[GRASS-SVN] r68182 - grass/trunk/lib/python/temporal
Tue Mar 29 02:23:26 PDT 2016
Author: zarch
Date: 2016-03-29 02:23:26 -0700 (Tue, 29 Mar 2016)
New Revision: 68182
   grass/trunk/lib/python/temporal/__init__.py
   grass/trunk/lib/python/temporal/abstract_dataset.py
   grass/trunk/lib/python/temporal/abstract_map_dataset.py
   grass/trunk/lib/python/temporal/abstract_space_time_dataset.py
   grass/trunk/lib/python/temporal/aggregation.py
   grass/trunk/lib/python/temporal/base.py
   grass/trunk/lib/python/temporal/c_libraries_interface.py
   grass/trunk/lib/python/temporal/core.py
   grass/trunk/lib/python/temporal/datetime_math.py
   grass/trunk/lib/python/temporal/extract.py
   grass/trunk/lib/python/temporal/factory.py
   grass/trunk/lib/python/temporal/gui_support.py
   grass/trunk/lib/python/temporal/list_stds.py
   grass/trunk/lib/python/temporal/mapcalc.py
   grass/trunk/lib/python/temporal/metadata.py
   grass/trunk/lib/python/temporal/open_stds.py
   grass/trunk/lib/python/temporal/register.py
   grass/trunk/lib/python/temporal/sampling.py
   grass/trunk/lib/python/temporal/space_time_datasets.py
   grass/trunk/lib/python/temporal/spatial_extent.py
   grass/trunk/lib/python/temporal/spatial_topology_dataset_connector.py
   grass/trunk/lib/python/temporal/spatio_temporal_relationships.py
   grass/trunk/lib/python/temporal/stds_export.py
   grass/trunk/lib/python/temporal/stds_import.py
   grass/trunk/lib/python/temporal/temporal_algebra.py
   grass/trunk/lib/python/temporal/temporal_extent.py
   grass/trunk/lib/python/temporal/temporal_granularity.py
   grass/trunk/lib/python/temporal/temporal_operator.py
   grass/trunk/lib/python/temporal/temporal_raster3d_algebra.py
   grass/trunk/lib/python/temporal/temporal_raster_algebra.py
   grass/trunk/lib/python/temporal/temporal_raster_base_algebra.py
   grass/trunk/lib/python/temporal/temporal_topology_dataset_connector.py
   grass/trunk/lib/python/temporal/temporal_vector_algebra.py
   grass/trunk/lib/python/temporal/univar_statistics.py
temporal: revert changes (r68139 and r68177) since they are not fixing bugs and therefore they should go in relbr72
Modified: grass/trunk/lib/python/temporal/__init__.py
--- grass/trunk/lib/python/temporal/__init__.py	2016-03-29 08:10:14 UTC (rev 68181)
+++ grass/trunk/lib/python/temporal/__init__.py	2016-03-29 09:23:26 UTC (rev 68182)
@@ -1,35 +1,33 @@
-from __future__ import (absolute_import)
-from .core import *
-from .base import *
-from .spatial_extent import *
-from .metadata import *
-from .abstract_dataset import *
-from .abstract_map_dataset import *
-from .abstract_space_time_dataset import *
-from .space_time_datasets import *
-from .datetime_math import *
-from .open_stds import *
-from .factory import *
-from .gui_support import *
-from .list_stds import *
-from .register import *
-from .sampling import *
-from .aggregation import *
-from .extract import *
-from .stds_export import *
-from .stds_import import *
-from .mapcalc import *
-from .univar_statistics import *
-from .c_libraries_interface import *
-from .spatio_temporal_relationships import *
-from .spatial_topology_dataset_connector import *
-from .temporal_extent import *
-from .temporal_topology_dataset_connector import *
-from .temporal_granularity import *
-from .temporal_algebra import *
-from .temporal_vector_algebra import *
-from .temporal_raster_base_algebra import *
-from .temporal_raster_algebra import *
-from .temporal_raster3d_algebra import *
-from .temporal_operator import *
+from core import *
+from base import *
+from spatial_extent import *
+from metadata import *
+from abstract_dataset import *
+from abstract_map_dataset import *
+from abstract_space_time_dataset import *
+from space_time_datasets import *
+from datetime_math import *
+from open_stds import *
+from factory import *
+from gui_support import *
+from list_stds import *
+from register import *
+from sampling import *
+from aggregation import *
+from extract import *
+from stds_export import *
+from stds_import import *
+from mapcalc import *
+from univar_statistics import *
+from c_libraries_interface import *
+from spatio_temporal_relationships import *
+from spatial_topology_dataset_connector import *
+from temporal_extent import *
+from temporal_topology_dataset_connector import *
+from temporal_granularity import *
+from temporal_algebra import *
+from temporal_vector_algebra import *
+from temporal_raster_base_algebra import *
+from temporal_raster_algebra import *
+from temporal_raster3d_algebra import *
+from temporal_operator import *
Modified: grass/trunk/lib/python/temporal/abstract_dataset.py
--- grass/trunk/lib/python/temporal/abstract_dataset.py	2016-03-29 08:10:14 UTC (rev 68181)
+++ grass/trunk/lib/python/temporal/abstract_dataset.py	2016-03-29 09:23:26 UTC (rev 68182)
@@ -11,11 +11,11 @@
 :authors: Soeren Gebbert
 from abc import ABCMeta, abstractmethod
Modified: grass/trunk/lib/python/temporal/abstract_map_dataset.py
--- grass/trunk/lib/python/temporal/abstract_map_dataset.py	2016-03-29 08:10:14 UTC (rev 68181)
+++ grass/trunk/lib/python/temporal/abstract_map_dataset.py	2016-03-29 09:23:26 UTC (rev 68182)
@@ -10,9 +10,8 @@
-from __future__ import print_function
 class AbstractMapDataset(AbstractDataset):
@@ -200,16 +199,16 @@
         if self.get_type() == "raster":
             #                1         2         3         4         5         6         7
             #      0123456789012345678901234567890123456789012345678901234567890123456789012345678
-            print(" +-------------------- Raster Dataset ----------------------------------------+")
+            print " +-------------------- Raster Dataset ----------------------------------------+"
         if self.get_type() == "raster3d":
             #                1         2         3         4         5         6         7
-            print(" +-------------------- 3D Raster Dataset -------------------------------------+")
+            print " +-------------------- 3D Raster Dataset -------------------------------------+"
         if self.get_type() == "vector":
             #                1         2         3         4         5         6         7
-            print(" +-------------------- Vector Dataset ----------------------------------------+")
-        print(" |        |")
+            print " +-------------------- Vector Dataset ----------------------------------------+"
+        print " |        |"
         self.base.print_info()
         self.temporal_extent.print_info()
         if self.is_topology_build():
@@ -229,8 +228,8 @@
                 else:
                     string += ",%s" % ds
                 count += 1
-        print(" | Registered datasets ........ " + string)
-        print(" +----------------------------------------------------------------------------+")
+        print " | Registered datasets ........ " + string
+        print " +----------------------------------------------------------------------------+"
     def print_shell_info(self):
         """Print information about this object in shell style"""
@@ -248,7 +247,7 @@
                 else:
                 count += 1
-            print("registered_datasets=" + string)
+            print "registered_datasets=" + string
             self.print_topology_shell_info()
@@ -540,25 +539,25 @@
                >>> map      = tgis.RasterDataset(None)
                >>> temp_ext = tgis.RasterRelativeTime(start_time=1, end_time=2, unit="years")
                >>> map.set_temporal_extent(temp_ext)
-               >>> print(map.get_temporal_extent_as_tuple())
+               >>> print map.get_temporal_extent_as_tuple()
                (1, 2)
                >>> map      = tgis.VectorDataset(None)
                >>> temp_ext = tgis.VectorAbsoluteTime(start_time=datetime.datetime(2000, 1, 1),
                ...                                        end_time=datetime.datetime(2001, 1, 1))
                (datetime.datetime(2000, 1, 1, 0, 0), datetime.datetime(2001, 1, 1, 0, 0))
                >>> map1 = tgis.VectorDataset("A at P")
                >>> check = map1.set_absolute_time(datetime.datetime(2000,5,5), datetime.datetime(2005,6,6))
-               >>> print(map1.get_temporal_extent_as_tuple())
+               >>> print map1.get_temporal_extent_as_tuple()
                (datetime.datetime(2000, 5, 5, 0, 0), datetime.datetime(2005, 6, 6, 0, 0))
                >>> map2 = tgis.RasterDataset("B at P")
                >>> check = map2.set_absolute_time(datetime.datetime(1990,1,1), datetime.datetime(1999,8,1))
-               >>> print(map2.get_temporal_extent_as_tuple())
+               >>> print map2.get_temporal_extent_as_tuple()
                (datetime.datetime(1990, 1, 1, 0, 0), datetime.datetime(1999, 8, 1, 0, 0))
                >>> map2.set_temporal_extent(map1.get_temporal_extent())
@@ -711,7 +710,7 @@
                >>> spat_ext = tgis.SpatialExtent(north=10, south=-10, east=20, west=-20, top=5, bottom=-5)
                >>> map.set_spatial_extent(spat_ext)
-               >>> print(map.get_spatial_extent_as_tuple())
+               >>> print map.get_spatial_extent_as_tuple()
                (10.0, -10.0, 20.0, -20.0, 5.0, -5.0)
@@ -730,7 +729,7 @@
                >>> map.spatial_buffer(10)
                (20.0, -20.0, 30.0, -30.0, 15.0, -15.0)
@@ -757,7 +756,7 @@
                >>> map.spatial_buffer_2d(10)
                (20.0, -20.0, 30.0, -30.0, 5.0, -5.0)
Modified: grass/trunk/lib/python/temporal/abstract_space_time_dataset.py
--- grass/trunk/lib/python/temporal/abstract_space_time_dataset.py	2016-03-29 08:10:14 UTC (rev 68181)
+++ grass/trunk/lib/python/temporal/abstract_space_time_dataset.py	2016-03-29 09:23:26 UTC (rev 68182)
@@ -10,12 +10,11 @@
 import sys
 import uuid
@@ -99,21 +98,21 @@
         if self.get_type() == "strds":
             #                1         2         3         4         5         6         7
-            print(" +-------------------- Space Time Raster Dataset -----------------------------+")
+            print " +-------------------- Space Time Raster Dataset -----------------------------+"
         if self.get_type() == "str3ds":
             #                1         2         3         4         5         6         7
-            print(" +-------------------- Space Time 3D Raster Dataset --------------------------+")
+            print " +-------------------- Space Time 3D Raster Dataset --------------------------+"
         if self.get_type() == "stvds":
             #                1         2         3         4         5         6         7
-            print(" +-------------------- Space Time Vector Dataset -----------------------------+")
-        print(" |        |")
+            print " +-------------------- Space Time Vector Dataset -----------------------------+"
+        print " |        |"
         self.spatial_extent.print_info()
         self.metadata.print_info()
         """Print information about this class in shell style"""
@@ -1138,7 +1137,7 @@
                 ...     maps.append(map)
                 >>> grans = tgis.AbstractSpaceTimeDataset.resample_maplist_by_granularity(maps,0,8,1)
                 >>> for map_list in grans:
-                ...    print(map_list[0].get_id(), map_list[0].get_temporal_extent_as_tuple())
+                ...    print map_list[0].get_id(), map_list[0].get_temporal_extent_as_tuple()
                 None (0, 1)
                 None (1, 2)
                 map0 at PERMANENT (2, 3)
@@ -1157,7 +1156,7 @@
                 >>> maps.append(map2)
                 >>> grans = tgis.AbstractSpaceTimeDataset.resample_maplist_by_granularity(maps,0,16,2)
                 None (0, 2)
                 map1 at PERMANENT (2, 4)
                 map1 at PERMANENT (4, 6)
@@ -1176,7 +1175,7 @@
                 >>> maps.append(map2)
                 None (0, 2)
                 None (4, 6)
@@ -1195,7 +1194,7 @@
                 >>> maps.append(map2)
                 >>> grans = tgis.AbstractSpaceTimeDataset.resample_maplist_by_granularity(maps,datetime(2000,1,1),datetime(2001,4,1),"1 month")
                 None (datetime.datetime(2000, 1, 1, 0, 0), datetime.datetime(2000, 2, 1, 0, 0))
                 None (datetime.datetime(2000, 2, 1, 0, 0), datetime.datetime(2000, 3, 1, 0, 0))
                 None (datetime.datetime(2000, 3, 1, 0, 0), datetime.datetime(2000, 4, 1, 0, 0))
Modified: grass/trunk/lib/python/temporal/aggregation.py
--- grass/trunk/lib/python/temporal/aggregation.py	2016-03-29 08:10:14 UTC (rev 68181)
+++ grass/trunk/lib/python/temporal/aggregation.py	2016-03-29 09:23:26 UTC (rev 68182)
@@ -17,10 +17,10 @@
 :author: Soeren Gebbert
-from .datetime_math import create_suffix_from_datetime
-from .datetime_math import create_time_suffix
-from .datetime_math import create_numeric_suffic
+from datetime_math import create_suffix_from_datetime
+from datetime_math import create_time_suffix
+from datetime_math import create_numeric_suffic
 import grass.script as gscript
 from grass.exceptions import CalledModuleError
Modified: grass/trunk/lib/python/temporal/base.py
--- grass/trunk/lib/python/temporal/base.py	2016-03-29 08:10:14 UTC (rev 68181)
+++ grass/trunk/lib/python/temporal/base.py	2016-03-29 09:23:26 UTC (rev 68182)
@@ -24,9 +24,9 @@
 from datetime import datetime
+from core import *
@@ -186,7 +186,7 @@
     def print_self(self):
         """Print the content of the internal dictionary to stdout
-        print(self.D)
+        print self.D
@@ -276,7 +276,7 @@
                         if None a temporary connection will be established
         sql = self.get_delete_statement()
-        #print(sql)
+        #print sql
         if dbif:
             dbif.execute(sql,   mapset=self.mapset)
@@ -350,8 +350,8 @@
         sql, args = self.get_select_statement()
-        #print(sql)
-        #print(args)
+        #print sql
+        #print args
         if dbif:
             if len(args) == 0:
@@ -408,8 +408,8 @@
         sql, args = self.get_insert_statement()
-        #print(sql)
-        #print(args)
+        #print sql
+        #print args
         if dbif:
             dbif.execute(sql, args, mapset=self.mapset)
@@ -462,8 +462,8 @@
             self.msgr.fatal(_("Missing identifer"))
         sql, args = self.get_update_statement(ident)
-        #print(sql)
-        #print(args)
+        #print sql
+        #print args
         if dbif:
@@ -513,8 +513,8 @@
         sql, args = self.get_update_all_statement(ident)
-        #print(sql)
-        #print(args)
+        #print sql
+        #print args
         if dbif:
@@ -766,26 +766,26 @@
     def print_info(self):
         """Print information about this class in human readable style"""
-        print( " +-------------------- Basic information -------------------------------------+")
-        print( " | Id: ........................ " + str(self.get_id()))
-        print(" | Name: ...................... " + str(self.get_name()))
-        print(" | Mapset: .................... " + str(self.get_mapset()))
+        print " +-------------------- Basic information -------------------------------------+"
+        print " | Id: ........................ " + str(self.get_id())
+        print " | Name: ...................... " + str(self.get_name())
+        print " | Mapset: .................... " + str(self.get_mapset())
         if self.get_layer():
-            print(" | Layer:...................... " + str(self.get_layer()))
-        print(" | Creator: ................... " + str(self.get_creator()))
-        print(" | Temporal type: ............. " + str(self.get_ttype()))
-        print(" | Creation time: ............. " + str(self.get_ctime()))
+            print " | Layer:...................... " + str(self.get_layer())
+        print " | Creator: ................... " + str(self.get_creator())
+        print " | Temporal type: ............. " + str(self.get_ttype())
+        print " | Creation time: ............. " + str(self.get_ctime())
-        print("id=" + str(self.get_id()))
-        print("name=" + str(self.get_name()))
-        print("mapset=" + str(self.get_mapset()))
+        print "id=" + str(self.get_id())
+        print "name=" + str(self.get_name())
+        print "mapset=" + str(self.get_mapset())
-            print("layer=" + str(self.get_layer()))
-        print("creator=" + str(self.get_creator()))
-        print("temporal_type=" + str(self.get_ttype()))
-        print("creation_time=" + str(self.get_ctime()))
+            print "layer=" + str(self.get_layer())
+        print "creator=" + str(self.get_creator())
+        print "temporal_type=" + str(self.get_ttype())
+        print "creation_time=" + str(self.get_ctime())
@@ -912,15 +912,15 @@
         DatasetBase.print_info(self)
-        print(" | Modification time:.......... " + str(self.get_mtime()))
-        print(" | Semantic type:.............. " + str(
-            self.get_semantic_type()))
+        print " | Modification time:.......... " + str(self.get_mtime())
+        print " | Semantic type:.............. " + str(
+            self.get_semantic_type())
         DatasetBase.print_shell_info(self)
-        print("modification_time=" + str(self.get_mtime()))
-        print("semantic_type=" + str(self.get_semantic_type()))
+        print "modification_time=" + str(self.get_mtime())
+        print "semantic_type=" + str(self.get_semantic_type())
Modified: grass/trunk/lib/python/temporal/c_libraries_interface.py
--- grass/trunk/lib/python/temporal/c_libraries_interface.py	2016-03-29 08:10:14 UTC (rev 68181)
+++ grass/trunk/lib/python/temporal/c_libraries_interface.py	2016-03-29 09:23:26 UTC (rev 68182)
@@ -18,7 +18,7 @@
 from multiprocessing import Process, Lock, Pipe
 import logging
 from ctypes import *
+from core import *
 import grass.lib.gis as libgis
 import grass.lib.raster as libraster
 import grass.lib.vector as libvector
@@ -59,7 +59,7 @@
 def _read_map_full_info(lock, conn, data):
-    """Read full map specific metadata from the spatial database using
+    """Read full map specific metadata from the spatial database using
        PyGRASS functions.
        :param lock: A multiprocessing.Lock instance
@@ -85,21 +85,21 @@
 def _read_raster_full_info(name, mapset):
     """Read raster info, history and cats using PyGRASS RasterRow
-       and return a dictionary. Colors should be supported in the
+       and return a dictionary. Colors should be supported in the
        future.
     info = {}
     r = RasterRow(name=name, mapset=mapset)
     if r.exist() is True:
         r.open("r")
         for item in r.info:
             info[item[0]] = item[1]
         for item in r.hist:
         info["full_name"] = r.name_mapset()
         info["mtype"] = r.mtype
         if r.cats:
@@ -150,14 +150,14 @@
         info["title"] = v.title
         info["thresh"] = v.thresh
         info["zone"] = v.zone
-        vtypes = ['areas', 'dblinks', 'faces', 'holes', 'islands',
-                  'kernels', 'lines', 'nodes', 'points', 'updated_lines',
+        vtypes = ['areas', 'dblinks', 'faces', 'holes', 'islands',
+                  'kernels', 'lines', 'nodes', 'points', 'updated_lines',
                   'updated_nodes', 'volumes']
         for vtype in vtypes:
             info[vtype] = v.number_of(vtype)
         info.update(v.num_primitives())
         if v.table is not None:
             info["columns"] = v.table.columns
@@ -293,15 +293,15 @@
         while mapsets[count]:
             char_list = ""
             mapset = mapsets[count]
             permission = libgis.G_mapset_permissions(mapset)
             in_search_path = libgis.G_is_mapset_in_search_path(mapset)
             c = 0
             while mapset[c] != "\x00":
                 char_list += mapset[c]
                 c += 1
             if permission >= 0 and in_search_path == 1:
                 mapset_list.append(char_list)
@@ -1172,10 +1172,10 @@
         self.client_conn.send([RPCDefs.READ_MAP_INFO, RPCDefs.TYPE_RASTER,
                                name, mapset, None])
         return self.safe_receive("read_raster_info")
     def read_raster_full_info(self, name, mapset):
            future.
            :param name: The name of the map
@@ -1184,7 +1184,7 @@
                      or None in case of an error
         self.check_server()
-        self.client_conn.send([RPCDefs.READ_MAP_FULL_INFO,
+        self.client_conn.send([RPCDefs.READ_MAP_FULL_INFO,
         return self.safe_receive("read_raster_full_info")
@@ -1379,7 +1379,7 @@
     def read_vector_full_info(self, name, mapset):
         """Read vector info using PyGRASS VectorTopo
            :param mapset: The mapset of the map
@@ -1387,7 +1387,7 @@
         self.check_server()
                                RPCDefs.TYPE_VECTOR,
         return self.safe_receive("read_vector_full_info")
Modified: grass/trunk/lib/python/temporal/core.py
--- grass/trunk/lib/python/temporal/core.py	2016-03-29 08:10:14 UTC (rev 68181)
+++ grass/trunk/lib/python/temporal/core.py	2016-03-29 09:23:26 UTC (rev 68182)
@@ -36,7 +36,7 @@
 from grass.pygrass import messages
 # Import all supported database backends
 # Ignore import errors since they are checked later
@@ -70,7 +70,7 @@
         sortby = 'cumulative'
         ps = pstats.Stats(pr, stream=s).sort_stats(sortby)
         ps.print_stats()
-        print(s.getvalue())
+        print s.getvalue()
     else:
         func()
@@ -1161,9 +1161,9 @@
                 if self.connected:
                     try:
                         return self.cursor.mogrify(sql, args)
-                    except Exception as exc:
-                        print(sql, args)
-                        raise exc
+                    except:
+                        print sql, args
+                        raise
                 else:
                     self.connect()
                     statement = self.cursor.mogrify(sql, args)
Modified: grass/trunk/lib/python/temporal/datetime_math.py
--- grass/trunk/lib/python/temporal/datetime_math.py	2016-03-29 08:10:14 UTC (rev 68181)
+++ grass/trunk/lib/python/temporal/datetime_math.py	2016-03-29 09:23:26 UTC (rev 68182)
@@ -9,7 +9,7 @@
 from datetime import datetime, timedelta
+from core import *
 import copy
 try:
@@ -863,9 +863,9 @@
 def create_time_suffix(mapp, end=False):
     """Create a datetime string based on a map datetime object
        :param mapp: a temporal map dataset
-       :param end: True if you want add also end time to the suffix
+       :param end: True if you want add also end time to the suffix
     start = mapp.temporal_extent.get_start_time()
     sstring = start.isoformat().replace(':', '_').replace('-', '_')
Modified: grass/trunk/lib/python/temporal/extract.py
--- grass/trunk/lib/python/temporal/extract.py	2016-03-29 08:10:14 UTC (rev 68181)
+++ grass/trunk/lib/python/temporal/extract.py	2016-03-29 09:23:26 UTC (rev 68182)
@@ -10,11 +10,11 @@
 from grass.script.utils import get_num_suffix
@@ -183,7 +183,7 @@
         msgr.percent(0, num_rows, 1)
         temporal_type, semantic_type, title, description = sp.get_initial_values()
-        new_sp = open_new_stds(output, type, sp.get_temporal_type(), title,
+        new_sp = open_new_stds(output, type, sp.get_temporal_type(), title,
                                description, semantic_type, dbif,
                                gscript.overwrite())
Modified: grass/trunk/lib/python/temporal/factory.py
--- grass/trunk/lib/python/temporal/factory.py	2016-03-29 08:10:14 UTC (rev 68181)
+++ grass/trunk/lib/python/temporal/factory.py	2016-03-29 09:23:26 UTC (rev 68182)
@@ -18,7 +18,7 @@
Modified: grass/trunk/lib/python/temporal/gui_support.py
--- grass/trunk/lib/python/temporal/gui_support.py	2016-03-29 08:10:14 UTC (rev 68181)
+++ grass/trunk/lib/python/temporal/gui_support.py	2016-03-29 09:23:26 UTC (rev 68182)
@@ -10,8 +10,8 @@
Modified: grass/trunk/lib/python/temporal/list_stds.py
--- grass/trunk/lib/python/temporal/list_stds.py	2016-03-29 08:10:14 UTC (rev 68181)
+++ grass/trunk/lib/python/temporal/list_stds.py	2016-03-29 09:23:26 UTC (rev 68182)
@@ -17,11 +17,11 @@
@@ -58,13 +58,13 @@
             >>> rows =  stds_list[mapset]
             >>> for row in rows:
             ...     if row["name"] == name:
-            ...         print(True)
+            ...         print True
             True
             >>> stds_list = tgis.get_dataset_list("strds", "absolute", columns="name,mapset", where="mapset = '%s'"%(mapset))
             >>> for row in rows:
             ...     if row["name"] == name and row["mapset"] == mapset:
-            ...         print(True)
+            ...         print True
             True
             >>> check = sp.delete()
@@ -192,7 +192,7 @@
             if outpath:
                 outfile.write('{st}\n'.format(st=string))
             else:
-                print(string)
+                print string
         if maps and len(maps) > 0:
@@ -240,7 +240,7 @@
                 if outpath:
                 else:
-                    print(string)
+                    print string
     else:
         # In comma separated mode only map ids are needed
@@ -262,7 +262,7 @@
                 if outpath:
                 else:
-                    print(string)
+                    print string
             elif method == "cols":
                 # Print the column names if requested
@@ -281,7 +281,7 @@
                     if outpath:
                         outfile.write('{st}\n'.format(st=output))
                     else:
-                        print(output)
+                        print output
                 for row in rows:
                     output = ""
@@ -295,7 +295,7 @@
                     if outpath:
                     else:
-                        print(output)
+                        print output
     if outpath:
         outfile.close()
     if connected:
Modified: grass/trunk/lib/python/temporal/mapcalc.py
--- grass/trunk/lib/python/temporal/mapcalc.py	2016-03-29 08:10:14 UTC (rev 68181)
+++ grass/trunk/lib/python/temporal/mapcalc.py	2016-03-29 09:23:26 UTC (rev 68182)
@@ -9,8 +9,8 @@
Modified: grass/trunk/lib/python/temporal/metadata.py
--- grass/trunk/lib/python/temporal/metadata.py	2016-03-29 08:10:14 UTC (rev 68181)
+++ grass/trunk/lib/python/temporal/metadata.py	2016-03-29 09:23:26 UTC (rev 68182)
@@ -21,8 +21,7 @@
+from base import *
@@ -235,26 +234,26 @@
-        print(" | Datatype:................... " + str(self.get_datatype()))
-        print(" | Number of columns:.......... " + str(self.get_cols()))
-        print(" | Number of rows:............. " + str(self.get_rows()))
-        print(" | Number of cells:............ " + str(
-            self.get_number_of_cells()))
-        print(" | North-South resolution:..... " + str(self.get_nsres()))
-        print(" | East-west resolution:....... " + str(self.get_ewres()))
-        print(" | Minimum value:.............. " + str(self.get_min()))
-        print(" | Maximum value:.............. " + str(self.get_max()))
+        print " | Datatype:................... " + str(self.get_datatype())
+        print " | Number of columns:.......... " + str(self.get_cols())
+        print " | Number of rows:............. " + str(self.get_rows())
+        print " | Number of cells:............ " + str(
+            self.get_number_of_cells())
+        print " | North-South resolution:..... " + str(self.get_nsres())
+        print " | East-west resolution:....... " + str(self.get_ewres())
+        print " | Minimum value:.............. " + str(self.get_min())
+        print " | Maximum value:.............. " + str(self.get_max())
-        print("datatype=" + str(self.get_datatype()))
-        print("cols=" + str(self.get_cols()))
-        print("rows=" + str(self.get_rows()))
-        print("number_of_cells=" + str(self.get_number_of_cells()))
-        print("nsres=" + str(self.get_nsres()))
-        print("ewres=" + str(self.get_ewres()))
-        print("min=" + str(self.get_min()))
-        print("max=" + str(self.get_max()))
+        print "datatype=" + str(self.get_datatype())
+        print "cols=" + str(self.get_cols())
+        print "rows=" + str(self.get_rows())
+        print "number_of_cells=" + str(self.get_number_of_cells())
+        print "nsres=" + str(self.get_nsres())
+        print "ewres=" + str(self.get_ewres())
+        print "min=" + str(self.get_min())
+        print "max=" + str(self.get_max())
@@ -324,7 +323,7 @@
-        print(" +-------------------- Metadata information ----------------------------------+")
+        print " +-------------------- Metadata information ----------------------------------+"
         RasterMetadataBase.print_info(self)
@@ -446,18 +445,18 @@
-        print(" | Number of depths:........... " + str(self.get_depths()))
-        print(" | Top-Bottom resolution:...... " + str(self.get_tbres()))
+        print " | Number of depths:........... " + str(self.get_depths())
+        print " | Top-Bottom resolution:...... " + str(self.get_tbres())
         RasterMetadataBase.print_shell_info(self)
-        print("depths=" + str(self.get_depths()))
-        print("tbres=" + str(self.get_tbres()))
+        print "depths=" + str(self.get_depths())
+        print "tbres=" + str(self.get_tbres())
@@ -764,36 +763,36 @@
-        print(" | Is map 3d .................. " + str(self.get_3d_info()))
-        print(" | Number of points ........... " + str(self.get_number_of_points()))
-        print(" | Number of lines ............ " + str(self.get_number_of_lines()))
-        print(" | Number of boundaries ....... " + str(self.get_number_of_boundaries()))
-        print(" | Number of centroids ........ " + str(self.get_number_of_centroids()))
-        print(" | Number of faces ............ " + str(self.get_number_of_faces()))
-        print(" | Number of kernels .......... " + str(self.get_number_of_kernels()))
-        print(" | Number of primitives ....... " + str(self.get_number_of_primitives()))
-        print(" | Number of nodes ............ " + str(self.get_number_of_nodes()))
-        print(" | Number of areas ............ " + str(self.get_number_of_areas()))
-        print(" | Number of islands .......... " + str(self.get_number_of_islands()))
-        print(" | Number of holes ............ " + str(self.get_number_of_holes()))
-        print(" | Number of volumes .......... " + str(self.get_number_of_volumes()))
+        print " | Is map 3d .................. " + str(self.get_3d_info())
+        print " | Number of points ........... " + str(self.get_number_of_points())
+        print " | Number of lines ............ " + str(self.get_number_of_lines())
+        print " | Number of boundaries ....... " + str(self.get_number_of_boundaries())
+        print " | Number of centroids ........ " + str(self.get_number_of_centroids())
+        print " | Number of faces ............ " + str(self.get_number_of_faces())
+        print " | Number of kernels .......... " + str(self.get_number_of_kernels())
+        print " | Number of primitives ....... " + str(self.get_number_of_primitives())
+        print " | Number of nodes ............ " + str(self.get_number_of_nodes())
+        print " | Number of areas ............ " + str(self.get_number_of_areas())
+        print " | Number of islands .......... " + str(self.get_number_of_islands())
+        print " | Number of holes ............ " + str(self.get_number_of_holes())
+        print " | Number of volumes .......... " + str(self.get_number_of_volumes())
-        print("is_3d=" + str(self.get_3d_info()))
-        print("points=" + str(self.get_number_of_points()))
-        print("lines=" + str(self.get_number_of_lines()))
-        print("boundaries=" + str(self.get_number_of_boundaries()))
-        print("centroids=" + str(self.get_number_of_centroids()))
-        print("faces=" + str(self.get_number_of_faces()))
-        print("kernels=" + str(self.get_number_of_kernels()))
-        print("primitives=" + str(self.get_number_of_primitives()))
-        print("nodes=" + str(self.get_number_of_nodes()))
-        print("areas=" + str(self.get_number_of_areas()))
-        print("islands=" + str(self.get_number_of_islands()))
-        print("holes=" + str(self.get_number_of_holes()))
-        print("volumes=" + str(self.get_number_of_volumes()))
+        print "is_3d=" + str(self.get_3d_info())
+        print "points=" + str(self.get_number_of_points())
+        print "lines=" + str(self.get_number_of_lines())
+        print "boundaries=" + str(self.get_number_of_boundaries())
+        print "centroids=" + str(self.get_number_of_centroids())
+        print "faces=" + str(self.get_number_of_faces())
+        print "kernels=" + str(self.get_number_of_kernels())
+        print "primitives=" + str(self.get_number_of_primitives())
+        print "nodes=" + str(self.get_number_of_nodes())
+        print "areas=" + str(self.get_number_of_areas())
+        print "islands=" + str(self.get_number_of_islands())
+        print "holes=" + str(self.get_number_of_holes())
+        print "volumes=" + str(self.get_number_of_volumes())
@@ -909,29 +908,29 @@
-        print(" | Number of registered maps:.. " + str(
-            self.get_number_of_maps()))
-        print(" |")
-        print(" | Title:")
-        print(" | " + str(self.get_title()))
-        print(" | Description:")
-        print(" | " + str(self.get_description()))
-        print(" | Command history:")
+        print " | Number of registered maps:.. " + str(
+            self.get_number_of_maps())
+        print " |"
+        print " | Title:"
+        print " | " + str(self.get_title())
+        print " | Description:"
+        print " | " + str(self.get_description())
+        print " | Command history:"
         command = self.get_command()
         if command:
             for token in command.split("\n"):
-                print(" | " + str(token))
+                print " | " + str(token)
     def print_history(self):
         """Print history information about this class in human readable
             shell style
-        print("# Title:")
-        print("# " + str(self.get_title()))
-        print("# Description:")
-        print("# " + str(self.get_description()))
-        print("# Command history:")
+        print "# Title:"
+        print "# " + str(self.get_title())
+        print "# Description:"
+        print "# " + str(self.get_description())
+        print "# Command history:"
         if command:
@@ -947,15 +946,15 @@
                 count += 1
                 if len(token) > 1:
                     if token[0] == "#":
-                        print(token)
+                        print token
                     elif count < len(print_list):
-                        print(token + " \\")
+                        print token + " \\"
                     else:
-                        print(token)
+                        print token
-        print("number_of_maps=" + str(self.get_number_of_maps()))
+        print "number_of_maps=" + str(self.get_number_of_maps())
@@ -1143,29 +1142,29 @@
-        print(" | North-South resolution min:. " + str(self.get_nsres_min()))
-        print(" | North-South resolution max:. " + str(self.get_nsres_max()))
-        print(" | East-west resolution min:... " + str(self.get_ewres_min()))
-        print(" | East-west resolution max:... " + str(self.get_ewres_max()))
-        print(" | Minimum value min:.......... " + str(self.get_min_min()))
-        print(" | Minimum value max:.......... " + str(self.get_min_max()))
-        print(" | Maximum value min:.......... " + str(self.get_max_min()))
-        print(" | Maximum value max:.......... " + str(self.get_max_max()))
-        print(" | Aggregation type:........... " + str(self.get_aggregation_type()))
+        print " | North-South resolution min:. " + str(self.get_nsres_min())
+        print " | North-South resolution max:. " + str(self.get_nsres_max())
+        print " | East-west resolution min:... " + str(self.get_ewres_min())
+        print " | East-west resolution max:... " + str(self.get_ewres_max())
+        print " | Minimum value min:.......... " + str(self.get_min_min())
+        print " | Minimum value max:.......... " + str(self.get_min_max())
+        print " | Maximum value min:.......... " + str(self.get_max_min())
+        print " | Maximum value max:.......... " + str(self.get_max_max())
+        print " | Aggregation type:........... " + str(self.get_aggregation_type())
         STDSMetadataBase.print_info(self)
-        print("aggregation_type=" + str(self.get_aggregation_type()))
+        print "aggregation_type=" + str(self.get_aggregation_type())
         STDSMetadataBase.print_shell_info(self)
-        print("nsres_min=" + str(self.get_nsres_min()))
-        print("nsres_max=" + str(self.get_nsres_max()))
-        print("ewres_min=" + str(self.get_ewres_min()))
-        print("ewres_max=" + str(self.get_ewres_max()))
-        print("min_min=" + str(self.get_min_min()))
-        print("min_max=" + str(self.get_min_max()))
-        print("max_min=" + str(self.get_max_min()))
-        print("max_max=" + str(self.get_max_max()))
+        print "nsres_min=" + str(self.get_nsres_min())
+        print "nsres_max=" + str(self.get_nsres_max())
+        print "ewres_min=" + str(self.get_ewres_min())
+        print "ewres_max=" + str(self.get_ewres_max())
+        print "min_min=" + str(self.get_min_min())
+        print "min_max=" + str(self.get_min_max())
+        print "max_min=" + str(self.get_max_min())
+        print "max_max=" + str(self.get_max_max())
@@ -1262,16 +1261,16 @@
-        print(" | Raster register table:...... " + str(
-            self.get_raster_register()))
+        print " | Raster register table:...... " + str(
+            self.get_raster_register())
         STDSRasterMetadataBase.print_info(self)
         STDSRasterMetadataBase.print_shell_info(self)
-        print("raster_register=" + str(self.get_raster_register()))
+        print "raster_register=" + str(self.get_raster_register())
@@ -1398,21 +1397,21 @@
-        print(" | 3D raster register table:... " + str(
-            self.get_raster3d_register()))
-        print(" | Top-bottom resolution min:.. " + str(self.get_ewres_min()))
-        print(" | Top-bottom resolution max:.. " + str(self.get_ewres_max()))
+        print " | 3D raster register table:... " + str(
+            self.get_raster3d_register())
+        print " | Top-bottom resolution min:.. " + str(self.get_ewres_min())
+        print " | Top-bottom resolution max:.. " + str(self.get_ewres_max())
-        print("tbres_min=" + str(self.get_tbres_min()))
-        print("tbres_max=" + str(self.get_tbres_max()))
-        print("raster3d_register=" + str(self.get_raster3d_register()))
+        print "tbres_min=" + str(self.get_tbres_min())
+        print "tbres_max=" + str(self.get_tbres_max())
+        print "raster3d_register=" + str(self.get_raster3d_register())
@@ -1663,40 +1662,40 @@
-        print(" | Vector register table:...... " + str(
-            self.get_vector_register()))
-        print(" | Number of points ........... " + str(self.number_of_points))
-        print(" | Number of lines ............ " + str(self.number_of_lines))
-        print(" | Number of boundaries ....... " + str(self.number_of_boundaries))
-        print(" | Number of centroids ........ " + str(self.number_of_centroids))
-        print(" | Number of faces ............ " + str(self.number_of_faces))
-        print(" | Number of kernels .......... " + str(self.number_of_kernels))
-        print(" | Number of primitives ....... " + str(self.number_of_primitives))
-        print(" | Number of nodes ............ " + str(self.number_of_nodes))
-        print(" | Number of areas ............ " + str(self.number_of_areas))
-        print(" | Number of islands .......... " + str(self.number_of_islands))
-        print(" | Number of holes ............ " + str(self.number_of_holes))
-        print(" | Number of volumes .......... " + str(self.number_of_volumes))
+        print " | Vector register table:...... " + str(
+            self.get_vector_register())
+        print " | Number of points ........... " + str(self.number_of_points)
+        print " | Number of lines ............ " + str(self.number_of_lines)
+        print " | Number of boundaries ....... " + str(self.number_of_boundaries)
+        print " | Number of centroids ........ " + str(self.number_of_centroids)
+        print " | Number of faces ............ " + str(self.number_of_faces)
+        print " | Number of kernels .......... " + str(self.number_of_kernels)
+        print " | Number of primitives ....... " + str(self.number_of_primitives)
+        print " | Number of nodes ............ " + str(self.number_of_nodes)
+        print " | Number of areas ............ " + str(self.number_of_areas)
+        print " | Number of islands .......... " + str(self.number_of_islands)
+        print " | Number of holes ............ " + str(self.number_of_holes)
+        print " | Number of volumes .......... " + str(self.number_of_volumes)
-        print("vector_register=" + str(self.get_vector_register()))
+        print "vector_register=" + str(self.get_vector_register())
Modified: grass/trunk/lib/python/temporal/open_stds.py
--- grass/trunk/lib/python/temporal/open_stds.py	2016-03-29 08:10:14 UTC (rev 68181)
+++ grass/trunk/lib/python/temporal/open_stds.py	2016-03-29 09:23:26 UTC (rev 68182)
@@ -18,7 +18,7 @@
@@ -37,7 +37,7 @@
        :param type: The type of the space time dataset (strd, str3ds, stvds,
                     raster, vector, raster3d)
        :param dbif: The optional database interface to be used
        :return: New stds object
Modified: grass/trunk/lib/python/temporal/register.py
--- grass/trunk/lib/python/temporal/register.py	2016-03-29 08:10:14 UTC (rev 68181)
+++ grass/trunk/lib/python/temporal/register.py	2016-03-29 09:23:26 UTC (rev 68182)
@@ -17,7 +17,7 @@
Modified: grass/trunk/lib/python/temporal/sampling.py
--- grass/trunk/lib/python/temporal/sampling.py	2016-03-29 08:10:14 UTC (rev 68181)
+++ grass/trunk/lib/python/temporal/sampling.py	2016-03-29 09:23:26 UTC (rev 68182)
@@ -16,10 +16,10 @@
 def sample_stds_by_stds_topology(intype, sampletype, inputs, sampler, header,
                                  separator, method, spatial=False,
                                  print_only=True):
@@ -122,7 +122,7 @@
             string += "%s%s" % ("end_time", separator)
             string += "%s%s" % ("interval_length", separator)
             string += "%s" % ("distance_from_begin")
-            print(string)
+            print string
         first_time, dummy = mapmatrizes[0][0]["granule"].get_temporal_extent_as_tuple()
@@ -163,7 +163,7 @@
             string += "%s%s" % (end, separator)
             string += "%s%s" % (delta, separator)
             string += "%s" % (delta_first)
-            print(string)
+            print string
     dbif.close()
     if len(mapmatrizes) > 0:
Modified: grass/trunk/lib/python/temporal/space_time_datasets.py
--- grass/trunk/lib/python/temporal/space_time_datasets.py	2016-03-29 08:10:14 UTC (rev 68181)
+++ grass/trunk/lib/python/temporal/space_time_datasets.py	2016-03-29 09:23:26 UTC (rev 68182)
@@ -9,8 +9,8 @@
 import getpass
 import grass.script.array as garray
Modified: grass/trunk/lib/python/temporal/spatial_extent.py
--- grass/trunk/lib/python/temporal/spatial_extent.py	2016-03-29 08:10:14 UTC (rev 68181)
+++ grass/trunk/lib/python/temporal/spatial_extent.py	2016-03-29 09:23:26 UTC (rev 68182)
@@ -33,8 +33,7 @@
+from base import *
 class SpatialExtent(SQLDatabaseInterface):
@@ -1783,22 +1782,22 @@
-        print(" +-------------------- Spatial extent ----------------------------------------+")
-        print(" | North:...................... " + str(self.get_north()))
-        print(" | South:...................... " + str(self.get_south()))
-        print(" | East:.. .................... " + str(self.get_east()))
-        print(" | West:....................... " + str(self.get_west()))
-        print(" | Top:........................ " + str(self.get_top()))
-        print(" | Bottom:..................... " + str(self.get_bottom()))
+        print " +-------------------- Spatial extent ----------------------------------------+"
+        print " | North:...................... " + str(self.get_north())
+        print " | South:...................... " + str(self.get_south())
+        print " | East:.. .................... " + str(self.get_east())
+        print " | West:....................... " + str(self.get_west())
+        print " | Top:........................ " + str(self.get_top())
+        print " | Bottom:..................... " + str(self.get_bottom())
-        print("north=" + str(self.get_north()))
-        print("south=" + str(self.get_south()))
-        print("east=" + str(self.get_east()))
-        print("west=" + str(self.get_west()))
-        print("top=" + str(self.get_top()))
-        print("bottom=" + str(self.get_bottom()))
+        print "north=" + str(self.get_north())
+        print "south=" + str(self.get_south())
+        print "east=" + str(self.get_east())
+        print "west=" + str(self.get_west())
+        print "top=" + str(self.get_top())
+        print "bottom=" + str(self.get_bottom())
Modified: grass/trunk/lib/python/temporal/spatial_topology_dataset_connector.py
--- grass/trunk/lib/python/temporal/spatial_topology_dataset_connector.py	2016-03-29 08:10:14 UTC (rev 68181)
+++ grass/trunk/lib/python/temporal/spatial_topology_dataset_connector.py	2016-03-29 09:23:26 UTC (rev 68182)
@@ -14,7 +14,6 @@
 import copy
@@ -69,7 +68,7 @@
             meet=a at P
             >>> rlist = tmr.get_spatial_relations()
             >>> if "COVER" in rlist.keys():
-            ...    print(rlist["COVER"][0].get_id())
+            ...    print rlist["COVER"][0].get_id()
             a at P
@@ -319,54 +318,54 @@
     def print_spatial_topology_info(self):
-        print(" +-------------------- Spatial Topology --------------------------------------+")
+        print " +-------------------- Spatial Topology --------------------------------------+"
         if self.equivalent is not None:
-            print(" | Equivalent: ................ " +
-                  self._generate_map_list_string(self.equivalent))
+            print " | Equivalent: ................ " + \
+                self._generate_map_list_string(self.equivalent)
         if self.cover is not None:
-            print(" | Cover: ..................... " +
-                  self._generate_map_list_string(self.cover))
+            print " | Cover: ..................... " + \
+                self._generate_map_list_string(self.cover)
         if self.covered is not None:
-            print(" | Covered: ................... " +
-                  self._generate_map_list_string(self.covered))
+            print " | Covered: ................... " + \
+                self._generate_map_list_string(self.covered)
         if self.overlap is not None:
-            print(" | Overlap: ................... " +
-                  self._generate_map_list_string(self.overlap))
+            print " | Overlap: ................... " + \
+                self._generate_map_list_string(self.overlap)
         if self.in_ is not None:
-            print(" | In: ........................ " +
-                  self._generate_map_list_string(self.in_))
+            print " | In: ........................ " + \
+                self._generate_map_list_string(self.in_)
         if self.contain is not None:
-            print(" | Contain: ................... " +
-                  self._generate_map_list_string(self.contain))
+            print " | Contain: ................... " + \
+                self._generate_map_list_string(self.contain)
         if self.meet is not None:
-            print(" | Meet: ...................... " +
-                  self._generate_map_list_string(self.meet))
+            print " | Meet: ...................... " + \
+                self._generate_map_list_string(self.meet)
     def print_spatial_topology_shell_info(self):
-            print("equivalent=" + self._generate_map_list_string(self.equivalent,
-        False))
+            print "equivalent=" + self._generate_map_list_string(self.equivalent,
+        False)
-            print("cover=" + self._generate_map_list_string(
-                  self.cover, False))
+            print "cover=" + self._generate_map_list_string(
+                self.cover, False)
-            print("covered=" +
-                  self._generate_map_list_string(self.covered, False))
+            print "covered=" + \
+                self._generate_map_list_string(self.covered, False)
-            print("overlap=" +
+            print "overlap=" + \
-            print("in=" +
+            print "in=" + \
-            print("contain=" +
+            print "contain=" + \
-            print("meet=" +
+            print "meet=" + \
Modified: grass/trunk/lib/python/temporal/spatio_temporal_relationships.py
--- grass/trunk/lib/python/temporal/spatio_temporal_relationships.py	2016-03-29 08:10:14 UTC (rev 68181)
+++ grass/trunk/lib/python/temporal/spatio_temporal_relationships.py	2016-03-29 09:23:26 UTC (rev 68182)
@@ -17,8 +17,8 @@
 import grass.lib.vector as vector
 import grass.lib.rtree as rtree
 import grass.lib.gis as gis
Modified: grass/trunk/lib/python/temporal/stds_export.py
--- grass/trunk/lib/python/temporal/stds_export.py	2016-03-29 08:10:14 UTC (rev 68181)
+++ grass/trunk/lib/python/temporal/stds_export.py	2016-03-29 09:23:26 UTC (rev 68182)
@@ -30,9 +30,9 @@
 import tarfile
 import tempfile
@@ -52,7 +52,7 @@
-def _export_raster_maps_as_gdal(rows, tar, list_file, new_cwd, fs, format_,
+def _export_raster_maps_as_gdal(rows, tar, list_file, new_cwd, fs, format_,
                                 type_):
     for row in rows:
         name = row["name"]
Modified: grass/trunk/lib/python/temporal/stds_import.py
--- grass/trunk/lib/python/temporal/stds_import.py	2016-03-29 08:10:14 UTC (rev 68181)
+++ grass/trunk/lib/python/temporal/stds_import.py	2016-03-29 09:23:26 UTC (rev 68182)
@@ -33,10 +33,10 @@
 import os.path
 import tarfile
-from . import factory
+import factory
@@ -244,7 +244,7 @@
         temp_file = open(temp_name, "w")
         proj_name = os.path.abspath(proj_file_name)
-        # We need to convert projection strings generated
+        # We need to convert projection strings generated
         # from other programms than g.proj into
         # new line format so that the grass file comparison function
         # can be used to compare the projections
Modified: grass/trunk/lib/python/temporal/temporal_algebra.py
--- grass/trunk/lib/python/temporal/temporal_algebra.py	2016-03-29 08:10:14 UTC (rev 68181)
+++ grass/trunk/lib/python/temporal/temporal_algebra.py	2016-03-29 09:23:26 UTC (rev 68182)
@@ -367,7 +367,7 @@
     None || None
     A* =  if condition None  then  A  else  B
     C = A*
     >>> p = tgis.TemporalAlgebraLexer()
     >>> p.build()
     >>> p.debug = True
@@ -390,7 +390,7 @@
     LexToken(LPAREN,'(',1,32)
     LexToken(NAME,'C',1,33)
     LexToken(RPAREN,')',1,34)
     >>> p.build()
     >>> p.debug = True
@@ -412,7 +412,7 @@
     LexToken(COMMA,',',1,33)
     LexToken(NAME,'A',1,35)
     LexToken(RPAREN,')',1,36)
     >>> p.build()
     >>> p.debug = True
@@ -438,7 +438,6 @@
     LexToken(RPAREN,')',1,48)
 try:
     import ply.lex as lex
@@ -449,17 +448,17 @@
 import os
 import copy
 import grass.pygrass.modules as pymod
 class TemporalAlgebraLexer(object):
     """Lexical analyzer for the GRASS GIS temporal algebra"""
-    # Functions that defines an if condition, temporal buffering, snapping and
+    # Functions that defines an if condition, temporal buffering, snapping and
     # selection of maps with temporal extent.
     conditional_functions = {
         'if'    : 'IF',
@@ -472,7 +471,7 @@
         'str3ds' : 'STR3DS',
         'stvds' : 'STVDS',
     # Variables with date and time strings
     datetime_functions = {
         'start_time'     : 'START_TIME',     # start time as HH::MM:SS
@@ -566,7 +565,7 @@
     t_T_REL_OPERATOR     = r'\{([a-zA-Z\| ])+\}'
     t_T_SELECT           = r':'
     t_T_NOT_SELECT       = r'!:'
-    t_LPAREN             = r'\('
+    t_LPAREN             = r'\('
     t_RPAREN             = r'\)'
     t_COMMA              = r','
     t_CEQUALS            = r'=='
@@ -665,7 +664,7 @@
         while True:
              tok = self.lexer.token()
              if not tok: break
-             print(tok)
+             print tok
@@ -737,7 +736,7 @@
         ('left', 'AND', 'OR', 'T_COMP_OPERATOR'), #2
-    def __init__(self, pid=None, run = True, debug = False, spatial = False,
+    def __init__(self, pid=None, run = True, debug = False, spatial = False,
                         null = False, register_null = False,  nprocs = 1):
         self.run = run
         self.debug = debug
@@ -762,45 +761,45 @@
     def __del__(self):
         if self.dbif.connected:
             self.dbif.close()
     def setup_common_granularity(self,  expression,  stdstype = 'strds',  lexer = None):
         """Configure the temporal algebra to use the common granularity of all
              space time datasets in the expression to generate the map lists.
              This function will analyze the expression to detect space time datasets
              and computes the common granularity from all granularities.
              This granularity is then be used to generate the map lists. Hence, all
              maps from all STDS will have equidistant temporal extents. The only meaningful
              temporal relation is "equal".
              :param expression: The algebra expression to analyze
              :param lexer: The temporal algebra lexer (select, raster, voxel, vector) that should be used to
                                     parse the expression, default is TemporalAlgebraLexer
              :return: True if successful, False otherwise
         l = lexer
         # Split the expression to ignore the left part
         expressions = expression.split("=")[1:]
         expression = " ".join(expressions)
         # Check if spatio-temporal operators are present in the expression
         if "{" in expression or "}" in expression:
             self.msgr.error(_("Spatio temporal operators are not supported in granularity algebra mode"))
             return False
         # detect all STDS
         if l is None:
             l = TemporalAlgebraLexer()
         l.build()
         l.lexer.input(expression)
         name_list = []
         tokens = []
         count = 0
         while True:
             tok = l.lexer.token()
@@ -812,7 +811,7 @@
             if count > 1:
                 if tokens[count - 2] == "MAP" or tokens[count - 2] == "TMAP":
                     ignore = True
             if tok.type == "NAME" and ignore == False:
                 name_list.append(tok.value)
             count += 1
@@ -832,23 +831,23 @@
             grans.append(stds.get_granularity())
             start_times.append(stds.get_temporal_extent_as_tuple()[0])
             ttypes[stds.get_temporal_type()] = stds.get_temporal_type()
         # Only one temporal type is allowed
         if len(ttypes) > 1:
             self.msgr.error(_("All input space time datasets must have the same temporal type."))
             return False
         # Compute the common granularity
         if "absolute" in ttypes.keys():
             self.granularity = compute_common_absolute_time_granularity(grans, start_times)
         else:
             self.granularity = compute_common_relative_time_granularity(grans)
         self.use_granularity = True
         return True
-    def parse(self, expression, stdstype = 'strds', maptype = 'rast',  mapclass = RasterDataset,
+    def parse(self, expression, stdstype = 'strds', maptype = 'rast',  mapclass = RasterDataset,
                       basename = None, overwrite=False):
         self.lexer = TemporalAlgebraLexer()
         self.lexer.build()
@@ -878,7 +877,7 @@
         self.names[name] = name
         return name
-    def generate_new_map(self, base_map, bool_op = 'and', copy = True,  rename = True,
+    def generate_new_map(self, base_map, bool_op = 'and', copy = True,  rename = True,
                                               remove = False):
         """Generate a new map using the spatio-temporal extent of the base map
@@ -968,7 +967,7 @@
                 if temp_ext != None:
                     mapA.set_temporal_extent(temp_ext)
                 else:
-                    returncode = 0
+                    returncode = 0
             elif temp_op == 'd':
                 temp_ext = mapA.temporal_disjoint_union(mapB)
@@ -984,25 +983,25 @@
         return(returncode)
     def set_temporal_extent_list(self, maplist, topolist = ["EQUAL"], temporal = 'l' ):
-        """ Change temporal extent of map list based on temporal relations to
+        """ Change temporal extent of map list based on temporal relations to
                 other map list and given temporal operator.
-            :param maplist: List of map objects for which relations has been build
+            :param maplist: List of map objects for which relations has been build
                                         correctely.
             :param topolist: List of strings of temporal relations.
             :param temporal: The temporal operator specifying the temporal
-                                            extent operation (intersection, union, disjoint
+                                            extent operation (intersection, union, disjoint
                                             union, right reference, left reference).
             :return: Map list with specified temporal extent.
         resultdict = {}
         for map_i in maplist:
             # Loop over temporal related maps and create overlay modules.
             tbrelations = map_i.get_temporal_relations()
             # Generate an intermediate map for the result map list.
-            map_new = self.generate_new_map(base_map=map_i, bool_op = 'and',
+            map_new = self.generate_new_map(base_map=map_i, bool_op = 'and',
        copy = True,  rename = True)
             # Combine temporal and spatial extents of intermediate map with related maps.
             for topo in topolist:
@@ -1010,7 +1009,7 @@
                     for map_j in (tbrelations[topo]):
                         if temporal == 'r':
                         # Create overlayed map extent.
                         returncode = self.overlay_map_extent(map_new, map_j, 'and', \
@@ -1025,10 +1024,10 @@
                             # print(map_new.cmd_list)
                             # resultlist.append(map_new)
                             resultdict[map_new.get_id()] = map_new
                         # Create r.mapcalc expression string for the operation.
-                        #cmdstring = self.build_command_string(s_expr_a = map_new,
-                        #        s_expr_b = map_j,
+                        #cmdstring = self.build_command_string(s_expr_a = map_new,
+                        #        s_expr_b = map_j,
                         #        operator = function)
                         # Conditional append of module command.
                         #map_new.cmd_list = cmdstring
@@ -1040,24 +1039,24 @@
         # Get sorted map objects as values from result dictionoary.
         resultlist = resultdict.values()
         resultlist = sorted(resultlist, key = AbstractDatasetComparisonKeyStartTime)
         return(resultlist)
     ######################### Temporal functions ##############################
     def remove_maps(self):
         """Removes empty or intermediate maps of different type.
         map_names = {}
         map_names["raster"] = []
         map_names["raster3d"] = []
         map_names["vector"] = []
         if self.removable_maps:
             for map in self.removable_maps.values():
                     map_names[map.get_type()].append(map.get_name())
         for key in map_names.keys():
             if map_names[key]:
                 self.msgr.message(_("Removing un-needed or empty %s maps"%(key)))
@@ -1065,7 +1064,7 @@
     def _remove_maps(self,  namelist,  map_type):
         """Remove maps of specific type
             :param namelist: List of map names to be removed
             :param map_type: The type of the maps  (raster, raster_3d or vector)
@@ -1073,13 +1072,13 @@
         chunklist = [namelist[i:i + max] for i in range(0, len(namelist), max)]
         for chunk in chunklist:
             stringlist = ",".join(chunk)
             if self.run:
                 m = copy.deepcopy(self.m_mremove)
                 m.inputs["type"].value = map_type
                 m.inputs["name"].value = stringlist
                 m.flags["f"].value = True
-                print(m.get_bash())
+                print m.get_bash()
                 m.run()
     def check_stds(self, input, clear = False,  stds_type = None,  check_type=True):
@@ -1088,7 +1087,7 @@
             :param input: Name of space time data set as string or list of maps.
             :param clear: Reset the stored conditional values to empty list.
             :param check_type: Check the type of the space time dataset to match the global stds type
-            :param stds_type: The type of the space time dataset to be opened, if not provided
+            :param stds_type: The type of the space time dataset to be opened, if not provided
                                           then self.stdstype will be used
             :return: List of maps.
@@ -1144,7 +1143,7 @@
         elif isinstance(input,  self.mapclass):
             # Check if the input is a single map and return it as list with one entry.
             maplist = [input]
         elif isinstance(input,  list):
             maplist = input
             # Create map_value as empty list item.
@@ -1159,19 +1158,19 @@
                     map_i.condition_value = []
         else:
             self.msgr.fatal(_("Wrong type of input " + str(input)))
         # We generate a unique map id that will be used
-        # in the topology analysis, since the maplist can
-        # contain maps with equal map ids
+        # in the topology analysis, since the maplist can
+        # contain maps with equal map ids
         for map in maplist:
             map.uid = self.generate_map_name()
             if self.debug:
-                print(map.get_name(), map.uid,  map.get_temporal_extent_as_tuple())
+                print map.get_name(), map.uid,  map.get_temporal_extent_as_tuple()
         return(maplist)
     def get_temporal_topo_list(self, maplistA, maplistB = None, topolist = ["EQUAL"],
-                               assign_val = False, count_map = False, compare_bool = False,
+                               assign_val = False, count_map = False, compare_bool = False,
                                compop = None, aggregate = None):
         """Build temporal topology for two space time data sets, copy map objects
           for given relation into map list.
@@ -1188,7 +1187,7 @@
                             related map list and compariosn operator.
           :param compop: Comparison operator, && or ||.
           :param aggregate: Aggregation operator for relation map list, & or |.
           :return: List of maps from maplistA that fulfil the topological relationships
                   to maplistB specified in topolist.
@@ -1216,8 +1215,8 @@
               >>> for map in resultlist:
               ...     if map.get_equal():
               ...         relations = map.get_equal()
-              ...         print("Map %s has equal relation to map %s"%(map.get_name(),
-              ...               relations[0].get_name()))
+              ...         print "Map %s has equal relation to map %s"%(map.get_name(),
+              ...               relations[0].get_name())
               Map a0 has equal relation to map b0
               Map a1 has equal relation to map b1
               Map a2 has equal relation to map b2
@@ -1249,8 +1248,8 @@
               ...     if map.get_starts():
               ...         relations = map.get_starts()
-              ...         print("Map %s has start relation to map %s"%(map.get_name(),
+              ...         print "Map %s has start relation to map %s"%(map.get_name(),
               Map a0 has start relation to map b0
               Map a1 has start relation to map b1
               Map a2 has start relation to map b2
@@ -1264,8 +1263,8 @@
               ...     if map.get_during():
               ...         relations = map.get_during()
-              ...         print("Map %s has during relation to map %s"%(map.get_name(),
+              ...         print "Map %s has during relation to map %s"%(map.get_name(),
               Map a0 has during relation to map b0
               Map a1 has during relation to map b0
               Map a2 has during relation to map b1
@@ -1367,22 +1366,22 @@
                     # Use unique identifier, since map names may be equal
                     resultdict[map_i.uid] = map_i
         # Sort list of maps chronological.
         return(resultlist)
     def assign_bool_value(self,  map_i, tbrelations, topolist = ["EQUAL"]):
-        """ Function to assign boolean map value based on the map_values from the
+        """ Function to assign boolean map value based on the map_values from the
                 compared map list by topological relationships.
           :param map_i: Map object with temporal extent.
           :param tbrelations: List of temporal relation to map_i.
           :param topolist: List of strings for given temporal relations.
-          :return: Map object with conditional value that has been assigned by
-                        relation maps that fulfil the topological relationships to
+          :return: Map object with conditional value that has been assigned by
+                        relation maps that fulfil the topological relationships to
         condition_value_list = []
@@ -1401,19 +1400,19 @@
         else:
             resultbool = False
         map_i.condition_value = [resultbool]
         return(resultbool)
     def compare_bool_value(self,  map_i, tbrelations, compop, aggregate,  topolist = ["EQUAL"]):
-        """ Function to evaluate two map lists with boolean values by boolean
-            comparison operator.
+        """ Function to evaluate two map lists with boolean values by boolean
+            comparison operator.
           :return: Map object with conditional value that has been evaluated by
                         comparison operators.
@@ -1445,20 +1444,20 @@
             print(resultbool)
         # Add boolean value to result list.
         return(resultbool)
     def eval_toperator(self, operator, optype = 'relation'):
         """This function evaluates a string containing temporal operations.
          :param operator: String of temporal operations, e.g. {!=,equal|during,l}.
          :param optype: String to define operator type.
          :return :List of temporal relations (equal, during), the given function
           (!:) and the interval/instances (l).
         .. code-block:: python
              >>> import grass.temporal as tgis
              >>> tgis.init()
              >>> p = tgis.TemporalOperatorParser()
@@ -1471,7 +1470,7 @@
         p = TemporalOperatorParser()
         p.parse(operator, optype)
         p.relations = [rel.upper() for rel in p.relations]
         return(p.relations, p.temporal, p.function,  p.aggregate)
     def perform_temporal_selection(self, maplistA, maplistB, topolist = ["EQUAL"],
@@ -1516,8 +1515,8 @@
               Map a5 has equal relation to map b0
               Map a6 has equal relation to map b1
               Map a7 has equal relation to map b2
@@ -1527,7 +1526,7 @@
               ...                                           True)
               ...     if not map.get_equal():
-              ...         print("Map %s has no equal relation to mapset mapsB"%(map.get_name()))
+              ...         print "Map %s has no equal relation to mapset mapsB"%(map.get_name())
               Map a0 has no equal relation to mapset mapsB
               Map a1 has no equal relation to mapset mapsB
               Map a2 has no equal relation to mapset mapsB
@@ -1663,7 +1662,7 @@
             if unchanged == True:
                 if self.debug:
                     print('Leave temporal extend of result map: ' +  map_i.get_map_id() + ' unchanged.')
@@ -1683,7 +1682,7 @@
           :return: Dictionary with temporal functions for given input map.
               >>> import datetime
               >>> tgis.init()
@@ -1854,14 +1853,14 @@
         """ This function evaluates temporal variable expressions of a conditional
              expression in two steps.
              At first it combines stepwise the single conditions by their relations with LALR.
-             In this prossess sub condition map lists will be created which will include
-             information of the underlying single conditions. Important: The temporal
-             relations between conditions are evaluated by implicit aggregation.
-             In the second step the aggregated condition map list will be compared with the
+             In this prossess sub condition map lists will be created which will include
+             information of the underlying single conditions. Important: The temporal
+             relations between conditions are evaluated by implicit aggregation.
+             In the second step the aggregated condition map list will be compared with the
              map list of conclusion statements by the given temporal relation.
-             The result is writen as 'condition_value' attribute to the resulting map objects.
-             These attribute consists of boolean expressions and operators which can be
+             The result is writen as 'condition_value' attribute to the resulting map objects.
+             These attribute consists of boolean expressions and operators which can be
              evaluated with the eval_condition_list function.
              [True,  '||', False, '&&', True]
@@ -1874,17 +1873,17 @@
              :param thenlist: Map list object of the conclusion statement.
                          It will be compared and evaluated by the conditions.
-             :param topolist: List of temporal relations between the conditions and the
+             :param topolist: List of temporal relations between the conditions and the
                          conclusions.
              :return: Map list with conditional values for all temporal expressions.
-        # Evaluate the temporal variable expression and compute the temporal combination
+        # Evaluate the temporal variable expression and compute the temporal combination
         # of conditions.
         # Check if the input expression is a valid single global variable.
         if isinstance(tvarexpr, GlobalTemporalVar) and tvarexpr.get_type() == "global" :
             # Use method eval_global_var to evaluate expression.
@@ -1931,14 +1930,14 @@
         return(resultlist)
     def eval_condition_list(self, maplist, inverse = False):
         """ This function evaluates conditional values of a map list.
              A recursive function is used to evaluate comparison statements
              from left to right in the given conditional list.
-             For example:
+             For example:
                   - [True,  '||', False, '&&', True]  -> True
                   - [True,  '||', False, '&&', False] -> False
                   - [True,  '&&', False, '&&', True]  -> False
@@ -2022,12 +2021,12 @@
             if isinstance(t[3], list):
                 num = len(t[3])
                 count = 0
-                register_list = []
+                register_list = []
                 if num > 0:
                     process_queue = pymod.ParallelModuleQueue(int(self.nprocs))
                     for map_i in t[3]:
-                        # Test if temporal extents have been changed by temporal
-                        # relation operators (i|r).
+                        # Test if temporal extents have been changed by temporal
+                        # relation operators (i|r).
                         if count == 0:
                             maps_stds_type = map_i.get_new_stds_instance(None).get_type()
                             map_type = map_i.get_type()
@@ -2083,14 +2082,14 @@
                     # Wait for running processes
                     process_queue.wait()
                     # Open connection to temporal database.
-                    # Create result space time dataset based on the map stds type
+                    # Create result space time dataset based on the map stds type
                     resultstds = open_new_stds(t[1],maps_stds_type, \
                                                              'absolute', t[1], t[1], \
                                                              'mean', self.dbif, \
-                                                             overwrite = self.overwrite)
-                    for map_i in register_list:
+                                                             overwrite = self.overwrite)
+                    for map_i in register_list:
                         # Get meta data from grass database.
                         map_i.load()
                         # Check if temporal extents have changed and a new map was created
@@ -2120,7 +2119,7 @@
                     self.msgr.warning("Empty result space time dataset. "\
                                                   "No map has been registered in %s"  %(t[1] ))
-                    # Create result space time dataset.
+                    # Create result space time dataset.
                     resultstds = open_new_stds(t[1], self.stdstype, \
                                                              'mean', dbif, \
@@ -2132,7 +2131,7 @@
             t[0] = t[3]
         if self.debug:
-            print(t[1], "=", t[3])
+            print t[1], "=", t[3]
     def p_stds_1(self, t):
         # Definition of a space time dataset
@@ -2153,7 +2152,7 @@
     def p_expr_strds_function(self, t):
         # Explicitly specify a space time raster dataset
-        # R = A : strds(B)
+        # R = A : strds(B)
         expr : STRDS LPAREN stds RPAREN
@@ -2162,11 +2161,11 @@
         else:
             t[0] = t[3]
             if self.debug:
-                print("Opening STRDS: ",  t[0])
+                print "Opening STRDS: ",  t[0]
     def p_expr_str3ds_function(self, t):
-        # R = A : str3ds(B)
+        # R = A : str3ds(B)
         expr : STR3DS LPAREN stds RPAREN
@@ -2175,28 +2174,28 @@
         else:
             t[0] = t[3]
             if self.debug:
-                print("Opening STR3DS: ",  t[0])
+                print "Opening STR3DS: ",  t[0]
     def p_expr_stvds_function(self, t):
         # Explicitly specify a space time vector dataset
-        # R = A : stvds(B)
+        # R = A : stvds(B)
         expr : STVDS LPAREN stds RPAREN
         if self.run:
-            print(t[3])
+            print t[3]
             t[0] = self.check_stds(t[3], stds_type = "stvds",  check_type=False)
         else:
             t[0] = t[3]
             if self.debug:
-                print("Opening STVDS: ",  t[0])
+                print "Opening STVDS: ",  t[0]
     def p_expr_tmap_function(self, t):
         # Add a single map.
-        # Only the spatial extent of the map is evaluated.
+        # Only the spatial extent of the map is evaluated.
         # Temporal extent is not existing.
         # Examples:
-        #    R = tmap(A)
+        #    R = tmap(A)
         expr : TMAP LPAREN stds RPAREN
@@ -2228,7 +2227,7 @@
             t[0] = "tmap(",  t[3] , ")"
         if self.debug:
-            print("tmap(", t[3] , ")")
+            print "tmap(", t[3] , ")"
     def p_expr_tmerge_function(self, t):
         # Merge two maplists of same STDS type into a result map list.
@@ -2245,7 +2244,7 @@
             # Check input map.
             maplistA   = self.check_stds(t[3])
             maplistB   = self.check_stds(t[5])
             # Check empty lists.
             if len(maplistA) == 0 and len(maplistB) == 0:
                 self.msgr.warning(_("Merging empty map lists"))
@@ -2265,14 +2264,14 @@
                     grass.fatal(_("Space time datasets to merge must have the same temporal type"))
                 resultlist = maplistA + maplistB
             # Return map list.
             t[0] = resultlist
         else:
             t[0] = "merge(",  t[3], ",", t[5], ")"
         if self.debug:
-            print("merge(", t[3], ",", t[5], ")")
+            print "merge(", t[3], ",", t[5], ")"
     def p_t_hash(self,t):
@@ -2333,7 +2332,7 @@
             t[0] = "td(" + str(t[3]) + ")"
         if self.debug:
-            print("td(" + str(t[3]) + ")")
+            print "td(" + str(t[3]) + ")"
     def p_t_time_var(self, t):
@@ -2397,11 +2396,11 @@
                         map_i.condition_value = boolname
                 except:
                     self.msgr.fatal("Error: the given expression does not contain a correct time difference object.")
             t[0] = maplist
         if self.debug:
-            print(t[1], t[2], t[3])
+            print t[1], t[2], t[3]
     def p_t_var_expr_number(self, t):
         # Examples:
@@ -2410,7 +2409,7 @@
         #    start_day(B) < start_month(A)
         t_var_expr : t_var LPAREN stds RPAREN comp_op number
-                | t_var LPAREN expr RPAREN comp_op number
+                | t_var LPAREN expr RPAREN comp_op number
         # TODO:  Implement comparison operator for map lists.
         #| t_var LPAREN stds RPAREN comp_op t_var LPAREN stds RPAREN
@@ -2430,7 +2429,7 @@
             t[0] = resultlist
         if self.debug:
-                print(t[1], t[3], t[5], t[6])
+                print t[1], t[3], t[5], t[6]
     def p_t_var_expr_time(self, t):
         # Examples:
@@ -2463,12 +2462,12 @@
             gvar.value  = t[6]
             # Evaluate temporal variable for given maplist.
             resultlist = self.eval_global_var(gvar, maplist)
             t[0] = resultlist
         if self.debug:
     def p_t_var_expr_comp(self, t):
@@ -2482,18 +2481,18 @@
             relations = ["EQUAL"]
             temporal = "l"
             function = t[2] + t[3]
-            aggregate = t[2]
-            # Build conditional values based on topological relationships.
+            aggregate = t[2]
+            # Build conditional values based on topological relationships.
             complist = self.get_temporal_topo_list(tvarexprA, tvarexprB, topolist = relations,
                                compare_bool = True, compop = function[0], aggregate = aggregate)
             # Set temporal extent based on topological relationships.
-            resultlist = self.set_temporal_extent_list(complist, topolist = relations,
+            resultlist = self.set_temporal_extent_list(complist, topolist = relations,
                                 temporal = temporal)
             t[0] = resultlist
         if self.debug:
-            print(t[1], t[2] + t[3], t[4])
+            print t[1], t[2] + t[3], t[4]
     def p_t_var_expr_comp_op(self, t):
@@ -2508,13 +2507,13 @@
             t[0] = resultlist
         if self.debug:
     def p_expr_t_select(self, t):
         # Temporal equal selection
@@ -2541,7 +2540,7 @@
             t[0] = t[1] , "*"
         if self.debug:
-            print(str(t[1]),  "* = ", t[1], t[2], t[3])
+            print str(t[1]),  "* = ", t[1], t[2], t[3]
     def p_expr_t_not_select(self, t):
@@ -2567,7 +2566,7 @@
             t[0] = t[1] + "*"
         if self.debug:
-            print(t[1] + "* = ", t[1], t[2], t[3])
+            print t[1] + "* = ", t[1], t[2], t[3]
     def p_expr_t_select_operator(self, t):
@@ -2600,7 +2599,7 @@
             # Perform selection.
             selectlist = self.perform_temporal_selection(maplistA, maplistB,
                          topolist = operators[0], inverse = negation)
-            selectlist = self.set_granularity(selectlist, maplistB, operators[1],
+            selectlist = self.set_granularity(selectlist, maplistB, operators[1],
                 operators[0])
             # Return map list.
             t[0] = selectlist
@@ -2608,7 +2607,7 @@
             t[0] = t[1] + "*"
         if self.debug:
     def p_expr_condition_if(self, t):
@@ -2623,7 +2622,7 @@
             thenlist     = self.check_stds(t[5])
             # Get temporal conditional statement.
             tvarexpr     = t[3]
-            thencond     = self.build_condition_list(tvarexpr, thenlist)
+            thencond     = self.build_condition_list(tvarexpr, thenlist)
             thenresult   = self.eval_condition_list(thencond)
             # Clear the map and conditional values of the map list.
             resultlist   = self.check_stds(thenresult, clear = True)
@@ -2633,7 +2632,7 @@
             t[0] = t[5] + "*"
         if self.debug:
-            print(str(t[5]) + "* = ", "if condition", str(t[3]), ' then ', str(t[5]))
+            print str(t[5]) + "* = ", "if condition", str(t[3]), ' then ', str(t[5])
     def p_expr_condition_if_relation(self, t):
         # Examples
@@ -2648,8 +2647,8 @@
             tvarexpr     = t[5]
             topolist     = self.eval_toperator(t[3],  optype = 'relation')[0]
-            thencond     = self.build_condition_list(tvarexpr, thenlist, topolist)
-            thenresult   = self.eval_condition_list(thencond)
+            thencond     = self.build_condition_list(tvarexpr, thenlist, topolist)
+            thenresult   = self.eval_condition_list(thencond)
             # Return resulting map list.
@@ -2658,7 +2657,7 @@
             t[0] = t[7] + "*"
         if self.debug:
-            print("result* = ", "if ", str(t[3]),  "condition", str(t[5]), " then ", str(t[7]))
+            print "result* = ", "if ", str(t[3]),  "condition", str(t[5]), " then ", str(t[7])
     def p_expr_condition_elif(self, t):
         # Examples
@@ -2691,7 +2690,7 @@
             t[0] = t[5] + "*"
         if self.debug:
-            print(str(t[5]) + "* = ", "if condition", str(t[3]), " then ", str(t[5]), ' else ', str(t[7]))
+            print str(t[5]) + "* = ", "if condition", str(t[3]), " then ", str(t[5]), ' else ', str(t[7])
     def p_expr_condition_elif_relation(self, t):
         # Examples
@@ -2731,9 +2730,9 @@
         if self.debug:
             if t[5]:
-                print(str(t[7]), "* = ", "if condition", str(t[5]), " then ", str(t[7]), ' else ', str(t[9]))
+                print str(t[7]), "* = ", "if condition", str(t[5]), " then ", str(t[7]), ' else ', str(t[9])
             else:
-                print(str(t[9]), "* = ", "if condition", str(t[5]), " then ", str(t[7]), ' else ', str(t[9]))
+                print str(t[9]), "* = ", "if condition", str(t[5]), " then ", str(t[7]), ' else ', str(t[9])
     def p_expr_t_buff(self, t):
         # Examples
@@ -2762,9 +2761,9 @@
         if self.debug:
             if len(t) == 10:
-                print(str(t[3]) + "* = buff_t(", str(t[3]), "," , '"', str(t[6]), str(t[7]), '"', ")")
+                print str(t[3]) + "* = buff_t(", str(t[3]), "," , '"', str(t[6]), str(t[7]), '"', ")"
             elif len(t) == 7:
-                print(str(t[3]) + "* = buff_t(", str(t[3]), ",", str(t[5]), ")")
+                print str(t[3]) + "* = buff_t(", str(t[3]), ",", str(t[5]), ")"
     def p_expr_t_snap(self, t):
         # Examples
@@ -2783,7 +2782,7 @@
             t[0] = t[3] + "*"
         if self.debug:
-            print(str(t[3]) + "* = tsnap(", str(t[3]), ")")
+            print str(t[3]) + "* = tsnap(", str(t[3]), ")"
     def p_expr_t_shift(self, t):
         # Examples
@@ -2811,9 +2810,9 @@
         if self.debug:
             if len(t) == 10:
-                print(str(t[3]) + "* = tshift(", str(t[3]), "," , '"', str(t[6]), str(t[7]), '"', ")")
+                print str(t[3]) + "* = tshift(", str(t[3]), "," , '"', str(t[6]), str(t[7]), '"', ")"
             elif len(t) == 7:
-                print(str(t[3]) + "* = tshift(", str(t[3]), ",", str(t[5]), ")")
+                print str(t[3]) + "* = tshift(", str(t[3]), ",", str(t[5]), ")"
     # Handle errors.
     def p_error(self, t):
Modified: grass/trunk/lib/python/temporal/temporal_extent.py
--- grass/trunk/lib/python/temporal/temporal_extent.py	2016-03-29 08:10:14 UTC (rev 68181)
+++ grass/trunk/lib/python/temporal/temporal_extent.py	2016-03-29 09:23:26 UTC (rev 68182)
@@ -19,8 +19,7 @@
 :authors: Soeren Gebbert
-from __future__ import print_function
-from .base import *
+from base import *
@@ -157,13 +156,13 @@
                >>> A = TemporalExtent(start_time=5, end_time=8 )
                >>> B = TemporalExtent(start_time=3, end_time=4 )
                >>> inter = A.intersect(B)
-               >>> print(inter)
+               >>> print inter
                None
                >>> B = TemporalExtent(start_time=3, end_time=None )
-               >>> print(inter)
+               >>> print inter
                None
@@ -397,13 +396,13 @@
-               >>> print(inter)
+               >>> print inter
                None
-               >>> print(inter)
+               >>> print inter
                None
@@ -1029,13 +1028,13 @@
         #      0123456789012345678901234567890
-        print(" | Start time:................. " + str(self.get_start_time()))
-        print(" | End time:................... " + str(self.get_end_time()))
+        print " | Start time:................. " + str(self.get_start_time())
+        print " | End time:................... " + str(self.get_end_time())
     def print_shell_info(self):
         """Print information about this class in shell style"""
-        print("start_time=" + str(self.get_start_time()))
-        print("end_time=" + str(self.get_end_time()))
+        print "start_time=" + str(self.get_start_time())
+        print "end_time=" + str(self.get_end_time())
@@ -1053,7 +1052,7 @@
-        print(" +-------------------- Absolute time -----------------------------------------+")
+        print " +-------------------- Absolute time -----------------------------------------+"
         TemporalExtent.print_info(self)
@@ -1178,14 +1177,14 @@
         AbsoluteTemporalExtent.print_info(self)
-        print(" | Granularity:................ " + str(self.get_granularity()))
-        print(" | Temporal type of maps:...... " + str(self.get_map_time()))
+        print " | Granularity:................ " + str(self.get_granularity())
+        print " | Temporal type of maps:...... " + str(self.get_map_time())
         AbsoluteTemporalExtent.print_shell_info(self)
-        print("granularity=" + str(self.get_granularity()))
-        print("map_time=" + str(self.get_map_time()))
+        print "granularity=" + str(self.get_granularity())
+        print "map_time=" + str(self.get_map_time())
@@ -1295,14 +1294,14 @@
-        print(" +-------------------- Relative time -----------------------------------------+")
+        print " +-------------------- Relative time -----------------------------------------+"
-        print(" | Relative time unit:......... " + str(self.get_unit()))
+        print " | Relative time unit:......... " + str(self.get_unit())
-        print("unit=" + str(self.get_unit()))
+        print "unit=" + str(self.get_unit())
@@ -1427,14 +1426,14 @@
         RelativeTemporalExtent.print_info(self)
         RelativeTemporalExtent.print_shell_info(self)
Modified: grass/trunk/lib/python/temporal/temporal_granularity.py
--- grass/trunk/lib/python/temporal/temporal_granularity.py	2016-03-29 08:10:14 UTC (rev 68181)
+++ grass/trunk/lib/python/temporal/temporal_granularity.py	2016-03-29 09:23:26 UTC (rev 68182)
@@ -17,8 +17,8 @@
-from .abstract_dataset import *
-from .datetime_math import *
+from abstract_dataset import *
+from datetime_math import *
@@ -497,7 +497,7 @@
 def compute_common_relative_time_granularity(gran_list):
 	"""Compute the greatest common granule from a list of relative time granules
@@ -505,7 +505,7 @@
             >>> grans = [1,2,30]
             >>> tgis.compute_common_relative_time_granularity(grans)
             1
             >>> tgis.init()
             >>> grans = [10,20,30]
@@ -756,23 +756,23 @@
             >>> grans = ["1 second", "2 seconds", "30 seconds"]
             >>> tgis.compute_common_absolute_time_granularity(grans)
             '1 second'
             >>> grans = ["3 second", "6 seconds", "30 seconds"]
             '3 seconds'
             >>> grans = ["12 second", "18 seconds", "30 seconds", "10 minutes"]
             '6 seconds'
             >>> grans = ["20 second", "10 minutes", "2 hours"]
             '20 seconds'
             >>> grans = ["7200 second", "240 minutes", "1 year"]
             '7200 seconds'
             >>> grans = ["7200 second", "89 minutes", "1 year"]
             '60 seconds'
@@ -821,37 +821,37 @@
             '1 year'
     has_seconds = False # 0
     has_minutes = False # 1
     has_hours = False     # 2
     has_days = False      # 3
     has_months = False  # 4
     has_years = False     # 5
     seconds = []
     minutes = []
     hours = []
     days = []
     months = []
     years = []
     min_gran = 6
     max_gran = -1
     for entry in gran_list:
         if not check_granularity_string(entry, "absolute"):
             return False
         num,  gran = entry.split()
         if gran in ["seconds",  "second"]:
             has_seconds = True
             if min_gran > 0:
                 min_gran = 0
             if max_gran < 0:
                 max_gran = 0
             seconds.append(int(num))
         if gran in ["minutes",  "minute"]:
@@ -860,7 +860,7 @@
                 min_gran = 1
             if max_gran < 1:
                 max_gran = 1
             minutes.append(int(num))
         if gran in ["hours",  "hour"]:
@@ -869,7 +869,7 @@
                 min_gran = 2
             if max_gran < 2:
                 max_gran = 2
             hours.append(int(num))
         if gran in ["days",  "day"]:
@@ -878,7 +878,7 @@
                 min_gran = 3
             if max_gran < 3:
                 max_gran = 3
             days.append(int(num))
         if gran in ["months",  "month"]:
@@ -887,7 +887,7 @@
                 min_gran = 4
             if max_gran < 4:
                 max_gran = 4
             months.append(int(num))
         if gran in ["years",  "year"]:
@@ -896,9 +896,9 @@
                 min_gran = 5
             if max_gran < 5:
                 max_gran = 5
             years.append(int(num))
     if has_seconds:
         if has_minutes:
             minutes.sort()
@@ -925,7 +925,7 @@
         if num > 1:
             gran += "s"
         return "%i %s"%(num,  gran)
     elif has_minutes:
         if has_hours:
             hours.sort()
@@ -948,7 +948,7 @@
         if num > 1:
             gran += "s"
     elif has_hours:
         if has_days:
             days.sort()
@@ -995,15 +995,15 @@
         if num > 1:
             gran += "s"
     elif has_years:
         num = gcd_list(years)
         gran = "year"
         if num > 1:
             gran += "s"
 # http://akiscode.com/articles/gcd_of_a_list.shtml
 # Copyright (c) 2010 Stephen Akiki
Modified: grass/trunk/lib/python/temporal/temporal_operator.py
--- grass/trunk/lib/python/temporal/temporal_operator.py	2016-03-29 08:10:14 UTC (rev 68181)
+++ grass/trunk/lib/python/temporal/temporal_operator.py	2016-03-29 09:23:26 UTC (rev 68182)
@@ -14,96 +14,95 @@
     >>> expression =  "{equal| during}"
     >>> p.parse(expression, optype = 'relation')
-    >>> print((p.relations, p.temporal, p.function))
+    >>> print(p.relations, p.temporal, p.function)
     (['equal', 'during'], None, None)
-    >>> p = TemporalOperatorParser()
+    >>> p = TemporalOperatorParser()
     >>> expression =  "{contains | starts}"
     >>> p.parse(expression)
     (['contains', 'starts'], None, None)
     >>> expression =  "{&&, during}"
     >>> p.parse(expression, optype = 'boolean')
-    >>> print((p.relations, p.temporal, p.function,p.aggregate))
+    >>> print(p.relations, p.temporal, p.function,p.aggregate)
     (['during'], 'l', '&&', '&')
     >>> expression =  "{||, equal | during}"
     (['equal', 'during'], 'l', '||', '|')
     >>> expression =  "{||, equal | during, &}"
     (['equal', 'during'], 'l', '||', '&')
     >>> expression =  "{&&, during, |}"
     (['during'], 'l', '&&', '|')
     >>> expression =  "{&&, during, |, r}"
     (['during'], 'r', '&&', '|')
     >>> expression =  "{&&, during, u}"
     (['during'], 'u', '&&', '&')
     >>> expression =  "{:, during, r}"
     >>> p.parse(expression, optype = 'select')
     (['during'], 'r', ':')
     >>> expression =  "{!:, equal | contains, d}"
     (['equal', 'contains'], 'd', '!:')
     >>> expression =  "{#, during, r}"
     >>> p.parse(expression, optype = 'hash')
     (['during'], 'r', '#')
     >>> expression =  "{#, equal | contains}"
     (['equal', 'contains'], 'l', '#')
     >>> expression =  "{+, during, r}"
     >>> p.parse(expression, optype = 'raster')
     (['during'], 'r', '+')
     >>> expression =  "{/, equal | contains}"
     (['equal', 'contains'], 'l', '/')
     >>> expression =  "{+, equal | contains,intersect}"
     (['equal', 'contains'], 'i', '+')
     >>> expression =  "{*, contains,disjoint}"
     (['contains'], 'd', '*')
     >>> expression =  "{~, equal,left}"
     >>> p.parse(expression, optype = 'overlay')
     (['equal'], 'l', '~')
     >>> expression =  "{^, over,right}"
     (['overlaps', 'overlapped'], 'r', '^')
 try:
@@ -135,7 +134,7 @@
         'COMMA',
         'LEFTREF',
         'RIGHTREF',
-        'UNION',
+        'UNION',
         'DISJOINT',
         'INTERSECT',
         'HASH',
@@ -143,11 +142,11 @@
         'AND',
         'DISOR',
         'XOR',
-        'NOT',
+        'NOT',
         'MOD',
         'DIV',
         'MULT',
-        'ADD',
+        'ADD',
         'SUB',
         'T_SELECT',
         'T_NOT_SELECT',
@@ -172,7 +171,7 @@
     t_AND                        = r'[&]'
     t_DISOR                     = r'\+'
     t_XOR                         = r'\^'
-    t_NOT                         = r'\~'
+    t_NOT                         = r'\~'
     t_MOD                       = r'[\%]'
     t_DIV                         = r'[\/]'
     t_MULT                      = r'[\*]'
@@ -235,7 +234,7 @@
         while True:
              if not tok: break
-             print(tok)
+             print tok
@@ -252,19 +251,19 @@
         self.aggregate = None
     def parse(self, expression,  optype = 'relation'):
-        self.optype = optype
+        self.optype = optype
         self.parser.parse(expression)
-        # The parameter optype can be of type: select {:, during, r}, boolean{&&, contains, |},
+        # The parameter optype can be of type: select {:, during, r}, boolean{&&, contains, |},
         #                                                            raster{*, equal, |}, vector {|, starts, &},
         #                                                            hash{#, during, l} or relation {during}.
     # Error rule for syntax errors.
         raise SyntaxError("Unexpected syntax error")
     # Get the tokens from the lexer class
     tokens = TemporalOperatorLexer.tokens
     def p_relation_operator(self, t):
         # The expression should always return a list of maps.
@@ -295,7 +294,7 @@
         if not self.optype == 'boolean':
             raise SyntaxError("invalid syntax")
-        else:
+        else:
             # Set three operator components.
             if isinstance(t[5], list):
                 self.relations = t[5]
@@ -304,7 +303,7 @@
             self.temporal  = "l"
             self.function  = t[2] + t[3]
             self.aggregate = t[2]
             t[0] = t[2]
     def p_relation_bool_combi_operator(self, t):
@@ -321,7 +320,7 @@
-        else:
+        else:
@@ -330,7 +329,7 @@
             self.temporal  = "l"
             self.aggregate = t[7]
             t[0] = t[2]
     def p_relation_bool_combi_operator2(self, t):
@@ -343,7 +342,7 @@
-        else:
+        else:
@@ -352,9 +351,9 @@
             self.temporal  = t[7]
             t[0] = t[2]
     def p_relation_bool_combi_operator3(self, t):
@@ -369,7 +368,7 @@
-        else:
+        else:
@@ -378,9 +377,9 @@
             self.temporal  = t[9]
             t[0] = t[2]
     def p_select_relation_operator(self, t):
@@ -613,3 +612,4 @@
 if __name__ == "__main__":
     import doctest
     doctest.testmod()
Modified: grass/trunk/lib/python/temporal/temporal_raster3d_algebra.py
--- grass/trunk/lib/python/temporal/temporal_raster3d_algebra.py	2016-03-29 08:10:14 UTC (rev 68181)
+++ grass/trunk/lib/python/temporal/temporal_raster3d_algebra.py	2016-03-29 09:23:26 UTC (rev 68182)
@@ -10,8 +10,10 @@
 :authors: Thomas Leppelt and Soeren Gebbert
-from .temporal_raster_base_algebra import *
+import grass.pygrass.modules as pygrass
+from temporal_raster_base_algebra import *
 class TemporalRaster3DAlgebraParser(TemporalRasterBaseAlgebraParser):
@@ -32,7 +34,7 @@
         while True:
             if not tok: break
             if tok.type == "STVDS" or tok.type == "STRDS" or tok.type == "STR3DS":
                 raise SyntaxError("Syntax error near '%s'" %(tok.type))
Modified: grass/trunk/lib/python/temporal/temporal_raster_algebra.py
--- grass/trunk/lib/python/temporal/temporal_raster_algebra.py	2016-03-29 08:10:14 UTC (rev 68181)
+++ grass/trunk/lib/python/temporal/temporal_raster_algebra.py	2016-03-29 09:23:26 UTC (rev 68182)
@@ -52,7 +52,7 @@
@@ -74,10 +74,10 @@
         while True:
             if not tok: break
         self.lexer = TemporalRasterAlgebraLexer()
         self.lexer.build()
         self.parser = yacc.yacc(module=self, debug=self.debug)
Modified: grass/trunk/lib/python/temporal/temporal_raster_base_algebra.py
--- grass/trunk/lib/python/temporal/temporal_raster_base_algebra.py	2016-03-29 08:10:14 UTC (rev 68181)
+++ grass/trunk/lib/python/temporal/temporal_raster_base_algebra.py	2016-03-29 09:23:26 UTC (rev 68182)
@@ -16,7 +16,7 @@
     >>> p.debug = True
     >>> expression =  'R = A {+,equal,l} B '
     >>> p.test(expression)
-    R = A {+,equal,l} B
+    R = A {+,equal,l} B
     LexToken(NAME,'R',1,0)
     LexToken(EQUALS,'=',1,2)
     LexToken(NAME,'A',1,4)
@@ -24,7 +24,7 @@
     LexToken(NAME,'B',1,18)
     >>> expression =  'R = A {*,equal|during,r} B '
     >>> p.test(expression)
-    R = A {*,equal|during,r} B
+    R = A {*,equal|during,r} B
@@ -32,7 +32,7 @@
     LexToken(NAME,'B',1,25)
     >>> expression =  'R = A {+,equal|during} B '
     >>> p.test(expression)
-    R = A {+,equal|during} B
+    R = A {+,equal|during} B
@@ -40,10 +40,10 @@
     LexToken(NAME,'B',1,23)
-from .temporal_operator import *
-from .temporal_algebra import *
+from temporal_operator import *
+from temporal_algebra import *
@@ -70,12 +70,12 @@
         'isnull'  : 'ISNULL',
         'isntnull': 'ISNTNULL',
         'null'    : 'NULL',
-        'exist'   : 'EXIST',
+        'exist'   : 'EXIST',
     # Functions that defines single maps with time stamp and without temporal extent.
     map_functions = {'map' : 'MAP'}
     # This is the list of token names.
     raster_tokens = (
         'MOD',
@@ -153,12 +153,12 @@
-                               compare_cmd = False,  compop = None, aggregate = None,
+                               compare_cmd = False,  compop = None, aggregate = None,
                                new = False,  convert = False,  operator_cmd = False):
           :param maplistA: List of maps.
           :param maplistB: List of maps.
@@ -174,11 +174,11 @@
           :param new: Boolean if new temporary maps should be created.
-          :param convert: Boolean if conditional values should be converted to
+          :param convert: Boolean if conditional values should be converted to
                         r.mapcalc command strings.
-          :param operator_cmd: Boolean for aggregate arithmetic operators implicitly
+          :param operator_cmd: Boolean for aggregate arithmetic operators implicitly
                         in command list values based on related map lists.
@@ -219,7 +219,7 @@
                 self.compare_cmd_value(map_i,  tbrelations, compop, aggregate, topolist, convert)
             elif operator_cmd:
                 self.operator_cmd_value(map_i,  tbrelations, compop, topolist)
                 if topo.upper() in tbrelations.keys():
                     if count_map:
@@ -233,30 +233,30 @@
-        return(resultlist)
+        return(resultlist)
     def build_command_string(self, map_i,  relmap, operator = None, cmd_type = None):
-        """This function build the r.mapcalc command string for conditionals,
+        """This function build the r.mapcalc command string for conditionals,
             spatial variable combinations and boolean comparisons.
             For Example: 'if(a1 == 1, b1, c2)' or 'exist(a1) && sin(b1)'
             :param map_i: map object with temporal extent and built relations.
             :param relmap: map object with defined temporal relation to map_i.
-            :param operator: String representing operator between two spatial variables
+            :param operator: String representing operator between two spatial variables
             :param cmd_type: map object with defined temporal relation to map_i:
                             condition, conclusion or operator.
-            :return: the resulting command string for conditionals or spatial variable
+            :return: the resulting command string for conditionals or spatial variable
                 combinations
         def sub_cmdstring(map_i):
-            """This function search for command string in a map object and
+            """This function search for command string in a map object and
             return substitute string (contained commandstring or map name)"""
             if "cmd_list" in dir(map_i):
                 map_sub = map_i.cmd_list
@@ -268,8 +268,8 @@
                 except:
                     map_sub = map_i
             return(map_sub)
-        # Check  for type of operation, conditional or spatial variable combination
+        # Check  for type of operation, conditional or spatial variable combination
         # and Create r.mapcalc expression string for the operation.
         cmdstring = ""
         if cmd_type == 'condition':
@@ -289,18 +289,18 @@
             cmdstring = "(%s %s %s)" %(leftsub, operator,  rightsub)
         return(cmdstring)
-    def compare_cmd_value(self,  map_i, tbrelations, compop, aggregate,
+    def compare_cmd_value(self,  map_i, tbrelations, compop, aggregate,
                                                 topolist = ["EQUAL"],  convert = False):
-            comparison operator. Extended temporal algebra version with command
+            comparison operator. Extended temporal algebra version with command
             list builder for temporal raster algebra.
@@ -315,7 +315,7 @@
             leftcmd = map_i.cmd_list
             cmd_value_list = [leftcmd]
         count = 0
                 relationmaplist = tbrelations[topo.upper()]
@@ -337,18 +337,18 @@
             cmd_value_str = ''.join(map(str, cmd_value_list))
             # Add command list to result map.
             map_i.cmd_list = cmd_value_str
             return(cmd_value_str)
     def operator_cmd_value(self,  map_i, tbrelations, operator, topolist = ["EQUAL"]):
         """ Function to evaluate two map lists by given arithmetic operator.
             :param operator: Arithmetic operator, +-*/%.
-            :return: Map object with command list with  operators that has been
+            :return: Map object with command list with  operators that has been
                         evaluated by implicit aggregration.
         # Build comandlist list with elements from related maps and given relation operator.
@@ -359,26 +359,26 @@
                 for relationmap in relationmaplist:
-                    cmdstring = self.build_command_string(leftcmd,
-        relationmap,
-        operator = operator,
+                    cmdstring = self.build_command_string(leftcmd,
+        relationmap,
+        operator = operator,
        cmd_type = "operator")
                     leftcmd = cmdstring
         map_i.cmd_list = cmdstring
         return(cmdstring)
-    def set_temporal_extent_list(self, maplist, topolist = ["EQUAL"], temporal = 'l' ,
+    def set_temporal_extent_list(self, maplist, topolist = ["EQUAL"], temporal = 'l' ,
                                                         cmd_bool = False, cmd_type = None,  operator = None):
                                         correctely.
             :param cmd_bool: Boolean if command string should be merged for related maps.
@@ -388,26 +388,26 @@
             :return: Map list with specified temporal extent and optional command string.
         resultdict = {}
                 if topo in tbrelations.keys():
                         if temporal == 'r':
        temp_op = temporal)
                         # Stop the loop if no temporal or spatial relationship exist.
                         if returncode == 0:
                             break
@@ -417,9 +417,9 @@
                             if cmd_bool:
-                                cmdstring = self.build_command_string(map_i,
-        map_j,
+                                cmdstring = self.build_command_string(map_i,
+        map_j,
        cmd_type = cmd_type)
@@ -433,12 +433,12 @@
         return(resultlist)
-    def build_condition_cmd_list(self, iflist, thenlist,  elselist = None,
-                                                        condition_topolist = ["EQUAL"],
-                                                        conclusion_topolist = ["EQUAL"],
+    def build_condition_cmd_list(self, iflist, thenlist,  elselist = None,
+                                                        condition_topolist = ["EQUAL"],
+                                                        conclusion_topolist = ["EQUAL"],
                                                         temporal = 'l', null = False):
         """This function build the r.mapcalc command strings for spatial conditionals.
@@ -446,52 +446,52 @@
             :param iflist: Map list with temporal extents and command list.
             :param thenlist: Map list with temporal extents and command list or numeric string.
             :param elselist: Map list with temporal extents and command list or numeric string.
-            :param condition_topolist: List of strings for given temporal relations between
+            :param condition_topolist: List of strings for given temporal relations between
                             conditions and conclusions.
-            :param conclusion_topolist: List of strings for given temporal relations between
+            :param conclusion_topolist: List of strings for given temporal relations between
                             conditions (then and else).
             :param null: Boolean if null map support should be activated.
             :return: map list with resulting command string for given condition type.
         resultlist = []
         # First merge conclusion command maplists or strings.
         # Check if alternative conclusion map list is given.
         if all([isinstance(thenlist, list), isinstance(elselist, list)]):
             # Build conclusion command map list.
             conclusiontopolist = self.get_temporal_topo_list(thenlist, elselist,  conclusion_topolist)
-            conclusionlist = self.set_temporal_extent_list(conclusiontopolist,
-        topolist = conclusion_topolist,
-        temporal = temporal ,
-        cmd_bool = True,
+            conclusionlist = self.set_temporal_extent_list(conclusiontopolist,
+        topolist = conclusion_topolist,
+        temporal = temporal ,
+        cmd_bool = True,
        cmd_type = "conclusion")
         # Check if any conclusion is a numeric statements.
         elif any([isinstance(thenlist, str), isinstance(elselist, str)]):
-            conclusionlist = []
+            conclusionlist = []
             # Check if only alternative conclusion is a numeric statements.
             if all([isinstance(thenlist, list), isinstance(elselist, str)]):
                 listinput = thenlist
                 numinput = elselist
                 for map_i in listinput:
-                    cmdstring = self.build_command_string( map_i,
-        numinput,
+                    cmdstring = self.build_command_string( map_i,
+        numinput,
        cmd_type = 'conclusion')
                     # Append map to result map list.
                     conclusionlist.append(map_i)
             # Check if only direct conclusion is a numeric statements.
-            elif all([isinstance(thenlist, str), isinstance(elselist, list)]):
+            elif all([isinstance(thenlist, str), isinstance(elselist, list)]):
                 listinput = elselist
                 numinput =  thenlist
-                    cmdstring = self.build_command_string(numinput,
-        map_i,
+                    cmdstring = self.build_command_string(numinput,
+        map_i,
@@ -502,14 +502,14 @@
         else:
             # The direct conclusion is used.
             conclusionlist = thenlist
-        # Use the conclusion map or string to merge it with the condition and
+        # Use the conclusion map or string to merge it with the condition and
         # return maplist.
         if isinstance(conclusionlist,  str):
             resultlist = []
             for map_i in iflist:
-        conclusionlist,
+        conclusionlist,
        cmd_type = 'condition')
@@ -518,12 +518,12 @@
             return(resultlist)
         elif isinstance(conclusionlist,  list):
             # Build result command map list between conditions and conclusions.
-            conditiontopolist = self.get_temporal_topo_list(iflist, conclusionlist,
+            conditiontopolist = self.get_temporal_topo_list(iflist, conclusionlist,
        topolist = condition_topolist)
-            resultlist = self.set_temporal_extent_list(conditiontopolist,
-        topolist = condition_topolist,
-        temporal = 'r' ,
-        cmd_bool = True,
+            resultlist = self.set_temporal_extent_list(conditiontopolist,
+        topolist = condition_topolist,
+        temporal = 'r' ,
+        cmd_bool = True,
        cmd_type = "condition")
             return(resultlist)
@@ -570,21 +570,21 @@
                         m.inputs["expression"].value = str(m_expression)
                         m.flags["overwrite"].value = self.overwrite
                         process_queue.put(m)
                     elif map_i.map_exists():
                         # Copy map if it exists
                         map_test = map_i.get_new_instance(newident + "@" + self.mapset)
                         map_test.set_temporal_extent(map_i.get_temporal_extent())
                         map_test.set_spatial_extent(map_i.get_spatial_extent())
                         map_test_list.append(map_test)
                         m = copy.deepcopy(self.m_mapcalc)
                         m_expression = newident + "=" + map_i.get_map_id()
                     else:
                         self.msgr.error(_("Error computing map <%s>"%(map_i.get_id()) ))
                     count  += 1
@@ -629,13 +629,13 @@
                 t[0] = register_list
                 self.remove_maps()
     def p_expr_spmap_function(self, t):
         # Add a single map.
         # Examples:
-        #    R = map(A)
+        #    R = map(A)
         mapexpr : MAP LPAREN stds RPAREN
@@ -666,7 +666,7 @@
             t[0] = "map(" + t[3] + ")"
         if self.debug:
-            print("map(" + t[3] + ")")
+            print "map(" + t[3] + ")"
     def p_arith1_operation(self, t):
@@ -692,7 +692,7 @@
         # Check input stds.
         maplistA = self.check_stds(t[1])
         maplistB = self.check_stds(t[3])
         topolist = self.get_temporal_topo_list(maplistA, maplistB)
         if self.run:
@@ -718,8 +718,8 @@
                         name = self.generate_map_name()
-                    cmdstring = self.build_command_string(map_i, map_j,
-        operator = t[2],
+                    cmdstring = self.build_command_string(map_i, map_j,
+        operator = t[2],
@@ -732,7 +732,7 @@
         if self.debug:
-                print(map.cmd_list)
+                print map.cmd_list
     def p_arith1_operation_numeric1(self, t):
@@ -747,13 +747,13 @@
             | stds DIV numberstr
             | expr DIV numberstr
             | stds MULT numberstr
-            | expr MULT numberstr
+            | expr MULT numberstr
             | stds MOD mapexpr
             | expr MOD mapexpr
             | stds DIV mapexpr
             | expr DIV mapexpr
             | stds MULT mapexpr
-            | expr MULT mapexpr
+            | expr MULT mapexpr
         # Check input stds.
         maplist = self.check_stds(t[1])
@@ -776,7 +776,7 @@
         if self.debug:
     def p_arith1_operation_numeric2(self, t):
@@ -792,13 +792,13 @@
             | numberstr DIV stds
             | numberstr DIV expr
             | numberstr MULT stds
-            | numberstr MULT expr
+            | numberstr MULT expr
             | mapexpr MOD stds
             | mapexpr MOD expr
             | mapexpr DIV stds
             | mapexpr DIV expr
             | mapexpr MULT stds
-            | mapexpr MULT expr
+            | mapexpr MULT expr
         # Check input stds.
         maplist = self.check_stds(t[3])
@@ -821,7 +821,7 @@
         if self.debug:
     def p_arith2_operation(self, t):
@@ -867,10 +867,10 @@
                     else:
-        operator = t[2],
+        operator = t[2],
@@ -884,7 +884,7 @@
         if self.debug:
     def p_arith2_operation_numeric1(self, t):
@@ -895,7 +895,7 @@
             | stds ADD numberstr
             | expr ADD numberstr
             | stds SUB numberstr
-            | expr SUB numberstr
+            | expr SUB numberstr
             | stds ADD mapexpr
             | expr ADD mapexpr
             | stds SUB mapexpr
@@ -922,7 +922,7 @@
         if self.debug:
     def p_arith2_operation_numeric2(self, t):
@@ -932,12 +932,12 @@
             | number SUB expr
             | numberstr ADD stds
             | numberstr ADD expr
-            | numberstr SUB stds
-            | numberstr SUB expr
+            | numberstr SUB stds
+            | numberstr SUB expr
             | mapexpr ADD stds
             | mapexpr ADD expr
             | mapexpr SUB stds
-            | mapexpr SUB expr
+            | mapexpr SUB expr
         # Check input stds.
@@ -960,7 +960,7 @@
         if self.debug:
     def p_arith1_operation_relation(self, t):
@@ -971,7 +971,7 @@
              | stds T_ARITH1_OPERATOR t_td_var
              | expr T_ARITH1_OPERATOR t_td_var
-        if self.run:
+        if self.run:
             # Check input stds.
@@ -980,14 +980,14 @@
             complist = self.get_temporal_topo_list(maplistA, maplistB, topolist = relations,
                                operator_cmd = True, compop = function)
+        t[0] = resultlist
-        t[0] = resultlist
         if self.debug:
     def p_arith2_operation_relation(self, t):
@@ -998,7 +998,7 @@
              | stds T_ARITH2_OPERATOR t_td_var
              | expr T_ARITH2_OPERATOR t_td_var
-        if self.run:
+        if self.run:
             # Check input stds.
@@ -1007,14 +1007,14 @@
         t[0] = resultlist
         if self.debug:
     def p_arith_operation_numeric_string(self, t):
@@ -1030,7 +1030,7 @@
         if self.debug:
             print(numstring)
     def p_mapcalc_function(self, t):
         # Supported mapcalc functions.
@@ -1051,7 +1051,7 @@
         if self.debug:
     def p_mapcalc_operation1(self, t):
@@ -1082,7 +1082,7 @@
         if self.debug:
     def p_mapexpr_operation(self, t):
         # Examples:
@@ -1099,7 +1099,7 @@
             t[0] = cmdstring
         if self.debug:
-            print(mapstring)
+            print mapstring
     def p_s_var_expr_1(self, t):
         # Examples:
@@ -1128,7 +1128,7 @@
         if self.debug:
     def p_s_var_expr_2(self, t):
         # Examples:
@@ -1157,7 +1157,7 @@
         if self.debug:
     def p_s_var_expr_3(self, t):
         # Examples:
@@ -1186,7 +1186,7 @@
         if self.debug:
     def p_s_var_expr_4(self, t):
         # Examples:
@@ -1215,8 +1215,8 @@
         if self.debug:
     def p_s_var_expr_comp(self, t):
         # Examples:
         #   A <= 2 || B == 10
@@ -1224,7 +1224,7 @@
         s_var_expr : s_var_expr AND AND s_var_expr
                    | s_var_expr OR OR s_var_expr
         if self.run:
             # Check input stds.
             s_var_exprA = self.check_stds(t[1])
@@ -1233,18 +1233,18 @@
             temporal = "l"
             aggregate = t[2]
             complist = self.get_temporal_topo_list(s_var_exprA, s_var_exprB, topolist = relations,
                                compare_cmd = True, compop = function, aggregate = aggregate)
             t[0] = resultlist
         if self.debug:
     def p_s_var_expr_comp_op(self, t):
         # Examples:
@@ -1263,14 +1263,14 @@
             t[0] = resultlist
         if self.debug:
     def p_s_expr_condition_if(self, t):
         # Examples:
@@ -1284,16 +1284,16 @@
         ifmaplist = self.check_stds(t[3])
         thenmaplist = self.check_stds(t[5])
-        resultlist = self.build_condition_cmd_list(ifmaplist, thenmaplist,
-        elselist = None,
+        resultlist = self.build_condition_cmd_list(ifmaplist, thenmaplist,
+        elselist = None,
        temporal = 'r', null = False)
         t[0] = resultlist
         if self.debug:
     def p_s_numeric_condition_if(self, t):
         # Examples:
@@ -1325,7 +1325,7 @@
         if self.debug:
     def p_s_expr_condition_if_relation(self, t):
         # Examples:
@@ -1336,20 +1336,20 @@
              | IF LPAREN T_REL_OPERATOR COMMA ts_var_expr COMMA stds RPAREN
              | IF LPAREN T_REL_OPERATOR COMMA ts_var_expr COMMA expr RPAREN
-        relations, temporal, function,  aggregation = self.eval_toperator(t[3],
+        relations, temporal, function,  aggregation = self.eval_toperator(t[3],
         ifmaplist = self.check_stds(t[5])
         thenmaplist = self.check_stds(t[7])
-        elselist = None,
-        condition_topolist = relations,
+        elselist = None,
+        condition_topolist = relations,
         t[0] = resultlist
         if self.debug:
     def p_s_expr_condition_elif(self, t):
         # Examples:
@@ -1369,17 +1369,17 @@
         elsemaplist = self.check_stds(t[7])
         # Create conditional command map list.
-        elselist = elsemaplist,
+        elselist = elsemaplist,
         t[0] = resultlist
         if self.debug:
     def p_s_numeric_condition_elif(self, t):
         # Examples:
@@ -1393,7 +1393,7 @@
              | IF LPAREN ts_var_expr COMMA number COMMA number RPAREN
              | IF LPAREN ts_var_expr COMMA NULL LPAREN RPAREN COMMA number RPAREN
              | IF LPAREN ts_var_expr COMMA number COMMA NULL LPAREN RPAREN RPAREN
-             | IF LPAREN ts_var_expr COMMA NULL LPAREN RPAREN COMMA NULL LPAREN RPAREN RPAREN
+             | IF LPAREN ts_var_expr COMMA NULL LPAREN RPAREN COMMA NULL LPAREN RPAREN RPAREN
         resultlist = []
@@ -1414,16 +1414,16 @@
         numelse = str(numelse)
         print(numthen + " " +numelse )
-        resultlist = self.build_condition_cmd_list(ifmaplist, numthen,  numelse,
+        resultlist = self.build_condition_cmd_list(ifmaplist, numthen,  numelse,
         t[0] = resultlist
         if self.debug:
     def p_s_numeric_expr_condition_elif(self, t):
         # Examples:
@@ -1445,7 +1445,7 @@
              | IF LPAREN ts_var_expr COMMA stds COMMA number RPAREN
              | IF LPAREN ts_var_expr COMMA stds COMMA NULL LPAREN RPAREN RPAREN
              | IF LPAREN ts_var_expr COMMA expr COMMA number RPAREN
-             | IF LPAREN ts_var_expr COMMA expr COMMA NULL LPAREN RPAREN RPAREN
+             | IF LPAREN ts_var_expr COMMA expr COMMA NULL LPAREN RPAREN RPAREN
         # Select input for r.mapcalc expression based on length of PLY object.
@@ -1465,16 +1465,16 @@
                 elseinput = str(t[7] + t[8] + t[9])
-        resultlist = self.build_condition_cmd_list(ifmaplist, theninput,  elseinput,
+        resultlist = self.build_condition_cmd_list(ifmaplist, theninput,  elseinput,
         t[0] = resultlist
         if self.debug:
     def p_s_numeric_expr_condition_elif_relation(self, t):
         # Examples:
@@ -1496,7 +1496,7 @@
              | IF LPAREN T_REL_OPERATOR COMMA ts_var_expr COMMA stds COMMA number RPAREN
              | IF LPAREN T_REL_OPERATOR COMMA ts_var_expr COMMA stds COMMA NULL LPAREN RPAREN RPAREN
              | IF LPAREN T_REL_OPERATOR COMMA ts_var_expr COMMA expr COMMA number RPAREN
-             | IF LPAREN T_REL_OPERATOR COMMA ts_var_expr COMMA expr COMMA NULL LPAREN RPAREN RPAREN
+             | IF LPAREN T_REL_OPERATOR COMMA ts_var_expr COMMA expr COMMA NULL LPAREN RPAREN RPAREN
         relations, temporal, function,  aggregation = self.eval_toperator(t[3],  optype = 'relation')
@@ -1517,16 +1517,16 @@
                 elseinput = str(t[9] + t[10] + t[11])
         t[0] = resultlist
         if self.debug:
     def p_s_expr_condition_elif_relation(self, t):
@@ -1546,18 +1546,18 @@
         elsemaplist = self.check_stds(t[9])
-        resultlist = self.build_condition_cmd_list(ifmaplist, thenmaplist,  elsemaplist,
+        resultlist = self.build_condition_cmd_list(ifmaplist, thenmaplist,  elsemaplist,
         t[0] = resultlist
         if self.debug:
     def p_ts_var_expr1(self, t):
         # Combination of spatial and temporal conditional expressions.
@@ -1588,19 +1588,19 @@
             temporal = "l"
             aggregate = t[2]
-            complist = self.get_temporal_topo_list(s_var_exprA, s_var_exprB,
-        topolist = relations, compare_cmd = True,
-        compop = function, aggregate = aggregate,
+            complist = self.get_temporal_topo_list(s_var_exprA, s_var_exprB,
+        topolist = relations, compare_cmd = True,
+        compop = function, aggregate = aggregate,
        convert = True)
         t[0] = resultlist
     def p_hash_operation(self, t):
-        # Calculate the number of maps within an interval of another map from a
+        # Calculate the number of maps within an interval of another map from a
         # second space time dataset.
         # A # B
         # A {equal,r#} B
@@ -1628,7 +1628,7 @@
         if self.debug:
Modified: grass/trunk/lib/python/temporal/temporal_topology_dataset_connector.py
--- grass/trunk/lib/python/temporal/temporal_topology_dataset_connector.py	2016-03-29 08:10:14 UTC (rev 68181)
+++ grass/trunk/lib/python/temporal/temporal_topology_dataset_connector.py	2016-03-29 09:23:26 UTC (rev 68182)
@@ -16,7 +16,6 @@
 import copy
@@ -105,7 +104,7 @@
             finished=a at P
             >>> rlist = tmr.get_temporal_relations()
             >>> if "FINISHED" in rlist.keys():
-            ...    print(rlist["FINISHED"][0].get_id())
+            ...    print rlist["FINISHED"][0].get_id()
             a at P
@@ -504,85 +503,85 @@
     def print_temporal_topology_info(self):
         """Print information about this class in human readable style"""
-        print(" +-------------------- Temporal Topology -------------------------------------+")
+        print " +-------------------- Temporal Topology -------------------------------------+"
         if self.next() is not None:
-            print(" | Next: ...................... " + str(self.next().get_id()))
+            print " | Next: ...................... " + str(self.next().get_id())
         if self.prev() is not None:
-            print(" | Previous: .................. " + str(self.prev().get_id()))
+            print " | Previous: .................. " + str(self.prev().get_id())
         if self.equal is not None:
-            print(" | Equal:...................... " +
-                  self._generate_map_list_string(self.equal))
+            print " | Equal:...................... " + \
+                self._generate_map_list_string(self.equal)
         if self.follows is not None:
-            print(" | Follows: ................... " +
-                  self._generate_map_list_string(self.follows))
+            print " | Follows: ................... " + \
+                self._generate_map_list_string(self.follows)
         if self.precedes is not None:
-            print(" | Precedes: .................. " +
-                  self._generate_map_list_string(self.precedes))
+            print " | Precedes: .................. " + \
+                self._generate_map_list_string(self.precedes)
         if self.overlaps is not None:
-            print(" | Overlaps: .................. " +
-                  self._generate_map_list_string(self.overlaps))
+            print " | Overlaps: .................. " + \
+                self._generate_map_list_string(self.overlaps)
         if self.overlapped is not None:
-            print(" | Overlapped: ................ " +
-                  self._generate_map_list_string(self.overlapped))
+            print " | Overlapped: ................ " + \
+                self._generate_map_list_string(self.overlapped)
         if self.during is not None:
-            print(" | During: .................... " +
-                  self._generate_map_list_string(self.during))
+            print " | During: .................... " + \
+                self._generate_map_list_string(self.during)
         if self.contains is not None:
-            print(" | Contains: .................. " +
-                  self._generate_map_list_string(self.contains))
+            print " | Contains: .................. " + \
+                self._generate_map_list_string(self.contains)
         if self.starts is not None:
-            print(" | Starts:.. .................. " +
-                  self._generate_map_list_string(self.starts))
+            print " | Starts:.. .................. " + \
+                self._generate_map_list_string(self.starts)
         if self.started is not None:
-            print(" | Started:. .................. " +
-                  self._generate_map_list_string(self.started))
+            print " | Started:. .................. " + \
+                self._generate_map_list_string(self.started)
         if self.finishes is not None:
-            print(" | Finishes:................... " +
-                  self._generate_map_list_string(self.finishes))
+            print " | Finishes:................... " + \
+                self._generate_map_list_string(self.finishes)
         if self.finished is not None:
-            print(" | Finished:................... " +
-                  self._generate_map_list_string(self.finished))
+            print " | Finished:................... " + \
+                self._generate_map_list_string(self.finished)
     def print_temporal_topology_shell_info(self):
-            print("next=" + self.next().get_id())
+            print "next=" + self.next().get_id()
-            print("prev=" + self.prev().get_id())
+            print "prev=" + self.prev().get_id()
-            print("equal=" + self._generate_map_list_string(self.equal, False))
+            print "equal=" + self._generate_map_list_string(self.equal, False)
-            print("follows=" + self._generate_map_list_string(self.follows,
-                                                              False))
+            print "follows=" + self._generate_map_list_string(self.follows,
+                                                              False)
-            print("precedes=" + self._generate_map_list_string(
-                  self.precedes, False))
+            print "precedes=" + self._generate_map_list_string(
+                self.precedes, False)
-            print("overlaps=" + self._generate_map_list_string(
-                  self.overlaps, False))
+            print "overlaps=" + self._generate_map_list_string(
+                self.overlaps, False)
-            print("overlapped=" +
-                  self._generate_map_list_string(self.overlapped, False))
+            print "overlapped=" + \
+                self._generate_map_list_string(self.overlapped, False)
-            print("during=" + self._generate_map_list_string(self.during,
-                                                             False))
+            print "during=" + self._generate_map_list_string(self.during,
+                                                             False)
-            print("contains=" + self._generate_map_list_string(
-                  self.contains, False))
+            print "contains=" + self._generate_map_list_string(
+                self.contains, False)
-            print("starts=" +
+            print "starts=" + \
-            print("started=" +
+            print "started=" + \
-            print("finishes=" +
+            print "finishes=" + \
-            print("finished=" +
+            print "finished=" + \
Modified: grass/trunk/lib/python/temporal/temporal_vector_algebra.py
--- grass/trunk/lib/python/temporal/temporal_vector_algebra.py	2016-03-29 08:10:14 UTC (rev 68181)
+++ grass/trunk/lib/python/temporal/temporal_vector_algebra.py	2016-03-29 09:23:26 UTC (rev 68182)
@@ -41,10 +41,10 @@
     LexToken(RPAREN,')',1,16)
@@ -129,7 +129,7 @@
         while True:
             if not tok: break
@@ -149,12 +149,12 @@
                                new = False,  convert = False,  overlay_cmd = False):
@@ -170,11 +170,11 @@
-          :param overlay_cmd: Boolean for aggregate overlay operators implicitly
+          :param overlay_cmd: Boolean for aggregate overlay operators implicitly
@@ -215,7 +215,7 @@
             elif overlay_cmd:
                 self.overlay_cmd_value(map_i,  tbrelations, compop, topolist)
                     if count_map:
@@ -229,21 +229,21 @@
         return(resultlist)
     def overlay_cmd_value(self,  map_i, tbrelations, function, topolist = ["EQUAL"]):
         """ Function to evaluate two map lists by given overlay operator.
           :param function: Overlay operator, &|+^~.
@@ -292,30 +292,30 @@
                     mapainput = name
         map_i.cmd_list = resultlist
         return(resultlist)
                                         correctely.
         resultdict = {}
-        copy = True,  rename = False,
+        copy = True,  rename = False,
        remove = True)
@@ -323,8 +323,8 @@
                         if temporal == 'r':
        remove = True)
@@ -344,9 +344,9 @@
         return(resultlist)
     def p_statement_assign(self, t):
@@ -427,7 +427,7 @@
                             count += 1
                             register_list.append(map_i)
                     else:
                         # relation operators (i|r). This is a code copy from temporal_algebra.py
                         map_i_extent = map_i.get_temporal_extent_as_tuple()
                         map_test = map_i.get_new_instance(map_i.get_id())
@@ -483,11 +483,11 @@
                             # Map is original from an input STVDS
                             map_i.load()
                         # Register map in result space time dataset.
-                        print(map_i.get_temporal_extent_as_tuple())
+                        print map_i.get_temporal_extent_as_tuple()
                         success = resultstds.register_map(map_i, dbif=dbif)
                     resultstds.update_from_registered_maps(dbif)
-            # Remove intermediate maps
+            # Remove intermediate maps
             self.remove_maps()
             if connected:
                 dbif.close()
@@ -521,13 +521,13 @@
-            temporal = 'l'
-            function = t[2]
+            temporal = 'l'
+            function = t[2]
             # Build commmand list for related maps.
        compop = function, overlay_cmd = True)
             t[0] = resultlist
@@ -550,9 +550,9 @@
             t[0] = resultlist
         if self.debug:
             str(t[1]) + t[2] + str(t[3])
Modified: grass/trunk/lib/python/temporal/univar_statistics.py
--- grass/trunk/lib/python/temporal/univar_statistics.py	2016-03-29 08:10:14 UTC (rev 68181)
+++ grass/trunk/lib/python/temporal/univar_statistics.py	2016-03-29 09:23:26 UTC (rev 68182)
@@ -18,9 +18,8 @@
-from .open_stds import *
+from open_stds import *
 import grass.script as gscript
@@ -72,7 +71,7 @@
             string += "third_quartile" + fs + "percentile_90"
         if output is None:
-            print(string)
+            print string
         else:
             out_file.write(string + "\n")
@@ -114,7 +113,7 @@
             string += fs + str(stats["third_quartile"]) + fs + str(stats["percentile_90"])
         if output is None:
-            print(string)
+            print string
         else:
@@ -192,7 +191,7 @@
         if output is None:
-            print(string)
+            print string
         else:
@@ -255,7 +254,7 @@
                     string += fs + fs + fs + fs
         if output is None:
-            print(string)
+            print string
         else:
