[GRASS-SVN] r69864 - grass-addons/grass7/raster/r.gwr
Mon Nov 21 12:59:01 PST 2016
Author: mmetz
Date: 2016-11-21 12:59:01 -0800 (Mon, 21 Nov 2016)
New Revision: 69864
Added:
   grass-addons/grass7/raster/r.gwr/flag.c
   grass-addons/grass7/raster/r.gwr/flag.h
   grass-addons/grass7/raster/r.gwr/gwr.h
   grass-addons/grass7/raster/r.gwr/gwra.c
   grass-addons/grass7/raster/r.gwr/rclist.c
   grass-addons/grass7/raster/r.gwr/rclist.h
   grass-addons/grass7/raster/r.gwr/Makefile
   grass-addons/grass7/raster/r.gwr/estimate_bw.c
   grass-addons/grass7/raster/r.gwr/gwr.c
   grass-addons/grass7/raster/r.gwr/local_proto.h
   grass-addons/grass7/raster/r.gwr/main.c
   grass-addons/grass7/raster/r.gwr/r.gwr.html
   grass-addons/grass7/raster/r.gwr/weights.c
r.gwr: +adaptive bandwidth, +mask option
Modified: grass-addons/grass7/raster/r.gwr/Makefile
--- grass-addons/grass7/raster/r.gwr/Makefile	2016-11-21 20:49:11 UTC (rev 69863)
+++ grass-addons/grass7/raster/r.gwr/Makefile	2016-11-21 20:59:01 UTC (rev 69864)
@@ -2,8 +2,8 @@
 PGM = r.gwr
-LIBES = $(RASTERLIB) $(GISLIB) $(GMATHLIB) $(MATHLIB)
-DEPENDENCIES = $(RASTERDEP) $(GISDEP)
+LIBES = $(RASTERLIB) $(BTREE2LIB) $(SEGMENTLIB) $(GISLIB) $(GMATHLIB) $(MATHLIB)
+DEPENDENCIES = $(RASTERDEP) $(BTREE2DEP) $(SEGMENTDEP) $(GISDEP)
 EXTRA_LIBS = $(OMPLIB)
 EXTRA_CFLAGS = $(OMPCFLAGS)
Modified: grass-addons/grass7/raster/r.gwr/estimate_bw.c
--- grass-addons/grass7/raster/r.gwr/estimate_bw.c	2016-11-21 20:49:11 UTC (rev 69863)
+++ grass-addons/grass7/raster/r.gwr/estimate_bw.c	2016-11-21 20:59:01 UTC (rev 69864)
@@ -140,9 +140,9 @@
 	    readrast(&ybuf3, nrows, ncols);
-	w1 = w_fn(prevbw);
-	w2 = w_fn(bw);
-	w3 = w_fn(nextbw);
+	w1 = calc_weights(prevbw);
+	w2 = calc_weights(bw);
+	w3 = calc_weights(nextbw);
 	/* leave one out: the center cell */
 	w1[prevbw][prevbw] = 0.;
 	w2[bw][bw] = 0.;
Added: grass-addons/grass7/raster/r.gwr/flag.c
--- grass-addons/grass7/raster/r.gwr/flag.c	                        (rev 0)
+++ grass-addons/grass7/raster/r.gwr/flag.c	2016-11-21 20:59:01 UTC (rev 69864)
@@ -0,0 +1,60 @@
+#include <grass/gis.h>
+#include <grass/glocale.h>
+#include "flag.h"
+FLAG *flag_create(int nrows, int ncols)
+    unsigned char *temp;
+    FLAG *new_flag;
+    register int i;
+    new_flag = (FLAG *) G_malloc(sizeof(FLAG));
+    new_flag->nrows = nrows;
+    new_flag->ncols = ncols;
+    new_flag->leng = (ncols + 7) / 8;
+    new_flag->array =
+	(unsigned char **)G_malloc(nrows * sizeof(unsigned char *));
+    if (!new_flag->array)
+	G_fatal_error(_("Out of memory!"));
+    temp =
+	(unsigned char *)G_malloc(nrows * new_flag->leng *
+				  sizeof(unsigned char));
+    if (!temp)
+    for (i = 0; i < nrows; i++) {
+	new_flag->array[i] = temp;
+	temp += new_flag->leng;
+    flag_clear_all(new_flag);
+    return (new_flag);
+int flag_destroy(FLAG * flags)
+    G_free(flags->array[0]);
+    G_free(flags->array);
+    G_free(flags);
+    return 0;
+int flag_clear_all(FLAG * flags)
+    register int r, c;
+    for (r = 0; r < flags->nrows; r++) {
+	for (c = 0; c < flags->leng; c++) {
+	    flags->array[r][c] = 0;
+    return 0;
Added: grass-addons/grass7/raster/r.gwr/flag.h
--- grass-addons/grass7/raster/r.gwr/flag.h	                        (rev 0)
+++ grass-addons/grass7/raster/r.gwr/flag.h	2016-11-21 20:59:01 UTC (rev 69864)
@@ -0,0 +1,64 @@
+#ifndef __FLAG_H__
+#define __FLAG_H__
+/* flag.[ch] is a set of routines which will set up an array of bits
+ ** that allow the programmer to "flag" cells in a raster map.
+ ** FLAG *
+ ** flag_create(nrows,ncols)
+ ** int nrows, ncols;
+ **     opens the structure flag.
+ **     The flag structure will be a two dimensional array of bits the
+ **     size of nrows by ncols.  Will initalize flags to zero (unset).
+ ** flag_destroy(flags)
+ ** FLAG *flags;
+ **     closes flags and gives the memory back to the system.
+ ** flag_clear_all(flags)
+ ** FLAG *flags;
+ **     sets all values in flags to zero.
+ ** flag_unset(flags, row, col)
+ ** FLAG *flags;
+ ** int row, col;
+ **     sets the value of (row, col) in flags to zero.
+ ** flag_set(flags, row, col)
+ ** FLAG *flags;
+ ** int row, col;
+ **     will set the value of (row, col) in flags to one.
+ ** int
+ ** flag_get(flags, row, col)
+ ** FLAG *flags;
+ ** int row, col;
+ **     returns the value in flags that is at (row, col).
+ ** idea by Michael Shapiro
+ ** code by Chuck Ehlschlaeger
+ ** April 03, 1989
+#define FLAG struct _flagsss_
+FLAG {
+    int nrows, ncols, leng;
+    unsigned char **array;
+#define FLAG_UNSET(flags,row,col) \
+	(flags)->array[(row)][(col)>>3] &= ~(1<<((col) & 7))
+#define FLAG_SET(flags,row,col) \
+	(flags)->array[(row)][(col)>>3] |= (1<<((col) & 7))
+#define FLAG_GET(flags,row,col) \
+	(flags)->array[(row)][(col)>>3] & (1<<((col) & 7))
+/* flag.c */
+FLAG *flag_create(int, int);
+int flag_destroy(FLAG *);
+int flag_clear_all(FLAG *);
+#endif /* __FLAG_H__ */
Modified: grass-addons/grass7/raster/r.gwr/gwr.c
--- grass-addons/grass7/raster/r.gwr/gwr.c	2016-11-21 20:49:11 UTC (rev 69863)
+++ grass-addons/grass7/raster/r.gwr/gwr.c	2016-11-21 20:59:01 UTC (rev 69864)
@@ -6,20 +6,13 @@
 #include <grass/raster.h>
 #include "local_proto.h"
+#include "gwr.h"
 /* geographically weighted regression:
  * estimate coefficients for given cell */
-struct MATRIX
+int solvemat(struct MATRIX *m, double a[], double B[])
-    int n;			/* SIZE OF THIS MATRIX (N x N) */
-    double **v;
-#define M(m,row,col) (m)->v[(row)][(col)]
-static int solvemat(struct MATRIX *m, double a[], double B[])
     int i, j, i2, j2, imark;
     double factor, temp, *tempp;
     double pivot;		/* ACTUAL VALUE OF THE LARGEST PIVOT CANDIDATE */
@@ -43,7 +36,7 @@
 	/* co-linear points result in an undefined matrix, and nearly */
 	/* co-linear points results in a solution with rounding error */
-	if (pivot == 0.0) {
+	if (fabs(pivot) < GRASS_EPSILON) {
 	    G_debug(1, "Matrix is unsolvable");
 	    return 0;
@@ -99,7 +92,7 @@
     int nsize;
     static DCELL *xval = NULL;
     DCELL yval;
-    int count, isnull;;
+    int count, isnull, solved;
     /* OLS */
     static double **a = NULL;
     static double **B = NULL;
@@ -210,17 +203,17 @@
 	    count++;
-    /* estimate coefficients */
     if (count < ninx + 1) {
-	G_debug(4, "Not enough valid cells available");
+	G_message(_("Unable to determine coefficients. Consider increasing the bandwidth."));
 	return 0;
+    /* estimate coefficients */
+    solved = ninx + 1;
     for (k = 0; k <= ninx; k++) {
 	m = &(m_all[k]);
@@ -235,17 +228,16 @@
 		fprintf(stdout, "b%d=0.0\n", i);
-	    G_debug(1, "Try a larger bandwidth");
-	    count = 0;
+	    G_debug(1, "Solving matrix %d failed", k);
+	    solved--;
-    if (count < ninx + 1) {
+    if (solved < ninx + 1) {
+	G_debug(3, "%d of %d equation systems could not be solved", ninx + 1 - solved, ninx + 1);
 	return 0;
     /* second pass: calculate estimates */
-    c = cc;
     isnull = 0;
     for (i = 0; i < ninx; i++) {
Added: grass-addons/grass7/raster/r.gwr/gwr.h
--- grass-addons/grass7/raster/r.gwr/gwr.h	                        (rev 0)
+++ grass-addons/grass7/raster/r.gwr/gwr.h	2016-11-21 20:59:01 UTC (rev 69864)
@@ -0,0 +1,10 @@
+struct MATRIX
+    int n;			/* SIZE OF THIS MATRIX (N x N) */
+    double **v;
+#define M(m,row,col) (m)->v[(row)][(col)]
+int solvemat(struct MATRIX *m, double a[], double B[]);
Added: grass-addons/grass7/raster/r.gwr/gwra.c
--- grass-addons/grass7/raster/r.gwr/gwra.c	                        (rev 0)
+++ grass-addons/grass7/raster/r.gwr/gwra.c	2016-11-21 20:59:01 UTC (rev 69864)
@@ -0,0 +1,327 @@
+#include <stdio.h>
+#include <stdlib.h>
+#include <math.h>
+#include <string.h>
+#include <grass/raster.h>
+#include <grass/rbtree.h>
+#include "rclist.h"
+#include "local_proto.h"
+#include "gwr.h"
+/* geographically weighted regression:
+ * estimate coefficients for given cell */
+struct gwr_pnt
+    int r, c;		/* row, col in target window */
+static int cmp_rc(const void *first, const void *second)
+    struct rc *a = (struct rc *)first, *b = (struct rc *)second;
+    if (a->row == b->row)
+	return (a->col - b->col);
+    return (a->row - b->row);
+static int cmp_pnts(const void *first, const void *second)
+    struct gwr_pnt *a = (struct gwr_pnt *)first;
+    struct gwr_pnt *b = (struct gwr_pnt *)second;
+    if (a->r == b->r)
+	return (a->c - b->c);
+    return (a->r - b->r);
+static int bfs_search(FLAG *null_flag, struct gwr_pnt *cur_pnts,
+                      int max_points, int row, int col, double *distmax)
+    int nrows, ncols, rown, coln;
+    int nextr[8] = {0, -1, 0, 1, -1, -1, 1, 1};
+    int nextc[8] = {1, 0, -1, 0, 1, -1, -1, 1};
+    int n, found;
+    struct rc next, ngbr_rc;
+    struct rclist rilist;
+    struct RB_TREE *visited;
+    double dx, dy, dist;
+    visited = rbtree_create(cmp_rc, sizeof(struct rc));
+    ngbr_rc.row = row;
+    ngbr_rc.col = col;
+    rbtree_insert(visited, &ngbr_rc);
+    nrows = Rast_window_rows();
+    ncols = Rast_window_cols();
+    found = 0;
+    *distmax = 0.0;
+    if (FLAG_GET(null_flag, row, col)) {
+	/* add to cur_pnts */
+	cur_pnts[found].r = row;
+	cur_pnts[found].c = col;
+	found++;
+    /* breadth-first search */
+    next.row = row;
+    next.col = col;
+    rclist_init(&rilist);
+    do {
+	for (n = 0; n < 8; n++) {
+	    rown = next.row + nextr[n];
+	    coln = next.col + nextc[n];
+	    if (rown < 0 || rown >= nrows || coln < 0 || coln >= ncols)
+		continue;
+	    ngbr_rc.row = rown;
+	    ngbr_rc.col = coln;
+	    if (rbtree_find(visited, &ngbr_rc))
+		continue;
+	    rclist_add(&rilist, rown, coln);
+	    if (FLAG_GET(null_flag, rown, coln)) {
+		dx = coln - col;
+		dy = rown - row;
+		dist = dx * dx + dy * dy;
+		if (*distmax < dist)
+		    *distmax = dist;
+		cur_pnts[found].r = rown;
+		cur_pnts[found].c = coln;
+		found++;
+	    if (found == max_points)
+		break;
+	    break;
+    } while (rclist_drop(&rilist, &next));   /* while there are cells to check */
+    rclist_destroy(&rilist);
+    rbtree_destroy(visited);
+    return found;
+int gwra(SEGMENT *in_seg, FLAG *null_flag, int ninx, int rr, int cc,
+        int npnts, DCELL *est, double **B0)
+    int r, c, n, nfound;
+    int i, j, k;
+    double bw, maxdist2, dist2, w;
+    static DCELL *xval = NULL, *seg_val = NULL;
+    DCELL yval;
+    static int npnts_alloc = 0;
+    static struct gwr_pnt *cur_pnts = NULL;
+    /* OLS */
+    static double **a = NULL;
+    static double **B = NULL;
+    static struct MATRIX *m_all = NULL;
+    struct MATRIX *m;
+    if (!xval) {
+	xval = G_malloc((ninx + 1) * sizeof(DCELL));
+	xval[0] = 1.;
+	seg_val = G_malloc((ninx + 1) * sizeof(DCELL));
+    if (!m_all) {
+	m_all = (struct MATRIX *)G_malloc((ninx + 1) * sizeof(struct MATRIX));
+	a = (double **)G_malloc((ninx + 1) * sizeof(double *));
+	B = (double **)G_malloc((ninx + 1) * sizeof(double *));
+	m = &(m_all[0]);
+	m->n = ninx + 1;
+	m->v = (double **)G_malloc(m->n * sizeof(double));
+	m->v[0] = (double *)G_malloc(m->n * m->n * sizeof(double));
+	for (i = 1; i < m->n; i++) {
+	    m->v[i] = m->v[i - 1] + m->n;
+	a[0] = (double *)G_malloc(m->n * sizeof(double));
+	B[0] = (double *)G_malloc(m->n * sizeof(double));
+	for (k = 1; k <= ninx; k++) {
+	    m = &(m_all[k]);
+	    m->n = ninx;
+	    m->v = (double **)G_malloc(m->n * sizeof(double*));
+	    a[k] = (double *)G_malloc(m->n * sizeof(double));
+	    B[k] = (double *)G_malloc(m->n * sizeof(double));
+    if (npnts_alloc < npnts) {
+	if (cur_pnts)
+	    G_free(cur_pnts);
+	npnts_alloc = npnts;
+	cur_pnts = G_malloc(sizeof(struct gwr_pnt) * npnts_alloc);
+    for (k = 0; k <= ninx; k++) {
+	m = &(m_all[k]);
+	for (i = 0; i < m->n; i++) {
+	    for (j = i; j < m->n; j++)
+		M(m, i, j) = 0.0;
+	    a[k][i] = 0.0;
+	    B[k][i] = 0.0;
+    Rast_set_d_null_value(est, ninx + 1);
+    if (B0)
+	*B0 = NULL;
+    /* first pass: collect values */
+    nfound = bfs_search(null_flag, cur_pnts, npnts, rr, cc, &maxdist2);
+    qsort(cur_pnts, nfound, sizeof(struct gwr_pnt), cmp_pnts);
+    /* bandwidth */
+    bw = sqrt(maxdist2);
+    /* second pass: load values */
+    count = 0;
+    for (n = 0; n < nfound; n++) {
+	r = cur_pnts[n].r;
+	c = cur_pnts[n].c;
+	Segment_get(in_seg, (void *)seg_val, r, c);
+	isnull = 0;
+	for (i = 0; i < ninx; i++) {
+	    xval[i + 1] = seg_val[i];
+	    if (Rast_is_d_null_value(&(xval[i + 1]))) {
+		isnull = 1;
+		break;
+	if (isnull)
+	    continue;
+	yval = seg_val[ninx];
+	if (Rast_is_d_null_value(&yval))
+	    continue;
+	dist2 = (r - rr) * (r - rr) + (c - cc) * (c - cc);
+	w = w_fn(dist2, bw);
+	for (i = 0; i <= ninx; i++) {
+	    double val1 = xval[i];
+	    for (j = i; j <= ninx; j++) {
+		double val2 = xval[j];
+		m = &(m_all[0]);
+		M(m, i, j) += val1 * val2 * w;
+		/* linear model without predictor k */
+		    if (k != i && k != j) {
+			int i2 = k > i ? i : i - 1;
+			int j2 = k > j ? j : j - 1;
+			m = &(m_all[k]);
+			M(m, i2, j2) += val1 * val2 * w;
+	    a[0][i] += yval * val1 * w;
+		if (k != i) {
+		    a[k][i2] += yval * val1 * w;
+	count++;
+    if (count < ninx + 1) {
+	G_message(_("Unable to determine coefficients. Consider increasing the number of points."));
+	return 0;
+	m = &(m_all[k]);
+	/* TRANSPOSE VALUES IN UPPER HALF OF M TO OTHER HALF */
+	    for (j = 0; j < i; j++)
+		M(m, i, j) = M(m, j, i);
+	if (!solvemat(m, a[k], B[k])) {
+		fprintf(stdout, "b%d=0.0\n", i);
+	    solved--;
+	return 0;
+    /* third pass: calculate estimates */
+    Segment_get(in_seg, (void *)seg_val, rr, cc);
+    isnull = 0;
+	    isnull = 1;
+	    break;
+    if (isnull)
+	return 0;
+    est[0] = 0.0;
+	est[0] += B[0][k] * xval[k];
+	if (k > 0) {
+	    est[k] = 0.0;
+		if (i != k) {
+		    j = k > i ? i : i - 1;
+		    est[k] += B[k][j] * xval[i];
+    if (B0)
+	*B0 = B[0];
+    return count;
Modified: grass-addons/grass7/raster/r.gwr/local_proto.h
--- grass-addons/grass7/raster/r.gwr/local_proto.h	2016-11-21 20:49:11 UTC (rev 69863)
+++ grass-addons/grass7/raster/r.gwr/local_proto.h	2016-11-21 20:59:01 UTC (rev 69864)
@@ -1,11 +1,18 @@
+#include <grass/segment.h>
+#include "flag.h"
 #include "bufs.h"
-extern double ** (*w_fn) (int);
 void set_wfn(char *name, int vfu);
+extern double (*w_fn) (double, double);
+double **calc_weights(int bw);
 int gwr(struct rb *xbuf, int ninx, struct rb *ybuf, int cc,
         int bw, double **w, DCELL *est, double **B0);
+int gwra(SEGMENT *in_seg, FLAG *yflag, int ninx, int rr, int cc,
+        int npnts, DCELL *est, double **B0);
 int estimate_bandwidth(int *inx, int ninx, int iny, int nrows, int ncols,
          DCELL *est, int bw);
Modified: grass-addons/grass7/raster/r.gwr/main.c
--- grass-addons/grass7/raster/r.gwr/main.c	2016-11-21 20:49:11 UTC (rev 69863)
+++ grass-addons/grass7/raster/r.gwr/main.c	2016-11-21 20:59:01 UTC (rev 69864)
@@ -10,7 +10,7 @@
  *               y = b0 + b1*x1 + b2*x2 + ... +  bn*xn + e
  *               with localized b coefficients
- * COPYRIGHT:    (C) 2011 by the GRASS Development Team
+ * COPYRIGHT:    (C) 2011-2016 by the GRASS Development Team
  *               This program is free software under the GNU General Public
  *               License (>=v2). Read the file COPYING that comes with GRASS
@@ -31,7 +31,7 @@
 int main(int argc, char *argv[])
     unsigned int r, c, rows, cols, count;
-    int *mapx_fd, mapy_fd, mapres_fd, mapest_fd;
+    int *mapx_fd, mapy_fd, mapres_fd, mapest_fd, mask_fd;
     int i, j, k, n_predictors;
     double yres;
     double *B, *Bmin, *Bmax, *Bsum, *Bsumsq, *Bmean, Bstddev;
@@ -41,20 +41,25 @@
     double SStot, SSerr, SSreg, *SSerr_without;
     double Rsq, Rsqadj, SE, F, t, AIC, AICc, BIC;
     DCELL *mapx_val, mapy_val, *mapy_buf, *mapres_buf, *mapest_buf;
+    CELL *mask_buf;
     struct rb *xbuf, ybuf;
+    SEGMENT in_seg;
+    DCELL **segx_buf, *seg_val;
+    int segsize, nseg;
+    double mem_mb;
+    FLAG *null_flag;
     struct outputb {
 	int fd;
 	char name[GNAME_MAX];
 	DCELL *buf;
     } *outb, *outbp;
     double **weights;
-    int bw;
+    int bw, npnts;
     char *name;
-    struct Option *input_mapx, *input_mapy,
+    struct Option *input_mapx, *input_mapy, *mask_opt,
                   *output_res, *output_est, *output_b, *output_opt,
-		  *bw_opt, *kernel_opt, *vf_opt;
+		  *kernel_opt, *vf_opt, *bw_opt, *pnts_opt, *mem_opt;
     struct Flag *shell_style, *estimate;
-    /*struct Flag *adaptive;*/
     struct Cell_head region;
     struct GModule *module;
@@ -75,6 +80,12 @@
     input_mapy->key = "mapy";
     input_mapy->description = (_("Map with Y variable"));
+    mask_opt = G_define_standard_option(G_OPT_R_INPUT);
+    mask_opt->key = "mask";
+    mask_opt->label = _("Raster map to use for masking");
+    mask_opt->description = _("Only cells that are not NULL and not zero are processed");
+    mask_opt->required = NO;
     output_res = G_define_standard_option(G_OPT_R_OUTPUT);
     output_res->key = "residuals";
     output_res->required = NO;
@@ -110,7 +121,7 @@
     bw_opt->key = "bandwidth";
     bw_opt->type = TYPE_INTEGER;
     bw_opt->answer = "10";
-    bw_opt->required = YES;
+    bw_opt->required = NO;
     bw_opt->description =
 	(_("Bandwidth of the weighing kernel."));
@@ -123,6 +134,21 @@
     vf_opt->description =
 	(_("Variance factor for Gaussian kernel: variance = bandwith / factor."));
+    pnts_opt = G_define_option();
+    pnts_opt->key = "npoints";
+    pnts_opt->type = TYPE_INTEGER;
+    pnts_opt->required = NO;
+    pnts_opt->answer = "0";
+    pnts_opt->label = _("Number of points for adaptive bandwidth");
+    pnts_opt->description = _("If 0, fixed bandwidth is used");
+    mem_opt = G_define_option();
+    mem_opt->key = "memory";
+    mem_opt->type = TYPE_INTEGER;
+    mem_opt->required = NO;
+    mem_opt->answer = "300";
+    mem_opt->description = _("Memory in MB for adaptive bandwidth");
     shell_style = G_define_flag();
     shell_style->key = 'g';
     shell_style->description = _("Print in shell script style");
@@ -131,10 +157,6 @@
     estimate->key = 'e';
     estimate->description = _("Estimate optimal bandwidth");
-    /*adaptive = G_define_flag();
-    adaptive->key = 'a';
-    adaptive->description = _("Adaptive kernel size");*/
     if (G_parser(argc, argv))
 	exit(EXIT_FAILURE);
@@ -163,9 +185,6 @@
     if (bw < 2)
 	G_fatal_error(_("Option <%s> must be > 1"), bw_opt->key);
-    /*if(adaptive->answer)*/
-        /*IN MAKING*/
     set_wfn(kernel_opt->answer, atoi(vf_opt->answer));
     /* open maps */
@@ -176,6 +195,13 @@
     mapy_fd = Rast_open_old(input_mapy->answer, "");
+    mask_fd = -1;
+    mask_buf = NULL;
+    if (mask_opt->answer) {
+	mask_fd = Rast_open_old(mask_opt->answer, "");
+	mask_buf = Rast_allocate_c_buf();
     for (i = 0; i < n_predictors; i++) {
 	SSerr_without[i] = 0.0;
@@ -192,12 +218,21 @@
 	exit(EXIT_SUCCESS);
+    npnts = 0;
+    if (pnts_opt->answer) {
+	npnts = atoi(pnts_opt->answer);
+	if (npnts != 0 && npnts < n_predictors + 1)
+	    G_fatal_error(_("Option <%s> must be > %d"), pnts_opt->key, n_predictors + 1);
     xbuf = (struct rb *)G_malloc(n_predictors * sizeof(struct rb));
-    for (i = 0; i < n_predictors; i++) {
-	allocate_bufs(&xbuf[i], cols, bw, mapx_fd[i]);
+    if (npnts == 0) {
+	for (i = 0; i < n_predictors; i++) {
+	    allocate_bufs(&xbuf[i], cols, bw, mapx_fd[i]);
+	allocate_bufs(&ybuf, cols, bw, mapy_fd);
-    allocate_bufs(&ybuf, cols, bw, mapy_fd);
     meanY = sumY = 0.0;
@@ -225,32 +260,29 @@
     if (count < (unsigned int) (n_predictors + 1))
 	G_fatal_error(_("Not enough valid cells available"));
+    if (npnts > 0 && (unsigned int) npnts > count)
+	G_fatal_error(_("The number of points for adaptive bandwidth is larger than the number of valid cells"));
     meanY = sumY / count;
     /* residuals output */
+    mapres_fd = -1;
+    mapres_buf = NULL;
     if (output_res->answer) {
 	mapres_fd = Rast_open_new(output_res->answer, DCELL_TYPE);
 	mapres_buf = Rast_allocate_d_buf();
-    else {
-	mapres_fd = -1;
-	mapres_buf = NULL;
     /* estimates output */
+    mapest_fd = -1;
+    mapest_buf = NULL;
     if (output_est->answer) {
 	mapest_fd = Rast_open_new(output_est->answer, DCELL_TYPE);
 	mapest_buf = Rast_allocate_d_buf();
-    else {
-	mapest_fd = -1;
-	mapest_buf = NULL;
     /* gwr for each cell: get estimate */
-    G_message(_("Geographically weighted regression..."));
-    weights = w_fn(bw);
     count = 0;
     mapx_val[0] = 1.0;
     SStot = SSerr = SSreg = 0.0;
@@ -258,13 +290,82 @@
-    /* initialize the raster buffers with 'bw' rows */
-    for (i = 0; i < bw; i++) {
-	for (j = 0; j < n_predictors; j++)
-	    readrast(&(xbuf[j]), rows, cols);
-	readrast(&ybuf, rows, cols);
+    segsize = 0;
+    seg_val = NULL;
+    null_flag = NULL;
+    weights = NULL;
+    if (npnts == 0) {
+	weights = calc_weights(bw);
+	/* initialize the raster buffers with 'bw' rows */
+	for (i = 0; i < bw; i++) {
+	    for (j = 0; j < n_predictors; j++)
+		readrast(&(xbuf[j]), rows, cols);
+	    readrast(&ybuf, rows, cols);
+    else {
+	G_message(_("Loading input maps to temporary file..."));
+	segsize = sizeof(DCELL) * (n_predictors + 1);
+	seg_val = G_malloc(segsize);
+	segx_buf = G_malloc(sizeof(DCELL *) * n_predictors);
+	    segx_buf[i] = Rast_allocate_d_buf();
+	mem_mb = 300;
+	if (mem_opt->answer)
+	    mem_mb = atoi(mem_opt->answer);
+	if (mem_mb < 10)
+	    mem_mb = 10;
+	nseg = mem_mb * 1024.0 / (64 * 64 * segsize);
+	Segment_open(&in_seg, G_tempfile(), rows, cols, 64, 64,
+	             segsize, nseg);
+	null_flag = flag_create(rows, cols);
+	for (r = 0; r < rows; r++) {
+	    G_percent(r, rows, 2);
+		Rast_get_d_row(mapx_fd[i], segx_buf[i], r);
+	    Rast_get_d_row(mapy_fd, mapy_buf, r);
+	    for (c = 0; c < cols; c++) {
+		int x_null;
+		x_null = 0;
+		    seg_val[i] = segx_buf[i][c];
+		    if (Rast_is_d_null_value(&seg_val[i])) {
+			Rast_set_d_null_value(seg_val, n_predictors + 1);
+			x_null = 1;
+			break;
+		if (!x_null) {
+		    seg_val[n_predictors] = mapy_buf[c];
+		if (Segment_put(&in_seg, (void *)seg_val, r, c) != 1)
+		    G_fatal_error(_("Unable to write to temporary file"));
+		if (!x_null && !Rast_is_d_null_value(&mapy_buf[c]))
+		    FLAG_SET(null_flag, r, c);
+	G_percent(1, 1, 1);
+	    G_free(segx_buf[i]);
+	G_free(segx_buf);
+    G_free(mapy_buf);
     /* initialize coefficient statistics */
     Bmin = G_malloc((n_predictors + 1) * sizeof(double));
     Bmax = G_malloc((n_predictors + 1) * sizeof(double));
@@ -293,15 +394,20 @@
+    G_message(_("Geographically weighted regression..."));
-	    readrast(&(xbuf[i]), rows, cols);
+	if (npnts == 0) {
+		readrast(&(xbuf[i]), rows, cols);
+	if (mask_buf)
+	    Rast_get_c_row(mask_fd, mask_buf, r);
 	if (mapres_buf)
 	    Rast_set_d_null_value(mapres_buf, cols);
 	if (mapest_buf)
@@ -316,21 +422,43 @@
 	    int isnull = 0;
+	    if (mask_buf) {
+		if (Rast_is_c_null_value(&mask_buf[c]) || mask_buf[c] == 0)
+		    continue;
-		mapx_val[i + 1] = xbuf[i].buf[bw][c + bw];
-		if (Rast_is_d_null_value(&(mapx_val[i + 1]))) {
+	    if (npnts == 0) {
+		    mapx_val[i + 1] = xbuf[i].buf[bw][c + bw];
+		    if (Rast_is_d_null_value(&(mapx_val[i + 1]))) {
+			isnull = 1;
+			break;
+		mapy_val = ybuf.buf[bw][c + bw];
+	    else {
+		Segment_get(&in_seg, (void *)seg_val, r, c);
+		if (Rast_is_d_null_value(&(seg_val[0]))) {
 		    isnull = 1;
-		    break;
+		mapy_val = seg_val[n_predictors];
 	    if (isnull)
 		continue;
-	    if (!gwr(xbuf, n_predictors, &ybuf, c, bw, weights, yest, &B)) {
-		G_warning(_("Unable to determine coefficients. Consider increasing the bandwidth."));
-		continue;
+	    if (npnts == 0) {
+		if (!gwr(xbuf, n_predictors, &ybuf, c, bw, weights, yest, &B)) {
+		    continue;
+	    else {
+		if (!gwra(&in_seg, null_flag, n_predictors, r, c, npnts, yest, &B)) {
+		    continue;
 	    /* coefficient stats */
 	    for (i = 0; i <= n_predictors; i++) {
@@ -353,7 +481,6 @@
 	    if (mapest_buf)
 		mapest_buf[c] = yest[0];
-	    mapy_val = ybuf.buf[bw][c + bw];
 	    if (Rast_is_d_null_value(&mapy_val))
 		continue;
@@ -507,8 +634,13 @@
 	Rast_close(mapx_fd[i]);
     Rast_close(mapy_fd);
-    G_free(mapy_buf);
+    if (mask_buf)
+	Rast_close(mask_fd);
+    if (npnts > 0)
+	Segment_close(&in_seg);
     if (mapres_fd > -1) {
 	struct History history;
Modified: grass-addons/grass7/raster/r.gwr/r.gwr.html
--- grass-addons/grass7/raster/r.gwr/r.gwr.html	2016-11-21 20:49:11 UTC (rev 69863)
+++ grass-addons/grass7/raster/r.gwr/r.gwr.html	2016-11-21 20:59:01 UTC (rev 69864)
@@ -77,9 +77,18 @@
 produce results similar to a global regression, and spatial
 non-stationarity can not be explored.
+<h4>Adaptive bandwidth</h4>
+Instead of using a fixed bandwidth (search radius for each cell), an
+adaptive bandwidth can be used by specifying the number of points to be
+used for each local regression with the <em>npoints</em> option. The
+module will find the nearest <em>npoints</em> points for each cell,
+adapt the bandwith accordingly and then calculate a local weighted
+regression.
 <h4>Kernel functions</h4>
-The kernel function has little influence on the result, much more important is the
-bandwidth. Available kernel funtions to calculate weights are
+The kernel function has little influence on the result, much more
+important is the bandwidth. Available kernel funtions to calculate
+weights are
 <dl>
 <dt><b>Epanechnikov</b></dt>
@@ -97,6 +106,10 @@
 d = distance to the current cell<br>
 bw = bandwidth
+<h4>Masking</h4>
+A <em>mask</em> map can be provided to restrict LWR to those cells
+where the mask map is not NULL and not 0 (zero).
 <h2>REFERENCES</h2>
 Brunsdon, C., Fotheringham, A.S., and Charlton, M.E., 1996,
Added: grass-addons/grass7/raster/r.gwr/rclist.c
--- grass-addons/grass7/raster/r.gwr/rclist.c	                        (rev 0)
+++ grass-addons/grass7/raster/r.gwr/rclist.c	2016-11-21 20:59:01 UTC (rev 69864)
@@ -0,0 +1,68 @@
+void rclist_init(struct rclist *list)
+    list->head = list->tail = NULL;
+    return;
+void rclist_add(struct rclist *list, int row, int col)
+    struct rc *new = G_malloc(sizeof(struct rc));
+    if (!new)
+	G_fatal_error(_("rclist out of memory"));
+    new->next = NULL;
+    new->row = row;
+    new->col = col;
+    if (list->head) {
+	list->head->next = new;
+	list->head = new;
+    else {
+	list->head = list->tail = new;
+    return;
+/* return 1 if an element was dropped
+ * return 0 if list is empty
+int rclist_drop(struct rclist *list, struct rc *rc)
+    if (list->tail) {
+	struct rc *next = list->tail->next;
+	rc->row = list->tail->row;
+	rc->col = list->tail->col;
+	G_free(list->tail);
+	list->tail = next;
+	if (!list->tail)
+	    list->head = NULL;
+	return 1;
+    return 0;
+void rclist_destroy(struct rclist *list)
+    struct rc *next = list->tail;
+    while (next) {
+	next = next->next;
+    return;
Added: grass-addons/grass7/raster/r.gwr/rclist.h
--- grass-addons/grass7/raster/r.gwr/rclist.h	                        (rev 0)
+++ grass-addons/grass7/raster/r.gwr/rclist.h	2016-11-21 20:59:01 UTC (rev 69864)
@@ -0,0 +1,20 @@
+/* row/col list */
+struct rc
+    struct rc *next;
+    int row;
+    int col;
+struct rclist
+    struct rc *tail, *head;
+/* rclist.c */
+void rclist_init(struct rclist *);
+void rclist_add(struct rclist *, int, int);
+int rclist_drop(struct rclist *, struct rc *);
+void rclist_destroy(struct rclist *);
Modified: grass-addons/grass7/raster/r.gwr/weights.c
--- grass-addons/grass7/raster/r.gwr/weights.c	2016-11-21 20:49:11 UTC (rev 69863)
+++ grass-addons/grass7/raster/r.gwr/weights.c	2016-11-21 20:59:01 UTC (rev 69864)
@@ -10,99 +10,72 @@
 static double vf = -0.5;
-double ** (*w_fn) (int);
+double (*w_fn) (double, double);
-double **epanechnikov(int bw)
+double epanechnikov(double d2, double bw)
-    int r, c;
-    double bw2, bw2d, d, **w;
+    double bw2, bw2d, w;
-    w = G_alloc_matrix(bw * 2 + 1, bw * 2 + 1);
     bw2 = (bw + 1);
     bw2d = bw * bw;
-    for (r = -bw; r <= bw; r++) {
-	for (c = -bw; c <= bw; c++) {
-	    d = r * r + c * c;
-	    w[r + bw][c + bw] = 0;
-	    if (d <= bw2d) {
-		w[r + bw][c + bw] = 1 - d / bw2;
+    w = 0;
+    if (d2 <= bw2d) {
+	w = 1 - d2 / bw2;
     return w;
-double **bisquare(int bw)
+double bisquare(double d2, double bw)
-    int r, c;
-    double bw2, bw2d, d, **w, t;
+    double bw2, bw2d, w, t;
     bw2 = (bw + 1) * (bw + 1);
     bw2d = bw * bw;
-	    if (d <= bw2d) {
-		t = 1 - d / bw2;
-		w[r + bw][c + bw] = t * t;
+    w = 0;
+    if (d2 <= bw2d) {
+	t = 1 - d2 / bw2;
+	w = t * t;
     return w;
-double **tricubic(int bw)
+double tricubic(double d2, double bw)
-    int r, c;
-    double bw3, bw3d, d, **w, t;
+    double bw3, bw3d, w, d3, t;
     bw3 = (bw + 1) * (bw + 1) * (bw + 1);
     bw3d = bw * bw * bw;
-	    d = sqrt(r * r + c * c);
-	    d = d * d * d;
-	    if (d <= bw3d) {
-		t = 1 - d / bw3;
-		w[r + bw][c + bw] = t * t * t;
+    d3 = sqrt(d2);
+    d3 = d3 * d3 * d3;
+    w = 0;
+    if (d3 <= bw3d) {
+	t = 1 - d3 / bw3;
+	w = t * t * t;
     return w;
-double **gauss(int bw)
+double gauss(double d2, double bw)
-    int r, c;
-    double bw2, d, **w;
+    double bw2, w;
     bw2 = bw * bw;
     /* Gaussian function: exp(-x^2 / ( 2 * variance) */
+    w = 0;
-	    if (d <= bw2) {
-		w[r + bw][c + bw] = exp(vf * d / bw2);
+    if (d2 <= bw2) {
+	w = exp(vf * d2 / bw2);
     return w;
@@ -124,3 +97,24 @@
     else
 	G_fatal_error(_("Invalid kernel option '%s'"), name);
+    int r, c, count;
+    double d2, **w;
+    w = G_alloc_matrix(bw * 2 + 1, bw * 2 + 1);
+    count = 0;
+    for (r = -bw; r <= bw; r++) {
+	for (c = -bw; c <= bw; c++) {
+	    d2 = r * r + c * c;
+	    w[r + bw][c + bw] = w_fn(d2, bw);
+	    if (w[r + bw][c + bw] > 0)
+		count++;
+    G_verbose_message(_("%d cells for bandwidth %d"), count, bw);
+    return w;
