[GRASS-SVN] r68181 - in grass/trunk/scripts: d.correlate d.frame	d.polar d.rast.edit d.rast.leg d.redraw db.dropcolumn	db.in.ogr db.out.ogr db.test db.univar g.extension	g.extension/testsuite g.extension.all g.manual	g.search.modules g.search.modules/testsuite i.colors.enhance	i.image.mosaic i.in.spotvgt i.oif i.spectral i.tasscap m.proj	r.blend r.buffer.lowmem r.colors.stddev r.fillnulls r.grow	r.import r.in.aster r.in.srtm r.in.wms r.mask r.out.xyz	r.pack r.plane r.reclass.area r.shade r.tileset r.unpack	r3.in.xyz v.build.all v.centroids v.db.addcolumn	v.db.addtable v.db.dropcolumn v.db.droprow v.db.droptable	v.db.join v.db.reconnect.all v.db.renamecolumn v.db.univar	v.db.update v.dissolve v.import v.in.e00 v.in.geonames	v.in.lines v.in.mapgen v.in.wfs v.krige v.pack v.rast.stats	v.rast.stats/testsuite v.report v.unpack v.what.strds	v.what.strds/testsuite wxpyimgview
    svn_grass at osgeo.org
    Tue Mar 29 01:10:14 PDT 2016
Author: zarch
Date: 2016-03-29 01:10:14 -0700 (Tue, 29 Mar 2016)
New Revision: 68181
   grass/trunk/scripts/d.correlate/d.correlate.py
   grass/trunk/scripts/d.frame/d.frame.py
   grass/trunk/scripts/d.polar/d.polar.py
   grass/trunk/scripts/d.rast.edit/d.rast.edit.py
   grass/trunk/scripts/d.rast.leg/d.rast.leg.py
   grass/trunk/scripts/d.redraw/d.redraw.py
   grass/trunk/scripts/db.dropcolumn/db.dropcolumn.py
   grass/trunk/scripts/db.in.ogr/db.in.ogr.py
   grass/trunk/scripts/db.out.ogr/db.out.ogr.py
   grass/trunk/scripts/db.test/db.test.py
   grass/trunk/scripts/db.univar/db.univar.py
   grass/trunk/scripts/g.extension.all/g.extension.all.py
   grass/trunk/scripts/g.extension/g.extension.py
   grass/trunk/scripts/g.extension/testsuite/test_addons_modules.py
   grass/trunk/scripts/g.manual/g.manual.py
   grass/trunk/scripts/g.search.modules/g.search.modules.py
   grass/trunk/scripts/g.search.modules/testsuite/test_g_search_modules.py
   grass/trunk/scripts/i.colors.enhance/i.colors.enhance.py
   grass/trunk/scripts/i.image.mosaic/i.image.mosaic.py
   grass/trunk/scripts/i.in.spotvgt/i.in.spotvgt.py
   grass/trunk/scripts/i.oif/i.oif.py
   grass/trunk/scripts/i.spectral/i.spectral.py
   grass/trunk/scripts/i.tasscap/i.tasscap.py
   grass/trunk/scripts/m.proj/m.proj.py
   grass/trunk/scripts/r.blend/r.blend.py
   grass/trunk/scripts/r.buffer.lowmem/r.buffer.lowmem.py
   grass/trunk/scripts/r.colors.stddev/r.colors.stddev.py
   grass/trunk/scripts/r.fillnulls/r.fillnulls.py
   grass/trunk/scripts/r.grow/r.grow.py
   grass/trunk/scripts/r.import/r.import.py
   grass/trunk/scripts/r.in.aster/r.in.aster.py
   grass/trunk/scripts/r.in.srtm/r.in.srtm.py
   grass/trunk/scripts/r.in.wms/r.in.wms.py
   grass/trunk/scripts/r.in.wms/srs.py
   grass/trunk/scripts/r.in.wms/wms_base.py
   grass/trunk/scripts/r.in.wms/wms_cap_parsers.py
   grass/trunk/scripts/r.in.wms/wms_drv.py
   grass/trunk/scripts/r.in.wms/wms_gdal_drv.py
   grass/trunk/scripts/r.mask/r.mask.py
   grass/trunk/scripts/r.out.xyz/r.out.xyz.py
   grass/trunk/scripts/r.pack/r.pack.py
   grass/trunk/scripts/r.plane/r.plane.py
   grass/trunk/scripts/r.reclass.area/r.reclass.area.py
   grass/trunk/scripts/r.shade/r.shade.py
   grass/trunk/scripts/r.tileset/r.tileset.py
   grass/trunk/scripts/r.unpack/r.unpack.py
   grass/trunk/scripts/r3.in.xyz/r3.in.xyz.py
   grass/trunk/scripts/v.build.all/v.build.all.py
   grass/trunk/scripts/v.centroids/v.centroids.py
   grass/trunk/scripts/v.db.addcolumn/v.db.addcolumn.py
   grass/trunk/scripts/v.db.addtable/v.db.addtable.py
   grass/trunk/scripts/v.db.dropcolumn/v.db.dropcolumn.py
   grass/trunk/scripts/v.db.droprow/v.db.droprow.py
   grass/trunk/scripts/v.db.droptable/v.db.droptable.py
   grass/trunk/scripts/v.db.join/v.db.join.py
   grass/trunk/scripts/v.db.reconnect.all/v.db.reconnect.all.py
   grass/trunk/scripts/v.db.renamecolumn/v.db.renamecolumn.py
   grass/trunk/scripts/v.db.univar/v.db.univar.py
   grass/trunk/scripts/v.db.update/v.db.update.py
   grass/trunk/scripts/v.dissolve/v.dissolve.py
   grass/trunk/scripts/v.import/v.import.py
   grass/trunk/scripts/v.in.e00/v.in.e00.py
   grass/trunk/scripts/v.in.geonames/v.in.geonames.py
   grass/trunk/scripts/v.in.lines/v.in.lines.py
   grass/trunk/scripts/v.in.mapgen/v.in.mapgen.py
   grass/trunk/scripts/v.in.wfs/v.in.wfs.py
   grass/trunk/scripts/v.krige/v.krige.py
   grass/trunk/scripts/v.pack/v.pack.py
   grass/trunk/scripts/v.rast.stats/testsuite/test_v_rast_stats.py
   grass/trunk/scripts/v.rast.stats/v.rast.stats.py
   grass/trunk/scripts/v.report/v.report.py
   grass/trunk/scripts/v.unpack/v.unpack.py
   grass/trunk/scripts/v.what.strds/testsuite/test_what_strds.py
   grass/trunk/scripts/v.what.strds/v.what.strds.py
   grass/trunk/scripts/wxpyimgview/wxpyimgview.py
   grass/trunk/scripts/wxpyimgview/wxpyimgview_gui.py
grass71/scripts: revert changes (r68140 and r68178) since they are not fixing bugs and therefore they should go in relbr72
Modified: grass/trunk/scripts/d.correlate/d.correlate.py
--- grass/trunk/scripts/d.correlate/d.correlate.py	2016-03-29 06:29:14 UTC (rev 68180)
+++ grass/trunk/scripts/d.correlate/d.correlate.py	2016-03-29 08:10:14 UTC (rev 68181)
@@ -29,23 +29,21 @@
 import sys
 import os
 from grass.script.utils import try_remove
-from grass.script import core as gcore
+from grass.script import core as grass
 def main():
     layers = options['map'].split(',')
     if len(layers) < 2:
-        gcore.error(_("At least 2 maps are required"))
+	grass.error(_("At least 2 maps are required"))
-    tmpfile = gcore.tempfile()
+    tmpfile = grass.tempfile()
     for map in layers:
-        if not gcore.find_file(map, element='cell')['file']:
-            gcore.fatal(_("Raster map <%s> not found") % map)
+	if not grass.find_file(map, element = 'cell')['file']:
+	    grass.fatal(_("Raster map <%s> not found") % map)
-    gcore.write_command('d.text', color='black', size=4, line=1,
-                        stdin="CORRELATION")
+    grass.write_command('d.text', color = 'black', size = 4, line = 1, stdin = "CORRELATION")
     os.environ['GRASS_RENDER_FILE_READ'] = 'TRUE'
@@ -54,60 +52,53 @@
     iloop = 0
     jloop = 0
     for iloop, i in enumerate(layers):
-        for jloop, j in enumerate(layers):
-            if i != j and iloop <= jloop:
-                color = colors[0]
-                colors = colors[1:]
-                colors.append(color)
-                gcore.write_command('d.text', color=color, size=4, line=line,
-                                    stdin="%s %s" % (i, j))
-                line += 1
+	for jloop, j in enumerate(layers):
+	    if i != j and iloop <= jloop:
+		color = colors[0]
+		colors = colors[1:]
+		colors.append(color)
+		grass.write_command('d.text', color = color, size = 4, line = line, stdin = "%s %s" % (i, j))
+		line += 1
-                ofile = file(tmpfile, 'w')
-                gcore.run_command('r.stats', flags='cnA', input=(i, j),
-                                  stdout=ofile)
-                ofile.close()
+		ofile = file(tmpfile, 'w')
+		grass.run_command('r.stats', flags = 'cnA', input = (i, j), stdout = ofile)
+		ofile.close()
-                ifile = file(tmpfile, 'r')
-                first = True
-                for l in ifile:
-                    f = l.rstrip('\r\n').split(' ')
-                    x = float(f[0])
-                    y = float(f[1])
-                    if first:
-                        minx = maxx = x
-                        miny = maxy = y
-                        first = False
-                    if minx > x:
-                        minx = x
-                    if maxx < x:
-                        maxx = x
-                    if miny > y:
-                        miny = y
-                    if maxy < y:
-                        maxy = y
-                ifile.close()
+		ifile = file(tmpfile, 'r')
+		first = True
+		for l in ifile:
+		    f = l.rstrip('\r\n').split(' ')
+		    x = float(f[0])
+		    y = float(f[1])
+		    if first:
+			minx = maxx = x
+			miny = maxy = y
+			first = False
+		    if minx > x: minx = x
+		    if maxx < x: maxx = x
+		    if miny > y: miny = y
+		    if maxy < y: maxy = y
+		ifile.close()
-                kx = 100.0 / (maxx - minx + 1)
-                ky = 100.0 / (maxy - miny + 1)
+		kx = 100.0/(maxx-minx+1)
+		ky = 100.0/(maxy-miny+1)
-                p = gcore.feed_command('d.graph', color=color)
-                ofile = p.stdin
+		p = grass.feed_command('d.graph', color = color)
+		ofile = p.stdin
-                for l in ifile:
-                    x = float(f[0])
-                    y = float(f[1])
-                    ofile.write("icon + 0.1 %f %f\n" % ((x - minx + 1) * kx,
-                                                        (y - miny + 1) * ky))
-                ifile.close()
+		for l in ifile:
+		    x = float(f[0])
+		    y = float(f[1])
+		    ofile.write("icon + 0.1 %f %f\n" % ((x-minx+1) * kx, (y-miny+1) * ky))
+		ifile.close()
-                ofile.close()
-                p.wait()
+		ofile.close()
+		p.wait()
     try_remove(tmpfile)
 if __name__ == "__main__":
-    options, flags = gcore.parser()
+    options, flags = grass.parser()
     main()
Modified: grass/trunk/scripts/d.frame/d.frame.py
--- grass/trunk/scripts/d.frame/d.frame.py	2016-03-29 06:29:14 UTC (rev 68180)
+++ grass/trunk/scripts/d.frame/d.frame.py	2016-03-29 08:10:14 UTC (rev 68181)
@@ -71,15 +71,11 @@
 from grass.script.core import parser, read_command, fatal, debug, run_command, gisenv, warning, parse_command
 # check if monitor is running
 def check_monitor():
     return read_command('d.mon', flags='p', quiet=True).strip()
 # read monitor file and return list of lines
 # TODO: replace by d.info (see #2577)
 def read_monitor_file(monitor, ftype='env'):
     mfile = check_monitor_file(monitor, ftype)
     try:
@@ -92,22 +88,18 @@
         lines.append(line)
     fd.close()
     return lines
 # check if monitor file exists
 def check_monitor_file(monitor, ftype='env'):
     mfile = parse_command('d.mon', flags='g').get(ftype, None)
     if mfile is None or not os.path.isfile(mfile):
         fatal(_("Unable to get monitor info (no %s found)") % var)
     return mfile
 # write new monitor file
 def write_monitor_file(monitor, lines, ftype='env'):
@@ -120,23 +112,19 @@
     fd.close()
 # remove all frames and erase screen
 def erase(monitor):
     # remove frames
     lines = []
     for line in read_monitor_file(monitor):
         if 'FRAME' not in line:
             lines.append(line)
     write_monitor_file(monitor, lines)
     # erase screen
     run_command('d.erase')
 # find frame for given monitor
 def find_frame(monitor, frame):
         if 'FRAME' in line:
@@ -146,8 +134,6 @@
     return False
 # print frames name(s) to stdout
 def print_frames(monitor, current_only=False, full=False):
@@ -160,14 +146,10 @@
         sys.stdout.write('\n')
 # get frame name from line
 def get_frame_name(line):
     return line.rstrip('\n').rsplit('#', 1)[1].strip(' ')
 # calculate position of the frame in percent
 def calculate_frame(frame, at, width, height):
     try:
         b, t, l, r = map(float, at.split(','))
@@ -178,13 +160,11 @@
     bottom = height - (b / 100. * height)
     left = l / 100. * width
     right = r / 100. * width
     return 'GRASS_RENDER_FRAME=%d,%d,%d,%d # %s%s' % \
         (top, bottom, left, right, frame, '\n')
 # create new frame
 def create_frame(monitor, frame, at, overwrite=False):
     lines = read_monitor_file(monitor)
     # get width and height of the monitor
@@ -200,7 +180,7 @@
     if width < 0 or height < 0:
         fatal(_("Invalid monitor size: %dx%d") % (width, height))
     if not overwrite:
         lines.append(calculate_frame(frame, at, width, height))
     else:
@@ -210,12 +190,10 @@
                 continue
             if get_frame_name(line) == frame:
                 lines[idx] = calculate_frame(frame, at, width, height)
 # select existing frame
 def select_frame(monitor, frame):
     for idx in range(len(lines)):
@@ -224,29 +202,28 @@
             continue
             if line.startswith('#'):
-                lines[idx] = line.lstrip('# ')  # un-comment line
+                lines[idx] = line.lstrip('# ') # un-comment line
         elif not line.startswith('#'):
-            lines[idx] = '# ' + line  # comment-line
+            lines[idx] = '# ' + line # comment-line
 def main():
     # get currently selected monitor
     monitor = check_monitor()
     if not monitor:
         fatal(_("No graphics device selected. Use d.mon to select graphics device."))
     if flags['e']:
         # remove frames and erase monitor and exit
         erase(monitor)
         return
     if flags['p']:
         # print current frame and exit
         print_frames(monitor, current_only=True)
         return
     if flags['a']:
         # print all frames including their position and exit
         print_frames(monitor, current_only=False, full=True)
@@ -268,13 +245,12 @@
             create_frame(monitor, options['frame'], options['at'], overwrite=True)
         else:
             if options['at']:
-                warning(
-                    _("Frame <%s> already found. An existing frame can be overwritten by '%s' flag.") %
-                    (options['frame'], "--overwrite"))
-    # select givenframe
+                warning(_("Frame <%s> already found. An existing frame can be overwritten by '%s' flag.") % \
+                        (options['frame'], "--overwrite"))
+    # select givenframe
     select_frame(monitor, options['frame'])
     options, flags = parser()
     sys.exit(main())
Modified: grass/trunk/scripts/d.polar/d.polar.py
--- grass/trunk/scripts/d.polar/d.polar.py	2016-03-29 06:29:14 UTC (rev 68180)
+++ grass/trunk/scripts/d.polar/d.polar.py	2016-03-29 08:10:14 UTC (rev 68181)
@@ -42,6 +42,7 @@
 #% description: Plot using Xgraph
 #%end
+import sys
 import os
 import string
 import types
@@ -50,38 +51,34 @@
 import glob
 import shutil
 from grass.script.utils import try_remove, basename
 def cleanup():
     try_remove(tmp)
     for f in glob.glob(tmp + '_*'):
-        try_remove(f)
+	try_remove(f)
 def plot_xgraph():
     newline = ['\n']
-    p = gcore.Popen(['xgraph'], stdin=gcore.PIPE)
+    p = grass.Popen(['xgraph'], stdin = grass.PIPE)
     for point in sine_cosine_replic + newline + outercircle + newline + vector:
-        if isinstance(point, types.TupleType):
-            p.stdin.write("%f %f\n" % point)
-        else:
-            p.stdin.write(point + '\n')
+	if isinstance(point, types.TupleType):
+	    p.stdin.write("%f %f\n" % point)
+	else:
+	    p.stdin.write(point + '\n')
     p.stdin.close()
     p.wait()
 def plot_dgraph():
-    # use d.info and d.frame to create a square frame in the center of the
-    # window.
-    s = gcore.read_command('d.info', flags='d')
+    # use d.info and d.frame to create a square frame in the center of the window.
+    s = grass.read_command('d.info', flags = 'd')
     f = s.split()
     frame_width = float(f[1])
     frame_height = float(f[2])
     # take shorter side as length of frame side
     min_side = min(frame_width, frame_height)
-    dx = (frame_width - min_side) / 2
+    dx = (frame_width  - min_side) / 2
     dy = (frame_height - min_side) / 2
     fl = dx
@@ -97,32 +94,32 @@
     scaleval = ring * totalvalidnumber / totalnumber
     sine_cosine_replic_normalized = [
-        ((scaleval * p[0] / maxradius + 1) * 50,
-         (scaleval * p[1] / maxradius + 1) * 50)
-        for p in sine_cosine_replic if isinstance(p, types.TupleType)]
+	((scaleval * p[0]/maxradius + 1)*50,
+	 (scaleval * p[1]/maxradius + 1)*50)
+	for p in sine_cosine_replic
+	if isinstance(p, types.TupleType)]
     # create circle
-    circle = [(50 * (1 + ring * math.sin(math.radians(i))),
-               50 * (1 + ring * math.cos(math.radians(i))))
-              for i in range(0, 361)]
+    circle = [(50*(1 + ring * math.sin(math.radians(i))),
+	       50*(1 + ring * math.cos(math.radians(i))))
+	      for i in range(0, 361)]
     # trend vector
-    vect = [((scaleval * p[0] / maxradius + 1) * 50,
-            for p in vector[1:]]
+    vect = [((scaleval * p[0]/maxradius + 1)*50,
+	    for p in vector[1:]]
     # Possible TODOs:
     # To fill data area with color, use BOTH d.graph's polyline and polygon commands.
-    # Using polygon alone gives a jagged boundary due to sampling technique
-    # (not a bug).
+    #  Using polygon alone gives a jagged boundary due to sampling technique (not a bug).
     # plot it!
     lines = [
-        # draw circle
-        #   mandatory when drawing proportional to non-square frame
-        "color 180:255:180",
-        "polyline"] + circle + [
-        # draw axes
+	# draw circle
+	#   mandatory when drawing proportional to non-square frame
+	"color 180:255:180",
+	"polyline"] + circle + [
+	# draw axes
         "color 180:180:180",
         "width 0",
         "move 0 50",
@@ -130,16 +127,16 @@
         "move 50 0",
         "draw 50 100",
-        # draw the goods
+	# draw the goods
         "color red",
         "width 0",
         "polyline"] + sine_cosine_replic_normalized + [
-        # draw vector
+	# draw vector
         "color blue",
         "width 3",
         "polyline"] + vect + [
-        # draw compass text
+	# draw compass text
         "color black",
         "width 2",
         "size 10 10",
@@ -152,7 +149,7 @@
         "move 97 51",
         "text E",
-        # draw legend text
+	# draw legend text
         "width 0",
         "size 10",
         "color 0:180:0",
@@ -164,21 +161,20 @@
         "color blue",
         "move 0.5 90.5",
         "text Avg. direction"
-    p = gcore.feed_command('d.graph', env=tenv)
+    p = grass.feed_command('d.graph', env = tenv)
     for point in lines:
-        else:
+	else:
     p.stdin.close()
     p.wait()
 def plot_eps(psout):
     # EPS output (by M.Neteler and Bruno Caprile, ITC-irst)
-    gcore.message(_("Generating %s ...") % psout)
+    grass.message(_("Generating %s ...") % psout)
     outerradius = maxradius
     epsscale = 0.1
@@ -193,24 +189,24 @@
     diagramfontsize = halfframe / 20
     halfframe_2 = halfframe * 2
-    averagedirectioncolor = 1  # (blue)
-    diagramcolor = 4  # (red)
-    circlecolor = 2  # (green)
-    axescolor = 0  # (black)
+    averagedirectioncolor = 1 #(blue)
+    diagramcolor = 4 #(red)
+    circlecolor = 2 #(green)
+    axescolor = 0 #(black)
     northjustification = 2
     eastjustification = 6
     southjustification = 8
     westjustification = 8
-    northxshift = 1.02 * halfframe
-    northyshift = 1.98 * halfframe
-    eastxshift = 1.98 * halfframe
-    eastyshift = 1.02 * halfframe
-    southxshift = 1.02 * halfframe
-    southyshift = 0.02 * halfframe
-    westxshift = 0.01 * halfframe
-    westyshift = 1.02 * halfframe
+    northxshift = 1.02 * halfframe
+    northyshift = 1.98 * halfframe
+    eastxshift  = 1.98 * halfframe
+    eastyshift  = 1.02 * halfframe
+    southxshift = 1.02 * halfframe
+    southyshift = 0.02 * halfframe
+    westxshift  = 0.01 * halfframe
+    westyshift  = 1.02 * halfframe
     alldatastring = "all data (null included)"
     realdatastring = "real data angles"
@@ -224,11 +220,7 @@
     outf = file(psout, 'w')
-    prolog = os.path.join(
-        os.environ['GISBASE'],
-        'etc',
-        'd.polar',
-        'ps_defs.eps')
+    prolog = os.path.join(os.environ['GISBASE'], 'etc', 'd.polar', 'ps_defs.eps')
     inf = file(prolog)
     shutil.copyfileobj(inf, outf)
     inf.close()
@@ -262,24 +254,20 @@
                                         %% first point moveto, then lineto
     s = t.substitute(
-        AXESLINEWIDTH=axeslinewidth,
-        DIAGRAMFONTSIZE=diagramfontsize,
-        DIAGRAMLINEWIDTH=diagramlinewidth,
-        EPSSCALE=epsscale,
-        HALFFRAME=halfframe,
-        HALFFRAME_2=halfframe_2
+	AXESLINEWIDTH = axeslinewidth,
+	DIAGRAMFONTSIZE = diagramfontsize,
+	DIAGRAMLINEWIDTH = diagramlinewidth,
+	EPSSCALE = epsscale,
+	HALFFRAME = halfframe,
+	HALFFRAME_2 = halfframe_2
     outf.write(s)
     sublength = len(outercircle) - 2
     (x, y) = outercircle[1]
-    outf.write(
-        "%.2f %.2f moveto\n" %
-        (x * scale + halfframe, y * scale + halfframe))
+    outf.write("%.2f %.2f moveto\n" % (x * scale + halfframe, y * scale + halfframe))
     for x, y in outercircle[2:]:
-        outf.write(
-            "%.2f %.2f lineto\n" %
+        outf.write("%.2f %.2f lineto\n" % (x * scale + halfframe, y * scale + halfframe))
     t = string.Template("""
 stroke
@@ -309,33 +297,29 @@
     s = t.substitute(
-        AXESFONTSIZE=axesfontsize,
-        EASTJUSTIFICATION=eastjustification,
-        EASTXSHIFT=eastxshift,
-        EASTYSHIFT=eastyshift,
-        NORTHJUSTIFICATION=northjustification,
-        NORTHXSHIFT=northxshift,
-        NORTHYSHIFT=northyshift,
-        SOUTHJUSTIFICATION=southjustification,
-        SOUTHXSHIFT=southxshift,
-        SOUTHYSHIFT=southyshift,
-        WESTJUSTIFICATION=westjustification,
-        WESTXSHIFT=westxshift,
-        WESTYSHIFT=westyshift
+	AXESFONTSIZE = axesfontsize,
+	EASTJUSTIFICATION = eastjustification,
+	EASTXSHIFT = eastxshift,
+	EASTYSHIFT = eastyshift,
+	NORTHJUSTIFICATION = northjustification,
+	NORTHXSHIFT = northxshift,
+	NORTHYSHIFT = northyshift,
+	SOUTHJUSTIFICATION = southjustification,
+	SOUTHXSHIFT = southxshift,
+	SOUTHYSHIFT = southyshift,
+	WESTJUSTIFICATION = westjustification,
+	WESTXSHIFT = westxshift,
+	WESTYSHIFT = westyshift
     outf.write(s)
     sublength = len(sine_cosine_replic) - 2
     (x, y) = sine_cosine_replic[1]
-    outf.write(
     for x, y in sine_cosine_replic[2:]:
-        outf.write(
 stroke
@@ -350,18 +334,14 @@
                                         %% coordinates of rescaled, translated average direction follow
                                         %% first point moveto, second lineto
-    s = t.substitute(DIAGRAMLINEWIDTH=diagramlinewidth)
+    s = t.substitute(DIAGRAMLINEWIDTH = diagramlinewidth)
     outf.write(s)
     sublength = len(vector) - 2
     (x, y) = vector[1]
-    outf.write(
     for x, y in vector[2:]:
-        outf.write(
 stroke
@@ -383,21 +363,20 @@
 ($AVERAGEDIRECTIONSTRING) $LEGENDSX $AVERAGEDIRECTIONLEGENDY 4 just-string
     s = t.substitute(
-        ALLDATALEGENDY=alldatalegendy,
-        ALLDATASTRING=alldatastring,
-        AVERAGEDIRECTIONLEGENDY=averagedirectionlegendy,
-        AVERAGEDIRECTIONSTRING=averagedirectionstring,
-        LEGENDSX=legendsx,
-        REALDATALEGENDY=realdatalegendy,
-        REALDATASTRING=realdatastring
+	ALLDATALEGENDY = alldatalegendy,
+	ALLDATASTRING = alldatastring,
+	AVERAGEDIRECTIONLEGENDY = averagedirectionlegendy,
+	AVERAGEDIRECTIONSTRING = averagedirectionstring,
+	LEGENDSX = legendsx,
+	REALDATALEGENDY = realdatalegendy,
+	REALDATASTRING = realdatastring
     outf.write(s)
     outf.close()
-    gcore.message(_("Done."))
+    grass.message(_("Done."))
 def main():
     global tmp
     global sine_cosine_replic, outercircle, vector
@@ -408,33 +387,31 @@
     eps = options['output']
     xgraph = flags['x']
-    tmp = gcore.tempfile()
+    tmp = grass.tempfile()
     if eps and xgraph:
-        gcore.fatal(_("Please select only one output method"))
+	grass.fatal(_("Please select only one output method"))
-    # check if we have xgraph (if no EPS output requested)
-    if xgraph and not gcore.find_program('xgraph'):
-        gcore.fatal(
-            _("xgraph required, please install first (www.xgraph.org)"))
+    #### check if we have xgraph (if no EPS output requested)
+    if xgraph and not grass.find_program('xgraph'):
+	grass.fatal(_("xgraph required, please install first (www.xgraph.org)"))
     # this file contains everthing:
     rawfile = tmp + "_raw"
     rawf = file(rawfile, 'w')
-    gcore.run_command('r.stats', flags='1', input=map, stdout=rawf)
+    grass.run_command('r.stats', flags = '1', input = map, stdout = rawf)
     rawf.close()
     rawf = file(rawfile)
     totalnumber = 0
     for line in rawf:
-        totalnumber += 1
+	totalnumber += 1
     rawf.close()
-    gcore.message(
-        _("Calculating statistics for polar diagram... (be patient)"))
+    grass.message(_("Calculating statistics for polar diagram... (be patient)"))
-    # wipe out NULL data and undef data if defined by user
+    #wipe out NULL data and undef data if defined by user
     # - generate degree binned to integer, eliminate NO DATA (NULL):
     # change 360 to 0 to close polar diagram:
@@ -443,26 +420,26 @@
     sumsin = 0
     freq = {}
     for line in rawf:
-        line = line.rstrip('\r\n')
-        if line in ['*', undef]:
-            continue
-        nvals += 1
-        x = float(line)
-        rx = math.radians(x)
-        sumcos += math.cos(rx)
-        sumsin += math.sin(rx)
-        ix = round(x)
-        if ix == 360:
-            ix = 0
-        if ix in freq:
-            freq[ix] += 1
-        else:
-            freq[ix] = 1
+	line = line.rstrip('\r\n')
+	if line in ['*', undef]:
+	    continue
+	nvals += 1
+	x = float(line)
+	rx = math.radians(x)
+	sumcos += math.cos(rx)
+	sumsin += math.sin(rx)
+	ix = round(x)
+	if ix == 360:
+	    ix = 0
+	if ix in freq:
+	    freq[ix] += 1
+	else:
+	    freq[ix] = 1
     rawf.close()
     totalvalidnumber = nvals
     if totalvalidnumber == 0:
-        gcore.fatal(_("No data pixel found"))
+	grass.fatal(_("No data pixel found"))
     # unit vector on raw data converted to radians without no data:
@@ -472,8 +449,9 @@
     # how many are there?:
-    occurrences = sorted([(math.radians(x), freq[x]) for x in freq])
+    occurrences = [(math.radians(x), freq[x]) for x in freq]
+    occurrences.sort()
     # find the maximum value
     maxradius = max([f for a, f in occurrences])
@@ -483,14 +461,14 @@
     sine_cosine_replic = ['"Real data angles'] + sine_cosine + sine_cosine[0:1]
     if eps or xgraph:
-        outercircle = []
-        outercircle.append('"All Data incl. NULLs')
-        scale = 1.0 * totalnumber / totalvalidnumber * maxradius
-        for i in range(0, 361):
-            a = math.radians(i)
-            x = math.cos(a) * scale
-            y = math.sin(a) * scale
-            outercircle.append((x, y))
+	outercircle = []
+	outercircle.append('"All Data incl. NULLs')
+	scale = 1.0 * totalnumber / totalvalidnumber * maxradius
+	for i in range(0, 361):
+	    a = math.radians(i)
+	    x = math.cos(a) * scale
+	    y = math.sin(a) * scale
+	    outercircle.append((x, y))
     # fix vector length to become visible (x? of $MAXRADIUS):
     vector = []
@@ -503,28 +481,19 @@
     # Now output:
     if eps:
-        psout = basename(eps, 'eps') + '.eps'
-        plot_eps(psout)
+	psout = basename(eps, 'eps') + '.eps'
+	plot_eps(psout)
     elif xgraph:
-        plot_xgraph()
+	plot_xgraph()
     else:
-        plot_dgraph()
+	plot_dgraph()
-    gcore.message(_("Average vector:"))
-    gcore.message(
-        _("direction: %.1f degrees CCW from East") %
-        math.degrees(
-            math.atan2(
-                unitvector[1],
-                unitvector[0])))
-    gcore.message(
-        _("magnitude: %.1f percent of fullscale") %
-        (100 *
-         math.hypot(
-             unitvector[0],
-             unitvector[1])))
+    grass.message(_("Average vector:"))
+    grass.message(_("direction: %.1f degrees CCW from East") % math.degrees(math.atan2(unitvector[1], unitvector[0])))
+    grass.message(_("magnitude: %.1f percent of fullscale") % (100 * math.hypot(unitvector[0], unitvector[1])))
     atexit.register(cleanup)
     main()
Modified: grass/trunk/scripts/d.rast.edit/d.rast.edit.py
--- grass/trunk/scripts/d.rast.edit/d.rast.edit.py	2016-03-29 06:29:14 UTC (rev 68180)
+++ grass/trunk/scripts/d.rast.edit/d.rast.edit.py	2016-03-29 08:10:14 UTC (rev 68181)
@@ -16,7 +16,7 @@
 #  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
 #  GNU General Public License for more details.
 #%module
 #% description: Edits cell values in a raster map.
@@ -81,15 +81,15 @@
 try:
     import wxversion
-    wxversion.select(['3.0', '2.8', '2.6'])
+    wxversion.select(['3.0', '2.8','2.6'])
     import wx
 except Exception:
     # ensure that --help, --interface-description etc work even without wx
-        if len(sys.argv) == 2:
-            arg = sys.argv[1]
-            if arg[0:2] == '--' or arg in ["help", "-help"]:
-                grass.parser()
+	if len(sys.argv) == 2:
+	    arg = sys.argv[1]
+	    if arg[0:2] == '--' or arg in ["help", "-help"]:
+		grass.parser()
     # Either we didn't call g.parser, or it returned
     # At this point, there's nothing to be done except re-raise the exception
     raise
@@ -97,637 +97,609 @@
 wind_keys = {
     'north': ('n', float),
     'south': ('s', float),
-    'east': ('e', float),
-    'west': ('w', float),
+    'east':  ('e', float),
+    'west':  ('w', float),
     'nsres': ('nsres', float),
     'ewres': ('ewres', float),
-    'rows': ('rows', int),
-    'cols': ('cols', int),
+    'rows':  ('rows', int),
+    'cols':  ('cols', int),
 gray12_bits = '\x00\x00\x22\x22\x00\x00\x88\x88\x00\x00\x22\x22\x00\x00\x88\x88\x00\x00\x22\x22\x00\x00\x88\x88\x00\x00\x22\x22\x00\x00\x88\x88'
 def run(cmd, **kwargs):
-    grass.run_command(cmd, quiet=True, **kwargs)
+    grass.run_command(cmd, quiet = True, **kwargs)
 class OverviewCanvas(wx.ScrolledWindow):
     def __init__(self, app, parent):
-        wx.ScrolledWindow.__init__(self, parent)
-        self.app = app
+	wx.ScrolledWindow.__init__(self, parent)
+	self.app = app
-        self.width = app.total['cols']
-        self.height = app.total['rows']
+	self.width = app.total['cols']
+	self.height = app.total['rows']
-        self.SetVirtualSize((self.width, self.height))
-        self.SetScrollRate(1, 1)
+	self.SetVirtualSize((self.width, self.height))
+	self.SetScrollRate(1, 1)
-        self.Bind(wx.EVT_LEFT_DOWN, self.OnMouse)
-        self.Bind(wx.EVT_MOTION, self.OnMouse)
-        self.Bind(wx.EVT_LEFT_UP, self.OnMouse)
-        self.Bind(wx.EVT_PAINT, self.OnPaint)
+	self.Bind(wx.EVT_LEFT_DOWN, self.OnMouse)
+	self.Bind(wx.EVT_MOTION, self.OnMouse)
+	self.Bind(wx.EVT_LEFT_UP, self.OnMouse)
+	self.Bind(wx.EVT_PAINT, self.OnPaint)
-        run('r.out.ppm', input=app.inmap, output=app.tempfile)
+	run('r.out.ppm', input = app.inmap, output = app.tempfile)
-        self.image = wx.BitmapFromImage(wx.Image(app.tempfile))
-        grass.try_remove(app.tempfile)
+	self.image = wx.BitmapFromImage(wx.Image(app.tempfile))
+	grass.try_remove(app.tempfile)
-        app.force_window()
+	app.force_window()
     def OnPaint(self, ev):
-        x0 = self.app.origin_x
-        y0 = self.app.origin_y
-        dx = self.app.cols
-        dy = self.app.rows
+	x0 = self.app.origin_x
+	y0 = self.app.origin_y
+	dx = self.app.cols
+	dy = self.app.rows
-        dc = wx.PaintDC(self)
-        self.DoPrepareDC(dc)
+	dc = wx.PaintDC(self)
+	self.DoPrepareDC(dc)
-        src = wx.MemoryDC()
-        src.SelectObjectAsSource(self.image)
-        dc.Blit(0, 0, self.width, self.height, src, 0, 0)
-        src.SelectObjectAsSource(wx.NullBitmap)
+	src = wx.MemoryDC()
+	src.SelectObjectAsSource(self.image)
+	dc.Blit(0, 0, self.width, self.height, src, 0, 0)
+	src.SelectObjectAsSource(wx.NullBitmap)
-        dc.SetPen(wx.Pen('red', style=wx.LONG_DASH))
-        dc.SetBrush(wx.Brush('black', style=wx.TRANSPARENT))
-        dc.DrawRectangle(x0, y0, dx, dy)
-        dc.SetBrush(wx.NullBrush)
-        dc.SetPen(wx.NullPen)
+	dc.SetPen(wx.Pen('red', style = wx.LONG_DASH))
+	dc.SetBrush(wx.Brush('black', style = wx.TRANSPARENT))
+	dc.DrawRectangle(x0, y0, dx, dy)
+	dc.SetBrush(wx.NullBrush)
+	dc.SetPen(wx.NullPen)
     def OnMouse(self, ev):
-        if ev.Moving():
-            return
-        x = ev.GetX()
-        y = ev.GetY()
-        (x, y) = self.CalcUnscrolledPosition(x, y)
-        self.set_window(x, y)
-        if ev.ButtonUp():
-            self.app.change_window()
+	if ev.Moving():
+	    return
+	x = ev.GetX()
+	y = ev.GetY()
+	(x, y) = self.CalcUnscrolledPosition(x, y)
+	self.set_window(x, y)
+	if ev.ButtonUp():
+	    self.app.change_window()
     def set_window(self, x, y):
-        self.app.origin_x = x - app.cols / 2
-        self.app.origin_y = y - app.rows / 2
-        self.app.force_window()
-        self.Refresh()
+	self.app.origin_x = x - app.cols / 2
+	self.app.origin_y = y - app.rows / 2
+	self.app.force_window()
+	self.Refresh()
 class OverviewWindow(wx.Frame):
     def __init__(self, app):
-        wx.Frame.__init__(
-            self,
-            None,
-            title="d.rast.edit overview (%s)" %
-            app.inmap)
-        self.app = app
+	wx.Frame.__init__(self, None, title = "d.rast.edit overview (%s)" % app.inmap)
+	self.app = app
-        self.canvas = OverviewCanvas(app, parent=self)
+	self.canvas = OverviewCanvas(app, parent = self)
-        self.Bind(wx.EVT_CLOSE, self.OnClose)
+	self.Bind(wx.EVT_CLOSE, self.OnClose)
     def OnClose(self, ev):
-        self.app.finalize()
+	self.app.finalize()
 class Canvas(wx.ScrolledWindow):
-        self.app = app
+	self.app = app
-        self.size = app.size
+	self.size = app.size
-        w = app.cols * self.size
-        h = app.rows * self.size
+	w = app.cols * self.size
+	h = app.rows * self.size
-        self.SetVirtualSize((w, h))
-        self.SetVirtualSizeHints(50, 50)
+	self.SetVirtualSize((w, h))
+	self.SetVirtualSizeHints(50, 50)
-        self.Bind(wx.EVT_RIGHT_DOWN, self.OnMouse)
-        self.Bind(wx.EVT_PAINT, self.OnPaint2)
+	self.Bind(wx.EVT_RIGHT_DOWN, self.OnMouse)
+	self.Bind(wx.EVT_PAINT, self.OnPaint2)
-        self.row = 0
-        self.col = 0
+	self.row = 0
+	self.col = 0
-        self.gray12 = wx.BitmapFromBits(gray12_bits, 16, 16)
+	self.gray12 = wx.BitmapFromBits(gray12_bits, 16, 16)
-        oldrow = self.row
-        oldcol = self.col
+	oldrow = self.row
+	oldcol = self.col
-        x = ev.GetX()
-        y = ev.GetY()
+	x = ev.GetX()
+	y = ev.GetY()
-        col = x / self.size
-        row = y / self.size
+	col = x / self.size
+	row = y / self.size
-        self.row = row
-        self.col = col
+	self.row = row
+	self.col = col
-        if ev.Moving():
-            self.refresh_cell(oldrow, oldcol)
-            self.refresh_cell(row, col)
-        elif ev.ButtonDown(wx.MOUSE_BTN_LEFT):
-            self.cell_set()
-        elif ev.ButtonDown(wx.MOUSE_BTN_RIGHT):
-            self.cell_get()
+	if ev.Moving():
+	    self.refresh_cell(oldrow, oldcol)
+	    self.refresh_cell(row, col)
+	elif ev.ButtonDown(wx.MOUSE_BTN_LEFT):
+	    self.cell_set()
+	elif ev.ButtonDown(wx.MOUSE_BTN_RIGHT):
+	    self.cell_get()
     def paint_cell(self, dc, r, c):
-        if r < 0 or r >= self.app.rows or c < 0 or c >= self.app.cols:
-            return
+	if r < 0 or r >= self.app.rows or c < 0 or c >= self.app.cols:
+	    return
-        val = self.app.values[r][c]
-        if val is None:
-            fill = 'black'
-            stipple = self.gray12
-        else:
-            fill = self.app.get_color(val)
-            stipple = None
+	val = self.app.values[r][c]
+	if val == None:
+	    fill = 'black'
+	    stipple = self.gray12
+	else:
+	    fill = self.app.get_color(val)
+	    stipple = None
-        if r == self.row and c == self.col:
-            outline = 'red'
-        elif self.app.changed[r][c]:
-            outline = 'white'
-        else:
-            outline = 'black'
+	if r == self.row and c == self.col:
+	    outline = 'red'
+	elif self.app.changed[r][c]:
+	    outline = 'white'
+	else:
+	    outline = 'black'
-        dc.SetPen(wx.Pen(outline))
+	dc.SetPen(wx.Pen(outline))
-        if stipple:
-            brush = wx.Brush(fill, style=wx.STIPPLE)
-            brush.SetStipple(stipple)
-        else:
-            brush = wx.Brush(fill, style=wx.SOLID)
+	if stipple:
+	    brush = wx.Brush(fill, style = wx.STIPPLE)
+	    brush.SetStipple(stipple)
+	else:
+	    brush = wx.Brush(fill, style = wx.SOLID)
-        x0 = c * self.size + 1
-        x1 = x0 + self.size - 1
-        y0 = r * self.size + 1
-        y1 = y0 + self.size - 1
+	x0 = c * self.size + 1
+	x1 = x0  + self.size - 1
+	y0 = r * self.size + 1
+	y1 = y0  + self.size - 1
-        dc.SetBrush(brush)
-        dc.DrawRectangle(x0, y0, x1 - x0, y1 - y0)
+	dc.SetBrush(brush)
+	dc.DrawRectangle(x0, y0, x1 - x0, y1 - y0)
-        if not self.app.angles:
-            return
+	if not self.app.angles:
+	    return
-        if self.app.angles[r][c] == '*':
-            return
+	if self.app.angles[r][c] == '*':
+	    return
-        cx = (x0 + x1) / 2
-        cy = (y0 + y1) / 2
+	cx = (x0 + x1) / 2
+	cy = (y0 + y1) / 2
-        a = math.radians(float(self.app.angles[r][c]))
-        dx = math.cos(a) * self.size / 2
-        dy = -math.sin(a) * self.size / 2
+	a = math.radians(float(self.app.angles[r][c]))
+	dx =  math.cos(a) * self.size / 2
+	dy = -math.sin(a) * self.size / 2
-        x0 = cx - dx
-        y0 = cy - dy
-        x1 = cx + dx
-        y1 = cy + dy
+	x0 = cx - dx
+	y0 = cy - dy
+	x1 = cx + dx
+	y1 = cy + dy
-        dx, dy = x1 - x0, y1 - y0
-        px, py = -dy, dx
+	dx, dy = x1 - x0, y1 - y0
+	px, py = -dy, dx
-        r, g, b = wx.NamedColor(fill)
-        if r + g + b > 384:
-            line = 'black'
-        else:
-            line = 'white'
+	r,g,b = wx.NamedColor(fill)
+	if r + g + b > 384:
+	    line = 'black'
+	else:
+	    line = 'white'
-        dc.SetPen(wx.Pen(line))
-        dc.DrawLine(x0, y0, x1, y1)
-        dc.DrawLine(x1, y1, x1 + px / 6 - dx / 3, y1 + py / 6 - dy / 3)
-        dc.DrawLine(x1, y1, x1 - px / 6 - dx / 3, y1 - py / 6 - dy / 3)
+	dc.SetPen(wx.Pen(line))
+	dc.DrawLine(x0, y0, x1, y1)
+	dc.DrawLine(x1, y1, x1 + px/6 - dx/3, y1 + py/6 - dy/3)
+	dc.DrawLine(x1, y1, x1 - px/6 - dx/3, y1 - py/6 - dy/3)
     def paint_rect(self, dc, x, y, w, h):
-        c0 = (x + 0) / self.size
-        c1 = (x + w + 1) / self.size
-        r0 = (y + 0) / self.size
-        r1 = (y + h + 1) / self.size
-        for r in range(r0, r1 + 1):
-            for c in range(c0, c1 + 1):
-                self.paint_cell(dc, r, c)
+	c0 = (x + 0) / self.size
+	c1 = (x + w + 1) / self.size
+	r0 = (y + 0) / self.size
+	r1 = (y + h + 1) / self.size
+	for r in range(r0, r1 + 1):
+	    for c in range(c0, c1 + 1):
+		self.paint_cell(dc, r, c)
-        for r in range(self.app.rows):
-            for c in range(self.app.cols):
+	for r in range(self.app.rows):
+	    for c in range(self.app.cols):
     def OnPaint2(self, ev):
-        it = wx.RegionIterator(self.GetUpdateRegion())
-        while it.HaveRects():
-            x = it.GetX()
-            y = it.GetY()
-            w = it.GetW()
-            h = it.GetH()
-            self.paint_rect(dc, x, y, w, h)
-            it.Next()
+	it = wx.RegionIterator(self.GetUpdateRegion())
+	while it.HaveRects():
+	    x = it.GetX()
+	    y = it.GetY()
+	    w = it.GetW()
+	    h = it.GetH()
+	    self.paint_rect(dc, x, y, w, h)
+	    it.Next()
     def cell_enter(self):
-        if not self.row or not self.col:
-            return
-        self.app.update_status(self.row, self.col)
+	if not self.row or not self.col:
+	    return
+	self.app.update_status(self.row, self.col)
     def cell_leave(self):
-        self.app.clear_status()
+	self.app.clear_status()
     def cell_get(self):
-        self.app.brush = self.app.values[self.row][self.col]
-        self.app.frame.brush_update()
+	self.app.brush = self.app.values[self.row][self.col]
+	self.app.frame.brush_update()
     def cell_set(self):
-        self.app.values[self.row][self.col] = self.app.brush
-        self.app.changed[self.row][self.col] = True
-        self.refresh_cell(self.row, self.col)
+	self.app.values[self.row][self.col] = self.app.brush
+	self.app.changed[self.row][self.col] = True
+	self.refresh_cell(self.row, self.col)
     def refresh_cell(self, row, col):
-        x = col * self.size
-        y = row * self.size
-        (x, y) = self.CalcScrolledPosition(x, y)
-        self.RefreshRect((x, y, self.size, self.size))
+	x = col * self.size
+	y = row * self.size
+	(x, y) = self.CalcScrolledPosition(x, y)
+	self.RefreshRect((x, y, self.size, self.size))
 class ColorPanel(wx.Panel):
     def __init__(self, **kwargs):
-        wx.Panel.__init__(self, **kwargs)
-        self.SetBackgroundStyle(wx.BG_STYLE_COLOUR)
-        self.stipple = wx.BitmapFromBits(gray12_bits, 16, 16)
-        self.null_bg = True
-        self.Bind(wx.EVT_ERASE_BACKGROUND, self.OnErase)
+	wx.Panel.__init__(self, **kwargs)
+	self.SetBackgroundStyle(wx.BG_STYLE_COLOUR)
+	self.stipple = wx.BitmapFromBits(gray12_bits, 16, 16)
+	self.null_bg = True
+	self.Bind(wx.EVT_ERASE_BACKGROUND, self.OnErase)
     def OnErase(self, ev):
-        self.ClearBackground()
+	self.ClearBackground()
-        if not self.null_bg:
-            return
+	if not self.null_bg:
+	    return
-        dc = ev.GetDC()
-        if not dc:
-            dc = wx.ClientDC(self)
+	dc = ev.GetDC()
+	if not dc:
+	    dc = wx.ClientDC(self)
-        brush = wx.Brush('black', style=wx.STIPPLE)
-        brush.SetStipple(self.stipple)
-        dc.SetBackground(brush)
-        dc.Clear()
-        dc.SetBackground(wx.NullBrush)
+	brush = wx.Brush('black', style = wx.STIPPLE)
+	brush.SetStipple(self.stipple)
+	dc.SetBackground(brush)
+	dc.Clear()
+	dc.SetBackground(wx.NullBrush)
     def SetNullBackgroundColour(self):
-        wx.Panel.SetBackgroundColour(self, 'gray')
+	wx.Panel.SetBackgroundColour(self, 'gray')
     def SetBackgroundColour(self, color):
-        wx.Panel.SetBackgroundColour(self, color)
-        self.null_bg = False
+	wx.Panel.SetBackgroundColour(self, color)
+	self.null_bg = False
 class MainWindow(wx.Frame):
-        wx.Frame.__init__(self, None, title="d.rast.edit (%s)" % app.inmap)
-        self.app = app
+	wx.Frame.__init__(self, None, title = "d.rast.edit (%s)" % app.inmap)
+	self.app = app
-        filemenu = wx.Menu()
-        filemenu.Append(wx.ID_SAVE, "&Save", "Save changes")
-        filemenu.Append(wx.ID_EXIT, "E&xit", "Terminate the program")
-        menubar = wx.MenuBar()
-        menubar.Append(filemenu, "&File")
-        self.SetMenuBar(menubar)
+	filemenu = wx.Menu()
+	filemenu.Append(wx.ID_SAVE, "&Save", "Save changes")
+	filemenu.Append(wx.ID_EXIT, "E&xit", "Terminate the program")
+	menubar = wx.MenuBar()
+	menubar.Append(filemenu, "&File")
+	self.SetMenuBar(menubar)
-        wx.EVT_MENU(self, wx.ID_SAVE, self.OnSave)
-        wx.EVT_MENU(self, wx.ID_EXIT, self.OnExit)
+	wx.EVT_MENU(self, wx.ID_SAVE, self.OnSave)
+	wx.EVT_MENU(self, wx.ID_EXIT, self.OnExit)
-        sizer = wx.BoxSizer(orient=wx.VERTICAL)
+	sizer = wx.BoxSizer(orient = wx.VERTICAL)
-        self.canvas = Canvas(app, parent=self)
-        si = sizer.Add(self.canvas, proportion=1, flag=wx.EXPAND)
+	self.canvas = Canvas(app, parent = self)
+	si = sizer.Add(self.canvas, proportion = 1, flag = wx.EXPAND)
-        tools = wx.BoxSizer(wx.HORIZONTAL)
+	tools = wx.BoxSizer(wx.HORIZONTAL)
-        l = wx.StaticText(parent=self, label='New Value:')
-        tools.Add(l, flag=wx.ALIGN_CENTER_VERTICAL)
-        tools.AddSpacer(5)
+	l = wx.StaticText(parent = self, label = 'New Value:')
+	tools.Add(l, flag = wx.ALIGN_CENTER_VERTICAL)
+	tools.AddSpacer(5)
-        self.newval = wx.TextCtrl(parent=self, style=wx.TE_PROCESS_ENTER)
-        tools.Add(self.newval, flag=wx.ALIGN_CENTER_VERTICAL)
+	self.newval = wx.TextCtrl(parent = self, style = wx.TE_PROCESS_ENTER)
+	tools.Add(self.newval, flag = wx.ALIGN_CENTER_VERTICAL)
-        l = wx.StaticText(parent=self, label='Color:')
+	l = wx.StaticText(parent = self, label = 'Color:')
-        self.color = ColorPanel(parent=self, size=(30, 5))
-        tools.Add(self.color, flag=wx.ALIGN_CENTER_VERTICAL | wx.EXPAND)
+	self.color = ColorPanel(parent = self, size = (30,5))
+	tools.Add(self.color, flag = wx.ALIGN_CENTER_VERTICAL | wx.EXPAND)
-        self.Bind(wx.EVT_TEXT_ENTER, self.OnReturn, source=self.newval)
+	self.Bind(wx.EVT_TEXT_ENTER, self.OnReturn, source = self.newval)
-        sizer.AddSizer(tools, proportion=0, flag=wx.EXPAND)
+	sizer.AddSizer(tools, proportion = 0, flag = wx.EXPAND)
-        self.SetSizerAndFit(sizer)
-        self.SetSize((app.width, app.height))
+	self.SetSizerAndFit(sizer)
+	self.SetSize((app.width, app.height))
-        self.status = self.CreateStatusBar(6)
+	self.status = self.CreateStatusBar(6)
-        self.brush_update()
+	self.brush_update()
     def OnSave(self, ev):
-        self.app.save_map()
+	self.app.save_map()
     def OnExit(self, ev):
-        self.Close(True)
+	self.Close(True)
     def OnReturn(self, ev):
-        self.app.brush = self.newval.GetValue()
-        if self.app.brush != '*' and self.app.brush.strip('0123456789') != '':
-            self.app.brush = '*'
+	self.app.brush = self.newval.GetValue()
+	if self.app.brush != '*' and self.app.brush.strip('0123456789') != '':
+	    self.app.brush = '*'
     def update_status(self):
-        for i, key in enumerate(['row', 'col', 'x', 'y', 'value', 'aspect']):
-            s = "%s%s: %s" % (key[0].upper(), key[1:], self.app.status[key])
-            self.status.SetStatusText(s, i)
+	for i, key in enumerate(['row', 'col', 'x', 'y', 'value', 'aspect']):
+	    s = "%s%s: %s" % (key[0].upper(), key[1:], self.app.status[key])
+	    self.status.SetStatusText(s, i)
     def clear_status(self):
-        for key in self.status:
-            self.status[key] = ''
+	for key in self.status:
+	    self.status[key] = ''
     def brush_update(self):
-        self.newval.ChangeValue(self.app.brush)
-        if self.app.brush == '*':
-            self.color.SetNullBackgroundColour()
-        else:
-            self.color.SetBackgroundColour(self.app.get_color(self.app.brush))
-        self.color.Refresh()
+	self.newval.ChangeValue(self.app.brush)
+	if self.app.brush == '*':
+	    self.color.SetNullBackgroundColour()
+	else:
+	    self.color.SetBackgroundColour(self.app.get_color(self.app.brush))
+	self.color.Refresh()
 class Application(wx.App):
     def __init__(self, options):
-        self.options = options
-        wx.App.__init__(self)
+	self.options = options
+	wx.App.__init__(self)
     def initialize(self):
-        grass.use_temp_region()
+	grass.use_temp_region()
-        run('g.region', raster=self.inmap)
+	run('g.region', raster = self.inmap)
-        reg = grass.region()
-        for k, f in wind_keys.values():
-            self.total[k] = (f)(reg[k])
+	reg = grass.region()
+	for k, f in wind_keys.values():
+	    self.total[k] = (f)(reg[k])
-        if self.cols > self.total['cols']:
-            self.cols = self.total['cols']
-        if self.rows > self.total['rows']:
-            self.rows = self.total['rows']
+	if self.cols > self.total['cols']:
+	    self.cols = self.total['cols']
+	if self.rows > self.total['rows']:
+	    self.rows = self.total['rows']
-        tempbase = grass.tempfile()
-        grass.try_remove(tempbase)
+	tempbase = grass.tempfile()
+	grass.try_remove(tempbase)
-        self.tempfile = tempbase + '.ppm'
-        self.tempmap = 'tmp.d.rast.edit'
+	self.tempfile = tempbase + '.ppm'
+	self.tempmap = 'tmp.d.rast.edit'
-        atexit.register(self.cleanup)
+	atexit.register(self.cleanup)
-        run('g.copy', raster=(self.inmap, self.outmap), overwrite=True)
-        run('r.colors', map=self.outmap, rast=self.inmap)
+	run('g.copy', raster = (self.inmap, self.outmap), overwrite = True)
+	run('r.colors', map = self.outmap, rast = self.inmap)
     def cleanup(self):
-        grass.try_remove(self.tempfile)
-        run('g.remove', flags='f', type='raster', name=self.tempmap)
+	grass.try_remove(self.tempfile)
+	run('g.remove', flags = 'f', type = 'raster', name = self.tempmap)
     def finalize(self):
-        self.save_map()
-        sys.exit(0)
+	self.save_map()
+	sys.exit(0)
     def save_map(self):
-        p = grass.feed_command(
-            'r.in.ascii',
-            input='-',
-            output=self.tempmap,
-            quiet=True,
-            overwrite=True)
-        outf = p.stdin
-        outf.write("north: %f\n" % self.wind['n'])
-        outf.write("south: %f\n" % self.wind['s'])
-        outf.write("east: %f\n" % self.wind['e'])
-        outf.write("west: %f\n" % self.wind['w'])
-        outf.write("rows: %d\n" % self.wind['rows'])
-        outf.write("cols: %d\n" % self.wind['cols'])
-        outf.write("null: *\n")
+	p = grass.feed_command('r.in.ascii', input = '-', output = self.tempmap, quiet = True, overwrite = True)
+	outf = p.stdin
+	outf.write("north: %f\n" % self.wind['n'])
+	outf.write("south: %f\n" % self.wind['s'])
+	outf.write("east: %f\n"  % self.wind['e'])
+	outf.write("west: %f\n"  % self.wind['w'])
+	outf.write("rows: %d\n"  % self.wind['rows'])
+	outf.write("cols: %d\n"  % self.wind['cols'])
+	outf.write("null: *\n")
-        for row in range(self.wind['rows']):
-            for col in range(self.wind['cols']):
-                if col > 0:
-                    outf.write(" ")
-                val = self.values[row][col]
-                if val and self.changed[row][col]:
-                    outf.write("%s" % val)
-                else:
-                    outf.write('*')
-            outf.write("\n")
+	for row in range(self.wind['rows']):
+	    for col in range(self.wind['cols']):
+		if col > 0:
+		    outf.write(" ")
+		val = self.values[row][col]
+		if val and self.changed[row][col]:
+		    outf.write("%s" % val)
+		else:
+		    outf.write('*')
+	    outf.write("\n")
-        outf.close()
-        p.wait()
+	outf.close()
+	p.wait()
-        run('r.patch',
-            input=(self.tempmap,
-                   self.outmap),
-            output=self.outmap,
-            overwrite=True)
+	run('r.patch', input = (self.tempmap, self.outmap), output = self.outmap, overwrite = True)
     def read_header(self, infile):
-        wind = {}
-        for i in range(6):
-            line = infile.readline().rstrip('\r\n')
-            f = line.split(':')
-            key = f[0]
-            val = f[1].strip()
-            (k, f) = wind_keys[key]
-            wind[k] = (f)(val)
-        return wind
+	wind = {}
+	for i in range(6):
+	    line = infile.readline().rstrip('\r\n')
+	    f = line.split(':')
+	    key = f[0]
+	    val = f[1].strip()
+	    (k, f) = wind_keys[key]
+	    wind[k] = (f)(val)
+	return wind
     def read_data(self, infile):
-        values = []
-            values.append(line.split())
-        return values
+	values = []
+	    values.append(line.split())
+	return values
     def load_map(self):
-        run('g.region', **self.wind)
+	run('g.region', **self.wind)
-        p = grass.pipe_command('r.out.ascii', input=self.inmap, quiet=True)
-        self.wind = self.read_header(p.stdout)
-        self.values = self.read_data(p.stdout)
-        self.changed = [[False for c in row] for row in self.values]
-        p.wait()
+	p = grass.pipe_command('r.out.ascii', input = self.inmap, quiet = True)
+	self.wind = self.read_header(p.stdout)
+	self.values = self.read_data(p.stdout)
+	self.changed = [[False for c in row] for row in self.values]
+	p.wait()
-        self.clear_changes()
+	self.clear_changes()
-        run('r.out.ppm', input=self.inmap, output=self.tempfile)
-        colorimg = wx.Image(self.tempfile)
+	run('r.out.ppm', input = self.inmap, output = self.tempfile)
+	colorimg = wx.Image(self.tempfile)
-                if val in self.colors:
-                    continue
-                r = colorimg.GetRed(col, row)
-                g = colorimg.GetGreen(col, row)
-                b = colorimg.GetBlue(col, row)
-                color = "#%02x%02x%02x" % (r, g, b)
-                self.colors[val] = color
+		if val in self.colors:
+		    continue
+		r = colorimg.GetRed(col, row)
+		g = colorimg.GetGreen(col, row)
+		b = colorimg.GetBlue(col, row)
+		color = "#%02x%02x%02x" % (r, g, b)
+		self.colors[val] = color
-        colorimg.Destroy()
+	colorimg.Destroy()
     def load_aspect(self):
-        if not self.aspect:
-            return
+	if not self.aspect:
+	    return
-        p = grass.pipe_command('r.out.ascii', input=self.aspect, quiet=True)
-        self.read_header(p.stdout)
-        self.angles = self.read_data(p.stdout)
-        p.wait()
+	p = grass.pipe_command('r.out.ascii', input = self.aspect, quiet = True)
+	self.read_header(p.stdout)
+	self.angles = self.read_data(p.stdout)
+	p.wait()
     def clear_changes(self):
-                self.changed[row][col] = 0
+		self.changed[row][col] = 0
     def update_window(self):
-        x0 = self.origin_x
-        y0 = self.origin_y
-        x1 = x0 + self.cols
-        y1 = y0 + self.rows
+	x0 = self.origin_x
+	y0 = self.origin_y
+	x1 = x0 + self.cols
+	y1 = y0 + self.rows
-        self.wind['n'] = self.total['n'] - y0 * self.total['nsres']
-        self.wind['s'] = self.total['n'] - y1 * self.total['nsres']
-        self.wind['w'] = self.total['w'] + x0 * self.total['ewres']
-        self.wind['e'] = self.total['w'] + x1 * self.total['ewres']
-        self.wind['rows'] = self.rows
-        self.wind['cols'] = self.cols
+	self.wind['n'] = self.total['n'] - y0 * self.total['nsres']
+	self.wind['s'] = self.total['n'] - y1 * self.total['nsres']
+	self.wind['w'] = self.total['w'] + x0 * self.total['ewres']
+	self.wind['e'] = self.total['w'] + x1 * self.total['ewres']
+	self.wind['rows'] = self.rows
+	self.wind['cols'] = self.cols
     def change_window(self):
-        self.save_map()
-        self.update_window()
-        self.load_map()
-        self.load_aspect()
-        self.refresh_canvas()
+	self.save_map()
+	self.update_window()
+	self.load_map()
+	self.load_aspect()
+	self.refresh_canvas()
     def force_window(self):
-        if self.origin_x < 0:
-            self.origin_x = 0
-        if self.origin_x > self.total['cols'] - self.cols:
-            self.origin_x = self.total['cols'] - self.cols
-        if self.origin_y < 0:
-            self.origin_y = 0
-        if self.origin_y > self.total['rows'] - self.rows:
-            self.origin_y = self.total['rows'] - self.rows
+	if self.origin_x < 0:
+	    self.origin_x = 0
+	if self.origin_x > self.total['cols'] - self.cols:
+	    self.origin_x = self.total['cols'] - self.cols
+	if self.origin_y < 0:
+	    self.origin_y = 0
+	if self.origin_y > self.total['rows'] - self.rows:
+	    self.origin_y = self.total['rows'] - self.rows
     def update_status(self, row, col):
-        self.status['row'] = row
-        self.status['col'] = col
-        self.status['x'] = self.wind[
-            'e'] + (col + 0.5) * (self.wind['e'] - self.wind['w']) / self.wind['cols']
-        self.status['y'] = self.wind[
-            'n'] - (row + 0.5) * (self.wind['n'] - self.wind['s']) / self.wind['rows']
-        self.status['value'] = self.values[row][col]
-        if self.angles:
-            self.status['aspect'] = self.angles[row][col]
+	self.status['row'] = row
+	self.status['col'] = col
+	self.status['x'] = self.wind['e'] + (col + 0.5) * (self.wind['e'] - self.wind['w']) / self.wind['cols']
+	self.status['y'] = self.wind['n'] - (row + 0.5) * (self.wind['n'] - self.wind['s']) / self.wind['rows']
+	self.status['value'] = self.values[row][col]
+	if self.angles:
+	    self.status['aspect'] = self.angles[row][col]
     def force_color(val):
-        run('g.region', rows=1, cols=1)
-        run('r.mapcalc', expression="%s = %d" % (self.tempmap, val))
-        run('r.colors', map=self.tempmap, rast=self.inmap)
-        run('r.out.ppm', input=self.tempmap, out=self.tempfile)
+	run('g.region', rows = 1, cols = 1)
+	run('r.mapcalc', expression = "%s = %d" % (self.tempmap, val))
+	run('r.colors', map = self.tempmap, rast = self.inmap)
+	run('r.out.ppm', input = self.tempmap, out = self.tempfile)
-        tempimg = wx.Image(self.tempfile)
+	tempimg = wx.Image(self.tempfile)
-        rgb = tempimg.get(0, 0)
-        color = "#%02x%02x%02x" % rgb
-        tempimg.delete()
+	rgb = tempimg.get(0, 0)
+	color = "#%02x%02x%02x" % rgb
+	tempimg.delete()
     def get_color(self, val):
-        if val not in self.colors:
-            try:
-                self.force_color(val)
-            except:
-                self.colors[val] = "#ffffff"
+	if val not in self.colors:
+	    try:
+		self.force_color(val)
+	    except:
+		self.colors[val] = "#ffffff"
-        return self.colors[val]
+	return self.colors[val]
     def refresh_canvas(self):
-        self.frame.canvas.Refresh()
+	self.frame.canvas.Refresh()
     def make_ui(self):
-        self.frame = MainWindow(self)
-        self.SetTopWindow(self.frame)
-        self.frame.Show()
-        self.overview = OverviewWindow(self)
-        self.overview.Show()
+	self.frame = MainWindow(self)
+	self.SetTopWindow(self.frame)
+	self.frame.Show()
+	self.overview = OverviewWindow(self)
+	self.overview.Show()
     def OnInit(self):
-        self.outmap = self.options['output']
-        self.inmap = self.options['input']
-        self.aspect = self.options['aspect']
-        self.width = int(self.options['width'])
-        self.height = int(self.options['height'])
-        self.size = int(self.options['size'])
-        self.rows = int(self.options['rows'])
-        self.cols = int(self.options['cols'])
+	self.outmap = self.options['output']
+	self.inmap  = self.options['input']
+	self.aspect = self.options['aspect']
+	self.width  = int(self.options['width'])
+	self.height = int(self.options['height'])
+	self.size   = int(self.options['size'])
+	self.rows   = int(self.options['rows'])
+	self.cols   = int(self.options['cols'])
-        self.status = {
-            'row': '',
-            'col': '',
-            'x': '',
-            'y': '',
-            'value': '',
-            'aspect': ''
+	self.status = {
+	    'row': '',
+	    'col': '',
+	    'x': '',
+	    'y': '',
+	    'value': '',
+	    'aspect': ''
-        self.values = None
-        self.changed = None
-        self.angles = None
-        self.colors = {}
-        self.brush = '*'
-        self.origin_x = 0
-        self.origin_y = 0
-        self.wind = {}
-        self.total = {}
+	self.values = None
+	self.changed = None
+	self.angles = None
+	self.colors = {}
+	self.brush = '*'
+	self.origin_x = 0
+	self.origin_y = 0
+	self.wind = {}
+	self.total = {}
-        self.initialize()
-        self.make_ui()
-        self.load_map()
+	self.initialize()
+	self.make_ui()
+	self.load_map()
-        return True
+	return True
Modified: grass/trunk/scripts/d.rast.leg/d.rast.leg.py
--- grass/trunk/scripts/d.rast.leg/d.rast.leg.py	2016-03-29 06:29:14 UTC (rev 68180)
+++ grass/trunk/scripts/d.rast.leg/d.rast.leg.py	2016-03-29 08:10:14 UTC (rev 68181)
@@ -125,10 +125,8 @@
     ncats = len(cats.strip().split('\n'))
     # Only need to adjust legend size if number of categories is between 1 and 10
-    if ncats < 2:
-        ncats = 2
-    if ncats > 10:
-        ncats = 10
+    if ncats < 2: ncats = 2
+    if ncats > 10: ncats = 10
     VSpacing = (100 - (ncats * 10) + 10)
Modified: grass/trunk/scripts/d.redraw/d.redraw.py
--- grass/trunk/scripts/d.redraw/d.redraw.py	2016-03-29 06:29:14 UTC (rev 68180)
+++ grass/trunk/scripts/d.redraw/d.redraw.py	2016-03-29 08:10:14 UTC (rev 68181)
@@ -26,7 +26,6 @@
 from grass.script.utils import split
 def main():
     mon = grass.gisenv().get('MONITOR', None)
     if not mon:
@@ -39,25 +38,25 @@
     try:
         fd = open(monCmd, 'r')
         cmdList = fd.readlines()
         grass.run_command('d.erase')
         for cmd in cmdList:
             grass.call(split(cmd))
     except IOError as e:
-        grass.fatal(_("Unable to open file '%s' for reading. Details: %s") %
-                    (monCmd, e))
+        grass.fatal(_("Unable to open file '%s' for reading. Details: %s") % \
+                        (monCmd, e))
     fd.close()
     # restore cmd file
     try:
         fd = open(monCmd, "w")
         fd.writelines(cmdList)
-        grass.fatal(_("Unable to open file '%s' for writing. Details: %s") %
-                    (monCmd, e))
+        grass.fatal(_("Unable to open file '%s' for writing. Details: %s") % \
+                        (monCmd, e))
     return 0
Modified: grass/trunk/scripts/db.dropcolumn/db.dropcolumn.py
--- grass/trunk/scripts/db.dropcolumn/db.dropcolumn.py	2016-03-29 06:29:14 UTC (rev 68180)
+++ grass/trunk/scripts/db.dropcolumn/db.dropcolumn.py	2016-03-29 08:10:14 UTC (rev 68181)
@@ -5,7 +5,7 @@
 # MODULE:       db.dropcolumn
 # AUTHOR(S):   	Markus Neteler
 #               Converted to Python by Glynn Clements
-# PURPOSE:      Interface to db.execute to drop a column from an
+# PURPOSE:      Interface to db.execute to drop a column from an
 #               attribute table
 #               - with special trick for SQLite
 # COPYRIGHT:    (C) 2007, 2012 by Markus Neteler and the GRASS Development Team
@@ -36,10 +36,10 @@
 #%end
 import sys
+import os
 import string
+import grass.script as grass
 from grass.exceptions import CalledModuleError
-import grass.script as gscript
 def main():
@@ -48,67 +48,66 @@
     force = flags['f']
     # check if DB parameters are set, and if not set them.
-    gscript.run_command('db.connect', flags='c')
+    grass.run_command('db.connect', flags = 'c')
-    kv = gscript.db_connection()
+    kv = grass.db_connection()
     database = kv['database']
     driver = kv['driver']
     # schema needed for PG?
     if force:
-        gscript.message(_("Forcing ..."))
+	grass.message(_("Forcing ..."))
     if column == "cat":
-        gscript.warning(_("Deleting <%s> column which may be needed to keep "
-                          "table connected to a vector map") % column)
+	grass.warning(_("Deleting <%s> column which may be needed to keep table connected to a vector map") % column)
-    cols = [f[0] for f in gscript.db_describe(table)['cols']]
+    cols = [f[0] for f in grass.db_describe(table)['cols']]
     if column not in cols:
-        gscript.fatal(_("Column <%s> not found in table") % column)
+	grass.fatal(_("Column <%s> not found in table") % column)
     if not force:
-        gscript.message(_("Column <%s> would be deleted.") % column)
-        gscript.message("")
-        gscript.message(_("You must use the force flag (-f) to actually "
-                          "remove it. Exiting."))
-        return 0
+	grass.message(_("Column <%s> would be deleted.") % column)
+	grass.message("")
+	grass.message(_("You must use the force flag (-f) to actually remove it. Exiting."))
+	return 0
     if driver == "sqlite":
-        # echo "Using special trick for SQLite"
-        # http://www.sqlite.org/faq.html#q13
-        colnames = []
-        coltypes = []
-        for f in gscript.db_describe(table)['cols']:
-            if f[0] != column:
-                colnames.append(f[0])
-                coltypes.append("%s %s" % (f[0], f[1]))
+	#echo "Using special trick for SQLite"
+	# http://www.sqlite.org/faq.html#q13
+	colnames = []
+	coltypes = []
+	for f in grass.db_describe(table)['cols']:
+	    if f[0] == column:
+		continue
+	    colnames.append(f[0])
+	    coltypes.append("%s %s" % (f[0], f[1]))
-        colnames = ", ".join(colnames)
-        coltypes = ", ".join(coltypes)
+	colnames = ", ".join(colnames)
+	coltypes = ", ".join(coltypes)
-        cmds = [
-            "BEGIN TRANSACTION",
-            "CREATE TEMPORARY TABLE ${table}_backup(${coldef})",
-            "INSERT INTO ${table}_backup SELECT ${colnames} FROM ${table}",
-            "DROP TABLE ${table}",
-            "CREATE TABLE ${table}(${coldef})",
-            "INSERT INTO ${table} SELECT ${colnames} FROM ${table}_backup",
-            "DROP TABLE ${table}_backup",
-            "COMMIT"
-        tmpl = string.Template(';\n'.join(cmds))
-        sql = tmpl.substitute(table=table, coldef=coltypes, colnames=colnames)
+	cmds = [
+	    "BEGIN TRANSACTION",
+	    "CREATE TEMPORARY TABLE ${table}_backup(${coldef})",
+	    "INSERT INTO ${table}_backup SELECT ${colnames} FROM ${table}",
+	    "DROP TABLE ${table}",
+	    "CREATE TABLE ${table}(${coldef})",
+	    "INSERT INTO ${table} SELECT ${colnames} FROM ${table}_backup",
+	    "DROP TABLE ${table}_backup",
+	    "COMMIT"
+	tmpl = string.Template(';\n'.join(cmds))
+	sql = tmpl.substitute(table = table, coldef = coltypes, colnames = colnames)
     else:
-        sql = "ALTER TABLE %s DROP COLUMN %s" % (table, column)
+	sql = "ALTER TABLE %s DROP COLUMN %s" % (table, column)
     try:
-        gscript.write_command('db.execute', input='-', database=database,
-                              driver=driver, stdin=sql)
+        grass.write_command('db.execute', input = '-', database = database,
+                               driver = driver, stdin = sql)
     except CalledModuleError:
-        gscript.fatal(_("Cannot continue (problem deleting column)"))
+        grass.fatal(_("Cannot continue (problem deleting column)"))
     return 0
-    options, flags = gscript.parser()
     sys.exit(main())
Modified: grass/trunk/scripts/db.in.ogr/db.in.ogr.py
--- grass/trunk/scripts/db.in.ogr/db.in.ogr.py	2016-03-29 06:29:14 UTC (rev 68180)
+++ grass/trunk/scripts/db.in.ogr/db.in.ogr.py	2016-03-29 08:10:14 UTC (rev 68181)
@@ -72,76 +72,74 @@
     mapset = grass.gisenv()['MAPSET']
     if db_table:
-        input = db_table
+	input = db_table
     if not output:
-        tmpname = input.replace('.', '_')
-        output = grass.basename(tmpname)
+	tmpname = input.replace('.', '_')
+	output = grass.basename(tmpname)
     # check if table exists
     try:
         nuldev = file(os.devnull, 'w+')
-        s = grass.read_command('db.tables', flags='p', quiet=True, stderr=nuldev)
+        s = grass.read_command('db.tables', flags = 'p', quiet=True, stderr=nuldev)
         nuldev.close()
         # check connection parameters, set if uninitialized
         grass.read_command('db.connect', flags='c')
-        s = grass.read_command('db.tables', flags='p', quiet=True)
+        s = grass.read_command('db.tables', flags = 'p', quiet=True)
     for l in s.splitlines():
         if l == output:
             if grass.overwrite():
-                grass.warning(_("Table <%s> already exists and will be "
-                                "overwritten") % output)
-                grass.write_command('db.execute', input='-',
-                                    stdin="DROP TABLE %s" % output)
+                grass.warning(_("Table <%s> already exists and will be overwritten") % output)
+                grass.write_command('db.execute', input = '-', stdin = "DROP TABLE %s" % output)
                 break
             else:
                 grass.fatal(_("Table <%s> already exists") % output)
     # treat DB as real vector map...
-    layer = db_table if db_table else None
+    if db_table:
+	layer = db_table
+    else:
+	layer = None
     vopts = {}
     if options['encoding']:
         vopts['encoding'] = options['encoding']
     try:
         grass.run_command('v.in.ogr', flags='o', input=input, output=output,
                           layer=layer, quiet=True, **vopts)
         if db_table:
-            grass.fatal(
-                _("Input table <%s> not found or not readable") %
-                input)
+            grass.fatal(_("Input table <%s> not found or not readable") % input)
         else:
             grass.fatal(_("Input DSN <%s> not found or not readable") % input)
     # rename ID col if requested from cat to new name
     if key:
-        grass.write_command('db.execute', quiet=True, input='-',
-                            stdin="ALTER TABLE %s ADD COLUMN %s integer" %
-                                  (output, key))
-                            stdin="UPDATE %s SET %s=cat" % (output, key))
+	grass.write_command('db.execute', quiet = True,
+                          input = '-',
+			  stdin = "ALTER TABLE %s ADD COLUMN %s integer" % (output, key) )
+                          input = '-',
+			  stdin = "UPDATE %s SET %s=cat" % (output, key) )
     # ... and immediately drop the empty geometry
-    vectfile = grass.find_file(output, element='vector', mapset=mapset)['file']
+    vectfile = grass.find_file(output, element = 'vector', mapset = mapset)['file']
     if not vectfile:
-        grass.fatal(_("Something went wrong. Should not happen"))
+	grass.fatal(_("Something went wrong. Should not happen"))
     else:
-        # remove the vector part
-        grass.run_command('v.db.connect', quiet=True, map=output, layer='1',
-                          flags='d')
-        grass.run_command('g.remove', flags='f', quiet=True, type='vector',
-                          name=output)
+	# remove the vector part
+	grass.run_command('v.db.connect', quiet = True, map = output, layer = '1', flags = 'd')
+	grass.run_command('g.remove', flags = 'f', quiet = True, type = 'vector', name = output)
     # get rid of superfluous auto-added cat column (and cat_ if present)
-    grass.run_command('db.dropcolumn', quiet=True, flags='f', table=output,
-                      column='cat', stdout=nuldev, stderr=nuldev)
+    grass.run_command('db.dropcolumn', quiet = True, flags = 'f', table = output,
+		      column = 'cat', stdout = nuldev, stderr = nuldev)
     nuldev.close()
     records = grass.db_describe(output)['nrows']
     grass.message(_("Imported table <%s> with %d rows") % (output, records))
Modified: grass/trunk/scripts/db.out.ogr/db.out.ogr.py
--- grass/trunk/scripts/db.out.ogr/db.out.ogr.py	2016-03-29 06:29:14 UTC (rev 68180)
+++ grass/trunk/scripts/db.out.ogr/db.out.ogr.py	2016-03-29 08:10:14 UTC (rev 68181)
@@ -54,10 +54,10 @@
 #% required: no
 #%end
+import sys
 import os
@@ -69,52 +69,54 @@
     table = options['table']
     if format.lower() == 'dbf':
-        format = "ESRI_Shapefile"
+	format = "ESRI_Shapefile"
     if format.lower() == 'csv':
-        olayer = basename(output, 'csv')
+	olayer = basename(output, 'csv')
     else:
-        olayer = None
+	olayer = None
-    # is there a simpler way of testing for --overwrite?
+    #is there a simpler way of testing for --overwrite?
     dbffile = input + '.dbf'
-    if os.path.exists(dbffile) and not gcore.overwrite():
-        gcore.fatal(_("File <%s> already exists") % dbffile)
+    if os.path.exists(dbffile) and not grass.overwrite():
+	grass.fatal(_("File <%s> already exists") % dbffile)
     if olayer:
         try:
-            gcore.run_command('v.out.ogr', quiet=True, input=input,
-                              layer=layer, output=output, format=format,
-                              type='point,line,area', olayer=olayer)
+            grass.run_command('v.out.ogr', quiet=True, input=input, layer=layer,
+                              output=output,
+                              format=format, type='point,line,area',
+                              olayer=olayer)
-            gcore.fatal(_("Module <%s> failed") % 'v.out.ogr')
+            grass.fatal(_("Module <%s> failed") % 'v.out.ogr')
     else:
         try:
                               format=format, type='point,line,area')
     if format == "ESRI_Shapefile":
-        exts = ['shp', 'shx', 'prj']
-        if output.endswith('.dbf'):
-            outname = basename(output, 'dbf')
-            for ext in exts:
-                try_remove("%s.%s" % (outname, ext))
-            outname += '.dbf'
-        else:
-            for ext in exts:
-                try_remove(os.path.join(output, "%s.%s" % (input, ext)))
-            outname = os.path.join(output, input + ".dbf")
+	exts = ['shp', 'shx', 'prj']
+	if output.endswith('.dbf'):
+	    outname = basename(output, 'dbf')
+	    for ext in exts:
+		try_remove("%s.%s" % (outname, ext))
+	    outname += '.dbf'
+	else:
+	    for ext in exts:
+		try_remove(os.path.join(output, "%s.%s" % (input, ext)))
+	    outname = os.path.join(output, input + ".dbf")
     elif format.lower() == 'csv':
-        outname = output + '.csv'
+	outname = output + '.csv'
     else:
-        outname = input
+	outname = input
-    gcore.message(_("Exported table <%s>") % outname)
+    grass.message(_("Exported table <%s>") % outname)
     main()
Modified: grass/trunk/scripts/db.test/db.test.py
--- grass/trunk/scripts/db.test/db.test.py	2016-03-29 06:29:14 UTC (rev 68180)
+++ grass/trunk/scripts/db.test/db.test.py	2016-03-29 08:10:14 UTC (rev 68181)
@@ -28,62 +28,61 @@
 import sys
 import os
 from grass.script import db as grassdb
 def main():
     test_file = options['test']
-    expected = gcore.tempfile()
-    result = gcore.tempfile()
+    expected = grass.tempfile()
+    result = grass.tempfile()
     dbconn = grassdb.db_connection()
-    gcore.message(_("Using DB driver: %s") % dbconn['driver'])
+    grass.message(_("Using DB driver: %s") % dbconn['driver'])
     infile = os.path.join(os.environ['GISBASE'], 'etc', 'db.test', test_file)
     inf = file(infile)
     while True:
-        type = inf.readline()
-        if not type:
-            break
-        type = type.rstrip('\r\n')
+	type = inf.readline()
+	if not type:
+	    break
+	type = type.rstrip('\r\n')
-        sql = inf.readline().rstrip('\r\n')
-        sys.stdout.write(sql + '\n')
+	sql = inf.readline().rstrip('\r\n')
+	sys.stdout.write(sql + '\n')
-        # Copy expected result to temp file
+	# Copy expected result to temp file
         try:
             if type == 'X':
-                gcore.write_command('db.execute', input='-', stdin=sql + '\n')
+                grass.write_command('db.execute', input = '-', stdin = sql + '\n')
             else:
                 resf = file(result, 'w')
-                gcore.write_command('db.select', input='-', flags='c',
-                                    stdin=sql + '\n', stdout=resf)
+                grass.write_command('db.select', input = '-', flags = 'c', stdin = sql + '\n', stdout = resf)
                 resf.close()
-            gcore.error("EXECUTE: ******** ERROR ********")
+            grass.error("EXECUTE: ******** ERROR ********")
         else:
-            gcore.message(_("EXECUTE: OK"))
+            grass.message(_("EXECUTE: OK"))
-        expf = file(expected, 'w')
-        while True:
-            res = inf.readline().rstrip('\r\n')
-            if not res:
-                break
-            expf.write(res + '\n')
-        expf.close()
+	expf = file(expected, 'w')
+	while True:
+	    res = inf.readline().rstrip('\r\n')
+	    if not res:
+		break
+	    expf.write(res + '\n')
+	expf.close()
-        if type == 'S':
-            if gcore.call(['diff', result, expected]) != 0:
-                gcore.error("RESULT: ******** ERROR ********")
-            else:
-                gcore.message(_("RESULT: OK"))
+	if type == 'S':
+	    if grass.call(['diff', result, expected]) != 0:
+		grass.error("RESULT: ******** ERROR ********")
+	    else:
+		grass.message(_("RESULT: OK"))
     main()
Modified: grass/trunk/scripts/db.univar/db.univar.py
--- grass/trunk/scripts/db.univar/db.univar.py	2016-03-29 06:29:14 UTC (rev 68180)
+++ grass/trunk/scripts/db.univar/db.univar.py	2016-03-29 08:10:14 UTC (rev 68181)
@@ -56,26 +56,25 @@
 #%end
 import sys
+import os
 import atexit
 import math
 def cleanup():
     for ext in ['', '.sort']:
-        gscript.try_remove(tmp + ext)
+        grass.try_remove(tmp + ext)
 def sortfile(infile, outfile):
     inf = file(infile, 'r')
     outf = file(outfile, 'w')
-    if gscript.find_program('sort', '--help'):
-        gscript.run_command('sort', flags='n', stdin=inf, stdout=outf)
+    if grass.find_program('sort', '--help'):
+        grass.run_command('sort', flags = 'n', stdin = inf, stdout = outf)
     else:
         # FIXME: we need a large-file sorting function
-        gscript.warning(_("'sort' not found: sorting in memory"))
+        grass.warning(_("'sort' not found: sorting in memory"))
         lines = inf.readlines()
         for i in range(len(lines)):
             lines[i] = float(lines[i].rstrip('\r\n'))
@@ -86,10 +85,9 @@
     inf.close()
     outf.close()
 def main():
     global tmp
-    tmp = gscript.tempfile()
     extend = flags['e']
     shellstyle = flags['g']
@@ -102,22 +100,21 @@
     perc = [float(p) for p in perc.split(',')]
-    desc_table = gscript.db_describe(table, database=database, driver=driver)
+    desc_table = grass.db_describe(table, database=database, driver=driver)
     if not desc_table:
-        gscript.fatal(_("Unable to describe table <%s>") % table)
+        grass.fatal(_("Unable to describe table <%s>") % table)
     found = False
     for cname, ctype, cwidth in desc_table['cols']:
         if cname == column:
             found = True
             if ctype not in ('INTEGER', 'DOUBLE PRECISION'):
-                gscript.fatal(_("Column <%s> is not numeric") % cname)
+                grass.fatal(_("Column <%s> is not numeric") % cname)
     if not found:
-        gscript.fatal(_("Column <%s> not found in table <%s>") % (column, table))
+        grass.fatal(_("Column <%s> not found in table <%s>") % (column, table))
     if not shellstyle:
-        gscript.verbose(_("Calculation for column <%s> of table <%s>..."
-                          ) % (column, table))
-        gscript.message(_("Reading column values..."))
+        grass.verbose(_("Calculation for column <%s> of table <%s>...") % (column, table))
+        grass.message(_("Reading column values..."))
     sql = "SELECT %s FROM %s" % (column, table)
     if where:
@@ -130,20 +127,20 @@
         driver = None
     tmpf = file(tmp, 'w')
-    gscript.run_command('db.select', flags='c', table=table,
-                        database=database, driver=driver, sql=sql,
-                        stdout=tmpf)
+    grass.run_command('db.select', flags = 'c', table = table,
+        database = database, driver = driver, sql = sql,
+        stdout = tmpf)
     tmpf.close()
     # check if result is empty
     tmpf = file(tmp)
     if tmpf.read(1) == '':
-        gscript.fatal(_("Table <%s> contains no data.") % table)
+        grass.fatal(_("Table <%s> contains no data.") % table)
         tmpf.close()
     # calculate statistics
     if not shellstyle:
-        gscript.verbose(_("Calculating statistics..."))
+        grass.verbose(_("Calculating statistics..."))
     N = 0
     sum = 0.0
@@ -154,8 +151,8 @@
     tmpf = file(tmp)
     for line in tmpf:
-        if len(line.rstrip('\r\n')) == 0:
-            continue
+	if len(line.rstrip('\r\n')) == 0:
+	    continue
         x = float(line.rstrip('\r\n'))
         N += 1
         sum += x
@@ -166,43 +163,30 @@
     tmpf.close()
     if N <= 0:
-        gscript.fatal(_("No non-null values found"))
+        grass.fatal(_("No non-null values found"))
     if not shellstyle:
-        sys.stdout.write("Number of values: %d\n" % N)
-        sys.stdout.write("Minimum: %.15g\n" % minv)
-        sys.stdout.write("Maximum: %.15g\n" % maxv)
-        sys.stdout.write("Range: %.15g\n" % (maxv - minv))
-        sys.stdout.write("Mean: %.15g\n" % (sum / N))
-        sys.stdout.write(
-            "Arithmetic mean of absolute values: %.15g\n" %
-            (sum3 / N))
-        sys.stdout.write("Variance: %.15g\n" % ((sum2 - sum * sum / N) / N))
-        sys.stdout.write(
-            "Standard deviation: %.15g\n" %
-            (math.sqrt((sum2 - sum * sum / N) / N)))
-        sys.stdout.write(
-            "Coefficient of variation: %.15g\n" %
-            ((math.sqrt((sum2 - sum * sum / N) / N)) /
-             (math.sqrt(sum * sum) / N)))
-        sys.stdout.write("Sum: %.15g\n" % sum)
+        sys.stdout.write("Number of values: %d\n"% N)
+        sys.stdout.write("Minimum: %.15g\n"% minv)
+        sys.stdout.write("Maximum: %.15g\n"% maxv)
+        sys.stdout.write("Range: %.15g\n"% (maxv - minv))
+        sys.stdout.write("Mean: %.15g\n"% (sum/N))
+        sys.stdout.write("Arithmetic mean of absolute values: %.15g\n"% (sum3/N))
+        sys.stdout.write("Variance: %.15g\n"% ((sum2 - sum*sum/N)/N))
+        sys.stdout.write("Standard deviation: %.15g\n"% (math.sqrt((sum2 - sum*sum/N)/N)))
+        sys.stdout.write("Coefficient of variation: %.15g\n"% ((math.sqrt((sum2 - sum*sum/N)/N))/(math.sqrt(sum*sum)/N)))
+        sys.stdout.write("Sum: %.15g\n"% sum)
     else:
-        sys.stdout.write("n=%d\n" % N)
-        sys.stdout.write("min=%.15g\n" % minv)
-        sys.stdout.write("max=%.15g\n" % maxv)
-        sys.stdout.write("range=%.15g\n" % (maxv - minv))
-        sys.stdout.write("mean=%.15g\n" % (sum / N))
-        sys.stdout.write("mean_abs=%.15g\n" % (sum3 / N))
-        sys.stdout.write("variance=%.15g\n" % ((sum2 - sum * sum / N) / N))
-        sys.stdout.write(
-            "stddev=%.15g\n" %
-            (math.sqrt(
-                (sum2 - sum * sum / N) / N)))
-        sys.stdout.write(
-            "coeff_var=%.15g\n" %
-        sys.stdout.write("sum=%.15g\n" % sum)
+        sys.stdout.write("n=%d\n"% N)
+        sys.stdout.write("min=%.15g\n"% minv)
+        sys.stdout.write("max=%.15g\n"% maxv)
+        sys.stdout.write("range=%.15g\n"% (maxv - minv))
+        sys.stdout.write("mean=%.15g\n"% (sum/N))
+        sys.stdout.write("mean_abs=%.15g\n"% (sum3/N))
+        sys.stdout.write("variance=%.15g\n"% ((sum2 - sum*sum/N)/N))
+        sys.stdout.write("stddev=%.15g\n"% (math.sqrt((sum2 - sum*sum/N)/N)))
+        sys.stdout.write("coeff_var=%.15g\n"% ((math.sqrt((sum2 - sum*sum/N)/N))/(math.sqrt(sum*sum)/N)))
+        sys.stdout.write("sum=%.15g\n"% sum)
     if not extend:
         return
@@ -210,26 +194,27 @@
     # preparations:
     sortfile(tmp, tmp + ".sort")
+    number = N
     odd = N % 2
-    eostr = ['even', 'odd'][odd]
+    eostr = ['even','odd'][odd]
     q25pos = round(N * 0.25)
     if q25pos == 0:
-        q25pos = 1
+	q25pos = 1
     q50apos = round(N * 0.50)
     if q50apos == 0:
-        q50apos = 1
+	q50apos = 1
     q50bpos = q50apos + (1 - odd)
     q75pos = round(N * 0.75)
     if q75pos == 0:
-        q75pos = 1
+	q75pos = 1
     ppos = {}
     pval = {}
     for i in range(len(perc)):
         ppos[i] = round(N * perc[i] / 100)
-        if ppos[i] == 0:
-            ppos[i] = 1
+	if ppos[i] == 0:
+	    ppos[i] = 1
         pval[i] = 0
     inf = file(tmp + ".sort")
@@ -255,45 +240,27 @@
         sys.stdout.write("Median (%s N): %.15g\n" % (eostr, q50))
         sys.stdout.write("3rd Quartile: %.15g\n" % q75)
-            if perc[i] == int(perc[i]):  # integer
+            if perc[i] == int(perc[i]): # integer
                 if int(perc[i]) % 10 == 1 and int(perc[i]) != 11:
-                    sys.stdout.write(
-                        "%dst Percentile: %.15g\n" %
-                        (int(
-                            perc[i]),
-                            pval[i]))
+                    sys.stdout.write("%dst Percentile: %.15g\n"% (int(perc[i]), pval[i]))
                 elif int(perc[i]) % 10 == 2 and int(perc[i]) != 12:
-                    sys.stdout.write(
-                        "%dnd Percentile: %.15g\n" %
-                        (int(
-                            perc[i]),
-                            pval[i]))
+                    sys.stdout.write("%dnd Percentile: %.15g\n"% (int(perc[i]), pval[i]))
                 elif int(perc[i]) % 10 == 3 and int(perc[i]) != 13:
-                    sys.stdout.write(
-                        "%drd Percentile: %.15g\n" %
-                        (int(
-                            perc[i]),
-                            pval[i]))
+                    sys.stdout.write("%drd Percentile: %.15g\n"% (int(perc[i]), pval[i]))
                 else:
-                    sys.stdout.write(
-                        "%dth Percentile: %.15g\n" %
-                        (int(
-                            perc[i]),
-                            pval[i]))
+                    sys.stdout.write("%dth Percentile: %.15g\n"% (int(perc[i]), pval[i]))
             else:
-                sys.stdout.write(
-                    "%.15g Percentile: %.15g\n" %
-                    (perc[i], pval[i]))
+                sys.stdout.write("%.15g Percentile: %.15g\n"% (perc[i], pval[i]))
     else:
-        sys.stdout.write("first_quartile=%.15g\n" % q25)
-        sys.stdout.write("median=%.15g\n" % q50)
-        sys.stdout.write("third_quartile=%.15g\n" % q75)
+        sys.stdout.write("first_quartile=%.15g\n"% q25)
+        sys.stdout.write("median=%.15g\n"% q50)
+        sys.stdout.write("third_quartile=%.15g\n"% q75)
             percstr = "%.15g" % perc[i]
-            percstr = percstr.replace('.', '_')
-            sys.stdout.write("percentile_%s=%.15g\n" % (percstr, pval[i]))
+            percstr = percstr.replace('.','_')
+            sys.stdout.write("percentile_%s=%.15g\n"% (percstr, pval[i]))
 if __name__ == "__main__":
+    options, flags = grass.parser()
     main()
Modified: grass/trunk/scripts/g.extension/g.extension.py
--- grass/trunk/scripts/g.extension/g.extension.py	2016-03-29 06:29:14 UTC (rev 68180)
+++ grass/trunk/scripts/g.extension/g.extension.py	2016-03-29 08:10:14 UTC (rev 68181)
@@ -314,7 +314,7 @@
         else:
             ret.append(tnode.get('name').strip())
     return ret
 # list extensions (read XML file from grass.osgeo.org/addons)
@@ -392,7 +392,6 @@
     return tlist
 def get_module_files(mnode):
     """Return list of module files
@@ -405,7 +404,6 @@
     return flist
 def get_module_executables(mnode):
     """Return list of module executables
@@ -414,16 +412,15 @@
     flist = []
     for filepath in get_module_files(mnode):
         if filepath.startswith(options['prefix'] + os.path.sep + 'bin') or \
-           (sys.platform != 'win32' and
-                filepath.startswith(options['prefix'] + os.path.sep + 'scripts')):
+           (sys.platform != 'win32' and \
+            filepath.startswith(options['prefix'] + os.path.sep + 'scripts')):
             filename = os.path.basename(filepath)
             if sys.platform == 'win32':
                 filename = os.path.splitext(filename)[0]
             flist.append(filename)
     return flist
 def get_optional_params(mnode):
     """Return description and keywords as a tuple
@@ -924,7 +921,7 @@
     """Install extension on MS Windows"""
     grass.message(_("Downloading precompiled GRASS Addons <%s>...") %
                   options['extension'])
     # build base URL
     if build_platform == 'x86_64':
         platform = build_platform
@@ -933,29 +930,29 @@
     base_url = "http://wingrass.fsv.cvut.cz/" \
                "grass%(major)s%(minor)s/%(platform)s/addons/" \
                "grass-%(major)s.%(minor)s.%(patch)s" % \
-               {'platform': platform,
+               {'platform' : platform,
                 'major': version[0], 'minor': version[1],
                 'patch': version[2]}
     # resolve ZIP URL
     source, url = resolve_source_code(url='{}/{}.zip'.format(base_url, name))
     # to hide non-error messages from subprocesses
     if grass.verbosity() <= 2:
         outdev = open(os.devnull, 'w')
     else:
         outdev = sys.stdout
     # download Addons ZIP file
     os.chdir(TMPDIR)  # this is just to not leave something behind
     srcdir = os.path.join(TMPDIR, name)
     download_source_code(source=source, url=url, name=name,
-                         outdev=outdev, directory=srcdir, tmpdir=TMPDIR)
+                        outdev=outdev, directory=srcdir, tmpdir=TMPDIR)
     # copy Addons copy tree to destination directory
     move_extracted_files(extract_dir=srcdir, target_dir=options['prefix'],
                          files=os.listdir(srcdir))
     return 0
@@ -1094,7 +1091,7 @@
         f, h = urlretrieve(url, zip_name)
         if h.get('content-type', '') != 'application/zip':
             grass.fatal(_("Extension <%s> not found") % name)
         extract_zip(name=zip_name, directory=directory, tmpdir=tmpdir)
         fix_newlines(directory)
     elif source.startswith('remote_') and \
@@ -1722,9 +1719,9 @@
     global TMPDIR
     TMPDIR = tempfile.mkdtemp()
     grass_version = grass.version()
     version = grass_version['version'].split('.')
     build_platform = grass_version['build_platform'].split('-', 1)[0]
     sys.exit(main())
Modified: grass/trunk/scripts/g.extension/testsuite/test_addons_modules.py
--- grass/trunk/scripts/g.extension/testsuite/test_addons_modules.py	2016-03-29 06:29:14 UTC (rev 68180)
+++ grass/trunk/scripts/g.extension/testsuite/test_addons_modules.py	2016-03-29 08:10:14 UTC (rev 68181)
@@ -99,7 +99,7 @@
         """Test installing extension from local .tar.gz"""
         self.assertModule('g.extension', extension='r.plus.example',
                           url=os.path.join(self.path,
-                                           'r.plus.example.tar.gz'),
+                                              'r.plus.example.tar.gz'),
                           prefix=self.install_prefix)
         for file in self.files:
             self.assertFileExists(file)
Modified: grass/trunk/scripts/g.extension.all/g.extension.all.py
--- grass/trunk/scripts/g.extension.all/g.extension.all.py	2016-03-29 06:29:14 UTC (rev 68180)
+++ grass/trunk/scripts/g.extension.all/g.extension.all.py	2016-03-29 08:10:14 UTC (rev 68181)
@@ -6,7 +6,7 @@
 # AUTHOR(S):    Martin Landa <landa.martin gmail.com>
-# PURPOSE:      Rebuilds or removes locally installed GRASS Addons extensions
+# PURPOSE:      Rebuilds or removes locally installed GRASS Addons extensions
 # COPYRIGHT:    (C) 2011-2013 by Martin Landa, and the GRASS Development Team
@@ -35,23 +35,23 @@
 #% key: f
 #% label: Force operation (required for removal)
 #% end
-from __future__ import print_function
 import os
 import sys
 try:
     import xml.etree.ElementTree as etree
 except ImportError:
-    import elementtree.ElementTree as etree  # Python <= 2.4
+    import elementtree.ElementTree as etree # Python <= 2.4
 def get_extensions():
     addon_base = os.getenv('GRASS_ADDON_BASE')
     if not addon_base:
-        gscript.fatal(_("%s not defined") % "GRASS_ADDON_BASE")
+        grass.fatal(_("%s not defined") % "GRASS_ADDON_BASE")
     fXML = os.path.join(addon_base, 'modules.xml')
     if not os.path.exists(fXML):
         return []
@@ -60,56 +60,51 @@
     fo = open(fXML, 'r')
     try:
         tree = etree.fromstring(fo.read())
-    except Exception as e:
-        gscript.error(_("Unable to parse metadata file: %s") % e)
+    except StandardError as e:
+        grass.error(_("Unable to parse metadata file: %s") % e)
         fo.close()
         return []
     fo.close()
-    libgis_rev = gscript.version()['libgis_revision']
+    libgis_rev = grass.version()['libgis_revision']
     ret = list()
     for tnode in tree.findall('task'):
         gnode = tnode.find('libgis')
         if gnode is not None and \
                 gnode.get('revision', '') != libgis_rev:
             ret.append(tnode.get('name'))
     return ret
 def main():
     remove = options['operation'] == 'remove'
     if remove or flags['f']:
-        extensions = gscript.read_command(
-            'g.extension',
-            quiet=True,
-            flags='a').splitlines()
+        extensions = grass.read_command('g.extension',
+                                        quiet = True, flags = 'a').splitlines()
     else:
         extensions = get_extensions()
     if not extensions:
         if remove:
-            gscript.info(_("No extension found. Nothing to remove."))
+            grass.info(_("No extension found. Nothing to remove."))
         else:
-            gscript.info(
-                _("Nothing to rebuild. Rebuilding process can be forced with -f flag."))
+            grass.info(_("Nothing to rebuild. Rebuilding process can be forced with -f flag."))
         return 0
     if remove and not flags['f']:
-        gscript.message(_("List of extensions to be removed:"))
-        print(os.linesep.join(extensions))
-        gscript.message(
-            _("You must use the force flag (-f) to actually remove them. Exiting."))
+        grass.message(_("List of extensions to be removed:"))
+        print os.linesep.join(extensions)
+        grass.message(_("You must use the force flag (-f) to actually remove them. Exiting."))
         return 0
     for ext in extensions:
-        gscript.message('-' * 60)
+        grass.message('-' * 60)
         if remove:
-            gscript.message(_("Removing extension <%s>...") % ext)
+            grass.message(_("Removing extension <%s>...") % ext)
         else:
-            gscript.message(_("Reinstalling extension <%s>...") % ext)
+            grass.message(_("Reinstalling extension <%s>...") % ext)
         if remove:
             operation = 'remove'
             operation_flags = 'f'
@@ -117,13 +112,13 @@
             operation = 'add'
             operation_flags = ''
         try:
-            gscript.run_command('g.extension', flags=operation_flags,
-                                extension=ext, operation=operation)
+            grass.run_command('g.extension', flags=operation_flags,
+                              extension=ext, operation=operation)
-            gscript.error(_("Unable to process extension:%s") % ext)
+            grass.error(_("Unable to process extension:%s") % ext)
     return 0
     sys.exit(main())
Modified: grass/trunk/scripts/g.manual/g.manual.py
--- grass/trunk/scripts/g.manual/g.manual.py	2016-03-29 06:29:14 UTC (rev 68180)
+++ grass/trunk/scripts/g.manual/g.manual.py	2016-03-29 08:10:14 UTC (rev 68181)
@@ -54,7 +54,6 @@
 from grass.script.utils import basename
 from grass.script import core as grass
 def start_browser(entry):
     if browser and \
        browser not in ('xdg-open', 'start') and \
@@ -62,68 +61,65 @@
         grass.fatal(_("Browser '%s' not found") % browser)
     if flags['o']:
-        major, minor, patch = grass.version()['version'].split('.')
-        url_path = 'http://grass.osgeo.org/grass%s%s/manuals/%s.html' % (major, minor, entry)
+        major,minor,patch = grass.version()['version'].split('.')
+        url_path = 'http://grass.osgeo.org/grass%s%s/manuals/%s.html' % (major,minor,entry)
         if urllib.urlopen(url_path).getcode() != 200:
-            url_path = 'http://grass.osgeo.org/grass%s%s/manuals/addons/%s.html' % (
-                major, minor, entry)
+            url_path = 'http://grass.osgeo.org/grass%s%s/manuals/addons/%s.html' % (major,minor,entry)
     else:
         path = os.path.join(gisbase, 'docs', 'html', entry + '.html')
         if not os.path.exists(path) and os.getenv('GRASS_ADDON_BASE'):
             path = os.path.join(os.getenv('GRASS_ADDON_BASE'), 'docs', 'html', entry + '.html')
         if not os.path.exists(path):
             grass.fatal(_("No HTML manual page entry for '%s'") % entry)
         url_path = 'file://' + path
     if browser and browser not in ('xdg-open', 'start'):
         webbrowser.register(browser_name, None)
     grass.verbose(_("Starting browser '%(browser)s' for manual"
-                    " entry '%(entry)s'...") %
+                    " entry '%(entry)s'...") % \
                   dict(browser=browser_name, entry=entry))
     try:
         webbrowser.open(url_path)
     except:
         grass.fatal(_("Error starting browser '%(browser)s' for HTML file"
                       " '%(path)s'") % dict(browser=browser, path=path))
 def start_man(entry):
     path = os.path.join(gisbase, 'docs', 'man', 'man1', entry + '.1')
         path = os.path.join(os.getenv('GRASS_ADDON_BASE'), 'docs', 'man', 'man1', entry + '.1')
     for ext in ['', '.gz', '.bz2']:
         if os.path.exists(path + ext):
             os.execlp('man', 'man', path + ext)
             grass.fatal(_("Error starting 'man' for '%s'") % path)
     grass.fatal(_("No manual page entry for '%s'") % entry)
 def main():
     global gisbase, browser, browser_name
     if flags['i'] and flags['t']:
         grass.fatal(_("Flags -%c and -%c are mutually exclusive") % ('i', 't'))
     special = None
     if flags['i']:
         special = 'index'
-    elif flags['t']:
+    elif flags ['t']:
         special = 'topics'
     if flags['m']:
         start = start_man
     else:
         start = start_browser
-    entry = options['entry']
+    entry  = options['entry']
     gisbase = os.environ['GISBASE']
     browser = os.getenv('GRASS_HTML_BROWSER', '')
     if sys.platform == 'darwin':
         # hack for MacOSX
         browser_name = os.getenv('GRASS_HTML_BROWSER_MACOSX', '..').split('.')[2]
@@ -132,14 +128,14 @@
         browser_name = basename(browser, 'exe')
     else:
         browser_name = basename(browser)
     # keep order!
     # first test for index...
     if special:
         start(special)
     else:
         start(entry)
     return 0
Modified: grass/trunk/scripts/g.search.modules/g.search.modules.py
--- grass/trunk/scripts/g.search.modules/g.search.modules.py	2016-03-29 06:29:14 UTC (rev 68180)
+++ grass/trunk/scripts/g.search.modules/g.search.modules.py	2016-03-29 08:10:14 UTC (rev 68181)
@@ -50,7 +50,7 @@
 #% description: JSON format
 #% guisection: Output
 #%end
 import os
 import sys
@@ -58,13 +58,12 @@
 try:
-    import xml.etree.ElementTree as etree
+    import xml.etree.ElementTree   as etree
 except ImportError:
-COLORIZE = False
+COLORIZE=False
 def main():
     global COLORIZE
     keywords = options['keyword'].lower().split(',')
@@ -80,9 +79,8 @@
     modules = _search_module(keywords, AND, manpages)
-    print_results(modules, out_format)
+    print_results(modules, out_format)
 def print_results(data, out_format=None):
     Print result of the searching method
@@ -109,35 +107,31 @@
     elif out_format == 'json':
         _print_results_json(data)
 def _print_results_shell(data):
     """Print just the name attribute"""
     for item in data:
-        print(item['name'])
+        print item['name']
 def _print_results_json(data):
     """Print JSON output"""
     import json
-    print(json.dumps(data, sort_keys=True, indent=4, separators=(',', ': ')))
+    print json.dumps(data, sort_keys=True, indent=4, separators=(',', ': '))
 def _print_results(data):
     import textwrap
     for item in data:
-        print('\n{}'.format(colorize(item['name'], attrs=['bold'])))
+        print '\n{}'.format(colorize(item['name'], attrs=['bold']))
         for attr in item['attributes']:
             out = '{}: {}'.format(attr, item['attributes'][attr])
-            out = textwrap.wrap(out, width=79, initial_indent=4 * ' ',
-                                subsequent_indent=4 * ' ' + len(attr) * ' ' + '  ')
+            out = textwrap.wrap(out, width=79, initial_indent=4*' ',
+                    subsequent_indent=4*' '+len(attr)*' '+'  ')
             for line in out:
-                print(line)
+                print line
 def colorize(text, attrs=None, pattern=None):
     """Colorize given text input
@@ -146,6 +140,7 @@
     :param string pattern: text to be highlighted in input text
     :return: colored string
     if COLORIZE:
         try:
@@ -161,7 +156,6 @@
     else:
         return colored(text, attrs=attrs)
 def _search_module(keywords, logical_and=False, manpages=False):
     """Search modules by given keywords
@@ -206,11 +200,11 @@
                     found = [True]
                 description = colorize(description,
-                                       attrs=['underline'],
-                                       pattern=keyword)
+                                        attrs=['underline'],
+                                        pattern=keyword)
                 module_keywords = colorize(module_keywords,
-                                           pattern=keyword)
+                                            pattern=keyword)
         if False not in found:
             found_modules.append({
@@ -223,9 +217,8 @@
     return found_modules
 def _basic_search(pattern, name, description, module_keywords):
     if name.lower().find(pattern) > -1 or\
        description.lower().find(pattern) > -1 or\
        module_keywords.lower().find(pattern) > -1:
@@ -234,7 +227,6 @@
     else:
         return False
 def _manpage_search(pattern, name):
     manpage = grass.read_command('g.manual', flags='m', entry=name)
Modified: grass/trunk/scripts/g.search.modules/testsuite/test_g_search_modules.py
--- grass/trunk/scripts/g.search.modules/testsuite/test_g_search_modules.py	2016-03-29 06:29:14 UTC (rev 68180)
+++ grass/trunk/scripts/g.search.modules/testsuite/test_g_search_modules.py	2016-03-29 08:10:14 UTC (rev 68181)
@@ -52,7 +52,7 @@
         stdout = module.outputs.stdout.split()
         self.assertEqual(stdout[0],
                          termcolor.colored('r.watershed',
-                                           attrs=['bold']))
+                         attrs=['bold']))
     def test_manual_pages(self):
         module = SimpleModule('g.search.modules', keyword="kapri", flags="gm")
Modified: grass/trunk/scripts/i.colors.enhance/i.colors.enhance.py
--- grass/trunk/scripts/i.colors.enhance/i.colors.enhance.py	2016-03-29 06:29:14 UTC (rev 68180)
+++ grass/trunk/scripts/i.colors.enhance/i.colors.enhance.py	2016-03-29 08:10:14 UTC (rev 68181)
@@ -8,7 +8,7 @@
 #		Hamish Bowman, scripting enhancements
-# PURPOSE:      create pretty RGBs: the trick is to remove outliers
+# PURPOSE:      create pretty RGBs: the trick is to remove outliers
 #               using percentiles (area under the histogram curve)
 # COPYRIGHT:	(C) 2006, 2008, 2012-2014 by the GRASS Development Team
@@ -68,9 +68,9 @@
 #%end
 import sys
+import os
+import string
 try:
     # new for python 2.6, in 2.5 it may be easy_install'd.
     import multiprocessing as mp
@@ -85,16 +85,14 @@
     val2 = percentiles[1]
     values = '%s,%s' % (val1, val2)
-    s = gscript.read_command('r.quantile', input=map,
-                             percentiles=values, quiet=True)
+    s = grass.read_command('r.quantile', input = map,
+                           percentiles = values, quiet = True)
     val_str1 = s.splitlines()[0].split(':')[2]
     val_str2 = s.splitlines()[1].split(':')[2]
     return (float(val_str1), float(val_str2))
 # wrapper to handle multiprocesses communications back to the parent
 def get_percentile_mp(map, percentiles, conn):
     # Process() doesn't like storing connection parts in
     #  separate dictionaries, only wants to pass through tuples,
@@ -103,16 +101,19 @@
     output_pipe, input_pipe = conn
     input_pipe.close()
     result = get_percentile(map, percentiles)
-    gscript.debug('child (%s) (%.1f, %.1f)' % (map, result[0], result[1]))
+    grass.debug('child (%s) (%.1f, %.1f)' % (map, result[0], result[1]))
     output_pipe.send(result)
     output_pipe.close()
 def set_colors(map, v0, v1):
-    rules = ''.join(["0% black\n", "%f black\n" % v0,
-                     "%f white\n" % v1, "100% white\n"])
-    gscript.write_command('r.colors', map=map, rules='-', stdin=rules,
-                          quiet=True)
+    rules = [
+	"0% black\n",
+	"%f black\n" % v0,
+	"%f white\n" % v1,
+	"100% white\n"
+    rules = ''.join(rules)
+    grass.write_command('r.colors', map = map, rules = '-', stdin = rules, quiet = True)
 def main():
@@ -123,7 +124,7 @@
     full = flags['f']
     preserve = flags['p']
     reset = flags['r']
     global do_mp
     if flags['s']:
@@ -134,90 +135,92 @@
     # must be more than "2" ?
     if full:
-        for i in [red, green, blue]:
-            gscript.run_command('r.colors', map=i, color='grey', quiet=True)
-        sys.exit(0)
+	for i in [red, green, blue]:
+	    grass.run_command('r.colors', map = i, color = 'grey', quiet = True)
+	sys.exit(0)
     if reset:
-            gscript.run_command('r.colors', map=i, color='grey255', quiet=True)
-        sys.exit(0)
+	    grass.run_command('r.colors', map = i, color = 'grey255', quiet = True)
+	sys.exit(0)
     if not preserve:
         if do_mp:
-            gscript.message(_("Processing..."))
-            # set up jobs and launch them
-            proc = {}
-            conn = {}
-                conn[i] = mp.Pipe()
-                proc[i] = mp.Process(target=get_percentile_mp,
-                                     args=(i, ['2', brightness],
-                                           conn[i],))
-                proc[i].start()
-            gscript.percent(1, 2, 1)
+            grass.message(_("Processing..."))
+	    # set up jobs and launch them
+	    proc = {}
+	    conn = {}
+	        conn[i] = mp.Pipe()
+	        proc[i] = mp.Process(target = get_percentile_mp,
+				     args = (i, ['2', brightness],
+				     conn[i],))
+		proc[i].start()
+            grass.percent(1, 2, 1)
+	    # collect results and wait for jobs to finish
+		output_pipe, input_pipe = conn[i]
+		(v0, v1) = input_pipe.recv()
+		grass.debug('parent (%s) (%.1f, %.1f)' % (i, v0, v1))
+		input_pipe.close()
+		proc[i].join()
+		set_colors(i, v0, v1)
+            grass.percent(1, 1, 1)
+	else:
+	        (v0, v1) = get_percentile(i, ['2', brightness])
+	        grass.debug("<%s>:  min=%f   max=%f" % (i, v0, v1))
-            # collect results and wait for jobs to finish
-                output_pipe, input_pipe = conn[i]
-                (v0, v1) = input_pipe.recv()
-                gscript.debug('parent (%s) (%.1f, %.1f)' % (i, v0, v1))
-                input_pipe.close()
-                proc[i].join()
-                set_colors(i, v0, v1)
-            gscript.percent(1, 1, 1)
-        else:
-                (v0, v1) = get_percentile(i, ['2', brightness])
-                gscript.debug("<%s>:  min=%f   max=%f" % (i, v0, v1))
     else:
-        all_max = 0
-        all_min = 999999
+	all_max = 0
+	all_min = 999999
-        if do_mp:
-            # set up jobs and launch jobs
-            proc = {}
-            conn = {}
-                                           conn[i],))
-                proc[i].start()
+	if do_mp:
+	    # set up jobs and launch jobs
+	    proc = {}
+	    conn = {}
+				     conn[i],))
+		proc[i].start()
+		proc[i].join()
+		all_min = min(all_min, v0)
+		all_max = max(all_max, v1)
+	else:
-                proc[i].join()
-                all_min = min(all_min, v0)
-                all_max = max(all_max, v1)
-        else:
+	grass.debug("all_min=%f   all_max=%f" % (all_min, all_max))
+	    set_colors(i, all_min, all_max)
-        gscript.debug("all_min=%f   all_max=%f" % (all_min, all_max))
-            set_colors(i, all_min, all_max)
     # write cmd history:
-    mapset = gscript.gisenv()['MAPSET']
+    mapset = grass.gisenv()['MAPSET']
-        if gscript.find_file(i)['mapset'] == mapset:
-            gscript.raster_history(i)
+        if grass.find_file(i)['mapset'] == mapset:
+            grass.raster_history(i)
     main()
Modified: grass/trunk/scripts/i.image.mosaic/i.image.mosaic.py
--- grass/trunk/scripts/i.image.mosaic/i.image.mosaic.py	2016-03-29 06:29:14 UTC (rev 68180)
+++ grass/trunk/scripts/i.image.mosaic/i.image.mosaic.py	2016-03-29 08:10:14 UTC (rev 68181)
@@ -32,70 +32,67 @@
 #%end
 #%option G_OPT_R_OUTPUT
 #%end
+import sys
+import os
 def copy_colors(fh, map, offset):
-    p = gscript.pipe_command('r.colors.out', map=map)
+    p = grass.pipe_command('r.colors.out', map = map)
     for line in p.stdout:
-        f = line.rstrip('\r\n').split(' ')
-        if offset:
-            if f[0] in ['nv', 'default']:
-                continue
-            f[0] = str(float(f[0]) + offset)
-        fh.write(' '.join(f) + '\n')
+	f = line.rstrip('\r\n').split(' ')
+	if offset:
+	    if f[0] in ['nv', 'default']:
+		continue
+	    f[0] = str(float(f[0]) + offset)
+	fh.write(' '.join(f) + '\n')
     p.wait()
 def get_limit(map):
-    return gscript.raster_info(map)['max']
+    return grass.raster_info(map)['max']
 def make_expression(i, count):
     if i > count:
-        return "null()"
+	return "null()"
     else:
-        e = make_expression(i + 1, count)
-        return "if(isnull($image%d),%s,$image%d+$offset%d)" % (i, e, i, i)
+	e = make_expression(i + 1, count)
+	return "if(isnull($image%d),%s,$image%d+$offset%d)" % (i, e, i, i)
 def main():
     images = options['input'].split(',')
     output = options['output']
     count = len(images)
-    msg = _('Do not forget to set region properly to cover all images.')
-    gscript.warning(msg)
+    grass.warning(_('Do not forget to set region properly to cover all images.'))
     offset = 0
     offsets = []
     parms = {}
     for n, img in enumerate(images):
-        offsets.append(offset)
-        parms['image%d' % (n + 1)] = img
-        parms['offset%d' % (n + 1)] = offset
-        offset += get_limit(img) + 1
+	offsets.append(offset)
+	parms['image%d' % (n + 1)] = img
+	parms['offset%d' % (n + 1)] = offset
+	offset += get_limit(img) + 1
-    gscript.message(_("Mosaicing %d images...") % count)
+    grass.message(_("Mosaicing %d images...") % count)
-    gscript.mapcalc("$output = " + make_expression(1, count),
-                    output=output, **parms)
+    grass.mapcalc("$output = " + make_expression(1, count),
+		  output = output, **parms)
-    # modify the color table:
-    p = gscript.feed_command('r.colors', map=output, rules='-')
+    #modify the color table:
+    p = grass.feed_command('r.colors', map = output, rules='-')
     for img, offset in zip(images, offsets):
-        print(img, offset)
-        copy_colors(p.stdin, img, offset)
+	print img, offset
+	copy_colors(p.stdin, img, offset)
     p.stdin.close()
     p.wait()
-    gscript.message(_("Done. Raster map <%s> created.") % output)
+    grass.message(_("Done. Raster map <%s> created.") % output)
-    gscript.raster_history(output)
+    grass.raster_history(output)
     main()
Modified: grass/trunk/scripts/i.in.spotvgt/i.in.spotvgt.py
--- grass/trunk/scripts/i.in.spotvgt/i.in.spotvgt.py	2016-03-29 06:29:14 UTC (rev 68180)
+++ grass/trunk/scripts/i.in.spotvgt/i.in.spotvgt.py	2016-03-29 08:10:14 UTC (rev 68181)
@@ -23,7 +23,7 @@
 #      -  gdal: http://www.gdal.org
 # Notes:
-# * According to the faq (http://www.vgt.vito.be/faq/faq.html), SPOT vegetation
+# * According to the faq (http://www.vgt.vito.be/faq/faq.html), SPOT vegetation
 #   coordinates refer to the center of a pixel.
 # * GDAL coordinates refer to the corner of a pixel
 #   -> correction of 0001/0001_LOG.TXT coordinates by 0.5 pixel
@@ -48,7 +48,7 @@
 import os
 import atexit
 import string
@@ -67,109 +67,103 @@
  </VRTRasterBand>
 </VRTDataset>"""
-# a function for writing VRT files
+#### a function for writing VRT files
 def create_VRT_file(projfile, vrtfile, infile):
     fh = file(projfile)
     kv = {}
     for l in fh:
-        f = l.rstrip('\r\n').split()
-        if f < 2:
-            continue
-        kv[f[0]] = f[1]
+	f = l.rstrip('\r\n').split()
+	if f < 2:
+	    continue
+	kv[f[0]] = f[1]
     fh.close()
     north_center = kv['CARTO_UPPER_LEFT_Y']
-    # south_center = kv['CARTO_LOWER_LEFT_Y']
-    # east_center = kv['CARTO_UPPER_RIGHT_X']
-    west_center = kv['CARTO_UPPER_LEFT_X']
+    south_center = kv['CARTO_LOWER_LEFT_Y']
+    east_center  = kv['CARTO_UPPER_RIGHT_X']
+    west_center  = kv['CARTO_UPPER_LEFT_X']
     map_proj_res = kv['MAP_PROJ_RESOLUTION']
-    xsize = kv['IMAGE_UPPER_RIGHT_COL']
-    ysize = kv['IMAGE_LOWER_RIGHT_ROW']
+    xsize        = kv['IMAGE_UPPER_RIGHT_COL']
+    ysize        = kv['IMAGE_LOWER_RIGHT_ROW']
-    resolution = float(map_proj_res)
+    resolution   = float(map_proj_res)
     north_corner = float(north_center) + resolution / 2
-    # south_corner = float(south_center) - resolution / 2
-    # east_corner = float(east_center) + resolution / 2
-    west_corner = float(west_center) - resolution / 2
+    south_corner = float(south_center) - resolution / 2
+    east_corner  = float(east_center ) + resolution / 2
+    west_corner  = float(west_center ) - resolution / 2
     t = string.Template(vrt)
-    s = t.substitute(NORTHCORNER=north_corner, WESTCORNER=west_corner,
-                     XSIZE=xsize, YSIZE=ysize, RESOLUTION=map_proj_res,
-                     FILENAME=infile)
+    s = t.substitute(NORTHCORNER = north_corner, WESTCORNER = west_corner,
+		     XSIZE = xsize, YSIZE = ysize, RESOLUTION = map_proj_res,
+		     FILENAME = infile)
     outf = file(vrtfile, 'w')
     outf.write(s)
     outf.close()
 def cleanup():
-    # clean up the mess
-    gscript.try_remove(vrtfile)
-    gscript.try_remove(tmpfile)
+   #### clean up the mess
+   grass.try_remove(vrtfile)
+   grass.try_remove(tmpfile)
 def main():
     global vrtfile, tmpfile
-    infile = options['input']
+    infile  = options['input']
     rast = options['output']
     also = flags['a']
-    # check for gdalinfo (just to check if installation is complete)
-    if not gscript.find_program('gdalinfo', '--help'):
-        gscript.fatal(_("'gdalinfo' not found, install GDAL tools first "
-                        "(http://www.gdal.org)"))
+    #### check for gdalinfo (just to check if installation is complete)
+    if not grass.find_program('gdalinfo', '--help'):
+	grass.fatal(_("'gdalinfo' not found, install GDAL tools first (http://www.gdal.org)"))
     pid = str(os.getpid())
-    tmpfile = gscript.tempfile()
+    tmpfile = grass.tempfile()
-    # let's go
+    ################### let's go
     spotdir = os.path.dirname(infile)
-    spotname = gscript.basename(infile, 'hdf')
+    spotname = grass.basename(infile, 'hdf')
     if rast:
-        name = rast
+	name = rast
     else:
-        name = spotname
+	name = spotname
-    if not gscript.overwrite() and gscript.find_file(name)['file']:
-        gscript.fatal(_("<%s> already exists. Aborting.") % name)
+    if not grass.overwrite() and grass.find_file(name)['file']:
+	grass.fatal(_("<%s> already exists. Aborting.") % name)
-    # still a ZIP file?  (is this portable?? see the r.in.srtm script for
-    # ideas)
+    # still a ZIP file?  (is this portable?? see the r.in.srtm script for ideas)
     if infile.lower().endswith('.zip'):
-        gscript.fatal(_("Please extract %s before import.") % infile)
+	grass.fatal(_("Please extract %s before import.") % infile)
     try:
-        p = gscript.Popen(['file', '-ib', infile], stdout=gscript.PIPE)
-        s = p.communicate()[0]
-        if s == "application/x-zip":
+	p = grass.Popen(['file', '-ib', infile], stdout = grass.PIPE)
+	s = p.communicate()[0]
+	if s == "application/x-zip":
     except:
-        pass
+	pass
-    # create VRT header for NDVI
+    ### create VRT header for NDVI
     projfile = os.path.join(spotdir, "0001_LOG.TXT")
     vrtfile = tmpfile + '.vrt'
     # first process the NDVI:
-    # let's import the NDVI map...
-    gscript.message(_("Importing SPOT VGT NDVI map..."))
+    ## let's import the NDVI map...
+    grass.message(_("Importing SPOT VGT NDVI map..."))
     try:
-        gscript.run_command('r.in.gdal', input=vrtfile, output=name)
+        grass.run_command('r.in.gdal', input=vrtfile, output=name)
-        gscript.fatal(_("An error occurred. Stop."))
+        grass.fatal(_("An error occurred. Stop."))
-    gscript.message(_("Imported SPOT VEGETATION NDVI map <%s>.") % name)
+    grass.message(_("Imported SPOT VEGETATION NDVI map <%s>.") % name)
-    # http://www.vgt.vito.be/faq/FAQS/faq19.html
+    ## http://www.vgt.vito.be/faq/FAQS/faq19.html
     # What is the relation between the digital number and the real NDVI ?
     # Real NDVI =coefficient a * Digital Number + coefficient b
     #           = a * DN +b
@@ -179,29 +173,28 @@
     # clone current region
     # switch to a temporary region
-    gscript.use_temp_region()
-    gscript.run_command('g.region', raster=name, quiet=True)
+    grass.run_command('g.region', raster = name, quiet = True)
-    gscript.message(_("Remapping digital numbers to NDVI..."))
+    grass.message(_("Remapping digital numbers to NDVI..."))
     tmpname = "%s_%s" % (name, pid)
-    gscript.mapcalc("$tmpname = 0.004 * $name - 0.1", tmpname=tmpname, name=name)
-    gscript.run_command('g.remove', type='raster', name=name, quiet=True,
-                        flags='f')
-    gscript.run_command('g.rename', raster=(tmpname, name), quiet=True)
+    grass.mapcalc("$tmpname = 0.004 * $name - 0.1", tmpname = tmpname, name = name)
+    grass.run_command('g.remove', type = 'raster', name = name, quiet = True, flags = 'f')
+    grass.run_command('g.rename', raster = (tmpname, name), quiet = True)
-    gscript.raster_history(name)
+    grass.raster_history(name)
-    # apply color table:
-    gscript.run_command('r.colors', map=name, color='ndvi', quiet=True)
+    #apply color table:
+    grass.run_command('r.colors', map = name, color = 'ndvi', quiet = True)
     # second, optionally process the SM quality map:
-    # SM Status Map
+    #SM Status Map
     # http://nieuw.vgt.vito.be/faq/FAQS/faq22.html
-    # Data about
+    #Data about
     # Bit NR 7: Radiometric quality for B0 coded as 0 if bad and 1 if good
     # Bit NR 6: Radiometric quality for B2 coded as 0 if bad and 1 if good
     # Bit NR 5: Radiometric quality for B3 coded as 0 if bad and 1 if good
@@ -212,7 +205,7 @@
     # Bit NR 0:	0	1	0		1
     # 		clear	shadow	uncertain	cloud
-    # Note:
+    #Note:
     # pos 7     6    5    4    3    2   1   0 (bit position)
     #   128    64   32   16    8    4   2   1 (values for 8 bit)
@@ -225,55 +218,54 @@
     # A good map threshold: >= 248
     if also:
-        gscript.message(_("Importing SPOT VGT NDVI quality map..."))
-        qname = spotname.replace('NDV', 'SM')
-        qfile = os.path.join(spotdir, qname)
-        create_VRT_file(projfile, vrtfile, qfile)
+	grass.message(_("Importing SPOT VGT NDVI quality map..."))
+	qname = spotname.replace('NDV','SM')
+	qfile = os.path.join(spotdir, qname)
+	create_VRT_file(projfile, vrtfile, qfile)
-        # let's import the SM quality map...
-        smfile = name + '.sm'
+	## let's import the SM quality map...
+	smfile = name + '.sm'
         try:
-            gscript.run_command('r.in.gdal', input=vrtfile, output=smfile)
+            grass.run_command('r.in.gdal', input=vrtfile, output=smfile)
-        # some of the possible values:
-        rules = [r + '\n' for r in ['8 50 50 50',
-                                    '11 70 70 70',
-                                    '12 90 90 90',
-                                    '60 grey',
-                                    '155 blue',
-                                    '232 violet',
-                                    '235 red',
-                                    '236 brown',
-                                    '248 orange',
-                                    '251 yellow',
-                                    '252 green']]
-        gscript.write_command('r.colors', map=smfile, rules='-', stdin=rules)
+	# some of the possible values:
+	rules = [r + '\n' for r in [
+	    '8 50 50 50',
+	    '11 70 70 70',
+	    '12 90 90 90',
+	    '60 grey',
+	    '155 blue',
+	    '232 violet',
+	    '235 red',
+	    '236 brown',
+	    '248 orange',
+	    '251 yellow',
+	    '252 green'
+	grass.write_command('r.colors', map = smfile, rules = '-', stdin = rules)
-        gscript.message(_("Imported SPOT VEGETATION SM quality map <%s>.") %
-                        smfile)
-        gscript.message(_("Note: A snow map can be extracted by category "
-                          "252 (d.rast %s cat=252)") % smfile)
-        gscript.message(_("Filtering NDVI map by Status Map quality layer..."))
+	grass.message(_("Imported SPOT VEGETATION SM quality map <%s>.") % smfile)
+	grass.message(_("Note: A snow map can be extracted by category 252 (d.rast %s cat=252)") % smfile)
+	grass.message("")
+	grass.message(_("Filtering NDVI map by Status Map quality layer..."))
-        filtfile = "%s_filt" % name
-        gscript.mapcalc("$filtfile = if($smfile % 4 == 3 || "
-                        "($smfile / 16) % 16 == 0, null(), $name)",
-                        filtfile=filtfile, smfile=smfile, name=name)
-        gscript.run_command('r.colors', map=filtfile, color='ndvi', quiet=True)
-        gscript.message(_("Filtered SPOT VEGETATION NDVI map <%s>.") %
-                        filtfile)
+	filtfile = "%s_filt" % name
+	grass.mapcalc("$filtfile = if($smfile % 4 == 3 || ($smfile / 16) % 16 == 0, null(), $name)",
+		      filtfile = filtfile, smfile = smfile, name = name)
+	grass.run_command('r.colors', map = filtfile, color = 'ndvi', quiet = True)
+	grass.message(_("Filtered SPOT VEGETATION NDVI map <%s>.") % filtfile)
-        # write cmd history:
-        gscript.raster_history(smfile)
-        gscript.raster_history(filtfile)
+	# write cmd history:
+	grass.raster_history(smfile)
+	grass.raster_history(filtfile)
-    gscript.message(_("Done."))
+    grass.message(_("Done."))
     atexit.register(cleanup)
     main()
Modified: grass/trunk/scripts/i.oif/i.oif.py
--- grass/trunk/scripts/i.oif/i.oif.py	2016-03-29 06:29:14 UTC (rev 68180)
+++ grass/trunk/scripts/i.oif/i.oif.py	2016-03-29 08:10:14 UTC (rev 68181)
@@ -121,6 +121,7 @@
             kv = parse_key_val(pout[band])
             stddev[band] = float(kv['stddev'])
     grass.message(_("Calculating Correlation Matrix..."))
     correlation = {}
     s = grass.read_command('r.covar', flags='r', map=[band for band in bands],
@@ -140,7 +141,7 @@
         oif.append((oifcalc(stddev, correlation, *p), p))
     oif.sort(reverse=True)
-    grass.verbose(_("The Optimum Index Factor analysis result "
+    grass.verbose(_("The Optimum Index Factor analysis result " \
                     "(best combination shown first):"))
     if shell:
Modified: grass/trunk/scripts/i.spectral/i.spectral.py
--- grass/trunk/scripts/i.spectral/i.spectral.py	2016-03-29 06:29:14 UTC (rev 68180)
+++ grass/trunk/scripts/i.spectral/i.spectral.py	2016-03-29 08:10:14 UTC (rev 68181)
@@ -20,7 +20,7 @@
 # written by Markus Neteler 18. August 1998
 #            neteler geog.uni-hannover.de
 # bugfix: 25. Nov.98/20. Jan. 1999
 # 3 March 2006: Added multiple images and group support by Francesco Pirotti - CIRGEO
@@ -77,22 +77,20 @@
 import os
 import atexit
 from grass.script.utils import try_rmdir
-from grass.script import core as gcore
+from grass.script import core as grass
 def cleanup():
     try_rmdir(tmp_dir)
 def write2textf(what, output):
     outf = open(output, 'w')
-    i = 0
+    i=0
     for row in enumerate(what):
-        i = i + 1
-        outf.write("%d, %s\n" % (i, row))
+        i=i+1
+        outf.write("%d, %s\n" % (i,row))
     outf.close()
 def draw_gnuplot(what, xlabels, output, img_format, coord_legend):
     xrange = 0
@@ -109,12 +107,12 @@
     if output:
         if img_format == 'png':
             term_opts = "png truecolor large size 825,550"
-        elif img_format == 'eps':
+	elif img_format == 'eps':
             term_opts = "postscript eps color solid size 6,4"
-        elif img_format == 'svg':
+	elif img_format == 'svg':
             term_opts = "svg size 825,550 dynamic solid"
         else:
-            gcore.fatal(_("Programmer error (%s)") % img_format)
+            grass.fatal(_("Programmer error (%s)") % img_format)
         lines += [
             "set term " + term_opts,
@@ -154,9 +152,9 @@
     plotf.close()
     if output:
-        gcore.call(['gnuplot', plotfile])
+        grass.call(['gnuplot', plotfile])
     else:
-        gcore.call(['gnuplot', '-persist', plotfile])
+        grass.call(['gnuplot', '-persist', plotfile])
 def draw_linegraph(what):
@@ -177,7 +175,7 @@
         yf.close()
         yfiles.append(yfile)
-    sienna = '#%02x%02x%02x' % (160, 82, 45)
+    sienna = '#%02x%02x%02x' % (160,  82, 45)
     coral = '#%02x%02x%02x' % (255, 127, 80)
     gp_colors = ['red', 'green', 'blue', 'magenta', 'cyan', sienna, 'orange',
                  coral]
@@ -187,7 +185,7 @@
         colors += gp_colors
     colors = colors[0:len(what)]
-    gcore.run_command('d.linegraph', x_file=xfile, y_file=yfiles,
+    grass.run_command('d.linegraph', x_file=xfile, y_file=yfiles,
                       y_color=colors, title='Spectral signatures',
                       x_title='Bands', y_title='DN Value')
@@ -203,26 +201,26 @@
     textfile = flags['t']
     global tmp_dir
-    tmp_dir = gcore.tempdir()
+    tmp_dir = grass.tempdir()
     if not group and not raster:
-        gcore.fatal(_("Either group= or raster= is required"))
+        grass.fatal(_("Either group= or raster= is required"))
     if group and raster:
-        gcore.fatal(_("group= and raster= are mutually exclusive"))
+        grass.fatal(_("group= and raster= are mutually exclusive"))
     # -t needs an output filename
     if textfile and not output:
-        gcore.fatal(_("Writing to text file requires output=filename"))
+        grass.fatal(_("Writing to text file requires output=filename"))
     # check if gnuplot is present
-    if gnuplot and not gcore.find_program('gnuplot', '-V'):
-        gcore.fatal(_("gnuplot required, please install first"))
+    if gnuplot and not grass.find_program('gnuplot', '-V'):
+        grass.fatal(_("gnuplot required, please install first"))
     # get data from group listing and set the x-axis labels
     if group:
         # Parse the group list output
-        s = gcore.read_command('i.group', flags='g', group=group, quiet=True)
+        s = grass.read_command('i.group', flags='g', group=group, quiet=True)
         rastermaps = s.splitlines()
     else:
         # get data from list of files and set the x-axis labels
@@ -233,10 +231,10 @@
     # get y-data for gnuplot-data file
     what = []
-    s = gcore.read_command('r.what', map=rastermaps, coordinates=coords,
+    s = grass.read_command('r.what', map=rastermaps, coordinates=coords,
                            null='0', quiet=True)
     if len(s) == 0:
-        gcore.fatal(_('No data returned from query'))
+        grass.fatal(_('No data returned from query'))
         f = l.split('|')
@@ -256,6 +254,6 @@
-    options, flags = gcore.parser()
     main()
Modified: grass/trunk/scripts/i.tasscap/i.tasscap.py
--- grass/trunk/scripts/i.tasscap/i.tasscap.py	2016-03-29 06:29:14 UTC (rev 68180)
+++ grass/trunk/scripts/i.tasscap/i.tasscap.py	2016-03-29 08:10:14 UTC (rev 68181)
@@ -75,24 +75,24 @@
 # weights for 6 Landsat bands: TM4, TM5, TM7, OLI
 # MODIS: Red, NIR1, Blue, Green, NIR2, SWIR1, SWIR2
-parms = [[(0.3037, 0.2793, 0.4743, 0.5585, 0.5082, 0.1863),  # Landsat TM4
-          (-0.2848, -0.2435, -0.5435, 0.7243, 0.0840, -0.1800),
-          (0.1509, 0.1973, 0.3279, 0.3406, -0.7112, -0.4572)],
-         [(0.2909, 0.2493, 0.4806, 0.5568, 0.4438, 0.1706, 10.3695),  # Landsat TM5
-          (-0.2728, -0.2174, -0.5508, 0.7221, 0.0733, -0.1648, -0.7310),
-          (0.1446, 0.1761, 0.3322, 0.3396, -0.6210, -0.4186, -3.3828),
-          (0.8461, -0.0731, -0.4640, -0.0032, -0.0492, -0.0119, 0.7879)],
-         [(0.3561, 0.3972, 0.3904, 0.6966, 0.2286, 0.1596),  # Landsat TM7
-          (-0.3344, -0.3544, -0.4556, 0.6966, -0.0242, -0.2630),
-          (0.2626, 0.2141, 0.0926, 0.0656, -0.7629, -0.5388),
-          (0.0805, -0.0498, 0.1950, -0.1327, 0.5752, -0.7775)],
-         [(0.3029, 0.2786, 0.4733, 0.5599, 0.5080, 0.1872),  # Landsat OLI
-          (-0.2941, -0.2430, -0.5424, 0.7276, 0.0713, -0.1608),
-          (0.1511, 0.1973, 0.3283, 0.3407, -0.7117, -0.4559),
-          (-0.8239, 0.0849, 0.4396, -0.0580, 0.2013, -0.2773)],
-         [(0.4395, 0.5945, 0.2460, 0.3918, 0.3506, 0.2136, 0.2678),  # MODIS
-          (-0.4064, 0.5129, -0.2744, -0.2893, 0.4882, -0.0036, -0.4169),
-          (0.1147, 0.2489, 0.2408, 0.3132, -0.3122, -0.6416, -0.5087)]]
+parms = [[(0.3037,  0.2793,  0.4743,  0.5585,  0.5082,  0.1863),  # Landsat TM4
+         (-0.2848, -0.2435, -0.5435,  0.7243,  0.0840, -0.1800),
+          (0.1509,  0.1973,  0.3279,  0.3406, -0.7112, -0.4572)],
+         [(0.2909,  0.2493,  0.4806,  0.5568,  0.4438,  0.1706, 10.3695),  # Landsat TM5
+         (-0.2728, -0.2174, -0.5508,  0.7221,  0.0733, -0.1648, -0.7310),
+          (0.1446,  0.1761,  0.3322,  0.3396, -0.6210, -0.4186, -3.3828),
+          (0.8461, -0.0731, -0.4640, -0.0032, -0.0492, -0.0119,  0.7879)],
+         [(0.3561,  0.3972,  0.3904,  0.6966,  0.2286,  0.1596),  # Landsat TM7
+         (-0.3344, -0.3544, -0.4556,  0.6966, -0.0242, -0.2630),
+          (0.2626,  0.2141,  0.0926,  0.0656, -0.7629, -0.5388),
+          (0.0805, -0.0498,  0.1950, -0.1327,  0.5752, -0.7775)],
+         [(0.3029,  0.2786,  0.4733,  0.5599,  0.5080,  0.1872),  # Landsat OLI
+         (-0.2941, -0.2430, -0.5424,  0.7276,  0.0713, -0.1608),
+          (0.1511,  0.1973,  0.3283,  0.3407, -0.7117, -0.4559),
+         (-0.8239,  0.0849,  0.4396, -0.0580,  0.2013, -0.2773)],
+         [(0.4395,  0.5945,  0.2460,  0.3918,  0.3506,  0.2136,  0.2678),  # MODIS
+         (-0.4064,  0.5129, -0.2744, -0.2893,  0.4882, -0.0036, -0.4169),
+          (0.1147,  0.2489,  0.2408,  0.3132, -0.3122, -0.6416, -0.5087)]]
 # satellite information
@@ -167,8 +167,8 @@
     # assign "Data Description" field in all four component maps
     for i, comp in enumerate(names):
-        grass.run_command('r.support', map="%s.%d" % (output_basename, i + 1),
-                          description="Tasseled Cap %d: %s" % (i + 1, comp))
+        grass.run_command('r.support', map="%s.%d" % (output_basename, i+1),
+                          description="Tasseled Cap %d: %s" % (i+1, comp))
     grass.message(_("Tasseled Cap components calculated"))
Modified: grass/trunk/scripts/m.proj/m.proj.py
--- grass/trunk/scripts/m.proj/m.proj.py	2016-03-29 06:29:14 UTC (rev 68180)
+++ grass/trunk/scripts/m.proj/m.proj.py	2016-03-29 08:10:14 UTC (rev 68181)
@@ -95,11 +95,10 @@
 import os
 import threading
 from grass.script.utils import separator, parse_key_val
 class TrThread(threading.Thread):
     def __init__(self, ifs, inf, outf):
         threading.Thread.__init__(self)
         self.ifs = ifs
@@ -132,28 +131,28 @@
     include_header = flags['c']
     # check for cs2cs
-    if not gcore.find_program('cs2cs'):
-        gcore.fatal(_(
+    if not grass.find_program('cs2cs'):
+        grass.fatal(_(
             "cs2cs program not found, install PROJ.4 first: \
             http://proj.maptools.org"))
     # check for overenthusiasm
     if proj_in and ll_in:
-        gcore.fatal(_("Choose only one input parameter method"))
+        grass.fatal(_("Choose only one input parameter method"))
     if proj_out and ll_out:
-        gcore.fatal(_("Choose only one output parameter method"))
+        grass.fatal(_("Choose only one output parameter method"))
     if ll_in and ll_out:
-        gcore.fatal(_("Choise only one auto-projection parameter method"))
+        grass.fatal(_("Choise only one auto-projection parameter method"))
-    if output and not gcore.overwrite() and os.path.exists(output):
-        gcore.fatal(_("Output file already exists"))
+    if output and not grass.overwrite() and os.path.exists(output):
+        grass.fatal(_("Output file already exists"))
     if not coords and not input:
-        gcore.fatal(_("One of <coordinates> and <input> must be given"))
+        grass.fatal(_("One of <coordinates> and <input> must be given"))
     if coords and input:
-        gcore.fatal(_(
+        grass.fatal(_(
             "Options <coordinates> and <input> are mutually exclusive"))
     # parse field separator
@@ -170,59 +169,59 @@
     ofs = separator(ofs)
     # set up projection params
-    s = gcore.read_command("g.proj", flags='j')
+    s = grass.read_command("g.proj", flags='j')
     kv = parse_key_val(s)
     if "XY location" in kv['+proj'] and (ll_in or ll_out):
-        gcore.fatal(_("Unable to project to or from a XY location"))
+        grass.fatal(_("Unable to project to or from a XY location"))
     in_proj = None
     if ll_in:
         in_proj = "+proj=longlat +datum=WGS84"
-        gcore.verbose(
+        grass.verbose(
             "Assuming LL WGS84 as input, current projection as output ")
     if ll_out:
-        in_proj = gcore.read_command('g.proj', flags='jf')
+        in_proj = grass.read_command('g.proj', flags='jf')
     if proj_in:
         if '+' in proj_in:
             in_proj = proj_in
         else:
-            gcore.fatal(_("Invalid PROJ.4 input specification"))
+            grass.fatal(_("Invalid PROJ.4 input specification"))
     if not in_proj:
-        gcore.verbose("Assuming current location as input")
+        grass.verbose("Assuming current location as input")
     in_proj = in_proj.strip()
-    gcore.verbose("Input parameters: '%s'" % in_proj)
+    grass.verbose("Input parameters: '%s'" % in_proj)
     out_proj = None
     if ll_out:
         out_proj = "+proj=longlat +datum=WGS84"
-        gcore.verbose(
+        grass.verbose(
             "Assuming current projection as input, LL WGS84 as output ")
     if ll_in:
-        out_proj = gcore.read_command('g.proj', flags='jf')
+        out_proj = grass.read_command('g.proj', flags='jf')
     if proj_out:
         if '+' in proj_out:
             out_proj = proj_out
         else:
-            gcore.fatal(_("Invalid PROJ.4 output specification"))
+            grass.fatal(_("Invalid PROJ.4 output specification"))
     if not out_proj:
-        gcore.fatal(_("Missing output projection parameters "))
+        grass.fatal(_("Missing output projection parameters "))
     out_proj = out_proj.strip()
-    gcore.verbose("Output parameters: '%s'" % out_proj)
+    grass.verbose("Output parameters: '%s'" % out_proj)
     # set up input file
     if coords:
         x, y = coords.split(',')
-        tmpfile = gcore.tempfile()
         fd = open(tmpfile, "w")
         fd.write("%s%s%s\n" % (x, ifs, y))
         fd.close()
@@ -234,9 +233,9 @@
         else:
             infile = input
             if not os.path.exists(infile):
-                gcore.fatal(_("Unable to read input data"))
+                grass.fatal(_("Unable to read input data"))
             inf = file(infile)
-            gcore.debug("input file=[%s]" % infile)
+            grass.debug("input file=[%s]" % infile)
     # set up output file
     if not output:
@@ -245,7 +244,7 @@
     else:
         outfile = output
         outf = open(outfile, 'w')
-        gcore.debug("output file=[%s]" % outfile)
+        grass.debug("output file=[%s]" % outfile)
     # set up output style
     if not decimal:
@@ -264,7 +263,7 @@
     cmd = ['cs2cs'] + copyinp + outfmt + \
         in_proj.split() + ['+to'] + out_proj.split()
-    p = gcore.Popen(cmd, stdin=gcore.PIPE, stdout=gcore.PIPE)
+    p = grass.Popen(cmd, stdin=grass.PIPE, stdout=grass.PIPE)
     tr = TrThread(ifs, inf, p.stdin)
     tr.start()
@@ -277,7 +276,7 @@
                 xy, z = line.split(' ', 1)
                 x, y = xy.split('\t')
             except ValueError:
-                gcore.fatal(line)
+                grass.fatal(line)
             outf.write('%s%s%s%s%s\n' %
                        (x.strip(), ofs, y.strip(), ofs, z.strip()))
@@ -295,9 +294,9 @@
     p.wait()
     if p.returncode != 0:
-        gcore.warning(_(
+        grass.warning(_(
             "Projection transform probably failed, please investigate"))
     main()
Modified: grass/trunk/scripts/r.blend/r.blend.py
--- grass/trunk/scripts/r.blend/r.blend.py	2016-03-29 06:29:14 UTC (rev 68180)
+++ grass/trunk/scripts/r.blend/r.blend.py	2016-03-29 08:10:14 UTC (rev 68181)
@@ -40,27 +40,28 @@
 #%end
 #% flag
 #% key: c
-#% description: Combine resulting R,G,B layers into single output map
+#% description: Combine resulting R,G,B layers into single output map
 #%end
+import sys
 import os
 import string
-import grass.script as gscript
+import grass.script as grass
 def main():
     first = options['first']
     second = options['second']
     percent = options['percent']
-    if not gscript.overwrite():
-        for ch in ['r', 'g', 'b']:
-            map = '%s.%s' % (output, ch)
-            if gscript.find_file(map, element='cell', mapset=mapset)['file']:
-                gscript.fatal(_("Raster map <%s> already exists.") % map)
+    if not grass.overwrite():
+	for ch in ['r','g','b']:
+	    map = '%s.%s' % (output, ch)
+	    if grass.find_file(map, element = 'cell', mapset = mapset)['file']:
+		grass.fatal(_("Raster map <%s> already exists.") % map)
     percent = float(percent)
     perc_inv = 100.0 - percent
@@ -68,54 +69,47 @@
     frac1 = percent / 100.0
     frac2 = perc_inv / 100.0
-    gscript.message(_("Calculating the three component maps..."))
+    grass.message(_("Calculating the three component maps..."))
-    template = string.Template("$$output.$ch = "
-                               "if(isnull($$first), $ch#$$second, "
-                               "if(isnull($$second), $ch#$$first, "
-                               "$$frac1 * $ch#$$first + "
-                               "$$frac2 * $ch#$$second))")
-    cmd = [template.substitute(ch=ch) for ch in ['r', 'g', 'b']]
+    template = string.Template("$$output.$ch = if(isnull($$first), $ch#$$second, if(isnull($$second), $ch#$$first, $$frac1 * $ch#$$first + $$frac2 * $ch#$$second))")
+    cmd = [template.substitute(ch = ch) for ch in ['r','g','b']]
     cmd = ';'.join(cmd)
-    gscript.mapcalc(cmd, output=output, first=first, second=second,
-                    frac1=frac1, frac2=frac2)
+    grass.mapcalc(cmd,
+		  output = output,
+		  first = first, second = second,
+		  frac1 = frac1, frac2 = frac2)
-        map = "%s.%s" % (output, ch)
-        gscript.run_command('r.colors', map=map, color='grey255')
-        gscript.run_command('r.support', map=map, history="",
-                            title="Color blend of %s and %s" % (first, second),
-                            description="generated by r.blend")
-                            history="r.blend %s channel." % ch)
-                            history="  %d%% of %s, %d%% of %s" %
-                                    (percent, first, perc_inv, second))
-        gscript.run_command('r.support', map=map, history="")
-        gscript.run_command('r.support', map=map, history=os.environ['CMDLINE'])
+	map = "%s.%s" % (output, ch)
+	grass.run_command('r.colors', map = map, color = 'grey255')
+	grass.run_command('r.support', map = map, history="",
+			  title = "Color blend of %s and %s" % (first, second),
+			  description = "generated by r.blend")
+			  history = "r.blend %s channel." % ch)
+			  history = "  %d%% of %s, %d%% of %s" % (percent, first, perc_inv, second))
+	grass.run_command('r.support', map = map, history = "")
+	grass.run_command('r.support', map = map, history = os.environ['CMDLINE'])
     if flags['c']:
-        gscript.run_command('r.composite', r='%s.r' % output,
-                            g='%s.g' % output, b='%s.b' % output,
-                            output=output)
+        grass.run_command('r.composite', r = '%s.r' % output,
+	    g = '%s.g' % output, b = '%s.b' % output, output = output)
-        gscript.run_command('r.support', map=output, history="",
-        gscript.run_command('r.support', map=output, history="")
-                            history=os.environ['CMDLINE'])
+	grass.run_command('r.support', map = output, history="",
+	grass.run_command('r.support', map = output, history = "")
+	grass.run_command('r.support', map = output, history = os.environ['CMDLINE'])
     else:
-        gscript.message(_("Done. Use the following command to visualize "
-                          "the result:"))
-        gscript.message(_("d.rgb r=%s.r g=%s.g b=%s.b") %
-                        (output, output, output))
+        grass.message(_("Done. Use the following command to visualize the result:"))
+        grass.message(_("d.rgb r=%s.r g=%s.g b=%s.b") % (output, output, output))
-    options, flags = gscript.parser()
     main()
Modified: grass/trunk/scripts/r.buffer.lowmem/r.buffer.lowmem.py
--- grass/trunk/scripts/r.buffer.lowmem/r.buffer.lowmem.py	2016-03-29 06:29:14 UTC (rev 68180)
+++ grass/trunk/scripts/r.buffer.lowmem/r.buffer.lowmem.py	2016-03-29 08:10:14 UTC (rev 68181)
@@ -53,18 +53,15 @@
     'feet': 0.3048,
     'miles': 1609.344,
     'nautmiles': 1852.0
 # what to do in case of user break:
 def cleanup():
     if grass.find_file(temp_src)['file']:
-        grass.run_command('g.remove', quiet=True, flags='fb', type='raster', name=temp_src)
+        grass.run_command('g.remove', quiet = True, flags = 'fb', type = 'raster', name = temp_src)
     if grass.find_file(temp_dist)['file']:
-        grass.run_command('g.remove', quiet=True, flags='fb', type='raster', name=temp_dist)
+        grass.run_command('g.remove', quiet = True, flags = 'fb', type = 'raster', name = temp_dist)
 def main():
     global temp_dist, temp_src
@@ -78,13 +75,13 @@
     temp_dist = "r.buffer.tmp.%s.dist" % tmp
     temp_src = "r.buffer.tmp.%s.src" % tmp
-    # check if input file exists
+    #check if input file exists
     if not grass.find_file(input)['file']:
         grass.fatal(_("Raster map <%s> not found") % input)
     scale = scales[units]
-    distances = distances.split(',')
+    distances  = distances.split(',')
     distances1 = [scale * float(d) for d in distances]
     distances2 = [d * d for d in distances1]
@@ -95,8 +92,8 @@
     else:
         metric = 'squared'
-    grass.run_command('r.grow.distance', input=input, metric=metric,
-                      distance=temp_dist, flags='m')
+    grass.run_command('r.grow.distance',  input = input, metric = metric,
+                      distance = temp_dist, flags = 'm')
     if zero:
         exp = "$temp_src = if($input == 0,null(),1)"
@@ -104,22 +101,22 @@
         exp = "$temp_src = if(isnull($input),null(),1)"
     grass.message(_("Extracting buffers (1/2)..."))
-    grass.mapcalc(exp, temp_src=temp_src, input=input)
+    grass.mapcalc(exp, temp_src = temp_src, input = input)
     exp = "$output = if(!isnull($input),$input,%s)"
     if metric == 'squared':
         for n, dist2 in enumerate(distances2):
-            exp %= "if($dist <= %f,%d,%%s)" % (dist2, n + 2)
+            exp %= "if($dist <= %f,%d,%%s)" % (dist2,n + 2)
     else:
         for n, dist2 in enumerate(distances1):
     exp %= "null()"
     grass.message(_("Extracting buffers (2/2)..."))
-    grass.mapcalc(exp, output=output, input=temp_src, dist=temp_dist)
+    grass.mapcalc(exp, output = output, input = temp_src, dist = temp_dist)
-    p = grass.feed_command('r.category', map=output,
-                           separator=':', rules='-')
+    p = grass.feed_command('r.category', map = output,
+                           separator=':', rules = '-')
     p.stdin.write("1:distances calculated from these locations\n")
     d0 = "0"
     for n, d in enumerate(distances):
@@ -128,11 +125,11 @@
     p.stdin.close()
     p.wait()
-    grass.run_command('r.colors', map=output, color='rainbow')
+    grass.run_command('r.colors', map = output, color = 'rainbow')
Modified: grass/trunk/scripts/r.colors.stddev/r.colors.stddev.py
--- grass/trunk/scripts/r.colors.stddev/r.colors.stddev.py	2016-03-29 06:29:14 UTC (rev 68180)
+++ grass/trunk/scripts/r.colors.stddev/r.colors.stddev.py	2016-03-29 08:10:14 UTC (rev 68181)
@@ -30,22 +30,19 @@
 #% description: Force center at zero
 #%end
+import sys
 import os
 import atexit
 def z(n):
     return mean + n * stddev
 def cleanup():
     if tmpmap:
-        gscript.run_command('g.remove', flags='f', type='raster',
-                            name=tmpmap, quiet=True)
+	grass.run_command('g.remove', flags = 'f', type = 'raster',
+                      name = tmpmap, quiet = True)
 def main():
     global tmpmap
     tmpmap = None
@@ -55,89 +52,90 @@
     bands = flags['b']
     if not zero:
-        s = gscript.read_command('r.univar', flags='g', map=map)
-        kv = gscript.parse_key_val(s)
-        global mean, stddev
-        mean = float(kv['mean'])
-        stddev = float(kv['stddev'])
+	s = grass.read_command('r.univar', flags = 'g', map = map)
+	kv = grass.parse_key_val(s)
+	global mean, stddev
+	mean = float(kv['mean'])
+	stddev = float(kv['stddev'])
-        if not bands:
-            # smooth free floating blue/white/red
-            rules = '\n'.join(["0% blue",
-                               "%f blue" % z(-2),
-                               "%f white" % mean,
-                               "%f red" % z(+2),
-                               "100% red"])
-        else:
-            # banded free floating  black/red/yellow/green/yellow/red/black
+	if not bands:
+	    # smooth free floating blue/white/red
+	    rules = '\n'.join([
+		"0% blue",
+		"%f blue"  % z(-2),
+		"%f white" % mean,
+		"%f red"   % z(+2),
+		"100% red"])
+	else:
+	    # banded free floating  black/red/yellow/green/yellow/red/black
-            # reclass with labels only works for category (integer) based maps
-            # r.reclass input="$GIS_OPT_MAP" output="${GIS_OPT_MAP}.stdevs" <<
-            # EOF
+	    # reclass with labels only works for category (integer) based maps
+            #r.reclass input="$GIS_OPT_MAP" output="${GIS_OPT_MAP}.stdevs" << EOF
-            # >3 S.D. outliers colored black so they show up in d.histogram w/ white background
-            rules = '\n'.join(["0% black",
-                               "%f black" % z(-3),
-                               "%f red" % z(-3),
-                               "%f red" % z(-2),
-                               "%f yellow" % z(-2),
-                               "%f yellow" % z(-1),
-                               "%f green" % z(-1),
-                               "%f green" % z(+1),
-                               "%f yellow" % z(+1),
-                               "%f yellow" % z(+2),
-                               "%f red" % z(+2),
-                               "%f red" % z(+3),
-                               "%f black" % z(+3),
-                               "100% black"])
+	    # >3 S.D. outliers colored black so they show up in d.histogram w/ white background
+		"0% black",
+		"%f black"  % z(-3),
+		"%f red"    % z(-3),
+		"%f red"    % z(-2),
+		"%f yellow" % z(-2),
+		"%f yellow" % z(-1),
+		"%f green"  % z(-1),
+		"%f green"  % z(+1),
+		"%f yellow" % z(+1),
+		"%f yellow" % z(+2),
+		"%f red"    % z(+2),
+		"%f red"    % z(+3),
+		"%f black"  % z(+3),
+		"100% black"])
     else:
-        tmpmap = "r_col_stdev_abs_%d" % os.getpid()
-        gscript.mapcalc("$tmp = abs($map)", tmp=tmpmap, map=map)
+	tmpmap = "r_col_stdev_abs_%d" % os.getpid()
+	grass.mapcalc("$tmp = abs($map)", tmp = tmpmap, map = map)
-        # data centered on 0  (e.g. map of deviations)
-        info = gscript.raster_info(tmpmap)
-        maxv = info['max']
+	# data centered on 0  (e.g. map of deviations)
+	info = grass.raster_info(tmpmap)
+	maxv = info['max']
-        # current r.univar truncates percentage to the base integer
-        s = gscript.read_command('r.univar', flags='eg', map=map,
-                                 percentile=[95.45,
-                                             68.2689,
-                                             99.7300])
+	# current r.univar truncates percentage to the base integer
+	s = grass.read_command('r.univar', flags = 'eg', map = map, percentile = [95.45,68.2689,99.7300])
-        stddev1 = float(kv['percentile_68_2689'])
-        stddev2 = float(kv['percentile_95_45'])
-        stddev3 = float(kv['percentile_99_73'])
+	stddev1 = float(kv['percentile_68_2689'])
+	stddev2 = float(kv['percentile_95_45'])
+	stddev3 = float(kv['percentile_99_73'])
-        if not bands:
-            # zero centered smooth blue/white/red
-            rules = '\n'.join(["%f blue" % -maxv,
-                               "%f blue" % -stddev2,
-                               "0 white",
-                               "%f red" % stddev2,
-                               "%f red" % maxv])
-        else:
-            # zero centered banded  black/red/yellow/green/yellow/red/black
+	if not bands:
+	    # zero centered smooth blue/white/red
+		"%f blue" % -maxv,
+		"%f blue" % -stddev2,
+		"0 white",
+		"%f red"  % stddev2,
+		"%f red"  % maxv])
+	else:
+	    # zero centered banded  black/red/yellow/green/yellow/red/black
-            rules = '\n'.join(["%f black" % -maxv,
-                               "%f black" % -stddev3,
-                               "%f red" % -stddev3,
-                               "%f red" % -stddev2,
-                               "%f yellow" % -stddev2,
-                               "%f yellow" % -stddev1,
-                               "%f green" % -stddev1,
-                               "%f green" % stddev1,
-                               "%f yellow" % stddev1,
-                               "%f yellow" % stddev2,
-                               "%f red" % stddev3,
-                               "%f black" % stddev3,
-                               "%f black" % maxv, ])
+		"%f black" % -maxv,
+		"%f black" % -stddev3,
+		"%f red" % -stddev3,
+		"%f red" % -stddev2,
+		"%f yellow" % -stddev2,
+		"%f yellow" % -stddev1,
+		"%f green" % -stddev1,
+		"%f green" % stddev1,
+		"%f yellow" % stddev1,
+		"%f yellow" % stddev2,
+		"%f red" % stddev3,
+		"%f black" % stddev3,
+		"%f black" % maxv,
-    gscript.write_command('r.colors', map=map, rules='-', stdin=rules)
+    grass.write_command('r.colors', map = map, rules = '-', stdin = rules)
     main()
Modified: grass/trunk/scripts/r.fillnulls/r.fillnulls.py
--- grass/trunk/scripts/r.fillnulls/r.fillnulls.py	2016-03-29 06:29:14 UTC (rev 68180)
+++ grass/trunk/scripts/r.fillnulls/r.fillnulls.py	2016-03-29 08:10:14 UTC (rev 68181)
@@ -98,19 +98,16 @@
 mapset = None
 def cleanup():
-    # delete internal mask and any TMP files:
+    #delete internal mask and any TMP files:
     if len(tmp_vmaps) > 0:
-        grass.run_command('g.remove', quiet=True, flags='fb', type='vector', name=tmp_vmaps)
+        grass.run_command('g.remove', quiet = True, flags = 'fb', type = 'vector', name = tmp_vmaps)
     if len(tmp_rmaps) > 0:
-        grass.run_command('g.remove', quiet=True, flags='fb', type='raster', name=tmp_rmaps)
+        grass.run_command('g.remove', quiet = True, flags = 'fb', type = 'raster', name = tmp_rmaps)
     if usermask and mapset:
-        if grass.find_file(usermask, mapset=mapset)['file']:
-            grass.run_command('g.rename', quiet=True, raster=(usermask, 'MASK'), overwrite=True)
+        if grass.find_file(usermask, mapset = mapset)['file']:
+            grass.run_command('g.rename', quiet = True, raster = (usermask, 'MASK'), overwrite = True)
 def main():
     global usermask, mapset, tmp_rmaps, tmp_vmaps
@@ -122,63 +119,63 @@
     edge = int(options['edge'])
     segmax = int(options['segmax'])
     npmin = int(options['npmin'])
-    quiet = True  # FIXME
+    quiet = True # FIXME
-    unique = str(os.getpid())  # Shouldn't we use temp name?
+    unique = str(os.getpid()) # Shouldn't we use temp name?
     prefix = 'r_fillnulls_%s_' % unique
-    failed_list = list()  # a list of failed holes. Caused by issues with v.surf.rst. Connected with #1813
+    failed_list = list() # a list of failed holes. Caused by issues with v.surf.rst. Connected with #1813
     # save original region
     reg_org = grass.region()
     # check if a MASK is already present
     # and remove it to not interfere with NULL lookup part
     # as we don't fill MASKed parts!
-    if grass.find_file('MASK', mapset=mapset)['file']:
+    if grass.find_file('MASK', mapset = mapset)['file']:
         usermask = "usermask_mask." + unique
         grass.message(_("A user raster mask (MASK) is present. Saving it..."))
-        grass.run_command('g.rename', quiet=quiet, raster=('MASK', usermask))
+        grass.run_command('g.rename', quiet = quiet, raster = ('MASK',usermask))
-    # check if method is rst to use v.surf.rst
+    #check if method is rst to use v.surf.rst
     if method == 'rst':
         # idea: filter all NULLS and grow that area(s) by 3 pixel, then
         # interpolate from these surrounding 3 pixel edge
         filling = prefix + 'filled'
         grass.use_temp_region()
-        grass.run_command('g.region', align=input, quiet=quiet)
+        grass.run_command('g.region', align = input, quiet = quiet)
         region = grass.region()
         ns_res = region['nsres']
         ew_res = region['ewres']
         grass.message(_("Using RST interpolation..."))
         grass.message(_("Locating and isolating NULL areas..."))
         # creating binary (0/1) map
         if usermask:
             grass.message(_("Skipping masked raster parts"))
             grass.mapcalc("$tmp1 = if(isnull($input) && !($mask == 0 || isnull($mask)),1,null())",
-                          tmp1=prefix + 'nulls', input=input, mask=usermask)
+                tmp1 = prefix + 'nulls', input = input, mask = usermask)
         else:
             grass.mapcalc("$tmp1 = if(isnull($input),1,null())",
-                          tmp1=prefix + 'nulls', input=input)
+                tmp1 = prefix + 'nulls', input = input)
         tmp_rmaps.append(prefix + 'nulls')
         # restoring user's mask, if present
         # to ignore MASKed original values
         if usermask:
             grass.message(_("Restoring user mask (MASK)..."))
             try:
-                grass.run_command('g.rename', quiet=quiet, raster=(usermask, 'MASK'))
+                grass.run_command('g.rename', quiet=quiet, raster = (usermask, 'MASK'))
             except CalledModuleError:
                 grass.warning(_("Failed to restore user MASK!"))
             usermask = None
         # grow identified holes by X pixels
         grass.message(_("Growing NULL areas"))
         tmp_rmaps.append(prefix + 'grown')
@@ -193,21 +190,15 @@
         grass.message(_("Assigning IDs to NULL areas"))
         tmp_rmaps.append(prefix + 'clumped')
         try:
-                'r.clump',
-                input=prefix +
-                'grown',
-                output=prefix +
-                'clumped',
-                quiet=quiet)
+            grass.run_command('r.clump', input=prefix + 'grown', output=prefix + 'clumped', quiet=quiet)
             grass.fatal(_("abandoned. Removing temporary map, restoring user mask if needed:"))
         # get a list of unique hole cat's
         grass.mapcalc("$out = if(isnull($inp), null(), $clumped)",
-                      out=prefix + 'holes', inp=prefix + 'nulls', clumped=prefix + 'clumped')
+                        out = prefix + 'holes', inp = prefix + 'nulls', clumped = prefix + 'clumped')
         tmp_rmaps.append(prefix + 'holes')
         # use new IDs to identify holes
         try:
             grass.run_command('r.to.vect', flags='v',
@@ -216,26 +207,20 @@
         except:
             grass.fatal(_("abandoned. Removing temporary maps, restoring user mask if needed:"))
         tmp_vmaps.append(prefix + 'holes')
         cats_file_name = grass.tempfile(False)
-            'v.db.select',
-            flags='c',
-            map=prefix + 'holes',
-            columns='cat',
-            file=cats_file_name,
-            quiet=quiet)
+        grass.run_command('v.db.select', flags = 'c', map = prefix + 'holes', columns = 'cat', file = cats_file_name, quiet = quiet)
         cat_list = list()
         cats_file = file(cats_file_name)
         for line in cats_file:
             cat_list.append(line.rstrip('\n'))
         cats_file.close()
         os.remove(cats_file_name)
         if len(cat_list) < 1:
             grass.fatal(_("Input map has no holes. Check region settings."))
         # GTC Hole is NULL area in a raster map
         grass.message(_("Processing %d map holes") % len(cat_list))
         first = True
@@ -253,20 +238,19 @@
             tmp_vmaps.append(holename + '_pol')
-            # zoom to specific hole with a buffer of two cells around the hole to
-            # remove rest of data
+            # zoom to specific hole with a buffer of two cells around the hole to remove rest of data
             try:
-                                  vector=holename + '_pol', align=input,
-                                  w='w-%d' % (edge * 2 * ew_res),
-                                  e='e+%d' % (edge * 2 * ew_res),
-                                  n='n+%d' % (edge * 2 * ns_res),
-                                  s='s-%d' % (edge * 2 * ns_res),
+                                  vector=holename + '_pol', align=input,
+                                  w = 'w-%d' % (edge * 2 * ew_res),
+                                  e = 'e+%d' % (edge * 2 * ew_res),
+                                  n = 'n+%d' % (edge * 2 * ns_res),
+                                  s = 's-%d' % (edge * 2 * ns_res),
                                   quiet=quiet)
             # remove temporary map to not overfill disk
             try:
                 grass.run_command('g.remove', flags='fb', type='vector',
@@ -274,29 +258,29 @@
             tmp_vmaps.remove(holename + '_pol')
             # copy only data around hole
             grass.mapcalc("$out = if($inp == $catn, $inp, null())",
-                          out=holename, inp=prefix + 'holes', catn=cat)
+                            out = holename, inp = prefix + 'holes', catn = cat)
             tmp_rmaps.append(holename)
-            # If here loop is split into two, next part of loop can be run in parallel
+            # If here loop is split into two, next part of loop can be run in parallel
             # (except final result patching)
             # Downside - on large maps such approach causes large disk usage
             # grow hole border to get it's edge area
             tmp_rmaps.append(holename + '_grown')
             try:
                 grass.run_command('r.grow', input=holename, radius=edge + 0.01,
-                                  old=-1, out=holename + '_grown', quiet=quiet)
+                             old=-1, out=holename + '_grown', quiet=quiet)
             # no idea why r.grow old=-1 doesn't replace existing values with NULL
-            grass.mapcalc("$out = if($inp == -1, null(), $dem)",
-                          out=holename + '_edges', inp=holename + '_grown', dem=input)
+            grass.mapcalc("$out = if($inp == -1, null(), $dem)",
+                            out = holename + '_edges', inp = holename + '_grown', dem = input)
             tmp_rmaps.append(holename + '_edges')
             # convert to points for interpolation
             tmp_vmaps.append(holename)
             try:
@@ -305,32 +289,32 @@
                                   type='point', flags='z', quiet=quiet)
             # count number of points to control segmax parameter for interpolation:
-            pointsnumber = grass.vector_info_topo(map=holename)['points']
+            pointsnumber = grass.vector_info_topo(map = holename)['points']
             grass.verbose(_("Interpolating %d points") % pointsnumber)
             if pointsnumber < 2:
                 grass.verbose(_("No points to interpolate"))
                 failed_list.append(holename)
                 continue
             # Avoid v.surf.rst warnings
             if pointsnumber < segmax:
                 npmin = pointsnumber + 1
                 segmax = pointsnumber
             # launch v.surf.rst
             tmp_rmaps.append(holename + '_dem')
             try:
                 grass.run_command('v.surf.rst', quiet=quiet,
                                   input=holename, elev=holename + '_dem',
-                                  tension=tension, smooth=smooth,
+                                  tension=tension, smooth=smooth,
                                   segmax=segmax, npmin=npmin)
                 grass.fatal(_("Failed to fill hole %s") % cat)
             # v.surf.rst sometimes fails with exit code 0
             # related bug #1813
             if not grass.find_file(holename + '_dem')['file']:
@@ -342,40 +326,30 @@
                     tmp_vmaps.remove(holename)
                 except:
                     pass
-                grass.warning(
-                    _("Filling has failed silently. Leaving temporary maps with prefix <%s> for debugging.") %
-                    holename)
+                grass.warning(_("Filling has failed silently. Leaving temporary maps with prefix <%s> for debugging.") % holename)
                 continue
             # append hole result to interpolated version later used to patch into original DEM
             if first:
                 tmp_rmaps.append(filling)
-                grass.run_command('g.region', align=input, raster=holename + '_dem', quiet=quiet)
-                grass.mapcalc("$out = if(isnull($inp), null(), $dem)",
-                              out=filling, inp=holename, dem=holename + '_dem')
+                grass.run_command('g.region', align = input, raster = holename + '_dem', quiet = quiet)
+                grass.mapcalc("$out = if(isnull($inp), null(), $dem)",
+                                out = filling, inp = holename, dem = holename + '_dem')
                 first = False
             else:
                 tmp_rmaps.append(filling + '_tmp')
-                    'g.region', align=input, raster=(
-                        filling, holename + '_dem'), quiet=quiet)
-                grass.mapcalc(
-                    "$out = if(isnull($inp), if(isnull($fill), null(), $fill), $dem)",
-                    out=filling + '_tmp',
-                    inp=holename,
-                    dem=holename + '_dem',
-                    fill=filling)
+                grass.run_command('g.region', align = input, raster = (filling, holename + '_dem'), quiet = quiet)
+                grass.mapcalc("$out = if(isnull($inp), if(isnull($fill), null(), $fill), $dem)",
+                                out = filling + '_tmp', inp = holename, dem = holename + '_dem', fill = filling)
                 try:
                                       raster=(filling + '_tmp', filling),
                                       overwrite=True, quiet=quiet)
-                    grass.fatal(
-                        _("abandoned. Removing temporary maps, restoring user mask if needed:"))
-                # this map has been removed. No need for later cleanup.
-                tmp_rmaps.remove(filling + '_tmp')
+                    grass.fatal(_("abandoned. Removing temporary maps, restoring user mask if needed:"))
+                tmp_rmaps.remove(filling + '_tmp') # this map has been removed. No need for later cleanup.
             # remove temporary maps to not overfill disk
             try:
                 tmp_rmaps.remove(holename)
@@ -402,28 +376,28 @@
                                   type='vector', name=holename)
-    # check if method is different from rst to use r.resamp.bspline
+    #check if method is different from rst to use r.resamp.bspline
     if method != 'rst':
         grass.message(_("Using %s bspline interpolation") % method)
-        grass.run_command('g.region', align=input)
+        grass.run_command('g.region', align = input)
         reg = grass.region()
         # launch r.resamp.bspline
         tmp_rmaps.append(prefix + 'filled')
         if usermask:
-            grass.run_command('r.resamp.bspline', input=input, mask=usermask,
-                              output=prefix + 'filled', method=method,
-                              ew_step=3 * reg['ewres'], ns_step=3 * reg['nsres'],
-                              lambda_=0.01, flags='n')
+            grass.run_command('r.resamp.bspline', input = input, mask = usermask,
+                output = prefix + 'filled', method = method,
+                ew_step = 3 * reg['ewres'], ns_step = 3 * reg['nsres'],
+                lambda_ = 0.01, flags = 'n')
         else:
     # restoring user's mask, if present:
     if usermask:
@@ -435,13 +409,13 @@
         usermask = None
     # set region to original extents, align to input
-    grass.run_command('g.region', n=reg_org['n'], s=reg_org['s'],
-                      e=reg_org['e'], w=reg_org['w'], align=input)
+    grass.run_command('g.region', n = reg_org['n'], s = reg_org['s'],
+                    e = reg_org['e'], w = reg_org['w'], align = input)
     # patch orig and fill map
     grass.message(_("Patching fill data into NULL areas..."))
     # we can use --o here as g.parser already checks on startup
-    grass.run_command('r.patch', input=(input, prefix + 'filled'), output=output, overwrite=True)
+    grass.run_command('r.patch', input = (input,prefix + 'filled'), output = output, overwrite = True)
     # restore the real region
     grass.del_temp_region()
@@ -450,10 +424,9 @@
     if len(failed_list) > 0:
-        grass.warning(
-            _("Following holes where not filled. Temporary maps with are left in place to allow examination of unfilled holes"))
+        grass.warning(_("Following holes where not filled. Temporary maps with are left in place to allow examination of unfilled holes"))
         outlist = failed_list[0]
         for hole in failed_list[1:]:
             outlist = ', ' + outlist
Modified: grass/trunk/scripts/r.grow/r.grow.py
--- grass/trunk/scripts/r.grow/r.grow.py	2016-03-29 06:29:14 UTC (rev 68180)
+++ grass/trunk/scripts/r.grow/r.grow.py	2016-03-29 08:10:14 UTC (rev 68181)
@@ -72,10 +72,9 @@
 def cleanup():
     for map in [temp_dist, temp_val]:
         if map:
-            grass.run_command('g.remove', flags='fb', quiet=True,
-                              type='rast', name=map)
+            grass.run_command('g.remove', flags = 'fb', quiet = True,
+                              type='rast', name = map)
 def main():
     global temp_dist, temp_val
@@ -109,7 +108,7 @@
         metric = 'squared'
         radius = radius * radius
@@ -121,10 +120,10 @@
     grass.mapcalc(
         "$output = if(!isnull($input),$old,if($dist < $radius,$new,null()))",
-        output=output, input=input, radius=radius,
-        old=old, new=new, dist=temp_dist)
+        output = output, input = input, radius = radius,
+        old = old, new = new, dist = temp_dist)
-    grass.run_command('r.colors', map=output, raster=input)
+    grass.run_command('r.colors', map = output, raster = input)
Modified: grass/trunk/scripts/r.import/r.import.py
--- grass/trunk/scripts/r.import/r.import.py	2016-03-29 06:29:14 UTC (rev 68180)
+++ grass/trunk/scripts/r.import/r.import.py	2016-03-29 08:10:14 UTC (rev 68181)
@@ -161,8 +161,7 @@
         if tgtres_value <= 0:
             grass.fatal(_("Resolution value can't be smaller than 0"))
     elif tgtres == 'value':
-        grass.fatal(
-            _("Please provide the resolution for the imported dataset or change to 'estimated' resolution"))
+         grass.fatal(_("Please provide the resolution for the imported dataset or change to 'estimated' resolution"))
     grassenv = grass.gisenv()
     tgtloc = grassenv['LOCATION_NAME']
@@ -212,18 +211,14 @@
             parameters['band'] = bands
         try:
             grass.run_command('r.in.gdal', **parameters)
-            grass.verbose(
-                _("Input <%s> successfully imported without reprojection") %
-                GDALdatasource)
+            grass.verbose(_("Input <%s> successfully imported without reprojection") % GDALdatasource)
             return 0
         except CalledModuleError as e:
             grass.fatal(_("Unable to import GDAL dataset <%s>") % GDALdatasource)
     # make sure target is not xy
     if grass.parse_command('g.proj', flags='g')['name'] == 'xy_location_unprojected':
-        grass.fatal(
-            _("Coordinate reference system not available for current location <%s>") %
-            tgtloc)
+        grass.fatal(_("Coordinate reference system not available for current location <%s>") % tgtloc)
     # switch to temp location
     os.environ['GISRC'] = str(SRCGISRC)
@@ -332,9 +327,7 @@
         grass.run_command('g.remove', type='vector', name=vreg,
                           flags='f', quiet=True)
-        grass.message(
-            _("Estimated target resolution for input band <{out}>: {res}").format(
-                out=outfile, res=estres))
+        grass.message(_("Estimated target resolution for input band <{out}>: {res}").format(out=outfile, res=estres))
         if flags['e']:
             continue
@@ -347,9 +340,7 @@
             res = estres
             res = tgtres_value
-            grass.message(
-                _("Using given resolution for input band <{out}>: {res}").format(
-                    out=outfile, res=res))
+            grass.message(_("Using given resolution for input band <{out}>: {res}").format(out=outfile, res=res))
             # align to requested resolution
             grass.run_command('g.region', res=res, flags='a')
         else:
Modified: grass/trunk/scripts/r.in.aster/r.in.aster.py
--- grass/trunk/scripts/r.in.aster/r.in.aster.py	2016-03-29 06:29:14 UTC (rev 68180)
+++ grass/trunk/scripts/r.in.aster/r.in.aster.py	2016-03-29 08:10:14 UTC (rev 68181)
@@ -5,9 +5,9 @@
 # MODULE:    r_in_aster.py
 # AUTHOR(S): Michael Barton (michael.barton at asu.edu) and
 #               Glynn Clements (glynn at gclements.plus.com)
-#               Based on r.in.aster bash script for GRASS
+#               Based on r.in.aster bash script for GRASS
 #               by Michael Barton and Paul Kelly
-# PURPOSE:   Rectifies, georeferences, & imports Terra-ASTER imagery
+# PURPOSE:   Rectifies, georeferences, & imports Terra-ASTER imagery
 #               using gdalwarp
 # COPYRIGHT: (C) 2008 by the GRASS Development Team
@@ -57,16 +57,16 @@
 bands = {
     'L1A': {
-        '1': "VNIR_Band1:ImageData",
-        '2': "VNIR_Band2:ImageData",
+        '1':  "VNIR_Band1:ImageData",
+        '2':  "VNIR_Band2:ImageData",
         '3n': "VNIR_Band3N:ImageData",
         '3b': "VNIR_Band3B:ImageData",
-        '4': "SWIR_Band4:ImageData",
-        '5': "SWIR_Band5:ImageData",
-        '6': "SWIR_Band6:ImageData",
-        '7': "SWIR_Band7:ImageData",
-        '8': "SWIR_Band8:ImageData",
-        '9': "SWIR_Band9:ImageData",
+        '4':  "SWIR_Band4:ImageData",
+        '5':  "SWIR_Band5:ImageData",
+        '6':  "SWIR_Band6:ImageData",
+        '7':  "SWIR_Band7:ImageData",
+        '8':  "SWIR_Band8:ImageData",
+        '9':  "SWIR_Band9:ImageData",
         '10': "TIR_Band10:ImageData",
         '11': "TIR_Band11:ImageData",
         '12': "TIR_Band12:ImageData",
@@ -74,16 +74,16 @@
         '14': "TIR_Band14:ImageData"
     'L1B': {
-        '1': "VNIR_Swath:ImageData1",
-        '2': "VNIR_Swath:ImageData2",
+        '1':  "VNIR_Swath:ImageData1",
+        '2':  "VNIR_Swath:ImageData2",
         '3n': "VNIR_Swath:ImageData3N",
         '3b': "VNIR_Swath:ImageData3B",
-        '4': "SWIR_Swath:ImageData4",
-        '5': "SWIR_Swath:ImageData5",
-        '6': "SWIR_Swath:ImageData6",
-        '7': "SWIR_Swath:ImageData7",
-        '8': "SWIR_Swath:ImageData8",
-        '9': "SWIR_Swath:ImageData9",
+        '4':  "SWIR_Swath:ImageData4",
+        '5':  "SWIR_Swath:ImageData5",
+        '6':  "SWIR_Swath:ImageData6",
+        '7':  "SWIR_Swath:ImageData7",
+        '8':  "SWIR_Swath:ImageData8",
+        '9':  "SWIR_Swath:ImageData9",
         '10': "TIR_Swath:ImageData10",
         '11': "TIR_Swath:ImageData11",
         '12': "TIR_Swath:ImageData12",
@@ -92,35 +92,35 @@
 def main():
     input = options['input']
     proctype = options['proctype']
     band = options['band']
-    # check whether gdalwarp is in path and executable
+    #check whether gdalwarp is in path and executable
     if not grass.find_program('gdalwarp', '--help'):
         grass.fatal(_("gdalwarp is not in the path and executable"))
-    # create temporary file to hold gdalwarp output before importing to GRASS
-    tempfile = grass.read_command("g.tempfile", pid=os.getpid()).strip() + '.tif'
+    #create temporary file to hold gdalwarp output before importing to GRASS
+    tempfile = grass.read_command("g.tempfile", pid = os.getpid()).strip() + '.tif'
-    # get projection information for current GRASS location
-    proj = grass.read_command('g.proj', flags='jf').strip()
+    #get projection information for current GRASS location
+    proj = grass.read_command('g.proj', flags = 'jf').strip()
-    # currently only runs in projected location
+    #currently only runs in projected location
     if "XY location" in proj:
-        grass.fatal(_("This module needs to be run in a projected location (found: %s)") % proj)
+      grass.fatal(_("This module needs to be run in a projected location (found: %s)") % proj)
-    # process list of bands
-    allbands = ['1', '2', '3n', '3b', '4', '5', '6', '7', '8', '9', '10', '11', '12', '13', '14']
+    #process list of bands
+    allbands = ['1','2','3n','3b','4','5','6','7','8','9','10','11','12','13','14']
     if band == 'all':
         bandlist = allbands
     else:
         bandlist = band.split(',')
-    # initialize datasets for L1A and L1B
+    #initialize datasets for L1A and L1B
     if proctype in ["L1A", "L1B"]:
         for band in bandlist:
             if band in allbands:
@@ -129,37 +129,36 @@
                 import_aster(proj, srcfile, tempfile, band)
             else:
                 grass.fatal(_('band %s is not an available Terra/ASTER band') % band)
-    elif proctype == "DEM":
+    elif proctype == "DEM":
         srcfile = input
         import_aster(proj, srcfile, tempfile, "DEM")
-    # cleanup
+    #cleanup
     grass.message(_("Cleaning up ..."))
     grass.try_remove(tempfile)
     return
 def import_aster(proj, srcfile, tempfile, band):
-    # run gdalwarp with selected options (must be in $PATH)
-    # to translate aster image to geotiff
+    #run gdalwarp with selected options (must be in $PATH)
+    #to translate aster image to geotiff
     grass.message(_("Georeferencing aster image ..."))
     grass.debug("gdalwarp -t_srs %s %s %s" % (proj, srcfile, tempfile))
     if platform.system() == "Darwin":
-        cmd = ["arch", "-i386", "gdalwarp", "-t_srs", proj, srcfile, tempfile]
+        cmd = ["arch", "-i386", "gdalwarp", "-t_srs", proj, srcfile, tempfile ]
     else:
-        cmd = ["gdalwarp", "-t_srs", proj, srcfile, tempfile]
+        cmd = ["gdalwarp", "-t_srs", proj, srcfile, tempfile ]
     p = grass.call(cmd)
     if p != 0:
-        # check to see if gdalwarp executed properly
+        #check to see if gdalwarp executed properly
         return
-    # import geotiff to GRASS
+    #import geotiff to GRASS
     grass.message(_("Importing into GRASS ..."))
     outfile = "%s.%s" % (output, band)
-    grass.run_command("r.in.gdal", input=tempfile, output=outfile)
+    grass.run_command("r.in.gdal", input = tempfile, output = outfile)
     # write cmd history
     grass.raster_history(outfile)
Modified: grass/trunk/scripts/r.in.srtm/r.in.srtm.py
--- grass/trunk/scripts/r.in.srtm/r.in.srtm.py	2016-03-29 06:29:14 UTC (rev 68180)
+++ grass/trunk/scripts/r.in.srtm/r.in.srtm.py	2016-03-29 08:10:14 UTC (rev 68181)
@@ -19,18 +19,18 @@
 # Aug 2004: modified to accept files from other directories
 #           (by H. Bowman)
 # June 2005: added flag to read in US 1-arcsec tiles (H. Bowman)
-# April 2006: links updated from ftp://e0dps01u.ecs.nasa.gov/srtm/
+# April 2006: links updated from ftp://e0dps01u.ecs.nasa.gov/srtm/
 #             to current links below
 # October 2008: Converted to Python by Glynn Clements
-# Derived from:
+#Derived from:
 # ftp://e0srp01u.ecs.nasa.gov/srtm/version1/Documentation/Notes_for_ARCInfo_users.txt
 #     (note: document was updated silently end of 2003)
 # ftp://e0srp01u.ecs.nasa.gov/srtm/version1/Documentation/SRTM_Topo.txt
 #  "3.0 Data Formats
-#  To be more exact, these coordinates refer to the geometric center of
+#  To be more exact, these coordinates refer to the geometric center of
 #  the lower left pixel, which in the case of SRTM-1 data will be about
 #  30 meters in extent."
@@ -40,7 +40,7 @@
 #- BIL uses *center* of the UL (!) pixel:
 #      http://downloads.esri.com/support/whitepapers/other_/eximgav.pdf
 #- GDAL uses *corners* of pixels for its coordinates.
 # NOTE: Even, if small difference: SRTM is referenced to EGM96, not WGS84 ellps
@@ -116,13 +116,12 @@
 def cleanup():
     if not in_temp:
-        return
+	return
     for ext in ['.bil', '.hdr', '.prj', '.hgt.zip']:
-        grass.try_remove(tile + ext)
+	grass.try_remove(tile + ext)
     os.chdir('..')
     grass.try_rmdir(tmpdir)
 def main():
     global tile, tmpdir, in_temp
@@ -132,55 +131,55 @@
     one = flags['1']
-    # are we in LatLong location?
+    #are we in LatLong location?
     if kv['+proj'] != 'longlat':
-        grass.fatal(_("This module only operates in LatLong locations"))
+	grass.fatal(_("This module only operates in LatLong locations"))
     # use these from now on:
     infile = input
     while infile[-4:].lower() in ['.hgt', '.zip']:
-        infile = infile[:-4]
+	infile = infile[:-4]
     (fdir, tile) = os.path.split(infile)
     if not output:
-        tileout = tile
+	tileout = tile
     else:
-        tileout = output
+	tileout = output
     zipfile = infile + ".hgt.zip"
     hgtfile = os.path.join(fdir, tile[:7] + ".hgt")
     if os.path.isfile(zipfile):
-        # check if we have unzip
-        if not grass.find_program('unzip'):
-            grass.fatal(_('The "unzip" program is required, please install it first'))
+        #### check if we have unzip
+	if not grass.find_program('unzip'):
+	    grass.fatal(_('The "unzip" program is required, please install it first'))
-        # really a ZIP file?
-        # make it quiet in a safe way (just in case -qq isn't portable)
-        tenv = os.environ.copy()
-        tenv['UNZIP'] = '-qq'
-        if grass.call(['unzip', '-t', zipfile], env=tenv) != 0:
-            grass.fatal(_("'%s' does not appear to be a valid zip file.") % zipfile)
+	# really a ZIP file?
+	# make it quiet in a safe way (just in case -qq isn't portable)
+	tenv = os.environ.copy()
+	tenv['UNZIP'] = '-qq'
+	if grass.call(['unzip', '-t', zipfile], env = tenv) != 0:
+	    grass.fatal(_("'%s' does not appear to be a valid zip file.") % zipfile)
-        is_zip = True
+	is_zip = True
     elif os.path.isfile(hgtfile):
-        # try and see if it's already unzipped
-        is_zip = False
+	# try and see if it's already unzipped
+	is_zip = False
     else:
-        grass.fatal(_("File '%s' or '%s' not found") % (zipfile, hgtfile))
+	grass.fatal(_("File '%s' or '%s' not found") % (zipfile, hgtfile))
-    # make a temporary directory
+    #make a temporary directory
     tmpdir = grass.tempfile()
     grass.try_remove(tmpdir)
     os.mkdir(tmpdir)
     if is_zip:
-        shutil.copyfile(zipfile, os.path.join(tmpdir, tile + ".hgt.zip"))
+	shutil.copyfile(zipfile, os.path.join(tmpdir, tile + ".hgt.zip"))
     else:
-        shutil.copyfile(hgtfile, os.path.join(tmpdir, tile + ".hgt"))
+	shutil.copyfile(hgtfile, os.path.join(tmpdir, tile + ".hgt"))
-    # change to temporary directory
+    #change to temporary directory
     os.chdir(tmpdir)
     in_temp = True
@@ -189,26 +188,26 @@
     bilfile = tile + ".bil"
     if is_zip:
-        # unzip & rename data file:
-        grass.message(_("Extracting '%s'...") % infile)
-        if grass.call(['unzip', zipfile], env=tenv) != 0:
-            grass.fatal(_("Unable to unzip file."))
+        #unzip & rename data file:
+	grass.message(_("Extracting '%s'...") % infile)
+	if grass.call(['unzip', zipfile], env = tenv) != 0:
+	    grass.fatal(_("Unable to unzip file."))
     grass.message(_("Converting input file to BIL..."))
     os.rename(hgtfile, bilfile)
     north = tile[0]
-    ll_latitude = int(tile[1:3])
+    ll_latitude  = int(tile[1:3])
     east = tile[3]
     ll_longitude = int(tile[4:7])
     # are we on the southern hemisphere? If yes, make LATITUDE negative.
     if north == "S":
-        ll_latitude *= -1
+	ll_latitude *= -1
     # are we west of Greenwich? If yes, make LONGITUDE negative.
     if east == "W":
-        ll_longitude *= -1
+	ll_longitude *= -1
     # Calculate Upper Left from Lower Left
     ulxmap = "%.1f" % ll_longitude
@@ -216,10 +215,10 @@
     ulymap = "%.1f" % (ll_latitude + 1)
     if not one:
-        tmpl = tmpl3sec
+	tmpl = tmpl3sec
     else:
-        grass.message(_("Attempting to import 1-arcsec data."))
-        tmpl = tmpl1sec
+	grass.message(_("Attempting to import 1-arcsec data."))
+	tmpl = tmpl1sec
     header = tmpl % (ulxmap, ulymap)
     hdrfile = tile + '.hdr'
@@ -227,7 +226,7 @@
     outf.write(header)
     outf.close()
-    # create prj file: To be precise, we would need EGS96! But who really cares...
+    #create prj file: To be precise, we would need EGS96! But who really cares...
     prjfile = tile + '.prj'
     outf = file(prjfile, 'w')
     outf.write(proj)
@@ -239,7 +238,7 @@
         grass.fatal(_("Unable to import data"))
     # nice color table
-    grass.run_command('r.colors', map=tileout, color='srtm')
+    grass.run_command('r.colors', map = tileout, color = 'srtm')
     grass.raster_history(tileout)
Modified: grass/trunk/scripts/r.in.wms/r.in.wms.py
--- grass/trunk/scripts/r.in.wms/r.in.wms.py	2016-03-29 06:29:14 UTC (rev 68180)
+++ grass/trunk/scripts/r.in.wms/r.in.wms.py	2016-03-29 08:10:14 UTC (rev 68181)
@@ -58,8 +58,8 @@
 #%option
 #% key: srs
 #% type: integer
-#% description: EPSG code of requested source projection
-#% answer:4326
+#% description: EPSG code of requested source projection
+#% answer:4326
 #% guisection: Request
 #%end
@@ -178,31 +178,29 @@
 def GetRegionParams(opt_region):
-    # set region
+    # set region
     if opt_region:
         reg_spl = opt_region.strip().split('@', 1)
         reg_mapset = '.'
         if len(reg_spl) > 1:
             reg_mapset = reg_spl[1]
-        if not grass.find_file(name=reg_spl[0], element='windows', mapset=reg_mapset)['name']:
-            grass.fatal(_("Region <%s> not found") % opt_region)
+        if not grass.find_file(name = reg_spl[0], element = 'windows', mapset = reg_mapset)['name']:
+             grass.fatal(_("Region <%s> not found") % opt_region)
     if opt_region:
         s = grass.read_command('g.region',
-                               quiet=True,
-                               flags='ug',
-                               region=opt_region)
-        region_params = grass.parse_key_val(s, val_type=float)
+                                quiet = True,
+                                flags = 'ug',
+                                region = opt_region)
+        region_params = grass.parse_key_val(s, val_type = float)
     else:
         region_params = grass.region()
     return region_params
 def main():
     if 'GRASS' in options['driver']:
@@ -213,7 +211,7 @@
         grass.debug("Using GDAL WMS driver")
         from wms_gdal_drv import WMSGdalDrv
         wms = WMSGdalDrv()
     if flags['c']:
         wms.GetCapabilities(options)
     else:
Modified: grass/trunk/scripts/r.in.wms/srs.py
--- grass/trunk/scripts/r.in.wms/srs.py	2016-03-29 06:29:14 UTC (rev 68180)
+++ grass/trunk/scripts/r.in.wms/srs.py	2016-03-29 08:10:14 UTC (rev 68181)
@@ -1,5 +1,5 @@
- at brief WMS, WMTS and NASA OnEarth drivers implemented in GRASS using GDAL Python bindings.
+ at brief WMS, WMTS and NASA OnEarth drivers implemented in GRASS using GDAL Python bindings.
 List of classes:
  - srs.py::Srs
@@ -32,7 +32,6 @@
           * urn:ogc:def:crs:EPSG:4326
         :param string axisorder: Force / override axisorder ('xy' or 'yx')
     def __init__(self, srs):
         self.id = srs
         self.naming_authority = None
@@ -46,7 +45,7 @@
         values = self.id.split(':')
-        if self.id.find('/def/crs/') != -1:  # URI Style 1
+        if self.id.find('/def/crs/') != -1: # URI Style 1
             self.encoding = "uri"
             vals = self.id.split('/')
             self.authority = vals[5].upper()
@@ -85,7 +84,7 @@
             self.code = int(values[1])
         if self.code in axisorder_yx:
-            self.axisorder = 'yx'
+                self.axisorder = 'yx'
     def getcode(self):
         """Create for example "EPSG:4326" string and return back
@@ -102,10 +101,10 @@
         return 'urn:%s:def:crs:%s:%s:%s' % (
-            (self.naming_authority and self.naming_authority or "ogc"),
-            (self.authority or ""),
-            (self.version or ""),
-            (self.code or ""))
+                    (self.naming_authority and self.naming_authority or "ogc"),
+                                    (self.authority or ""),
+                                    (self.version or ""),
+                                    (self.code or ""))
 axisorder_yx = frozenset([
     4326,
Modified: grass/trunk/scripts/r.in.wms/wms_base.py
--- grass/trunk/scripts/r.in.wms/wms_base.py	2016-03-29 06:29:14 UTC (rev 68180)
+++ grass/trunk/scripts/r.in.wms/wms_base.py	2016-03-29 08:10:14 UTC (rev 68181)
@@ -1,5 +1,5 @@
- at brief Preparation of parameters for drivers, which download it, and managing downloaded data.
+ at brief Preparation of parameters for drivers, which download it, and managing downloaded data.
 List of classes:
  - wms_base::WMSBase
@@ -26,32 +26,31 @@
 class WMSBase:
     def __init__(self):
         # these variables are information for destructor
         self.temp_files_to_cleanup = []
         self.params = {}
-        self.tile_size = {'bbox': None}
+        self.tile_size = {'bbox' : None}
         self.temp_map = None
         self.temp_warpmap = None
     def __del__(self):
         # tries to remove temporary files, all files should be
         # removed before, implemented just in case of unexpected
         # stop of module
         for temp_file in self.temp_files_to_cleanup:
             grass.try_remove(temp_file)
     def _debug(self, fn, msg):
         grass.debug("%s.%s: %s" %
                     (self.__class__.__name__, fn, msg))
     def _initializeParameters(self, options, flags):
         self._debug("_initialize_parameters", "started")
         # initialization of module parameters (options, flags)
         self.params['driver'] = options['driver']
         drv_info = WMSDriversInfo()
@@ -69,49 +68,46 @@
         if self.flags['o']:
             self.params['transparent'] = 'FALSE'
         else:
-            self.params['transparent'] = 'TRUE'
+            self.params['transparent'] = 'TRUE'
         for key in ['password', 'username', 'urlparams']:
-            self.params[key] = options[key]
+            self.params[key] = options[key]
         if (self.params ['password'] and self.params ['username'] == '') or \
-           (self.params['password'] == '' and self.params['username']):
-            grass.fatal(_("Please insert both %s and %s parameters or none of them." %
-                          ('password', 'username')))
+           (self.params ['password'] == '' and self.params ['username']):
+                grass.fatal(_("Please insert both %s and %s parameters or none of them." % ('password', 'username')))
         self.params['bgcolor'] = options['bgcolor'].strip()
         if options['format'] == "jpeg" and \
            not 'format' in driver_props['ignored_params']:
             if not flags['o'] and \
-                    'WMS' in self.params['driver']:
+              'WMS' in self.params['driver']:
                 grass.warning(_("JPEG format does not support transparency"))
         self.params['format'] = drv_info.GetFormat(options['format'])
         if not self.params['format']:
             self.params['format'] = self.params['format']
-        # TODO: get srs from Tile Service file in OnEarth_GRASS driver
+        #TODO: get srs from Tile Service file in OnEarth_GRASS driver
         self.params['srs'] = int(options['srs'])
-        if self.params['srs'] <= 0 and not 'srs' in driver_props['ignored_params']:
+        if self.params['srs'] <= 0 and  not 'srs' in driver_props['ignored_params']:
             grass.fatal(_("Invalid EPSG code %d") % self.params['srs'])
-        self.params['wms_version'] = options['wms_version']
+        self.params['wms_version'] = options['wms_version']
         if "CRS" in GetSRSParamVal(self.params['srs']) and self.params['wms_version'] == "1.1.1":
             self.params['wms_version'] = "1.3.0"
-            grass.warning(
-                _("WMS version <1.3.0> will be used, because version <1.1.1> does not support <%s>projection") %
-                GetSRSParamVal(
-                    self.params['srs']))
+            grass.warning(_("WMS version <1.3.0> will be used, because version <1.1.1> does not support <%s>projection")
+                            % GetSRSParamVal(self.params['srs']))
         if self.params['wms_version'] == "1.3.0":
             self.params['proj_name'] = "CRS"
         else:
             self.params['proj_name'] = "SRS"
         # read projection info
-        self.proj_location = grass.read_command('g.proj',
-                                                flags='jf').rstrip('\n')
+        self.proj_location = grass.read_command('g.proj',
+                                                flags ='jf').rstrip('\n')
         self.proj_location = self._modifyProj(self.proj_location)
         if self.params['srs'] in [3857, 900913]:
@@ -120,10 +116,10 @@
             # needed to be tested on more servers
             self.proj_srs = '+proj=merc +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0 +k=1.0 +no_defs +a=6378137 +b=6378137 +nadgrids=@null +to_meter=1'
         else:
-            self.proj_srs = grass.read_command('g.proj',
-                                               flags='jf',
-                                               epsg=str(GetEpsg(self.params['srs']))).rstrip('\n')
+            self.proj_srs = grass.read_command('g.proj',
+                                               flags = 'jf',
+                                               epsg = str(GetEpsg(self.params['srs']))).rstrip('\n')
         self.proj_srs = self._modifyProj(self.proj_srs)
         if not self.proj_srs or not self.proj_location:
@@ -135,27 +131,18 @@
         maxcols = int(options['maxcols'])
         if maxcols <= min_tile_size:
             grass.fatal(_("Maxcols must be greater than 100"))
         maxrows = int(options['maxrows'])
         if maxrows <= min_tile_size:
             grass.fatal(_("Maxrows must be greater than 100"))
-        # setting optimal tile size according to maxcols and maxrows constraint
-        # and region cols and rows
-        self.tile_size['cols'] = int(
-            self.region['cols'] /
-            ceil(
-                float(maxcols)))
-        self.tile_size['rows'] = int(
-            self.region['rows'] /
-            ceil(
-                float(maxrows)))
+        # setting optimal tile size according to maxcols and maxrows constraint and region cols and rows
+        self.tile_size['cols'] = int(self.region['cols'] / ceil(self.region['cols'] / float(maxcols)))
+        self.tile_size['rows'] = int(self.region['rows'] / ceil(self.region['rows'] / float(maxrows)))
         # default format for GDAL library
         self.gdal_drv_format = "GTiff"
         self._debug("_initialize_parameters", "finished")
     def _modifyProj(self, proj):
@@ -173,34 +160,34 @@
         not_relevant_params = []
         for i_param in driver_props['ignored_params']:
-            if i_param in options and \
+            if options.has_key(i_param) and \
                options[i_param] and \
-               i_param not in ['srs', 'wms_version', 'format']:  # params with default value
-                not_relevant_params.append('<' + i_param + '>')
+               i_param not in ['srs', 'wms_version', 'format']: # params with default value
+                not_relevant_params.append('<' + i_param  + '>')
         if len(not_relevant_params) > 0:
             grass.warning(_("These parameter are ignored: %s\n\
-                             %s driver does not support the parameters." %
+                             %s driver does not support the parameters." %\
                             (','.join(not_relevant_params), options['driver'])))
         not_relevant_flags = []
         for i_flag in driver_props['ignored_flags']:
             if flags[i_flag]:
-                not_relevant_flags.append('<' + i_flag + '>')
+                not_relevant_flags.append('<' + i_flag  + '>')
         if len(not_relevant_flags) > 0:
             grass.warning(_("These flags are ignored: %s\n\
-                             %s driver does not support the flags." %
+                             %s driver does not support the flags." %\
                             (','.join(not_relevant_flags), options['driver'])))
     def GetMap(self, options, flags):
         """!Download data from WMS server."""
-        self._initializeParameters(options, flags)
+        self._initializeParameters(options, flags)
-        self.bbox = self._computeBbox()
+        self.bbox     = self._computeBbox()
         self.temp_map = self._download()
         if not self.temp_map:
@@ -209,8 +196,8 @@
         self._reprojectMap()
         return self.temp_warpmap
-    def _fetchCapabilities(self, options):
+    def _fetchCapabilities(self, options):
         """!Download capabilities from WMS server
         cap_url = options['url'].strip()
@@ -225,48 +212,46 @@
         elif 'OnEarth' in options['driver']:
             cap_url += "REQUEST=GetTileService"
         else:
-            cap_url += "SERVICE=WMS&REQUEST=GetCapabilities&VERSION=" + options['wms_version']
+            cap_url += "SERVICE=WMS&REQUEST=GetCapabilities&VERSION=" + options['wms_version']
         if options['urlparams']:
             cap_url += "&" + options['urlparams']
         grass.debug('Fetching capabilities file.\n%s' % cap_url)
         try:
             cap = self._fetchDataFromServer(cap_url, options['username'], options['password'])
         except (IOError, HTTPException) as e:
-            if isinstance(e, urllib2.HTTPError) and e.code == 401:
-                grass.fatal(
-                    _("Authorization failed to <%s> when fetching capabilities") %
-                    options['url'])
+            if urllib2.HTTPError == type(e) and e.code == 401:
+                grass.fatal(_("Authorization failed to <%s> when fetching capabilities") % options['url'])
             else:
                 msg = _("Unable to fetch capabilities from <%s>: %s") % (options['url'], e)
                 if hasattr(e, 'reason'):
                     msg += _("\nReason: ") + e.reason
                 grass.fatal(msg)
         grass.debug('Fetching capabilities OK')
         return cap
-    def _fetchDataFromServer(self, url, username=None, password=None):
+    def _fetchDataFromServer(self, url, username = None, password = None):
         """!Fetch data from server
         request = urllib2.Request(url)
         if username and password:
-            base64string = base64.encodestring('%s:%s' % (username, password)).replace('\n', '')
-            request.add_header("Authorization", "Basic %s" % base64string)
+                    base64string = base64.encodestring('%s:%s' % (username, password)).replace('\n', '')
+                    request.add_header("Authorization", "Basic %s" % base64string)
         try:
             return urllib2.urlopen(request)
         except ValueError as error:
             grass.fatal("%s" % error)
-    def GetCapabilities(self, options):
+    def GetCapabilities(self, options):
         """!Get capabilities from WMS server
-        cap = self._fetchCapabilities(options)
+        cap  = self._fetchCapabilities(options)
         capfile_output = options['capfile_output'].strip()
         # save to file
@@ -276,61 +261,61 @@
                 temp.write(cap.read())
                 temp.close()
                 return
-            except IOError as error:
+            except IOError as error:
                 grass.fatal(_("Unabble to open file '%s'.\n%s\n" % (cap_file, error)))
         # print to output
         cap_lines = cap.readlines()
-        for line in cap_lines:
+        for line in cap_lines:
             print line.rstrip()
     def _computeBbox(self):
         """!Get region extent for WMS query (bbox)
         self._debug("_computeBbox", "started")
-        bbox_region_items = {'maxy': 'n', 'miny': 's', 'maxx': 'e', 'minx': 'w'}
+        bbox_region_items = {'maxy' : 'n', 'miny' : 's', 'maxx' : 'e', 'minx' : 'w'}
         bbox = {}
-        if self.proj_srs == self.proj_location:  # TODO: do it better
+        if self.proj_srs == self.proj_location: # TODO: do it better
             for bbox_item, region_item in bbox_region_items.iteritems():
                 bbox[bbox_item] = self.region[region_item]
         # if location projection and wms query projection are
         # different, corner points of region are transformed into wms
         # projection and then bbox is created from extreme coordinates
         # of the transformed points
         else:
-            for bbox_item, region_item in bbox_region_items.iteritems():
+            for bbox_item, region_item  in bbox_region_items.iteritems():
                 bbox[bbox_item] = None
             temp_region = self._tempfile()
             try:
                 temp_region_opened = open(temp_region, 'w')
-                temp_region_opened.write("%f %f\n%f %f\n%f %f\n%f %f\n" %
-                                         (self.region['e'], self.region['n'],
-                                          self.region['w'], self.region['n'],
-                                          self.region['w'], self.region['s'],
-                                          self.region['e'], self.region['s']))
+                temp_region_opened.write("%f %f\n%f %f\n%f %f\n%f %f\n"  %\
+                                       (self.region['e'], self.region['n'],\
+                                        self.region['w'], self.region['n'],\
+                                        self.region['w'], self.region['s'],\
+                                        self.region['e'], self.region['s'] ))
             except IOError:
-                grass.fatal(_("Unable to write data into tempfile"))
-            finally:
-                temp_region_opened.close()
+                 grass.fatal(_("Unable to write data into tempfile"))
+            finally:
+                temp_region_opened.close()
-            points = grass.read_command('m.proj', flags='d',
-                                        proj_out=self.proj_srs,
-                                        proj_in=self.proj_location,
-                                        input=temp_region,
-                                        quiet=True)  # TODO: stdin
+            points = grass.read_command('m.proj', flags = 'd',
+                                        proj_out = self.proj_srs,
+                                        proj_in = self.proj_location,
+                                        input = temp_region,
+                                        quiet = True) # TODO: stdin
             grass.try_remove(temp_region)
             if not points:
                 grass.fatal(_("Unable to determine region, %s failed") % 'm.proj')
             points = points.splitlines()
             if len(points) != 4:
                 grass.fatal(_("Region definition: 4 points required"))
             for point in points:
                 try:
                     point = map(float, point.split("|"))
@@ -342,33 +327,33 @@
                     bbox['maxx'] = point[0]
                     bbox['minx'] = point[0]
                     continue
-                if bbox['maxy'] < point[1]:
+                if   bbox['maxy'] < point[1]:
                     bbox['maxy'] = point[1]
                 elif bbox['miny'] > point[1]:
                     bbox['miny'] = point[1]
-                if bbox['maxx'] < point[0]:
+                if   bbox['maxx'] < point[0]:
                 elif bbox['minx'] > point[0]:
-                    bbox['minx'] = point[0]
+                    bbox['minx'] = point[0]
         self._debug("_computeBbox", "finished -> %s" % bbox)
         # Ordering of coordinates axis of geographic coordinate
-        # systems in WMS 1.3.0 is flipped. If  self.tile_size['flip_coords'] is
+        # systems in WMS 1.3.0 is flipped. If  self.tile_size['flip_coords'] is
         # True, coords in bbox need to be flipped in WMS query.
         return bbox
-    def _reprojectMap(self):
+    def _reprojectMap(self):
         """!Reproject data  using gdalwarp if needed
         # reprojection of raster
-        if self.proj_srs != self.proj_location:  # TODO: do it better
+        if self.proj_srs != self.proj_location: # TODO: do it better
             grass.message(_("Reprojecting raster..."))
             self.temp_warpmap = grass.tempfile()
             if int(os.getenv('GRASS_VERBOSE', '2')) <= 2:
                 nuldev = file(os.devnull, 'w+')
             else:
@@ -380,7 +365,7 @@
                 gdal_method = "bilinear"
             else:
                 gdal_method = self.params['method']
             #"+proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0 +k=1.0 +units=m +nadgrids=@null +no_defs"
             # RGB rasters - alpha layer is added for cropping edges of projected raster
             try:
@@ -389,21 +374,21 @@
                                       '-s_srs', '%s' % self.proj_srs,
                                       '-t_srs', '%s' % self.proj_location,
                                       '-r', gdal_method, '-dstalpha',
-                                      self.temp_map, self.temp_warpmap], stdout=nuldev)
+                                      self.temp_map, self.temp_warpmap], stdout = nuldev)
                 # RGBA rasters
                 else:
                     ps = grass.Popen(['gdalwarp',
                                       '-r', gdal_method,
                 ps.wait()
             except OSError as e:
                 grass.fatal('%s \nThis can be caused by missing %s utility. ' % (e, 'gdalwarp'))
             if nuldev:
                 nuldev.close()
             if ps.returncode != 0:
                 grass.fatal(_('%s failed') % 'gdalwarp')
             grass.try_remove(self.temp_map)
@@ -413,28 +398,26 @@
             self.temp_files_to_cleanup.remove(self.temp_map)
     def _tempfile(self):
-        """!Create temp_file and append list self.temp_files_to_cleanup
-            with path of file
+        """!Create temp_file and append list self.temp_files_to_cleanup
+            with path of file
         @return string path to temp_file
         temp_file = grass.tempfile()
         if temp_file is None:
             grass.fatal(_("Unable to create temporary files"))
         # list of created tempfiles for destructor
         self.temp_files_to_cleanup.append(temp_file)
         return temp_file
 class GRASSImporter:
     def __init__(self, opt_output):
-        self.cleanup_mask = False
+        self.cleanup_mask   = False
         self.cleanup_layers = False
         # output map name
@@ -444,13 +427,13 @@
         # into raster named:self.opt_output + this suffix)
         self.original_mask_suffix = "_temp_MASK"
-        # check names of temporary rasters, which module may create
+        # check names of temporary rasters, which module may create
         maps = []
-        for suffix in ('.red', '.green', '.blue', '.alpha', self.original_mask_suffix):
+        for suffix in ('.red', '.green', '.blue', '.alpha', self.original_mask_suffix ):
             rast = self.opt_output + suffix
-            if grass.find_file(rast, element='cell', mapset='.')['file']:
+            if grass.find_file(rast, element = 'cell', mapset = '.')['file']:
                 maps.append(rast)
         if len(maps) != 0:
             grass.fatal(_("Please change output name, or change names of these rasters: %s, "
                           "module needs to create this temporary maps during execution.") % ",".join(maps))
@@ -464,9 +447,8 @@
                 grass.fatal(_('%s failed') % 'r.mask')
-            # restore original mask, if exists
-            if grass.find_file(self.opt_output + self.original_mask_suffix,
-                               element='cell', mapset='.')['name']:
+            # restore original mask, if exists
+            if grass.find_file(self.opt_output + self.original_mask_suffix, element = 'cell', mapset = '.' )['name']:
                 try:
                     mask_copy = self.opt_output + self.original_mask_suffix
                     grass.run_command('g.copy', quiet=True,
@@ -475,25 +457,25 @@
                     grass.fatal(_('%s failed') % 'g.copy')
         # remove temporary created rasters
-        if self.cleanup_layers:
+        if self.cleanup_layers:
             maps = []
                     maps.append(rast)
             if maps:
-                                  quiet=True,
-                                  flags='fb',
-                                  type='raster',
-                                  name=','.join(maps))
-        # delete environmental variable which overrides region
+                                  quiet = True,
+                                  flags = 'fb',
+                                  type = 'raster',
+                                  name = ','.join(maps))
+        # delete environmental variable which overrides region
         if 'GRASS_REGION' in os.environ.keys():
             os.environ.pop('GRASS_REGION')
-    def ImportMapIntoGRASS(self, raster):
+    def ImportMapIntoGRASS(self, raster):
         """!Import raster into GRASS.
         # importing temp_map into GRASS
@@ -507,20 +489,20 @@
         # information for destructor to cleanup temp_layers, created
         # with r.in.gdal
         self.cleanup_layers = True
         # setting region for full extend of imported raster
-        if grass.find_file(self.opt_output + '.red', element='cell', mapset='.')['file']:
+        if grass.find_file(self.opt_output + '.red', element = 'cell', mapset = '.')['file']:
             region_map = self.opt_output + '.red'
         else:
-        os.environ['GRASS_REGION'] = grass.region_env(rast=region_map)
+        os.environ['GRASS_REGION'] = grass.region_env(rast = region_map)
         # mask created from alpha layer, which describes real extend
         # of warped layer (may not be a rectangle), also mask contains
         # transparent parts of raster
-        if grass.find_file(self.opt_output + '.alpha', element='cell', mapset='.')['name']:
+        if grass.find_file( self.opt_output + '.alpha', element = 'cell', mapset = '.' )['name']:
             # saving current mask (if exists) into temp raster
-            if grass.find_file('MASK', element='cell', mapset='.')['name']:
+            if grass.find_file('MASK', element = 'cell', mapset = '.' )['name']:
                 try:
@@ -539,8 +521,8 @@
-        # TODO one band + alpha band?
+        #TODO one band + alpha band?
             try:
                                   quiet=True, overwrite=True,
@@ -553,9 +535,7 @@
         grass.message(_('<%s> created.') % self.opt_output)
 class WMSDriversInfo:
     def __init__(self):
         """!Provides information about driver parameters.
@@ -564,16 +544,11 @@
         self.f_labels = ["geotiff", "tiff", "png", "jpeg", "gif", "png8"]
         # form for request
-        self.formats = [
-            "image/geotiff",
-            "image/tiff",
-            "image/png",
-            "image/jpeg",
-            "image/gif",
-            "image/png8"]
+        self.formats = ["image/geotiff", "image/tiff", "image/png", "image/jpeg", "image/gif", "image/png8"]
         self.srs = ("epsg", "crs")
     def GetDrvProperties(self, driver):
         """!Get information about driver parameters.
@@ -586,11 +561,12 @@
         if 'OnEarth' in driver:
             return self._OnEarthProperties()
     def _OnEarthProperties(self):
         props = {}
         props['ignored_flags'] = ['o']
-        props['ignored_params'] = ['bgcolor', 'styles', 'capfile_output',
+        props['ignored_params'] = ['bgcolor', 'styles', 'capfile_output',
                                    'format', 'srs', 'wms_version']
         props['req_multiple_layers'] = False
@@ -619,7 +595,7 @@
         props = {}
         props['ignored_flags'] = []
         props['ignored_params'] = ['urlparams', 'bgcolor', 'capfile', 'capfile_output',
-                                   'username', 'password']
+                                    'username', 'password']
         props['req_multiple_layers'] = True
         return props
@@ -646,7 +622,8 @@
         return self.srs
-# TODO move to utils?
+#TODO move to utils?
 def GetSRSParamVal(srs):
     """!Decides whether to use CRS or EPSG prefix according to srs number.
@@ -656,12 +633,11 @@
     else:
         return "EPSG:%d" % srs
 def GetEpsg(srs):
-     @return EPSG number
+     @return EPSG number
              If srs is CRS number, return EPSG number which corresponds to CRS number.
     if srs == 84:
         return 4326
     if srs == 83:
Modified: grass/trunk/scripts/r.in.wms/wms_cap_parsers.py
--- grass/trunk/scripts/r.in.wms/wms_cap_parsers.py	2016-03-29 06:29:14 UTC (rev 68180)
+++ grass/trunk/scripts/r.in.wms/wms_cap_parsers.py	2016-03-29 08:10:14 UTC (rev 68181)
@@ -18,36 +18,32 @@
 try:
     from xml.etree.ElementTree import ParseError
-except ImportError:  # < Python 2.7
+except ImportError: # < Python 2.7
     from xml.parsers.expat import ExpatError as ParseError
 import xml.etree.ElementTree as etree
-import grass.script as grass
 class BaseCapabilitiesTree(etree.ElementTree):
     def __init__(self, cap_file):
         """!Initialize xml.etree.ElementTree
         try:
-            etree.ElementTree.__init__(self, file=cap_file)
+            etree.ElementTree.__init__(self, file = cap_file)
         except ParseError:
             raise ParseError(_("Unable to parse XML file"))
             raise ParseError(_("Unable to open XML file '%s'.\n%s\n" % (cap_file, error)))
         if self.getroot() is None:
-            raise ParseError(_("Root node was not found."))
+            raise ParseError(_("Root node was not found."))
 class WMSXMLNsHandler:
     def __init__(self, caps):
         """!Handle XML namespaces according to WMS version of capabilities.
         self.namespace = "{http://www.opengis.net/wms}"
         if caps.getroot().find("Service") is not None:
             self.use_ns = False
         elif caps.getroot().find(self.namespace + "Service") is not None:
@@ -55,7 +51,7 @@
         else:
             raise ParseError(_("Unable to parse capabilities file.\n\
                                 Tag <%s> was not found.") % "Service")
     def Ns(self, tag_name):
         """!Add namespace to tag_name according to version
@@ -63,32 +59,30 @@
             tag_name = self.namespace + tag_name
         return tag_name
 class WMSCapabilitiesTree(BaseCapabilitiesTree):
-    def __init__(self, cap_file, force_version=None):
+    def __init__(self, cap_file, force_version = None):
         """!Parses WMS capabilities file.
             If the capabilities file cannot be parsed if it raises xml.etree.ElementTree.ParseError.
-        The class manges inheritance in 'Layer' elements. Inherited elements
+        The class manges inheritance in 'Layer' elements. Inherited elements
         are added to 'Layer' element.
-        The class also removes elements which are in invalid form and are needed
+        The class also removes elements which are in invalid form and are needed
         by wxGUI capabilities dialog.
-        @param cap_file - capabilities file
+        @param cap_file - capabilities file
         @param force_version - force capabilities file version (1.1.1, 1.3.0)
         BaseCapabilitiesTree.__init__(self, cap_file)
         self.xml_ns = WMSXMLNsHandler(self)
         grass.debug('Checking WMS capabilities tree.', 4)
         if not "version" in self.getroot().attrib:
             raise ParseError(_("Missing version attribute root node "
-                               "in Capabilities XML file"))
+                                "in Capabilities XML file"))
         else:
             wms_version = self.getroot().attrib["version"]
         if wms_version == "1.3.0":
             self.proj_tag = "CRS"
         else:
@@ -108,54 +102,54 @@
     def _checkFormats(self, capability):
         """!Check if format element is defined.
         request = self._find(capability, "Request")
         get_map = self._find(request, "GetMap")
         formats = self._findall(get_map, "Format")
-    def _checkLayerTree(self, parent_layer, first=True):
+    def _checkLayerTree(self, parent_layer, first = True):
         """!Recursively check layer tree and manage inheritance in the tree
         if first:
             self._initLayer(parent_layer, None)
         layers = parent_layer.findall((self.xml_ns.Ns("Layer")))
         for l in layers:
             self._initLayer(l, parent_layer)
             self._checkLayerTree(l, False)
     def _initLayer(self, layer, parent_layer):
         """Inherit elements from parent layer
         @param layer - <Layer> element which inherits
-        @param parent_layer - <Layer> element which is inherited from
+        @param parent_layer - <Layer> element which is inherited from
         if parent_layer is not None:
-            replaced_elements = [["EX_GeographicBoundingBox", "replace"],
-                                 ["Attribution", "replace"],
-                                 ["MinScaleDenominator", "replace"],
-                                 ["MaxScaleDenominator", "replace"],
-                                 ["AuthorityURL", "add"]]
+            replaced_elements = [ ["EX_GeographicBoundingBox", "replace"],
+                                  ["Attribution", "replace"],
+                                  ["MinScaleDenominator", "replace"],
+                                  ["MaxScaleDenominator", "replace"],
+                                  ["AuthorityURL", "add"]]
             for element in replaced_elements:
                 elems = layer.findall(self.xml_ns.Ns(element[0]))
                 if len(elems) != 0 or element[1] == "add":
                     for e in parent_layer.findall(self.xml_ns.Ns(element[0])):
                         layer.append(e)
             inh_arguments = ["queryable", "cascaded", "opaque",
                              "noSubsets", "fixedWidth", "fixedHeight"]
             for attr in parent_layer.attrib:
                 if attr not in layer.attrib and attr in inh_arguments:
                     layer.attrib[attr] = parent_layer.attrib[attr]
             self._inhNotSame(self.proj_tag, "element_content", layer, parent_layer)
             self._inhNotSame("BoundingBox", "attribute", layer, parent_layer, self.proj_tag)
-            # remove invalid Styles
+            # remove invalid Styles
             styles = layer.findall(self.xml_ns.Ns('Style'))
             for s in styles:
                 s_name = s.find(self.xml_ns.Ns('Name'))
@@ -166,7 +160,7 @@
             self._inhNotSame("Style", "child_element_content", layer, parent_layer, "Name")
             self._inhNotSame("Dimension", "attribute", layer, parent_layer, "name")
-    def _inhNotSame(self, element_name, cmp_type, layer, parent_layer, add_arg=None):
+    def _inhNotSame(self, element_name, cmp_type, layer, parent_layer, add_arg = None):
         """Inherit elements which have unique values.
         @param element_name - name of inherited element
@@ -174,7 +168,7 @@
         @param cmp_type - 'child_element_content' - compared value is text of a child of the <Layer> element
         @param cmp_type - 'attribute' - compared value is text of the <Layer> element attribute
         @param add_arg - name of child element or attribute
         elem = layer.findall(self.xml_ns.Ns(element_name))
@@ -182,50 +176,50 @@
         parent_elems = []
             parent_elems = parent_layer.findall(self.xml_ns.Ns(element_name))
         for par_elem in parent_elems:
             parent_cmp_text = None
             if cmp_type == "attribute":
                 if add_arg in par_elem.attrib:
-                    parent_cmp_text = par_elem.attrib[add_arg]
+                    parent_cmp_text = par_elem.attrib[add_arg];
             elif cmp_type == "element_content":
                 parent_cmp_text = par_elem.text
             elif cmp_type == "child_element_content":
                 parent_cmp = par_elem.find(self.xml_ns.Ns(add_arg))
                 if parent_cmp is not None:
                     parent_cmp_text = parent_cmp.text
             if parent_cmp_text is None:
                 continue
             is_there = False
             for elem in elem:
                 cmp_text = None
                     if add_arg in elem.attrib:
                         cmp_text = elem.attrib[add_arg]
                     cmp_text = elem.text
                     cmp = elem.find(self.xml_ns.Ns(add_arg))
                     if cmp is not None:
                         cmp_text = cmp.text
                 if cmp_text is None or \
                    cmp_text.lower() == parent_cmp_text.lower():
                     is_there = True
                     break
             if not is_there:
                 layer.append(par_elem)
     def _find(self, etreeElement, tag):
         """!Find child element.
-            If the element is not found it raises xml.etree.ElementTree.ParseError.
+            If the element is not found it raises xml.etree.ElementTree.ParseError.
         res = etreeElement.find(self.xml_ns.Ns(tag))
@@ -237,7 +231,7 @@
     def _findall(self, etreeElement, tag):
         """!Find all children element.
-            If no element is found it raises xml.etree.ElementTree.ParseError.
+            If no element is found it raises xml.etree.ElementTree.ParseError.
         res = etreeElement.findall(self.xml_ns.Ns(tag))
@@ -257,11 +251,9 @@
         return self.xml_ns
 class WMTSXMLNsHandler:
     """!Handle XML namespaces which are used in WMTS capabilities file.
     def NsWmts(self, tag):
         """!Add namespace.
@@ -272,21 +264,19 @@
         return "{http://www.opengis.net/ows/1.1}" + tag
 class WMTSCapabilitiesTree(BaseCapabilitiesTree):
         """!Parses WMTS capabilities file.
             If the capabilities file cannot be parsed it raises xml.etree.ElementTree.ParseError.
         by wxGUI capabilities dialog or for creation of GetTile request by GRASS WMS library.
         self.xml_ns = WMTSXMLNsHandler()
         grass.debug('Checking WMTS capabilities tree.', 4)
         contents = self._find(self.getroot(), 'Contents', self.xml_ns.NsWmts)
@@ -330,8 +320,8 @@
         for t_mat in tile_mats:
             if not self._checkMat(t_mat):
-                grass.debug('Removed invalid <TileMatrix> element.', 4)
-                mat_set.remove(t_mat)
+               grass.debug('Removed invalid <TileMatrix> element.', 4)
+               mat_set.remove(t_mat)
         tile_mats = mat_set.findall(self.xml_ns.NsWmts('TileMatrix'))
         if not tile_mats:
@@ -339,12 +329,12 @@
         return True
-    def _checkMat(self, t_mat):
+    def _checkMat(self, t_mat):
         """!Check <TileMatrix>.
         def _checkElement(t_mat, e, func):
             element = t_mat.find(self.xml_ns.NsWmts(e))
-            if element is None or not element.text:
+            if element is None or not element.text:
                 return False
             try:
@@ -356,12 +346,12 @@
                 return False
             return True
-        for e, func in [['ScaleDenominator', float],
-                        ['TileWidth', int],
+        for e, func in [['ScaleDenominator', float],
+                        ['TileWidth', int],
                         ['TileHeight', int]]:
             if not _checkElement(t_mat, e, func):
                 return False
         tile_mat_id = t_mat.find(self.xml_ns.NsOws('Identifier'))
         if tile_mat_id is None or not tile_mat_id.text:
             return False
@@ -374,13 +364,13 @@
         if len(tl) < 2:
             return False
-        for t in tl:
+        for t in tl:
             try:
                 t = float(t)
             except ValueError:
                 return False
         return True
     def _checkLayer(self, layer):
         """!Check <Layer> element.
@@ -405,7 +395,7 @@
         contents = self.getroot().find(self.xml_ns.NsWmts('Contents'))
         mat_sets = contents.findall(self.xml_ns.NsWmts('TileMatrixSet'))
-        for link in mat_set_links:
+        for link in  mat_set_links:
             # <TileMatrixSetLink> does not point to existing  <TileMatrixSet>
             if not self._checkMatSetLink(link, mat_sets):
                 grass.debug('Removed invalid <TileMatrixSetLink> element.', 4)
@@ -443,7 +433,7 @@
             if not tile_mat_limits:
                 grass.debug('Removed invalid <TileMatrixSetLimits> element.', 4)
                 link.remove(tile_mat_set_limits)
         if not found:
             return False
@@ -466,9 +456,9 @@
                 return False
         return True
-    def _find(self, etreeElement, tag, ns=None):
+    def _find(self, etreeElement, tag, ns = None):
         if not ns:
             res = etreeElement.find(tag)
@@ -481,9 +471,9 @@
         return res
-    def _findall(self, etreeElement, tag, ns=None):
+    def _findall(self, etreeElement, tag, ns = None):
         if not ns:
             res = etreeElement.findall(tag)
@@ -501,17 +491,15 @@
         return self.xml_ns
 class OnEarthCapabilitiesTree(BaseCapabilitiesTree):
         """!Parse NASA OnEarth tile service file.
             If the file cannot be parsed it raises xml.etree.ElementTree.ParseError.
         by wxGUI capabilities dialog or for creation of GetMap request by GRASS WMS library.
@@ -521,7 +509,7 @@
         grass.debug('Check if OnEarth capabilities tree was finished.', 4)
         """!Recursively check layer tree.
         if first:
@@ -538,11 +526,11 @@
                 grass.debug(('Removed invalid <%s> element.' % l.tag), 4)
                 parent_layer.remove(l)
             if l.tag == 'TiledGroups':
-                self._checkLayerTree(l, False)
+               self._checkLayerTree(l, False)
@@ -557,7 +545,7 @@
         if layer.tag == 'TiledGroups':
             return True
         name = layer.find('Name')
         if name is None or not name.text:
             return False
@@ -586,7 +574,7 @@
         """!Get all urls from tile pattern.
         urls = []
-        if tile_pattern.text is not None:
+        if  tile_pattern.text is not None:
             tile_patt_lines = tile_pattern.text.split('\n')
             for line in tile_patt_lines:
@@ -597,7 +585,7 @@
     def gettilepatternurldata(self, url):
         """!Parse url string in Tile Pattern.
-        par_url = bbox = width = height = None
+        par_url = bbox = width = height = None
         bbox_idxs = self.geturlparamidxs(url, "bbox=")
         if bbox_idxs is None:
@@ -605,7 +593,7 @@
         par_url = [url[:bbox_idxs[0] - 1], url[bbox_idxs[1]:]]
-        bbox = url[bbox_idxs[0] + len('bbox='): bbox_idxs[1]]
+        bbox = url[bbox_idxs[0] + len('bbox=') : bbox_idxs[1]]
         bbox_list = bbox.split(',')
         if len(bbox_list) < 4:
             return None
@@ -620,8 +608,8 @@
             return None
         try:
-            width = int(url[width_idxs[0] + len('width='): width_idxs[1]])
-        except ValueError:
+            width = int(url[width_idxs[0] + len('width=') : width_idxs[1]])
+        except  ValueError:
             return None
         height_idxs = self.geturlparamidxs(url, "height=")
@@ -629,8 +617,8 @@
             return None
         try:
-            height = int(url[height_idxs[0] + len('height='): height_idxs[1]])
+            height = int(url[height_idxs[0] + len('height=') : height_idxs[1]])
             return None
         if height < 0 or width < 0:
@@ -642,7 +630,7 @@
         """!Find start and end index of parameter and it's value in url string
         start_i = params_str.lower().find(param_key)
-        if start_i < 0:
+        if start_i < 0:
             return None
         end_i = params_str.find("&", start_i)
         if end_i < 0:
Modified: grass/trunk/scripts/r.in.wms/wms_drv.py
--- grass/trunk/scripts/r.in.wms/wms_drv.py	2016-03-29 06:29:14 UTC (rev 68180)
+++ grass/trunk/scripts/r.in.wms/wms_drv.py	2016-03-29 08:10:14 UTC (rev 68181)
@@ -1,5 +1,5 @@
 List of classes:
  - wms_drv::WMSDrv
@@ -17,13 +17,13 @@
 import socket
+import grass.script as grass
-from time import sleep
+from time      import sleep
 try:
     from osgeo import gdal
-    from osgeo import gdalconst
+    from osgeo import gdalconst
 except:
     grass.fatal(_("Unable to load GDAL python bindings"))
@@ -35,22 +35,20 @@
 from httplib import HTTPException
 try:
 from wms_base import WMSBase, GetSRSParamVal
 from wms_cap_parsers import WMTSCapabilitiesTree, OnEarthCapabilitiesTree
 from srs import Srs
 class WMSDrv(WMSBase):
     def _download(self):
         """!Downloads data from WMS server using own driver
         @return temp_map with downloaded data
         grass.message(_("Downloading data from WMS server..."))
         if "?" in self.params["url"]:
@@ -65,29 +63,13 @@
         # initialize correct manager according to chosen OGC service
         if self.params['driver'] == 'WMTS_GRASS':
-            req_mgr = WMTSRequestMgr(
-                self.params,
-                self.bbox,
-                self.region,
-                self.proj_srs,
-                self.cap_file)
+            req_mgr = WMTSRequestMgr(self.params, self.bbox, self.region, self.proj_srs, self.cap_file)
         elif self.params['driver'] == 'WMS_GRASS':
-            req_mgr = WMSRequestMgr(
-                self.params,
-                self.bbox,
-                self.region,
-                self.tile_size,
-                self.proj_srs)
+            req_mgr = WMSRequestMgr(self.params, self.bbox, self.region, self.tile_size, self.proj_srs)
         elif self.params['driver'] == 'OnEarth_GRASS':
-            req_mgr = OnEarthRequestMgr(
-                self.params,
-                self.bbox,
-                self.region,
-                self.proj_srs,
-                self.cap_file)
+            req_mgr = OnEarthRequestMgr(self.params, self.bbox, self.region, self.proj_srs, self.cap_file)
-        # get information about size in pixels and bounding box of raster, where
-        # all tiles will be joined
+        # get information about size in pixels and bounding box of raster, where all tiles will be joined
         map_region = req_mgr.GetMapRegion()
         init = True
@@ -99,11 +81,10 @@
         while True:
             if fetch_try == 0:
-                # get url for request the tile and information for placing the tile into
-                # raster with other tiles
+                # get url for request the tile and information for placing the tile into raster with other tiles
                 tile = req_mgr.GetNextTile()
-            # if last tile has been already downloaded
+            # if last tile has been already downloaded
             if not tile:
                 break
@@ -113,22 +94,16 @@
             # the tile size and offset in pixels for placing it into raster where tiles are joined
             tile_ref = tile[1]
             grass.debug(query_url, 2)
-            try:
-                wms_data = self._fetchDataFromServer(
-                    query_url, self.params['username'],
-                    self.params['password'])
+            try:
+                wms_data = self._fetchDataFromServer(query_url, self.params['username'], self.params['password'])
-                if isinstance(e, HTTPError) and e.code == 401:
-                    grass.fatal(
-                        _("Authorization failed to '%s' when fetching data.\n%s") %
-                        (self.params['url'], str(e)))
+                if HTTPError == type(e) and e.code == 401:
+                    grass.fatal(_("Authorization failed to '%s' when fetching data.\n%s") % (self.params['url'], str(e)))
                 else:
-                    grass.fatal(
-                        _("Unable to fetch data from: '%s'\n%s") %
+                    grass.fatal(_("Unable to fetch data from: '%s'\n%s") % (self.params['url'], str(e)))
             temp_tile = self._tempfile()
             # download data into temporary file
             try:
                 temp_tile_opened = open(temp_tile, 'wb')
@@ -136,9 +111,8 @@
             except IOError as e:
                 # some servers are not happy with many subsequent requests for tiles done immediately,
                 # if immediate request was unsuccessful, try to repeat the request after 5s and 30s breaks
-                # TODO probably servers can return more kinds of errors related to this
-                # problem (not only 104)
-                if isinstance(e, socket.error) and e[0] == 104 and fetch_try < 2:
+                # TODO probably servers can return more kinds of errors related to this problem (not only 104)
+                if socket.error == type(e) and e[0] == 104 and fetch_try < 2:
                     fetch_try += 1
                     if fetch_try == 1:
@@ -146,9 +120,7 @@
                     elif fetch_try == 2:
                         sleep_time = 30
-                    grass.warning(
-                        _("Server refused to send data for a tile.\nRequest will be repeated after %d s.") %
-                        sleep_time)
+                    grass.warning(_("Server refused to send data for a tile.\nRequest will be repeated after %d s.") % sleep_time)
                     sleep(sleep_time)
                     continue
@@ -158,250 +130,226 @@
                 temp_tile_opened.close()
             fetch_try = 0
-            tile_dataset_info = gdal.Open(temp_tile, gdal.GA_ReadOnly)
+            tile_dataset_info = gdal.Open(temp_tile, gdal.GA_ReadOnly)
             if tile_dataset_info is None:
                 # print error xml returned from server
                 try:
                     error_xml_opened = open(temp_tile, 'rb')
-                    err_str = error_xml_opened.read()
+                    err_str = error_xml_opened.read()
                     grass.fatal(_("Unable to read data from tempfile.\n%s") % str(e))
                 finally:
                     error_xml_opened.close()
-                if err_str is not None:
-                    grass.fatal(_("WMS server error: %s") % err_str)
+                if  err_str is not None:
+                    grass.fatal(_("WMS server error: %s") %  err_str)
                 else:
-                    grass.fatal(_("WMS server unknown error"))
+                    grass.fatal(_("WMS server unknown error") )
             temp_tile_pct2rgb = None
             if tile_dataset_info.RasterCount == 1 and \
                tile_dataset_info.GetRasterBand(1).GetRasterColorTable() is not None:
-                # expansion of color table into bands
+                # expansion of color table into bands
                 temp_tile_pct2rgb = self._tempfile()
                 tile_dataset = self._pct2rgb(temp_tile, temp_tile_pct2rgb)
-            else:
+            else:
                 tile_dataset = tile_dataset_info
             # initialization of temp_map_dataset, where all tiles are merged
             if init:
                 temp_map = self._tempfile()
                 driver = gdal.GetDriverByName(self.gdal_drv_format)
                 metadata = driver.GetMetadata()
-                if gdal.DCAP_CREATE not in metadata or \
-                        metadata[gdal.DCAP_CREATE] == 'NO':
-                    grass.fatal(_('Driver %s does not supports Create() method') % drv_format)
+                if not metadata.has_key(gdal.DCAP_CREATE) or \
+                       metadata[gdal.DCAP_CREATE] == 'NO':
+                    grass.fatal(_('Driver %s does not supports Create() method') % drv_format)
                 self.temp_map_bands_num = tile_dataset.RasterCount
                 temp_map_dataset = driver.Create(temp_map, map_region['cols'], map_region['rows'],
-                                                 self.temp_map_bands_num,
+                                                 self.temp_map_bands_num,
                                                  tile_dataset.GetRasterBand(1).DataType)
                 init = False
             # tile is written into temp_map
             tile_to_temp_map = tile_dataset.ReadRaster(0, 0, tile_ref['sizeX'], tile_ref['sizeY'],
-                                                       tile_ref['sizeX'], tile_ref['sizeY'])
+                                                             tile_ref['sizeX'], tile_ref['sizeY'])
             temp_map_dataset.WriteRaster(tile_ref['t_cols_offset'], tile_ref['t_rows_offset'],
-                                         tile_ref['sizeX'], tile_ref['sizeY'], tile_to_temp_map)
+                                         tile_ref['sizeX'],  tile_ref['sizeY'], tile_to_temp_map)
             tile_dataset = None
             tile_dataset_info = None
             grass.try_remove(temp_tile)
-            grass.try_remove(temp_tile_pct2rgb)
+            grass.try_remove(temp_tile_pct2rgb)
         if not temp_map:
             return temp_map
         # georeferencing and setting projection of temp_map
-        projection = grass.read_command('g.proj',
-                                        flags='wf',
-                                        epsg=self.params['srs']).rstrip('\n')
+        projection = grass.read_command('g.proj',
+                                        flags = 'wf',
+                                        epsg =self.params['srs']).rstrip('\n')
         temp_map_dataset.SetProjection(projection)
         pixel_x_length = (map_region['maxx'] - map_region['minx']) / int(map_region['cols'])
         pixel_y_length = (map_region['miny'] - map_region['maxy']) / int(map_region['rows'])
-        geo_transform = [
-            map_region['minx'],
-            pixel_x_length,
-            0.0,
-            map_region['maxy'],
-            0.0,
-            pixel_y_length]
-        temp_map_dataset.SetGeoTransform(geo_transform)
+        geo_transform = [map_region['minx'] , pixel_x_length  , 0.0 , map_region['maxy'] , 0.0 , pixel_y_length]
+        temp_map_dataset.SetGeoTransform(geo_transform )
         temp_map_dataset = None
         return temp_map
     def _pct2rgb(self, src_filename, dst_filename):
-        """!Create new dataset with data in dst_filename with bands according to src_filename
+        """!Create new dataset with data in dst_filename with bands according to src_filename
         raster color table - modified code from gdal utility pct2rgb
         @return new dataset
         out_bands = 4
         band_number = 1
         # open source file
         src_ds = gdal.Open(src_filename)
         if src_ds is None:
             grass.fatal(_('Unable to open %s ' % src_filename))
         src_band = src_ds.GetRasterBand(band_number)
         # Build color table
-        lookup = [Numeric.arrayrange(256),
-                  Numeric.arrayrange(256),
-                  Numeric.ones(256) * 255]
-        ct = src_band.GetRasterColorTable()
+        lookup = [ Numeric.arrayrange(256),
+                   Numeric.arrayrange(256),
+                   Numeric.ones(256)*255 ]
+        ct = src_band.GetRasterColorTable()
         if ct is not None:
-            for i in range(min(256, ct.GetCount())):
+            for i in range(min(256,ct.GetCount())):
                 entry = ct.GetColorEntry(i)
                 for c in range(4):
                     lookup[c][i] = entry[c]
         # create the working file
         gtiff_driver = gdal.GetDriverByName(self.gdal_drv_format)
         tif_ds = gtiff_driver.Create(dst_filename,
                                      src_ds.RasterXSize, src_ds.RasterYSize, out_bands)
         # do the processing one scanline at a time
         for iY in range(src_ds.RasterYSize):
-            src_data = src_band.ReadAsArray(0, iY, src_ds.RasterXSize, 1)
+            src_data = src_band.ReadAsArray(0,iY,src_ds.RasterXSize,1)
             for iBand in range(out_bands):
                 band_lookup = lookup[iBand]
+                dst_data = Numeric.take(band_lookup,src_data)
+                tif_ds.GetRasterBand(iBand+1).WriteArray(dst_data,0,iY)
+        return tif_ds
-                dst_data = Numeric.take(band_lookup, src_data)
-                tif_ds.GetRasterBand(iBand + 1).WriteArray(dst_data, 0, iY)
-        return tif_ds
 class BaseRequestMgr:
-    """!Base class for request managers.
+    """!Base class for request managers.
     def _computeRequestData(self, bbox, tl_corner, tile_span, tile_size, mat_num_bbox):
         """!Initialize data needed for iteration through tiles. Used by WMTS_GRASS and OnEarth_GRASS drivers.
         epsilon = 1e-15
-        # request data bbox specified in row and col number
+        # request data bbox specified in row and col number
         self.t_num_bbox = {}
-        self.t_num_bbox['min_col'] = int(
-            floor((bbox['minx'] - tl_corner['minx']) / tile_span['x'] + epsilon))
-        self.t_num_bbox['max_col'] = int(
-            floor((bbox['maxx'] - tl_corner['minx']) / tile_span['x'] - epsilon))
+        self.t_num_bbox['min_col'] = int(floor((bbox['minx'] - tl_corner['minx']) / tile_span['x'] + epsilon))
+        self.t_num_bbox['max_col'] = int(floor((bbox['maxx'] - tl_corner['minx']) / tile_span['x'] - epsilon))
-        self.t_num_bbox['min_row'] = int(
-            floor((tl_corner['maxy'] - bbox['maxy']) / tile_span['y'] + epsilon))
-        self.t_num_bbox['max_row'] = int(
-            floor((tl_corner['maxy'] - bbox['miny']) / tile_span['y'] - epsilon))
+        self.t_num_bbox['min_row'] = int(floor((tl_corner['maxy'] - bbox['maxy']) / tile_span['y'] + epsilon))
+        self.t_num_bbox['max_row'] = int(floor((tl_corner['maxy'] - bbox['miny']) / tile_span['y'] - epsilon))
         # Does required bbox intersects bbox of data available on server?
         self.intersects = False
         for col in ['min_col', 'max_col']:
             for row in ['min_row', 'max_row']:
-                if (self.t_num_bbox['min_row'] <= self.t_num_bbox[row] and self.t_num_bbox[row] <= mat_num_bbox['max_row']) and (
-                        self.t_num_bbox['min_col'] <= self.t_num_bbox[col] and self.t_num_bbox[col] <= mat_num_bbox['max_col']):
+                if (self.t_num_bbox['min_row'] <= self.t_num_bbox[row] and self.t_num_bbox[row] <= mat_num_bbox['max_row']) and \
+                   (self.t_num_bbox['min_col'] <= self.t_num_bbox[col] and self.t_num_bbox[col] <= mat_num_bbox['max_col']):
                     self.intersects = True
         if not self.intersects:
             grass.warning(_('Region is out of server data extend.'))
             self.map_region = None
             return
-        # crop request bbox to server data bbox extend
+        # crop request bbox to server data bbox extend
         if self.t_num_bbox['min_col'] < (mat_num_bbox['min_col']):
-            self.t_num_bbox['min_col'] = int(mat_num_bbox['min_col'])
+            self.t_num_bbox['min_col']  = int(mat_num_bbox['min_col'])
         if self.t_num_bbox['max_col'] > (mat_num_bbox['max_col']):
-            self.t_num_bbox['max_col'] = int(mat_num_bbox['max_col'])
+            self.t_num_bbox['max_col']  = int(mat_num_bbox['max_col'])
         if self.t_num_bbox['min_row'] < (mat_num_bbox['min_row']):
-            self.t_num_bbox['min_row'] = int(mat_num_bbox['min_row'])
+            self.t_num_bbox['min_row'] = int(mat_num_bbox['min_row'])
         if self.t_num_bbox['max_row'] > (mat_num_bbox['max_row']):
-            self.t_num_bbox['max_row'] = int(mat_num_bbox['max_row'])
+            self.t_num_bbox['max_row'] = int(mat_num_bbox['max_row'])
-        grass.debug(
-            't_num_bbox: min_col:%d max_col:%d min_row:%d max_row:%d' %
-            (self.t_num_bbox['min_col'],
-             self.t_num_bbox['max_col'],
-             self.t_num_bbox['min_row'],
-             self.t_num_bbox['max_row']),
-            3)
-        num_tiles = (self.t_num_bbox['max_col'] - self.t_num_bbox['min_col'] + 1) * (
-            self.t_num_bbox['max_row'] - self.t_num_bbox['min_row'] + 1)
-        grass.message(
-            _('Fetching %d tiles with %d x %d pixel size per tile...') %
-            (num_tiles, tile_size['x'], tile_size['y']))
+        grass.debug('t_num_bbox: min_col:%d max_col:%d min_row:%d max_row:%d' % (self.t_num_bbox['min_col'], self.t_num_bbox['max_col'], self.t_num_bbox['min_row'], self.t_num_bbox['max_row']), 3)
+        num_tiles = (self.t_num_bbox['max_col'] - self.t_num_bbox['min_col'] + 1) * (self.t_num_bbox['max_row'] - self.t_num_bbox['min_row'] + 1)
+        grass.message(_('Fetching %d tiles with %d x %d pixel size per tile...') % (num_tiles, tile_size['x'], tile_size['y']))
         # georeference of raster, where tiles will be merged
         self.map_region = {}
         self.map_region['minx'] = self.t_num_bbox['min_col'] * tile_span['x'] + tl_corner['minx']
         self.map_region['maxy'] = tl_corner['maxy'] - (self.t_num_bbox['min_row']) * tile_span['y']
-        self.map_region['maxx'] = (
-            self.t_num_bbox['max_col'] + 1) * tile_span['x'] + tl_corner['minx']
-        self.map_region['miny'] = tl_corner[
-            'maxy'] - (self.t_num_bbox['max_row'] + 1) * tile_span['y']
+        self.map_region['maxx'] = (self.t_num_bbox['max_col'] + 1) * tile_span['x'] + tl_corner['minx']
+        self.map_region['miny'] = tl_corner['maxy'] - (self.t_num_bbox['max_row'] + 1) * tile_span['y']
         # size of raster, where tiles will be merged
-        self.map_region['cols'] = int(tile_size['x'] *
-                                      (self.t_num_bbox['max_col'] - self.t_num_bbox['min_col'] + 1))
-        self.map_region['rows'] = int(tile_size['y'] *
-                                      (self.t_num_bbox['max_row'] - self.t_num_bbox['min_row'] + 1))
+        self.map_region['cols'] = int(tile_size['x'] * (self.t_num_bbox['max_col'] -  self.t_num_bbox['min_col'] + 1))
+        self.map_region['rows'] = int(tile_size['y'] * (self.t_num_bbox['max_row'] -  self.t_num_bbox['min_row'] + 1))
-        # hold information about current column and row during iteration
+        # hold information about current column and row during iteration
         self.i_col = self.t_num_bbox['min_col']
-        self.i_row = self.t_num_bbox['min_row']
+        self.i_row = self.t_num_bbox['min_row']
         # bbox for first tile request
-        self.query_bbox = {
-            'minx': tl_corner['minx'],
-            'maxy': tl_corner['maxy'],
-            'maxx': tl_corner['minx'] + tile_span['x'],
-            'miny': tl_corner['maxy'] - tile_span['y'],
+        self.query_bbox = {
+                            'minx' : tl_corner['minx'],
+                            'maxy' : tl_corner['maxy'],
+                            'maxx' : tl_corner['minx'] + tile_span['x'],
+                            'miny' : tl_corner['maxy'] - tile_span['y'],
         self.tile_ref = {
-            'sizeX': tile_size['x'],
-            'sizeY': tile_size['y']
+                          'sizeX' : tile_size['x'],
+                          'sizeY' : tile_size['y']
     def _isGeoProj(self, proj):
-        """!Is it geographic projection?
-        if (proj.find("+proj=latlong") != -1 or
-                proj.find("+proj=longlat") != -1):
+        """!Is it geographic projection?
+        if (proj.find("+proj=latlong")  != -1 or \
+            proj.find("+proj=longlat")  != -1):
             return True
         return False
 class WMSRequestMgr(BaseRequestMgr):
-    def __init__(self, params, bbox, region, tile_size, proj_srs, cap_file=None):
+    def __init__(self, params, bbox, region, tile_size, proj_srs, cap_file = None):
         self.version = params['wms_version']
         self.srs_param = params['srs']
-        proj = params['proj_name'] + "=" + GetSRSParamVal(params['srs'])
-        self.url = params['url'] + ("SERVICE=WMS&REQUEST=GetMap&VERSION=%s&LAYERS=%s&WIDTH=%s&HEIGHT=%s&STYLES=%s&TRANSPARENT=%s" % (
-            params['wms_version'], params['layers'], tile_size['cols'], tile_size['rows'], params['styles'], params['transparent']))
+        proj = params['proj_name'] + "=" +  GetSRSParamVal(params['srs'])
+        self.url = params['url'] + ("SERVICE=WMS&REQUEST=GetMap&VERSION=%s&LAYERS=%s&WIDTH=%s&HEIGHT=%s&STYLES=%s&TRANSPARENT=%s" % \
+                  (params['wms_version'], params['layers'], tile_size['cols'], tile_size['rows'], params['styles'], \
+                   params['transparent']))
         if params['bgcolor']:
-            self.url += "&BGCOLOR=" + params['bgcolor']
+            self.url +=  "&BGCOLOR=" + params['bgcolor']
-        self.url += "&" + proj + "&" + "FORMAT=" + params['format']
+        self.url += "&" +proj+ "&" + "FORMAT=" + params['format']
         self.bbox = bbox
         self.proj_srs = proj_srs
@@ -410,35 +358,33 @@
         if params['urlparams'] != "":
             self.url += "&" + params['urlparams']
         cols = int(region['cols'])
         rows = int(region['rows'])
-        # computes parameters of tiles
-        self.num_tiles_x = cols / self.tile_cols
+        # computes parameters of tiles
+        self.num_tiles_x = cols / self.tile_cols
         self.last_tile_x_size = cols % self.tile_cols
-        self.tile_length_x = float(
-            self.tile_cols) / float(cols) * (self.bbox['maxx'] - self.bbox['minx'])
+        self.tile_length_x =  float(self.tile_cols) / float(cols) * (self.bbox['maxx'] - self.bbox['minx'])
         self.last_tile_x = False
         if self.last_tile_x_size != 0:
             self.last_tile_x = True
             self.num_tiles_x = self.num_tiles_x + 1
-        self.num_tiles_y = rows / self.tile_rows
+        self.num_tiles_y = rows / self.tile_rows
         self.last_tile_y_size = rows % self.tile_rows
-        self.tile_length_y = float(
-            self.tile_rows) / float(rows) * (self.bbox['maxy'] - self.bbox['miny'])
+        self.tile_length_y =  float(self.tile_rows) / float(rows) * (self.bbox['maxy'] - self.bbox['miny'])
         self.last_tile_y = False
         if self.last_tile_y_size != 0:
             self.last_tile_y = True
             self.num_tiles_y = self.num_tiles_y + 1
         self.tile_bbox = dict(self.bbox)
-        self.tile_bbox['maxx'] = self.bbox['minx'] + self.tile_length_x
+        self.tile_bbox['maxx'] = self.bbox['minx']  + self.tile_length_x
-        self.i_x = 0
+        self.i_x = 0
         self.i_y = 0
         self.map_region = self.bbox
@@ -458,14 +404,14 @@
         if self.i_x >= self.num_tiles_x:
             return None
         tile_ref['sizeX'] = self.tile_cols
         if self.i_x == self.num_tiles_x - 1 and self.last_tile_x:
             tile_ref['sizeX'] = self.last_tile_x_size
         # set bbox for tile (N, S)
         if self.i_y != 0:
-            self.tile_bbox['miny'] -= self.tile_length_y
+            self.tile_bbox['miny'] -= self.tile_length_y
             self.tile_bbox['maxy'] -= self.tile_length_y
         else:
             self.tile_bbox['maxy'] = self.bbox['maxy']
@@ -473,14 +419,10 @@
         tile_ref['sizeY'] = self.tile_rows
         if self.i_y == self.num_tiles_y - 1 and self.last_tile_y:
-            tile_ref['sizeY'] = self.last_tile_y_size
+            tile_ref['sizeY'] = self.last_tile_y_size
         query_bbox = self._getQueryBbox(self.tile_bbox, self.proj_srs, self.srs_param, self.version)
-        query_url = self.url + "&" + "BBOX=%s,%s,%s,%s" % (
-            query_bbox['minx'],
-            query_bbox['miny'],
-            query_bbox['maxx'],
-            query_bbox['maxy'])
+        query_url = self.url + "&" + "BBOX=%s,%s,%s,%s" % ( query_bbox['minx'],  query_bbox['miny'],  query_bbox['maxx'],  query_bbox['maxy'])
         tile_ref['t_cols_offset'] = int(self.tile_cols * self.i_x)
         tile_ref['t_rows_offset'] = int(self.tile_rows * self.i_y)
@@ -488,18 +430,18 @@
         if self.i_y >= self.num_tiles_y - 1:
             self.i_y = 0
             self.i_x += 1
-            # set bbox for next tile (E, W)
-            self.tile_bbox['maxx'] += self.tile_length_x
-            self.tile_bbox['minx'] += self.tile_length_x
+            # set bbox for next tile (E, W)
+            self.tile_bbox['maxx'] += self.tile_length_x
+            self.tile_bbox['minx'] += self.tile_length_x
         else:
             self.i_y += 1
         return query_url, tile_ref
     def _getQueryBbox(self, bbox, proj, srs_param, version):
-        """!Creates query bbox (used in request URL)
+        """!Creates query bbox (used in request URL)
-        Mostly bbox is not modified but if WMS standard is 1.3.0 and
+        Mostly bbox is not modified but if WMS standard is 1.3.0 and
         projection is geographic, the bbox x and y are in most cases flipped.
         # CRS:84 and CRS:83 are exception (CRS:83 and CRS:27 need to be tested)
@@ -511,14 +453,14 @@
         return bbox
     def _flipBbox(self, bbox):
         Flips bbox values between this keys:
         maxy -> maxx
         maxx -> maxy
         miny -> minx
         minx -> miny
         @return copy of bbox with flipped coordinates
         temp_bbox = dict(bbox)
         new_bbox = {}
@@ -529,10 +471,8 @@
         return new_bbox
 class WMTSRequestMgr(BaseRequestMgr):
-    def __init__(self, params, bbox, region, proj_srs, cap_file=None):
+    def __init__(self, params, bbox, region, proj_srs, cap_file = None):
         """!Initializes data needed for iteration through tiles.
@@ -554,17 +494,15 @@
         root = cap_tree.getroot()
         # get layer tile matrix sets with required projection
-        # [[TileMatrixSet, TileMatrixSetLink], ....]
-        mat_sets = self._getMatSets(root, params['layers'], params['srs'])
+        mat_sets = self._getMatSets(root, params['layers'], params['srs'])  #[[TileMatrixSet, TileMatrixSetLink], ....]
         # TODO: what if more tile matrix sets have required srs (returned more than 1)?
         mat_set = mat_sets[0][0]
         mat_set_link = mat_sets[0][1]
         params['tile_matrix_set'] = mat_set.find(self.xml_ns.NsOws('Identifier')).text
-        # find tile matrix with resolution closest and smaller to wanted resolution
-        tile_mat = self._findTileMats(mat_set.findall(
-            self.xml_ns.NsWmts('TileMatrix')), region, bbox)
+        # find tile matrix with resolution closest and smaller to wanted resolution
+        tile_mat  = self._findTileMats(mat_set.findall(self.xml_ns.NsWmts('TileMatrix')), region, bbox)
         # get extend of data available on server expressed in max/min rows and cols of tile matrix
         mat_num_bbox = self._getMatSize(tile_mat, mat_set_link)
@@ -588,8 +526,8 @@
         for layer in layers:
             layer_id = layer.find(self.xml_ns.NsOws('Identifier')).text
             if layer_id == layer_name:
-                ch_layer = layer
-                break
+                ch_layer = layer
+                break
         if ch_layer is None:
             grass.fatal(_("Layer '%s' was not found in capabilities file") % layer_name)
@@ -599,10 +537,10 @@
         suitable_mat_sets = []
         tileMatrixSets = contents.findall(self.xml_ns.NsWmts('TileMatrixSet'))
             mat_set_link_id = link.find(self.xml_ns.NsWmts('TileMatrixSet')).text
             for mat_set in tileMatrixSets:
-                mat_set_id = mat_set.find(self.xml_ns.NsOws('Identifier')).text
+                mat_set_id = mat_set.find(self.xml_ns.NsOws('Identifier')).text
                 if mat_set_id != mat_set_link_id:
                     continue
                 mat_set_srs = self._getMatSetSrs(mat_set)
@@ -610,11 +548,9 @@
                     suitable_mat_sets.append([mat_set, link])
         if not suitable_mat_sets:
-            grass.fatal(
-                _("Layer '%s' is not available with %s code.") %
-                (layer_name, "EPSG:" + str(srs)))
+            grass.fatal(_("Layer '%s' is not available with %s code.") % (layer_name,  "EPSG:" + str(srs)))
-        return suitable_mat_sets  # [[TileMatrixSet, TileMatrixSetLink], ....]
+        return suitable_mat_sets # [[TileMatrixSet, TileMatrixSetLink], ....]
     def _getMatSetSrs(self, mat_set):
@@ -622,13 +558,11 @@
     def _findTileMats(self, tile_mats, region, bbox):
         """!Find best tile matrix set for requested resolution.
         scale_dens = []
-        scale_dens.append((bbox['maxy'] - bbox['miny']) / region['rows']
-                          * self._getMetersPerUnit() / self.pixel_size)
-        scale_dens.append((bbox['maxx'] - bbox['minx']) / region['cols']
+        scale_dens.append((bbox['maxy'] - bbox['miny']) / region['rows'] * self._getMetersPerUnit()  / self.pixel_size)
+        scale_dens.append((bbox['maxx'] - bbox['minx']) / region['cols'] * self._getMetersPerUnit() / self.pixel_size)
         scale_den = min(scale_dens)
@@ -640,11 +574,11 @@
                 best_t_mat = t_mat
                 first = False
                 continue
             best_diff = best_scale_den - scale_den
             mat_diff = mat_scale_den - scale_den
             if (best_diff < mat_diff  and  mat_diff < 0) or \
-               (best_diff > mat_diff and best_diff > 0):
+               (best_diff > mat_diff  and  best_diff > 0):
                 best_t_mat = t_mat
                 best_scale_den = mat_scale_den
@@ -652,7 +586,7 @@
     def _getMetersPerUnit(self):
         """!Get coefficient which allows converting units of request projection into meters.
         if self.meters_per_unit:
             return self.meters_per_unit
@@ -665,16 +599,16 @@
                     break
             equator_perim = 2 * pi * a
             # meters per degree on equator
-            self.meters_per_unit = equator_perim / 360
+            self.meters_per_unit = equator_perim / 360
         # other units
         elif '+to_meter' in self.proj_srs:
             proj_params = self.proj_srs.split(' ')
             for param in proj_params:
                 if '+to_meter' in param:
-                    self.meters_per_unit = 1 / float(param.split('=')[1])
+                    self.meters_per_unit = 1/float(param.split('=')[1])
                     break
-        # coordinate system in meters
+        # coordinate system in meters
         else:
@@ -703,7 +637,7 @@
             limit_id = limit_tile_mat.text
             if limit_id == tile_mat_id:
-                for i in [['min_row', 'MinTileRow'], ['max_row', 'MaxTileRow'],
+                for i in [['min_row', 'MinTileRow'], ['max_row', 'MaxTileRow'], \
                           ['min_col', 'MinTileCol'], ['max_col', 'MaxTileCol']]:
                     i_tag = limit.find(self.xml_ns.NsWmts(i[1]))
@@ -717,7 +651,7 @@
     def _computeRequestData(self, tile_mat, params, bbox, mat_num_bbox, mat_set_srs):
         scale_den = float(tile_mat.find(self.xml_ns.NsWmts('ScaleDenominator')).text)
         pixel_span = scale_den * self.pixel_size / self._getMetersPerUnit()
@@ -728,10 +662,9 @@
         tl_corner['minx'] = float(tl_str[0])
         tl_corner['maxy'] = float(tl_str[1])
-        # TODO do it more generally WMS cap parser may use it in future(not needed now)???
-        s = Srs(mat_set_srs)  # NOTE not used params['srs'], it is just number, encoding needed
-        # TODO needs to be tested, tried only on
-        # http://www.landesvermessung.sachsen.de/geoserver/gwc/service/wmts?:
+        #TODO do it more generally WMS cap parser may use it in future(not needed now)???
+        s = Srs(mat_set_srs) #NOTE not used params['srs'], it is just number, encoding needed
+        # TODO needs to be tested, tried only on http://www.landesvermessung.sachsen.de/geoserver/gwc/service/wmts?:
         if s.getcode() == 'EPSG:4326' and s.encoding in ('uri', 'urn'):
             grass.warning('switch')
             (tl_corner['minx'], tl_corner['maxy']) = (tl_corner['maxy'], tl_corner['minx'])
@@ -743,42 +676,37 @@
         self.tile_size['x'] = int(tile_mat.find(self.xml_ns.NsWmts('TileWidth')).text)
         tile_span['x'] = pixel_span * self.tile_size['x']
         self.tile_size['y'] = int(tile_mat.find(self.xml_ns.NsWmts('TileHeight')).text)
         tile_span['y'] = pixel_span * self.tile_size['y']
-        self.url = params['url'] + ("SERVICE=WMTS&REQUEST=GetTile&VERSION=1.0.0&"
-                                    "LAYER=%s&STYLE=%s&FORMAT=%s&TILEMATRIXSET=%s&TILEMATRIX=%s" %
-                                    (params['layers'], params['styles'], params['format'],
-                                     params['tile_matrix_set'], tile_mat.find(self.xml_ns.NsOws('Identifier')).text))
+        self.url = params['url'] + ("SERVICE=WMTS&REQUEST=GetTile&VERSION=1.0.0&" \
+                                    "LAYER=%s&STYLE=%s&FORMAT=%s&TILEMATRIXSET=%s&TILEMATRIX=%s" % \
+                                   (params['layers'], params['styles'], params['format'],
+                                    params['tile_matrix_set'], tile_mat.find(self.xml_ns.NsOws('Identifier')).text ))
-        BaseRequestMgr._computeRequestData(
-            self, bbox, tl_corner, tile_span, self.tile_size, mat_num_bbox)
+        BaseRequestMgr._computeRequestData(self, bbox, tl_corner, tile_span, self.tile_size, mat_num_bbox)
     def GetNextTile(self):
         """!Get url for tile request from server and information for merging the tile with other tiles.
         if not self.intersects or self.i_col > self.t_num_bbox['max_col']:
-            return None
+            return None
+        query_url = self.url + "&TILECOL=%i&TILEROW=%i" % (int(self.i_col), int(self.i_row))
-        query_url = self.url + "&TILECOL=%i&TILEROW=%i" % (int(self.i_col), int(self.i_row))
+        self.tile_ref['t_cols_offset'] = int(self.tile_size['x'] * (self.i_col - self.t_num_bbox['min_col']))
+        self.tile_ref['t_rows_offset'] = int(self.tile_size['y'] * (self.i_row - self.t_num_bbox['min_row']))
-        self.tile_ref['t_cols_offset'] = int(
-            self.tile_size['x'] * (self.i_col - self.t_num_bbox['min_col']))
-        self.tile_ref['t_rows_offset'] = int(
-            self.tile_size['y'] * (self.i_row - self.t_num_bbox['min_row']))
         if self.i_row >= self.t_num_bbox['max_row']:
             self.i_col += 1
         else:
-            self.i_row += 1
+            self.i_row += 1
         return query_url, self.tile_ref
 class OnEarthRequestMgr(BaseRequestMgr):
     def __init__(self, params, bbox, region, proj_srs, tile_service):
@@ -792,8 +720,7 @@
         root = self.cap_tree.getroot()
         # parse tile service file and get needed data for making tile requests
-        url, self.tile_span, t_patt_bbox, self.tile_size = self._parseTileService(
-            root, bbox, region, params)
+        url, self.tile_span, t_patt_bbox, self.tile_size = self._parseTileService(root, bbox, region, params)
         self.url = url
         self.url[0] = params['url'] + url[0]
         # initialize data needed for iteration through tiles
@@ -810,9 +737,7 @@
         tiled_patterns = root.find('TiledPatterns')
         tile_groups = self._getAllTiledGroup(tiled_patterns)
         if not tile_groups:
-            grass.fatal(
-                _("Unable to parse tile service file. \n No tag '%s' was found.") %
-                'TiledGroup')
+            grass.fatal(_("Unable to parse tile service file. \n No tag '%s' was found.") % 'TiledGroup')
         req_group = None
         for group in tile_groups:
@@ -840,7 +765,7 @@
         tile_span = {}
         tile_span['x'] = abs(t_bbox[0] - t_bbox[2])
         tile_span['y'] = abs(t_bbox[1] - t_bbox[3])
         tile_pattern_bbox = req_group.find('LatLonBoundingBox')
         t_patt_bbox = {}
@@ -853,7 +778,7 @@
         return url, tile_span, t_patt_bbox, tile_size
-    def _getAllTiledGroup(self, parent, tiled_groups=None):
+    def _getAllTiledGroup(self, parent, tiled_groups = None):
         """!Get all 'TileGroup' elements
         if not tiled_groups:
@@ -881,8 +806,7 @@
         t_res = {}
         best_patt = None
         for pattern in group_t_patts:
-            url, t_bbox, width, height = self.cap_tree.gettilepatternurldata(pattern.text.split(
-                '\n')[0])
+            url, t_bbox, width, height = self.cap_tree.gettilepatternurldata(pattern.text.split('\n')[0])
             t_res['x'] = abs(t_bbox[0] - t_bbox[2]) / width
             t_res['y'] = abs(t_bbox[1] - t_bbox[3]) / height
@@ -892,12 +816,12 @@
                 best_patt = pattern
                 first = False
                 continue
             best_diff = best_res - res[comp_res]
             tile_diff = t_res[comp_res] - res[comp_res]
             if (best_diff < tile_diff  and  tile_diff < 0) or \
-               (best_diff > tile_diff and best_diff > 0):
+               (best_diff > tile_diff  and  best_diff > 0):
                 best_res = t_res[comp_res]
                 best_patt = pattern
@@ -905,14 +829,14 @@
         return best_patt
     def _insTimeToTilePatternUrl(self, url_params, urls):
-        """!Time can be variable in some urls in OnEarth TMS.
+        """!Time can be variable in some urls in OnEarth TMS.
             Insert requested time from 'urlparams' into the variable if any url of urls contains the variable.
         url = None
         not_sup_params = []
         url_params_list = url_params.split('&')
-        for param in url_params_list:
+        for param in  url_params_list:
             try:
                 k, v = param.split('=')
             except ValueError:
@@ -924,75 +848,63 @@
                 continue
             has_time_var = False
-            for url in urls:
+            for url in urls:
                 url_p_idxs = self.geturlparamidxs(url, k)
                 if not url_p_idxs:
                     continue
-                url_p_value = url[url_p_idxs[0] + len(k + '='): url_p_idxs[1]]
+                url_p_value = url[url_p_idxs[0] + len(k + '=') : url_p_idxs[1]]
                 if url_p_value[:2] == '${'  and \
                    url_p_value[len(url_p_value) - 1] == '}':
-                    url = url[:url_p_idxs[0]] + param + url[url_p_idxs[1]:]
-                    has_time_var = True
-                    break
+                   url = url[:url_p_idxs[0]] + param + url[url_p_idxs[1]:]
+                   has_time_var = True
+                   break
             if not has_time_var:
-                grass.warning(
-                    _("Parameter '%s' in '%s' is not variable in tile pattern url.") %
-                    (k, 'urlparams'))
+                grass.warning(_("Parameter '%s' in '%s' is not variable in tile pattern url.") % (k, 'urlparams'))
         if not_sup_params:
-            grass.warning(
-                _("%s driver supports only '%s' parameter in '%s'. Other parameters are ignored.") %
-                ('OnEarth GRASS', 'time', 'urlparams'))
+                grass.warning(_("%s driver supports only '%s' parameter in '%s'. Other parameters are ignored.") % \
+                               ('OnEarth GRASS', 'time', 'urlparams'))
         return url
     def _computeRequestData(self, bbox, t_patt_bbox, tile_span, tile_size):
         epsilon = 1e-15
         mat_num_bbox = {}
         mat_num_bbox['min_row'] = mat_num_bbox['min_col'] = 0
-        mat_num_bbox['max_row'] = floor(
-            (t_patt_bbox['maxy'] - t_patt_bbox['miny']) / tile_span['y'] + epsilon)
-        mat_num_bbox['max_col'] = floor(
-            (t_patt_bbox['maxx'] - t_patt_bbox['minx']) / tile_span['x'] + epsilon)
+        mat_num_bbox['max_row'] = floor((t_patt_bbox['maxy'] - t_patt_bbox['miny'])/ tile_span['y'] + epsilon)
+        mat_num_bbox['max_col'] = floor((t_patt_bbox['maxx'] - t_patt_bbox['minx'])/ tile_span['x'] + epsilon)
-            self,
-            bbox,
-            t_patt_bbox,
-            self.tile_span,
-            self.tile_size,
-            mat_num_bbox)
+        BaseRequestMgr._computeRequestData(self, bbox, t_patt_bbox, self.tile_span, self.tile_size, mat_num_bbox)
         if self.i_col > self.t_num_bbox['max_col']:
-            return None
+            return None
         x_offset = self.tile_span['x'] * self.i_col
         y_offset = self.tile_span['y'] * self.i_row
-        query_url = self.url[0] + "&" + "bbox=%s,%s,%s,%s" % (
-            float(self.query_bbox['minx'] + x_offset),
-            float(self.query_bbox['miny'] - y_offset),
-            float(self.query_bbox['maxx'] + x_offset),
-            float(self.query_bbox['maxy'] - y_offset)) + self.url[1]
+        query_url = self.url[0] + "&" + "bbox=%s,%s,%s,%s" % (float(self.query_bbox['minx'] + x_offset),
+                                                              float(self.query_bbox['miny'] - y_offset),
+                                                              float(self.query_bbox['maxx'] + x_offset),
+                                                              float(self.query_bbox['maxy'] - y_offset)) + self.url[1]
-            self.tile_size['y'] * (self.i_col - self.t_num_bbox['min_col']))
-            self.tile_size['x'] * (self.i_row - self.t_num_bbox['min_row']))
+        self.tile_ref['t_cols_offset'] = int(self.tile_size['y'] * (self.i_col - self.t_num_bbox['min_col']))
+        self.tile_ref['t_rows_offset'] = int(self.tile_size['x'] * (self.i_row - self.t_num_bbox['min_row']))
             self.i_col += 1
         else:
-            self.i_row += 1
+            self.i_row += 1
Modified: grass/trunk/scripts/r.in.wms/wms_gdal_drv.py
--- grass/trunk/scripts/r.in.wms/wms_gdal_drv.py	2016-03-29 06:29:14 UTC (rev 68180)
+++ grass/trunk/scripts/r.in.wms/wms_gdal_drv.py	2016-03-29 08:10:14 UTC (rev 68181)
@@ -1,5 +1,5 @@
- at brief GDAL WMS driver.
+ at brief GDAL WMS driver.
 List of classes:
  - wms_drv::NullDevice
@@ -14,7 +14,7 @@
 import os
 try:
@@ -26,133 +26,129 @@
 class NullDevice():
     def write(self, s):
         pass
 class WMSGdalDrv(WMSBase):
     def _createXML(self):
         """!Create XML for GDAL WMS driver
         @return path to XML file
         self._debug("_createXML", "started")
         gdal_wms = etree.Element("GDAL_WMS")
         service = etree.SubElement(gdal_wms, "Service")
         name = etree.Element("name")
-        service.set("name", "WMS")
+        service.set("name","WMS")
         version = etree.SubElement(service, "Version")
-        version.text = self.params['wms_version']
+        version.text =self.params['wms_version']
         server_url = etree.SubElement(service, "ServerUrl")
-        server_url.text = self.params['url']
-        srs = etree.SubElement(service, self.params['proj_name'])
+        server_url.text =self.params['url']
+        srs = etree.SubElement(service, self.params['proj_name'])
         srs.text = GetSRSParamVal(self.params['srs'])
         image_format = etree.SubElement(service, "ImageFormat")
         image_format.text = self.params['format']
         image_format = etree.SubElement(service, "Transparent")
         image_format.text = self.params['transparent']
         layers = etree.SubElement(service, "Layers")
         layers.text = self.params['layers']
         styles = etree.SubElement(service, "Styles")
         styles.text = self.params['styles']
         data_window = etree.SubElement(gdal_wms, "DataWindow")
         upper_left_x = etree.SubElement(data_window, "UpperLeftX")
-        upper_left_x.text = str(self.bbox['minx'])
+        upper_left_x.text = str(self.bbox['minx'])
         upper_left_y = etree.SubElement(data_window, "UpperLeftY")
-        upper_left_y.text = str(self.bbox['maxy'])
+        upper_left_y.text = str(self.bbox['maxy'])
         lower_right_x = etree.SubElement(data_window, "LowerRightX")
-        lower_right_x.text = str(self.bbox['maxx'])
+        lower_right_x.text = str(self.bbox['maxx'])
         lower_right_y = etree.SubElement(data_window, "LowerRightY")
         lower_right_y.text = str(self.bbox['miny'])
         size_x = etree.SubElement(data_window, "SizeX")
-        size_x.text = str(self.region['cols'])
+        size_x.text = str(self.region['cols'])
         size_y = etree.SubElement(data_window, "SizeY")
-        size_y.text = str(self.region['rows'])
+        size_y.text = str(self.region['rows'])
         # RGB + alpha
         self.temp_map_bands_num = 4
         block_size_x = etree.SubElement(gdal_wms, "BandsCount")
         block_size_x.text = str(self.temp_map_bands_num)
         block_size_x = etree.SubElement(gdal_wms, "BlockSizeX")
-        block_size_x.text = str(self.tile_size['cols'])
+        block_size_x.text = str(self.tile_size['cols'])
         block_size_y = etree.SubElement(gdal_wms, "BlockSizeY")
         block_size_y.text = str(self.tile_size['rows'])
         xml_file = self._tempfile()
         etree.ElementTree(gdal_wms).write(xml_file)
         self._debug("_createXML", "finished -> %s" % xml_file)
         return xml_file
         """!Downloads data from WMS server using GDAL WMS driver
         @return temp_map with stored downloaded data
         grass.message("Downloading data from WMS server...")
-        # GDAL WMS driver does not flip geographic coordinates
+        # GDAL WMS driver does not flip geographic coordinates
         # according to WMS standard 1.3.0.
-        if ("+proj=latlong" in self.proj_srs or
-                "+proj=longlat" in self.proj_srs) and \
-                self.params['wms_version'] == "1.3.0":
+        if ("+proj=latlong" in self.proj_srs or \
+            "+proj=longlat" in self.proj_srs) and \
+            self.params['wms_version'] == "1.3.0":
             grass.warning(_("If module will not be able to fetch the data in this " +
                             "geographic projection, \n try 'WMS_GRASS' driver or use WMS version 1.1.1."))
         self._debug("_download", "started")
+        temp_map = self._tempfile()
-        temp_map = self._tempfile()
         xml_file = self._createXML()
         wms_dataset = gdal.Open(xml_file, gdal.GA_ReadOnly)
         grass.try_remove(xml_file)
         if wms_dataset is None:
             grass.fatal(_("Unable to open GDAL WMS driver"))
         self._debug("_download", "GDAL dataset created")
         if driver is None:
             grass.fatal(_("Unable to find %s driver" % format))
-        if gdal.DCAP_CREATECOPY not in metadata or \
+        if not metadata.has_key(gdal.DCAP_CREATECOPY) or \
            metadata[gdal.DCAP_CREATECOPY] == 'NO':
             grass.fatal(_('Driver %s supports CreateCopy() method.') % self.gdal_drv_name)
         self._debug("_download", "calling GDAL CreateCopy...")
         temp_map_dataset = driver.CreateCopy(temp_map, wms_dataset, 0)
         if temp_map_dataset is None:
             grass.fatal(_("Incorrect WMS query"))
-        temp_map_dataset = None
+        temp_map_dataset  = None
         wms_dataset = None
         self._debug("_download", "finished")
         return temp_map
Modified: grass/trunk/scripts/r.mask/r.mask.py
--- grass/trunk/scripts/r.mask/r.mask.py	2016-03-29 06:29:14 UTC (rev 68180)
+++ grass/trunk/scripts/r.mask/r.mask.py	2016-03-29 08:10:14 UTC (rev 68181)
@@ -75,13 +75,12 @@
 def cleanup():
     if tmp:
-        grass.run_command('g.remove', flags='f', type='raster',
-                          name=tmp, quiet=True)
+        grass.run_command('g.remove', flags = 'f', type = 'raster',
+                          name = tmp, quiet = True)
     if tmp_hull:
-        grass.run_command('g.remove', flags='f', type='vector',
-                          name=tmp_hull, quiet=True)
+        grass.run_command('g.remove', flags = 'f', type = 'vector',
+                          name = tmp_hull, quiet = True)
 def main():
     raster = options['raster']
     maskcats = options['maskcats']
@@ -96,13 +95,13 @@
         grass.fatal(_("Either parameter <raster> ot parameter <vector> is required"))
     mapset = grass.gisenv()['MAPSET']
-    exists = bool(grass.find_file('MASK', element='cell', mapset=mapset)['file'])
+    exists = bool(grass.find_file('MASK', element = 'cell', mapset = mapset)['file'])
     if remove:
         # -> remove
         if exists:
-            grass.run_command('g.remove', flags='f', quiet=True,
-                              type='raster', name='MASK')
+            grass.run_command('g.remove', flags = 'f', quiet = True,
+                              type = 'raster', name = 'MASK')
             grass.message(_("Raster MASK removed"))
         else:
             grass.fatal(_("No existing MASK to remove"))
@@ -113,9 +112,9 @@
                 grass.fatal(_("MASK already found in current mapset. Delete first or overwrite."))
             else:
                 grass.warning(_("MASK already exists and will be overwritten"))
         if raster:
             # check if input raster exists
             if not grass.find_file(raster)['file']:
@@ -126,12 +125,7 @@
                     grass.fatal(_("The raster map <%s> must be integer (CELL type) "
                                   " in order to use the 'maskcats' parameter") % raster)
-            p = grass.feed_command(
-                'r.reclass',
-                input=raster,
-                output='MASK',
-                overwrite=True,
-                rules='-')
+            p = grass.feed_command('r.reclass', input = raster, output = 'MASK', overwrite = True, rules = '-')
             p.stdin.write("%s = 1" % maskcats)
             p.stdin.close()
             p.wait()
@@ -139,13 +133,13 @@
             vector_name = grass.find_file(vector, 'vector')['fullname']
             if not vector_name:
                 grass.fatal(_("Vector map <%s> not found") % vector)
             # parser bug?
             if len(cats) == 0:
                 cats = None
             if len(where) == 0:
                 where = None
             if grass.vector_info_topo(vector_name)['areas'] < 1:
                 grass.warning(_("No area found in vector map <%s>. "
                                 "Creating a convex hull for MASK.") % vector_name)
@@ -158,25 +152,23 @@
                                       input=vector_name, output=tmp_hull,
                                       layer=layer, cats=cats, where=where)
                 except CalledModuleError:
-                    grass.fatal(
-                        _("Unable to create a convex hull for vector map <%s>") %
-                        vector_name)
+                    grass.fatal(_("Unable to create a convex hull for vector map <%s>") % vector_name)
             else:
                 to_rast_input = vector_name
             env = os.environ.copy()
             if grass.verbosity() > 1:
                 env['GRASS_VERBOSE'] = '1'
-            grass.run_command('v.to.rast', input=to_rast_input, layer=layer,
-                              output='MASK', use='val', val='1',
-                              type='area', cats=cats, where=where, env=env)
+            grass.run_command('v.to.rast', input = to_rast_input, layer = layer,
+                              output = 'MASK', use = 'val', val = '1',
+                              type = 'area', cats = cats, where = where, env = env)
         if invert:
             global tmp
             tmp = "r_mask_%d" % os.getpid()
-            grass.run_command('g.rename', raster=('MASK', tmp), quiet=True)
+            grass.run_command('g.rename', raster = ('MASK', tmp), quiet = True)
             grass.message(_("Creating inverted raster MASK..."))
-            grass.mapcalc("MASK = if(isnull($tmp), 1, null())", tmp=tmp)
+            grass.mapcalc("MASK = if(isnull($tmp), 1, null())", tmp = tmp)
             grass.verbose(_("Inverted raster MASK created"))
         else:
             grass.verbose(_("Raster MASK created"))
Modified: grass/trunk/scripts/r.out.xyz/r.out.xyz.py
--- grass/trunk/scripts/r.out.xyz/r.out.xyz.py	2016-03-29 06:29:14 UTC (rev 68180)
+++ grass/trunk/scripts/r.out.xyz/r.out.xyz.py	2016-03-29 08:10:14 UTC (rev 68181)
@@ -37,7 +37,6 @@
 from grass.script import core as grass
 from grass.exceptions import CalledModuleError
 def main():
     # if no output filename, output to stdout
     output = options['output']
Modified: grass/trunk/scripts/r.pack/r.pack.py
--- grass/trunk/scripts/r.pack/r.pack.py	2016-03-29 06:29:14 UTC (rev 68180)
+++ grass/trunk/scripts/r.pack/r.pack.py	2016-03-29 08:10:14 UTC (rev 68181)
@@ -40,11 +40,9 @@
 from grass.script.utils import try_rmdir, try_remove
 def cleanup():
     try_rmdir(tmp)
 def main():
     infile = options['input']
     compression_off = flags['c']
@@ -56,30 +54,30 @@
         outfile_path, outfile_base = os.path.split(os.path.abspath(options['output']))
     else:
         outfile_path, outfile_base = os.path.split(os.path.abspath(infile + ".pack"))
     outfile = os.path.join(outfile_path, outfile_base)
     global tmp
     tmp = grass.tempdir()
     tmp_dir = os.path.join(tmp, infile)
     os.mkdir(tmp_dir)
     grass.debug('tmp_dir = %s' % tmp_dir)
-    gfile = grass.find_file(name=infile, element='cell', mapset=mapset)
+    gfile = grass.find_file(name = infile, element = 'cell', mapset = mapset)
     if not gfile['name']:
         grass.fatal(_("Raster map <%s> not found") % infile)
     if os.path.exists(outfile):
         if os.getenv('GRASS_OVERWRITE'):
             grass.warning(_("Pack file <%s> already exists and will be overwritten") % outfile)
             try_remove(outfile)
         else:
             grass.fatal(_("option <output>: <%s> exists.") % outfile)
     grass.message(_("Packing <%s> to <%s>...") % (gfile['fullname'], outfile))
     basedir = os.path.sep.join(os.path.normpath(gfile['file']).split(os.path.sep)[:-2])
-    olddir = os.getcwd()
+    olddir  = os.getcwd()
     # copy elements
     for element in ['cats', 'cell', 'cellhd', 'colr', 'fcell', 'hist']:
         path = os.path.join(basedir, element, infile)
@@ -87,14 +85,14 @@
             grass.debug('copying %s' % path)
             shutil.copyfile(path,
                             os.path.join(tmp_dir, element))
     if os.path.exists(os.path.join(basedir, 'cell_misc', infile)):
         shutil.copytree(os.path.join(basedir, 'cell_misc', infile),
                         os.path.join(tmp_dir, 'cell_misc'))
     if not os.listdir(tmp_dir):
         grass.fatal(_("No raster map components found"))
     # copy projection info
     # (would prefer to use g.proj*, but this way is 5.3 and 5.7 compat)
     gisenv = grass.gisenv()
@@ -103,22 +101,22 @@
                             'PERMANENT', 'PROJ_' + support)
         if os.path.exists(path):
             shutil.copyfile(path, os.path.join(tmp_dir, 'PROJ_' + support))
     # pack it all up
     os.chdir(tmp)
     if compression_off:
-        tar = tarfile.TarFile.open(name=outfile_base, mode='w:')
+        tar = tarfile.TarFile.open(name = outfile_base, mode = 'w:')
     else:
-        tar = tarfile.TarFile.open(name=outfile_base, mode='w:gz')
-    tar.add(infile, recursive=True)
+        tar = tarfile.TarFile.open(name = outfile_base, mode = 'w:gz')
+    tar.add(infile, recursive = True)
     tar.close()
     try:
         shutil.move(outfile_base, outfile)
     except shutil.Error as e:
         grass.fatal(e)
     os.chdir(olddir)
     grass.verbose(_("Raster map saved to '%s'" % outfile))
Modified: grass/trunk/scripts/r.plane/r.plane.py
--- grass/trunk/scripts/r.plane/r.plane.py	2016-03-29 06:29:14 UTC (rev 68180)
+++ grass/trunk/scripts/r.plane/r.plane.py	2016-03-29 08:10:14 UTC (rev 68181)
@@ -59,37 +59,38 @@
 #%end
 #%option
 #% key: type
-#% type: string
+#% type: string
 #% options: CELL,FCELL,DCELL
 #% description: Type of raster map to be created
 #% answer: FCELL
 #%end
+import sys
+import os
 import math
 import string
-import grass.script as gscript
 def main():
     name = options['output']
     type = options['type']
     dip = float(options['dip'])
-    az = float(options['azimuth'])
-    ea = float(options['easting'])
-    no = float(options['northing'])
-    el = float(options['elevation'])
+    az  = float(options['azimuth'])
+    ea  = float(options['easting'])
+    no  = float(options['northing'])
+    el  = float(options['elevation'])
-    # reg = gscript.region()
+    reg = grass.region()
     ### test input values ###
     if abs(dip) >= 90:
-        gscript.fatal(_("dip must be between -90 and 90."))
+	grass.fatal(_("dip must be between -90 and 90."))
     if az < 0 or az >= 360:
-        gscript.fatal(_("azimuth must be between 0 and 360"))
+	grass.fatal(_("azimuth must be between 0 and 360"))
-    # now the actual algorithm
-    az_r = math.radians(-az)
+    ### now the actual algorithm
+    az_r  = math.radians(-az)
     sinaz = math.sin(az_r)
     cosaz = math.cos(az_r)
@@ -101,28 +102,27 @@
     kz = el - ea * sinaz * tandip - no * cosaz * tandip
     if type == "CELL":
-        round = "round"
-        dtype = "int"
+	round = "round"
+	dtype = "int"
     elif type == "FCELL":
-        round = ""
-        dtype = "float"
+	round = ""
+	dtype = "float"
     else:
-        round = ""
-        dtype = "double"
+	round = ""
+	dtype = "double"
-    gscript.mapcalc("$name = $type($round(x() * $kx + y() * $ky + $kz))",
-                    name=name, type=dtype, round=round, kx=kx, ky=ky, kz=kz)
+    grass.mapcalc("$name = $type($round(x() * $kx + y() * $ky + $kz))",
+		  name = name, type = dtype, round = round, kx = kx, ky = ky, kz = kz)
-    gscript.run_command('r.support', map=name, history='')
-    gscript.raster_history(name)
+    grass.run_command('r.support', map = name, history = '')
+    grass.raster_history(name)
-    gscript.message(_("Done."))
-    t = string.Template("Raster map <$name> generated by r.plane "
-                        "at point $ea E, $no N, elevation $el with dip = $dip"
-                        " degrees and aspect = $az degrees ccw from north.")
-    gscript.message(t.substitute(name=name, ea=ea, no=no, el=el, dip=dip,
-                                 az=az))
+    grass.message(_("Done."))
+    t = string.Template("Raster map <$name> generated by r.plane " +
+			"at point $ea E, $no N, elevation $el with dip = $dip degrees and " +
+			"aspect = $az degrees ccw from north.")
+    grass.message(t.substitute(name = name, ea = ea, no = no, el = el, dip = dip, az = az))
 if __name__ == "__main__":
-    options, flags = gscript.parser()
+    options, flags = grass.parser()
     main()
Modified: grass/trunk/scripts/r.reclass.area/r.reclass.area.py
--- grass/trunk/scripts/r.reclass.area/r.reclass.area.py	2016-03-29 06:29:14 UTC (rev 68180)
+++ grass/trunk/scripts/r.reclass.area/r.reclass.area.py	2016-03-29 08:10:14 UTC (rev 68181)
@@ -204,7 +204,7 @@
     limit = float(value)
     if mode == 'greater' and method == 'rmarea':
         grass.fatal(_("You have to specify mode='lesser' with method='rmarea'"))
     if not grass.find_file(infile)['name']:
Modified: grass/trunk/scripts/r.shade/r.shade.py
--- grass/trunk/scripts/r.shade/r.shade.py	2016-03-29 06:29:14 UTC (rev 68180)
+++ grass/trunk/scripts/r.shade/r.shade.py	2016-03-29 08:10:14 UTC (rev 68181)
@@ -111,17 +111,15 @@
             relief_map = relief_map_tmp
             to_remove.append(relief_map_tmp)
         gcore.run_command('r.his', hue=drape_map, intensity=relief_map,
-                          red=tmp_r, green=tmp_g, blue=tmp_b,
-                          **rhis_extra_args)
+                          red=tmp_r, green=tmp_g, blue=tmp_b, **rhis_extra_args)
         to_remove.extend([tmp_r, tmp_g, tmp_b])
         gcore.run_command('r.composite', red=tmp_r, green=tmp_g,
                           blue=tmp_b, output=output_map)
         remove(to_remove)  # who knows if finally is called when exit
-    except CalledModuleError as error:
+    except CalledModuleError, error:
         remove(to_remove)
         # TODO: implement module name to CalledModuleError
-        gcore.fatal(_("Module %s failed. Check the above error messages.") %
-                    error.cmd)
+        gcore.fatal(_("Module %s failed. Check the above error messages.") % error.cmd)
Modified: grass/trunk/scripts/r.tileset/r.tileset.py
--- grass/trunk/scripts/r.tileset/r.tileset.py	2016-03-29 06:29:14 UTC (rev 68180)
+++ grass/trunk/scripts/r.tileset/r.tileset.py	2016-03-29 08:10:14 UTC (rev 68181)
@@ -106,14 +106,13 @@
 # An array of points indexed by 0 for "x" and 4 for "y" + by number 0, 1, 2, and 3
 # A reprojector [0] is name of source projection, [1] is name of destination
 # A projection - [0] is proj.4 text, [1] is scale
-from __future__ import print_function
 import sys
 import tempfile
 import math
 from grass.script.utils import separator
-from grass.script import core as gcore
+from grass.script import core as grass
@@ -159,7 +158,7 @@
     errors = 0
     points = []
     try:
-        ret = gcore.read_command('m.proj',
+        ret = grass.read_command('m.proj',
                                  quiet=True,
                                  flags='d',
                                  proj_in=source['proj'],
@@ -167,10 +166,10 @@
                                  sep=';',
                                  input=file)
-        gcore.fatal(cs2cs + ' failed')
+        grass.fatal(cs2cs + ' failed')
     if not ret:
     for line in ret.splitlines():
         if "*" in line:
@@ -239,42 +238,40 @@
     max_rows = int(options['maxrows']) - int(options['overlap'])
     if max_cols == 0:
-        gcore.fatal(_("It is not possibile to set 'maxcols=%s' and "
+        grass.fatal(_("It is not possibile to set 'maxcols=%s' and "
                       "'overlap=%s'. Please set maxcols>overlap" %
                       (options['maxcols'], options['overlap'])))
     elif max_rows == 0:
-        gcore.fatal(_("It is not possibile to set 'maxrows=%s' and "
+        grass.fatal(_("It is not possibile to set 'maxrows=%s' and "
                       "'overlap=%s'. Please set maxrows>overlap" %
                       (options['maxrows'], options['overlap'])))
     # destination projection
     if not options['destproj']:
-        dest_proj = gcore.read_command('g.proj',
+        dest_proj = grass.read_command('g.proj',
                                        quiet=True,
                                        flags='jf').rstrip('\n')
         if not dest_proj:
-            gcore.fatal(_('g.proj failed'))
+            grass.fatal(_('g.proj failed'))
     else:
         dest_proj = options['destproj']
-    gcore.debug("Getting destination projection -> '%s'" % dest_proj)
+    grass.debug("Getting destination projection -> '%s'" % dest_proj)
     # projection scale
     if not options['destscale']:
-        ret = gcore.parse_command('g.proj',
+        ret = grass.parse_command('g.proj',
                                   quiet=True,
                                   flags='j')
         if not ret:
         if '+to_meter' in ret:
             dest_scale = ret['+to_meter'].strip()
         else:
-            gcore.warning(
-                _("Scale (%s) not found, assuming '1'") %
-                '+to_meter')
+            grass.warning(_("Scale (%s) not found, assuming '1'") % '+to_meter')
             dest_scale = '1'
     else:
         dest_scale = options['destscale']
-    gcore.debug('Getting destination projection scale -> %s' % dest_scale)
+    grass.debug('Getting destination projection scale -> %s' % dest_scale)
     # set up the projections
     srs_source = {'proj': options['sourceproj'],
@@ -282,17 +279,17 @@
     srs_dest = {'proj': dest_proj, 'scale': float(dest_scale)}
     if options['region']:
-        gcore.run_command('g.region',
+        grass.run_command('g.region',
                           quiet=True,
                           region=options['region'])
-    dest_bbox = gcore.region()
-    gcore.debug('Getting destination region')
+    dest_bbox = grass.region()
+    grass.debug('Getting destination region')
     # output field separator
     fs = separator(options['separator'])
     # project the destination region into the source:
-    gcore.verbose('Projecting destination region into source...')
+    grass.verbose('Projecting destination region into source...')
     dest_bbox_points = bboxToPoints(dest_bbox)
     dest_bbox_source_points, errors_dest = projectPoints(dest_bbox_points,
@@ -300,24 +297,24 @@
                                                          dest=srs_source)
     if len(dest_bbox_source_points) == 0:
-        gcore.fatal(_("There are no tiles available. Probably the output "
+        grass.fatal(_("There are no tiles available. Probably the output "
                       "projection system it is not compatible with the "
                       "projection of the current location"))
     source_bbox = pointsToBbox(dest_bbox_source_points)
-    gcore.verbose('Projecting source bounding box into destination...')
+    grass.verbose('Projecting source bounding box into destination...')
     source_bbox_points = bboxToPoints(source_bbox)
     source_bbox_dest_points, errors_source = projectPoints(source_bbox_points,
-                                                           source=srs_source,
-                                                           dest=srs_dest)
+                                                            source=srs_source,
+                                                            dest=srs_dest)
     x_metric = 1 / dest_bbox['ewres']
     y_metric = 1 / dest_bbox['nsres']
-    gcore.verbose('Computing length of sides of source bounding box...')
+    grass.verbose('Computing length of sides of source bounding box...')
     source_bbox_dest_lengths = sideLengths(source_bbox_dest_points,
                                            x_metric, y_metric)
@@ -327,14 +324,12 @@
     # In the direction (x or y) in which the world is least skewed (ie north south in lat long)
     # Divide the world into strips. These strips are as big as possible contrained by max_
     # In the other direction do the same thing.
-    # Theres some recomputation of the size of the world that's got to come in
-    # here somewhere.
+    # Theres some recomputation of the size of the world that's got to come in here somewhere.
     # For now, however, we are going to go ahead and request more data than is necessary.
     # For small regions far from the critical areas of projections this makes very little difference
     # in the amount of data gotten.
-    # We can make this efficient for big regions or regions near critical
-    # points later.
+    # We can make this efficient for big regions or regions near critical points later.
     bigger = []
     bigger.append(max(source_bbox_dest_lengths['x']))
@@ -347,7 +342,7 @@
     # I'm going to make the numbers all simpler and add this extra cell to
     # every tile.
-    gcore.message(_('Computing tiling...'))
+    grass.message(_('Computing tiling...'))
     tiles = [-1, -1]
     tile_base_size = [-1, -1]
     tiles_extra_1 = [-1, -1]
@@ -368,7 +363,7 @@
         # Add overlap to tiles (doesn't effect tileset_size
         tile_size_overlap[i] = tile_size[i] + int(options['overlap'])
-    gcore.verbose("There will be %d by %d tiles each %d by %d cells" %
+    grass.verbose("There will be %d by %d tiles each %d by %d cells" %
                   (tiles[0], tiles[1], tile_size[0], tile_size[1]))
     ximax = tiles[0]
@@ -385,21 +380,16 @@
     tile_bbox = {'w': -1, 's': -1, 'e': -1, 'n': -1}
     if errors_dest > 0:
-        gcore.warning(_("During computation %i tiles could not be created" %
+        grass.warning(_("During computation %i tiles could not be created" %
                         errors_dest))
     while xi < ximax:
-        tile_bbox['w'] = float(
-            min_x) + (float(xi) * float(tile_size[0]) / float(tileset_size[0])) * float(span_x)
-        tile_bbox['e'] = float(min_x) + (float(xi + 1) * float(tile_size_overlap[0]
-                                                               ) / float(tileset_size[0])) * float(span_x)
+        tile_bbox['w'] = float(min_x) + (float(xi) * float(tile_size[0]) / float(tileset_size[0])) * float(span_x)
+        tile_bbox['e'] = float(min_x) + (float(xi + 1) * float(tile_size_overlap[0]) / float(tileset_size[0])) * float(span_x)
         yi = 0
         while yi < yimax:
-            tile_bbox['s'] = float(
-                min_y) + (float(yi) * float(tile_size[1]) / float(tileset_size[1])) * float(span_y)
-            tile_bbox['n'] = float(min_y) + (
-                float(yi + 1) * float(tile_size_overlap[1]) /
-                float(tileset_size[1])) * float(span_y)
+            tile_bbox['s'] = float(min_y) + (float(yi) * float(tile_size[1]) / float(tileset_size[1])) * float(span_y)
+            tile_bbox['n'] = float(min_y) + (float(yi + 1) * float(tile_size_overlap[1]) / float(tileset_size[1])) * float(span_y)
             tile_bbox_points = bboxToPoints(tile_bbox)
             tile_dest_bbox_points, errors = projectPoints(tile_bbox_points,
                                                           source=srs_source,
@@ -407,24 +397,24 @@
             tile_dest_bbox = pointsToBbox(tile_dest_bbox_points)
             if bboxesIntersect(tile_dest_bbox, dest_bbox):
                 if flags['w']:
-                    print("bbox=%s,%s,%s,%s&width=%s&height=%s" %
+                    print "bbox=%s,%s,%s,%s&width=%s&height=%s" % \
                           (tile_bbox['w'], tile_bbox['s'], tile_bbox['e'],
                            tile_bbox['n'], tile_size_overlap[0],
-                           tile_size_overlap[1]))
+                           tile_size_overlap[1])
                 elif flags['g']:
-                    print("w=%s;s=%s;e=%s;n=%s;cols=%s;rows=%s" %
+                    print "w=%s;s=%s;e=%s;n=%s;cols=%s;rows=%s" % \
                 else:
-                    print("%s%s%s%s%s%s%s%s%s%s%s" %
+                    print "%s%s%s%s%s%s%s%s%s%s%s" % \
                           (tile_bbox['w'], fs, tile_bbox['s'], fs,
                            tile_bbox['e'], fs, tile_bbox['n'], fs,
-                           tile_size_overlap[0], fs, tile_size_overlap[1]))
+                           tile_size_overlap[0], fs, tile_size_overlap[1])
             yi += 1
         xi += 1
     cs2cs = 'cs2cs'
-    options, flags = gcore.parser()
     sys.exit(main())
Modified: grass/trunk/scripts/r.unpack/r.unpack.py
--- grass/trunk/scripts/r.unpack/r.unpack.py	2016-03-29 06:29:14 UTC (rev 68180)
+++ grass/trunk/scripts/r.unpack/r.unpack.py	2016-03-29 08:10:14 UTC (rev 68181)
@@ -82,8 +82,7 @@
         if os.environ.get('GRASS_OVERWRITE', '0') != '1':
             grass.fatal(_('Raster map <{name}> already exists'.format(name=map_name)))
         else:
-            grass.warning(
-                _('Raster map <{name}> already exists and will be overwritten'.format(name=map_name)))
+            grass.warning(_('Raster map <{name}> already exists and will be overwritten'.format(name=map_name)))
     # extract data
     tar.extractall()
@@ -101,37 +100,36 @@
     if flags['o']:
         grass.warning(_("Overriding projection check (using current location's projection)."))
     else:
         diff_result_1 = diff_result_2 = None
         proj_info_file_1 = 'PROJ_INFO'
         proj_info_file_2 = os.path.join(mset_dir, '..', 'PERMANENT', 'PROJ_INFO')
         skip_projection_check = False
         if not os.path.exists(proj_info_file_1):
             if os.path.exists(proj_info_file_2):
-                grass.fatal(
-                    _("PROJ_INFO file is missing, unpack raster map in XY (unprojected) location."))
+                grass.fatal(_("PROJ_INFO file is missing, unpack raster map in XY (unprojected) location."))
             skip_projection_check = True  # XY location
         if not skip_projection_check:
             if not grass.compare_key_value_text_files(filename_a=proj_info_file_1,
                                                       filename_b=proj_info_file_2,
-                                                      proj=True):
+                                                      proj=True):
                 diff_result_1 = diff_files(proj_info_file_1, proj_info_file_2)
             proj_units_file_1 = 'PROJ_UNITS'
             proj_units_file_2 = os.path.join(mset_dir, '..', 'PERMANENT', 'PROJ_UNITS')
             if not grass.compare_key_value_text_files(filename_a=proj_units_file_1,
                                                       filename_b=proj_units_file_2,
-                                                      units=True):
+                                                      units=True):
                 diff_result_2 = diff_files(proj_units_file_1, proj_units_file_2)
             if diff_result_1 or diff_result_2:
                 if diff_result_1:
                     grass.warning(_("Difference between PROJ_INFO file of packed map "
                                     "and of current location:\n{diff}").format(diff=''.join(diff_result_1)))
Modified: grass/trunk/scripts/r3.in.xyz/r3.in.xyz.py
--- grass/trunk/scripts/r3.in.xyz/r3.in.xyz.py	2016-03-29 06:29:14 UTC (rev 68180)
+++ grass/trunk/scripts/r3.in.xyz/r3.in.xyz.py	2016-03-29 08:10:14 UTC (rev 68181)
@@ -280,7 +280,7 @@
                                       **addl_opts)
         grass.debug("i=%d, %%=%d  (workers=%d)" % (i, i % workers, workers))
-        # print sys.getsizeof(proc)  # sizeof(proc array)  [not so big]
+        #print sys.getsizeof(proc)  # sizeof(proc array)  [not so big]
         if i % workers is 0:
             # wait for the ones launched so far to finish
@@ -299,7 +299,7 @@
     grass.verbose(_("Assembling 3D cube ..."))
-    # input order: lower most strata first
+    #input order: lower most strata first
     slices = grass.read_command('g.list', type='raster', sep=',',
                                 pattern='tmp.r3xyz.%d.*' % os.getpid()).rstrip(os.linesep)
     grass.debug(slices)
Modified: grass/trunk/scripts/v.build.all/v.build.all.py
--- grass/trunk/scripts/v.build.all/v.build.all.py	2016-03-29 06:29:14 UTC (rev 68180)
+++ grass/trunk/scripts/v.build.all/v.build.all.py	2016-03-29 08:10:14 UTC (rev 68181)
@@ -22,7 +22,6 @@
 def main():
     mapset = env['MAPSET']
@@ -30,17 +29,17 @@
     vectors = grass.list_grouped('vect')[mapset]
     num_vectors = len(vectors)
     if grass.verbosity() < 2:
         quiet = True
     else:
         quiet = False
     i = 1
     for vect in vectors:
         map = "%s@%s" % (vect, mapset)
-        grass.message(_("%s\nBuilding topology for vector map <%s> (%d of %d)...\n%s") %
-                      ('-' * 80, map, i, num_vectors, '-' * 80))
+        grass.message(_("%s\nBuilding topology for vector map <%s> (%d of %d)...\n%s") % \
+                          ('-' * 80, map, i, num_vectors, '-' * 80))
         grass.verbose(_("v.build map=%s") % map)
         try:
             grass.run_command("v.build", map=map, quiet=quiet)
Modified: grass/trunk/scripts/v.centroids/v.centroids.py
--- grass/trunk/scripts/v.centroids/v.centroids.py	2016-03-29 06:29:14 UTC (rev 68180)
+++ grass/trunk/scripts/v.centroids/v.centroids.py	2016-03-29 08:10:14 UTC (rev 68181)
@@ -50,19 +50,20 @@
 #%end
 import sys
+import os
+import re
 def main():
     if options['option'] == 'add':
-        num_bound = gscript.vector_info_topo(map=options['input'])['boundaries']
-        if num_bound == 0:
-            gscript.fatal(_("Input vector map contains no boundaries."))
+        num_bound = grass.vector_info_topo(map = options['input'])['boundaries']
+	if num_bound == 0:
+	    grass.fatal(_("Input vector map contains no boundaries."))
-        gscript.exec_command("v.category", type='area', **options)
+	grass.exec_command("v.category", type = 'area', **options)
     sys.exit(0)
     main()
Modified: grass/trunk/scripts/v.db.addcolumn/v.db.addcolumn.py
--- grass/trunk/scripts/v.db.addcolumn/v.db.addcolumn.py	2016-03-29 06:29:14 UTC (rev 68180)
+++ grass/trunk/scripts/v.db.addcolumn/v.db.addcolumn.py	2016-03-29 08:10:14 UTC (rev 68181)
@@ -3,7 +3,7 @@
 # MODULE:       v.db.addcolumnumn
-# AUTHOR(S):    Moritz Lennert
+# AUTHOR(S):    Moritz Lennert
 #               Converted to Python by Glynn Clements
 # PURPOSE:      interface to db.execute to add a column to the attribute table
 #               connected to a given vector map
@@ -42,31 +42,29 @@
 import os
 import grass.script as grass
 def main():
-    map = options['map']
-    layer = options['layer']
+    map     = options['map']
+    layer   = options['layer']
     columns = options['columns']
     columns = [col.strip() for col in columns.split(',')]
     # does map exist in CURRENT mapset?
-    exists = bool(grass.find_file(map, element='vector', mapset=mapset)['file'])
+    exists = bool(grass.find_file(map, element = 'vector', mapset = mapset)['file'])
     if not exists:
         grass.fatal(_("Vector map <%s> not found in current mapset") % map)
     try:
         f = grass.vector_db(map)[int(layer)]
     except KeyError:
-        grass.fatal(
-            _("There is no table connected to this map. Run v.db.connect or v.db.addtable first."))
-    table = f['table']
+        grass.fatal(_("There is no table connected to this map. Run v.db.connect or v.db.addtable first."))
+    table    = f['table']
     database = f['database']
-    driver = f['driver']
-    column_existing = grass.vector_columns(map, int(layer)).keys()
+    driver   = f['driver']
+    column_existing = grass.vector_columns(map, int(layer)).keys()
     for col in columns:
         if not col:
             grass.fatal(_("There is an empty column. Did you leave a trailing comma?"))
@@ -75,13 +73,13 @@
             grass.error(_("Column <%s> is already in the table. Skipping.") % col_name)
             continue
         grass.verbose(_("Adding column <%s> to the table") % col_name)
-        p = grass.feed_command('db.execute', input='-', database=database, driver=driver)
+        p = grass.feed_command('db.execute', input = '-', database = database, driver = driver)
         p.stdin.write("ALTER TABLE %s ADD COLUMN %s" % (table, col))
         grass.debug("ALTER TABLE %s ADD COLUMN %s" % (table, col))
         p.stdin.close()
         if p.wait() != 0:
             grass.fatal(_("Unable to add column <%s>.") % col)
     # write cmd history:
     grass.vector_history(map)
Modified: grass/trunk/scripts/v.db.addtable/v.db.addtable.py
--- grass/trunk/scripts/v.db.addtable/v.db.addtable.py	2016-03-29 06:29:14 UTC (rev 68180)
+++ grass/trunk/scripts/v.db.addtable/v.db.addtable.py	2016-03-29 08:10:14 UTC (rev 68181)
@@ -3,7 +3,7 @@
 # MODULE:       v.db.addtable
-# AUTHOR(S):    Markus Neteler
+# AUTHOR(S):    Markus Neteler
 #               Key column added by Martin Landa <landa.martin gmail.com>
 # PURPOSE:      interface to db.execute to creates and add a new table to given vector map
@@ -23,14 +23,14 @@
 #%end
 #%option G_OPT_V_MAP
 #%end
-#%option
+#%option
 #% key: table
 #% type: string
 #% description: Name of new attribute table (default: vector map name)
 #% required: no
 #% guisection: Definition
 #%end
-#%option
+#%option
 #% key: layer
 #% type: integer
 #% description: Layer number where to add new attribute table
@@ -64,14 +64,14 @@
     key = options['key']
-    if not grass.find_file(vector, element='vector', mapset=mapset)['file']:
+    if not grass.find_file(vector, element = 'vector', mapset = mapset)['file']:
         grass.fatal(_("Vector map <%s> not found in current mapset") % vector)
     map_name = vector.split('@')[0]
     if not table:
         if layer == '1':
             grass.verbose(_("Using vector map name as table name: <%s>") % map_name)
@@ -79,46 +79,44 @@
         else:
             # to avoid tables with identical names on higher layers
             table = "%s_%s" % (map_name, layer)
-            grass.verbose(
-                _("Using vector map name extended by layer number as table name: <%s>") %
-                table)
+            grass.verbose(_("Using vector map name extended by layer number as table name: <%s>") % table)
     else:
         grass.verbose(_("Using user specified table name: %s") % table)
     # check if DB parameters are set, and if not set them.
-    grass.run_command('db.connect', flags='c')
+    grass.run_command('db.connect', flags = 'c')
     grass.verbose(_("Creating new DB connection based on default mapset settings..."))
     kv = grass.db_connection()
     database = kv['database']
     driver = kv['driver']
     schema = kv['schema']
     # maybe there is already a table linked to the selected layer?
     nuldev = file(os.devnull, 'w')
     try:
-        grass.vector_db(map_name, stderr=nuldev)[int(layer)]
+        grass.vector_db(map_name, stderr = nuldev)[int(layer)]
         grass.fatal(_("There is already a table linked to layer <%s>") % layer)
     except KeyError:
         pass
     # maybe there is already a table with that name?
-    tables = grass.read_command('db.tables', flags='p', database=database, driver=driver,
-                                stderr=nuldev)
+    tables = grass.read_command('db.tables', flags = 'p', database = database, driver = driver,
+                                stderr = nuldev)
     if not table in tables.splitlines():
         if columns:
             column_def = map(lambda x: x.strip().lower(), columns.strip().split(','))
         else:
             column_def = []
         # if not existing, create it:
         column_def_key = "%s integer" % key
         if column_def_key not in column_def:
             column_def.insert(0, column_def_key)
         column_def = ','.join(column_def)
         grass.verbose(_("Creating table with columns (%s)...") % column_def)
         sql = "CREATE TABLE %s (%s)" % (table, column_def)
         try:
             grass.run_command('db.execute',
@@ -129,22 +127,22 @@
     # connect the map to the DB:
     if schema:
         table = '{schema}.{table}'.format(schema=schema, table=table)
-    grass.run_command('v.db.connect', quiet=True,
-                      map=map_name, database=database, driver=driver,
-                      layer=layer, table=table, key=key)
+    grass.run_command('v.db.connect', quiet = True,
+                      map = map_name, database = database, driver = driver,
+                      layer = layer, table = table, key = key)
     # finally we have to add cats into the attribute DB to make modules such as v.what.rast happy:
     # (creates new row for each vector line):
-    grass.run_command('v.to.db', map=map_name, layer=layer,
-                      option='cat', column=key, qlayer=layer)
+    grass.run_command('v.to.db', map = map_name, layer = layer,
+                      option = 'cat', column = key, qlayer = layer)
     grass.verbose(_("Current attribute table links:"))
     if grass.verbosity() > 2:
-        grass.run_command('v.db.connect', flags='p', map=map_name)
+        grass.run_command('v.db.connect', flags = 'p', map = map_name)
     grass.vector_history(map_name)
     return 0
Modified: grass/trunk/scripts/v.db.dropcolumn/v.db.dropcolumn.py
--- grass/trunk/scripts/v.db.dropcolumn/v.db.dropcolumn.py	2016-03-29 06:29:14 UTC (rev 68180)
+++ grass/trunk/scripts/v.db.dropcolumn/v.db.dropcolumn.py	2016-03-29 08:10:14 UTC (rev 68181)
@@ -5,7 +5,7 @@
 # MODULE:       v.db.dropcolumn
-# PURPOSE:      interface to db.execute to drop a column from the
+# PURPOSE:      interface to db.execute to drop a column from the
 #               attribute table connected to a given vector map
 #               - Based on v.db.addcolumn
 #               - with special trick for SQLite
@@ -45,43 +45,43 @@
 def main():
     columns = options['columns'].split(',')
-    if not grass.find_file(map, element='vector', mapset=mapset)['file']:
+    if not grass.find_file(map, element = 'vector', mapset = mapset)['file']:
     f = grass.vector_layer_db(map, layer)
     table = f['table']
     keycol = f['key']
     if not table:
         grass.fatal(_("There is no table connected to the input vector map. "
                       "Unable to delete any column. Exiting."))
     if keycol in columns:
         grass.fatal(_("Unable to delete <%s> column as it is needed to keep table <%s> "
-                      "connected to the input vector map <%s>") %
-                    (keycol, table, map))
+                      "connected to the input vector map <%s>") % \
+                        (keycol, table, map))
     for column in columns:
-        if column not in grass.vector_columns(map, layer):
+        if not grass.vector_columns(map, layer).has_key(column):
             grass.warning(_("Column <%s> not found in table <%s>. Skipped") % (column, table))
             continue
         if driver == "sqlite":
             # echo "Using special trick for SQLite"
             # http://www.sqlite.org/faq.html#q11
             colnames = []
             coltypes = []
-            for f in grass.db_describe(table, database=database, driver=driver)['cols']:
+            for f in grass.db_describe(table, database = database, driver = driver)['cols']:
                 if f[0] == column:
                     continue
                 colnames.append(f[0])
@@ -100,21 +100,21 @@
                 "CREATE UNIQUE INDEX ${table}_cat ON ${table} (${keycol} )",
                 "DROP TABLE ${table}_backup",
                 "COMMIT"
             tmpl = string.Template(';\n'.join(cmds))
-            sql = tmpl.substitute(table=table, coldef=coltypes, colnames=colnames, keycol=keycol)
+            sql = tmpl.substitute(table = table, coldef = coltypes, colnames = colnames, keycol = keycol)
         else:
             sql = "ALTER TABLE %s DROP COLUMN %s" % (table, column)
         try:
-            grass.write_command('db.execute', input='-', database=database, driver=driver,
-                                stdin=sql)
+            grass.write_command('db.execute', input = '-', database = database, driver = driver,
+                                stdin = sql)
             grass.fatal(_("Deleting column failed"))
     main()
Modified: grass/trunk/scripts/v.db.droprow/v.db.droprow.py
--- grass/trunk/scripts/v.db.droprow/v.db.droprow.py	2016-03-29 06:29:14 UTC (rev 68180)
+++ grass/trunk/scripts/v.db.droprow/v.db.droprow.py	2016-03-29 08:10:14 UTC (rev 68181)
@@ -51,7 +51,7 @@
         return 1
-    grass.vector_history(map=options['output'])
+    grass.vector_history(map = options['output'])
     return 0
Modified: grass/trunk/scripts/v.db.droptable/v.db.droptable.py
--- grass/trunk/scripts/v.db.droptable/v.db.droptable.py	2016-03-29 06:29:14 UTC (rev 68180)
+++ grass/trunk/scripts/v.db.droptable/v.db.droptable.py	2016-03-29 08:10:14 UTC (rev 68181)
@@ -3,7 +3,7 @@
 # MODULE:       v.db.droptable
 # PURPOSE:      interface to db.execute to drop an existing table of given vector map
 # COPYRIGHT:    (C) 2005, 2008 by the GRASS Development Team
@@ -36,7 +36,7 @@
 import sys
 import os
+import grass.script as grass
@@ -47,58 +47,56 @@
     # do some paranoia tests as well:
-    f = gscript.vector_layer_db(map, layer)
+    f = grass.vector_layer_db(map, layer)
     if not table:
-        # Removing table name connected to selected layer
-        if not table:
-            gscript.fatal(_("No table assigned to layer <%s>") % layer)
+	# Removing table name connected to selected layer
+	if not table:
+	    grass.fatal(_("No table assigned to layer <%s>") % layer)
     else:
-        # Removing user specified table
-        existingtable = f['table']
-        if existingtable != table:
-            gscript.fatal(_("User selected table <%s> but the table <%s> "
-                            "is linked to layer <%s>") %
-                          (table, existingtable, layer))
+	# Removing user specified table
+	existingtable = f['table']
+	if existingtable != table:
+	    grass.fatal(_("User selected table <%s> but the table <%s> is linked to layer <%s>")
+			% (table, existingtable, layer))
-    # we use the DB settings selected layer
+    # we use the DB settings selected layer
-    gscript.message(_("Removing table <%s> linked to layer <%s> of vector"
-                      " map <%s>") % (table, layer, map))
+    grass.message(_("Removing table <%s> linked to layer <%s> of vector map <%s>")
+		  % (table, layer, map))
     if not force:
-        gscript.message(_("You must use the -f (force) flag to actually "
-                          "remove the table. Exiting."))
-        gscript.message(_("Leaving map/table unchanged."))
-        sys.exit(0)
+	grass.message(_("You must use the -f (force) flag to actually remove the table. Exiting."))
+	grass.message(_("Leaving map/table unchanged."))
+	sys.exit(0)
-    gscript.message(_("Dropping table <%s>...") % table)
+    grass.message(_("Dropping table <%s>...") % table)
     try:
-        gscript.write_command('db.execute', stdin="DROP TABLE %s" % table,
-                              input='-', database=database, driver=driver)
+        grass.write_command('db.execute', stdin="DROP TABLE %s" % table,
+                            input='-', database=database, driver=driver)
-        gscript.fatal(_("An error occurred while running db.execute"))
+        grass.fatal(_("An error occurred while running db.execute"))
-    gscript.run_command('v.db.connect', flags='d', map=map, layer=layer)
+    grass.run_command('v.db.connect', flags = 'd', map = map, layer = layer)
-    gscript.message(_("Current attribute table link(s):"))
+    grass.message(_("Current attribute table link(s):"))
     # silently test first to avoid confusing error messages
     try:
-        gscript.run_command('v.db.connect', flags='p', map=map, quiet=True,
-                            stdout=nuldev, stderr=nuldev)
+        grass.run_command('v.db.connect', flags='p', map=map, quiet=True,
+                          stdout=nuldev, stderr=nuldev)
-        gscript.message(_("(No database links remaining)"))
+        grass.message(_("(No database links remaining)"))
     else:
-        gscript.run_command('v.db.connect', flags='p', map=map)
+        grass.run_command('v.db.connect', flags='p', map=map)
-    gscript.vector_history(map)
+    grass.vector_history(map)
     main()
Modified: grass/trunk/scripts/v.db.join/v.db.join.py
--- grass/trunk/scripts/v.db.join/v.db.join.py	2016-03-29 06:29:14 UTC (rev 68180)
+++ grass/trunk/scripts/v.db.join/v.db.join.py	2016-03-29 08:10:14 UTC (rev 68181)
@@ -77,7 +77,7 @@
     maptable = f['table']
     if driver == 'dbf':
         grass.fatal(_("JOIN is not supported for tables stored in DBF format"))
@@ -86,7 +86,7 @@
         grass.fatal(_("There is no table connected to this map. Unable to join any column."))
     # check if column is in map table
         grass.fatal(_("Column <%s> not found in table <%s>") % (column,
        maptable))
@@ -154,9 +154,7 @@
                                    otable=otable, ocolumn=ocolumn,
                                    colname=colname)
         grass.debug(stmt, 1)
-        grass.verbose(
-            _("Updating column <%s> of vector map <%s>...") %
-            (colname, map))
+        grass.verbose(_("Updating column <%s> of vector map <%s>...") % (colname, map))
         try:
             grass.write_command('db.execute', stdin=stmt, input='-',
Modified: grass/trunk/scripts/v.db.reconnect.all/v.db.reconnect.all.py
--- grass/trunk/scripts/v.db.reconnect.all/v.db.reconnect.all.py	2016-03-29 06:29:14 UTC (rev 68180)
+++ grass/trunk/scripts/v.db.reconnect.all/v.db.reconnect.all.py	2016-03-29 08:10:14 UTC (rev 68181)
@@ -53,120 +53,107 @@
 import os
 import string
 # substitute variables (gisdbase, location_name, mapset)
 def substitute_db(database):
-    gisenv = gscript.gisenv()
+    gisenv = grass.gisenv()
     tmpl = string.Template(database)
+    return tmpl.substitute(GISDBASE = gisenv['GISDBASE'],
+                           LOCATION_NAME = gisenv['LOCATION_NAME'],
+                           MAPSET = gisenv['MAPSET'])
-    return tmpl.substitute(GISDBASE=gisenv['GISDBASE'],
-                           LOCATION_NAME=gisenv['LOCATION_NAME'],
-                           MAPSET=gisenv['MAPSET'])
 # create database if doesn't exist
 def create_db(driver, database):
     subst_database = substitute_db(database)
     if driver == 'dbf':
         path = subst_database
         # check if destination directory exists
         if not os.path.isdir(path):
-            # create dbf database
+	    # create dbf database
             os.makedirs(path)
-            return True
+	    return True
         return False
     if driver == 'sqlite':
         path = os.path.dirname(subst_database)
             os.makedirs(path)
-    if subst_database in gscript.read_command('db.databases', quiet=True,
-                                              driver=driver).splitlines():
+    if subst_database in grass.read_command('db.databases', quiet = True,
+                                      driver = driver).splitlines():
         return False
-    gscript.info(_("Target database doesn't exist, "
-                   "creating a new database using <%s> driver...") % driver)
+    grass.info(_("Target database doesn't exist, "
+                 "creating a new database using <%s> driver...") % driver)
     try:
-        gscript.run_command('db.createdb', driver=driver,
-                            database=subst_database)
+        grass.run_command('db.createdb', driver = driver,
+                          database = subst_database)
-        gscript.fatal(_("Unable to create database <%s> by driver <%s>") %
-                      (subst_database, driver))
+        grass.fatal(_("Unable to create database <%s> by driver <%s>") % \
+                        (subst_database, driver))
     return False
 # copy tables if required (-c)
 def copy_tab(from_driver, from_database, from_table,
              to_driver, to_database, to_table):
-    if to_table in gscript.read_command('db.tables', quiet=True,
-                                        driver=to_driver,
-                                        database=to_database,
-                                        stderr=nuldev).splitlines():
+    if to_table in grass.read_command('db.tables', quiet = True,
+                                      driver = to_driver,
+                                      database = to_database,
+                                      stderr = nuldev).splitlines():
         return False
-    gscript.info("Copying table <%s> to target database..." % to_table)
+    grass.info("Copying table <%s> to target database..." % to_table)
     try:
-        gscript.run_command('db.copy', from_driver=from_driver,
-                            from_database=from_database,
-                            from_table=from_table, to_driver=to_driver,
-                            to_database=to_database,
-                            to_table=to_table)
+        grass.run_command('db.copy', from_driver = from_driver,
+                          from_database = from_database,
+                          from_table = from_table, to_driver = to_driver,
+                          to_database = to_database,
+                          to_table = to_table)
-        gscript.fatal(_("Unable to copy table <%s>") % from_table)
+        grass.fatal(_("Unable to copy table <%s>") % from_table)
     return True
 # drop tables if required (-d)
 def drop_tab(vector, layer, table, driver, database):
     # disconnect
     try:
-        gscript.run_command('v.db.connect', flags='d', quiet=True, map=vector,
-                            layer=layer, table=table)
+        grass.run_command('v.db.connect', flags = 'd', quiet = True, map = vector,
+			          layer = layer, table = table)
-        gscript.warning(_("Unable to disconnect table <%s> from vector <%s>") %
-                        (table, vector))
+        grass.warning(_("Unable to disconnect table <%s> from vector <%s>") % (table, vector))
     # drop table
     try:
-        gscript.run_command('db.droptable', quiet=True, flags='f',
-                            driver=driver, database=database,
-                            table=table)
+        grass.run_command('db.droptable', quiet = True, flags = 'f',
+                          driver = driver, database = database,
+                          table = table)
-        gscript.fatal(_("Unable to drop table <%s>") % table)
+        grass.fatal(_("Unable to drop table <%s>") % table)
 # create index on key column
 def create_index(driver, database, table, index_name, key):
     if driver == 'dbf':
-        return False
+	return False
-    gscript.info(_("Creating index <%s>...") % index_name)
+    grass.info(_("Creating index <%s>...") % index_name)
     try:
-        gscript.run_command('db.execute', quiet=True, driver=driver,
-                            database=database,
-                            sql="create unique index %s on %s(%s)" %
-                                (index_name, table, key))
+        grass.run_command('db.execute', quiet = True,
+                          sql = "create unique index %s on %s(%s)" % (index_name, table, key))
-        gscript.warning(_("Unable to create index <%s>") % index_name)
+        grass.warning(_("Unable to create index <%s>") % index_name)
 def main():
     # old connection
     old_database = options['old_database']
     old_schema = options['old_schema']
     # new connection
-    default_connection = gscript.db_connection()
+    default_connection = grass.db_connection()
     if options['new_driver']:
         new_driver = options['new_driver']
     else:
@@ -181,105 +168,93 @@
         new_schema = default_connection['schema']
     if old_database == '':
-        old_database = None
+    	old_database = None
     old_database_subst = None
     if old_database is not None:
-        old_database_subst = substitute_db(old_database)
+	old_database_subst = substitute_db(old_database)
     new_database_subst = substitute_db(new_database)
     if old_database_subst == new_database_subst and old_schema == new_schema:
-        gscript.fatal(_("Old and new database connection is identical. "
-                        "Nothing to do."))
-    mapset = gscript.gisenv()['MAPSET']
-    vectors = gscript.list_grouped('vect')[mapset]
+	grass.fatal(_("Old and new database connection is identical. Nothing to do."))
+    mapset = grass.gisenv()['MAPSET']
+    vectors = grass.list_grouped('vect')[mapset]
     if flags['c']:
-        # create new database if not existing
-        create_db(new_driver, new_database)
+	# create new database if not existing
+	create_db(new_driver, new_database)
     i = 0
         vect = "%s@%s" % (vect, mapset)
         i += 1
-        gscript.message(_("%s\nReconnecting vector map <%s> "
-                          "(%d of %d)...\n%s") %
-                        ('-' * 80, vect, i, num_vectors, '-' * 80))
-        for f in gscript.vector_db(vect, stderr=nuldev).itervalues():
+	grass.message(_("%s\nReconnecting vector map <%s> (%d of %d)...\n%s") % \
+                          ('-' * 80, vect, i, num_vectors, '-' * 80))
+        for f in grass.vector_db(vect, stderr = nuldev).itervalues():
             layer = f['layer']
             schema_table = f['table']
             key = f['key']
             # split schema.table
             if '.' in schema_table:
                 schema, table = schema_table.split('.', 1)
             else:
                 schema = ''
             if new_schema:
                 new_schema_table = "%s.%s" % (new_schema, table)
             else:
                 new_schema_table = table
+            grass.debug("DATABASE = '%s' SCHEMA = '%s' TABLE = '%s' ->\n"
+                        "      NEW_DATABASE = '%s' NEW_SCHEMA_TABLE = '%s'" % \
+                            (old_database, schema, table, new_database, new_schema_table))
-            gscript.debug("DATABASE = '%s' SCHEMA = '%s' TABLE = '%s' ->\n"
-                          "      NEW_DATABASE = '%s' NEW_SCHEMA_TABLE = '%s'" %
-                          (old_database, schema, table, new_database,
-                           new_schema_table))
             do_reconnect = True
-            if old_database_subst is not None:
-                if database != old_database_subst:
-                    do_reconnect = False
-            if database == new_database_subst:
-            if schema != old_schema:
+	    if old_database_subst is not None:
+		if database != old_database_subst:
+		    do_reconnect = False
+	    if database == new_database_subst:
+	    if schema != old_schema:
             if do_reconnect == True:
-                gscript.verbose(_("Reconnecting layer %d...") % layer)
+                grass.verbose(_("Reconnecting layer %d...") % layer)
                 if flags['c']:
                     # check if table exists in new database
                     copy_tab(driver, database, schema_table,
                              new_driver, new_database, new_schema_table)
                 # drop original table if required
                 if flags['d']:
-                    drop_tab(
-                        vect,
-                        layer,
-                        schema_table,
-                        driver,
-                        substitute_db(database))
+                    drop_tab(vect, layer, schema_table, driver, substitute_db(database))
                 # reconnect tables (don't use substituted new_database)
-                # NOTE: v.db.connect creates an index on the key column
+		# NOTE: v.db.connect creates an index on the key column
                 try:
-                    gscript.run_command('v.db.connect', flags='o', quiet=True,
-                                        map=vect, layer=layer,
-                                        driver=new_driver,
-                                        database=new_database,
-                                        table=new_schema_table, key=key)
+                    grass.run_command('v.db.connect', flags = 'o', quiet = True, map = vect,
+                                      layer = layer, driver = new_driver, database = new_database,
+                                      table = new_schema_table, key = key)
-                    gscript.warning(_("Unable to connect table <%s> to vector "
-                                      "<%s> on layer <%s>") %
-                                    (table, vect, str(layer)))
+                    grass.warning(_("Unable to connect table <%s> to vector <%s> on layer <%s>") %
+				  (table, vect, str(layer)))
             else:
-                if database != new_database_subst:
-                    gscript.warning(_("Layer <%d> will not be reconnected "
-                                      "because database or schema do not "
-                                      "match.") % layer)
+		if database != new_database_subst:
+		    grass.warning(_("Layer <%d> will not be reconnected because "
+				    "database or schema do not match.") % layer)
     return 0
     sys.exit(main())
Modified: grass/trunk/scripts/v.db.renamecolumn/v.db.renamecolumn.py
--- grass/trunk/scripts/v.db.renamecolumn/v.db.renamecolumn.py	2016-03-29 06:29:14 UTC (rev 68180)
+++ grass/trunk/scripts/v.db.renamecolumn/v.db.renamecolumn.py	2016-03-29 08:10:14 UTC (rev 68181)
@@ -5,10 +5,10 @@
 # MODULE:       v.db.renamecolumn
 #               - Based on v.db.dropcolumn
-#               - with special trick for SQLite and DBF (here the new col is
+#               - with special trick for SQLite and DBF (here the new col is
 #                 added/values copied/old col deleted)
 # COPYRIGHT:    (C) 2007 by the GRASS Development Team
@@ -30,7 +30,7 @@
 #%end
 #%option G_OPT_V_FIELD
 #%end
-#%option
+#%option
 #% key: column
 #% type: string
 #% description: Old and new name of the column (old,new)
@@ -43,7 +43,6 @@
 import os
 def main():
@@ -51,7 +50,7 @@
-    if not grass.find_file(map, element='vector', mapset=mapset):
+    if not grass.find_file(map, element = 'vector', mapset = mapset):
@@ -70,14 +69,10 @@
     if driver == "dbf":
         if len(newcol) > 10:
-            grass.fatal(
-                _("Column name <%s> too long. The DBF driver supports column names not longer than 10 characters") %
-                newcol)
+            grass.fatal(_("Column name <%s> too long. The DBF driver supports column names not longer than 10 characters") % newcol)
     if oldcol == keycol:
-        grass.fatal(
-            _("Cannot rename column <%s> as it is needed to keep table <%s> connected to the input vector map") %
-            (oldcol, table))
+        grass.fatal(_("Cannot rename column <%s> as it is needed to keep table <%s> connected to the input vector map") % (oldcol, table))
     # describe old col
     oldcoltype = None
@@ -98,10 +93,10 @@
         else:
             colspec = "%s %s" % (newcol, oldcoltype)
-        grass.run_command('v.db.addcolumn', map=map, layer=layer, column=colspec)
+        grass.run_command('v.db.addcolumn', map = map, layer = layer, column = colspec)
         sql = "UPDATE %s SET %s=%s" % (table, newcol, oldcol)
-        grass.write_command('db.execute', input='-', database=database, driver=driver, stdin=sql)
-        grass.run_command('v.db.dropcolumn', map=map, layer=layer, column=oldcol)
+        grass.write_command('db.execute', input = '-', database = database, driver = driver, stdin = sql)
+        grass.run_command('v.db.dropcolumn', map = map, layer = layer, column = oldcol)
     elif driver == 'mysql':
         if oldcoltype.upper() == "CHARACTER":
             newcoltype = "varchar(%s)" % (oldcollength)
@@ -109,10 +104,10 @@
             newcoltype = oldcoltype
         sql = "ALTER TABLE %s CHANGE %s %s %s" % (table, oldcol, newcol, newcoltype)
     else:
         sql = "ALTER TABLE %s RENAME %s TO %s" % (table, oldcol, newcol)
Modified: grass/trunk/scripts/v.db.univar/v.db.univar.py
--- grass/trunk/scripts/v.db.univar/v.db.univar.py	2016-03-29 06:29:14 UTC (rev 68180)
+++ grass/trunk/scripts/v.db.univar/v.db.univar.py	2016-03-29 08:10:14 UTC (rev 68181)
@@ -53,49 +53,50 @@
 import sys
 import os
 def main():
     global tmp
-    tmp = gscript.tempfile()
+    tmp = grass.tempfile()
     vector = options['map']
     column = options['column']
     where = options['where']
     perc = options['percentile']
+    extend = flags['e']
+    shellstyle = flags['g']
-    if not gscript.find_file(vector, element='vector')['file']:
-        gscript.fatal(_("Vector map <%s> not found") % vector)
+    if not grass.find_file(vector, element='vector')['file']:
+        grass.fatal(_("Vector map <%s> not found") % vector)
     try:
-        fi = gscript.vector_db(vector, stderr=nuldev)[int(layer)]
+        fi = grass.vector_db(vector, stderr = nuldev)[int(layer)]
     except KeyError:
-        gscript.fatal(_("No attribute table linked to layer <%s>") % layer)
+        grass.fatal(_("No attribute table linked to layer <%s>") % layer)
     table = fi['table']
     database = fi['database']
     driver = fi['driver']
     passflags = None
     if flags['e']:
-        passflags = 'e'
+	passflags = 'e'
     if flags['g']:
-        if not passflags:
-            passflags = 'g'
-        else:
-            passflags = passflags + 'g'
+	if not passflags:
+	    passflags = 'g'
+	else:
+	    passflags = passflags + 'g'
     try:
-        gscript.run_command('db.univar', table=table, column=column,
-                            database=database, driver=driver,
-                            perc=perc, where=where, flags=passflags)
+        grass.run_command('db.univar', table = table, column = column,
+                          database = database, driver = driver,
+                          perc = perc, where = where, flags = passflags)
         sys.exit(1)
     main()
Modified: grass/trunk/scripts/v.db.update/v.db.update.py
--- grass/trunk/scripts/v.db.update/v.db.update.py	2016-03-29 06:29:14 UTC (rev 68180)
+++ grass/trunk/scripts/v.db.update/v.db.update.py	2016-03-29 08:10:14 UTC (rev 68181)
@@ -54,7 +54,6 @@
 import os
 def main():
@@ -62,19 +61,18 @@
     value = options['value']
     qcolumn = options['query_column']
-    sqlitefile = options['sqliteextra']
+    sqlitefile  = options['sqliteextra']
     try:
         f = grass.vector_db(vector)[int(layer)]
     except KeyError:
-        grass.fatal(
-            _('There is no table connected to this map. Run v.db.connect or v.db.addtable first.'))
+        grass.fatal(_('There is no table connected to this map. Run v.db.connect or v.db.addtable first.'))
     table = f['table']
@@ -115,7 +113,7 @@
         cmd = sqliteload + cmd
     grass.verbose("SQL: \"%s\"" % cmd)
-    grass.write_command('db.execute', input='-', database=database, driver=driver, stdin=cmd)
+    grass.write_command('db.execute', input = '-', database = database, driver = driver, stdin = cmd)
     grass.vector_history(vector)
Modified: grass/trunk/scripts/v.dissolve/v.dissolve.py
--- grass/trunk/scripts/v.dissolve/v.dissolve.py	2016-03-29 06:29:14 UTC (rev 68180)
+++ grass/trunk/scripts/v.dissolve/v.dissolve.py	2016-03-29 08:10:14 UTC (rev 68181)
@@ -43,11 +43,8 @@
 def cleanup():
-        'g.remove', flags='f', type='vector', name='%s_%s' %
-        (output, tmp), quiet=True, stderr=nuldev)
+    grass.run_command('g.remove', flags = 'f', type = 'vector', name = '%s_%s' % (output, tmp), quiet = True, stderr = nuldev)
 def main():
     global output, tmp
@@ -56,45 +53,44 @@
-    # setup temporary file
+    #### setup temporary file
     tmp = str(os.getpid())
     # does map exist?
-    if not grass.find_file(input, element='vector')['file']:
-        grass.fatal(_("Vector map <%s> not found") % input)
+    if not grass.find_file(input, element = 'vector')['file']:
+	grass.fatal(_("Vector map <%s> not found") % input)
     if not column:
-        grass.warning(
-            _("No '%s' option specified. Dissolving based on category values from layer <%s>.") %
-            ("column", layer))
-        grass.run_command('v.extract', flags='d', input=input,
-                          output=output, type='area', layer=layer)
+        grass.warning(_("No '%s' option specified. Dissolving based on category values from layer <%s>.") % \
+                          ("column", layer))
+	grass.run_command('v.extract', flags = 'd', input = input,
+			  output = output, type = 'area', layer = layer)
     else:
         if int(layer) == -1:
             grass.warning(_("Invalid layer number (%d). "
-                            "Parameter '%s' specified, assuming layer '1'.") %
+                            "Parameter '%s' specified, assuming layer '1'.") %
                           (int(layer), 'column'))
             layer = '1'
         try:
             coltype = grass.vector_columns(input, layer)[column]
         except KeyError:
             grass.fatal(_('Column <%s> not found') % column)
+	if coltype['type'] not in ('INTEGER', 'SMALLINT', 'CHARACTER', 'TEXT'):
+	    grass.fatal(_("Key column must be of type integer or string"))
-        if coltype['type'] not in ('INTEGER', 'SMALLINT', 'CHARACTER', 'TEXT'):
-            grass.fatal(_("Key column must be of type integer or string"))
         f = grass.vector_layer_db(input, layer)
-        tmpfile = '%s_%s' % (output, tmp)
+	tmpfile = '%s_%s' % (output, tmp)
         try:
             grass.run_command('v.reclass', input=input, output=tmpfile,
                               layer=layer, column=column)
             grass.run_command('v.extract', flags='d', input=tmpfile,
-        except CalledModuleError as e:
+        except CalledModuleError, e:
             grass.fatal(_("Final extraction steps failed."
                           " Check above error messages and"
                           " see following details:\n%s") % e)
Modified: grass/trunk/scripts/v.import/v.import.py
--- grass/trunk/scripts/v.import/v.import.py	2016-03-29 06:29:14 UTC (rev 68180)
+++ grass/trunk/scripts/v.import/v.import.py	2016-03-29 08:10:14 UTC (rev 68181)
@@ -153,10 +153,10 @@
         # list datum transform parameters
         if not options['epsg']:
             grass.fatal(_("Missing value for parameter <%s>") % 'epsg')
         return grass.run_command('g.proj', epsg=options['epsg'],
                                  datum_trans=options['datum_trans'])
     grassenv = grass.gisenv()
     tgtloc = grassenv['LOCATION_NAME']
     tgtmapset = grassenv['MAPSET']
@@ -191,12 +191,12 @@
     # switch to temp location
     os.environ['GISRC'] = str(SRCGISRC)
-    if options['epsg']:  # force given EPSG
+    if options['epsg']: # force given EPSG
         kwargs = {}
         if options['datum_trans']:
             kwargs['datum_trans'] = options['datum_trans']
         grass.run_command('g.proj', flags='c', epsg=options['epsg'], **kwargs)
     # switch to target location
     os.environ['GISRC'] = str(tgtgisrc)
@@ -206,25 +206,21 @@
         try:
             grass.run_command('v.in.ogr', input=OGRdatasource,
                               flags=vflags, overwrite=overwrite, **vopts)
-            grass.message(
-                _("Input <%s> successfully imported without reprojection") %
-                OGRdatasource)
+            grass.message(_("Input <%s> successfully imported without reprojection") % OGRdatasource)
             return 0
             grass.fatal(_("Unable to import <%s>") % OGRdatasource)
     # make sure target is not xy
     if grass.parse_command('g.proj', flags='g')['name'] == 'xy_location_unprojected':
-        grass.fatal(
-            _("Coordinate reference system not available for current location <%s>") %
-            tgtloc)
+        grass.fatal(_("Coordinate reference system not available for current location <%s>") % tgtloc)
     # print projection at verbose level
     grass.verbose(grass.read_command('g.proj', flags='p').rstrip(os.linesep))
     # make sure input is not xy
         grass.fatal(_("Coordinate reference system not available for input <%s>") % OGRdatasource)
Modified: grass/trunk/scripts/v.in.e00/v.in.e00.py
--- grass/trunk/scripts/v.in.e00/v.in.e00.py	2016-03-29 06:29:14 UTC (rev 68180)
+++ grass/trunk/scripts/v.in.e00/v.in.e00.py	2016-03-29 08:10:14 UTC (rev 68181)
@@ -43,7 +43,7 @@
 import glob
 from grass.script.utils import try_rmdir, try_remove, basename
 from grass.script import vector as gvect
@@ -54,115 +54,113 @@
     e00tmp = str(os.getpid())
-    # check for avcimport
-    if not gcore.find_program('avcimport'):
-        gcore.fatal(_("'avcimport' program not found, install it first") +
-                    "\n" + "http://avce00.maptools.org")
+    #### check for avcimport
+    if not grass.find_program('avcimport'):
+	grass.fatal(_("'avcimport' program not found, install it first") +
+		    "\n" +
-    # check for e00conv
-    if not gcore.find_program('e00conv'):
-        gcore.fatal(_("'e00conv' program not found, install it first") +
+    #### check for e00conv
+    if not grass.find_program('e00conv'):
+	grass.fatal(_("'e00conv' program not found, install it first") +
+		    "\n" +
     # check that the user didn't use all three, which gets past the parser.
-    if type not in ['point', 'line', 'area']:
-        gcore.fatal(_('Must specify one of "point", "line", or "area".'))
+    if type not in ['point','line','area']:
+	grass.fatal(_('Must specify one of "point", "line", or "area".'))
     e00name = basename(filename, 'e00')
     # avcimport only accepts 13 chars:
     e00shortname = e00name[:13]
-    # check if this is a split E00 file (.e01, .e02 ...):
+    #check if this is a split E00 file (.e01, .e02 ...):
     merging = False
     if os.path.exists(e00name + '.e01') or os.path.exists(e00name + '.E01'):
-        gcore.message(_("Found that E00 file is split into pieces (.e01, ...)."
-                        " Merging..."))
-        merging = True
+	grass.message(_("Found that E00 file is split into pieces (.e01, ...). Merging..."))
+	merging = True
     if vect:
-        name = vect
+	name = vect
     else:
-        name = e00name
+	name = e00name
-    # do import
+    ### do import
-    # make a temporary directory
-    tmpdir = gcore.tempfile()
+    #make a temporary directory
+    tmpdir = grass.tempfile()
     try_remove(tmpdir)
     os.mkdir(tmpdir)
-    files = glob.glob(
-        e00name + '.e[0-9][0-9]') + glob.glob(e00name + '.E[0-9][0-9]')
+    files = glob.glob(e00name + '.e[0-9][0-9]') + glob.glob(e00name + '.E[0-9][0-9]')
     for f in files:
-        shutil.copy(f, tmpdir)
+	shutil.copy(f, tmpdir)
-    # change to temporary directory to later avoid removal problems (rm -r ...)
+    #change to temporary directory to later avoid removal problems (rm -r ...)
     os.chdir(tmpdir)
-    # check for binay E00 file (we can just check if import fails):
-    # avcimport doesn't set exist status :-(
+    #check for binay E00 file (we can just check if import fails):
+    #avcimport doesn't set exist status :-(
     if merging:
-        files.sort()
-        filename = "%s.cat.%s.e00" % (e00name, e00tmp)
-        outf = file(filename, 'wb')
-        for f in files:
-            inf = file(f, 'rb')
-            shutil.copyfileobj(inf, outf)
-            inf.close()
-        outf.close()
+	files.sort()
+	filename = "%s.cat.%s.e00" % (e00name, e00tmp)
+	outf = file(filename, 'wb')
+	for f in files:
+	    inf = file(f, 'rb')
+	    shutil.copyfileobj(inf, outf)
+	    inf.close()
+	outf.close()
     nuldev = file(os.devnull, 'w+')
-    gcore.message(_("An error may appear next which will be ignored..."))
-    if gcore.call(['avcimport', filename, e00shortname], stdout=nuldev,
-                  stderr=nuldev) == 1:
-        gcore.message(_("E00 ASCII found and converted to Arc Coverage in "
-                        "current directory"))
+    grass.message(_("An error may appear next which will be ignored..."))
+    if grass.call(['avcimport', filename, e00shortname], stdout = nuldev, stderr = nuldev) == 1:
+	grass.message(_("E00 ASCII found and converted to Arc Coverage in current directory"))
     else:
-        gcore.message(
-            _("E00 Compressed ASCII found. Will uncompress first..."))
-        try_remove(e00shortname)
-        gcore.call(['e00conv', filename, e00tmp + '.e00'])
-        gcore.message(_("...converted to Arc Coverage in current directory"))
-        gcore.call(['avcimport', e00tmp + '.e00', e00shortname], stderr=nuldev)
+	grass.message(_("E00 Compressed ASCII found. Will uncompress first..."))
+	try_remove(e00shortname)
+	grass.call(['e00conv', filename, e00tmp + '.e00'])
+	grass.message(_("...converted to Arc Coverage in current directory"))
+	grass.call(['avcimport', e00tmp + '.e00', e00shortname], stderr = nuldev)
-    # SQL name fix:
+    #SQL name fix:
     name = name.replace('-', '_')
-    # let's import...
-    gcore.message(_("Importing %ss...") % type)
+    ## let's import...
+    grass.message(_("Importing %ss...") % type)
-    layer = dict(point='LAB', line='ARC', area=['LAB', 'ARC'])
-    itype = dict(point='point', line='line', area='centroid')
+    layer = dict(point = 'LAB', line = 'ARC', area = ['LAB','ARC'])
+    itype = dict(point = 'point', line = 'line', area = 'centroid')
     try:
-        gcore.run_command('v.in.ogr', flags='o', input=e00shortname,
+        grass.run_command('v.in.ogr', flags='o', input=e00shortname,
                           layer=layer[type], type=itype[type],
                           output=name)
-        gcore.fatal(_("An error occurred while running v.in.ogr"))
+        grass.fatal(_("An error occurred while running v.in.ogr"))
-    gcore.message(_("Imported <%s> vector map <%s>.") % (type, name))
+    grass.message(_("Imported <%s> vector map <%s>.") % (type, name))
-    # clean up the mess
+    #### clean up the mess
     for root, dirs, files in os.walk('.', False):
-        for f in files:
-            path = os.path.join(root, f)
-            try_remove(path)
-        for d in dirs:
-            path = os.path.join(root, d)
-            try_rmdir(path)
+	for f in files:
+	    path = os.path.join(root, f)
+	    try_remove(path)
+	for d in dirs:
+	    path = os.path.join(root, d)
+	    try_rmdir(path)
     os.chdir('..')
     os.rmdir(tmpdir)
+    #### end
-    # end
-    gcore.message(_("Done."))
     gvect.vector_history(name)
     main()
Modified: grass/trunk/scripts/v.in.geonames/v.in.geonames.py
--- grass/trunk/scripts/v.in.geonames/v.in.geonames.py	2016-03-29 06:29:14 UTC (rev 68180)
+++ grass/trunk/scripts/v.in.geonames/v.in.geonames.py	2016-03-29 08:10:14 UTC (rev 68181)
@@ -37,12 +37,11 @@
 import os
 def main():
-    infile = options['input']
+    infile  = options['input']
     outfile = options['output']
-    # are we in LatLong location?
+    #are we in LatLong location?
     s = grass.read_command("g.proj", flags='j')
     kv = grass.parse_key_val(s)
     if kv['+proj'] != 'longlat':
@@ -56,8 +55,7 @@
     dbfdriver = kv['driver'] == 'dbf'
     if dbfdriver:
-        grass.warning(
-            _("Since DBF driver is used, the content of the 'alternatenames' column might be cut with respect to the original Geonames.org column content"))
+        grass.warning(_("Since DBF driver is used, the content of the 'alternatenames' column might be cut with respect to the original Geonames.org column content"))
     with open(infile) as f:
         num_places = sum(1 for _ in f)
@@ -89,54 +87,55 @@
     # geonameid|name|asciiname|alternatenames|latitude|longitude|featureclass|featurecode|countrycode|cc2|admin1code|admin2code|admin3code|admin4code|population|elevation|gtopo30|timezone|modificationdate
     # debug:
     # head -n 3 ${TMPFILE}.csv
     # use different column names limited to 10 chars for dbf
     if dbfdriver:
         columns = ['geonameid integer',
-                   'name varchar(200)',
-                   'asciiname varchar(200)',
-                   'altname varchar(4000)',
-                   'latitude double precision',
-                   'longitude double precision',
-                   'featrclass varchar(1)',
-                   'featrcode varchar(10)',
-                   'cntrycode varchar(2)',
-                   'cc2 varchar(60)',
-                   'admin1code varchar(20)',
-                   'admin2code varchar(20)',
-                   'admin3code varchar(20)',
-                   'admin4code varchar(20)',
-                   'population integer',
-                   'elevation integer',
-                   'gtopo30 integer',
-                   'timezone varchar(50)',
-                   'mod_date date']
+           'name varchar(200)',
+           'asciiname varchar(200)',
+           'altname varchar(4000)',
+           'latitude double precision',
+           'longitude double precision',
+           'featrclass varchar(1)',
+           'featrcode varchar(10)',
+           'cntrycode varchar(2)',
+           'cc2 varchar(60)',
+           'admin1code varchar(20)',
+           'admin2code varchar(20)',
+           'admin3code varchar(20)',
+           'admin4code varchar(20)',
+           'population integer',
+           'elevation integer',
+           'gtopo30 integer',
+           'timezone varchar(50)',
+           'mod_date date']
     else:
-                   'alternatename varchar(4000)',
-                   'featureclass varchar(1)',
-                   'featurecode varchar(10)',
-                   'countrycode varchar(2)',
-                   'modification date']
+           'alternatename varchar(4000)',
+           'featureclass varchar(1)',
+           'featurecode varchar(10)',
+           'countrycode varchar(2)',
+           'modification date']
-    grass.run_command('v.in.ascii', cat=0, x=6, y=5, sep='tab',
-                      input=infile, output=outfile,
-                      columns=columns)
+    grass.run_command('v.in.ascii', cat = 0, x = 6, y = 5, sep = 'tab',
+              input = infile, output = outfile,
+              columns = columns)
     grass.vector_history(outfile)
@@ -144,3 +143,4 @@
     main()
Modified: grass/trunk/scripts/v.in.lines/v.in.lines.py
--- grass/trunk/scripts/v.in.lines/v.in.lines.py	2016-03-29 06:29:14 UTC (rev 68180)
+++ grass/trunk/scripts/v.in.lines/v.in.lines.py	2016-03-29 08:10:14 UTC (rev 68181)
@@ -41,11 +41,9 @@
 from grass.script.utils import separator, try_remove
 def cleanup():
     try_remove(tmp)
 def main():
     global tmp
@@ -59,9 +57,11 @@
     else:
         do3D = ''
-    # set up input file
+    #### set up input file
     if options['input'] == '-':
         infile = None
         inf = sys.stdin
@@ -71,6 +71,7 @@
             grass.fatal(_("Unable to read input file <%s>") % infile)
         grass.debug("input file=[%s]" % infile)
     if not infile:
         # read from stdin and write to tmpfile (v.in.mapgen wants a real file)
         outf = file(tmp, 'w')
@@ -98,7 +99,8 @@
             outf.close()
             runfile = tmp
-    # check that there are at least two columns (three if -z is given)
+    ##### check that there are at least two columns (three if -z is given)
     inf = file(runfile)
     for line in inf:
         if len(line.lstrip()) == 0 or line[0] == '#':
@@ -109,10 +111,11 @@
     if (do3D and numcols < 3) or (not do3D and numcols < 2):
         grass.fatal(_("Not enough data columns. (incorrect fs setting?)"))
-    grass.run_command('v.in.mapgen', flags='f' + do3D,
-                      input=runfile, output=options['output'])
+    grass.run_command('v.in.mapgen', flags = 'f' + do3D,
+                      input = runfile, output = options['output'])
     atexit.register(cleanup)
Modified: grass/trunk/scripts/v.in.mapgen/v.in.mapgen.py
--- grass/trunk/scripts/v.in.mapgen/v.in.mapgen.py	2016-03-29 06:29:14 UTC (rev 68180)
+++ grass/trunk/scripts/v.in.mapgen/v.in.mapgen.py	2016-03-29 08:10:14 UTC (rev 68181)
@@ -34,7 +34,7 @@
 #%end
 #%flag
 #% key: z
-#% description: Create a 3D vector points map from 3 column Matlab data
+#% description: Create a 3D vector points map from 3 column Matlab data
 #%end
 #%option G_OPT_F_INPUT
 #% description: Name of input file in Mapgen/Matlab format
@@ -59,7 +59,6 @@
     try_remove(tmp)
     try_remove(tmp + '.dig')
 def main():
     global tmp
@@ -90,32 +89,32 @@
-    # create ascii vector file
+    #### create ascii vector file
     inf = file(infile)
     grass.message(_("Importing data..."))
-    cat = 1
+    cat = 1
     if matlab:
-        # HB:  OLD v.in.mapgen.sh Matlab import command follows.
-        # I have no idea what it's all about, so "new" matlab format will be
-        # a series of x y with "nan nan" breaking lines. (as NOAA provides)
-        # Old command:
+        ## HB:  OLD v.in.mapgen.sh Matlab import command follows.
+        ##    I have no idea what it's all about, so "new" matlab format will be
+        ##    a series of x y with "nan nan" breaking lines. (as NOAA provides)
+        ##  Old command:
         #  tac $infile | $AWK 'BEGIN { FS="," ; R=0 }
         #    $1~/\d*/   { printf("L %d\n", R) }
         #    $1~/   .*/ { printf(" %lf %lf\n", $2, $1) ; ++R }
         #    $1~/END/   { }' | tac > "$TMP"
-        # matlab format.
+        ## matlab format.
         points = []
         for line in inf:
             f = line.split()
             if f[0].lower() == 'nan':
                 if points != []:
                     outf.write("L %d 1\n" % len(points))
                     for point in points:
-                        outf.write(" %.15g %.15g %.15g\n" % tuple(map(float, point)))
+                        outf.write(" %.15g %.15g %.15g\n" % tuple(map(float,point)))
                     outf.write(" 1 %d\n" % cat)
                     cat += 1
                 points = []
@@ -123,7 +122,7 @@
                 if len(f) == 2:
                     f.append('0')
                 points.append(f)
         if points != []:
@@ -132,36 +131,36 @@
                 except ValueError:
                     grass.fatal(_("An error occurred on line '%s', exiting.") % line.strip())
-            cat += 1
+            cat += 1
     else:
-        # mapgen format.
+        ## mapgen format.
         points = []
         for line in inf:
             if line[0] == '#':
                 if points != []:
-                        outf.write(" %.15g %.15g\n" % tuple(map(float, point)))
+                        outf.write(" %.15g %.15g\n" % tuple(map(float,point)))
                     cat += 1
                 points = []
             else:
                 points.append(line.rstrip('\r\n').split('\t'))
         if points != []:
             cat += 1
     outf.close()
     inf.close()
-    # create digit header
+    #### create digit header
     digfile = tmp + '.dig'
     outf = file(digfile, 'w')
-        """ORGANIZATION: GRASSroots organization
+    t = string.Template(\
+"""ORGANIZATION: GRASSroots organization
 DIGIT DATE:   $date
 DIGIT NAME:   $user@$host
 MAP NAME:     $name
@@ -176,12 +175,12 @@
     year = time.strftime("%Y")
     user = os.getenv('USERNAME') or os.getenv('LOGNAME')
     host = os.getenv('COMPUTERNAME') or os.uname()[1]
-    s = t.substitute(prog=prog, name=name, date=date, year=year,
-                     user=user, host=host)
+    s = t.substitute(prog = prog, name = name, date = date, year = year,
+                     user = user, host = host)
     outf.write(s)
-    # process points list to ascii vector file (merge in vertices)
+    #### process points list to ascii vector file (merge in vertices)
     inf = file(tmp)
     inf.close()
@@ -189,13 +188,13 @@
     outf.close()
     if not name:
-        # if no name for vector file given, cat to stdout
+        #### if no name for vector file given, cat to stdout
         inf = file(digfile)
         shutil.copyfileobj(inf, sys.stdout)
         inf.close()
     else:
-        # import to binary vector file
-        grass.message(_("Importing with v.in.ascii..."))
+        #### import to binary vector file
+        grass.message(_("Importing with v.in.ascii..."))
         try:
             grass.run_command('v.in.ascii', flags=do3D, input=digfile,
                               output=name, format='standard')
@@ -206,3 +205,4 @@
     main()
Modified: grass/trunk/scripts/v.in.wfs/v.in.wfs.py
--- grass/trunk/scripts/v.in.wfs/v.in.wfs.py	2016-03-29 06:29:14 UTC (rev 68180)
+++ grass/trunk/scripts/v.in.wfs/v.in.wfs.py	2016-03-29 08:10:14 UTC (rev 68181)
@@ -64,7 +64,7 @@
 #%end
 #%flag
 #% key: l
-# todo #% description: List available layers and exit
+#todo #% description: List available layers and exit
 #% description: Download server capabilities to 'wms_capabilities.xml' in the current directory and exit
 #% suppress_required: yes
 #%end
@@ -80,7 +80,6 @@
 import urllib
 def main():
     out = options['output']
     wfs_url = options['url']
@@ -105,7 +104,7 @@
             grass.fatal('Features begin with index "1"')
     if flags['r']:
-        bbox = grass.read_command("g.region", flags='w').split('=')[1]
+        bbox = grass.read_command("g.region", flags = 'w').split('=')[1]
         wfs_url += '&BBOX=' + bbox
     if flags['l']:
@@ -120,10 +119,10 @@
     inf = urllib.urlopen(wfs_url)
     outf = file(tmpxml, 'wb')
     while True:
-        s = inf.read()
-        if not s:
-            break
-        outf.write(s)
+	s = inf.read()
+	if not s:
+	    break
+	outf.write(s)
     inf.close()
     outf.close()
@@ -136,6 +135,7 @@
         try_remove(tmpxml)
         sys.exit(0)
     try:
         grass.run_command('v.in.ogr', flags='o', input=tmpxml, output=out)
Modified: grass/trunk/scripts/v.krige/v.krige.py
--- grass/trunk/scripts/v.krige/v.krige.py	2016-03-29 06:29:14 UTC (rev 68180)
+++ grass/trunk/scripts/v.krige/v.krige.py	2016-03-29 08:10:14 UTC (rev 68181)
@@ -15,7 +15,7 @@
 for details.
-# g.parser information
+## g.parser information
 #%module
 #% description: Performs ordinary or block kriging for vector maps.
@@ -96,26 +96,27 @@
 #% description: If omitted, will be <input name>_kriging.var
 #% required : no
 #%end
-import os
-import sys
-# i18N
-import gettext
+import os, sys
+from tempfile import gettempdir
+import time
+import thread
-if "GISBASE" not in os.environ:
-    print("You must be in GRASS GIS to run this program.")
+if not os.environ.has_key("GISBASE"):
+    print "You must be in GRASS GIS to run this program."
     sys.exit(1)
-gettext.install('grasswxpy', os.path.join(os.getenv("GISBASE"), 'locale'))
+### i18N
+import gettext
+gettext.install('grasswxpy', os.path.join(os.getenv("GISBASE"), 'locale'), unicode = True)
-# dependencies to be checked once, as they are quite time-consuming. cfr. grass.parser.
+### dependencies to be checked once, as they are quite time-consuming. cfr. grass.parser.
 # GRASS binding
 try:
 except ImportError:
     sys.exit(_("No GRASS-python library found"))
 # move other checks in functions, as R?
 # globals
@@ -127,15 +128,12 @@
 #~ robjects = None
 #~ rinterface = None
-# classes in alphabetical order. methods in logical order :)
+#classes in alphabetical order. methods in logical order :)
-# <2.5 class definition, without () - please test
+# <2.5 class definition, without () - please test
 class Controller:
     """ Executes analysis. For the moment, only with gstat functions."""
     # moved here the global variables
     def __init__(self):
         #~ self.Command = None
         self.InputData = None
@@ -143,24 +141,24 @@
         #~ VariogramFunction = None
         #~ robjects = None
     def ImportMap(self, map, column):
         """ Imports GRASS map as SpatialPointsDataFrame and adds x/y columns to attribute table.
         Checks for NULL values in the provided column and exits if they are present."""
         #@NOTE: new way with R - as it doesn't alter original data
-        Rpointmap = robjects.r.readVECT(map, type='point')
+        Rpointmap = robjects.r.readVECT(map, type =  'point')
         # checks if x,y columns are present in dataframe. If they do are present, but with different names,
         # they'll be duplicated.
-        if "x" not in robjects.r.names(Rpointmap):
+        if "x" not in robjects.r.names(Rpointmap):
             # extract coordinates with S4 method
             coordinatesPreDF = robjects.r['as.data.frame'](robjects.r.coordinates(Rpointmap))
-            coordinatesDF = robjects.r['data.frame'](x=coordinatesPreDF.rx('coords.x1')[0],
-                                                     y=coordinatesPreDF.rx('coords.x2')[0])
+            coordinatesDF = robjects.r['data.frame'](x = coordinatesPreDF.rx('coords.x1')[0],
+                                                     y = coordinatesPreDF.rx('coords.x2')[0])
             # match coordinates with data slot of SpatialPointsDataFrame - maptools function
             # match is done on row.names
             Rpointmap = robjects.r.spCbind(Rpointmap, coordinatesDF)
         # GRASS checks for null values in the chosen column. R can hardly handle column as a variable,
         # looks for a hardcoded string.
         cols = grass.vector_columns(map=map, layer=1)
@@ -168,101 +166,95 @@
                                         map=map,
                                         column=column,
                                         type='point',
-                                        parse=(grass.parse_key_val,
-                                               {'sep': ': '}
+                                        parse = (grass.parse_key_val,
+                                                 {'sep':': '}
                                         )['number of NULL attributes'])
-        if nulls > 0:
-            grass.fatal(
-                _("%d NULL value(s) in the selected column - unable to perform kriging.") %
-                nulls)
+        if nulls > 0:
+            grass.fatal(_("%d NULL value(s) in the selected column - unable to perform kriging.") % nulls)
         return Rpointmap
     def CreateGrid(self, inputdata):
         Region = grass.region()
         Grid = robjects.r.gmeta2grd()
         # addition of coordinates columns into dataframe.
         coordinatesDF = robjects.r['as.data.frame'](robjects.r.coordinates(Grid))
-        data = robjects.r['data.frame'](x=coordinatesDF.rx('s1')[0],
-                                        y=coordinatesDF.rx('s2')[0],
-                                        k=robjects.r.rep(1, Region['cols'] * Region['rows']))
-        GridPredicted = robjects.r.SpatialGridDataFrame(
-            Grid, data, proj4string=robjects.r.CRS(
-                robjects.r.proj4string(inputdata)))
+        data = robjects.r['data.frame'](x = coordinatesDF.rx('s1')[0],
+                                        y = coordinatesDF.rx('s2')[0],
+                                        k = robjects.r.rep(1, Region['cols']*Region['rows']))
+        GridPredicted = robjects.r.SpatialGridDataFrame(Grid,
+                                                        data,
+                                                        proj4string =  robjects.r.CRS(robjects.r.proj4string(inputdata)))
         return GridPredicted
     def ComposeFormula(self, column, isblock):
         if isblock is True:
             predictor = 'x+y'
         else:
             predictor = '1'
-        print(column + "~" + predictor)
+        print column + "~" + predictor
         Formula = robjects.Formula(column + "~" + predictor)
         return Formula
-    def FitVariogram(self, formula, inputdata, sill, nugget, range, kappa, model=''):
+    def FitVariogram(self, formula, inputdata, sill, nugget, range, kappa, model = ''):
         """ Fits variogram either automagically either specifying all parameters.
         Returns a list containing data and model variograms. """
         Variograms = {}
         if model is '':
             robjects.r.require('automap')
             DottedParams = {}
             #print (nugget.r_repr(), sill, range)
             DottedParams['fix.values'] = robjects.r.c(nugget, range, sill)
-            if not isinstance(kappa, float):
+            if not type(kappa) == float:
                 # autofit gives strange results if kappa is NA
                 VariogramModel = robjects.r.autofitVariogram(formula, inputdata, **DottedParams)
             else:
-                VariogramModel = robjects.r.autofitVariogram(
-                    formula, inputdata, kappa=kappa, **DottedParams)
-            # print robjects.r.warnings()
+                VariogramModel = robjects.r.autofitVariogram(formula, inputdata, kappa=kappa, **DottedParams)
+            #print robjects.r.warnings()
             Variograms['datavariogram'] = VariogramModel.rx('exp_var')[0]
             Variograms['variogrammodel'] = VariogramModel.rx('var_model')[0]
-            # obtain the model name. *Too* complicated to get the string instead of
-            # level, unlike R does.
-            VariogramAsDF = robjects.r['as.data.frame'](
-                VariogramModel.rx('var_model')[0])  # force conversion
+            # obtain the model name. *Too* complicated to get the string instead of level, unlike R does.
+            VariogramAsDF = robjects.r['as.data.frame'](VariogramModel.rx('var_model')[0]) # force conversion
             ModelDF = VariogramAsDF.rx('model')[0]
             Variograms['model'] = ModelDF.levels[ModelDF[1] - 1]
         else:
             DataVariogram = robjects.r['variogram'](formula, inputdata)
             VariogramModel = robjects.r['fit.variogram'](DataVariogram,
-                                                         model=robjects.r.vgm(psill=sill,
-        model=model,
-        nugget=nugget,
-        range=range,
-        kappa=kappa))
+                                                         model = robjects.r.vgm(psill = sill,
+        model = model,
+        nugget = nugget,
+        range = range,
+        kappa = kappa))
             Variograms['datavariogram'] = DataVariogram
             Variograms['model'] = model
         return Variograms
     def DoKriging(self, formula, inputdata, grid, model, block):
-        DottedParams = {'debug.level': -1}  # let krige() print percentage status
-        if block is not '':  # @FIXME(anne): but it's a string!! and krige accepts it!!
+        DottedParams = {'debug.level': -1} # let krige() print percentage status
+        if block is not '': #@FIXME(anne): but it's a string!! and krige accepts it!!
             DottedParams['block'] = block
-        # print DottedParams
+        #print DottedParams
         KrigingResult = robjects.r.krige(formula, inputdata, grid, model, **DottedParams)
         return KrigingResult
     def ExportMap(self, map, column, name, overwrite, command, variograms):
         # add kriging parameters to raster map history
-        robjects.r.writeRAST(map, vname=name, zcol=column, overwrite=overwrite)
+        robjects.r.writeRAST(map, vname = name, zcol = column, overwrite = overwrite)
         grass.run_command('r.support',
-                          map=name,
-                          title='Kriging output',
-                          history='Issued from command v.krige ' + command)
-        if command.find(
-                'model') is -1:  # if the command has no model option, add automap chosen model
-            grass.run_command('r.support',
-                              map=name,
-                              history='Model chosen by automatic fitting: ' + variograms['model'])
-    def Run(self, input, column, output, package, sill, nugget, range, kappa, logger,
+                          map = name,
+                          title = 'Kriging output',
+                          history = 'Issued from command v.krige ' + command)
+        if command.find('model') is -1: # if the command has no model option, add automap chosen model
+                    grass.run_command('r.support',
+                                      map = name,
+                                      history = 'Model chosen by automatic fitting: ' + variograms['model'])
+    def Run(self, input, column, output, package, sill, nugget, range, kappa, logger, \
             overwrite, model, block, output_var, command, **kwargs):
         """ Wrapper for all functions above. """
@@ -275,9 +267,9 @@
         # and from here over, InputData refers to the global variable
         #print(robjects.r.slot(InputData, 'data').names)
         logger.message(_("Data successfully imported."))
         GridPredicted = self.CreateGrid(self.InputData)
         logger.message(_("Fitting variogram..."))
         if block is not '':
@@ -286,93 +278,87 @@
             self.predictor = '1'
         if self.Variogram is None:
             self.Variogram = self.FitVariogram(robjects.Formula(column + "~" + self.predictor),
-                                               self.InputData,
-                                               model=model,
-                                               sill=sill,
-                                               nugget=nugget,
-                                               range=range,
-                                               kappa=kappa)
+                                          self.InputData,
+                                          model = model,
+                                          sill = sill,
+                                          nugget = nugget,
+                                          range = range,
+                                          kappa = kappa)
         logger.message(_("Variogram fitting complete."))
         logger.message(_("Kriging..."))
-        KrigingResult = self.DoKriging(
-            robjects.Formula(
-                column + "~" + self.predictor),
-            self.InputData,
-            GridPredicted,
-            self.Variogram['variogrammodel'],
-            block)  # using global ones
+        KrigingResult = self.DoKriging(robjects.Formula(column + "~" + self.predictor), self.InputData,
+                 GridPredicted, self.Variogram['variogrammodel'], block) # using global ones
         logger.message(_("Kriging complete."))
-        self.ExportMap(map=KrigingResult,
+        self.ExportMap(map = KrigingResult,
                        column='var1.pred',
-                       name=output,
-                       overwrite=overwrite,
-                       command=command,
-                       variograms=self.Variogram)
+                       name = output,
+                       overwrite = overwrite,
+                       command = command,
+                       variograms = self.Variogram)
         if output_var is not '':
                            column='var1.var',
-                           name=output_var,
-                           command=command,
-def main(argv=None):
+                           name = output_var,
+def main(argv = None):
     """ Main. Calls either GUI or CLI, depending on arguments provided. """
     #@FIXME: solve this double ifelse. the control should not be done twice.
     controller = Controller()
     if argv is None:
         importR()
-        argv = sys.argv[1:]  # stripping first item, the full name of this script
+        argv = sys.argv[1:] # stripping first item, the full name of this script
         # wxGUI call
         if not os.getenv("GRASS_WXBUNDLED"):
             from core import globalvar
             globalvar.CheckForWx()
         from modules import vkrige as GUI
         import wx
         app = wx.App()
-        KrigingFrame = GUI.KrigingModule(parent=None,
-                                         Rinstance=robjects,
-                                         controller=controller)
+        KrigingFrame = GUI.KrigingModule(parent = None,
+                                         Rinstance = robjects,
+                                         controller = controller)
         KrigingFrame.Centre()
         KrigingFrame.Show()
         app.MainLoop()
     else:
-        # CLI
+        #CLI
         options, flags = argv
         #@TODO: Work on verbosity. Sometimes it's too verbose (R), sometimes not enough.
-        if grass.find_file(options['input'], element='vector')['fullname'] is '':
-            grass.fatal(_("Vector map <%s> not found") % options['input'])
+        if grass.find_file(options['input'], element = 'vector')['fullname'] is '':
+            grass.fatal(_("Vector map <%s> not found") % options['input'] )
         #@TODO: elaborate input string, if contains mapset or not.. thanks again to Bob for testing on 64bit.
         # create output map name, if not specified
         if options['output'] is '':
-            try:  # to strip mapset name from fullname. Ugh.
+            try: # to strip mapset name from fullname. Ugh.
                 options['input'] = options['input'].split("@")[0]
             except:
                 pass
             options['output'] = options['input'] + '_kriging'
         # check for output map with same name. g.parser can't handle this, afaik.
-        if grass.find_file(options['output'], element='cell')['fullname'] \
-           and os.getenv("GRASS_OVERWRITE") is None:
+        if grass.find_file(options['output'], element = 'cell')['fullname'] \
+           and os.getenv("GRASS_OVERWRITE") == None:
             grass.fatal(_("option: <output>: Raster map already exists."))
         if options['output_var'] is not '' \
-           and (grass.find_file(options['output_var'], element='cell')['fullname']
-                and os.getenv("GRASS_OVERWRITE") is None):
+           and (grass.find_file(options['output_var'], element = 'cell')['fullname'] \
+           and os.getenv("GRASS_OVERWRITE") == None):
             grass.fatal(_("option: <output>: Variance raster map already exists."))
-        importR()
+        importR()
         if options['model'] is '':
             try:
                 robjects.r.require("automap")
@@ -380,20 +366,19 @@
                 grass.fatal(_("R package automap is missing, no variogram autofit available."))
         else:
             if options['sill'] is '' or options['nugget'] is '' or options['range'] is '':
-                grass.fatal(
-                    _("You have specified model, but forgot at least one of sill, nugget and range."))
+                grass.fatal(_("You have specified model, but forgot at least one of sill, nugget and range."))
         #@TODO: let GRASS remount its commandstring. Until then, keep that 4 lines below.
-        # print grass.write_command(argv)
+        #print grass.write_command(argv)
         command = ""
         notnulloptions = {}
         for k, v in options.items():
             if v is not '':
                 notnulloptions[k] = v
         command = command.join("%s=%s " % (k, v) for k, v in notnulloptions.items())
         # re-cast integers from strings, as parser() cast everything to string.
-        for each in ("sill", "nugget", "range", "kappa"):
+        for each in ("sill","nugget","range","kappa"):
             if options[each] is not '':
                 if each == "kappa":
                     options[each] = float(options[each])
@@ -401,24 +386,23 @@
                     options[each] = int(options[each])
             else:
                 options[each] = robjects.r('''NA''')
         #controller = Controller()
-        controller.Run(input=options['input'],
-                       column=options['column'],
-                       output=options['output'],
-                       overwrite=os.getenv("GRASS_OVERWRITE") == 1,
-                       package=options['package'],
-                       model=options['model'],
-                       block=options['block'],
-                       sill=options['sill'],
-                       nugget=options['nugget'],
-                       range=options['range'],
-                       kappa=options['kappa'],
-                       output_var=options['output_var'],
-                       command=command,
-                       logger=grass)
+        controller.Run(input = options['input'],
+                       column = options['column'],
+                       output = options['output'],
+                       overwrite = os.getenv("GRASS_OVERWRITE") == 1,
+                       package = options['package'],
+                       model = options['model'],
+                       block = options['block'],
+                       sill = options['sill'],
+                       nugget = options['nugget'],
+                       range = options['range'],
+                       kappa = options['kappa'],
+                       output_var = options['output_var'],
+                       logger = grass)
 def importR():
     # R
     # unuseful since rpy2 will complain adequately.
@@ -427,31 +411,31 @@
     #    grass.find_program('R')
     # except:
     #    sys.exit(_("R is not installed. Install it and re-run, or modify environment variables."))
     # rpy2
     global robjects
     global rinterface
     grass.message(_('Loading dependencies, please wait...'))
     try:
         import rpy2.robjects as robjects
-        import rpy2.rinterface as rinterface  # to speed up kriging? for plots.
+        import rpy2.rinterface as rinterface #to speed up kriging? for plots.
     except ImportError:
         # ok for other OSes?
         grass.fatal(_("Python module 'Rpy2' not found. Please install it and re-run v.krige."))
     # R packages check. Will create one error message after check of all packages.
     missingPackagesList = []
     for each in ["rgeos", "gstat", "rgrass7", "maptools"]:
-        if not robjects.r.require(each, quietly=True)[0]:
+        if not robjects.r.require(each, quietly = True)[0]:
             missingPackagesList.append(each)
     if missingPackagesList:
         errorString = _("R package(s) ") + \
-            ", ".join(map(str, missingPackagesList)) + \
-            _(" missing. Install it/them and re-run v.krige.")
+                      ", ".join(map(str, missingPackagesList)) + \
+                      _(" missing. Install it/them and re-run v.krige.")
         grass.fatal(errorString)
 if __name__ == '__main__':
     if len(sys.argv) > 1:
-        sys.exit(main(argv=grass.parser()))
+        sys.exit(main(argv = grass.parser()))
     else:
         main()
Modified: grass/trunk/scripts/v.pack/v.pack.py
--- grass/trunk/scripts/v.pack/v.pack.py	2016-03-29 06:29:14 UTC (rev 68180)
+++ grass/trunk/scripts/v.pack/v.pack.py	2016-03-29 08:10:14 UTC (rev 68181)
@@ -43,38 +43,36 @@
 from grass.script import core as grass
 from grass.script import vector as vector
 def cleanup():
     try_rmdir(basedir)
 def main():
     compression_off = flags['c']
     global basedir
     basedir = grass.tempdir()
     # check if vector map exists
-    gfile = grass.find_file(infile, element='vector')
+    gfile = grass.find_file(infile, element = 'vector')
     if not gfile['name']:
         grass.fatal(_("Vector map <%s> not found") % infile)
     # check if input vector map is in the native format
     if vector.vector_info(gfile['fullname'])['format'] != 'native':
-        grass.fatal(_("Unable to pack vector map <%s>. Only native format supported.") %
-                    gfile['fullname'])
+        grass.fatal(_("Unable to pack vector map <%s>. Only native format supported.") % \
+                        gfile['fullname'])
     # split the name if there is the mapset name
     if infile.find('@'):
         infile = infile.split('@')[0]
     # output name
     if options['output']:
     else:
         outfile = infile + '.pack'
     # check if exists the output file
     if os.path.exists(outfile):
         if os.getenv('GRASS_OVERWRITE'):
@@ -82,18 +80,18 @@
             try_remove(outfile)
         else:
             grass.fatal(_("option <%s>: <%s> exists.") % ("output", outfile))
     # prepare for packing
     grass.verbose(_("Packing <%s>...") % (gfile['fullname']))
-    # write tar file, optional compression
+    # write tar file, optional compression
     if compression_off:
-        tar = tarfile.open(name=outfile, mode='w:')
+        tar = tarfile.open(name = outfile, mode = 'w:')
     else:
-        tar = tarfile.open(name=outfile, mode='w:gz')
+        tar = tarfile.open(name = outfile, mode = 'w:gz')
     tar.add(gfile['file'], infile)
-    # check if exist a db connection for the vector
+    # check if exist a db connection for the vector
     db_vect = vector.vector_db(gfile['fullname'])
     if not db_vect:
         grass.verbose(_('There is not database connected with vector map <%s>') % gfile['fullname'])
@@ -101,14 +99,14 @@
         # for each layer connection save a table in sqlite database
         sqlitedb = os.path.join(basedir, 'db.sqlite')
         for i, dbconn in db_vect.iteritems():
-            grass.run_command('db.copy', from_driver=dbconn['driver'],
-                              from_database=dbconn['database'],
-                              from_table=dbconn['table'],
-                              to_driver='sqlite', to_database=sqlitedb,
-                              to_table=dbconn['table'])
+            grass.run_command('db.copy', from_driver = dbconn['driver'],
+                              from_database = dbconn['database'],
+                              from_table =  dbconn['table'],
+                              to_driver = 'sqlite', to_database = sqlitedb,
+                              to_table = dbconn['table'])
         tar.add(sqlitedb, 'db.sqlite')
-    # add to the tar file the PROJ files to check when unpack file
+    # add to the tar file the PROJ files to check when unpack file
     for support in ['INFO', 'UNITS', 'EPSG']:
         path = os.path.join(gisenv['GISDBASE'], gisenv['LOCATION_NAME'],
@@ -116,9 +114,9 @@
         if os.path.exists(path):
             tar.add(path, 'PROJ_' + support)
     tar.close()
     grass.message(_("Pack file <%s> created") % os.path.join(os.getcwd(), outfile))
 if __name__ == "__main__":
     options, flags = grass.parser()
Modified: grass/trunk/scripts/v.rast.stats/testsuite/test_v_rast_stats.py
--- grass/trunk/scripts/v.rast.stats/testsuite/test_v_rast_stats.py	2016-03-29 06:29:14 UTC (rev 68180)
+++ grass/trunk/scripts/v.rast.stats/testsuite/test_v_rast_stats.py	2016-03-29 08:10:14 UTC (rev 68181)
@@ -5,7 +5,6 @@
 from grass.gunittest.case import TestCase
 from grass.gunittest.gmodules import SimpleModule
 class TestRastStats(TestCase):
     @classmethod
@@ -37,20 +36,19 @@
     def test_1(self):
         # Output of v.rast.stats
-        univar_string = """cat|value|label|a_minimum|a_maximum|a_sum
+        univar_string="""cat|value|label|a_minimum|a_maximum|a_sum
 1|1||102|209|265905
 2|2||121|280|1281195
-        self.assertModule("v.rast.stats", map="zone_map", raster="map_a",
-                          method=["minimum", "maximum", "sum"], flags="c",
+        self.assertModule("v.rast.stats",  map="zone_map", raster="map_a",
+                          method=["minimum","maximum","sum"], flags="c",
                           column_prefix="a")
         v_db_select = SimpleModule("v.db.select", map="zone_map")
-        self.runModule(v_db_select)
+        self.runModule(v_db_select)
         self.assertLooksLike(univar_string, v_db_select.outputs.stdout)
 class TestRastStatsFails(TestCase):
     def test_error_handling_a(self):
@@ -62,7 +60,7 @@
         # No raster map
         self.assertModuleFail("v.rast.stats", map="zone_map",
                               column_prefix="a")
     def test_error_handling_d(self):
         # No column_prefix
         self.assertModuleFail("v.rast.stats", map="zone_map", raster="map_b")
@@ -70,3 +68,5 @@
     from grass.gunittest.main import test
     test()
Modified: grass/trunk/scripts/v.rast.stats/v.rast.stats.py
--- grass/trunk/scripts/v.rast.stats/v.rast.stats.py	2016-03-29 06:29:14 UTC (rev 68180)
+++ grass/trunk/scripts/v.rast.stats/v.rast.stats.py	2016-03-29 08:10:14 UTC (rev 68181)
@@ -79,7 +79,7 @@
 def main():
     global tmp, sqltmp, tmpname, nuldev, vector, rastertmp
     rastertmp = False
-    # setup temporary files
+    #### setup temporary files
     sqltmp = tmp + ".sql"
     # we need a random name
@@ -146,15 +146,13 @@
     try:
         fi = grass.vector_db(map=vector)[int(layer)]
     except KeyError:
-        grass.fatal(
     # we need this for non-DBF driver:
     dbfdriver = fi['driver'] == 'dbf'
     # Find out which table is linked to the vector map on the given layer
     if not fi['table']:
-        grass.fatal(
     # replaced by user choiche
     #basecols = ['n', 'min', 'max', 'range', 'mean', 'stddev', 'variance', 'cf_var', 'sum']
@@ -208,7 +206,7 @@
         if currcolumn in grass.vector_columns(vector, layer).keys():
             if not flags['c']:
                 grass.fatal((_("Cannot create column <%s> (already present). ") % currcolumn) +
-                            _("Use -c flag to update values in this column."))
+                             _("Use -c flag to update values in this column."))
         else:
             if i == "n":
                 coltype = "INTEGER"
@@ -279,9 +277,7 @@
                          " of vector map <{vector}>."
                          ).format(raster=raster, vector=vector)))
     except CalledModuleError:
-        grass.warning(
-            _("Failed to upload statistics to attribute table of vector map <%s>.") %
-            vector)
+        grass.warning(_("Failed to upload statistics to attribute table of vector map <%s>.") % vector)
         exitcode = 1
     sys.exit(exitcode)
Modified: grass/trunk/scripts/v.report/v.report.py
--- grass/trunk/scripts/v.report/v.report.py	2016-03-29 06:29:14 UTC (rev 68180)
+++ grass/trunk/scripts/v.report/v.report.py	2016-03-29 08:10:14 UTC (rev 68181)
@@ -47,7 +47,6 @@
 import os
 def uniq(l):
     result = []
     last = None
@@ -57,7 +56,6 @@
             last = i
     return result
 def main():
     mapname = options['map']
     option = options['option']
@@ -77,13 +75,13 @@
         colnames = ['cat']
     if option == 'coor':
-        columns = ['dummy1', 'dummy2', 'dummy3']
-        extracolnames = ['x', 'y', 'z']
+        columns = ['dummy1','dummy2','dummy3']
+        extracolnames = ['x','y','z']
     else:
         columns = ['dummy1']
         extracolnames = [option]
-    if units in ['p', 'percent']:
+    if units in ['p','percent']:
         unitsp = 'meters'
     elif units:
         unitsp = units
@@ -92,7 +90,7 @@
     # NOTE: we suppress -1 cat and 0 cat
     if isConnection:
-        p = grass.pipe_command('v.db.select', quiet=True, flags='c', map=mapname, layer=layer)
+        p = grass.pipe_command('v.db.select', quiet = True, flags='c', map = mapname, layer = layer)
         records1 = []
         for line in p.stdout:
             cols = line.rstrip('\r\n').split('|')
@@ -102,23 +100,23 @@
         p.wait()
         if p.returncode != 0:
             sys.exit(1)
         records1.sort()
         if len(records1) == 0:
             try:
-                f = grass.vector_db(map=mapname)[int(layer)]
+                f = grass.vector_db(map = mapname)[int(layer)]
                 grass.fatal(_("There is a table connected to input vector map '%s', but"
                               "there are no categories present in the key column '%s'. Consider using"
                               "v.to.db to correct this.") % (mapname, f['key']))
             except KeyError:
                 pass
-        # fetch the requested attribute sorted by cat:
-        p = grass.pipe_command('v.to.db', flags='p',
-                               quiet=True,
-                               map=mapname, option=option, columns=columns,
-                               layer=layer, units=unitsp)
+        #fetch the requested attribute sorted by cat:
+        p = grass.pipe_command('v.to.db', flags = 'p',
+                               quiet = True,
+                               map = mapname, option = option, columns = columns,
+                               layer = layer, units = unitsp)
         records2 = []
             fields = line.rstrip('\r\n').split('|')
@@ -128,7 +126,7 @@
         p.wait()
         records2.sort()
-        # make pre-table
+        #make pre-table
         # len(records1) may not be the same as len(records2) because
         # v.db.select can return attributes that are not linked to features.
         records3 = []
@@ -136,7 +134,7 @@
             records3.append(filter(lambda r1: r1[0] == r2[0], records1)[0] + r2[1:])
     else:
         records1 = []
-        p = grass.pipe_command('v.category', inp=mapname, layer=layer, option='print')
+        p = grass.pipe_command('v.category', inp = mapname, layer = layer, option = 'print')
             field = int(line.rstrip())
             if field > 0:
@@ -145,10 +143,10 @@
         records1.sort()
         records1 = uniq(records1)
-        # make pre-table
+        #make pre-table
         records3 = []
             fields = line.split('|')
@@ -161,11 +159,11 @@
     # print table header
     sys.stdout.write('|'.join(colnames + extracolnames) + '\n')
-    # make and print the table:
+    #make and print the table:
     numcols = len(colnames) + len(extracolnames)
     # calculate percents if requested
-    if units != '' and units in ['p', 'percent']:
+    if units != '' and units in ['p','percent']:
         # calculate total area value
         areatot = 0
         for r in records3:
@@ -178,12 +176,12 @@
     # sort results
     if options['sort']:
         if options['sort'] == 'asc':
-            records3.sort(key=lambda r: r[-1])
+            records3.sort(key = lambda r: r[-1])
         else:
-            records3.sort(key=lambda r: r[-1], reverse=True)
+            records3.sort(key = lambda r: r[-1], reverse = True)
     for r in records3:
-        sys.stdout.write('|'.join(map(str, r)) + '\n')
+        sys.stdout.write('|'.join(map(str,r)) + '\n')
Modified: grass/trunk/scripts/v.unpack/v.unpack.py
--- grass/trunk/scripts/v.unpack/v.unpack.py	2016-03-29 06:29:14 UTC (rev 68180)
+++ grass/trunk/scripts/v.unpack/v.unpack.py	2016-03-29 08:10:14 UTC (rev 68181)
@@ -116,8 +116,7 @@
     skip_projection_check = False
     if not os.path.exists(os.path.join(tmp_dir, 'PROJ_INFO')):
         if os.path.exists(loc_proj):
-            grass.fatal(
-                _("PROJ_INFO file is missing, unpack vector map in XY (unprojected) location."))
+            grass.fatal(_("PROJ_INFO file is missing, unpack vector map in XY (unprojected) location."))
         skip_projection_check = True  # XY location
     if not skip_projection_check:
@@ -125,14 +124,14 @@
         if not grass.compare_key_value_text_files(filename_a=os.path.join(tmp_dir, 'PROJ_INFO'),
                                                   filename_b=loc_proj, proj=True):
             diff_result_1 = diff_files(os.path.join(tmp_dir, 'PROJ_INFO'),
-                                       loc_proj)
+                                             loc_proj)
         if not grass.compare_key_value_text_files(filename_a=os.path.join(tmp_dir, 'PROJ_UNITS'),
                                                   filename_b=loc_proj_units,
                                                   units=True):
             diff_result_2 = diff_files(os.path.join(tmp_dir, 'PROJ_UNITS'),
-                                       loc_proj_units)
+                                             loc_proj_units)
         if diff_result_1 or diff_result_2:
             if flags['o']:
                 grass.warning(_("Projection information does not match. Proceeding..."))
@@ -168,7 +167,7 @@
         # check if dbf or sqlite directory exists
         if dbconn['driver'] == 'dbf' and not os.path.exists(os.path.join(mset_dir, 'dbf')):
             os.mkdir(os.path.join(mset_dir, 'dbf'))
-        elif dbconn['driver'] == 'sqlite' and not os.path.exists(os.path.join(mset_dir, 'sqlite')):
+	elif dbconn['driver'] == 'sqlite' and not os.path.exists(os.path.join(mset_dir, 'sqlite')):
             os.mkdir(os.path.join(mset_dir, 'sqlite'))
         # for each old connection
         for t in dbnlist:
Modified: grass/trunk/scripts/v.what.strds/testsuite/test_what_strds.py
--- grass/trunk/scripts/v.what.strds/testsuite/test_what_strds.py	2016-03-29 06:29:14 UTC (rev 68180)
+++ grass/trunk/scripts/v.what.strds/testsuite/test_what_strds.py	2016-03-29 08:10:14 UTC (rev 68181)
@@ -21,12 +21,12 @@
         """Initiate the temporal GIS and set the region
         cls.use_temp_region()
-        cls.runModule("g.region", s=0, n=80, w=0, e=120, b=0, t=50,
-                      res=10, res3=10)
-        cls.runModule("r.mapcalc", expression="a_1 = 100", overwrite=True)
-        cls.runModule("r.mapcalc", expression="a_2 = 200", overwrite=True)
-        cls.runModule("r.mapcalc", expression="a_3 = 300", overwrite=True)
-        cls.runModule("r.mapcalc", expression="a_4 = 400", overwrite=True)
+        cls.runModule("g.region",  s=0,  n=80,  w=0,  e=120,  b=0,  t=50,
+                      res=10,  res3=10)
+        cls.runModule("r.mapcalc", expression="a_1 = 100",  overwrite=True)
+        cls.runModule("r.mapcalc", expression="a_2 = 200",  overwrite=True)
+        cls.runModule("r.mapcalc", expression="a_3 = 300",  overwrite=True)
+        cls.runModule("r.mapcalc", expression="a_4 = 400",  overwrite=True)
         cls.runModule("v.random", output="points", npoints=3, seed=1,
                       overwrite=True)
Modified: grass/trunk/scripts/v.what.strds/v.what.strds.py
--- grass/trunk/scripts/v.what.strds/v.what.strds.py	2016-03-29 06:29:14 UTC (rev 68180)
+++ grass/trunk/scripts/v.what.strds/v.what.strds.py	2016-03-29 08:10:14 UTC (rev 68181)
@@ -60,7 +60,6 @@
 class Sample(object):
     def __init__(self, start=None, end=None, raster_names=None,
                  strds_name=None):
         self.start = start
@@ -152,9 +151,9 @@
                               "datasets must be equal\n<%(a)s> of type "
                               "%(type_a)s do not match <%(b)s> of type "
                               "%(type_b)s" % {"a": first_strds.get_id(),
-                                              "type_a": first_strds.get_temporal_type(),
-                                              "b": dataset.get_id(),
-                                              "type_b": dataset.get_temporal_type()}))
+                               "type_a": first_strds.get_temporal_type(),
+                               "b": dataset.get_id(),
+                               "type_b": dataset.get_temporal_type()}))
         mapmatrizes = tgis.sample_stds_by_stds_topology("strds", "strds",
                                                         strds_names,
Modified: grass/trunk/scripts/wxpyimgview/wxpyimgview.py
--- grass/trunk/scripts/wxpyimgview/wxpyimgview.py	2016-03-29 06:29:14 UTC (rev 68180)
+++ grass/trunk/scripts/wxpyimgview/wxpyimgview.py	2016-03-29 08:10:14 UTC (rev 68181)
@@ -16,7 +16,7 @@
 #  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
 #  GNU General Public License for more details.
 #%module
 #% description: Views BMP images from the PNG driver.
@@ -43,7 +43,7 @@
-    image = options['image']
+    image   = options['image']
     percent = options['percent']
     python = os.getenv('GRASS_PYTHON', 'python')
     gisbase = os.environ['GISBASE']
Modified: grass/trunk/scripts/wxpyimgview/wxpyimgview_gui.py
--- grass/trunk/scripts/wxpyimgview/wxpyimgview_gui.py	2016-03-29 06:29:14 UTC (rev 68180)
+++ grass/trunk/scripts/wxpyimgview/wxpyimgview_gui.py	2016-03-29 08:10:14 UTC (rev 68181)
@@ -16,7 +16,7 @@
 #%module
@@ -46,127 +46,124 @@
 wxversion.select('2.8')
 import wx
 class Frame(wx.Frame):
     title = "Image Viewer"
     def __init__(self, app, size):
-        self.app = app
-        wx.Frame.__init__(self, None, title=Frame.title, size=size)
-        self.Create()
+	self.app = app
+	wx.Frame.__init__(self, None, title = Frame.title, size = size)
+	self.Create()
     def Create(self):
-        self.Bind(wx.EVT_ERASE_BACKGROUND, self.erase)
-        self.Bind(wx.EVT_PAINT, self.redraw)
+	self.Bind(wx.EVT_ERASE_BACKGROUND, self.erase)
+	self.Bind(wx.EVT_PAINT, self.redraw)
-        self.Bind(wx.EVT_TIMER, self.tick, id=1)
-        self.timer = wx.Timer(self, 1)
-        self.timer.Start(100, True)
+	self.Bind(wx.EVT_TIMER, self.tick, id = 1)
+	self.timer = wx.Timer(self, 1)
+	self.timer.Start(100, True)
-        # Python doesn't receive signals while wx is waiting for an event
-        self.Bind(wx.EVT_TIMER, self.dummy, id=2)
-        self.ticker = wx.Timer(self, 2)
-        self.ticker.Start(100, False)
+	# Python doesn't receive signals while wx is waiting for an event
+	self.Bind(wx.EVT_TIMER, self.dummy, id = 2)
+	self.ticker = wx.Timer(self, 2)
+	self.ticker.Start(100, False)
     def erase(self, ev):
-        ev.GetDC()
+	ev.GetDC();
     def draw(self):
-        app = self.app
-        size = self.GetSize()
-        x0 = (size.GetWidth() - app.i_width) / 2
-        y0 = (size.GetHeight() - app.i_height) / 2
-        dc = wx.PaintDC(self)
-        data = app.imgbuf.reshape((app.i_height, app.i_width, 4))
-        data = data[::, ::, 2::-1]
-        fn = getattr(data, "tobytes", getattr(data, "tostring"))
-        image = wx.ImageFromData(app.i_width, app.i_height, fn())
-        dc.DrawBitmap(wx.BitmapFromImage(image), x0, y0, False)
+	app = self.app
+	size = self.GetSize()
+	x0 = (size.GetWidth()  - app.i_width) / 2
+	y0 = (size.GetHeight() - app.i_height) / 2
+	dc = wx.PaintDC(self)
+	data = app.imgbuf.reshape((app.i_height, app.i_width, 4))
+	data = data[::,::,2::-1]
+	fn = getattr(data, "tobytes", getattr(data, "tostring"))
+	image = wx.ImageFromData(app.i_width, app.i_height, fn())
+	dc.DrawBitmap(wx.BitmapFromImage(image), x0, y0, False)
     def redraw(self, ev):
-        if self.app.fraction > 0.001:
-            t0 = time.time()
-            self.draw()
-            t1 = time.time()
+	if self.app.fraction > 0.001:
+	    t0 = time.time()
+	    self.draw()
+	    t1 = time.time()
-            last = t1 - t0
-            delay = last / self.app.fraction
-            self.timer.Start(int(delay * 1000), True)
-        else:
-            self.draw()
+	    last = t1 - t0
+	    delay = last / self.app.fraction
+	    self.timer.Start(int(delay * 1000), True)
+	else:
+	    self.draw()
     def tick(self, ev):
-        self.Refresh()
+	self.Refresh()
     def dummy(self, ev):
-        pass
+	pass
 class Application(wx.App):
     def __init__(self):
-        self.image = sys.argv[1]
-        self.fraction = int(sys.argv[2]) / 100.0
-        self.HEADER_SIZE = 64
-        wx.App.__init__(self)
+	self.image = sys.argv[1]
+	self.fraction = int(sys.argv[2]) / 100.0
+	self.HEADER_SIZE = 64
+	wx.App.__init__(self)
     def read_bmp_header(self, header):
-        magic, bmfh, bmih = struct.unpack("2s12s40s10x", header)
+	magic, bmfh, bmih = struct.unpack("2s12s40s10x", header)
-        if magic != 'BM':
-            raise SyntaxError("Invalid magic number")
+	if magic != 'BM':
+	    raise SyntaxError("Invalid magic number")
-        size, res1, res2, hsize = struct.unpack("<IHHI", bmfh)
+	size, res1, res2, hsize = struct.unpack("<IHHI", bmfh)
-        if hsize != self.HEADER_SIZE:
-            raise SyntaxError("Invalid file header size")
+	if hsize != self.HEADER_SIZE:
+	    raise SyntaxError("Invalid file header size")
-        hsize, width, height, planes, bpp, compression, imsize, xppm, yppm, cused, cimp = \
-            struct.unpack("<IiiHHIIiiII", bmih)
+	hsize, width, height, planes, bpp, compression, imsize, xppm, yppm, cused, cimp = \
+	       struct.unpack("<IiiHHIIiiII", bmih)
-        if hsize != 40:
-            raise SyntaxError("Invalid info header size")
+	if hsize != 40:
+	    raise SyntaxError("Invalid info header size")
-        self.i_width = width
-        self.i_height = -height
+	self.i_width = width
+	self.i_height = -height
-        if planes != 1:
-            raise SyntaxError("Planar data not supported")
-        if bpp != 32:
-            raise SyntaxError("Only 32-BPP images supported")
-        if compression != 0:
-            raise SyntaxError("Compression not supported")
-        if imsize != self.i_width * self.i_height * 4:
-            raise SyntaxError("Invalid image data size")
-        if size != self.HEADER_SIZE + self.i_width * self.i_height * 4:
-            raise SyntaxError("Invalid image size")
+	if planes != 1:
+	    raise SyntaxError("Planar data not supported")
+	if bpp != 32:
+	    raise SyntaxError("Only 32-BPP images supported")
+	if compression != 0:
+	    raise SyntaxError("Compression not supported")
+	if imsize != self.i_width * self.i_height * 4:
+	    raise SyntaxError("Invalid image data size")
+	if size != self.HEADER_SIZE + self.i_width * self.i_height * 4:
+	    raise SyntaxError("Invalid image size")
     def map_file(self):
-        f = open(self.image, 'r')
+	f = open(self.image, 'r')
-        header = f.read(self.HEADER_SIZE)
-        self.read_bmp_header(header)
+	header = f.read(self.HEADER_SIZE)
+	self.read_bmp_header(header)
-        self.imgbuf = numpy.memmap(f, mode='r', offset=self.HEADER_SIZE)
+	self.imgbuf = numpy.memmap(f, mode = 'r', offset = self.HEADER_SIZE)
     def signal_handler(self, sig, frame):
-        wx.CallAfter(self.mainwin.Refresh)
+	wx.CallAfter(self.mainwin.Refresh);
     def set_handler(self):
-        if 'SIGUSR1' in dir(signal):
-            signal.signal(signal.SIGUSR1, self.signal_handler)
+	if 'SIGUSR1' in dir(signal):
+	    signal.signal(signal.SIGUSR1, self.signal_handler)
     def OnInit(self):
-        self.map_file()
+	self.map_file()
-        size = wx.Size(self.i_width, self.i_height)
-        self.mainwin = Frame(self, size)
-        self.mainwin.Show()
-        self.SetTopWindow(self.mainwin)
+	size = wx.Size(self.i_width, self.i_height)
+	self.mainwin = Frame(self, size)
+	self.mainwin.Show()
+	self.SetTopWindow(self.mainwin)
-        self.set_handler()
+	self.set_handler()
-        return True
+	return True
     app = Application()
