[GRASS-SVN] r68733 - grass-addons/grass7/raster/r.forestfrag
svn_grass at osgeo.org
Wed Jun 22 11:41:43 PDT 2016
Author: wenzeslaus
Date: 2016-06-22 11:41:43 -0700 (Wed, 22 Jun 2016)
New Revision: 68733
grass-addons/grass7/raster/r.forestfrag/r.forestfrag.py
r.forestfrag: use r.info wrapper to get raster metadata
The previous implementation did full export
and used NumPy but check only min and max.
The NumPy import also failed for non-CELL map.
Modified: grass-addons/grass7/raster/r.forestfrag/r.forestfrag.py
--- grass-addons/grass7/raster/r.forestfrag/r.forestfrag.py 2016-06-22 18:15:49 UTC (rev 68732)
+++ grass-addons/grass7/raster/r.forestfrag/r.forestfrag.py 2016-06-22 18:41:43 UTC (rev 68733)
@@ -74,7 +74,6 @@
# import libraries
import os
import sys
-import numpy as np
import uuid
import atexit
import tempfile
@@ -128,15 +127,18 @@
grass.message("Setting region to input map...")
grass.run_command('g.region', quiet=True, raster=ipl)
- # Check if map values are limited to 1 and 0
- tmpdir = tempfile.mkdtemp()
- tmpfile = tmpdir + 'forestfrag1'
- grass.run_command("r.stats", flags="cn", overwrite=True,
- quiet=True, input=ipl, output=tmpfile, separator="|")
- tstf = np.loadtxt(tmpfile, delimiter="|", dtype="int")
- os.remove(tmpfile)
- if min(tstf[:,0]) != 0 or max(tstf[:,0]) != 1:
- grass.fatal("Your input map must be binary, with values 0 and 1")
+ # check if map values are limited to 1 and 0
+ input_info = grass.raster_info(ipl)
+ # we know what we are doing only when input is integer
+ if input_info['datatype'] != 'CELL':
+ grass.fatal(_("The input raster map must have type CELL"
+ " (integer)"))
+ # for integer, we just need to text min and max
+ if input_info['min'] != 0 or input_info['max'] != 1:
+ grass.fatal(_("The input raster map must be a binary raster,"
+ " i.e. it should contain only values 0 and 1"
+ " (now the minimum is %d and maximum is %d)")
+ % (input_info['min'], input_info['max']))
# computing pf values
grass.info("Step 1: Computing Pf values...")
@@ -393,8 +395,8 @@
# Clean up
if flag_a:
grass.run_command("g.region", region=regionoriginal, quiet=True, overwrite=True)
- os.removedirs(tmpdir)
if __name__ == "__main__":
options, flags = grass.parser()
atexit.register(cleanup)
