[GRASS-SVN] r69724 - grass/branches/releasebranch_7_0/vector/v.vect.stats
svn_grass at osgeo.org
Tue Oct 25 12:11:13 PDT 2016
Author: mmetz
Date: 2016-10-25 12:11:13 -0700 (Tue, 25 Oct 2016)
New Revision: 69724
grass/branches/releasebranch_7_0/vector/v.vect.stats/main.c
v.vect.stats: fix #3184, also remove the erroneous 'half' parameter (backport from trunk r69722)
Modified: grass/branches/releasebranch_7_0/vector/v.vect.stats/main.c
--- grass/branches/releasebranch_7_0/vector/v.vect.stats/main.c 2016-10-25 19:11:01 UTC (rev 69723)
+++ grass/branches/releasebranch_7_0/vector/v.vect.stats/main.c 2016-10-25 19:11:13 UTC (rev 69724)
@@ -29,7 +29,7 @@
struct menu
stat_func *method; /* routine to compute new value */
- int half; /* whether to add 0.5 to result */
+ int is_int; /* whether the result is an integer (unused) */
char *name; /* method name */
char *text; /* menu display - full description */
@@ -37,18 +37,18 @@
/* modify this table to add new methods */
static struct menu menu[] = {
{c_sum, 0, "sum", "sum of values"},
- {c_ave, 1, "average", "average value"},
+ {c_ave, 0, "average", "average value"},
{c_median, 0, "median", "median value"},
{c_mode, 0, "mode", "most frequently occurring value"},
{c_min, 0, "minimum", "lowest value"},
- {c_minx, 0, "min_cat", "category number of lowest value"},
+ {c_minx, 1, "min_cat", "category number of lowest value"},
{c_max, 0, "maximum", "highest value"},
- {c_maxx, 0, "max_cat", "category number of highest value"},
+ {c_maxx, 1, "max_cat", "category number of highest value"},
{c_range, 0, "range", "range of values"},
- {c_stddev, 1, "stddev", "standard deviation"},
- {c_var, 1, "variance", "statistical variance"},
- {c_divr, 0, "diversity", "number of different values"},
- {0, 0, 0, 0}
+ {c_stddev, 0, "stddev", "standard deviation"},
+ {c_var, 0, "variance", "statistical variance"},
+ {c_divr, 1, "diversity", "number of different values"},
+ {NULL, 0, NULL, NULL}
/* Structure to store info for each area category */
@@ -68,18 +68,14 @@
AREA_CAT *p1 = (AREA_CAT *) pa;
AREA_CAT *p2 = (AREA_CAT *) pb;
- if (p1->area_cat < p2->area_cat)
- return -1;
- if (p1->area_cat > p2->area_cat)
- return 1;
- return 0;
+ return (p1->area_cat - p2->area_cat);
int main(int argc, char *argv[])
char *p;
int i, j, k;
- int method, half, use_catno;
+ int method, use_catno;
const char *mapset;
struct GModule *module;
struct Option *point_opt, /* point vector */
@@ -258,7 +254,6 @@
method = -1;
use_catno = 0;
- half = 0;
if (method_opt->answer) {
/* get the method */
for (method = 0; (p = menu[method].name); method++)
@@ -287,6 +282,7 @@
/* Open database driver */
db_init_string(&stmt);
Adriver = NULL;
+ AFi = NULL;
if (!print_flag->answer) {
@@ -358,8 +354,6 @@
- else
- AFi = NULL;
Pdriver = NULL;
@@ -400,11 +394,7 @@
ctype =
db_column_Ctype(Pdriver, PFi->table, point_column_opt->answer);
- if (ctype == DB_C_TYPE_INT)
- half = menu[method].half;
- else if (ctype == DB_C_TYPE_DOUBLE)
- half = 0;
- else
+ if (ctype != DB_C_TYPE_INT && ctype != DB_C_TYPE_DOUBLE)
G_fatal_error(_("column for points vector must be numeric"));
db_CatValArray_init(&cvarr);
@@ -443,6 +433,8 @@
Area_cat[nacats].count = 0;
Area_cat[nacats].nvalues = 0;
Area_cat[nacats].nalloc = 0;
+ Area_cat[nacats].values = NULL;
+ Area_cat[nacats].cats = NULL;
nacats++;
if (nacats >= nacatsalloc) {
nacatsalloc += 100;
@@ -458,18 +450,22 @@
G_debug(1, "%d cats loaded from vector (including duplicates)", nacats);
+ if (nacats == 0)
+ G_fatal_error(_("No area categories in vector <%s>, layer <%s>"),
+ area_opt->answer, area_field_opt->answer);
/* Sort by category */
qsort((void *)Area_cat, nacats, sizeof(AREA_CAT), cmp_area);
/* remove duplicate categories */
+ j = 1;
for (i = 1; i < nacats; i++) {
- if (Area_cat[i].area_cat == Area_cat[i - 1].area_cat) {
- for (j = i; j < nacats - 1; j++) {
- Area_cat[j].area_cat = Area_cat[j + 1].area_cat;
- nacats--;
+ if (Area_cat[i].area_cat != Area_cat[i - 1].area_cat) {
+ Area_cat[j].area_cat = Area_cat[i].area_cat;
+ j++;
+ nacats = j;
G_debug(1, "%d cats loaded from vector (unique)", nacats);
@@ -658,9 +654,7 @@
statsvalue(&result, Area_cat[i].values, Area_cat[i].nvalues,
NULL);
- if (half)
- result += 0.5;
- else if (use_catno)
+ if (use_catno)
result = Area_cat[i].cats[(int)result];
if (print_flag->answer) {
