[GRASS-SVN] r68777 - grass/trunk/vector/v.random
svn_grass at osgeo.org
Sun Jun 26 15:03:59 PDT 2016
Author: neteler
Date: 2016-06-26 15:03:59 -0700 (Sun, 26 Jun 2016)
New Revision: 68777
Added:
grass/trunk/vector/v.random/vrandom_restricted_area.png
grass/trunk/vector/v.random/vrandom_restricted_attr.png
grass/trunk/vector/v.random/main.c
grass/trunk/vector/v.random/v.random.html
v.random manual: major cleanup; screenshots added
Property changes on: grass/trunk/vector/v.random
___________________________________________________________________
Modified: svn:ignore
- OBJ.*
+ OBJ.*
*.tmp.html
Modified: grass/trunk/vector/v.random/main.c
--- grass/trunk/vector/v.random/main.c 2016-06-26 19:06:25 UTC (rev 68776)
+++ grass/trunk/vector/v.random/main.c 2016-06-26 22:03:59 UTC (rev 68777)
@@ -99,6 +99,7 @@
G_add_keyword(_("statistics"));
G_add_keyword(_("random"));
G_add_keyword(_("point pattern"));
+ G_add_keyword(_("stratified random sampling"));
module->description = _("Generates random 2D/3D vector points.");
parm.output = G_define_standard_option(G_OPT_V_OUTPUT);
Modified: grass/trunk/vector/v.random/v.random.html
--- grass/trunk/vector/v.random/v.random.html 2016-06-26 19:06:25 UTC (rev 68776)
+++ grass/trunk/vector/v.random/v.random.html 2016-06-26 22:03:59 UTC (rev 68777)
@@ -28,24 +28,66 @@
be generated in total.
<h2>EXAMPLES</h2>
-All examples use the North Carolina sample dataset.
-<p>
-Generate 20 random points with binary attribute (only 0 or 1):
+All examples are based on the North Carolina sample dataset.
+<h3>Generating random points in 2D</h3>
+Generate 20 random points with binary attributes (only 0 or 1):
<div class="code"><pre>
-v.random output=binary_random npoints=20 zmin=0 zmax=1 column='binary INTEGER'
+v.random output=binary_random npoints=20 zmin=0 zmax=1 column='binary'
+v.db.select binary_random
+cat|binary
+1|0.63495
+2|0.233421
+3|0.489302
+4|0.748264
+5|0.505556
+6|0.32975
+v.univar -d binary_random
+Calculating geometric distances between 20 primitives...
+minimum: 148.515
+maximum: 16572.8
</pre></div>
+<h3>Generating random points in 2D with binary attributes</h3>
+<div class="code"><pre>
+v.random output=binary_random npoints=20 zmin=0 zmax=1 column='binary' column_type=integer
+cat|binary
+1|0
+2|0
+3|0
+4|0
+5|1
+6|0
+</pre></div>
+<h3>Generating random points in 3D</h3>
Generate 20 random 3D points using a specific random seed:
v.random seed=52 output=height_random npoints=40 zmin=110 zmax=170 -z
+v.univar -d height_random
+Calculating geometric distances between 40 primitives...
+minimum: 334.889
+maximum: 18351.9
+range: 18017
+sum: 5.38425e+06
+mean: 7266.2
+mean of absolute values: 7266.2
+population standard deviation: 3563.95
+skewness: 0.34703
</pre></div>
-<p>
-<center>
-<img src="vrandom_z.png"><br>
-Random points with different X, Y, and Z coordinates
-</center>
g.region raster=elev_lid792_1m
@@ -54,50 +96,108 @@
-Get 20 random samples from raster map:
+<p>
+<center>
+<img src="vrandom_z.png" border=1><br>
+Random points with different X, Y, and Z coordinates
+</center>
+<h3>Random sampling from raster map</h3>
+Generate 20 random samples from a raster map:
g.region -p raster=elevation
v.random output=random_samples npoints=20
-v.db.addtable map=random_samples layer=1 columns='cat INTEGER, sample DOUBLE PRECISION'
-v.what.rast vector=random_samples raster=elevation at PERMANENT layer=1 column=sample
+v.db.addtable map=random_samples columns='cat INTEGER, sample DOUBLE PRECISION'
+v.what.rast map=random_samples raster=elevation column=sample
+v.db.select random_samples
+cat|sample
+1|103.9935
+2|129.1266
+3|96.01388
</pre></div>
+<h3>Random sampling from vector map</h3>
Generate 20 random points and sample attribute data from geology (vector) map:
g.region -p vector=geology
-v.db.addtable map=random_samples layer=1 columns='cat integer, geology varchar(100)'
-v.what.vect vector=random_samples layer=1 column=geology \
- qvector=geology at PERMANENT qlayer=1 qcolumn=label
+v.db.addtable map=random_samples columns='cat integer, geology varchar(100)'
+v.what.vect map=random_samples column=geology \
+ query_map=geology query_layer=1 query_column=GEO_NAME
+cat|geology
+1|PzZm
+2|
+3|Zatm
</pre></div>
-Generate 20 random points in forested areas
+<h3>Stratified random sampling: Random sampling from vector map by attribute</h3>
+Generate 20 random points restricted to forested areas:
g.region -p raster=landclass96
r.to.vect -v input=landclass96 output=landclass96 type=area
-v.random input=landclass96 output=random_samples npoints=20 \
- where="label = 'forest'"
+v.random restrict=landclass96 output=random_samples npoints=20 \
+ where="label = 'forest'" layer=1
</pre></div>
-Generate 20 random points in each forest patch
+d.font Vera
+d.rast landclass96
+d.vect random_samples icon=basic/triangle color=blue fcolor=black size=14
+d.vect random_samples color=white
+<p>
+<center>
+<img src="vrandom_restricted_attr.png" border=1><br>
+Random points only sampled in forested areas (stratified random sampling)
+</center>
+<h3>Stratified random sampling: Random sampling from vector map with spatial contraints</h3>
+Generating n points for each individual area: in this example two random
+points in each water body:
- where="label = 'forest'" -a
+v.random restrict=landclass96 output=random_samples npoints=2 \
+ where="label = 'water'" layer=1 -a
</pre></div>
+d.font Vera
+d.rast landclass96
+<p>
+<center>
+<img src="vrandom_restricted_area.png" border=1><br>
+Two random points sampled in each individual water body (stratified
+random sampling)
+</center>
<h2>SEE ALSO</h2>
<em>
<a href="g.region.html">g.region</a>,
<a href="r.random.html">r.random</a>,
+<a href="v.db.addtable.html">v.db.addtable</a>,
<a href="v.perturb.html">v.perturb</a>,
<a href="v.sample.html">v.sample</a>,
+<a href="v.univar.html">v.univar</a>,
<a href="v.what.rast.html">v.what.rast</a>,
<a href="v.what.vect.html">v.what.vect</a>
</em>
+<p>
+<a href="sql.html">SQL support in GRASS GIS</a>
<h2>AUTHOR</h2>
Added: grass/trunk/vector/v.random/vrandom_restricted_area.png
(Binary files differ)
Property changes on: grass/trunk/vector/v.random/vrandom_restricted_area.png
Added: svn:mime-type
+ image/png
Added: grass/trunk/vector/v.random/vrandom_restricted_attr.png
Property changes on: grass/trunk/vector/v.random/vrandom_restricted_attr.png
+ image/png
