[GRASS-SVN] r68115 - grass-addons/grass7/raster/r.niche.similarity
svn_grass at osgeo.org
Wed Mar 23 02:05:24 PDT 2016
Author: pvanbosgeo
Date: 2016-03-23 02:05:24 -0700 (Wed, 23 Mar 2016)
New Revision: 68115
grass-addons/grass7/raster/r.niche.similarity/r.niche.similarity.html
grass-addons/grass7/raster/r.niche.similarity/r.niche.similarity.py
r.niche.similarity addon: fix how intermediate files are removed + cleanup code
Modified: grass-addons/grass7/raster/r.niche.similarity/r.niche.similarity.html
--- grass-addons/grass7/raster/r.niche.similarity/r.niche.similarity.html 2016-03-23 09:01:45 UTC (rev 68114)
+++ grass-addons/grass7/raster/r.niche.similarity/r.niche.similarity.html 2016-03-23 09:05:24 UTC (rev 68115)
@@ -34,10 +34,10 @@
<ul>
<li>Warren, D. L., Glor, R. E., & Turelli, M. 2008.
Environmental Niche Equivalency Versus Conservatism: Quantitative
-Approaches to Niche Evolution. Evolution 62(11): 2868–2883</li>
+Approaches to Niche Evolution. Evolution 62(11): 2868-2883</li>
<li> Warren, D. L., R. E. Glor, and M. Turelli. 2010. ENMTools: a
toolbox for comparative studies of environmental niche models. Ecography
-33:607–611.</li>
+33:607-611.</li>
<li>Robert J. Hijmans, Steven Phillips, John
Leathwick and Jane Elith (2013). dismo: Species distribution
modeling. R package version 0.8-5.
Modified: grass-addons/grass7/raster/r.niche.similarity/r.niche.similarity.py
--- grass-addons/grass7/raster/r.niche.similarity/r.niche.similarity.py 2016-03-23 09:01:45 UTC (rev 68114)
+++ grass-addons/grass7/raster/r.niche.similarity/r.niche.similarity.py 2016-03-23 09:05:24 UTC (rev 68115)
@@ -95,26 +95,9 @@
def cleanup():
for rast in clean_rast:
- grass.run_command("g.remove",
+ grass.run_command("g.remove", flags="f",
type="rast", name=rast, quiet=True)
-def fileexist(fname, suffix):
- k = 0
- fname2 = fname[:]
- fname2 = fname2.split('.')
- while os.path.isfile(fname):
- k = k + 1
- opft = fname.split('.')
- if len(opft) == 1:
- fname = opft[0] + "_" + str(k)
- else:
- fname = fname2[0] + suffix + str(k) + "." + fname2[1]
- if k > 0:
- grass.info("there is already a file " + fname2[0] + ".")
- grass.info("Using " + fname + " instead")
- return fname
## main function
@@ -129,8 +112,6 @@
OPF = options['output']
if OPF == '':
OPF = tempfile.mkstemp()[1]
- else:
- OPF = fileexist(OPF, "v_")
flag_i = flags['i']
flag_d = flags['d']
flag_c = flags['c']
@@ -180,7 +161,6 @@
quiet=True)
NO = float(grass.parse_command("r.univar", quiet=True, flags="g", map=tmpf0)['sum'])
NOV = 1 - (0.5 * NO)
- grass.run_command("g.remove", quiet=True, flags="f", type="raster", name=tmpf0)
text_file.write("D," + nvar1 + "," + nvar2 + "," + str(NOV) + "\n")
grass.message("Niche overlap (D) of " + nvar1 + " and " + nvar2 + ": " + str(round(NOV, 3)))
@@ -202,7 +182,6 @@
quiet=True)
NE = float(grass.parse_command("r.univar", quiet=True, flags="g", map=tmpf1)['sum'])
NEQ = 1 - (0.5 * NE)
- grass.run_command("g.remove", quiet=True, flags="f", type="raster", name=tmpf1)
text_file.write("I," + nvar1 + "," + nvar2 + "," + str(NEQ) + "\n")
grass.message("Niche overlap (I) of " + nvar1 + " and " + nvar2 + ": " + str(round(NEQ, 3)))
