[GRASS-SVN] r68732 - grass-addons/grass7/raster/r.forestfrag
svn_grass at osgeo.org
Wed Jun 22 11:15:49 PDT 2016
Author: wenzeslaus
Date: 2016-06-22 11:15:49 -0700 (Wed, 22 Jun 2016)
New Revision: 68732
grass-addons/grass7/raster/r.forestfrag/r.forestfrag.py
r.forestfrag: small cleanup towards PEP8, cleanup of parser options block
Modified: grass-addons/grass7/raster/r.forestfrag/r.forestfrag.py
--- grass-addons/grass7/raster/r.forestfrag/r.forestfrag.py 2016-06-22 17:50:08 UTC (rev 68731)
+++ grass-addons/grass7/raster/r.forestfrag/r.forestfrag.py 2016-06-22 18:15:49 UTC (rev 68732)
@@ -1,41 +1,41 @@
#!/usr/bin/env python
# -*- coding: utf-8 -*-
-# MODULE: r.forestfrag
+# MODULE: r.forestfrag
-# AUTHOR(S): Paulo van Breugel, Emmanuel Sambale, Stefan Sylla
-# Maintainer: Paulo van Breugel (paulo at ecodiv.org)
+# AUTHOR(S): Emmanuel Sambale, Stefan Sylla,
+# Paulo van Breugel (Python version, paulo at ecodiv.org)
-# PURPOSE: Creates forest fragmentation index map from a forest-non-forest
-# raster; The index map is based on Riitters, K., J. Wickham,
-# R. O'Neill, B. Jones, and E. Smith. 2000. in: Global-scale
-# patterns of forest fragmentation. Conservation Ecology 4(2): 3.
-# [online] URL:http://www.consecol.org/vol4/iss2/art3/
+# PURPOSE: Creates forest fragmentation index map from a
+# forest-non-forest raster; The index map is based on
+# Riitters, K., J. Wickham, R. O'Neill, B. Jones, and
+# E. Smith. 2000. in: Global-scalepatterns of forest
+# fragmentation. Conservation Ecology 4(2): 3. [online]
+# URL: http://www.consecol.org/vol4/iss2/art3/
+# COPYRIGHT: (C) 1997-2016 by the GRASS Development Team
-# COPYRIGHT: (C) 1997-2016 by the GRASS Development Team
+# This program is free software under the GNU General Public
+# License (>=v2). Read the file COPYING that comes with GRASS
+# for details.
-# This program is free software under the GNU General Public
-# License (>=v2). Read the file COPYING that comes with GRASS
-# for details.
-#%Module
+#%module
#% description: Computes the forest fragmentation index (Riitters et al. 2000)
#% keyword: raster
#% keyword: forest
#% keyword: fragmentation index
#% keyword: landscape structure analysis
#% keyword: Riitters
-#%End
+#%end
#%option G_OPT_R_INPUT
#% description: Name of forest raster map (where forest=1, non-forest=0)
-#% required : yes
-#%End
+#% required: yes
+#%end
#%option G_OPT_R_OUTPUT
#% required: yes
@@ -46,7 +46,7 @@
#% type: integer
#% description: Moving window size (odd number)
#% key_desc: number
-#% answer : 3
+#% answer: 3
#% required: yes
#%end
@@ -56,29 +56,21 @@
#%end
#%flag
-#% key: t
-#% description: Keep Pf and Pff maps
-#%END
+#% key: t
+#% description: Keep Pf and Pff maps
+#%end
#%flag
-#% key: s
-#% description: Run r.report on output map
-#%END
+#% key: s
+#% description: Run r.report on output map
+#%end
#%flag
-#% key: a
-#% description: Trim the output map to avoid border effects
-#%END
+#% key: a
+#% description: Trim the output map to avoid border effects
+#%end
-# For testing purposes
-#options = {"input":"forest96 at forestfrag", "output":"mosaicindex", "window":"5"}
-#flags = {"r":False, "t":True, "s":True, "a":False}
-# Standard
# import libraries
import os
import sys
@@ -96,14 +88,13 @@
# create set to store names of temporary maps to be deleted upon exit
clean_rast = []
def cleanup():
cleanrast = list(reversed(clean_rast))
for rast in cleanrast:
grass.run_command("g.remove", flags="f", type="rast", name=rast, quiet=True)
# Functions
def CheckLayer(envlay):
ffile = grass.find_file(envlay, element = 'cell')
@@ -116,16 +107,10 @@
clean_rast.append(tmpf)
return tmpf
# Main
def main():
# Variables
ipl = options['input']
CheckLayer(ipl)
opl = options['output']
@@ -138,7 +123,7 @@
flag_a = flags['a']
- #set to current input map region (user option, default=current region)
+ # set to current input map region (user option, default=current region)
if flag_r:
grass.message("Setting region to input map...")
grass.run_command('g.region', quiet=True, raster=ipl)
@@ -153,9 +138,7 @@
if min(tstf[:,0]) != 0 or max(tstf[:,0]) != 1:
grass.fatal("Your input map must be binary, with values 0 and 1")
# computing pf values
grass.info("Step 1: Computing Pf values...")
# let forested pixels be x and number of all pixels in moving window
@@ -167,16 +150,13 @@
tmpC3 = tmpname('tmpA02_')
grass.run_command("r.neighbors", quiet=True, input=ipl,
output=[tmpA2, tmpC3], method=["sum", "count"], size=wz)
- #grass.mapcalc("$tmpC3 = float($wz^2)",tmpC3=tmpC3a,wz=str(wz),quiet=True)
# create pf map
pf = tmpname('tmpA03_')
grass.mapcalc("$pf = if(" + ipl + ">=0, float($tmpA2) / float($tmpC3))", pf=pf,
tmpA2=tmpA2, tmpC3=tmpC3, quiet=True)
# computing pff values
## Considering pairs of pixels in cardinal directions in a 3x3 window, the total
## number of adjacent pixel pairs is 12. Assuming that x pairs include at least
@@ -191,7 +171,6 @@
grass.run_command("r.null", map=tmpC4, null=0, quiet=True)
# calculate number of 'forest-forest' pairs
# Compute matrix dimensions
SWn= int((wz - 1) / 2)
@@ -223,7 +202,6 @@
os.remove(tmpfile2)
# number of 'forest patches
fd3, tmpfile3 = tempfile.mkstemp()
tmpl5 = tmpname('tmpA06_')
@@ -252,15 +230,12 @@
os.remove(tmpfile3)
# create pff map
pff = tmpname('tmpA07_')
grass.mapcalc("$pff = if(" + ipl + " >= 0, float($tmpl4) / float($tmpl5))", tmpl4=tmpl4,
tmpl5=tmpl5, pff=pff,quiet=True)
# computing fragmentation index
grass.info("Step 3: Computing fragmentation index...")
pf2 = tmpname('tmpA08_')
@@ -399,9 +374,7 @@
os.close(fd8)
os.remove(tmphist)
# Report fragmentation index and names of layers created
if flag_s:
grass.run_command("r.report", map=opl, units=["h","p"],
@@ -417,9 +390,7 @@
clean_rast.remove(pf)
clean_rast.remove(pff)
# Clean up
if flag_a:
grass.run_command("g.region", region=regionoriginal, quiet=True, overwrite=True)
os.removedirs(tmpdir)
@@ -428,7 +399,3 @@
options, flags = grass.parser()
atexit.register(cleanup)
sys.exit(main())
