[GRASS-SVN] r68788 - in sandbox/bo/i.segment.gsoc2016/i.segment: . testing
svn_grass at osgeo.org
Mon Jun 27 21:23:09 PDT 2016
Author: hao2309
Date: 2016-06-27 21:23:09 -0700 (Mon, 27 Jun 2016)
New Revision: 68788
sandbox/bo/i.segment.gsoc2016/i.segment/mean_shift.c
sandbox/bo/i.segment.gsoc2016/i.segment/testing/test_map.ascii
modifying clustering function
Modified: sandbox/bo/i.segment.gsoc2016/i.segment/mean_shift.c
--- sandbox/bo/i.segment.gsoc2016/i.segment/mean_shift.c 2016-06-27 20:53:19 UTC (rev 68787)
+++ sandbox/bo/i.segment.gsoc2016/i.segment/mean_shift.c 2016-06-28 04:23:09 UTC (rev 68788)
@@ -30,9 +30,94 @@
return exp(-diff2 / (2 * var));
+int clustering2(struct globals *globals){
+ int class_val, px_count, first_change;/* the value of class */
+ int row, col, nrows, ncols, stop_row, stop_col,edge_row, edge_col,diag;
+ struct ngbr_stats Rin, Rstop;
+ nrows = globals->row_max;
+ ncols = globals->col_max;
+ CELL temp_id;
+ double cluster_threshold,cluster_threshold2;
+ int **indicator_matrix;
+ /* the indicator matrix to mark if the pixel has been clumped */
+ Rin.mean = G_malloc(globals->datasize);
+ Rstop.mean = G_malloc(globals->datasize);
+ indicator_matrix = G_malloc(nrows * sizeof(int*));
+ diag=0;
+ for (row = globals->row_min; row < nrows; row++) {
+ indicator_matrix[row] = G_malloc(ncols * sizeof(int));
+ for (col = globals->col_min; col < ncols; col++) {
+ indicator_matrix[row][col] = 0;
+ G_message(_("Pass 1 of 2 for clustering"));
+ px_count=0;
+ class_val=0;
+ stop_row=0;
+ stop_col=0;
+ cluster_threshold = 0.05;
+ cluster_threshold2= pow(cluster_threshold ,2);
+ while (px_count<nrows*ncols){
+ class_val+=1;
+ Segment_get(globals->bands_out, (void *)Rstop.mean, stop_row, stop_col);
+ first_change =0;/* mark the first time non-clump */
+ /* get the first stop row when */
+ G_percent(row - globals->row_min,
+ globals->row_max - globals->row_min, 4);
+ if (!(FLAG_GET(globals->candidate_flag, row, col)))
+ continue;
+ Segment_get(globals->bands_out, (void *)Rin.mean, row, col);
+ // G_message(_("row: %d, col: %d, temp_id is: %d"),row,col,temp_id);
+ if ((globals->calculate_similarity)(&Rin, &Rstop, globals) <= cluster_threshold2 && indicator_matrix[row][col]==0){
+ indicator_matrix[row][col]+=1;
+ /* if the seg is not in the edg of the image */
+ // if (row!= globals->row_min && col!=globals->col_min && row!=nrows-1 && col!=ncols-1){
+ // /* If this seg is saperate from surrounded segments */
+ // if (indicator_matrix[row+1][col]+indicator_matrix[row][col+1]+indicator_matrix[row-1][col]+indicator_matrix[row][col-1]==0){
+ // class_val+=1;
+ // if (diag){
+ // if (indicator_matrix[row-1][col-1]+indicator_matrix[row+1][col-1]+indicator_matrix[row-1][col+1]+indicator_matrix[row+1][col+1]==0){
+ // class_val+=1;
+ Segment_put(&globals->rid_seg, &class_val, row, col);
+ px_count+=1;
+ else if(first_change == 0 && indicator_matrix[row][col]==0){
+ first_change = 1;
+ stop_col = col;
+ stop_row = row;
+ return TRUE;
int clustering(struct globals *globals){
- int row, col, n, nin;
+ int row, col, n3, nin;
int diag;/* if using diag pixel */
int class_val;
struct ngbr_stats Rin, Rleft, Rabove;
@@ -56,20 +141,26 @@
- for (row = globals->row_min+1; row < globals->row_max; row++) {
+ for (row = globals->row_min; row < globals->row_max; row++) {
- for (col = globals->col_min+1; col < globals->col_max; col++) {
+ for (col = globals->col_min; col < globals->col_max; col++) {
continue;
old_val=new_val=0;
/* get the current pixel value */
- /* get left pixel value */
- /* compare with left value and set if same cluster */
+ /* get left pixel value if not the first col*/
+ if(col != globals->col_min){
Segment_get(globals->bands_out, (void *)Rleft.mean, row, (col-1));
+ /* get above pixel value if not the first row*/
+ if(row != globals->row_min){
+ Segment_get(&globals->bands_seg2, (void *)Rabove.mean, row-1, col);
if (col == globals->col_min && row == globals->row_min){
class_val+=1;
@@ -91,7 +182,6 @@
else if(col == globals->col_min){
/* compare with above value and set if same cluster */
- Segment_get(&globals->bands_seg2, (void *)Rabove.mean, row-1, col);
if ((globals->calculate_similarity)(&Rin, &Rabove, globals) <= cluster_threshold2){
G_debug(1, "row: %d, col: %d, above_similarity is: %f",row,col,(globals->calculate_similarity)(&Rin, &Rabove, globals));
Segment_get(&globals->rid_seg, (void *)&above_new_val, row-1, col);
@@ -107,18 +197,20 @@
if ((globals->calculate_similarity)(&Rin, &Rleft, globals) <= cluster_threshold2){
Segment_get(&globals->rid_seg, (void *)&left_new_val, row, col-1);
old_val=seg_id = left_new_val;
+ // G_message(_("row: %d, col: %d, oldval is: %d, newval is: %d, compare to left"),row,col,old_val,new_val);
if(diag){
- /* check above right, center, left, in that order */
+ // /* check above right, center, left, in that order */
else{
- Segment_get(&globals->bands_seg2, (void *) Rabove.mean, row-1, col);
temp_clump = &above_new_val;
seg_id = *temp_clump;
+ // G_message(_("row: %d, col: %d, oldval is: %d, newval is: %d, compare to above"),row,col,old_val,new_val);
if (old_val==0){
old_val = *temp_clump;
@@ -129,19 +221,19 @@
* Must go back to the left in the current row and to the right
* in the previous row to change all the clump values as well.
+ // G_message(_("row: %d, col: %d, oldval is: %d, newval is: %d, conflict"),row,col,old_val,new_val);
/* left of the current row from 1 to col - 1 */
- for(n = globals->col_min+1; n< col; n++){
- Segment_get(&globals->rid_seg, (void *)temp_clump, row, n);
+ for(n3 = globals->col_min+1; n3< col; n3++){
+ Segment_get(&globals->rid_seg, (void *)temp_clump, row, n3);
if (*temp_clump==old_val){
- Segment_put(&globals->rid_seg, &new_val, row, n);
+ Segment_put(&globals->rid_seg, &new_val, row, n3);
// /* right of previous row from col + 1 to ncols */
- for(n = col+1; n< globals->col_max; n++){
- Segment_get(&globals->rid_seg, (void *)temp_clump, row-1, n);
+ for(n3 = col+1; n3< globals->col_max; n3++){
+ Segment_get(&globals->rid_seg, (void *)temp_clump, row-1, n3);
- Segment_put(&globals->rid_seg, &new_val, row-1, n);
+ Segment_put(&globals->rid_seg, &new_val, row-1, n3);
@@ -152,10 +244,11 @@
if (old_val ==0){
class_val+=1;
seg_id = class_val;
+ // G_message(_("row: %d, col: %d, oldval is: %d, newval is: %d, class++"),row,col,old_val,new_val);
Segment_put(&globals->rid_seg, &seg_id, row, col);
@@ -163,7 +256,6 @@
int mean_shift(struct globals *globals)
int row, col, t, n1, n2;
@@ -324,14 +416,13 @@
G_message(_("Mean shift converged after %d iterations"), t);
- if (clustering(globals) != TRUE)
+ if (clustering2(globals) != TRUE)
G_fatal_error(_("Error in clustering segments"));
* Part 3 identify connected components *
* Merge small super-pixel to bigger super-pixels *
return TRUE;
Modified: sandbox/bo/i.segment.gsoc2016/i.segment/testing/test_map.ascii
--- sandbox/bo/i.segment.gsoc2016/i.segment/testing/test_map.ascii 2016-06-27 20:53:19 UTC (rev 68787)
+++ sandbox/bo/i.segment.gsoc2016/i.segment/testing/test_map.ascii 2016-06-28 04:23:09 UTC (rev 68788)
@@ -9,8 +9,8 @@
103 103 103 103 103 103 106 104
103 147 147 153 147 156 153 104
107 153 153 153 153 153 153 107
-103 153 147 96 98 153 153 104
-107 156 153 97 96 147 153 107
-103 153 153 147 156 153 153 101
-103 156 153 147 147 153 153 104
+103 153 98 96 98 153 153 104
+107 156 153 97 148 147 153 107
+103 153 153 147 156 96 96 101
+103 156 153 147 147 153 97 104
103 103 107 104 103 106 103 107
