[GRASS-SVN] r69830 - in grass/branches/releasebranch_7_2/temporal: t.connect t.connect/testsuite t.create t.info t.info/testsuite t.rast.aggregate/testsuite t.rast.algebra t.rast.list t.rast.mapcalc t.rast.neighbors t.rast.univar t.rast.univar/testsuite t.rast3d.algebra t.rast3d.mapcalc t.sample t.select t.topology t.unregister/testsuite t.vect.algebra t.vect.extract/testsuite t.vect.list t.vect.univar
svn_grass at osgeo.org
Tue Nov 15 05:09:04 PST 2016
Author: huhabla
Date: 2016-11-15 05:09:04 -0800 (Tue, 15 Nov 2016)
New Revision: 69830
grass/branches/releasebranch_7_2/temporal/t.connect/main.c
grass/branches/releasebranch_7_2/temporal/t.connect/testsuite/test_distr_tgis_db_raster.py
grass/branches/releasebranch_7_2/temporal/t.connect/testsuite/test_distr_tgis_db_raster3d.py
grass/branches/releasebranch_7_2/temporal/t.connect/testsuite/test_distr_tgis_db_vector.py
grass/branches/releasebranch_7_2/temporal/t.create/t.create.py
grass/branches/releasebranch_7_2/temporal/t.info/t.info.html
grass/branches/releasebranch_7_2/temporal/t.info/t.info.py
grass/branches/releasebranch_7_2/temporal/t.info/testsuite/test.t.info.sh
grass/branches/releasebranch_7_2/temporal/t.rast.aggregate/testsuite/test_aggregation_absolute.py
grass/branches/releasebranch_7_2/temporal/t.rast.algebra/t.rast.algebra.py
grass/branches/releasebranch_7_2/temporal/t.rast.list/t.rast.list.py
grass/branches/releasebranch_7_2/temporal/t.rast.mapcalc/t.rast.mapcalc.py
grass/branches/releasebranch_7_2/temporal/t.rast.neighbors/t.rast.neighbors.py
grass/branches/releasebranch_7_2/temporal/t.rast.univar/t.rast.univar.html
grass/branches/releasebranch_7_2/temporal/t.rast.univar/t.rast.univar.py
grass/branches/releasebranch_7_2/temporal/t.rast.univar/testsuite/test_univar.py
grass/branches/releasebranch_7_2/temporal/t.rast3d.algebra/t.rast3d.algebra.py
grass/branches/releasebranch_7_2/temporal/t.rast3d.mapcalc/t.rast3d.mapcalc.py
grass/branches/releasebranch_7_2/temporal/t.sample/t.sample.py
grass/branches/releasebranch_7_2/temporal/t.select/t.select.py
grass/branches/releasebranch_7_2/temporal/t.topology/t.topology.py
grass/branches/releasebranch_7_2/temporal/t.unregister/testsuite/test_unregister.py
grass/branches/releasebranch_7_2/temporal/t.vect.algebra/t.vect.algebra.py
grass/branches/releasebranch_7_2/temporal/t.vect.extract/testsuite/test_vect_extract.py
grass/branches/releasebranch_7_2/temporal/t.vect.list/t.vect.list.py
grass/branches/releasebranch_7_2/temporal/t.vect.univar/t.vect.univar.py
temporal modules: Attempt to harmonize the flags of temporal modules (merge from trunk r69510,
r69554, r69555, r69576, r69674)
Modified: grass/branches/releasebranch_7_2/temporal/t.connect/main.c
--- grass/branches/releasebranch_7_2/temporal/t.connect/main.c 2016-11-15 08:44:51 UTC (rev 69829)
+++ grass/branches/releasebranch_7_2/temporal/t.connect/main.c 2016-11-15 13:09:04 UTC (rev 69830)
@@ -31,9 +31,9 @@
/* Set description */
module = G_define_module();
- G_add_keyword(_("database"));
- G_add_keyword(_("attribute table"));
- G_add_keyword(_("connection settings"));
+ G_add_keyword(_("temporal"));
+ G_add_keyword(_("settings"));
+ G_add_keyword(_("metadata"));
module->description =
_("Prints/sets general temporal GIS database connection for current mapset.");
Modified: grass/branches/releasebranch_7_2/temporal/t.connect/testsuite/test_distr_tgis_db_raster.py
--- grass/branches/releasebranch_7_2/temporal/t.connect/testsuite/test_distr_tgis_db_raster.py 2016-11-15 08:44:51 UTC (rev 69829)
+++ grass/branches/releasebranch_7_2/temporal/t.connect/testsuite/test_distr_tgis_db_raster.py 2016-11-15 13:09:04 UTC (rev 69830)
@@ -32,7 +32,7 @@
cls.runModule("g.region", s=0, n=80,
w=0, e=120, b=0, t=50, res=10, res3=10)
cls.runModule("t.connect", flags="d")
- cls.runModule("t.info", flags="s")
+ cls.runModule("t.info", flags="d")
cls.runModule("r.mapcalc", expression="a1 = 100")
cls.runModule("r.mapcalc", expression="a2 = 200")
cls.runModule("r.mapcalc", expression="a3 = 300")
@@ -104,7 +104,7 @@
a3|test1|2001-03-01 00:00:00|2001-04-01 00:00:00"""
trast_list = SimpleModule(
- "t.rast.list", quiet=True, flags="s", input="A at test1")
+ "t.rast.list", quiet=True, flags="u", input="A at test1")
self.assertModule(trast_list)
out = trast_list.outputs["stdout"].value
@@ -117,7 +117,7 @@
a3|test2|2001-05-01 00:00:00|2001-07-01 00:00:00"""
- "t.rast.list", quiet=True, flags="s", input="A at test2")
+ "t.rast.list", quiet=True, flags="u", input="A at test2")
@@ -130,7 +130,7 @@
a3|test3|2001-07-01 00:00:00|2001-10-01 00:00:00"""
- "t.rast.list", quiet=True, flags="s", input="A at test3")
+ "t.rast.list", quiet=True, flags="u", input="A at test3")
@@ -143,7 +143,7 @@
a3|test4|2001-09-01 00:00:00|2002-01-01 00:00:00"""
- "t.rast.list", quiet=True, flags="s", input="A at test4")
+ "t.rast.list", quiet=True, flags="u", input="A at test4")
@@ -156,7 +156,7 @@
a3|test5|2001-11-01 00:00:00|2002-04-01 00:00:00"""
- "t.rast.list", quiet=True, flags="s", input="A at test5")
+ "t.rast.list", quiet=True, flags="u", input="A at test5")
@@ -164,7 +164,7 @@
for a, b in zip(list_string.split("\n"), out.split("\n")):
self.assertEqual(a.strip(), b.strip())
- trast_list = SimpleModule("t.rast.list", quiet=True, flags="s",
+ trast_list = SimpleModule("t.rast.list", quiet=True, flags="u",
input="A at test5", output=self.outfile)
self.assertFileExists(self.outfile)
Modified: grass/branches/releasebranch_7_2/temporal/t.connect/testsuite/test_distr_tgis_db_raster3d.py
--- grass/branches/releasebranch_7_2/temporal/t.connect/testsuite/test_distr_tgis_db_raster3d.py 2016-11-15 08:44:51 UTC (rev 69829)
+++ grass/branches/releasebranch_7_2/temporal/t.connect/testsuite/test_distr_tgis_db_raster3d.py 2016-11-15 13:09:04 UTC (rev 69830)
@@ -37,7 +37,7 @@
cls.runModule("r3.mapcalc", expression="a3 = 300")
# Create the temporal database
cls.runModule("t.create", type="str3ds", temporaltype="absolute",
output="A", title="A test3d", description="A test3d")
cls.runModule(
Modified: grass/branches/releasebranch_7_2/temporal/t.connect/testsuite/test_distr_tgis_db_vector.py
--- grass/branches/releasebranch_7_2/temporal/t.connect/testsuite/test_distr_tgis_db_vector.py 2016-11-15 08:44:51 UTC (rev 69829)
+++ grass/branches/releasebranch_7_2/temporal/t.connect/testsuite/test_distr_tgis_db_vector.py 2016-11-15 13:09:04 UTC (rev 69830)
@@ -37,7 +37,7 @@
cls.runModule("v.random", output="a3", npoints=20)
cls.runModule("t.create", type="stvds", temporaltype="absolute",
output="A", title="A testvect", description="A testvect")
cls.runModule("t.register", flags="i", type="vector", input="A",
@@ -102,7 +102,7 @@
a2|testvect1|2001-02-01 00:00:00|2001-03-01 00:00:00
a3|testvect1|2001-03-01 00:00:00|2001-04-01 00:00:00"""
- trast_list = SimpleModule("t.vect.list", quiet=True, flags="s",
+ trast_list = SimpleModule("t.vect.list", quiet=True, flags="u",
columns=[
"name", "mapset", "start_time", "end_time"],
input="A at testvect1")
@@ -118,7 +118,7 @@
a3|testvect2|2001-05-01 00:00:00|2001-07-01 00:00:00"""
- "t.vect.list", quiet=True, flags="s",
+ "t.vect.list", quiet=True, flags="u",
columns=["name", "mapset", "start_time", "end_time"],
input="A at testvect2")
@@ -132,7 +132,7 @@
a2|testvect3|2001-04-01 00:00:00|2001-07-01 00:00:00
a3|testvect3|2001-07-01 00:00:00|2001-10-01 00:00:00"""
columns=[
input="A at testvect3")
@@ -148,7 +148,7 @@
a3|testvect4|2001-09-01 00:00:00|2002-01-01 00:00:00"""
input="A at testvect4")
@@ -158,7 +158,7 @@
input="A at testvect4", output=self.outfile)
Modified: grass/branches/releasebranch_7_2/temporal/t.create/t.create.py
--- grass/branches/releasebranch_7_2/temporal/t.create/t.create.py 2016-11-15 08:44:51 UTC (rev 69829)
+++ grass/branches/releasebranch_7_2/temporal/t.create/t.create.py 2016-11-15 13:09:04 UTC (rev 69830)
@@ -78,7 +78,7 @@
tgis.init()
tgis.open_new_stds(name, type, temporaltype, title, descr,
- semantic, None, grass.overwrite())
+ semantic, None, grass.overwrite())
if __name__ == "__main__":
options, flags = grass.parser()
Modified: grass/branches/releasebranch_7_2/temporal/t.info/t.info.html
--- grass/branches/releasebranch_7_2/temporal/t.info/t.info.html 2016-11-15 08:44:51 UTC (rev 69829)
+++ grass/branches/releasebranch_7_2/temporal/t.info/t.info.html 2016-11-15 13:09:04 UTC (rev 69830)
@@ -28,7 +28,7 @@
In order to obtain information about temporal DBMI backend, run:
<div class="code"><pre>
-t.info -s
+t.info -d
+------------------- Temporal DBMI backend information ----------------------+
| DBMI Python interface:...... sqlite3
| Temporal database string:... /grassdata/nc_spm_temporal_workshop/climate_2000_2012/tgis/sqlite.db
Modified: grass/branches/releasebranch_7_2/temporal/t.info/t.info.py
--- grass/branches/releasebranch_7_2/temporal/t.info/t.info.py 2016-11-15 08:44:51 UTC (rev 69829)
+++ grass/branches/releasebranch_7_2/temporal/t.info/t.info.py 2016-11-15 13:09:04 UTC (rev 69830)
@@ -43,7 +43,7 @@
#%end
#%flag
-#% key: s
+#% key: d
#% description: Print information about the temporal DBMI interface and exit
#% suppress_required: yes
#%end
@@ -60,7 +60,7 @@
name = options["input"]
type_ = options["type"]
shellstyle = flags['g']
- system = flags['s']
+ system = flags['d']
history = flags['h']
# Make sure the temporal database exists
@@ -68,7 +68,6 @@
dbif, connected = tgis.init_dbif(None)
rows = tgis.get_tgis_metadata(dbif)
if system and not shellstyle:
Modified: grass/branches/releasebranch_7_2/temporal/t.info/testsuite/test.t.info.sh
--- grass/branches/releasebranch_7_2/temporal/t.info/testsuite/test.t.info.sh 2016-11-15 08:44:51 UTC (rev 69829)
+++ grass/branches/releasebranch_7_2/temporal/t.info/testsuite/test.t.info.sh 2016-11-15 13:09:04 UTC (rev 69830)
@@ -2,7 +2,7 @@
# Test the info output
# We need to set a specific region in the
-# @preprocess step of this test.
+# @preprocess step of this test.
g.region s=0 n=80 w=0 e=120 b=0 t=50 res=10 res3=10 -p3
export GRASS_OVERWRITE=1
@@ -17,8 +17,8 @@
v.random -z output=lidar_abs_2 n=20 zmin=0 zmax=100 column=height
# The first @test
-t.info -s
-t.info -sg
+t.info -d
+t.info -dg
t.create type=strds temporaltype=absolute output=precip_abs1 title="A test" descr="A test"
t.create type=strds temporaltype=absolute output=precip_abs2 title="A test" descr="A test"
Modified: grass/branches/releasebranch_7_2/temporal/t.rast.aggregate/testsuite/test_aggregation_absolute.py
--- grass/branches/releasebranch_7_2/temporal/t.rast.aggregate/testsuite/test_aggregation_absolute.py 2016-11-15 08:44:51 UTC (rev 69829)
+++ grass/branches/releasebranch_7_2/temporal/t.rast.aggregate/testsuite/test_aggregation_absolute.py 2016-11-15 13:09:04 UTC (rev 69830)
@@ -103,7 +103,7 @@
# Check the map names are correct
lister = SimpleModule("t.rast.list", input="B", columns="name",
- flags="s")
+ flags="u")
self.runModule(lister)
#print lister.outputs.stdout
maps="b_2001_01" + os.linesep + "b_2001_02" + os.linesep + \
@@ -144,7 +144,7 @@
- flags="s")
+ flags="u")
maps="b_11" + os.linesep + "b_12" + os.linesep
@@ -177,7 +177,7 @@
- flags="s")
+ flags="u")
maps="b_101" + os.linesep
Modified: grass/branches/releasebranch_7_2/temporal/t.rast.algebra/t.rast.algebra.py
--- grass/branches/releasebranch_7_2/temporal/t.rast.algebra/t.rast.algebra.py 2016-11-15 08:44:51 UTC (rev 69829)
+++ grass/branches/releasebranch_7_2/temporal/t.rast.algebra/t.rast.algebra.py 2016-11-15 13:09:04 UTC (rev 69830)
@@ -50,7 +50,7 @@
#%flag
#% key: s
-#% description: Activate spatial topology
+#% description: Check the spatial topology of temporally related maps and process only spatially related maps
#%end
#%flag
@@ -97,11 +97,11 @@
nprocs=nprocs,
register_null=register_null,
dry_run=dry_run)
if granularity:
if not p.setup_common_granularity(expression=expression, lexer = tgis.TemporalRasterAlgebraLexer()):
grass.script.fatal(_("Unable to process the expression in granularity algebra mode"))
pc = p.parse(expression, basename, grass.script.overwrite())
if dry_run is True:
Modified: grass/branches/releasebranch_7_2/temporal/t.rast.list/t.rast.list.py
--- grass/branches/releasebranch_7_2/temporal/t.rast.list/t.rast.list.py 2016-11-15 08:44:51 UTC (rev 69829)
+++ grass/branches/releasebranch_7_2/temporal/t.rast.list/t.rast.list.py 2016-11-15 13:09:04 UTC (rev 69830)
@@ -80,7 +80,7 @@
#%end
#%flag
-#% key: s
+#% key: u
#% description: Suppress printing of column names
#% guisection: Formatting
#%end
@@ -101,7 +101,7 @@
separator = grass.separator(options["separator"])
method = options["method"]
granule = options["granule"]
- header = flags["s"]
+ header = flags["u"]
output = options["output"]
Modified: grass/branches/releasebranch_7_2/temporal/t.rast.mapcalc/t.rast.mapcalc.py
--- grass/branches/releasebranch_7_2/temporal/t.rast.mapcalc/t.rast.mapcalc.py 2016-11-15 08:44:51 UTC (rev 69829)
+++ grass/branches/releasebranch_7_2/temporal/t.rast.mapcalc/t.rast.mapcalc.py 2016-11-15 13:09:04 UTC (rev 69830)
@@ -64,11 +64,9 @@
#%flag
#% key: s
-#% description: Check spatial overlap
#%end
-from multiprocessing import Process
-import copy
import grass.script as grass
import grass.temporal as tgis
Modified: grass/branches/releasebranch_7_2/temporal/t.rast.neighbors/t.rast.neighbors.py
--- grass/branches/releasebranch_7_2/temporal/t.rast.neighbors/t.rast.neighbors.py 2016-11-15 08:44:51 UTC (rev 69829)
+++ grass/branches/releasebranch_7_2/temporal/t.rast.neighbors/t.rast.neighbors.py 2016-11-15 13:09:04 UTC (rev 69830)
@@ -83,6 +83,12 @@
#% key: n
#% description: Register Null maps
#%end
+#%flag
+#% key: r
+#% description: Ignore the current region settings and use the raster map regions
+#%end
from __future__ import print_function
import copy
@@ -167,7 +173,7 @@
# Open the new space time raster dataset
ttype, stype, title, descr = sp.get_initial_values()
new_sp = tgis.open_new_stds(output, "strds", ttype, title,
- descr, stype, dbif, overwrite)
+ descr, stype, dbif, overwrite)
num_maps = len(new_maps)
# collect empty maps to remove them
empty_maps = []
Modified: grass/branches/releasebranch_7_2/temporal/t.rast.univar/t.rast.univar.html
--- grass/branches/releasebranch_7_2/temporal/t.rast.univar/t.rast.univar.html 2016-11-15 08:44:51 UTC (rev 69829)
+++ grass/branches/releasebranch_7_2/temporal/t.rast.univar/t.rast.univar.html 2016-11-15 13:09:04 UTC (rev 69830)
@@ -6,7 +6,7 @@
<p>
By default it returns the name of the map, the start and end date of
dataset and the following values: mean, minimum and maximum vale,
-mean_of_abs, standard deviation, variance,coeff_var, number of null
+mean_of_abs, standard deviation, variance, coeff_var, number of null
cells, total number of cell.
<p>
Using the <em>e</em> flag it can calculate also extended statistics:
Modified: grass/branches/releasebranch_7_2/temporal/t.rast.univar/t.rast.univar.py
--- grass/branches/releasebranch_7_2/temporal/t.rast.univar/t.rast.univar.py 2016-11-15 08:44:51 UTC (rev 69829)
+++ grass/branches/releasebranch_7_2/temporal/t.rast.univar/t.rast.univar.py 2016-11-15 13:09:04 UTC (rev 69830)
@@ -49,7 +49,7 @@
#%end
#%flag
-#% key: s
+#% key: u
#%end
@@ -67,7 +67,7 @@
where = options["where"]
extended = flags["e"]
- no_header = flags["s"]
+ no_header = flags["u"]
rast_region = bool(flags["r"])
Modified: grass/branches/releasebranch_7_2/temporal/t.rast.univar/testsuite/test_univar.py
--- grass/branches/releasebranch_7_2/temporal/t.rast.univar/testsuite/test_univar.py 2016-11-15 08:44:51 UTC (rev 69829)
+++ grass/branches/releasebranch_7_2/temporal/t.rast.univar/testsuite/test_univar.py 2016-11-15 13:09:04 UTC (rev 69830)
@@ -25,23 +25,23 @@
cls.runModule("r.mapcalc", expression="a_3 = 300", overwrite=True)
cls.runModule("r.mapcalc", expression="a_4 = 400", overwrite=True)
- cls.runModule("t.create", type="strds", temporaltype="absolute",
- output="A", title="A test", description="A test",
+ cls.runModule("t.create", type="strds", temporaltype="absolute",
+ output="A", title="A test", description="A test",
overwrite=True)
- cls.runModule("t.register", flags="i", type="raster", input="A",
- maps="a_1,a_2,a_3,a_4", start="2001-01-01",
+ cls.runModule("t.register", flags="i", type="raster", input="A",
+ maps="a_1,a_2,a_3,a_4", start="2001-01-01",
increment="3 months", overwrite=True)
@classmethod
def tearDownClass(cls):
"""Remove the temporary region
- cls.runModule("t.remove", flags="rf", type="strds",
+ cls.runModule("t.remove", flags="rf", type="strds",
inputs="A")
cls.del_temp_region()
def test_1(self):
t_rast_univar = SimpleModule("t.rast.univar", input="A",
where="start_time >= '2001-01-01'",
overwrite=True, verbose=True)
@@ -122,7 +122,7 @@
def test_5(self):
self.runModule("g.region", res=10)
- self.assertModule("t.rast.univar", input="A", flags="rs",
+ self.assertModule("t.rast.univar", input="A", flags="ru",
output="univar_output.txt",
where="start_time >= '2001-03-01'",
Modified: grass/branches/releasebranch_7_2/temporal/t.rast3d.algebra/t.rast3d.algebra.py
--- grass/branches/releasebranch_7_2/temporal/t.rast3d.algebra/t.rast3d.algebra.py 2016-11-15 08:44:51 UTC (rev 69829)
+++ grass/branches/releasebranch_7_2/temporal/t.rast3d.algebra/t.rast3d.algebra.py 2016-11-15 13:09:04 UTC (rev 69830)
@@ -51,7 +51,7 @@
#%flag
#% key: s
#%end
#%flag
@@ -88,11 +88,11 @@
tgis.init(True)
p = tgis.TemporalRaster3DAlgebraParser(run = True, debug=False, spatial = spatial, nprocs = nprocs, register_null = register_null)
if granularity:
if not p.setup_common_granularity(expression=expression, stdstype = 'str3ds', lexer = tgis.TemporalRasterAlgebraLexer()):
Modified: grass/branches/releasebranch_7_2/temporal/t.rast3d.mapcalc/t.rast3d.mapcalc.py
--- grass/branches/releasebranch_7_2/temporal/t.rast3d.mapcalc/t.rast3d.mapcalc.py 2016-11-15 08:44:51 UTC (rev 69829)
+++ grass/branches/releasebranch_7_2/temporal/t.rast3d.mapcalc/t.rast3d.mapcalc.py 2016-11-15 13:09:04 UTC (rev 69830)
@@ -68,7 +68,7 @@
#%flag
#% key: s
#%end
Modified: grass/branches/releasebranch_7_2/temporal/t.sample/t.sample.py
--- grass/branches/releasebranch_7_2/temporal/t.sample/t.sample.py 2016-11-15 08:44:51 UTC (rev 69829)
+++ grass/branches/releasebranch_7_2/temporal/t.sample/t.sample.py 2016-11-15 13:09:04 UTC (rev 69830)
@@ -57,7 +57,7 @@
#%flag
#% key: s
+#% description: Check for spatial topological overlap
#%end
Modified: grass/branches/releasebranch_7_2/temporal/t.select/t.select.py
--- grass/branches/releasebranch_7_2/temporal/t.select/t.select.py 2016-11-15 08:44:51 UTC (rev 69829)
+++ grass/branches/releasebranch_7_2/temporal/t.select/t.select.py 2016-11-15 13:09:04 UTC (rev 69830)
@@ -37,7 +37,7 @@
#%flag
#% key: s
+#% description: Check the spatial topology of temporally related maps and select only spatially related maps
#%end
#%flag
Modified: grass/branches/releasebranch_7_2/temporal/t.topology/t.topology.py
--- grass/branches/releasebranch_7_2/temporal/t.topology/t.topology.py 2016-11-15 08:44:51 UTC (rev 69829)
+++ grass/branches/releasebranch_7_2/temporal/t.topology/t.topology.py 2016-11-15 13:09:04 UTC (rev 69830)
@@ -34,12 +34,12 @@
#%flag
#% key: m
-#% description: Print temporal relationships and exit
+#% description: Print temporal topological relationships and exit
#%end
#%flag
#% key: s
-#% description: Print spatio-temporal relationships and exit
+#% description: Print spatio-temporal topological relationships and exit
#%end
Modified: grass/branches/releasebranch_7_2/temporal/t.unregister/testsuite/test_unregister.py
--- grass/branches/releasebranch_7_2/temporal/t.unregister/testsuite/test_unregister.py 2016-11-15 08:44:51 UTC (rev 69829)
+++ grass/branches/releasebranch_7_2/temporal/t.unregister/testsuite/test_unregister.py 2016-11-15 13:09:04 UTC (rev 69830)
@@ -82,14 +82,14 @@
self.assertModule("t.unregister", input="A", maps="a1,a2,a3")
lister = SimpleModule("t.rast.list", input="A", columns="name",
- flags="s")
+ flags="u")
self.assertEqual(a456, lister.outputs.stdout)
# Check if all maps are present in STRDS B
- flags="s")
+ flags="u")
self.assertEqual(al, lister.outputs.stdout)
@@ -112,7 +112,7 @@
# Check that masp a1, a2 and a3 are not present in STRDS B
- flags="s")
+ flags="u")
Modified: grass/branches/releasebranch_7_2/temporal/t.vect.algebra/t.vect.algebra.py
--- grass/branches/releasebranch_7_2/temporal/t.vect.algebra/t.vect.algebra.py 2016-11-15 08:44:51 UTC (rev 69829)
+++ grass/branches/releasebranch_7_2/temporal/t.vect.algebra/t.vect.algebra.py 2016-11-15 13:09:04 UTC (rev 69830)
@@ -43,7 +43,7 @@
#%flag
#% key: s
#%end
import grass.script
Modified: grass/branches/releasebranch_7_2/temporal/t.vect.extract/testsuite/test_vect_extract.py
--- grass/branches/releasebranch_7_2/temporal/t.vect.extract/testsuite/test_vect_extract.py 2016-11-15 08:44:51 UTC (rev 69829)
+++ grass/branches/releasebranch_7_2/temporal/t.vect.extract/testsuite/test_vect_extract.py 2016-11-15 13:09:04 UTC (rev 69830)
@@ -30,7 +30,7 @@
column="value", value="'random()'")
output="A", title="A testvect", description="A testvect",
overwrite=True)
Modified: grass/branches/releasebranch_7_2/temporal/t.vect.list/t.vect.list.py
--- grass/branches/releasebranch_7_2/temporal/t.vect.list/t.vect.list.py 2016-11-15 08:44:51 UTC (rev 69829)
+++ grass/branches/releasebranch_7_2/temporal/t.vect.list/t.vect.list.py 2016-11-15 13:09:04 UTC (rev 69830)
@@ -72,7 +72,7 @@
#%end
#%flag
-#% key: s
+#% key: u
#%end
@@ -92,7 +92,7 @@
Modified: grass/branches/releasebranch_7_2/temporal/t.vect.univar/t.vect.univar.py
--- grass/branches/releasebranch_7_2/temporal/t.vect.univar/t.vect.univar.py 2016-11-15 08:44:51 UTC (rev 69829)
+++ grass/branches/releasebranch_7_2/temporal/t.vect.univar/t.vect.univar.py 2016-11-15 13:09:04 UTC (rev 69830)
@@ -62,7 +62,7 @@
#%end
#%flag
-#% key: s
+#% key: u
#%end
@@ -83,7 +83,7 @@
column = options["column"]
