[GRASS-SVN] r68183 - grass/trunk/lib/python/script/testsuite
svn_grass at osgeo.org
Tue Mar 29 06:45:52 PDT 2016
Author: zarch
Date: 2016-03-29 06:45:51 -0700 (Tue, 29 Mar 2016)
New Revision: 68183
grass/trunk/lib/python/script/testsuite/test_utils.py
script.utils: change tests to avoid decorator
Modified: grass/trunk/lib/python/script/testsuite/test_utils.py
--- grass/trunk/lib/python/script/testsuite/test_utils.py 2016-03-29 09:23:26 UTC (rev 68182)
+++ grass/trunk/lib/python/script/testsuite/test_utils.py 2016-03-29 13:45:51 UTC (rev 68183)
@@ -7,30 +7,29 @@
from grass.script import utils
-def change_environ(**envs):
+class EnvironChange(TestCase):
+ env = dict()
NOT_FOUND = 'Not found!'
- original_envs = {k: os.environ.get(k, NOT_FOUND) for k in envs.keys()}
- def work_with_env(func):
- def wrap_func(*args, **kwargs):
- # modify the environment variables
- for k, v in envs.items():
+ def setUp(self):
+ self.original_env = {k: os.environ.get(k, self.NOT_FOUND)
+ for k in self.env.keys()}
+ for k, v in self.env.items():
os.environ[k] = v
- # execute
- func(*args, **kwargs)
- # restore the environment variables
- oval = original_envs[k]
- if oval == NOT_FOUND:
+ def tearDown(self):
+ oval = self.original_env[k]
+ if oval == self.NOT_FOUND:
os.environ.pop(k)
else:
os.environ[k] = oval
- return wrap_func
- return work_with_env
+class LcAllC(EnvironChange):
+ env = dict(LC_ALL='C')
class TestEncode(TestCase):
"""Tests function `encode` that convert value to bytes."""
@@ -40,15 +39,7 @@
def test_unicode(self):
self.assertEqual(b'text', utils.encode(u'text'))
- @change_environ(LC_ALL='C')
- def test_bytes_LC_ALL_C(self):
- self.assertEqual(b'text', utils.encode(b'text'))
- def test_unicode_LC_ALL_C(self):
- self.assertEqual(b'text', utils.encode(u'text'))
class TestDecode(TestCase):
"""Tests function `encode` that convert value to unicode."""
@@ -58,16 +49,14 @@
self.assertEqual(u'text', utils.decode(u'text'))
- self.assertEqual(u'text', utils.decode(b'text'))
- self.assertEqual(u'text', utils.decode(u'text'))
+class TestEncodeLcAllC(TestEncode, LcAllC):
+ pass
+class TestDecodeLcAllC(TestDecode, LcAllC):
+ pass
if __name__ == '__main__':
- test()
\ No newline at end of file
+ test()
