[GRASS-SVN] r68725 - sandbox/bo/i.segment.gsoc2016/i.segment
Tue Jun 21 20:57:55 PDT 2016
Author: hao2309
Date: 2016-06-21 20:57:55 -0700 (Tue, 21 Jun 2016)
New Revision: 68725
   sandbox/bo/i.segment.gsoc2016/i.segment/iseg.h
   sandbox/bo/i.segment.gsoc2016/i.segment/mean_shift.c
   sandbox/bo/i.segment.gsoc2016/i.segment/parse_args.c
   sandbox/bo/i.segment.gsoc2016/i.segment/write_output.c
addfucntion to write out multi bands of shifted value
Modified: sandbox/bo/i.segment.gsoc2016/i.segment/iseg.h
--- sandbox/bo/i.segment.gsoc2016/i.segment/iseg.h	2016-06-22 03:38:15 UTC (rev 68724)
+++ sandbox/bo/i.segment.gsoc2016/i.segment/iseg.h	2016-06-22 03:57:55 UTC (rev 68725)
@@ -70,7 +70,6 @@
     long ncells, notnullcells;
     char *out_name;		/* name of output raster map */
-    char *ms_bands_out; /* name of out put shifted band for ms */
 	char *seeds, *bounds_map;	/* optional segment seeds and polygon constraints/boundaries */
     CELL lower_bound, upper_bound;
     const char *bounds_mapset;
Modified: sandbox/bo/i.segment.gsoc2016/i.segment/mean_shift.c
--- sandbox/bo/i.segment.gsoc2016/i.segment/mean_shift.c	2016-06-22 03:38:15 UTC (rev 68724)
+++ sandbox/bo/i.segment.gsoc2016/i.segment/mean_shift.c	2016-06-22 03:57:55 UTC (rev 68725)
@@ -51,7 +51,7 @@
 	G_percent_reset();
 	class_val=0;
 	cluster_threshold = 0.05;
-	cluster_threshold2= pow((cluster_threshold * globals->max_diff),2);
+	cluster_threshold2= pow(cluster_threshold ,2);
 	for (row = globals->row_min; row < globals->row_max; row++) {
 	    G_percent(row - globals->row_min,
 	              globals->row_max - globals->row_min, 4);
@@ -260,6 +260,11 @@
 		/* get the current pixel value */
 		Segment_get(globals->bands_in, (void *)Rin.mean, row, col);
+		/* reset Rout to zero to prepare next iteration */
+		n2 = globals->nbands - 1;
+		do{
+			Rout.mean[n2] =0;
+		} while(n2--);
 		/* start of the moving window */
 		for (current_window_row = window_row_north;current_window_row<window_row_south;current_window_row++){
@@ -302,11 +307,6 @@
 		if (diff2 > alpha2)
 		    n_changes++;
-		/* reset Rout to zero to prepare next iteration */
-		n2 = globals->nbands - 1;
-		do{
-			Rout.mean[n2] =0;
-		} while(n2--);
 		// G_message(_("row: %d, col: %d, diff2 is: %f"),row,col,diff2);
 	    }/* end col iteration */
Modified: sandbox/bo/i.segment.gsoc2016/i.segment/parse_args.c
--- sandbox/bo/i.segment.gsoc2016/i.segment/parse_args.c	2016-06-22 03:38:15 UTC (rev 68724)
+++ sandbox/bo/i.segment.gsoc2016/i.segment/parse_args.c	2016-06-22 03:57:55 UTC (rev 68725)
@@ -11,7 +11,7 @@
     struct Option *group, *seeds, *bounds, *output,
                   *method, *similarity, *threshold, *min_segment_size,
-				  *ms_range_bandwidth, *ms_spatial_bandwidth, *ms_suffix, *ms_bands_out, // added ms_suffix, ms_range_bandwidth,ms_bands_out, ms_spatial_bandwidth for mean shift
+				  *ms_range_bandwidth, *ms_spatial_bandwidth, *ms_suffix, // added ms_suffix, ms_range_bandwidth, ms_spatial_bandwidth for mean shift
 #ifdef _OR_SHAPE_
 		  *shape_weight, *smooth_weight,
 #endif
@@ -52,12 +52,12 @@
     ms_spatial_bandwidth->description = _("Moving window radiuns (1-32 in number of pixel) for mean shift");
     ms_spatial_bandwidth->guisection = _("MS_Settings");
-	ms_bands_out = G_define_option();
-    ms_bands_out->key = "ms_bands_out";
-    ms_bands_out->type = TYPE_STRING;
-    ms_bands_out->required = NO;
-    ms_bands_out->answer = "ms_shiftval_band";
-    ms_bands_out->description = _("If also output the intermediam shifted-value band");
+	ms_suffix = G_define_option();
+    ms_suffix->key = "ms_suffix";
+    ms_suffix->type = TYPE_STRING;
+    ms_suffix->required = NO;
+    ms_suffix->answer = "ms_shiftval_band";
+    ms_suffix->description = _("If also output the intermediam shifted-value band");
 	ms_range_bandwidth = G_define_option();
@@ -69,14 +69,6 @@
     ms_range_bandwidth->description = _("Nomarlized range bandwidth for mean shift");
     ms_range_bandwidth->guisection = _("MS_Settings");
-	ms_suffix = G_define_option();
-    ms_suffix->key = "ms_suffix";
-    ms_suffix->type = TYPE_STRING;
-    ms_suffix->required = NO;
-    ms_suffix->answer = "mean_shift";
-    ms_suffix->description = _("a suffix to be appended to the input bands when writing out shifted band values");
-    ms_suffix->guisection = _("MS_Settings");
 	/* ===end parameters for ms_setting=== */
     similarity = G_define_option();
@@ -282,7 +274,7 @@
     globals->ncols = Rast_window_cols();
 	/* for mean shift seg2 output */
-	globals->ms_bands_out = ms_bands_out->answer;
+	globals->ms_suffix = ms_suffix->answer;
     /* debug help */
     if (outband->answer == NULL)
Modified: sandbox/bo/i.segment.gsoc2016/i.segment/write_output.c
--- sandbox/bo/i.segment.gsoc2016/i.segment/write_output.c	2016-06-22 03:38:15 UTC (rev 68724)
+++ sandbox/bo/i.segment.gsoc2016/i.segment/write_output.c	2016-06-22 03:57:55 UTC (rev 68725)
@@ -15,11 +15,12 @@
  int write_ms_seg2(struct globals *globals)
 	int *seg2_fd, row, col, n;
 	DCELL **outbuf2, *seg2;
 	struct ngbr_stats;
+	char suffix[50], band_num[10];
 	seg2_fd = G_malloc(globals->nbands * sizeof(int));
 	outbuf2 = (DCELL **) G_malloc(globals->nbands * sizeof(DCELL *));
 	seg2 = G_malloc(sizeof(DCELL) * globals->nbands);
@@ -31,7 +32,10 @@
     G_debug(1, "preparing shifted value output raster");
     /* open output raster map */
 	for (n=0;n<globals->nbands; n++){
-    seg2_fd[n] = Rast_open_new(globals->ms_bands_out, DCELL_TYPE);
+	strcpy(suffix,  globals->ms_suffix);
+    strcpy(band_num, itoa(n,band_num,10));
+	strcat(suffix,band_num);
+    seg2_fd[n] = Rast_open_new(suffix, DCELL_TYPE);
     G_debug(1, "start data transfer from seg2 file to raster");
@@ -47,7 +51,7 @@
 	for (col = 0; col < globals->ncols; col++){
 	    if (!(FLAG_GET(globals->null_flag, row, col))) {
-		Segment_get(&globals->bands_seg2, (void *)seg2, row, col);
+		Segment_get(globals->bands_out, (void *)seg2, row, col);
 				outbuf2[n][col] = seg2[n];
