[GRASS-SVN] r68724 - grass-addons/grass7/raster/r.colors.matplotlib
svn_grass at osgeo.org
Tue Jun 21 20:38:15 PDT 2016
Author: wenzeslaus
Date: 2016-06-21 20:38:15 -0700 (Tue, 21 Jun 2016)
New Revision: 68724
Added:
grass-addons/grass7/raster/r.colors.matplotlib/r_colors_matplotlib_viscm.png
grass-addons/grass7/raster/r.colors.matplotlib/r_colors_matplotlib_viscm_edit.png
grass-addons/grass7/raster/r.colors.matplotlib/r_colors_matplotlib_viscm_properties.png
grass-addons/grass7/raster/r.colors.matplotlib/r.colors.matplotlib.html
grass-addons/grass7/raster/r.colors.matplotlib/r.colors.matplotlib.py
r.colors.matplotlib: consume files created in the viscm tool
Modified: grass-addons/grass7/raster/r.colors.matplotlib/r.colors.matplotlib.html
--- grass-addons/grass7/raster/r.colors.matplotlib/r.colors.matplotlib.html 2016-06-22 02:29:52 UTC (rev 68723)
+++ grass-addons/grass7/raster/r.colors.matplotlib/r.colors.matplotlib.html 2016-06-22 03:38:15 UTC (rev 68724)
@@ -41,7 +41,7 @@
that the perceptually uniform sequential color tables, namely
<em>viridis</em>, <em>inferno</em>, <em>plasma</em>, and <em>magma</em>,
are available in Matplotlib 1.5 and above.
-Color tables are called <em>color maps</em> in Matplotlib
+Color tables are called <em>color maps</em> (or colormaps) in Matplotlib
and the best overview of available color maps in the
<a href="http://matplotlib.org/examples/color/colormaps_reference.html">colormaps_reference</a>
example in Matplotlib documentation.
@@ -114,7 +114,7 @@
<img src="r_colors_matplotlib_terrain.png" alt="Matplotlib terrain">
<p><em>
summer, winter, autumn, cubehelix, and terrain color tables applied
-to elevation raster from North Carolina sample dataset. winter and
+to elevation raster from the North Carolina sample dataset. winter and
cubehelix are set to be discrete instead of continuous.
</em>
</center>
@@ -135,7 +135,56 @@
Color table for 3D raster map can be set in the same way.
+<h3>Using color tables generated by the viscm tool</h3>
+A <a href="https://pypi.python.org/pypi/viscm/">viscm</a> tool is a
+little tool for analyzing color tables and creating new color tables
+(color maps) for Matplotlib. The tool was used to create perceptually
+uniform color tables for Matplotlib (for example viridis). The new
+color table is stored into a file. In version 0.7, a temporary file
+named <tt>/tmp/new_cm.py</tt> which is a Python source code which
+creates a <em>Colormap</em> object. If this module gets a name of
+existing file instead of a color table name, it assumes that it this
+kind of file and reads object called <tt>test_cm</tt> as Matplotlib
+color table. The possible workflow follows. (Note that you need to
+install the viscm tool, e.g. using <tt>sudo pip install viscm</tt> on
+Linux.)
+<p>
+Start the tool, create and save a color table:
+<div class="code"><pre>
+python -m viscm edit
+</pre></div>
+Now store the color table in GRASS GIS format:
+r.colors.matplotlib color=/tmp/new_cm.py rules=from_viscm.txt
+</pre></div>
+<center>
+<img src="r_colors_matplotlib_viscm_edit.png" alt="Editing color table in viscm">
+<img src="r_colors_matplotlib_viscm_properties.png" alt="Reviewing color table properties in viscm">
+<p><em>
+Editing color table in viscm (right): the yellow dot on the blue spline must
+stay in the colored area as the red line moves. Reviewing color table
+properties is done using several displays including color blindness
+simulations.
+</em>
+</center>
+<center>
+<img src="r_colors_matplotlib_viscm.png" alt="Applied color table form viscm">
+<p><em>
+A color table from viscm applied to elevation raster
+from the North Carolina sample dataset.
+</em>
+</center>
+The same works for any Python files which follow the same schema,
+so it works for example with files from the
+<a href="https://github.com/BIDS/colormap">BIDS/colormap</a> repository.
<h2>SEE ALSO</h2>
<em>
Modified: grass-addons/grass7/raster/r.colors.matplotlib/r.colors.matplotlib.py
--- grass-addons/grass7/raster/r.colors.matplotlib/r.colors.matplotlib.py 2016-06-22 02:29:52 UTC (rev 68723)
+++ grass-addons/grass7/raster/r.colors.matplotlib/r.colors.matplotlib.py 2016-06-22 03:38:15 UTC (rev 68724)
@@ -33,7 +33,7 @@
#% key: color
#% type: string
#% label: Name of color table
-#% description: Available color tables depend on the Matplotlib version
+#% description: Available color tables depend on the Matplotlib version. Alternatively this can be file name of a file generated by Python viscm tool
#% required: no
#% guisection: Basic
#%end
@@ -141,17 +141,32 @@
if flags['n']:
name += '_r'
- # not sure if datad is part of the API but it is in one example
- # datad might be potentially better way of getting the table
- # it contains the raw data, but on the other hand it might not be
- # clear if you can interpolate linearly in between (but likely yes)
- if hasattr(cm, 'datad') and name not in cm.datad.keys():
- import matplotlib as mpl
- gscript.fatal(_("Matplotlib {v} does not contain color table"
- " <{n}>").format(v=mpl.__version__, n=name))
- cmap = cm.get_cmap(name, lut=n_colors)
+ if os.path.isfile(name):
+ ns = {'__name__': '',
+ '__file__': os.path.basename(name),
+ with open(name) as f:
+ code = compile(f.read(),
+ os.path.basename(name),
+ 'exec')
+ exec(code, globals(), ns)
+ cmap = ns.get("test_cm", None)
+ # we ignore user input since we need to use whatever the
+ # color map object is defined with
+ n_colors = cmap.N
+ else:
+ # not sure if datad is part of the API but it is in one example
+ # datad might be potentially better way of getting the table
+ # it contains the raw data, but on the other hand it might not be
+ # clear if you can interpolate linearly in between (but likely yes)
+ if hasattr(cm, 'datad') and name not in cm.datad.keys():
+ import matplotlib as mpl
+ gscript.fatal(_("Matplotlib {v} does not contain color table"
+ " <{n}>").format(v=mpl.__version__, n=name))
+ cmap = cm.get_cmap(name, lut=n_colors)
comments = []
comments.append(
"Generated from Matplotlib color table <{}>".format(name))
Added: grass-addons/grass7/raster/r.colors.matplotlib/r_colors_matplotlib_viscm.png
(Binary files differ)
Property changes on: grass-addons/grass7/raster/r.colors.matplotlib/r_colors_matplotlib_viscm.png
___________________________________________________________________
Added: svn:mime-type
+ application/octet-stream
Added: grass-addons/grass7/raster/r.colors.matplotlib/r_colors_matplotlib_viscm_edit.png
Property changes on: grass-addons/grass7/raster/r.colors.matplotlib/r_colors_matplotlib_viscm_edit.png
Added: grass-addons/grass7/raster/r.colors.matplotlib/r_colors_matplotlib_viscm_properties.png
Property changes on: grass-addons/grass7/raster/r.colors.matplotlib/r_colors_matplotlib_viscm_properties.png
