[GRASS-SVN] r69817 - grass/branches/releasebranch_7_2/gui/wxpython/tplot
svn_grass at osgeo.org
Sun Nov 13 15:40:02 PST 2016
Author: annakrat
Date: 2016-11-13 15:40:02 -0800 (Sun, 13 Nov 2016)
New Revision: 69817
grass/branches/releasebranch_7_2/gui/wxpython/tplot/frame.py
g.gui.tplot: do not use EVT_COMBOBOX_CLOSEUP, not available on all platforms, see #3175 (merge from trunk, r69685)
Modified: grass/branches/releasebranch_7_2/gui/wxpython/tplot/frame.py
--- grass/branches/releasebranch_7_2/gui/wxpython/tplot/frame.py 2016-11-13 23:24:40 UTC (rev 69816)
+++ grass/branches/releasebranch_7_2/gui/wxpython/tplot/frame.py 2016-11-13 23:40:02 UTC (rev 69817)
@@ -227,7 +227,7 @@
self.datasetSelectV = gselect.Select(
parent=self.controlPanelVector, id=wx.ID_ANY,
size=globalvar.DIALOG_GSELECT_SIZE, type='stvds', multiple=True)
- self.datasetSelectV.Bind(wx.EVT_COMBOBOX_CLOSEUP,
+ self.datasetSelectV.Bind(wx.EVT_TEXT,
self.OnVectorSelected)
self.attribute = gselect.ColumnSelect(parent=self.controlPanelVector)
@@ -885,7 +885,18 @@
def OnVectorSelected(self, event):
"""Update the controlbox related to stvds"""
dataset = self.datasetSelectV.GetValue().strip()
- if dataset:
+ name = dataset.split('@')[0]
+ mapset = dataset.split('@')[1] if len(dataset.split('@')) > 1 else ''
+ found = False
+ for each in tgis.tlist(type='stvds', dbif=self.dbif):
+ each_name, each_mapset = each.split('@')
+ if name == each_name:
+ if mapset and mapset != each_mapset:
+ continue
+ dataset = name + '@' + each_mapset
+ found = True
+ break
+ if found:
try:
vect_list = grass.read_command('t.vect.list', flags='s',
input=dataset, column='name')
@@ -900,7 +911,7 @@
for vec in vect_list:
self.attribute.InsertColumns(vec, 1)
else:
- return
+ self.attribute.Clear()
class LookUp:
