[GRASS-SVN] r69670 - grass/trunk/display/d.linegraph
Mon Oct 3 17:25:50 PDT 2016
Author: wenzeslaus
Date: 2016-10-03 17:25:50 -0700 (Mon, 03 Oct 2016)
New Revision: 69670
   grass/trunk/display/d.linegraph/main.c
d.linegraph: merge y min max options from r69614 to range to follow d.legend and others
Modified: grass/trunk/display/d.linegraph/main.c
--- grass/trunk/display/d.linegraph/main.c	2016-10-03 23:50:16 UTC (rev 69669)
+++ grass/trunk/display/d.linegraph/main.c	2016-10-04 00:25:50 UTC (rev 69670)
@@ -7,6 +7,8 @@
  *               Roberto Flor <flor itc.it>, Bernhard Reiter <bernhard intevation.de>,
  *               Huidae Cho <grass4u gmail.com>, Glynn Clements <glynn gclements.plus.com>,
  *               Hamish Bowman <hamish_b yahoo.com>
+ *               Vaclav Petras <wenzeslaus gmail com> (various features)
  * PURPOSE:
  * COPYRIGHT:    (C) 1999-2016 by the GRASS Development Team
@@ -118,7 +120,7 @@
     struct Option *line_width_opt;
     struct Option *title[3];
     struct Option *t_color_opt;
-    struct Option *y_min, *y_max;
+    struct Option *y_range_opt;
     /* Initialize the GIS calls */
     G_gisinit(argv[0]);
@@ -202,18 +204,13 @@
     title[2]->required = NO;
     title[2]->answer = "";
-    y_min = G_define_option();
-    y_min->key = "y_min";
-    y_min->description = _("Minimum value for Y axis");
-    y_min->type = TYPE_DOUBLE;
-    y_min->required = NO;
+    y_range_opt = G_define_option();
+    y_range_opt->key = "y_range";
+    y_range_opt->description = _("Minimum and maximun value for Y axis (min,max)");
+    y_range_opt->type = TYPE_DOUBLE;
+    y_range_opt->key_desc = "min,max";
+    y_range_opt->required = NO;
-    y_max = G_define_option();
-    y_max->key = "y_max";
-    y_max->description = _("Maximum value for Y axis");
-    y_max->type = TYPE_DOUBLE;
-    y_max->required = NO;
     if (G_parser(argc, argv))
 	exit(EXIT_FAILURE);
@@ -410,11 +407,20 @@
-    if (y_min->answer)
-        min_y = atof(y_min->answer);
-    if (y_max->answer)
-        max_y = atof(y_max->answer);
+    /* parse and set y min max */
+    if (y_range_opt->answer != NULL) {
+        /* all checks should be done by the parser */
+        sscanf(y_range_opt->answers[0], "%f", &min_y);
+        sscanf(y_range_opt->answers[1], "%f", &max_y);
+        if (min_y > max_y) {
+            /* swap values to tolerate some errors */
+            double d_tmp = max_y;
+            max_y = min_y;
+            min_y = d_tmp;
     /* close all files */
     for (i = 0; i <= num_y_files; i++)
