[GRASS-SVN] r69622 - grass/trunk/display/d.linegraph
svn_grass at osgeo.org
Sat Oct 1 14:01:59 PDT 2016
Author: wenzeslaus
Date: 2016-10-01 14:01:59 -0700 (Sat, 01 Oct 2016)
New Revision: 69622
grass/trunk/display/d.linegraph/d.linegraph.html
d.linegraph: example with two variables
Modified: grass/trunk/display/d.linegraph/d.linegraph.html
--- grass/trunk/display/d.linegraph/d.linegraph.html 2016-10-01 20:59:33 UTC (rev 69621)
+++ grass/trunk/display/d.linegraph/d.linegraph.html 2016-10-01 21:01:59 UTC (rev 69622)
@@ -75,6 +75,52 @@
(You can make GNUplot output pretty by using its SVG or PostScript output
driver and converting that back into a rasterized image in a paint program)
+<h2>EXAMPLE</h2>
+The following can be executed in Bash to create the input data for this
+example. The user can just create these files in a text editor, save
+them and specify path to them.
+<div class="code"><pre>
+cat > x.txt <<EOF
+1
+3
+4
+6
+9
+EOF
+cat > y1.txt <<EOF
+50
+58
+65
+34
+27
+EOF
+cat > y2.txt <<EOF
+10
+20
+35
+50
+45
+EOF
+</pre></div>
+export GRASS_FONT=sans # fixes bad default font
+d.mon start=cairo output=plot.png width=400 height=400 --o
+d.erase # previous image is not cleaned
+The series of commands creates a file <tt>plot.png</tt> in the current
+directory which is the drawing make by <em>d.linegraph</em>.
+d.linegraph x_file=x.txt y_file=y1.txt,y2.txt
+d.mon stop=cairo
+</pre></div>
<h2>SEE ALSO</h2>
<em>
<a href="d.frame.html">d.frame</a>,
