[GRASS-SVN] r68476 - in grass/trunk/vector: v.in.lidar v.in.pdal
svn_grass at osgeo.org
Fri May 20 07:54:35 PDT 2016
Author: wenzeslaus
Date: 2016-05-20 07:54:35 -0700 (Fri, 20 May 2016)
New Revision: 68476
grass/trunk/vector/v.in.lidar/main.c
grass/trunk/vector/v.in.pdal/main.cpp
v.in.lidar, v.in.pdal: add -c to not store unique cat for each point
No default and explicit flag works better in GUI forms
which do not allow passing nothing when there is a default answer.
The command line is also better as it requires -c or id_layer
when other layer options are used.
It also checks if two layer options are set to
the same numbers and fatals if they are
(allowed in GRASS but does not make sense here).
Verbose message when unique category is stored
for each point.
Modified: grass/trunk/vector/v.in.lidar/main.c
--- grass/trunk/vector/v.in.lidar/main.c 2016-05-20 11:28:00 UTC (rev 68475)
+++ grass/trunk/vector/v.in.lidar/main.c 2016-05-20 14:54:35 UTC (rev 68476)
@@ -40,7 +40,34 @@
# define MAX(a,b) ((a>b) ? a : b)
#endif
+static void check_layers_not_equal(int primary, int secondary,
+ const char *primary_name,
+ const char *secondary_name)
+ if (primary && primary == secondary)
+ G_fatal_error(_("Values of %s and %s are the same."
+ " All categories would be stored only"
+ " in layer number <%d>"), primary_name,
+ secondary_name, primary);
+static void check_layers_in_list_not_equal(struct Option **options,
+ int *values, size_t size)
+ size_t layer_index_1, layer_index_2;
+ for (layer_index_1 = 0; layer_index_1 < size; layer_index_1++) {
+ for (layer_index_2 = 0; layer_index_2 < size; layer_index_2++) {
+ if (layer_index_1 != layer_index_2) {
+ check_layers_not_equal(values[layer_index_1],
+ values[layer_index_2],
+ options[layer_index_1]->key,
+ options[layer_index_2]->key);
int main(int argc, char *argv[])
int i;
@@ -55,6 +82,7 @@
struct Option *skip_opt, *preserve_opt, *offset_opt, *limit_opt;
struct Option *outloc_opt, *zrange_opt;
struct Flag *print_flag, *notab_flag, *region_flag, *notopo_flag;
+ struct Flag *nocats_flag;
struct Flag *over_flag, *extend_flag, *no_import_flag;
struct Flag *invert_mask_flag;
char buf[2000];
@@ -118,9 +146,8 @@
id_layer_opt = G_define_standard_option(G_OPT_V_FIELD);
id_layer_opt->key = "id_layer";
id_layer_opt->label = _("Layer number to store generated point ID as category");
- id_layer_opt->description =
- _("Set empty to not store it. Required for attribute table.");
- id_layer_opt->answer = "1";
+ id_layer_opt->description = _("Set to 1 by default, use -c to not store it");
+ id_layer_opt->answer = NULL;
id_layer_opt->guisection = _("Categories");
return_layer_opt = G_define_standard_option(G_OPT_V_FIELD);
@@ -266,6 +293,14 @@
notab_flag = G_define_standard_flag(G_FLG_V_TABLE);
notab_flag->guisection = _("Speed");
+ nocats_flag = G_define_flag();
+ nocats_flag->key = 'c';
+ nocats_flag->label =
+ _("Do not automatically add unique ID as category to each point");
+ nocats_flag->description =
+ _("Create only requested layers and categories");
+ nocats_flag->guisection = _("Speed");
notopo_flag = G_define_standard_flag(G_FLG_V_TOPO);
notopo_flag->guisection = _("Speed");
@@ -284,6 +319,11 @@
no_import_flag->suppress_required = YES;
G_option_exclusive(skip_opt, preserve_opt, NULL);
+ G_option_requires(nocats_flag, notab_flag, NULL);
+ G_option_exclusive(nocats_flag, id_layer_opt, NULL);
+ G_option_requires(return_layer_opt, id_layer_opt, nocats_flag, NULL);
+ G_option_requires(class_layer_opt, id_layer_opt, nocats_flag, NULL);
+ G_option_requires(rgb_layer_opt, id_layer_opt, nocats_flag, NULL);
/* The parser checks if the map already exists in current mapset, this is
* wrong if location options is used, so we switch out the check and do it
@@ -338,7 +378,7 @@
struct ClassFilter class_filter;
class_filter_create_from_strings(&class_filter, class_opt->answers);
- int id_layer = 0;
+ int id_layer = 1;
int return_layer = 0;
int class_layer = 0;
int rgb_layer = 0;
@@ -350,12 +390,27 @@
class_layer = atoi(class_layer_opt->answer);
if (rgb_layer_opt->answer)
rgb_layer = atoi(rgb_layer_opt->answer);
+ if (nocats_flag->answer) {
+ id_layer = 0;
/* no cats forces no table earlier */
if (!notab_flag->answer && !id_layer) {
G_message(_("-%c flag is not set but ID layer is not specified"), notab_flag->key);
G_fatal_error(_("ID layer is required to store attribute table"));
+ struct Option *layer_options[4] = {id_layer_opt, return_layer_opt,
+ class_layer_opt, rgb_layer_opt};
+ int layer_values[4] = {id_layer, return_layer, class_layer, rgb_layer};
+ check_layers_in_list_not_equal(layer_options, layer_values, 4);
+ if (id_layer)
+ G_verbose_message(_("Storing generated point IDs as categories"
+ " in the layer <%d>, consequently no more"
+ " than %d points can be imported"),
+ id_layer, GV_CAT_MAX);
double zrange_min, zrange_max;
int use_zrange = FALSE;
Modified: grass/trunk/vector/v.in.pdal/main.cpp
--- grass/trunk/vector/v.in.pdal/main.cpp 2016-05-20 11:28:00 UTC (rev 68475)
+++ grass/trunk/vector/v.in.pdal/main.cpp 2016-05-20 14:54:35 UTC (rev 68476)
@@ -27,7 +27,34 @@
typedef unsigned long gpoint_count;
#endif
+/* this is plain C but in sync with v.in.lidar */
void pdal_point_to_grass(struct Map_info *output_vector,
struct line_pnts *points, struct line_cats *cats,
pdal::PointViewPtr point_view, pdal::PointId idx,
@@ -72,7 +99,6 @@
Vect_write_line(output_vector, GV_POINT, points, cats);
G_gisinit(argv[0]);
@@ -94,9 +120,8 @@
Option *id_layer_opt = G_define_standard_option(G_OPT_V_FIELD);
Option *return_layer_opt = G_define_standard_option(G_OPT_V_FIELD);
@@ -236,6 +261,15 @@
_("Initial distance for ground filter");
ground_cell_size_opt->guisection = _("Ground filter");
+ Flag *nocats_flag = G_define_flag();
+ /* v.in.lidar has this in Speed but we don't have it here */
+ nocats_flag->guisection = _("Categories");
Flag *region_flag = G_define_flag();
region_flag->key = 'r';
region_flag->guisection = _("Selection");
@@ -276,6 +310,10 @@
G_option_exclusive(spatial_opt, region_flag, NULL);
G_option_exclusive(reproject_flag, over_flag, NULL);
G_option_exclusive(extract_ground_flag, classify_ground_flag, NULL);
if (G_parser(argc, argv))
return EXIT_FAILURE;
@@ -289,6 +327,7 @@
struct GLidarLayers layers;
GLidarLayers_set_no_layers(&layers);
+ layers.id_layer = 1;
if (id_layer_opt->answer && id_layer_opt->answer[0] != '\0')
layers.id_layer = std::stoi(id_layer_opt->answer);
if (return_layer_opt->answer && return_layer_opt->answer[0] != '\0')
@@ -298,6 +337,23 @@
if (rgb_layer_opt->answer && rgb_layer_opt->answer[0] != '\0')
layers.rgb_layer = std::stoi(rgb_layer_opt->answer);
+ layers.id_layer = 0;
+ /* this is plain C but in sync with v.in.lidar */
+ Option *layer_options[4] = {id_layer_opt, return_layer_opt,
+ int layer_values[4] = {layers.id_layer, layers.return_layer,
+ layers.class_layer, layers.rgb_layer};
+ if (layers.id_layer)
+ layers.id_layer, GV_CAT_MAX);
double xmin = 0;
double ymin = 0;
double xmax = 0;
