[GRASS-SVN] r68758 - grass/trunk/display/d.legend
svn_grass at osgeo.org
Fri Jun 24 07:51:32 PDT 2016
Author: annakrat
Date: 2016-06-24 07:51:32 -0700 (Fri, 24 Jun 2016)
New Revision: 68758
grass/trunk/display/d.legend/draw.c
grass/trunk/display/d.legend/main.c
d.legend: fix background for categorical legend (#3013) and fix border_color option name, author Adam Laza
Modified: grass/trunk/display/d.legend/draw.c
--- grass/trunk/display/d.legend/draw.c 2016-06-24 04:21:30 UTC (rev 68757)
+++ grass/trunk/display/d.legend/draw.c 2016-06-24 14:51:32 UTC (rev 68758)
@@ -70,6 +70,7 @@
double bb,bt,bl,br;
char MaxLabel[512];
double num;
+ int MaxLabelW, LabelW;
if (draw) {
@@ -117,6 +118,7 @@
do_smooth = TRUE;
MaxLabelLen = 0; /* init variable */
+ MaxLabelW = 0;
/* How many categories to show */
/* not fp */
@@ -191,9 +193,11 @@
continue;
else { /* ie has a label */
- if (!hide_catstr && (MaxLabelLen < strlen(cstr)))
+ if (!hide_catstr && (MaxLabelLen < strlen(cstr))) {
MaxLabelLen = strlen(cstr);
+ sprintf(MaxLabel, "%s", cstr);
if (!hide_catnum)
if (i > maxCat)
@@ -230,22 +234,6 @@
lines = 0;
- if (MaxLabelLen > 0) { /* ie we've picked up at least one label */
- MaxLabelLen++; /* compensate for leading space */
- if (!hide_catnum)
- MaxLabelLen += 3; /* compensate for "%2d) " */
- else {
- if (!hide_catnum)
- MaxLabelLen = 1;
- /* compensate for categories >100 */
- if (!hide_catnum) {
- if (maxCat > 99)
- MaxLabelLen += (int)(log10(maxCat));
/* following covers both the above if(do_cats == cats_num) and k++ loop */
if (lines < 1) {
lines = 1; /* ward off the dpl floating point exception */
@@ -411,10 +399,8 @@
min_ind + k * (double)(1 + max_ind -
min_ind) / lleg;
else
- tcell =
- (max_ind + 1) - k * (double)(1 + max_ind -
- min_ind) / lleg;
- D_color((CELL) tcell, &colors);
+ D_box_abs(x0, y0 + k, x0 - (dx ? -dx : 1),
+ y0 + k + (dy ? -dy : 1));
else {
if (!flip)
@@ -590,8 +576,11 @@
D_text(buff);
- if (strlen(buff) > MaxLabelLen) {
- MaxLabelLen = strlen(buff);
+ D_text_size(txsiz, txsiz);
+ D_get_text_box(buff,&bb,&bt, &bl, &br);
+ LabelW = br - bl;
+ if (LabelW > MaxLabelW) {
+ MaxLabelW = LabelW;
sprintf(MaxLabel, DispFormat, val);
} /* for */
@@ -658,9 +647,11 @@
D_use_color(color);
D_text(buff);
+ LabelW = br - bl;
sprintf(MaxLabel, DispFormat, tick_values[i]);
@@ -733,8 +724,11 @@
if (!horiz)
while (t_start < dmax) {
sprintf(buff, DispFormat, t_start);
+ LabelW = br - bl;
sprintf(MaxLabel, DispFormat, t_start);
if (draw) {
@@ -754,8 +748,11 @@
else
+ LabelW = br - bl;
@@ -779,8 +776,11 @@
if (!horiz)
+ LabelW = br - bl;
@@ -801,8 +801,11 @@
else
+ LabelW = br - bl;
@@ -882,7 +885,7 @@
else {
x_tit = x0;
- y_tit = y0 - (titsiz);
+ y_tit = y0 - txsiz;
x1_tit = x_tit + (br - bl);
@@ -943,9 +946,9 @@
x1bg = x1_tit + txsiz;
y1bg = y0 + lleg + txsiz;
if (strlen(title) > 0)
- y0bg = y0 - (2.5 * titsiz);
+ y0bg = y0 - titsiz -2 * txsiz;
else
- y0bg = y0 - titsiz;
+ y0bg = y0 - txsiz;
else {
x0bg = x0 - (br - bl) / 2 - txsiz;
@@ -1122,40 +1125,98 @@
buff[0] = 0;
if (!hide_catnum) { /* num */
sprintf(buff, DispFormat, (int)catlist[i]);
- if (!flip)
+ LabelW = br - bl;
+ sprintf(MaxLabel, DispFormat, (int)catlist[i]);
+ if (!flip) {
- else
+ LabelW = br - bl;
+ else {
(int)catlist[catlistCount - i - 1]);
+ LabelW = br - bl;
+ (int)catlist[catlistCount - i - 1]);
if (!hide_catstr) /* both */
strcat(buff, ")");
- if (!hide_catstr) /* str */
+ if (!hide_catstr) { /* str */
sprintf(buff + strlen(buff), " %s", cstr);
+ LabelW = br - bl;
+ sprintf(MaxLabel, " %s", buff);
else { /* is fp */
if (!flip) {
- if (use_catlist)
+ if (use_catlist) {
/* pass through format exactly as given by the user in
the use= command line parameter (helps with log scale) */
sprintf(buff, "%s", opt_use->answers[i]);
- else
+ LabelW = br - bl;
+ sprintf(MaxLabel, " %s", opt_use->answers[i]);
+ else {
/* automatically generated/tuned decimal precision format */
sprintf(buff, DispFormat, catlist[i]);
+ LabelW = br - bl;
+ sprintf(MaxLabel, DispFormat, catlist[i]);
else {
- if (use_catlist)
- sprintf(buff, "%s",
- opt_use->answers[catlistCount - i - 1]);
- else
- sprintf(buff, DispFormat,
- catlist[catlistCount - i - 1]);
+ if (use_catlist){
+ sprintf(buff, "%s", opt_use->answers[catlistCount - i - 1]);
+ LabelW = br - bl;
+ sprintf(MaxLabel, " %s", opt_use->answers[catlistCount - i - 1]);
- sprintf(MaxLabel, DispFormat, catlist[catlistCount - i - 1]);
+ else {
+ sprintf(buff, DispFormat, catlist[catlistCount - i - 1]);
+ LabelW = br - bl;
if (draw) {
D_pos_abs((l + 3 + dots_per_line), (cur_dot_row) - 3);
@@ -1170,7 +1231,7 @@
/* display title */
if (strlen(title) > 0) {
x_tit = x0;
- y_tit = y0;
D_text_size(titsiz, titsiz);
D_get_text_box(title, &bb, &bt, &bl, &br);
@@ -1211,6 +1272,7 @@
if (!draw) {
/* Draw background */
D_get_text_box(MaxLabel, &bb, &bt, &bl, &br);
x0bg = x0 - txsiz;
x1bg =
@@ -1219,9 +1281,9 @@
y1bg = cur_dot_row + txsiz;
- y0bg = y0 - (2 * titsiz);
+ y0bg = y0 - 2 * txsiz - titsiz;
else
- y0bg = y0;
D_use_color(colorbg);
Modified: grass/trunk/display/d.legend/main.c
--- grass/trunk/display/d.legend/main.c 2016-06-24 04:21:30 UTC (rev 68757)
+++ grass/trunk/display/d.legend/main.c 2016-06-24 14:51:32 UTC (rev 68758)
@@ -226,7 +226,7 @@
opt_charset->guisection = _("Font settings");
opt_brdcolor = G_define_standard_option(G_OPT_CN);
- opt_brdcolor->key = "borde_color";
+ opt_brdcolor->key = "border_color";
opt_brdcolor->answer = "black";
opt_brdcolor->label = _("Border color");
opt_brdcolor->guisection = _("Background");
