[GRASS-SVN] r68477 - in grass/trunk/gui/wxpython: . dbmgr gmodeler gui_core modules psmap vdigit
svn_grass at osgeo.org
Fri May 20 12:02:54 PDT 2016
Author: annakrat
Date: 2016-05-20 12:02:54 -0700 (Fri, 20 May 2016)
New Revision: 68477
grass/trunk/gui/wxpython/dbmgr/base.py
grass/trunk/gui/wxpython/gis_set.py
grass/trunk/gui/wxpython/gmodeler/dialogs.py
grass/trunk/gui/wxpython/gui_core/preferences.py
grass/trunk/gui/wxpython/modules/extensions.py
grass/trunk/gui/wxpython/psmap/dialogs.py
grass/trunk/gui/wxpython/vdigit/dialogs.py
wxGUI: don't use sys.maxsize with wx.ListCtrl - breaks GUI on 64bit Windows, see #3011
Modified: grass/trunk/gui/wxpython/dbmgr/base.py
--- grass/trunk/gui/wxpython/dbmgr/base.py 2016-05-20 14:54:35 UTC (rev 68476)
+++ grass/trunk/gui/wxpython/dbmgr/base.py 2016-05-20 19:02:54 UTC (rev 68477)
@@ -2699,7 +2699,7 @@
# add item to the list of table columns
tlist = self.FindWindowById(self.layerPage[self.selLayer]['tableData'])
- index = tlist.InsertStringItem(sys.maxsize, str(name))
+ index = tlist.InsertStringItem(tlist.GetItemCount(), str(name))
tlist.SetStringItem(index, 0, str(name))
tlist.SetStringItem(index, 1, str(ctype))
tlist.SetStringItem(index, 2, str(length))
@@ -2889,7 +2889,7 @@
i = 0
for column in self.columns:
- index = self.InsertStringItem(sys.maxsize, str(column))
+ index = self.InsertStringItem(i, str(column))
self.SetStringItem(index, 0, str(column))
self.SetStringItem(index, 1, str(self.table[column]['type']))
self.SetStringItem(index, 2, str(self.table[column]['length']))
@@ -2947,7 +2947,7 @@
i = 0
for layer in self.layers.keys():
- index = self.InsertStringItem(sys.maxsize, str(layer))
+ index = self.InsertStringItem(i, str(layer))
self.SetStringItem(index, 0, str(layer))
database = str(self.layers[layer]['database'])
driver = str(self.layers[layer]['driver'])
Modified: grass/trunk/gui/wxpython/gis_set.py
--- grass/trunk/gui/wxpython/gis_set.py 2016-05-20 14:54:35 UTC (rev 68476)
+++ grass/trunk/gui/wxpython/gis_set.py 2016-05-20 19:02:54 UTC (rev 68477)
@@ -1137,8 +1137,9 @@
:param disabled: list of indices of non-selectable items
idx = 0
+ count = self.GetItemCount()
for item in choices:
- index = self.InsertStringItem(sys.maxsize, item)
+ index = self.InsertStringItem(count + idx, item)
self.SetStringItem(index, 0, item)
if idx in disabled:
Modified: grass/trunk/gui/wxpython/gmodeler/dialogs.py
--- grass/trunk/gui/wxpython/gmodeler/dialogs.py 2016-05-20 14:54:35 UTC (rev 68476)
+++ grass/trunk/gui/wxpython/gmodeler/dialogs.py 2016-05-20 19:02:54 UTC (rev 68477)
@@ -753,7 +753,7 @@
self.DeleteAllItems()
i = 0
for name, vtype, value, desc in self.itemDataMap.itervalues():
- index = self.InsertStringItem(sys.maxsize, name)
+ index = self.InsertStringItem(i, name)
self.SetStringItem(index, 0, name)
self.SetStringItem(index, 1, vtype)
self.SetStringItem(index, 2, value)
@@ -772,7 +772,7 @@
return _("Variable <%s> already exists in the model. "
"Adding variable failed.") % name
+ index = self.InsertStringItem(self.GetItemCount(), name)
@@ -938,7 +938,7 @@
i = 0
if len(self.columns) == 2:
for name, desc in self.itemDataMap.itervalues():
- index = self.InsertStringItem(sys.maxsize, str(i))
+ index = self.InsertStringItem(i, str(i))
self.SetStringItem(index, 1, desc)
self.SetItemData(index, i)
@@ -947,7 +947,7 @@
i += 1
else:
for name, inloop, param, desc in self.itemDataMap.itervalues():
self.SetStringItem(index, 1, inloop)
self.SetStringItem(index, 2, param)
Modified: grass/trunk/gui/wxpython/gui_core/preferences.py
--- grass/trunk/gui/wxpython/gui_core/preferences.py 2016-05-20 14:54:35 UTC (rev 68476)
+++ grass/trunk/gui/wxpython/gui_core/preferences.py 2016-05-20 19:02:54 UTC (rev 68477)
@@ -2292,7 +2292,7 @@
gisenv['LOCATION_NAME'])
for mapset in self.parent.all_mapsets_ordered:
- index = self.InsertStringItem(sys.maxsize, mapset)
+ index = self.InsertStringItem(self.GetItemCount(), mapset)
mapsetPath = os.path.join(locationPath,
mapset)
stat_info = os.stat(mapsetPath)
Modified: grass/trunk/gui/wxpython/modules/extensions.py
--- grass/trunk/gui/wxpython/modules/extensions.py 2016-05-20 14:54:35 UTC (rev 68476)
+++ grass/trunk/gui/wxpython/modules/extensions.py 2016-05-20 19:02:54 UTC (rev 68477)
@@ -533,7 +533,7 @@
quiet=True, parent=self, read=True,
flags='a').splitlines():
if ext:
- self.InsertStringItem(sys.maxsize, ext)
+ self.InsertStringItem(self.GetItemCount(), ext)
def GetExtensions(self):
"""Get extensions to be un-installed
Modified: grass/trunk/gui/wxpython/psmap/dialogs.py
--- grass/trunk/gui/wxpython/psmap/dialogs.py 2016-05-20 14:54:35 UTC (rev 68476)
+++ grass/trunk/gui/wxpython/psmap/dialogs.py 2016-05-20 19:02:54 UTC (rev 68477)
@@ -3637,7 +3637,7 @@
for vector in vectors:
index = self.vectorListCtrl.InsertStringItem(
- sys.maxsize, vector[0].split('@')[0])
+ self.vectorListCtrl.GetItemCount(), vector[0].split('@')[0])
self.vectorListCtrl.SetStringItem(index, 1, vector[4])
self.vectorListCtrl.SetItemData(index, index)
self.vectorListCtrl.CheckItem(index, True)
@@ -4446,7 +4446,7 @@
self.vectorListCtrl.DeleteAllItems()
Modified: grass/trunk/gui/wxpython/vdigit/dialogs.py
--- grass/trunk/gui/wxpython/vdigit/dialogs.py 2016-05-20 14:54:35 UTC (rev 68476)
+++ grass/trunk/gui/wxpython/vdigit/dialogs.py 2016-05-20 19:02:54 UTC (rev 68477)
@@ -581,7 +581,7 @@
for layer in cats.keys():
catsList = cats[layer]
for cat in catsList:
- index = self.InsertStringItem(sys.maxsize, str(catsList[0]))
+ index = self.InsertStringItem(self.GetItemCount(), str(catsList[0]))
self.SetStringItem(index, 1, str(cat))
@@ -801,7 +801,7 @@
self.InsertColumn(1, _('Layer (Categories)'))
for item in data:
- index = self.InsertStringItem(sys.maxsize, str(item[0]))
+ index = self.InsertStringItem(self.GetItemCount(), str(item[0]))
self.SetStringItem(index, 1, str(item[1]))
# enable all items by default
