[GRASS-SVN] r69621 - grass/trunk/display/d.linegraph
svn_grass at osgeo.org
Sat Oct 1 13:59:34 PDT 2016
Author: wenzeslaus
Date: 2016-10-01 13:59:33 -0700 (Sat, 01 Oct 2016)
New Revision: 69621
grass/trunk/display/d.linegraph/Makefile
grass/trunk/display/d.linegraph/main.c
d.linegraph: support color table for individual variables
Modified: grass/trunk/display/d.linegraph/Makefile
--- grass/trunk/display/d.linegraph/Makefile 2016-10-01 20:48:55 UTC (rev 69620)
+++ grass/trunk/display/d.linegraph/Makefile 2016-10-01 20:59:33 UTC (rev 69621)
@@ -2,8 +2,8 @@
PGM = d.linegraph
-LIBES = $(DISPLAYLIB) $(GISLIB)
-DEPENDENCIES = $(DISPLAYDEP) $(GISDEP)
+LIBES = $(DISPLAYLIB) $(GISLIB) $(RASTERLIB)
+DEPENDENCIES = $(DISPLAYDEP) $(GISDEP) $(RASTERDEP)
include $(MODULE_TOPDIR)/include/Make/Module.make
Modified: grass/trunk/display/d.linegraph/main.c
--- grass/trunk/display/d.linegraph/main.c 2016-10-01 20:48:55 UTC (rev 69620)
+++ grass/trunk/display/d.linegraph/main.c 2016-10-01 20:59:33 UTC (rev 69621)
@@ -86,6 +86,7 @@
int num_pnts; /* number of lines in file */
int color; /* color to use for y lines */
+ int r, g, b;
float max; /* maximum value in file */
float min; /* minimum value in file */
float value; /* current value read in */
@@ -112,6 +113,7 @@
struct Option *dir_opt, *x_opt, *y_opt;
struct Option *y_color_opt;
+ struct Option *color_table_opt;
struct Option *title[3];
struct Option *t_color_opt;
struct Option *y_min, *y_max;
@@ -156,6 +158,10 @@
y_color_opt->gisprompt = "old_color,color,color";
y_color_opt->answers = NULL;
+ color_table_opt = G_define_standard_option(G_OPT_M_COLR);
+ color_table_opt->key = "color_table";
+ color_table_opt->guisection = _("Define");
t_color_opt = G_define_option();
t_color_opt->key = "title_color";
t_color_opt->description = _("Color for axis, tics, numbers, and title");
@@ -271,6 +277,29 @@
G_fatal_error(_("Only <%d> colors given for <%d> lines"), j,
num_y_files);
+ else if (color_table_opt->answer) {
+ struct Colors colors;
+ Rast_init_colors(&colors);
+ Rast_make_colors(&colors, color_table_opt->answer, 1, num_y_files);
+ int* values = G_malloc(sizeof(int));
+ unsigned char* r = G_malloc(sizeof(unsigned char));
+ unsigned char* g = G_malloc(sizeof(unsigned char));
+ unsigned char* b = G_malloc(sizeof(unsigned char));
+ unsigned char* set = G_malloc(sizeof(unsigned char));
+ for (i = 0; i < num_y_files; i++)
+ values[i] = i + 1;
+ Rast_lookup_c_colors(values, r, g, b, set, num_y_files, &colors);
+ for (i = 0; i < num_y_files; i++) {
+ /* the in list is indexed from 1 */
+ in[i + 1].r = r[i];
+ in[i + 1].g = g[i];
+ in[i + 1].b = b[i];
+ G_free(r);
+ G_free(g);
+ G_free(b);
+ G_free(set);
else
/* no colors given on command line, use default list */
@@ -417,7 +446,10 @@
/* draw increment of each Y file's data */
- D_use_color(in[i].color);
+ if (color_table_opt->answer)
+ D_RGB_color(in[i].r, in[i].g, in[i].b);
+ else
+ D_use_color(in[i].color);
/* find out position of where Y should be drawn. */
/* if our minimum value of y is not negative, this is easy */
