[GRASS-SVN] r69726 - grass-addons/grass7/raster/r.hants
svn_grass at osgeo.org
Tue Oct 25 12:27:03 PDT 2016
Author: mmetz
Date: 2016-10-25 12:27:02 -0700 (Tue, 25 Oct 2016)
New Revision: 69726
grass-addons/grass7/raster/r.hants/main.c
r.hants: optimize
Modified: grass-addons/grass7/raster/r.hants/main.c
--- grass-addons/grass7/raster/r.hants/main.c 2016-10-25 19:26:08 UTC (rev 69725)
+++ grass-addons/grass7/raster/r.hants/main.c 2016-10-25 19:27:02 UTC (rev 69726)
@@ -45,7 +45,7 @@
static int solvemat(double **m, double a[], double B[], int n)
int i, j, i2, j2, imark;
- double factor, temp;
+ double factor, temp, *tempp;
double pivot; /* ACTUAL VALUE OF THE LARGEST PIVOT CANDIDATE */
for (i = 0; i < n; i++) {
@@ -75,12 +75,18 @@
/* if row with highest pivot is not the current row, switch them */
if (imark != i) {
for (j2 = 0; j2 < n; j2++) {
temp = m[imark][j2];
m[imark][j2] = m[i][j2];
m[i][j2] = temp;
+ tempp = m[imark];
+ m[imark] = m[i];
+ m[i] = tempp;
temp = a[imark];
a[imark] = a[i];
a[i] = temp;
@@ -144,7 +150,7 @@
int row, col;
double lo, hi, fet, *cs, *sn, *ts, delta;
int bl;
- double **mat, **mat_t, **A, *Azero, *za, *zr, maxerrlo, maxerrhi;
+ double **mat, **mat_t, **A, *Av, *Azero, *za, *zr, maxerrlo, maxerrhi;
int asize;
int dod, nf, nr, nout, noutmax;
int rejlo, rejhi, *useval;
@@ -467,6 +473,7 @@
mat = G_alloc_matrix(nr, num_inputs);
mat_t = G_alloc_matrix(num_inputs, nr);
A = G_alloc_matrix(nr, nr);
+ Av = *A;
Azero = G_alloc_vector(nr * nr);
asize = nr * nr * sizeof(double);
za = G_alloc_vector(nr);
@@ -566,7 +573,7 @@
* A temp: nr, num_inputs
* A: nr, nr */
- memcpy(*A, Azero, asize);
+ memcpy(Av, Azero, asize);
for (i = 0; i < nr; i++) {
za[i] = 0;
for (j = 0; j < num_inputs; j++) {
@@ -604,7 +611,6 @@
maxerrlo = rc[i] - values[i];
if (maxerrhi < values[i] - rc[i])
maxerrhi = values[i] - rc[i];
if (rejlo || rejhi) {
@@ -613,21 +619,21 @@
done = 0;
if (rejhi && maxerrhi > fet)
done = 0;
- if (!done && (rejlo || rejhi)) {
- /* filter outliers */
- for (i = 0; i < num_inputs; i++) {
+ if (!done) {
+ /* filter outliers */
+ for (i = 0; i < num_inputs; i++) {
- if (useval[i]) {
- if (rejlo && rc[i] - values[i] > maxerrlo * 0.5) {
- useval[i] = 0;
- nout++;
+ if (useval[i]) {
+ if (rejlo && rc[i] - values[i] > maxerrlo * 0.5) {
+ useval[i] = 0;
+ nout++;
+ if (rejhi && values[i] - rc[i] > maxerrhi * 0.5) {
+ useval[i] = 0;
+ nout++;
- if (rejhi && values[i] - rc[i] > maxerrhi * 0.5) {
- useval[i] = 0;
- nout++;
@@ -641,8 +647,12 @@
for (i = 0; i < num_outputs; i++) {
struct output *out = &outputs[i];
out->buf[col] = rc[i];
+ if (rc[i] < lo)
+ out->buf[col] = lo;
+ else if (rc[i] > hi)
+ out->buf[col] = hi;
if (do_amp || do_phase) {
