[GRASS-SVN] r68681 - grass/trunk/raster/r.patch
svn_grass at osgeo.org
Tue Jun 14 07:40:47 PDT 2016
Author: mlennert
Date: 2016-06-14 07:40:47 -0700 (Tue, 14 Jun 2016)
New Revision: 68681
grass/trunk/raster/r.patch/main.c
grass/trunk/raster/r.patch/r.patch.html
r.patch: add flag to avoid creation of color and category files
Modified: grass/trunk/raster/r.patch/main.c
--- grass/trunk/raster/r.patch/main.c 2016-06-14 10:23:28 UTC (rev 68680)
+++ grass/trunk/raster/r.patch/main.c 2016-06-14 14:40:47 UTC (rev 68681)
@@ -41,7 +41,7 @@
char *rname;
int i;
int row, nrows, ncols;
- int use_zero;
+ int use_zero, no_support;
char *new_name;
char **names;
char **ptr;
@@ -49,7 +49,7 @@
struct Cell_head *cellhd;
struct GModule *module;
- struct Flag *zeroflag;
+ struct Flag *zeroflag, *nosupportflag;
struct Option *opt1, *opt2;
G_gisinit(argv[0]);
@@ -80,10 +80,16 @@
zeroflag->description =
_("Use zero (0) for transparency instead of NULL");
+ nosupportflag = G_define_flag();
+ nosupportflag->key = 's';
+ nosupportflag->description =
+ _("Do not create color and category files");
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
use_zero = (zeroflag->answer);
+ no_support = (nosupportflag->answer);
names = opt1->answers;
@@ -163,19 +169,24 @@
G_free(presult);
for (i = 0; i < nfiles; i++)
Rast_close(infd[i]);
- * build the new cats and colors. do this before closing the new
- * file, in case the new file is one of the patching files as well.
- G_verbose_message(_("Creating support files for raster map <%s>..."), new_name);
- support(names, statf, nfiles, &cats, &cats_ok, &colr, &colr_ok, out_type);
+ if(!no_support) {
+ * build the new cats and colors. do this before closing the new
+ * file, in case the new file is one of the patching files as well.
+ G_verbose_message(_("Creating support files for raster map <%s>..."), new_name);
+ support(names, statf, nfiles, &cats, &cats_ok, &colr, &colr_ok, out_type);
/* now close (and create) the result */
Rast_close(outfd);
- if (cats_ok)
- Rast_write_cats(new_name, &cats);
- if (colr_ok)
- Rast_write_colors(new_name, G_mapset(), &colr);
+ if(!no_support) {
+ if (cats_ok)
+ Rast_write_cats(new_name, &cats);
+ if (colr_ok)
+ Rast_write_colors(new_name, G_mapset(), &colr);
Rast_short_history(new_name, "raster", &history);
Rast_command_history(&history);
Modified: grass/trunk/raster/r.patch/r.patch.html
--- grass/trunk/raster/r.patch/r.patch.html 2016-06-14 10:23:28 UTC (rev 68680)
+++ grass/trunk/raster/r.patch/r.patch.html 2016-06-14 14:40:47 UTC (rev 68681)
@@ -80,7 +80,13 @@
layer.
<p>
-<em>r.patch</em> creates support files for the patched, composite output map.
+<em>r.patch</em> reads the existing category label files and color tables
+from the <em>input</em> maps and creates these files for the patched,
+composite <em>output</em> map. This can be quite time consuming for
+certain maps, especially if there are many different category values
+across the patched maps. The <em>-s</em> flag allows to disable the reading
+and creation of these support files, meaning that the <em>output</em>
+map will have no category labels and no explicit color table.
<p>
Number of raster maps to be processed is given by the limit of the
