[GRASS-SVN] r68773 - in grass/branches/releasebranch_7_0: lib/db/sqlp scripts/v.db.addcolumn scripts/v.db.addtable
svn_grass at osgeo.org
Sun Jun 26 07:45:35 PDT 2016
Author: neteler
Date: 2016-06-26 07:45:35 -0700 (Sun, 26 Jun 2016)
New Revision: 68773
grass/branches/releasebranch_7_0/lib/db/sqlp/sql.html
grass/branches/releasebranch_7_0/scripts/v.db.addcolumn/v.db.addcolumn.py
grass/branches/releasebranch_7_0/scripts/v.db.addtable/v.db.addtable.html
grass/branches/releasebranch_7_0/scripts/v.db.addtable/v.db.addtable.py
.db.addcolumn, v.db.addtable + manual: clarify and standardize name and type of new column(s) (trunk, r68770 + r68771)
Modified: grass/branches/releasebranch_7_0/lib/db/sqlp/sql.html
--- grass/branches/releasebranch_7_0/lib/db/sqlp/sql.html 2016-06-26 14:44:55 UTC (rev 68772)
+++ grass/branches/releasebranch_7_0/lib/db/sqlp/sql.html 2016-06-26 14:45:35 UTC (rev 68773)
@@ -76,7 +76,11 @@
<li> DBF column names are limited to 10 characters (DBF API definition).</li>
</ul>
+<h3>Database table column types</h3>
+The supported types of columns depend on the database backend. However, all backends
+should support VARCHAR, INT, DOUBLE PRECISION and DATE.
<h2>EXAMPLES</h2>
<h3>Display of vector feature selected by attribute query</h3>
Modified: grass/branches/releasebranch_7_0/scripts/v.db.addcolumn/v.db.addcolumn.py
--- grass/branches/releasebranch_7_0/scripts/v.db.addcolumn/v.db.addcolumn.py 2016-06-26 14:44:55 UTC (rev 68772)
+++ grass/branches/releasebranch_7_0/scripts/v.db.addcolumn/v.db.addcolumn.py 2016-06-26 14:45:35 UTC (rev 68773)
@@ -34,8 +34,10 @@
#% key: columns
#% type: string
#% label: Name and type of the new column(s) ('name type [,name type, ...]')
-#% description: Data types depend on database backend, but all support VARCHAR(), INT, DOUBLE PRECISION and DATE
+#% description: Types depend on database backend, but all support VARCHAR(), INT, DOUBLE PRECISION and DATE. Example: 'label varchar(250), value integer'
#% required: yes
+#% multiple: yes
+#% key_desc: name type
#%end
import sys
Modified: grass/branches/releasebranch_7_0/scripts/v.db.addtable/v.db.addtable.html
--- grass/branches/releasebranch_7_0/scripts/v.db.addtable/v.db.addtable.html 2016-06-26 14:44:55 UTC (rev 68772)
+++ grass/branches/releasebranch_7_0/scripts/v.db.addtable/v.db.addtable.html 2016-06-26 14:45:35 UTC (rev 68773)
@@ -9,8 +9,8 @@
<em>v.db.addtable</em> is a front-end to <em>db.execute</em> to allow easier
usage.
-v.db.addtable will only insert category values into the table for those features
+<p>
+<em>v.db.addtable</em> will only insert category values into the table for those features
which actually have a category value in the relevant layer. The use can add
category values automatically by using <em>v.category</em> or manually with
<em><a href="wxGUI.vdigit.html">wxGUI vector digitizer</a></em>
@@ -18,7 +18,7 @@
and then use either a combinatino of <em>v.category</em> + <em>v.to.db</em> or
to add the relevant lines to the table.
+<p>
backends should support VARCHAR, INT, DOUBLE PRECISION and DATE.
<p>The existing database connection(s) can be verified with <em>v.db.connect</em>.
Modified: grass/branches/releasebranch_7_0/scripts/v.db.addtable/v.db.addtable.py
--- grass/branches/releasebranch_7_0/scripts/v.db.addtable/v.db.addtable.py 2016-06-26 14:44:55 UTC (rev 68772)
+++ grass/branches/releasebranch_7_0/scripts/v.db.addtable/v.db.addtable.py 2016-06-26 14:45:35 UTC (rev 68773)
@@ -44,8 +44,8 @@
#%option
#% key: columns
#% type: string
-#% label: Name and type of the new column(s)
-#% description: Types depend on database backend, but all support VARCHAR(), INT, DOUBLE PRECISION and DATE. Example: "label varchar(250), type integer"
+#% label: Name and type of the new column(s) ('name type [,name type, ...]')
#% required: no
#% multiple: yes
