[GRASS-SVN] r69725 - grass-addons/grass7/vector/v.surf.tps
svn_grass at osgeo.org
Tue Oct 25 12:26:08 PDT 2016
Author: mmetz
Date: 2016-10-25 12:26:08 -0700 (Tue, 25 Oct 2016)
New Revision: 69725
grass-addons/grass7/vector/v.surf.tps/tps.c
v.surf.tps: optimize
Modified: grass-addons/grass7/vector/v.surf.tps/tps.c
--- grass-addons/grass7/vector/v.surf.tps/tps.c 2016-10-25 19:11:13 UTC (rev 69724)
+++ grass-addons/grass7/vector/v.surf.tps/tps.c 2016-10-25 19:26:08 UTC (rev 69725)
@@ -109,7 +109,7 @@
/* TPS */
- for (k = 0; k < n_points; k++) {
+ for (k = 0; k <= i; k++) {
dx = (pnts[i].c -pnts[k].c) * 2.0;
dy = (pnts[i].r -pnts[k].r) * 2.0;
@@ -118,9 +118,17 @@
if (dist2 > 0)
dist = dist2 * log(dist2) * 0.5;
- m[i + 1 + n_vars][k + 1 + n_vars] = m[k + 1 + n_vars][i + 1 + n_vars] = dist;
- if (regularization > 0 && dist2 > 0)
- distsum += sqrt(dist2);
+ m[i + 1 + n_vars][k + 1 + n_vars] = dist;
+ if (regularization > 0 && dist2 > 0) {
+ dist = sqrt(dist2);
+ distsum += dist;
+ if (k != i) {
+ m[k + 1 + n_vars][i + 1 + n_vars] = m[i + 1 + n_vars][k + 1 + n_vars];
+ distsum += dist;
@@ -338,14 +346,14 @@
int local_tps(int out_fd, int *var_fd, int n_vars, int mask_fd,
struct tps_pnt *pnts, int n_points, int min_points,
double regularization, double overlap, double pthin,
- int do_bfs, double segs_mb)
+ int clustered, double segs_mb)
int ridx, cidx, row, col, nrows, ncols;
double **m, *a, *B;
int i, j;
int kdalloc, palloc, n_cur_points;
struct tps_pnt *cur_pnts;
- double dx, dy, dist, dist2, ovlfactor;
+ double dx, dy, dist, dist2, mfactor;
DCELL **dbuf, result, *outbuf, *varbuf;
CELL *maskbuf;
int solved;
@@ -405,11 +413,9 @@
maskbuf = NULL;
- do_bfs = (do_bfs > 0);
/* create and init SEG structs */
varsize = n_vars * sizeof(DCELL);
- segsize = (double)64 * 64 * (sizeof(struct tps_out) + varsize + do_bfs * sizeof(int));
+ segsize = (double)64 * 64 * (sizeof(struct tps_out) + varsize + clustered * sizeof(int));
nsegs = 1024. * 1024. * segs_mb / segsize;
if (Segment_open(&out_seg, G_tempfile(), nrows, ncols, 64, 64,
@@ -432,7 +438,7 @@
- if (do_bfs) {
+ if (clustered) {
G_message("Creating temporary point map...");
if (Segment_open(&p_seg, G_tempfile(), nrows, ncols, 64, 64,
@@ -623,7 +629,7 @@
pfound = kdfound;
- if (do_bfs) {
+ if (clustered) {
/* collect points with breadth-first search
* min dist must be > max dist of nearest neighbors */
@@ -735,32 +741,37 @@
cmax = cur_pnts[i].c;
- /* must be < 0.5 */
- ovlfactor = 0.3;
- irow1 = rmin + (int)((rmax - rmin) * overlap * ovlfactor);
- irow2 = rmax - (int)((rmax - rmin) * overlap * ovlfactor);
- icol1 = cmin + (int)((cmax - cmin) * overlap * ovlfactor);
- icol2 = cmax - (int)((cmax - cmin) * overlap * ovlfactor);
+ /* must be <= 0.5 */
+ mfactor = 0.0;
+ /* min: 0
+ * max: 0.5
+ * 1 - 1 / d: -> 0 for dense spacing
+ * 1 for sparse points
- if (rmin == rminp)
- irow1 = 0;
- if (rmax == rmaxp)
- irow2 = nrows - 1;
- if (cmin == cminp)
- icol1 = 0;
- if (cmax == cmaxp)
- icol2 = ncols - 1;
+ if (clustered) {
+ double mfactoradj;
+ double dmin;
+ double dmax;
- if (irow1 < 0)
- irow1 = 0;
- if (irow2 > nrows - 1)
- if (icol1 < 0)
- icol1 = 0;
- if (icol2 > ncols - 1)
+ dmin = 2.0 * sqrt(2.0 * kdfound / M_PI);
+ dmax = rmax - rmin;
+ if (dmax < cmax - cmin)
+ dmax = cmax - cmin;
+ mfactoradj = 0.0;
+ if (dmax > dmin) {
+ mfactoradj = pow((1 - dmin / dmax), 2.0) * 0.5;
+ G_debug(1, "adjusted mfactor: %g", mfactoradj);
+ mfactor = mfactoradj;
+ irow1 = rmin + (int)((rmax - rmin) * mfactor);
+ irow2 = rmax - (int)((rmax - rmin) * mfactor);
+ icol1 = cmin + (int)((cmax - cmin) * mfactor);
+ icol2 = cmax - (int)((cmax - cmin) * mfactor);
if (irow1 > row) {
irow2 -= irow1 - row;
irow1 = row;
@@ -778,6 +789,15 @@
icol2 = col;
+ if (rmin == rminp)
+ irow1 = 0;
+ if (rmax == rmaxp)
+ irow2 = nrows - 1;
+ if (cmin == cminp)
+ icol1 = 0;
+ if (cmax == cmaxp)
+ icol2 = ncols - 1;
if (irow1 < 0)
irow1 = 0;
@@ -787,9 +807,6 @@
icol2 = ncols - 1;
- dx = icol2 - icol1;
- dy = irow2 - irow1;
dxi = icol2 - icol1 + 1;
dyi = irow2 - irow1 + 1;
@@ -867,7 +884,7 @@
if (n_vars)
Segment_close(&var_seg);
- if (do_bfs)
+ if (clustered)
Segment_close(&p_seg);
outbuf = Rast_allocate_d_buf();
