[GRASS-SVN] r69619 - grass/trunk/display/d.barscale
svn_grass at osgeo.org
Sat Oct 1 12:51:11 PDT 2016
Author: annakrat
Date: 2016-10-01 12:51:11 -0700 (Sat, 01 Oct 2016)
New Revision: 69619
grass/trunk/display/d.barscale/draw_scale.c
grass/trunk/display/d.barscale/main.c
grass/trunk/display/d.barscale/options.h
d.barscale: improve layout, use variables instead of magick numbers, add width_scale variable to scale barscale for different resolutions
Modified: grass/trunk/display/d.barscale/draw_scale.c
--- grass/trunk/display/d.barscale/draw_scale.c 2016-10-01 18:10:29 UTC (rev 69618)
+++ grass/trunk/display/d.barscale/draw_scale.c 2016-10-01 19:51:11 UTC (rev 69619)
@@ -63,7 +63,7 @@
int draw_scale(double east, double north, int length, int seg, int units,
- char *label_cstm, int style, int text_posn, double fontsize)
+ char *label_cstm, int style, int text_posn, double width_scale, double fontsize)
double meters;
double line_len;
@@ -82,6 +82,8 @@
double symbol_size;
char *label;
double size;
+ double xspace_bf_N, x_pos_start, xspace_around_line, xsize_N;
+ double ysize, ysize_solid, ysize_checker, ysize_ticks;
/* Establish text size */
@@ -133,70 +135,68 @@
D_setup_unity(0);
+ /* setup size variables */
+ xspace_bf_N = 5 * width_scale;
+ xspace_around_line = 10 * width_scale;
+ xsize_N = 10 * width_scale;
+ x_pos_start = x_pos + (north_arrow ? (xspace_bf_N + xsize_N + xspace_around_line) : xspace_around_line);
+ ysize = 30 * width_scale;
+ ysize_solid = 8 * width_scale;
+ ysize_checker = 6 * width_scale;
+ ysize_ticks = 20 * width_scale; /* the length of the edge tick */
if (do_background) {
/* Blank out area with background color */
D_get_text_box(label, &tt, &tb, &tl, &tr);
+ pl = x_pos + 0;
+ pr = x_pos + line_len + 2 * xspace_around_line +
+ (north_arrow ? xspace_bf_N + xsize_N : 0);
if (text_posn == TEXT_OVER) {
- pr = x_pos + 35 + line_len;
- pl = x_pos + 0;
- pt = y_pos + tb - 5;
- pb = y_pos + 30;
- if (style != STYLE_CLASSIC_BAR && style != STYLE_THIN_WITH_ENDS)
- pl += 15;
+ pt = y_pos + tb - 5 * width_scale;
+ pb = y_pos + ysize;
if (style == STYLE_TICKS_DOWN)
- pb += 12;
+ pb += 12 * width_scale;
if (text_posn == TEXT_UNDER) {
- pl = x_pos + 0;
pt = y_pos + 0;
- pb = y_pos + 30 - tb + 5;
- pl += 15;
+ pb = y_pos + ysize - tb + 5 * width_scale;
if (style == STYLE_TICKS_UP)
- pt -= 12;
+ pt -= 12 * width_scale;
else if (text_posn == TEXT_RIGHT) {
- pr = x_pos + 35 + line_len + tr + 5;
- pl = x_pos + 0;
+ pr = pr + tr + xspace_around_line;
pt = y_pos + 0;
- pb = y_pos + 30;
if (style == STYLE_TICKS_UP) {
- pt -= 12;
- pb -= 6;
- pl += 15;
+ pb -= 6 * width_scale;
if (style == STYLE_TICKS_DOWN) {
- pt += 4;
- pb += 12;
- pl += 15;
+ pt += 4 * width_scale;
else if (text_posn == TEXT_LEFT) {
- pl = x_pos - tr - 13;
+ pl = x_pos - tr - 13 * width_scale;
pt = y_pos + 0;
- pb = y_pos + 30;
- pt -= 12;
- pb -= 4;
+ pb -= 4 * width_scale;
- pt += 3;
- pb += 11;
+ pt += 3 * width_scale;
+ pb += 11 * width_scale;
if (fontsize < 0) { /* no text */
+ pl = x_pos + 0;
switch (style) {
case STYLE_CLASSIC_BAR:
case STYLE_THIN_WITH_ENDS:
- pl = x_pos + 0;
- pt = y_pos + 0;
- pb = y_pos + 30;
- break;
case STYLE_PART_CHECKER:
case STYLE_FULL_CHECKER:
case STYLE_MIXED_CHECKER:
@@ -205,22 +205,16 @@
case STYLE_HOLLOW_BAR:
case STYLE_TICKS_BOTH:
case STYLE_ARROW_ENDS:
- pl = x_pos + 15;
pt = y_pos + 0;
- pb = y_pos + 30;
break;
case STYLE_TICKS_UP:
- pl = x_pos + 15;
- pt = y_pos - 12;
- pb = y_pos + 25;
+ pt = y_pos - 12 * width_scale;
+ pb = y_pos + 25 * width_scale;
break;
case STYLE_TICKS_DOWN:
- pl = x_pos + 15;
- pt = y_pos + 3;
- pb = y_pos + 40;
+ pt = y_pos + 3 * width_scale;
+ pb = y_pos + 40 * width_scale;
break;
default:
G_fatal_error(_("Programmer error"));
@@ -236,7 +230,6 @@
pl = l;
if (pr > r)
pr = r;
D_use_color(bg_color);
D_box_abs(pl, pt, pr, pb);
@@ -245,16 +238,16 @@
D_use_color(fg_color);
if (north_arrow) {
D_begin();
- D_move_abs(x_pos + 5, y_pos + 20);
- D_cont_rel(0, -10);
- D_cont_rel(10, 10);
- D_move_rel(-5, 14);
- D_cont_rel(0, -17);
- D_cont_rel(-2.5, -0);
- D_cont_rel(2.5, -4);
- D_cont_rel(2.5, 4);
+ D_move_abs(x_pos + xspace_bf_N, y_pos + 2 * ysize / 3);
+ D_cont_rel(0, -10 * width_scale);
+ D_cont_rel(10 * width_scale, 10 * width_scale);
+ D_move_rel(-5 * width_scale, 14 * width_scale);
+ D_cont_rel(0, -17 * width_scale);
+ D_cont_rel(-2.5 * width_scale, -0);
+ D_cont_rel(2.5 * width_scale, -4 * width_scale);
+ D_cont_rel(2.5 * width_scale, 4 * width_scale);
D_close();
D_end();
D_stroke();
@@ -264,87 +257,87 @@
and (x_pos + 25 + line_len, y_pos + 15) */
if (style == STYLE_CLASSIC_BAR) {
D_begin();
- D_move_abs(x_pos + 25, y_pos + 17);
- /* actual width is line_len-1+1=line_len and height is 4+1=5 */
+ D_move_abs(x_pos_start, y_pos + ysize / 2 + ysize_checker / 2);
+ /* actual width is line_len-1+1=line_len */
D_cont_rel(line_len - 1, 0);
- D_cont_rel(0, -4);
+ D_cont_rel(0, -ysize_checker);
D_cont_rel(-line_len + 1, 0);
- D_cont_rel(0, 4);
+ D_cont_rel(0, ysize_checker);
D_end();
D_close();
D_stroke();
for (i = 1; i <= seg; i += 2) {
/* width is seg_len and height is 5 */
- D_box_rel(seg_len, -4);
+ D_box_rel(seg_len, -ysize_checker);
D_pos_rel(seg_len * 2, 0);
else if (style == STYLE_THIN_WITH_ENDS) {
/* draw simple line scale */
D_begin();
- D_move_abs(x_pos + 25, y_pos + 5);
- D_cont_abs(x_pos + 25, y_pos + 25);
- D_move_abs(x_pos + 25, y_pos + 15);
- D_cont_abs(x_pos + 25 + line_len, y_pos + 15);
- D_move_abs(x_pos + 25 + line_len, y_pos + 5);
- D_cont_abs(x_pos + 25 + line_len, y_pos + 25);
+ D_move_abs(x_pos_start, y_pos + (ysize - ysize_ticks) / 2);
+ D_cont_abs(x_pos_start, y_pos + ysize - (ysize - ysize_ticks) / 2);
+ D_move_abs(x_pos_start, y_pos + ysize / 2);
+ D_cont_abs(x_pos_start + line_len, y_pos + ysize / 2);
+ D_move_abs(x_pos_start + line_len, y_pos + (ysize - ysize_ticks) / 2);
+ D_cont_abs(x_pos_start + line_len, y_pos + ysize - (ysize - ysize_ticks) / 2);
D_close();
D_end(); /* no-op? */
else if (style == STYLE_SOLID_BAR) {
/* draw simple solid-bar scale */
xarr[0] = 0;
- yarr[0] = +8;
+ yarr[0] = ysize_solid;
xarr[1] = line_len;
yarr[1] = 0;
xarr[2] = 0;
- yarr[2] = -8;
+ yarr[2] = -ysize_solid;
xarr[3] = -line_len;
yarr[3] = 0;
xarr[4] = 0;
- yarr[4] = +8;
+ yarr[4] = ysize_solid;
- D_move_abs(x_pos + 25, y_pos + 15 - 4);
+ D_move_abs(x_pos_start, y_pos + ysize / 2 - ysize_solid / 2);
D_polygon_rel(xarr, yarr, 5);
else if (style == STYLE_HOLLOW_BAR) {
/* draw hollow-bar scale */
D_begin();
- D_cont_rel(0, +8);
+ D_cont_rel(0, ysize_solid);
D_cont_rel(line_len, 0);
- D_cont_rel(0, -8);
+ D_cont_rel(0, -ysize_solid);
D_cont_rel(-line_len, 0);
D_close();
else if (style == STYLE_FULL_CHECKER) {
D_begin();
- D_move_abs(x_pos + 25, y_pos + 15 + 6);
+ D_move_abs(x_pos_start, y_pos + ysize / 2 + ysize_checker);
/* actual width is line_len-1+1=line_len and height is 7+1=8 */
- D_cont_rel(0, -12);
+ D_cont_rel(0, -2 * ysize_checker);
- D_cont_rel(0, +12);
+ D_cont_rel(0, +2 * ysize_checker);
D_close();
D_stroke();
- D_pos_rel(0, -6);
+ D_pos_rel(0, -ysize_checker);
for (i = 1; i <= seg; i++) {
xarr[0] = 0;
yarr[0] = 0;
xarr[1] = seg_len;
yarr[1] = 0;
xarr[2] = 0;
- yarr[2] = (i % 2 ? -6 : 6);
+ yarr[2] = (i % 2 ? -ysize_checker : ysize_checker);
xarr[3] = -seg_len;
yarr[3] = 0;
xarr[4] = 0;
- yarr[4] = (i % 2 ? 6 : -6);
+ yarr[4] = (i % 2 ? ysize_checker : -ysize_checker);
/* width is seg_len and height is 6 */
D_pos_rel(seg_len, 0);
@@ -352,17 +345,17 @@
else if (style == STYLE_PART_CHECKER) {
D_begin();
D_close();
D_stroke();
- D_pos_rel(0, -6);
if (i <= (seg == 5 ? 2 : 4)) {
xarr[0] = 0;
@@ -370,11 +363,11 @@
xarr[1] = seg_len / 2.;
yarr[1] = 0;
xarr[2] = 0;
- yarr[2] = -6;
+ yarr[2] = -ysize_checker;
xarr[3] = -seg_len / 2.;
yarr[3] = 0;
xarr[4] = 0;
- yarr[4] = 6;
+ yarr[4] = ysize_checker;
D_pos_rel(seg_len / 2., 0);
@@ -383,11 +376,11 @@
yarr[1] = 0;
xarr[2] = 0;
- yarr[2] = 6;
+ yarr[2] = ysize_checker;
yarr[3] = 0;
xarr[4] = 0;
- yarr[4] = -6;
+ yarr[4] = -ysize_checker;
@@ -397,11 +390,11 @@
xarr[1] = seg_len;
yarr[1] = 0;
xarr[2] = 0;
xarr[3] = -seg_len;
yarr[3] = 0;
xarr[4] = 0;
@@ -410,21 +403,21 @@
else if (style == STYLE_MIXED_CHECKER) {
D_begin();
/* horizontal line across the middle to separate white from white */
D_close();
D_stroke();
if (i <= (seg == 5 ? 2 : 6)) {
@@ -434,11 +427,11 @@
xarr[1] = seg_len;
yarr[1] = 0;
xarr[2] = 0;
- yarr[2] = -6;
xarr[3] = -seg_len;
yarr[3] = 0;
xarr[4] = 0;
- yarr[4] = +6;
+ yarr[4] = +ysize_checker;
@@ -447,11 +440,11 @@
yarr[1] = 0;
xarr[2] = 0;
- yarr[2] = +6;
+ yarr[2] = +ysize_checker;
yarr[3] = 0;
xarr[4] = 0;
- yarr[4] = -6;
@@ -462,30 +455,30 @@
xarr[1] = seg_len;
yarr[1] = 0;
xarr[2] = 0;
- yarr[2] = (i % 2 ? 6 : +6);
+ yarr[2] = (i % 2 ? ysize_checker : +ysize_checker);
xarr[3] = -seg_len;
yarr[3] = 0;
xarr[4] = 0;
- yarr[4] = (i % 2 ? -6 : 6);
+ yarr[4] = (i % 2 ? -ysize_checker : ysize_checker);
- D_pos_rel(seg_len, -6);
+ D_pos_rel(seg_len, -ysize_checker);
else if (style == STYLE_TAIL_CHECKER) {
/* first draw outside box */
D_begin();
D_close();
D_stroke();
- D_pos_rel(0, -6);
for (i = 1; i <= (seg == 5 ? 3 : 5); i++) {
xarr[0] = 0;
@@ -493,23 +486,23 @@
xarr[1] = seg_len;
yarr[1] = 0;
xarr[2] = 0;
xarr[3] = -seg_len;
yarr[3] = 0;
xarr[4] = 0;
/* draw a vertical cross line */
D_begin();
- D_move_rel(0, 6);
+ D_move_rel(0, ysize_checker);
D_close();
D_stroke();
- D_pos_rel(0, 6);
+ D_pos_rel(0, ysize_checker);
xarr[0] = 0;
yarr[0] = 0;
xarr[1] = line_len / 2.;
@@ -517,49 +510,49 @@
xarr[1] -= seg_len / 2.;
yarr[1] = 0;
xarr[2] = 0;
- yarr[2] = 6;
xarr[3] = -line_len / 2.;
if (seg == 5)
xarr[3] += seg_len / 2.;
yarr[3] = 0;
xarr[4] = 0;
- yarr[4] = -6;
else if (style == STYLE_TICKS_BOTH) {
/* draw simple line scale with corssing ticks */
D_begin();
- D_move_rel(0, +6);
+ D_move_rel(0, ysize_ticks / 4);
for (i = 0; i <= seg - 2; i++) {
D_move_rel(seg_len, 0);
- D_cont_rel(0, -11); /* 5 above, on px on line, and 5 below */
- D_move_rel(0, +11);
+ D_cont_rel(0, -ysize_ticks/2); /* 5 above, on px on line, and 5 below */
+ D_move_rel(0, +ysize_ticks/2);
else if (style == STYLE_TICKS_UP) {
/* draw simple line scale with up facing ticks */
D_begin();
- D_move_abs(x_pos + 25, y_pos - 2);
- D_cont_abs(x_pos + 25, y_pos + 15);
- D_move_abs(x_pos + 25 + line_len, y_pos - 2);
+ D_move_abs(x_pos_start, y_pos - 2 * width_scale);
+ D_cont_abs(x_pos_start, y_pos + ysize / 2);
+ D_move_abs(x_pos_start + line_len,y_pos - 2 * width_scale);
- D_cont_rel(0, -7); /* 5 above, on px on line, and 5 below */
- D_move_rel(0, +7);
D_close();
@@ -567,17 +560,17 @@
else if (style == STYLE_TICKS_DOWN) {
/* draw simple line scale with down facing ticks */
D_begin();
- D_move_abs(x_pos + 25, y_pos + 15 + 17);
- D_move_abs(x_pos + 25 + line_len, y_pos + 15 + 17);
+ D_move_abs(x_pos_start, y_pos + ysize / 2 + 17 * width_scale);
+ D_move_abs(x_pos_start + line_len, y_pos + ysize / 2 + 17 * width_scale);
- D_cont_rel(0, +7); /* 5 above, on px on line, and 5 below */
- D_move_rel(0, -7);
+ D_cont_rel(0, +ysize_ticks/2); /* 5 above, on px on line, and 5 below */
+ D_move_rel(0, -ysize_ticks/2);
D_close();
@@ -585,8 +578,8 @@
else if (style == STYLE_ARROW_ENDS) {
/* draw line scale with |<--dimension arrows-->| on the ends */
D_begin();
D_end();
/* display the symbol */
@@ -609,10 +602,10 @@
fill_color->b = (unsigned char)B;
fill_color->a = RGBA_COLOR_OPAQUE;
- symbol_size = 12;
+ symbol_size = 12 * width_scale;
- x0 = D_d_to_u_col(x_pos + 25);
- y0 = D_d_to_u_row(y_pos + 15);
+ x0 = D_d_to_u_col(x_pos_start);
+ y0 = D_d_to_u_row(y_pos + ysize / 2);
Symb = S_read("extra/dim_arrow");
if (!Symb)
G_fatal_error(_("Could not read symbol \"%s\""),
@@ -621,8 +614,8 @@
D_symbol(Symb, x0, y0, line_color, fill_color);
G_free(Symb);
- x0 = D_d_to_u_col(x_pos + line_len + 25);
+ x0 = D_d_to_u_col(line_len + x_pos_start);
S_stroke(Symb, symbol_size, 180., 0);
@@ -633,8 +626,8 @@
/* draw simple line between the two ends */
D_begin();
D_stroke();
@@ -648,34 +641,38 @@
- D_pos_abs(x_pos + 25 + line_len / 2.
- - strlen(label) * fontsize * 0.81 / 2, y_pos);
+ D_pos_abs(x_pos + line_len/2 + xspace_around_line +
+ (north_arrow ? xspace_bf_N + xsize_N : 0) - (tr - tl) / 2,
+ y_pos);
D_text(label);
else if (text_posn == TEXT_UNDER) {
- - strlen(label) * fontsize * 0.81 / 2, y_pos + 43);
+ y_pos + 40 * width_scale);
D_text(label);
- y_pos -= 8;
+ y_pos -= 8 * width_scale;
- y_pos += 9;
+ y_pos += 9 * width_scale;
- D_pos_abs(x_pos + 35 + line_len, y_pos + 20);
+ D_pos_abs(x_pos + line_len + 2 * xspace_around_line +
+ (north_arrow ? xspace_bf_N + xsize_N : 0),
+ y_pos + ysize / 2 + (tt - tb) /2);
D_text(label);
- y_pos -= 8;
- y_pos += 9;
if (style == STYLE_CLASSIC_BAR || style == STYLE_THIN_WITH_ENDS)
- x_pos -= 13;
+ x_pos -= 13 * width_scale;
- D_pos_abs(x_pos + 5 - (tr - tl), y_pos + 20);
+ D_pos_abs(x_pos + 5 - (tr - tl), y_pos + ysize / 2 + (tt - tb) /2);
D_text(label);
Modified: grass/trunk/display/d.barscale/main.c
--- grass/trunk/display/d.barscale/main.c 2016-10-01 18:10:29 UTC (rev 69618)
+++ grass/trunk/display/d.barscale/main.c 2016-10-01 19:51:11 UTC (rev 69619)
@@ -12,8 +12,9 @@
* Glynn Clements <glynn gclements.plus.com>,
* Hamish Bowman <hamish_b yahoo.com>,
* Jan-Oliver Wagner <jan intevation.de>
- * Major rewrite for GRASS 7 by Hamish Bowman, June 2013
+ * Major rewrite for GRASS 7 by Hamish Bowman, June 2013
* Adam Laza <ad.laza32 at gmail.com>, GSoC 2016
+ * Anna Petrasova <kratochanna gmail.com>, width_scale added
* PURPOSE: Displays a barscale on graphics monitor
@@ -43,7 +44,8 @@
struct GModule *module;
struct Option *bg_color_opt, *fg_color_opt, *coords, *fsize, *barstyle,
- *text_placement, *length_opt, *segm_opt, *units_opt, *label_opt;
+ *text_placement, *length_opt, *segm_opt, *units_opt, *label_opt,
+ *width_scale_opt;
struct Flag *feet, *no_text, *n_symbol;
struct Cell_head W;
double east, north;
@@ -52,6 +54,7 @@
double length;
int segm;
char *label;
+ double width_scale;
/* Initialize the GIS calls */
G_gisinit(argv[0]);
@@ -161,6 +164,14 @@
text_placement->options = "under,over,left,right";
text_placement->answer = "right";
text_placement->guisection = _("Text");
+ width_scale_opt = G_define_option();
+ width_scale_opt->key = "width_scale";
+ width_scale_opt->type = TYPE_DOUBLE;
+ width_scale_opt->required = NO;
+ width_scale_opt->answer = "1";
+ width_scale_opt->options = "0.5-100";
+ width_scale_opt->description = _("Scale factor to change bar width");
fsize = G_define_option();
fsize->key = "fontsize";
@@ -293,6 +304,8 @@
if (no_text->answer)
fontsize = -1;
+ width_scale = atof(width_scale_opt->answer);
/* Parse and select foreground color */
fg_color = D_parse_color(fg_color_opt->answer, 0);
@@ -306,7 +319,7 @@
D_setup(0);
- draw_scale(east, north, length, segm, units, label, bar_style, text_position, fontsize);
+ draw_scale(east, north, length, segm, units, label, bar_style, text_position, width_scale, fontsize);
D_save_command(G_recreate_command());
D_close_driver();
Modified: grass/trunk/display/d.barscale/options.h
--- grass/trunk/display/d.barscale/options.h 2016-10-01 18:10:29 UTC (rev 69618)
+++ grass/trunk/display/d.barscale/options.h 2016-10-01 19:51:11 UTC (rev 69619)
@@ -28,4 +28,4 @@
extern int north_arrow;
/* draw_scale.c */
-int draw_scale(double, double, int, int, int, char *, int, int, double);
+int draw_scale(double, double, int, int, int, char *, int, int, double, double);
