regions for univar statistical calculation"
+msgstr "Ignorar la configuración de la región actual y usar las regiones del mapa ráster para calcular estadísticas univariadas"
#: ../locale/scriptstrings/t.rast.univar_to_translate.c:11
#: ../locale/scriptstrings/t.rast.list_to_translate.c:16
@@ -18871,14 +17029,12 @@
#: ../locale/scriptstrings/t.rast3d.univar_to_translate.c:11
#: ../locale/scriptstrings/t.vect.list_to_translate.c:15
#: ../locale/scriptstrings/t.vect.univar_to_translate.c:11
-#, fuzzy
msgid "Suppress printing of column names"
-msgstr "Suprimir la impresión de información de cabecera"
+msgstr "Suprime el mostrado de los nombres de columnas"
#: ../locale/scriptstrings/t.rename_to_translate.c:1
-#, fuzzy
msgid "Renames a space time dataset"
-msgstr "Crea una base de datos vacía."
+msgstr "Renombrar un conjunto de datos espacio temporales"
#: ../locale/scriptstrings/t.rename_to_translate.c:3
#: ../locale/scriptstrings/t.rast.list_to_translate.c:3
@@ -18895,15 +17051,13 @@
#: ../general/g.remove/main.c:70 ../general/g.list/main.c:66
#: ../general/g.access/main.c:38 ../raster/r.compress/main.c:65
#: ../imagery/i.target/main.c:46 ../imagery/i.group/main.c:53
-#, fuzzy
msgid "map management"
-msgstr "general, gestión de mapas"
+msgstr "gestión de mapas"
#: ../locale/scriptstrings/t.rename_to_translate.c:4
#: ../general/g.rename/main.c:47
-#, fuzzy
msgid "rename"
-msgstr "nombre"
+msgstr "renombrar"
#: ../locale/scriptstrings/t.rename_to_translate.c:6
#: ../locale/scriptstrings/t.snap_to_translate.c:7
@@ -18912,9 +17066,8 @@
#: ../locale/scriptstrings/t.support_to_translate.c:6
#: ../locale/scriptstrings/t.topology_to_translate.c:5
#: ../locale/scriptstrings/t.info_to_translate.c:7
-#, fuzzy
msgid "input"
-msgstr "Entrada"
+msgstr "entrada"
#: ../locale/scriptstrings/t.rename_to_translate.c:7
#: ../locale/scriptstrings/t.snap_to_translate.c:8
@@ -18931,18 +17084,12 @@
#: ../locale/scriptstrings/v.build.all_to_translate.c:1
msgid "Rebuilds topology on all vector maps in the current mapset."
-msgstr ""
-"Reconstruye la topología de todos los mapas vectoriales en el directorio de "
-"mapas actual"
+msgstr "Reconstruye la topología de todos los mapas vectoriales en el directorio de mapas actual"
#: ../locale/scriptstrings/t.rast.contour_to_translate.c:1
#, fuzzy
-msgid ""
-"Produces a space time vector dataset of specified contours from a space time "
-"raster dataset."
-msgstr ""
-"Produce un mapa vectorial de contrornos específicado a partir de un mapa "
-"raster."
+msgid "Produces a space time vector dataset of specified contours from a space time raster dataset."
+msgstr "Produce un mapa vectorial de contrornos específicado a partir de un mapa raster."
#: ../locale/scriptstrings/t.rast.contour_to_translate.c:3
#, fuzzy
@@ -18959,10 +17106,7 @@
#: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:10
#: ../locale/scriptstrings/t.rast.gapfill_to_translate.c:8
#: ../locale/scriptstrings/t.rast3d.extract_to_translate.c:9
-msgid ""
-"Suffix to add at basename: set 'gran' for granularity, 'time' for the full "
-"time format, 'num' for numerical suffix with a specific number of digits "
-"(default %05)"
+msgid "Suffix to add at basename: set 'gran' for granularity, 'time' for the full time format, 'num' for numerical suffix with a specific number of digits (default %05)"
msgstr ""
#: ../locale/scriptstrings/t.rast.contour_to_translate.c:10
@@ -18991,9 +17135,7 @@
msgstr "Número mínimo de puntos para una línea de contorno (0 -> sin límite)"
#: ../locale/scriptstrings/t.rast.contour_to_translate.c:15
-msgid ""
-"Number of r.contour processes to run in parallel, more than 1 process works "
-"only in conjunction with flag -t"
+msgid "Number of r.contour processes to run in parallel, more than 1 process works only in conjunction with flag -t"
msgstr ""
#: ../locale/scriptstrings/t.rast.contour_to_translate.c:16
@@ -19009,9 +17151,8 @@
-#, fuzzy
msgid "Lists registered maps of a space time raster dataset."
-msgstr "Listar mapas vectoriales en la localización de entrada y salir"
+msgstr "Enlistar mapas registrados en un conjunto de datos ráster espacio temporales."
#: ../locale/scriptstrings/t.rast.list_to_translate.c:5
#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:4
@@ -19023,51 +17164,41 @@
#: ../locale/scriptstrings/t.rast.list_to_translate.c:7
#: ../locale/scriptstrings/t.vect.list_to_translate.c:7
#: ../locale/scriptstrings/t.list_to_translate.c:10
-#, fuzzy
msgid "Sort the space time dataset by category"
+msgstr "Ordenar el conjunto de datos espacio temporales por categoría"
#: ../locale/scriptstrings/t.rast.list_to_translate.c:9
#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:9
#: ../locale/scriptstrings/t.vect.list_to_translate.c:9
#: ../locale/scriptstrings/t.list_to_translate.c:13
-#, fuzzy
msgid "Columns to be printed to stdout"
-msgstr "Nombre de columna (debe ser de tipo numérico)"
+msgstr "Columnas que serán mostradas en la salida estándar"
#: ../locale/scriptstrings/t.rast.list_to_translate.c:12
#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:12
#: ../locale/scriptstrings/t.vect.list_to_translate.c:12
-#, fuzzy
msgid "Method used for data listing"
+msgstr "Método usado para enlistar datos"
#: ../locale/scriptstrings/t.rast.list_to_translate.c:13
-msgid ""
-"The granule to be used for listing. The granule must be specified as string "
-"eg.: absolute time \"1 months\" or relative time \"1\""
-msgstr ""
+msgid "The granule to be used for listing. The granule must be specified as string eg.: absolute time \"1 months\" or relative time \"1\""
+msgstr "El gránulo que se usará para enlistar. El gránulo debe ser especificado como cadena ej.: tiempo absoluto \"1 months\" o tiempo relativo \"1\""
#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:1
msgid "Imports SPOT VGT NDVI data into a raster map."
msgstr "Importa datos de SPOT VGT NDVI a un mapa ráster."
#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:4
-#, fuzzy
msgid "Also import quality map (SM status map layer) and filter NDVI map"
-msgstr ""
-"importar también mapa de calidad (capa de mapa de estado SM) y filtrar mapa "
-"NDVI"
+msgstr "Tambien importa calidad de mapa (capa de mapa SM status) y filtrar mapa NDVI"
#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:5
-#, fuzzy
msgid "Name of input SPOT VGT NDVI HDF file"
-msgstr "Nombres de los archivos DXF de entrada"
+msgstr "Nombre de archivo SPOT VGT NDVI HDF de entrada"
#: ../locale/scriptstrings/i.colors.enhance_to_translate.c:1
-#, fuzzy
msgid "Performs auto-balancing of colors for RGB images."
-msgstr "Realiza balance automático de colores para imágenes LANDSAT."
+msgstr "Realiza un autobalanceo de colores para imágenes RGB."
#: ../locale/scriptstrings/i.colors.enhance_to_translate.c:3
#: ../locale/scriptstrings/r.rgb_to_translate.c:3
@@ -19087,19 +17218,16 @@
msgstr "colores"
#: ../locale/scriptstrings/i.colors.enhance_to_translate.c:6
-#, fuzzy
msgid "Name of red channel"
-msgstr "Canal rojo LANDSAT"
+msgstr "Nombre de canal rojo"
#: ../locale/scriptstrings/i.colors.enhance_to_translate.c:7
-#, fuzzy
msgid "Name of green channel"
-msgstr "Canal verde LANDSAT"
+msgstr "Nombre de canal verde"
#: ../locale/scriptstrings/i.colors.enhance_to_translate.c:8
-#, fuzzy
msgid "Name of blue channel"
-msgstr "Canal azul LANDSAT"
+msgstr "Nombre de canal azul"
#: ../locale/scriptstrings/i.colors.enhance_to_translate.c:9
msgid "Cropping intensity (upper brightness level)"
@@ -19120,12 +17248,11 @@
#: ../locale/scriptstrings/i.colors.enhance_to_translate.c:16
#: ../locale/scriptstrings/i.oif_to_translate.c:7
msgid "Process bands serially (default: run in parallel)"
-msgstr ""
+msgstr "Procesar bandas de manera serial (predeterminado: correr en paralelo)"
#: ../locale/scriptstrings/v.report_to_translate.c:1
-#, fuzzy
msgid "Reports geometry statistics for vector maps."
-msgstr "Informa estadísticas de geometría para vectoriales."
+msgstr "Informa estadísticas de geometría para mapas vectoriales."
#: ../locale/scriptstrings/v.report_to_translate.c:6
msgid "Value to calculate"
@@ -19140,28 +17267,22 @@
msgstr "asc;Ordenar de modo ascendente;desc;Ordenar de modo descendente"
#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:1
-#, fuzzy
msgid "Computes cyclic accumulations of a space time raster dataset."
-msgstr "Nombre de mapa ráster de orientación"
+msgstr "Calcula acumulaciones cíclicas de un conjunto de datos ráster espacio temporales"
#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:3
#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:3
#: ../raster/r.series.accumulate/main.c:82
-#, fuzzy
msgid "accumulation"
-msgstr "Cálculo del promedio"
+msgstr "acumulación"
#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:6
-msgid ""
-"Input space time raster dataset that defines the lower threshold, values "
-"lower this threshold are excluded from accumulation"
-msgstr ""
+msgid "Input space time raster dataset that defines the lower threshold, values lower this threshold are excluded from accumulation"
+msgstr "Conjunto de datos ráster espacio temporales que define el úmbral mínimo, valores menores que este umbral serán excluidos de la acumulación"
#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:7
-msgid ""
-"Input space time raster dataset that defines the upper threshold, values "
-"upper this threshold are excluded from accumulation"
-msgstr ""
+msgid "Input space time raster dataset that defines the upper threshold, values upper this threshold are excluded from accumulation"
+msgstr "Conjunto de datos ráster espacio temporales que define el úmbral máximo, valores mayores que este umbral serán excluidos de la acumulación"
#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:8
#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:10
@@ -19176,7 +17297,7 @@
#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:10
#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:12
msgid "The temporal cycle to restart the accumulation, eg '12 months'"
-msgstr ""
+msgstr "Ciclo temporal para reiniciar la acumulación, ej. '12 months'"
#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:11
#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:13
@@ -19188,113 +17309,90 @@
msgstr "Granularidad para acumulación '1 day'"
#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:16
-msgid ""
-"Use these limits in case lower and/or upper input space time raster "
-"datasets are not defined or contain NULL values"
+msgid "Use these limits in case lower and/or upper input space time raster datasets are not defined or contain NULL values"
msgstr ""
#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:17
-#, fuzzy
msgid "Scale factor for input space time raster dataset"
-msgstr "Nombre del mapa ráster que contiene el resultado de la reclasificación"
+msgstr "Factor de escalamiento para conjunto de datos ráster espacio temporales de entrada"
#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:18
-#, fuzzy
msgid "Shift factor for input space time raster dataset"
+msgstr ""
#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:19
-msgid ""
-"This method will be applied to compute the accumulative values from the "
-"input maps in a single granule"
-msgstr ""
+msgid "This method will be applied to compute the accumulative values from the input maps in a single granule"
+msgstr "Este métdo será aplicado para calcular la acumulación de valores desde mapas de entrada en un solo gránulo"
#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:20
-msgid ""
-"Growing Degree Days or Winkler indices; Mean: sum(input maps)/(number of "
-"input maps); Biologically Effective Degree Days; Huglin Heliothermal index"
-msgstr ""
+msgid "Growing Degree Days or Winkler indices; Mean: sum(input maps)/(number of input maps); Biologically Effective Degree Days; Huglin Heliothermal index"
+msgstr "Índice de grado de días de crecimiento o índices Winkler: media: sum(mapas de entrada)/(cantidad de mapas de entrada); Grado de días biológicamente efectivos; índice heliotermal Huglin"
#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:21
#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:19
-msgid ""
-"Register empty maps in the output space time raster dataset, otherwise they "
-"will be deleted"
-msgstr ""
+msgid "Register empty maps in the output space time raster dataset, otherwise they will be deleted"
+msgstr "Registrar mapas vacíos en el conjunto de datos espacio temporales de salida, de otra manera serán eliminados"
#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:22
#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:20
msgid "Reverse time direction in cyclic accumulation"
-msgstr ""
+msgstr "Revertir dirección del tiempo en acumulación cíclica"
#: ../locale/scriptstrings/v.in.e00_to_translate.c:1
-#, fuzzy
msgid "Imports E00 file into a vector map."
-msgstr "Importar archivo E00 a mapa vectorial."
+msgstr "Importa archivo E00 a mapa vectorial."
#: ../locale/scriptstrings/v.in.e00_to_translate.c:4
msgid "E00"
-msgstr ""
+msgstr "E00"
#: ../locale/scriptstrings/v.in.e00_to_translate.c:5
-#, fuzzy
msgid "Name of input E00 file"
+msgstr "Nombres de los archivo E00 de entrada"
-msgid ""
-"Aggregates data of an existing space time raster dataset using the time "
-"intervals of a second space time dataset."
-msgstr ""
+msgid "Aggregates data of an existing space time raster dataset using the time intervals of a second space time dataset."
+msgstr "Agrega datos de un conjunto de datos ráster espacio temporales usando el tiempo de intervalo de un segundo conjunto de datos espacio temporales."
#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:6
-msgid ""
-"Time intervals from this space time dataset (raster, vector or raster3d) are "
-"used for aggregation computation"
-msgstr ""
+msgid "Time intervals from this space time dataset (raster, vector or raster3d) are used for aggregation computation"
+msgstr "Intervalos de tiempo para este conjunto de datos espacio temporales (ráster,vectorial o ráster3d) son usados para calcular agregación"
#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:7
-#, fuzzy
msgid "Type of the aggregation space time dataset"
-msgstr "Nombre de la nueva base de datos"
+msgstr "Tipo de agregación del conjunto de datos espacio temporales"
#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:11
#: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:10
#: ../locale/scriptstrings/t.vect.what.strds_to_translate.c:8
#: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:7
#: ../locale/scriptstrings/t.rast.series_to_translate.c:7
-#, fuzzy
msgid "Aggregate operation to be performed on the raster maps"
-msgstr "Nombre de dos o más mapas raster de entrada"
+msgstr "Operación de agregar va a ser realizara en los mapas ráster"
#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:12
#: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:11
-msgid ""
-"Offset that is used to create the output map ids, output map id is generated "
-"as: basename_ (count + offset)"
+msgid "Offset that is used to create the output map ids, output map id is generated as: basename_ (count + offset)"
msgstr ""
#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:13
#: ../locale/scriptstrings/t.rast.algebra_to_translate.c:9
#: ../locale/scriptstrings/t.rast.mapcalc_to_translate.c:9
#: ../locale/scriptstrings/t.rast.extract_to_translate.c:10
-#, fuzzy
msgid "Number of r.mapcalc processes to run in parallel"
+msgstr "Número de procesos r.mapcalc que correrán en paralelo"
#: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:1
-#, fuzzy
msgid "Exports space time raster dataset as VTK time series."
-msgstr "Actualizar estadísticas del mapa ráster"
+msgstr "Exporta conjunto de datos ráster espacio temporales como serie de tiempo VTK."
#: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:5
msgid "VTK"
-msgstr ""
+msgstr "VTK"
#: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:7
-#, fuzzy
msgid "Path to the export directory"
-msgstr "Nombre del archivo de salida"
+msgstr "Ruta al directorio de exportación"
#: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:8
#: ../raster/r.out.vtk/parameters.c:45
@@ -19303,32 +17401,25 @@
#: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:9
#: ../raster/r.out.vtk/parameters.c:59
-msgid ""
-"Create VTK point data instead of VTK cell data (if no elevation map is given)"
-msgstr ""
-"Crear datos de puntos VTK en vez de datos de celdas VTK (si no se indica "
-"mapa de elevación)"
+msgid "Create VTK point data instead of VTK cell data (if no elevation map is given)"
+msgstr "Crear datos de puntos VTK en vez de datos de celdas VTK (si no se indica mapa de elevación)"
#: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:11
-msgid ""
-"Export files using the space time dataset granularity for equidistant time "
-"between maps, where statement will be ignored"
-msgstr ""
+msgid "Export files using the space time dataset granularity for equidistant time between maps, where statement will be ignored"
+msgstr "Exportar archivos usando granularidad del conjunto de datos espacio temporales para tiempos equidistantes entre mapas, sentencias where serán ignoradas"
#: ../locale/scriptstrings/v.in.wfs_to_translate.c:1
-#, fuzzy
msgid "Imports GetFeature from a WFS server."
-msgstr "Importar GetFeature de WFS"
+msgstr "Importa GetFeature desde un servidor WFS."
#: ../locale/scriptstrings/v.in.wfs_to_translate.c:4
#: ../locale/scriptstrings/r.in.wms_to_translate.c:4
msgid "OGC web services"
-msgstr ""
+msgstr "Servicios web OGC"
#: ../locale/scriptstrings/v.in.wfs_to_translate.c:5
-#, fuzzy
msgid "Base URL starting with 'http' and ending in '?'"
-msgstr "URL de GetFeature comenzando con 'http'"
+msgstr "URL base que inicia con 'http' y temina en '?'"
#: ../locale/scriptstrings/v.in.wfs_to_translate.c:6
msgid "Comma separated names of data layers to download"
@@ -19336,17 +17427,15 @@
#: ../locale/scriptstrings/v.in.wfs_to_translate.c:7
msgid "Specify alternate spatial reference system (example: EPSG:4326)"
-msgstr ""
+msgstr "Especificar sistema de referencia alternativo (ejemplo: EPSG:4326)"
#: ../locale/scriptstrings/v.in.wfs_to_translate.c:8
-msgid ""
-"The given code must be supported by the server, consult the capabilities file"
-msgstr ""
+msgid "The given code must be supported by the server, consult the capabilities file"
+msgstr "El código dado debe estar soportado por el servidor, consulte el archivo de funciones"
#: ../locale/scriptstrings/v.in.wfs_to_translate.c:9
-#, fuzzy
msgid "Maximum number of features to download"
-msgstr "Número máximo de filas a cargar"
+msgstr "Número máximo de elementos a descargar"
#: ../locale/scriptstrings/v.in.wfs_to_translate.c:10
msgid "(default: unlimited)"
@@ -19354,28 +17443,23 @@
#: ../locale/scriptstrings/v.in.wfs_to_translate.c:11
msgid "Skip earlier feature IDs and start downloading at this one"
-msgstr ""
+msgstr "Omitir IDs de elementos previas y empezar descargando ésta"
#: ../locale/scriptstrings/v.in.wfs_to_translate.c:12
msgid "(default: start with the first feature)"
msgstr "(predeterminado: iniciar con el primer elemento)"
#: ../locale/scriptstrings/v.in.wfs_to_translate.c:13
-msgid ""
-"Download server capabilities to 'wms_capabilities.xml' in the current "
-"directory and exit"
-msgstr ""
+msgid "Download server capabilities to 'wms_capabilities.xml' in the current directory and exit"
+msgstr "Descargar funciones de servidor a 'wms_capabilities.xml' en el directorio actual y salir"
#: ../locale/scriptstrings/v.in.wfs_to_translate.c:14
msgid "Restrict fetch to features which touch the current region"
msgstr ""
#: ../locale/scriptstrings/i.spectral_to_translate.c:1
-msgid ""
-"Displays spectral response at user specified locations in group or images."
-msgstr ""
-"Muestra la respuesta espectral en localizaciones especificadas por el "
-"usuario en grupo o imágenes."
+msgid "Displays spectral response at user specified locations in group or images."
+msgstr "Muestra la respuesta espectral en localizaciones especificadas por el usuario en grupo o imágenes."
#: ../locale/scriptstrings/i.spectral_to_translate.c:5
#: ../locale/scriptstrings/i.oif_to_translate.c:3
@@ -19388,19 +17472,16 @@
msgstr "Nombre para el archivo imagen de salida (sin extensión)"
#: ../locale/scriptstrings/i.spectral_to_translate.c:11
-#, fuzzy
msgid "Graphics format for output file"
+msgstr "Formato de gráficas para archivo de salida"
#: ../locale/scriptstrings/i.spectral_to_translate.c:13
-#, fuzzy
msgid "Show sampling coordinates instead of numbering in the legend"
-msgstr "Etiquetar con coordenadas en vez de numeración"
+msgstr "Mostrar coordenadas de muestra en vez de numeración en la leyenda"
#: ../locale/scriptstrings/i.spectral_to_translate.c:14
-#, fuzzy
msgid "Use gnuplot for display"
-msgstr "Texto a mostrar"
+msgstr "Usar gnuplot para visualizador"
#: ../locale/scriptstrings/i.spectral_to_translate.c:15
#, fuzzy
@@ -19408,9 +17489,7 @@
msgstr "Archivo de georeferenciación de salida"
#: ../locale/scriptstrings/t.rast.what_to_translate.c:1
-msgid ""
-"Sample a space time raster dataset at specific vector point coordinates and "
-"write the output to stdout using different layouts"
+msgid "Sample a space time raster dataset at specific vector point coordinates and write the output to stdout using different layouts"
msgstr ""
#: ../locale/scriptstrings/t.rast.what_to_translate.c:6
@@ -19429,9 +17508,7 @@
msgstr "Ordenar los mapas por categoría"
#: ../locale/scriptstrings/t.rast.what_to_translate.c:9
-msgid ""
-"The layout of the output. One point per row (row), one point per column "
-"(col), all timsteps in one row (timerow)"
+msgid "The layout of the output. One point per row (row), one point per column (col), all timsteps in one row (timerow)"
msgstr ""
#: ../locale/scriptstrings/t.rast.what_to_translate.c:10
@@ -19449,10 +17526,8 @@
msgstr ""
#: ../locale/scriptstrings/t.vect.import_to_translate.c:1
-#, fuzzy
-msgid ""
-"Imports a space time vector dataset from a GRASS GIS specific archive file."
+msgid "Imports a space time vector dataset from a GRASS GIS specific archive file."
+msgstr "Importa un conjunto de daos vectoriales espacio temporales a partir de un archivo de almacenamiento específico para GRASS."
#: ../locale/scriptstrings/t.vect.import_to_translate.c:8
#: ../locale/scriptstrings/t.rast.import_to_translate.c:8
@@ -19473,27 +17548,21 @@
#: ../locale/scriptstrings/t.vect.import_to_translate.c:11
#: ../locale/scriptstrings/t.rast.import_to_translate.c:11
-msgid ""
-"Create a new location and import the data into it. Do not run this module in "
-"parallel or interrupt it when a new location should be created"
-msgstr ""
+msgid "Create a new location and import the data into it. Do not run this module in parallel or interrupt it when a new location should be created"
+msgstr "Crear una nueva Localización e importar los datos a ella. No correr este módilo en paralelo o interrumpirlo cuado una nueva Localización deba ser creada"
#: ../locale/scriptstrings/t.vect.import_to_translate.c:12
#: ../locale/scriptstrings/t.rast.import_to_translate.c:16
msgid "Extend location extents based on new dataset"
-msgstr ""
-"Ampliar la extensión de la localización en base a nuevo conjunto de datos"
+msgstr "Ampliar la extensión de la localización en base a nuevo conjunto de datos"
#: ../locale/scriptstrings/t.vect.import_to_translate.c:15
-msgid ""
-"Create the location specified by the \"location\" parameter and exit. Do not "
-"import the space time vector datasets."
-msgstr ""
+msgid "Create the location specified by the \"location\" parameter and exit. Do not import the space time vector datasets."
+msgstr "Crear la Localización especificada por el parámetro \"location\" y salir. No importa conjuntos de datos vectoriales espacio temporales."
#: ../locale/scriptstrings/r.in.wms_to_translate.c:1
-#, fuzzy
msgid "Downloads and imports data from WMS/WMTS/NASA OnEarth server."
-msgstr "Descarga e importa datos de servidores WMS."
+msgstr "Descarga e importa datos de servidor WMS/WMTS/NASA OnEarth."
#: ../locale/scriptstrings/r.in.wms_to_translate.c:5
msgid "Typically starts with \"http://\""
@@ -19507,14 +17576,12 @@
msgstr "Nombre para el mapa ráster de salida"
#: ../locale/scriptstrings/r.in.wms_to_translate.c:7
-#, fuzzy
msgid "Layer(s) to request from the map server"
-msgstr "Estilos a solicitar del servidor de mapas"
+msgstr "Capa(s) a solicitar al servidor de mapas"
#: ../locale/scriptstrings/r.in.wms_to_translate.c:8
-#, fuzzy
msgid "Layer style(s) to request from the map server"
+msgstr "Estilo(s) de capa a solicitar del servidor de mapas"
#: ../locale/scriptstrings/r.in.wms_to_translate.c:9
#: ../locale/scriptstrings/r.in.wms_to_translate.c:34
@@ -19546,11 +17613,8 @@
msgstr "Controlador usado para comunicación con el servidor"
#: ../locale/scriptstrings/r.in.wms_to_translate.c:15
-msgid ""
-"WMS_GDAL;Download data using GDAL WMS driver;WMS_GRASS;Download data using "
-"native GRASS-WMS driver;WMTS_GRASS;Download data using native GRASS-WMTS "
-"driver;OnEarth_GRASS;Download data using native GRASS-OnEarth driver;"
-msgstr ""
+msgid "WMS_GDAL;Download data using GDAL WMS driver;WMS_GRASS;Download data using native GRASS-WMS driver;WMTS_GRASS;Download data using native GRASS-WMTS driver;OnEarth_GRASS;Download data using native GRASS-OnEarth driver;"
+msgstr "WMS_GDAL;descargar datos usando controlador GDAL WMS;WMS_GRASS;descargar datos usando cotrolador nativo GRASS-WMS;WMTS_GRASS;descargar datos usando controlador nativo GRASS-WMTS;OnEarth_GRASS;descargar datos usando controlador nativo GRASS-OnEarth;"
#: ../locale/scriptstrings/r.in.wms_to_translate.c:17
msgid "WMS standard version"
@@ -19582,45 +17646,36 @@
#: ../locale/scriptstrings/r.in.wms_to_translate.c:30
msgid "Request data for this named region instead of the current region bounds"
-msgstr ""
+msgstr "Solicitar datos para esta región nombrada en vez de los bordes de la región actual"
#: ../locale/scriptstrings/r.in.wms_to_translate.c:33
msgid "Format: 0xRRGGBB"
msgstr "Formato: 0xRRGGBB"
#: ../locale/scriptstrings/r.in.wms_to_translate.c:35
-msgid ""
-"Capabilities file to parse (input). It is relevant for WMTS_GRASS and "
-"OnEarth_GRASS drivers"
+msgid "Capabilities file to parse (input). It is relevant for WMTS_GRASS and OnEarth_GRASS drivers"
msgstr ""
#: ../locale/scriptstrings/r.in.wms_to_translate.c:36
msgid "File where the server capabilities will be saved ('c' flag)"
-msgstr ""
-"Archivo donde las capacidades del servidor serán guardadas (opción 'c')"
+msgstr "Archivo donde las capacidades del servidor serán guardadas (opción 'c')"
#: ../locale/scriptstrings/r.in.wms_to_translate.c:37
msgid "Get the server capabilities then exit"
msgstr "Obtener las capacidades del servidor y luego salir"
#: ../locale/scriptstrings/r.in.wms_to_translate.c:39
-#, fuzzy
msgid "Do not request transparent data"
msgstr "No solicitar datos transparentes"
#: ../locale/scriptstrings/r.tileset_to_translate.c:1
-msgid ""
-"Produces tilings of the source projection for use in the destination region "
-"and projection."
-msgstr ""
-"Produce teselado de la proyección del origen para usarlo en la región y "
-"proyección de destino."
+msgid "Produces tilings of the source projection for use in the destination region and projection."
+msgstr "Produce teselado de la proyección del origen para usarlo en la región y proyección de destino."
#: ../locale/scriptstrings/r.tileset_to_translate.c:3
#: ../raster3d/r3.retile/main.c:97 ../raster/r.tile/main.c:44
-#, fuzzy
msgid "tiling"
-msgstr "ráster, teselado"
+msgstr "haciendo mosaico"
#: ../locale/scriptstrings/r.tileset_to_translate.c:4
msgid "Produces shell script output"
@@ -19631,10 +17686,8 @@
msgstr "Produce salida de cadena de consulta de servidor web de mapas"
#: ../locale/scriptstrings/r.tileset_to_translate.c:6
-msgid ""
-"Name of region to use instead of current region for bounds and resolution"
-msgstr ""
-"Nombre de la región a usar en vez de la actual para contornos y resolución"
+msgid "Name of region to use instead of current region for bounds and resolution"
+msgstr "Nombre de la región a usar en vez de la actual para contornos y resolución"
#: ../locale/scriptstrings/r.tileset_to_translate.c:7
msgid "Source projection"
@@ -19643,8 +17696,7 @@
#: ../locale/scriptstrings/r.tileset_to_translate.c:8
#: ../locale/scriptstrings/r.tileset_to_translate.c:10
msgid "Conversion factor from units to meters in source projection"
-msgstr ""
-"Factor de conversión de las unidades a metros en la proyección de origen"
+msgstr "Factor de conversión de las unidades a metros en la proyección de origen"
#: ../locale/scriptstrings/r.tileset_to_translate.c:9
msgid "Destination projection, defaults to this location's projection"
@@ -19668,16 +17720,12 @@
#, fuzzy
-msgid ""
-"Apply temporal and spatial operations on space time raster datasets using "
-"temporal raster algebra."
+msgid "Apply temporal and spatial operations on space time raster datasets using temporal raster algebra."
#: ../locale/scriptstrings/t.rast.algebra_to_translate.c:6
#, fuzzy
-msgid ""
-"r.mapcalc expression for temporal and spatial analysis of space time raster "
-"datasets"
+msgid "r.mapcalc expression for temporal and spatial analysis of space time raster datasets"
#: ../locale/scriptstrings/d.rast.leg_to_translate.c:1
@@ -19721,34 +17769,26 @@
msgstr "Número de líneas que deben aparecer en la leyenda"
#: ../locale/scriptstrings/d.rast.leg_to_translate.c:10
-#, fuzzy
msgid "Name of input raster map to generate legend from"
-msgstr "Nombre del mapa raster para generar leyenda de"
+msgstr "Nombre de mapa ráster de entrada desde el cual generar leyenda"
#: ../locale/scriptstrings/t.vect.observe.strds_to_translate.c:1
-msgid ""
-"Observes specific locations in a space time raster dataset over a period of "
-"time using vector points."
-msgstr ""
+msgid "Observes specific locations in a space time raster dataset over a period of time using vector points."
+msgstr "Observa ubicaciones específicas en un periodo de tiempo de un conjunto de datos raster espacio temporales usando puntos vectoriales."
#: ../locale/scriptstrings/t.vect.observe.strds_to_translate.c:6
#, fuzzy
-msgid ""
-"Name of the new created vector map that stores the sampled values in "
-"different layers"
+msgid "Name of the new created vector map that stores the sampled values in different layers"
msgstr "Nombre del mapa ráster a visualizar"
#: ../locale/scriptstrings/t.vect.observe.strds_to_translate.c:7
#, fuzzy
-msgid ""
-"Names of the vector columns to be created and to store sampled raster "
-"values, one name for each STRDS"
+msgid "Names of the vector columns to be created and to store sampled raster values, one name for each STRDS"
msgstr "Nombre de columna de atributos a usar para etiquetas"
#: ../locale/scriptstrings/i.oif_to_translate.c:1
-#, fuzzy
msgid "Calculates Optimum-Index-Factor table for spectral bands"
-msgstr "Calcula tabla de Factor de Índice Óptimo para bandas LANDSAT 1-5 y 7"
+msgstr "Calcula tabla de Factor de Índice Óptimo para bandas espectrales"
#: ../locale/scriptstrings/i.oif_to_translate.c:6
#: ../locale/scriptstrings/t.info_to_translate.c:9
@@ -19758,25 +17798,20 @@
msgstr "Imprimir en estilo de script de consola"
#: ../locale/scriptstrings/t.vect.db.select_to_translate.c:1
-#, fuzzy
-msgid ""
-"Prints attributes of vector maps registered in a space time vector dataset."
+msgid "Prints attributes of vector maps registered in a space time vector dataset."
+msgstr "Muestra atributos de mapas vectoriales registrados en un conjunto de datos espacio temporales"
-#, fuzzy
msgid "Lists registered maps of a space time raster3d dataset."
+msgstr "Enlista mapas registrados de un conjunto de datos raster 3D espacio temporales."
#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:8
-#, fuzzy
msgid "Order the space time dataset by category"
#: ../locale/scriptstrings/t.snap_to_translate.c:1
-#, fuzzy
msgid "Snaps temporally the maps of a space time dataset."
+msgstr "Autoensambla temporalmente los mapas de un conjuto de datos espacio temporal."
#: ../locale/scriptstrings/t.snap_to_translate.c:3
#: ../locale/scriptstrings/t.shift_to_translate.c:3
@@ -19791,15 +17826,13 @@
msgstr "Nombre de un conjunto de datos espacio temporales existente"
#: ../locale/scriptstrings/i.image.mosaic_to_translate.c:1
-#, fuzzy
msgid "Mosaics several images and extends colormap."
-msgstr ""
-"Hace mosaicos de hasta 4 imágenes y extiende colormap; crea mapas *.mosaico"
+msgstr "Hace mosaicos de varias imágenes y extiende colormap."
#: ../locale/scriptstrings/i.image.mosaic_to_translate.c:4
#: ../raster/r.patch/main.c:60
msgid "mosaicking"
-msgstr ""
+msgstr "haciendo mosaicos"
#: ../locale/scriptstrings/t.shift_to_translate.c:1
#, fuzzy
@@ -19815,39 +17848,28 @@
msgstr "Cambiar granularidad"
#: ../locale/scriptstrings/t.shift_to_translate.c:10
-msgid ""
-"Format absolute time: \"x years, x months, x weeks, x days, x hours, x "
-"minutes, x seconds\", relative time is of type integer"
-msgstr ""
+msgid "Format absolute time: \"x years, x months, x weeks, x days, x hours, x minutes, x seconds\", relative time is of type integer"
+msgstr "Formato de tiempo absoluto \"x años, x meses, x semanas, x días, x horas, x minutos, x segundos\" tiempo relativo es de tipo entero"
#: ../locale/scriptstrings/v.dissolve_to_translate.c:1
-msgid ""
-"Dissolves boundaries between adjacent areas sharing a common category number "
-"or attribute."
-msgstr ""
-"Disuelve contornos entre áreas adyacentes que comparten un número de "
-"categoría o atributo común."
+msgid "Dissolves boundaries between adjacent areas sharing a common category number or attribute."
+msgstr "Disuelve contornos entre áreas adyacentes que comparten un número de categoría o atributo común."
#: ../locale/scriptstrings/v.dissolve_to_translate.c:6
msgid "Layer number or name."
msgstr "Número o nombre de la capa."
#: ../locale/scriptstrings/v.dissolve_to_translate.c:7
-#, fuzzy
msgid "Name of attribute column used to dissolve common boundaries"
-msgstr "Nombre de columna usada para disolver contornos comunes"
+msgstr "Nombre de la columna de atributo usada para disolver contornos comunes"
#: ../locale/scriptstrings/v.to.lines_to_translate.c:1
-#, fuzzy
msgid "Converts vector polygons or points to lines."
-msgstr ""
-"Convierte un mapa vectorial binario de GRASS (sólo puntos) en una capa de "
-"mapa ráster 3D de GRASS."
+msgstr "Convierte polígonos vectoriales o puntos en líneas."
#: ../locale/scriptstrings/v.to.lines_to_translate.c:7
-#, fuzzy
msgid "Method used for point interpolation"
+msgstr "Método a usar para interpolación puntos"
#: ../locale/scriptstrings/v.to.lines_to_translate.c:8
#: ../locale/scriptstrings/r.reclass.area_to_translate.c:6
@@ -19882,46 +17904,36 @@
msgstr "Forzar eliminación (requerido para el borrado real de la tabla)"
#: ../locale/scriptstrings/v.db.droptable_to_translate.c:6
-#, fuzzy
msgid "Table name (default: vector map name)"
-msgstr ""
-"Nombre de la nueva tabla de atributos (por omisión: nombre del mapa "
-"vectorial)"
+msgstr "Nombre de tabla (predeterminado: nombre de mapa vectorial)"
#: ../locale/scriptstrings/r.rgb_to_translate.c:1
-#, fuzzy
msgid "Splits a raster map into red, green and blue maps."
-msgstr "Convierte un mapa ráster en una capa de mapa vectorial."
+msgstr "Divide un mapa ráster en mapas rojo, verde y azul."
#: ../locale/scriptstrings/r.rgb_to_translate.c:4
-#, fuzzy
msgid "separate"
-msgstr "Separador de campos"
+msgstr "separar"
#: ../locale/scriptstrings/r.rgb_to_translate.c:5
msgid "split"
-msgstr ""
+msgstr "dividir"
#: ../locale/scriptstrings/r.rgb_to_translate.c:6
-#, fuzzy
msgid "Red channel raster map name"
-msgstr "Nombre del mapa ráster resultante"
+msgstr "Nombre de mapa ráster de canal rojo"
#: ../locale/scriptstrings/r.rgb_to_translate.c:7
-#, fuzzy
msgid "Green channel raster map name"
+msgstr "Nombre de mapa ráster de canal verde"
#: ../locale/scriptstrings/r.rgb_to_translate.c:8
-#, fuzzy
msgid "Blue channel raster map name"
+msgstr "Nombre de mapa ráster de canal azul"
#: ../locale/scriptstrings/r.unpack_to_translate.c:1
-#, fuzzy
-msgid ""
-"Imports a raster map as GRASS GIS specific archive file (packed with r.pack)"
+msgid "Imports a raster map as GRASS GIS specific archive file (packed with r.pack)"
+msgstr "Importa un mapa ráster de un archivo de almacenamiento específico de GRASS GIS (empaquetado con r.pack)"
#: ../locale/scriptstrings/r.unpack_to_translate.c:4
#: ../locale/scriptstrings/v.unpack_to_translate.c:4
@@ -19932,19 +17944,15 @@
#: ../locale/scriptstrings/r.unpack_to_translate.c:5
#: ../locale/scriptstrings/v.unpack_to_translate.c:5
-#, fuzzy
msgid "Name of input pack file"
+msgstr "Nombre de archivo pack de entrada"
#: ../locale/scriptstrings/r.unpack_to_translate.c:6
-#, fuzzy
msgid "Name for output raster map (default: taken from input file internals)"
+msgstr "Nombre para mapa ráster de salida (predeterminado: se toma de archivo de entrada internos)"
#: ../locale/scriptstrings/t.vect.algebra_to_translate.c:1
-msgid ""
-"Apply temporal and spatial oeprations on space time vector datasets using "
-"temporal vector algebra."
+msgid "Apply temporal and spatial oeprations on space time vector datasets using temporal vector algebra."
msgstr ""
#: ../locale/scriptstrings/t.vect.algebra_to_translate.c:6
@@ -19953,9 +17961,8 @@
msgstr "Expresión mapcalc espacio temporal"
#: ../locale/scriptstrings/t.merge_to_translate.c:1
-#, fuzzy
msgid "Merges several space time datasets into a single space time dataset."
-msgstr "Convierte mapas ráster 3D en mapas ráster 2D"
+msgstr "Combina varios conjuntos de datos espacio temporales en un solo conjunto de datos espacio temporal."
#: ../locale/scriptstrings/t.merge_to_translate.c:4 ../raster/r.patch/main.c:61
msgid "merge"
@@ -19963,37 +17970,28 @@
#: ../locale/scriptstrings/t.merge_to_translate.c:6
#: ../locale/scriptstrings/t.remove_to_translate.c:8
-#, fuzzy
msgid "inputs"
-msgstr "Entrada"
+msgstr "entradas"
#: ../locale/scriptstrings/t.sample_to_translate.c:1
-#, fuzzy
-msgid ""
-"Samples the input space time dataset(s) with a sample space time dataset and "
-"print the result to stdout."
+msgid "Samples the input space time dataset(s) with a sample space time dataset and print the result to stdout."
+msgstr "Muestrea el conjuto(s) de datos espacio temporales de entrada con un conjunto de datos espacio temporales muestrales y muestra el resultado en la salida estándar."
#: ../locale/scriptstrings/t.sample_to_translate.c:5
-#, fuzzy
msgid "Name of the sample space time dataset"
+msgstr "Nombre de conjunto de datos espacio temporales"
#: ../locale/scriptstrings/t.sample_to_translate.c:8
-#, fuzzy
msgid "Type of the sample space time dataset"
+msgstr "Tipo del conjunto de datos espacio temporales de muestra"
#: ../locale/scriptstrings/t.sample_to_translate.c:9
-#, fuzzy
msgid "Field separator between output columns, default is tabular \" | \""
+msgstr "Caracter que separa campos entre las columnas de salida, el predeterminado es tabular \" | \" "
#: ../locale/scriptstrings/t.sample_to_translate.c:10
-msgid ""
-"Do not use \",\" as this char is reserved to list several map ids in a "
-"sample granule"
-msgstr ""
+msgid "Do not use \",\" as this char is reserved to list several map ids in a sample granule"
+msgstr "No usar \",\" ya que este caracter está reservado para enlistar varias ids de mapas en un gránulo muestral"
#: ../locale/scriptstrings/t.sample_to_translate.c:11
#: ../locale/scriptstrings/t.list_to_translate.c:18
@@ -20007,68 +18005,44 @@
msgstr "Revisar superposición espacial"
-msgid ""
-"Detects accumulation patterns in temporally accumulated space time raster "
-"datasets created by t.rast.accumulate."
-msgstr ""
+msgid "Detects accumulation patterns in temporally accumulated space time raster datasets created by t.rast.accumulate."
+msgstr "Detecta patrones de acumulación en conjuntos de datos ráster espacio temporales temporalmente acumulados creados por t.rast.accumulate."
#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:6
-msgid ""
-"Input space time raster dataset that specifies the minimum values to detect "
-"the accumulation pattern"
-msgstr ""
+msgid "Input space time raster dataset that specifies the minimum values to detect the accumulation pattern"
+msgstr "Conjunto de datos espacio temporales de entrada que especifica el valor mínimo para detectar patrón de acumulación"
#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:7
-msgid ""
-"Input space time raster dataset that specifies the maximum values to detect "
-msgstr ""
+msgid "Input space time raster dataset that specifies the maximum values to detect the accumulation pattern"
+msgstr "Conjunto de datos espacio temporales de entrada que especifica el valor máximo para detectar patrón de acumulación"
#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:8
-msgid ""
-"The output space time raster dataset that stores the occurrence of the the "
-"accumulation pattern using the provided data range"
-msgstr ""
+msgid "The output space time raster dataset that stores the occurrence of the the accumulation pattern using the provided data range"
+msgstr "Conjunto de datos ráster espacio temporales de salida que guarda la ocurrencia del patrón de acumulación usando rango de datos que se proveyó"
#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:9
-msgid ""
-"The output space time raster dataset that stores the indication of the "
-"start, intermediate and end of the specified data range"
-msgstr ""
+msgid "The output space time raster dataset that stores the indication of the start, intermediate and end of the specified data range"
+msgstr "El conjunto de datos ráster espacio temporales de salida que guarda la indicación del tiempo de inicio, intermedio y término del rango de datos especificados"
#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:16
-msgid ""
-"time format, 'count' for numerical suffix with a specific number of digits "
-"(default %05)"
+msgid "Suffix to add at basename: set 'gran' for granularity, 'time' for the full time format, 'count' for numerical suffix with a specific number of digits (default %05)"
msgstr ""
#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:17
-msgid ""
-"The minimum and maximum value of the occurrence of accumulated values, these "
-"values will be used if the min/max space time raster datasets are not "
-"specified"
-msgstr ""
+msgid "The minimum and maximum value of the occurrence of accumulated values, these values will be used if the min/max space time raster datasets are not specified"
+msgstr "El valor mínimo y máximo de la ocurrencia de valores acumulados, estos valores serán usados si no se especifica mínimo/máximo de conjunto de datos ráster espacio temporales"
#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:18
-msgid ""
-"The user defined values that indicate start, intermediate and end status in "
-"the indicator output space time raster dataset"
-msgstr ""
+msgid "The user defined values that indicate start, intermediate and end status in the indicator output space time raster dataset"
+msgstr "Valores definidos por el usuario que indican estátus de inicio, intermedio y término en el conjunto de datos ráster de indicadores de salida"
#: ../locale/scriptstrings/d.to.rast_to_translate.c:1
-#, fuzzy
msgid "Saves the contents of the active display monitor to a raster map."
-msgstr "Guarda el contenido del monitor activo en un fichero gráfico."
+msgstr "Guarda el contenido del monitor de visualización activo en un mapa ráster"
-#, fuzzy
-msgid ""
-"3D raster map of a space time 3D raster dataset."
-msgstr ""
-"ráster."
+msgid "Calculates univariate statistics from the non-null cells for each registered 3D raster map of a space time 3D raster dataset."
+msgstr "Calcula estadísticas univariadas a partir de celdas no nulas para cada mapa ráster 3D registrado en un conjunto de datos ráster 3D espacio temporales."
#: ../locale/scriptstrings/r.shade_to_translate.c:1
#: ../locale/scriptstrings/d.shade_to_translate.c:1
@@ -20090,15 +18064,13 @@
#: ../locale/scriptstrings/r.shade_to_translate.c:7
#: ../locale/scriptstrings/d.shade_to_translate.c:7
-#, fuzzy
msgid "Name of shaded relief or aspect raster map"
-msgstr "Nombre del mapa compartido de relieve u orientación"
+msgstr "Nombre de mapa ráster de sombreado de relieve o de aspecto"
#: ../locale/scriptstrings/r.shade_to_translate.c:8
#: ../locale/scriptstrings/d.shade_to_translate.c:8
-#, fuzzy
msgid "Name of raster to drape over relief raster map"
-msgstr "Nombre del ráster superponer sobre mapa de relieve"
+msgstr "Nombre de mapa ráster a colocar sobre mapa ráster de relieve"
#: ../locale/scriptstrings/r.shade_to_translate.c:9
#: ../locale/scriptstrings/d.shade_to_translate.c:9
@@ -20106,9 +18078,8 @@
msgstr "Típicamente, este ráster es de elevación u otro ráster colorido"
#: ../locale/scriptstrings/r.shade_to_translate.c:10
-#, fuzzy
msgid "Name of shaded raster map"
-msgstr "Nombre del segundo mapa ráster"
+msgstr "Nombre de mapa ráster de sombreado"
#: ../locale/scriptstrings/r.shade_to_translate.c:11
#: ../locale/scriptstrings/d.shade_to_translate.c:10
@@ -20116,33 +18087,25 @@
msgstr "Porcentaje para aumentar el brilloConvergencia porcentual"
#: ../locale/scriptstrings/r.shade_to_translate.c:12 ../raster/r.his/main.c:121
-#, fuzzy
msgid "Color to use instead of NULL values"
-msgstr "Ignorar celdas de datos cero (0) en vez de celdas NULAS"
+msgstr "Color a usar en vez de valores nulos (NULL)"
#: ../locale/scriptstrings/r.shade_to_translate.c:13
-#, fuzzy
msgid "Either a standard color name, R:G:B triplet, or \"none\""
-msgstr "O un color standard GRASS, triplete R:G:B, o \"ninguno\""
+msgstr "Puede ser un nombre de color estándar, triplete R:G:B, o \"none\""
#: ../locale/scriptstrings/r.shade_to_translate.c:14 ../raster/r.his/main.c:126
-#, fuzzy
msgid "Use colors from color tables for NULL values"
-msgstr "Obtener color de texto del valor de color de la celda"
+msgstr "Usar colores desde tabla de colores para valores nulos (NULL)"
#: ../locale/scriptstrings/db.univar_to_translate.c:1
-#, fuzzy
msgid "Calculates univariate statistics on selected table column."
-msgstr ""
-"Calcula estadísticas univariante sobre la columna de tabal seleccionada para "
-"un mapa vectorial de GRASS."
+msgstr "Calcula estadísticas univariadas en columna seleccionada de tabla."
#: ../locale/scriptstrings/db.univar_to_translate.c:5
#: ../locale/scriptstrings/v.db.univar_to_translate.c:5
-#, fuzzy
-msgid ""
-"Name of attribute column on which to calculate statistics (must be numeric)"
-msgstr "Columna sobre la que calcular las estadísticas (debe ser numérica)"
+msgid "Name of attribute column on which to calculate statistics (must be numeric)"
+msgstr "Nombre de columna de atributo a la que se le calcularán estadísticas (debe ser numérica)"
#: ../locale/scriptstrings/db.univar_to_translate.c:7
#: ../locale/scriptstrings/v.db.univar_to_translate.c:7
@@ -20151,57 +18114,40 @@
#: ../locale/scriptstrings/db.univar_to_translate.c:8
#: ../locale/scriptstrings/v.db.univar_to_translate.c:8
-#, fuzzy
msgid "Print stats in shell script style"
-msgstr "Imprimir las estadísticas en estilo de script de consola"
+msgstr "Mostrar las estadísticas en estilo de script de consola de comandos"
-#, fuzzy
msgid "Lists registered maps of a space time vector dataset."
+msgstr "Enlista mapas registrados de un conjunto de datos vectoriales espacio temporales."
#: ../locale/scriptstrings/v.db.update_to_translate.c:1
-#, fuzzy
msgid "Updates a column in the attribute table connected to a vector map."
-msgstr ""
-"Permite actualizar una columna en la tabla de atributos conectada a un mapa "
-"vectorial."
+msgstr "Actualiza una columna en la tabla de atributos conectada a un mapa vectorial."
#: ../locale/scriptstrings/v.db.update_to_translate.c:5
-#, fuzzy
msgid "Name of attribute column to update"
-msgstr "Nombre de columna de atributos a usar para etiquetas"
+msgstr "Nombre de la columna de atributos a actualizar"
#: ../locale/scriptstrings/v.db.update_to_translate.c:6
msgid "Literal value to update the column with"
msgstr "Valor literal con el cual actualizar la columna"
#: ../locale/scriptstrings/v.db.update_to_translate.c:7
-#, fuzzy
-msgid ""
-"Name of other attribute column to query, can be combination of columns (e.g. "
-"co1+col2)"
-msgstr ""
-"Valor con el que actualizar la columna (los valores varchar tienen que estar "
-"entre comillas simples, ej.: 'grass')"
+msgid "Name of other attribute column to query, can be combination of columns (e.g. co1+col2)"
+msgstr "Nombre de otra columna de atributos a consultar, puede ser combinación de columnas (ej. col1 + col2)"
#: ../locale/scriptstrings/v.db.update_to_translate.c:8
msgid "Name of SQLite extension file for extra functions (SQLite backend only)"
msgstr ""
#: ../locale/scriptstrings/d.redraw_to_translate.c:1
-#, fuzzy
msgid "Redraws the content of currently selected monitor."
-msgstr "Impirmir el nombre de la pantalla seleccionada actualmente"
+msgstr "Redibuja el contenido del monitor actualmente seleccionado."
#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:1
-#, fuzzy
-msgid ""
-"Create a 3D raster map from an assemblage of many coordinates using "
-"univariate statistics"
-msgstr ""
-"Crear un mapa ráster a partir de un ensamblaje de muchas coordenadas usando "
-"estadísticas univariantes."
+msgid "Create a 3D raster map from an assemblage of many coordinates using univariate statistics"
+msgstr "Crear un mapa ráster 3D a patrir de un ensamblaje de varias coordenadas usando estadísticas univariadas"
#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:9
#: ../raster3d/r3.in.lidar/main.c:131 ../raster/r.in.xyz/main.c:163
@@ -20225,10 +18171,8 @@
msgstr "Ignorar líneas quebradas"
#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:13
-#, fuzzy
msgid "ASCII file containing input data"
-msgstr ""
-"Archivo ASCII que contiene los datos de entrada (o \"-\" para leer de stdin)"
+msgstr "Archivo ASCII que contiene datos de entrada"
#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:15
#: ../raster/r.in.xyz/main.c:179 ../raster/r.in.lidar/main.c:137
@@ -20253,9 +18197,7 @@
#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:19
#: ../raster/r.in.xyz/main.c:229
msgid "Column number of x coordinates in input file (first column is 1)"
-msgstr ""
-"Número de columna de las coordenadas X en el archivo de entrada (la primera "
-"columna es 1)"
+msgstr "Número de columna de las coordenadas X en el archivo de entrada (la primera columna es 1)"
#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:21
#: ../raster/r.in.xyz/main.c:237
@@ -20263,9 +18205,8 @@
msgstr "Número de columna de las coordenadas Y en el archivo de entrada"
#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:23
-#, fuzzy
msgid "Column number of z coordinates in input file"
-msgstr "Número de columna de las coordenadas Y en el archivo de entrada"
+msgstr "Número de columna de las coordenadas z en el archivo de entrada"
#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:25
#: ../raster/r.in.xyz/main.c:245
@@ -20273,19 +18214,16 @@
msgstr "Número de columna de los valores de datos en el archivo de entrada"
#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:26
-#, fuzzy
msgid "If not given or set to 0, the data points' z-values are used"
-msgstr "Si no se da se usa el nombre del mapa de entrada"
+msgstr "Si no se da o se establece en 0, se usan los datos de los valores z de los puntos"
#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:28
-#, fuzzy
msgid "Filter range for value column data (min,max)"
-msgstr "Rango de filtrado para los datos Z (mínimo, máximo)"
+msgstr "Filtrar rango para valor datos de columna (mín,máx)"
#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:29
-#, fuzzy
msgid "Scaling factor to apply to value column data"
-msgstr "Factor de escala para valores de columna de atributos"
+msgstr "Factor de escalamiento a aplicar a datos de columna de valores"
#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:30
#: ../raster/r.in.xyz/main.c:308 ../raster/r.in.lidar/main.c:226
@@ -20299,66 +18237,45 @@
#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:33
#: ../raster/r.in.xyz/main.c:326 ../raster/r.in.lidar/main.c:245
-msgid ""
-"Discard <trim> percent of the smallest and <trim> percent of the largest "
-"observations"
-msgstr ""
-"Descartar <trim> porcentaje de las menores y <trim> porcentaje de las "
-"mayores observaciones"
+msgid "Discard <trim> percent of the smallest and <trim> percent of the largest observations"
+msgstr "Descartar <trim> porcentaje de las menores y <trim> porcentaje de las mayores observaciones"
#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:35
-#, fuzzy
msgid "Number of parallel processes to launch"
+msgstr "Número de procesos paralelos a lanzar"
#: ../locale/scriptstrings/v.unpack_to_translate.c:1
-#, fuzzy
-msgid ""
-"Imports a vector map as GRASS GIS specific archive file (packed with v.pack)"
+msgid "Imports a vector map as GRASS GIS specific archive file (packed with v.pack)"
+msgstr "Importa un mapa vectorial de un archivo de almacenamiento específico de GRASS GIS (empaquetado con v.pack)"
#: ../locale/scriptstrings/v.unpack_to_translate.c:6
msgid "Name for output vector map"
msgstr "Nombre para el mapa vectorial de salida"
#: ../locale/scriptstrings/v.unpack_to_translate.c:7
-#, fuzzy
msgid "Default: taken from input file internals"
-msgstr "Nombre para el mapa ráster de salida (por omisión: el de entrada)"
+msgstr "Predeterminado: tomado de los archivos internos de entrada"
#: ../locale/scriptstrings/d.what.rast_to_translate.c:1
-#, fuzzy
-msgid ""
-"Allows the user to interactively query raster map layers at user-selected "
-"locations."
-msgstr ""
-"Permite consultar de forma interactiva una capa vectorial en localizaciones "
-"seleccionadas por el usuario dentro de la región geográfica actual."
+msgid "Allows the user to interactively query raster map layers at user-selected locations."
+msgstr "Permite al usuario consultar de forma interactiva una capa de mapa ráster en ubicaciones seleccionadas por el usuario."
#: ../locale/scriptstrings/v.import_to_translate.c:1
-#, fuzzy
-msgid ""
-"Imports vector data into a GRASS vector map using OGR library and reprojects "
-"on the fly."
-msgstr ""
-"Importa datos vecotriales a mapas vectoriales de GRASS usando la librería "
-"OGR."
+msgid "Imports vector data into a GRASS vector map using OGR library and reprojects on the fly."
+msgstr "Importa datos vectoriales a mapa vectorial GRASS usando librería OGR y reproyecta al vuelo utilizando la librería OGR."
#: ../locale/scriptstrings/v.import_to_translate.c:11
-#, fuzzy
msgid "Output vector map extent"
-msgstr "Mapa vectorial de salida de errores"
+msgstr "Extensión de mapa vectorial de salida"
#: ../locale/scriptstrings/v.import_to_translate.c:12
-#, fuzzy
msgid "input;extent of input map;region;extent of current region"
-msgstr "Alinear la región actual al mapa raster de entrada"
+msgstr "entrada;extensión de mapa de entrada;región;extensión de región actual"
#: ../locale/scriptstrings/v.import_to_translate.c:20
#: ../locale/scriptstrings/v.import_to_translate.c:22
-#, fuzzy
msgid "Input SRS"
-msgstr "Entrada"
+msgstr "SRS de entrada"
#: ../locale/scriptstrings/v.import_to_translate.c:21
#: ../general/g.proj/main.c:159
@@ -20371,9 +18288,8 @@
msgstr "Número de índice de los parámetros de transformación del Datum"
#: ../locale/scriptstrings/v.import_to_translate.c:24
-#, fuzzy
msgid "-1 to list available datum transform parameters"
-msgstr "Número de índice de los parámetros de transformación del Datum"
+msgstr "-1 para enlistar todos los parámetros de transformación de datum disponibles"
#: ../locale/scriptstrings/db.droptable_to_translate.c:1
msgid "Drops an attribute table."
@@ -20386,34 +18302,28 @@
msgstr "Forzar eliminación (requerido para la eliminación real de archivos)"
#: ../locale/scriptstrings/db.droptable_to_translate.c:5
-#, fuzzy
msgid "Name of database driver"
-msgstr "Nombre de un archivo de base de datos"
+msgstr "Nombre del controlador de la base de datos"
#: ../locale/scriptstrings/db.droptable_to_translate.c:6
-#, fuzzy
msgid "If not given then default driver is used"
+msgstr "Si no se da se usa el controlador predeterminado"
#: ../locale/scriptstrings/db.droptable_to_translate.c:8
-#, fuzzy
msgid "Name of database"
-msgstr "Nombre de la base de datos antigua"
+msgstr "Nombre de base de datos"
#: ../locale/scriptstrings/db.droptable_to_translate.c:9
-#, fuzzy
msgid "If not given then default database is used"
+msgstr "Si no se da se usa el controlador de bases de datos predeterminado"
#: ../locale/scriptstrings/db.droptable_to_translate.c:11
-#, fuzzy
msgid "Name of table to drop"
-msgstr "Nombre de la columna atributo utilizada para la opción 'consulta'"
+msgstr "Nombre de tabla a eliminar"
#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:1
-#, fuzzy
msgid "Imports Mapgen or Matlab-ASCII vector maps into GRASS."
-msgstr "Importar mapas vectoriales Mapgen o Matlab a GRASS."
+msgstr "Importa a GRASS mapas vectoriales Mapgen o ASCII de Matlab."
#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:4
msgid "Input map is in Matlab format"
@@ -20421,8 +18331,7 @@
#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:5
msgid "Create a 3D vector points map from 3 column Matlab data"
-msgstr ""
-"Crear un mapa vectorial 3D de puntos a partir de datos Matlab de 3 columnas"
+msgstr "Crear un mapa vectorial 3D de puntos a partir de datos Matlab de 3 columnas"
#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:6
msgid "Name of input file in Mapgen/Matlab format"
@@ -20430,12 +18339,11 @@
#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:7
msgid "Name for output vector map (omit for display to stdout)"
-msgstr ""
-"Nombre para el mapa vectorial de salida (omitir para visualización a stdout)"
+msgstr "Nombre para el mapa vectorial de salida (omitir para visualización a stdout)"
#: ../locale/scriptstrings/g.search.modules_to_translate.c:1
msgid "Search in GRASS modules using keywords"
-msgstr ""
+msgstr "Buscar módulos GRASS usando palabras clave"
#: ../locale/scriptstrings/g.search.modules_to_translate.c:2
#: ../locale/scriptstrings/g.extension.all_to_translate.c:3
@@ -20458,48 +18366,39 @@
#: ../locale/scriptstrings/g.search.modules_to_translate.c:3
msgid "modules"
-msgstr ""
+msgstr "módulos"
#: ../locale/scriptstrings/g.search.modules_to_translate.c:4
-#, fuzzy
msgid "search"
-msgstr "ruta de búsqueda"
+msgstr "burcar"
#: ../locale/scriptstrings/g.search.modules_to_translate.c:5
-#, fuzzy
msgid "Keyword to be searched"
-msgstr "Tipos a ser extraídos"
+msgstr "Palabra clave que será buscada"
#: ../locale/scriptstrings/g.search.modules_to_translate.c:6
-msgid ""
-"Display only modules where all keywords are available (AND), default: OR"
-msgstr ""
+msgid "Display only modules where all keywords are available (AND), default: OR"
+msgstr "Mostrar solamente los módulos que contienen todas las palabras clave (AND), predeterminado: OR"
#: ../locale/scriptstrings/g.search.modules_to_translate.c:8
msgid "Search in manual pages too (can be slow)"
-msgstr ""
+msgstr "Buscar también en páginas del manual (puede ser lento)"
#: ../locale/scriptstrings/g.search.modules_to_translate.c:10
msgid "Use colorized (more readable) output to terminal"
-msgstr ""
+msgstr "Usar salida coloreada (más fácil de leer) en la terminal"
#: ../locale/scriptstrings/g.search.modules_to_translate.c:12
-#, fuzzy
msgid "Shell script format"
-msgstr "Imprimir en estilo de script de consola"
+msgstr "Formato de consola de comandos"
#: ../locale/scriptstrings/g.search.modules_to_translate.c:14
-#, fuzzy
msgid "JSON format"
-msgstr "Formato de salida"
+msgstr "Formato JSON"
#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:1
-msgid ""
-"Adds one or more columns to the attribute table connected to a given vector "
-"map."
-msgstr ""
-"Añade una o más columnas a la tabla de atributos conectada a un mapa "
-"vectorial dado."
+msgid "Adds one or more columns to the attribute table connected to a given vector map."
+msgstr "Añade una o más columnas a la tabla de atributos conectada a un mapa vectorial dado."
#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:5
msgid "Layer number where to add column(s)"
@@ -20508,54 +18407,37 @@
#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:6
#: ../locale/scriptstrings/v.db.addtable_to_translate.c:10
msgid "Name and type of the new column(s) ('name type [,name type, ...]')"
-msgstr ""
-"Nombre y tipo de la nueva(s) columna(s) ('nombre tipo [,nombre tipo, ...]')"
+msgstr "Nombre y tipo de la nueva(s) columna(s) ('nombre tipo [,nombre tipo, ...]')"
#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:7
#: ../locale/scriptstrings/v.db.addtable_to_translate.c:11
#, fuzzy
-msgid ""
-"Types depend on database backend, but all support VARCHAR(), INT, DOUBLE "
-"PRECISION and DATE. Example: 'label varchar(250), value integer'"
-msgstr ""
-"Los tipos de datos dependen de la base de datos de destino, pero todas "
-"soportan VARCHAR(), INT, DOUBLE PRECISION Y FECHA)"
+msgid "Types depend on database backend, but all support VARCHAR(), INT, DOUBLE PRECISION and DATE. Example: 'label varchar(250), value integer'"
+msgstr "Los tipos de datos dependen de la base de datos de destino, pero todas soportan VARCHAR(), INT, DOUBLE PRECISION Y FECHA)"
#: ../locale/scriptstrings/t.vect.univar_to_translate.c:1
-#, fuzzy
-msgid ""
-"Calculates univariate statistics of attributes for each registered vector "
-"map of a space time vector dataset"
-msgstr ""
-"Calcula estadísticas univariantes a partir de celdas no nulas de un mapa "
-"ráster."
+msgid "Calculates univariate statistics of attributes for each registered vector map of a space time vector dataset"
+msgstr "Calcula estadísticas univariadas para cada atributo para cada mapa vectorial registrado en un conjunto de datos espacio temporal"
#: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:1
-#, fuzzy
-msgid ""
-"Performs r3.mapcalc expressions on maps of sampled space time 3D raster "
-"datasets."
+msgid "Performs r3.mapcalc expressions on maps of sampled space time 3D raster datasets."
+msgstr "Ejecuta expresiones de r3.mapcalc en mapas muestreados de conjunto de datos ráster 3D espacio temporales."
#: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:7
msgid "r3.mapcalc expression applied to each time step of the sampled data"
msgstr "expresión r3.mapcalc aplicada a cada tiempo de los datos muestreados"
#: ../locale/scriptstrings/t.vect.extract_to_translate.c:1
-#, fuzzy
msgid "Extracts a subset of a space time vector dataset."
+msgstr "Extraer subconjunto de conjunto de datos espacio temporales vectoriales."
#: ../locale/scriptstrings/t.vect.extract_to_translate.c:9
-msgid ""
-"The number of v.extract processes to run in parallel. Use only if database "
-"backend is used which supports concurrent writing"
-msgstr ""
+msgid "The number of v.extract processes to run in parallel. Use only if database backend is used which supports concurrent writing"
+msgstr "El número de procesos v.extract a ejecutar de manera paralela. Usar solamente si se usa backend de base de datos que soporte escritura concurrente"
#: ../locale/scriptstrings/t.vect.extract_to_translate.c:10
-#, fuzzy
msgid "Register empty maps"
-msgstr "Mapas raster de entrada"
+msgstr "Registrado mapas vacíos"
#: ../locale/scriptstrings/v.centroids_to_translate.c:1
msgid "Adds missing centroids to closed boundaries."
@@ -20570,85 +18452,64 @@
msgstr "Valor inicial de número de categoría"
#: ../locale/scriptstrings/g.extension.all_to_translate.c:1
-#, fuzzy
msgid "Rebuilds or removes all locally installed GRASS Addons extensions."
-msgstr "Prefijo donde instalar la extensión"
+msgstr "Reconstuir o eliminar todos los Complementos de extensión instalados localmente"
#: ../locale/scriptstrings/g.extension.all_to_translate.c:2
-msgid ""
-"By default only extensions built against different GIS Library are rebuilt."
-msgstr ""
+msgid "By default only extensions built against different GIS Library are rebuilt."
+msgstr "De manera predeterminada solamente las extensiones construidas con GIS Library diferente son reconstruidas."
#: ../locale/scriptstrings/g.extension.all_to_translate.c:4
#: ../locale/scriptstrings/g.extension_to_translate.c:4
-#, fuzzy
msgid "installation"
-msgstr "Asignación de métricas"
+msgstr "instalación"
#: ../locale/scriptstrings/g.extension.all_to_translate.c:5
#: ../locale/scriptstrings/g.extension_to_translate.c:5
-#, fuzzy
msgid "extensions"
-msgstr "Codificación de caracteres"
+msgstr "extensiones"
#: ../locale/scriptstrings/g.extension.all_to_translate.c:7
-#, fuzzy
msgid "Force operation (required for removal)"
-msgstr "Forzar eliminación (requerido para el borrado real de la tabla)"
+msgstr "Forzar operación (requerido para el remover)"
#: ../locale/scriptstrings/db.dropcolumn_to_translate.c:1
-#, fuzzy
msgid "Drops a column from selected attribute table."
-msgstr "Elimina una columna de la tabla de atributos seleccionada"
+msgstr "Elimina una columna de la tabla de atributos seleccionada."
#: ../locale/scriptstrings/d.correlate_to_translate.c:1
-#, fuzzy
msgid "Prints a graph of the correlation between raster maps (in pairs)."
-msgstr ""
-"Imprime un gráfico de la correlación entre dos capas de datos (en pares)."
+msgstr "Muestra una gráfica de la correlación entre dos mapas ráster (en pares)."
#: ../locale/scriptstrings/d.correlate_to_translate.c:5
#: ../locale/scriptstrings/d.polar_to_translate.c:3
-#, fuzzy
msgid "diagram"
-msgstr "mostrar, diagrama"
+msgstr "diagrama"
#: ../locale/scriptstrings/d.correlate_to_translate.c:6
-#, fuzzy
msgid "correlation"
-msgstr "Correlación"
+msgstr "correlación"
-#, fuzzy
msgid "Lists space time datasets and maps registered in the temporal database."
-msgstr ""
-"Nombre(s) de los directorio(s) de mapas existentes a eliminar de la lista de "
-"búsqueda"
+msgstr "Enlista conjuntos de datos espacio temporales y los mapas registrados en la base de datos temporal."
#: ../locale/scriptstrings/t.list_to_translate.c:6
-#, fuzzy
msgid "Type of the space time dataset or map, default is strds"
+msgstr "Tipo del conjunto de datos o mapa espacio temporal, el predeterminado es strds"
#: ../locale/scriptstrings/t.list_to_translate.c:9
#: ../locale/scriptstrings/t.list_to_translate.c:12
-msgid ""
-"Columns number_of_maps and granularity only available for space time datasets"
-msgstr ""
+msgid "Columns number_of_maps and granularity only available for space time datasets"
+msgstr "Columnas number_of_maps y granularidad solamente disponibles para conjuntos de datos espacio temporales"
-msgid ""
-"Creates and connects a new attribute table to a given layer of an existing "
-"vector map."
-msgstr ""
-"Crea y conecta una nueva tabla de atributos a una capa dada de un mapa "
-"vectorial existente."
+msgid "Creates and connects a new attribute table to a given layer of an existing vector map."
+msgstr "Crea y conecta una nueva tabla de atributos a una capa dada de un mapa vectorial existente."
#: ../locale/scriptstrings/v.db.addtable_to_translate.c:5
msgid "Name of new attribute table (default: vector map name)"
-msgstr ""
-"vectorial)"
+msgstr "Nombre de la nueva tabla de atributos (por omisión: nombre del mapa vectorial)"
#: ../locale/scriptstrings/v.db.addtable_to_translate.c:6
#: ../locale/scriptstrings/v.db.addtable_to_translate.c:8
@@ -20658,93 +18519,70 @@
msgstr "Definición"
#: ../locale/scriptstrings/v.db.addtable_to_translate.c:7
-#, fuzzy
msgid "Layer number where to add new attribute table"
-msgstr "Capa a la que añadir la nueva tabla de atributos"
+msgstr "Número de la capa a cual añadir nueva tabla de atributos"
-#, fuzzy
-msgid ""
-"Aggregates temporally the maps of a space time raster dataset by a user "
-"defined granularity."
-msgstr "Listar mapas vectoriales en la localización de entrada y salir"
+msgid "Aggregates temporally the maps of a space time raster dataset by a user defined granularity."
+msgstr "Agrega temporalmente los mapas de un conjunto de datos ráster espacio temporales a partir de un tamaño de grano definido por el usuario."
#: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:7
-msgid ""
-"Either a numerical suffix or the start time (s-flag) separated by an "
-"underscore will be attached to create a unique identifier"
-msgstr ""
+msgid "Either a numerical suffix or the start time (s-flag) separated by an underscore will be attached to create a unique identifier"
+msgstr "Se adjuntara un sufijo numérico o tiempo de inicio (bandera s) separado por un guión bajo para crear un identificador único"
#: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:9
-msgid ""
-"Aggregation granularity, format absolute time \"x years, x months, x weeks, "
-"x days, x hours, x minutes, x seconds\" or an integer value for relative time"
-msgstr ""
+msgid "Aggregation granularity, format absolute time \"x years, x months, x weeks, x days, x hours, x minutes, x seconds\" or an integer value for relative time"
+msgstr "Granularidad de agregación, formato de tiempo absoluto \"x años, x meses, x días, x horas, x minutos, x segundos\" o un valor entero para tiempo relativo"
#: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:12
-#, fuzzy
msgid "Number of r.series processes to run in parallel"
-msgstr "Número de puntos de interpolación"
+msgstr "Número de procesos r.series que correrán en paralelo"
#: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:13
msgid "The maximum number of open files allowed for each r.series process"
msgstr ""
#: ../locale/scriptstrings/t.rast.mapcalc_to_translate.c:1
-#, fuzzy
-msgid ""
-"Performs spatio-temporal mapcalc expressions on temporally sampled maps of "
-"space time raster datasets."
+msgid "Performs spatio-temporal mapcalc expressions on temporally sampled maps of space time raster datasets."
+msgstr "Ejecuta expresiones mapcalc espacio temporales en mapas temporales muestreados de conjunto de datos ráster espacio temporales."
#: ../locale/scriptstrings/t.rast.mapcalc_to_translate.c:7
-#, fuzzy
msgid "Basename for output raster maps"
-msgstr "Nombre para el mapa ráster de salida"
+msgstr "Nombre base para mapas ráster de salida"
#: ../locale/scriptstrings/v.db.dropcolumn_to_translate.c:1
-msgid ""
-"Drops a column from the attribute table connected to a given vector map."
-msgstr ""
-"Elimina una columna de la tabla de atributos conectada a un mapa vectorial "
-"dado."
+msgid "Drops a column from the attribute table connected to a given vector map."
+msgstr "Elimina una columna de la tabla de atributos conectada a un mapa vectorial dado."
#: ../locale/scriptstrings/v.db.dropcolumn_to_translate.c:5
-#, fuzzy
msgid "Name of attribute column(s) to drop"
-msgstr "Nombre de la columna"
+msgstr "Nombre de columna(s) de atributos a eliminar"
#: ../locale/scriptstrings/m.proj_to_translate.c:1
-#, fuzzy
msgid "Converts coordinates from one projection to another (cs2cs frontend)."
msgstr "Convierte coordenadas de una proyección a otra (interfaz cs2cs)."
#: ../locale/scriptstrings/m.proj_to_translate.c:4
-#, fuzzy
msgid "Input coordinates to reproject"
-msgstr "Muestra el monitor para lanzar"
+msgstr "Coordenadas de entrada a reproyectar"
#: ../locale/scriptstrings/m.proj_to_translate.c:5
#: ../locale/scriptstrings/m.proj_to_translate.c:8
#: ../locale/scriptstrings/m.proj_to_translate.c:12
-#, fuzzy
msgid "Input coordinates"
-msgstr "Coordenadas inválidas"
+msgstr "Coordenadas de entrada"
#: ../locale/scriptstrings/m.proj_to_translate.c:6
-#, fuzzy
msgid "Name of input coordinate file"
-msgstr "Nombres de los archivos de entrada"
+msgstr "Nombres de archivo de coordenadas de entrada"
#: ../locale/scriptstrings/m.proj_to_translate.c:9
-#, fuzzy
msgid "Name for output coordinate file (omit to send to stdout)"
-msgstr "Archivo de coordenadas de salida (omitir para enviar a stdout)"
+msgstr "Nombre para archivo de coordenadas de salida (omitido si se manda a salida estándar)"
#: ../locale/scriptstrings/m.proj_to_translate.c:11
-#, fuzzy
msgid "Field separator (format: input[,output])"
-msgstr "Separador de campos (modo de puntos)"
+msgstr "Separador de campos (formato: input[,output])"
#: ../locale/scriptstrings/m.proj_to_translate.c:13
msgid "Input projection parameters (PROJ.4 style)"
@@ -20763,64 +18601,42 @@
#: ../locale/scriptstrings/m.proj_to_translate.c:17
msgid "Use LL WGS84 as input and current location as output projection"
-msgstr ""
-"Usar LL WGS84 como entrada y la localización actual como proyección de salida"
+msgstr "Usar LL WGS84 como entrada y la localización actual como proyección de salida"
#: ../locale/scriptstrings/m.proj_to_translate.c:19
msgid "Use current location as input and LL WGS84 as output projection"
-msgstr ""
-"Usar la localización actual como entrada y LL WGS84 como proyección de salida"
+msgstr "Usar la localización actual como entrada y LL WGS84 como proyección de salida"
#: ../locale/scriptstrings/m.proj_to_translate.c:21
-msgid ""
-"Output long/lat in decimal degrees, or other projections with many decimal "
-"places"
-msgstr ""
-"Producir long/lat en grados decimales, u otras proyecciones con muchos "
-"decimales"
+msgid "Output long/lat in decimal degrees, or other projections with many decimal places"
+msgstr "Producir long/lat en grados decimales, u otras proyecciones con muchos decimales"
#: ../locale/scriptstrings/m.proj_to_translate.c:23
-#, fuzzy
msgid "Include input coordinates in output file"
+msgstr "incluir coordenadas de entrada en archivo de salida"
#: ../locale/scriptstrings/m.proj_to_translate.c:25
-#, fuzzy
msgid "Include column names in output file"
-msgstr "No incluir nombres de columna en la salida"
+msgstr "Incluir nombre de columna e archivo de salida"
#: ../locale/scriptstrings/t.vect.what.strds_to_translate.c:1
-#, fuzzy
-msgid ""
-"Stores raster map values at spatial and temporal positions of vector points "
-"as vector attributes."
-msgstr ""
-"Carga valores ráster en las posiciones de puntos vectoriales a la tabla."
+msgid "Stores raster map values at spatial and temporal positions of vector points as vector attributes."
+msgstr "Guarda como atributos vectoriales los valores del mapa ráster en las posiciones espacio temporales de los puntos vectoriales."
#: ../locale/scriptstrings/t.vect.what.strds_to_translate.c:6
-#, fuzzy
-msgid ""
-"Name of the vector column to be created and to store sampled raster values"
+msgid "Name of the vector column to be created and to store sampled raster values"
+msgstr "Nombre de la columna vectorial a ser creada y en la que se guardarán los valores ráster muestreados"
#: ../locale/scriptstrings/t.vect.what.strds_to_translate.c:7
-msgid ""
-"The use of a column name forces t.vect.what.rast to sample only values from "
-"the first map found in an interval. Otherwise the raster map names are used "
-"as column names"
-msgstr ""
+msgid "The use of a column name forces t.vect.what.rast to sample only values from the first map found in an interval. Otherwise the raster map names are used as column names"
+msgstr "El uso de una columna nombre fuerza t.vect.what.rast a muestrear solamente valores del primer mapa encontrado en un intervalo. De otro modo nombres de mapa ráster son usados como nombres de columna"
#: ../locale/scriptstrings/g.extension_to_translate.c:1
-#, fuzzy
msgid "Maintains GRASS Addons extensions in local GRASS installation."
-msgstr ""
-"Herramienta para mantener las extensiones GRASS en una instalación local "
-"GRASS"
+msgstr "Mantiene los Complementos de extensiones de GRASS en instalación local GRASS"
#: ../locale/scriptstrings/g.extension_to_translate.c:2
-msgid ""
-"Downloads and installs extensions from GRASS Addons repository or other "
-"source into the local GRASS installation or removes installed extensions."
+msgid "Downloads and installs extensions from GRASS Addons repository or other source into the local GRASS installation or removes installed extensions."
msgstr ""
#: ../locale/scriptstrings/g.extension_to_translate.c:6
@@ -20832,33 +18648,28 @@
msgstr ""
#: ../locale/scriptstrings/g.extension_to_translate.c:8
-#, fuzzy
msgid "Name of extension to install or remove"
-msgstr "Nombre de la extensión a instalar/eliminar"
+msgstr "Nombre de extensión a instalar o eliminar"
#: ../locale/scriptstrings/g.extension_to_translate.c:9
msgid "Name of toolbox (set of extensions) when -t flag is given"
-msgstr ""
+msgstr "Nombre de caja de herramientas (conjunto de extesiones) cuando se de la bandera -t"
#: ../locale/scriptstrings/g.extension_to_translate.c:11
-msgid ""
-"URL or directory to get the extension from (supported only on Linux and Mac)"
+msgid "URL or directory to get the extension from (supported only on Linux and Mac)"
msgstr ""
#: ../locale/scriptstrings/g.extension_to_translate.c:12
-msgid ""
-"The official repository is used by default. User can specify a ZIP file, "
-"directory or a repository on common hosting services. If not identified, "
-"Subversion repository is assumed. See manual for all options."
+msgid "The official repository is used by default. User can specify a ZIP file, directory or a repository on common hosting services. If not identified, Subversion repository is assumed. See manual for all options."
msgstr ""
#: ../locale/scriptstrings/g.extension_to_translate.c:13
msgid "Prefix where to install extension (ignored when flag -s is given)"
-msgstr ""
+msgstr "Prefijo donde instalar extensión (ignorado cuando se da la bandera -s)"
#: ../locale/scriptstrings/g.extension_to_translate.c:14
msgid "Set the proxy with: \"http=<value>,ftp=<value>\""
-msgstr ""
+msgstr "Establecer el proxy con: \"http=<value>,ftp=<value>\""
#: ../locale/scriptstrings/g.extension_to_translate.c:15
#, fuzzy
@@ -20867,22 +18678,17 @@
#: ../locale/scriptstrings/g.extension_to_translate.c:17
#, fuzzy
-msgid ""
-"List available extensions in the official GRASS GIS Addons repository "
-"including module description"
+msgid "List available extensions in the official GRASS GIS Addons repository including module description"
msgstr "Listar reglas disponibles y salir"
#: ../locale/scriptstrings/g.extension_to_translate.c:19
#, fuzzy
-msgid ""
-"List available extensions in the official GRASS GIS Addons repository (shell "
-"script style)"
+msgid "List available extensions in the official GRASS GIS Addons repository (shell script style)"
#: ../locale/scriptstrings/g.extension_to_translate.c:21
-#, fuzzy
msgid "List locally installed extensions"
+msgstr "Enlistar extensiones instaladas localmente"
#: ../locale/scriptstrings/g.extension_to_translate.c:23
msgid "Install system-wide (may need system administrator rights)"
@@ -20896,7 +18702,7 @@
#: ../locale/scriptstrings/g.extension_to_translate.c:25
msgid "Download source code and exit"
-msgstr ""
+msgstr "Descargar código fuente y salir"
#: ../locale/scriptstrings/g.extension_to_translate.c:27
msgid "Do not install new extension, just compile it"
@@ -20907,35 +18713,30 @@
msgstr "Forzar eliminar cuando desinstalando la extensión (operation=remove)"
#: ../locale/scriptstrings/g.extension_to_translate.c:31
-#, fuzzy
msgid "Operate on toolboxes instead of single modules (experimental)"
-msgstr "Tablas de sistema en vez de tablas de usuario"
+msgstr "Operar en cajas de herramientas en vez de módulos individuales (expermiental)"
#: ../locale/scriptstrings/t.register_to_translate.c:1
-#, fuzzy
msgid "Registers raster, vector and raster3d maps in a space time datasets."
+msgstr "Registra mapas ráster, vectoriales y ráster3d en un conjunto de datos espacio temporales."
#: ../locale/scriptstrings/t.register_to_translate.c:4
-#, fuzzy
msgid "register"
-msgstr "ráster"
+msgstr "registrar"
#: ../locale/scriptstrings/t.register_to_translate.c:8
#: ../locale/scriptstrings/t.unregister_to_translate.c:7
-#, fuzzy
msgid "input,maps"
-msgstr "Mapa de entrada"
+msgstr "entrada,mapas"
#: ../locale/scriptstrings/t.register_to_translate.c:10
#: ../locale/scriptstrings/t.unregister_to_translate.c:6
-#, fuzzy
msgid "Input file with map names, one per line"
-msgstr "Mapa vectorial de entrada que contiene líneas"
+msgstr "Archivo de entrada con nombres de mapas, uno por línea"
#: ../locale/scriptstrings/t.register_to_translate.c:11
msgid "Additionally the start time and the end time can be specified per line"
-msgstr ""
+msgstr "Adicionalmente el tiempo de inicio y el tiempo de término pueden ser especificados por línea"
#: ../locale/scriptstrings/t.register_to_translate.c:13
msgid "Valid start date and time of the first map"
@@ -20943,12 +18744,8 @@
#: ../locale/scriptstrings/t.register_to_translate.c:14
#: ../locale/scriptstrings/t.register_to_translate.c:17
-msgid ""
-"Format absolute time: \"yyyy-mm-dd HH:MM:SS +HHMM\", relative time is of "
-"type integer)."
-msgstr ""
-"Formato tiempo absoluto: \"yyyy-mm-dd HH:MM:SS +HHMM\", el tiempo relativo "
-"es de tipo entero)."
+msgid "Format absolute time: \"yyyy-mm-dd HH:MM:SS +HHMM\", relative time is of type integer)."
+msgstr "Formato tiempo absoluto: \"yyyy-mm-dd HH:MM:SS +HHMM\", el tiempo relativo es de tipo entero)."
#: ../locale/scriptstrings/t.register_to_translate.c:15
#: ../locale/scriptstrings/t.register_to_translate.c:18
@@ -20963,9 +18760,8 @@
msgstr "Tiempo y fecha finales válidos de todo el mapa"
#: ../locale/scriptstrings/t.register_to_translate.c:19
-#, fuzzy
msgid "Time stamp unit"
-msgstr "Marca de tiempo no válida"
+msgstr "Unidad de marca de tiempo"
#: ../locale/scriptstrings/t.register_to_translate.c:20
msgid "Unit must be set in case of relative time stamps"
@@ -20973,31 +18769,23 @@
#: ../locale/scriptstrings/t.register_to_translate.c:22
msgid "Time increment, works only in conjunction with start option"
-msgstr ""
+msgstr "Incremento de tiempo, fuciona solamente en conjuto con opción start"
#: ../locale/scriptstrings/t.register_to_translate.c:23
-msgid ""
-"Time increment between maps for valid time interval creation (format "
-"absolute: NNN seconds, minutes, hours, days, weeks, months, years; format "
-"relative is integer: 5)"
-msgstr ""
+msgid "Time increment between maps for valid time interval creation (format absolute: NNN seconds, minutes, hours, days, weeks, months, years; format relative is integer: 5)"
+msgstr "Tiempo de incremento entre mapas para intervalo de tiempo de creación válido (formato absoluto: NNN segundos, minutos, horas, días, semanas, meses, años; formato relativo son enteros: 5)"
#: ../locale/scriptstrings/t.register_to_translate.c:25
-#, fuzzy
msgid "Field separator character of the input file"
-msgstr "Separador de campos (modo conciso solamente)"
+msgstr "Caracter separador de campos del archivo de entrada"
#: ../locale/scriptstrings/t.register_to_translate.c:27
-msgid ""
-"Create an interval (start and end time) in case an increment and the start "
-"time are provided"
-msgstr ""
+msgid "Create an interval (start and end time) in case an increment and the start time are provided"
+msgstr "Crear un intervalo (tiempo de inicio y término) en caso de que se provea un incremento y el tiempo de inicio"
#: ../locale/scriptstrings/d.polar_to_translate.c:1
msgid "Draws polar diagram of angle map such as aspect or flow directions"
-msgstr ""
-"Dibujar un diagrama polar de un mapa con ángulos como direcciones de "
-"orientación o corriente"
+msgstr "Dibujar un diagrama polar de un mapa con ángulos como direcciones de orientación o corriente"
#: ../locale/scriptstrings/d.polar_to_translate.c:4
msgid "Name of raster angle map"
@@ -21008,77 +18796,60 @@
msgstr "Valor pixel para interpretar como indefinido (distinto de nulo)"
#: ../locale/scriptstrings/d.polar_to_translate.c:6
-#, fuzzy
msgid "Name for optional EPS output file"
-msgstr "Nombre del archivo de salida EPS opcional"
+msgstr "Nombre para archivo EPS de salida opcional"
#: ../locale/scriptstrings/d.polar_to_translate.c:7
msgid "Plot using Xgraph"
msgstr "Salida gráfica usando Xgraph"
#: ../locale/scriptstrings/t.select_to_translate.c:1
-msgid ""
-"Select maps from space time datasets by topological relationships to other "
-"space time datasets using temporal algebra."
-msgstr ""
+msgid "Select maps from space time datasets by topological relationships to other space time datasets using temporal algebra."
+msgstr "Seleccionar mapas desde conjunto de datos por relaciones topológicas a otro conjunto de datos espacio temporales usando álgebra de mapas"
#: ../locale/scriptstrings/t.select_to_translate.c:7
msgid "The temporal mapcalc expression"
-msgstr ""
+msgstr "La expresión mapcalc temporal"
#: ../locale/scriptstrings/v.db.droprow_to_translate.c:1
-#, fuzzy
msgid "Removes a vector feature from a vector map through attribute selection."
-msgstr ""
-"Imprime/establece la conexión a la base de datos para un mapa vectorial a la "
-"tabla de atributos."
+msgstr "Elimina un elemento vectorial de un mapa vectorial mediante la selección de atributos."
#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:1
-#, fuzzy
-msgid ""
-"Reconnects attribute tables for all vector maps from the current mapset to a "
-"new database."
+msgid "Reconnects attribute tables for all vector maps from the current mapset to a new database."
+msgstr "Reconecta tabla de atributos para todos los mapas vectoriales a partir del Directorio de mapas actual a una nueva base de datos."
#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:5
msgid "Copy attribute tables to the target database if not exist"
msgstr "Copiar tablas de atributos a la base de datos objetivo si no existe"
#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:6
-#, fuzzy
msgid "Delete attribute tables from the source database"
-msgstr "Elimina una tabla de la base de datos."
+msgstr "Eliminar tablas de atributos desde la base de datos fuente"
#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:7
-#, fuzzy
msgid "Name of source database"
+msgstr "Nombre de base de datos fuente"
#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:8
-#, fuzzy
msgid "Name of source database schema"
-msgstr "Esquema de la base de datos"
+msgstr "Nombre de esquema de base de datos fuente"
#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:9
-#, fuzzy
msgid "Name for target driver"
-msgstr "Nombre de destino del conjunto de mapas"
+msgstr "Nombre del controlador de destino"
#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:10
-#, fuzzy
msgid "Name for target database"
-msgstr "Nombre de la nueva base de datos"
+msgstr "Nombre para base de datos de destino"
#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:11
-#, fuzzy
msgid "Name for target database schema"
+msgstr "Nombre para esquema de base de datos de destino"
#: ../locale/scriptstrings/db.test_to_translate.c:1
msgid "Test database driver, database must exist and set by db.connect."
-msgstr ""
-"Probar el controlador de base de datos. La base de datos debe existir y "
-"estar conectada por db. connect."
+msgstr "Probar el controlador de base de datos. La base de datos debe existir y estar conectada por db. connect."
#: ../locale/scriptstrings/db.test_to_translate.c:4
msgid "Test name"
@@ -21091,14 +18862,11 @@
#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:11
#: ../raster/r.to.vect/main.c:94
-#, fuzzy
msgid "Name of attribute column to store value"
+msgstr "Nombre de columa de atributos en la cual guardar valor"
#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:12
-msgid ""
-"Number of r.to.vect processes to run in parallel, more than 1 process works "
-"only in conjunction with flag -t"
+msgid "Number of r.to.vect processes to run in parallel, more than 1 process works only in conjunction with flag -t"
msgstr ""
#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:15
@@ -21108,58 +18876,40 @@
#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:16
#: ../raster/r.to.vect/main.c:110
-#, fuzzy
msgid "Write raster values as z coordinate"
-msgstr "Cambiando valor para coordenadas Z"
+msgstr "Escribir valores ráster como coordenada z"
#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:17
#: ../raster/r.to.vect/main.c:111
-#, fuzzy
msgid "Table is not created. Currently supported only for points."
-msgstr ""
-"Escribir valores ráster como coordenada Z. No se crea la tabla. Actualmente "
-"sólo soportado para puntos."
+msgstr "Tabla no ha sido creada. Actualmente soportada solamente para puntos."
#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:18
#: ../raster/r.to.vect/main.c:117
-#, fuzzy
msgid "Do not build vector topology"
-msgstr "No construir topología"
+msgstr "No constuir topología vectorial"
#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:19
#: ../raster/r.to.vect/main.c:95
msgid "Name must be SQL compliant"
-msgstr ""
+msgstr "Nombre debe ajustarse al estándar SQL"
#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:20
#: ../raster/r.to.vect/main.c:105
msgid "Use raster values as categories instead of unique sequence (CELL only)"
-msgstr ""
-"Usar valores ráster como categorías en vez de secuencia única (sólo CELL)"
+msgstr "Usar valores ráster como categorías en vez de secuencia única (sólo CELL)"
#: ../locale/scriptstrings/d.what.vect_to_translate.c:1
-#, fuzzy
-msgid ""
-"Allows the user to interactively query vector map layers at user-selected "
-"locations."
-msgstr ""
+msgid "Allows the user to interactively query vector map layers at user-selected locations."
+msgstr "Permite al usuario consultar de forma interactiva una capa de mapa vectorial en ubicaciones seleccionadas por el usuario."
#: ../locale/scriptstrings/r.reclass.area_to_translate.c:1
-msgid ""
-"Reclasses a raster map greater or less than user specified area size (in "
-"hectares)."
-msgstr ""
-"Reclasifica un mapa ráster mayor o menor que la superficie indicada por el "
-"usuario (en hectáreas)."
+msgid "Reclasses a raster map greater or less than user specified area size (in hectares)."
+msgstr "Reclasifica un mapa ráster mayor o menor que la superficie indicada por el usuario (en hectáreas)."
#: ../locale/scriptstrings/r.reclass.area_to_translate.c:5
-#, fuzzy
msgid "Value option that sets the area size limit (in hectares)"
-msgstr ""
-"Opción de valor menor que establece el <= límite de tamaño de área "
-"[hectáreas]"
+msgstr "Opción de valor menor que establece el límite del tamaño mínimo del área (en hectáreas)"
#: ../locale/scriptstrings/r.reclass.area_to_translate.c:7
msgid "Lesser or greater than specified value"
@@ -21180,14 +18930,12 @@
msgstr "Filtrar todas las celdas sin datos"
#: ../locale/scriptstrings/t.rast.export_to_translate.c:1
-#, fuzzy
msgid "Exports space time raster dataset."
-msgstr "Actualizar estadísticas del mapa ráster"
+msgstr "Exporta u conjunto de datos espacio temporales."
#: ../locale/scriptstrings/t.rast.export_to_translate.c:6
-#, fuzzy
msgid "Name of a space time raster dataset archive"
-msgstr "Nombre de mapa ráster de orientación"
+msgstr "Nombre de un archivo conjunto de datos ráter espacio temporales"
#: ../locale/scriptstrings/t.rast.export_to_translate.c:7
#: ../locale/scriptstrings/t.vect.export_to_translate.c:7
@@ -21196,20 +18944,16 @@
#: ../locale/scriptstrings/t.rast.export_to_translate.c:8
#: ../locale/scriptstrings/t.vect.export_to_translate.c:8
-#, fuzzy
msgid "Compression method of the tar archive"
-msgstr "Utilizar la versión de baja-memoria del programa"
+msgstr "Método de compresión para el archivo tar"
#: ../locale/scriptstrings/t.rast.export_to_translate.c:9
-#, fuzzy
msgid "The export format of a single raster map"
-msgstr "Genera estadísticas de superficie para capas de mapa ráster."
+msgstr "El formato de exportación de un solo mapa ráster"
#: ../locale/scriptstrings/t.rast.export_to_translate.c:10
-msgid ""
-"Supported are GTiff, AAIGrid via r.out.gdal and the GRASS package format of "
-"r.pack"
-msgstr ""
+msgid "Supported are GTiff, AAIGrid via r.out.gdal and the GRASS package format of r.pack"
+msgstr "Los soportados son GTiff, AAIGrid vía r.out.gdal y el formato de paquete GRASS de r.pack"
#: ../locale/scriptstrings/t.rast.export_to_translate.c:11
#: ../raster/r.out.gdal/main.c:192
@@ -21222,9 +18966,8 @@
msgstr "La opción z sólo está soportada para puntos"
#: ../locale/scriptstrings/g.manual_to_translate.c:1
-#, fuzzy
msgid "Displays the manual pages of GRASS modules."
-msgstr "Mostrar las páginas man HTML de GRASS"
+msgstr "Mostrar las páginas del manual de los módulos GRASS."
#: ../locale/scriptstrings/g.manual_to_translate.c:3
msgid "manual"
@@ -21239,137 +18982,105 @@
msgstr "Mostrar índice"
#: ../locale/scriptstrings/g.manual_to_translate.c:6
-#, fuzzy
msgid "Display topics"
-msgstr "Mostrar índice"
+msgstr "Mostrar temas"
#: ../locale/scriptstrings/g.manual_to_translate.c:7
msgid "Display as MAN text page instead of HTML page in browser"
msgstr "Mostrar como páginas de texto MAN en vez de páginas HTML en navegador"
#: ../locale/scriptstrings/g.manual_to_translate.c:8
-#, fuzzy
msgid "Display online manuals instead of locally installed"
-msgstr "Dibujar una línea de escala en vez de una barra de escala"
+msgstr "Mostrar manuales online en vez de los instalados localmente"
#: ../locale/scriptstrings/g.manual_to_translate.c:9
-msgid ""
-"Use online manuals available at http://grass.osgeo.org website. This flag "
-"has no effect when displaying MAN text pages."
-msgstr ""
+msgid "Use online manuals available at http://grass.osgeo.org website. This flag has no effect when displaying MAN text pages."
+msgstr "Usar manuales online disponibles en sel sitio web http://grass.osgeo.org. Esta bandear no tiene efecto cuando se muestran paǵinas MAN de texto."
#: ../locale/scriptstrings/g.manual_to_translate.c:10
msgid "Manual entry to be displayed"
msgstr "Entrada de manual a mostrar"
#: ../locale/scriptstrings/v.db.univar_to_translate.c:1
-msgid ""
-"Calculates univariate statistics on selected table column for a GRASS vector "
-"map."
-msgstr ""
+msgid "Calculates univariate statistics on selected table column for a GRASS vector map."
+msgstr "Calcula estadísticas univariante sobre la columna de tabal seleccionada para un mapa vectorial de GRASS."
#: ../locale/scriptstrings/t.rast.extract_to_translate.c:1
-#, fuzzy
msgid "Extracts a subset of a space time raster datasets."
+msgstr "Extraer un subconjunto de conjunto de datos ráster espacio temporales."
#: ../locale/scriptstrings/t.rast.extract_to_translate.c:6
msgid "r.mapcalc expression assigned to all extracted raster maps"
-msgstr ""
+msgstr "expresión r.mapcalc asignada a todos los mapas ráster extraidos"
#: ../locale/scriptstrings/t.remove_to_translate.c:1
-#, fuzzy
msgid "Removes space time datasets from temporal database."
+msgstr "Remueve conjuntos de datos espacio temporales de bases de datos temporales."
#: ../locale/scriptstrings/t.remove_to_translate.c:4
#: ../general/g.remove/main.c:71
-#, fuzzy
msgid "remove"
-msgstr "Eliminar balanceos"
+msgstr "eliminar"
#: ../locale/scriptstrings/t.remove_to_translate.c:7
msgid "Type of the space time dataset, default is strds"
-msgstr ""
-"Tipo del conjunto de datos espacio temporales, el predeterminado es strds"
+msgstr "Tipo del conjunto de datos espacio temporales, el predeterminado es strds"
#: ../locale/scriptstrings/t.remove_to_translate.c:10
-#, fuzzy
msgid "Input file with dataset names, one per line"
+msgstr "Archivo de entrada con nombres de conjunto de datos, uno por línea"
#: ../locale/scriptstrings/t.remove_to_translate.c:12
-#, fuzzy
-msgid ""
-"Remove all registered maps from the temporal and also from the spatial "
-"database"
+msgid "Remove all registered maps from the temporal and also from the spatial database"
+msgstr "Elimina todos los mapas registrados de la base de datos temporal y también la espacial"
#: ../locale/scriptstrings/t.remove_to_translate.c:13
msgid "Force recursive removing"
msgstr "Forzar remosión recursiva"
#: ../locale/scriptstrings/v.in.geonames_to_translate.c:1
-#, fuzzy
msgid "Imports geonames.org country files into a vector points map."
-msgstr ""
-"Importa archivos de país geonames.org a un mapa vectorial de puntos de GRASS."
+msgstr "Importa archivos de país de geonames.org a un mapa vectorial de puntos."
#: ../locale/scriptstrings/v.in.geonames_to_translate.c:4
msgid "gazetteer"
msgstr ""
#: ../locale/scriptstrings/v.in.geonames_to_translate.c:5
-#, fuzzy
msgid "Name of uncompressed geonames file (with .txt extension)"
-msgstr "Archivo geonames sin comprimir de (con extensión .txt)"
+msgstr "Nombre de archivo geonames descomprimido (con extensión .txt)"
#: ../locale/scriptstrings/v.rast.stats_to_translate.c:1
-#, fuzzy
-msgid ""
-"Calculates univariate statistics from a raster map based on a vector map and "
-"uploads statistics to new attribute columns."
-msgstr ""
-"Calcular estadísticas univariantes a partir de un mapa ráster de GRASS "
-"basadas en polígonos vectoriales y carga las estadísticas en nuevas columnas "
-"de atributos."
+msgid "Calculates univariate statistics from a raster map based on a vector map and uploads statistics to new attribute columns."
+msgstr "Calcula estadísticas univariadas a partir de un mapa ráster a partir de un mapa vectorial y carga estadísticas a nueva columna de atributos."
#: ../locale/scriptstrings/v.rast.stats_to_translate.c:7
msgid "Continue if upload column(s) already exist"
msgstr "Continuar si la columna(s) en la que cargar ya existe"
#: ../locale/scriptstrings/v.rast.stats_to_translate.c:8
-#, fuzzy
msgid "Name of input raster map to calculate statistics from"
-msgstr "Nombre del mapa ráster del que calcular estadísticas"
+msgstr "Nombre de mapa ráster de etrada al cual se le calcularán las estadísticas"
#: ../locale/scriptstrings/v.rast.stats_to_translate.c:9
msgid "Column prefix for new attribute columns"
-msgstr "Prefijo de columna para las nuevas columnas de atributos"
+msgstr "Prefijo de columna para nuevas columnas de atributos"
#: ../locale/scriptstrings/v.rast.stats_to_translate.c:10
-#, fuzzy
msgid "The methods to use"
-msgstr "Método de reproyección a usar"
+msgstr "Métodos a usar"
#: ../locale/scriptstrings/v.rast.stats_to_translate.c:11
-#, fuzzy
msgid "Percentile to calculate"
-msgstr "Valor a calcular"
+msgstr "Pencertil a calcular"
#: ../locale/scriptstrings/t.rast.colors_to_translate.c:1
-#, fuzzy
-msgid ""
-"Creates/modifies the color table associated with each raster map of the "
-"space time raster dataset."
-msgstr "Crea/modifica la tabla de colores asociada a una capa de mapa ráster."
+msgid "Creates/modifies the color table associated with each raster map of the space time raster dataset."
+msgstr "Crea/modifica la tabla de colores asociada con cada mapa ráster del conjunto de datos ráster espacio temporales."
#: ../locale/scriptstrings/t.rast.colors_to_translate.c:6
-#, fuzzy
msgid "Name of color table (see r.color help)"
-msgstr "Tipo de tabla de color (para usar con -z flag)"
+msgstr "Nombre de tabla de colores (ver ayuda de r.color)"
#: ../locale/scriptstrings/t.rast.colors_to_translate.c:25
#: ../raster/r.colors/edit_colors.c:147
@@ -21377,25 +19088,21 @@
msgstr "Ecualización de histograma"
#: ../locale/scriptstrings/t.support_to_translate.c:1
-#, fuzzy
msgid "Modifies the metadata of a space time dataset."
+msgstr "Modifica los metadatos de un conjunto de datos espacio temporales."
#: ../locale/scriptstrings/t.support_to_translate.c:5
#: ../locale/scriptstrings/t.create_to_translate.c:7
-#, fuzzy
msgid "Semantic type of the space time dataset"
+msgstr "Tipo semántico del conjunto de datos espacio temporales"
#: ../locale/scriptstrings/t.support_to_translate.c:8
-#, fuzzy
msgid "Title of the space time dataset"
+msgstr "Título del conjunto de datos espacio temporales"
#: ../locale/scriptstrings/t.support_to_translate.c:9
-#, fuzzy
msgid "Description of the space time dataset"
+msgstr "Descripción del nuevo conjunto de datos espacio temporales"
#: ../locale/scriptstrings/t.support_to_translate.c:10
#, fuzzy
@@ -21403,68 +19110,54 @@
#: ../locale/scriptstrings/t.support_to_translate.c:11
-msgid ""
-"Update the metadata information and spatial extent of registered maps from "
-"the GRASS spatial database"
-msgstr ""
+msgid "Update the metadata information and spatial extent of registered maps from the GRASS spatial database"
+msgstr "Actualizar información de metadatos y extensión espacial de los mapas registrados desde la base de datos espaciales GRASS"
#: ../locale/scriptstrings/t.support_to_translate.c:12
-msgid ""
-"Check for removed maps and delete them from the temporal database and all "
-"effected space time datasets"
-msgstr ""
+msgid "Check for removed maps and delete them from the temporal database and all effected space time datasets"
+msgstr "Revisar para mapas eliminados y eliminarlos desde la base de datos y todos los conjuntos de datos afectados"
#: ../locale/scriptstrings/t.support_to_translate.c:13
-msgid ""
-"Update metadata information, temporal and spatial extent from registered "
-"maps based on database entries."
+msgid "Update metadata information, temporal and spatial extent from registered maps based on database entries."
msgstr ""
#: ../locale/scriptstrings/t.vect.export_to_translate.c:1
-#, fuzzy
msgid "Exports a space time vector dataset as GRASS GIS specific archive file."
+msgstr "Exporta un conjunto de datos vectoriales espacio temporales como un archivo de almacenamiento específico para GRASS GIS."
#: ../locale/scriptstrings/t.vect.export_to_translate.c:6
-#, fuzzy
msgid "Name of a space time vector dataset archive"
+msgstr "Nombre de un archivo de conjunto de datos vectoriales espacio temporales"
#: ../locale/scriptstrings/t.vect.export_to_translate.c:9
-#, fuzzy
msgid "The export format of a single vector map"
#: ../locale/scriptstrings/t.vect.export_to_translate.c:10
msgid "Supported are GML via v.out.ogr and the GRASS package format of v.pack"
-msgstr ""
+msgstr "Los soportados son GML vía rc,out.ogr y el formato de paquete GRASS de v.pack"
#: ../locale/scriptstrings/t.topology_to_translate.c:1
-#, fuzzy
msgid "Lists temporal topology of a space time dataset."
-msgstr "Imprimir la matriz de transformación a stdout"
+msgstr "Enlista topología temporal de un conjunto de datos espacio temporales."
#: ../locale/scriptstrings/t.topology_to_translate.c:7
-#, fuzzy
msgid "Print temporal relationships and exit"
+msgstr "Mostrar relaciones temporales y salir"
#: ../locale/scriptstrings/t.topology_to_translate.c:8
-#, fuzzy
msgid "Print spatio-temporal relationships and exit"
+msgstr "Mostrar relaciones espacio temporales y salir"
#: ../locale/scriptstrings/i.tasscap_to_translate.c:1
-#, fuzzy
msgid "Performs Tasseled Cap (Kauth Thomas) transformation."
-msgstr "Transformación Tasseled Cap (Kauth Thomas) para datos LANDSAT-TM"
+msgstr "Realiza transformación Tasseled Cap (Kauth Thomas)"
#: ../locale/scriptstrings/i.tasscap_to_translate.c:4
#: ../imagery/i.landsat.toar/main.c:77 ../imagery/i.landsat.acca/main.c:109
#: ../imagery/i.albedo/main.c:99
-#, fuzzy
msgid "Landsat"
-msgstr "Número de capa"
+msgstr "Landsat"
#: ../locale/scriptstrings/i.tasscap_to_translate.c:5
#: ../imagery/i.modis.qc/main.c:155 ../imagery/i.albedo/main.c:102
@@ -21472,54 +19165,37 @@
msgstr "MODIS"
#: ../locale/scriptstrings/i.tasscap_to_translate.c:6
-#, fuzzy
msgid "Tasseled Cap transformation"
-msgstr "vectorial, transformación"
+msgstr "Transformación Tasseled Cap"
#: ../locale/scriptstrings/i.tasscap_to_translate.c:7
-msgid ""
-"For Landsat4-7: bands 1, 2, 3, 4, 5, 7; for Landsat8: bands 2, 3, 4, 5, 6, "
-"7; for MODIS: bands 1, 2, 3, 4, 5, 6, 7"
-msgstr ""
-"Para Landsat4-7: bandas 1, 2, 3, 4, 5, 7; para Landsat8: bandas 2, 3, 4, 5, "
-"6, 7; para MODIS: bandas 1, 2, 3, 4, 5, 6, 7"
+msgid "For Landsat4-7: bands 1, 2, 3, 4, 5, 7; for Landsat8: bands 2, 3, 4, 5, 6, 7; for MODIS: bands 1, 2, 3, 4, 5, 6, 7"
+msgstr "Para Landsat4-7: bandas 1, 2, 3, 4, 5, 7; para Landsat8: bandas 2, 3, 4, 5, 6, 7; para MODIS: bandas 1, 2, 3, 4, 5, 6, 7"
#: ../locale/scriptstrings/i.tasscap_to_translate.c:8
#: ../imagery/i.pca/main.c:85
-#, fuzzy
msgid "Name for output basename raster map(s)"
-msgstr "Nombre para el mapa(s) raster de salida"
+msgstr "Nombre base del mapa(s) ráster de salida"
#: ../locale/scriptstrings/i.tasscap_to_translate.c:9
msgid "Satellite sensor"
msgstr "Satélite sensor"
#: ../locale/scriptstrings/i.tasscap_to_translate.c:10
-msgid ""
-"landsat4_tm;Use transformation rules for Landsat 4 TM;landsat5_tm;Use "
-"transformation rules for Landsat 5 TM;landsat7_etm;Use transformation rules "
-"for Landsat 7 ETM;landsat8_oli;Use transformation rules for Landsat 8 OLI;"
-"modis;Use transformation rules for MODIS"
-msgstr ""
-"landsat4_tm;Use reglas de transformación para Landsat 4 TM;landsat5_tm;Use "
-"Use reglas de transformación para Landsat 5 TM;landsat7_etm;Use reglas de "
-"transformación para Landsat 7 ETM;landsat8_oli;Use reglas de transformación "
-"para Landsat 8 OLI;modis;Use reglas de transformación para MODIS"
+msgid "landsat4_tm;Use transformation rules for Landsat 4 TM;landsat5_tm;Use transformation rules for Landsat 5 TM;landsat7_etm;Use transformation rules for Landsat 7 ETM;landsat8_oli;Use transformation rules for Landsat 8 OLI;modis;Use transformation rules for MODIS"
+msgstr "landsat4_tm;Use reglas de transformación para Landsat 4 TM;landsat5_tm;Use Use reglas de transformación para Landsat 5 TM;landsat7_etm;Use reglas de transformación para Landsat 7 ETM;landsat8_oli;Use reglas de transformación para Landsat 8 OLI;modis;Use reglas de transformación para MODIS"
#: ../locale/scriptstrings/t.unregister_to_translate.c:1
-msgid ""
-"Unregisters raster, vector and raster3d maps from the temporal database or a "
-"specific space time dataset."
-msgstr ""
+msgid "Unregisters raster, vector and raster3d maps from the temporal database or a specific space time dataset."
+msgstr "Quita registro a mapas ráster, vectoriales y raster3d de una base de datos temporal o un conjunto de datos espacio temporales específico."
#: ../locale/scriptstrings/t.unregister_to_translate.c:4
msgid "unregister"
-msgstr "cancelar el registro"
+msgstr "quitar registro"
#: ../locale/scriptstrings/t.unregister_to_translate.c:8
-#, fuzzy
msgid "Name(s) of existing raster, vector or raster3d map(s) to unregister"
-msgstr "Nombre de mapa(s) ráster existente a consultar"
+msgstr "Nombre del(los) mapa(s) ráster, vectorial(es) o raster3d existente(s) a eliminar del registro"
#: ../locale/scriptstrings/t.create_to_translate.c:1
msgid "Creates a space time dataset."
@@ -21530,136 +19206,104 @@
msgstr "crear"
#: ../locale/scriptstrings/t.create_to_translate.c:6
-#, fuzzy
msgid "Type of the output space time dataset"
+msgstr "Tipo de salida para conjunto de datos espacio temporales"
#: ../locale/scriptstrings/r.out.xyz_to_translate.c:1
-#, fuzzy
-msgid ""
-"Exports a raster map to a text file as x,y,z values based on cell centers."
-msgstr ""
-"Exportar un mapa ráster a un archivo de texto como valores X, Y, Z basados "
-"en los centros de las celdas."
+msgid "Exports a raster map to a text file as x,y,z values based on cell centers."
+msgstr "Exportar un mapa ráster a un archivo de texto como valores x,y,z basado en los centros de las celdas."
#: ../locale/scriptstrings/r.out.xyz_to_translate.c:4
msgid "ASCII"
msgstr "ASCII"
#: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:1
-#, fuzzy
-msgid ""
-"Performs a neighborhood analysis for each map in a space time raster dataset."
+msgid "Performs a neighborhood analysis for each map in a space time raster dataset."
+msgstr "Realiza un análisis de vecindario para cada mapa en un conjunto de datos ráster espacio temporales."
#: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:6
#: ../raster/r.neighbors/main.c:212
msgid "Neighborhood size"
-msgstr "Tamaño de vecindad"
+msgstr "Tamaño de vecindario"
#: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:11
-#, fuzzy
msgid "Number of r.neighbor processes to run in parallel"
+msgstr "Número de procesos r.neighbor que correrán en paralelo"
#: ../locale/scriptstrings/r.in.srtm_to_translate.c:1
-#, fuzzy
msgid "Imports SRTM HGT files into raster map."
-msgstr "Importar archivo SPOT VGT NDVI a un mapa ráster"
+msgstr "Importa archivo SRTM HGT a un mapa ráster."
#: ../locale/scriptstrings/r.in.srtm_to_translate.c:4
-#, fuzzy
msgid "Name of SRTM input tile (file without .hgt.zip extension)"
-msgstr "Archivo de entrada SRTM (archivo sin extensión .hgt.zip)"
+msgstr "Nombre de archivo de entrada SRTM (archivo sin extensión .hgt.zip)"
#: ../locale/scriptstrings/r.in.srtm_to_translate.c:5
-#, fuzzy
msgid "Name for output raster map (default: input tile)"
+msgstr "Nombre para mapa ráster de salida (predeterminado: el de entrada)"
#: ../locale/scriptstrings/r.in.srtm_to_translate.c:6
msgid "Input is a 1-arcsec tile (default: 3-arcsec)"
msgstr "La entrada es un tile 1-arcsec (por defecto: 3-arcsec)"
#: ../locale/scriptstrings/r.pack_to_translate.c:1
-#, fuzzy
msgid "Exports a raster map as GRASS GIS specific archive file"
+msgstr "Exporta un mapa ráster como un archivo de almacenamiento específico para GRASS GIS"
#: ../locale/scriptstrings/r.pack_to_translate.c:5
-#, fuzzy
msgid "Name of raster map to pack up"
-msgstr "Nombre del mapa raster a visualizar"
+msgstr "Nombre de mapa ráster a empaquetar"
#: ../locale/scriptstrings/r.pack_to_translate.c:6
#: ../locale/scriptstrings/v.pack_to_translate.c:6
-#, fuzzy
msgid "Name for output file (default is <input>.pack)"
+msgstr "Nombre para archivo de salida (el predeterminado es <input>.pack"
#: ../locale/scriptstrings/r.pack_to_translate.c:7
#: ../locale/scriptstrings/v.pack_to_translate.c:7
-#, fuzzy
msgid "Switch the compression off"
+msgstr "Cambiar a desactivar la compresión"
#: ../locale/scriptstrings/r.import_to_translate.c:1
-#, fuzzy
-msgid ""
-"Imports raster data into a GRASS raster map using GDAL library and "
-"reprojects on the fly."
-msgstr "Importar un archivo ráster binario a una capa de mapa ráster de GRASS."
+msgid "Imports raster data into a GRASS raster map using GDAL library and reprojects on the fly."
+msgstr "Importa datos ráster a mapa ráster de GRASS usando librería GDAL y reproyecta al vuelo."
#: ../locale/scriptstrings/r.import_to_translate.c:5
-#, fuzzy
msgid "Name of GDAL dataset to be imported"
-msgstr "Mapa ráster a importar"
+msgstr "Nombre de conjunto de datos GDAL que será importado"
#: ../locale/scriptstrings/r.import_to_translate.c:7
-#, fuzzy
msgid "Input band(s) to select (default is all bands)"
-msgstr "Banda a seleccionar (por omisión todas las bandas)"
+msgstr "Banda(s) de entrada a seleccionar (de manera predeterminada todas las bandas)"
#: ../locale/scriptstrings/r.import_to_translate.c:13
-#, fuzzy
msgid "Resampling method to use for reprojection"
-msgstr "Método de interpolación a usar en la reproyección"
+msgstr "Método de remuestreo que se usará para reproyección"
#: ../locale/scriptstrings/r.import_to_translate.c:14
-msgid ""
-"nearest;nearest neighbor;bilinear;bilinear interpolation;bicubic;bicubic "
-"interpolation;lanczos;lanczos filter;bilinear_f;bilinear interpolation with "
-"fallback;bicubic_f;bicubic interpolation with fallback;lanczos_f;lanczos "
-"filter with fallback"
-msgstr ""
+#, fuzzy
+msgid "nearest;nearest neighbor;bilinear;bilinear interpolation;bicubic;bicubic interpolation;lanczos;lanczos filter;bilinear_f;bilinear interpolation with fallback;bicubic_f;bicubic interpolation with fallback;lanczos_f;lanczos filter with fallback"
+msgstr "nearest;vecino más cercano;bilinear;interpolación bilineal;bicubic;interpolación bicúbica;lanczos;filtro lanczos;bilinear_f;bilinear interpolation with fallback;bicubic_f;bicubic interpolation with fallback;lanczos_f;lanczos filter with fallback"
#: ../locale/scriptstrings/r.import_to_translate.c:16
-#, fuzzy
msgid "Output raster map extent"
-msgstr "Título de mapa ráster de salida"
+msgstr "Extensión de mapa ráster de salida"
#: ../locale/scriptstrings/r.import_to_translate.c:17
-#, fuzzy
msgid "region;extent of current region;input;extent of input map"
+msgstr "region;extensión de la región actual;input;extensión del mapa de entrada"
#: ../locale/scriptstrings/r.import_to_translate.c:19
-#, fuzzy
msgid "Resolution of output raster map (default: estimated)"
-msgstr "Resolución del mapa de salida"
+msgstr "Resolución de mapa ráster de salida (predeterminada: estimated)"
#: ../locale/scriptstrings/r.import_to_translate.c:20
-#, fuzzy
-msgid ""
-"estimated;estimated resolution;value;user-specified resolution;region;"
-"current region resolution"
-msgstr ""
-"La resolución del archivo de elevación es distinta que la de la región actual"
+msgid "estimated;estimated resolution;value;user-specified resolution;region;current region resolution"
+msgstr "estimated;resolución estimada;value;resolución especificada por el usuario;region; resolución de la región actual"
#: ../locale/scriptstrings/r.import_to_translate.c:22
-#, fuzzy
msgid "Resolution of output raster map (use with option resolution=value)"
+msgstr "Resolución de mapa ráster (usar con opción resolution=valor)"
#: ../locale/scriptstrings/r.import_to_translate.c:24
#: ../raster/r.support/main.c:66 ../raster/r.in.ascii/main.c:96
@@ -21679,39 +19323,33 @@
msgstr "Metadatos"
#: ../locale/scriptstrings/r.import_to_translate.c:26
-#, fuzzy
msgid "Estimate resolution only"
-msgstr "Resolución correcta"
+msgstr "Estimar solamente resolución"
#: ../locale/scriptstrings/r.import_to_translate.c:27
#: ../locale/scriptstrings/r.import_to_translate.c:29
#: ../raster/r.horizon/main.c:278 ../raster/r.horizon/main.c:297
-#, fuzzy
msgid "Optional"
-msgstr "Nombre de archivo de salida <%s> no válido"
+msgstr "Opcional"
#: ../locale/scriptstrings/r.import_to_translate.c:28
#: ../raster/r.proj/main.c:208
msgid "Do not perform region cropping optimization"
-msgstr ""
+msgstr "No realizar optimización de cortado de la región"
#: ../locale/scriptstrings/r.import_to_translate.c:30
#: ../raster/r.in.gdal/main.c:204
msgid "Force Lat/Lon maps to fit into geographic coordinates (90N,S; 180E,W)"
-msgstr ""
-"Forzar los mpas Lat/Lon a encajar en coordenadas geogPosición de pantalla en "
-"coordenadas geográficas (90N,S; 180E,W)"
+msgstr "Forzar los mpas Lat/Lon a encajar en coordenadas geogPosición de pantalla en coordenadas geográficas (90N,S; 180E,W)"
#: ../locale/scriptstrings/d.rast.edit_to_translate.c:1
-#, fuzzy
msgid "Edits cell values in a raster map."
-msgstr "Editar valores de celda de forma interactiva en un mapa ráster."
+msgstr "Edita valores de celdas en mapa ráster."
#: ../locale/scriptstrings/d.rast.edit_to_translate.c:5
#: ../raster/r.flow/main.c:434
-#, fuzzy
msgid "Name of input aspect raster map"
+msgstr "Nombre de mapa ráster de entrada"
#: ../locale/scriptstrings/d.rast.edit_to_translate.c:6
msgid "Width of display canvas"
@@ -21734,11 +19372,8 @@
msgstr "Número máximo de columnas a cargar"
#: ../locale/scriptstrings/r.colors.stddev_to_translate.c:1
-#, fuzzy
msgid "Sets color rules based on stddev from a raster map's mean value."
-msgstr ""
-"Establecer normas de color basadas en stddev a partir de un valor medio del "
-"mapa."
+msgstr "Define las reglas de color basado en desviación estandar a partir del valor promedio de un mapa ráster."
#: ../locale/scriptstrings/r.colors.stddev_to_translate.c:4
msgid "Color using standard deviation bands"
@@ -21749,11 +19384,8 @@
msgstr "Forzar el centro a cero"
#: ../locale/scriptstrings/v.db.renamecolumn_to_translate.c:1
-msgid ""
-"Renames a column in the attribute table connected to a given vector map."
-msgstr ""
-"Cambia el nombre de una columna en la tabla de atributos conectada a un mapa "
-"vectorial dado."
+msgid "Renames a column in the attribute table connected to a given vector map."
+msgstr "Cambia el nombre de una columna en la tabla de atributos conectada a un mapa vectorial dado."
#: ../locale/scriptstrings/v.db.renamecolumn_to_translate.c:5
msgid "Old and new name of the column (old,new)"
@@ -21761,8 +19393,7 @@
#: ../locale/scriptstrings/v.what.vect_to_translate.c:1
msgid "Uploads vector values at positions of vector points to the table."
-msgstr ""
-"Carga valores vectoriales en las posiciones de puntos vectoriales a la tabla."
+msgstr "Carga valores vectoriales en las posiciones de puntos vectoriales a la tabla."
#: ../locale/scriptstrings/v.what.vect_to_translate.c:9
#: ../locale/scriptstrings/v.db.join_to_translate.c:6
@@ -21775,9 +19406,8 @@
msgstr "columna"
#: ../locale/scriptstrings/v.what.vect_to_translate.c:12
-#, fuzzy
msgid "Name of vector map to be queried"
-msgstr "Nombre de mapa vectorial a editar"
+msgstr "Nombre de mapa vectorial a consultar"
#: ../locale/scriptstrings/v.what.vect_to_translate.c:13
#, fuzzy
@@ -21790,18 +19420,16 @@
msgstr "capa,columna"
#: ../locale/scriptstrings/v.what.vect_to_translate.c:15
-#, fuzzy
msgid "Name of attribute column to be queried"
-msgstr "Nombre de columna de atributos a usar para etiquetas"
+msgstr "Nombre de columna de atributos a consultar"
#: ../locale/scriptstrings/v.what.vect_to_translate.c:16
msgid "Maximum query distance in map units"
msgstr "Distancia máxima de consulta en unidades de mapa"
#: ../locale/scriptstrings/v.in.lines_to_translate.c:1
-#, fuzzy
msgid "Imports ASCII x,y[,z] coordinates as a series of lines."
-msgstr "Importar coordenadas x,y[,z] ASCII como series de líneas."
+msgstr "Importa coordenadas x,y[,z] ASCII como series de líneas."
#: ../locale/scriptstrings/v.in.lines_to_translate.c:6
msgid "Create a 3D line from 3 column data"
@@ -21812,48 +19440,40 @@
msgstr "Nombre del archivo de entrada (o \"-\" a leer de stdin)"
#: ../locale/scriptstrings/t.info_to_translate.c:1
-#, fuzzy
msgid "Lists information about space time datasets and maps."
-msgstr "Mostrar información sobre ráster de entrada y salir"
+msgstr "Enlista información acerca de un conjunto de datos y mapas espacio temporales."
#: ../locale/scriptstrings/t.info_to_translate.c:6
-#, fuzzy
msgid "Name of an existing space time dataset or map"
-msgstr "Nombre de un mapa ráster existente"
+msgstr "Nombre de un conjunto de datos espacio temporales o mapa existente"
#: ../locale/scriptstrings/t.info_to_translate.c:10
-#, fuzzy
-msgid ""
-"Print history information in human readable shell style for space time "
-"datasets"
-msgstr "Impresión buena en formato leíble"
+msgid "Print history information in human readable shell style for space time datasets"
+msgstr "Mostrar la información histórica en el estilo humanamente legible de consola de comandos para conjunto de datos espacio temporales"
#: ../locale/scriptstrings/t.info_to_translate.c:11
-#, fuzzy
msgid "Print information about the temporal DBMI interface and exit"
+msgstr "Mostrar información acerca de interfaz temporal DBMI y salir"
#: ../locale/scriptstrings/v.krige_to_translate.c:1
msgid "Performs ordinary or block kriging for vector maps."
-msgstr ""
+msgstr "Realiza kriging ordinario o por bloques para mapas vectoriales."
#: ../locale/scriptstrings/v.krige_to_translate.c:5
msgid "kriging"
msgstr "kriging"
#: ../locale/scriptstrings/v.krige_to_translate.c:6
-#, fuzzy
msgid "Name of point vector map containing sample data"
-msgstr "Nombre del mapa vectorial de entrada que contiene líneas"
+msgstr "Nombre de mapa vectorial de puntos que contiene los datos de muestra"
#: ../locale/scriptstrings/v.krige_to_translate.c:7
-#, fuzzy
msgid "Name of attribute column with numerical value to be interpolated"
-msgstr "Columna de la tabla de atributos con valores a interpolar"
+msgstr "Nombre de columna de atributos que con los valores numéricos a interpolar"
#: ../locale/scriptstrings/v.krige_to_translate.c:9
msgid "If omitted, will be <input name>_kriging"
-msgstr ""
+msgstr "Si se omite, será <input name>_kriging"
#: ../locale/scriptstrings/v.krige_to_translate.c:10
msgid "R package to use"
@@ -21861,11 +19481,11 @@
#: ../locale/scriptstrings/v.krige_to_translate.c:11
msgid "Variogram model(s)"
-msgstr ""
+msgstr "Modelo(s) del variograma"
#: ../locale/scriptstrings/v.krige_to_translate.c:12
msgid "Leave empty to test all models (requires automap)"
-msgstr ""
+msgstr "Dejar vacio para probar todos los modelos (requiere automap)"
#: ../locale/scriptstrings/v.krige_to_translate.c:13
msgid "Block size (square block)"
@@ -21876,26 +19496,23 @@
msgstr "Tamaño de bloque. Usado para kriging de bloques (block kriging)."
#: ../locale/scriptstrings/v.krige_to_translate.c:15
-#, fuzzy
msgid "Range value"
-msgstr "Valor ráster"
+msgstr "Valor de rango"
#: ../locale/scriptstrings/v.krige_to_translate.c:16
#: ../locale/scriptstrings/v.krige_to_translate.c:18
#: ../locale/scriptstrings/v.krige_to_translate.c:20
#: ../locale/scriptstrings/v.krige_to_translate.c:22
msgid "Automatically fixed if not set"
-msgstr ""
+msgstr "Se ajusta automáticamente si no se define"
#: ../locale/scriptstrings/v.krige_to_translate.c:17
-#, fuzzy
msgid "Nugget value"
-msgstr "Valores Eigen:"
+msgstr "Valor de pepita"
#: ../locale/scriptstrings/v.krige_to_translate.c:19
-#, fuzzy
msgid "Sill value"
-msgstr "Valores ID"
+msgstr "Valor de meseta"
#: ../locale/scriptstrings/v.krige_to_translate.c:21
#, fuzzy
@@ -21903,18 +19520,16 @@
#: ../locale/scriptstrings/v.krige_to_translate.c:23
-#, fuzzy
msgid "Name for output variance raster map"
-msgstr "Nombre para el mapa raster de orientación de salida"
+msgstr "Nombre de mapas ráster de varianza de salida"
#: ../locale/scriptstrings/v.krige_to_translate.c:24
msgid "If omitted, will be <input name>_kriging.var"
-msgstr ""
+msgstr "Si se omite, será <input name>_kriging.var"
#: ../locale/scriptstrings/r.mask_to_translate.c:1
-#, fuzzy
msgid "Creates a MASK for limiting raster operation."
-msgstr "Crear una MÁSCARA para limitar la operación ráster"
+msgstr "Crear MÁSCARA para limitar la operación ráster."
#: ../locale/scriptstrings/r.mask_to_translate.c:3
#: ../raster3d/r3.mask/main.c:134
@@ -21931,13 +19546,12 @@
msgstr "Raster"
#: ../locale/scriptstrings/r.mask_to_translate.c:6
-#, fuzzy
msgid "Raster values to use for mask"
-msgstr "Mapa ráster a usar como MÁSCARA"
+msgstr "Valores ráster a usar para máscara"
#: ../locale/scriptstrings/r.mask_to_translate.c:7
msgid "Format: 1 2 3 thru 7 *"
-msgstr ""
+msgstr "Formato: 1 2 3 thru 7 *"
#: ../locale/scriptstrings/r.mask_to_translate.c:9
msgid "Name of vector map to use as mask"
@@ -21959,14 +19573,12 @@
msgstr "Valores de categoría (vectorial)"
#: ../locale/scriptstrings/r.mask_to_translate.c:15
-#, fuzzy
msgid "WHERE conditions of SQL statement without 'where' keyword (vector)"
-msgstr "Hasta condiciones WHERE de sentencia SQL sin palabra clave 'where'"
+msgstr "Condiciones WHERE de sentencia SQL sin palabra clave 'where' (vectorial)"
#: ../locale/scriptstrings/r.mask_to_translate.c:17
-#, fuzzy
msgid "Create inverse mask"
-msgstr "Crear un mapa raster integer"
+msgstr "Crear máscara inversa"
#: ../locale/scriptstrings/r.mask_to_translate.c:18
#: ../general/g.proj/main.c:201 ../general/g.mapset/main.c:70
@@ -21974,9 +19586,8 @@
msgstr "Crear"
#: ../locale/scriptstrings/r.mask_to_translate.c:19
-#, fuzzy
msgid "Remove existing mask (overrides other options)"
-msgstr "Eliminar MÁSCARA existente (ignora otras opciones)"
+msgstr "Eliminar máscara existente (ignora otras opciones)"
#: ../locale/scriptstrings/db.in.ogr_to_translate.c:1
msgid "Imports attribute tables in various formats."
@@ -21987,9 +19598,8 @@
msgstr "Archivo de tabla a importar o cadena de conexión a base de datos"
#: ../locale/scriptstrings/db.in.ogr_to_translate.c:6
-#, fuzzy
msgid "Name of table from given DB to be imported"
+msgstr "Nombre de tabla desde DB dada que será importada"
#: ../locale/scriptstrings/db.in.ogr_to_translate.c:7
msgid "Name for output table"
@@ -22001,21 +19611,15 @@
#: ../locale/scriptstrings/db.in.ogr_to_translate.c:12
msgid "Overrides encoding interpretation, useful when importing DBF tables"
-msgstr ""
+msgstr "Ignora interpretación de codificación, útil cuando se importan tablasa DBF"
#: ../locale/scriptstrings/t.rast.to.rast3_to_translate.c:1
-#, fuzzy
msgid "Converts a space time raster dataset into a 3D raster map."
-msgstr "Convierte mapas ráster 3D en mapas ráster 2D"
+msgstr "Convierte un conjunto de datos ráster en un mapa ráster 3D."
#: ../locale/scriptstrings/t.rast.series_to_translate.c:1
-#, fuzzy
-msgid ""
-"Performs different aggregation algorithms from r.series on all or a subset "
-"of raster maps in a space time raster dataset."
-msgstr ""
-"Calcula estadísticas univariantes a partir de celdas no nulas de un mapa "
-"ráster."
+msgid "Performs different aggregation algorithms from r.series on all or a subset of raster maps in a space time raster dataset."
+msgstr "Realiza algoritmos de agregación diferentes de r.series en todos los subconjuntos de mapas raster en un conjunto de datos ráster espacio temporales."
#: ../locale/scriptstrings/t.rast.series_to_translate.c:4
#: ../raster/r.series.accumulate/main.c:81 ../raster/r.series.interp/main.c:65
@@ -22024,11 +19628,8 @@
msgstr "series"
#: ../locale/scriptstrings/t.rast.series_to_translate.c:9
-#, fuzzy
-msgid ""
-"Do not assign the space time raster dataset start and end time to the output "
-"map"
+msgid "Do not assign the space time raster dataset start and end time to the output map"
+msgstr "No asignar el tiempo de inicio y término del conjunto de datos espacio temporales al mapa de salida"
#: ../locale/scriptstrings/t.rast.series_to_translate.c:10
#: ../raster/r.series.accumulate/main.c:159 ../raster/r.resamp.stats/main.c:285
@@ -22038,18 +19639,12 @@
#: ../locale/scriptstrings/r.buffer.lowmem_to_translate.c:1
#: ../raster/r.buffer/main.c:69
-#, fuzzy
-msgid ""
-"Creates a raster map showing buffer zones surrounding cells that contain non-"
-"NULL category values."
-msgstr ""
-"Crea una capa de mapa ráster que muestra zonas de buffer que rodean celdas "
-"que contienen valores de categoría no NULOS."
+msgid "Creates a raster map showing buffer zones surrounding cells that contain non-NULL category values."
+msgstr "Crea una capa de mapa ráster que muestra zonas de buffer que rodean celdas que contienen valores de categoría no NULOS."
#: ../locale/scriptstrings/r.buffer.lowmem_to_translate.c:2
msgid "This is the low-memory alternative to the classic r.buffer module."
-msgstr ""
-"Esta es la alternativa de bajo uso de memoria al módulo clásico r.buffer."
+msgstr "Esta es la alternativa de bajo uso de memoria al módulo clásico r.buffer."
#: ../locale/scriptstrings/r.buffer.lowmem_to_translate.c:5
#: ../raster/r.buffer/main.c:94
@@ -22068,19 +19663,16 @@
#: ../locale/scriptstrings/r.grow_to_translate.c:1
msgid "Generates a raster map layer with contiguous areas grown by one cell."
-msgstr ""
-"Genera una capa de mapa ráster con áreas contiguas incrementadas en una "
-"celda."
+msgstr "Genera una capa de mapa ráster con áreas contiguas incrementadas en una celda."
#: ../locale/scriptstrings/r.grow_to_translate.c:4
#: ../raster/r.grow.distance/main.c:154
msgid "proximity"
-msgstr ""
+msgstr "proximidad"
#: ../locale/scriptstrings/r.grow_to_translate.c:5
-#, fuzzy
msgid "Radius is in map units rather than cells"
-msgstr "Radio de buffer en celdas ráster"
+msgstr "Radio en unidades de mapa en vez de en celdas"
#: ../locale/scriptstrings/r.grow_to_translate.c:6
msgid "Radius of buffer in raster cells"
@@ -22100,42 +19692,32 @@
msgstr "Valor a escribir para celdas \"incrementadas\""
#: ../locale/scriptstrings/t.rast.gapfill_to_translate.c:1
-#, fuzzy
-msgid ""
-"Replaces gaps in a space time raster dataset with interpolated raster maps."
+msgid "Replaces gaps in a space time raster dataset with interpolated raster maps."
+msgstr "Reemplaza vacíos en un conjunto de datos ráster espacio temporales con mapas ráster interpolados."
#: ../locale/scriptstrings/t.rast.gapfill_to_translate.c:9
-#, fuzzy
msgid "Number of interpolation processes to run in parallel"
+msgstr "Número de procesos de interpolación a correr en paralelo"
#: ../locale/scriptstrings/t.rast.gapfill_to_translate.c:10
-msgid ""
-"Assign the space time raster dataset start and end time to the output map"
-msgstr ""
+msgid "Assign the space time raster dataset start and end time to the output map"
+msgstr "Asignar el tiempo de inicio y término del conjunto de datos espacio temporales en el mapa de salida"
#: ../locale/scriptstrings/t.rast3d.extract_to_translate.c:1
-#, fuzzy
msgid "Extracts a subset of a space time 3D raster dataset."
+msgstr "Extrae un subconjunto del conjunto de datos ráster 3D espacio temporales."
#: ../locale/scriptstrings/t.rast3d.extract_to_translate.c:7
-#, fuzzy
msgid "The r3.mapcalc expression assigned to all extracted 3D raster maps"
-msgstr "Listar mapas vectoriales en la localización de entrada y salir"
+msgstr "La expresión r3.mapcalc asignada a todos los mapas ráster 3D extraidos"
#: ../locale/scriptstrings/t.rast3d.extract_to_translate.c:8
-#, fuzzy
msgid "Basename of the new generated 3D raster maps"
-msgstr "Nombre del mapa ráster 3D de entrada"
+msgstr "Nombre base del nuevo mapa ráster 3D generado"
#: ../locale/scriptstrings/r.fillnulls_to_translate.c:1
-#, fuzzy
msgid "Fills no-data areas in raster maps using spline interpolation."
-msgstr ""
-"Rellenar áreas sin datos de los mapas ráster usando la interpolación splines "
-"de v.sufr.rst"
+msgstr "Rellenar áreas sin datos de mapas ráster, usando la interpolación de splines."
#: ../locale/scriptstrings/r.fillnulls_to_translate.c:5
#: ../raster/r.proj/main.c:182
@@ -22153,9 +19735,8 @@
#: ../locale/scriptstrings/r.fillnulls_to_translate.c:11
#: ../locale/scriptstrings/r.fillnulls_to_translate.c:13
#: ../locale/scriptstrings/r.fillnulls_to_translate.c:15
-#, fuzzy
msgid "RST options"
-msgstr "Localización: %s\n"
+msgstr "Opciones RST"
#: ../locale/scriptstrings/r.fillnulls_to_translate.c:8
msgid "Spline smoothing parameter"
@@ -22177,9 +19758,8 @@
#: ../locale/scriptstrings/v.db.join_to_translate.c:1
-#, fuzzy
msgid "Joins a database table to a vector map table."
-msgstr "Permite unir una tabla a la tabla de un mapa vectorial."
+msgstr "Une tabla de una base de datos a una tabla de un mapa vectorial."
#: ../locale/scriptstrings/v.db.join_to_translate.c:5
msgid "Vector map to which to join other table"
@@ -22191,117 +19771,98 @@
#: ../locale/scriptstrings/v.db.join_to_translate.c:9
msgid "Identifier column (e.g.: cat) in the vector table to be used for join"
-msgstr ""
+msgstr "Columna de identificador (ej.: cat) en la tabla vectorial que será usada para unión"
#: ../locale/scriptstrings/v.db.join_to_translate.c:10
msgid "Other table name"
msgstr "Nombre de la otra tabla"
#: ../locale/scriptstrings/v.db.join_to_translate.c:11
-#, fuzzy
msgid "ocolumn,scolumns"
-msgstr "Columnas"
+msgstr "ocolumn,scolumns"
#: ../locale/scriptstrings/v.db.join_to_translate.c:12
msgid "Identifier column (e.g.: id) in the other table used for join"
-msgstr ""
+msgstr "Columna de identificador (ej.: cat) en la otra tabla usada para unión"
#: ../locale/scriptstrings/v.db.join_to_translate.c:13
-#, fuzzy
msgid "Subset of columns from the other table"
-msgstr "Número de columnas que aparecen en la tabla de color"
+msgstr "Subconjunto de columnas desde la otra tabla"
#: ../locale/scriptstrings/t.rast.import_to_translate.c:1
-#, fuzzy
msgid "Imports space time raster dataset."
+msgstr "Importa conjunto de datos ráster espacio temporales."
#: ../locale/scriptstrings/t.rast.import_to_translate.c:14
-#, fuzzy
msgid "Set the current region from the last map that was imported"
-msgstr "Alinear la región actual al mapa raster de entrada"
+msgstr "Establecer la región actual desde el último mapa que fue importado"
#: ../locale/scriptstrings/t.rast.import_to_translate.c:15
-#, fuzzy
msgid "Link the raster files using r.external"
-msgstr "Link al mapa raster <%s> creado"
+msgstr "Enlazar el archivo ráster usando r.external"
#: ../locale/scriptstrings/t.rast.import_to_translate.c:19
-msgid ""
-"Create the location specified by the \"location\" parameter and exit. Do not "
-"import the space time raster datasets."
-msgstr ""
+msgid "Create the location specified by the \"location\" parameter and exit. Do not import the space time raster datasets."
+msgstr "Crear la Localización especificada por el parámetro \"location\" y salir. No importa conjuntos de datos ráster espacio temporales."
#: ../locale/scriptstrings/v.pack_to_translate.c:1
-#, fuzzy
msgid "Exports a vector map as GRASS GIS specific archive file"
+msgstr "Exporta un mapa vectorial como un archivo de almacenamiento específico de GRASS GIS"
#: ../locale/scriptstrings/v.pack_to_translate.c:5
-#, fuzzy
msgid "Name of vector map to pack up"
-msgstr "Nombre del mapa ráster a visualizar"
+msgstr "Nombre de mapa vectorial a empaquetar"
#: ../locale/scriptstrings/db.out.ogr_to_translate.c:1
msgid "Exports attribute tables into various formats."
msgstr "Exporta tablas de atributos a varios formatos."
#: ../locale/scriptstrings/db.out.ogr_to_translate.c:5
-#, fuzzy
msgid "GRASS table name"
-msgstr "Nombre de la otra tabla"
+msgstr "Nombre de tabla GRASS"
#: ../locale/scriptstrings/db.out.ogr_to_translate.c:6
-#, fuzzy
msgid "Output table file name or DB connection string"
-msgstr "Archivo de tabla a importar o cadena de conexión a base de datos"
+msgstr "Nombre de archivo de tabla de salida o cadena de conexión DB"
#: ../locale/scriptstrings/db.out.ogr_to_translate.c:7
msgid "Table format"
-msgstr "Formato de la tabla"
+msgstr "Formato de tabla"
#: ../locale/scriptstrings/db.out.ogr_to_translate.c:8
-#, fuzzy
msgid "Name for output table (default: input name)"
-msgstr "Nombre para el mapa vectorial de salida (por defecto: el de entrada)"
+msgstr "Nombre para tabla de salida (predeterminado: nombre de entrada)"
#: ../raster3d/r3.timestamp/main.c:48
msgid "Print/add/remove a timestamp for a 3D raster map"
-msgstr "Imprimir/añadir/eliminar una marca de tiempo para un mapa ráster 3D"
+msgstr "Mostrar/añadir/eliminar una marca de tiempo para un mapa ráster 3D"
#: ../raster3d/r3.timestamp/main.c:57
msgid "Datetime, datetime1/datetime2, or none"
-msgstr "Fecha y hora, fecha1/fecha2 o ninguna"
+msgstr "Datetime, datetime1/datetime2, o none"
#: ../raster3d/r3.timestamp/main.c:90
-#, fuzzy
msgid "Timestamp format is invalid"
-msgstr "Formato de indicador de tiempo desconocido: "
+msgstr "Formato de marca de tiempo no válido"
#: ../raster3d/r3.info/main.c:80
msgid "Outputs basic information about a user-specified 3D raster map layer."
-msgstr ""
-"Saca información básica de una capa de mapa ráster 3D especificada por el "
-"usuario."
+msgstr "Saca información básica de una capa de mapa ráster 3D especificada por el usuario."
#: ../raster3d/r3.info/main.c:86
-#, fuzzy
msgid "Print raster3d information in shell style"
-msgstr ""
-"Imprimir información en el estilo de script de la consola de comandos de UNIX"
+msgstr "Mostrar información de ráster3d en estilo de consola de comandos"
#: ../raster3d/r3.info/main.c:90
-#, fuzzy
msgid "Print range in shell style only"
-msgstr ""
+msgstr "Mostrar solamente rango en estilo de consola de comandos"
#: ../raster3d/r3.info/main.c:94 ../raster/r.info/main.c:93
msgid "Print raster history instead of info"
msgstr "Imprimir histórico del ráster en vez de información"
#: ../raster3d/r3.info/main.c:103
-#, fuzzy, c-format
+#, c-format
msgid "3D Raster map <%s> not found"
msgstr "Mapa ráster 3D <%s> no encontrado"
@@ -22319,9 +19880,9 @@
#: ../raster3d/r3.out.netcdf/main.c:617 ../raster3d/r3.retile/main.c:127
#: ../raster3d/r3.mkdspf/main.c:168 ../raster/r.univar/r3.univar_main.c:151
#: ../raster/r.univar/r3.univar_main.c:189
-#, fuzzy, c-format
+#, c-format
msgid "Unable to open 3D raster map <%s>"
-msgstr "No se puede abrir el mapa ráster <%s>"
+msgstr "No ha sido posible abrir mapa ráster 3D <%s>"
#: ../raster3d/r3.info/main.c:138 ../raster3d/r3.info/main.c:145
#: ../raster3d/r3.info/main.c:151 ../raster3d/r3.info/main.c:156
@@ -22344,9 +19905,9 @@
#: ../raster3d/r3.info/main.c:328 ../raster3d/r3.info/main.c:448
#: ../raster3d/r3.mkdspf/main.c:171
-#, fuzzy, c-format
+#, c-format
msgid "Unable to read range of 3D raster map <%s>"
-msgstr "No se puede leer el intervalo del mapa raster <%s>"
+msgstr "No ha sido posible leer el rango del mapa ráster 3D <%s>"
#: ../raster3d/r3.info/main.c:492
msgid "Error while reading history file"
@@ -22354,9 +19915,9 @@
#: ../raster3d/r3.info/main.c:499 ../raster3d/r3.cross.rast/main.c:343
#: ../raster3d/r3.null/main.c:169 ../raster3d/r3.out.vtk/errorHandling.c:65
-#, fuzzy, c-format
+#, c-format
msgid "Unable to close 3D raster map <%s>"
-msgstr "No se puede cerrar el mapa ráster <%s@%s>"
+msgstr "No se puede cerrar mapa ráster 3D <%s>"
#: ../raster3d/r3.out.bin/main.c:113 ../raster/r.out.bin/main.c:53
#: ../raster/r.out.bin/main.c:62 ../raster/r.out.bin/main.c:470
@@ -22366,18 +19927,16 @@
msgstr "Error al escribir datos"
#: ../raster3d/r3.out.bin/main.c:208
-#, fuzzy
msgid "Exports a GRASS 3D raster map to a binary array."
-msgstr "Exporta un ráster de GRASS a una secuencia binaria."
+msgstr "Exporta un mapa ráster 3D de GRASS a una matriz binaria."
#: ../raster3d/r3.out.bin/main.c:221 ../raster/r.out.bin/main.c:304
msgid "Value to write out for null"
msgstr "Valor a escribir para nulos"
#: ../raster3d/r3.out.bin/main.c:228 ../raster3d/r3.in.bin/main.c:268
-#, fuzzy
msgid "Number of bytes per cell in binary file"
-msgstr "Número de bytes por celda"
+msgstr "Número de bytes por celda en archivo binario"
#: ../raster3d/r3.out.bin/main.c:235 ../raster/r.out.bin/main.c:318
#: ../raster/r.in.bin/main.c:330
@@ -22388,17 +19947,16 @@
#: ../raster3d/r3.out.bin/main.c:240 ../raster3d/r3.out.ascii/main.c:106
#: ../raster3d/r3.in.bin/main.c:354
msgid "Switch the row order in output from north->south to south->north"
-msgstr ""
+msgstr "Cambiar el orden de las filas en salida de norte->sur a sur->norte"
#: ../raster3d/r3.out.bin/main.c:245 ../raster3d/r3.out.ascii/main.c:110
#: ../raster3d/r3.in.bin/main.c:359
msgid "Switch the depth order in output from bottom->top to top->bottom"
-msgstr ""
+msgstr "Cambiar el orden de la profundidad en la salida desde fondo->cima a cima->fondo"
#: ../raster3d/r3.out.bin/main.c:250
-#, fuzzy
msgid "Write data as integer"
-msgstr "Leer mapa fp como entero"
+msgstr "Escribir datos como enteros"
#: ../raster3d/r3.out.bin/main.c:256 ../raster/r.out.bin/main.c:347
msgid "Invalid value for null (integers only)"
@@ -22410,14 +19968,14 @@
#: ../raster3d/r3.out.bin/main.c:273
msgid "Integer output doesn't support bytes=8 in this build"
-msgstr ""
+msgstr "Salida de enteros no soporta bytes=8 en su construcción"
#: ../raster3d/r3.out.bin/main.c:321 ../raster/r.out.bin/main.c:144
#: ../raster/r.out.bin/main.c:228 ../raster/r.out.bin/main.c:414
#: ../display/d.mon/start.c:168 ../display/d.mon/start.c:207
#, c-format
msgid "Unable to create file <%s>"
-msgstr "No se puede crear el archivo <%s>"
+msgstr "No ha sido posible crear archivo <%s>"
#: ../raster3d/r3.out.bin/main.c:323 ../raster/r.out.bin/main.c:454
msgid "Using the current region settings..."
@@ -22426,22 +19984,22 @@
#: ../raster3d/r3.out.bin/main.c:324 ../raster/r.out.bin/main.c:455
#, c-format
msgid "north=%f"
-msgstr "Norte=%f"
+msgstr "norte=%f"
#: ../raster3d/r3.out.bin/main.c:325 ../raster/r.out.bin/main.c:456
#, c-format
msgid "south=%f"
-msgstr "Sur=%f"
+msgstr "sur=%f"
#: ../raster3d/r3.out.bin/main.c:326 ../raster/r.out.bin/main.c:457
#, c-format
msgid "east=%f"
-msgstr "Este?%f"
+msgstr "este=%f"
#: ../raster3d/r3.out.bin/main.c:327 ../raster/r.out.bin/main.c:458
#, c-format
msgid "west=%f"
-msgstr "Oeste=%f"
+msgstr "oeste=%f"
#: ../raster3d/r3.out.bin/main.c:328
#, c-format
@@ -22451,7 +20009,7 @@
#: ../raster3d/r3.out.bin/main.c:329
#, c-format
msgid "bottom=%f"
-msgstr "fodo=%f"
+msgstr "fondo=%f"
#: ../raster3d/r3.out.bin/main.c:330 ../raster/r.in.mat/main.c:398
#: ../raster/r.out.mat/main.c:180
@@ -22471,104 +20029,68 @@
msgstr "profundides=%d"
#: ../raster3d/r3.gwflow/main.c:54
-#, fuzzy
msgid "Input 3D raster map with initial piezometric heads in [m]"
-msgstr "La altura piezométrica inicial en [m]"
+msgstr "Mapa ráster 3D de entrada con cargas piezométricas inciales en [m]"
#: ../raster3d/r3.gwflow/main.c:60
-msgid ""
-"Input 3D raster map providing the status for each cell, = 0 - inactive, 1 - "
-"active, 2 - dirichlet"
-msgstr ""
-"Mapa ráster 3D de entrada que define el estado para cada celda, = 0 - "
-"inactiva, 1 - activa, 2 - dirichlet"
+msgid "Input 3D raster map providing the status for each cell, = 0 - inactive, 1 - active, 2 - dirichlet"
+msgstr "Mapa ráster 3D de entrada que define el estado para cada celda, = 0 - inactiva, 1 - activa, 2 - dirichlet"
#: ../raster3d/r3.gwflow/main.c:65
-msgid ""
-"Input 3D raster map with the x-part of the hydraulic conductivity tensor in "
-"[m/s]"
-msgstr ""
-"Mapa de entrada ráster 3D con la parte X del tensor de conductividad "
-"hidráulica en [m/s]"
+msgid "Input 3D raster map with the x-part of the hydraulic conductivity tensor in [m/s]"
+msgstr "Mapa de entrada ráster 3D con la parte X del tensor de conductividad hidráulica en [m/s]"
#: ../raster3d/r3.gwflow/main.c:70
-#, fuzzy
-msgid ""
-"Input 3D raster map with the y-part of the hydraulic conductivity tensor in "
-"[m/s]"
-msgstr "La parte Y del tensor de conductividad hidráulica en [m/s]"
+msgid "Input 3D raster map with the y-part of the hydraulic conductivity tensor in [m/s]"
+msgstr "Mapa ráster 3D de entrada con parte y del tensor de conductividad hidráulica en [m/s]"
#: ../raster3d/r3.gwflow/main.c:75
-#, fuzzy
-msgid ""
-"Input 3D raster map with the z-part of the hydraulic conductivity tensor in "
-"[m/s]"
-msgstr "Parte Z del tensor de conductividad hidráulica en [m/s]"
+msgid "Input 3D raster map with the z-part of the hydraulic conductivity tensor in [m/s]"
+msgstr "Mapa ráster 3D de entrada con parte z del tensor de conductividad hidráulica en [m/s]"
#: ../raster3d/r3.gwflow/main.c:80
-#, fuzzy
msgid "Input 3D raster map with sources and sinks in [m^3/s]"
-msgstr "Fuentes de agua y sumideros en [m³/s]"
+msgstr "Mapa ráster 3D con fuentes y sumideros en [m^3/s]"
#: ../raster3d/r3.gwflow/main.c:84
-#, fuzzy
msgid "Specific yield [1/m] input 3D raster map"
-msgstr "Rendimiento específico en [1/m]"
+msgstr "Mapa ráster 3D de entrada de rendimiento específico [1/m]"
#: ../raster3d/r3.gwflow/main.c:89
-#, fuzzy
msgid "Recharge input 3D raster map in m^3/s"
-msgstr "Recargar mapa ráster en m^3/s"
+msgstr "Mapa ráster 3D de entrada de recarga en m^3/s"
#: ../raster3d/r3.gwflow/main.c:93
-#, fuzzy
-msgid ""
-"Output 3D raster map storing the piezometric head result of the numerical "
-"calculation"
-msgstr "Mapa ráster 3D de salida que guarda "
+msgid "Output 3D raster map storing the piezometric head result of the numerical calculation"
+msgstr "Mapa ráster 3D de salida que guarda carga piezométrica resultante del cálculo numérico"
#: ../raster3d/r3.gwflow/main.c:99
-#, fuzzy
-msgid ""
-"Output 3D raster map storing the groundwater filter velocity vector part in "
-"x direction [m/s]"
-msgstr "Calcular vectorial a nombre"
+msgid "Output 3D raster map storing the groundwater filter velocity vector part in x direction [m/s]"
+msgstr "Mapa ráster 3D de salida que guarda el vector de la velocidad de filtrado en dirección x [m/s]"
#: ../raster3d/r3.gwflow/main.c:105
-#, fuzzy
-msgid ""
-"y direction [m/s]"
+msgid "Output 3D raster map storing the groundwater filter velocity vector part in y direction [m/s]"
+msgstr "Mapa ráster 3D de salida que guarda el vector de la velocidad de filtrado en dirección y [m/s]"
#: ../raster3d/r3.gwflow/main.c:111
-#, fuzzy
-msgid ""
-"z direction [m/s]"
+msgid "Output 3D raster map storing the groundwater filter velocity vector part in z direction [m/s]"
+msgstr "Mapa ráster 3D de salida que guarda el vector de la velocidad de filtrado en dirección z [m/s]"
#: ../raster3d/r3.gwflow/main.c:117
-#, fuzzy
-msgid ""
-"Output 3D raster map storing the groundwater budget for each cell [m^3/s]"
+msgid "Output 3D raster map storing the groundwater budget for each cell [m^3/s]"
+msgstr "Mapa ráster 3D de salida que guarda el presupuesto hídrico de agua subterranea para cada celda [m^3/s]"
#: ../raster3d/r3.gwflow/main.c:127
-#, fuzzy
msgid "Use 3D raster mask (if exists)"
-msgstr "Usar máscara G3D (si existe) con el mapa de entrada"
+msgstr "Usar máscara ráster 3D (si existe)"
#: ../raster3d/r3.gwflow/main.c:131 ../raster/r.solute.transport/main.c:192
-msgid ""
-"Use a full filled quadratic linear equation system, default is a sparse "
-"linear equation system."
-msgstr ""
+msgid "Use a full filled quadratic linear equation system, default is a sparse linear equation system."
+msgstr "Usar un sistema de ecuaciones lineales cuadráticas completamente llenado, el predeterminado es un sistema de ecuaciones lineales incompleto."
#: ../raster3d/r3.gwflow/main.c:160 ../raster/r.gwflow/main.c:209
-#, fuzzy
msgid "groundwater flow"
-msgstr "El tipo de flujo de "
+msgstr "Flujo hídrico subterraneo"
#: ../raster3d/r3.gwflow/main.c:162 ../raster3d/r3.flow/test_main.c:44
#: ../raster3d/r3.flow/main.c:180 ../raster/r.topmodel/main.c:52
@@ -22584,13 +20106,8 @@
msgstr "hidrología"
#: ../raster3d/r3.gwflow/main.c:163
-#, fuzzy
-msgid ""
-"Numerical calculation program for transient, confined groundwater flow in "
-"three dimensions."
-msgstr ""
-"Programa de cálculo numérico para flujos transientes de aguas subterráneas "
-"confinadas en tres dimensiones"
+msgid "Numerical calculation program for transient, confined groundwater flow in three dimensions."
+msgstr "Programa de cálculo numérico para flujo de aguas subterráneas temporales, confinadas, en tres dimensiones."
#: ../raster3d/r3.gwflow/main.c:180
msgid ""
@@ -22606,9 +20123,9 @@
#: ../raster3d/r3.in.lidar/main.c:281 ../raster3d/r3.in.lidar/main.c:287
#: ../raster3d/r3.in.lidar/main.c:294 ../raster3d/r3.in.lidar/main.c:301
#: ../raster3d/r3.in.lidar/main.c:307 ../raster3d/r3.in.lidar/main.c:313
-#, fuzzy, c-format
+#, c-format
msgid "Unable to create 3D raster map <%s>"
-msgstr "No se puede crear el mapa ráster <%s>"
+msgstr "No ha sido posible crear mapa ráster 3D <%s>"
#: ../raster3d/r3.gwflow/main.c:412 ../raster3d/r3.to.rast/main.c:55
#: ../raster3d/r3.to.rast/main.c:383 ../raster3d/r3.cross.rast/main.c:55
@@ -22632,31 +20149,20 @@
#: ../raster3d/r3.to.rast/main.c:91 ../raster3d/r3.cross.rast/main.c:109
#: ../raster3d/r3.out.ascii/main.c:118 ../raster3d/r3.out.netcdf/main.c:116
#: ../raster/r.to.rast3elev/main.c:194
-#, fuzzy
msgid "Use 3D raster mask (if exists) with input map"
+msgstr "Usar máscara 3D (si existe) con el mapa de entrada"
#: ../raster3d/r3.to.rast/main.c:96
-#, fuzzy
-msgid ""
-"Use the same resolution as the input 3D raster map for the 2D output maps, "
-"independent of the current region settings"
-msgstr ""
-"Usar la misma resolución que en mapa RASTER3D de entrada para los mapas 2D "
-"de salida, independientemente de la configuración de la región actual"
+msgid "Use the same resolution as the input 3D raster map for the 2D output maps, independent of the current region settings"
+msgstr "Usar la misma resolución que en mapa ráster 3D de entrada para los mapas 2D de salida, independientemente de la configuración de la región actual"
#: ../raster3d/r3.to.rast/main.c:210
msgid "Converts 3D raster maps to 2D raster maps"
#: ../raster3d/r3.to.rast/main.c:271 ../raster3d/r3.out.vtk/main.c:451
-#, fuzzy
-msgid ""
-"The 2D and 3D region settings are different. Using the 2D window settings to "
-"adjust the 2D part of the 3D region."
-msgstr ""
-"Las configuraciones de la región 2D y 3D son diferentes. Usando las "
-"configuraciones de la ventana 2D para ajustar la parte 2D de la región 3D."
+msgid "The 2D and 3D region settings are different. Using the 2D window settings to adjust the 2D part of the 3D region."
+msgstr "Las configuraciones de la región 2D y 3D son diferentes. Usando las configuraciones de la ventana 2D para ajustar la parte 2D de la región 3D."
#: ../raster3d/r3.to.rast/main.c:297
#, c-format
@@ -22669,10 +20175,9 @@
msgstr "Nombre de archivo del mapa ráster %i: %s"
#: ../raster3d/r3.to.rast/main.c:308
-#, fuzzy, c-format
-msgid ""
-"Raster map %d Filename: %s already exists. Use the flag --o to overwrite."
-msgstr "Nombre de archivo del mapa ráster %i: %s ya existe. ¡Se sobrescribirá!"
+#, c-format
+msgid "Raster map %d Filename: %s already exists. Use the flag --o to overwrite."
+msgstr "Nombre de archivo de mapa ráster %d: %s ya existe. Usar la bandear --o para sobreescribir."
#: ../raster3d/r3.flow/test_main.c:46
#, fuzzy
@@ -22699,21 +20204,17 @@
msgstr "Calculando direcciones de flujo..."
#: ../raster3d/r3.flow/main.c:193
-msgid ""
-"Names of three 3D raster maps describing x, y, z components of vector field"
+msgid "Names of three 3D raster maps describing x, y, z components of vector field"
msgstr ""
#: ../raster3d/r3.flow/main.c:200
-msgid ""
-"If no map is provided, flow lines are generated from each cell of the input "
-"3D raster"
+msgid "If no map is provided, flow lines are generated from each cell of the input 3D raster"
msgstr ""
#: ../raster3d/r3.flow/main.c:203
#, fuzzy
msgid "Name of vector map with points from which flow lines are generated"
-msgstr ""
-"Nombre del mapa vectorial de puntos para el que editar la tabla de atributos"
+msgstr "Nombre del mapa vectorial de puntos para el que editar la tabla de atributos"
#: ../raster3d/r3.flow/main.c:210
#, fuzzy
@@ -22731,8 +20232,7 @@
msgstr "Nombre del mapa(s) raster para el brillo"
#: ../raster3d/r3.flow/main.c:226
-msgid ""
-"Values of this 3D raster will be stored as attributes of flowlines segments"
+msgid "Values of this 3D raster will be stored as attributes of flowlines segments"
msgstr ""
#: ../raster3d/r3.flow/main.c:240
@@ -22756,8 +20256,7 @@
#: ../raster3d/r3.flow/main.c:244
#, fuzzy
msgid "Default unit is cell"
-msgstr ""
-"Anchura de corriente (en metros). Por defecto es la anchura de celda ráster."
+msgstr "Anchura de corriente (en metros). Por defecto es la anchura de celda ráster."
#: ../raster3d/r3.flow/main.c:245 ../raster3d/r3.flow/main.c:254
#: ../raster3d/r3.flow/main.c:262 ../raster3d/r3.flow/main.c:272
@@ -22813,23 +20312,20 @@
msgstr "Error leyendo datos"
#: ../raster3d/r3.stats/main.c:51
-#, fuzzy
msgid "Generates volume statistics for 3D raster maps."
msgstr "Genera estadísticas de volúmenes para mapas ráster 3D."
#: ../raster3d/r3.stats/main.c:62
-#, fuzzy
msgid "Number of subranges to collect stats from"
-msgstr "Número de subrangos de los que recoger estadísticas"
+msgstr "Número de subrangos de los cuales se colectarán estadísticas"
#: ../raster3d/r3.stats/main.c:67
msgid "Calculate statistics based on equal value groups"
msgstr "Calcula estadísticas basadas en grupos de valores iguales"
#: ../raster3d/r3.stats/main.c:71
-#, fuzzy
msgid "Only print cell counts"
-msgstr "Imprimir cuenta de celdas"
+msgstr "Mostrar solamente conteo de celdas"
#: ../raster3d/r3.stats/main.c:91
msgid "The number of subranges has to be equal or greater than 1"
@@ -22840,9 +20336,8 @@
msgstr "Ordenar valores no nulos"
#: ../raster3d/r3.cross.rast/main.c:90
-#, fuzzy
msgid "Input 3D raster map for cross section"
-msgstr "Mapa ráster 3D de entrada para la sección cruzada."
+msgstr "Mapa ráster 3D de entrada para la sección cruzada"
#: ../raster3d/r3.cross.rast/main.c:97
msgid "2D elevation map used to create the cross section map"
@@ -22858,53 +20353,37 @@
msgstr "perfil"
#: ../raster3d/r3.cross.rast/main.c:233
-#, fuzzy
-msgid ""
-"Creates cross section 2D raster map from 3D raster map based on 2D elevation "
-"map"
-msgstr ""
-"Crea un mapa ráster 2D de sección cruzada a partir de un mapa ráster 3D "
-"basado en mapa 2D de elevación"
+msgid "Creates cross section 2D raster map from 3D raster map based on 2D elevation map"
+msgstr "Crea mapa ráster 2D de sección cruzada a partir de un mapa ráster 3D basado en mapa 2D de elevación"
#: ../raster3d/r3.cross.rast/main.c:259
-#, fuzzy
-msgid ""
-"The 2D and 3D region settings are different. Using the 3D raster map "
-"settings to adjust the 2D region."
-msgstr ""
-"Las configuraciones de la región 2D y 3D son diferentes. Usaré las "
-"configuraciones G3D para ajustar la región 2D."
+msgid "The 2D and 3D region settings are different. Using the 3D raster map settings to adjust the 2D region."
+msgstr "Las configuraciones de la región 2D y 3D son diferentes. Usando las configuraciones 3D para ajustar la región 2D."
#: ../raster3d/r3.cross.rast/main.c:302
msgid "Output map already exists. Will be overwritten!"
msgstr "El mapa de salida ya existe. ¡Se sobrescribirá!"
#: ../raster3d/r3.cross.rast/main.c:338
-#, fuzzy
msgid "Wrong 3D raster datatype! Cannot create raster map"
-msgstr "¡Tipo de datos RASTER3D incorrecto! No se puede crear el mapa ráster."
+msgstr "¡Tipo de datos ráster 3D incorrecto! No se puede crear el mapa ráster."
#: ../raster3d/r3.in.v5d/main.c:66
-#, fuzzy
msgid "Name of V5D raster file to be imported"
+msgstr "Nombre de archivo ráster V5D a importar"
#: ../raster3d/r3.in.v5d/main.c:182
-#, fuzzy
msgid "Import 3-dimensional Vis5D files."
-msgstr "Exportar un mapa ráster 3D GRASS a archivo tridimensional Vis5D."
+msgstr "Importa archivos tridimensonales Vis5D."
#: ../raster3d/r3.in.v5d/main.c:201 ../raster3d/r3.in.ascii/main.c:387
#: ../raster3d/r3.in.bin/main.c:463
-#, fuzzy
msgid "Unable to open 3D raster map"
+msgstr "No ha sido posible abrir mapa ráster 3D"
#: ../raster3d/r3.in.ascii/main.c:94
msgid "String representing NULL value data cell (use 'none' if no such value)"
-msgstr ""
-"Cadena que representa celdas con valor nulo (usar 'ninguno' si no hay tal "
-"valor)"
+msgstr "Cadena que representa celdas con valor nulo (usar 'ninguno' si no hay tal valor)"
#: ../raster3d/r3.in.ascii/main.c:130 ../raster/r.in.ascii/main.c:279
msgid "Unable to write to file"
@@ -22915,9 +20394,9 @@
msgstr "No se puede leer la entrada desde stdin"
#: ../raster3d/r3.in.ascii/main.c:221
-#, fuzzy, c-format
+#, c-format
msgid "Unsupported GRASS version %s"
-msgstr "Tipo de columna de <%s> no soportado"
+msgstr "Versión GRASS %s no soportada"
#: ../raster3d/r3.in.ascii/main.c:265
#, c-format
@@ -22935,28 +20414,20 @@
#: ../raster3d/r3.in.ascii/main.c:322
#, c-format
-msgid ""
-"Data exists in input file after fully importing expected data. [%.4f ...]"
-msgstr ""
-"Los datos existen en el fichero de entrada después de importar completamente "
-"los datos esperados. [%.4f ...]"
+msgid "Data exists in input file after fully importing expected data. [%.4f ...]"
+msgstr "Los datos existen en el fichero de entrada después de importar completamente los datos esperados. [%.4f ...]"
#: ../raster3d/r3.in.ascii/main.c:360
-#, fuzzy
msgid "Converts a 3D ASCII raster text file into a (binary) 3D raster map."
-msgstr ""
-"Convertir un archivo de texto ráster ASCII 3D en una capa de mapa ráster 3D "
-"(binaria)"
+msgstr "Convierte un archivo de texto de ráster ASCII 3D en un mapa ráster 3D (binario)"
#: ../raster3d/r3.in.ascii/main.c:403
-#, fuzzy
msgid "Unable to close ASCII file"
-msgstr "No se puede abrir el archivo ASCII <%s>"
+msgstr "No ha sido posible cerrar archivo ASCII"
#: ../raster3d/r3.null/main.c:55
-#, fuzzy
msgid "3D raster map for which to modify null values"
-msgstr "mapa ráster 3D para el que modificar los valores nulos"
+msgstr "Mapa ráster 3D al cual se modificarán valores nulos"
#: ../raster3d/r3.null/main.c:63 ../raster/r.null/main.c:73
msgid "List of cell values to be set to NULL"
@@ -22983,14 +20454,12 @@
msgstr ""
#: ../raster3d/r3.null/main.c:171
-#, fuzzy
msgid "modifyNull: Unable to close tmp file"
-msgstr "modifyNull: error al cerrar archivo tmp"
+msgstr "modifyNull: no ha sido posible cerrar archivo tmp"
#: ../raster3d/r3.null/main.c:187 ../raster/r.null/main.c:61
-#, fuzzy
msgid "null data"
-msgstr "vectorial, metadatos"
+msgstr "dato nulo"
#: ../raster3d/r3.null/main.c:190
msgid "Explicitly create the 3D NULL-value bitmap file."
@@ -22998,11 +20467,8 @@
#: ../raster3d/r3.in.lidar/main.c:133
#, fuzzy
-msgid ""
-"Creates a 3D raster map from LAS LiDAR points using univariate statistics."
-msgstr ""
-"Crear un mapa ráster a partir de un ensamblaje de muchas coordenadas usando "
-"estadísticas univariantes."
+msgid "Creates a 3D raster map from LAS LiDAR points using univariate statistics."
+msgstr "Crear un mapa ráster a partir de un ensamblaje de muchas coordenadas usando estadísticas univariantes."
#: ../raster3d/r3.in.lidar/main.c:139
msgid "LiDAR input file in LAS format (*.las or *.laz)"
@@ -23071,12 +20537,8 @@
msgstr "No se pueden crear archivos temporales"
#: ../raster3d/r3.support/main.c:52
-#, fuzzy
-msgid ""
-"Allows creation and/or modification of 3D raster map layer support files."
-msgstr ""
-"Permite la creación y/o modificación de archivos de soporte de capas de "
-"mapas ráster."
+msgid "Allows creation and/or modification of 3D raster map layer support files."
+msgstr "Permite la creación y/o modificación de archivos de soporte de capas de mapas ráster."
#: ../raster3d/r3.support/main.c:62
msgid "Text to use for map title"
@@ -23087,13 +20549,12 @@
msgstr "Texto a unir a la siguiente línea del archivo de metadatos del mapa"
#: ../raster3d/r3.support/main.c:76
-#, fuzzy
msgid "The map data unit"
-msgstr "Texto a usar para unidades de datos del mapa"
+msgstr "El dato de unidad de mapa"
#: ../raster3d/r3.support/main.c:82
msgid "The vertical unit of the map"
-msgstr ""
+msgstr "La unidad vertical del mapa"
#: ../raster3d/r3.support/main.c:89 ../raster/r.support/main.c:93
msgid "Text to use for data source, line 1"
@@ -23114,22 +20575,21 @@
#: ../raster3d/r3.support/main.c:116 ../raster/r.support/main.c:120
msgid "Text file from which to load history"
-msgstr ""
+msgstr "Texto desde el cual cargar historia"
#: ../raster3d/r3.support/main.c:121 ../raster/r.support/main.c:125
msgid "Text file in which to save history"
-msgstr ""
+msgstr "Testo al cual guardar historia"
#: ../raster3d/r3.support/main.c:125
-#, fuzzy
msgid "Update range"
-msgstr "Rango de datos de salida"
+msgstr "Actualizar rango"
#: ../raster3d/r3.support/main.c:248 ../raster/r.support/main.c:245
#: ../raster/r.statistics/main.c:110 ../display/d.title/main.c:110
-#, fuzzy, c-format
+#, c-format
msgid "Unable to read category file of raster map <%s>"
-msgstr "No se puede leer el archivo de categorías del mapa ráster <%s@%s>"
+msgstr "No ha sido posible leer archivo de categorías de mapa ráster <%s>"
#: ../raster3d/r3.support/main.c:252 ../raster/r.support/main.c:249
#, c-format
@@ -23137,21 +20597,18 @@
msgstr "Tabla de categorías de [%s] establecida a %s"
#: ../raster3d/r3.support/check.c:20
-#, fuzzy, c-format
+#, c-format
msgid "Updating statistics for <%s>"
-msgstr ""
-"\n"
-" Actualizando estadísticas de [%s]"
+msgstr "Actualizando estaísticas para <%s>"
#: ../raster3d/r3.support/check.c:36
-#, fuzzy, c-format
+#, c-format
msgid "Updating the number of categories for <%s>"
-msgstr "Actualizando el número de categorías para [%s]..."
+msgstr "Actualizando el número de categorías para <%s>..."
#: ../raster3d/r3.out.ascii/main.c:82
-#, fuzzy
msgid "3D raster map to be converted to ASCII"
-msgstr "Mapa raster 3d a convertir a ASCII"
+msgstr "Mapa raster 3A a convertir a ASCII"
#: ../raster3d/r3.out.ascii/main.c:86
msgid "Name for ASCII output file"
@@ -23167,28 +20624,24 @@
#: ../raster3d/r3.out.ascii/main.c:114
msgid "Print grass6 compatible format. Flags -d and -r are ignored."
-msgstr ""
-"Mostrar formato compatible con grass6. Las opciones -d y -r son ignoradas."
+msgstr "Mostrar formato compatible con grass6. Las opciones -d y -r son ignoradas."
#: ../raster3d/r3.out.ascii/main.c:308
-#, fuzzy
msgid "Converts a 3D raster map layer into a ASCII text file."
-msgstr "Convierte una capa de mapa ráster 3D en un archivo de texto ASCII"
+msgstr "Convierte una capa de mapa ráster 3D en un archivo de texto ASCII."
#: ../raster3d/r3.out.ascii/main.c:371
-#, fuzzy
msgid "Unable to close new ASCII file"
+msgstr "No ha sido posible cerrar nuevo archivo ASCII"
#: ../raster3d/r3.in.bin/main.c:73
-#, fuzzy
msgid "Error reading binary data"
-msgstr "Error leyendo datos"
+msgstr "Error al leer datos binarios"
#: ../raster3d/r3.in.bin/main.c:154
-#, fuzzy, c-format
+#, c-format
msgid "Loading %s data with %i bytes ... (%dx%dx%d)"
-msgstr "Cargando datos... (%dx%dx%d)"
+msgstr "Cargando %s datoscon %i bytes ... (%dx%dx%d)"
#: ../raster3d/r3.in.bin/main.c:202 ../raster3d/r3.neighbors/main.c:311
#, fuzzy
@@ -23196,14 +20649,12 @@
msgstr "Error al cerrar archivo G3D"
#: ../raster3d/r3.in.bin/main.c:256
-#, fuzzy
msgid "Imports a binary raster file into a GRASS 3D raster map."
+msgstr "Importar un archivo ráster binario a un mapa ráster de GRASS."
#: ../raster3d/r3.in.bin/main.c:259
-#, fuzzy
msgid "Name of binary 3D raster file to be imported"
+msgstr "Nombre de archivo ráster 3D binario a importar"
#: ../raster3d/r3.in.bin/main.c:275
msgid "Byte order in binary file"
@@ -23244,14 +20695,12 @@
msgstr "Límite Oeste de la región geográfica (borde exterior)"
#: ../raster3d/r3.in.bin/main.c:315
-#, fuzzy
msgid "Bottom limit of geographic region (outer edge)"
-msgstr "Límite Norte de la región geográfica (borde exterior)"
+msgstr "Límite inferior de región geográfica (borde exterior)"
#: ../raster3d/r3.in.bin/main.c:322
-#, fuzzy
msgid "Top limit of geographic region (outer edge)"
+msgstr "Límite superior de región geográfica (borde exterior)"
#: ../raster3d/r3.in.bin/main.c:329 ../raster/r.in.bin/main.c:369
msgid "Number of rows"
@@ -23262,18 +20711,16 @@
msgstr "Número de columnas"
#: ../raster3d/r3.in.bin/main.c:343
-#, fuzzy
msgid "Number of depths"
-msgstr "Número de líneas"
+msgstr "Número de profundidades"
#: ../raster3d/r3.in.bin/main.c:350 ../raster/r.in.bin/main.c:383
msgid "Set Value to NULL"
msgstr "Establecer valor a NULO"
#: ../raster3d/r3.in.bin/main.c:365
-#, fuzzy
msgid "Binary data is of type integer"
-msgstr "La columna clave debe ser entero"
+msgstr "Datos binarios son de tipo entero"
#: ../raster3d/r3.in.bin/main.c:369 ../raster/r.in.bin/main.c:274
msgid "Signed data (two's complement)"
@@ -23282,11 +20729,11 @@
#: ../raster3d/r3.in.bin/main.c:399
#, c-format
msgid "bytes=%d; must be 4 or 8 in case of floating point input"
-msgstr ""
+msgstr "bytes=%d; debería ser 4 u 8 en caso de entrada de punto flotante"
#: ../raster3d/r3.in.bin/main.c:409
msgid "Integer input doesn't support size=8 in this build"
-msgstr ""
+msgstr "entrada de entero no soporta size=8 en esta construcción"
#: ../raster3d/r3.in.bin/main.c:413
msgid "bytes= must be 1, 2, 4 or 8"
@@ -23322,55 +20769,50 @@
#: ../raster3d/r3.in.bin/main.c:446
#, c-format
msgid "File Size %lld ... Total Bytes %lld"
-msgstr ""
+msgstr "Tamaño de archivo %lld ... Total de bytes %lld"
#: ../raster3d/r3.in.bin/main.c:448 ../raster/r.in.bin/main.c:577
msgid "Bytes do not match file size"
msgstr "Los bytes no se corresponden con el tamaño del archivo"
#: ../raster3d/r3.out.v5d/main.c:73
-#, fuzzy
msgid "3D raster map to be converted to Vis5D (V5D) file"
-msgstr "Mapa ráster 3D a convertir en archivo Vis5 (V5D)"
+msgstr "Mapa ráster 3D a convertir a archivo Vis5D (V5D)"
#: ../raster3d/r3.out.v5d/main.c:77
-#, fuzzy
msgid "Name for V5D output file"
-msgstr "Nombre del archivo V5D de salida"
+msgstr "Nombre para archivo V5D de salida"
#: ../raster3d/r3.out.v5d/main.c:147
-#, fuzzy, c-format
+#, c-format
msgid "Vis5D allows %d columns, %d columns found"
-msgstr "Viz5D permite %d columnas. Tiene %d columnas"
+msgstr "Viz5D permite %d columnas. Se encontraron %d columnas"
#: ../raster3d/r3.out.v5d/main.c:150
-#, fuzzy, c-format
+#, c-format
msgid "Vis5D allows %d rows, %d rows found"
-msgstr "Viz5D permite %d filas. Tiene %d filas"
+msgstr "Viz5D permite %d filas. Se encontraron %d filas"
#: ../raster3d/r3.out.v5d/main.c:257
-#, fuzzy, c-format
+#, c-format
msgid "Unable to create V5D file <%s>"
+msgstr "No ha sido posible crear archivo V5D <%s>"
#: ../raster3d/r3.out.v5d/main.c:262
-#, fuzzy
msgid "Failed writing V5D file"
-msgstr "Fallo al copiar archivo"
+msgstr "Fallo al copiar archivo V5D"
#: ../raster3d/r3.out.v5d/main.c:288
-#, fuzzy
msgid "Exports GRASS 3D raster map to 3-dimensional Vis5D file."
+msgstr "Exportar mapa ráster 3D GRASS a archivo tridimensional Vis5D."
#: ../raster3d/r3.out.v5d/main.c:295
msgid "Use map coordinates instead of xyz coordinates"
msgstr "Usar coordenadas del mapa en vez de coordenadas XYZ"
#: ../raster3d/r3.mask/main.c:75
-#, fuzzy
msgid "Unable to open 3D raster mask file"
+msgstr "No ha sido posible abrir archivo ráster 3D de máscara"
#: ../raster3d/r3.mask/main.c:104
msgid "makeMask: error flushing tiles in cube"
@@ -23381,9 +20823,8 @@
msgstr ""
#: ../raster3d/r3.mask/main.c:117
-#, fuzzy
msgid "Unable to close 3D raster mask file"
-msgstr "No se puede cerrar el mapa ráster"
+msgstr "No ha sido posible cerrar archivo ráster 3D de máscara"
#: ../raster3d/r3.mask/main.c:119
#, c-format
@@ -23395,7 +20836,6 @@
msgstr "Establece la máscara ráster 3D de trabajo actual."
#: ../raster3d/r3.mask/main.c:145
-#, fuzzy
msgid "3D raster map with reference values"
msgstr "Mapa ráster 3D con valores de referencia"
@@ -23408,9 +20848,8 @@
msgstr "No se puede crear archivo de máscara: RASTER3D_MASK ya existe"
#: ../raster3d/r3.out.vtk/main.c:117
-#, fuzzy
msgid "Specify top and bottom map"
-msgstr "Tienes que especificar el mapa superior e inferior"
+msgstr "Especificar cima y fondo del mapa"
#: ../raster3d/r3.out.vtk/main.c:124
#, c-format
@@ -23423,33 +20862,26 @@
msgstr "Mapa de celdas inferior <%s> no encontrado"
#: ../raster3d/r3.out.vtk/main.c:152
-#, fuzzy, c-format
+#, c-format
msgid "3D raster map RGB map <%s> not found"
-msgstr "Mapa ráster 3D <%s> no encontrado"
+msgstr "Mapa ráster RGB 3D <%s> no encontrado"
#: ../raster3d/r3.out.vtk/main.c:155
-#, fuzzy
msgid "Please provide three RGB 3D raster maps"
-msgstr "Por favor, proporciona tres mapas RGB G3D"
+msgstr "Por favor provea tres mapas ráster RGB 3D"
#: ../raster3d/r3.out.vtk/main.c:165
-#, fuzzy, c-format
+#, c-format
msgid "3D vector map <%s> not found"
-msgstr "Mapa vectorial <%s> no encontrado"
+msgstr "Mapa vectorial 3D <%s> no encontrado"
#: ../raster3d/r3.out.vtk/main.c:168
-#, fuzzy
msgid "Please provide three 3D raster maps for the xyz-vector maps [x,y,z]"
-msgstr "Por favor, proporciona tres mapas vectoriales G3D [x,y,z]"
+msgstr "Por favor provea tres mapas ráster 3D para los mapas vectoriales xyz [x,y,z]"
#: ../raster3d/r3.out.vtk/main.c:175
-#, fuzzy
-msgid ""
-"No 3D raster data, RGB or xyz-vector maps are provided! Will only write the "
-"geometry."
-msgstr ""
-"¡No se ha proporcionado ningún mapa de datos RASTER3D, RGB o vectorial xyz! "
-"Sólo se escribirá la geometría."
+msgid "No 3D raster data, RGB or xyz-vector maps are provided! Will only write the geometry."
+msgstr "¡No se proveyeron datos ráster 3D, RGB o mapas vectoriales xyz! Se escribirá solamente la geometría."
#: ../raster3d/r3.out.vtk/main.c:209
msgid "No RGB Data will be created."
@@ -23460,9 +20892,8 @@
msgstr "No se creará ningún dato vectorial."
#: ../raster3d/r3.out.vtk/main.c:381
-#, fuzzy
msgid "Converts 3D raster maps into the VTK-ASCII format."
-msgstr "Convierte mapas ráster al formato VTK-ASCII"
+msgstr "Convierte mapas ráster 3D al formato VTK-ASCII."
#: ../raster3d/r3.out.vtk/main.c:392
msgid "failed to interpret dp as an integer"
@@ -23473,25 +20904,20 @@
msgstr "dp tiene que estar entre 0 y 20"
#: ../raster3d/r3.out.vtk/main.c:542
-#, fuzzy
msgid "Unable to close 3D raster map, the VTK file may be incomplete"
-msgstr ""
-"Error al cerrar el mapa ráster 3D. El archivo VTK puede estar incompleto."
+msgstr "No ha sido posible cerrar mapa ráster 3D, es posible que el archivo VTK esté incompleto"
#: ../raster3d/r3.out.vtk/main.c:557
-#, fuzzy
msgid "Unable to close VTK-ASCII file"
+msgstr "No ha sido posible cerrar archivo VTK-ASCII"
#: ../raster3d/r3.out.vtk/errorHandling.c:105
-#, fuzzy
msgid "Unable to close input raster maps"
-msgstr "no se puede cerrar el mapa ráster de entrada"
+msgstr "No ha sido posible cerrar mapas ráster de entrada"
#: ../raster3d/r3.out.vtk/parameters.c:30
-#, fuzzy
msgid "3D raster map(s) to be converted to VTK-ASCII data format"
-msgstr "Mapa(s) RASTER3D a convertir al formato de datos VTK-ASCII"
+msgstr "Mapa(s) ráster 3D a convertir a formato de datos VTK-ASCII"
#: ../raster3d/r3.out.vtk/parameters.c:34 ../raster/r.out.vtk/parameters.c:36
msgid "Name for VTK-ASCII output file"
@@ -23503,9 +20929,7 @@
#: ../raster3d/r3.out.vtk/parameters.c:47
msgid "Create VTK pointdata instead of VTK celldata (celldata is default)"
-msgstr ""
-"Crear puntos de datos VTK en vez de celdas de datos VTK (predeterminado: "
-"celdas de datos)"
+msgstr "Crear puntos de datos VTK en vez de celdas de datos VTK (predeterminado: celdas de datos)"
#: ../raster3d/r3.out.vtk/parameters.c:56
#, fuzzy
@@ -23518,49 +20942,32 @@
msgstr "Mapa ráster 2D de superficie inferior"
#: ../raster3d/r3.out.vtk/parameters.c:71
-#, fuzzy
-msgid ""
-"Create 3D elevation output with a top and a bottom surface, both raster maps "
-"are required."
-msgstr ""
-"Crear salida de elevación 3D con una superficie superior e inferior, se "
-"requieren ambos mapas ráster."
+msgid "Create 3D elevation output with a top and a bottom surface, both raster maps are required."
+msgstr "Crear salida de elevación 3D con una superficie superior e inferior, se requieren ambos mapas."
#: ../raster3d/r3.out.vtk/parameters.c:80
-#, fuzzy
-msgid ""
-"Three (R,G,B) 3D raster maps to create RGB values [redmap,greenmap,bluemap]"
-msgstr ""
-"Tres mapas ráster 3D (RGB) para crear valores RGB [mapa rojo,mapa verde,mapa "
-"azul]"
+msgid "Three (R,G,B) 3D raster maps to create RGB values [redmap,greenmap,bluemap]"
+msgstr "Tres mapas ráster 3D (R,G,B) para crear valores RGB [maparojo,mapaverde,mapaazul]"
#: ../raster3d/r3.out.vtk/parameters.c:88
-#, fuzzy
msgid "Three (x,y,z) 3D raster maps to create vector values [xmap,ymap,zmap]"
-msgstr ""
-"Tres mapas ráster 3D (X,Y,Z) para crear valores vectoriales [mapa X,mapa Y,"
-"mapa Z]"
+msgstr "Tres mapas ráster 3D (x,y,z) para crear valores vectoriales [xmap,ymap,zmap]"
#: ../raster3d/r3.out.vtk/parameters.c:112
-#, fuzzy
msgid "Use 3D raster mask (if exists) with input maps"
#: ../raster3d/r3.out.vtk/parameters.c:117
-#, fuzzy
msgid "Scale factor affects the origin"
-msgstr "El factor de escala afecta al origen"
+msgstr "El factor de escalamiento afecta al origen"
#: ../raster3d/r3.out.vtk/parameters.c:123 ../raster/r.out.vtk/parameters.c:128
-#, fuzzy
msgid "Correct the coordinates to match the VTK-OpenGL precision"
-msgstr "Corregir las coordenadas para ajustar a la precisión VTK-OpenGL"
+msgstr "Corregir las coordenadas para ajustar la precisión VTK-OpenGL"
#: ../raster3d/r3.out.vtk/parameters.c:129
-msgid ""
-"Do not convert the top-bottom resolution in case of lat long projection to "
-"meters"
-msgstr ""
+msgid "Do not convert the top-bottom resolution in case of lat long projection to meters"
+msgstr "No convertir resolución cima-fondo en caso de proyección lat long a metros"
#: ../raster3d/r3.out.vtk/writeVTKData.c:122
msgid "write_vtk_points: Writing point coordinates"
@@ -23572,19 +20979,13 @@
#: ../raster3d/r3.out.vtk/writeVTKData.c:335
#, c-format
-msgid ""
-"write_vtk_data: Writing Celldata %s with rows %i cols %i depths %i to vtk-"
-"ascii file"
-msgstr ""
-"write_vtk_data: escribiendo datos de las celdas %s con filas %i columnas %i "
-"profundidades %i a archivo vtk-ASCII"
+msgid "write_vtk_data: Writing Celldata %s with rows %i cols %i depths %i to vtk-ascii file"
+msgstr "write_vtk_data: escribiendo datos de las celdas %s con filas %i columnas %i profundidades %i a archivo vtk-ascii"
#: ../raster3d/r3.out.vtk/writeVTKData.c:441
#, fuzzy
msgid "Wrong 3D raster map values! Values should in between 0 and 255!"
-msgstr ""
-"¡Valores de mapa ráster 3D incorrectos! Los valores deben estar entre 0 y "
-"255\n"
+msgstr "¡Valores de mapa ráster 3D incorrectos! Los valores deben estar entre 0 y 255\n"
#: ../raster3d/r3.neighbors/main.c:94 ../raster/r.resamp.stats/main.c:298
#: ../raster/r.series/main.c:104 ../raster/r.neighbors/main.c:102
@@ -23602,15 +21003,12 @@
msgstr "Quantil a calcular por el método=quantil"
#: ../raster3d/r3.neighbors/main.c:137
-msgid ""
-"The size of the window in x, y and z direction, values must be odd integer "
-"numbers, eg: 3,3,3"
-msgstr ""
+msgid "The size of the window in x, y and z direction, values must be odd integer numbers, eg: 3,3,3"
+msgstr "El tamaño de la ventana en direcciones x, y, z, los valores deben ser interos impares, ej: 3,3,3"
#: ../raster3d/r3.neighbors/main.c:213 ../raster/r.neighbors/main.c:171
-#, fuzzy
msgid "neighbor"
-msgstr "Vecindad"
+msgstr "vecino"
#: ../raster3d/r3.neighbors/main.c:214 ../raster/r.neighbors/main.c:172
#, fuzzy
@@ -23618,19 +21016,12 @@
msgstr "ráster, estadísticas"
#: ../raster3d/r3.neighbors/main.c:218
-#, fuzzy
-msgid ""
-"Makes each voxel value a function of the values assigned to the voxels "
-"around it, and stores new voxel values in an output 3D raster map"
-msgstr ""
-"Hace cada valor de categoría de celda una función de los valores de "
-"categoría asignados a las celdas a su alrededor y guarda los nuevos valores "
-"de celda en una capa de mapa ráster de salida."
+msgid "Makes each voxel value a function of the values assigned to the voxels around it, and stores new voxel values in an output 3D raster map"
+msgstr "Hace de cada valor voxel una función de los valores asignados a los voxels de alrededor, y guarda el nuevo valor voxel en un mapa ráster 3D de salida"
#: ../raster3d/r3.neighbors/main.c:287
-#, fuzzy
msgid "Unable to allocate buffer"
-msgstr "No se pueden asignar los buffers de celdas."
+msgstr "No ha sido posible asignar buffer"
#: ../raster3d/r3.gradient/main.c:44
#, fuzzy
@@ -23639,12 +21030,8 @@
#: ../raster3d/r3.gradient/main.c:47
#, fuzzy
-msgid ""
-"Computes gradient of a 3D raster map and outputs gradient components as "
-"three 3D raster maps."
-msgstr ""
-"Combina mapas raster rojos, verdes y azules en una sola composición de mapa "
-"raster."
+msgid "Computes gradient of a 3D raster map and outputs gradient components as three 3D raster maps."
+msgstr "Combina mapas raster rojos, verdes y azules en una sola composición de mapa raster."
#: ../raster3d/r3.gradient/main.c:56
#, fuzzy
@@ -23669,74 +21056,59 @@
#: ../raster3d/r3.out.netcdf/main.c:81
#, fuzzy, c-format
msgid "Unable to close 3D raster map while catching error: %s"
+msgstr "No ha sido posible cerrar mapa ráster 3D mientras "
#: ../raster3d/r3.out.netcdf/main.c:97
-#, fuzzy
msgid "Name for netCDF output file"
-msgstr "Nombre para el archivo de salida"
+msgstr "Nombre para archivo de salida netCDF"
#: ../raster3d/r3.out.netcdf/main.c:106
-#, fuzzy
msgid "The value to be used for null values, default is the netCDF standard"
-msgstr "El valor para rellenar las celdas superiores, por omisión es nulo"
+msgstr "El valor que será usado para valores nulos, el predeterminado es el del estádar netCDF"
#: ../raster3d/r3.out.netcdf/main.c:111
-#, fuzzy
msgid "Export projection information as wkt and proj4 parameter"
-msgstr "Imprimir información de proyección en formato PROJ.4"
+msgstr "Exportar información de proyección como texto bien conocido (wtk) y parámeto proj4"
#: ../raster3d/r3.out.netcdf/main.c:588
msgid "netCDF"
-msgstr ""
+msgstr "netCDF"
#: ../raster3d/r3.out.netcdf/main.c:590
-#, fuzzy
msgid "Export a 3D raster map as netCDF file."
+msgstr "Expotrar un mapa ráster 3D como archivo netCDF."
#: ../raster3d/r3.retile/main.c:49
-#, fuzzy
msgid "Unable to close the 3D raster map"
-msgstr "No se puede cerrar el mapa ráster 3D"
+msgstr "No ha sido posible cerrar mapa ráster 3D"
#: ../raster3d/r3.retile/main.c:71
-#, fuzzy
msgid "Name of the retiled 3D raster map"
+msgstr ""
#: ../raster3d/r3.retile/main.c:99
-msgid ""
-"Retiles an existing 3D raster map with user defined x, y and z tile size."
+msgid "Retiles an existing 3D raster map with user defined x, y and z tile size."
msgstr ""
#: ../raster3d/r3.retile/main.c:135
msgid "Rast3d_get_standard3d_params: tile dimension value invalid"
-msgstr ""
+msgstr "Rast3d_get_standard3d_params: valor de dimensión de mosaico no válido"
#: ../raster3d/r3.retile/main.c:148
-#, fuzzy
msgid "Error closing 3D raster map"
-msgstr "Error cerrando mapa raster 3d"
+msgstr "Error al cerrar mapa ráster 3D"
#: ../raster3d/r3.mkdspf/main.c:83
-#, fuzzy
-msgid ""
-"Creates a display file from an existing 3D raster map according to specified "
-"threshold levels."
-msgstr ""
-"Crea un archivo de presentación a partir de un archivo grid3 existente de "
-"acuerdo con los niveles umbral especificados."
+msgid "Creates a display file from an existing 3D raster map according to specified threshold levels."
+msgstr "Crea un archivo de visualización a partir de un mapa ráster existente de acuerdo con los niveles umbral especificados."
#: ../raster3d/r3.mkdspf/main.c:91
-#, fuzzy
msgid "Name of an existing 3D raster map"
msgstr "Nombre de un mapa ráster 3D existente"
#: ../raster3d/r3.mkdspf/main.c:96
-#, fuzzy
msgid "Name for output display file"
-msgstr "Nombre del archivo de presentación de salida"
+msgstr "Nombre del archivo de visualización de salida"
#: ../raster3d/r3.mkdspf/main.c:103
msgid "List of thresholds for isosurfaces"
@@ -23777,9 +21149,9 @@
msgstr "No se puede encontrar archivo grid3 para [%s]"
#: ../raster3d/r3.mkdspf/main.c:200
-#, fuzzy, c-format
+#, c-format
msgid "Unable to open display file <%s>"
-msgstr "No se puede abrir el archivo <%s>"
+msgstr "No ha sido posible abrir archivo de visualización <%s>"
#: ../raster3d/r3.mkdspf/main.c:221
#, c-format
@@ -23790,9 +21162,8 @@
#: ../general/g.dirseps/main.c:36 ../general/g.message/main.c:35
#: ../general/g.findetc/main.c:30 ../general/g.gisenv/main.c:46
#: ../general/g.tempfile/main.c:40
-#, fuzzy
msgid "scripts"
-msgstr "PostScript"
+msgstr "scripts"
#: ../general/g.filename/main.c:42
msgid "Prints GRASS data base file names."
@@ -23811,38 +21182,36 @@
msgstr "Nombre de un directorio de mapas (por omisión: actual)"
#: ../general/g.parser/rules.c:14
-#, fuzzy, c-format
+#, c-format
msgid "Unknown flag \"-%c\" in rule\n"
-msgstr "Columna <%s> desconocida en la tabla <%s>"
+msgstr "Bandera desconocida \"-%c\" en regla\n"
#: ../general/g.parser/rules.c:26
-#, fuzzy, c-format
+#, c-format
msgid "Unknown option \"%s\" in rule\n"
-msgstr "Opción '%s' desconocida"
+msgstr "Opción desconocida \"%s\" en regla\n"
#: ../general/g.parser/rules.c:94
-#, fuzzy, c-format
+#, c-format
msgid "Unknown rule type \"%s\" at line %d\n"
-msgstr "Tipo desconocido: %d"
+msgstr "Tipo desconocido de regla \"%s\" en línea %d\n"
#: ../general/g.parser/main.c:74
msgid "Usage"
msgstr "Uso"
#: ../general/g.parser/main.c:84
-#, fuzzy
msgid "Unable to open script file"
-msgstr "No se puede abrir el archivo de salida"
+msgstr "No ha sido posible abrir archivo de script"
#: ../general/g.parser/main.c:99
#, c-format
msgid "Line too long or missing newline at line %d\n"
-msgstr ""
+msgstr "Línea demasiado larga o falta nueva línea en línea %d\n"
#: ../general/g.parser/main.c:139
-#, fuzzy
msgid "Error closing script file"
-msgstr "Error al cerrar archivo ASCII"
+msgstr "Error al cerrar archivo de script"
#: ../general/g.parser/parse.c:22
#, c-format
@@ -23850,50 +21219,45 @@
msgstr "Valor booleano desconocido \"%s\" en la linea %d\n"
#: ../general/g.parser/parse.c:70
-#, fuzzy, c-format
+#, c-format
msgid "Unknown command \"%s\" at line %d\n"
+msgstr "Comando desconocido \"%s\" en linea %d\n"
#: ../general/g.parser/parse.c:103
-#, c-format
+#, fuzzy
msgid "Unknown module parameter \"%s\" at line %d\n"
msgstr "En la línea %d hay un parámetro \"%s\" desconocido para el módulo\n"
#: ../general/g.parser/parse.c:140
-#, c-format
+#, fuzzy
msgid "Unknown flag parameter \"%s\" at line %d\n"
-msgstr "En la línea %d hay un parámetro \"%s\" desconocido para la opción\n"
+msgstr "En la línea %d hay un flag \"%s\" desconocido para la opción\n"
#: ../general/g.parser/parse.c:155
-#, fuzzy, c-format
+#, c-format
msgid "Unknown type \"%s\" at line %d\n"
+msgstr "Tipo desconocido \"%s\" en linea %d\n"
#: ../general/g.parser/parse.c:233
-#, c-format
+#, fuzzy
msgid "Unknown option parameter \"%s\" at line %d\n"
msgstr "En la línea %d hay una opción \"%s\" desconocida para el parámetro\n"
#: ../general/g.parser/revoke.c:63
-#, fuzzy
msgid "G_spawn() failed"
-msgstr "Falló %s"
+msgstr "G_spawn() falló"
#: ../general/g.parser/revoke.c:71
-#, fuzzy
msgid "execl() failed"
-msgstr "Falló %s"
+msgstr "execl() falló"
#: ../general/g.findfile/element.c:7
-#, fuzzy
msgid "List of available elements:"
-msgstr "Listar todos los directorios de mapas disponibles"
+msgstr "Lista de elementos disponibles:"
#: ../general/g.findfile/main.c:42
msgid "Searches for GRASS data base files and sets variables for the shell."
-msgstr ""
-"Busca archivos de bases de datos de GRASS y establece variables para la "
-"consola de comandos de UNIX."
+msgstr "Busca archivos de bases de datos de GRASS y establece variables para la consola de comandos de UNIX."
#: ../general/g.findfile/main.c:59
msgid "Name of an existing map"
@@ -23908,64 +21272,50 @@
msgstr "'.' para directorio de mapas actual"
#: ../general/g.findfile/main.c:70
-#, fuzzy
msgid "Do not add quotes"
msgstr "No añadir comillas"
#: ../general/g.findfile/main.c:74
-#, fuzzy
msgid "List available elements and exit"
-msgstr "Listar las capas disponibles y salir"
+msgstr "Enlistar elementos disponibles y salir"
#: ../general/g.findfile/main.c:97
#, c-format
-msgid ""
-"Parameter 'file' contains reference to <%s> mapset, but mapset parameter <"
-"%s> does not correspond"
-msgstr ""
-"El parámetro 'archivo' contiene referencias al directorio de mapas <%s>, "
-"pero el parámetro <%s> del directorio de mapas no corresponde"
+msgid "Parameter 'file' contains reference to <%s> mapset, but mapset parameter <%s> does not correspond"
+msgstr "El parámetro 'archivo' contiene referencias al directorio de mapas <%s>, pero el parámetro <%s> del directorio de mapas no corresponde"
#: ../general/g.dirseps/main.c:38
msgid "Internal GRASS utility for converting directory separator characters."
-msgstr ""
-"Utilidad interna de GRASS para convertir caracteres de separación de "
-"directorios."
+msgstr "Utilidad interna de GRASS para convertir caracteres de separación de directorios."
#: ../general/g.version/main.c:66 ../general/g.message/main.c:34
#: ../general/g.tempfile/main.c:39
-#, fuzzy
msgid "support"
-msgstr "Importar"
+msgstr "soportar"
#: ../general/g.version/main.c:67
-#, fuzzy
msgid "citing"
-msgstr "Configuraciones"
+msgstr "forma de citar"
#: ../general/g.version/main.c:68
-#, fuzzy
msgid "copyright"
-msgstr "copiando"
+msgstr "derechos de autor"
#: ../general/g.version/main.c:69
-#, fuzzy
msgid "version"
-msgstr "Por posición"
+msgstr "versión"
#: ../general/g.version/main.c:70
msgid "license"
-msgstr ""
+msgstr "licencia"
#: ../general/g.version/main.c:71
-#, fuzzy
msgid "Displays GRASS GIS version info."
-msgstr "Muestra información de versión y copyright."
+msgstr "Muestra información de versión de GRASS GIS."
#: ../general/g.version/main.c:72
-#, fuzzy
msgid "Optionally also prints build or copyright information."
+msgstr "Opcionalmente "
#: ../general/g.version/main.c:76
msgid "Print also the copyright message"
@@ -24005,8 +21355,7 @@
#: ../general/g.version/main.c:103
#, fuzzy
msgid "Print info in shell script style (including SVN revision number)"
-msgstr ""
+msgstr "Imprimir información en el estilo de script de la consola de comandos de UNIX"
#: ../general/g.version/main.c:104
msgid "Shell"
@@ -24014,15 +21363,11 @@
#: ../general/g.version/main.c:172
#, c-format
-msgid ""
-"Cannot determine GRASS libgis version and date number. The GRASS build might "
-"be broken. Report this to developers or packagers.\n"
-msgstr ""
+msgid "Cannot determine GRASS libgis version and date number. The GRASS build might be broken. Report this to developers or packagers.\n"
+msgstr "No se puede determinar versión GRASS libgis y número de fecha. La construcción GRASS puede estar rota. Reporte esto a los desarrolladores o a quienes se encargan de los paquetes.\n"
#: ../general/g.version/main.c:179
-msgid ""
-"GRASS GIS libgis version and date number don't have the expected format. "
-"Trying to print the original strings..."
+msgid "GRASS GIS libgis version and date number don't have the expected format. Trying to print the original strings..."
msgstr ""
#: ../general/g.version/main.c:181
@@ -24064,33 +21409,32 @@
msgstr "No se puede asignar el buffer de la fila de entrada"
#: ../general/g.ppmtopng/main.c:77
-#, fuzzy
msgid "Error writing PNG file"
-msgstr "Error al escribir el archivo PGM"
+msgstr "Error al escribir archivo PNG"
#: ../general/g.ppmtopng/main.c:81
-#, fuzzy, c-format
+#, c-format
msgid "Unable to open output file %s"
-msgstr "No se puede abrir el archivo de salida <%s>"
+msgstr "No ha sido posible abrir archivo de salida %s"
#: ../general/g.ppmtopng/main.c:119
msgid "Converts between PPM/PGM and PNG image formats."
msgstr "Convierte entre formatos de imagen PPM/PGM y PNG."
#: ../general/g.cairocomp/main.c:49
-#, fuzzy, c-format
+#, c-format
msgid "Unable to read input file <%s>"
-msgstr "No se puede leer la entrada desde <%s>"
+msgstr "No ha sido posible leer archivo de entrada <%s>"
#: ../general/g.cairocomp/main.c:52
-#, fuzzy, c-format
+#, c-format
msgid "Unable to parse input file <%s>"
-msgstr "No se puede abrir el archivo de entrada <%s>"
+msgstr "No ha sido posible parsear archivo de salida <%s>"
#: ../general/g.cairocomp/main.c:71
-#, fuzzy, c-format
+#, c-format
msgid "Unable to write output file <%s>"
+msgstr "No ha sido posible escribir archivo de salida <%s>"
#: ../general/g.cairocomp/main.c:113
#, fuzzy
@@ -24098,9 +21442,8 @@
msgstr "No se puede mostrar"
#: ../general/g.cairocomp/main.c:129
-#, fuzzy
msgid "Failed to initialize output surface"
-msgstr "Nombre de la superficie aleatoria de salida"
+msgstr "Falla al inicializar superficie de salida"
#: ../general/g.cairocomp/main.c:150 ../general/g.pnmcomp/main.c:38
#, c-format
@@ -24118,19 +21461,16 @@
msgstr "Superpone dos mapas vectoriales."
#: ../general/g.cairocomp/main.c:203 ../general/g.pnmcomp/main.c:290
-#, fuzzy
msgid "Name of input file(s)"
-msgstr "Nombres de los archivos de entrada"
+msgstr "Nombre(s) de archivo(s) de entrada"
#: ../general/g.cairocomp/main.c:212
-#, fuzzy
msgid "Output Visual XID"
-msgstr "TIFF teselado de salida"
+msgstr "Salida Visual XID"
#: ../general/g.cairocomp/main.c:218
-#, fuzzy
msgid "Output screen"
-msgstr "Tipo de salida"
+msgstr "Pantalla de salida"
#: ../general/g.cairocomp/main.c:224 ../general/g.pnmcomp/main.c:302
msgid "Layer opacities"
@@ -24145,30 +21485,24 @@
msgstr "Altura de imagen"
#: ../general/g.cairocomp/main.c:240
-#, fuzzy
msgid "Background color (R:G:B:A)"
-msgstr "Color de fondo"
+msgstr "Color de fondo (R:G:B:A)"
#: ../general/g.cairocomp/main.c:245
-#, fuzzy
msgid "Do not composite; just delete input Pixmaps"
-msgstr "No componer; solo eliminar Pixmaps de entrada"
+msgstr "No componer; solamente eliminar Pixmaps de entrada"
#: ../general/g.cairocomp/main.c:277
msgid "input= and opacity= must have the same number of values"
msgstr "input= and opacity= deben tener el mismo número de valores"
#: ../general/g.message/main.c:37
-msgid ""
-"Prints a message, warning, progress info, or fatal error in the GRASS way."
-msgstr ""
-"Imprime un mensaje, advertencia, información de progresso, o error fatal al "
-"modo de GRASS."
+msgid "Prints a message, warning, progress info, or fatal error in the GRASS way."
+msgstr "Imprime un mensaje, advertencia, información de progresso, o error fatal al modo de GRASS."
#: ../general/g.message/main.c:39
msgid "This module should be used in scripts for messages served to user."
-msgstr ""
-"Este módulo debería usarse en scripts para los mensajes mostrados al usuario."
+msgstr "Este módulo debería usarse en scripts para los mensajes mostrados al usuario."
#: ../general/g.message/main.c:43 ../general/g.message/main.c:48
#: ../general/g.message/main.c:53 ../general/g.message/main.c:58
@@ -24198,9 +21532,8 @@
msgstr "Nivel"
#: ../general/g.message/main.c:64
-#, fuzzy
msgid "Print message in all modes except of quiet mode"
-msgstr "Imprimir mensaje en modo silencioso pero completo"
+msgstr "Mostrar mensaje en todos los moddos excepto en el modo \"silencioso\""
#: ../general/g.message/main.c:65
msgid "Message is printed on GRASS_VERBOSE>=1"
@@ -24236,14 +21569,11 @@
#: ../general/g.rename/main.c:49
msgid "Renames data base element files in the user's current mapset."
-msgstr ""
-"Renombra archivos de elementos de base de datos en el directorio de mapas "
-"actual del usuario."
+msgstr "Renombra archivos de elementos de base de datos en el directorio de mapas actual del usuario."
#: ../general/g.rename/main.c:55
-#, fuzzy
msgid "renamed"
-msgstr "nombre"
+msgstr "renombrado"
#: ../general/g.rename/main.c:76
#, c-format
@@ -24267,29 +21597,26 @@
#: ../general/g.rename/main.c:90
#, c-format
msgid "%s=%s,%s: files could be the same, no rename possible"
-msgstr ""
-"%s=%s,%s: los archivos podrían ser los mismos, no es posible cambiar el "
-"nombre"
+msgstr "%s=%s,%s: los archivos podrían ser los mismos, no es posible cambiar el nombre"
#: ../general/g.rename/main.c:116
-#, fuzzy
msgid "Updating reclass maps"
-msgstr "Cambiando el nombre de los mapas reclasificados"
+msgstr "Actualizando mapas reclasificados"
#: ../general/g.rename/main.c:184
-#, fuzzy, c-format
+#, c-format
msgid "Unable to find reclass information for <%s> in base map <%s@%s>"
-msgstr "No se puede leer el archivo de color del mapa ráster <%s@%s>"
+msgstr "No ha sido posible encontrar información de reclasificación para <%s> en mapa base <%s@%s>"
#: ../general/g.rename/main.c:188
-#, fuzzy, c-format
+#, c-format
msgid "Updating base map <%s@%s>"
-msgstr "Escribiendo mapa ráster <%s>"
+msgstr "Actualizando mapa base <%s@%s>"
#: ../general/g.rename/main.c:194
-#, fuzzy, c-format
+#, c-format
msgid "Unable to update dependency file in <%s@%s>"
+msgstr "No ha sido posible actualizar archivo de dependencia en <%s@%s>"
#: ../general/g.mapsets/main.c:64 ../general/g.region/main.c:64
#: ../general/g.mapset/main.c:50 ../general/g.gisenv/main.c:44
@@ -24304,29 +21631,19 @@
#: ../general/g.mapsets/main.c:66
msgid "Modifies/prints the user's current mapset search path."
-msgstr ""
-"Modifica/muestra la actual ruta de búsqueda del directorio de mapas actual "
-"del usuario."
+msgstr "Modifica/muestra la actual ruta de búsqueda del directorio de mapas actual del usuario."
#: ../general/g.mapsets/main.c:67
-msgid ""
-"Affects the user's access to data existing under the other mapsets in the "
-"current location."
-msgstr ""
-"Afecta al acceso del usuario a datos existentes bajo otros directorios de "
-"mapas en la localización actual."
+msgid "Affects the user's access to data existing under the other mapsets in the current location."
+msgstr "Afecta al acceso del usuario a datos existentes bajo otros directorios de mapas en la localización actual."
#: ../general/g.mapsets/main.c:73
-#, fuzzy
msgid "Name(s) of existing mapset(s) to add/remove or set"
-msgstr ""
-"Nombre(s) de los directorio(s) de mapas existentes a eliminar de la lista de "
-"búsqueda"
+msgstr "Nombre(s) de los Directorio(s) de mapas existentes a añadir/eliminar o definir"
#: ../general/g.mapsets/main.c:85
-#, fuzzy
msgid "Field separator for printing (-l and -p flags)"
-msgstr "Separador de campos (modo de puntos)"
+msgstr "Separador de campos para mostrar (banderas -l y -p)"
#: ../general/g.mapsets/main.c:91
msgid "List all available mapsets in alphabetical order"
@@ -24337,14 +21654,13 @@
msgstr "Imprimir la ruta de búsqueda del directorio de mapas actual"
#: ../general/g.mapsets/main.c:103
-#, fuzzy
msgid "Launch mapset selection GUI dialog"
-msgstr "Mostrar diálogo de selección del directorio de mapas"
+msgstr "Lanzar cuadro de diálogo GUI de selección de Directorio de mapas"
#: ../general/g.mapsets/main.c:126
-#, fuzzy, c-format
+#, c-format
msgid "Unknown operation '%s'"
-msgstr "Operador desconocido"
+msgstr "Operación '%s' desconocida"
#: ../general/g.mapsets/main.c:136 ../general/g.mapsets/main.c:138
#: ../general/g.mapsets/main.c:148 ../display/d.mon/main.c:157
@@ -24364,14 +21680,14 @@
msgstr "Directorio de mapas <%s> no encontrado"
#: ../general/g.mapsets/main.c:181 ../general/g.mapsets/main.c:240
-#, fuzzy, c-format
+#, c-format
msgid "Current mapset (<%s>) must always included in the search path"
-msgstr "Imprimir la ruta de búsqueda del directorio de mapas actual"
+msgstr "Directorio de mapas actual (<%s>) debe ser siempre incluido en la ruta de búsqueda"
#: ../general/g.mapsets/main.c:203
-#, fuzzy, c-format
+#, c-format
msgid "Mapset <%s> already in the path"
-msgstr "Directorio de mapas <%s> añadido a la ruta de búsqueda"
+msgstr "Directorio de mapas <%s> ya está en la ruta de búsqueda"
#: ../general/g.mapsets/main.c:210
#, c-format
@@ -24384,14 +21700,12 @@
msgstr "Directorio de mapas <%s> eliminado de la ruta de búsqueda"
#: ../general/g.mapsets/main.c:255
-#, fuzzy
msgid "Search path not modified"
-msgstr "Buscar ruta"
+msgstr "Ruta de búsqueda no modificada"
#: ../general/g.mapsets/main.c:273
-#, fuzzy
msgid "Unable to open SEARCH_PATH for write"
-msgstr "No se puede abrir SEARCH_PATH para escritura"
+msgstr "No ha sido posible abrir SEARCH_PATH para escritura"
#: ../general/g.mapsets/list.c:10
msgid "Available mapsets:"
@@ -24402,19 +21716,12 @@
msgstr "Directorios de mapas a los que se puede acceder:"
#: ../general/g.copy/main.c:44
-#, fuzzy
-msgid ""
-"Copies available data files in the current mapset search path to the user's "
-"current mapset."
-msgstr ""
-"Copia archivos de datos disponibles en la ruta de búsqueda del directorio de "
-"datos y localización actuales del usuario a los directorios de elementos "
-"adecuados bajo el directorio de mapas actual de usuario."
+msgid "Copies available data files in the current mapset search path to the user's current mapset."
+msgstr "Copia archivos de datos disponibles en la ruta de búsqueda actual del Directorios de mapas actual a la ruta del Directorio de mapas del usuario actual."
#: ../general/g.copy/main.c:51
-#, fuzzy
msgid "copied"
-msgstr "Porcentaje completado: "
+msgstr "copiado"
#: ../general/g.copy/main.c:66
#, c-format
@@ -24451,25 +21758,20 @@
msgstr "crear localización"
#: ../general/g.proj/main.c:69
-#, fuzzy
-msgid ""
-"Prints or modifies GRASS projection information files (in various co-"
-"ordinate system descriptions)."
-msgstr "Imprimir también la información de la instalación de GRASS"
+msgid "Prints or modifies GRASS projection information files (in various co-ordinate system descriptions)."
+msgstr "Muestra o modifica archivos de información de proyección de GRASS (en varias descripciones de sistema de coordenadas)."
#: ../general/g.proj/main.c:72
msgid "Can also be used to create new GRASS locations."
msgstr "También puede ser utilizado para crear nuevas localizaciones GRASS."
#: ../general/g.proj/main.c:75
-#, fuzzy
msgid "Prints and manipulates GRASS projection information files."
+msgstr "Muestra y manipula archivos de información de proyección de GRASS."
#: ../general/g.proj/main.c:82
-#, fuzzy
msgid "Print projection information in conventional GRASS format"
-msgstr "Imprimir información de proyección (en formato convencional GRASS)"
+msgstr "Mostrar información de proyección en formato convencional de GRASS"
#: ../general/g.proj/main.c:88
msgid "Print projection information in shell script style"
@@ -24477,19 +21779,15 @@
#: ../general/g.proj/main.c:94
msgid "Verify datum information and print transformation parameters"
-msgstr ""
-"Verificar información del datum e imprimir parámetros de transformación"
+msgstr "Verificar información del datum e imprimir parámetros de transformación"
#: ../general/g.proj/main.c:100
msgid "Print projection information in PROJ.4 format"
#: ../general/g.proj/main.c:106
-msgid ""
-"Print 'flat' output with no linebreaks (applies to WKT and PROJ.4 output)"
-msgstr ""
-"Imprimir salida 'lisa' sin saltos de página (aplicable a salidas WKT y "
-"PROJ.4)"
+msgid "Print 'flat' output with no linebreaks (applies to WKT and PROJ.4 output)"
+msgstr "Imprimir salida 'lisa' sin saltos de página (aplicable a salidas WKT y PROJ.4)"
#: ../general/g.proj/main.c:116
msgid "Print projection information in WKT format"
@@ -24506,14 +21804,11 @@
#: ../general/g.proj/main.c:130
msgid "Name of georeferenced data file to read projection information from"
-msgstr ""
-"Nombre del archivo georreferenciado del cual leer la información de "
-"proyección"
+msgstr "Nombre del archivo georreferenciado del cual leer la información de proyección"
#: ../general/g.proj/main.c:139
msgid "Name of ASCII file containing a WKT projection description"
-msgstr ""
-"Nombre del archivo ASCII que contiene una descripción de proyección WKT"
+msgstr "Nombre del archivo ASCII que contiene una descripción de proyección WKT"
#: ../general/g.proj/main.c:149
msgid "PROJ.4 projection description"
@@ -24525,28 +21820,20 @@
msgstr "Datum"
#: ../general/g.proj/main.c:169
-#, fuzzy
msgid "Datum (overrides any datum specified in input co-ordinate system)"
-msgstr ""
-"Forzar a ignorar la información de transformación del datum en el sistema de "
-"coordenadas de entrada"
+msgstr "Datum (anula cualquier datum especificado en sistema de coordenadas de entrada)"
#: ../general/g.proj/main.c:171
msgid "Accepts standard GRASS datum codes, or \"list\" to list and exit"
-msgstr ""
-"Acepta códigos estándar de datum GRASS, o \"list\" para enlistar y salir"
+msgstr "Acepta códigos estándar de datum GRASS, o \"list\" para enlistar y salir"
#: ../general/g.proj/main.c:182
msgid "\"0\" for unspecified or \"-1\" to list and exit"
msgstr " \"0\" para sin especificar o \"-1\" para listar y salir"
#: ../general/g.proj/main.c:188
-msgid ""
-"Force override of datum transformation information in input co-ordinate "
-"system"
-msgstr ""
+msgid "Force override of datum transformation information in input co-ordinate system"
+msgstr "Forzar a ignorar la información de transformación del datum en el sistema de coordenadas de entrada"
#: ../general/g.proj/main.c:193 ../raster/r.null/main.c:74
#: ../raster/r.null/main.c:82
@@ -24573,22 +21860,17 @@
#: ../general/g.proj/main.c:283
#, c-format
msgid "Only one of -%c, -%c, -%c, -%c, -%c or -%c flags may be specified"
-msgstr ""
-"Sólo se puede especificar una de las opciones -%c, -%c, -%c, -%c, -%c o -%c"
+msgstr "Sólo se puede especificar una de las opciones -%c, -%c, -%c, -%c, -%c o -%c"
#: ../general/g.proj/main.c:310
#, c-format
msgid "No output format specified, define one of flags -%c, -%c, -%c, or -%c"
-msgstr ""
-"No se especificó el formato de salida, defina una de las opciones -%c, -%c, -"
-"%c, o -%c"
+msgstr "No se especificó el formato de salida, defina una de las opciones -%c, -%c, -%c, o -%c"
#: ../general/g.proj/main.c:314
#, c-format
msgid "No output format specified, define one of flags -%c, -%c, or -%c"
-msgstr ""
-"No se especificó el formato de salida, defina una de las opciones -%c, -%c, "
-"o -%c"
+msgstr "No se especificó el formato de salida, defina una de las opciones -%c, -%c, o -%c"
#: ../general/g.proj/input.c:91
msgid "Error reading WKT projection description"
@@ -24626,12 +21908,8 @@
#: ../general/g.proj/input.c:259
#, c-format
-msgid ""
-"Read of file %s was successful, but it did not contain projection "
-"information. 'XY (unprojected)' will be used"
-msgstr ""
-"La lectura del archivo %s tuvo éxito , pero no contiene información de "
-"proyección. Se usará 'XY (sin proyectar)'"
+msgid "Read of file %s was successful, but it did not contain projection information. 'XY (unprojected)' will be used"
+msgstr "La lectura del archivo %s tuvo éxito , pero no contiene información de proyección. Se usará 'XY (sin proyectar)'"
#: ../general/g.proj/output.c:189
#, c-format
@@ -24663,33 +21941,22 @@
"`%s=%s`"
#: ../general/g.proj/create.c:40
-#, fuzzy, c-format
-msgid ""
-"You must select the PERMANENT mapset before updating the current location's "
-"projection (current mapset is <%s>)"
-msgstr ""
-"Debe seleccionar el directorio de mapas PERMANENT antes de actualizar la "
-"proyección de la localización actual. (El directorio de mapas actual es %s)"
+#, c-format
+msgid "You must select the PERMANENT mapset before updating the current location's projection (current mapset is <%s>)"
+msgstr "Debe seleccionar el Directorio de mapas PERMANENT antes de actualizar la proyección de la Localización actual (Directorio de mapas actual es <%s>)"
#: ../general/g.proj/create.c:66
-#, fuzzy
-msgid ""
-"Default region was updated to the new projection, but if you have multiple "
-"mapsets `g.region -d` should be run in each to update the region from the "
-"default"
-msgstr ""
-"N.B. La región por omisión se actualizó a la nueva proyección, pero si tiene "
-"múltiples directorios de mapas debería ejecutar g.mapset -d en cada uno para "
-"actualizar la región a partir de la predeterminada."
+msgid "Default region was updated to the new projection, but if you have multiple mapsets `g.region -d` should be run in each to update the region from the default"
+msgstr "La región predeterminada fue actualizada a la nueva proyección, pero si usted tiene múltiples Directorios de mapas debe correr 'g.region -d' en cada uno para actualizar la región a partir de la predeterminada"
#: ../general/g.proj/create.c:70
msgid "Projection information updated"
msgstr "Información de la proyección actualizada"
#: ../general/g.proj/create.c:91
-#, fuzzy, c-format
+#, c-format
msgid "Unable to create PROJ_EPSG file: %s"
-msgstr "No se puede crear el archivo <%s>"
+msgstr "No ha sido posible crear archivo PROJ_EPSG file: %s"
#: ../general/g.pnmcomp/main.c:54
msgid "Error reading PPM file"
@@ -24732,80 +21999,58 @@
#: ../general/g.pnmcomp/main.c:285
-#, fuzzy
msgid "Overlays multiple PPM image files."
-msgstr "Superpone dos mapas vectoriales."
+msgstr "Superpone múltiples archivos de imagen PPM."
#: ../general/g.pnmcomp/main.c:296
-#, fuzzy
msgid "Name of input mask file(s)"
+msgstr "Nombre de archivo(s) de máscara de entrada"
#: ../general/g.pnmcomp/main.c:309
-#, fuzzy
msgid "Name for output mask file"
-msgstr "Nombre del archivo de máscara de salida"
+msgstr "Nombre para archivo de máscara de salida"
#: ../general/g.mkfontcap/main.c:73
-msgid ""
-"Generates the font configuration file by scanning various directories for "
-"fonts."
-msgstr ""
+msgid "Generates the font configuration file by scanning various directories for fonts."
+msgstr "Genera el archivo de configuración de fuente revisando varios directorios para fuentes."
#: ../general/g.mkfontcap/main.c:79
msgid "Overwrite font configuration file if already existing"
-msgstr ""
+msgstr "Sobreescribir archivo de configuración de fuente si ya existe"
#: ../general/g.mkfontcap/main.c:84
-msgid ""
-"Write font configuration file to standard output instead of $GISBASE/etc"
-msgstr ""
+msgid "Write font configuration file to standard output instead of $GISBASE/etc"
+msgstr "Escribir archivo de configuración de fuente en salida estándar en vez de $GISBASE/etc"
#: ../general/g.mkfontcap/main.c:91
msgid "List of extra directories to scan"
msgstr "Lista directorios extras que serán explorados"
#: ../general/g.mkfontcap/main.c:93
-msgid ""
-"Comma-separated list of extra directories to scan for Freetype-compatible "
-"fonts as well as the defaults (see documentation)"
-msgstr ""
-"Lista separada por comas de directorios extras que serán explorados para "
-"fuentes Freetype-compatible así como para las predeterminadas (ver "
-"documentación)"
+msgid "Comma-separated list of extra directories to scan for Freetype-compatible fonts as well as the defaults (see documentation)"
+msgstr "Lista separada por comas de directorios extras que serán explorados para fuentes Freetype-compatible así como para las predeterminadas (ver documentación)"
#: ../general/g.mkfontcap/main.c:110
#, fuzzy, c-format
-msgid ""
-"Fontcap file %s already exists; use -%c flag if you wish to overwrite it"
+msgid "Fontcap file %s already exists; use -%c flag if you wish to overwrite it"
msgstr "El archivo '%s'ya existe y se sobrescribirá."
#: ../general/g.mkfontcap/main.c:122
-msgid ""
-"This GRASS installation was compiled without Freetype support, extradirs "
-"parameter ignored"
-msgstr ""
-"Esta instalación de GRASS fue compilada sin soporte de Freetype, parámetro "
-"extradirs ignorado"
+msgid "This GRASS installation was compiled without Freetype support, extradirs parameter ignored"
+msgstr "Esta instalación de GRASS fue compilada sin soporte de Freetype, parámetro extradirs ignorado"
#: ../general/g.mkfontcap/main.c:149
-#, fuzzy, c-format
+#, c-format
msgid "Cannot open %s for writing: %s"
-msgstr "Abriendo %s para escritura... "
+msgstr "No se puede abrir %s para escritura: %s"
#: ../general/g.mkfontcap/freetype_fonts.c:55
-#, fuzzy
msgid "Unable to initialise Freetype"
-msgstr "No se puede inicializar FreeType"
+msgstr "No ha sido posible inicializar Freetype"
#: ../general/g.remove/main.c:73
-#, fuzzy
-msgid ""
-"Removes data base element files from the user's current mapset using the "
-"search pattern."
-msgstr ""
-"Elimina archivos de elementos de bases de datos del directorio de mapas "
+msgid "Removes data base element files from the user's current mapset using the search pattern."
+msgstr "Elimina archivos de bases de datos de elementos del Directorio de mapas actual del usuario usando el patrón de búsqueda."
#: ../general/g.remove/main.c:83 ../general/g.remove/main.c:91
#: ../general/g.remove/main.c:133
@@ -24813,14 +22058,12 @@
msgstr "Básico"
#: ../general/g.remove/main.c:90
-#, fuzzy
msgid "Name of file(s) to remove"
-msgstr "Nombre de la columna atributo utilizada para la opción 'consulta'"
+msgstr "Nombre de archivo(s) a eliminar"
#: ../general/g.remove/main.c:99
-#, fuzzy
msgid "Name of file(s) to ignore (default: none)"
-msgstr "Lista de capas a importar"
+msgstr "Nombre de archivo(s) a ignorar (predeterminado: none)"
#: ../general/g.remove/main.c:100 ../general/g.remove/main.c:106
#: ../general/g.remove/main.c:112 ../general/g.remove/main.c:117
@@ -24828,23 +22071,20 @@
#: ../general/g.list/main.c:86 ../general/g.list/main.c:94
#: ../general/g.list/main.c:120 ../general/g.list/main.c:126
#: ../general/g.list/main.c:132
-#, fuzzy
msgid "Pattern"
-msgstr "Raster"
+msgstr "Patrón"
#: ../general/g.remove/main.c:105
-#, fuzzy
msgid "File name search pattern"
-msgstr "Patrón de búsqueda de nombre mapa (por omisión: todos)"
+msgstr "Patrón de búsqueda de nombre de archivo"
#: ../general/g.remove/main.c:111
-#, fuzzy
msgid "File name exclusion pattern (default: none)"
-msgstr "Patrón de exclusión de Map name (por defecto: ninguno)"
+msgstr "Patrón de exclusión de nombre de archivo (predeterminado: none)"
#: ../general/g.remove/main.c:116 ../general/g.list/main.c:119
msgid "Ignore case"
-msgstr ""
+msgstr "Ignorar mayúsculas y minúsculas"
#: ../general/g.remove/main.c:122 ../general/g.list/main.c:125
msgid "Use basic regular expressions instead of wildcards"
@@ -24855,70 +22095,56 @@
msgstr "Usar expressiones regulares largas en vez de comodines"
#: ../general/g.remove/main.c:139
-#, fuzzy
msgid "Remove base raster maps"
-msgstr "Eliminar mapas base"
+msgstr "Eliminar mapas ráster base"
#: ../general/g.remove/main.c:178 ../general/g.remove/main.c:202
#: ../general/g.list/main.c:184 ../general/g.list/main.c:211
-#, fuzzy, c-format
+#, c-format
msgid "Unable to compile pattern <%s>"
+msgstr "No ha sido posible compilar patrón <%s>"
#: ../general/g.remove/main.c:208
-#, fuzzy
msgid "The following data base element files would be deleted:"
-msgstr "Los siguientes archivos serán eliminados:"
+msgstr "Los siguientes archivos de bases de datos de elementos serían eliminados:"
#: ../general/g.remove/main.c:259
-#, fuzzy
msgid "No data base element files found"
-msgstr "No se encontraron mapas raster"
+msgstr "No se encontraron archivos de elementos de bases de datos"
#: ../general/g.remove/main.c:267
#, c-format
-msgid ""
-"Nothing removed. You must use the force flag (-%c) to actually remove them. "
-"Exiting."
-msgstr ""
+msgid "Nothing removed. You must use the force flag (-%c) to actually remove them. Exiting."
+msgstr "No se removió nada. Debe usar la bandera para forzar (-%c) para realmente removerlos. Saliendo."
#: ../general/g.remove/check_reclass.c:16
-#, fuzzy, c-format
+#, c-format
msgid "Raster map <%s@%s> is a base map for <%s>. Remove forced."
-msgstr "[%s@%s] es un mapa base para [%s]. Eliminar forzado."
+msgstr "Mapa raster <%s@%s> es un mapa base para <%s>. Eliminación forzada."
#: ../general/g.remove/check_reclass.c:19
-#, fuzzy, c-format
+#, c-format
msgid "Raster map <%s@%s> is a base map. Remove reclassed map <%s> first."
-msgstr "[%s@%s] es un mapa base. Eliminar mapas reclasificados primero: %s"
+msgstr "Mapa raster <%s@%s> es un mapa base. Remueva primero el mapa reclasificado <%s>."
#: ../general/g.remove/check_reclass.c:41
#: ../general/g.remove/check_reclass.c:54
-#, fuzzy, c-format
+#, c-format
msgid "Removing information about reclassed map from <%s@%s> failed"
-msgstr ""
-"La eliminación de la información sobre el mapa reclasificado a partir de [%s@"
-"%s] falló"
+msgstr "Falló el remover información sobre el mapa reclasificado a partir de <%s@%s>"
#: ../general/g.remove/construct_pattern.c:37
-#, fuzzy, c-format
+#, c-format
msgid "%s: Cannot remove or exclude files not in the current mapset."
-msgstr ""
+msgstr "%s: no se puede eliminar o excluir archivos que no se encuentren en el directorio de mapas actual."
#: ../general/g.remove/construct_pattern.c:57
msgid "Illegal filenames not allowed in the name or ignore option."
-msgstr ""
+msgstr "Nombres de archivo ilegales no permitidos en el nombre o ignorar opción."
#: ../general/g.list/main.c:69
-#, fuzzy
-msgid ""
-"Lists available GRASS data base files of the user-specified data type "
-"optionally using the search pattern."
-msgstr ""
-"Lista archivos de base de datos de GRASS del tipo de datos especificado por "
-"el usuario para una salida estándar."
+msgid "Lists available GRASS data base files of the user-specified data type optionally using the search pattern."
+msgstr "Enlista archivos de base de datos de GRASS del tipo de datos especificado por el usuario opcionalmente usando el patrón de búsqueda."
#: ../general/g.list/main.c:85
msgid "Map name search pattern (default: all)"
@@ -24930,35 +22156,27 @@
#: ../general/g.list/main.c:99
msgid "Name of mapset to list (default: current search path)"
-msgstr ""
-"Directorio de mapas a enlistar (predeterminado: ruta de búsqueda actual)"
+msgstr "Directorio de mapas a enlistar (predeterminado: ruta de búsqueda actual)"
#: ../general/g.list/main.c:101
msgid "'.' for current mapset; '*' for all mapsets in location"
-msgstr ""
-"'.' para directorio de mapas actual, '*' para todos los directorios de mapas "
-"de la localización"
+msgstr "'.' para directorio de mapas actual, '*' para todos los directorios de mapas de la localización"
#: ../general/g.list/main.c:107
-#, fuzzy
msgid "Name of saved region for map search (default: not restricted)"
-msgstr "Nombre de un directorio de mapas (por omisión: actual)"
+msgstr "Nombre de región guardada para mapa de búsqueda (predeterminado: no restingido)"
#: ../general/g.list/main.c:109
-#, fuzzy
msgid "'.' for current region; '*' for default region"
-msgstr "Establecer la región actual a partir de la región nombrada"
+msgstr "'.' para región actual; '*' para región predeterminada"
#: ../general/g.list/main.c:136
msgid "Print data types"
msgstr "Imprimir tipos de datos"
#: ../general/g.list/main.c:141
-#, fuzzy
msgid "Print fully-qualified map names (including mapsets)"
msgstr ""
-"Mostar nombres de los mapas totalmente cualificado (incluyendo directorios "
-"de mapas)"
#: ../general/g.list/main.c:146
msgid "Pretty printing in human readable format"
@@ -24979,14 +22197,13 @@
msgstr "No se puede leer la cabecera del mapa ráster 3D <%s@%s>"
#: ../general/g.list/list.c:131
-#, fuzzy, c-format
+#, c-format
msgid "Unable to open vector map <%s@%s> on topological level"
-msgstr "No se puede abrir el mapa vectorial <%s> al nivel topológico %d"
+msgstr "No se puede abrir el mapa vectorial <%s@%s> al nivel topológico"
#: ../general/g.region/main.c:66
msgid "Manages the boundary definitions for the geographic region."
-msgstr ""
-"Administra las definiciones de los contornos para la región geográfica."
+msgstr "Administra las definiciones de los contornos para la región geográfica."
#: ../general/g.region/main.c:72 ../raster/r.region/main.c:65
msgid "Set from default region"
@@ -25015,8 +22232,7 @@
#: ../general/g.region/main.c:88
msgid "Print the current region in lat/long using the current ellipsoid/datum"
-msgstr ""
-"Imprimir la región actual en lat/long utilizando el elipsoide/datum actual"
+msgstr "Imprimir la región actual en lat/long utilizando el elipsoide/datum actual"
#: ../general/g.region/main.c:94
msgid "Print the current region extent"
@@ -25043,10 +22259,8 @@
msgstr "Imprimir el ángulo de convergencia (grados CCW)"
#: ../general/g.region/main.c:125
-msgid ""
-"The difference between the projection's grid north and true north, measured "
-"at the center coordinates of the current region."
-msgstr ""
+msgid "The difference between the projection's grid north and true north, measured at the center coordinates of the current region."
+msgstr "La diferencia entre el norte de la malla de proyección y el norte verdadero, medida en la coordenada central de la región actual."
#: ../general/g.region/main.c:131
msgid "Print also 3D settings"
@@ -25057,12 +22271,8 @@
msgstr "Imprimir los límites máximos en latitud/longitud en WGS84"
#: ../general/g.region/main.c:148
-msgid ""
-"Align region to resolution (default = align to bounds, works only for 2D "
-"resolution)"
-msgstr ""
-"Alinear la región a la resolución (por omisión = alinear a los límites, "
-"funciona sólo para resolución 2D)"
+msgid "Align region to resolution (default = align to bounds, works only for 2D resolution)"
+msgstr "Alinear la región a la resolución (por omisión = alinear a los límites, funciona sólo para resolución 2D)"
#: ../general/g.region/main.c:154
msgid "Do not update the current region"
@@ -25073,21 +22283,16 @@
#: ../general/g.region/main.c:167
-#, fuzzy
msgid "Set region to match raster map(s)"
-msgstr "Establecer la región para ajustar este mapa ráster"
+msgstr "Establecer la región para que coincida con mapa(s) ráster"
#: ../general/g.region/main.c:175
-#, fuzzy
msgid "Set region to match 3D raster map(s) (both 2D and 3D values)"
-msgstr ""
-"Establecer la región para ajustar este mapa ráster 3D (tanto valores 2D como "
-"3D)"
+msgstr "Establecer la región para que coincida con mapa(s) ráster 3D (tanto valores 2D como 3D)"
#: ../general/g.region/main.c:183
-#, fuzzy
msgid "Set region to match vector map(s)"
-msgstr "Establecer la región para ajustar este mapa vectorial"
+msgstr "Establecer la región para que coincida con mapa(s) vectorial"
#: ../general/g.region/main.c:193 ../raster/r.region/main.c:103
msgid "Value for the northern edge"
@@ -25129,39 +22334,32 @@
msgstr "Número de columnas en la nueva región"
#: ../general/g.region/main.c:266
-#, fuzzy
msgid "2D grid resolution (north-south and east-west)"
-msgstr "Resolución de la cuadrícula 2D (tanto Norte-Sur como Este-Oeste)"
+msgstr "Resolución de malla 2D (Norte-Sur y Este-Oeste)"
#: ../general/g.region/main.c:276
msgid "3D grid resolution (north-south, east-west and top-bottom)"
-msgstr ""
-"Resolución de la cuadrícula 3D (Norte-Sur, Este-Oeste y Superior-Inferior)"
+msgstr "Resolución de la cuadrícula 3D (Norte-Sur, Este-Oeste y Superior-Inferior)"
#: ../general/g.region/main.c:285
-#, fuzzy
msgid "North-south 2D grid resolution"
-msgstr "Resolución Norte-Sur de la cuadrícula 2D"
+msgstr "Resolución Norte-Sur de malla 2D"
#: ../general/g.region/main.c:294
-#, fuzzy
msgid "East-west 2D grid resolution"
-msgstr "Resolución Este-Oeste de la cuadrícula 2D"
+msgstr "Resolución Este-Oeste -Sur de malla 2D"
#: ../general/g.region/main.c:303
-#, fuzzy
msgid "Top-bottom 3D grid resolution"
-msgstr "Resolución superior-inferior de la cuadrícula 3D"
+msgstr "Resolución Cima-Fondo de malla 3D"
#: ../general/g.region/main.c:313
-#, fuzzy
msgid "Shrink region until it meets non-NULL data from this raster map"
+msgstr "Encojer la región hasta que encuentre datos no nulos (non-NULL) de este mapa raster"
#: ../general/g.region/main.c:324
-#, fuzzy
msgid "Adjust region cells to cleanly align with this raster map"
+msgstr "Ajustar región para alinear limpiamente con este mapa raster"
#: ../general/g.region/main.c:335
msgid "Save current region settings in named region file"
@@ -25183,9 +22381,7 @@
#: ../general/g.region/main.c:774
msgid "Unable to change default region. The current mapset is not <PERMANENT>."
-msgstr ""
-"No se puede cambiar la región predeterminada. El directorio de mapas actual "
-"no es <PERMANENT>."
+msgstr "No se puede cambiar la región predeterminada. El directorio de mapas actual no es <PERMANENT>."
#: ../general/g.region/main.c:791 ../raster/r.in.lidar/main.c:508
#, c-format
@@ -25196,15 +22392,13 @@
#: ../general/g.region/printwindow.c:611 ../raster/r.horizon/main.c:531
#: ../raster/r.sun/main.c:745 ../display/d.where/main.c:107
msgid "Can't get projection info of current location"
-msgstr ""
-"No se puede obtener información de la proyección de la localización actual"
+msgstr "No se puede obtener información de la proyección de la localización actual"
#: ../general/g.region/printwindow.c:239 ../general/g.region/printwindow.c:495
#: ../general/g.region/printwindow.c:614 ../raster/r.horizon/main.c:534
#: ../raster/r.sun/main.c:749 ../display/d.where/main.c:110
msgid "Can't get projection units of current location"
-msgstr ""
-"No se pueden obtener unidades de la proyección de la localización actual"
+msgstr "No se pueden obtener unidades de la proyección de la localización actual"
#: ../general/g.region/printwindow.c:252 ../general/g.region/printwindow.c:505
#: ../general/g.region/printwindow.c:636 ../raster/r.sunhours/main.c:232
@@ -25227,42 +22421,28 @@
msgstr "Ya está en Lat/Long. Usar la opción -p en su lugar."
#: ../general/g.region/printwindow.c:401
-#, fuzzy
-msgid ""
-"You are in a simple XY location, projection to Lat/Lon is not possible. Use "
-"the -p flag instead."
-msgstr ""
-"Está en una localización XY (ninguna proyección posible, use la opción -p en "
-"su lugar)."
+msgid "You are in a simple XY location, projection to Lat/Lon is not possible. Use the -p flag instead."
+msgstr "Está en una localización XY, proyectar a Lat/Lon no es posible. Use la bandera -p en su lugar."
#: ../general/g.region/printwindow.c:626
-msgid ""
-"WGS84 output not possible as this location does not contain datum "
-"transformation parameters. Try running g.setproj."
-msgstr ""
-"Salida WGS84 imposible, ya que esta localización no contiene parámetros de "
-"transformación del datum. Pruebe a ejecutar g.setproj."
+msgid "WGS84 output not possible as this location does not contain datum transformation parameters. Try running g.setproj."
+msgstr "Salida WGS84 imposible, ya que esta localización no contiene parámetros de transformación del datum. Pruebe a ejecutar g.setproj."
#: ../general/g.region/printwindow.c:772
msgid "Lat/Long calculations are not possible from a simple XY system"
msgstr "Los cálculos Lat/Long no pueden realizarse desde un sistema simple XY"
#: ../general/g.mapset/main.c:51
-#, fuzzy
msgid "Changes/reports current mapset."
-msgstr "Cambia el directorio de mapas actual."
+msgstr "Cambios/reportes del Directorio de mapas actual."
#: ../general/g.mapset/main.c:52
-msgid ""
-"Optionally create new mapset or list available mapsets in given location."
-msgstr ""
-"Opcionalmente crear nuevo directorio de mapas o lista disponible de "
-"directorios de mapas en una posición dada."
+msgid "Optionally create new mapset or list available mapsets in given location."
+msgstr "Opcionalmente crear nuevo directorio de mapas o lista disponible de directorios de mapas en una posición dada."
#: ../general/g.mapset/main.c:56
-#, fuzzy
msgid "Name of mapset where to switch"
-msgstr "Nombre del mapa de salida donde se escriben los errores"
+msgstr "Nombre del Directorio de mapas al cual cambiar"
#: ../general/g.mapset/main.c:57 ../general/g.mapset/main.c:61
#: ../general/g.mapset/main.c:64
@@ -25287,14 +22467,14 @@
msgstr "<%s> ya es el directorio de mapas actual"
#: ../general/g.mapset/main.c:145
-#, fuzzy, c-format
+#, c-format
msgid "You don't have permission to use the mapset <%s>"
-msgstr "No tiene permiso para usar este directorio de mapas"
+msgstr "No tiene permiso para usar el Directorio de mapas <%s>"
#: ../general/g.mapset/main.c:153
-#, fuzzy, c-format
+#, c-format
msgid "Unable to create new mapset <%s>"
-msgstr "No se puede crear el mapa vectorial <%s>"
+msgstr "No ha sido posible crear nuevo Directorio de mapas <%s>"
#: ../general/g.mapset/main.c:156
#, c-format
@@ -25308,26 +22488,20 @@
#: ../general/g.mapset/main.c:182
#, c-format
msgid "Lock file of mapset <%s> cannot be checked"
-msgstr ""
-"Archivo de bloqueo del directorio de mapas <%s> no puede ser comprobado"
+msgstr "Archivo de bloqueo del directorio de mapas <%s> no puede ser comprobado"
#: ../general/g.mapset/main.c:185
#, c-format
msgid "There appears to be an active GRASS session in selected mapset <%s>"
-msgstr ""
-"Parece ser que hay una sesión de GRASS activa en el directorio de mapas "
-"seleccionado <%s>"
+msgstr "Parece ser que hay una sesión de GRASS activa en el directorio de mapas seleccionado <%s>"
#: ../general/g.mapset/main.c:191
msgid "Cleaning up temporary files..."
msgstr " Limpiando archivos temporales..."
#: ../general/g.mapset/main.c:205
-#, fuzzy
-msgid ""
-"Mapset switched. Your shell continues to use the history for the old mapset"
-msgstr ""
-"Su consola continúa usando el histórico para el directorio de mapas antiguo"
+msgid "Mapset switched. Your shell continues to use the history for the old mapset"
+msgstr "Directorio de mapas cambiado. Su consola continúa usando el histórico para el Directorio de mapas antiguo"
#: ../general/g.mapset/main.c:210
#, c-format
@@ -25353,19 +22527,16 @@
msgstr "El actual directorio de mapas es <%s>"
#: ../general/g.gisenv/main.c:45
-#, fuzzy
msgid "variables"
-msgstr "Inutilizar"
+msgstr "variables"
#: ../general/g.gisenv/main.c:48
msgid "Outputs and modifies the user's current GRASS variable settings."
-msgstr ""
-"Saca y modifica la configuración actual de variables de GRASS del usuario."
+msgstr "Saca y modifica la configuración actual de variables de GRASS del usuario."
#: ../general/g.gisenv/main.c:49
msgid "Prints all defined GRASS variables if no option is given."
-msgstr ""
-"Muestra todas las variables GRASS definidas si no se da ninguna opción."
+msgstr "Muestra todas las variables GRASS definidas si no se da ninguna opción."
#: ../general/g.gisenv/main.c:54
msgid "GRASS variable to get"
@@ -25380,9 +22551,8 @@
msgstr "Variable de GRASS a establecer"
#: ../general/g.gisenv/main.c:71
-#, fuzzy
msgid "GRASS variable to unset"
-msgstr "Variable de GRASS a establecer"
+msgstr "Variable de GRASS a desestablecer"
#: ../general/g.gisenv/main.c:82
msgid "Where GRASS variable is stored"
@@ -25397,24 +22567,22 @@
msgstr "Utilizar sintaxis de la consola de comandos UNIX (para \"eval\")"
#: ../general/g.gisenv/main.c:97
-#, fuzzy
msgid "Do not use shell syntax"
-msgstr "No utilizar la sintaxis de la consola de comandos UNIX"
+msgstr "No utilizar la sintaxis de la consola de comandos"
#: ../general/g.gisenv/main.c:171
#, c-format
msgid "Variable <%s> is mandatory. No operation performed."
-msgstr ""
+msgstr "Es obligatoria la variable <%s>. No se realizó ninguna operación."
#: ../general/g.gisenv/main.c:177
-#, fuzzy, c-format
+#, c-format
msgid "Value '%s' ignored when unsetting the GRASS variable"
-msgstr "El valor '%s' es ignorado cuando se ....unsetting.. la variable GRASS"
+msgstr "Valor '%s' ignorado cuando se desestablece la variable GRASS"
#: ../general/g.gisenv/main.c:216
-#, fuzzy
msgid "GRASS variable not defined"
+msgstr "Variable GRASS no definida"
#: ../general/g.gisenv/main.c:222
#, c-format
@@ -25438,44 +22606,37 @@
msgstr "GUI"
#: ../general/g.gui/main.c:41
-#, fuzzy
msgid "user interface"
-msgstr "Realiza el mantenimiento de redes."
+msgstr "interfaz de usuario"
#: ../general/g.gui/main.c:44
msgid "Launches a GRASS graphical user interface (GUI) session."
msgstr "Lanza una sesión GRASS con interfície gráfica de usuario (GUI)"
#: ../general/g.gui/main.c:45
-#, fuzzy
msgid "Optionally updates default user interface settings."
-msgstr "Actualizar la configuración por defecto de la GUI"
+msgstr "Opcionalmente actualiza las configuraciones de la interfaz de usuario"
#: ../general/g.gui/main.c:50
-#, fuzzy
msgid "User interface"
+msgstr "Interfaz de usuario"
#: ../general/g.gui/main.c:54
msgid "wxPython based GUI (wxGUI)"
msgstr "GUI basada en wxPyhton (wxGUI)"
#: ../general/g.gui/main.c:55
-#, fuzzy
msgid "command line interface only"
-msgstr "No se encontró el mapa ráster"
+msgstr "solamente interfaz de línea de comandos"
#: ../general/g.gui/main.c:56
-#, fuzzy
msgid "command line interface with GUI startup screen"
+msgstr "interfaz de línea de comando con pantalla GUI de arranque"
#: ../general/g.gui/main.c:66
#, fuzzy
msgid "Name of workspace file to load on start-up"
-msgstr ""
-"Nombre del archivo del espacio de trabajo que se cargará en el arranque "
-"(válido solo para wxGUI)"
+msgstr "Nombre del archivo del espacio de trabajo que se cargará en el arranque (válido solo para wxGUI)"
#: ../general/g.gui/main.c:67
msgid "This is valid only for wxGUI (wxpython)"
@@ -25486,25 +22647,20 @@
msgstr ""
#: ../general/g.gui/main.c:72
-msgid ""
-"By default the GUI starts in the background and control is immediately "
-"returned to the caller. When GUI runs in foregreound, it blocks the command "
-"line"
+msgid "By default the GUI starts in the background and control is immediately returned to the caller. When GUI runs in foregreound, it blocks the command line"
msgstr ""
#: ../general/g.gui/main.c:78
-#, fuzzy
msgid "Update default user interface settings"
+msgstr "Actualizar configuración predeterminada de interfaz de usuario"
#: ../general/g.gui/main.c:79 ../general/g.gui/main.c:85
msgid "Default"
msgstr "Predeterminado"
#: ../general/g.gui/main.c:84
-#, fuzzy
msgid "Do not launch GUI after updating the default user interface settings"
-msgstr "No lanzar la GUI después de actualizar el ajuste GUI por defecto"
+msgstr "No lanzar Gui luego de actualizar la configuración predeterminada de la interfaz de usuario"
#: ../general/g.gui/main.c:95
#, c-format
@@ -25514,11 +22670,11 @@
#: ../general/g.gui/main.c:101
#, c-format
msgid "Nothing to do. For setting up <%s> as default UI use -%c flag."
-msgstr ""
+msgstr "Nada qué hacer. Para configurar <%s> como interfaz de usuario predeterminada use la bandera -%c"
#: ../general/g.gui/main.c:108
msgid "Your installation doesn't include GUI, exiting."
-msgstr ""
+msgstr "Tu instalación no incluye la GUI, saliendo."
#: ../general/g.gui/main.c:111
#, fuzzy, c-format
@@ -25540,14 +22696,11 @@
#: ../general/g.access/main.c:41
msgid "Controls access to the current mapset for other users on the system."
-msgstr ""
-"Controla el acceso al directorio de mapas actual para otros usuarios del "
-"sistema."
+msgstr "Controla el acceso al directorio de mapas actual para otros usuarios del sistema."
#: ../general/g.access/main.c:42
-#, fuzzy
msgid "If no option given, prints current status."
-msgstr "No escribir tabla de colores estándard GDAL"
+msgstr "Si no se da ninguna opción, muestra el estado actual."
#: ../general/g.access/main.c:49
msgid "Access for group"
@@ -25559,20 +22712,15 @@
#: ../general/g.access/main.c:64
msgid "UNIX filesystem access controls are not supported by MS-Windows"
-msgstr ""
-"Los controles de acceso a los archivos del sistema UNIX no son soportados "
-"por MS-Windows"
+msgstr "Los controles de acceso a los archivos del sistema UNIX no son soportados por MS-Windows"
#: ../general/g.access/main.c:72
msgid "Access to the PERMANENT mapset must be open, nothing changed"
-msgstr ""
-"El acceso al directorio de mapas PERMANENT debe estar abierto, no se cambia "
-"nada"
+msgstr "El acceso al directorio de mapas PERMANENT debe estar abierto, no se cambia nada"
#: ../general/g.access/main.c:76
-#, fuzzy
msgid "Unable to determine mapset permissions"
-msgstr "No se pueden determinar los permisos del directorio de mapas"
+msgstr "No ha sido posible determinar permisos de Directorio de mapas"
#: ../general/g.access/exp_perms.c:11 ../general/g.access/exp_perms.c:29
msgid "have"
@@ -25616,20 +22764,18 @@
msgstr "ahora"
#: ../general/g.setproj/proj.c:168
-#, fuzzy, c-format
+#, c-format
msgid "Unrecognized 'ask' value in parms.table: %s"
-msgstr "Valor 'ask' desconocido en proj-parms.table: %s"
+msgstr "Valor 'ask' no reconocido en parms.table: %s"
#: ../general/g.setproj/proj.c:178
-#, fuzzy, c-format
+#, c-format
msgid "Unrecognized default value in parms.table: %s"
-msgstr "No se reconoce el valor por defecto en proj-parms.table: %s"
+msgstr "Valor predeterminado no reconocido en parms.table: %s"
#: ../general/g.setproj/main.c:81
msgid "Interactively reset the location's projection settings."
-msgstr ""
-"Restablecer la configuración de la proyección de la localización de forma "
-"interactiva."
+msgstr "Restablecer la configuración de la proyección de la localización de forma interactiva."
#: ../general/g.setproj/main.c:88
msgid "You must be in the PERMANENT mapset to run g.setproj"
@@ -25675,8 +22821,7 @@
#: ../general/g.setproj/main.c:198
#, c-format
msgid "Projection %s is not specified in the file 'proj-parms.table'"
-msgstr ""
-"La proyección %s no está especificada en el el archivo 'proj-parms.table'"
+msgstr "La proyección %s no está especificada en el el archivo 'proj-parms.table'"
#: ../general/g.setproj/main.c:205
msgid "Do you wish to specify a geodetic datum for this location?"
@@ -25689,8 +22834,7 @@
#: ../general/g.setproj/main.c:217
msgid "Do you wish to change the datum (or datum transformation parameters)?"
-msgstr ""
-"¿Quiere cambiar el datum (o los parámetros de transformación del datum)?"
+msgstr "¿Quiere cambiar el datum (o los parámetros de transformación del datum)?"
#: ../general/g.setproj/main.c:225
msgid "The datum information has not been changed"
@@ -25740,14 +22884,8 @@
msgstr "La información de la zona UTM no se ha actualizado"
#: ../general/g.setproj/main.c:456
-msgid ""
-"But if you change zone, all the existing data will be interpreted by "
-"projection software. GRASS will not automatically re-project or even change "
-"the headers for existing maps."
-msgstr ""
-"Pero si cambia la zona, todos los datos existente se interpretarán mediante "
-"software de proyección. GRASS no reproyectará ni cambiará las cabeceras de "
-"los mapas existentes de forma automática."
+msgid "But if you change zone, all the existing data will be interpreted by projection software. GRASS will not automatically re-project or even change the headers for existing maps."
+msgstr "Pero si cambia la zona, todos los datos existente se interpretarán mediante software de proyección. GRASS no reproyectará ni cambiará las cabeceras de los mapas existentes de forma automática."
#: ../general/g.setproj/main.c:461
msgid "Would you still like to change the UTM zone?"
@@ -25802,9 +22940,8 @@
msgstr "Ejecutar g.region -d para actualizarla"
#: ../general/g.setproj/get_stp.c:43
-#, fuzzy
msgid "This should not happen. See your system admin."
-msgstr "Esto no tendría que suceder, consulta a tu administrador del sistema"
+msgstr "Esto no tendría que suceder. Consulta a tu administrador del sistema"
#: ../general/g.setproj/get_stp.c:99
msgid "Unable to open FIPS code file"
@@ -25844,14 +22981,14 @@
msgstr "Mi primer módulo vectorial"
#: ../doc/vector/v.example/main.c:170
-#, fuzzy, c-format
+#, c-format
msgid "Unable to get attribute data for cat %d"
-msgstr "No se pueden seleccionar atributos para la categoría = %d"
+msgstr "No ha sido posible obtener datos para categoría %d"
#: ../doc/vector/v.example/main.c:179
-#, fuzzy, c-format
+#, c-format
msgid "Error while retrieving database record for cat %d"
-msgstr "Error al eliminar el mapa de celdas de MÁSCARA antiguo."
+msgstr "Error al recuperar registro de base de datos para categoría %d"
#: ../doc/vector/v.example/main.c:212
#, c-format
@@ -25863,9 +23000,8 @@
msgstr "Mi primer módulo ráster"
#: ../raster/r.out.gridatb/main.c:70
-#, fuzzy
msgid "Exports GRASS raster map to GRIDATB.FOR map file (TOPMODEL)."
-msgstr "Exporta mapa ráster de GRASS a archivo de mapa GRIDATB.FOR (TOPMODEL)"
+msgstr "Exporta mapa ráster de GRASS a archivo de mapa GRIDATB.FOR (TOPMODEL)."
#: ../raster/r.buffer/write_map.c:45 ../raster/r.flow/io.c:207
#: ../raster/r.cost/main.c:1034
@@ -25899,9 +23035,8 @@
#: ../raster/r.slope.aspect/main.c:152 ../raster/r.param.scale/interface.c:56
#: ../raster/r.relief/main.c:110 ../imagery/i.topo.corr/main.c:48
-#, fuzzy
msgid "terrain"
-msgstr "Correlación"
+msgstr "terreno"
#: ../raster/r.slope.aspect/main.c:153
msgid "aspect"
@@ -25912,24 +23047,16 @@
msgstr "pendiente"
#: ../raster/r.slope.aspect/main.c:155
-#, fuzzy
msgid "curvature"
-msgstr "Elementos"
+msgstr "curvatura"
#: ../raster/r.slope.aspect/main.c:156
-#, fuzzy
-msgid ""
-"Generates raster maps of slope, aspect, curvatures and partial derivatives "
-"from an elevation raster map."
-msgstr ""
-"Genera mapas raster de pendiente, orientación, curvaturas y derivadas "
-"parciales a partir de un mapa raster de elevación."
+msgid "Generates raster maps of slope, aspect, curvatures and partial derivatives from an elevation raster map."
+msgstr "Genera mapas raster de pendiente, orientación (aspect), curvaturas y derivadas parciales a partir de un mapa raster de elevación."
#: ../raster/r.slope.aspect/main.c:158
msgid "Aspect is calculated counterclockwise from east."
-msgstr ""
-"La orientación se calcula en el sentido contrario a las agujas del reloj "
-"desde el este."
+msgstr "La orientación se calcula en el sentido contrario a las agujas del reloj desde el este."
#: ../raster/r.slope.aspect/main.c:180
msgid "Format for reporting the slope"
@@ -25940,51 +23067,36 @@
msgstr "Tipo de mapas de orientación y pendiente"
#: ../raster/r.slope.aspect/main.c:210
-msgid ""
-"Name for output first order partial derivative dx (E-W slope) raster map"
-msgstr ""
-"Nombre de archivo de derivada dx (pendiente E-W) parcial de primer orden de "
-"salida"
+msgid "Name for output first order partial derivative dx (E-W slope) raster map"
+msgstr "Nombre de archivo de derivada dx (pendiente E-W) parcial de primer orden de salida"
#: ../raster/r.slope.aspect/main.c:217
-#, fuzzy
-msgid ""
-"Name for output first order partial derivative dy (N-S slope) raster map"
-msgstr ""
-"Nombre de archivo de derivada dy (pendiente N-S) parcial de primer orden de "
-"salida"
+msgid "Name for output first order partial derivative dy (N-S slope) raster map"
+msgstr "Nombre para mapa ráster de derivadas parciales dy (pendiente N-S) de primer orden"
#: ../raster/r.slope.aspect/main.c:224
-#, fuzzy
msgid "Name for output second order partial derivative dxx raster map"
-msgstr "Nombre de archivo de derivada dxx parcial de segundo orden de salida"
+msgstr "Nombre para mapa ráster de derivadas parciales dxx de segundo orden"
#: ../raster/r.slope.aspect/main.c:231
-#, fuzzy
msgid "Name for output second order partial derivative dyy raster map"
-msgstr "Nombre de archivo de derivada dyy parcial de segundo orden de salida"
+msgstr "Nombre para mapa ráster de derivadas parciales dyy de segundo orden"
#: ../raster/r.slope.aspect/main.c:238
-#, fuzzy
msgid "Name for output second order partial derivative dxy raster map"
-msgstr "Nombre de archivo de derivada dxy parcial de segundo orden de salida"
+msgstr "Nombre para mapa ráster de derivadas parciales dxy de segundo orden"
#: ../raster/r.slope.aspect/main.c:244
-#, fuzzy
msgid "Multiplicative factor to convert elevation units to horizontal units"
-msgstr "Factor de multiplicación para convertir unidades de elevación a metros"
+msgstr "Factor de multiplicación para convertir unidades de elevación a unidades horizontales"
#: ../raster/r.slope.aspect/main.c:253
-#, fuzzy
msgid "Minimum slope value (in percent) for which aspect is computed"
-msgstr ""
-"Valor de pendiente mínimo (en porcentaje) para el que se procesa la "
-"orientación"
+msgstr "Valor de pendiente mínimo (en porcentaje) para el que se calcula la orientación"
#: ../raster/r.slope.aspect/main.c:262
-#, fuzzy
msgid "Do not align the current region to the raster elevation map"
-msgstr "No alinear la región actual con la capa de elevación"
+msgstr "No alinear la región actual al mapa ráster de elevación"
#: ../raster/r.slope.aspect/main.c:316 ../raster/r.relief/main.c:220
#, c-format
@@ -25999,12 +23111,8 @@
#: ../raster/r.slope.aspect/main.c:337
#, c-format
-msgid ""
-"You must specify at least one of the parameters: <%s>, <%s>, <%s>, <%s>, <"
-"%s>, <%s>, <%s>, <%s> or <%s>"
-msgstr ""
-"Tienes que especificar como mínimo uno de los parámetros:<%s>, <%s>, <%s>, <"
-"%s>, <%s>, <%s>, <%s>, <%s> o <%s>"
+msgid "You must specify at least one of the parameters: <%s>, <%s>, <%s>, <%s>, <%s>, <%s>, <%s>, <%s> or <%s>"
+msgstr "Tienes que especificar como mínimo uno de los parámetros:<%s>, <%s>, <%s>, <%s>, <%s>, <%s>, <%s>, <%s> o <%s>"
#: ../raster/r.slope.aspect/main.c:359
#, c-format
@@ -26012,10 +23120,8 @@
msgstr "Tipo de raster incorrecto: %s"
#: ../raster/r.slope.aspect/main.c:388
-msgid ""
-"r.slope.aspect does not convert horizontal units to meters in this version, "
-"see manual page."
-msgstr ""
+msgid "r.slope.aspect does not convert horizontal units to meters in this version, see manual page."
+msgstr "r.slope.aspect no convierte unidades horizontales a metros en esta versión, ver página del manual."
#: ../raster/r.slope.aspect/main.c:545 ../raster/r.series.accumulate/main.c:318
#: ../raster/r.series.interp/main.c:339 ../raster/r.relief/main.c:316
@@ -26061,7 +23167,7 @@
#: ../raster/r.slope.aspect/main.c:1286
#, c-format
msgid "E-W slope raster map <%s> complete"
-msgstr "Pendiente E-W del mapa raster <%s> terminada"
+msgstr "Pendiente este-oeste (E-W) del mapa ráster <%s> terminada"
#: ../raster/r.slope.aspect/main.c:1311
#, c-format
@@ -26071,7 +23177,7 @@
#: ../raster/r.slope.aspect/main.c:1336
#, c-format
msgid "Dxx raster map <%s> complete"
-msgstr "Mapa raster Dxx <%s> terminado"
+msgstr "Mapa ráster Dxx <%s> terminado"
#: ../raster/r.slope.aspect/main.c:1361
#, c-format
@@ -26081,17 +23187,15 @@
#: ../raster/r.slope.aspect/main.c:1386
#, c-format
msgid "Dxy raster map <%s> complete"
-msgstr "Mapa raster Dxy <%s>terminado"
+msgstr "Mapa ráster Dxy <%s>terminado"
#: ../raster/r.param.scale/main.c:42
-#, fuzzy
msgid "Lat/Long locations are not supported by this module"
-msgstr "Localización latitud/longitud no soportada"
+msgstr "Localizaciones Lat/Long no están soportadas por este módulo"
#: ../raster/r.param.scale/interface.c:55
-#, fuzzy
msgid "geomorphology"
-msgstr "ráster, goemorfología"
+msgstr "goemorfología"
#: ../raster/r.param.scale/interface.c:58
msgid "landform"
@@ -26102,17 +23206,12 @@
msgstr "Extrae parámetros del terreno a partir de un DEM."
#: ../raster/r.param.scale/interface.c:60
-msgid ""
-"Uses a multi-scale approach by taking fitting quadratic parameters to any "
-"size window (via least squares)."
-msgstr ""
-"Utiliza una aproximación multiescala tomando parámetros cuadráticos que se "
-"ajusten a cualquier tamaño de ventana (vía las menores esquinas)."
+msgid "Uses a multi-scale approach by taking fitting quadratic parameters to any size window (via least squares)."
+msgstr "Utiliza una aproximación multiescala tomando parámetros cuadráticos que se ajusten a cualquier tamaño de ventana (vía las menores esquinas)."
#: ../raster/r.param.scale/interface.c:78
-#, fuzzy
msgid "Name for output raster map containing morphometric parameter"
-msgstr "Capa ráster de salida que contenga parámetros morfométricos"
+msgstr "Nombre de mapa ráster de salida que contenga parámetros morfométricos"
#: ../raster/r.param.scale/interface.c:82
msgid "Slope tolerance that defines a 'flat' surface (degrees)"
@@ -26123,10 +23222,8 @@
msgstr "Tolerancia de curvatura que define una superficie 'planar'"
#: ../raster/r.param.scale/interface.c:96
-#, fuzzy
msgid "Size of processing window (odd number only)"
-msgstr ""
-"Tamaño de la ventana de procesamiento (sólo números impares, máximo %i)"
+msgstr "Tamaño de la ventana de procesamiento (solamente números impares)"
#: ../raster/r.param.scale/interface.c:104
msgid "Morphometric parameter in 'size' window to calculate"
@@ -26154,28 +23251,24 @@
#: ../raster/r.param.scale/process.c:75
msgid "E-W and N-S grid resolutions are different. Taking average."
-msgstr ""
-"Las resoluciones de cuadrícula E-W y N-S son diferentes. Se toma la media."
+msgstr "Las resoluciones de cuadrícula E-W y N-S son diferentes. Se toma la media."
#: ../raster/r.in.png/main.c:297
-#, fuzzy, c-format
+#, c-format
msgid "Unable to open PNG file '%s'"
-msgstr "No se puede abrir el archivo <%s>"
+msgstr "No ha sido posible abrir archivo PNG '%s'"
#: ../raster/r.in.png/main.c:300
-#, fuzzy
msgid "Input file empty or too short"
-msgstr "Formato del archivo de entrada"
+msgstr "Archivo de entrada vacío o demasiado corto"
#: ../raster/r.in.png/main.c:303
-#, fuzzy
msgid "Input file not a PNG file"
-msgstr "El archivo de entrada se puede importar."
+msgstr "Archivo de entrada no es un archivo PNG"
#: ../raster/r.in.png/main.c:314
-#, fuzzy
msgid "PNG error"
-msgstr "Parámetros"
+msgstr "PNG de errores"
#: ../raster/r.in.png/main.c:485 ../raster/r.cross/main.c:169
#: ../raster/r.resample/main.c:125 ../raster/r.basins.fill/main.c:146
@@ -26184,34 +23277,28 @@
msgstr "Creando archivos de soporte para %s..."
#: ../raster/r.in.png/main.c:522
-#, fuzzy
msgid "Imports non-georeferenced PNG format image."
-msgstr "Exporta un ráster de GRASS como una images PNG no georeferenciada."
+msgstr "Importa imagen no georeferenciada en formato PNG."
#: ../raster/r.in.png/main.c:532
-#, fuzzy
msgid "Title for created raster map"
-msgstr "Título para el mapa ráster resultante"
+msgstr "Título para mapa ráster creado"
#: ../raster/r.in.png/main.c:538
-#, fuzzy
msgid "Display gamma"
-msgstr "Mostrar"
+msgstr "Visualizar gamma"
#: ../raster/r.in.png/main.c:544
-#, fuzzy
msgid "Alpha threshold"
-msgstr "Herramienta: umbral"
+msgstr "Umbral alfa"
#: ../raster/r.in.png/main.c:548
-#, fuzzy
msgid "Create floating-point map (0.0 - 1.0)"
-msgstr "Truncar datos de coma flotante"
+msgstr "Crear mapa de punto flotante (0.0 1.0)"
#: ../raster/r.in.png/main.c:552
-#, fuzzy
msgid "Output image file header only and exit"
-msgstr "Salida en metros solamente"
+msgstr "Solamente encabezado de archivo de imagen de salida y salir"
#: ../raster/r.sunhours/solpos00.c:994 ../raster/r.sunmask/solpos00.c:949
#, c-format
@@ -26246,7 +23333,7 @@
#: ../raster/r.sunhours/solpos00.c:1009 ../raster/r.sunmask/solpos00.c:964
#, c-format
msgid "S_decode ==> Please fix the second: %d"
-msgstr "S_decode ==> Por favor, corrija los segundo: %d"
+msgstr "S_decode ==> Por favor corrija el segundo: %d"
#: ../raster/r.sunhours/solpos00.c:1011 ../raster/r.sunmask/solpos00.c:966
#, c-format
@@ -26314,45 +23401,36 @@
#: ../raster/r.sunhours/main.c:75 ../raster/r.sunmask/main.c:118
#: ../raster/r.horizon/main.c:182
-#, fuzzy
msgid "sun position"
-msgstr "Proyeccion del origen"
+msgstr "posición del sol"
#: ../raster/r.sunhours/main.c:76
-#, fuzzy
msgid "Calculates solar elevation, solar azimuth, and sun hours."
-msgstr "Calcula la desviación estándar del área de parche en un mapa ráster"
+msgstr "Calcula la elevación solar, el azimut solar, y las horas de sol."
#: ../raster/r.sunhours/main.c:77
-msgid ""
-"Solar elevation: the angle between the direction of the geometric center of "
-"the sun's apparent disk and the (idealized) horizon. Solar azimuth: the "
-"angle from due north in clockwise direction."
+msgid "Solar elevation: the angle between the direction of the geometric center of the sun's apparent disk and the (idealized) horizon. Solar azimuth: the angle from due north in clockwise direction."
msgstr ""
#: ../raster/r.sunhours/main.c:83
-#, fuzzy
msgid "Output raster map with solar elevation angle"
-msgstr "Nombre de prefijo de mapa ráster de salida"
+msgstr "Genera mapa ráster con el ángulo de elevación solar"
#: ../raster/r.sunhours/main.c:88
-#, fuzzy
msgid "Output raster map with solar azimuth angle"
-msgstr "Título de mapa ráster de salida"
+msgstr "Genera mapa ráster con el ángulo del azimut solar"
#: ../raster/r.sunhours/main.c:93
-#, fuzzy
msgid "Output raster map with sunshine hours"
+msgstr "Genera mapa ráster con las horas de sol"
#: ../raster/r.sunhours/main.c:94
msgid "Sunshine hours require SOLPOS use and Greenwich standard time"
msgstr ""
#: ../raster/r.sunhours/main.c:101
-#, fuzzy
msgid "Year"
-msgstr "Año (B)"
+msgstr "Año"
#: ../raster/r.sunhours/main.c:103 ../raster/r.sunhours/main.c:112
#: ../raster/r.sunhours/main.c:120 ../raster/r.sunhours/main.c:129
@@ -26367,33 +23445,28 @@
msgstr "Tiempo"
#: ../raster/r.sunhours/main.c:109
-#, fuzzy
msgid "Month"
-msgstr "Mes (B)"
+msgstr "Mes"
#: ../raster/r.sunhours/main.c:110
msgid "If not given, day is interpreted as day of the year"
msgstr ""
#: ../raster/r.sunhours/main.c:118
-#, fuzzy
msgid "Day"
-msgstr "Día (B)"
+msgstr "Día"
#: ../raster/r.sunhours/main.c:126
-#, fuzzy
msgid "Hour"
-msgstr "Hora (B)"
+msgstr "Hora"
#: ../raster/r.sunhours/main.c:135
-#, fuzzy
msgid "Minutes"
-msgstr "B: minutos (0.60)"
+msgstr "Minutos"
#: ../raster/r.sunhours/main.c:144
-#, fuzzy
msgid "Seconds"
-msgstr "Segundos (B)"
+msgstr "Segundos"
#: ../raster/r.sunhours/main.c:151
msgid "Time is local sidereal time, not Greenwich standard time"
@@ -26401,51 +23474,44 @@
#: ../raster/r.sunhours/main.c:155
msgid "Do not use SOLPOS algorithm of NREL"
-msgstr ""
+msgstr "No usar algoritmo SOLPOS de NREL"
#: ../raster/r.sunhours/main.c:167
msgid "No output requested, exiting."
-msgstr ""
+msgstr "No se solicitó salida, saliendo."
#: ../raster/r.sunhours/main.c:193
msgid "NREL SOLPOS algorithm uses Greenwich standard time."
-msgstr ""
+msgstr "Algoritmo NREL SOLPOS usa tiempo estándar de Greenwich."
#: ../raster/r.sunhours/main.c:194 ../raster/r.sunhours/main.c:202
msgid "Time will be interpreted as Greenwich standard time."
-msgstr ""
+msgstr "El tiempo será interpretado como tiempo estándar de Greenwich."
#: ../raster/r.sunhours/main.c:200
+#, fuzzy
msgid "Time will be interpreted as local sidereal time."
-msgstr ""
+msgstr "El tiempo será interpretado como tiempo sideral local."
#: ../raster/r.sunhours/main.c:205
msgid "Sunshine hours require NREL SOLPOS."
-msgstr ""
+msgstr "NREL SOLPOS necesita horas de sol."
#: ../raster/r.sunhours/main.c:210
-#, fuzzy
msgid "Current projection is x,y (undefined)."
-msgstr "La proyección actual no es latitud-longitud"
+msgstr "La proyección actual es x,y (indefinida)."
#: ../raster/r.sunhours/main.c:216
-#, fuzzy
msgid "Cannot get projection info of current location"
-msgstr ""
+msgstr "No se puede obtener información de la proyección de la Localización actual"
#: ../raster/r.sunhours/main.c:219
-#, fuzzy
msgid "Cannot get projection units of current location"
-msgstr ""
+msgstr "No se pueden obtener unidades de la proyección de la Localización actual"
#: ../raster/r.sunhours/main.c:222
-#, fuzzy
msgid "Cannot get projection key values of current location"
-msgstr ""
-"No se pueden obtener los valores clave de la proyección de la localización "
-"actual"
+msgstr "No se pueden obtener valores clave de la Localización actual"
#: ../raster/r.sunhours/main.c:324 ../raster/r.sunhours/main.c:335
#: ../raster/r.sunhours/main.c:346 ../raster/r.mapcalc/map3.c:606
@@ -26457,27 +23523,20 @@
msgstr "No se puede crear el mapa ráster <%s>"
#: ../raster/r.sunhours/main.c:356
-#, fuzzy
msgid "Calculating solar elevation and azimuth..."
-msgstr "Calculando matrices de covarianza de clase..."
+msgstr "Calculando elevación solar y azimut..."
#: ../raster/r.sunhours/main.c:359
-#, fuzzy
msgid "Calculating solar elevation..."
-msgstr "Calculando medias de clase..."
+msgstr "Calculando elevación solar..."
#: ../raster/r.sunhours/main.c:362
-#, fuzzy
msgid "Calculating solar azimuth..."
-msgstr "Calculando mapas..."
+msgstr "Calculando azimut solar..."
#: ../raster/r.surf.random/main.c:40
-#, fuzzy
-msgid ""
-"Produces a raster surface map of uniform random deviates with defined range."
-msgstr ""
-"Produce un mapa raster de desviaciones aleatorias uniformes cuyo intervalo "
-"puede ser expresado por el usuario."
+msgid "Produces a raster surface map of uniform random deviates with defined range."
+msgstr "Genera un mapa ráster de superficie de desviaciones aleatorias uniformes con rango definido."
#: ../raster/r.surf.random/main.c:46
msgid "Minimum random value"
@@ -26503,14 +23562,12 @@
msgstr "Importa un archivo binario MAT(v4) a un ráster de GRASS."
#: ../raster/r.in.mat/main.c:101
-#, fuzzy
msgid "Name of input MAT-File(v4)"
-msgstr "Nombre de un archivo MAT(v4) existente"
+msgstr "Nombre de archivo MAT(v4) de entrada"
#: ../raster/r.in.mat/main.c:105
-#, fuzzy
msgid "Name for output raster map (override)"
-msgstr "Nombre para el mapa ráster de salida (no tener en cuenta)"
+msgstr "Nombre para mapa ráster de salida (anular)"
#: ../raster/r.in.mat/main.c:149
msgid "Reading MAT-File..."
@@ -26641,10 +23698,8 @@
msgstr "Escribiendo nuevo mapa ráster..."
#: ../raster/r.proj/main.c:149
-#, fuzzy
msgid "Re-projects a raster map from given location to the current location."
-msgstr ""
-"Reproyecta un mapa ráster desde una localización a la localización actual."
+msgstr "Reproyecta un mapa ráster de una Localización dada a la Localización actual."
#: ../raster/r.proj/main.c:153
msgid "Location containing input raster map"
@@ -26659,14 +23714,12 @@
msgstr "Nombre del mapa ráster a reproyectar"
#: ../raster/r.proj/main.c:171
-#, fuzzy
msgid "Name for output raster map (default: same as 'input')"
-msgstr "Nombre para el mapa ráster de salida (por omisión: el de entrada)"
+msgstr "Nombre para mapa ráster de salida (predeterminado: igual al de 'input')"
#: ../raster/r.proj/main.c:198
-#, fuzzy
msgid "Resolution of output raster map"
-msgstr "Resolución del mapa de salida"
+msgstr "Resolución de mapa ráster de salida"
#: ../raster/r.proj/main.c:203
msgid "List raster maps in input mapset and exit"
@@ -26674,15 +23727,11 @@
#: ../raster/r.proj/main.c:213
msgid "Print input map's bounds in the current projection and exit"
-msgstr ""
-"Imprimir los límites del mapa de entrada en la proyección actual y salir"
+msgstr "Imprimir los límites del mapa de entrada en la proyección actual y salir"
#: ../raster/r.proj/main.c:219
-msgid ""
-"Print input map's bounds in the current projection and exit (shell style)"
-msgstr ""
-"Imprimir los límites del mapa de entrada en la proyección actual y salir (en "
-"el estilo de la consola de comandos UNIX)"
+msgid "Print input map's bounds in the current projection and exit (shell style)"
+msgstr "Imprimir los límites del mapa de entrada en la proyección actual y salir (en el estilo de la consola de comandos UNIX)"
#: ../raster/r.proj/main.c:254
msgid "Input and output locations are the same"
@@ -26690,19 +23739,15 @@
#: ../raster/r.proj/main.c:264
msgid "Unable to get projection info of output raster map"
-msgstr ""
-"No se puede obtener información de la proyección del mapa ráster de salida"
+msgstr "No se puede obtener información de la proyección del mapa ráster de salida"
#: ../raster/r.proj/main.c:267
msgid "Unable to get projection units of output raster map"
-msgstr ""
-"No se pueden obtener las unidades de la proyección del mapa ráster de salida"
+msgstr "No se pueden obtener las unidades de la proyección del mapa ráster de salida"
#: ../raster/r.proj/main.c:270
msgid "Unable to get projection key values of output raster map"
-msgstr ""
-"No se pueden obtener los valores clave de la proyección del mapa ráster de "
-"salida"
+msgstr "No se pueden obtener los valores clave de la proyección del mapa ráster de salida"
#: ../raster/r.proj/main.c:279
#, c-format
@@ -26712,9 +23757,7 @@
#: ../raster/r.proj/main.c:303
#, c-format
msgid "Raster map <%s> in location <%s> in mapset <%s> not found"
-msgstr ""
-"No se encuentra el mapa ráster <%s> en la localización <%s> en el directorio "
-"de mapas <%s>"
+msgstr "No se encuentra el mapa ráster <%s> en la localización <%s> en el directorio de mapas <%s>"
#: ../raster/r.proj/main.c:311
msgid "Unable to get projection info of input map"
@@ -26726,8 +23769,7 @@
#: ../raster/r.proj/main.c:317
msgid "Unable to get projection key values of input map"
-msgstr ""
-"No se pueden obtener los valores clave de la proyección del mapa de entrada"
+msgstr "No se pueden obtener los valores clave de la proyección del mapa de entrada"
#: ../raster/r.proj/main.c:332
msgid "Unable to work with unprojected data (xy location)"
@@ -26795,9 +23837,8 @@
msgstr "El mapa ráster de entrada está fuera de la región actual"
#: ../raster/r.proj/bordwalk.c:242
-#, fuzzy
msgid "Unable to reproject map center"
-msgstr "No se puede establecer la proyección"
+msgstr "No ha sido posible reproyectar centro del mapa"
#: ../raster/r.proj/readcell.c:59 ../raster/r.proj/readcell.c:129
#: ../raster/r.stats.quantile/main.c:309 ../raster/r.stats.zonal/main.c:482
@@ -26807,9 +23848,8 @@
msgstr "No se puede abrir el archivo temporal"
#: ../raster/r.proj/readcell.c:67
-#, fuzzy
msgid "Allocating memory and reading input raster map..."
-msgstr "Asignando memoria y leyendo el mapa de entrada..."
+msgstr "Asignando memoria y volviendo a leer mapa ráster de entrada..."
#: ../raster/r.proj/readcell.c:92
#: ../imagery/i.ortho.photo/i.ortho.rectify/readcell.c:100
@@ -26836,9 +23876,7 @@
#: ../raster/r.support/main.c:56
msgid "Allows creation and/or modification of raster map layer support files."
-msgstr ""
-"Permite la creación y/o modificación de archivos de soporte de capas de "
-"mapas ráster."
+msgstr "Permite la creación y/o modificación de archivos de soporte de capas de mapas ráster."
#: ../raster/r.support/main.c:80
msgid "Text to use for map data units"
@@ -26849,25 +23887,21 @@
msgstr "Texto a usar para datum vertical del mapa"
#: ../raster/r.support/main.c:129
-#, fuzzy
msgid "Update statistics (histogram, range)"
-msgstr "¿Actualizar las estadísticas (histograma, rango) de [%s]?"
+msgstr "Actualizar estadísticas (histograma, rango)"
#: ../raster/r.support/main.c:133
-#, fuzzy
msgid "Create/reset the null file"
-msgstr "Crear archivo 3D"
+msgstr "Crear/reiniciar el archivo nulo"
#: ../raster/r.support/main.c:137
-#, fuzzy
msgid "Delete the null file"
-msgstr "No se puede abrir el archivo de firmas"
+msgstr "Eliminar el archivo nulo"
#: ../raster/r.support/main.c:147 ../raster/r.category/main.c:130
#, c-format
msgid "Raster map <%s> not found in current mapset"
-msgstr ""
-"No se ha encontrado el mapa ráster <%s> en el directorio de mapas actual"
+msgstr "No se ha encontrado el mapa ráster <%s> en el directorio de mapas actual"
#: ../raster/r.support/main.c:273 ../raster/r.support/main.c:301
#, c-format
@@ -26907,100 +23941,85 @@
"\n"
#: ../raster/r.volume/main.c:77
-#, fuzzy
msgid "volume"
-msgstr "Columnas"
+msgstr "volumen"
#: ../raster/r.volume/main.c:78 ../raster/r.clump/main.c:57
-#, fuzzy
msgid "clumps"
-msgstr "%d grupos."
+msgstr "grupos"
#: ../raster/r.volume/main.c:80
msgid "Calculates the volume of data \"clumps\"."
-msgstr ""
+msgstr "Calcula el volumen de \"agrupamiento\" de los datos"
#: ../raster/r.volume/main.c:81
-#, fuzzy
-msgid ""
-"Optionally produces a GRASS vector points map containing the calculated "
-"centroids of these clumps."
-msgstr ""
-"Calcula el volumen de datos \"clumps\" GRASS vectorial puntos centroides."
+msgid "Optionally produces a GRASS vector points map containing the calculated centroids of these clumps."
+msgstr "Opcionalmente produce un mapa vectorial GRASS de puntos que contiene los centroides calculados de estos grupos."
#: ../raster/r.volume/main.c:86
-#, fuzzy
-msgid ""
-"Name of input raster map representing data that will be summed within clumps"
-msgstr ""
-"El mapa raster existente representa los datos que se sumarán dentro de clumps"
+msgid "Name of input raster map representing data that will be summed within clumps"
+msgstr "Nombre del mapa ráster de entrada que representa datos que serán juntados dentro de grupos"
#: ../raster/r.volume/main.c:92
-#, fuzzy
msgid "Name of input clump raster map"
-msgstr "Nombre del mapa ráster de entrada"
+msgstr "Nombre de mapa ráster de entrada de grupos"
#: ../raster/r.volume/main.c:93
-msgid ""
-"Preferably the output of r.clump. If no clump map is given than MASK is used."
-msgstr ""
+msgid "Preferably the output of r.clump. If no clump map is given than MASK is used."
+msgstr "De preferencia la salida de r.clump. Si no se da un mapa de agrupamiento entonces se usa MASK."
#: ../raster/r.volume/main.c:99
-#, fuzzy
msgid "Name for output vector points map to contain clump centroids"
-msgstr "Nombre del mapa vectorial de salida que contiene un corte mínimo"
+msgstr "Nombre para mapa vectorial de puntos de salida que contiene los centroides de los grupos"
#: ../raster/r.volume/main.c:104 ../raster/r.report/parse.c:63
-#, fuzzy
msgid "Name for output file to hold the report"
-msgstr "Nombre de un archivo de salida para albergar el informe"
+msgstr "Nombre para archivo de salida que contendrá el reporte"
#: ../raster/r.volume/main.c:106 ../raster/r.report/parse.c:65
-#, fuzzy
msgid "If no output file given report is printed to standard output"
-msgstr "Si no se da lee de la entrada estándar"
+msgstr "Si no se da ningún archivo de salida el reporte es mostrado en la salida estándar"
#: ../raster/r.volume/main.c:110
-#, fuzzy
msgid "Generate unformatted report (items separated by colon)"
-msgstr "Generar informe sin formato"
+msgstr "Generar reporte sin formato (elementos separados por comas)"
#: ../raster/r.volume/main.c:143
-msgid ""
-"No MASK found. If no clump map is given than the MASK is required. You need "
-"to define a clump raster map or create a MASK by r.mask command."
-msgstr ""
+msgid "No MASK found. If no clump map is given than the MASK is required. You need to define a clump raster map or create a MASK by r.mask command."
+msgstr "No se encontró MÁSCARA. Si no se da un mapa de agrupamiento entonces se necesita MÁSCARA. Usted necesita definir mapa ráster de agrupamiento o crear una MÁSACARA con el comando r.mask."
#: ../raster/r.volume/main.c:145
msgid "No clump map given, using MASK"
-msgstr ""
+msgstr "No se dio mapa de agrupamiento, usando MÁSCARA"
#: ../raster/r.volume/main.c:198
#, c-format
msgid "Invalid category value %d (max=%d): row=%d col=%d"
-msgstr ""
+msgstr "Valor de categoría no válido %d (máx=%d): fila=%d columna=%d"
#: ../raster/r.volume/main.c:231
-#, fuzzy, c-format
+#, c-format
msgid "Creating vector point map <%s>..."
-msgstr "Parcheando el mapa vectorial <%s@%s>..."
+msgstr "Creando mapa vectorial de puntos <%s>"
#: ../raster/r.volume/main.c:233
-#, fuzzy, c-format
+#, c-format
msgid "From '%s' on raster map <%s> using clumps from <%s>"
-msgstr "No se puede crear el mapa ráster <%s> usando el controlador <%s>"
+msgstr "Desde '%s' en mapa ráster <%s> usando grupos desde <%s>"
#: ../raster/r.volume/main.c:266
-#, c-format
+#, fuzzy
msgid ""
"\n"
"Volume report on data from <%s> using clumps on <%s> raster map"
msgstr ""
+"\n"
+"Reporte de volumen en dato"
#: ../raster/r.volume/main.c:270
#, c-format
msgid "Category Average Data # Cells Centroid Total\n"
-msgstr ""
+msgstr "Categoría Promedio Datos # Celdas Centroide Total\n"
#: ../raster/r.volume/main.c:272
#, c-format
@@ -27008,128 +24027,76 @@
msgstr ""
#: ../raster/r.volume/main.c:318
-#, fuzzy
msgid "Total Volume"
-msgstr "Volúmenes"
+msgstr "Volumen total"
#: ../raster/r.spread/main.c:106 ../raster/r.ros/main.c:213
#: ../raster/r.spreadpath/main.c:89
-#, fuzzy
msgid "fire"
-msgstr "Líneas"
+msgstr "fuego"
#: ../raster/r.spread/main.c:107 ../raster/r.ros/main.c:214
-#, fuzzy
msgid "spread"
-msgstr "leer"
+msgstr "propagación"
#: ../raster/r.spread/main.c:108 ../raster/r.ros/main.c:216
#: ../raster/r.lake/main.c:152
msgid "hazard"
-msgstr ""
+msgstr "riesgo"
#: ../raster/r.spread/main.c:109 ../raster/r.ros/main.c:217
#: ../raster/r.topmodel/main.c:53 ../raster/r.sim/r.sim.sediment/main.c:118
#: ../raster/r.sim/r.sim.water/main.c:118
msgid "model"
-msgstr ""
+msgstr "modelo"
#: ../raster/r.spread/main.c:111
msgid "Simulates elliptically anisotropic spread."
msgstr "Simula propagación elíptica anisotrópica."
#: ../raster/r.spread/main.c:113
-#, fuzzy
-msgid ""
-"Generates a raster map of the cumulative time of spread, given raster maps "
-"containing the rates of spread (ROS), the ROS directions and the spread "
-"origins. It optionally produces raster maps to contain backlink UTM "
-"coordinates for tracing spread paths. Usable for fire spread simulations."
-msgstr ""
-"Simula propagación anisotrópica elípticamente en una ventana de gráficos y "
-"general un mapa ráster del tiempo acumulado de propagación, dados mapas "
-"ráster que contengan las tasas de propagación (ROS), las direcciones de ROS "
-"y los orígenes de propagación."
+msgid "Generates a raster map of the cumulative time of spread, given raster maps containing the rates of spread (ROS), the ROS directions and the spread origins. It optionally produces raster maps to contain backlink UTM coordinates for tracing spread paths. Usable for fire spread simulations."
+msgstr "Genera un mapa ráster del tiempo acumulativo de propagación, a partir de mapas ráster dados que contengan las tasas de propagación (ROS), las direcciones de ROS y los orígenes de propagación. Opcionalmente produce mapas ráster que contienen coordenadas UTM vínculo de retroceso para seguir las rutas de dispersión. Es utilizado para simulaciones de propagación de fuego."
#: ../raster/r.spread/main.c:127
-#, fuzzy
msgid "Raster map containing base ROS (cm/min)"
-msgstr "Nombre de mapa ráster que contenga Tasa de Propagación BASE /cm/min)"
+msgstr "Mapa ráster que contiene la tasa de propagación (ROS) básica (cm/min)"
#: ../raster/r.spread/main.c:129
-msgid ""
-"Name of an existing raster map layer in the user's current mapset search "
-"path containing the ROS values in the directions perpendicular to maximum "
-"ROSes' (cm/minute). These ROSes are also the ones without the effect of "
-"directional factors."
-msgstr ""
-"Nombre de la capa del mapa raster en la ruta de búsqueda del directorio de "
-"mapas del usuario actual que contiene los valores ROS en las direcciones "
-"perpendicular al máximos ROSes' (cm/minuto). Estos ROSes son también los que "
-"no tienen el efecto de los factores direccionales."
+msgid "Name of an existing raster map layer in the user's current mapset search path containing the ROS values in the directions perpendicular to maximum ROSes' (cm/minute). These ROSes are also the ones without the effect of directional factors."
+msgstr "Nombre de la capa del mapa raster en la ruta de búsqueda del directorio de mapas del usuario actual que contiene los valores ROS en las direcciones perpendicular al máximos ROSes' (cm/minuto). Estos ROSes son también los que no tienen el efecto de los factores direccionales."
#: ../raster/r.spread/main.c:141
-#, fuzzy
msgid "Raster map containing maximal ROS (cm/min)"
+msgstr "Mapa ráster que contiene la tasa de propagación máxima (ROS) (cm/min)"
#: ../raster/r.spread/main.c:143
-msgid ""
-"path containing the maximum ROS values (cm/minute)."
-msgstr ""
-"mapas del usuario actual que contiene los valores máximos de ROS (cm/minuto)."
+msgid "Name of an existing raster map layer in the user's current mapset search path containing the maximum ROS values (cm/minute)."
+msgstr "Nombre de la capa del mapa raster en la ruta de búsqueda del directorio de mapas del usuario actual que contiene los valores máximos de ROS (cm/minuto)."
#: ../raster/r.spread/main.c:153
-#, fuzzy
msgid "Raster map containing directions of maximal ROS (degree)"
-msgstr ""
-"Nombre de mapa ráster que contenga Direcciones de máxima Tasa de Propagación "
-"ROS (grados)"
+msgstr "Mapa ráster que contiene las direcciones de la máxima tasa de propagación (ROS) (grados)"
#: ../raster/r.spread/main.c:155
-msgid ""
-"path containing directions of the maximum ROSes, clockwise from north "
-"(degree)."
-msgstr ""
-"mapas del usuario actual que contiene los valores máximos de ROSes, en "
-"dirección de las agujas del reloj desde el norte (grado)."
+msgid "Name of an existing raster map layer in the user's current mapset search path containing directions of the maximum ROSes, clockwise from north (degree)."
+msgstr "Nombre de la capa del mapa raster en la ruta de búsqueda del directorio de mapas del usuario actual que contiene los valores máximos de ROSes, en dirección de las agujas del reloj desde el norte (grado)."
#: ../raster/r.spread/main.c:166
-#, fuzzy
msgid "Raster map containing starting sources"
-msgstr "Nombre del mapa raster que contiene fuentes STARTing"
+msgstr "Mapa ráster que contiene las fuentes iniciales"
#: ../raster/r.spread/main.c:168
-msgid ""
-"path containing starting locations of the spread phenomenon. Any positive "
-"integers in this map are recognized as starting sources (seeds)."
-msgstr ""
-"Nombre de un mapa raster existente en la ruta de búsqueda del directorio de "
-"mapas del usuario que contiene las localizaciones de inicio del fenómeno de "
-"dispersión. Cualquier entero positivo en el mapa es reconocido como fuente "
-"de inicio (seeds)."
+msgid "Name of an existing raster map layer in the user's current mapset search path containing starting locations of the spread phenomenon. Any positive integers in this map are recognized as starting sources (seeds)."
+msgstr "Nombre de un mapa raster existente en la ruta de búsqueda del directorio de mapas del usuario que contiene las localizaciones de inicio del fenómeno de dispersión. Cualquier entero positivo en el mapa es reconocido como fuente de inicio (seeds)."
#: ../raster/r.spread/main.c:179
-#, fuzzy
msgid "Raster map containing maximal spotting distance (m, required with -s)"
-msgstr ""
-"Nombre del mapa raster que contienen la distancia máxima SPOTting (m) "
-"(necesaria w/ -s)"
+msgstr "Nombre del mapa raster que contienen la distancia máxima de detección (m, necesaria con -s)"
#: ../raster/r.spread/main.c:181
-#, fuzzy
-msgid ""
-"path containing the maximum potential spotting distances (meters)."
-msgstr ""
-"mapas del usuario que contiene la distancia potencial máxima de ....."
-"spotting.. (metros)."
+msgid "Name of an existing raster map layer in the user's current mapset search path containing the maximum potential spotting distances (meters)."
+msgstr "Nombre de un mapa raster existente en la ruta de búsqueda del Directorio de mapas del usuario que contiene la distancia potencial máxima de detección (metros)."
#: ../raster/r.spread/main.c:191
#, fuzzy
@@ -27137,164 +24104,104 @@
msgstr "Nombre ráster mínimo requerido"
#: ../raster/r.spread/main.c:193 ../raster/r.ros/main.c:279
-msgid ""
-"path containing wind velocities at half of the average flame height (feet/"
-"minute)."
-msgstr ""
-"mapas del usuario que contiene la velocidad del viento a la mitad de la "
-"altura promedio de la flama (pies/minuto)."
+msgid "Name of an existing raster map layer in the user's current mapset search path containing wind velocities at half of the average flame height (feet/minute)."
+msgstr "Nombre de un mapa raster existente en la ruta de búsqueda del directorio de mapas del usuario que contiene la velocidad del viento a la mitad de la altura promedio de la flama (pies/minuto)."
#: ../raster/r.spread/main.c:203
#, fuzzy
-msgid ""
-"Raster map containing fine fuel moisture of the cell receiving a spotting "
-"firebrand (%, required with -s)"
-msgstr "Nombre ráster requerido"
+msgid "Raster map containing fine fuel moisture of the cell receiving a spotting firebrand (%, required with -s)"
+msgstr "Mapa ráster que contiene humedad de combustible fino de la celda "
#: ../raster/r.spread/main.c:205 ../raster/r.ros/main.c:240
-msgid ""
-"path containing the 1-hour (<.25\") fuel moisture (percentage content "
-"multiplied by 100)."
-msgstr ""
-"mapas del usuario que contiene la humedad del combustible a 1 hora (<.25\") "
-"(procentaje de contenido multiplicado por 100)."
+msgid "Name of an existing raster map layer in the user's current mapset search path containing the 1-hour (<.25\") fuel moisture (percentage content multiplied by 100)."
+msgstr "Nombre de un mapa raster existente en la ruta de búsqueda del directorio de mapas del usuario que contiene la humedad del combustible a 1 hora (<.25\") (procentaje de contenido multiplicado por 100)."
#: ../raster/r.spread/main.c:215
-#, fuzzy
msgid "Basic sampling window size needed to meet certain accuracy (3)"
-msgstr ""
-"TAMAÑO de ventana de muestreo básico necesario para conseguir cierta "
-"precisión (3)"
+msgstr "Tamaño básico de ventana de muestreo necesario para alcanzar cierta exactitud (3)"
#: ../raster/r.spread/main.c:217
-msgid ""
-"An odd integer ranging 3 - 15 indicating the basic sampling window size "
-"within which all cells will be considered to see whether they will be "
-"reached by the current spread cell. The default number is 3 which means a "
-"3x3 window."
-msgstr ""
+msgid "An odd integer ranging 3 - 15 indicating the basic sampling window size within which all cells will be considered to see whether they will be reached by the current spread cell. The default number is 3 which means a 3x3 window."
+msgstr "Un entero impar entre 3 - 15 que indique el tamaño básico de la ventana de muestreo en la cual cada celda será considerada para ver si será alcanzada por la celda de propagación actual. El número predeterminado es 3 lo que indica una ventana de 3x3."
#: ../raster/r.spread/main.c:227
-#, fuzzy
msgid "Sampling density for additional computing (range: 0.0 - 1.0 (0.5))"
-msgstr ""
-"DENSIDAD de muestreo para cálculos adicionales (rango: 0.0 - 1.0 (0.5))"
+msgstr "Densidad de muestreo para cálculos adicionales (rango: 0.0 - 1.0 (0.5))"
#: ../raster/r.spread/main.c:229
-msgid ""
-"A decimal number ranging 0.0 - 1.0 indicating additional sampling cells will "
-"be considered to see whether they will be reached by the current spread "
-"cell. The closer to 1.0 the decimal number is, the longer the program will "
-"run and the higher the simulation accuracy will be. The default number is "
-"0.5."
-msgstr ""
+msgid "A decimal number ranging 0.0 - 1.0 indicating additional sampling cells will be considered to see whether they will be reached by the current spread cell. The closer to 1.0 the decimal number is, the longer the program will run and the higher the simulation accuracy will be. The default number is 0.5."
+msgstr "Un número decimal que esté en el rango de 0.0 - 1.0 que indique celdas muestrales adicionales será considerado para ver si éstas serán alcanzadas por la celda de propagación. Mientras más cercano a 1.0 sea el número decimal, más tiempo se ejecutará el programa y mayor exactitud tendrá. El número predeterminado es 0.5. "
#: ../raster/r.spread/main.c:241
-#, fuzzy
msgid "Initial time for current simulation (0) (min)"
-msgstr "HORA INICIAL para la simulación actual (0) (mínimo)"
+msgstr "Tiempo inicial para simulación actual (0) (mínimo)"
#: ../raster/r.spread/main.c:243
-msgid ""
-"A non-negative number specifying the initial time for the current spread "
-"simulation (minutes). This is useful when multiple phase simulation is "
-"conducted. The default time is 0."
-msgstr ""
+msgid "A non-negative number specifying the initial time for the current spread simulation (minutes). This is useful when multiple phase simulation is conducted. The default time is 0."
+msgstr "Un número no negativo que especifique el tiempo inicial para la simulación de propagación actual (minutos). Esto es útil cuando se hace una simulación de fases múltiples. El tiempo predeterminado es 0."
#: ../raster/r.spread/main.c:252
msgid "Simulating time duration LAG (fill the region) (min)"
msgstr "Simulación tiempo de duración LAG (llenar la región) (min)"
#: ../raster/r.spread/main.c:254
-msgid ""
-"A non-negative integer specifying the simulating duration time lag "
-"(minutes). The default is infinite, but the program will terminate when the "
-"current geographic region/mask has been filled. It also controls the "
-"computational time, the shorter the time lag, the faster the program will "
-"run."
-msgstr ""
+msgid "A non-negative integer specifying the simulating duration time lag (minutes). The default is infinite, but the program will terminate when the current geographic region/mask has been filled. It also controls the computational time, the shorter the time lag, the faster the program will run."
+msgstr "Un entero no negativo que especifique la duración del lapso de tiempo (minutos). El predeterminado es infinito, pero el programa determinará cuando la región geográfica/máscara actual estén llenos. También controla el tiempo computacional, mientras más corto sea el lapso de tiempo, más rápido correrá el programa."
#: ../raster/r.spread/main.c:266
#, fuzzy
msgid "Name of raster map as a display backdrop"
-msgstr "Nombre ráster mostrar"
+msgstr "Nombre de mapa ráster "
#: ../raster/r.spread/main.c:268
-msgid ""
-"path to be used as the background on which the \"live\" movement will be "
-"shown."
-msgstr ""
-"mapas del usuario que será usado como fondo en el cual el movimiento \"live"
-"\" será mostrado."
+msgid "Name of an existing raster map layer in the user's current mapset search path to be used as the background on which the \"live\" movement will be shown."
+msgstr "Nombre de un mapa raster existente en la ruta de búsqueda del directorio de mapas del usuario que será usado como fondo en el cual el movimiento \"live\" será mostrado."
#: ../raster/r.spread/main.c:279
-#, fuzzy
msgid "Raster map to contain output spread time (min)"
-msgstr ""
-"Nombre del mapa ráster para contener el tiempo de propagación de SALIDA (min)"
+msgstr "Nombre de mapa ráster que contendrá el tiempo de propagación de salida (minutos)"
#: ../raster/r.spread/main.c:281
-msgid ""
-"Name of the new raster map layer to contain the results of the cumulative "
-"spread time needed for a phenomenon to reach each cell from the starting "
-"sources (minutes)."
-msgstr ""
+msgid "Name of the new raster map layer to contain the results of the cumulative spread time needed for a phenomenon to reach each cell from the starting sources (minutes)."
+msgstr "Nombre de nueva capa de mapa ráster que contendrá los resultados del tiempo acumulado de propagación necesario para que un fenómeno alcance todas las celdas de las fuentes iniciales (minutos)."
#: ../raster/r.spread/main.c:291
#, fuzzy
msgid "Name of raster map to contain X back coordinates"
-msgstr "Nombre del mapa raster que contiene coordenadas X_BACK"
+msgstr "Nombre de mapa ráster que contendrá "
#: ../raster/r.spread/main.c:293
-msgid ""
-"Name of the new raster map layer to contain the results of backlink "
-"information in UTM easting coordinates for each cell."
-msgstr ""
+msgid "Name of the new raster map layer to contain the results of backlink information in UTM easting coordinates for each cell."
+msgstr "Nombre de nueva capa de mapa ráster que contendrá los resultados de la información backlink en coordenadas UTM este para cada celda."
#: ../raster/r.spread/main.c:303
#, fuzzy
msgid "Name of raster map to contain Y back coordinates"
-msgstr "Nombre del mapa raster que contendrá las coordenadas Y_BACK"
#: ../raster/r.spread/main.c:305
-msgid ""
-"information in UTM northing coordinates for each cell."
-msgstr ""
+msgid "Name of the new raster map layer to contain the results of backlink information in UTM northing coordinates for each cell."
+msgstr "Nombre de nueva capa de mapa ráster que contendrá los resultados de la información backlink en coordenadas UTM norte para cada celda."
#: ../raster/r.spread/main.c:312
msgid "DISPLAY 'live' spread process on screen"
msgstr "MOSTRAR proceso de propagación 'en directo' en pantalla"
#: ../raster/r.spread/main.c:314
-msgid ""
-"Display the 'live' simulation on screen. A graphics window must be opened "
-"and selected before using this option."
-msgstr ""
+msgid "Display the 'live' simulation on screen. A graphics window must be opened and selected before using this option."
+msgstr "Mostrar la simulación 'live' en la pantalla. Debe estar abierta y seleccionada una ventana gráfica antes de usar esta opción."
#: ../raster/r.spread/main.c:320
msgid "Consider spotting effect (for wildfires)"
-msgstr ""
+msgstr "Considerar efecto de detección (para incendios no controlados)"
#: ../raster/r.spread/main.c:324
-#, fuzzy
msgid "Use start raster map values in output spread time raster map"
-msgstr ""
+msgstr "Usar valores iniciales de mapa ráster en el mapa ráster de tiempo de propagación"
#: ../raster/r.spread/main.c:326
-msgid ""
-"Designed to be used with output of previous run of r.spread when computing "
-"spread iteratively. The values in start raster map are considered as time. "
-"Allowed values in raster map are from zero to the value of init_time option. "
-"If not enabled, init_time is used in the area of start raster map"
-msgstr ""
+msgid "Designed to be used with output of previous run of r.spread when computing spread iteratively. The values in start raster map are considered as time. Allowed values in raster map are from zero to the value of init_time option. If not enabled, init_time is used in the area of start raster map"
+msgstr "Diseñado para se usado con salida de ejecución previa de r.spread cuando se calcula la propagación de manera iterativa. Los valores en mapa ráster inicial serán considerados como tiempo. Los valores permitidos en mapa ráster son desde cero al valor de la opción init_time. Si no está disponible, init_time es usado en el área de mapa ráster inicial"
#: ../raster/r.spread/main.c:502
msgid "Reading inputs..."
@@ -27303,12 +24210,12 @@
#: ../raster/r.spread/main.c:543
#, c-format
msgid "Maximum of start raster map is grater than init_time (%d > %d)"
-msgstr ""
+msgstr "Máximo de mapa ráster inicial es mayor que init_time (%d > %d)"
#: ../raster/r.spread/main.c:547
#, c-format
msgid "Minimum of start raster map is less than zero (%d < 0)"
-msgstr ""
+msgstr "Mínimo de mapa ráster es menor a cero (%d < 0)"
#: ../raster/r.spread/main.c:555
#, c-format
@@ -27316,28 +24223,20 @@
msgstr "Leyendo %s..."
#: ../raster/r.series.accumulate/main.c:84
-#, fuzzy
-msgid ""
-"Makes each output cell value a accumulationfunction of the values assigned "
-"to the corresponding cells in the input raster map layers."
-msgstr ""
-"Hace cada valor de celda de salida una función de los valores asignados a "
-"las celdas correspondientes en las capas de mapa ráster de entrada."
+msgid "Makes each output cell value a accumulationfunction of the values assigned to the corresponding cells in the input raster map layers."
+msgstr "Hace que cada valor de celda de salida sea una función de acumulación de los valores asignados a las celdas correspondientes en las capas de mapa ráster de entrada."
#: ../raster/r.series.accumulate/main.c:90
-#, fuzzy
msgid "Existing map to be added to output"
-msgstr "Escribiendo site en la salida..."
+msgstr "Mapa existente que será añadido a la salida"
#: ../raster/r.series.accumulate/main.c:98
-#, fuzzy
msgid "Input file with raster map names, one per line"
-msgstr "Mapa vectorial de entrada que contiene líneas"
+msgstr "Archivo con nombres de mapas ráster de entrada, uno por línea"
#: ../raster/r.series.accumulate/main.c:109
-#, fuzzy
msgid "Scale factor for input"
-msgstr "Factor de escala para la elevación"
+msgstr "Factor de escalamiento para entrada"
#: ../raster/r.series.accumulate/main.c:116
#, fuzzy
@@ -27345,15 +24244,12 @@
msgstr "Factor de escala para coordenadas X"
#: ../raster/r.series.accumulate/main.c:121
-msgid ""
-"The raster map specifying the lower accumulation limit, also called baseline"
-msgstr ""
+msgid "The raster map specifying the lower accumulation limit, also called baseline"
+msgstr "El mapa ráster que especifica el límite mínimo de acumulación, también llamado línea base"
#: ../raster/r.series.accumulate/main.c:126
-msgid ""
-"The raster map specifying the upper accumulation limit, also called cutoff. "
-"Only applied to BEDD computation."
-msgstr ""
+msgid "The raster map specifying the upper accumulation limit, also called cutoff. Only applied to BEDD computation."
+msgstr "El mapa ráster que especifica el límite superior de acumulación, también llamado cierre. Solamente es aplicado a cálculo BEDD."
#: ../raster/r.series.accumulate/main.c:132 ../raster/r.series/main.c:183
msgid "Ignore values outside this range"
@@ -27361,24 +24257,23 @@
#: ../raster/r.series.accumulate/main.c:139
msgid "Use these limits in case lower and/or upper input maps are not defined"
-msgstr ""
+msgstr "Use estos límites en caso de que los mapas de entrada lower y/o upper no estén definidos"
#: ../raster/r.series.accumulate/main.c:151
msgid "Growing Degree Days or Winkler indices"
-msgstr ""
+msgstr "Grado de días de crecimiento o índices Winkler"
#: ../raster/r.series.accumulate/main.c:152
-#, fuzzy
msgid "Mean: sum(input maps)/(number of input maps)"
-msgstr "El número mínimo de mapas ráster de entrada es dos"
+msgstr "Media: sum(mapas de entrada)/(cantidad de mapas de entrada)"
#: ../raster/r.series.accumulate/main.c:153
msgid "Biologically Effective Degree Days"
-msgstr ""
+msgstr "Grado de días biológicamente efectivos"
#: ../raster/r.series.accumulate/main.c:154
msgid "Huglin Heliothermal index"
-msgstr ""
+msgstr "Ídice heliotermal de Huglin"
#: ../raster/r.series.accumulate/main.c:163 ../raster/r.series/main.c:191
msgid "Do not keep files open"
@@ -27386,14 +24281,14 @@
#: ../raster/r.series.accumulate/main.c:167
msgid "Create a FCELL map (floating point single precision) as output"
-msgstr ""
+msgstr "Crear un mapa FCELL (punto flotante de precisión simple) como salida"
#: ../raster/r.series.accumulate/main.c:210
#: ../raster/r.series.interp/main.c:126 ../raster/r.series.interp/main.c:142
#: ../raster/r.series/main.c:208
-#, fuzzy, c-format
+#, c-format
msgid "Please specify %s= or %s="
-msgstr "Por favor, especifique la columna Z"
+msgstr "Por favor especifique %s= o %s="
#: ../raster/r.series.accumulate/main.c:255 ../raster/r.series/main.c:275
msgid "No raster map name found in input file"
@@ -27405,102 +24300,57 @@
msgstr "Mapa ráster no encontrado"
#: ../raster/r.series.accumulate/main.c:354
-#, fuzzy, c-format
+#, c-format
msgid "'%s'=%f must be > '%s'=%f"
-msgstr "'%s' debe ser > 0 para '%s'"
+msgstr "'%s'=%f debe ser > '%s'=%f"
#: ../raster/r.ros/main.c:215
-#, fuzzy
msgid "rate of spread"
-msgstr "Nombre del creador: %s"
+msgstr "relación de propagación"
#: ../raster/r.ros/main.c:218
-#, fuzzy
msgid "Generates rate of spread raster maps."
-msgstr "Genera estadísticas de superficie para capas de mapa ráster."
+msgstr "Genera mapas ráster de la tasa de propagación."
#: ../raster/r.ros/main.c:220
-#, fuzzy
-msgid ""
-"Generates three, or four raster map layers showing the base (perpendicular) "
-"rate of spread (ROS), the maximum (forward) ROS, the direction of the "
-"maximum ROS, and optionally the maximum potential spotting distance for fire "
-"spread simulation."
-msgstr ""
-"Genera tres o cuatro capas de mapa ráster mostrando 1) la tasa de "
-"propagación (ROS) básica (perpendicular), 2) la ROS máxima (hacia delante), "
-"3) la dirección de la máxima ROS y (opcional) 4) la distancia spotting "
-"potencial máxima."
+msgid "Generates three, or four raster map layers showing the base (perpendicular) rate of spread (ROS), the maximum (forward) ROS, the direction of the maximum ROS, and optionally the maximum potential spotting distance for fire spread simulation."
+msgstr "Genera tres, o cuatro capas de mapa ráster mostrando la tasa de propagación (ROS) básica (perpendicular), la ROS máxima (hacia delante), la dirección de la máxima ROS y (opcional) la distancia de detección potencial máxima."
#: ../raster/r.ros/main.c:227
-#, fuzzy
msgid "Raster map containing fuel models"
-msgstr "Nombre del mapa ráster que contiene MODELOS de combustible"
+msgstr "Mapa que contiene los modelos de combustibles"
#: ../raster/r.ros/main.c:229
-msgid ""
-"path containing the standard fuel models defined by the USDA Forest Service. "
-"Valid values are 1-13; other numbers are recognized as barriers by r.ros."
-msgstr ""
-"El nombre de un mapa ráster existente en la ruta de búsqueda del directorio "
-"de mapas del usuario que contiene los modelos estandar de combustibles "
-"definidos por la USDA Forest Service. Los valores válidos son 1-13; otros "
-"números son reconocidos como barreras por r.ros."
+msgid "Name of an existing raster map layer in the user's current mapset search path containing the standard fuel models defined by the USDA Forest Service. Valid values are 1-13; other numbers are recognized as barriers by r.ros."
+msgstr "El nombre de un mapa ráster existente en la ruta de búsqueda del directorio de mapas del usuario que contiene los modelos estandar de combustibles definidos por la USDA Forest Service. Los valores válidos son 1-13; otros números son reconocidos como barreras por r.ros."
#: ../raster/r.ros/main.c:238
-#, fuzzy
msgid "Raster map containing the 1-hour fuel moisture (%)"
-msgstr ""
-"Nombre del mapa ráster que contiene la HUMEDAD de combustible a 1-HORA (%)"
+msgstr "Mapa ráster que contiene la humeda del combustible de 1-hora (%)"
#: ../raster/r.ros/main.c:248
-#, fuzzy
msgid "Raster map containing the 10-hour fuel moisture (%)"
-msgstr ""
-"Nombre del mapa ráster que contiene la HUMEDAD de combustible a 10-HORAS (%)"
+msgstr "Mapa ráster que contiene la humeda del combustible de 10-horas (%)"
#: ../raster/r.ros/main.c:250
-msgid ""
-"path containing the 10-hour (.25-1\") fuel moisture (percentage content "
-msgstr ""
-"mapas del usuario que contiene la humedad del combustible a 10 horas "
-"(.25-1\") (procentaje de contenido multiplicado por 100)."
+msgid "Name of an existing raster map layer in the user's current mapset search path containing the 10-hour (.25-1\") fuel moisture (percentage content multiplied by 100)."
+msgstr "Nombre de un mapa raster existente en la ruta de búsqueda del directorio de mapas del usuario que contiene la humedad del combustible a 10 horas (.25-1\") (procentaje de contenido multiplicado por 100)."
#: ../raster/r.ros/main.c:258
-#, fuzzy
msgid "Raster map containing the 100-hour fuel moisture (%)"
-msgstr ""
-"Nombre del mapa ráster que contiene la HUMEDAD de combustible a 100-HORAS (%)"
+msgstr "Mapa ráster que contiene la humeda del combustible de 100-hora (%)"
#: ../raster/r.ros/main.c:260
-msgid ""
-"path containing the 100-hour (1-3\") fuel moisture (percentage content "
-msgstr ""
-"mapas del usuario que contiene la humedad del combustible a 100 horas "
-"(1-3\") (procentaje de contenido multiplicado por 100)."
+msgid "Name of an existing raster map layer in the user's current mapset search path containing the 100-hour (1-3\") fuel moisture (percentage content multiplied by 100)."
+msgstr "Nombre de un mapa raster existente en la ruta de búsqueda del directorio de mapas del usuario que contiene la humedad del combustible a 100 horas (1-3\") (procentaje de contenido multiplicado por 100)."
#: ../raster/r.ros/main.c:267
-#, fuzzy
msgid "Raster map containing live fuel moisture (%)"
-msgstr ""
-"Mapa ráster que contiene los valores usados para la longitud de las flechas"
+msgstr "Mapa ráster que contiene la humeda del combustible vivo (%)"
#: ../raster/r.ros/main.c:269
-msgid ""
-"path containing live (herbaceous) fuel moisture (percentage content "
-msgstr ""
-"mapas del usuario que contiene la humedad del combustible vivo (herbáceo) "
+msgid "Name of an existing raster map layer in the user's current mapset search path containing live (herbaceous) fuel moisture (percentage content multiplied by 100)."
+msgstr "Nombre de un mapa raster existente en la ruta de búsqueda del directorio de mapas del usuario que contiene la humedad del combustible vivo (herbáceo) (procentaje de contenido multiplicado por 100)."
#: ../raster/r.ros/main.c:277
#, fuzzy
@@ -27513,13 +24363,8 @@
msgstr "Nombre del mapa ráster que contiene las DIRECCIONES de viento (grados)"
#: ../raster/r.ros/main.c:289
-msgid ""
-"path containing wind direction, clockwise from north (degree)."
-msgstr ""
-"mapas del usuario que contiene la dirección del viento, en favor de las "
-"manecillas del reloj a partir del norte (grados)."
+msgid "Name of an existing raster map layer in the user's current mapset search path containing wind direction, clockwise from north (degree)."
+msgstr "Nombre de un mapa raster existente en la ruta de búsqueda del directorio de mapas del usuario que contiene la dirección del viento, en favor de las manecillas del reloj a partir del norte (grados)."
#: ../raster/r.ros/main.c:297
#, fuzzy
@@ -27527,128 +24372,90 @@
msgstr "Nombre del mapa ráster que contiene la PENDIENTE (grados)"
#: ../raster/r.ros/main.c:299
-msgid ""
-"path containing topographic slope (degree)."
-msgstr ""
-"mapas del usuario que contiene la pendiente topográfica (grados)."
+msgid "Name of an existing raster map layer in the user's current mapset search path containing topographic slope (degree)."
+msgstr "Nombre de un mapa raster existente en la ruta de búsqueda del directorio de mapas del usuario que contiene la pendiente topográfica (grados)."
#: ../raster/r.ros/main.c:307
#, fuzzy
msgid "Raster map containing aspect (degree, CCW from E)"
-msgstr ""
-"Nombre del mapa ráster que contiene la ORIENTACIÓN (grados, en sentido "
-"antihorario desde el Este)"
+msgstr "Nombre del mapa ráster que contiene la ORIENTACIÓN (grados, en sentido antihorario desde el Este)"
#: ../raster/r.ros/main.c:309
-msgid ""
-"path containing topographic aspect, counterclockwise from east (GRASS "
-"convention) in degrees."
-msgstr ""
-"mapas del usuario que contiene el aspecto topográfico, en contra de las "
-"manecillas del reloj a partir del este (convención de GRASS) en grados."
+msgid "Name of an existing raster map layer in the user's current mapset search path containing topographic aspect, counterclockwise from east (GRASS convention) in degrees."
+msgstr "Nombre de un mapa raster existente en la ruta de búsqueda del directorio de mapas del usuario que contiene el aspecto topográfico, en contra de las manecillas del reloj a partir del este (convención de GRASS) en grados."
#: ../raster/r.ros/main.c:317
-#, fuzzy
msgid "Raster map containing elevation (m, required for spotting)"
-msgstr "Nombre del mapa ráster que contiene la ELEVACIÓN (m) (requerido w/ -s)"
+msgstr "Nombre del mapa ráster que contiene la elevación (m, necesario para detección)"
#: ../raster/r.ros/main.c:319
-#, fuzzy
-msgid ""
-"path containing elevation (meters). Option is required from spotting "
-"distance computation (when spotting_distance option is provided)"
-msgstr ""
+msgid "Name of an existing raster map layer in the user's current mapset search path containing elevation (meters). Option is required from spotting distance computation (when spotting_distance option is provided)"
+msgstr "Nombre de una capa de mapa raster en la ruta de búsqueda del Directorio de mapas del usuario actual que contiene la elevación (metros). La opción es necesaria cuando para el cálculo de la distancia de detección (cuando la opción spotting_distance sea dada)"
#: ../raster/r.ros/main.c:328
-#, fuzzy
msgid "Output raster map containing base ROS (cm/min)"
+msgstr "Mapa ráster de salida que contiene la tasa de propagación (ROS) básica (cm/min)"
#: ../raster/r.ros/main.c:330
msgid "Base (perpendicular) rate of spread (ROS)"
-msgstr ""
+msgstr "Tasa de propagación (ROS) base (perpendicular)"
#: ../raster/r.ros/main.c:336
-#, fuzzy
msgid "Output raster map containing maximal ROS (cm/min)"
+msgstr "Mapa ráster de salida que contiene la tasa de propagación (ROS) máxima (cm/min)"
#: ../raster/r.ros/main.c:338
msgid "The maximum (forward) rate of spread (ROS)"
-msgstr ""
+msgstr "La tasa de propagación (ROS) máxima (hacia adelante)"
#: ../raster/r.ros/main.c:344
-#, fuzzy
msgid "Output raster map containing directions of maximal ROS (degree)"
-msgstr ""
-"ROS (grados)"
+msgstr "Mapa ráster de salida que contiene las direcciones de la máxima tasa de propagación (ROS) (grado)"
#: ../raster/r.ros/main.c:346
msgid "The direction of the maximal (forward) rate of spread (ROS)"
-msgstr ""
+msgstr "La dirección de la tasa de propagación (ROS) máxima (hacia adelante)"
#: ../raster/r.ros/main.c:352
-#, fuzzy
msgid "Output raster map containing maximal spotting distance (m)"
-msgstr ""
+msgstr "Nombre del mapa raster que contienen la distancia de detección máxima (m)"
#: ../raster/r.ros/main.c:354
-msgid ""
-"The maximal potential spotting distance (requires elevation raster map to be "
-"provided)."
-msgstr ""
+msgid "The maximal potential spotting distance (requires elevation raster map to be provided)."
+msgstr "La máxima distancia potencial de detección (requiere que se procea mapa ráster de elevación)."
#: ../raster/r.ros/main.c:373
-msgid ""
-"No dead fuel moisture is given. At least one of the 1-h, 10-h, 100-h "
-"moisture layers is required."
-msgstr ""
+msgid "No dead fuel moisture is given. At least one of the 1-h, 10-h, 100-h moisture layers is required."
+msgstr "No se dio humedad de combustible muerto. Se necesita al menos una de las capas 1-h, 10-h, 100-h."
#: ../raster/r.ros/main.c:397
#, c-format
-msgid ""
-"A wind direction layer should be given if the wind velocity layer <%s> has "
-"been given"
-msgstr ""
+msgid "A wind direction layer should be given if the wind velocity layer <%s> has been given"
+msgstr "Se debe dar una capa de dirección de viento si se ha dado una capa de velocidad de viento <%s>"
#: ../raster/r.ros/main.c:402
#, c-format
-msgid ""
-"A wind velocity layer should be given if the wind direction layer <%s> has "
-"been given"
-msgstr ""
-"Se debe dar una capa de velocidad del viento si se ha dado la capa de "
-"dirección del viento <%s>"
+msgid "A wind velocity layer should be given if the wind direction layer <%s> has been given"
+msgstr "Se debe dar una capa de velocidad del viento si se ha dado la capa de dirección del viento <%s>"
#: ../raster/r.ros/main.c:416
#, c-format
msgid "An aspect layer should be given if the slope layer <%s> has been given"
-msgstr ""
+msgstr "Se debe de dar una capa de elevación si se dio la capa de pendiente <%s>"
#: ../raster/r.ros/main.c:421
#, c-format
msgid "A slope layer should be given if the aspect layer <%s> has been given"
-msgstr ""
#: ../raster/r.ros/main.c:437
msgid "An elevation layer should be given if considering spotting"
-msgstr ""
+msgstr "Se debe dar una capa de elevación si se considera la detección"
#: ../raster/r.ros/main.c:873
-#, fuzzy, c-format
+#, c-format
msgid "Raster maps <%s>, <%s> and <%s> created."
-msgstr "El mapa ráster <%s> ya existe"
+msgstr "Mapas ráster <%s>, <%s> y <%s> creados."
#: ../raster/r.topmodel/topmodel.c:30
#, c-format
@@ -27665,33 +24472,28 @@
msgstr "Simula TOPMODEL que es un modelo hidrológico basado físicamente."
#: ../raster/r.topmodel/main.c:60
-#, fuzzy
msgid "Name of input TOPMODEL parameters file"
-msgstr "(E) Archivo de parámetros TOPMODEL"
+msgstr "Nombre de archivo de entrada de parámetros TOPMODEL"
#: ../raster/r.topmodel/main.c:65
-#, fuzzy
msgid "Name of input topographic index statistics file"
-msgstr "(S/E) Archivo de estadísticas de índice topográfico"
+msgstr "Nombre de archivo de entrada de estadísitcas de índices topográficos"
#: ../raster/r.topmodel/main.c:69
-#, fuzzy
msgid "Name of input rainfall and potential evapotranspiration data file"
-msgstr "(E) Archivo de datos de precipitaciones y evotranspiración potencial"
+msgstr "Nombre de archivo de datos de lluvia y evapotranspiración potencial"
#: ../raster/r.topmodel/main.c:76
msgid "Time step"
-msgstr ""
+msgstr "Paso de tiempo"
#: ../raster/r.topmodel/main.c:77
-#, fuzzy
msgid "Generate output for this time step"
-msgstr "Genera estadísticas para i.smap del mapa raster."
+msgstr "Generar salida para este paso de tiempo"
#: ../raster/r.topmodel/main.c:83
-#, fuzzy
msgid "Topographic index class"
-msgstr "Producir mapa de índice topográfico"
+msgstr "Clases de índices topográficos"
#: ../raster/r.topmodel/main.c:85
msgid "Generate output for this topographic index class"
@@ -27699,11 +24501,10 @@
#: ../raster/r.topmodel/main.c:92
msgid "Name of input topographic index raster map"
-msgstr ""
+msgstr "Nombre de mapa ráster de entrada de índice topográfico"
#: ../raster/r.topmodel/main.c:94
-msgid ""
-"Must be clipped to the catchment boundary. Used for generating outtopidxstats"
+msgid "Must be clipped to the catchment boundary. Used for generating outtopidxstats"
msgstr ""
#: ../raster/r.topmodel/main.c:96 ../raster/r.topmodel/main.c:106
@@ -27712,18 +24513,16 @@
msgstr "Pre procesamiento"
#: ../raster/r.topmodel/main.c:100
-#, fuzzy
msgid "Number of topographic index classes"
-msgstr "(E) Número de clases de índice topográfico"
+msgstr "Número de clases de índices topográficos"
#: ../raster/r.topmodel/main.c:102
msgid "Used for generating outtopidxstats"
msgstr ""
#: ../raster/r.topmodel/main.c:111
-#, fuzzy
msgid "Name for output topographic index statistics file"
+msgstr "Nombre para archivo de salida de estadísticas de índice topográfico"
#: ../raster/r.topmodel/main.c:113
msgid "Requires topidx and ntopidxclasses"
@@ -27734,14 +24533,14 @@
msgstr ""
#: ../raster/r.topmodel/main.c:150
-#, fuzzy, c-format
+#, c-format
msgid "%s must be greater than 1"
-msgstr "Alto (%d) tiene que ser mayor que 1"
+msgstr "%s debe ser mayor que 1"
#: ../raster/r.topmodel/main.c:154 ../raster/r.topmodel/main.c:157
#, c-format
msgid "Ignoring %s because %s is not specified"
-msgstr ""
+msgstr "Ignorando %s por que %s no está especificado"
#: ../raster/r.topmodel/file_io.c:56
#, c-format
@@ -27750,40 +24549,29 @@
#: ../raster/r.topmodel/infiltration.c:69
#: ../raster/r.topmodel/infiltration.c:108
-#, fuzzy, c-format
+#, c-format
msgid "Maximum number of iterations exceeded at timestep %d"
-msgstr " Número máximo de iteraciones: %d\n"
+msgstr "El número máximo de iteraciónes fue excedido en el paso de tiemp %d"
#: ../raster/r.coin/main.c:69
-msgid ""
-"Tabulates the mutual occurrence (coincidence) of categories for two raster "
-"map layers."
-msgstr ""
-"Tabula la ocurrencia mutua (coincidencia) de categorías de dos capas de mapa "
-"ráster."
+msgid "Tabulates the mutual occurrence (coincidence) of categories for two raster map layers."
+msgstr "Tabula la ocurrencia mutua (coincidencia) de categorías de dos capas de mapa ráster."
#: ../raster/r.coin/main.c:74
-#, fuzzy
msgid "Name of first input raster map"
-msgstr "Nombre del primer mapa ráster"
+msgstr "Nombre del primer mapa ráster de entrada"
#: ../raster/r.coin/main.c:78
-#, fuzzy
msgid "Name of second input raster map"
-msgstr "Nombre del segundo mapa ráster"
+msgstr "Nombre del segundo mapa ráster de entrada"
#: ../raster/r.coin/main.c:84
msgid "Unit of measure"
msgstr "Unidad de medida"
#: ../raster/r.coin/main.c:86
-msgid ""
-"c(ells), p(ercent), x(percent of category [column]), y(percent of category "
-"[row]), a(cres), h(ectares), k(square kilometers), m(square miles)"
-msgstr ""
-"c(eldas), p(orcentaje), x(porcentaje de categoría [columna]), y(porcentaje "
-"de categoría [fila]), a(cres), h(ectáreas), k(ilómetros cuadrados), m(illas "
-"cuadradas)"
+msgid "c(ells), p(ercent), x(percent of category [column]), y(percent of category [row]), a(cres), h(ectares), k(square kilometers), m(square miles)"
+msgstr "c(eldas), p(orcentaje), x(porcentaje de categoría [columna]), y(porcentaje de categoría [fila]), a(cres), h(ectáreas), k(ilómetros cuadrados), m(illas cuadradas)"
#: ../raster/r.coin/main.c:93
msgid "Wide report, 132 columns (default: 80)"
@@ -27820,7 +24608,6 @@
msgstr "Actualizando histogramas..."
#: ../raster/r.stats.quantile/main.c:111 ../raster/r.quantile/main.c:97
-#, fuzzy
msgid "Computing bins"
msgstr "Calculando bins"
@@ -27829,32 +24616,28 @@
msgstr ""
#: ../raster/r.stats.quantile/main.c:218 ../raster/r.quantile/main.c:179
-#, fuzzy
msgid "Sorting bins"
msgstr "Ordenando bins"
#: ../raster/r.stats.quantile/main.c:242
-#, fuzzy
msgid "Printing quantiles"
-msgstr "Preprocesando: tolerancias de quantización"
+msgstr "Mostrando cuantiles"
#: ../raster/r.stats.quantile/main.c:257 ../raster/r.quantile/main.c:189
msgid "Computing quantiles"
msgstr "Calculando quantiles"
#: ../raster/r.stats.quantile/main.c:294
-#, fuzzy
msgid "Generating reclass maps"
-msgstr "Cambiando el nombre de los mapas reclasificados"
+msgstr "Generado mapas reclasificados"
#: ../raster/r.stats.quantile/main.c:333
-#, fuzzy
msgid "Writing output maps"
-msgstr "Escribiendo mapa..."
+msgstr "Escribiendo mapas de salida"
#: ../raster/r.stats.quantile/main.c:391
msgid "Compute category quantiles using two passes."
-msgstr ""
+msgstr "Calcula categoría de cuantiles usando dos pasos."
#: ../raster/r.stats.quantile/main.c:401 ../raster/r.quantile/main.c:266
msgid "Number of quantiles"
@@ -27865,65 +24648,55 @@
msgstr "Lista de percentiles"
#: ../raster/r.stats.quantile/main.c:414 ../raster/r.quantile/main.c:280
-#, fuzzy
msgid "Number of bins to use"
msgstr "Número de bins a usar"
#: ../raster/r.stats.quantile/main.c:418
-#, fuzzy
msgid "Resultant raster map(s)"
-msgstr "Nombre para el mapa ráster resultante"
+msgstr "Mapa(s) ráster resultantes"
#: ../raster/r.stats.quantile/main.c:425 ../raster/r.stats.zonal/main.c:149
msgid "Create reclass map with statistics as category labels"
-msgstr ""
+msgstr "Crea mapa reclasificado con estadísticas como leyendas de categoría"
#: ../raster/r.stats.quantile/main.c:430
-#, fuzzy
msgid "Do not create output maps; just print statistics"
-msgstr "Nombre del mapa ráster del que calcular estadísticas"
+msgstr "No crear mapas de salida; solamente mostrar estadísticas"
#: ../raster/r.stats.quantile/main.c:442
-#, fuzzy, c-format
+#, c-format
msgid "Either -%c or %s= must be given"
-msgstr "Se deben facilitar -h o filas= y cols= "
+msgstr "Se deben dar -%c o -%s="
#: ../raster/r.stats.quantile/main.c:446 ../raster/r.out.bin/main.c:369
#: ../raster/r.in.bin/main.c:426 ../raster/r.in.bin/main.c:432
#: ../raster/r.neighbors/main.c:262
-#, fuzzy, c-format
+#, c-format
msgid "-%c and %s= are mutually exclusive"
-msgstr "weight= y -c son excluyentes mutuamente"
+msgstr "-%c and %s= son mutuamete excluyentes"
#: ../raster/r.stats.quantile/main.c:471
-#, fuzzy, c-format
+#, c-format
msgid "Number of quantiles (%d) does not match number of output maps (%d)"
-msgstr ""
-"El número de columnas definidas (%d) no concuerda con el número de columnas "
-"(%d) en la entrada"
+msgstr "Número de cuantiles (%d) no coincide con el número de mapas de salida (%d)"
#: ../raster/r.stats.quantile/main.c:480 ../raster/r.stats.zonal/main.c:181
-#, fuzzy
msgid "The base map must be an integer (CELL) map"
-msgstr "El mapa patrón debería ser un mapa de celdas binario 0/1"
+msgstr "El mapa base debe ser un mapa de enteros (CELL)"
#: ../raster/r.stats.quantile/main.c:483 ../raster/r.stats.zonal/main.c:184
-#, fuzzy, c-format
+#, c-format
msgid "Unable to read range of base map <%s>"
-msgstr "No se puede leer el intervalo fp del mapa ráster <%s>"
+msgstr "No ha sido posible leer rango de mapa base <%s>"
#: ../raster/r.stats.quantile/main.c:488
-#, fuzzy, c-format
+#, c-format
msgid "Base map <%s> has too many categories (max: %d)"
-msgstr "** <%s> tiene demasiadas firmas (el límite es 255)"
+msgstr "Mapa base <%s> tiene demasiadas categorías (máximo: %d)"
#: ../raster/r.category/main.c:55
-msgid ""
-"Manages category values and labels associated with user-specified raster map "
-"layers."
-msgstr ""
-"Administra valores de categoría y etiquetas asociados con las capas de mapa "
-"ráster especificadas por el usuario."
+msgid "Manages category values and labels associated with user-specified raster map layers."
+msgstr "Administra valores de categoría y etiquetas asociados con las capas de mapa ráster especificadas por el usuario."
#: ../raster/r.category/main.c:69
msgid "Comma separated value list"
@@ -27935,9 +24708,7 @@
#: ../raster/r.category/main.c:87
msgid "File containing category label rules (or \"-\" to read from stdin)"
-msgstr ""
-"Archivo que contiene reglas de etiquetas de categorías (o \"-\" para leer de "
-"stdin)"
+msgstr "Archivo que contiene reglas de etiquetas de categorías (o \"-\" para leer de stdin)"
#: ../raster/r.category/main.c:95
msgid "Default label or format string for dynamic labeling"
@@ -27953,7 +24724,7 @@
#: ../raster/r.category/main.c:107
msgid "Two pairs of category multiplier and offsets, for $1 and $2"
-msgstr ""
+msgstr "Dos pares de multiplicadores de categoría y compensación, para $1 y $2"
#: ../raster/r.category/main.c:148 ../raster/r.category/main.c:230
#: ../raster/r.report/parse.c:294 ../raster/r.mapcalc/map.c:233
@@ -27968,11 +24739,11 @@
msgstr "Tabla de categorías para <%s> establecida de <%s>"
#: ../raster/r.category/main.c:211
-#, c-format
+#, fuzzy
msgid ""
"Incorrect format of input rules. Check separators. Invalid line is:\n"
"%s"
-msgstr ""
+msgstr "Formato de reglas de entrada incorrecto"
#: ../raster/r.category/main.c:267
#, c-format
@@ -27981,9 +24752,7 @@
#: ../raster/r.category/main.c:283
msgid "The map is floating point! Ignoring cats list, using vals list"
-msgstr ""
-"¡El mapa es de coma flotante! Se ignora la lista de categorías, se usa la "
-"lista de valores"
+msgstr "¡El mapa es de coma flotante! Se ignora la lista de categorías, se usa la lista de valores"
#: ../raster/r.category/main.c:300
msgid "vals argument is required for floating point map!"
@@ -27995,19 +24764,16 @@
msgstr "Leyendo <%s> en <%s>"
#: ../raster/r.in.ascii/main.c:74
-#, fuzzy
msgid "Converts a GRASS ASCII raster file to binary raster map."
-msgstr "Convierte un archivo ráster ASCII en una capa de mapa ráster binaria."
+msgstr "Convierte un archivo ráster GRASS ASCII en un mapa ráster binario."
#: ../raster/r.in.ascii/main.c:89
-#, fuzzy
msgid "Default: CELL for integer values, DCELL for floating-point values"
-msgstr "Exportando ráster como valores de coma flotante"
+msgstr "Predeterminado: CELL para valores enteros, DCELL para valores de punto flotante"
#: ../raster/r.in.ascii/main.c:101 ../raster/r.in.ascii/main.c:106
-#, fuzzy
msgid "Default: read from header"
-msgstr "No se puede leer la cabecera BMP"
+msgstr "Predeterminado: leer desde encabezado"
#: ../raster/r.in.ascii/main.c:103
msgid "Multiplier for ASCII data"
@@ -28060,9 +24826,7 @@
#: ../raster/r.in.ascii/gethead.c:41
msgid "error reading the column and row dimension from the Surfer grid file"
-msgstr ""
-"error al leer las dimensiones de columnas y filas del archivo de cuadrícula "
-"Surfer"
+msgstr "error al leer las dimensiones de columnas y filas del archivo de cuadrícula Surfer"
#: ../raster/r.in.ascii/gethead.c:47
msgid "error reading the X range from the Surfer grid file"
@@ -28086,9 +24850,7 @@
#: ../raster/r.in.ascii/gethead.c:169
msgid "ignoring type filed in header, type is set on command line"
-msgstr ""
-"ignorando tipo rellenado en la cabecera. El tipo se establece en línea de "
-"comandos"
+msgstr "ignorando tipo rellenado en la cabecera. El tipo se establece en línea de comandos"
#: ../raster/r.in.ascii/gethead.c:176
msgid "illegal multiplier field: using 1.0"
@@ -28096,15 +24858,11 @@
#: ../raster/r.in.ascii/gethead.c:181
msgid "ignoring multiplier filed in header, multiplier is set on command line"
-msgstr ""
-"ignorando el multiplicador rellenado en la cabecera. El multiplicador se "
-"establece en línea de comandos"
+msgstr "ignorando el multiplicador rellenado en la cabecera. El multiplicador se establece en línea de comandos"
#: ../raster/r.in.ascii/gethead.c:189
msgid "ignoring null filed in header, null string is set on command line"
-msgstr ""
-"ignorando nulo rellenado en la cabecera. La cadena nula se establece en "
-"línea de comandos"
+msgstr "ignorando nulo rellenado en la cabecera. La cadena nula se establece en línea de comandos"
#: ../raster/r.in.ascii/gethead.c:218
msgid "error in ascii data format"
@@ -28126,46 +24884,38 @@
msgstr "el campo\"%s\" falta en la cabecera"
#: ../raster/r.series.interp/main.c:69
-msgid ""
-"Interpolates raster maps located (temporal or spatial) in between input "
-"raster maps at specific sampling positions."
+msgid "Interpolates raster maps located (temporal or spatial) in between input raster maps at specific sampling positions."
msgstr ""
#: ../raster/r.series.interp/main.c:79
-#, fuzzy
msgid "Data point position for each input map"
-msgstr "No se puede obtener información de la proyección del mapa de entrada"
+msgstr "Posición de puntos de datos para cada mapa de entrada"
#: ../raster/r.series.interp/main.c:84
-msgid ""
-"Input file with one input raster map name and data point position per line, "
-"field separator between name and sample point is |"
+msgid "Input file with one input raster map name and data point position per line, field separator between name and sample point is |"
msgstr ""
#: ../raster/r.series.interp/main.c:97
-#, fuzzy
msgid "Sampling point position for each output map"
-msgstr "Seleccionando elementos..."
+msgstr "Ubicación de putos de muestra para cada mapa de salida"
#: ../raster/r.series.interp/main.c:101
-msgid ""
-"Input file with one output raster map name and sample point position per "
-"line, field separator between name and sample point is |"
+msgid "Input file with one output raster map name and sample point position per line, field separator between name and sample point is |"
msgstr ""
#: ../raster/r.series.interp/main.c:111
msgid "Interpolation method, currently only linear interpolation is supported"
-msgstr ""
+msgstr "Método de interpolación, actualmente solo la interpolación lineal está soportada"
#: ../raster/r.series.interp/main.c:130 ../raster/r.series.interp/main.c:146
-#, fuzzy, c-format
+#, c-format
msgid "Please specify %s= and %s="
+msgstr "Por favor especifique %s= y %s="
#: ../raster/r.series.interp/main.c:180 ../raster/r.colors/edit_colors.c:186
-#, fuzzy, c-format
+#, c-format
msgid "Unable to open %s file <%s>"
-msgstr "No se puede abrir el archivo <%s>"
+msgstr "No ha sido posible abrir %s archivo <%s>"
#: ../raster/r.series.interp/main.c:213
#, c-format
@@ -28173,24 +24923,24 @@
msgstr ""
#: ../raster/r.series.interp/main.c:228 ../raster/r.series.interp/main.c:262
-#, fuzzy, c-format
+#, c-format
msgid "Preparing %s map <%s> at position %g"
-msgstr "Leyendo mapa ráster <%s en %s> ..."
+msgstr "Preparango %s mapa <%s> en posición %g"
#: ../raster/r.series.interp/main.c:232
-#, fuzzy, c-format
+#, c-format
msgid "No raster map name found in %s file <%s>"
-msgstr "Nombres de los archivos de entrada"
+msgstr "No se encontró ningún nombre de mapa ráster en %s archivo <%s>"
#: ../raster/r.series.interp/main.c:243
-#, fuzzy, c-format
+#, c-format
msgid "No %s raster map not found"
-msgstr "%s: mapa ráster de base no encontrado"
+msgstr "No se encontró mapa ráster %s"
#: ../raster/r.series.interp/main.c:250
-#, fuzzy, c-format
+#, c-format
msgid "The number of %s maps and %s point positions must be equal"
-msgstr "El número de mapas de entrada y de elevación no es igual"
+msgstr "El número de %s mapas y %s posiciones de puntos debe ser igual"
#: ../raster/r.series.interp/main.c:279
#, c-format
@@ -28199,34 +24949,25 @@
#: ../raster/r.series.interp/main.c:299
#, c-format
-msgid ""
-"map <%s> at position %g was not interpolated. Check the interpolation "
-"interval."
-msgstr ""
+msgid "map <%s> at position %g was not interpolated. Check the interpolation interval."
+msgstr "mapa <%s> en posición %g no fue interpolado. Revisar el intervalo de interpolación."
#: ../raster/r.series.interp/main.c:319
-#, fuzzy
msgid "At least 2 input maps are required for linear interpolation"
-msgstr "Asignando memoria para interpolación bilineal"
+msgstr "Son necesarios al menos 2 mapas para interpolación lineal"
#: ../raster/r.series.interp/main.c:337
#, c-format
msgid "Interpolate map <%s> at position %g in interval (%g;%g)"
-msgstr ""
+msgstr "Interpolar mapa <%s> en posición %g en intervalo (%g;%g)"
#: ../raster/r.in.xyz/main.c:167
-#, fuzzy
-msgid ""
-"Creates a raster map from an assemblage of many coordinates using univariate "
-"statistics."
-msgstr ""
-"Crear un mapa ráster a partir de un ensamblaje de muchas coordenadas usando "
-"estadísticas univariantes."
+msgid "Creates a raster map from an assemblage of many coordinates using univariate statistics."
+msgstr "Crea un mapa ráster a partir de un ensamblaje de muchas coordenadas usando estadísticas univariadas."
#: ../raster/r.in.xyz/main.c:171
msgid "ASCII file containing input data (or \"-\" to read from stdin)"
-msgstr ""
-"Archivo ASCII que contiene los datos de entrada (o \"-\" para leer de stdin)"
+msgstr "Archivo ASCII que contiene los datos de entrada (o \"-\" para leer de stdin)"
#: ../raster/r.in.xyz/main.c:198 ../raster/r.in.lidar/main.c:156
#, fuzzy
@@ -28270,8 +25011,7 @@
#: ../raster/r.in.xyz/main.c:206 ../raster/r.in.lidar/main.c:164
#, fuzzy
msgid "Coefficient of variance of point values in cell"
-msgstr ""
-"Calcula el coeficiente de varianza del área de parche en un mapa ráster"
+msgstr "Calcula el coeficiente de varianza del área de parche en un mapa ráster"
#: ../raster/r.in.xyz/main.c:207 ../raster/r.in.lidar/main.c:165
#, fuzzy
@@ -28294,48 +25034,38 @@
msgstr "El último punto será ignorado"
#: ../raster/r.in.xyz/main.c:247
-msgid ""
-"If a separate value column is given, this option refers to the z-coordinate "
-"column to be filtered by the zrange option"
+msgid "If a separate value column is given, this option refers to the z-coordinate column to be filtered by the zrange option"
msgstr ""
#: ../raster/r.in.xyz/main.c:258
-#, fuzzy
msgid "Number of header lines to skip at top of input file"
-msgstr ""
-"Número de líneas de la cabecera a saltar al comienzo del archivo de entrada "
-"(modo de puntos)"
+msgstr "Número de líneas de encabezado que se saltarán desde la línea de hata arriba del archivo de entrada"
#: ../raster/r.in.xyz/main.c:267 ../raster/r.in.xyz/main.c:275
#: ../raster/r.in.xyz/main.c:284 ../raster/r.in.xyz/main.c:292
#: ../raster/r.in.xyz/main.c:300
-#, fuzzy
msgid "Advanced Input"
-msgstr "Avanzado"
+msgstr "Entrada avanzada"
#: ../raster/r.in.xyz/main.c:274
msgid "Scale to apply to z data"
msgstr "Escala a aplicar a los datos Z"
#: ../raster/r.in.xyz/main.c:282
-#, fuzzy
msgid "Alternate column number of data values in input file"
-msgstr "Número de columna de los valores de datos en el archivo de entrada"
+msgstr "Número de columna alternativa de valores de datos en archivo de entrada"
#: ../raster/r.in.xyz/main.c:283
-#, fuzzy
msgid "If not given (or set to 0) the z-column data is used"
-msgstr "Si no se da se usa el nombre del mapa de entrada"
+msgstr "Si no se da (o establecido en 0) se usarán la columna de datos z"
#: ../raster/r.in.xyz/main.c:291
-#, fuzzy
msgid "Filter range for alternate value column data (min,max)"
-msgstr "Rango de filtrado para los datos Z (mínimo, máximo)"
+msgstr "Gama de filtros para datos de columna de valores alternativos (mín,máx)"
#: ../raster/r.in.xyz/main.c:299
-#, fuzzy
msgid "Scale to apply to alternate value column data"
-msgstr "Escala a aplicar a los datos Z"
+msgstr "Escalamiento a aplicar a columna de datos de valores alternativos"
#: ../raster/r.in.xyz/main.c:361
msgid "Please specify a reasonable column number."
@@ -28346,9 +25076,8 @@
msgstr "rangoz no válido"
#: ../raster/r.in.xyz/main.c:392
-#, fuzzy
msgid "Invalid vrange"
-msgstr "rangoz no válido"
+msgstr "vrange no válido"
#: ../raster/r.in.xyz/main.c:478 ../raster/r.in.lidar/point_binning.c:205
msgid "Unable to calculate percentile without the pth option specified!"
@@ -28356,32 +25085,24 @@
#: ../raster/r.in.xyz/main.c:490 ../raster/r.in.lidar/point_binning.c:217
msgid "Unable to calculate trimmed mean without the trim option specified!"
-msgstr ""
-"No es posible calcular la media recortada sin especificar la opción de "
-"recorte!"
+msgstr "No es posible calcular la media recortada sin especificar la opción de recorte!"
#: ../raster/r.in.xyz/main.c:531
#, c-format
-msgid ""
-"Unable to process the hole map at once. Please set the %s option to some "
-"value lower than 100."
-msgstr ""
+msgid "Unable to process the hole map at once. Please set the %s option to some value lower than 100."
+msgstr "No ha sido posible procesar todo el mapa de una sola vez. Por favor defina la opción %s a una valor menor que 100."
#: ../raster/r.in.xyz/main.c:584
-msgid ""
-"If input is not from a file it is only possible to perform a single pass."
-msgstr ""
-"Si la entrada no es de un archivo sólo se puede realizar un único pase."
+msgid "If input is not from a file it is only possible to perform a single pass."
+msgstr "Si la entrada no es de un archivo sólo se puede realizar un único pase."
#: ../raster/r.in.xyz/main.c:596
-#, fuzzy
msgid "Range filters will not be taken into account during scan"
-msgstr "el rango z no se tendrá en cuenta durante el escaneo"
+msgstr ""
#: ../raster/r.in.xyz/main.c:633
-#, fuzzy
msgid "Reading input data..."
-msgstr "Leyendo entradas..."
+msgstr "Leyendo datos de entrada..."
#: ../raster/r.in.xyz/main.c:640 ../raster/r.in.poly/poly2rast.c:56
#: ../raster/r.in.lidar/main.c:599
@@ -28393,12 +25114,10 @@
#: ../raster/r.in.xyz/main.c:1217 ../raster/r.in.xyz/main.c:1225
#, c-format
msgid ""
-"Not enough data columns. Incorrect delimiter or column number? Found the "
-"following character(s) in row %lu:\n"
+"Not enough data columns. Incorrect delimiter or column number? Found the following character(s) in row %lu:\n"
"[%s]"
msgstr ""
-"Columnas de datos insuficientes. ¿Delimitador o número de columna "
-"incorrecto? Se encontró el siguiente carácter(es) en la fila %lu:\n"
+"Columnas de datos insuficientes. ¿Delimitador o número de columna incorrecto? Se encontró el siguiente carácter(es) en la fila %lu:\n"
"[%s]"
#: ../raster/r.in.xyz/main.c:720 ../raster/r.in.xyz/main.c:1221
@@ -28421,14 +25140,13 @@
msgstr "Coordenada Z incorrecta línea %lu columna %d. <%s>"
#: ../raster/r.in.xyz/main.c:777 ../raster/r.in.xyz/main.c:1288
-#, fuzzy, c-format
+#, c-format
msgid "Bad data value line %lu column %d. <%s>"
-msgstr "Coordenada Y incorrecta línea %lu columna %d. <%s>"
+msgstr ""
#: ../raster/r.in.xyz/main.c:833
-#, fuzzy
msgid "Writing to output raster map..."
-msgstr "Escribiendo mapa ráster de salida %s... "
+msgstr "Escribiendo mapa ráster de salida..."
#: ../raster/r.in.xyz/main.c:1173
#, c-format
@@ -28449,45 +25167,29 @@
msgstr "No se puede asignar memoria intermedia para leer el mapa ráster"
#: ../raster/r.out.gdal/export_band.c:156
-#, fuzzy, c-format
+#, c-format
msgid "Using GDAL data type <%s>"
-msgstr "Exportando al tipo de datos de GDAL: %s"
+msgstr "Usando tipo de datos GDAL <%s>"
#: ../raster/r.out.gdal/export_band.c:161
#, c-format
-msgid ""
-"Input raster map contains cells with NULL-value (no-data). The value %d will "
-"be used to represent no-data values in the input map. You can specify a "
-"nodata value with the %s option."
-msgstr ""
-"El mapa raster de entrada contiene celdas con valor NULO (sin datos). El "
-"valor %d se utilizará para respresentar valores sin-datos. Puedes "
-"especificar un valor sin datos en la opción %s ."
+msgid "Input raster map contains cells with NULL-value (no-data). The value %d will be used to represent no-data values in the input map. You can specify a nodata value with the %s option."
+msgstr "El mapa raster de entrada contiene celdas con valor NULO (sin datos). El valor %d se utilizará para respresentar valores sin-datos. Puedes especificar un valor sin datos en la opción %s ."
#: ../raster/r.out.gdal/export_band.c:166
-#, fuzzy, c-format
-msgid ""
-"Input raster map contains cells with NULL-value (no-data). The value %g will "
-msgstr ""
-"El mapa ráster de entrada contiene celdas con valor NULO (sin datos). Para "
-"los valores sin datos se usó el valor %d. Puede especificar el valor para "
-"para las celdas sin datos con el parámetro %s."
+#, c-format
+msgid "Input raster map contains cells with NULL-value (no-data). The value %g will be used to represent no-data values in the input map. You can specify a nodata value with the %s option."
+msgstr "El mapa ráster de entrada contiene celdas con valor NULL (sin datos). El valor %g será usado para representar valores sin datos en el mapa de entrada. Puede especificar valor sindato con la opción %s."
#: ../raster/r.out.gdal/export_band.c:176
#, c-format
-msgid ""
-"The default nodata value is present in rasterband <%s> and would lead to "
-"data loss. Please specify a custom nodata value with the %s parameter."
-msgstr ""
+msgid "The default nodata value is present in rasterband <%s> and would lead to data loss. Please specify a custom nodata value with the %s parameter."
+msgstr "El valor predeterminado de sindato (nodata) está presente en banda ráster <%s> y provocará pérdida de datos. Por favor especifique el valor sindato (nodata) con el parámetro %s."
#: ../raster/r.out.gdal/export_band.c:183
#, c-format
-msgid ""
-"The user given nodata value %g is present in rasterband <%s> and would lead "
-"to data loss. Please specify a different nodata value with the %s parameter."
-msgstr ""
+msgid "The user given nodata value %g is present in rasterband <%s> and would lead to data loss. Please specify a different nodata value with the %s parameter."
+msgstr "El valor sindato (nodata) %g dado por el usuario está presente en banda ráster <%s> y provocará pérdida de datos. Por favor especifique un valor diferente de sindato (nodata) con el parámetro %s."
#: ../raster/r.out.gdal/export_band.c:227
msgid "Unable to get raster band"
@@ -28562,19 +25264,16 @@
msgstr "No escribir tabla de colores estándard GDAL"
#: ../raster/r.out.gdal/main.c:148
-#, fuzzy
msgid "Only applicable to Byte or UInt16 data types"
-msgstr "Sólo aplicable a Byte o a los tipos de datos UInt16"
+msgstr "Solamente es aplicable a tipos de datos Byte o UInt16"
#: ../raster/r.out.gdal/main.c:153
-#, fuzzy
msgid "Write raster attribute table"
-msgstr "No crear la tabla de atributos"
+msgstr "Escribir tabla de atributos ráster"
#: ../raster/r.out.gdal/main.c:154
-#, fuzzy
msgid "Some export formats may not be supported"
-msgstr "Segmento sobre 2 (o más) segmentos, no soportado todavía"
+msgstr "Algunos formatos de exportación pueden no estar soportados"
#: ../raster/r.out.gdal/main.c:158
msgid "Force raster export despite any warnings of data loss"
@@ -28593,38 +25292,28 @@
msgstr "Nombre para el archivo ráster de salida"
#: ../raster/r.out.gdal/main.c:171
-#, fuzzy
msgid "Raster data format to write (case sensitive, see also -l flag)"
-msgstr ""
-"Formato GIS a escribir (sensible a mayúsculas, ver también la opción -l)"
+msgstr "Formato de datos ráster a escribir (sensible a mayúsculas y minísculas, ver tambien la bandera -l)"
#: ../raster/r.out.gdal/main.c:202
msgid "Creation option(s) to pass to the output format driver"
msgstr "Opción(es) de creación para pasar al formato driver de salida"
#: ../raster/r.out.gdal/main.c:204
-#, fuzzy
msgid "In the form of \"NAME=VALUE\", separate multiple entries with a comma"
-msgstr ""
-"En la expresión \"NAME=VALUE\", separar las distintas entradas con una coma."
+msgstr "En la forma de \"NAME=VALUE\", separar múltiles entracas con una coma"
#: ../raster/r.out.gdal/main.c:212
msgid "Metadata key(s) and value(s) to include"
msgstr "Clave(s) y valor(es) de los metadatos a incluir"
#: ../raster/r.out.gdal/main.c:214
-msgid ""
-"In the form of \"META-TAG=VALUE\", separate multiple entries with a comma. "
-"Not supported by all output format drivers."
-msgstr ""
-"En la expresión \"META-TAG=VALUE\", separar las distintas entradas con una "
-"coma. No soportado por todos los formatos de salida de los drivers."
+msgid "In the form of \"META-TAG=VALUE\", separate multiple entries with a comma. Not supported by all output format drivers."
+msgstr "En la expresión \"META-TAG=VALUE\", separar las distintas entradas con una coma. No soportado por todos los formatos de salida de los drivers."
#: ../raster/r.out.gdal/main.c:224
msgid "Assign a specified nodata value to output bands"
-msgstr ""
-"Asignar un valor especificado a las celdas sin datos para las bandas de "
-"salida"
+msgstr "Asignar un valor especificado a las celdas sin datos para las bandas de salida"
#: ../raster/r.out.gdal/main.c:254
#, c-format
@@ -28643,12 +25332,8 @@
#: ../raster/r.out.gdal/main.c:278
#, c-format
-msgid ""
-"Driver <%s> does not support direct writing. Using MEM driver for "
-"intermediate dataset."
-msgstr ""
-"El controlador <%s> no soporta la escritura directa. Se usa el controlador "
-"MEM para datos intermedios."
+msgid "Driver <%s> does not support direct writing. Using MEM driver for intermediate dataset."
+msgstr "El controlador <%s> no soporta la escritura directa. Se usa el controlador MEM para datos intermedios."
#: ../raster/r.out.gdal/main.c:283
msgid "Unable to get in-memory raster driver"
@@ -28671,47 +25356,31 @@
#: ../raster/r.out.gdal/main.c:434
msgid "Raster export would result in complete data loss, aborting."
-msgstr ""
-"La exportación raster puede resultar en una pérdida completa de datos, "
-"cancelando."
+msgstr "La exportación raster puede resultar en una pérdida completa de datos, cancelando."
#: ../raster/r.out.gdal/main.c:445
#, c-format
-msgid ""
-"Precision loss: Raster map <%s> of type %s to be exported as %s. This can be "
-"avoided by using %s."
-msgstr ""
-"Pérdida de precisión: Mapa raster <%s> de tipo %s a exportar como %s. Esto "
-"puede ser evitado utilizando %s."
+msgid "Precision loss: Raster map <%s> of type %s to be exported as %s. This can be avoided by using %s."
+msgstr "Pérdida de precisión: Mapa raster <%s> de tipo %s a exportar como %s. Esto puede ser evitado utilizando %s."
#: ../raster/r.out.gdal/main.c:456
#, c-format
-msgid ""
-"Precision loss: The range of <%s> can not be accurately preserved with GDAL "
-"datatype Float32. This can be avoided by exporting to Int32 or Float64."
-msgstr ""
-"Pérdida de precisión: El rango de <%s> no puede ser preservado exactamente "
-"con GDAL tipo de datos Float32. Esto puede ser evitado exportanto a Int32 o "
-"Float64."
+msgid "Precision loss: The range of <%s> can not be accurately preserved with GDAL datatype Float32. This can be avoided by exporting to Int32 or Float64."
+msgstr "Pérdida de precisión: El rango de <%s> no puede ser preservado exactamente con GDAL tipo de datos Float32. Esto puede ser evitado exportanto a Int32 o Float64."
#: ../raster/r.out.gdal/main.c:464
#, c-format
-msgid ""
-"Precision loss: Float32 can not preserve the DCELL precision of raster <%s>. "
-"This can be avoided by using Float64"
-msgstr ""
-"Pérdida de precisión: Float32 no puede preservar la precisión DCELL del "
-"raster <%s>. Esto puede ser evitado utilizando Float64"
+msgid "Precision loss: Float32 can not preserve the DCELL precision of raster <%s>. This can be avoided by using Float64"
+msgstr "Pérdida de precisión: Float32 no puede preservar la precisión DCELL del raster <%s>. Esto puede ser evitado utilizando Float64"
#: ../raster/r.out.gdal/main.c:473
-#, fuzzy
msgid "Forcing raster export"
-msgstr "Forzando exportación raster."
+msgstr "Forzando exportación raster"
#: ../raster/r.out.gdal/main.c:475
#, c-format
msgid "Raster export aborted. To override data loss check, use the -%c flag"
-msgstr ""
+msgstr "Se abortó exportación de ráster. Para anular revisión de pérdida de datos, usar la bandera -%c"
#: ../raster/r.out.gdal/main.c:490 ../raster/r.out.gdal/main.c:519
#: ../raster/r.out.gdal/main.c:523
@@ -28720,7 +25389,7 @@
#: ../raster/r.out.gdal/main.c:500
msgid "Checking GDAL data type and nodata value..."
-msgstr ""
+msgstr "Revisando tipo de datos GDAL y valor sindato (nodata)..."
#: ../raster/r.out.gdal/main.c:503
#, c-format
@@ -28733,8 +25402,7 @@
#: ../raster/r.out.gdal/main.c:548
msgid "Unable to create dataset using memory raster driver"
-msgstr ""
-"No se puede el conjunto de datos usando el controlador ráster en memoria"
+msgstr "No se puede el conjunto de datos usando el controlador ráster en memoria"
#: ../raster/r.out.gdal/main.c:557
#, c-format
@@ -28750,9 +25418,9 @@
msgstr "No se puede establecer la proyección"
#: ../raster/r.out.gdal/main.c:586
-#, fuzzy, c-format
+#, c-format
msgid "Exporting raster data to %s format..."
-msgstr "Exportando el mapa ráster <%s> (banda %d)..."
+msgstr "Exportando datos ráster a formato %s..."
#: ../raster/r.out.gdal/main.c:589
#, c-format
@@ -28780,11 +25448,8 @@
#: ../raster/r.out.gdal/main.c:760 ../raster/r.out.gdal/main.c:773
#: ../raster/r.out.gdal/main.c:788
#, c-format
-msgid ""
-"Mismatch between metadata nodata value and actual nodata value in exported "
-"raster: specified nodata value %g gets converted to %d by selected GDAL "
-"datatype."
-msgstr ""
+msgid "Mismatch between metadata nodata value and actual nodata value in exported raster: specified nodata value %g gets converted to %d by selected GDAL datatype."
+msgstr "Valor de sindato (nodata) de metadatos y valor actual de sindato (nodata) en ráster exportado: valor sindato (nodata) especificado %g será convertido a %d por tipo de datos GDAL seleccionado."
#: ../raster/r.out.gdal/main.c:736 ../raster/r.out.gdal/main.c:763
#: ../raster/r.out.gdal/main.c:791
@@ -28799,11 +25464,8 @@
#: ../raster/r.out.gdal/main.c:802
#, c-format
-msgid ""
-"raster: specified nodata value %g gets converted to %g by selected GDAL "
-"datatype."
-msgstr ""
+msgid "Mismatch between metadata nodata value and actual nodata value in exported raster: specified nodata value %g gets converted to %g by selected GDAL datatype."
+msgstr "Valor de sindato (nodata) de metadatos y valor actual de sindato (nodata) en ráster exportado: valor sindato (nodata) especificado %g será convertido a %g por tipo de datos GDAL seleccionado."
#: ../raster/r.out.gdal/main.c:805
#, c-format
@@ -28811,14 +25473,12 @@
msgstr "Tipo de datos GDAL: %s, rango válido: %g - %g"
#: ../raster/r.out.gdal/attr.c:90 ../raster/r.out.gdal/attr.c:128
-#, fuzzy
msgid "Failed to set raster attribute table"
-msgstr "vectorial, ráster, tabla de atributos"
+msgstr "Falló el establecimiento de tabla de atributos ráster"
#: ../raster/r.in.gridatb/main.c:48
-#, fuzzy
msgid "Imports GRIDATB.FOR map file (TOPMODEL) into a GRASS raster map."
-msgstr "Importa archivo de mapa GRIDTB.FOR (TOPMODEL) a mapa ráster de GRASS"
+msgstr "Importa archivo de mapa GRIDTB.FOR (TOPMODEL) a mapa ráster de GRASS."
#: ../raster/r.in.gridatb/main.c:51
msgid "GRIDATB i/o map file"
@@ -28842,13 +25502,8 @@
msgstr "Columnas cambiadas"
#: ../raster/r.mode/main.c:58
-msgid ""
-"Finds the mode of values in a cover map within areas assigned the same "
-"category value in a user-specified base map."
-msgstr ""
-"Encuentra el modo de los valores en un para de cobertura dentro de áreas con "
-"los mismos valores de categoría asignados en un mapa base especificado por "
-"el usuario."
+msgid "Finds the mode of values in a cover map within areas assigned the same category value in a user-specified base map."
+msgstr "Encuentra el modo de los valores en un para de cobertura dentro de áreas con los mismos valores de categoría asignados en un mapa base especificado por el usuario."
#: ../raster/r.mode/main.c:64
msgid "Base map to be reclassified"
@@ -28873,46 +25528,34 @@
#: ../raster/r.walk/main.c:179 ../raster/r.drain/main.c:111
#: ../raster/r.cost/main.c:141
-#, fuzzy
msgid "cost surface"
-msgstr "Varianza de la suma"
+msgstr "superficie de costo"
#: ../raster/r.walk/main.c:180 ../raster/r.spreadpath/main.c:90
#: ../raster/r.cost/main.c:142
-#, fuzzy
msgid "cumulative costs"
-msgstr "Un valor de coste acumulativo máximo opcional"
+msgstr "costos acumulados"
#: ../raster/r.walk/main.c:183
-#, fuzzy
-msgid ""
-"Creates a raster map showing the anisotropic cumulative cost of moving "
-"between different geographic locations on an input raster map whose cell "
-"category values represent cost."
-msgstr ""
-"Crea un mapa raster que muestra el coste acumulado de moverse entre "
-"diferentes localizaciones geográficas en un mapa raster de entrada cuyos "
-"valores de categoría de celdas representan coste."
+msgid "Creates a raster map showing the anisotropic cumulative cost of moving between different geographic locations on an input raster map whose cell category values represent cost."
+msgstr "Genera una capa de mapa ráster que muestra el coste anisotrópico acumulado de moverse entre diferentes posiciones geográficas ubicadas en una capa de mapa ráster de entrada cuyos valores de de celda son categorías que representan un coste."
#: ../raster/r.walk/main.c:193
msgid "Name of input raster map containing friction costs"
msgstr "Nombre del mapa ráster de entrada que contiene costes de fricción"
#: ../raster/r.walk/main.c:196
-#, fuzzy
msgid "Name for output raster map to contain walking costs"
-msgstr "Nombre del mapa ráster de entrada que contiene costes de fricción"
+msgstr "Nombre para mapa ráster que contendrá costes de desplazamiento"
#: ../raster/r.walk/main.c:202 ../raster/r.cost/main.c:167
-#, fuzzy
msgid "Name for output raster map to contain movement directions"
+msgstr "Nombre para mapa ráster que contendrá direcciones de movimiento"
#: ../raster/r.walk/main.c:203 ../raster/r.cost/main.c:161
#: ../raster/r.cost/main.c:168
-#, fuzzy
msgid "Optional outputs"
+msgstr "Salida opcional"
#: ../raster/r.walk/main.c:208 ../raster/r.cost/main.c:173
msgid "Name of starting vector points map"
@@ -28952,43 +25595,33 @@
msgstr "Coordenadas de mapa del punto(s) iniciales (E,N)"
#: ../raster/r.walk/main.c:244 ../raster/r.cost/main.c:209
-#, fuzzy
msgid "Maximum cumulative cost"
-msgstr "Coste acumulativo máximo opcional"
+msgstr "Coste acumulativo máximo"
#: ../raster/r.walk/main.c:253 ../raster/r.cost/main.c:218
msgid "Cost assigned to null cells. By default, null cells are excluded"
-msgstr ""
-"Coste asignado a celdas nulas. Por defecto, las celdas nulas son excluidas"
+msgstr "Coste asignado a celdas nulas. Por defecto, las celdas nulas son excluidas"
#: ../raster/r.walk/main.c:254 ../raster/r.walk/main.c:304
#: ../raster/r.cost/main.c:219 ../raster/r.cost/main.c:238
-#, fuzzy
msgid "NULL cells"
-msgstr "Celdas nulas"
+msgstr "Celdas NULAS"
#: ../raster/r.walk/main.c:263 ../raster/r.cost/main.c:228
-#, fuzzy
msgid "Maximum memory to be used in MB"
-msgstr "Memoria máxima a utilizar con -m flag (en MB)"
+msgstr "Memoria máxima a utilizar en MB"
#: ../raster/r.walk/main.c:273
msgid "Coefficients for walking energy formula parameters a,b,c,d"
-msgstr ""
-"Coeficientes para los parámetros a,b,c,d de la fórmula de energía de "
-"desplazamiento"
+msgstr "Coeficientes para los parámetros a,b,c,d de la fórmula de energía de desplazamiento"
#: ../raster/r.walk/main.c:283
msgid "Lambda coefficients for combining walking energy and friction cost"
-msgstr ""
-"Coeficientes lambda para combinar energía de desplazamiento y coste de "
-"fricción"
+msgstr "Coeficientes lambda para combinar energía de desplazamiento y coste de fricción"
#: ../raster/r.walk/main.c:293
msgid "Slope factor determines travel energy cost per height step"
-msgstr ""
-"El factor de pendiente determina el coste energético del viaje por paso de "
-"altura"
+msgstr "El factor de pendiente determina el coste energético del viaje por paso de altura"
#: ../raster/r.walk/main.c:299 ../raster/r.cost/main.c:233
msgid "Use the 'Knight's move'; slower, but more accurate"
@@ -29003,16 +25636,12 @@
msgstr "Comenzar con valores en mapa ráster"
#: ../raster/r.walk/main.c:313 ../raster/r.cost/main.c:247
-#, fuzzy
msgid "Print info about disk space and memory requirements and exit"
-msgstr "Mostrar información sobre ráster de entrada y salir"
+msgstr "Mostrar información acerca de espacio en disco y requerimientos de memoria y salir"
#: ../raster/r.walk/main.c:357 ../raster/r.cost/main.c:297
msgid "Must specify exactly one of start_points, start_rast or coordinate"
-msgstr ""
-"Se debe especificar exactamente uno de los siguientes parámetros: mapa "
-"vectorial de puntos inicial (start_points), mapa ráster de puntos inicial "
-"(start_rast) o coordenadas"
+msgstr "Se debe especificar exactamente uno de los siguientes parámetros: mapa vectorial de puntos inicial (start_points), mapa ráster de puntos inicial (start_rast) o coordenadas"
#: ../raster/r.walk/main.c:362 ../raster/r.walk/main.c:845
#: ../raster/r.cost/main.c:302 ../raster/r.cost/main.c:712
@@ -29025,9 +25654,9 @@
msgstr "Coste máximo inapropiado: %d"
#: ../raster/r.walk/main.c:372 ../raster/r.cost/main.c:312
-#, fuzzy, c-format
+#, c-format
msgid "Inappropriate amount of memory: %d"
-msgstr "Memoria porcentual inapropiada: %d"
+msgstr "Cantidad inapropiada de memoria: %d"
#: ../raster/r.walk/main.c:377
#, c-format
@@ -29035,9 +25664,9 @@
msgstr "Falta un valor requerido: se obtuvo %d en vez de 4"
#: ../raster/r.walk/main.c:380
-#, fuzzy, c-format
+#, c-format
msgid "Walking costs are a=%g b=%g c=%g d=%g"
-msgstr "Los costes de desplazamiento son a=%lf b=%lf c=%lf d=%lf"
+msgstr "Costes de desplazamiento son a=%lf b=%lf c=%lf d=%lf"
#: ../raster/r.walk/main.c:385 ../raster/r.walk/main.c:393
#, c-format
@@ -29045,14 +25674,14 @@
msgstr "Falta un valore requerido: %d"
#: ../raster/r.walk/main.c:388
-#, fuzzy, c-format
+#, c-format
msgid "Lambda is %g"
-msgstr "Lambda es %lf"
+msgstr "Lambda es %g"
#: ../raster/r.walk/main.c:396
-#, fuzzy, c-format
+#, c-format
msgid "Slope_factor is %g"
-msgstr "Factor de pendiente es %If"
+msgstr "Factor de pendiente es %g"
#: ../raster/r.walk/main.c:415 ../raster/r.cost/main.c:330
msgid "Assigning negative cost to null cell. Null cells excluded."
@@ -29072,34 +25701,33 @@
#: ../raster/r.walk/main.c:529 ../raster/r.walk/main.c:540
#: ../raster/r.cost/main.c:416 ../raster/r.cost/main.c:426
-#, fuzzy, c-format
+#, c-format
msgid "%d of %d segments are kept in memory"
-msgstr "Porcentaje de mapa a mantener en memoria"
+msgstr "Segmentos %d de %d se mantienen en memoria"
#: ../raster/r.walk/main.c:545 ../raster/r.cost/main.c:431
msgid "Creating some temporary files..."
msgstr "Creando algunos archivos temporales..."
#: ../raster/r.walk/main.c:558
-#, fuzzy, c-format
+#, c-format
msgid "Reading raster maps <%s> and <%s>, initializing output..."
+msgstr "Leyendo mapas ráster <%s> y <%s>, inicializando salida..."
#: ../raster/r.walk/main.c:643 ../raster/r.cost/main.c:504
-#, fuzzy
msgid "Initializing directional output..."
-msgstr "Inicializando la salida "
+msgstr "Inicializando salida direccional..."
#: ../raster/r.walk/main.c:675 ../raster/r.drain/main.c:270
#: ../raster/r.cost/main.c:535
-#, fuzzy, c-format
+#, c-format
msgid "Reading vector map <%s> with start points..."
-msgstr "Leyendo el mapa vectorial <%s en %s> ..."
+msgstr "Leyendo mapa vectorial <%s> con puntos de inicio..."
#: ../raster/r.walk/main.c:722
-#, fuzzy, c-format
+#, c-format
msgid "No start points found in vector <%s>"
-msgstr "Encontradas %d líneas o contornos en el mapa vectorial <%s@%s>"
+msgstr "No se encontraron puntos en mapa vectorial <%s>"
#: ../raster/r.walk/main.c:734 ../raster/r.cost/main.c:598
#, fuzzy, c-format
@@ -29118,15 +25746,13 @@
msgstr "No se puede asignar memoria"
#: ../raster/r.walk/main.c:810 ../raster/r.cost/main.c:675
-#, fuzzy, c-format
+#, c-format
msgid "Reading raster map <%s> with start points..."
+msgstr "Leyendo mapa ráster <%s> con puntos de inicio..."
#: ../raster/r.walk/main.c:859 ../raster/r.cost/main.c:726
msgid "Specified starting location outside database window"
-msgstr ""
-"La localización de inicio especificada está fuera de la ventana de la base "
-"de datos"
+msgstr "La localización de inicio especificada está fuera de la ventana de la base de datos"
#: ../raster/r.walk/main.c:879 ../raster/r.cost/main.c:748
msgid "Finding cost path..."
@@ -29137,14 +25763,14 @@
msgstr "Error, ct == pres_cell"
#: ../raster/r.walk/main.c:1368
-#, fuzzy, c-format
+#, c-format
msgid "Writing output raster map <%s>... "
msgstr "Escribiendo mapa ráster de salida <%s>..."
#: ../raster/r.walk/main.c:1432 ../raster/r.cost/main.c:1131
-#, fuzzy, c-format
+#, c-format
msgid "Writing output movement direction raster map <%s>..."
-msgstr "Escribiendo mapa ráster de salida <%s>..."
+msgstr "Escribiendo mapa ráster de dirección de salida de movimiento <%s>..."
#: ../raster/r.walk/main.c:1477 ../raster/r.cost/main.c:1197
#, fuzzy, c-format
@@ -29162,18 +25788,17 @@
msgstr "Coordenada Y no admitida <%s>"
#: ../raster/r.walk/main.c:1504 ../raster/r.cost/main.c:1225
-#, fuzzy, c-format
+#, c-format
msgid "Warning, ignoring point outside window: %g, %g"
-msgstr "Aviso, se ignoran los puntos fuera de la ventana: %.4f,%.4f"
+msgstr "Aviso, se ignoran los puntos fuera de la ventana: %g, %g"
#: ../raster/r.null/main.c:62
msgid "Manages NULL-values of given raster map."
msgstr "Gestiona los valores-NULOS de un determinado mapa raster."
#: ../raster/r.null/main.c:65
-#, fuzzy
msgid "Name of raster map for which to edit null values"
-msgstr "mapa ráster 3D para el que modificar los valores nulos"
+msgstr "Nombre de mapa ráster para el cual editar valores nulos"
#: ../raster/r.null/main.c:86
msgid "Only do the work if the map is floating-point"
@@ -29182,7 +25807,7 @@
#: ../raster/r.null/main.c:87 ../raster/r.null/main.c:92
#: ../raster/r.null/main.c:98
msgid "Check"
-msgstr ""
+msgstr "Revisar"
#: ../raster/r.null/main.c:91
msgid "Only do the work if the map is integer"
@@ -29190,15 +25815,11 @@
#: ../raster/r.null/main.c:97
msgid "Only do the work if the map doesn't have a NULL-value bitmap file"
-msgstr ""
-"Hacer el trabajo sólo si el mapa es no tiene un archivo de mapa de bits de "
-"valor NULO"
+msgstr "Hacer el trabajo sólo si el mapa es no tiene un archivo de mapa de bits de valor NULO"
#: ../raster/r.null/main.c:103
msgid "Create NULL-value bitmap file validating all data cells"
-msgstr ""
-"Crear archivo de mapa de bits de valor NULO validando todas las celdas de "
-"datos"
+msgstr "Crear archivo de mapa de bits de valor NULO validando todas las celdas de datos"
#: ../raster/r.null/main.c:107
msgid "Remove NULL-value bitmap file"
@@ -29207,18 +25828,12 @@
#: ../raster/r.null/main.c:113
#, fuzzy
msgid "Re-create NULL-value bitmap file (to compress or uncompress)"
-msgstr ""
-"datos"
#: ../raster/r.null/main.c:132
#, c-format
-msgid ""
-"Raster map <%s> is a reclass of map <%s@%s>. Consider to generate a copy "
-"with r.mapcalc. Exiting."
-msgstr ""
-"El mapa ráster <%s> es una reclasificación de mapa <%s@%s>. Considera "
-"generar una copia con r.mapcalc. Saliendo."
+msgid "Raster map <%s> is a reclass of map <%s@%s>. Consider to generate a copy with r.mapcalc. Exiting."
+msgstr "El mapa ráster <%s> es una reclasificación de mapa <%s@%s>. Considera generar una copia con r.mapcalc. Saliendo."
#: ../raster/r.null/main.c:138
#, c-format
@@ -29243,7 +25858,7 @@
#: ../raster/r.null/main.c:160
#, c-format
msgid "<%s> is integer raster map (CELL). Using null=%d."
-msgstr ""
+msgstr "<%s> es un mapa de enteros (CELL). Usando null=%d."
#: ../raster/r.null/main.c:166
#, c-format
@@ -29290,49 +25905,41 @@
msgstr "Imprimir/añadir/eliminar marca de tiempo para un mapa ráster."
#: ../raster/r.timestamp/main.c:65
-#, fuzzy, c-format
+#, c-format
msgid "Raster map <%s> not found %s"
-msgstr "Mapa ráster <%s> no encontrado"
+msgstr "Mapa ráster <%s> no encontrado %s"
#: ../raster/r.latlong/main.c:57
msgid "latitude"
msgstr "latitud"
#: ../raster/r.latlong/main.c:58
-#, fuzzy
msgid "longitude"
-msgstr "Salida sensible a región"
+msgstr "longitud"
#: ../raster/r.latlong/main.c:60
-#, fuzzy
msgid "Creates a latitude/longitude raster map."
-msgstr "Crear un mapa entero"
+msgstr "Crea un mapa ráster latitud/longitud."
#: ../raster/r.latlong/main.c:66
-#, fuzzy
msgid "Name for output latitude or longitude raster map"
-msgstr "Nombre vectorial puntos"
+msgstr "Nombre para mapa ráster de salida de latitud o longitud"
#: ../raster/r.latlong/main.c:70
-#, fuzzy
msgid "Longitude output"
+msgstr "Salida de Longitud"
#: ../raster/r.latlong/main.c:101 ../raster/r.sunmask/g_solposition.c:98
msgid "Unable to get projection info of current location"
-msgstr ""
-"No se puede obtener información de la proyección de la localización actual"
+msgstr "No se puede obtener información de la proyección de la localización actual"
#: ../raster/r.latlong/main.c:103 ../raster/r.sunmask/g_solposition.c:101
msgid "Unable to get projection units of current location"
-msgstr ""
-"No se pueden obtener las unidades de la proyección de la localización actual"
+msgstr "No se pueden obtener las unidades de la proyección de la localización actual"
#: ../raster/r.latlong/main.c:105 ../raster/r.sunmask/g_solposition.c:104
msgid "Unable to get projection key values of current location"
-msgstr ""
-"No se pueden obtener los valores clave de la proyección de la localización "
-"actual"
+msgstr "No se pueden obtener los valores clave de la proyección de la localización actual"
#: ../raster/r.quant/main.c:49
#, fuzzy
@@ -29348,9 +25955,8 @@
msgstr "Mapa(s) ráster a cuantizar"
#: ../raster/r.quant/main.c:64
-#, fuzzy
msgid "Path to rules file (\"-\" to read from stdin)"
-msgstr "Archivo de coordenadas de entrada (omitir para leer de stdin)"
+msgstr "Ruta a archivo (\"-\" para leer desde entrada estándar)"
#: ../raster/r.quant/main.c:70
msgid "Base map to take quant rules from"
@@ -29373,14 +25979,14 @@
msgstr "Redondear datos de coma flotante"
#: ../raster/r.quant/main.c:111
-#, fuzzy, c-format
+#, c-format
msgid "-%c, -%c, %s=, %s= and %s= are mutually exclusive"
+msgstr "-%c, -%c, %s=, %s= y %s= son mutuamente excluyentes"
#: ../raster/r.quant/main.c:120
-#, fuzzy, c-format
+#, c-format
msgid "%s= and %s= must be used together"
-msgstr "Nombre de los mapas ráster a parchear juntos"
+msgstr "%s= y %s= deben ser usados juntos"
#: ../raster/r.quant/main.c:131
#, fuzzy, c-format
@@ -29396,30 +26002,28 @@
msgstr "Redondeando..."
#: ../raster/r.quant/main.c:152
-#, fuzzy, c-format
+#, c-format
msgid "%s is integer map, it can't be used as basemap"
-msgstr "Nombre del mapa ráster a utilizar como máscara"
+msgstr "%s es un mapa de enteros, no puede ser usado como mapa base"
#: ../raster/r.quant/main.c:156
#, fuzzy, c-format
msgid "unable to read quant rules for basemap <%s>"
-msgstr "No se puede leer el intervalo para el mapa <%s>"
+msgstr "no ha sido posible leer reglas de "
#: ../raster/r.quant/main.c:163 ../raster/r.quant/main.c:166
-#, fuzzy, c-format
+#, c-format
msgid "invalid value for %s= <%s>"
-msgstr "Valor no válido para scalex"
+msgstr "valor no válido para %s= <%s>"
#: ../raster/r.quant/main.c:168
#, fuzzy, c-format
msgid "Setting quant rules for input map(s) to (%f,%f) -> (%d,%d)"
-msgstr ""
-"Configurar reglar de cuantización para el(los) mapa(s) a (%f %f) -> (%d,%d)"
+msgstr "Configurar reglar de cuantización para el(los) mapa(s) a (%f %f) -> (%d,%d)"
#: ../raster/r.quant/main.c:181
msgid "No rules specified. Quant table(s) not changed."
-msgstr ""
-"No se han especificado reglas. La tabla(s) de cuantización no se ha cambiado."
+msgstr "No se han especificado reglas. La tabla(s) de cuantización no se ha cambiado."
#: ../raster/r.quant/main.c:183 ../raster/r.reclass/main.c:142
#: ../raster/r.recode/main.c:99
@@ -29450,23 +26054,25 @@
msgstr "El antiguo rango de datos enteros es de %d a %d"
#: ../raster/r.quant/read_rules.c:83
-#, fuzzy, c-format
+#, c-format
msgid "unable to open input file <%s>"
-msgstr "No se puede abrir el archivo de entrada <%s>"
+msgstr "no ha sido posible abrir archivo de entrada <%s>"
#: ../raster/r.quant/read_rules.c:89
-#, fuzzy, c-format
+#, c-format
msgid ""
"\n"
"Enter the rule or 'help' for the format description or 'end' to exit:\n"
-msgstr "Introducir la regla o 'help' para una descripción del formato"
+msgstr ""
+"\n"
+"Ingrese la regla o 'help' para la descripción del formato o 'end' para salir:\n"
#: ../raster/r.quant/read_rules.c:112
msgid "quant rules do not cover the whole range map"
msgstr ""
#: ../raster/r.quant/read_rules.c:158 ../raster/r.recode/read_rules.c:126
-#, fuzzy, c-format
+#, c-format
msgid "%s is not a valid rule"
msgstr "%s no es una regla válida"
@@ -29480,9 +26086,9 @@
msgstr "No se puede leer la cabecera del archivo de <%s@%s>"
#: ../raster/r.reclass/reclass.c:234
-#, fuzzy, c-format
+#, c-format
msgid "Cannot overwrite existing raster map <%s>"
-msgstr "No se puede crear el mapa ráster <%s>"
+msgstr "No se puede sobreescribir mapa ráster <%s> existente"
#: ../raster/r.reclass/reclass.c:239
#, c-format
@@ -29495,25 +26101,16 @@
#: ../raster/r.reclass/main.c:52
-#, fuzzy
msgid "Reclassify raster map based on category values."
-msgstr ""
-"Consulta capas de mapa ráster en sus valores de categoría y etiquetas de "
-"categoría."
+msgstr "Consultar mapa ráster de acuerdo a sus valores de categorías."
#: ../raster/r.reclass/main.c:54
-#, fuzzy
-msgid ""
-"Creates a new raster map whose category values are based upon a "
-"reclassification of the categories in an existing raster map."
-msgstr ""
-"Crea una nueva capa de mapa cuyos valores de categorías están basados en una "
-"reclasificación de las categorías de una capa de mapa ráster existente."
+msgid "Creates a new raster map whose category values are based upon a reclassification of the categories in an existing raster map."
+msgstr "Crea un nuevo mapa ráster cuyos valores de categorías están basados en la reclasificación de las categorías de un mapa ráster existente."
#: ../raster/r.reclass/main.c:59
-#, fuzzy
msgid "Name of raster map to be reclassified"
-msgstr "Mapa por reclasificar"
+msgstr "Nombre de mapa ráster a reclasificar"
#: ../raster/r.reclass/main.c:65
msgid "File containing reclass rules"
@@ -29536,24 +26133,22 @@
#: ../raster/r.reclass/main.c:103
#, c-format
msgid "Enter rule(s), \"end\" when done, \"help\" if you need it\n"
-msgstr ""
-"Introduzca regla(s), \"end\" cuando haya finalizado, \"help\" si necesitas "
-"ayuda\n"
+msgstr "Introduzca regla(s), \"end\" cuando haya finalizado, \"help\" si necesitas ayuda\n"
#: ../raster/r.reclass/main.c:105
-#, fuzzy, c-format
+#, c-format
msgid "FCELL: Data range is %.7g to %.7g\n"
-msgstr "El intervalo es de %ld a %ld\n"
+msgstr "FCELL: rango de datos es %.7g hacia %.7g\n"
#: ../raster/r.reclass/main.c:108
-#, fuzzy, c-format
+#, c-format
msgid "DCELL: Data range is %.15g to %.15g\n"
-msgstr "fp: el rango de datos es %.25f a %.25f\n"
+msgstr "DCELL: Rango de datos es %.15g a %.15g\n"
#: ../raster/r.reclass/main.c:111
-#, fuzzy, c-format
+#, c-format
msgid "CELL: Data range is %ld to %ld\n"
+msgstr "CELL: Rango de datos es %ld a %ld\n"
#: ../raster/r.reclass/main.c:119
#, c-format
@@ -29602,23 +26197,19 @@
#: ../raster/r.in.poly/main.c:37
msgid "Creates raster maps from ASCII polygon/line/point data files."
-msgstr ""
-"Crea mapas ráster a partir de archivos de datos de polígonos/líneas/puntos "
-"ASCII."
+msgstr "Crea mapas ráster a partir de archivos de datos de polígonos/líneas/puntos ASCII."
#: ../raster/r.in.poly/main.c:41
msgid "Name of input file; or \"-\" to read from stdin"
msgstr "Nombre del archivo de entrada; o \"-\" a leer de stdin"
#: ../raster/r.in.poly/main.c:56
-#, fuzzy
msgid "Output raster type"
-msgstr "Hata tipo de elemento"
+msgstr "Tipo de ráster de salida"
#: ../raster/r.in.poly/main.c:64
-#, fuzzy
msgid "Integer representing NULL value data cell"
-msgstr "Cadena que representa celdas de datos con valor NULO"
+msgstr "Entero que representa datos de valores NULL"
#: ../raster/r.in.poly/main.c:70
msgid "Number of rows to hold in memory"
@@ -29629,9 +26220,8 @@
msgstr "El número mínimo de filas a mantener en memoria es 1"
#: ../raster/r.in.poly/main.c:87
-#, fuzzy
msgid "Type doesn't exist"
-msgstr "La herramienta no existe"
+msgstr "Tipo no existe"
#: ../raster/r.in.poly/get_item.c:97
#, c-format
@@ -29649,9 +26239,8 @@
msgstr "Coordenada Este <%s> no admitida, saliendo."
#: ../raster/r.out.ppm/main.c:56
-#, fuzzy
msgid "Converts a GRASS raster map to a PPM image file."
-msgstr "Convierte un mapa ráster en una capa de mapa vectorial."
+msgstr "Convierte mapa ráster GRASS a archivo de imagen PPM."
#: ../raster/r.out.ppm/main.c:64
msgid "Name for new PPM file (use '-' for stdout)"
@@ -29662,24 +26251,23 @@
msgstr "Salida en escala de grises en vez de color"
#: ../raster/r.out.ppm/main.c:72
-#, fuzzy
msgid "Suppress printing of PPM header"
-msgstr "Suprimir la impresión de información de cabecera"
+msgstr "Suprime el mostrado de encabezado PPM"
#: ../raster/r.out.ppm/main.c:101 ../raster/r.out.ppm3/main.c:95
-#, fuzzy, c-format
+#, c-format
msgid "row = %d"
msgid_plural "rows = %d"
-msgstr[0] "Filas = %d"
-msgstr[1] "Filas = %d"
+msgstr[0] "fila = %d"
+msgstr[1] "filas = %d"
#. GTC Raster columns
#: ../raster/r.out.ppm/main.c:102 ../raster/r.out.ppm3/main.c:97
-#, fuzzy, c-format
+#, c-format
msgid "column = %d"
msgid_plural "columns = %d"
-msgstr[0] "Columnas = %d"
-msgstr[1] "Columnas = %d"
+msgstr[0] "columna = %d"
+msgstr[1] "columnas = %d"
#: ../raster/r.out.ppm/main.c:124
#, c-format
@@ -29696,11 +26284,8 @@
msgstr "Archivo %s creado"
#: ../raster/r.in.lidar/main.c:114
-#, fuzzy
msgid "Creates a raster map from LAS LiDAR points using univariate statistics."
-msgstr ""
+msgstr "Crea un mapa ráster a partir de puntos LAS LiDAR usando estadísticas univariadas."
#: ../raster/r.in.lidar/main.c:128
#, fuzzy
@@ -29713,8 +26298,7 @@
msgstr "Cambiando valor para coordenadas Z"
#: ../raster/r.in.lidar/main.c:184
-msgid ""
-"The scale for Z is applied beforehand, the range filter for Z afterwards"
+msgid "The scale for Z is applied beforehand, the range filter for Z afterwards"
msgstr ""
#: ../raster/r.in.lidar/main.c:193
@@ -29740,14 +26324,11 @@
#: ../raster/r.in.lidar/main.c:243
#, fuzzy
msgid "Discard given percentage of the smallest and largest values"
-msgstr ""
-"Descartar <trim> porcentaje de las menores y <trim> porcentaje de las "
-"mayores observaciones"
+msgstr "Descartar <trim> porcentaje de las menores y <trim> porcentaje de las mayores observaciones"
#: ../raster/r.in.lidar/main.c:253
-#, fuzzy
msgid "Output raster resolution"
-msgstr "Se requiere mapa raster de salida"
+msgstr "Resolución de mapa ráster de salida"
#: ../raster/r.in.lidar/main.c:284
msgid "Use the extent of the input for the raster extent"
@@ -29763,9 +26344,7 @@
msgstr "Establecer la región para ajustar este mapa ráster"
#: ../raster/r.in.lidar/main.c:295
-msgid ""
-"Set computation region to match the 2D extent and resolution of the newly "
-"created new raster map"
+msgid "Set computation region to match the 2D extent and resolution of the newly created new raster map"
msgstr ""
#: ../raster/r.in.lidar/main.c:319
@@ -29786,9 +26365,7 @@
msgstr "Usar expressiones regulares básicas en vez de comodines"
#: ../raster/r.in.lidar/main.c:334
-msgid ""
-"For getting values from base raster, use its actual resolution instead of "
-"computational region resolution"
+msgid "For getting values from base raster, use its actual resolution instead of computational region resolution"
msgstr ""
#: ../raster/r.in.lidar/main.c:344
@@ -29806,14 +26383,13 @@
#: ../raster/r.in.lidar/main.c:408
-msgid ""
-"First file's projection checked, checking projection of the other files..."
+msgid "First file's projection checked, checking projection of the other files..."
msgstr ""
#: ../raster/r.in.lidar/main.c:446
-#, fuzzy, c-format
+#, c-format
msgid "Unknown filter option <%s>"
-msgstr "Opción de norma: '%s' desconocida"
+msgstr "Opción de filtro no conocida <%s>"
#: ../raster/r.in.lidar/main.c:476
#, fuzzy, c-format
@@ -29821,15 +26397,13 @@
msgstr "Mapa no válido <%s>"
#: ../raster/r.in.lidar/main.c:511
-#, fuzzy, c-format
+#, c-format
msgid "Option '%s' must be > 0.0"
-msgstr "Se requiere la opción <%s>"
+msgstr "Opción '%s debe ser > 0.0"
#: ../raster/r.in.lidar/main.c:579
#, c-format
-msgid ""
-"Unable to process the hole map at once. Please set the '%s' option to some "
+msgid "Unable to process the hole map at once. Please set the '%s' option to some value lower than 100."
msgstr ""
#: ../raster/r.in.lidar/main.c:591
@@ -29856,26 +26430,20 @@
msgstr "No se puede abrir el archivo '%s' para lectura"
#: ../raster/r.grow.distance/main.c:156
-#, fuzzy
msgid "Generates a raster map containing distances to nearest raster features."
-msgstr ""
-"Genera una capa de mapa raster de las distancias a los elementos en la capa "
-"de entrada."
+msgstr "Genera un mapa ráster de la distancia a elementos ráster más cercanos."
#: ../raster/r.grow.distance/main.c:163
-#, fuzzy
msgid "Name for distance output raster map"
-msgstr "Nombre para el mapa de distancia de salida"
+msgstr "Nombre para mapa ráster de distancias"
#: ../raster/r.grow.distance/main.c:169
-#, fuzzy
msgid "Name for value output raster map"
-msgstr "Nombre para el mapa ráster de salida"
+msgstr "Nombre para mapa ráster de salida de valores"
#: ../raster/r.grow.distance/main.c:182
-#, fuzzy
msgid "Output distances in meters instead of map units"
-msgstr "Distancia máxima entre puntos en unidades de mapa"
+msgstr "Distancias de salida en metros en vez de en unidades de mapa"
#: ../raster/r.grow.distance/main.c:186
#, fuzzy
@@ -29892,43 +26460,40 @@
#: ../raster/r.grow.distance/main.c:205
msgid "At least one of distance= and value= must be given"
-msgstr "Se debe especificar al menos una opción de %s"
+msgstr "Se debe dar al menos una de las dos distance= y value="
#: ../raster/r.grow.distance/main.c:220
msgid "metric=geodesic is only valid for lat/lon"
-msgstr "metrico=geodesic es válido solo para lat/lon"
+msgstr "metric=geodesic es válido solamente para lat/lon"
#: ../raster/r.grow.distance/main.c:226
-#, fuzzy, c-format
+#, c-format
msgid "Unknown metric: '%s'"
-msgstr "Métrica desconocida: [%s]."
+msgstr "Métrica desconocida: '%s'"
#: ../raster/r.grow.distance/main.c:231
-#, fuzzy, c-format
+#, c-format
msgid "Output distance in meters for lat/lon is only possible with '%s=%s'"
+msgstr "Distancia de salida en metros para lat/long solamente es posible con '%s=%s'"
#: ../raster/r.grow.distance/main.c:251
#, c-format
msgid "Unable to create temporary file <%s>"
-msgstr "No se puede crear archivo temporal <%s>"
+msgstr "No ha sido posible crear archivo temporal <%s>"
#: ../raster/r.grow.distance/main.c:327 ../raster/r.fill.dir/main.c:250
#: ../raster/r.stream.extract/close.c:248
-#, fuzzy
msgid "Writing output raster maps..."
+msgstr "Escribiendo mapas ráster de salida..."
#: ../raster/r.regression.line/main.c:48
#: ../raster/r.regression.multi/main.c:130
-#, fuzzy
msgid "regression"
-msgstr "Por posición"
+msgstr "regresión"
#: ../raster/r.regression.line/main.c:50
-#, fuzzy
msgid "Calculates linear regression from two raster maps: y = a + b*x."
-msgstr "Calcula la regresión lineal de dos mapas ráster: y = a + b*x"
+msgstr "Calcula regresión lineal de dos mapas ráster: y = a + b*x"
#: ../raster/r.regression.line/main.c:55
#: ../raster/r.regression.multi/main.c:137
@@ -29942,12 +26507,8 @@
#: ../raster/r.regression.line/main.c:65
#: ../raster/r.regression.multi/main.c:157
-msgid ""
-"ASCII file for storing regression coefficients (output to screen if file not "
-"specified)."
-msgstr ""
-"Archivo ASCII para guardar los coeficientes de regresión (salida a pantalla "
-"si no se especifica ningún archivo)."
+msgid "ASCII file for storing regression coefficients (output to screen if file not specified)."
+msgstr "Archivo ASCII para guardar los coeficientes de regresión (salida a pantalla si no se especifica ningún archivo)."
#: ../raster/r.what.color/main.c:91
msgid "Queries colors for a raster map layer."
@@ -29975,8 +26536,7 @@
#: ../raster/r.describe/main.c:57
msgid "Prints terse list of category values found in a raster map layer."
-msgstr ""
-"Imprime una lista concisa de valores de categoría en una capa de mapa ráster."
+msgstr "Imprime una lista concisa de valores de categoría en una capa de mapa ráster."
#: ../raster/r.describe/main.c:71
msgid "Number of quantization steps"
@@ -29999,9 +26559,8 @@
msgstr "Usar la región actual"
#: ../raster/r.describe/main.c:93
-#, fuzzy
msgid "Read floating-point map as integer"
-msgstr "Leer mapa fp como entero"
+msgstr "Leer mapa de punto flotate como entero"
#: ../raster/r.describe/main.c:105
#, c-format
@@ -30009,23 +26568,21 @@
msgstr "%s = %s -- debe ser mayor que cero"
#: ../raster/r.describe/describe.c:94
-#, fuzzy, c-format
+#, c-format
msgid "Reading <%s> ..."
-msgstr "Leyendo %s ..."
+msgstr "Leyendo <%s>..."
#: ../raster/r.out.png/main.c:116
-#, fuzzy
msgid "Export a GRASS raster map as a non-georeferenced PNG image."
-msgstr "Exporta un ráster de GRASS a formatos soportados por GDAL."
+msgstr "Exportar un mapa ráster de GRASS como formato de imagen PNG no georreferenciada."
#: ../raster/r.out.png/main.c:122
-#, fuzzy
msgid "Name for new PNG file (use '-' for stdout)"
-msgstr "Nombre para el nuevo archivo PPM. (usar '-' para stdout)"
+msgstr "Nombre para nuevo archivo PNG (usar '-' para salida estándar)"
#: ../raster/r.out.png/main.c:130
msgid "Compression level of PNG file"
-msgstr "Nivel de compresión del archivo png"
+msgstr "Nivel de compresión del archivo PNG"
#: ../raster/r.out.png/main.c:131
msgid "(0 = none, 1 = fastest, 9 = best)"
@@ -30037,7 +26594,7 @@
#: ../raster/r.out.png/main.c:142
msgid "Output world file"
-msgstr "Archivo de georeferenciación de salida"
+msgstr ""
#: ../raster/r.out.png/main.c:175 ../display/d.graph/main.c:104
#: ../display/d.graph/do_graph.c:105 ../display/d.graph/do_graph.c:355
@@ -30059,7 +26616,7 @@
#: ../raster/r.out.png/main.c:422
msgid "Writing world file"
-msgstr "Escribiendo archivo de georeferenciación"
+msgstr ""
#: ../raster/r.out.png/main.c:425
msgid "Got null file name"
@@ -30071,15 +26628,11 @@
#: ../raster/r.out.png/main.c:429
msgid "Unable to open world file for writing"
-msgstr "No se puede abrir el archivo de georeferenciación para escritura"
+msgstr ""
#: ../raster/r.covar/main.c:54
-msgid ""
-"Outputs a covariance/correlation matrix for user-specified raster map "
-"layer(s)."
-msgstr ""
-"Produce una matriz de covarianza/correlación para la capa(s) de mapa ráster "
-"especificada por el usuario."
+msgid "Outputs a covariance/correlation matrix for user-specified raster map layer(s)."
+msgstr "Produce una matriz de covarianza/correlación para la capa(s) de mapa ráster especificada por el usuario."
#: ../raster/r.covar/main.c:61
msgid "Print correlation matrix"
@@ -30095,12 +26648,8 @@
msgstr "Ningún valor no nulo"
#: ../raster/r.random/main.c:56
-msgid ""
-"Creates a raster map layer and vector point map containing randomly located "
-"points."
-msgstr ""
-"Crea una capa de mapa ráster y un mapa de puntos vectoriales que contiene "
-"puntos situados de forma aleatoria."
+msgid "Creates a raster map layer and vector point map containing randomly located points."
+msgstr "Crea una capa de mapa ráster y un mapa de puntos vectoriales que contiene puntos situados de forma aleatoria."
#: ../raster/r.random/main.c:60 ../raster/r.out.bin/main.c:290
#: ../imagery/i.zc/main.c:65
@@ -30198,118 +26747,100 @@
msgstr "Error del programador en get_stats/switch"
#: ../raster/r.report/main.c:69
-#, fuzzy
msgid "Reports statistics for raster maps."
-msgstr "Informa estadísticas para capas de mapas ráster."
+msgstr "Reporta estadísticas para mapas ráster."
#: ../raster/r.report/parse.c:38 ../raster/r.stats/main.c:114
-#, fuzzy
msgid "Name of raster map(s) to report on"
-msgstr "Mapa(s) ráster sobre el que informar"
+msgstr "Nombre de mapa(s) ráster sobre el cual reportar"
#: ../raster/r.report/parse.c:45
-#, fuzzy
msgid "Units to report"
-msgstr "Nada que exportar"
+msgstr "área a reportar"
#: ../raster/r.report/parse.c:49
-#, fuzzy
msgid "area in square miles"
-msgstr "Superficie del lago %f metros cuadrados"
+msgstr "área en millas cuadradas"
#: ../raster/r.report/parse.c:50
-#, fuzzy
msgid "area in square meters"
+msgstr "área en metros cuadrados"
#: ../raster/r.report/parse.c:51
-#, fuzzy
msgid "area in square kilometers"
+msgstr "área en kilómetros cuadrados"
#: ../raster/r.report/parse.c:52
-#, fuzzy
msgid "area in acres"
-msgstr "área"
+msgstr "área en acres"
#: ../raster/r.report/parse.c:53
msgid "area in hectares"
msgstr "área en hectareas"
#: ../raster/r.report/parse.c:54
-#, fuzzy
msgid "number of cells"
-msgstr "Número de fotogramas"
+msgstr "cantidad de celdas"
#: ../raster/r.report/parse.c:55
-#, fuzzy
msgid "percent cover"
-msgstr "Convergencia porcentual"
+msgstr "porcentaje de cobertura"
#: ../raster/r.report/parse.c:58 ../raster/r.stats/main.c:158
#: ../raster/r.stats/main.c:163 ../raster/r.stats/main.c:169
-#, fuzzy
msgid "Statistics"
-msgstr "Estadístico"
+msgstr "Estadísticas"
#: ../raster/r.report/parse.c:75
-#, fuzzy
msgid "Page length"
-msgstr "Longitud de página no admitida"
+msgstr "Longitud de página"
#: ../raster/r.report/parse.c:83
-#, fuzzy
msgid "Page width"
-msgstr "Anchura de imagen"
+msgstr "Anchura de página"
#: ../raster/r.report/parse.c:94 ../raster/r.stats/main.c:136
-#, fuzzy
msgid "Number of floating-point subranges to collect stats from"
-msgstr "Número de subrangos fp de los que recopilar las estadísticas"
+msgstr "Número de rangos de punto flotante de los cuales colectar estadísticas"
#: ../raster/r.report/parse.c:95 ../raster/r.report/parse.c:139
#: ../raster/r.report/parse.c:145 ../raster/r.stats/main.c:137
#: ../raster/r.stats/main.c:192 ../raster/r.stats/main.c:197
#: ../raster/r.stats/main.c:212 ../raster/r.stats/main.c:217
-#, fuzzy
msgid "Floating point"
-msgstr " Mapa de coma flotante"
+msgstr "Puto flotante"
#: ../raster/r.report/parse.c:102 ../raster/r.stats/main.c:144
msgid "Sort output statistics by cell counts"
-msgstr ""
+msgstr "Ordenar estadísticas por cantidad de celdas"
#: ../raster/r.report/parse.c:103 ../raster/r.stats/main.c:145
-#, fuzzy
msgid "Default: sorted by categories or intervals"
-msgstr "No se pueden escribir categorías para el mapa raster <%s>"
+msgstr "Predeterminado: ordener por categorías o intervalos"
#: ../raster/r.report/parse.c:107 ../raster/r.stats/main.c:149
msgid "Sort by cell counts in ascending order"
-msgstr ""
+msgstr "Ordenar por conteo de celdas en orden ascendente"
#: ../raster/r.report/parse.c:108 ../raster/r.stats/main.c:150
-#, fuzzy
msgid "Sort by cell counts in descending order"
-msgstr "Organizando los valores propios en orden descendente..."
+msgstr "Ordenar por conteo de celdas en orden descendente"
#: ../raster/r.report/parse.c:113
msgid "Suppress page headers"
msgstr "Suprimir encabezados de página"
#: ../raster/r.report/parse.c:118
-#, fuzzy
msgid "Use formfeeds between pages"
-msgstr "Usar formfeeds entre páginas"
+msgstr ""
#: ../raster/r.report/parse.c:123
msgid "Scientific format"
msgstr "Formato científico"
#: ../raster/r.report/parse.c:128 ../raster/r.stats/main.c:201
-#, fuzzy
msgid "Do not report no data value"
-msgstr "Eliminar la tabla de colores existente"
+msgstr "No reportar valor sin datos"
#: ../raster/r.report/parse.c:129 ../raster/r.report/parse.c:134
#: ../raster/r.stats/main.c:202 ../raster/r.stats/main.c:207
@@ -30317,19 +26848,16 @@
msgstr "No hay datos"
#: ../raster/r.report/parse.c:133 ../raster/r.stats/main.c:206
-#, fuzzy
msgid "Do not report cells where all maps have no data"
-msgstr "Filtrar celdas en las que todos los mapas no tienen datos"
+msgstr "No reportar celdas en las que todos los mapas carecen de datos"
#: ../raster/r.report/parse.c:138 ../raster/r.stats/main.c:211
-#, fuzzy
msgid "Report for cats floating-point ranges (floating-point maps only)"
-msgstr "Informar para rangos fp de categorías (sólo mapas fp)"
+msgstr "Reportar cats para rangos de punto flotante (solamente mapas de punto flotante)"
#: ../raster/r.report/parse.c:144 ../raster/r.stats/main.c:216
-#, fuzzy
msgid "Read floating-point map as integer (use map's quant rules)"
-msgstr "Leer mapa fp como entero (usar reglas quant del mapa)"
+msgstr "Leer mapa de punto flotante como mapa de enteros (usar reglas quant del mapa)"
#: ../raster/r.report/parse.c:187
msgid "nsteps has to be > 0; using nsteps=255"
@@ -30355,7 +26883,7 @@
#: ../raster/r.report/label.c:13
msgid "Page width is too small"
-msgstr ""
+msgstr "El tamaño de página es demasiado pequeño"
#: ../raster/r.report/stats.c:93
#, c-format
@@ -30368,9 +26896,7 @@
#: ../raster/r.profile/main.c:56
msgid "Outputs the raster map layer values lying on user-defined line(s)."
-msgstr ""
-"Saca los valores de la capa de mapa ráster que caen en la línea(s) definida "
-"por el usuario."
+msgstr "Saca los valores de la capa de mapa ráster que caen en la línea(s) definida por el usuario."
#: ../raster/r.profile/main.c:64 ../raster/r.horizon/main.c:304
msgid "Name of file for output (use output=- for stdout)"
@@ -30381,54 +26907,46 @@
msgstr "Pares de coordenadas del perfil"
#: ../raster/r.profile/main.c:75
-#, fuzzy
msgid "Name of input file containing coordinate pairs"
-msgstr "Nombre del archivo que contiene signaturas"
+msgstr "Nombre de archivo de entrada que contiene pares de coordenadas"
#: ../raster/r.profile/main.c:77
-#, fuzzy
msgid "Use instead of the 'coordinates' option. \"-\" reads from stdin."
-msgstr "Archivo que contiene coordenadas a transformar (\"-\" a leer de stdin)"
+msgstr "Usar en vez de la opción 'coordinates'. \"-\" lee desde entrada estándar."
#: ../raster/r.profile/main.c:85
msgid "Resolution along profile (default = current region resolution)"
-msgstr ""
-"Resolución a lo largo del perfil (por omisión = resolución de la región "
-"actual)"
+msgstr "Resolución a lo largo del perfil (por omisión = resolución de la región actual)"
#: ../raster/r.profile/main.c:93 ../raster/r.transect/main.c:126
msgid "Output easting and northing in first two columns of four column output"
-msgstr ""
-"Sacar Este y Norte en las primeras dos columnas de una salida de 4 columnas"
+msgstr "Sacar Este y Norte en las primeras dos columnas de una salida de 4 columnas"
#: ../raster/r.profile/main.c:98
msgid "Output RRR:GGG:BBB color values for each profile point"
msgstr "Dar los valores de color RRR GGG BBB para cada punto del perfil"
#: ../raster/r.profile/main.c:103
-msgid ""
-"If units are not specified, current location units are used. Meters are used "
-"by default in geographic (latlon) locations."
-msgstr ""
+msgid "If units are not specified, current location units are used. Meters are used by default in geographic (latlon) locations."
+msgstr "Si no se especifican las unidades, se usarán uidades de Localización. De manera predeterminada se usarán metros en Localizaciones geográficas (latlon)."
#: ../raster/r.profile/main.c:117
msgid "Either use profile option or coordinate_file option, but not both"
-msgstr ""
+msgstr "Usar ya sea la opción profile o coordinate_file, pero no ambas"
#: ../raster/r.profile/main.c:144
-#, fuzzy, c-format
+#, c-format
msgid "Illegal resolution %g [%s]"
-msgstr "¡Resolución no admitida! [%g]"
+msgstr "¡Resolución no admitida! %g [%s]"
#: ../raster/r.profile/main.c:151
-#, fuzzy, c-format
+#, c-format
msgid "Using resolution: %g [%s]"
-msgstr "Usando resolución [%g]"
+msgstr "Usando resolución %g [%s]"
#: ../raster/r.profile/main.c:182
-#, fuzzy
msgid "Output columns:"
-msgstr "Salidas"
+msgstr "Columnas de salida:"
#: ../raster/r.profile/main.c:185
#, fuzzy, c-format
@@ -30436,19 +26954,18 @@
msgstr "[Este] [Norte] [Distancia a lo largo del recorrido.(m)] [Elevación]"
#: ../raster/r.profile/main.c:187
-#, fuzzy, c-format
+#, c-format
msgid "Along track dist. [%s], Elevation"
-msgstr "[Distancia a lo largo del recorrido.(m)] [Elevación]"
+msgstr "Distancia a lo largo de la ruta [%s]. Elevación"
#: ../raster/r.profile/main.c:189
-#, fuzzy
msgid " RGB color"
-msgstr " [Color RGB]"
+msgstr "Color RGB"
#: ../raster/r.profile/main.c:200
-#, fuzzy, c-format
+#, c-format
msgid "Could not open <%s>"
-msgstr "No se pudo abrir el mapa %s"
+msgstr "Podría no abrir <%s>"
#: ../raster/r.profile/main.c:207
#, c-format
@@ -30456,15 +26973,13 @@
msgstr "Coordenadas no válidas %s %s"
#: ../raster/r.profile/main.c:278
-#, fuzzy, c-format
+#, c-format
msgid "Approx. transect length: %f [%s]"
-msgstr "Longitud de transecto aproximada [%f] m"
+msgstr "Longitud aproximada de transecto: %f [%s]"
#: ../raster/r.profile/main.c:281
msgid "Endpoint coordinates are outside of current region settings"
-msgstr ""
-"Las coordenadas del punto final están fuera de la configuración de la región "
-"actual"
+msgstr "Las coordenadas del punto final están fuera de la configuración de la región actual"
#: ../raster/r.profile/input.c:30 ../raster/r.profile/input.c:47
#: ../raster/r.profile/input.c:60
@@ -30472,29 +26987,25 @@
msgstr "Una par de coordenadas por línea, por favor"
#: ../raster/r.colors.out/raster_main.c:49
-#, fuzzy
msgid "Exports the color table associated with a raster map."
-msgstr "Exporta la tabla de color asociada con la capa de un mapa raster."
+msgstr "Exporta la tabla de colores asociada a un mapa ráster."
#: ../raster/r.colors.out/raster3d_main.c:50
-#, fuzzy
msgid "Exports the color table associated with a 3D raster map."
+msgstr "Exporta la tabla de colores asociada con un mapa ráster 3D."
#: ../raster/r.colors.out/raster3d_main.c:70
-#, fuzzy, c-format
+#, c-format
msgid "Unable to read color table for raster3d map <%s>"
-msgstr "No se puede leer la tabla de color para el mapa raster <%s>"
+msgstr "No ha sido posible leer tabla de colores para mapa raster3d <%s>"
#: ../raster/r.out.mpeg/main.c:104
-#, fuzzy
msgid "animation"
-msgstr "Clasificación de puntos"
+msgstr "animación"
#: ../raster/r.out.mpeg/main.c:107
-#, fuzzy
msgid "Converts raster map series to MPEG movie."
-msgstr "Programa de conversión de series de archivos ráster a MPEG."
+msgstr "Convierte serie de mapas ráster a película MPEG."
#: ../raster/r.out.mpeg/main.c:115
#, fuzzy, c-format
@@ -30510,27 +27021,21 @@
msgstr "Factor de calidad (1 = calidad más alta, baja compresión)"
#: ../raster/r.out.mpeg/main.c:136
-#, fuzzy
msgid "Convert on the fly, uses less disk space"
-msgstr ""
-"Convertir al vuelo, usar menos espacio de disco\n"
-"\t(requiere r.out.ppm con la opción stdout)"
+msgstr "Convertir al vuelo, usar menos espacio de disco"
#: ../raster/r.out.mpeg/main.c:137
-#, fuzzy
msgid "Requires r.out.ppm with stdout option"
-msgstr ""
+msgstr "requiere r.out.ppm con la opción stdout"
#: ../raster/r.out.mpeg/main.c:160
msgid "Either mpeg_encode or ppmtompeg must be installed"
msgstr "Deben estar instalados mpeg_encode o ppmtompeg"
#: ../raster/r.out.mpeg/main.c:291
-#, fuzzy, c-format
+#, c-format
msgid "Unable to read color table for <%s>"
-msgstr "No se puede leer la tabla de color para %s"
+msgstr "No ha sido posible leer tabla de colores para <%s>"
#: ../raster/r.out.mpeg/main.c:341 ../raster/r.out.mpeg/main.c:374
msgid "mpeg_encode ERROR"
@@ -30560,11 +27065,11 @@
#: ../raster/r.out.bin/main.c:223
#, c-format
msgid "World File = %s"
-msgstr "ARchivo de referenciación = %s"
+msgstr ""
#: ../raster/r.out.bin/main.c:281
msgid "Exports a GRASS raster to a binary array."
-msgstr "Exporta un ráster de GRASS a una secuencia binaria."
+msgstr "Exporta un ráster de GRASS a una matriz binaria."
#: ../raster/r.out.bin/main.c:297
msgid "Name for output binary map (use output=- for stdout)"
@@ -30595,14 +27100,14 @@
msgstr ""
#: ../raster/r.out.bin/main.c:399
-#, fuzzy, c-format
+#, c-format
msgid "Floating-point output requires %s=4 or %s=8"
-msgstr "Un punto floating de salida requiere de bytes=4 o bytes=8"
+msgstr "Un punto flotante de salida requiere %s=4 o %s=8"
#: ../raster/r.out.bin/main.c:404
#, c-format
msgid "Integer output doesn't support %s=8 in this build"
-msgstr ""
+msgstr "Salida de enteros no soporta %s=8 en esta construcción"
#: ../raster/r.out.bin/main.c:419
msgid "GMT grid doesn't support 64-bit integers"
@@ -30613,18 +27118,18 @@
msgstr "Creando archivos de soporte BIL..."
#: ../raster/r.out.bin/main.c:442
-#, fuzzy, c-format
+#, c-format
msgid "Exporting raster as floating values (%s=%d)"
-msgstr "Exportando ráster como valores flotantes (bytes=%d)"
+msgstr "Exportando ráster como valores de punto flotante (%s=%d)"
#: ../raster/r.out.bin/main.c:445
msgid "Writing GMT float format ID=1"
msgstr "Escribiendo ID de formato flotante GMT=1"
#: ../raster/r.out.bin/main.c:448
-#, fuzzy, c-format
+#, c-format
msgid "Exporting raster as integer values (%s=%d)"
-msgstr "Exportando ráster como valores enteros (bytes=%d)"
+msgstr "Exportando ráster como valores enteros (%s=%d)"
#: ../raster/r.out.bin/main.c:451
msgid "Writing GMT integer format ID=2"
@@ -30641,15 +27146,12 @@
msgstr "c=%d"
#: ../raster/r.surf.contour/main.c:64
-#, fuzzy
msgid "Generates surface raster map from rasterized contours."
-msgstr ""
-"Programa de generación de superficies a partir de contornos rasterizados."
+msgstr "Genera mapas ráster de superficie a partir de contornos rasterizados."
#: ../raster/r.surf.contour/main.c:67
-#, fuzzy
msgid "Name of input raster map containing contours"
-msgstr "Nombre del mapa ráster existente que contiene los contornos"
+msgstr "Nombre de mapa ráster de entrada que contiene contornos"
#: ../raster/r.out.vrml/main.c:49
msgid "VRML"
@@ -30657,8 +27159,7 @@
#: ../raster/r.out.vrml/main.c:51
msgid "Exports a raster map to the Virtual Reality Modeling Language (VRML)."
-msgstr ""
-"Exporta un mapa ráster al Lenguaje de Modelado de Realidad Virtual (VRML)"
+msgstr "Exporta un mapa ráster al Lenguaje de Modelado de Realidad Virtual (VRML)"
#: ../raster/r.out.vrml/main.c:58
msgid "Name of input color map"
@@ -30697,50 +27198,37 @@
msgstr "transformación de color"
#: ../raster/r.his/main.c:73
-#, fuzzy
-msgid ""
-"Generates red, green and blue (RGB) raster map layers combining hue, "
-"intensity and saturation (HIS) values from user-specified input raster map "
-"layers."
-msgstr ""
-"Genera capas de mapa ráster roja, verde y azul combinando valores de matiz, "
-"intensidad y saturación (HIS) a partir de capas de mapa ráster de entrada "
-"especificadas por el usuario."
+msgid "Generates red, green and blue (RGB) raster map layers combining hue, intensity and saturation (HIS) values from user-specified input raster map layers."
+msgstr "Genera capas de mapa ráster roja, verde y azul (RGB) combinando valores de matiz, intensidad y saturación (HIS) a partir de capas de mapa ráster de entrada especificadas por el usuario."
#: ../raster/r.his/main.c:82 ../display/d.his/main.c:78
-#, fuzzy
msgid "Name of layer to be used for hue"
-msgstr "Nombre de la capa a usar para TONALIDAD"
+msgstr "Nombre de la capa a usar para tonalidad"
#: ../raster/r.his/main.c:89 ../display/d.his/main.c:85
-#, fuzzy
msgid "Name of layer to be used for intensity"
+msgstr "Nombre de la capa a usar para intensidad"
#: ../raster/r.his/main.c:96 ../display/d.his/main.c:92
-#, fuzzy
msgid "Name of layer to be used for saturation"
+msgstr "Nombre de la capa a usar para saturación"
#: ../raster/r.his/main.c:103
-#, fuzzy
msgid "Name of output layer to be used for red"
-msgstr "Nombre de la capa de salida a usar para el ROJO"
+msgstr "Nombre de capa de salida a usar para rojo"
#: ../raster/r.his/main.c:110
-#, fuzzy
msgid "Name of output layer to be used for green"
+msgstr "Nombre de capa de salida a usar para verde"
#: ../raster/r.his/main.c:117
-#, fuzzy
msgid "Name of output layer to be used for blue"
+msgstr "Nombre de capa de salida a usar para azul"
#: ../raster/r.his/main.c:145
-#, fuzzy, c-format
+#, c-format
msgid "No such color <%s>"
-msgstr "[%s]: No hay tal color"
+msgstr "No hay tal color <%s>"
#: ../raster/r.his/main.c:167 ../raster/r.his/main.c:183
#: ../raster/r.his/main.c:201 ../raster/r.out.ppm3/main.c:115
@@ -30754,52 +27242,41 @@
msgstr "Archivo de color para <%s> no disponible"
#: ../raster/r.fill.dir/main.c:89
-#, fuzzy
-msgid ""
-"Filters and generates a depressionless elevation map and a flow direction "
-"map from a given elevation raster map."
-msgstr ""
-"Filtra y genera un mapa de elevación sin depresiones y un mapa de dirección "
-"de flujo a partir de una capa de elevación dada."
+msgid "Filters and generates a depressionless elevation map and a flow direction map from a given elevation raster map."
+msgstr "Filtra y genera un mapa de elevación sin depresiones y un mapa de dirección de flujo a partir de un mapa ráster de elevaciones dado."
#: ../raster/r.fill.dir/main.c:96
-#, fuzzy
msgid "Name for output depressionless elevation raster map"
-msgstr "Producir mapa ráster de curvatura de perfil"
+msgstr "Nombre para mapa ráster de elevación de salida sin depresiones"
#: ../raster/r.fill.dir/main.c:100
-#, fuzzy
-msgid ""
-"Name for output flow direction map for depressionless elevation raster map"
-msgstr "(S) Mapa de dirección para mapa de elevación sin depresiones"
+msgid "Name for output flow direction map for depressionless elevation raster map"
+msgstr "Nombre para mapa ráster de salida de mapa de direcciones de flujo"
#: ../raster/r.fill.dir/main.c:105
-#, fuzzy
msgid "Name for output raster map of problem areas"
-msgstr "Producir mapa ráster de áreas problemáticas"
+msgstr "Nombre para mapa ráster de salida de áreas problema"
#: ../raster/r.fill.dir/main.c:112
-#, fuzzy
msgid "Aspect direction format"
-msgstr "Producir mapa ráster de dirección"
+msgstr "Formato de dirección de orientación (aspect)"
#: ../raster/r.fill.dir/main.c:118
msgid "Find unresolved areas only"
msgstr "Encontrar áreas no resueltas solamente"
#: ../raster/r.fill.dir/main.c:124
-#, fuzzy, c-format
+#, c-format
msgid "The '%c' flag requires '%s'to be specified"
-msgstr "2 capas deben ser especificadas"
+msgstr "La bandera '%c' requiere que '%s' esté especificada"
#: ../raster/r.fill.dir/main.c:145
msgid "Direction map is D8 resolution, i.e. 45 degrees"
-msgstr ""
+msgstr "Mapa de dirección es resolución D8, i.e. 45 grados"
#: ../raster/r.fill.dir/main.c:187
-#, fuzzy
msgid "Reading input elevation raster map..."
-msgstr "Leyendo mapa de elevación..."
+msgstr "Leyendo mapa ráster de elevaciones de entrada..."
#: ../raster/r.fill.dir/main.c:197
msgid "Filling sinks..."
@@ -30829,30 +27306,27 @@
msgstr "Pase %d hacia arriba"
#: ../raster/r.fill.dir/dopolys.c:84
-#, fuzzy, c-format
+#, c-format
msgid "Found %d unresolved area"
msgid_plural "Found %d unresolved areas"
-msgstr[0] "Encontradas %d áreas sin resolver"
-msgstr[1] "Encontradas %d áreas sin resolver"
+msgstr[0] "Se encontró %d área sin resolver"
+msgstr[1] "Se encontraron %d áreas sin resolver"
#: ../raster/r.relief/main.c:112
msgid "Creates shaded relief map from an elevation map (DEM)."
-msgstr ""
-"Crea un mapa compartido de relieve a partir de un mapa de elevaciones (DEM)."
+msgstr "Crea un mapa compartido de relieve a partir de un mapa de elevaciones (DEM)."
#: ../raster/r.relief/main.c:117
-#, fuzzy
msgid "Name for output shaded relief map"
+msgstr "Nombre para mapa de sombreado de relieve de salida"
#: ../raster/r.relief/main.c:125
msgid "Altitude of the sun in degrees above the horizon"
msgstr "Altura del sol sobre el horizonte en grados"
#: ../raster/r.relief/main.c:126 ../raster/r.relief/main.c:136
-#, fuzzy
msgid "Sun position"
-msgstr "Proyeccion del origen"
+msgstr "Posición del sol"
#: ../raster/r.relief/main.c:135
msgid "Azimuth of the sun in degrees to the east of north"
@@ -30863,34 +27337,30 @@
msgstr "Factor para exagerar el relive"
#: ../raster/r.relief/main.c:151
-#, fuzzy
msgid "Scale factor for converting meters to elevation units"
-msgstr ""
-"Factor de escala para convertir unidades horizontales a unidades de elevación"
+msgstr "Factor de escalamiento para convertir unidades horizontales a unidades de elevación"
#: ../raster/r.relief/main.c:158
-#, fuzzy
msgid "Elevation units (overrides scale factor)"
-msgstr "Valor no admitido para factor de escala"
+msgstr "Unidades de elevación (se impone sobre factor de escalamiento)"
#: ../raster/r.relief/main.c:163
-#, fuzzy
msgid "international feet"
-msgstr "vectorial, interpolación"
+msgstr "pie internacional"
#: ../raster/r.relief/main.c:164
msgid "survey feet"
msgstr ""
#: ../raster/r.relief/main.c:215
-#, fuzzy, c-format
+#, c-format
msgid "%s=%s - must not be zero"
-msgstr "%s = %s -- de ser un número posiivollll"
+msgstr "%s=%s - no debe ser cero"
#: ../raster/r.relief/main.c:474
-#, fuzzy, c-format
+#, c-format
msgid "Shaded relief raster map <%s> complete"
-msgstr "Mapa raster de pendientes <%s> terminado"
+msgstr "Mapa ráster de sombreado de relieve <%s> completado"
#: ../raster/r.to.rast3elev/main.c:99
msgid "The number of input and elevation maps is not equal"
@@ -30910,28 +27380,24 @@
#: ../raster/r.to.rast3elev/main.c:175 ../raster/r.to.rast3/main.c:84
msgid "The maximum tile size in kilo bytes. Default is 32KB."
-msgstr ""
+msgstr "Tamaño máximo de mosaico en kilo bytes. El predeterminado es 32KB."
#: ../raster/r.to.rast3elev/main.c:185
msgid "Use the input map values to fill the upper cells"
-msgstr ""
-"Usar los valores del mapa de entrada para rellenar las celdas superiores"
+msgstr "Usar los valores del mapa de entrada para rellenar las celdas superiores"
#: ../raster/r.to.rast3elev/main.c:190
msgid "Use the input map values to fill the lower cells"
-msgstr ""
-"Usar los valores del mapa de entrada para rellenar las celdas inferiores"
+msgstr "Usar los valores del mapa de entrada para rellenar las celdas inferiores"
#: ../raster/r.to.rast3elev/main.c:287 ../raster/r.to.rast3elev/main.c:320
#, fuzzy
msgid "Error writing 3D raster double data"
-msgstr "Error al escribir datos dobles G3D"
+msgstr "Error al escribir ráster 3D"
#: ../raster/r.to.rast3elev/main.c:366
msgid "Creates a 3D volume map based on 2D elevation and value raster maps."
-msgstr ""
-"Crea un mapa de volumen 3D basado en un mapas ráster de elevación 2D y "
-"valores."
+msgstr "Crea un mapa de volumen 3D basado en un mapas ráster de elevación 2D y valores."
#: ../raster/r.to.rast3elev/main.c:400
msgid "The upper value is not valid"
@@ -30942,13 +27408,8 @@
msgstr "El valor inferior no es válido"
#: ../raster/r.to.rast3elev/main.c:427
-#, fuzzy
-msgid ""
-"The 2D and 3D region settings are different. I will use the 3D region "
-"settings to adjust the 2D region."
-msgstr ""
-"Las configuraciones de la región 2D y 3D son diferentes. Usaré las "
-"configuraciones G3D para ajustar la región 2D."
+msgid "The 2D and 3D region settings are different. I will use the 3D region settings to adjust the 2D region."
+msgstr "Las configuraciones de la región 2D y 3D son diferentes. Usaré las configuraciones 3D para ajustar la región 2D."
#: ../raster/r.to.rast3elev/main.c:443 ../raster/r.to.rast3/main.c:291
msgid "Error opening 3D raster map"
@@ -30967,9 +27428,8 @@
msgstr "Exporta un ráster de GRASS a un archivo MAT binario."
#: ../raster/r.out.mat/main.c:73
-#, fuzzy
msgid "Name for output binary MAT file"
-msgstr "Nombre para el archivo MAT binario de salida"
+msgstr "Nombre para archivo binario MAT de salida"
#: ../raster/r.out.mat/main.c:113
#, c-format
@@ -31006,15 +27466,13 @@
msgstr "%ld bytes escritos a '%s'"
#: ../raster/r.rescale.eq/main.c:53 ../raster/r.rescale/main.c:49
-#, fuzzy
msgid "rescale"
-msgstr "ráster, remuestrear"
+msgstr "rescalar"
#: ../raster/r.rescale.eq/main.c:55
-msgid ""
-"Rescales histogram equalized the range of category values in a raster map "
-"layer."
-msgstr ""
+#, fuzzy
+msgid "Rescales histogram equalized the range of category values in a raster map layer."
+msgstr "Reescala histograma ecualizado de los valores de rango de categorías en una capa de mapa ráster."
#: ../raster/r.rescale.eq/main.c:61 ../raster/r.rescale/main.c:56
msgid "The name of the raster map to be rescaled"
@@ -31022,9 +27480,7 @@
#: ../raster/r.rescale.eq/main.c:69 ../raster/r.rescale/main.c:64
msgid "The input data range to be rescaled (default: full range of input map)"
-msgstr ""
-"Rango de datos de entrada a rescalar (por omisión: todo el rango del mapa de "
-"entrada)"
+msgstr "Rango de datos de entrada a rescalar (por omisión: todo el rango del mapa de entrada)"
#: ../raster/r.rescale.eq/main.c:72 ../raster/r.rescale/main.c:67
msgid "The resulting raster map name"
@@ -31049,9 +27505,8 @@
#: ../raster/r.recode/main.c:49
-#, fuzzy
msgid "recode categories"
-msgstr "%ld categorías"
+msgstr "recodifica categorías"
#: ../raster/r.recode/main.c:51
msgid "Recodes categorical raster maps."
@@ -31121,7 +27576,7 @@
#: ../raster/r.recode/read_rules.c:88
msgid "old_low:old_high:new_val (i.e. new_high == new_low)"
-msgstr ""
+msgstr "old_low:old_high:new_val (i.e. new_high == new_low)"
#: ../raster/r.recode/read_rules.c:89
msgid "*:old_val:new_val (interval [inf, old_val])"
@@ -31138,18 +27593,12 @@
#: ../raster/r.surf.gauss/main.c:42
#, fuzzy
msgid "Generates a raster map using gaussian random number generator."
-msgstr ""
-"de entrada."
+msgstr "Genera una capa de mapa raster de las distancias a los elementos en la capa de entrada."
#: ../raster/r.surf.gauss/main.c:44
#, fuzzy
-msgid ""
-"Mean and standard deviation of gaussian deviates can be expressed by the "
-"user."
-msgstr ""
-"Produce un mapa raster de desviaciones aleatorias uniformes cuyo intervalo "
-"puede ser expresado por el usuario."
+msgid "Mean and standard deviation of gaussian deviates can be expressed by the user."
+msgstr "Produce un mapa raster de desviaciones aleatorias uniformes cuyo intervalo puede ser expresado por el usuario."
#: ../raster/r.surf.gauss/main.c:51
msgid "Distribution mean"
@@ -31160,17 +27609,12 @@
msgstr "Desviación estándar"
#: ../raster/r.clump/main.c:56
-#, fuzzy
msgid "reclass"
-msgstr "%d clases."
+msgstr "reclasificar"
#: ../raster/r.clump/main.c:59
-msgid ""
-"Recategorizes data in a raster map by grouping cells that form physically "
-"discrete areas into unique categories."
-msgstr ""
-"Recategoriza datos en un mapa raster agrupando celdas que forman áreas "
-"físicamente discretas en categorías únicas."
+msgid "Recategorizes data in a raster map by grouping cells that form physically discrete areas into unique categories."
+msgstr "Recategoriza datos en un mapa raster agrupando celdas que forman áreas físicamente discretas en categorías únicas."
#: ../raster/r.clump/main.c:78
msgid "Threshold to identify similar cells"
@@ -31187,7 +27631,7 @@
#: ../raster/r.clump/main.c:84
msgid "Clumps are also traced along diagonal neighboring cells"
-msgstr ""
+msgstr "Agrupa también celdas diagonales vecinas"
#: ../raster/r.clump/main.c:88
#, fuzzy
@@ -31207,25 +27651,21 @@
msgstr[1] "%d grupos."
#: ../raster/r.clump/clump.c:72 ../raster/r.clump/clump.c:394
-#, fuzzy
msgid "Unable to open temp file"
-msgstr "No se puede abrir el archivo temporal."
+msgstr "No ha sido posible abrir archivo temporal"
#: ../raster/r.clump/clump.c:94 ../raster/r.clump/clump.c:409
-#, fuzzy
msgid "Pass 1 of 2..."
-msgstr "Pase: %d..."
+msgstr "Paso 1 de 2..."
#: ../raster/r.clump/clump.c:206 ../raster/r.clump/clump.c:220
#: ../raster/r.clump/clump.c:565 ../raster/r.clump/clump.c:579
-#, fuzzy
msgid "Unable to write to temp file"
-msgstr "No se pueden crear archivos temporales"
+msgstr "No ha sido posible escribir archivo temporal"
#: ../raster/r.clump/clump.c:264 ../raster/r.clump/clump.c:625
-#, fuzzy
msgid "Pass 2 of 2..."
+msgstr "Paso 2 de 2..."
#: ../raster/r.clump/clump.c:270 ../raster/r.clump/clump.c:631
#, fuzzy
@@ -31240,14 +27680,13 @@
#: ../raster/r.clump/clump.c:367 ../imagery/i.segment/open_files.c:69
#: ../imagery/i.segment/open_files.c:228 ../imagery/i.segment/open_files.c:236
#: ../imagery/i.segment/write_output.c:116
-#, fuzzy, c-format
+#, c-format
msgid "No min/max found in raster map <%s>"
-msgstr "Columna <%s> no encontrada en la tabla <%s>"
+msgstr "No hay mínimo/máximo en mapa ráster <%s>"
#: ../raster/r.drain/main.c:113
#, fuzzy
-msgid ""
-"Traces a flow through an elevation model or cost surface on a raster map."
+msgid "Traces a flow through an elevation model or cost surface on a raster map."
msgstr "Traza un flujo mediante un modelo de elevación sobre un mapa raster."
#: ../raster/r.drain/main.c:116
@@ -31257,7 +27696,7 @@
#: ../raster/r.drain/main.c:121
msgid "Name of input movement direction map associated with the cost surface"
-msgstr ""
+msgstr "Nombre de mapa de dirección de movimiento asociado con la superficie de coste"
#: ../raster/r.drain/main.c:123 ../raster/r.drain/main.c:164
#, fuzzy
@@ -31265,13 +27704,12 @@
msgstr "Varianza de la suma"
#: ../raster/r.drain/main.c:131
-#, fuzzy
msgid "Name for output drain vector map"
-msgstr "Nombre vectorial"
+msgstr "Nombre para mapa vectorial de salida de drenaje"
#: ../raster/r.drain/main.c:132
msgid "Recommended for cost surface made using knight's move"
-msgstr ""
+msgstr "Recomendado para superficie de coste hecha usando movimiento de knight"
#: ../raster/r.drain/main.c:142
#, fuzzy
@@ -31296,32 +27734,26 @@
msgstr "Contar números de celdas a lo largo de la ruta"
#: ../raster/r.drain/main.c:163
-msgid ""
-"The input raster map is a cost surface (direction surface must also be "
-"specified)"
-msgstr ""
+msgid "The input raster map is a cost surface (direction surface must also be specified)"
+msgstr "El mapa ráster de entrada es una superficie de coste (se debe especificar tambien dirección de coste)"
#: ../raster/r.drain/main.c:175
msgid "Directional drain selected... checking for direction raster map"
-msgstr ""
+msgstr "Drenado superficial seleccionado... revsando para mapa ráster de dirección"
#: ../raster/r.drain/main.c:178
msgid "Surface/Hydrology drain selected"
-msgstr ""
+msgstr "Superficie/Hidrología de drenado seleccionada"
#: ../raster/r.drain/main.c:183
#, c-format
-msgid ""
-"Direction raster map <%s> not specified, if direction flag is on, a "
-"direction raster must be given"
-msgstr ""
+msgid "Direction raster map <%s> not specified, if direction flag is on, a direction raster must be given"
+msgstr "Mapa ráster de dirección <%s> no especificado, si la bandera direction está dada, se debe proporcionar un mapa ráster de dirección"
#: ../raster/r.drain/main.c:190
#, c-format
-msgid ""
-"Direction raster map <%s> should not be specified for Surface/Hydrology "
-"drains"
-msgstr ""
+msgid "Direction raster map <%s> should not be specified for Surface/Hydrology drains"
+msgstr "Mapa ráster de dirección <%s> no debe ser especificado para drenado Superficie/Hidrología"
#: ../raster/r.drain/main.c:209
msgid "Specify just one of the -c, -a and -n flags"
@@ -31335,8 +27767,7 @@
#: ../raster/r.drain/main.c:315
#, c-format
msgid "Starting vector map <%s> contains no points in the current region"
-msgstr ""
-"El comienzo del mapa vectorial <%s> no contiene puntos en la región actual"
+msgstr "El comienzo del mapa vectorial <%s> no contiene puntos en la región actual"
#: ../raster/r.drain/main.c:323
msgid "No start/stop point(s) specified"
@@ -31347,9 +27778,8 @@
msgstr "Calculando direcciones de flujo..."
#: ../raster/r.drain/main.c:467
-#, fuzzy
msgid "Writing output raster map..."
-msgstr "Escribiendo mapa ráster de salida %s... "
+msgstr "Escribiendo mapa ráster de salida..."
#: ../raster/r.drain/main.c:519 ../raster/r.composite/main.c:191
#: ../raster/r.random.surface/save.c:98 ../raster/r.random.cells/indep.c:139
@@ -31370,9 +27800,8 @@
#: ../raster/r.water.outlet/main.c:59 ../raster/r.watershed/front/main.c:75
#: ../raster/r.basins.fill/main.c:56
-#, fuzzy
msgid "watershed"
-msgstr "wtrshed pass %d"
+msgstr "cuenca"
#: ../raster/r.water.outlet/main.c:62
#, fuzzy
@@ -31380,9 +27809,8 @@
#: ../raster/r.water.outlet/main.c:65
-#, fuzzy
msgid "Name for output watershed basin map"
+msgstr "Nombre para mapa de salida de cuencas hidrográficas"
#: ../raster/r.water.outlet/main.c:68
#, fuzzy
@@ -31405,25 +27833,20 @@
#: ../raster/r.stats/main.c:109
-#, fuzzy
msgid "Generates area statistics for raster map."
-msgstr "Genera estadísticas de superficie para capas de mapa ráster."
+msgstr "Genera estadísticas de mapa ráster"
#: ../raster/r.stats/main.c:157
-#, fuzzy
msgid "Print area totals in square meters"
-msgstr "Imprimir totales de áreas"
+msgstr "Mostrar total de área en metros cuadrados"
#: ../raster/r.stats/main.c:162
-#, fuzzy
msgid "Print cell counts (sortable)"
-msgstr "Imprimir cuenta de celdas"
+msgstr "Mostrar conteo de celdas (es ordenable)"
#: ../raster/r.stats/main.c:168
-#, fuzzy
msgid "Print approximate (total percent may not be 100%) percents"
-msgstr ""
-"Imprimir porcentajes APROXIMADOS (el porcentaje total puede no ser 100%)"
+msgstr "Mostrar porcentajes aproximados (porcentaje total no puede mayor que 100%)"
#: ../raster/r.stats/main.c:173
msgid "Print category labels"
@@ -31438,9 +27861,8 @@
msgstr "Imprimir coordenadas de cuadrícula (Este y Norte)"
#: ../raster/r.stats/main.c:182 ../raster/r.stats/main.c:187
-#, fuzzy
msgid "Coordinates"
-msgstr "Precisión de coordenadas"
+msgstr "Coordenadas"
#: ../raster/r.stats/main.c:186
msgid "Print x and y (column and row)"
@@ -31463,30 +27885,18 @@
#: ../raster/r.stats/main.c:303
#, c-format
-msgid ""
-"Raster map <%s> is reading as integer map! Flag '-%c' and/or '%s' option "
-"will be ignored."
-msgstr ""
-"El mapa raster <%s> está leyendo como un mapa integer! Flag '-%c' y/o '%s' "
-"la opción será ignorada."
+msgid "Raster map <%s> is reading as integer map! Flag '-%c' and/or '%s' option will be ignored."
+msgstr "El mapa raster <%s> está leyendo como un mapa integer! Flag '-%c' y/o '%s' la opción será ignorada."
#: ../raster/r.stats/main.c:319
#, c-format
-msgid ""
-"Cats for raster map <%s> are either missing or have no explicit labels. "
-"Using %s=%d."
-msgstr ""
-"Las Cats para el mapa raster <%s> o faltan o no tienen etiquetas explícitas. "
-"Utilizando %s=%d. "
+msgid "Cats for raster map <%s> are either missing or have no explicit labels. Using %s=%d."
+msgstr "Las Cats para el mapa raster <%s> o faltan o no tienen etiquetas explícitas. Utilizando %s=%d. "
#: ../raster/r.stats/main.c:325
#, c-format
-msgid ""
-"Flag '-%c' was given, using cats fp ranges of raster map <%s>, ignoring '%s' "
-"option"
-msgstr ""
-"Se dio Flag '-%c' , utilizando rangos fp de categorías mapa raster <%s>, "
-"ignorando '%s' opción "
+msgid "Flag '-%c' was given, using cats fp ranges of raster map <%s>, ignoring '%s' option"
+msgstr "Se dio Flag '-%c' , utilizando rangos fp de categorías mapa raster <%s>, ignorando '%s' opción "
#: ../raster/r.stats/main.c:331 ../raster/r.contour/main.c:149
#, c-format
@@ -31527,24 +27937,11 @@
#, fuzzy, c-format
msgid ""
"USAGE for basin delineation:\n"
-"%s -4 elevation=elevation_map threshold=swale_threshold "
-"[flow=overland_flow_map] [drainage=drain_direction_map] "
-"[depression=depression_map] [accumulation=accumulation_map] "
-"[basin=watershed_basin_map] [stream=stream_segment_map]\n"
+"%s -4 elevation=elevation_map threshold=swale_threshold [flow=overland_flow_map] [drainage=drain_direction_map] [depression=depression_map] [accumulation=accumulation_map] [basin=watershed_basin_map] [stream=stream_segment_map]\n"
"\n"
"USAGE for slope length determination:\n"
-"%s [-4] elevation=elevation_map threshold=swale_threshold "
-"[drainage=drain_direction_map] [depression=depression_map] "
-"[accumulation=accumulation_map] [max_slope_length=max_slope_length] "
-"[blocking=overland_blocking_map] [slope_steepness=slope_steepness_map] "
-"length_slope=length_slope_map [disturbed_land=rill_erosion_map] "
-"[slope_deposition=slope_deposition value or map]USAGE for ARMSED FILE "
-"creation:\n"
-"[basin=watershed_basin_map] [stream=stream_segment_map] "
-"[half_basin=half_basin_map] ar=ARMSED_file_name\n"
+"%s [-4] elevation=elevation_map threshold=swale_threshold [drainage=drain_direction_map] [depression=depression_map] [accumulation=accumulation_map] [max_slope_length=max_slope_length] [blocking=overland_blocking_map] [slope_steepness=slope_steepness_map] length_slope=length_slope_map [disturbed_land=rill_erosion_map] [slope_deposition=slope_deposition value or map]USAGE for ARMSED FILE creation:\n"
+"%s [-4] elevation=elevation_map threshold=swale_threshold [flow=overland_flow_map] [drainage=drain_direction_map] [depression=depression_map] [accumulation=accumulation_map] [basin=watershed_basin_map] [stream=stream_segment_map] [half_basin=half_basin_map] ar=ARMSED_file_name\n"
"\n"
msgstr ""
"USO para delineación de cuenca:\n"
@@ -31553,11 +27950,10 @@
#: ../raster/r.watershed/ram/close_maps2.c:34
#: ../raster/r.watershed/seg/close_maps2.c:38
msgid "No basins were created. Verify threshold and region settings."
-msgstr ""
+msgstr "No se crearon cuencas. Verificar umbral y configuraciones de región."
#: ../raster/r.watershed/ram/do_astar.c:27
#: ../raster/r.watershed/seg/do_astar.c:30
-#, fuzzy
msgid "SECTION 2: A* Search."
msgstr "SECCIÓN 2: A * Buscar."
@@ -31631,23 +28027,20 @@
#: ../raster/r.watershed/ram/do_cum.c:276
#: ../raster/r.watershed/seg/do_cum.c:293
-#, fuzzy
msgid "SECTION 3a: Accumulating Surface Flow with MFD."
-msgstr "SECCIÓN 3: Acumulando Flujo de Superficie con MFD."
+msgstr "SECCIÓN 3: acumulando flujo superficial con MFD."
#: ../raster/r.watershed/ram/do_cum.c:443
#: ../raster/r.watershed/seg/do_cum.c:487
#: ../raster/r.stream.extract/streams.c:336
#, c-format
msgid "MFD: cumulative proportion of flow distribution not 1.0 but %f"
-msgstr ""
-"MFD: la proporción acumulativa de la distribución de flujo no es 1.0 sino %f"
+msgstr "MFD: la proporción acumulativa de la distribución de flujo no es 1.0 sino %f"
#: ../raster/r.watershed/ram/do_cum.c:480
#, c-format
msgid "MFD: A * path already processed when distributing flow: %d of %d cell"
-msgid_plural ""
-"MFD: A * path already processed when distributing flow: %d of %d cells"
+msgid_plural "MFD: A * path already processed when distributing flow: %d of %d cells"
msgstr[0] ""
msgstr[1] ""
@@ -31689,15 +28082,11 @@
#: ../raster/r.watershed/shed/basin_maps.c:13
msgid "parameter hydrologic/soil erosion model. Continue inputing cell map"
-msgstr ""
-"modelo de erosión hidrológica/de terreno de parámetros agrupados. Continuar "
-"introduciendo capas de mapas"
+msgstr "modelo de erosión hidrológica/de terreno de parámetros agrupados. Continuar introduciendo capas de mapas"
#: ../raster/r.watershed/shed/basin_maps.c:14
msgid "layers, one at a time, until all desired map layers are in."
-msgstr ""
-"de celdas, una cada vez, hasta que todas las capas de mapa deseadas estén "
-"dentro."
+msgstr "de celdas, una cada vez, hasta que todas las capas de mapa deseadas estén dentro."
#: ../raster/r.watershed/shed/basin_maps.c:15
#, c-format
@@ -31783,9 +28172,7 @@
#: ../raster/r.watershed/shed/intro.c:10
#, c-format
msgid "%s also allows the user to prepare a report of map layers for each"
-msgstr ""
-"%s también perm
