[GRASS-SVN] r69617 - in grass/branches/releasebranch_7_2/lib/python/script: . testsuite
svn_grass at osgeo.org
Sat Oct 1 10:50:07 PDT 2016
Author: wenzeslaus
Date: 2016-10-01 10:50:06 -0700 (Sat, 01 Oct 2016)
New Revision: 69617
grass/branches/releasebranch_7_2/lib/python/script/testsuite/test_start_command_functions.py
grass/branches/releasebranch_7_2/lib/python/script/testsuite/test_utils.py
grass/branches/releasebranch_7_2/lib/python/script/utils.py
pythonlib: use isinstance to distinguish string types (meant to fix r65787, needed for r65804 according to #3171)
Modified: grass/branches/releasebranch_7_2/lib/python/script/testsuite/test_start_command_functions.py
--- grass/branches/releasebranch_7_2/lib/python/script/testsuite/test_start_command_functions.py 2016-10-01 17:15:30 UTC (rev 69616)
+++ grass/branches/releasebranch_7_2/lib/python/script/testsuite/test_start_command_functions.py 2016-10-01 17:50:06 UTC (rev 69617)
@@ -1,3 +1,5 @@
+# -*- coding: utf-8 -*-
+# the utf-8 is important because we do use the characters
"""Tests of start_command function family (location independent)"""
from grass.gunittest.case import TestCase
@@ -3,5 +5,5 @@
from grass.gunittest.main import test
-from grass.script.core import start_command, PIPE
+from grass.script.core import start_command, PIPE, run_command
@@ -38,5 +40,28 @@
self.assertEquals(returncode, 1)
self.assertIn(b'raster', stderr)
+class TestPythonModuleWithUnicodeParameters(TestCase):
+ """Tests if unicode works in parameters of Python modules
+ This in fact tests also the `parser()` function (original motivation
+ for this tests).
+ Using g.search.module because it takes any option values.
+ def test_python_module_ascii(self):
+ """This tests if Python module works"""
+ run_command('g.search.modules', keyword=b'Priserny kun')
+ def test_python_module_czech_nonascii(self):
+ """This likely fails on non-UTF-8 systems (i.e. MS Win)"""
+ run_command('g.search.modules', keyword=b'Příšerný kůň')
+ def test_python_module_czech_unicode(self):
+ run_command('g.search.modules', keyword=u'Příšerný kůň')
if __name__ == '__main__':
test()
Modified: grass/branches/releasebranch_7_2/lib/python/script/testsuite/test_utils.py
--- grass/branches/releasebranch_7_2/lib/python/script/testsuite/test_utils.py 2016-10-01 17:15:30 UTC (rev 69616)
+++ grass/branches/releasebranch_7_2/lib/python/script/testsuite/test_utils.py 2016-10-01 17:50:06 UTC (rev 69617)
@@ -39,7 +39,11 @@
def test_unicode(self):
self.assertEqual(b'text', utils.encode(u'text'))
+ def test_bytes_grabage_in_out(self):
+ """If the input is bytes we should not touch it for encoding"""
+ self.assertEqual(b'Příšerný kůň', utils.encode(b'Příšerný kůň'))
class TestDecode(TestCase):
"""Tests function `encode` that convert value to unicode."""
Modified: grass/branches/releasebranch_7_2/lib/python/script/utils.py
--- grass/branches/releasebranch_7_2/lib/python/script/utils.py 2016-10-01 17:15:30 UTC (rev 69616)
+++ grass/branches/releasebranch_7_2/lib/python/script/utils.py 2016-10-01 17:50:06 UTC (rev 69617)
@@ -150,26 +150,31 @@
self[key] = value
-def decode(bytes):
- """Decode bytes with default locale
+def decode(bytes_):
+ """Decode bytes with default locale and return (unicode) string
- :param bytes bytes: the bytes to decode
+ No-op if parameter is not bytes (assumed unicode string).
+ :param bytes bytes_: the bytes to decode
- enc = locale.getdefaultlocale()[1]
- if hasattr(bytes, 'decode'):
- return bytes.decode(enc) if enc else bytes.decode()
- return bytes
+ if isinstance(bytes_, bytes):
+ enc = locale.getdefaultlocale()[1]
+ return bytes_.decode(enc) if enc else bytes_.decode()
+ return bytes_
def encode(string):
- """Encode string with default locale -> bytes
+ """Encode string with default locale and return bytes with that encoding
+ No-op if parameter is bytes (assumed already encoded).
+ This ensures garbage in, garbage out.
:param str string: the string to encode
+ if isinstance(string, bytes):
+ return string
- if hasattr(string, 'encode'):
- return string.encode(enc) if enc else string.encode()
- return string
+ return string.encode(enc) if enc else string.encode()
def parse_key_val(s, sep='=', dflt=None, val_type=None, vsep=None):
