[GRASS-SVN] r68673 - sandbox/bo/i.segment.gsoc2016/i.segment
svn_grass at osgeo.org
Sun Jun 12 13:17:14 PDT 2016
Author: hao2309
Date: 2016-06-12 13:17:14 -0700 (Sun, 12 Jun 2016)
New Revision: 68673
sandbox/bo/i.segment.gsoc2016/i.segment/mean_shift.c
sandbox/bo/i.segment.gsoc2016/i.segment/open_files.c
debugging ongoing, can't add bands_seg2 to openfile.c, grass stop running
Modified: sandbox/bo/i.segment.gsoc2016/i.segment/mean_shift.c
--- sandbox/bo/i.segment.gsoc2016/i.segment/mean_shift.c 2016-06-12 19:39:56 UTC (rev 68672)
+++ sandbox/bo/i.segment.gsoc2016/i.segment/mean_shift.c 2016-06-12 20:17:14 UTC (rev 68673)
@@ -33,17 +33,20 @@
int mean_shift(struct globals *globals)
- int row, col, t;
+ int row, col, current_window_row, current_window_col, t;
int n_changes, window_size;
+ int window_row_north, window_row_south, window_col_west,window_col_east;
double alpha2;
struct ngbr_stats Rin, Rout, Rwin;
- double diff2;
- /* G_fatal_error(_("Mean shift is not yet implemented"));
- return FALSE; */
+ double weight, sum_of_weights, diff2;
+ double min_val, max_val;
double ms_spatial_bandwidth = 3;
double ms_range_bandwidth = 0.1;
+ /* G_fatal_error(_("Mean shift is not yet implemented"));
+ return FALSE; */
Rin.mean = G_malloc(globals->datasize);
Rwin.mean = G_malloc(globals->datasize);
Rout.mean = G_malloc(globals->datasize);
@@ -52,7 +55,7 @@
* initially, input and output are original band values */
/* set the pointers */
globals->bands_in = &globals->bands_seg;
- globals->bands_out = &globals->bands_seg;
+ globals->bands_out = &globals->bands_seg2;
/*window size in pixel number*/
window_size = ms_spatial_bandwidth*2+1;
@@ -83,6 +86,7 @@
FLAG_SET(globals->candidate_flag, row, col);
globals->candidate_count++;
@@ -98,13 +102,13 @@
if (!(FLAG_GET(globals->candidate_flag, row, col)))
continue;
/* left bound of the window */
- int window_row_north = row - globals->ms_spatial_bandwidth;
+ window_row_north = row - globals->ms_spatial_bandwidth;
/* right bound of the window */
- int window_row_south = window_row_north + window_size;
+ window_row_south = window_row_north + window_size;
/* upper bound of the window */
- int window_col_west = col - globals->ms_spatial_bandwidth;
+ window_col_west = col - globals->ms_spatial_bandwidth;
/* lower bound of the window */
- int window_col_east = window_col_west + window_size;
+ window_col_east = window_col_west + window_size;
/* clip window in the edge */
if (window_row_north < globals->row_min){
@@ -121,10 +125,9 @@
/* calculate new band values */
- double sum_of_weights = 0;
+ sum_of_weights = 0;
G_message(_("window_size is: %d"),window_size);
- G_message(_("globals->bands_max is: %d"),globals->bands_max);
G_message(_("window_row_north is: %d"),window_row_north);
G_message(_("window_row_south is: %d"),window_row_south);
G_message(_("window_col_west is: %d"),window_col_west);
@@ -133,23 +136,24 @@
/* get the current pixel value */
Segment_get(globals->bands_in, (void *)Rin.mean, row, col);
G_message(_("row: %d, col: %d, Rin.mean is: %f"),row,col,Rin.mean[0]);
/* start of the moving window */
- for (int current_window_row = window_row_north;current_window_row<window_row_south;current_window_row++){
- for (int current_window_col = window_col_west;current_window_col<window_col_east;current_window_col++){
- double weight = 1;
+ for (current_window_row = window_row_north;current_window_row<window_row_south;current_window_row++){
+ for (current_window_col = window_col_west;current_window_col<window_col_east;current_window_col++){
+ weight = 1;
/* adapt initial spatial and range bandwidths */
if (pow((current_window_row - row),2)+pow((current_window_col - col),2) <= pow(ms_spatial_bandwidth,2)){
/* get the current moving window pixel value */
- Segment_get(&globals->bands_seg, (void *)Rwin.mean,current_window_row, current_window_col);
+ Segment_get(globals->bands_in, (void *)Rwin.mean,current_window_row, current_window_col);
// G_message(_("row: %d, col: %d, Rin.mean is: %f"),row,col,Rin.mean[0]);
// G_message(_("row: %d, col: %d, Rwin is: %f"),row,col,Rwin.mean[0]);
/* check range bandwidth */
if ((globals->calculate_similarity)(&Rin, &Rwin, globals) <= pow((ms_range_bandwidth * globals->max_diff),2)){
- int n = globals->nbands - 1;
/* I think sum_of_weights should be place out of loop because only the same index band pixels will take part in the calculation(Rout.mean[n] += Rwin.mean[n]*weight) */
sum_of_weights += weight;
+ int n = globals->nbands - 1;
do{
weight *=1;/* later can apply gaussian kernal */
Rout.mean[n] += Rwin.mean[n]*weight;
@@ -166,7 +170,7 @@
G_message(_("row: %d, col: %d, Rout.mean is: %f"),row,col,Rout.mean[0]);
/* write the output to bands_out*/
- Segment_put(&globals->bands_seg, (void *)Rout.mean, row, col);
+ Segment_put(globals->bands_out, (void *)Rout.mean, row, col);
/* Segment_put(&globals->bands_seg2, (void *)Rout.mean, row, col); */
/* if the squared difference between old and new band values
Modified: sandbox/bo/i.segment.gsoc2016/i.segment/open_files.c
--- sandbox/bo/i.segment.gsoc2016/i.segment/open_files.c 2016-06-12 19:39:56 UTC (rev 68672)
+++ sandbox/bo/i.segment.gsoc2016/i.segment/open_files.c 2016-06-12 20:17:14 UTC (rev 68673)
@@ -174,7 +174,7 @@
(void *)globals->bands_val, row, col) != 1)
G_fatal_error(_("Unable to write to temporary file"));
- // /* add globals->bands_seg2 when using mean shift */
+ /* add globals->bands_seg2 when using mean shift */
// if (globals->method == ORM_MS){
// if(Segment_put(&globals->bands_seg2, (void *)globals->bands_val, row, col) !=1);
// G_fatal_error(_("Unable to initiate the shift-value band for mean-shift"));
