[GRASS-SVN] r68478 - grass/trunk/raster/r.in.lidar
svn_grass at osgeo.org
Fri May 20 13:42:57 PDT 2016
Author: wenzeslaus
Date: 2016-05-20 13:42:57 -0700 (Fri, 20 May 2016)
New Revision: 68478
grass/trunk/raster/r.in.lidar/main.c
r.in.lidar: separate z and intensity in filters and statistics (#2932)
Modified: grass/trunk/raster/r.in.lidar/main.c
--- grass/trunk/raster/r.in.lidar/main.c 2016-05-20 19:02:54 UTC (rev 68477)
+++ grass/trunk/raster/r.in.lidar/main.c 2016-05-20 20:42:57 UTC (rev 68478)
@@ -42,6 +42,7 @@
char *infile, *outmap;
int percent;
double zrange_min, zrange_max, d_tmp;
+ double irange_min, irange_max;
unsigned long estimated_lines;
RASTER_MAP_TYPE rtype, base_raster_data_type;
@@ -61,11 +62,13 @@
unsigned int counter;
char buff[BUFFSIZE];
double x, y, z;
+ double intensity;
int arr_row, arr_col;
unsigned long count, count_total;
int point_class;
double zscale = 1.0;
+ double iscale = 1.0;
double res = 0.0;
struct BinIndex bin_index_nodes;
@@ -75,10 +78,13 @@
struct GModule *module;
struct Option *input_opt, *output_opt, *percent_opt, *type_opt, *filter_opt, *class_opt;
- struct Option *method_opt, *base_raster_opt, *zrange_opt, *zscale_opt;
+ struct Option *method_opt, *base_raster_opt;
+ struct Option *zrange_opt, *zscale_opt;
+ struct Option *irange_opt, *iscale_opt;
struct Option *trim_opt, *pth_opt, *res_opt;
struct Option *file_list_opt;
- struct Flag *print_flag, *scan_flag, *shell_style, *over_flag, *extents_flag, *intens_flag;
+ struct Flag *print_flag, *scan_flag, *shell_style, *over_flag, *extents_flag;
+ struct Flag *intens_flag, *intens_import_flag;
struct Flag *set_region_flag;
struct Flag *base_rast_res_flag;
@@ -161,6 +167,22 @@
zscale_opt->description = _("Scale to apply to z data");
zscale_opt->guisection = _("Transform");
+ irange_opt = G_define_option();
+ irange_opt->key = "intensity_range";
+ irange_opt->type = TYPE_DOUBLE;
+ irange_opt->required = NO;
+ irange_opt->key_desc = "min,max";
+ irange_opt->description = _("Filter range for intensity values (min,max)");
+ irange_opt->guisection = _("Selection");
+ iscale_opt = G_define_option();
+ iscale_opt->key = "intensity_scale";
+ iscale_opt->type = TYPE_DOUBLE;
+ iscale_opt->required = NO;
+ iscale_opt->answer = "1.0";
+ iscale_opt->description = _("Scale to apply to intensity values");
+ iscale_opt->guisection = _("Transform");
percent_opt = G_define_option();
percent_opt->key = "percent";
percent_opt->type = TYPE_INTEGER;
@@ -259,11 +281,18 @@
intens_flag->description =
_("Import intensity values rather than z values");
+ intens_import_flag = G_define_flag();
+ intens_import_flag->key = 'j';
+ intens_import_flag->description =
+ _("Use z values for filtering, but import intensity values");
base_rast_res_flag = G_define_flag();
base_rast_res_flag->key = 'd';
base_rast_res_flag->description =
_("Use base raster actual resolution instead of computational region");
+ G_option_exclusive(intens_flag, intens_import_flag, NULL);
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
@@ -379,7 +408,10 @@
class_filter_create_from_strings(&class_filter, class_opt->answers);
percent = atoi(percent_opt->answer);
- zscale = atof(zscale_opt->answer);
+ if (zscale_opt->answer)
+ zscale = atof(zscale_opt->answer);
+ if (iscale_opt->answer)
+ iscale = atof(iscale_opt->answer);
/* parse zrange */
if (zrange_opt->answer != NULL) {
@@ -395,7 +427,21 @@
zrange_min = d_tmp;
+ /* parse irange */
+ if (irange_opt->answer != NULL) {
+ if (irange_opt->answers[0] == NULL)
+ G_fatal_error(_("Invalid %s"), irange_opt->key);
+ sscanf(irange_opt->answers[0], "%lf", &irange_min);
+ sscanf(irange_opt->answers[1], "%lf", &irange_max);
+ if (irange_min > irange_max) {
+ d_tmp = irange_max;
+ irange_max = irange_min;
+ irange_min = d_tmp;
point_binning_set(&point_binning, method_opt->answer, pth_opt->answer,
trim_opt->answer, FALSE);
@@ -556,7 +602,8 @@
x = LASPoint_GetX(LAS_point);
y = LASPoint_GetY(LAS_point);
if (intens_flag->answer)
- /* use z variable here to allow for scaling of intensity below */
+ /* use intensity as z here to allow all filters (and
+ * modifications) below to be applied for intensity */
z = LASPoint_GetIntensity(LAS_point);
else
z = LASPoint_GetZ(LAS_point);
@@ -611,6 +658,19 @@
+ if (intens_import_flag->answer || irange_opt->answer) {
+ intensity = LASPoint_GetIntensity(LAS_point);
+ intensity *= iscale;
+ if (irange_opt->answer) {
+ if (intensity < irange_min || intensity > irange_max) {
+ continue;
+ /* use intensity for statistics */
+ if (intens_import_flag->answer)
+ z = intensity;
count++;
/* G_debug(5, "x: %f, y: %f, z: %f", x, y, z); */
