[GRASS-SVN] r68116 - grass-addons/grass7/raster/r.meb
svn_grass at osgeo.org
Wed Mar 23 02:08:06 PDT 2016
Author: pvanbosgeo
Date: 2016-03-23 02:08:06 -0700 (Wed, 23 Mar 2016)
New Revision: 68116
grass-addons/grass7/raster/r.meb/r.meb.html
grass-addons/grass7/raster/r.meb/r.meb.py
r.meb addon: bugfix how temp files are removed and improving how temp layers are handled
Modified: grass-addons/grass7/raster/r.meb/r.meb.html
--- grass-addons/grass7/raster/r.meb/r.meb.html 2016-03-23 09:05:24 UTC (rev 68115)
+++ grass-addons/grass7/raster/r.meb/r.meb.html 2016-03-23 09:08:06 UTC (rev 68116)
@@ -80,12 +80,16 @@
The results are written to Test.csv
</pre></div>
+<h2>CITATION</h2> Suggested citation: <p>van Breugel P, Kindt R,
+Lillesø J-PB, van Breugel M (2015) Environmental Gap
+Analysis to Prioritize Conservation Efforts in Eastern Africa. PLoS
+ONE 10(4): e0121444. doi: 10.1371/journal.pone.0121444
<h2>REFERENCES</h2>
<ul>
- <li>Elith, J., Kearney, M., and Phillips, S. 2010. The art of modelling range-shifting species. Methods in Ecology and Evolution 1:330-342.</li>
- <li>van Breugel P, Kindt R, Lillesø J-PB, van Breugel M. 2015. Environmental Gap Analysis to Prioritize Conservation Efforts in Eastern Africa. PLoS ONE 10:e0121444.</li>
+ <li>Elith, J, Kearney, M, and Phillips, S. 2010. The art of modelling range-shifting species. Methods in Ecology and Evolution 1:330-342.</li>
+ <li>van Breugel P, Kindt R, Lillesø J-PB, van Breugel M. 2015. Environmental Gap Analysis to Prioritize Conservation Efforts in Eastern Africa. PLoS ONE 10(4): e0121444. doi: 10.1371/journal.pone.0121444.</li>
</ul>
Modified: grass-addons/grass7/raster/r.meb/r.meb.py
--- grass-addons/grass7/raster/r.meb/r.meb.py 2016-03-23 09:05:24 UTC (rev 68115)
+++ grass-addons/grass7/raster/r.meb/r.meb.py 2016-03-23 09:08:06 UTC (rev 68116)
@@ -112,12 +112,6 @@
#%end
-#Test
-#options = {"env":"bio_1 at climate,bio_2 at climate,bio_3 at climate", "file":"test.txt", "ref":"PAs2", "output":"AAA_test", "digits":"5"}
-#flags = {"m":True, "n":True, "o":True, "i":True}
# Standard
@@ -143,10 +137,13 @@
# create set to store names of temporary maps to be deleted upon exit
clean_rast = set()
def cleanup():
for rast in clean_rast:
- grass.run_command("g.remove", type="rast", name=rast, quiet=True)
+ cf = grass.find_file(name=rast, element = 'cell',
+ mapset=grass.gisenv()['MAPSET'])
+ if cf['fullname'] != '':
+ grass.run_command("g.remove", type="raster",
+ name=rast, quiet=True, flags="f")
# Functions
@@ -181,15 +178,16 @@
# Write color rule file
def defcol(mapname):
# Color table
- tmpcol = tempfile.mkstemp()
- text_file = open(tmpcol[1], "w")
+ fd1, tmpcol = tempfile.mkstemp()
+ text_file = open(tmpcol, "w")
text_file.write("0% 244:109:67\n")
text_file.write("50 255:255:210\n")
text_file.write("100% 50:136:189\n")
text_file.close()
# Assign color table
- grass.run_command("r.colors", flags="n", quiet=True, map=mapname, rules=tmpcol[1])
- os.remove(tmpcol[1])
+ grass.run_command("r.colors", flags="n", quiet=True, map=mapname, rules=tmpcol)
+ os.close(fd1)
+ os.remove(tmpcol)
# Compute EB for input file (simlay = similarity, reflay = reference layer)
def EB(simlay, reflay):
@@ -280,8 +278,12 @@
grass.run_command("g.copy", quiet=True, raster=(ref, tmpref0))
ipi = []
+ grass.info("\n")
+ grass.info("Computing the ES for:")
+ grass.info("-------------------------------------------")
for j in xrange(len(ipl)):
- grass.info("Computing ES for layer " + ipl[j])
+ grass.info("Data layer " + ipl[j])
# Calculate the frequency distribution
tmpf1 = tmpname('reb1')
@@ -314,8 +316,8 @@
a2 = np.hstack([np.array(sstval.T[0])[0,:] -1, (e2)])
b1 = np.hstack([(0), c])
- tmprule = tempfile.mkstemp()
- text_file = open(tmprule[1], "w")
+ fd2, tmprule = tempfile.mkstemp()
+ text_file = open(tmprule, "w")
for k in np.arange(0, len(b1.T)):
rtmp = str(int(a1[k])) + ":" + str(int(a2[k])) + ":" + str(b1[k])
text_file.write(rtmp + "\n")
@@ -324,7 +326,7 @@
# Create the recode layer and calculate the IES
tmpf2 = tmpname('reb2')
clean_rast.add(tmpf2)
- grass.run_command("r.recode", input=tmpf1, output=tmpf2, rules=tmprule[1])
+ grass.run_command("r.recode", input=tmpf1, output=tmpf2, rules=tmprule)
tmpf3 = tmpname('reb3')
clean_rast.add(tmpf3)
@@ -334,55 +336,69 @@
grass.mapcalc(calcc, quiet=True)
grass.run_command("g.remove", quiet=True, flags="f", type="raster", name=tmpf2)
grass.run_command("g.remove", quiet=True, flags="f", type="raster", name=tmpf1)
- #os.remove(tmprule[1])
+ os.close(fd2)
+ os.remove(tmprule)
ipi.append(tmpf3)
+ grass.info("\n")
# Calculate EB statistics
# EB MES
if flag_m:
- grass.info("Computing the MES")
+ grass.info("Computing the EB based on mean ES values")
nmn = tmpf0 + "_MES_mean"
+ if out == '':
+ clean_rast.add(nmn)
grass.run_command("r.series", quiet=True, output=nmn, input=tuple(ipi), method="average")
defcol(nmn)
- grass.info("Computing the EB")
ebm = EB(simlay=nmn, reflay=tmpref0)
+ grass.info("\n")
if flag_n:
+ grass.info("Computing the EB based on median ES values")
nmn = tmpf0 + "_MES_median"
+ if out == '':
grass.run_command("r.series", quiet=True, output=nmn, input=tuple(ipi), method="median")
defcol(nmn)
ebn = EB(simlay=nmn, reflay=tmpref0)
+ grass.info("\n")
if flag_o:
+ grass.info("Computing the EB based on minimum ES values")
nmn = tmpf0 + "_MES_minimum"
+ if out == '':
grass.run_command("r.series", quiet=True, output=nmn, input=tuple(ipi), method="minimum")
defcol(nmn)
ebo = EB(simlay=nmn, reflay=tmpref0)
+ grass.info("\n")
# EB individual layers
if flag_i:
grass.info("Computing the EB for the individual layers")
ebi = {}
for mm in xrange(len(ipi)):
nmn = tmpf0 + "_" + ipn[mm]
+ if out == '':
grass.run_command("g.rename", quiet=True, raster=(ipi[mm], nmn))
defcol(nmn)
+ grass.info("Computing the EB for " + ipn[mm])
value = EB(simlay=nmn, reflay=tmpref0)
- ebi[nmn] = value
+ ebi[ipn[mm]] = value
+ grass.info("\n")
else:
grass.run_command("g.remove", quiet=True, flags="f", type="raster", name=ipi)
- # Remove temporary copy of ref layer
- grass.run_command("g.remove", quiet=True, flags="f", type="raster", name=tmpref0)
if filename != '':
+ grass.info("Writing results to text file")
with open(filename, 'wb') as csvfile:
fieldnames = ['variable', 'median_region', 'median_reference', 'mad', 'eb']
writer = csv.DictWriter(csvfile, fieldnames=fieldnames)
@@ -403,7 +419,7 @@
writer.writerow({'variable':vari,'median_region':ebj[1],
'median_reference':ebj[2], 'mad':ebj[0],'eb':ebj[3]})
grass.info("\nThe results are written to " + filename + "\n")
- grass.info("\n-------------------------------------------\n")
+ grass.info("\n")
if __name__ == "__main__":
options, flags = grass.parser()
