[GRASS-SVN] r68672 - sandbox/bo/i.segment.gsoc2016/i.segment
Sun Jun 12 12:39:57 PDT 2016
Author: hao2309
Date: 2016-06-12 12:39:56 -0700 (Sun, 12 Jun 2016)
New Revision: 68672
   sandbox/bo/i.segment.gsoc2016/i.segment/mean_shift.c
   sandbox/bo/i.segment.gsoc2016/i.segment/open_files.c
   sandbox/bo/i.segment.gsoc2016/i.segment/parse_args.c
debugging in progress, some glabal paramters won't be read, e.g. globals->msspatial_bandwidth
Modified: sandbox/bo/i.segment.gsoc2016/i.segment/mean_shift.c
--- sandbox/bo/i.segment.gsoc2016/i.segment/mean_shift.c	2016-06-12 19:09:49 UTC (rev 68671)
+++ sandbox/bo/i.segment.gsoc2016/i.segment/mean_shift.c	2016-06-12 19:39:56 UTC (rev 68672)
@@ -34,14 +34,16 @@
 int mean_shift(struct globals *globals)
     int row, col, t;
-    int n_changes;
+    int n_changes, window_size;
     double alpha2;
     struct ngbr_stats Rin, Rout, Rwin;
     double diff2;
     /* G_fatal_error(_("Mean shift is not yet implemented"));
     return FALSE; */
+	double ms_spatial_bandwidth = 3;
+	double ms_range_bandwidth = 0.1;
     Rin.mean = G_malloc(globals->datasize);
 	Rwin.mean = G_malloc(globals->datasize);
     Rout.mean = G_malloc(globals->datasize);
@@ -50,12 +52,14 @@
      * initially, input and output are original band values */
 	/* set the pointers */
 	globals->bands_in = &globals->bands_seg;
-	globals->bands_out = &globals->bands_seg2;
+	globals->bands_out = &globals->bands_seg;
 	/*window size in pixel number*/
-	int window_size = globals->ms_spatial_bandwidth*2+1;
-    alpha2 = globals->alpha * globals->alpha;
+	window_size = ms_spatial_bandwidth*2+1;
+    /* alpha2 = globals->alpha * globals->alpha;
+	use local threshold for temporal testing,*/
+    alpha2 = 0.0001;
     t = 0;
     n_changes = 1;
     while (t < globals->end_t && n_changes > 0) {
@@ -82,7 +86,6 @@
 	G_debug(4, "Starting to process %ld candidate cells",
 		globals->candidate_count);
@@ -119,44 +122,53 @@
 		/* calculate new band values */
 		double sum_of_weights = 0;
-		double *px_new_val = G_malloc(sizeof(double) * globals->nbands);
+		G_message(_("window_size is: %d"),window_size);
+		G_message(_("globals->bands_max is: %d"),globals->bands_max);
+		G_message(_("window_row_north is: %d"),window_row_north);
+		G_message(_("window_row_south is: %d"),window_row_south);
+		G_message(_("window_col_west is: %d"),window_col_west);
+		G_message(_("window_col_east is: %d"),window_col_east);
+		/* get the current pixel value */
+		Segment_get(globals->bands_in, (void *)Rin.mean, row, col);
+		G_message(_("row: %d, col: %d, Rin.mean is: %f"),row,col,Rin.mean[0]);
 		/* start of the moving window */
 		for (int current_window_row = window_row_north;current_window_row<window_row_south;current_window_row++){
 			for (int current_window_col = window_col_west;current_window_col<window_col_east;current_window_col++){
 				double weight = 1;
 				/* adapt initial spatial and range bandwidths */
-				double distance2 = pow((current_window_row - row),2)+pow((current_window_col - col),2);
-				if (distance2 <= pow(globals->ms_spatial_bandwidth,2)){
-					/* get the current pixel value */
-					Segment_get(globals->bands_in, (void *)Rin.mean,row, col);
+				if (pow((current_window_row - row),2)+pow((current_window_col - col),2) <= pow(ms_spatial_bandwidth,2)){
 					/* get the current moving window pixel value */
 					Segment_get(&globals->bands_seg, (void *)Rwin.mean,current_window_row, current_window_col);
+					// G_message(_("row: %d, col: %d, Rin.mean is: %f"),row,col,Rin.mean[0]);
+					// G_message(_("row: %d, col: %d, Rwin is: %f"),row,col,Rwin.mean[0]);
 					/* check range bandwidth */
-					if ((globals->calculate_similarity)(&Rin, &Rwin, globals) <= (globals->ms_range_bandwidth * globals->ms_range_bandwidth)){
+					if ((globals->calculate_similarity)(&Rin, &Rwin, globals) <= pow((ms_range_bandwidth * globals->max_diff),2)){
 						int n = globals->nbands - 1;
+						/* I think sum_of_weights should be place out of loop because only the same index band pixels will take part in the calculation(Rout.mean[n] += Rwin.mean[n]*weight) */
+						sum_of_weights += weight;
 						do{
 							weight *=1;/* later can apply gaussian kernal */
-							sum_of_weights += weight;
-							px_new_val[n] += Rwin.mean[n]*weight;
+							Rout.mean[n] += Rwin.mean[n]*weight;
 						} while(n--);
 			}/* end of moving window col */
 		}/* end of moving window row */
+		int n1 = globals->nbands - 1;
+		do{
+			Rout.mean[n1] /=sum_of_weights;
+		} while(n1--);
+		G_message(_("row: %d, col: %d, Rout.mean is: %f"),row,col,Rout.mean[0]);
 		/* write the output to bands_out*/
-		int n = globals->nbands - 1;
-		do{
-			Rout.mean[n] = px_new_val[n];
-			Rout.mean[n] /= sum_of_weights;
-		}while(n--);
-		Segment_put(globals->bands_out, (void *)Rout.mean, row, col);
+		Segment_put(&globals->bands_seg, (void *)Rout.mean, row, col);
 		/* Segment_put(&globals->bands_seg2, (void *)Rout.mean, row, col); */
 		/* if the squared difference between old and new band values
 		 * is larger than alpha2, then increase n_changes */
@@ -164,6 +176,13 @@
 		if (diff2 > alpha2)
 		    n_changes++;
+		/* reset Rout to zero to prepare next iteration */
+		int n2 = globals->nbands - 1;
+		do{
+			Rout.mean[n2] =0;
+		} while(n2--);
+		G_message(_("row: %d, col: %d, diff2 is: %f"),row,col,diff2);
 	    }/* end col iteration */
 	}/* end row iteration */
     }/* end while iteration */
@@ -177,15 +196,15 @@
     return TRUE;
-/* test out put the result */
-void print_matrix(struct globals *globals){
-	int i,j;
-	struct ngbr_stats R_prt;
-	R_prt.mean = G_malloc(globals->datasize);
-	for (i = globals->row_min; i < globals->row_max; i++){
-	    for (j = globals->col_min; j < globals->col_max; j++) {
-			Segment_get(&globals->bands_seg, (void *)R_prt.mean,i, j);
-			G_message(_("\t%.2f"),R_prt.mean[0]);
\ No newline at end of file
+// /* test out put the result */
+// void print_matrix(struct globals *globals){
+	// int i,j;
+	// struct ngbr_stats R_prt;
+	// R_prt.mean = G_malloc(globals->datasize);
+	// for (i = globals->row_min; i < globals->row_max; i++){
+	    // for (j = globals->col_min; j < globals->col_max; j++) {
+			// Segment_get(&globals->bands_seg, (void *)R_prt.mean,i, j);
+			// G_message(_("\t%.2f"),R_prt.mean[0]);
Modified: sandbox/bo/i.segment.gsoc2016/i.segment/open_files.c
--- sandbox/bo/i.segment.gsoc2016/i.segment/open_files.c	2016-06-12 19:09:49 UTC (rev 68671)
+++ sandbox/bo/i.segment.gsoc2016/i.segment/open_files.c	2016-06-12 19:39:56 UTC (rev 68672)
@@ -174,11 +174,11 @@
 	                    (void *)globals->bands_val, row, col) != 1)
 		G_fatal_error(_("Unable to write to temporary file"));
-		/* add globals->bands_seg2 when using mean shift */
-		if (globals->method == ORM_MS){
-			if(Segment_put(&globals->bands_seg2, &globals->bands_seg, row, col) !=1);
-			G_fatal_error(_("Unable to initiate the shift-value band for mean-shift"));
+		// /* add globals->bands_seg2 when using mean shift */
+		// if (globals->method == ORM_MS){
+			// if(Segment_put(&globals->bands_seg2, (void *)globals->bands_val, row, col) !=1);
+			// G_fatal_error(_("Unable to initiate the shift-value band for mean-shift"));
 	    if (!is_null) {
Modified: sandbox/bo/i.segment.gsoc2016/i.segment/parse_args.c
--- sandbox/bo/i.segment.gsoc2016/i.segment/parse_args.c	2016-06-12 19:09:49 UTC (rev 68671)
+++ sandbox/bo/i.segment.gsoc2016/i.segment/parse_args.c	2016-06-12 19:39:56 UTC (rev 68672)
@@ -47,7 +47,7 @@
     ms_spatial_bandwidth->key = "ms_spatial_bandwidth";
     ms_spatial_bandwidth->type = TYPE_DOUBLE;
     ms_spatial_bandwidth->required = NO;
-    ms_spatial_bandwidth->answer = "2";
+    ms_spatial_bandwidth->answer = "3";
     ms_spatial_bandwidth->options = "1-32";
     ms_spatial_bandwidth->description = _("Moving window radiuns (1-32 in number of pixel) for mean shift");
     ms_spatial_bandwidth->guisection = _("MS_Settings");
