[GRASS-SVN] r68680 - grass-addons/grass7/imagery/i.segment.stats
svn_grass at osgeo.org
Tue Jun 14 03:23:29 PDT 2016
Author: mlennert
Date: 2016-06-14 03:23:28 -0700 (Tue, 14 Jun 2016)
New Revision: 68680
grass-addons/grass7/imagery/i.segment.stats/i.segment.stats.html
grass-addons/grass7/imagery/i.segment.stats/i.segment.stats.py
i.segment.stats: leave it up to the user to run r.clump if necessary
Modified: grass-addons/grass7/imagery/i.segment.stats/i.segment.stats.html
--- grass-addons/grass7/imagery/i.segment.stats/i.segment.stats.html 2016-06-13 19:43:53 UTC (rev 68679)
+++ grass-addons/grass7/imagery/i.segment.stats/i.segment.stats.html 2016-06-14 10:23:28 UTC (rev 68680)
@@ -1,30 +1,42 @@
<h2>DESCRIPTION</h2>
+<p>
<em>i.segment.stats</em> calculates statistics for areas in a raster
map. Areas are defined by adjacent pixels with the same value. Such
areas can be the output of <a href="i.segment.html">i.segment</a> or
<a href="r.clump.html">r.clump</a>.
+<p>
Available statistics are those related to the shape and size of the areas
(see the <a href="v.to.db.html">v.to.db</a> man page for more information
on the statistics) and aggregated statistics of pixel values of other
raster maps (see <a href="v.univar.html">v.univar</a> for details).
+<p>
The user can chose between output in the form of a vector map of the areas
with the statistics in the attribute table and/or in the form of a CSV
text file.
<h2>NOTES</h2>
+<p>
The module respects the current region settings. The <em>-r</em> flag allows
to force the module to adjust the region to the input raster map before
calculating the statistics.
+<p>
This module is a simple front-end to <a href="v.univar.html">v.univar</a>
and <a href="v.to.db.html">v.to.db</a>. If other statistics are desired,
these should probably be implemented in those (or other) modules which
can then be called from this module.
+<p>
+Problems can arise in the calculation of some form statistics for certain
+segment forms. If errors arise, the user might want to try to run
+<a href="r.clump.html">r.clump</a> on the input raster file before running
+<em>i.segment.stats</em>.
<h2>EXAMPLE</h2>
<div class="code"><pre>
Modified: grass-addons/grass7/imagery/i.segment.stats/i.segment.stats.py
--- grass-addons/grass7/imagery/i.segment.stats/i.segment.stats.py 2016-06-13 19:43:53 UTC (rev 68679)
+++ grass-addons/grass7/imagery/i.segment.stats/i.segment.stats.py 2016-06-14 10:23:28 UTC (rev 68680)
@@ -87,9 +87,6 @@
if grass.find_file(temporary_vect, element='vector')['name']:
grass.run_command('g.remove', flags='f', type_='vector',
name=temporary_vect, quiet=True)
- if grass.find_file(temporary_clumped_rast, element='cell')['name']:
- grass.run_command('g.remove', flags='f', type_='raster',
- name=temporary_clumped_rast, quiet=True)
if insert_sql:
os.remove(insert_sql)
@@ -111,8 +108,6 @@
insert_sql = None
global temporary_vect
- global temporary_clumped_rast
- temporary_clumped_rast = 'segmstat_tmp_clumpedrast_%d' % os.getpid()
temporary_vect = 'segmstat_tmp_vect_%d' % os.getpid()
raster_stat_dict = {'zone': 0, 'min': 4, 'third_quart': 16, 'max': 5, 'sum':
@@ -125,12 +120,8 @@
grass.use_temp_region()
grass.run_command('g.region', raster=segment_map)
- grass.run_command('r.clump',
- input_=segment_map,
- output=temporary_clumped_rast,
- quiet=True)
grass.run_command('r.to.vect',
- input_=temporary_clumped_rast,
+ input_=segment_map,
output=temporary_vect,
type_='area',
flags='vt')
@@ -153,7 +144,7 @@
stat_indices = [raster_stat_dict[x] for x in raster_statistics]
res=grass.read_command('r.univar',
map_=raster,
- zones=temporary_clumped_rast,
+ zones=segment_map,
flags='et').splitlines()[1:]
for element in res:
values = element.split('|')
