[GRASS-SVN] r68759 - grass/trunk/display/d.legend
svn_grass at osgeo.org
Fri Jun 24 07:51:58 PDT 2016
Author: annakrat
Date: 2016-06-24 07:51:58 -0700 (Fri, 24 Jun 2016)
New Revision: 68759
Added:
grass/trunk/display/d.legend/d_legend_custom_labels_and_background.png
grass/trunk/display/d.legend/d_legend_logarithmic.png
grass/trunk/display/d.legend/d.legend.html
d.legend: document new features, author Adam Laza
Modified: grass/trunk/display/d.legend/d.legend.html
--- grass/trunk/display/d.legend/d.legend.html 2016-06-24 14:51:32 UTC (rev 68758)
+++ grass/trunk/display/d.legend/d.legend.html 2016-06-24 14:51:58 UTC (rev 68759)
@@ -63,7 +63,9 @@
<p>
The text produced from floating-point raster maps will automatically create
output with a meaningful number of significant digits. For very small values,
-numbers will be expressed in scientific notation, e.g. "1.7e-9".
+numbers will be expressed in scientific notation, e.g. "1.7e-9". Option
+<b>digits</b> can be used to determine how many digits after decimal point
+will be displayed.
<p>
When the <b>-d</b> flag is used to display a histogram distribution along
side the smoothed gradient legend, note that the statistics are calculated
@@ -73,7 +75,25 @@
<p>
If the raster map's <i>units</i> metadata has been set with the
<em>r.support</em> module then it will be displayed along side the legend.
+<p>
+The option <b>title</b> will display the custom title at the top of the legend.
+In case of vertical legend the title is aligned to the left edge of legend, in case
+of horizontal legend the title is aligned to the center. <b>title_fontsize</b> can
+be used to set the size of legend title. By default the legend title font size is
+the same as labels font size.
+<p>
+There are different options to customize displayed labels. The <b>labelnum</b> set
+the number of labels which are displayed in regular intervals. The <b>label_values</b>
+will specify the values where the labels will be displayed. The <b>label_step</b> will
+display labels at values which are divisible by this value.
+<p>
+The flag <b>-t</b> will show ticks at labels.
+<p>
+The flag <b>-b</b> will show the background. Options <b>bgcolor</b> and <b>border_color</b> can be
+used to choose the color of border and background fill.
+<p>
+The flag <b>-l</b> will switch to logarithmic scale. In case this flag is used,
+the provided step in <b>label_step</b>is interpreted in the logarithmic space.
<h2>EXAMPLE</h2>
Displaying the legend along with a histogram (North Carolina Sample dataset):
@@ -88,7 +108,33 @@
<img src="d_legend.png" alt="Elevation map with legend" border=1>
</center>
+Displaying the legend with custom labels and background:
+<div class="code"><pre>
+g.region raster=elevation -p
+d.rast elevation
+d.legend raster=elevation -t label_step=20 label_values=108 title=Legend -b bgcolor=255:255:204 border_color=gray
+</pre></div>
+<center>
+<img src="d_legend_custom_labels_and_background.png" alt="Elevation map with custom legend" border=1>
+</center>
+Displaying the legend with logarithmic scale:
+r.watershed -a elevation=elevation threshold=1000 accumulation=flowacc
+d.rast flowacc
+d.legend raster=flowacc -t -l label_step=1
+</pre></div>
+<center>
+<img src="d_legend_logarithmic.png" alt="Flow accumulation map with logarithmic legend" border=1>
+</center>
<h2>SEE ALSO</h2>
<em>
Added: grass/trunk/display/d.legend/d_legend_custom_labels_and_background.png
(Binary files differ)
Property changes on: grass/trunk/display/d.legend/d_legend_custom_labels_and_background.png
___________________________________________________________________
Added: svn:mime-type
+ image/png
Added: grass/trunk/display/d.legend/d_legend_logarithmic.png
Property changes on: grass/trunk/display/d.legend/d_legend_logarithmic.png
+ image/png
