[GRASS-SVN] r69671 - grass-addons/grass7/raster/r.randomforest
svn_grass at osgeo.org
Mon Oct 3 22:01:52 PDT 2016
Author: spawley
Date: 2016-10-03 22:01:52 -0700 (Mon, 03 Oct 2016)
New Revision: 69671
grass-addons/grass7/raster/r.randomforest/r.randomforest.html
grass-addons/grass7/raster/r.randomforest/r.randomforest.py
Enhanced accuracy metrics
Modified: grass-addons/grass7/raster/r.randomforest/r.randomforest.html
--- grass-addons/grass7/raster/r.randomforest/r.randomforest.html 2016-10-04 00:25:50 UTC (rev 69670)
+++ grass-addons/grass7/raster/r.randomforest/r.randomforest.html 2016-10-04 05:01:52 UTC (rev 69671)
@@ -16,6 +16,8 @@
<br><br>The tree-based classifiers include a measure of variable importance based on the Gini impurity criterion, which measures how each variable contributes to the homogeneity of the nodes, with important variables causing a larger decrease in the Gini coefficient in successive node splits. This variable importance allows the contributions of the individual predictors to be determined. The feature importance scores are displayed in the command output.
+<br><br>Cross validation can be performed by setting the <i>cv</i> parameters to > 1. Cross-validation is performed using stratified kfolds, and multiple global and per-class accuracy measures are produced, consisting of accuracy, kappa, precision, recall, f1 measure, and if the response variable is binary (0,1), area under the receiver operating curve (auc). Note in a multiclass classification, the global precision, recall and f1 measures represent a weighted average of the per-class metrics (weighted by number of samples per class). Also note that this cross-validation is performed on a pixel basis. If there is a strong autocorrelation between pixels (i.e. the pixels represent polygons) then the training/test splits will not represent independent samples and will overestimate the accuracy. In this case you should train/split manually and use <i>i.kappa</i>.
<br><br>Most machine learning algorithms do not perform well in the case of a large class imbalance. In this case, the classifier will seek to reduce the overall model error, but this will occur by predicting the majority class with a very high accuracy, but at the expense of the minority class. If you have a highly imbalanced dataset, the 'balanced' <i>b</i> flag can be set. The scikit-learn implementation balanced mode then automatically adjust weights inversely proportional to class frequencies. This only applies to the LogisticRegression, DecisionTree, RandomForest, and GradientBoostingClassifiers.
<br><br>The module also offers the ability to save and load a classification or regression model. The model is saved as a list of filenames (starting with the extension .pkl which is added automatically) for each numpy array. This list can involve a large number of files, so it makes sense to save each model in a separate directory. To load the model, you need to select the .pkl file that was saved. Saving and loading a model represents a useful feature because it allows a model to be built on one imagery group (ie. set of predictor variables), and then the prediction can be performed on other imagery groups. This approach is commonly employed in species prediction modelling, or landslide susceptibility modelling, where a classification or regression model is built with one set of predictors (e.g. which include present-day climatic variables) and then predictions can be performed on other imagery groups containing forecasted climatic variables.
Modified: grass-addons/grass7/raster/r.randomforest/r.randomforest.py
--- grass-addons/grass7/raster/r.randomforest/r.randomforest.py 2016-10-04 00:25:50 UTC (rev 69670)
+++ grass-addons/grass7/raster/r.randomforest/r.randomforest.py 2016-10-04 05:01:52 UTC (rev 69671)
@@ -559,6 +559,69 @@
return(X, y)
+def cross_val_classification(clf, X, y, cv, rstate):
+ # custom function to calculate classification metrics
+ # eliminated need to calculate each metric separately using cross_val_score function
+ # returns: a 1D list of accuracy, kappa and auc scores
+ # returns: mean precision/recall and std precision/recall per class
+ from sklearn import cross_validation, metrics
+ class_list = np.unique(y)
+ nclasses = len(np.unique(y))
+ # Store performance measures per class
+ byclass_metrics = {
+ 'precision': np.zeros((nclasses, cv)),
+ 'recall': np.zeros((nclasses, cv)),
+ 'f1': np.zeros((nclasses, cv))
+ # generate Kfold indices
+ k_fold = cross_validation.StratifiedKFold(y, n_folds=cv, shuffle=False, random_state=rstate)
+ # dictionary of lists to store metrics
+ cmstats = {
+ 'accuracy': [],
+ 'precision': [],
+ 'recall': [],
+ 'f1': [],
+ 'kappa': [],
+ 'auc': []
+ # loop through each fold
+ fold=0
+ for train_indices, test_indices in k_fold:
+ X_train, X_test = X[train_indices], X[test_indices]
+ y_train, y_test = y[train_indices], y[test_indices]
+ # fit the model on the training data and predict the test data
+ fit = clf.fit(X_train, y_train)
+ y_pred = fit.predict(X_test)
+ # calculate metrics
+ cmstats['accuracy'] = np.append(cmstats['accuracy'], metrics.accuracy_score(y_test, y_pred))
+ cmstats['precision'] = np.append(cmstats['precision'], metrics.precision_score(y_test, y_pred, average='weighted'))
+ cmstats['recall'] = np.append(cmstats['recall'], metrics.recall_score(y_test, y_pred, average='weighted'))
+ cmstats['f1'] = np.append(cmstats['f1'], metrics.f1_score(y_test, y_pred, average='weighted'))
+ cmstats['kappa'] = np.append(cmstats['kappa'], metrics.cohen_kappa_score(y_test, y_pred))
+ # test for if binary and classes equal 0,1
+ if len(np.unique(y)) == 2 and all ([0,1] == np.unique(y)):
+ y_pred_proba = fit.predict_proba(X_test)[:,1]
+ cmstats['auc'] = np.append(cmstats['auc'], metrics.roc_auc_score(y_test, y_pred_proba))
+ # Get performance measures by class
+ for cindex in range(nclasses):
+ byclass_metrics['recall'][cindex, fold] = metrics.recall_score(y_test, y_pred, labels = [class_list[cindex]], pos_label=class_list[cindex])
+ byclass_metrics['precision'][cindex, fold] = metrics.precision_score(y_test, y_pred, labels = [class_list[cindex]], pos_label=class_list[cindex])
+ byclass_metrics['f1'][cindex, fold] = metrics.f1_score(y_test, y_pred, labels = [class_list[cindex]], pos_label=class_list[cindex])
+ fold+=1
+ return(cmstats, byclass_metrics)
def save_training_data(X, y, file):
# append X and y and save to csv
training_data = np.zeros((y.shape[0], X.shape[1]+1))
@@ -831,30 +894,49 @@
if model == 'RandomForestRegressor':
grass.message(_("\r\n"))
grass.message(_('Coefficient of determination R^2: \t %0.3f' %
- (clf.score(X, y))))
+ (clf.score(X=training_data, y=training_labels))))
# If cv > 1 then use cross-validation to generate performance measures
if cv > 1:
- from sklearn.cross_validation import cross_val_score
- from sklearn.metrics import classification_report
from sklearn.cross_validation import cross_val_predict
grass.message(_('\r\n'))
grass.message(_("Cross validation global performance measures......:"))
if mode == 'classification':
- accuracy = cross_val_score(clf, X, y, scoring='accuracy', cv=cv, n_jobs=-1)
- grass.message(_("Accuracy :\t%0.2f\t+/-2SD\t%0.2f" %(accuracy.mean(), accuracy.std() * 2)))
- if len(np.unique(y)) == 2:
- auc = cross_val_score(clf, X, y, cv=cv, scoring='roc_auc', n_jobs=-1)
- grass.message(_("ROC AUC :\t%0.2f\t+/-2SD\t%0.2f" % (auc.mean(), auc.std() * 2)))
+ # get metrics from kfold cross validation
+ cmstats, byclass_stats = cross_val_classification(clf, X, y, cv, randst)
- # calculate scores by class using classification report
- y_pred = cross_val_predict(clf, X, y, cv=cv, n_jobs=-1)
- grass.message(_("\n"))
- grass.message(_("Classification report:"))
- grass.message(_(classification_report(y, y_pred)))
+ grass.message(_("Accuracy :\t%0.2f\t+/-SD\t%0.2f" \
+ %(cmstats['accuracy'].mean(), cmstats['accuracy'].std())))
+ grass.message(_("Kappa :\t%0.2f\t+/-SD\t%0.2f" \
+ % (cmstats['kappa'].mean(), cmstats['kappa'].std())))
+ grass.message(_("Precision weighted average:\t%0.2f\t+/-SD\t%0.2f" \
+ % (cmstats['precision'].mean(), cmstats['precision'].std())))
+ grass.message(_("Recall weighted average :\t%0.2f\t+/-SD\t%0.2f" \
+ % (cmstats['recall'].mean(), cmstats['recall'].std())))
+ grass.message(_("f1 weighted average :\t%0.2f\t+/-SD\t%0.2f" \
+ % (cmstats['f1'].mean(), cmstats['f1'].std())))
+ grass.message(_("ROC AUC :\t%0.2f\t+/-SD\t%0.2f"\
+ % (cmstats['auc'].mean(), cmstats['auc'].std())))
+ # calculate scores by class
+ grass.message(_("\r\n"))
+ grass.message(_("Performance measures by class......:"))
+ grass.message(_("Cla\tRecall\t2SD \tPrecision\t2SD\tf1 \tSD"))
+ byclass_scores = ['recall', 'precision', 'f1']
+ for i in range(nclasses):
+ row = str(int(class_list[i])) + '\t'
+ for method in byclass_scores:
+ row += ('%.2f' % byclass_stats[method][i, :].mean() ) +\
+ '\t' + ('%.2f' % byclass_stats[method][i, :].std() ) + '\t'
+ grass.message(_(row))
else:
r2 = cross_val_score(clf, X, y, cv=cv, scoring='r2', n_jobs=-1)
grass.message(_("R2:\t%0.2f\t+/-\t%0.2f" % (r2.mean(), r2.std() * 2)))
