[GRASS-SVN] r69816 - in grass/branches/releasebranch_7_2/raster: r.info r.support
Sun Nov 13 15:24:40 PST 2016
Author: annakrat
Date: 2016-11-13 15:24:40 -0800 (Sun, 13 Nov 2016)
New Revision: 69816
   grass/branches/releasebranch_7_2/raster/r.info/main.c
   grass/branches/releasebranch_7_2/raster/r.support/main.c
r.support/r.info: set the right title and show it properly, see #3035 (merge from trunk, r68746-8, r69645)
Modified: grass/branches/releasebranch_7_2/raster/r.info/main.c
--- grass/branches/releasebranch_7_2/raster/r.info/main.c	2016-11-13 23:15:06 UTC (rev 69815)
+++ grass/branches/releasebranch_7_2/raster/r.info/main.c	2016-11-13 23:24:40 UTC (rev 69816)
@@ -40,6 +40,7 @@
 int main(int argc, char **argv)
     const char *name, *mapset;
+    const char *title;
     char tmp1[100], tmp2[100], tmp3[100];
     char timebuff[256];
     char *units, *vdatum;
@@ -128,6 +129,21 @@
     out = stdout;
+    if (eflag->answer || (!gflag->answer && !rflag->answer && !hflag->answer)) {
+	title = "";
+	/* empty title by default */
+	/* use title from category file as the primary (and only) title */
+	if (cats_ok)
+	    title = cats.title;
+	/* only use hist file title if there is none in the category file */
+	if ((!title || title[0] == '\0') && hist_ok) {
+	    title = Rast_get_history(&hist, HIST_TITLE);
+	    /* if the title is the same as name of the map, don't use it */
+	    if (strcmp(title, name) == 0)
+		title = "";
     if (!gflag->answer && !rflag->answer &&
 	!eflag->answer && !hflag->answer) {
 	divider('+');
@@ -138,9 +154,7 @@
 		     mapset, hist_ok ? Rast_get_history(&hist, HIST_CREATOR) : "??");
 	compose_line(out, "Location: %s", G_location());
 	compose_line(out, "DataBase: %s", G_gisdbase());
-	compose_line(out, "Title:    %s ( %s )",
-		     cats_ok ? cats.title : "??",
-		     hist_ok ? Rast_get_history(&hist, HIST_TITLE) : "??");
+	compose_line(out, "Title:    %s", title);
 	/* This shows the TimeStamp */
 	if (time_ok && (first_time_ok || second_time_ok)) {
@@ -368,8 +382,7 @@
             fprintf(out, "database=%s\n", G_gisdbase());
             fprintf(out, "date=\"%s\"\n", hist_ok ? Rast_get_history(&hist, HIST_MAPID) : "??");
             fprintf(out, "creator=\"%s\"\n", hist_ok ? Rast_get_history(&hist, HIST_CREATOR) : "??");
-	    fprintf(out, "title=\"%s (%s)\"\n", cats_ok ? cats.title :
-		    "??", hist_ok ? Rast_get_history(&hist, HIST_TITLE) : "??");
+	    fprintf(out, "title=\"%s\"\n", title);
 		G_format_timestamp(&ts, timebuff);
Modified: grass/branches/releasebranch_7_2/raster/r.support/main.c
--- grass/branches/releasebranch_7_2/raster/r.support/main.c	2016-11-13 23:15:06 UTC (rev 69815)
+++ grass/branches/releasebranch_7_2/raster/r.support/main.c	2016-11-13 23:24:40 UTC (rev 69816)
@@ -45,7 +45,6 @@
     struct Flag *stats_flag, *null_flag, *del_flag;
     int is_reclass;		/* Is raster reclass? */
     const char *infile;
-    char title[MAX_TITLE_LEN + 1];
     struct History hist;
     /* Initialize GIS engine */
@@ -151,13 +150,8 @@
     is_reclass = (Rast_is_reclass(raster->answer, "", rname, rmapset) > 0);
     if (title_opt->answer) {
-	strncpy(title, title_opt->answer, MAX_TITLE_LEN);
-	title[MAX_TITLE_LEN - 1] = '\0';	/* strncpy doesn't null terminate oversized input */
-	G_strip(title);
-	G_debug(3, "map title= [%s]  (%li chars)", title, strlen(title));
-	Rast_read_history(raster->answer, "", &hist);
-	Rast_set_history(&hist, HIST_TITLE, title);
-	Rast_write_history(raster->answer, &hist);
+        Rast_put_cell_title(raster->answer, title_opt->answer);
+	G_debug(3, "map title= [%s]  (%li chars)", title_opt->answer, strlen(title_opt->answer));
     if (save_opt->answer) {
