Author: annakrat
Date: 2016-10-01 11:10:29 -0700 (Sat, 01 Oct 2016)
New Revision: 69618
grass-addons/grass7/vector/v.surf.icw/v.surf.icw.py
v.surf.icw: write temporary maps into file instead of passing through command line (by mlennert), see #2574
Modified: grass-addons/grass7/vector/v.surf.icw/v.surf.icw.py
--- grass-addons/grass7/vector/v.surf.icw/v.surf.icw.py 2016-10-01 17:50:06 UTC (rev 69617)
+++ grass-addons/grass7/vector/v.surf.icw/v.surf.icw.py 2016-10-01 18:10:29 UTC (rev 69618)
@@ -126,12 +126,14 @@
import grass.script as grass
from grass.exceptions import CalledModuleError
+TMP_FILE = None
def cleanup():
grass.verbose(_("Cleanup.."))
tmp_base = 'tmp_icw_' + str(os.getpid()) + '_'
grass.run_command('g.remove', flags = 'f', type = 'raster', pattern = tmp_base + '*',
quiet = True)
+ grass.try_remove(TMP_FILE)
def main():
@@ -381,14 +383,19 @@
grass.message(_("Summation of cost weights ..."))
input_maps = tmp_base + '1by_cost_site_sq.%05d' % 1
- for i in range(2, n+1):
- input_maps += ',%s1by_cost_site_sq.%05d' % (tmp_base, i)
+ global TMP_FILE
+ TMP_FILE = grass.tempfile()
+ with open(TMP_FILE, 'w') as maplist:
+ for i in range(2, n+1):
+ mapname = '%s1by_cost_site_sq.%05d' % (tmp_base, i)
+ maplist.write(mapname + '\n')
#grass.run_command('g.list', type = 'raster', mapset = '.')
sum_of_1by_cost_sqs = tmp_base + 'sum_of_1by_cost_sqs'
try:
- grass.run_command('r.series', method='sum', input=input_maps,
+ grass.run_command('r.series', method='sum', file=TMP_FILE,
output=sum_of_1by_cost_sqs)
except CalledModuleError:
grass.fatal(_('Problem running %s') % 'r.series')
