[GRASS-SVN] r68787 - grass/branches/releasebranch_7_0/raster/r.to.vect
svn_grass at osgeo.org
Mon Jun 27 13:53:19 PDT 2016
Author: mmetz
Date: 2016-06-27 13:53:19 -0700 (Mon, 27 Jun 2016)
New Revision: 68787
grass/branches/releasebranch_7_0/raster/r.to.vect/areas.c
grass/branches/releasebranch_7_0/raster/r.to.vect/areas_io.c
grass/branches/releasebranch_7_0/raster/r.to.vect/global.h
grass/branches/releasebranch_7_0/raster/r.to.vect/lines.c
grass/branches/releasebranch_7_0/raster/r.to.vect/lines_io.c
grass/branches/releasebranch_7_0/raster/r.to.vect/main.c
grass/branches/releasebranch_7_0/raster/r.to.vect/util.c
r.to.vect: sync to trunk, fix #2045
Modified: grass/branches/releasebranch_7_0/raster/r.to.vect/areas.c
--- grass/branches/releasebranch_7_0/raster/r.to.vect/areas.c 2016-06-27 20:52:56 UTC (rev 68786)
+++ grass/branches/releasebranch_7_0/raster/r.to.vect/areas.c 2016-06-27 20:53:19 UTC (rev 68787)
@@ -107,11 +107,13 @@
int extract_areas(void)
double nullVal;
+ int i;
row = col = top = 0; /* get started for read of first */
bottom = 1; /* line from raster map */
area_num = 0;
tl_area = 0;
+ n_alloced_ptrs = 0;
Rast_set_d_null_value(&nullVal, 1);
/* represents the "outside", the external null values */
@@ -121,7 +123,7 @@
scan_length = read_next();
while (read_next()) { /* read rest of file, one row at *//* a time */
- G_percent(row, n_rows, 2);
+ G_percent(row, n_rows + 1, 2);
for (col = 0; col < scan_length - 1; col++) {
tl = get_raster_value(buffer[top], col); /* top left in window */
@@ -136,15 +138,25 @@
row++;
+ G_percent(1, 1, 1);
write_area(a_list, e_list, area_num, n_equiv);
G_free(a_list);
+ for (i = 0; i < n_equiv; i++) {
+ if (e_list[i].ptr)
+ G_free(e_list[i].ptr);
G_free(e_list);
G_free(v_list);
G_free(buffer[0]);
G_free(buffer[1]);
+ if (n_alloced_ptrs) {
+ /* should not happen */
+ G_warning("Memory leak: %d points are still in use", n_alloced_ptrs);
return 0;
} /* extract_areas */
@@ -215,7 +227,7 @@
v_list[col]->row = row; /* keep downward-growing point */
v_list[col]->fptr = h_ptr->bptr; /* and join it to predecessor */
h_ptr->bptr->fptr = v_list[col]; /* of right-growing point */
- G_free(h_ptr); /* right-growing point disappears */
+ free_ptr(h_ptr); /* right-growing point disappears */
h_ptr = NULPTR; /* turn loose of pointers */
write_boundary(v_list[col]); /* try to write line */
v_list[col] = NULPTR; /* turn loose of pointers */
@@ -383,6 +395,8 @@
ptr->col = col;
ptr->fptr = ptr->bptr = NULPTR;
ptr->node = ptr->left = ptr->right = 0;
+ n_alloced_ptrs++;
return (ptr);
Modified: grass/branches/releasebranch_7_0/raster/r.to.vect/areas_io.c
--- grass/branches/releasebranch_7_0/raster/r.to.vect/areas_io.c 2016-06-27 20:52:56 UTC (rev 68786)
+++ grass/branches/releasebranch_7_0/raster/r.to.vect/areas_io.c 2016-06-27 20:53:19 UTC (rev 68787)
@@ -28,15 +28,13 @@
static int write_bnd(struct COOR *, struct COOR *, int);
static int write_smooth_bnd(struct COOR *, struct COOR *, int);
-static int *equivs;
/* write_line - attempt to write a line to output */
/* just returns if line is not completed yet */
int write_boundary(struct COOR *seed)
- struct COOR *point, *line_begin, *line_end;
- int dir, line_type, n, n1;
+ struct COOR *point, *line_begin, *line_end, *last;
+ int dir, line_type, n, n1, i;
point = seed;
if ((dir = at_end(point))) { /* already have one end of line */
@@ -68,12 +66,60 @@
direction = FORWARD; /* direction is arbitrary */
+ dir = direction;
if (smooth_flag == SMOOTH)
write_smooth_bnd(line_begin, line_end, n);
else
write_bnd(line_begin, line_end, n);
+ /* now free all the pointers */
+ direction = dir;
+ point = line_begin;
+ last = NULPTR;
+ n1 = 0;
+ /* skip first and last point */
+ while ((point = move(point)) == line_begin);
+ while (point && point != line_end) {
+ last = point;
+ n1++;
+ point = move(point);
+ if (point == last) {
+ G_warning("loop during free ptrs, ptr %d of %d", n1, n);
+ if (last->fptr != NULPTR)
+ if (last->fptr->fptr == last)
+ last->fptr->fptr = NULPTR;
+ /* it can be NULL after the previous line, even though before it wasn't */
+ if (last->fptr->bptr == last)
+ last->fptr->bptr = NULPTR;
+ if (last->bptr != NULPTR)
+ if (last->bptr->fptr == last)
+ last->bptr->fptr = NULPTR;
+ if (last->bptr->bptr == last)
+ last->bptr->bptr = NULPTR;
+ free_ptr(last);
+ if (point != line_end) {
+ G_warning("Line end not reached, possible memory leak");
+ /* free first and last point */
+ free_ptr(line_begin);
+ if (line_end != line_begin)
+ free_ptr(line_end);
return (0);
@@ -94,20 +140,18 @@
points = Vect_new_line_struct();
Vect_reset_line(points);
- n++; /* %% 6.4.88 */
p = line_begin;
y = cell_head.north - (double)p->row * cell_head.ns_res;
x = cell_head.west + (double)p->col * cell_head.ew_res;
Vect_append_point(points, x, y, 0.0);
- for (i = 1; i < n; i++) {
+ for (i = 0; i < n; i++) {
last = p;
/* this should NEVER happen */
if ((p = move(p)) == NULPTR)
- G_fatal_error(_("Line terminated unexpectedly\n"
+ G_fatal_error(_("write_bnd: line terminated unexpectedly\n"
"previous (%d) point %p (%d,%d,%d) %p %p"),
direction, last, last->row, last->col, last->node,
last->fptr, last->bptr);
@@ -118,35 +162,6 @@
- /* now free all the pointers */
- p = line_begin;
- last = p;
- if ((p = move(p)) == NULPTR)
- break;
- if (last == p)
- break;
- if (last->fptr != NULPTR)
- if (last->fptr->fptr == last)
- last->fptr->fptr = NULPTR;
- /* it can be NULL after the previous line, even though before it wasn't */
- if (last->fptr->bptr == last)
- last->fptr->bptr = NULPTR;
- if (last->bptr != NULPTR)
- if (last->bptr->fptr == last)
- last->bptr->fptr = NULPTR;
- if (last->bptr->bptr == last)
- last->bptr->bptr = NULPTR;
- G_free(last);
- } /* end of for i */
- if (p != NULPTR)
- G_free(p);
Vect_write_line(&Map, GV_BOUNDARY, points, Cats);
return 0;
@@ -172,8 +187,6 @@
p = line_begin;
/* allocate the arrays and get the first point */
@@ -183,13 +196,13 @@
/* generate the list of smoothed points, may be duplicate points */
total = 1;
if (i < 10)
G_debug(3, " row: %d col: %d\n", p->row, p->col);
last = p;
if ((p = move(p)) == NULPTR) { /* this should NEVER happen */
- G_debug(3, "write_line: line terminated unexpectedly\n");
+ G_debug(3, "write_smooth_bnd: line terminated unexpectedly\n");
G_debug(3, " previous (%d) point %p (%d,%d,%d) %p %p\n",
@@ -219,44 +232,11 @@
/* strip out the duplicate points from the list */
Vect_line_prune(points);
- G_debug(3, "removed duplicates: %d", total - points->n_points);
+ if (total != points->n_points)
+ G_debug(3, "removed duplicates: %d", total - points->n_points);
- /* write files */
- p = line_begin;
- if (i < 10)
- G_debug(3, " row: %d col: %d\n", p->row, p->col);
- last = p;
- break;
- if (last == p)
- break;
- /* now it can already ne NULL */
- G_free(last);
- if (p != NULPTR)
- G_free(p);
return 0;
@@ -270,10 +250,12 @@
int n, i;
struct area_table *p;
char *temp_buf;
+ int *equivs;
int cat;
int catNum;
double x, y;
+ equivs = NULL;
total_areas = 0;
if (n_equiv < n_areas) {
equivs = (int *)G_malloc(n_areas * sizeof(int));
@@ -380,6 +362,9 @@
G_percent(1, 1, 1);
+ if (equivs)
+ G_free(equivs);
return 0;
Modified: grass/branches/releasebranch_7_0/raster/r.to.vect/global.h
--- grass/branches/releasebranch_7_0/raster/r.to.vect/global.h 2016-06-27 20:52:56 UTC (rev 68786)
+++ grass/branches/releasebranch_7_0/raster/r.to.vect/global.h 2016-06-27 20:53:19 UTC (rev 68787)
@@ -44,6 +44,7 @@
extern int input_fd;
extern int row_length, row_count, n_rows;
extern int total_areas;
+extern int n_alloced_ptrs;
extern int smooth_flag; /* this is 0 for no smoothing, 1 for smoothing of lines */
extern int value_flag; /* use raster values as categories */
@@ -123,3 +124,4 @@
int at_end(struct COOR *);
int read_row(void *);
void insert_value(int, int, double);
+int free_ptr(struct COOR *ptr);
Modified: grass/branches/releasebranch_7_0/raster/r.to.vect/lines.c
--- grass/branches/releasebranch_7_0/raster/r.to.vect/lines.c 2016-06-27 20:52:56 UTC (rev 68786)
+++ grass/branches/releasebranch_7_0/raster/r.to.vect/lines.c 2016-06-27 20:53:19 UTC (rev 68787)
@@ -63,6 +63,7 @@
int extract_lines(void)
row = -3;
read_next();
read_next();
@@ -181,6 +182,11 @@
G_free(bottom);
G_free(v_list);
return 0;
@@ -588,7 +594,7 @@
else
q->bptr->bptr = p;
- G_free(q);
+ free_ptr(q);
write_line(p);
return 0;
@@ -705,6 +711,8 @@
p->bptr = p->fptr = NULL;
+ n_alloced_ptrs++;
return (p);
Modified: grass/branches/releasebranch_7_0/raster/r.to.vect/lines_io.c
--- grass/branches/releasebranch_7_0/raster/r.to.vect/lines_io.c 2016-06-27 20:52:56 UTC (rev 68786)
+++ grass/branches/releasebranch_7_0/raster/r.to.vect/lines_io.c 2016-06-27 20:53:19 UTC (rev 68787)
@@ -48,7 +48,7 @@
int write_line(struct COOR *seed)
- struct COOR *point, *begin, *end;
+ struct COOR *point, *begin, *end, *last;
point = seed;
@@ -87,9 +87,55 @@
+ dir = direction;
/* if (n > 2) */
write_ln(begin, end, n);
+ direction = dir;
+ point = begin;
+ while ((point = move(point)) == begin);
+ while (point && point != end) {
+ last = point;
+ if (last->fptr != NULL)
+ last->fptr->fptr = NULL;
+ /* now it can already ne NULL */
+ last->fptr->bptr = NULL;
+ if (last->bptr != NULL)
+ last->bptr->fptr = NULL;
+ last->bptr->bptr = NULL;
+ free_ptr(last);
+ } /* end of for i */
+ if (point != end) {
+ free_ptr(begin);
+ if (end != begin)
+ free_ptr(end);
return (0);
@@ -110,7 +156,6 @@
field = 1;
- ++n;
Vect_reset_cats(Cats);
@@ -124,7 +169,7 @@
Vect_cat_set(Cats, field, cat);
last = p;
@@ -162,35 +207,5 @@
count++;
- p = begin;
- last = p;
- if ((p = move(p)) == NULL)
- break;
- if (last == p)
- break;
- if (last->fptr != NULL)
- last->fptr->fptr = NULL;
- last->fptr->bptr = NULL;
- if (last->bptr != NULL)
- last->bptr->fptr = NULL;
- last->bptr->bptr = NULL;
- G_free(last);
- if (p != NULL)
- G_free(p);
return 0;
Modified: grass/branches/releasebranch_7_0/raster/r.to.vect/main.c
--- grass/branches/releasebranch_7_0/raster/r.to.vect/main.c 2016-06-27 20:52:56 UTC (rev 68786)
+++ grass/branches/releasebranch_7_0/raster/r.to.vect/main.c 2016-06-27 20:53:19 UTC (rev 68787)
@@ -47,6 +47,7 @@
int input_fd;
int total_areas;
+int n_alloced_ptrs;
@@ -56,6 +57,11 @@
dbDriver *driver;
dbString sql, label;
+static int cmp_int(const void *a, const void *b)
+ return (*(int *)a - *(int *)b);
int main(int argc, char *argv[])
struct GModule *module;
@@ -261,27 +267,53 @@
Rast_close(input_fd);
- if (!no_topol->answer)
- Vect_build(&Map);
/* insert cats and optionally labels if raster cats were used */
if (driver && value_flag) {
char buf[1000];
- int c, i, cat, fidx, ncats, lastcat, tp, id;
+ int c, i, j, cat;
+ struct ilist *clist;
+ int type;
- fidx = Vect_cidx_get_field_index(&Map, 1);
- if (fidx >= 0) {
- ncats = Vect_cidx_get_num_cats_by_index(&Map, fidx);
- lastcat = -1;
+ clist = G_new_ilist();
+ /* create category list */
+ Vect_rewind(&Map);
+ while (1) {
+ /* register line */
+ type = Vect_read_next_line(&Map, NULL, Cats);
+ /* Note: check for dead lines is not needed, because they are skipped by V1_read_next_line_nat() */
+ if (type == -1) {
+ G_warning(_("Unable to read vector map"));
+ break;
+ else if (type == -2) {
+ break;
+ for (i = 0; i < Cats->n_cats; i++)
+ G_ilist_add(clist, Cats->cat[i]);
+ if (clist->n_values > 0) {
+ qsort(clist->value, clist->n_values, sizeof(int), cmp_int);
+ j = 1;
+ for (i = 1; i < clist->n_values; i++) {
+ if (clist->value[i] != clist->value[j - 1]) {
+ clist->value[j] = clist->value[i];
+ j++;
+ clist->n_values = j;
G_important_message(_("Updating attributes..."));
- for (c = 0; c < ncats; c++) {
- Vect_cidx_get_cat_by_index(&Map, fidx, c, &cat, &tp, &id);
+ for (c = 0; c < clist->n_values; c++) {
+ G_percent(c, clist->n_values, 4);
+ cat = clist->value[c];
- if (lastcat == cat)
- continue;
/* find label, slow -> TODO faster */
db_set_string(&label, "");
for (i = 0; i < RastCats.ncats; i++) {
@@ -301,10 +333,10 @@
if (db_execute_immediate(driver, &sql) != DB_OK)
G_fatal_error(_("Unable to insert into table: %s"),
db_get_string(&sql));
- lastcat = cat;
+ G_free_ilist(clist);
if (has_cats)
@@ -315,6 +347,9 @@
db_close_database_shutdown_driver(driver);
+ if (!no_topol->answer)
+ Vect_build(&Map);
Vect_close(&Map);
G_done_msg(" ");
Modified: grass/branches/releasebranch_7_0/raster/r.to.vect/util.c
--- grass/branches/releasebranch_7_0/raster/r.to.vect/util.c 2016-06-27 20:52:56 UTC (rev 68786)
+++ grass/branches/releasebranch_7_0/raster/r.to.vect/util.c 2016-06-27 20:53:19 UTC (rev 68787)
@@ -157,3 +157,10 @@
G_fatal_error(_("Cannot insert new row: %s"), db_get_string(&sql));
+ G_free(ptr);
+ return (--n_alloced_ptrs);
